TDA4VL-Q1: Capture node frame tearing
Part Number: TDA4VL-Q1
Hi TI experts,
HW: our custom board
SDK: j721s2, 8.6
Frame tearing occurs occasionally in our vision_apps application, the following is the application output log. How to resolve it? Could you give me some suggestions?
Summary of CPU load,
CPU: mpu1_0: TOTAL LOAD =  47.37 % ( HWI =   1.80 %, SWI =   0.32 % )
CPU: mcu2_0: TOTAL LOAD =  36. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
CPU:  c7x_1: TOTAL LOAD =  49. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
CPU:  c7x_2: TOTAL LOAD =  48. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
HWA performance statistics,
HWA:   LDC : LOAD =  39.56 % ( 167 MP/s )
HWA:   MSC0: LOAD =  12.30 % ( 61 MP/s )
HWA:   MSC1: LOAD =   6.11 % ( 31 MP/s )
HWA:   GPU : LOAD =  63.67 % | PVR_LOAD =  39% ( 85 MP/s )
DDR performance statistics,
DDR: READ  BW: AVG =   2780 MB/s, PEAK =  10199 MB/s
DDR: WRITE BW: AVG =   1627 MB/s, PEAK =   7888 MB/s
DDR: TOTAL BW: AVG =   4407 MB/s, PEAK =  18087 MB/s
GRAPH:        avm_graph (#nodes =   8, #executions =   1037)
 NODE:       CAPTURE1:             capture_node: avg =  16467 usecs, min/max =    172 /  76329 usecs, #executions =       1037
 NODE:      VPAC_LDC1:                  ldc_avm: avg =  11723 usecs, min/max =   8811 /  17962 usecs, #executions =       1037
 NODE:          A72-2:      OpenGL_APS_SRV_Node: avg =  23604 usecs, min/max =  18684 /  53821 usecs, #executions =       1037
 NODE:       DSS_M2M2:             CsitxM2mNode: avg =   4806 usecs, min/max =   4122 /   5661 usecs, #executions =       1037
 NODE:          CSITX:                CsitxNode: avg =  17543 usecs, min/max =  16693 /  20150 usecs, #executions =       1037
 NODE:       DSS_M2M2:           DisplayM2mNode: avg =   2998 usecs, min/max =   2511 /   5055 usecs, #executions =       1037
 NODE:          A72-0:     PARKLANE_DETECT_NODE: avg =     29 usecs, min/max =     16 /    135 usecs, #executions =       1037
 NODE:      VPAC_LDC1:                 ldc_node: avg =  12377 usecs, min/max =   8852 /  19390 usecs, #executions =       1037
 PERF:         AvmGraph: avg =  42427 usecs, min/max =  21092 / 145779 usecs, #executions =       1037
 PERF:         AvmGraph:   23.56 FPS
GRAPH:   avm_graph_tidl (#nodes =   8, #executions =   1038)
 NODE:      VPAC_MSC2:               ScalerNode: avg =   3680 usecs, min/max =   3311 /   9433 usecs, #executions =       1038
 NODE:          DSP-1:            SDPreProcNode: avg =   2302 usecs, min/max =   1439 /  12666 usecs, #executions =       1038
 NODE:       DSP_C7-1:          StopperTIDLNode: avg =   7281 usecs, min/max =   5809 /   8956 usecs, #executions =       1038
 NODE:          DSP-1:      PostProcStopperNode: avg =     74 usecs, min/max =     16 /  15421 usecs, #executions =       1038
 NODE:       DSP_C7-1:               SDTIDLNode: avg =   6578 usecs, min/max =   5259 /   8121 usecs, #executions =       1038
 NODE:          DSP-1:           PostProcSdNode: avg =     82 usecs, min/max =     56 /   5935 usecs, #executions =       1038
 NODE:          A72-0:        LZQSlotFusionNode: avg =     50 usecs, min/max =     20 /   1103 usecs, #executions =       1038
 NODE:          DSP-1:    LZQDrawDetectionsNode: avg =   5008 usecs, min/max =   1669 /  23341 usecs, #executions =       1038
 PERF:     AvmTidlGraph: avg =  42426 usecs, min/max =  21089 / 144281 usecs, #executions =       1037
 PERF:     AvmTidlGraph:   23.57 FPS
GRAPH:       tidl_graph (#nodes =   5, #executions =    510)
 NODE:      VPAC_MSC1:               ScalerNode: avg =  14966 usecs, min/max =  13488 /  22775 usecs, #executions =        510
 NODE:          DSP-1:           img_merge_node: avg =    347 usecs, min/max =    237 /   5785 usecs, #executions =        510
 NODE:          DSP-1:            ODPreProcNode: avg =   3062 usecs, min/max =   1916 /  21890 usecs, #executions =        510
 NODE:       DSP_C7-1:               ODTIDLNode: avg =  22571 usecs, min/max =  18442 /  25889 usecs, #executions =        510
 NODE:          A72-0:           AVM Putod Node: avg =    437 usecs, min/max =     18 /   9169 usecs, #executions =        510
 PERF:        TidlGraph: avg =  86527 usecs, min/max =  67075 / 181440 usecs, #executions =        508
 PERF:        TidlGraph:   11.55 FPS
[MCU2_0]     65.841589 s: ==========================================================
[MCU2_0]     65.841724 s:  Capture Status: Instance|0
[MCU2_0]     65.841761 s: ==========================================================
[MCU2_0]     65.841814 s:  overflowCount: 0
[MCU2_0]     65.841853 s:  spuriousUdmaIntrCount: 0
[MCU2_0]     65.841941 s:  frontFIFOOvflCount: 0
[MCU2_0]     65.841993 s:  crcCount: 0
[MCU2_0]     65.842029 s:  eccCount: 0
[MCU2_0]     65.842063 s:  correctedEccCount: 0
[MCU2_0]     65.842103 s:  dataIdErrorCount: 0
[MCU2_0]     65.842141 s:  invalidAccessCount: 0
[MCU2_0]     65.842179 s:  invalidSpCount: 0
[MCU2_0]     65.842221 s:  strmFIFOOvflCount[0]: 0
[MCU2_0]     65.842273 s:  strmFIFOOvflCount[1]: 0
[MCU2_0]     65.842317 s:  Channel Num | Frame Queue Count | Frame De-queue Count | Frame Drop Count | Error Frame Count |
[MCU2_0]     65.842407 s:            0 |              1041 |                 1039 |               61 |                 0 |
[MCU2_0]     65.842509 s:            1 |              1041 |                 1039 |               61 |                 0 |
[MCU2_0]     65.842609 s:            2 |              1041 |                 1039 |               61 |                 0 |
[MCU2_0]     65.842715 s:            3 |              1041 |                 1039 |               61 |                 0 |
quanfeng
  • Hi quanfeng,
    As such capture does not report any error, so does not seem like coming from the capture. If you can share some output image, it would help to understand the issue.
    Also what else are you running along with the capture node?
    Is it possible to check it out on the latest SDK9.2 release?
    Brijesh
  • Hi Brijesh,
    This project is close to SOP and I can't switch the SDK version.
    As shown in the figure below, the top left is the loop test image we used in the CAPTURE node, it is normal with no tearing, the other 3 are raw camera outputs all have tearing. By the way, the image sensor is output in UYVY format.
    quanfeng
    Sorry, the image is not visible, so can you please share it again? or can you zip it and share it on the forum?
    Btw, since you are using YUV422 camera format, can you try enabling dual-pixel mode in the CSIRX and see if it helps?
    Brijesh
  • Hi Brijesh,
    Do you mean setting the numPixels variable to 1?
    captureObj->params.instCfg[id].numPixels = 1U;
    When I add the above line to the code, the image still tears.
    Below is the image file.
    IMG_4159.zip
    quanfeng
  • Hi Brijesh,
    In addition, image tearing occurs at high dsp loads(50%), and almost no tearing occurs when we reduce the DSP algorithm runs(load 24%).
    quanfeng
  • Hi quanfeng,
       Here is gel script, could you please dump these info to us?
       /cfs-file/__key/communityserver-discussions-components-files/791/TDA4VL_5F00_Qos_5F00_Dump_5F00_update.gel
    Linjun
  • Hi Linjun,
    Here is the dump info.
    qos.log
    quanfeng
  • Hi TI experts,
    Our dsp algorithm mainly does image affine transformation and luminance balancing. We found that the image tearing is reduced when moving the DSP algorithm from C7x_2 to C7x_1(~80% load on C7x_1 and ~20% load on C7x_2). However, this will result in the TIDL running at a frame rate that does not meet our requirements.Why does running the same algorithm on different DSP cores lead to different situations?
    quanfeng
  • Hi quanfeng,
          One c71 with MMA, the other without MMA.
    Linjun
  • Hi Linjun,
    Here are the Dsp binaries. In the zip file, DSP-algOnC7x_1 indicates that the algorithm runs on C7x_1, and so on.
    dsp-bin.zip
    quanfeng
  • End point Column3 Column4 EPRIORITY ORDERID QOS
    COMPUTE_CLUSTER_J7AHP_MAIN_0_GIC_MEM_RD_VBUSM   Reg_0x45D86100   0x00007000 7 0 0
    COMPUTE_CLUSTER_J7AHP_MAIN_0_GIC_MEM_WR_VBUSM   Reg_0x45D86500   0x00007000 7 0 0
    DEBUGSS_K3_WRAP_CV0_MAIN_0_VBUSMR   Reg_0x45DA0100   0x00007000 7 0 0
    DEBUGSS_K3_WRAP_CV0_MAIN_0_VBUSMW   Reg_0x45DA0500   0x00007000 7 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH0  Reg_0x45DC0100   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH1  Reg_0x45DC0104   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH2  Reg_0x45DC0108   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH3  Reg_0x45DC010C   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH4  Reg_0x45DC0110   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH5  Reg_0x45DC0114   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH6  Reg_0x45DC0118   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH7  Reg_0x45DC011C   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH8  Reg_0x45DC0120   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH9  Reg_0x45DC0124   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH10  Reg_0x45DC0128   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH11  Reg_0x45DC012C   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH12  Reg_0x45DC0130   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH13  Reg_0x45DC0134   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH14  Reg_0x45DC0138   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH15  Reg_0x45DC013C   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH16  Reg_0x45DC0140   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH17  Reg_0x45DC0144   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH18  Reg_0x45DC0148   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH19  Reg_0x45DC014C   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH20  Reg_0x45DC0150   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH21  Reg_0x45DC0154   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH22  Reg_0x45DC0158   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH23  Reg_0x45DC015C   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH24  Reg_0x45DC0160   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH25  Reg_0x45DC0164   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH26  Reg_0x45DC0168   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH27  Reg_0x45DC016C   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH28  Reg_0x45DC0170   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH29  Reg_0x45DC0174   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH30  Reg_0x45DC0178   0x00000000 0 0 0
    DMPAC_TOP_MAIN_0_DATA_MST_CH31  Reg_0x45DC017C   0x00000000 0 0 0
    EMMC8SS_16FFC_MAIN_0_EMMCSS_WR   Reg_0x45D9B500   0x00007000 7 0 0
    EMMC8SS_16FFC_MAIN_0_EMMCSS_RD   Reg_0x45D9B900   0x00007000 7 0 0
    EMMCSD4SS_MAIN_0_EMMCSDSS_RD   Reg_0x45D82900   0x00007000 7 0 0
    EMMCSD4SS_MAIN_0_EMMCSDSS_WR   Reg_0x45D82D00   0x00007000 7 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH0  Reg_0x45DC5100   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH1  Reg_0x45DC5104   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH2  Reg_0x45DC5108   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH3  Reg_0x45DC510C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH4  Reg_0x45DC5110   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH5  Reg_0x45DC5114   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH6  Reg_0x45DC5118   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH7  Reg_0x45DC511C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH8  Reg_0x45DC5120   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH9  Reg_0x45DC5124   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH10  Reg_0x45DC5128   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH11  Reg_0x45DC512C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH12  Reg_0x45DC5130   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH13  Reg_0x45DC5134   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH14  Reg_0x45DC5138   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH15  Reg_0x45DC513C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH16  Reg_0x45DC5140   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH17  Reg_0x45DC5144   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH18  Reg_0x45DC5148   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH19  Reg_0x45DC514C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH20  Reg_0x45DC5150   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH21  Reg_0x45DC5154   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH22  Reg_0x45DC5158   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH23  Reg_0x45DC515C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH24  Reg_0x45DC5160   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH25  Reg_0x45DC5164   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH26  Reg_0x45DC5168   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH27  Reg_0x45DC516C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH28  Reg_0x45DC5170   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH29  Reg_0x45DC5174   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH30  Reg_0x45DC5178   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH31  Reg_0x45DC517C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH32  Reg_0x45DC5180   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH33  Reg_0x45DC5184   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH34  Reg_0x45DC5188   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH35  Reg_0x45DC518C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH36  Reg_0x45DC5190   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH37  Reg_0x45DC5194   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH38  Reg_0x45DC5198   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH39  Reg_0x45DC519C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH40  Reg_0x45DC51A0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH41  Reg_0x45DC51A4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH42  Reg_0x45DC51A8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH43  Reg_0x45DC51AC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH44  Reg_0x45DC51B0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH45  Reg_0x45DC51B4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH46  Reg_0x45DC51B8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH47  Reg_0x45DC51BC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH48  Reg_0x45DC51C0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH49  Reg_0x45DC51C4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH50  Reg_0x45DC51C8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH51  Reg_0x45DC51CC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH52  Reg_0x45DC51D0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH53  Reg_0x45DC51D4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH54  Reg_0x45DC51D8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH55  Reg_0x45DC51DC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH56  Reg_0x45DC51E0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH57  Reg_0x45DC51E4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH58  Reg_0x45DC51E8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH59  Reg_0x45DC51EC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH60  Reg_0x45DC51F0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH61  Reg_0x45DC51F4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH62  Reg_0x45DC51F8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH63  Reg_0x45DC51FC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH64  Reg_0x45DC5200   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH65  Reg_0x45DC5204   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH66  Reg_0x45DC5208   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH67  Reg_0x45DC520C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH68  Reg_0x45DC5210   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH69  Reg_0x45DC5214   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH70  Reg_0x45DC5218   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH71  Reg_0x45DC521C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH72  Reg_0x45DC5220   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH73  Reg_0x45DC5224   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH74  Reg_0x45DC5228   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH75  Reg_0x45DC522C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH76  Reg_0x45DC5230   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH77  Reg_0x45DC5234   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH78  Reg_0x45DC5238   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH79  Reg_0x45DC523C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH80  Reg_0x45DC5240   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH81  Reg_0x45DC5244   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH82  Reg_0x45DC5248   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH83  Reg_0x45DC524C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH84  Reg_0x45DC5250   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH85  Reg_0x45DC5254   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH86  Reg_0x45DC5258   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH87  Reg_0x45DC525C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH88  Reg_0x45DC5260   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH89  Reg_0x45DC5264   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH90  Reg_0x45DC5268   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH91  Reg_0x45DC526C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH92  Reg_0x45DC5270   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH93  Reg_0x45DC5274   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH94  Reg_0x45DC5278   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH95  Reg_0x45DC527C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH96  Reg_0x45DC5280   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH97  Reg_0x45DC5284   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH98  Reg_0x45DC5288   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH99  Reg_0x45DC528C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH100  Reg_0x45DC5290   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH101  Reg_0x45DC5294   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH102  Reg_0x45DC5298   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH103  Reg_0x45DC529C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH104  Reg_0x45DC52A0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH105  Reg_0x45DC52A4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH106  Reg_0x45DC52A8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH107  Reg_0x45DC52AC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH108  Reg_0x45DC52B0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH109  Reg_0x45DC52B4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH110  Reg_0x45DC52B8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH111  Reg_0x45DC52BC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH112  Reg_0x45DC52C0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH113  Reg_0x45DC52C4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH114  Reg_0x45DC52C8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH115  Reg_0x45DC52CC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH116  Reg_0x45DC52D0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH117  Reg_0x45DC52D4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH118  Reg_0x45DC52D8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH119  Reg_0x45DC52DC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH120  Reg_0x45DC52E0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH121  Reg_0x45DC52E4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH122  Reg_0x45DC52E8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH123  Reg_0x45DC52EC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH124  Reg_0x45DC52F0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH125  Reg_0x45DC52F4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH126  Reg_0x45DC52F8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH127  Reg_0x45DC52FC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH128  Reg_0x45DC5300   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH129  Reg_0x45DC5304   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH130  Reg_0x45DC5308   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH131  Reg_0x45DC530C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH132  Reg_0x45DC5310   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH133  Reg_0x45DC5314   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH134  Reg_0x45DC5318   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH135  Reg_0x45DC531C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH136  Reg_0x45DC5320   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH137  Reg_0x45DC5324   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH138  Reg_0x45DC5328   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH139  Reg_0x45DC532C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH140  Reg_0x45DC5330   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH141  Reg_0x45DC5334   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH142  Reg_0x45DC5338   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH143  Reg_0x45DC533C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH144  Reg_0x45DC5340   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH145  Reg_0x45DC5344   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH146  Reg_0x45DC5348   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH147  Reg_0x45DC534C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH148  Reg_0x45DC5350   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH149  Reg_0x45DC5354   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH150  Reg_0x45DC5358   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH151  Reg_0x45DC535C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH152  Reg_0x45DC5360   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH153  Reg_0x45DC5364   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH154  Reg_0x45DC5368   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH155  Reg_0x45DC536C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH156  Reg_0x45DC5370   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH157  Reg_0x45DC5374   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH158  Reg_0x45DC5378   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC_CH159  Reg_0x45DC537C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH0  Reg_0x45DC5900   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH1  Reg_0x45DC5904   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH2  Reg_0x45DC5908   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH3  Reg_0x45DC590C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH4  Reg_0x45DC5910   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH5  Reg_0x45DC5914   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH6  Reg_0x45DC5918   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH7  Reg_0x45DC591C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH8  Reg_0x45DC5920   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH9  Reg_0x45DC5924   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH10  Reg_0x45DC5928   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH11  Reg_0x45DC592C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH12  Reg_0x45DC5930   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH13  Reg_0x45DC5934   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH14  Reg_0x45DC5938   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH15  Reg_0x45DC593C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH16  Reg_0x45DC5940   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH17  Reg_0x45DC5944   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH18  Reg_0x45DC5948   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH19  Reg_0x45DC594C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH20  Reg_0x45DC5950   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH21  Reg_0x45DC5954   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH22  Reg_0x45DC5958   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH23  Reg_0x45DC595C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH24  Reg_0x45DC5960   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH25  Reg_0x45DC5964   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH26  Reg_0x45DC5968   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH27  Reg_0x45DC596C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH28  Reg_0x45DC5970   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH29  Reg_0x45DC5974   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH30  Reg_0x45DC5978   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH31  Reg_0x45DC597C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH32  Reg_0x45DC5980   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH33  Reg_0x45DC5984   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH34  Reg_0x45DC5988   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH35  Reg_0x45DC598C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH36  Reg_0x45DC5990   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH37  Reg_0x45DC5994   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH38  Reg_0x45DC5998   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH39  Reg_0x45DC599C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH40  Reg_0x45DC59A0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH41  Reg_0x45DC59A4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH42  Reg_0x45DC59A8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH43  Reg_0x45DC59AC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH44  Reg_0x45DC59B0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH45  Reg_0x45DC59B4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH46  Reg_0x45DC59B8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH47  Reg_0x45DC59BC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH48  Reg_0x45DC59C0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH49  Reg_0x45DC59C4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH50  Reg_0x45DC59C8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH51  Reg_0x45DC59CC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH52  Reg_0x45DC59D0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH53  Reg_0x45DC59D4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH54  Reg_0x45DC59D8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH55  Reg_0x45DC59DC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH56  Reg_0x45DC59E0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH57  Reg_0x45DC59E4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH58  Reg_0x45DC59E8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH59  Reg_0x45DC59EC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH60  Reg_0x45DC59F0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH61  Reg_0x45DC59F4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH62  Reg_0x45DC59F8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH63  Reg_0x45DC59FC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH64  Reg_0x45DC5A00   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH65  Reg_0x45DC5A04   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH66  Reg_0x45DC5A08   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH67  Reg_0x45DC5A0C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH68  Reg_0x45DC5A10   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH69  Reg_0x45DC5A14   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH70  Reg_0x45DC5A18   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH71  Reg_0x45DC5A1C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH72  Reg_0x45DC5A20   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH73  Reg_0x45DC5A24   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH74  Reg_0x45DC5A28   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH75  Reg_0x45DC5A2C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH76  Reg_0x45DC5A30   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH77  Reg_0x45DC5A34   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH78  Reg_0x45DC5A38   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH79  Reg_0x45DC5A3C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH80  Reg_0x45DC5A40   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH81  Reg_0x45DC5A44   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH82  Reg_0x45DC5A48   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH83  Reg_0x45DC5A4C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH84  Reg_0x45DC5A50   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH85  Reg_0x45DC5A54   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH86  Reg_0x45DC5A58   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH87  Reg_0x45DC5A5C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH88  Reg_0x45DC5A60   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH89  Reg_0x45DC5A64   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH90  Reg_0x45DC5A68   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH91  Reg_0x45DC5A6C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH92  Reg_0x45DC5A70   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH93  Reg_0x45DC5A74   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH94  Reg_0x45DC5A78   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH95  Reg_0x45DC5A7C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH96  Reg_0x45DC5A80   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH97  Reg_0x45DC5A84   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH98  Reg_0x45DC5A88   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH99  Reg_0x45DC5A8C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH100  Reg_0x45DC5A90   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH101  Reg_0x45DC5A94   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH102  Reg_0x45DC5A98   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH103  Reg_0x45DC5A9C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH104  Reg_0x45DC5AA0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH105  Reg_0x45DC5AA4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH106  Reg_0x45DC5AA8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH107  Reg_0x45DC5AAC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH108  Reg_0x45DC5AB0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH109  Reg_0x45DC5AB4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH110  Reg_0x45DC5AB8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH111  Reg_0x45DC5ABC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH112  Reg_0x45DC5AC0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH113  Reg_0x45DC5AC4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH114  Reg_0x45DC5AC8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH115  Reg_0x45DC5ACC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH116  Reg_0x45DC5AD0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH117  Reg_0x45DC5AD4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH118  Reg_0x45DC5AD8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH119  Reg_0x45DC5ADC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH120  Reg_0x45DC5AE0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH121  Reg_0x45DC5AE4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH122  Reg_0x45DC5AE8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH123  Reg_0x45DC5AEC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH124  Reg_0x45DC5AF0   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH125  Reg_0x45DC5AF4   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH126  Reg_0x45DC5AF8   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH127  Reg_0x45DC5AFC   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH128  Reg_0x45DC5B00   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH129  Reg_0x45DC5B04   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH130  Reg_0x45DC5B08   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH131  Reg_0x45DC5B0C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH132  Reg_0x45DC5B10   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH133  Reg_0x45DC5B14   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH134  Reg_0x45DC5B18   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH135  Reg_0x45DC5B1C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH136  Reg_0x45DC5B20   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH137  Reg_0x45DC5B24   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH138  Reg_0x45DC5B28   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH139  Reg_0x45DC5B2C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH140  Reg_0x45DC5B30   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH141  Reg_0x45DC5B34   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH142  Reg_0x45DC5B38   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH143  Reg_0x45DC5B3C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH144  Reg_0x45DC5B40   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH145  Reg_0x45DC5B44   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH146  Reg_0x45DC5B48   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH147  Reg_0x45DC5B4C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH148  Reg_0x45DC5B50   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH149  Reg_0x45DC5B54   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH150  Reg_0x45DC5B58   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH151  Reg_0x45DC5B5C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH152  Reg_0x45DC5B60   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH153  Reg_0x45DC5B64   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH154  Reg_0x45DC5B68   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH155  Reg_0x45DC5B6C   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH156  Reg_0x45DC5B70   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH157  Reg_0x45DC5B74   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH158  Reg_0x45DC5B78   0x30000000 0 0 0
    J7AEP_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC_CH159  Reg_0x45DC5B7C   0x30000000 0 0 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH0  Reg_0x45DC2100   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH1  Reg_0x45DC2104   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH2  Reg_0x45DC2108   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH3  Reg_0x45DC210C   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH4  Reg_0x45DC2110   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH5  Reg_0x45DC2114   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH6  Reg_0x45DC2118   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH7  Reg_0x45DC211C   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH8  Reg_0x45DC2120   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_DMA_CH9  Reg_0x45DC2124   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH0  Reg_0x45DC2500   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH1  Reg_0x45DC2504   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH2  Reg_0x45DC2508   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH3  Reg_0x45DC250C   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH4  Reg_0x45DC2510   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH5  Reg_0x45DC2514   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH6  Reg_0x45DC2518   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH7  Reg_0x45DC251C   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH8  Reg_0x45DC2520   0x300000F0 0 15 0
    K3_DSS_MAIN_0_DSS_INST0_VBUSM_FBDC_CH9  Reg_0x45DC2524   0x300000F0 0 15 0
    K3_VPU_WAVE521CL_MAIN_0_SEC_M_VBUSM_R_ASYNC   Reg_0x45DC0D00   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_SEC_M_VBUSM_W_ASYNC   Reg_0x45DC1100   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_R_ASYNC_CH0  Reg_0x45DC3500   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_R_ASYNC_CH1  Reg_0x45DC3504   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_R_ASYNC_CH2  Reg_0x45DC3508   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_R_ASYNC_CH3  Reg_0x45DC350C   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_R_ASYNC_CH4  Reg_0x45DC3510   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_W_ASYNC_CH0  Reg_0x45DC3900   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_W_ASYNC_CH1  Reg_0x45DC3904   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_W_ASYNC_CH2  Reg_0x45DC3908   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_W_ASYNC_CH3  Reg_0x45DC390C   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_W_ASYNC_CH4  Reg_0x45DC3910   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_SEC_M_VBUSM_R_ASYNC   Reg_0x45DC3D00   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_SEC_M_VBUSM_W_ASYNC   Reg_0x45DC4100   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_R_ASYNC _CH0  Reg_0x45DC4500   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_R_ASYNC _CH1  Reg_0x45DC4504   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_R_ASYNC _CH2  Reg_0x45DC4508   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_R_ASYNC _CH3  Reg_0x45DC450C   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_R_ASYNC _CH4  Reg_0x45DC4510   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_W_ASYNC _CH0  Reg_0x45DC4900   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_W_ASYNC _CH1  Reg_0x45DC4904   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_W_ASYNC _CH2  Reg_0x45DC4908   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_W_ASYNC _CH3  Reg_0x45DC490C   0x00007000 7 0 0
    K3_VPU_WAVE521CL_MAIN_1_PRI_M_VBUSM_W_ASYNC _CH4  Reg_0x45DC4910   0x00007000 7 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_RD_CH0  Reg_0x45D98500   0x00007000 7 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_RD_CH1  Reg_0x45D98504   0x00007000 7 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_RD_CH2  Reg_0x45D98508   0x00007000 7 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_RD_CH3  Reg_0x45D9850C   0x00007000 7 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_RD_CH4  Reg_0x45D98510   0x00007000 7 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_RD_CH5  Reg_0x45D98514   0x00007000 7 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_RD_CH6  Reg_0x45D98518   0x00007000 7 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_RD_CH7  Reg_0x45D9851C   0x00007000 7 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_WR_CH0  Reg_0x45D98D00   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_WR_CH1  Reg_0x45D98D04   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_WR_CH2  Reg_0x45D98D08   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_WR_CH3  Reg_0x45D98D0C   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_WR_CH4  Reg_0x45D98D10   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_WR_CH5  Reg_0x45D98D14   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_WR_CH6  Reg_0x45D98D18   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_0_PCIE_MST_WR_CH7  Reg_0x45D98D1C   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_RD_CH0  Reg_0x45D99500   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_RD_CH1  Reg_0x45D99504   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_RD_CH2  Reg_0x45D99508   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_RD_CH3  Reg_0x45D9950C   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_RD_CH4  Reg_0x45D99510   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_RD_CH5  Reg_0x45D99514   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_RD_CH6  Reg_0x45D99518   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_RD_CH7  Reg_0x45D9951C   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_WR_CH0  Reg_0x45D99D00   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_WR_CH1  Reg_0x45D99D04   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_WR_CH2  Reg_0x45D99D08   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_WR_CH3  Reg_0x45D99D0C   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_WR_CH4  Reg_0x45D99D10   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_WR_CH5  Reg_0x45D99D14   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_WR_CH6  Reg_0x45D99D18   0x00007000 0 0 0
    PCIE_G3X4_128_MAIN_1_PCIE_MST_WR_CH7  Reg_0x45D99D1C   0x00007000 0 0 0
    PULSAR_SL_MAIN_0_PBDG_RMST0   Reg_0x45D78100   0x00007000 0 0 0
    PULSAR_SL_MAIN_0_PBDG_WMST0   Reg_0x45D78500   0x00007000 0 0 0
    PULSAR_SL_MAIN_0_PBDG_RMST1   Reg_0x45D78900   0x00007000 0 0 0
    PULSAR_SL_MAIN_0_PBDG_WMST1   Reg_0x45D78D00   0x00007000 0 0 0
    PULSAR_SL_MAIN_0_CPU0_RMST   Reg_0x45DC8100   0x00007000 0 0 0
    PULSAR_SL_MAIN_0_CPU0_WMST   Reg_0x45DC8500   0x00007000 0 0 0
    PULSAR_SL_MAIN_0_CPU1_RMST   Reg_0x45DC8900   0x000000F0 0 15 0
    PULSAR_SL_MAIN_0_CPU1_WMST   Reg_0x45DC8D00   0x000000F0 0 15 0
    PULSAR_SL_MAIN_1_CPU0_RMST   Reg_0x45DA8100   0x00007000 0 0 0
    PULSAR_SL_MAIN_1_CPU0_WMST   Reg_0x45DA8500   0x00007000 0 0 0
    PULSAR_SL_MAIN_1_CPU1_RMST   Reg_0x45DA8900   0x00007000 0 0 0
    PULSAR_SL_MAIN_1_CPU1_WMST   Reg_0x45DA8D00   0x00007000 0 0 0
    PULSAR_SL_MAIN_1_PBDG_RMST0   Reg_0x45DCA100   0x00007000 0 0 0
    PULSAR_SL_MAIN_1_PBDG_WMST0   Reg_0x45DCA500   0x00007000 0 0 0
    PULSAR_SL_MAIN_1_PBDG_RMST1   Reg_0x45DCA900   0x00007000 0 0 0
    PULSAR_SL_MAIN_1_PBDG_WMST1   Reg_0x45DCAD00   0x00007000 0 0 0
    PULSAR_SL_MAIN_2_CPU0_RMST   Reg_0x45DA9100   0x00007000 0 0 0
    PULSAR_SL_MAIN_2_CPU0_WMST   Reg_0x45DA9500   0x00007000 0 0 0
    PULSAR_SL_MAIN_2_CPU1_RMST   Reg_0x45DA9900   0x00007000 0 0 0
    PULSAR_SL_MAIN_2_CPU1_WMST   Reg_0x45DA9D00   0x00007000 0 0 0
    PULSAR_SL_MAIN_2_PBDG_RMST0   Reg_0x45DCB100   0x00007000 0 0 0
    PULSAR_SL_MAIN_2_PBDG_WMST0   Reg_0x45DCB500   0x00007000 0 0 0
    PULSAR_SL_MAIN_2_PBDG_RMST1   Reg_0x45DCB900   0x00007000 0 0 0
    PULSAR_SL_MAIN_2_PBDG_WMST1   Reg_0x45DCBD00   0x00007000 0 0 0
    PULSAR_SL_MCU_0_CPU0_RMST   Reg_0x45D10100   0x00007000 0 0 0
    PULSAR_SL_MCU_0_CPU0_WMST   Reg_0x45D10500   0x00007000 0 0 0
    PULSAR_SL_MCU_0_CPU0_PMST   Reg_0x45D10900   0x00007000 0 0 0
    PULSAR_SL_MCU_0_CPU1_RMST   Reg_0x45D11100   0x00007000 0 0 0
    PULSAR_SL_MCU_0_CPU1_WMST   Reg_0x45D11500   0x00007000 0 0 0
    PULSAR_SL_MCU_0_CPU1_PMST   Reg_0x45D11900   0x00007000 0 0 0
    SA2_UL_MAIN_0_CTXCACH_EXT_DMA   Reg_0x45D9BD00   0x00007000 0 0 0
    SA3SS_AM62_MCU_0_CTXCACH_EXT_DMA   Reg_0x45D13100   0x00007000 0 0 0
    SMS_WKUP_0_TIFS_VBUSP_M   Reg_0x45D00100   0x00007000 0 0 0
    SMS_WKUP_0_HSM_VBUSP_M   Reg_0x45D00500   0x00007000 0 0 0
    UFSHCI2P1SS_16FFC_MAIN_0_UFSHCI_VBM_MST_RD_CH0  Reg_0x45D9AD00   0x00007000 0 0 0
    UFSHCI2P1SS_16FFC_MAIN_0_UFSHCI_VBM_MST_RD_CH1  Reg_0x45D9AD04   0x00007000 0 0 0
    UFSHCI2P1SS_16FFC_MAIN_0_UFSHCI_VBM_MST_WR_CH0  Reg_0x45D9B100   0x00007000 0 0 0
    UFSHCI2P1SS_16FFC_MAIN_0_UFSHCI_VBM_MST_WR_CH1  Reg_0x45D9B104   0x00007000 0 0 0
    UFSHCI2P1SS_16FFC_MAIN_0_UFSHCI_VBM_MST_WR_CH2  Reg_0x45D9B108   0x00007000 0 0 0
    UFSHCI2P1SS_16FFC_MAIN_0_UFSHCI_VBM_MST_WR_CH3  Reg_0x45D9B10C   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTR0   Reg_0x45D9A100   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTR1  Reg_0x45D9A104   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTR2  Reg_0x45D9A108   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTR3  Reg_0x45D9A10C   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTR4  Reg_0x45D9A110   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTR5  Reg_0x45D9A114   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTR6  Reg_0x45D9A118   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTR7  Reg_0x45D9A11C   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTW0   Reg_0x45D9A500   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTW1  Reg_0x45D9A504   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTW2  Reg_0x45D9A508   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTW3  Reg_0x45D9A50C   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTW4  Reg_0x45D9A510   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTW5  Reg_0x45D9A514   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTW6  Reg_0x45D9A518   0x00007000 0 0 0
    USB3P0SS_16FFC_MAIN_0_MSTW7  Reg_0x45D9A51C   0x00007000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH0  Reg_0x45DC1500   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH1  Reg_0x45DC1504   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH2  Reg_0x45DC1508   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH3  Reg_0x45DC150C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH4  Reg_0x45DC1510   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH5  Reg_0x45DC1514   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH6  Reg_0x45DC1518   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH7  Reg_0x45DC151C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH8  Reg_0x45DC1520   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH9  Reg_0x45DC1524   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH10  Reg_0x45DC1528   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH11  Reg_0x45DC152C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH12  Reg_0x45DC1530   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH13  Reg_0x45DC1534   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH14  Reg_0x45DC1538   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH15  Reg_0x45DC153C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH16  Reg_0x45DC1540   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH17  Reg_0x45DC1544   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH18  Reg_0x45DC1548   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH19  Reg_0x45DC154C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH20  Reg_0x45DC1550   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH21  Reg_0x45DC1554   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH22  Reg_0x45DC1558   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH23  Reg_0x45DC155C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH24  Reg_0x45DC1560   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH25  Reg_0x45DC1564   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH26  Reg_0x45DC1568   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH27  Reg_0x45DC156C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH28  Reg_0x45DC1570   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH29  Reg_0x45DC1574   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH30  Reg_0x45DC1578   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_0_CH31  Reg_0x45DC157C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH0  Reg_0x45DC1900   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH1  Reg_0x45DC1904   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH2  Reg_0x45DC1908   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH3  Reg_0x45DC190C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH4  Reg_0x45DC1910   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH5  Reg_0x45DC1914   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH6  Reg_0x45DC1918   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH7  Reg_0x45DC191C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH8  Reg_0x45DC1920   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH9  Reg_0x45DC1924   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH10  Reg_0x45DC1928   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH11  Reg_0x45DC192C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH12  Reg_0x45DC1930   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH13  Reg_0x45DC1934   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH14  Reg_0x45DC1938   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH15  Reg_0x45DC193C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH16  Reg_0x45DC1940   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH17  Reg_0x45DC1944   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH18  Reg_0x45DC1948   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH19  Reg_0x45DC194C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH20  Reg_0x45DC1950   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH21  Reg_0x45DC1954   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH22  Reg_0x45DC1958   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH23  Reg_0x45DC195C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH24  Reg_0x45DC1960   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH25  Reg_0x45DC1964   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH26  Reg_0x45DC1968   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH27  Reg_0x45DC196C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH28  Reg_0x45DC1970   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH29  Reg_0x45DC1974   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH30  Reg_0x45DC1978   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH31  Reg_0x45DC197C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH32  Reg_0x45DC1980   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH33  Reg_0x45DC1984   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH34  Reg_0x45DC1988   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH35  Reg_0x45DC198C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH36  Reg_0x45DC1990   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH37  Reg_0x45DC1994   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH38  Reg_0x45DC1998   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH39  Reg_0x45DC199C   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH40  Reg_0x45DC19A0   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH41  Reg_0x45DC19A4   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH42  Reg_0x45DC19A8   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH43  Reg_0x45DC19AC   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH44  Reg_0x45DC19B0   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH45  Reg_0x45DC19B4   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH46  Reg_0x45DC19B8   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH47  Reg_0x45DC19BC   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH48  Reg_0x45DC19C0   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH49  Reg_0x45DC19C4   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH50  Reg_0x45DC19C8   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH51  Reg_0x45DC19CC   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH52  Reg_0x45DC19D0   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH53  Reg_0x45DC19D4   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH54  Reg_0x45DC19D8   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH55  Reg_0x45DC19DC   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH56  Reg_0x45DC19E0   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH57  Reg_0x45DC19E4   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH58  Reg_0x45DC19E8   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH59  Reg_0x45DC19EC   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH60  Reg_0x45DC19F0   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH61  Reg_0x45DC19F4   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH62  Reg_0x45DC19F8   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_DATA_MST_1 _CH63  Reg_0x45DC19FC   0x00000000 0 0 0
    VPAC_TOP_MAIN_0_LDC0_M_MST_CH0  Reg_0x45DC1D00   0x00007000 0 0 0
    VPAC_TOP_MAIN_0_LDC0_M_MST_CH1  Reg_0x45DC1D04   0x00007000 0 0 0
    VPAC_TOP_MAIN_0_LDC0_M_MST_CH2  Reg_0x45DC1D08   0x00007000 0 0 0
    VPAC_TOP_MAIN_1_LDC0_M_MST_CH0  Reg_0x45DC2900   0x00007000 0 0 0
    VPAC_TOP_MAIN_1_LDC0_M_MST_CH1  Reg_0x45DC2904   0x00007000 0 0 0
    VPAC_TOP_MAIN_1_LDC0_M_MST_CH2  Reg_0x45DC2908   0x00007000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH0  Reg_0x45DC2D00   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH1  Reg_0x45DC2D04   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH2  Reg_0x45DC2D08   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH3  Reg_0x45DC2D0C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH4  Reg_0x45DC2D10   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH5  Reg_0x45DC2D14   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH6  Reg_0x45DC2D18   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH7  Reg_0x45DC2D1C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH8  Reg_0x45DC2D20   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH9  Reg_0x45DC2D24   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH10  Reg_0x45DC2D28   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH11  Reg_0x45DC2D2C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH12  Reg_0x45DC2D30   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH13  Reg_0x45DC2D34   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH14  Reg_0x45DC2D38   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH15  Reg_0x45DC2D3C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH16  Reg_0x45DC2D40   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH17  Reg_0x45DC2D44   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH18  Reg_0x45DC2D48   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH19  Reg_0x45DC2D4C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH20  Reg_0x45DC2D50   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH21  Reg_0x45DC2D54   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH22  Reg_0x45DC2D58   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH23  Reg_0x45DC2D5C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH24  Reg_0x45DC2D60   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH25  Reg_0x45DC2D64   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH26  Reg_0x45DC2D68   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH27  Reg_0x45DC2D6C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH28  Reg_0x45DC2D70   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH29  Reg_0x45DC2D74   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH30  Reg_0x45DC2D78   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_0_CH31  Reg_0x45DC2D7C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH0  Reg_0x45DC3100   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH1  Reg_0x45DC3104   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH2  Reg_0x45DC3108   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH3  Reg_0x45DC310C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH4  Reg_0x45DC3110   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH5  Reg_0x45DC3114   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH6  Reg_0x45DC3118   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH7  Reg_0x45DC311C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH8  Reg_0x45DC3120   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH9  Reg_0x45DC3124   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH10  Reg_0x45DC3128   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH11  Reg_0x45DC312C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH12  Reg_0x45DC3130   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH13  Reg_0x45DC3134   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH14  Reg_0x45DC3138   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH15  Reg_0x45DC313C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH16  Reg_0x45DC3140   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH17  Reg_0x45DC3144   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH18  Reg_0x45DC3148   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH19  Reg_0x45DC314C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH20  Reg_0x45DC3150   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH21  Reg_0x45DC3154   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH22  Reg_0x45DC3158   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH23  Reg_0x45DC315C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH24  Reg_0x45DC3160   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH25  Reg_0x45DC3164   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH26  Reg_0x45DC3168   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH27  Reg_0x45DC316C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH28  Reg_0x45DC3170   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH29  Reg_0x45DC3174   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH30  Reg_0x45DC3178   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH31  Reg_0x45DC317C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH32  Reg_0x45DC3180   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH33  Reg_0x45DC3184   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH34  Reg_0x45DC3188   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH35  Reg_0x45DC318C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH36  Reg_0x45DC3190   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH37  Reg_0x45DC3194   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH38  Reg_0x45DC3198   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH39  Reg_0x45DC319C   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH40  Reg_0x45DC31A0   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH41  Reg_0x45DC31A4   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH42  Reg_0x45DC31A8   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH43  Reg_0x45DC31AC   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH44  Reg_0x45DC31B0   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH45  Reg_0x45DC31B4   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH46  Reg_0x45DC31B8   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH47  Reg_0x45DC31BC   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH48  Reg_0x45DC31C0   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH49  Reg_0x45DC31C4   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH50  Reg_0x45DC31C8   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH51  Reg_0x45DC31CC   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH52  Reg_0x45DC31D0   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH53  Reg_0x45DC31D4   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH54  Reg_0x45DC31D8   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH55  Reg_0x45DC31DC   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH56  Reg_0x45DC31E0   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH57  Reg_0x45DC31E4   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH58  Reg_0x45DC31E8   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH59  Reg_0x45DC31EC   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH60  Reg_0x45DC31F0   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH61  Reg_0x45DC31F4   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH62  Reg_0x45DC31F8   0x00000000 0 0 0
    VPAC_TOP_MAIN_1_DATA_MST_1_CH63  Reg_0x45DC31FC   0x00000000 0 0 0
    VUSR_DUAL_MAIN_0_V0_M   Reg_0x45D9C100   0x00000000 0 0 0
    VUSR_DUAL_MAIN_0_V1_M   Reg_0x45D9C500   0x00000000 0 0 0
  • Hi Quanfen,
       I disassembled the vx_app_rtos_linux_c7x_1.out and vx_app_rtos_linux_c7x_2.out , found when you use the C7X_1, the stream engine is enable in both folder. Such as below,
      ./vx_app_rtos_linux_c7x_1.out.txt:1847:0x0000b1400b28   4a080433 || SEOPEN .D2 D0,0,VB2
    ./vx_app_rtos_linux_c7x_1.out.txt:1911:0x0000b1400c24   4a188433 || SEOPEN .D2 D1,0x1,VB2
    ./vx_app_rtos_linux_c7x_1.out.txt:1937:0x0000b1400c8c   42080432 || SEOPEN .D2 D0,0,VB0
    ./vx_app_rtos_linux_c7x_1.out.txt:1978:0x0000b1400d28   46188432    SEOPEN .D2 D1,0x1,VB1
    ./vx_app_rtos_linux_c7x_1.out.txt:1982:0x0000b1400d38   42080432 || SEOPEN .D2 D0,0,VB0
    ./vx_app_rtos_linux_c7x_1.out.txt:19266:0x0000b141154c   42168432    SEOPEN .D2 A13,0x1,VB0
    ./vx_app_rtos_linux_c7x_1.out.txt:19267:0x0000b1411550   460c0432    SEOPEN .D2 D8,0,VB1
    ./vx_app_rtos_linux_c7x_1.out.txt:29387:0x0000b141b10c   46080433    SEOPEN .D2 D0,0,VB1
    ./vx_app_rtos_linux_c7x_1.out.txt:29389:0x0000b141b114   621f0432    SEOPEN .D2 D14,0x1,VB8
    ./vx_app_rtos_linux_c7x_1.out.txt:34792:0x0000b1420448   46130432 || SEOPEN .D2 A6,0x1,VB1
    ./vx_app_rtos_linux_c7x_1.out.txt:34847:0x0000b1420524   46080433 || SEOPEN .D2 D0,0,VB1
    ./vx_app_rtos_linux_c7x_1.out.txt:34912:0x0000b1420624   46130433 || SEOPEN .D2 A6,0x1,VB1
      As to the algorithm should works  on L2, leveraged the access to DDR bandwidth, so the issue seems disappeared.
      What you should do is optimize your TIDL and AVM algorithm on C7x_1.
       Thanks.
    Linjun
