TDA4VM: Edge AI : Gather functionality issue with egdeai sdk for custom model
Part Number: TDA4VM
Hello Champs ,
I am trying to run a custom model and i am getting the following error please find the following logs and debug
Settings :
SDK : 9.2.7
Docker
Mode : Compilation
root@397074ad6dc3:/home/root/examples/osrt_python/ort# python3 onnxrt_ep_dock927_condlanet_fp32.py -c
Available execution providers :  ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
Running 1 Models - ['condlanet_org']
Running_Model :  condlanet_org
Running shape inference on model /home/root/lucid/model_onnx/condlanettest.onnx
***** WARNING : tensor_bits = 32 -- Compiling for floating point - target execution is not supported for 32 bit compilation !! *****
tidl_tools_path                                 = /home/root/tidl_tools
artifacts_folder                                = ../../../model-artifacts//condlanet_org/
tidl_tensor_bits                                = 32
debug_level                                     = 6
num_tidl_subgraphs                              = 16
tidl_denylist                                   = Div   Gather
tidl_denylist_layer_name                        =
tidl_denylist_layer_type                         =
tidl_allowlist_layer_name                        =
model_type                                      =
tidl_calibration_accuracy_level                 = 64
tidl_calibration_options:num_frames_calibration = 3
tidl_calibration_options:bias_calibration_iterations = 3
mixed_precision_factor = -1.000000
model_group_id = 0
power_of_2_quantization                         = 2
ONNX QDQ Enabled                                = 0
enable_high_resolution_optimization             = 0
pre_batchnorm_fold                              = 1
add_data_convert_ops                            = 0
output_feature_16bit_names_list                 =
m_params_16bit_names_list                       =
m_single_core_layers_names_list                    =
reserved_compile_constraints_flag               = 1601
ti_internal_reserved_1                          =
WARNING : 'meta_layers_names_list' is not provided - running OD post processing in ARM mode
Number of OD backbone nodes = 0
Size of odBackboneNodeIds = 0
Layer 0 -- layer name -- Conv_0
 Input dims size = 4     dims --- 1   3   320   800
Supported TIDL layer type ---            Conv -- Conv_0
Layer 1 -- layer name -- Relu_1
 Input dims size = 4     dims --- 1   64   160   400
Supported TIDL layer type ---            Relu -- Relu_1
Layer 2 -- layer name -- MaxPool_2
Supported TIDL layer type ---         MaxPool -- MaxPool_2
Layer 3 -- layer name -- Conv_3
 Input dims size = 4     dims --- 1   64   80   200
Supported TIDL layer type ---            Conv -- Conv_3
Layer 4 -- layer name -- Relu_4
Supported TIDL layer type ---            Relu -- Relu_4
Layer 5 -- layer name -- Conv_5
Supported TIDL layer type ---            Conv -- Conv_5
Layer 6 -- layer name -- Add_6
Supported TIDL layer type ---             Add -- Add_6
Layer 7 -- layer name -- Relu_7
Supported TIDL layer type ---            Relu -- Relu_7
Layer 8 -- layer name -- Conv_8
Supported TIDL layer type ---            Conv -- Conv_8
Layer 9 -- layer name -- Relu_9
Supported TIDL layer type ---            Relu -- Relu_9
Layer 10 -- layer name -- Conv_10
Supported TIDL layer type ---            Conv -- Conv_10
Layer 11 -- layer name -- Add_11
Supported TIDL layer type ---             Add -- Add_11
Layer 12 -- layer name -- Relu_12
Supported TIDL layer type ---            Relu -- Relu_12
Layer 13 -- layer name -- Conv_13
Supported TIDL layer type ---            Conv -- Conv_13
Layer 14 -- layer name -- Relu_14
 Input dims size = 4     dims --- 1   128   40   100
Supported TIDL layer type ---            Relu -- Relu_14
Layer 15 -- layer name -- Conv_15
Supported TIDL layer type ---            Conv -- Conv_15
Layer 16 -- layer name -- Conv_16
Supported TIDL layer type ---            Conv -- Conv_16
Layer 17 -- layer name -- Add_17
Supported TIDL layer type ---             Add -- Add_17
Layer 18 -- layer name -- Relu_18
Supported TIDL layer type ---            Relu -- Relu_18
Layer 19 -- layer name -- Conv_19
Supported TIDL layer type ---            Conv -- Conv_19
Layer 20 -- layer name -- Relu_20
Supported TIDL layer type ---            Relu -- Relu_20
Layer 21 -- layer name -- Conv_21
Supported TIDL layer type ---            Conv -- Conv_21
Layer 22 -- layer name -- Add_22
Supported TIDL layer type ---             Add -- Add_22
Layer 23 -- layer name -- Relu_23
Supported TIDL layer type ---            Relu -- Relu_23
Layer 24 -- layer name -- Conv_24
Supported TIDL layer type ---            Conv -- Conv_24
Layer 25 -- layer name -- Relu_25
 Input dims size = 4     dims --- 1   256   20   50
Supported TIDL layer type ---            Relu -- Relu_25
Layer 26 -- layer name -- Conv_26
Supported TIDL layer type ---            Conv -- Conv_26
Layer 27 -- layer name -- Conv_27
Supported TIDL layer type ---            Conv -- Conv_27
Layer 28 -- layer name -- Add_28
Supported TIDL layer type ---             Add -- Add_28
Layer 29 -- layer name -- Relu_29
Supported TIDL layer type ---            Relu -- Relu_29
Layer 30 -- layer name -- Conv_30
Supported TIDL layer type ---            Conv -- Conv_30
Layer 31 -- layer name -- Relu_31
Supported TIDL layer type ---            Relu -- Relu_31
Layer 32 -- layer name -- Conv_32
Supported TIDL layer type ---            Conv -- Conv_32
Layer 33 -- layer name -- Add_33
Supported TIDL layer type ---             Add -- Add_33
Layer 34 -- layer name -- Relu_34
Supported TIDL layer type ---            Relu -- Relu_34
Layer 35 -- layer name -- Conv_35
Supported TIDL layer type ---            Conv -- Conv_35
Layer 36 -- layer name -- Relu_36
 Input dims size = 4     dims --- 1   512   10   25
Supported TIDL layer type ---            Relu -- Relu_36
Layer 37 -- layer name -- Conv_37
Supported TIDL layer type ---            Conv -- Conv_37
Layer 38 -- layer name -- Conv_38
Supported TIDL layer type ---            Conv -- Conv_38
Layer 39 -- layer name -- Add_39
Supported TIDL layer type ---             Add -- Add_39
Layer 40 -- layer name -- Relu_40
Supported TIDL layer type ---            Relu -- Relu_40
Layer 41 -- layer name -- Conv_41
Supported TIDL layer type ---            Conv -- Conv_41
Layer 42 -- layer name -- Relu_42
Supported TIDL layer type ---            Relu -- Relu_42
Layer 43 -- layer name -- Conv_43
Supported TIDL layer type ---            Conv -- Conv_43
Layer 44 -- layer name -- Add_44
Supported TIDL layer type ---             Add -- Add_44
Layer 45 -- layer name -- Relu_45
Supported TIDL layer type ---            Relu -- Relu_45
Layer 46 -- layer name -- Conv_46
Supported TIDL layer type ---            Conv -- Conv_46
Layer 47 -- layer name -- Relu_47
 Input dims size = 4     dims --- 1   64   10   25
Supported TIDL layer type ---            Relu -- Relu_47
Layer 48 -- layer name -- Add_58
Supported TIDL layer type ---             Add -- Add_58
Layer 49 -- layer name -- Conv_59
Supported TIDL layer type ---            Conv -- Conv_59
Layer 50 -- layer name -- Reshape_64
 Input dims size = 4     dims --- 1   16   10   25
Supported TIDL layer type ---         Reshape -- Reshape_64
Layer 51 -- layer name -- Transpose_65
 Input dims size = 3     dims --- 1   16   250
Supported TIDL layer type ---       Transpose -- Transpose_65
Layer 52 -- layer name -- Conv_66
Supported TIDL layer type ---            Conv -- Conv_66
Layer 53 -- layer name -- Reshape_71
Supported TIDL layer type ---         Reshape -- Reshape_71
Layer 54 -- layer name -- MatMul_72
 Input dims size = 3     dims --- 1   250   16
Supported TIDL layer type ---          MatMul -- MatMul_72
Layer 55 -- layer name -- Softmax_73
 Input dims size = 3     dims --- 1   250   250
Supported TIDL layer type ---         Softmax -- Softmax_73
Layer 56 -- layer name -- Transpose_74
Supported TIDL layer type ---       Transpose -- Transpose_74
Layer 57 -- layer name -- Conv_75
Supported TIDL layer type ---            Conv -- Conv_75
Layer 58 -- layer name -- Reshape_80
Supported TIDL layer type ---         Reshape -- Reshape_80
Layer 59 -- layer name -- MatMul_81
 Input dims size = 3     dims --- 1   64   250
Supported TIDL layer type ---          MatMul -- MatMul_81
Layer 60 -- layer name -- Reshape_86
Supported TIDL layer type ---         Reshape -- Reshape_86
Layer 61 -- layer name -- custom_added_Mul0
Supported TIDL layer type ---             Mul -- custom_added_Mul0
Layer 62 -- layer name -- Add_88
Supported TIDL layer type ---             Add -- Add_88
Layer 63 -- layer name -- Conv_89
Supported TIDL layer type ---            Conv -- Conv_89
Layer 64 -- layer name -- Relu_90
Supported TIDL layer type ---            Relu -- Relu_90
Layer 65 -- layer name -- Conv_91
Supported TIDL layer type ---            Conv -- Conv_91
Layer 66 -- layer name -- Relu_92
Supported TIDL layer type ---            Relu -- Relu_92
Layer 67 -- layer name -- Add_103
Supported TIDL layer type ---             Add -- Add_103
Layer 68 -- layer name -- Conv_104
Supported TIDL layer type ---            Conv -- Conv_104
Layer 69 -- layer name -- Reshape_109
Supported TIDL layer type ---         Reshape -- Reshape_109
Layer 70 -- layer name -- Transpose_110
Supported TIDL layer type ---       Transpose -- Transpose_110
Layer 71 -- layer name -- Conv_111
Supported TIDL layer type ---            Conv -- Conv_111
Layer 72 -- layer name -- Reshape_116
Supported TIDL layer type ---         Reshape -- Reshape_116
Layer 73 -- layer name -- MatMul_117
Supported TIDL layer type ---          MatMul -- MatMul_117
Layer 74 -- layer name -- Softmax_118
Supported TIDL layer type ---         Softmax -- Softmax_118
Layer 75 -- layer name -- Transpose_119
Supported TIDL layer type ---       Transpose -- Transpose_119
Layer 76 -- layer name -- Conv_120
Supported TIDL layer type ---            Conv -- Conv_120
Layer 77 -- layer name -- Reshape_125
Supported TIDL layer type ---         Reshape -- Reshape_125
Layer 78 -- layer name -- MatMul_126
Supported TIDL layer type ---          MatMul -- MatMul_126
Layer 79 -- layer name -- Reshape_131
Supported TIDL layer type ---         Reshape -- Reshape_131
Layer 80 -- layer name -- custom_added_Mul1
Supported TIDL layer type ---             Mul -- custom_added_Mul1
Layer 81 -- layer name -- Add_133
Supported TIDL layer type ---             Add -- Add_133
Layer 82 -- layer name -- Conv_134
Supported TIDL layer type ---            Conv -- Conv_134
Layer 83 -- layer name -- Relu_135
Supported TIDL layer type ---            Relu -- Relu_135
Layer 84 -- layer name -- Conv_138
Supported TIDL layer type ---            Conv -- Conv_138
Layer 85 -- layer name -- Upsample_139
Supported TIDL layer type ---        Upsample -- Upsample_139
Layer 86 -- layer name -- Conv_137
Supported TIDL layer type ---            Conv -- Conv_137
Layer 87 -- layer name -- Add_140
 Input dims size = 4     dims --- 1   64   20   50
Supported TIDL layer type ---             Add -- Add_140
Layer 88 -- layer name -- Conv_144
Supported TIDL layer type ---            Conv -- Conv_144
Layer 89 -- layer name -- Conv_148
Supported TIDL layer type ---            Conv -- Conv_148
Layer 90 -- layer name -- Relu_149
Supported TIDL layer type ---            Relu -- Relu_149
Layer 91 -- layer name -- Conv_150
Supported TIDL layer type ---            Conv -- Conv_150
Layer 92 -- layer name -- Sigmoid_166
 Input dims size = 4     dims --- 1   8   20   50
Supported TIDL layer type ---         Sigmoid -- Sigmoid_166
Layer 93 -- layer name -- Clip_167
Supported TIDL layer type ---            Clip -- Clip_167
Layer 94 -- layer name -- custom_added_Mul9
Supported TIDL layer type ---             Mul -- custom_added_Mul9
Layer 95 -- layer name -- MaxPool_182
Supported TIDL layer type ---         MaxPool -- MaxPool_182
Layer 96 -- layer name -- custom_added_Add1
Supported TIDL layer type ---             Add -- custom_added_Add1
Layer 97 -- layer name -- custom_added_Add0
Supported TIDL layer type ---             Add -- custom_added_Add0
Op type 'Div'  added to unsupported nodes as specified in deny list
Layer 99 -- layer name -- custom_added_Mul8
Supported TIDL layer type ---             Mul -- custom_added_Mul8
Layer 100 -- layer name -- custom_added_Add3
Supported TIDL layer type ---             Add -- custom_added_Add3
Layer 101 -- layer name -- Mul_189
Supported TIDL layer type ---             Mul -- Mul_189
Layer 102 -- layer name -- Squeeze_190
Supported TIDL layer type ---         Squeeze -- Squeeze_190
Layer 103 -- layer name -- Reshape_192
 Input dims size = 3     dims --- 8   20   50
Supported TIDL layer type ---         Reshape -- Reshape_192
Layer 104 -- layer name -- TopK_193
 Input dims size = 1     dims --- 8000
Unsupported (imports) TIDL layer type for ONNX op type --- TopK
Layer 105 -- layer name -- Reshape_195
 Input dims size = 1     dims --- 6
Supported TIDL layer type ---         Reshape -- Reshape_195
Layer 106 -- layer name -- custom_added_Mul2
 Input dims size = 2     dims --- 6   1
Supported TIDL layer type ---             Mul -- custom_added_Mul2
Layer 107 -- layer name -- Slice_203
 Input dims size = 2     dims --- 6   134
Supported TIDL layer type ---           Slice -- Slice_203
Op type 'Gather'  added to unsupported nodes as specified in deny list
Layer 109 -- layer name -- Conv_151
Supported TIDL layer type ---            Conv -- Conv_151
Layer 110 -- layer name -- Relu_152
Supported TIDL layer type ---            Relu -- Relu_152
Layer 111 -- layer name -- Conv_153
Supported TIDL layer type ---            Conv -- Conv_153
Layer 112 -- layer name -- Reshape_172
 Input dims size = 4     dims --- 1   1072   20   50
Supported TIDL layer type ---         Reshape -- Reshape_172
Layer 113 -- layer name -- Transpose_179
 Input dims size = 5     dims --- 1   8   134   20   50
Supported TIDL layer type ---       Transpose -- Transpose_179
Layer 114 -- layer name -- Reshape_181
 Input dims size = 5     dims --- 1   8   20   50   134
Supported TIDL layer type ---         Reshape -- Reshape_181
Layer 115 -- layer name -- Slice_205
 Input dims size = 2     dims --- 8000   134
Supported TIDL layer type ---           Slice -- Slice_205
Layer 117 -- layer name -- Slice_228
 Input dims size = 2     dims --- 6   67
Supported TIDL layer type ---           Slice -- Slice_228
Layer 118 -- layer name -- Reshape_236
 Input dims size = 2     dims --- 6   66
Supported TIDL layer type ---         Reshape -- Reshape_236
Layer 119 -- layer name -- Reshape_243
 Input dims size = 4     dims --- 6   66   1   1
Supported TIDL layer type ---         Reshape -- Reshape_243
Layer 120 -- layer name -- Upsample_141
Supported TIDL layer type ---        Upsample -- Upsample_141
Layer 121 -- layer name -- Conv_136
Supported TIDL layer type ---            Conv -- Conv_136
Layer 122 -- layer name -- Add_142
 Input dims size = 4     dims --- 1   64   40   100
Supported TIDL layer type ---             Add -- Add_142
Layer 123 -- layer name -- Conv_143
Supported TIDL layer type ---            Conv -- Conv_143
Layer 124 -- layer name -- Conv_173
Supported TIDL layer type ---            Conv -- Conv_173
Layer 125 -- layer name -- Relu_174
Supported TIDL layer type ---            Relu -- Relu_174
Layer 126 -- layer name -- Conv_175
Supported TIDL layer type ---            Conv -- Conv_175
Layer 127 -- layer name -- Relu_176
Supported TIDL layer type ---            Relu -- Relu_176
Layer 128 -- layer name -- Conv_177
Supported TIDL layer type ---            Conv -- Conv_177
Layer 129 -- layer name -- Relu_178
Supported TIDL layer type ---            Relu -- Relu_178
Layer 130 -- layer name -- Concat_217
 Input dims size = 0     dims ---
Supported TIDL layer type ---          Concat -- Concat_217
Layer 131 -- layer name -- Concat_220
 Input dims size = 4     dims --- 1   66   40   100
Supported TIDL layer type ---          Concat -- Concat_220
Layer 132 -- layer name -- Reshape_224
 Input dims size = 4     dims --- 1   396   40   100
Supported TIDL layer type ---         Reshape -- Reshape_224
Layer 133 -- layer name -- Mul_244
Unsupported (TIDL check) TIDL layer type ---             Mul
Layer 134 -- layer name -- Reshape_246
Supported TIDL layer type ---         Reshape -- Reshape_246
Layer 135 -- layer name -- ReduceSum_247
 Input dims size = 5     dims --- 1   6   66   40   100
Unsupported (imports) TIDL layer type for ONNX op type --- ReduceSum
Layer 136 -- layer name -- Slice_229
Supported TIDL layer type ---           Slice -- Slice_229
Layer 137 -- layer name -- custom_added_Reshape1
Supported TIDL layer type ---         Reshape -- custom_added_Reshape1
Layer 138 -- layer name -- custom_added_Add5
 Input dims size = 4     dims --- 1   1   1   6
Supported TIDL layer type ---             Add -- custom_added_Add5
Layer 139 -- layer name -- Reshape_249
Supported TIDL layer type ---         Reshape -- Reshape_249
Layer 140 -- layer name -- Add_250
 Input dims size = 4     dims --- 1   6   40   100
Unsupported (TIDL check) TIDL layer type ---             Add
Layer 141 -- layer name -- Reshape_254
Supported TIDL layer type ---         Reshape -- Reshape_254
Layer 142 -- layer name -- Transpose_305
Supported TIDL layer type ---       Transpose -- Transpose_305
Layer 143 -- layer name -- custom_added_Conv0
 Input dims size = 4     dims --- 6   100   1   40
Supported TIDL layer type ---            Conv -- custom_added_Conv0
Layer 144 -- layer name -- Relu_314
 Input dims size = 4     dims --- 6   64   1   40
Supported TIDL layer type ---            Relu -- Relu_314
Layer 145 -- layer name -- custom_added_Conv1
Supported TIDL layer type ---            Conv -- custom_added_Conv1
Layer 146 -- layer name -- custom_added_Squeeze2
 Input dims size = 4     dims --- 6   2   1   40
Supported TIDL layer type ---         Squeeze -- custom_added_Squeeze2
Layer 147 -- layer name -- Transpose_316
 Input dims size = 3     dims --- 6   2   40
Supported TIDL layer type ---       Transpose -- Transpose_316
Layer 148 -- layer name -- Slice_204
Supported TIDL layer type ---           Slice -- Slice_204
Layer 150 -- layer name -- Slice_255
Supported TIDL layer type ---           Slice -- Slice_255
Layer 152 -- layer name -- Slice_278
Supported TIDL layer type ---           Slice -- Slice_278
Layer 153 -- layer name -- Reshape_286
Supported TIDL layer type ---         Reshape -- Reshape_286
Layer 154 -- layer name -- Reshape_293
Supported TIDL layer type ---         Reshape -- Reshape_293
Layer 155 -- layer name -- Reshape_274
Supported TIDL layer type ---         Reshape -- Reshape_274
Layer 156 -- layer name -- Mul_294
Layer 157 -- layer name -- Reshape_296
Supported TIDL layer type ---         Reshape -- Reshape_296
Layer 158 -- layer name -- ReduceSum_297
Layer 159 -- layer name -- Slice_279
Supported TIDL layer type ---           Slice -- Slice_279
Layer 160 -- layer name -- custom_added_Reshape2
Supported TIDL layer type ---         Reshape -- custom_added_Reshape2
Layer 161 -- layer name -- custom_added_Add4
Supported TIDL layer type ---             Add -- custom_added_Add4
Layer 162 -- layer name -- Reshape_299
Supported TIDL layer type ---         Reshape -- Reshape_299
Layer 163 -- layer name -- Add_300
Layer 164 -- layer name -- Reshape_304
Supported TIDL layer type ---         Reshape -- Reshape_304
Layer 165 -- layer name -- custom_added_Reshape0
Supported TIDL layer type ---         Reshape -- custom_added_Reshape0
Layer 166 -- layer name -- Reshape_197
Supported TIDL layer type ---         Reshape -- Reshape_197
Preliminary subgraphs created = 13
Final number of subgraphs created are : 11, - Offloaded Nodes - 155, Total Nodes - 167
INFORMATION -- [TIDL_ResizeLayer]  Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
Node in deny list...delegated to ARM --- layer type - Div, Node name - Div_186
Layers type not supported by TIDL --- layer type - TopK,  Node name -TopK_193
Node in deny list...delegated to ARM --- layer type - Gather, Node name - Gather_207
Node in deny list...delegated to ARM --- layer type - Gather, Node name - Gather_209
ALLOWLISTING : ADD/MUL/SUB/DIV layer : The variable inputs must of be same dimensions --tidl_import_common_model_check.cpp , TIDL_checkAddMulSubDivTensorProperties , 403
Layers type not supported by TIDL --- layer type - ReduceSum,  Node name -ReduceSum_247
Node in deny list...delegated to ARM --- layer type - Gather, Node name - Gather_257
Node in deny list...delegated to ARM --- layer type - Gather, Node name - Gather_259
Layers type not supported by TIDL --- layer type - ReduceSum,  Node name -ReduceSum_297
Running runtimes graphviz - /home/root/tidl_tools/tidl_graphVisualiser_runtimes.out ../../../model-artifacts//condlanet_org//allowedNode.txt ../../../model-artifacts//condlanet_org//tempDir/graphvizInfo.txt ../../../model-artifacts//condlanet_org//tempDir/runtimes_visualization.svg
*** In TIDL_createStateImportFunc ***
Compute on node : TIDLExecutionProvider_TIDL_0_0
  0,            Conv, 3, 1, image, 600
  1,            Relu, 1, 1, 600, 203
  2,         MaxPool, 1, 1, 203, 204
  3,            Conv, 3, 1, 204, 603
  4,            Relu, 1, 1, 603, 207
  5,            Conv, 3, 1, 207, 606
  6,             Add, 2, 1, 606, 210
  7,            Relu, 1, 1, 210, 211
  8,            Conv, 3, 1, 211, 609
  9,            Relu, 1, 1, 609, 214
 10,            Conv, 3, 1, 214, 612
 11,             Add, 2, 1, 612, 217
 12,            Relu, 1, 1, 217, 218
 13,            Conv, 3, 1, 218, 621
 14,            Conv, 3, 1, 218, 615
 15,            Relu, 1, 1, 615, 221
 16,            Conv, 3, 1, 221, 618
 17,             Add, 2, 1, 618, 226
 18,            Relu, 1, 1, 226, 227
 19,            Conv, 3, 1, 227, 624
 20,            Relu, 1, 1, 624, 230
 21,            Conv, 3, 1, 230, 627
 22,             Add, 2, 1, 627, 233
 23,            Relu, 1, 1, 233, 234
 24,            Conv, 3, 1, 234, 636
 25,            Conv, 3, 1, 234, 630
 26,            Relu, 1, 1, 630, 237
 27,            Conv, 3, 1, 237, 633
 28,             Add, 2, 1, 633, 242
 29,            Relu, 1, 1, 242, 243
 30,            Conv, 3, 1, 243, 639
 31,            Relu, 1, 1, 639, 246
 32,            Conv, 3, 1, 246, 642
 33,             Add, 2, 1, 642, 249
 34,            Relu, 1, 1, 249, 250
 35,            Conv, 3, 1, 250, 378
 36,            Conv, 3, 1, 250, 651
 37,            Conv, 3, 1, 250, 645
 38,            Relu, 1, 1, 645, 253
 39,            Conv, 3, 1, 253, 648
 40,             Add, 2, 1, 648, 258
 41,            Relu, 1, 1, 258, 259
 42,            Conv, 3, 1, 259, 654
 43,            Relu, 1, 1, 654, 262
 44,            Conv, 3, 1, 262, 657
 45,             Add, 2, 1, 657, 265
 46,            Relu, 1, 1, 265, 266
 47,            Conv, 3, 1, 266, 660
 48,            Relu, 1, 1, 660, 269
 49,             Add, 2, 1, 269, 280
 50,            Conv, 3, 1, 280, 301
 51,         Reshape, 2, 1, 301, 308
 52,            Conv, 3, 1, 280, 290
 53,         Reshape, 2, 1, 290, 297
 54,            Conv, 3, 1, 280, 281
 55,         Reshape, 2, 1, 281, 288
 56,       Transpose, 1, 1, 288, 289
 57,          MatMul, 2, 1, 289, 298
 58,         Softmax, 1, 1, 298, 299
 59,       Transpose, 1, 1, 299, 300
 60,          MatMul, 2, 1, 308, 309
 61,         Reshape, 2, 1, 309, 316
 62,             Mul, 2, 1, 316, 317
 63,             Add, 2, 1, 317, 318
 64,            Conv, 3, 1, 318, 663
 65,            Relu, 1, 1, 663, 321
 66,            Conv, 3, 1, 321, 666
 67,            Relu, 1, 1, 666, 324
 68,             Add, 2, 1, 324, 335
 69,            Conv, 3, 1, 335, 356
 70,         Reshape, 2, 1, 356, 363
 71,            Conv, 3, 1, 335, 345
 72,         Reshape, 2, 1, 345, 352
 73,            Conv, 3, 1, 335, 336
 74,         Reshape, 2, 1, 336, 343
 75,       Transpose, 1, 1, 343, 344
 76,          MatMul, 2, 1, 344, 353
 77,         Softmax, 1, 1, 353, 354
 78,       Transpose, 1, 1, 354, 355
 79,          MatMul, 2, 1, 363, 364
 80,         Reshape, 2, 1, 364, 371
 81,             Mul, 2, 1, 371, 372
 82,             Add, 2, 1, 372, 373
 83,            Conv, 3, 1, 373, 669
 84,            Relu, 1, 1, 669, 376
 85,            Conv, 3, 1, 376, 379
 86,        Upsample, 2, 1, 379, 383
 87,             Add, 2, 1, 378, 384
 88,            Conv, 3, 1, 384, 391
 89,            Conv, 3, 1, 391, 398
 90,            Relu, 1, 1, 398, 399
 91,            Conv, 3, 1, 399, 400
 92,         Reshape, 2, 1, 400, 423
 93,       Transpose, 1, 1, 423, 433
 94,         Reshape, 2, 1, 433, 435
 95,           Slice, 1, 1, 435, 524
 96,           Slice, 1, 1, 435, 460
 97,            Conv, 3, 1, 391, 395
 98,            Relu, 1, 1, 395, 396
 99,            Conv, 3, 1, 396, 397
100,         Sigmoid, 1, 1, 397, 413
101,            Clip, 1, 1, 413, 414
102,         MaxPool, 1, 1, 414, 436
103,             Mul, 2, 1, 414, mul_out_Sub_183
104,             Add, 2, 1, mul_out_Sub_183, 437
105,             Add, 2, 1, 437, 439
Input tensor name -  image
Output tensor name - 234
Output tensor name - 384
Output tensor name - 414
Output tensor name - 437
Output tensor name - 439
Output tensor name - 460
Output tensor name - 524
Compute on node : TIDLExecutionProvider_TIDL_1_1
  0,             Mul, 2, 1, 440, mul_out_Sub_188
  1,             Add, 2, 1, mul_out_Sub_188, 442
  2,             Mul, 2, 1, 414, 443
  3,         Squeeze, 1, 1, 443, 444
  4,         Reshape, 2, 1, 444, 446
Input tensor name -  440
Input tensor name -  414
Output tensor name - 446
Compute on node : TIDLExecutionProvider_TIDL_2_2
  0,         Reshape, 2, 1, 448, seeds
  1,             Mul, 2, 1, seeds, 454
  2,           Slice, 1, 1, 454, 458
Input tensor name -  448
Output tensor name - seeds
Output tensor name - 454
Output tensor name - 458
Compute on node : TIDLExecutionProvider_TIDL_3_3
  0,            Conv, 3, 1, 234, 377
  1,        Upsample, 2, 1, 384, 388
  2,             Add, 2, 1, 377, 389
  3,            Conv, 3, 1, 389, 390
  4,            Conv, 3, 1, 390, 672
  5,            Relu, 1, 1, 672, 426
  6,            Conv, 3, 1, 426, 675
  7,            Relu, 1, 1, 675, 429
  8,            Conv, 3, 1, 429, 678
  9,            Relu, 1, 1, 678, 432
 10,          Concat, 2, 1, 471, 472
 11,          Concat, 6, 1, 472, 475
 12,         Reshape, 2, 1, 475, 483
 13,           Slice, 1, 1, 464, 487
 14,         Reshape, 2, 1, 487, 501
 15,         Reshape, 2, 1, 501, 508
Input tensor name -  464
Input tensor name -  384
Input tensor name -  234
Output tensor name - 508
Output tensor name - 475
Output tensor name - 483
Compute on node : TIDLExecutionProvider_TIDL_4_4
  0,         Reshape, 2, 1, 509, 511
Input tensor name -  509
Output tensor name - 511
Compute on node : TIDLExecutionProvider_TIDL_5_5
  0,           Slice, 1, 1, 464, 488
  1,         Reshape, 2, 1, 488, reshape_out_Sub_231
  2,             Add, 2, 1, reshape_out_Sub_231, add_out_Sub_231
  3,         Reshape, 2, 1, add_out_Sub_231, 514
Output tensor name - 514
Compute on node : TIDLExecutionProvider_TIDL_6_6
  0,           Slice, 1, 1, 454, 459
  1,         Reshape, 2, 1, 515, 523
  2,       Transpose, 1, 1, 523, out_Transpose_305
  3,            Conv, 3, 1, out_Transpose_305, out_Conv_313
  4,            Relu, 1, 1, out_Conv_313, out_Relu_314
  5,            Conv, 3, 1, out_Relu_314, out_Conv_315
  6,         Squeeze, 1, 1, out_Conv_315, 598
  7,       Transpose, 1, 1, 598, 599
Input tensor name -  515
Input tensor name -  454
Output tensor name - 523
Output tensor name - 599
Output tensor name - 459
Compute on node : TIDLExecutionProvider_TIDL_7_7
  0,         Reshape, 2, 1, 475, 547
  1,           Slice, 1, 1, 528, 551
  2,         Reshape, 2, 1, 551, 565
  3,         Reshape, 2, 1, 565, 572
Input tensor name -  528
Input tensor name -  475
Output tensor name - 572
Output tensor name - 547
Compute on node : TIDLExecutionProvider_TIDL_8_8
  0,         Reshape, 2, 1, 573, 575
Input tensor name -  573
Output tensor name - 575
Compute on node : TIDLExecutionProvider_TIDL_9_9
  0,           Slice, 1, 1, 528, 552
  1,         Reshape, 2, 1, 552, reshape_out_Sub_281
  2,             Add, 2, 1, reshape_out_Sub_281, add_out_Sub_281
  3,         Reshape, 2, 1, add_out_Sub_281, 578
Output tensor name - 578
Compute on node : TIDLExecutionProvider_TIDL_10_10
  0,         Reshape, 2, 1, 447, output_dict_list
  1,         Reshape, 2, 1, seeds, output_seeds
  2,         Reshape, 2, 1, 579, 587
Input tensor name -  579
Input tensor name -  seeds
Input tensor name -  447
Output tensor name - 587
Output tensor name - output_seeds
Output tensor name - output_dict_list
***************Running_Inference Section **********
This is Lucid Model for image /home/root/lucid/data_onnx/test_images/img0221.png
 Graph Domain TO version : 9In TIDL_onnxRtImportInit subgraph_name=subgraph_0
Layer 0, subgraph id subgraph_0, name=234
Layer 1, subgraph id subgraph_0, name=384
Layer 2, subgraph id subgraph_0, name=414
Layer 3, subgraph id subgraph_0, name=437
Layer 4, subgraph id subgraph_0, name=439
Layer 5, subgraph id subgraph_0, name=460
Layer 6, subgraph id subgraph_0, name=524
Layer 7, subgraph id subgraph_0, name=image
In TIDL_runtimesOptimizeNet: LayerIndex = 114, dataIndex = 107
WARNING: Batch Norm Layer custom_added_Mul0's coeff cannot be found(or not match) in coef file, Random bias will be generated! Only for evaluation usage! Results are all random!
WARNING: Batch Norm Layer custom_added_Mul1's coeff cannot be found(or not match) in coef file, Random bias will be generated! Only for evaluation usage! Results are all random!
 ************** Frame index 1 : Running float import *************
In TIDL_runtimesPostProcessNet
In TIDL_runtimesPostProcessNet 1
In TIDL_runtimesPostProcessNet 2
In TIDL_runtimesPostProcessNet 3
INFORMATION: [TIDL_ResizeLayer] Upsample_139 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
**          1 WARNINGS          0 ERRORS          **
In TIDL_runtimesPostProcessNet 4
************ in TIDL_subgraphRtCreate ************
 The soft limit is 2048
The hard limit is 2048
MEM: Init ... !!!
MEM: Init ... Done !!!
 0.0s:  VX_ZONE_INIT:Enabled
 0.8s:  VX_ZONE_ERROR:Enabled
 0.10s:  VX_ZONE_WARNING:Enabled
 0.2258s:  VX_ZONE_INIT:[tivxInit:185] Initialization Done !!!
TIDL_initDebugTraceParams Done
TIDL Memory size requiement (record wise):
MemRecNum   , Space               , Attribute   , Alignment   , Size(KBytes), BasePtr
0           , DDR Cacheable       , Persistent  ,  128, 19.25   , 0x00000000
1           , DDR Cacheable       , Persistent  ,  128, 0.64    , 0x00000000
2           , DDR Cacheable       , Scratch     ,  128, 16.00   , 0x00000000
3           , DDR Cacheable       , Scratch     ,  128, 4.00    , 0x00000000
4           , DDR Cacheable       , Scratch     ,  128, 56.00   , 0x00000000
5           , DDR Cacheable       , Persistent  ,  128, 537.00  , 0x00000000
6           , DDR Cacheable       , Scratch     ,  128, 70188.19, 0x00000000
7           , DDR Cacheable       , Scratch     ,  128, 0.12    , 0x00000000
8           , DDR Cacheable       , Scratch     ,  128, 24511.25, 0x00000000
9           , DDR Cacheable       , Scratch     ,  128, 32684.50, 0x00000000
10          , DDR Cacheable       , Persistent  ,  128, 1589.58 , 0x00000000
11          , DDR Cacheable       , Scratch     ,  128, 512.25  , 0x00000000
12          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x00000000
13          , DDR Cacheable       , Persistent  ,  128, 52728.01, 0x00000000
14          , DDR Cacheable       , Persistent  ,  128, 0.00    , 0x00000000
Total memory size requirement (space wise):
Mem Space , Size(KBytes)
DDR Cacheable, 182846.92
NOTE: Memory requirement in host emulation can be different from the same on EVM
      To get the actual TIDL memory requirement make sure to run on EVM with
      debugTraceLevel = 2
TIDL init call from ivision API
0           , DDR Cacheable       , Persistent  ,  128, 19.25   , 0x9578e000
1           , DDR Cacheable       , Persistent  ,  128, 0.64    , 0xb29bd000
2           , DDR Cacheable       , Scratch     ,  128, 16.00   , 0xb2728000
3           , DDR Cacheable       , Scratch     ,  128, 4.00    , 0xb2066000
4           , DDR Cacheable       , Scratch     ,  128, 56.00   , 0x33ecb000
5           , DDR Cacheable       , Persistent  ,  128, 537.00  , 0x25679000
6           , DDR Cacheable       , Scratch     ,  128, 70188.19, 0x97b74000
7           , DDR Cacheable       , Scratch     ,  128, 0.12    , 0xaf83d000
8           , DDR Cacheable       , Scratch     ,  128, 24511.25, 0xa246e000
9           , DDR Cacheable       , Scratch     ,  128, 32684.50, 0xa0482000
10          , DDR Cacheable       , Persistent  ,  128, 1589.58 , 0xa02f4000
11          , DDR Cacheable       , Scratch     ,  128, 512.25  , 0xe3a4d000
12          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x9d52d000
13          , DDR Cacheable       , Persistent  ,  128, 52728.01, 0x947f5000
14          , DDR Cacheable       , Persistent  ,  128, 0.00    , 0x9ce07000
      debugTraceLevel = 2
Alg Init for Layer # -    1
Alg Init for Layer # -    2
Alg Init for Layer # -    3
Alg Init for Layer # -    4
Alg Init for Layer # -    5
Alg Init for Layer # -    6
Alg Init for Layer # -    7
Alg Init for Layer # -    8
Alg Init for Layer # -    9
Alg Init for Layer # -   10
Alg Init for Layer # -   11
Alg Init for Layer # -   12
Alg Init for Layer # -   13
Alg Init for Layer # -   14
Alg Init for Layer # -   15
Alg Init for Layer # -   16
Alg Init for Layer # -   17
Alg Init for Layer # -   18
Alg Init for Layer # -   19
Alg Init for Layer # -   20
Alg Init for Layer # -   21
Alg Init for Layer # -   22
Alg Init for Layer # -   23
Alg Init for Layer # -   24
Alg Init for Layer # -   25
Alg Init for Layer # -   26
Alg Init for Layer # -   27
Alg Init for Layer # -   28
Alg Init for Layer # -   29
Alg Init for Layer # -   30
Alg Init for Layer # -   31
Alg Init for Layer # -   32
Alg Init for Layer # -   33
Alg Init for Layer # -   34
Alg Init for Layer # -   35
Alg Init for Layer # -   37
Alg Init for Layer # -   38
Alg Init for Layer # -   39
Alg Init for Layer # -   40
Alg Init for Layer # -   41
Alg Init for Layer # -   42
Alg Init for Layer # -   43
Alg Init for Layer # -   44
Alg Init for Layer # -   45
Alg Init for Layer # -   46
Alg Init for Layer # -   47
Alg Init for Layer # -   48
Alg Init for Layer # -   49
Alg Init for Layer # -   50
Alg Init for Layer # -   51
Alg Init for Layer # -   52
Alg Init for Layer # -   53
Alg Init for Layer # -   54
Alg Init for Layer # -   55
Alg Init for Layer # -   56
Alg Init for Layer # -   57
Alg Init for Layer # -   58
Alg Init for Layer # -   59
Alg Init for Layer # -   60
Alg Init for Layer # -   61
Alg Init for Layer # -   62
Alg Init for Layer # -   63
Alg Init for Layer # -   64
Alg Init for Layer # -   65
Alg Init for Layer # -   66
Alg Init for Layer # -   67
Alg Init for Layer # -   68
Alg Init for Layer # -   69
Alg Init for Layer # -   70
Alg Init for Layer # -   71
Alg Init for Layer # -   72
Alg Init for Layer # -   73
Alg Init for Layer # -   74
Alg Init for Layer # -   75
Alg Init for Layer # -   76
Alg Init for Layer # -   77
Alg Init for Layer # -   78
Alg Init for Layer # -   79
Alg Init for Layer # -   80
Alg Init for Layer # -   81
Alg Init for Layer # -   82
Alg Init for Layer # -   83
Alg Init for Layer # -   84
Alg Init for Layer # -   85
Alg Init for Layer # -   86
Alg Init for Layer # -   87
Alg Init for Layer # -   88
Alg Init for Layer # -   89
Alg Init for Layer # -   90
Alg Init for Layer # -   91
Alg Init for Layer # -   92
Alg Init for Layer # -   93
Alg Init for Layer # -   94
Alg Init for Layer # -   95
Alg Init for Layer # -   96
Alg Init for Layer # -   97
Alg Init for Layer # -   98
Alg Init for Layer # -   99
Alg Init for Layer # -  100
Alg Init for Layer # -  101
Alg Init for Layer # -  102
Alg Init for Layer # -  103
Alg Init for Layer # -  104
Alg Init for Layer # -  105
Alg Init for Layer # -  106
Alg Init for Layer # -  107
Alg Init for Layer # -  108
Alg Init for Layer # -  109
Alg Init for Layer # -  110
Alg Init for Layer # -  111
Alg Init for Layer # -  112
Alg Init for Layer # -  113
Alg Init for Layer # -  114
Alg Init for Layer # -  115
Alg Init for Layer # -  116
Alg Init for Layer # -  117
Alg Init for Layer # -  118
Alg Init for Layer # -  119
Alg Init for Layer # -  120
Alg Init for Layer # -  121
Alg Init for Layer # -  122
Alg Init for Layer # -  123
Alg Init for Layer # -  124
Alg Init for Layer # -  125
Alg Init for Layer # -  126
Alg Init for Layer # -  127
Alg Init for Layer # -  128
Alg Init for Layer # -  129
Alg Init for Layer # -  134
Alg Init for Layer # -  135
Alg Init for Layer # -  136
Alg Init for Layer # -  137
Alg Init for Layer # -  138
Alg Init for Layer # -  139
Alg Init for Layer # -  140
Alg Init for Layer # -  141
Alg Init for Layer # -  142
Alg Init for Layer # -  143
Alg Init for Layer # -  144
Alg Init for Layer # -  145
Alg Init for Layer # -  146
Alg Init for Layer # -  147
PREEMPTION: Adding a new priority object for targetPriority = 2, handle = 0x7d449578e000
PREEMPTION: Now total number of priority objects = 1 at priorityId = 2,    with new memRec of base = 0x7d449d52d000 and size = 128
PREEMPTION: Requesting context memory addr for handle 0x7d449578e000, return Addr = 0x7d43cc039db8
************ TIDL_subgraphRtCreate done ************
**********  Frame Index 1 : Running float inference **********
 Graph Domain TO version : 9In TIDL_onnxRtImportInit subgraph_name=subgraph_1
Layer 0, subgraph id subgraph_1, name=446
Layer 1, subgraph id subgraph_1, name=440
Layer 2, subgraph id subgraph_1, name=414
In TIDL_runtimesOptimizeNet: LayerIndex = 8, dataIndex = 7
**                ALL MODEL CHECK PASSED          **
5           , DDR Cacheable       , Persistent  ,  128, 320.00  , 0x00000000
6           , DDR Cacheable       , Scratch     ,  128, 32.75   , 0x00000000
8           , DDR Cacheable       , Scratch     ,  128, 47.00   , 0x00000000
9           , DDR Cacheable       , Scratch     ,  128, 65.50   , 0x00000000
10          , DDR Cacheable       , Persistent  ,  128, 302.89  , 0x00000000
13          , DDR Cacheable       , Persistent  ,  128, 6290.82 , 0x00000000
DDR Cacheable, 7667.35
      debugTraceLevel = 2
0           , DDR Cacheable       , Persistent  ,  128, 19.25   , 0x91a2a000
1           , DDR Cacheable       , Persistent  ,  128, 0.64    , 0x92936000
2           , DDR Cacheable       , Scratch     ,  128, 16.00   , 0x44c29000
3           , DDR Cacheable       , Scratch     ,  128, 4.00    , 0x92935000
4           , DDR Cacheable       , Scratch     ,  128, 56.00   , 0x283a1000
5           , DDR Cacheable       , Persistent  ,  128, 320.00  , 0x1f089000
6           , DDR Cacheable       , Scratch     ,  128, 32.75   , 0x43ea3000
7           , DDR Cacheable       , Scratch     ,  128, 0.12    , 0x92934000
8           , DDR Cacheable       , Scratch     ,  128, 47.00   , 0x2566d000
9           , DDR Cacheable       , Scratch     ,  128, 65.50   , 0x187ef000
10          , DDR Cacheable       , Persistent  ,  128, 302.89  , 0xe91b4000
11          , DDR Cacheable       , Scratch     ,  128, 512.25  , 0xe367f000
12          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x922a9000
13          , DDR Cacheable       , Persistent  ,  128, 6290.82 , 0xa70d7000
14          , DDR Cacheable       , Persistent  ,  128, 0.00    , 0x922a8000
      debugTraceLevel = 2
PREEMPTION: Adding a new priority object for targetPriority = 2, handle = 0x7d4491a2a000
PREEMPTION: Now total number of priority objects = 2 at priorityId = 2,    with new memRec of base = 0x7d44922a9000 and size = 128
PREEMPTION: Requesting context memory addr for handle 0x7d4491a2a000, return Addr = 0x7d43cc039db8
 Graph Domain TO version : 9In TIDL_onnxRtImportInit subgraph_name=subgraph_2
Layer 0, subgraph id subgraph_2, name=seeds
Layer 1, subgraph id subgraph_2, name=454
Layer 2, subgraph id subgraph_2, name=458
Layer 3, subgraph id subgraph_2, name=448
In TIDL_runtimesOptimizeNet: LayerIndex = 7, dataIndex = 4
5           , DDR Cacheable       , Persistent  ,  128, 260.64  , 0x00000000
6           , DDR Cacheable       , Scratch     ,  128, 1.67    , 0x00000000
8           , DDR Cacheable       , Scratch     ,  128, 4.88    , 0x00000000
9           , DDR Cacheable       , Scratch     ,  128, 9.28    , 0x00000000
13          , DDR Cacheable       , Persistent  ,  128, 6233.32 , 0x00000000
DDR Cacheable, 7421.07
      debugTraceLevel = 2
0           , DDR Cacheable       , Persistent  ,  128, 19.25   , 0x2839c000
1           , DDR Cacheable       , Persistent  ,  128, 0.64    , 0x2566c000
2           , DDR Cacheable       , Scratch     ,  128, 16.00   , 0x187d4000
3           , DDR Cacheable       , Scratch     ,  128, 4.00    , 0x1f088000
4           , DDR Cacheable       , Scratch     ,  128, 56.00   , 0xe91a6000
5           , DDR Cacheable       , Persistent  ,  128, 260.64  , 0xe00b3000
6           , DDR Cacheable       , Scratch     ,  128, 1.67    , 0x1f087000
7           , DDR Cacheable       , Scratch     ,  128, 0.12    , 0x187d3000
8           , DDR Cacheable       , Scratch     ,  128, 4.88    , 0x187d1000
9           , DDR Cacheable       , Scratch     ,  128, 9.28    , 0x187ce000
10          , DDR Cacheable       , Persistent  ,  128, 302.89  , 0xe0067000
11          , DDR Cacheable       , Scratch     ,  128, 512.25  , 0xd3f7f000
12          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x187cd000
13          , DDR Cacheable       , Persistent  ,  128, 6233.32 , 0xa6ac0000
14          , DDR Cacheable       , Persistent  ,  128, 0.00    , 0x187cc000
      debugTraceLevel = 2
PREEMPTION: Adding a new priority object for targetPriority = 2, handle = 0x7d442839c000
PREEMPTION: Now total number of priority objects = 3 at priorityId = 2,    with new memRec of base = 0x7d44187cd000 and size = 128
PREEMPTION: Requesting context memory addr for handle 0x7d442839c000, return Addr = 0x7d43cc039db8
 Warning : Couldn't find corresponding ioBuf tensor for onnx tensor with matching name
2024-05-22 11:54:38.782101957 [E:onnxruntime:, sequential_executor.cc:494 ExecuteKernel] Non-zero status code returned while running Gather node. Name:'Gather_207' Status Message: /onnxruntime/onnxruntime/core/framework/op_kernel.cc:83 virtual OrtValue* onnxruntime::OpKernelContext::OutputMLValue(int, const onnxruntime::TensorShape&) status.IsOK() was false. Shape mismatch attempting to re-use buffer. {1,1,1,1,1,6 } != {1,1,1,6,67}. Validate usage of dim_value (values should be > 0) and dim_param (all values with the same string should equate to the same size) in shapes in the model.
Traceback (most recent call last):
  File "/home/root/examples/osrt_python/ort/onnxrt_ep_dock927_condlanet_fp32.py", line 434, in <module>
    run_model(model, mIdx)
  File "/home/root/examples/osrt_python/ort/onnxrt_ep_dock927_condlanet_fp32.py", line 332, in run_model
    imgs, output, proc_time, sub_graph_time, height, width,org_imgs,img_name  = infer_image(sess, input_images, config)
  File "/home/root/examples/osrt_python/ort/onnxrt_ep_dock927_condlanet_fp32.py", line 189, in infer_image
    output = list(sess.run(None, {input_name: input_data }))
  File "/usr/local/lib/python3.10/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py", line 200, in run
    return self._sess.run(output_names, input_feed, run_options)
onnxruntime.capi.onnxruntime_pybind11_state.RuntimeException: [ONNXRuntimeError] : 6 : RUNTIME_EXCEPTION : Non-zero status code returned while running Gather node. Name:'Gather_207' Status Message: /onnxruntime/onnxruntime/core/framework/op_kernel.cc:83 virtual OrtValue* onnxruntime::OpKernelContext::OutputMLValue(int, const onnxruntime::TensorShape&) status.IsOK() was false. Shape mismatch attempting to re-use buffer. {1,1,1,1,1,6} != {1,1,1,6,67}. Validate usage of dim_value (values should be > 0) and dim_param (all values with the same string should equate to the same size) in shapes in the model.
************ in TIDL_subgraphRtDelete ************
 PREEMPTION: Removing priroty object with handle = 0x7d449578e000 and targetPriority = 2,      Number of obejcts left are = 2, removed object with base  = 0x7d44922a9000 and size =128
 PREEMPTION: Removing priroty object with handle = 0x7d4491a2a000 and targetPriority = 2,      Number of obejcts left are = 1, removed object with base  = 0x7d44187cd000 and size =128
 PREEMPTION: Removing priroty object with handle = 0x7d442839c000 and targetPriority = 2,      Number of obejcts left are = 0, removed object with base  = 0x7d449d52d000 and size =128
MEM: Deinit ... !!!
MEM: Alloc's: 84 alloc's of 285425743 bytes
MEM: Free's : 84 free's  of 285425743 bytes
MEM: Open's : 0 allocs  of 0 bytes
MEM: Deinit ... Done !!!
Segmentation fault (core dumped)
  • Hi Abhilash,
    Firstly wanted to understand that is this the same model that you have shared to us via email ? And was the OSRT inference without tidl offload was successful ?
    From the logs its seems like Gather_207 was added in deny list and during arm execution it thrown the error, osrt inference without tidl offload logs will add some clarify about this.
  • Yes the model is shared with you through mail
    PFA
    oot@30229850e11c:/home/root/examples/osrt_python/ort# python3 onnxrt_ep_dock927_condlanet_fp32.py -c | tee log_condlanet_slicev2_c.txt
    debug_level                                     = 6
    tidl_denylist                                   =
    model_type                                      =
    model_group_id = 0
    Layer 98 -- layer name -- Div_186
    Supported TIDL layer type ---             Div -- Div_186
    Layer 108 -- layer name -- Gather_207
    Unsupported (TIDL check) TIDL layer type ---          Gather
    Layer 116 -- layer name -- Gather_209
     Input dims size = 2     dims --- 8000   67
    Supported TIDL layer type ---          Gather -- Gather_209
    Layer 143 -- layer name -- Reshape_312
     Input dims size = 4     dims --- 1   6   100   40
    Supported TIDL layer type ---         Reshape -- Reshape_312
    Layer 144 -- layer name -- Conv_313
     Input dims size = 3     dims --- 6   100   40
    Unsupported (TIDL check) TIDL layer type ---            Conv
    Layer 145 -- layer name -- Relu_314
     Input dims size = 3     dims --- 6   64   40
    Layer 146 -- layer name -- Conv_315
    Layer 149 -- layer name -- Gather_257
    Layer 151 -- layer name -- Gather_259
    Supported TIDL layer type ---          Gather -- Gather_259
    Preliminary subgraphs created = 12
    Final number of subgraphs created are : 10, - Offloaded Nodes - 156, Total Nodes - 167
    ALLOWLISTING : Unsupported axis configuration for gather layer!, only line gather is supported  --  file info - tidl_import_common_model_check.cpp , TIDL_checkGatherTensorProperties , 825
    WARNING -- [TIDL_ConvolutionLayer]  Layer parameter combination has undergone limited validation and may have some issues. Following are the parameters:
            Kernel 1x0 Stride 1x1 dilation 1x1 Pad 0x0 Bias 1
     89,            Conv, 3, 1, 391, 395
     90,            Relu, 1, 1, 395, 396
     91,            Conv, 3, 1, 396, 397
     92,         Sigmoid, 1, 1, 397, 413
     93,            Clip, 1, 1, 413, 414
     94,         MaxPool, 1, 1, 414, 436
     95,             Mul, 2, 1, 414, mul_out_Sub_183
     96,             Add, 2, 1, mul_out_Sub_183, 437
     97,             Add, 2, 1, 437, 439
     98,             Div, 2, 1, 437, 440
     99,             Mul, 2, 1, 440, mul_out_Sub_188
    100,             Add, 2, 1, mul_out_Sub_188, 442
    101,             Mul, 2, 1, 414, 443
    102,         Squeeze, 1, 1, 443, 444
    103,         Reshape, 2, 1, 444, 446
    Output tensor name - 391
      0,            Conv, 3, 1, 391, 398
      1,            Relu, 1, 1, 398, 399
      2,            Conv, 3, 1, 399, 400
      3,         Reshape, 2, 1, 400, 423
      4,       Transpose, 1, 1, 423, 433
      5,         Reshape, 2, 1, 433, 435
      7,          Gather, 2, 1, 460, 464
      8,           Slice, 1, 1, 464, 488
      9,         Reshape, 2, 1, 488, reshape_out_Sub_231
     10,             Add, 2, 1, reshape_out_Sub_231, add_out_Sub_231
     11,         Reshape, 2, 1, add_out_Sub_231, 514
     12,            Conv, 3, 1, 234, 377
     13,        Upsample, 2, 1, 384, 388
     14,             Add, 2, 1, 377, 389
     15,            Conv, 3, 1, 389, 390
     16,            Conv, 3, 1, 390, 672
     17,            Relu, 1, 1, 672, 426
     18,            Conv, 3, 1, 426, 675
     19,            Relu, 1, 1, 675, 429
     20,            Conv, 3, 1, 429, 678
     21,            Relu, 1, 1, 678, 432
     22,          Concat, 2, 1, 471, 472
     23,          Concat, 6, 1, 472, 475
     24,         Reshape, 2, 1, 475, 483
     25,           Slice, 1, 1, 464, 487
     26,         Reshape, 2, 1, 487, 501
     27,         Reshape, 2, 1, 501, 508
    Input tensor name -  391
    Input tensor name -  462
    Output tensor name - 435
      0,         Reshape, 2, 1, 515, 523
      1,       Transpose, 1, 1, 523, 588
      2,         Reshape, 2, 1, 588, 595
    Output tensor name - 595
      0,            Relu, 1, 1, 596, 597
    Input tensor name -  596
    Output tensor name - 597
      1,       Transpose, 1, 1, 598, 599
    Input tensor name -  598
      0,           Slice, 1, 1, 435, 524
      1,          Gather, 2, 1, 524, 528
      2,           Slice, 1, 1, 528, 552
      3,         Reshape, 2, 1, 552, reshape_out_Sub_281
      4,             Add, 2, 1, reshape_out_Sub_281, add_out_Sub_281
      5,         Reshape, 2, 1, add_out_Sub_281, 578
      6,         Reshape, 2, 1, 475, 547
      7,           Slice, 1, 1, 528, 551
      8,         Reshape, 2, 1, 551, 565
      9,         Reshape, 2, 1, 565, 572
    Input tensor name -  435
    Input tensor name -  526
    Warning: FFFFFF is not a known color.
    Layer 2, subgraph id subgraph_0, name=391
    Layer 3, subgraph id subgraph_0, name=446
    Layer 4, subgraph id subgraph_0, name=image
    In TIDL_runtimesOptimizeNet: LayerIndex = 109, dataIndex = 105
    MEM: Init ... !!!
     0.4s:  VX_ZONE_ERROR:Enabled
     0.4s:  VX_ZONE_WARNING:Enabled
     0.1763s:  VX_ZONE_INIT:[tivxInit:185] Initialization Done !!!
    2           , L1D                 , Scratch     ,  128, 16.00   , 0x00000000
    3           , L2                  , Scratch     ,  128, 4.00    , 0x00000000
    4           , L3/MSMC             , Scratch     ,  128, 56.00   , 0x00000000
    5           , DDR Cacheable       , Persistent  ,  128, 586.88  , 0x00000000
    6           , DDR Cacheable       , Scratch     ,  128, 45090.69, 0x00000000
    7           , L1D                 , Scratch     ,    0, 0.00    , 0x00000000
    9           , L1D                 , Scratch     ,    0, 0.00    , 0x00000000
    10          , DDR Cacheable       , Persistent  ,  128, 1457.12 , 0x00000000
    12          , L1D                 , Scratch     ,    0, 0.00    , 0x00000000
    13          , L1D                 , Scratch     ,    0, 0.00    , 0x00000000
    L1D       , 16.00
    L2        , 4.00
    L3/MSMC   , 56.00
    DDR Cacheable, 72178.08
          debugTraceLevel = 2
     0.35371s:  VX_ZONE_ERROR:[tivxAlgiVisionCreate:363] Calling ialg.algAlloc failed with status = -1120
     0.35395s:  VX_ZONE_ERROR:[tivxKernelTIDLCreate:926] tivxAlgiVisionCreate returned NULL
     0.35499s:  VX_ZONE_ERROR:[ownContextSendCmd:822] Command ack message returned failure cmd_status: -1
     0.35501s:  VX_ZONE_ERROR:[ownContextSendCmd:862] tivxEventWait() failed.
     0.35502s:  VX_ZONE_ERROR:[ownNodeKernelInit:584] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
     0.35503s:  VX_ZONE_ERROR:[ownNodeKernelInit:585] Please be sure the target callbacks have been registered for this core
     0.35504s:  VX_ZONE_ERROR:[ownNodeKernelInit:586] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
     0.35506s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:4 ... failed !!!
     0.35509s:  VX_ZONE_ERROR:[vxVerifyGraph:2059] Node kernel init failed
     0.35510s:  VX_ZONE_ERROR:[vxVerifyGraph:2113] Graph verify failed
    TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
    TIDL_RT_OVX: ERROR: Verify OpenVX graph failed
    Layer 0, subgraph id subgraph_1, name=seeds
    Layer 1, subgraph id subgraph_1, name=454
    Layer 2, subgraph id subgraph_1, name=458
    Layer 3, subgraph id subgraph_1, name=448
          debugTraceLevel = 2
    0           , DDR Cacheable       , Persistent  ,  128, 19.25   , 0x0e6e9000
    1           ,2024-05-20 15:17:45.709887924 [E:onnxruntime:, sequential_executor.cc:494 ExecuteKernel] Non-zero status code returned while running Gather node. Name:'Gather_207' Status Message: /onnxruntime/onnxruntime/core/framework/op_kernel.cc:83 virtual OrtValue* onnxruntime::OpKernelContext::OutputMLValue(int, const onnxruntime::TensorShape&) status.IsOK() was false. Shape mismatch attempting to re-use buffer. {1,1,1,1,1,6} != {1,1,1,6,67}. Validate usage of dim_value (values should be > 0) and dim_param (all values with the same string should equate to the same size) in shapes in the model.
      File "/home/root/examples/osrt_python/ort/onnxrt_ep_dock927_condlanet_fp32.py", line 431, in <module>
     DDR Cacheable       , Persistent  ,  128, 0.64    , 0x0e6e8000
    2           , DDR Cacheable       , Scratch     ,  128, 16.00   , 0x032ab000
    3           , DDR Cacheable       , Scratch     ,  128, 4.00    , 0x0e6e7000
    4           , DDR Cacheable       , Scratch     ,  128, 56.00   , 0xb4eb8000
    5           , DDR Cacheable       , Persistent  ,  128, 260.64  , 0x993be000
    6           , DDR Cacheable       , Scratch     ,  128, 1.67    , 0x0e6e6000
    7           , DDR Cacheable       , Scratch     ,  128, 0.12    , 0x0e6e5000
    8           , DDR Cacheable       , Scratch     ,  128, 4.88    , 0x032a9000
    9           , DDR Cacheable       , Scratch     ,  128, 9.28    , 0x02e0b000
    10          , DDR Cacheable       , Persistent  ,  128, 302.89  , 0x966b4000
    11          , DDR Cacheable       , Scratch     ,  128, 512.25  , 0x54c4d000
    12          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x03b34000
    13          , DDR Cacheable       , Persistent  ,  128, 6233.32 , 0x177b2000
    14          , DDR Cacheable       , Persistent  ,  128, 0.00    , 0x032a8000
          debugTraceLevel = 2
    PREEMPTION: Adding a new priority object for targetPriority = 2, handle = 0x7bcb0e6e9000
    PREEMPTION: Now total number of priority objects = 1 at priorityId = 2,    with new memRec of base = 0x7bcb03b34000 and size = 128
    PREEMPTION: Requesting context memory addr for handle 0x7bcb0e6e9000, return Addr = 0x7bca34039db8
      File "/home/root/examples/osrt_python/ort/onnxrt_ep_dock927_condlanet_fp32.py", line 329, in run_model
      File "/home/root/examples/osrt_python/ort/onnxrt_ep_dock927_condlanet_fp32.py", line 186, in infer_image
  • Hi Abhilash,
    Thank for confirmation on model front.
    As discussed in condlane thread here : https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1352963/tda4vm-edge-ai-duplicate-definition-of-name
    We have highlighted TIDL float 32 pass issue (same as per shared logs in this thread) adding it here for better reference.
    I happen to recall (can you confirm as well) for condlane model OSRT(ONNX-RT) inference without TIDL offload(-d)  is working correctly right ? This make clear that operator failing in deny list mentioned here (gather_207) executed correctly.
    The above observation on adding gather to deny list is reproducible at my end.
    I have tried couple of other experiment along the same way to validate few things detailed observations are listed in JIRA.
    Adding JIRA link for TIs internal tracking purpose.
    https://jira.itg.ti.com/browse/TIDL-4049
