Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TDA4VH
Hi TI,
Do we have Deep Learning Accelerator(r (8 TOPS) enabled in our TI Linux build..?
If yes Can you please provide the verification process
Mallesh
Could you please elaborate the above statement in details ?
What verification process you are looking exactly here ?
In TDA4VH 140
We have Deep Learning Accelerator(r (8 TOPS), as EE team concern it will consume more power
So I need to know what will be the thermal condition of TDA4VH when Deep Learning is enable.
For that I raise a quire weather the Deep learning is enabled or not in TI Linux Build SDK is 9.0.1
Hi CC Mallesh,
The TDA4VH is 32 TOPS device, it has 4 C7x-MMA cores available.
We support RTOS SDK that caters deep learning use case.
Coming to thermal conditions when deep learning is enabled, i will have to check with the team, will get back to you on this.
Using Linux you can measure temperature of the SOC: https://e2e.ti.com/support/processors/f/791/t/1060764
You can read out the temperature of the SOC runtime while running the deep learning use case.
Let me know if you have more questions on thermal.
- Keerthy
