TDA4VH-Q1: sdk8.6-cpsw9g-rx-error
Part Number: TDA4VH-Q1
Hi,Ti ,expert
First we found the RX packets is 0;
2_0] 1.930150 s: ti sdk version:8.6.7.3 build:Apr 26 2024 06:44:34 repo:HEADdetachedata2dc792c(a2dc792cbc7c3eb3fbf06c2c2d907a695d137d00)
2_0] 1.930267 s: CIO: Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
2_0] 1.930294 s: Board_Id: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
2_0] 1.930489 s: This board id is gpio_num0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
2_0] 1.930518 s: This board id is tdavh0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
2_0] 1.930549 s: [Fusa] gpio_register index:1 Pinnum=41 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
2_0] 1.930583 s: [Fusa] gpio_register index:2 Pinnum=48 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
2_0] 1.930614 s: [Fusa] gpio_register index:3 Pinnum=47 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
2_0] 1.930802 s: ### CPU Frequency = 1000000000 Hz internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
2_0] 1.930831 s: CPU is running FreeRTOS internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.930852 s: APP: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.930872 s: SCICLIENT: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.931066 s: SCICLIENT: DMSC FW version [8.6.3--1-g2249f (Chill Capybara] internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.931101 s: SCICLIENT: DMSC FW revision 0x8 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.931130 s: SCICLIENT: DMSC FW ABI revision 3.1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.931161 s: SCICLIENT: Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.931184 s: UDMA: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.932517 s: UDMA: Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.932558 s: UDMA: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.933231 s: UDMA: Init for CSITX/CSIRX ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.933282 s: MEM: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.933317 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e4000000 of size 16777216 bytes !!!
CU2_0] 1.933376 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 60000000 of size 262144 bytes !!! internuclear_log.cpp:LogDeviceSendString:110
CU2_0] 1.933427 s: MEM: Created heap (DDR_FREETECH_SHA, id=7, flags=0x00000001) @ c1000000 of size 33554432 bytes !!!
CU2_0] 1.933479 s: MEM: Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.933501 s: SCICLIENT: Sciclient_pmSetModuleState module=275 state=2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.933597 s: SCICLIENT: Sciclient_pmSetModuleState success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.933702 s: INFO | 1.933679s: CCD_MODULE | ccd_init:488 dsp Information commitid:ddb4ad7 internuclear_log.cpp:LogDeviceSendString:110
CU2_0] 1.933808 s: INFO | 1.933788s: HOTPLUG_MODULE | ccd_hotplug_lock_create:619 hotplug global lock created ok
CU2_0] 1.934270 s: Driver Sensor Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.934301 s: IPC: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.934348 s: IPC: 10 CPUs participating in IPC !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.934390 s: IPC: Waiting for HLOS to be ready ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.934416 s: IPC: Ipc_isRemoteReady=0 ... internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.934458 s: [IssSensor_Priv] current SOC chip is TDA4VH_1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.934602 s: INFO | 1.934572s: I2C | ft_dsp_i2c_open:61 i2cInst:5 handle:a4689444 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.934699 s: INFO | 1.934677s: I2C | ft_dsp_i2c_open:62 [i2c-5] i2c_clock 400kHz internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.934808 s: INFO | 1.934778s: I2C | ft_dsp_i2c_open:63 [i2c-5] i2cInst baseaddr,enableIntr:0x2050000, 1 internuclear_log.cpp:LogDeviceSendString:110
CU2_0] 1.935138 s: INFO | 1.935110s: I2C | ft_dsp_i2c_open:61 i2cInst:2 handle:a4689420 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.935233 s: INFO | 1.935212s: I2C | ft_dsp_i2c_open:62 [i2c-2] i2c_clock 400kHz internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 1.935342 s: INFO | 1.935313s: I2C | ft_dsp_i2c_open:63 [i2c-2] i2cInst baseaddr,enableIntr:0x2020000, 1 internuclear_log.cpp:LogDeviceSendString:110
CU2_0] 2.192093 s: ERROR | 2.192057s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.192265 s: ERROR | 2.192230s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.192436 s: ERROR | 2.192401s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.192543 s: ERROR | 2.192519s: FAW_ROUND |faw_round.c, round_ovx3d_config:625 ERROR: Serdes Config Failed for camera # 0
CU2_0] 2.288092 s: ERROR | 2.288056s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.288260 s: ERROR | 2.288225s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.288427 s: ERROR | 2.288392s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.288531 s: ERROR | 2.288508s: FAW_ROUND |faw_round.c, round_ovx3d_config:625 ERROR: Serdes Config Failed for camera # 1
CU2_0] 2.384092 s: ERROR | 2.384057s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.384259 s: ERROR | 2.384224s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.384426 s: ERROR | 2.384391s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.384531 s: ERROR | 2.384508s: FAW_ROUND |faw_round.c, round_ovx3d_config:625 ERROR: Serdes Config Failed for camera # 2
CU2_0] 2.480088 s: ERROR | 2.480052s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.480255 s: ERROR | 2.480220s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.480420 s: ERROR | 2.480386s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.480526 s: ERROR | 2.480503s: FAW_ROUND |faw_round.c, round_ovx3d_config:625 ERROR: Serdes Config Failed for camera # 3
CU2_0] 2.481211 s: INFO | 2.481180s: HOTPLUG_MODULE | ccd_hotplug_task:668 ccd_hotplug_task name:ROUND-OVX3D-M96717F-UVYV is creat ok delay:150 times:5
CU2_0] 2.632099 s: ERROR | 2.632059s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.632271 s: ERROR | 2.632235s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.632440 s: ERROR | 2.632405s: I2C |ft_dsp_i2c.c, ft_dsp_i2c_16bit_write:488 ret,slaveAddr,regAddr:-3,0x42,0x302,a4689444
CU2_0] 2.632551 s: ERROR | 2.632526s: CPM |ccd_comm_fxns.c, cpm_config:128 [NIGHT-OV2311-M96717F-UVYV] ERROR: Serdes Config Failed for camera # 0
CU2_0] 2.632660 s: WARN | 2.632639s: FAW_NIGHT | night_ov2311_customCtrl:266 invalid cmd:65538 internuclear_log.cpp:LogDeviceSendString:110
CU2_0] 2.632997 s: INFO | 2.632967s: HOTPLUG_MODULE | ccd_hotplug_task:668 ccd_hotplug_task name:NIGHT-OV2311-M96717F-UVYV is creat ok delay:150 times:5
CU2_0] 2.638897 s: INFO | 2.638872s: DCD_DIAGNOSE | dcd_diagnose_task:58 dcd_diagnose_task name:FAW_AVM_OUT_MAX96717 is creat ok
CU2_0] 2.644559 s: INFO | 2.644535s: DCD_DIAGNOSE | dcd_diagnose_task:58 dcd_diagnose_task name:FAW_NVC_OUT_MAX96717 is creat ok
CU2_0] 2.788395 s: UTILS_IPC_RTOS utilsIpc is not initialized internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 2.788425 s: update csitx diagnose state failed,ipc send time out status:-1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 2.794381 s: UTILS_IPC_RTOS utilsIpc is not initialized internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 2.794409 s: update csitx diagnose state failed,ipc send time out status:-1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.983967 s: IPC: Ipc_isRemoteReady=0 ... Done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984000 s: IPC: Ipc_isRemoteReady=1 ... internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984027 s: IPC: Ipc_isRemoteReady=1 ... Done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984053 s: IPC: Ipc_isRemoteReady=4 ... internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984078 s: IPC: Ipc_isRemoteReady=4 ... Done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984104 s: IPC: Ipc_isRemoteReady=7 ... internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984129 s: IPC: Ipc_isRemoteReady=7 ... Done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984155 s: IPC: Ipc_isRemoteReady=8 ... internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984180 s: IPC: Ipc_isRemoteReady=8 ... Done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984207 s: IPC: Ipc_isRemoteReady=9 ... internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984232 s: IPC: Ipc_isRemoteReady=9 ... Done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984258 s: IPC: Ipc_isRemoteReady=10 ... internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984284 s: IPC: Ipc_isRemoteReady=10 ... Done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984310 s: IPC: Ipc_isRemoteReady=11 ... internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984335 s: IPC: Ipc_isRemoteReady=11 ... Done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984361 s: IPC: Ipc_isRemoteReady=12 ... internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984386 s: IPC: Ipc_isRemoteReady=12 ... Done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 3.984414 s: IPC: HLOS is ready !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.005920 s: IPC: Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.005952 s: APP: Syncing with 9 CPUs ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.017713 s: APP: Syncing with 9 CPUs ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.017748 s: REMOTE_SERVICE: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.019606 s: REMOTE_SERVICE: Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.019697 s: FT_REMOTE_SERVICE: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.020772 s: FT_REMOTE_SERVICE: Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.020805 s: UTILS_IPC_RTOS Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.020829 s: INFO: DRV_RPMSG Proc ID,name:0,mpu1_0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.020860 s: INFO: DRV_RPMSG Proc ID,name:1,mcu1_0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.020888 s: INFO: DRV_RPMSG Proc ID,name:2,mcu1_1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
CU2_0] 4.020916 s: INFO: DRV_RPMSG Proc ID,name:3,mcu2_0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.020943 s: INFO: DRV_RPMSG Proc ID,name:4,mcu2_1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.020975 s: INFO: DRV_RPMSG Proc ID,name:5,mcu3_0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.021004 s: INFO: DRV_RPMSG Proc ID,name:6,mcu3_1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.021032 s: INFO: DRV_RPMSG Proc ID,name:7,mcu4_0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.021060 s: INFO: DRV_RPMSG Proc ID,name:8,mcu4_1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.021087 s: INFO: DRV_RPMSG Proc ID,name:9,c7x_1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.021114 s: INFO: DRV_RPMSG Proc ID,name:10,c7x_2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.021142 s: INFO: DRV_RPMSG Proc ID,name:11,c7x_3 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.021169 s: INFO: DRV_RPMSG Proc ID,name:12,c7x_4 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.021197 s: INFO: DRV_RPMSG Proc ID,name:13,mpu1_1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.023550 s: INFO: UTILS_IPC_RTOS 113,61 Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.023632 s: APP: utilsIpcInit ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.023660 s: ETHFW: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.026708 s: ETHFW: Shared multicasts (software fanout): internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.026755 s: ETHFW: Reserved multicasts: internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.026781 s: 01:80:c2:00:00:0e internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.026824 s: 01:1b:19:00:00:00 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.027027 s: EnetMcm: CPSW_9G on MAIN NAVSS internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 4.043889 s: Cpsw_openPortLinkNoPhy: Port 1: Link up: 10-Gbps Full-Duplex internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.970569 s: Cpsw_openPortLinkNoPhy: Port 2: Link up: 10-Gbps Full-Duplex internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.973475 s: internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] ETHFW Version : 0.02.00 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.973523 s: ETHFW Build Date: Apr 26, 2024 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.973548 s: ETHFW Build Time: 06:38:31 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.973570 s: ETHFW Commit SHA: a2dc792c internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.973629 s: ETHFW: Init ... DONE !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.973653 s: ETHFW: Remove server Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.973806 s: CpswProxyServer: Virtual port configuration: internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.973846 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.973883 s: mpu_1_0 <-> MAC port 2: mpu_1_0_ethmac-device-2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.974664 s: CpswProxyServer: initialization completed (core: mcu2_0) internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.974711 s: ETHFW: Remove server Init ... DONE !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.975758 s: Starting lwIP, local interface IP is 192.168.1.200 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.976672 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.984850 s: Host MAC address: 70:ff:76:1d:92:c4 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.985449 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.985511 s: Added interface 'ti1', IP is 192.168.1.200 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.985555 s: EthFw: TimeSync PTP enabled internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.989115 s: Rx Flow for Software Inter-VLAN Routing is up internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.990337 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.023975 s: FVID2: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024060 s: FVID2: Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024089 s: DSS: Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024112 s: DSS: Display type is eDP !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024134 s: DSS: M2M Path is enabled !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024158 s: DSS: SoC init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024178 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024390 s: SCICLIENT: Sciclient_pmSetModuleState success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024422 s: SCICLIENT: Sciclient_pmSetModuleState module=404 state=2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024528 s: SCICLIENT: Sciclient_pmSetModuleState success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024556 s: SCICLIENT: Sciclient_pmSetModuleState module=217 state=2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024646 s: SCICLIENT: Sciclient_pmSetModuleState success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024673 s: SCICLIENT: Sciclient_pmSetModuleState module=404 state=2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024758 s: SCICLIENT: Sciclient_pmSetModuleState success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024784 s: SCICLIENT: Sciclient_pmSetModuleState module=217 state=2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024869 s: SCICLIENT: Sciclient_pmSetModuleState success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.024895 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.025000 s: SCICLIENT: Sciclient_pmSetModuleState success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.025034 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=218 clk=3 freq=148500000 internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 11.025220 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6, MacAddress:aa:bb:cc:dd:ee:39, FlowIdx:114,
[MCU2_0] 11.028152 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.028192 s: SCICLIENT: Sciclient_pmModuleClkRequest module=218 clk=3 state=2 flag=2 internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 11.028343 s: SCICLIENT: Sciclient_pmModuleClkRequest success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.028373 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.028537 s: SCICLIENT: Sciclient_pmSetModuleState success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.028564 s: DSS: SoC init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.045503 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6,mode:disable
[MCU2_0] 11.045701 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6,mode:disable
[MCU2_0] 11.048280 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6,mode:disable
[MCU2_0] 11.050083 s: DSS: Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.050125 s: VHWA: VPAC Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.050147 s: SCICLIENT: Sciclient_pmSetModuleState module=399 state=2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.050339 s: SCICLIENT: Sciclient_pmSetModuleState success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.050369 s: VHWA: LDC Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.052787 s: VHWA: LDC Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.052832 s: VHWA: MSC Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.062802 s: VHWA: MSC Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.062843 s: VHWA: NF Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.064122 s: VHWA: NF Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.064158 s: VHWA: VISS Init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.072053 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6,mode:disable
[MCU2_0] 11.072503 s: VHWA: VISS Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.072537 s: VHWA: VPAC Init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.072570 s: VX_ZONE_INIT:Enabled internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.072592 s: VX_ZONE_LOG:Enabled internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.072613 s: VX_ZONE_ERROR:Enabled internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.072635 s: VX_ZONE_WARNING:Enabled internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.074136 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.074337 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.074518 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.074702 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.074890 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.075182 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.075386 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.075571 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.075758 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.075955 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6,mode:disable
[MCU2_0] 11.076186 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.076399 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.076607 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.076807 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.077047 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.077241 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.077430 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.077610 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.077794 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.078023 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.078217 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.078408 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.078591 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX2 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.078804 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE9 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.079055 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE10 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.079252 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE11 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.079442 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE12 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.079487 s: VX_ZONE_INIT:[tivxInitLocal:131] Initialization Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.079517 s: APP: OpenVX Target kernel init ... !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 11.084139 s: Function:CpswProxyServer_registerIpv4MacHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c3
[MCU2_0] 11.107189 s: APP: OpenVX Target kernel init ... Done !!! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 10.288020 s: 10.288s ERROR|DRIVER_SHAREMEM| [DRIVER_shareMemAlloc:253]wait IPC run [35] internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 10.311142 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6,mode:disable
[MCU2_0] 10.317075 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6,mode:disable
:[MCU2_0] 10.388026 s: 10.388s ERROR|DRIVER_SHAREMEM| [DRIVER_shareMemAlloc:253]wait IPC run [38] internuclear_log.cpp:LogDeviceSendString:110
:[MCU2_0] 10.394076 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6,mode:disable
:[MCU2_0] 10.463112 s: INFO: UTILS_IPC_RTOS struct,cmd,procId,pid,endPt,len:32,0xbcbceaee,0,1469,1028,32,main_service_1469
:[MCU2_0] 10.463201 s: INFO: UTILS_IPC_RTOS ProcId 0 Linux pid 1469 Port 1028, main_service_1469 register internuclear_log.cpp:LogDeviceSendString:110
:[MCU2_0] 10.488025 s: 10.488s ERROR|DRIVER_SHAREMEM| [DRIVER_shareMemAlloc:253]wait IPC run [41] internuclear_log.cpp:LogDeviceSendString:110
:[MCU2_0] 10.494093 s: INFO: UTILS_IPC_RTOS struct,cmd,procId,pid,endPt,len:32,0xbcbceaee,0,1479,1032,32,main_service_1479
:[MCU2_0] 10.494178 s: INFO: UTILS_IPC_RTOS ProcId 0 Linux pid 1479 Port 1032, main_service_1479 register internuclear_log.cpp:LogDeviceSendString:110
:[MCU2_0] 10.552082 s: FT_REMOTE_SERVICE: rx set_connect_endpt cmd,src_cpu_id:0 reply_endpt:1033 internuclear_log.cpp:LogDeviceSendString:110
:[MCU2_0] 10.560068 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a468c8b0,CoreKey:38acb7e6,mode:disable
:[MCU2_0] 10.588028 s: 10.588s INFO |DRIVER_SHAREMEM|coreId=3 sync Freetech memory allocation end internuclear_log.cpp:LogDeviceSendString:110
:[MCU2_0] 10.588104 s: 10.588s INFO |DRIVER_SHAREMEM|malloc NON-ANONYMOUNS MEM FROM FREETECH_SHARED_MEM
:[MCU2_0] 10.588154 s: 10.588s INFO |DRIVER_SHAREMEM|malloc NON-ANONYMOUNS MEM FROM FREETECH_SHARED_MEM key:2 addr:c1400000
:[MCU2_0] 10.588218 s: 10.588s INFO |FTZEN_CBUF |FTZen_CbufShmemCreate chn:6 port:0 memSzie:10240 base:c1496020 c1497410 magic:[5893eadc 4665184
:[MCU2_0] 10.588315 s: 10.588s INFO |FTZEN_CBUF |cbuf channel[6], portId[0] memSize[10240] create success
:[MCU2_0] 10.588373 s: [TimeSync]: FTZen_CbufCreateChn success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 10.588410 s: 10.588s INFO |UTILS_TIMEMANAGER|UTILS_timeSyncCreate 900 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 10.588460 s: 10.588s INFO |UTILS_TIMEMANAGER|GTC freq:250 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 10.588505 s: 10.588s INFO |DRIVER_SHAREMEM|malloc NON-ANONYMOUNS MEM FROM FREETECH_SHARED_MEM
:[MCU2_0] 10.588550 s: 10.588s INFO |DRIVER_SHAREMEM|malloc NON-ANONYMOUNS MEM FROM FREETECH_SHARED_MEM key:3 addr:c1510000
:[MCU2_0] 10.588607 s: 10.588s INFO |UTILS_TIMEMANAGER|local core:3 server core:3 timeSyncInfoAddr:c1510000
:[MCU2_0] 10.588665 s: 10.588s INFO |UTILS_TIMEMANAGER|core:3 timeSyncInfo:c1510000 method:3 creating!
:[MCU2_0] 10.588722 s: 10.588s INFO |UTILS_TIMEMANAGER|gPTP start! internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 10.588893 s: 10.588s INFO |UTILS_TIMEMANAGER|GTC freq:250 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 10.605787 s: 10.605s ERROR|FT_PTP | [Ft_Ptp_createPtpTasks:925]create task success! internuclear_log.cpp:LogDeviceSendString:110
:[MCU2_0] 10.605886 s: 10.605s INFO |FT_PTP |Ft_Ptp_init suc internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 12.535913 s: 12.535s INFO |UTILS_TIMEMANAGER|UTILS_timeCallbackRegist success !!! internuclear_log.cpp:LogDeviceSendString:110
:[MCU2_0] 12.535961 s: driverTimeSyncTask pPrivObj:a46605f0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 0.001072 s: 0.001s ERROR|UTILS_TIMEMANAGER| [UTILS_timeStampClientGetTime:319]time sync error : old_time:12536354 new_time:1059
:[MCU2_0] 0.001163 s: 0.001s ERROR|UTILS_TIMEMANAGER| [UTILS_timeStampClientGetTime:328]o_index:0 o_usec:0 o_sync:0 o_gtc:0 n_index:1  tid:281473114665184
:[MCU2_0] 0.001281 s: create driver timesync task!!!! done internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 0.001311 s: [TimeSync]: UTILS_TimeSyncCreate success. internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 0.001340 s: [WatchDogClient]: WatchDogInit FTZen_CbufCreateChn Ready Start internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 0.001380 s: 0.001s WARN |FTZEN_CBUF |cbuf is already inited. internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
:[MCU2_0] 0.001418 s: [WatchDogClient]: WatchDogInit FTZen_CbufCreateChn create cbuf channel = 7, portid = 0, memsize = 2048, crcCheckEnable=1
:[MCU2_0] 0.001929 s: 0.001s INFO |DRIVER_SHAREMEM|malloc NON-ANONYMOUNS MEM FROM FREETECH_SHARED_MEM
MCU2_0] 0.001998 s: 0.001s INFO |DRIVER_SHAREMEM|malloc NON-ANONYMOUNS MEM FROM FREETECH_SHARED_MEM key:2 addr:c1400000
MCU2_0] 0.002069 s: 0.002s INFO |FTZEN_CBUF |FTZen_CbufShmemCreate chn:7 port:0 memSzie:2048 base:c14af020 c14af410 magic:[5893eadc 5893eadc]
MCU2_0] 0.002172 s: 0.002s INFO |FTZEN_CBUF |cbuf channel[7], portId[0] memSize[2048] create success
MCU2_0] 0.002227 s: [WatchDogClient]: WatchDogInit FTZen_CbufCreateChn success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
MCU2_0] 0.002266 s: [Fusa] register new diag_module:cpsw internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
MCU2_0] 0.002295 s: [Fusa] register new diag_module:io internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
MCU2_0] 0.002322 s: [FusaDiagClient]: FusaDiagInit FTZen_CbufCreateChn create cbuf channel = 5, portid = 0, memsize = 2048, crcCheckEnable=1
MCU2_0] 0.002786 s: 0.002s INFO |DRIVER_SHAREMEM|malloc NON-ANONYMOUNS MEM FROM FREETECH_SHARED_MEM internuclear_log.cpp:LogDeviceSendString:110
MCU2_0] 0.002851 s: 0.002s INFO |DRIVER_SHAREMEM|malloc NON-ANONYMOUNS MEM FROM FREETECH_SHARED_MEM key:2 addr:c1400000
MCU2_0] 0.002919 s: 0.002s INFO |FTZEN_CBUF |FTZen_CbufShmemCreate chn:5 port:0 memSzie:2048 base:c147d020 c147d410 magic:[5893eadc 5893eadc]
[MCU2_0] 0.003018 s: 0.003s INFO |FTZEN_CBUF |cbuf channel[5], portId[0] memSize[2048] create success
[MCU2_0] 0.003075 s: [FusaDiagClient]: FusaDiagInit FTZen_CbufCreateChn success internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.003121 s: 0.003s WARN |FTZEN_CBUF |FTzenCbufCheckReady no successfull internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.003161 s: [WatchDogClient]: SendWdgTriggerSignal FTZen_CbufPutData failed internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.003501 s: 0.003s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.003611 s: 0.003s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.003853 s: 0.003s INFO |FT_PTP |[Ft_Ptp_processPtpFrame] FT_PTP_PDLY_RSP_MSG_ID status : 0, nanoseconds : 3481344, seconds : 0
[MCU2_0] 0.003987 s: 0.003s INFO |FT_PTP |[Ft_Ptp_processPtpFrame]>>>FT_PTP_PDLY_RESP_FLW_UP_MSG_ID == pktType status : 0
[MCU2_0] 0.004057 s: 0.004s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.004107 s: 0.004s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.004157 s: 0.003s INFO |FT_PTP |[FT_Ptp_pdelayReqSendTask] send pdelay request internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.022698 s: 0.022s INFO |FTZEN_CBUF |cbuf[7] Successful match internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.042734 s: [WatchDogClient]: SendWdgTriggerSignal Sending,count = 1 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.065391 s: INFO: UTILS_IPC_RTOS struct,cmd,procId,pid,endPt,len:32,0xbcbceaee,0,1617,1037,32,main_service_1617
[MCU2_0] 0.065490 s: INFO: UTILS_IPC_RTOS ProcId 0 Linux pid 1617 Port 1037, main_service_1617 register internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.082629 s: ROUND-OVX3D-M96717F-UVYV sensor has already power on internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.082958 s: INFO: UTILS_IPC_RTOS struct,cmd,procId,pid,endPt,len:32,0xbcbceaee,0,1617,1037,32,com.ft.image_sensor_diagnose
[MCU2_0] 0.083044 s: INFO: UTILS_IPC_RTOS ProcId 0 Linux pid 1617 Port 1037, com.ft.image_sensor_diagnose register
[MCU2_0] 0.086026 s: CSI2RX: Init ... !!! instId=0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.086075 s: CSI2RX: Init ... Done !!! instId=0 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.098365 s: INFO: UTILS_IPC_RTOS struct,cmd,procId,pid,endPt,len:32,0xbcbceaee,0,1612,1041,32,main_service_1612
[MCU2_0] 0.098451 s: INFO: UTILS_IPC_RTOS ProcId 0 Linux pid 1612 Port 1041, main_service_1612 register internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.109480 s: 0.109s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.109755 s: 0.109s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.109755 s: 0.109s INFO |FT_PTP |[Ft_Ptp_processPtpFrame] FT_PTP_SYNC_MSG_ID status : 0, nanoseconds : 109441184, seconds : 0
[MCU2_0] 0.109963 s: 0.109s INFO |FT_PTP |FT_PTP_FOLLOW_UP_MSG_ID == pktType internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.110023 s: 0.110s INFO |FT_PTP |origin sec:1715246151 ori nsec:610351715 originTime:1715246151610351715
[MCU2_0] 0.110131 s: 0.110s INFO |FT_PTP |[Ft_Ptp_doFirstAdjustment] doubleWord : 1715246151611033349, origin_doubleWord:1715246151610351715 viceSendString:110 tid:281473114665184
[MCU2_0] 0.110256 s: 0.110s INFO |FT_PTP |doubleWord : 1715246151611033349, RESER_originTime:0 ,diff : 1715246151611033349
[MCU2_0] 0.110340 s: 0.110s ERROR|TIMESYNC | [DRIVER_TimeSync_setClockTime:439]TimeSync_setClockTime seconds : 1715246151, nanoSeconds :
[MCU2_0] 0.110448 s: 0.110s INFO |FTZEN_CBUF |cbuf[6] Successful match internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.110549 s: [TimeSync]: CbufHandleUnit::SendtData datatype = 10012000, data = 65536 internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.110596 s: [TimeSync]: TIME_LEAP_FUTURE error. internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.110633 s: 0.110s INFO |FT_PTP |[Ft_Ptp_calcRcfAndSyncInterval] curIndex:0 syntIndex:1 internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.110770 s: 0.110s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.110828 s: 0.110s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.159477 s: INFO: UTILS_IPC_RTOS struct,cmd,procId,pid,endPt,len:32,0xbcbceaee,0,1434,1045,32,main_service_1434
[MCU2_0] 0.159563 s: INFO: UTILS_IPC_RTOS ProcId 0 Linux pid 1434 Port 1045, main_service_1434 register internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.204775 s: 0.204s INFO |FT_PTP |[FT_Ptp_pdelayReqSendTask] send pdelay request internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.204945 s: 0.204s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.205045 s: 0.205s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.205149 s: 0.205s INFO |FT_PTP |[Ft_Ptp_processPtpFrame] FT_PTP_PDLY_RSP_MSG_ID status : 0, nanoseconds : 705514491, seconds :
[MCU2_0] 0.205271 s: 0.205s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.205325 s: 0.205s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.235787 s: 0.235s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.235936 s: 0.235s INFO |FT_PTP |[Ft_Ptp_processPtpFrame] FT_PTP_SYNC_MSG_ID status : 0, nanoseconds : 736355503, seconds : 1715246151
[MCU2_0] 0.236075 s: 0.236s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.236132 s: 0.236s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.236205 s: 0.236s INFO |FT_PTP |FT_PTP_FOLLOW_UP_MSG_ID == pktType internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.236261 s: 0.236s INFO |FT_PTP |origin sec:1715246151 ori nsec:736670047 originTime:1715246151736670047
[MCU2_0] 0.236341 s: 0.236s INFO |FT_PTP |[Ft_Ptp_processSyncFrame] stateMachine:3 : internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.236394 s: 0.236s INFO |FT_PTP |[Ft_Ptp_calcRcfAndSyncInterval] curIndex:1 syntIndex:2 internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.236456 s: 0.236s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.361597 s: 0.361s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.361867 s: 0.361s INFO |TIMESYNC |frameNotifyCfg->rxNotifyCb != NULL internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.361867 s: 0.361s INFO |FT_PTP |[Ft_Ptp_processPtpFrame] FT_PTP_SYNC_MSG_ID status : 0, nanoseconds : 862162415, seconds : 1715246151
[MCU2_0] 0.362021 s: 0.362s INFO |FT_PTP |FT_PTP_FOLLOW_UP_MSG_ID == pktType internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.362077 s: 0.362s INFO |FT_PTP |origin sec:1715246151 ori nsec:862449240 originTime:1715246151862449240
[MCU2_0] 0.362156 s: 0.362s INFO |FT_PTP |[Ft_Ptp_processSyncFrame] stateMachine:3 : internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.362208 s: 0.362s INFO |FT_PTP |[Ft_Ptp_calcRcfAndSyncInterval] curIndex:2 syntIndex:3 internuclear_log.cpp:LogDeviceSendString:110
[MCU2_0] 0.362271 s: 0.362s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.362320 s: 0.362s INFO |FT_PTP | get error DRIVER_TimeSync_getPtpFrame internuclear_log.cpp:LogDeviceSendString:110 tid:281473114665184
[MCU2_0] 0.367780 s: WARN | 0.367748s: CPM | cpm_i2c_write_scripts:23 script is NULL,component:0 no need to config
    Can you please capture CPSW Statistics and share with us.
    Please refer to FAQ for collecting CPSW statistics. You many need to integrate the patch in FAQ into EthFw and observe the statistics from MCU2_0.
    Make sure you are capturing the right port statistics.
    Also, can you please confirm are you running with QNX client?
    I could see Port-1, Port-2 are Link up with 10Gbps from log shared above?
    Sudheer
  • Hi,expert:
    with linux client
    with link up time port2 is link with VH,link up time is long than 10s
    Can you please share complete log of EthFW.
    Also, I could see from EthFw there is wait for Link Up after Port is open.
    It could be reason for the reflecting the Port Link Up status gets delayed, might be Link up with Link Partner gets delayed.
    Sudheer
  • Hi,Ti expert:
    Can pass the link up tuning  and some interface to resume or reinit the port ?
    No, Link up should happen. as per S/W Design.
    As per my understanding If Link is not Up, while sending the packets from Host Port to this Port will be blocked the Host FIFO, and no further transmission from Host Port. As Host Port FIFO Is fulll due to Non LinkUp Port.
    Sudheer
