PROCESSOR-SDK-J784S4: Waiting continously for root device to load rootfs from USB
Part Number: PROCESSOR-SDK-J784S4
Other Parts Discussed in Thread: TDA4VH
Hi TI Team,
Please find below log. I have shared the command I entered in u-boot as well. I have enabled related kernel configurations and dts changes as well. I dont see it working. Please help me with this.
Hit any key to stop autoboot: 0
=> usb start
starting USB...
Bus usb@6000000: cdns-usb3-host usb@6000000: Unable to get USB3 phy (ret -61)
cdns-usb3-host usb@6000000: DRD version v1 (ID: 0004024e, rev: 00000200)
Register 2000840 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@6000000 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
=> load usb 0 ${kernel_addr_r} boot/Image-6.1.46-g5892b80d6b
20369920 bytes read in 614 ms (31.6 MiB/s)
=> load usb 0 ${fdt_addr_r} boot/dtb/ti/k3-j784s4-ospas140-is.dtb
110555 bytes read in 25 ms (4.2 MiB/s)
=> setenv bootargs console=ttyS2,115200n8 root=/dev/sda1 earlyprintk rw rootfstype=ext4 rootwait init=/sbin/init
=> booti ${loadaddr} ${rd_spec} ${fdtaddr}
Working FDT set to 88000000
Loading Device Tree to 000000008ffe2000, end 000000008fffffda ... OK
Working FDT set to 8ffe2000
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.1.46-g5892b80d6b (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Mon Nov 27 16:11:04 UTC 2023
[ 0.000000] Machine model: Aptiv OSPAS-140 TDA4VH
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000d8fe00000, size 1792 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ab000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@ab000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@ab100000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000dffffefff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000abffffff]
[ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000ffffefff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x0000000dffffefff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000dffffefff]
[ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 6193150
[ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/sda1 earlyprintk rw rootfstype=ext4 rootwait init=/sbin/init
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 8.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Memory: 22530564K/25165816K available (12352K kernel code, 1268K rwdata, 4036K rodata, 2112K init, 435K bss, 800244K reserved, 1835008K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: [Firmware Bug]: GICR region 0x0000000001900000 has overlapping address
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000880050000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000217] Console: colour dummy device 80x25
[ 0.000250] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000256] pid_max: default: 32768 minimum: 301
[ 0.000281] LSM: Security Framework initializing
[ 0.000386] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000452] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001391] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.001396] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.001436] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.001438] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.001521] rcu: Hierarchical SRCU implementation.
[ 0.001523] rcu: Max phase no-delay instances is 1000.
[ 0.001673] Platform MSI: msi-controller@1820000 domain created
[ 0.001797] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.001959] EFI services will not be available.
[ 0.002166] smp: Bringing up secondary CPUs ...
[ 0.010620] Detected PIPT I-cache on CPU1
[ 0.010678] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.010692] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
[ 0.010723] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.019191] Detected PIPT I-cache on CPU2
[ 0.019229] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[ 0.019242] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
[ 0.019265] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[ 0.027675] Detected PIPT I-cache on CPU3
[ 0.027719] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[ 0.027732] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
[ 0.027755] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[ 0.036225] Detected PIPT I-cache on CPU4
[ 0.036301] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[ 0.036315] GICv3: CPU4: using allocated LPI pending table @0x00000008800a0000
[ 0.036347] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[ 0.044814] Detected PIPT I-cache on CPU5
[ 0.044864] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[ 0.044877] GICv3: CPU5: using allocated LPI pending table @0x00000008800b0000
[ 0.044900] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[ 0.053336] Detected PIPT I-cache on CPU6
[ 0.053387] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[ 0.053401] GICv3: CPU6: using allocated LPI pending table @0x00000008800c0000
[ 0.053423] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[ 0.061857] Detected PIPT I-cache on CPU7
[ 0.061912] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[ 0.061925] GICv3: CPU7: using allocated LPI pending table @0x00000008800d0000
[ 0.061948] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[ 0.061993] smp: Brought up 1 node, 8 CPUs
[ 0.061997] SMP: Total of 8 processors activated.
[ 0.062000] CPU features: detected: 32-bit EL0 Support
[ 0.062003] CPU features: detected: CRC32 instructions
[ 0.062053] CPU: All CPU(s) started at EL2
[ 0.062055] alternatives: applying system-wide alternatives
[ 0.062996] devtmpfs: initialized
[ 0.071882] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.071897] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.103129] pinctrl core: initialized pinctrl subsystem
[ 0.103399] DMI not present or invalid.
[ 0.103728] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.105069] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.105822] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.106570] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.106606] audit: initializing netlink subsys (disabled)
[ 0.106734] audit: type=2000 audit(0.104:1): state=initialized audit_enabled=0 res=1
[ 0.106930] thermal_sys: Registered thermal governor 'step_wise'
[ 0.106933] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.107014] cpuidle: using governor menu
[ 0.107079] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.107167] ASID allocator initialised with 65536 entries
[ 0.115615] platform a000000.dp-bridge: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.117405] platform a000000.dp-bridge: Fixed dependency cycle(s) with /dp0-connector
[ 0.117865] KASLR disabled due to lack of seed
[ 0.120790] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.120793] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.120797] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.120799] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.120801] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.120803] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.120805] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.120807] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.121492] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[ 0.122324] iommu: Default domain type: Translated
[ 0.122330] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.122455] SCSI subsystem initialized
[ 0.122597] usbcore: registered new interface driver usbfs
[ 0.122614] usbcore: registered new interface driver hub
[ 0.122628] usbcore: registered new device driver usb
[ 0.122818] pps_core: LinuxPPS API ver. 1 registered
[ 0.122820] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.122826] PTP clock support registered
[ 0.122914] EDAC MC: Ver: 3.0.0
[ 0.123378] FPGA manager framework
[ 0.123410] Advanced Linux Sound Architecture Driver Initialized.
[ 0.123809] clocksource: Switched to clocksource arch_sys_counter
[ 0.123922] VFS: Disk quotas dquot_6.6.0
[ 0.123943] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.126782] NET: Registered PF_INET protocol family
[ 0.127172] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.132341] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.132505] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.132518] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.133336] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.134424] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.134531] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.134845] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.135263] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.135556] RPC: Registered named UNIX socket transport module.
[ 0.135561] RPC: Registered udp transport module.
[ 0.135563] RPC: Registered tcp transport module.
[ 0.135564] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.135568] NET: Registered PF_XDP protocol family
[ 0.135581] PCI: CLS 0 bytes, default 64
[ 0.136254] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.137142] Initialise system trusted keyrings
[ 0.137249] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.139273] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.139507] NFS: Registering the id_resolver key type
[ 0.139521] Key type id_resolver registered
[ 0.139523] Key type id_legacy registered
[ 0.139547] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.139550] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.159038] Key type asymmetric registered
[ 0.159041] Asymmetric key parser 'x509' registered
[ 0.159075] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.159150] io scheduler mq-deadline registered
[ 0.159153] io scheduler kyber registered
[ 0.161308] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[ 0.161385] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[ 0.161490] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[ 0.161565] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[ 0.161686] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[ 0.162124] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.165850] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[ 0.170754] loop: module loaded
[ 0.171344] megasas: 07.719.03.00-rc1
[ 0.172875] tun: Universal TUN/TAP device driver, 1.6
[ 0.173221] thunder_xcv, ver 1.0
[ 0.173237] thunder_bgx, ver 1.0
[ 0.173250] nicpf, ver 1.0
[ 0.173341] e1000: Intel(R) PRO/1000 Network Driver
[ 0.173343] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.173358] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.173360] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.173377] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.173379] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.173390] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.173392] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.173461] sky2: driver version 1.30
[ 0.173869] VFIO - User Level meta-driver version: 0.3
[ 0.174245] usbcore: registered new interface driver usb-storage
[ 0.174559] i2c_dev: i2c /dev entries driver
[ 0.175112] sdhci: Secure Digital Host Controller Interface driver
[ 0.175114] sdhci: Copyright(c) Pierre Ossman
[ 0.175232] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.175637] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.175729] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.175885] usbcore: registered new interface driver usbhid
[ 0.175887] usbhid: USB HID core driver
[ 0.176386] optee: probing for conduit method.
[ 0.176404] optee: revision 4.0 (2a5b1d12)
[ 0.192790] optee: dynamic shared memory is enabled
[ 0.193016] optee: initialized driver
[ 0.194035] Initializing XFRM netlink socket
[ 0.194050] NET: Registered PF_PACKET protocol family
[ 0.194088] Key type dns_resolver registered
[ 0.194261] registered taskstats version 1
[ 0.194274] Loading compiled-in X.509 certificates
[ 0.200381] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.2--v09.01.02 (Kool Koala)')
[ 0.232200] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.232878] omap_i2c 2010000.i2c: bus 1 rev0.12 at 400 kHz
[ 0.233350] omap_i2c 2020000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.233786] omap_i2c 2030000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.234283] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 0.234335] pca953x 4-0020: using no AI
[ 0.247864] pca953x 4-0020: failed writing register
[ 0.247945] pca953x: probe of 4-0020 failed with error -121
[ 0.247985] omap_i2c 2040000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.248171] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[ 0.248264] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[ 0.248354] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[ 0.248568] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[ 0.253965] ti-udma 311a0000.dma-controller: Number of rings: 48
[ 0.254624] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
[ 0.255434] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[ 0.255439] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.255442] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 0.256891] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[ 0.256897] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.256899] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 0.257322] 40a00000.serial: ttyS0 at MMIO 0x40a00000 (irq = 217, base_baud = 6000000) is a 8250
[ 0.257773] 2810000.serial: ttyS1 at MMIO 0x2810000 (irq = 218, base_baud = 3000000) is a 8250
[ 0.258161] 2840000.serial: ttyS2 at MMIO 0x2840000 (irq = 219, base_baud = 3000000) is a 8250
[ 2.206798] printk: console [ttyS2] enabled
[ 2.211392] 2850000.serial: ttyS5 at MMIO 0x2850000 (irq = 220, base_baud = 3000000) is a 8250
[ 2.220368] 2880000.serial: ttyS3 at MMIO 0x2880000 (irq = 221, base_baud = 3000000) is a 8250
[ 2.267810] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.275455] davinci_mdio 46000f00.mdio: no live phy, scanning all
[ 2.294733] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 2.307598] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.314808] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.320965] pps pps0: new PPS source ptp0
[ 2.325095] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[ 2.335362] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[ 2.344268] mmc0: CQHCI version 5.10
[ 2.345857] gpio-363 (gpio_hog_gpio0_6): hogged as output/high
[ 2.388767] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 2.480552] mmc0: Command Queue Engine enabled
[ 2.484996] mmc0: new HS200 MMC card at address 0001
[ 2.490310] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 2.497142] mmcblk0: p1
[ 2.499973] mmcblk0boot0: mmc0:0001 G1M15M 31.5 MiB
[ 2.505592] mmcblk0boot1: mmc0:0001 G1M15M 31.5 MiB
[ 2.511119] mmcblk0rpmb: mmc0:0001 G1M15M 4.00 MiB, chardev (240:0)
[ 2.641847] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[ 2.648641] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[ 2.655425] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[ 2.662206] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
[ 2.668999] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[ 2.675775] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
[ 2.684452] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.692379] j721e-pcie-host 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.700895] j721e-pcie-host 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.709407] j721e-pcie-host 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.719653] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0000:00
[ 3.726360] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.731837] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[ 3.741294] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.748180] pci 0000:00:00.0: [104c:b013] type 01 class 0x060400
[ 3.754175] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 3.763939] pci 0000:00:00.0: supports D1
[ 3.767938] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 3.773697] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[ 3.780557] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[ 3.792097] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.800188] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.806806] pci 0000:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
[ 3.814104] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.819318] pcieport 0000:00:00.0: PME: Signaling with IRQ 489
[ 3.825306] pcieport 0000:00:00.0: AER: enabled with IRQ 489
[ 3.831672] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[ 3.841645] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[ 3.853722] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[ 3.858979] 7 fixed-partitions partitions found on MTD device 47040000.spi.0
[ 3.866016] Creating 7 MTD partitions on "47040000.spi.0":
[ 3.871489] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 3.877663] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 3.883563] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 3.889489] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 3.895182] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 3.901476] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 3.907438] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 3.951816] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 3.959460] davinci_mdio 46000f00.mdio: no live phy, scanning all
[ 3.978732] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 3.991604] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 3.998813] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 4.004979] pps pps0: new PPS source ptp1
[ 4.009118] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[ 4.019090] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 4.027130] debugfs: Directory 'pd:74' with parent 'pm_genpd' already present!
[ 4.034377] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
[ 4.041669] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
[ 4.049388] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
[ 4.056697] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
[ 4.064001] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
[ 4.080876] ALSA device list:
[ 4.083844] No soundcards found.
[ 4.087471] Waiting for root device /dev/sda1...
[ 14.303911] platform regulator-dp0-prw: deferred probe pending
[ 14.309733] platform regulator-dp1-prw: deferred probe pending
