PROCESSOR-SDK-J722S: ENTRY SDK9.2
Part Number: PROCESSOR-SDK-J722S
Hi Team,
     We  used entry j722S2 sdk9.2 to boot mcu2_0 successed , but when we opened mcu1_0 definition and generated mcu1_0.out , boot failed. log as follows
U-Boot 2023.04 (Apr 14 2024 - 19:44:10 +0800)
SoC:   J722S SR1.0 HS-FS
Model: Texas Instruments J722S EVM
Reading on-board EEPROM at 0x51 failed -121
Board: J722SX-EVM rev E1
DRAM:  2 GiB (effective 8 GiB)
Core:  70 devices, 27 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:
Warning: ethernet@8000000port@1 (eth0) using random MAC address - 7a:50:21:0b:88:20
eth0: ethernet@8000000port@1
Hit any key to stop autoboot:  0
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@23: Error reading output register
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
1011 bytes read in 31 ms (31.3 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
## Error: "main_cpsw0_qsgmii_phyinit" not defined
187492 bytes read in 42 ms (4.3 MiB/s)
Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices
ti_sci system-controller@44043000: Message not acknowledgedti-sci processor set_config failed: -19
Load Remote Processor 0 with data@addr=0x82000000 187492 bytes: Failed!
887712 bytes read in 70 ms (12.1 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 887712 bytes: Success!
11722864 bytes read in 519 ms (21.5 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 11722864 bytes: Success!
Load Remote Processor 4 with data@addr=0x82000000 11722864 bytes: Success!
19376640 bytes read in 833 ms (22.2 MiB/s)
68937 bytes read in 35 ms (1.9 MiB/s)
Working FDT set to 88000000
7279 bytes read in 33 ms (214.8 KiB/s)
ERROR: reserving fdt memory region failed (addr=880000000 size=20000000 flags=4)
   Loading Device Tree to 000000008feec000, end 000000008fffffff ... OK
Working FDT set to 8feec000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.80 (lixm@linm) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Sun Apr 14 18:57:18 CST 2024
[    0.000000] Machine model: Texas Instruments J722S EVM
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ad000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@ad000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ad100000, size 63 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@ad100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b1100000, size 63 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory1b1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b5000000, size 40 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@b5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 896 MiB
[    0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a3ffffff]
[    0.000000]   node   0: [mem 0x00000000a4000000-0x00000000a4ffffff]
[    0.000000]   node   0: [mem 0x00000000a5000000-0x00000000b77fffff]
[    0.000000]   node   0: [mem 0x00000000b7800000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x000000089fffffff]
[    0.000000]   node   0: [mem 0x00000008a0000000-0x00000009ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2064384
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=1e626e45-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 5784388K/8388608K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 1686716K reserved, 917504K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008a0040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a0050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008541] Console: colour dummy device 80x25
[    0.013128] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023798] pid_max: default: 32768 minimum: 301
[    0.028557] LSM: Security Framework initializing
[    0.033392] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.041152] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.050859] cblist_init_generic: Setting adjustable number of callback queues.
[    0.058283] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.064566] cblist_init_generic: Setting adjustable number of callback queues.
[    0.071951] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.078312] rcu: Hierarchical SRCU implementation.
[    0.083213] rcu:     Max phase no-delay instances is 1000.
[    0.088773] Platform MSI: msi-controller@1820000 domain created
[    0.095074] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.104515] EFI services will not be available.
[    0.109392] smp: Bringing up secondary CPUs ...
ERROR:   Failed to get response (-19)
ERROR:   Transfer send failed (-19)
ERROR:   Request to start core failed: -19
[    0.125087] psci: failed to boot CPU1 (-22)
[    0.129410] CPU1: failed to boot: -22
[    0.144238] psci: failed to boot CPU2 (-22)
[    0.148576] CPU2: failed to boot: -22
[    0.163352] psci: failed to boot CPU3 (-22)
[    0.167691] CPU3: failed to boot: -22
[    0.171466] smp: Brought up 1 node, 1 CPU
[    0.175571] SMP: Total of 1 processors activated.
[    0.180387] CPU features: detected: 32-bit EL0 Support
[    0.185639] CPU features: detected: CRC32 instructions
[    0.190941] CPU: All CPU(s) started at EL2
[    0.195121] alternatives: applying system-wide alternatives
[    0.202300] devtmpfs: initialized
[    0.216072] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.226088] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.260007] pinctrl core: initialized pinctrl subsystem
[    0.265955] DMI not present or invalid.
[    0.270437] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.277370] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.284817] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.292942] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.301191] audit: initializing netlink subsys (disabled)
[    0.307242] thermal_sys: Registered thermal governor 'step_wise'
[    0.307251] thermal_sys: Registered thermal governor 'power_allocator'
[    0.313403] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
[    0.328012] cpuidle: using governor menu
[    0.332171] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.339144] ASID allocator initialised with 65536 entries
[    0.357716] KASLR disabled due to lack of seed
[    0.368457] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.375459] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.381931] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.388865] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.395264] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.402195] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.408594] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.415525] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.423187] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected
[    0.433313] iommu: Default domain type: Translated
[    0.438337] iommu: DMA domain TLB invalidation policy: strict mode
[    0.444984] SCSI subsystem initialized
[    0.449113] usbcore: registered new interface driver usbfs
[    0.454753] usbcore: registered new interface driver hub
[    0.460197] usbcore: registered new device driver usb
[    0.465775] pps_core: LinuxPPS API ver. 1 registered
[    0.470847] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.480187] PTP clock support registered
[    0.484313] EDAC MC: Ver: 3.0.0
[    0.488307] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[    0.495147] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[    0.501942] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[    0.508771] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100
[    0.515764] FPGA manager framework
[    0.519315] Advanced Linux Sound Architecture Driver Initialized.
[    0.526376] clocksource: Switched to clocksource arch_sys_counter
[    0.532867] VFS: Disk quotas dquot_6.6.0
[    0.536915] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.549026] Carveout Heap: Exported 512 MiB at 0x0000000900000000
[    0.555413] NET: Registered PF_INET protocol family
[    0.560809] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.573932] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.582771] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.590699] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.599213] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.608554] TCP: Hash tables configured (established 65536 bind 65536)
[    0.615431] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.622532] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.630217] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.636435] RPC: Registered named UNIX socket transport module.
[    0.642527] RPC: Registered udp transport module.
[    0.647332] RPC: Registered tcp transport module.
[    0.652133] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.658715] NET: Registered PF_XDP protocol family
[    0.663619] PCI: CLS 0 bytes, default 64
[    0.668254] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.678214] Initialise system trusted keyrings
[    0.683005] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.693720] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.700223] NFS: Registering the id_resolver key type
[    0.705436] Key type id_resolver registered
[    0.709709] Key type id_legacy registered
[    0.713853] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.720701] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.763210] Key type asymmetric registered
[    0.767398] Asymmetric key parser 'x509' registered
[    0.772421] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.780120] io scheduler mq-deadline registered
[    0.784759] io scheduler kyber registered
[    0.792264] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.798908] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.810946] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.825546] loop: module loaded
[    0.829956] megasas: 07.719.03.00-rc1
[    0.836601] tun: Universal TUN/TAP device driver, 1.6
[    0.842528] VFIO - User Level meta-driver version: 0.3
[    0.848488] usbcore: registered new interface driver usb-storage
[    0.855200] i2c_dev: i2c /dev entries driver
[    0.860699] sdhci: Secure Digital Host Controller Interface driver
[    0.867077] sdhci: Copyright(c) Pierre Ossman
[    0.871767] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.878192] ledtrig-cpu: registered to indicate activity on CPUs
[    0.884488] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.891412] usbcore: registered new interface driver usbhid
[    0.897105] usbhid: USB HID core driver
[    0.901850] optee: probing for conduit method.
[    0.906427] optee: revision 4.1 (012cdca4)
[    0.906696] optee: dynamic shared memory is enabled
[    0.916085] optee: initialized driver
[    0.921599] Initializing XFRM netlink socket
[    0.926069] NET: Registered PF_PACKET protocol family
[    0.931314] Key type dns_resolver registered
[    0.936023] registered taskstats version 1
[    0.940234] Loading compiled-in X.509 certificates
[    0.953406] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--w2023.01-j722s (Kool Koa')
[    0.975588] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=36, clk=2, ret=-19
[    0.986181] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=36, clk=3, ret=-19
[    0.996767] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=37, clk=2, ret=-19
[    1.007333] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=37, clk=3, ret=-19
[    1.017913] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=38, clk=2, ret=-19
[    1.028514] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=38, clk=3, ret=-19
[    1.039094] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=39, clk=2, ret=-19
[    1.049664] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=39, clk=3, ret=-19
[    1.060244] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=40, clk=2, ret=-19
[    1.070808] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=40, clk=3, ret=-19
[    1.081390] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=41, clk=2, ret=-19
[    1.091958] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=41, clk=3, ret=-19
[    1.102540] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=42, clk=2, ret=-19
[    1.113103] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=42, clk=3, ret=-19
[    1.123664] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=43, clk=2, ret=-19
[    1.134245] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=43, clk=3, ret=-19
[    1.147611] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=125, clk=0, ret=-19
[    1.158282] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=125, clk=2, ret=-19
[    1.168955] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=126, clk=0, ret=-19
[    1.179608] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=126, clk=2, ret=-19
[    1.190280] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=127, clk=0, ret=-19
[    1.200934] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=127, clk=2, ret=-19
[    1.211624] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=128, clk=0, ret=-19
[    1.222284] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=128, clk=2, ret=-19
[    1.232954] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=130, clk=0, ret=-19
[    1.243611] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=130, clk=2, ret=-19
[    1.254267] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=135, clk=0, ret=-19
[    1.264937] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=136, clk=0, ret=-19
[    1.275595] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=137, clk=0, ret=-19
[    1.286266] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=138, clk=0, ret=-19
[    1.297342] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=161, clk=3, ret=-19
[    1.308000] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=182, clk=0, ret=-19
[    1.318674] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=182, clk=3, ret=-19
[    1.329329] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=182, clk=4, ret=-19
[    1.340010] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=201, clk=0, ret=-19
[    1.350843] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=247, clk=0, ret=-19
[    1.361499] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=247, clk=3, ret=-19
[    1.372172] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=247, clk=4, ret=-19
[    1.382825] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=248, clk=0, ret=-19
[    1.393496] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=248, clk=3, ret=-19
[    1.404151] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=248, clk=4, ret=-19
[    1.414822] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=249, clk=0, ret=-19
[    1.425482] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=249, clk=3, ret=-19
[    1.436154] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=249, clk=4, ret=-19
[    1.446905] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=278, clk=1, ret=-19
[    1.457562] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=278, clk=3, ret=-19
[    1.468227] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=278, clk=4, ret=-19
[    1.478916] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=279, clk=0, ret=-19
[    1.489574] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=279, clk=1, ret=-19
[    1.500246] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=279, clk=5, ret=-19
[    1.510903] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=280, clk=0, ret=-19
[    1.521571] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=280, clk=1, ret=-19
[    1.532231] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=280, clk=5, ret=-19
[    1.543837] clk: failed to reparent clk:36:2 to clk:36:3: -22
[    1.550002] clk: failed to reparent clk:37:2 to clk:37:3: -22
[    1.556077] clk: failed to reparent clk:38:2 to clk:38:3: -22
[    1.562134] clk: failed to reparent clk:39:2 to clk:39:3: -22
[    1.568187] clk: failed to reparent clk:40:2 to clk:40:3: -22
[    1.574239] clk: failed to reparent clk:41:2 to clk:41:3: -22
[    1.580289] clk: failed to reparent clk:42:2 to clk:42:3: -22
[    1.586341] clk: failed to reparent clk:43:2 to clk:43:3: -22
[    1.593107] omap_i2c 2b200000.i2c: bus 0 rev0.12 at 400 kHz
[    1.599578] omap_i2c 20000000.i2c: bus 1 rev0.12 at 400 kHz
[    1.606202] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    1.612252] ti-sci-intr 4210000.interrupt-controller: Destination irq resource allocation failed
[    1.621234] ti-sci-intr: probe of 4210000.interrupt-controller failed with error -22
[    1.629490] ti-sci-intr bus@f0000:interrupt-controller@a00000: Destination irq resource allocation failed
[    1.639273] ti-sci-intr: probe of bus@f0000:interrupt-controller@a00000 failed with error -22
[    1.648192] ti-sci-inta 48000000.interrupt-controller: VINT resource allocation failed
[    1.656281] ti-sci-inta: probe of 48000000.interrupt-controller failed with error -22
[    1.664913] clk: failed to reparent clk:279:1 to clk:279:5: -22
[    1.671162] clk: failed to reparent clk:280:1 to clk:280:5: -22
[    1.677525] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.683937] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.691067] printk: console [ttyS2] disabled
[    1.695530] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 23, base_baud = 3000000) is a 8250
[    1.704318] printk: console [ttyS2] enabled
[    1.712771] printk: bootconsole [ns16550a0] disabled
[    1.762413] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
[    1.772024] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.780189] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
[    1.793048] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[    1.799343] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.806483] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.812963] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
[    1.823680] cpu cpu0: _of_add_opp_table_v2: no supported OPPs
[    1.829506] cpu cpu0: OPP table can't be empty
[    1.834718] clk: failed to reparent clk:36:2 to clk:36:3: -22
[    2.846531] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[    2.857364] ti-sci 44043000.system-controller: Mbox send fail -110
[    2.863781] clk: failed to reparent clk:37:2 to clk:37:3: -22
[    3.870384] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
[    3.880297] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
[    3.890205] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
[    3.900111] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[    3.910887] ti-sci 44043000.system-controller: Mbox send fail -110
[    3.917065] ti-sci 44043000.system-controller: Mbox send fail -110
[    3.923244] ti-sci 44043000.system-controller: Mbox send fail -110
[    3.929418] ti-sci 44043000.system-controller: Mbox send fail -110
[    3.935796] clk: failed to reparent clk:38:2 to clk:38:3: -22
[    4.958378] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[    4.969153] ti-sci 44043000.system-controller: Mbox send fail -110
[    4.975491] clk: failed to reparent clk:39:2 to clk:39:3: -22
[    5.982377] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[    5.993152] ti-sci 44043000.system-controller: Mbox send fail -110
[    5.999478] clk: failed to reparent clk:40:2 to clk:40:3: -22
[    7.006378] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[    7.017151] ti-sci 44043000.system-controller: Mbox send fail -110
[    7.023476] clk: failed to reparent clk:41:2 to clk:41:3: -22
[    8.030384] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[    8.041158] ti-sci 44043000.system-controller: Mbox send fail -110
[    8.047476] clk: failed to reparent clk:42:2 to clk:42:3: -22
[    9.054385] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[    9.065159] ti-sci 44043000.system-controller: Mbox send fail -110
[    9.071482] clk: failed to reparent clk:43:2 to clk:43:3: -22
[   10.078384] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   10.089157] ti-sci 44043000.system-controller: Mbox send fail -110
[   11.102391] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   11.113165] ti-sci 44043000.system-controller: Mbox send fail -110
[   12.126385] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   12.137160] ti-sci 44043000.system-controller: Mbox send fail -110
[   12.143511] clk: failed to reparent clk:279:1 to clk:279:5: -22
[   13.150384] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   13.161159] ti-sci 44043000.system-controller: Mbox send fail -110
[   13.167483] clk: failed to reparent clk:280:1 to clk:280:5: -22
[   14.174385] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   14.185158] ti-sci 44043000.system-controller: Mbox send fail -110
[   14.191619] ti-udma 485c0100.dma-controller: Number of rings: 82
[   14.197927] ti-udma 485c0000.dma-controller: Number of rings: 150
[   15.230392] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   15.241173] ti-sci 44043000.system-controller: Mbox send fail -110
[   16.254388] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_set_rate+0x48/0x54)
[   16.263866] ti-sci 44043000.system-controller: Mbox send fail -110
[   17.278378] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_recalc_rate+0x48/0xb0)
[   17.288109] ti-sci 44043000.system-controller: Mbox send fail -110
[   17.294281] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=75, clk=7, ret=-110
[   18.334384] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   18.345156] ti-sci 44043000.system-controller: Mbox send fail -110
[   19.358378] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   19.369153] ti-sci 44043000.system-controller: Mbox send fail -110
[   19.375932] clk: failed to reparent clk:36:2 to clk:36:3: -22
[   20.382392] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   20.393169] ti-sci 44043000.system-controller: Mbox send fail -110
[   20.399488] clk: failed to reparent clk:37:2 to clk:37:3: -22
[   21.406386] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   21.417159] ti-sci 44043000.system-controller: Mbox send fail -110
[   21.423478] clk: failed to reparent clk:38:2 to clk:38:3: -22
[   22.430386] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   22.441160] ti-sci 44043000.system-controller: Mbox send fail -110
[   22.447479] clk: failed to reparent clk:39:2 to clk:39:3: -22
[   23.454377] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   23.465151] ti-sci 44043000.system-controller: Mbox send fail -110
[   23.471468] clk: failed to reparent clk:40:2 to clk:40:3: -22
[   24.478385] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
[   24.489159] ti-sci 44043000.system-controller: Mbox send fail -110
[   24.495477] clk: failed to reparent clk:41:2 to clk:41:3: -22
in sdk9.2 , how to change dm file in uboot? We can find board-support/prebuilt-images/ti-dm/j722s/ipc_echo_testb_mcu1_0_release_strip.xer5f . whats the difference between    ipc_echo_testb_mcu1_0_release_strip.xer5f  and vx_app_rtos_linux_mcu1_0.out ?
    Are you able to boot with the default images?
    Is this a custom board or TI EVM?
    This is simple ipc echo test based DM binary.
    This is vision apps based firmware binary.
    Any reason why you want to build own DM binary?
    Keerthy
  • We tried on our custom board  and  we want to do some function on mcu1-0,  so how to do it ?
     Part C is MCU2-0  and B runs ipc_echo_testb_mcu1_0_release_strip.xer5f , A runs vx_app_rtos_linux_mcu1_0.out , right?
    How can we run our own function on A an B?
    Thanks for the details. I will check internally and get back to you early next week.
    - Keerthy
  • We can find board-support/prebuilt-images/ti-dm/j722s/ipc_echo_testb_mcu1_0_release_strip.xer5f . whats the difference between    ipc_echo_testb_mcu1_0_release_strip.xer5f
    have you tried with the default Binary board-support/prebuilt-images/ti-dm/j722s/ipc_echo_testb_mcu1_0_release_strip.xer5f. I believe that is working. Can you confirm?
    The custom changes might be causing issues with IPC. I will loop in our IPC expert. Please share the changes that you have done for custom MCU1_0 app.
    - Keerthy
  • Hi  Keerthy,
          We have no changes for MCU1_0 app,  just open the defination "BUILD_CPU_MCU1_0?=yes  ", and then make uboot , make sdk, the  ipc_echo_testb_mcu1_0_release_strip.xer5f will be updated , in linux sdk do the make install , in the end , make the sd card
          Please help to confirm ipc_echo_testb_mcu1_0_release_strip.xer5f the file is generated from which C file ?
    the log after open mcu1-0, the system is blocked .
    ti_sci system-controller@44043000: ti_sci_get_response: Message receive failed. ret = -110
    ti-sci processor set_config failed: -110
    ti-sci processor release failed: -110
    850848 bytes read in 74 ms (11 MiB/s)
    ti-sci processor request failed: -110
    after remove the link file : /lib/firmware/j722s-mcu-r5f0_0-fw ,  the system can login by root.
    The above is a vision_apps change. If the flag is set to yes, then the mcu1_0 should come from vision_apps.
    So you way of making the SD Card should be similar to how the SD Card is made using vision_apps binaries.
    Also, when the flag is "yes", "make sdk" will automatically call "make u-boot" internally.
    Please refer the u-boot build flow when the flag is set to "yes"
    Here the vision_apps binary "vx_app_rtos_linux_mcu1_0.out" is copied and renamed as "ipc_echo_testb_mcu1_0_release_strip.xer5f" in the highlighted command.
    Then when you do "make linux_fs_install_sd" to copy the vision_apps firmware to the SD Card, it would softlink the "vx_app_rtos_linux_mcu1_0.out" to the mcu1_0 firmware as shown below
    Hence, please follow the vision_apps way of creating the SD Card, if you are using vision_apps firmware (i.e. BUILD_CPU_MCU1_0?=yes)
    Vision Apps User Guide: Run Instructions
    Nikhil
  • Hi Nikhil,
         If using BUILD_CPU_MCU1_0?=yes ,  why the boot process  is blocked ? If using BUILD_CPU_MCU1_0?=no, how to modify ipc_echo_testb_mcu1_0_release_strip?
    Joney
  • Hi Joney,
    May I know your exact usecase?
    Are you running vision_apps based firmware on MCU1_0 (or) are you running ipc_echo_testb on MCU1_0 (or) are you running your own binary on MCU1_0 (which is not a vision_apps binary) ?
    Nikhil
  • Hi Nikhil,
        We want to add some function in vision_apps/platform/j722s/rtos/mcu1_0 , first we use BUILD_CPU_MCU1_0?=yes  and want to check if vx_app_arm_remote_log.out can print MCU1_0 log, but failed on system boot process.
    Joney
  • Hi Joney,
    Please follow the below steps in these case.
    Step 1: Keep BUILD_CPU_MCU1_0?=no and clean build the sdk (i.e. make vision_apps_scrub and then make sdk )
    Step 2: Follow the below steps to create the SD Card, that could run vision_apps usecase
    Step 3: Boot the EVM using this SD Card and ensure that the ./vision_apps_init.sh has logs from the remote cores. (MCU2_0, C7x_1 and C7x_2)
    Step 4: Once this is done, change BUILD_CPU_MCU1_0?=yes and also enable "ENABLE_IPC_MCU1_0" in the file vision_apps/platform/j722s/rtos/common/app_cfg.h and then execute "make sdk". This should automatically build the u-boot as well.
    Step 5: Ensure that there is vx_app_rtos_linux_mcu1_0.out created in the out folder of vision_apps.
    Step 6: Run the command "make linux_fs_install_sd" to copy all the required libs and out files to the SD Card.
    Step 7: Repeat Step 3 and check if you are getting MCU1_0 logs as well now.
    This should resolve your issue.
    Nikhil
  • Hi  Nikhil ,
         I have followed the steps above , but the boot process is blocked too.  So  I remove the mcu1-0 soft link in lib/firmware , system can login and print the mcu1-0 log :
    j722s-evm:/opt# ./vx_app_arm_remote_log.out
    [MCU1_0] 0.032935 s: CIO: Init ... Done !!!
    [MCU1_0] 0.032974 s: CPU is running FreeRTOS
    [MCU1_0] 0.032985 s: APP: Init ... !!!
    [MCU1_0] 0.032995 s: MEM: Init ... !!!
    [MCU1_0] 0.033008 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ b5000000 of size 8388608 bytes !!!
    [MCU1_0] 0.033038 s: MEM: Init ... Done !!!
    [MCU1_0] 0.033048 s: IPC: Init ... !!!
    [MCU1_0] 0.033061 s: IPC: 5 CPUs participating in IPC !!!
    [MCU1_0] 0.033273 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU1_0] 13.002213 s: IPC: HLOS is ready !!!
    [MCU1_0] 13.002308 s: IPC: Init ... Done !!!
    [MCU1_0] 13.002329 s: APP: Syncing with 4 CPUs ... !!!
    [MCU1_0] 13.504491 s: APP: Syncing with 4 CPUs ... Done !!!
    [MCU1_0] 13.504527 s: REMOTE_SERVICE: Init ... !!!
    [MCU1_0] 13.504617 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU1_0] 13.504639 s: APP: Init ... Done !!!
    [MCU1_0] 13.504651 s: APP: Run ... !!!
    [MCU1_0] 13.504661 s: IPC: Starting echo test ...
    [MCU1_0] 13.504763 s: APP: Run ... Done !!!
    [MCU1_0] 13.516556 s: IPC: Echo status: a530-0[.] wkup-r5f0-0[s] main-r5f0-0[P] c75ss0[.] c75ss1[.]
    [MCU1_0] 13.516696 s: IPC: Echo status: a530-0[.] wkup-r5f0-0[s] main-r5f0-0[P] c75ss0[P] c75ss1[.]
    [MCU1_0] 13.516853 s: IPC: Echo status: a530-0[.] wkup-r5f0-0[s] main-r5f0-0[P] c75ss0[P] c75ss1[P]
    [MCU2_0] 5.233405 s: CIO: Init ... Done !!!
    [MCU2_0] 5.233444 s: CPU is running FreeRTOS
    [MCU2_0] 5.233459 s: APP: Init ... !!!
    [MCU2_0] 5.233469 s: SCICLIENT: Init ... !!!
    I have deleted the mcu1-0 soft link , so  which file printed the mcu1-0 log    ?
    Sorry for the delay in response. The thread was closed as you had clicked it resolved.
    May I know why are you deleting the softlink here? The logs are from the firmware "vx_app_rtos_linux_mcu1_0.out"
    And I see that you are getting full logs from MCU1_0 along with IPC echo test passing at the end.
    This means that the MCU1_0 is up with vision_apps firmware.
    Nikhil
  • HI ,
       The printed log is in IPC echo test , which generated with ./board-support/prebuilt-images/ti-dm/j722s/ipc_echo_testb_mcu1_0_release_strip.xer5f , not from vx_app_rtos_linux_mcu1_0.out .
    MCU1-0 is running ipc_echo_testb_mcu1_0_release_strip.xer5f.  But if mcu1-0 softlink not deleted in vision_apps/lib/firmware ,  the boot process will be blocked ,
    Starting kernel ...
    [    0.000000] Linux version 6.1.80 (zhangdongsheng@zhangdongsheng) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Mon May  6 14:19:37 CST 2024
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=42de6433-02 rw rootfstype=ext4 rootwait
    [    0.000000] Memory: 5784384K/8388608K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 1686720K reserved, 917504K cma-reserved)
    [    0.008530] Console: colour dummy device 80x25
    [    0.013115] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023785] pid_max: default: 32768 minimum: 301
    [    0.028545] LSM: Security Framework initializing
    [    0.033378] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.041141] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.050834] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.058263] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.064546] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.071932] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.078299] rcu: Hierarchical SRCU implementation.
    [    0.083201] rcu:     Max phase no-delay instances is 1000.
    [    0.088760] Platform MSI: msi-controller@1820000 domain created
    [    0.095064] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.104495] EFI services will not be available.
    [    0.109371] smp: Bringing up secondary CPUs ...
    [    0.125056] psci: failed to boot CPU1 (-22)
    [    0.129382] CPU1: failed to boot: -22
    [    0.144214] psci: failed to boot CPU2 (-22)
    [    0.148550] CPU2: failed to boot: -22
    [    0.163317] psci: failed to boot CPU3 (-22)
    [    0.167656] CPU3: failed to boot: -22
    [    0.171433] smp: Brought up 1 node, 1 CPU
    [    0.175538] SMP: Total of 1 processors activated.
    [    0.180355] CPU features: detected: 32-bit EL0 Support
    [    0.185608] CPU features: detected: CRC32 instructions
    [    0.190910] CPU: All CPU(s) started at EL2
    [    0.195091] alternatives: applying system-wide alternatives
    [    0.202296] devtmpfs: initialized
    [    0.216079] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.226097] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.260983] pinctrl core: initialized pinctrl subsystem
    [    0.266935] DMI not present or invalid.
    [    0.271417] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.278342] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.285796] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.293919] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.302166] audit: initializing netlink subsys (disabled)
    [    0.308240] thermal_sys: Registered thermal governor 'step_wise'
    [    0.308248] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.314401] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
    [    0.329011] cpuidle: using governor menu
    [    0.333167] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.340137] ASID allocator initialised with 65536 entries
    [    0.358202] KASLR disabled due to lack of seed
    [    0.368960] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.375962] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.382436] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.389372] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.395773] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.402704] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.409104] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.416033] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.423692] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected
    [    0.433828] iommu: Default domain type: Translated
    [    0.438849] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.445500] SCSI subsystem initialized
    [    0.449632] usbcore: registered new interface driver usbfs
    [    0.455277] usbcore: registered new interface driver hub
    [    0.460723] usbcore: registered new device driver usb
    [    0.466284] pps_core: LinuxPPS API ver. 1 registered
    [    0.471358] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.480700] PTP clock support registered
    [    0.484824] EDAC MC: Ver: 3.0.0
    [    0.488794] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    0.495637] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    0.502432] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [    0.509262] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100
    [    0.516247] FPGA manager framework
    [    0.519793] Advanced Linux Sound Architecture Driver Initialized.
    [    0.526860] clocksource: Switched to clocksource arch_sys_counter
    [    0.533345] VFS: Disk quotas dquot_6.6.0
    [    0.537387] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.549508] Carveout Heap: Exported 512 MiB at 0x0000000900000000
    [    0.555895] NET: Registered PF_INET protocol family
    [    0.561294] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.574423] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.583263] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.591190] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.599711] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.609062] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.615935] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.623036] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.630717] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.636914] RPC: Registered named UNIX socket transport module.
    [    0.643004] RPC: Registered udp transport module.
    [    0.647808] RPC: Registered tcp transport module.
    [    0.652608] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.659190] NET: Registered PF_XDP protocol family
    [    0.664095] PCI: CLS 0 bytes, default 64
    [    0.668750] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.678650] Initialise system trusted keyrings
    [    0.683438] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [    0.694131] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.700631] NFS: Registering the id_resolver key type
    [    0.705848] Key type id_resolver registered
    [    0.710120] Key type id_legacy registered
    [    0.714267] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.721113] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.762825] Key type asymmetric registered
    [    0.767012] Asymmetric key parser 'x509' registered
    [    0.772034] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.779733] io scheduler mq-deadline registered
    [    0.784371] io scheduler kyber registered
    [    0.791696] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.798260] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.810035] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.824729] loop: module loaded
    [    0.829119] megasas: 07.719.03.00-rc1
    [    0.835719] tun: Universal TUN/TAP device driver, 1.6
    [    0.841563] VFIO - User Level meta-driver version: 0.3
    [    0.847523] usbcore: registered new interface driver usb-storage
    [    0.854196] i2c_dev: i2c /dev entries driver
    [    0.859673] sdhci: Secure Digital Host Controller Interface driver
    [    0.866047] sdhci: Copyright(c) Pierre Ossman
    [    0.870720] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.877112] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.883396] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.890300] usbcore: registered new interface driver usbhid
    [    0.895994] usbhid: USB HID core driver
    [    0.900722] optee: probing for conduit method.
    [    0.905299] optee: revision 4.1 (012cdca4)
    [    0.905568] optee: dynamic shared memory is enabled
    [    0.914970] optee: initialized driver
    [    0.920443] Initializing XFRM netlink socket
    [    0.924914] NET: Registered PF_PACKET protocol family
    [    0.930153] Key type dns_resolver registered
    [    0.934897] registered taskstats version 1
    [    0.939099] Loading compiled-in X.509 certificates
    [    0.952195] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--w2023.01-j722s (Kool Koa')
    [    1.982873] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_auto+0x3c/0x8c)
    [    1.993132] ti-sci 44043000.system-controller: Mbox send fail -110
    [    3.006867] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_auto+0x3c/0x8c)
    [    3.017092] ti-sci 44043000.system-controller: Mbox send fail -110
    [    4.030867] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_auto+0x3c/0x8c)
    [    4.041092] ti-sci 44043000.system-controller: Mbox send fail -110
    [    5.054874] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_scan_clocks_from_dt+0x150/0x340)
    [    5.065632] ti-sci 44043000.system-controller: Mbox send fail -110
    [    6.078873] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_scan_clocks_from_dt+0x150/0x340)
    [    6.089629] ti-sci 44043000.system-controller: Mbox send fail -110
    [    7.102873] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_scan_clocks_from_dt+0x150/0x340)
    [    7.113628] ti-sci 44043000.system-controller: Mbox send fail -110
    [    8.126873] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_scan_clocks_from_dt+0x150/0x340)
    [    8.137628] ti-sci 44043000.system-controller: Mbox send fail -110
    [    9.150873] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_scan_clocks_from_dt+0x150/0x340)
    [    9.161627] ti-sci 44043000.system-controller: Mbox send fail -110
    [   10.174873] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_scan_clocks_from_dt+0x150/0x340)
    [   10.185629] ti-sci 44043000.system-controller: Mbox send fail -110
    [   11.198878] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_scan_clocks_from_dt+0x150/0x340)
    [   11.209632] ti-sci 44043000.system-controller: Mbox send fail -110
  • Can you please confirm if this thread is same as (+) PROCESSOR-SDK-J722S: ENTRY SDK9.2 mcu R5f : How to compile and use ? - Processors forum - Processors - TI E2E support forums
    If yes, we can continue the discussion on the other thread.
    Nikhil
