Part Number: PROCESSOR-SDK-AM57X
Other Parts Discussed in Thread: TPD12S015
Hi Team,
I'm trying the newly released SDK 09_02_00_00 version. I have some queires kindly clarify.
1. In the bootlog, I see the Exception stack(0xf035dfa8 to 0xf035dff0) error happening in the drm driver loading, wasn't that noticed?
11.020172] ------------[ cut here ]------------
[ 11.027038] WARNING: CPU: 0 PID: 144 at drivers/gpu/drm/drm_bridge.c:1410 drm_bridge_hpd_enable+0x7c/0x80
[ 11.036743] Hot plug detection already enabled
[ 11.041229] Modules linked in: ti_vpe snd_soc_simple_card ti_vip omapdrm(+) snd_soc_simple_card_utils ti_sc pruss ti_csc cec ti_vpdma omap_aes_driver pvrsrvkm(O) omap_wdt libaes v4l2_mem2mem v4l2_fwno
de ahci_dwc v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common dwc3_omap videodev mc omap_mailbox rtc_omap snd_soc_davinci_mcasp snd_soc_ti_udma snd_soc_ti_edma snd_soc_ti_s
dma omap_des snd_soc_tlv320aic3x_i2c snd_soc_tlv320aic3x omap_crypto libdes snd_soc_core snd_pcm_dmaengine ac97_bus snd_pcm snd_timer extcon_palmas snd soundcore omap_sham crypto_engine omap_remoteproc v
irtio_rpmsg_bus rpmsg_ns rpmsg_core display_connector ti_tpd12s015 gdbserverproxy(O) cryptodev(O)
[ 11.103363] CPU: 0 PID: 144 Comm: systemd-udevd Tainted: G O 6.1.80-ti-g2e423244f8c0 #1
[ 11.103363] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 11.103393] unwind_backtrace from show_stack+0x10/0x14
[ 11.103393] show_stack from dump_stack_lvl+0x40/0x4c
[ 11.103424] dump_stack_lvl from __warn+0x7c/0x158
[ 11.103454] __warn from warn_slowpath_fmt+0x124/0x1c0
[ 11.103454] warn_slowpath_fmt from drm_bridge_hpd_enable+0x7c/0x80
[ 11.103485] drm_bridge_hpd_enable from pdev_probe+0x5bc/0x75c [omapdrm]
[ 11.152404] pdev_probe [omapdrm] from platform_probe+0x5c/0xbc
[ 11.158447] platform_probe from really_probe+0xc8/0x2ec
[ 11.163787] really_probe from __driver_probe_device+0x88/0x1a0
[ 11.169738] __driver_probe_device from driver_probe_device+0x30/0x104
[ 11.176300] driver_probe_device from __driver_attach+0x90/0x174
[ 11.182342] __driver_attach from bus_for_each_dev+0x74/0xc0
[ 11.188018] bus_for_each_dev from bus_add_driver+0x164/0x1f0
[ 11.193817] bus_add_driver from driver_register+0x88/0x11c
[ 11.199432] driver_register from __platform_register_drivers+0x38/0x88
[ 11.206085] __platform_register_drivers from omap_drm_init+0x3c/0x50 [omapdrm]
[ 11.213531] omap_drm_init [omapdrm] from do_one_initcall+0x48/0x254
[ 11.220001] do_one_initcall from do_init_module+0x44/0x1d4
[ 11.225616] do_init_module from sys_finit_module+0xc0/0x110
[ 11.231292] sys_finit_module from __sys_trace_return+0x0/0x10
[ 11.237182] Exception stack(0xf035dfa8 to 0xf035dff0)
[ 11.242248] dfa0: 00000000 00000000 0000000f b6cca8a0 00000000 00020000
[ 11.250457] dfc0: 00000000 00000000 00000000 0000017b 00000000 000979a8 00000007 00000000
[ 11.258666] dfe0: bebe0710 bebe0700 b6cc5d4f b6bfafe2
Starting Print notice about GPLv3 packages[ 11.263854] ---[ end trace 0000000000000000 ]---
2. Wayland compositor was not configured good, I think, it fails to load the qt examples, kindly check the log attached
root@am57xx-evm:~# /usr/share/examples/opengl/hellowindow/hellowindow
MESA: info: Loaded libpvr_dri_support.so
error marshalling arguments for add: dup failed: Bad file descriptor
Error marshalling request: Bad file descriptor
The Wayland connection experienced a fatal error: Bad file descriptor
The Wayland connection broke. Did the Wayland compositor die?
3. Any issues with Eglfs platform, aswell?
root@am57xx-evm:~# /usr/share/examples/opengl/hellowindow/hellowindow -platform eglfs
PVR:(Error): PVRDRICreateScreenImpl: Failed to create display device (err=19) [0, ]
MESA: info: Unloaded libpvr_dri_support.so
MESA-LOADER: failed to open zink: /usr/lib/dri/zink_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/dri, suffix _dri)
failed to load driver: zink
drmModeGetResources failed (Operation not supported)
qt.qpa.input: xkbcommon not available, not performing key mapping
Segmentation fault (core dumped)
4. Does sgx-ddk-um was built with MESA?
I could see the default dependencies were moved from libdrm, libgdm to mesa?
when i try to manual built this, i am seeing a missing libzstd.so libray from zstd, But I don't see any zstd dependecies added for Mesa or ddk-um recipes
Thanks in advance.
U-Boot SPL 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
DRA752-GP ES2.0
Trying to boot from MMC1
Loading Environment from FAT... *** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
Loading Environment from MMC... OK
U-Boot 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
CPU : DRA752-GP ES2.0
Model: TI AM5728 BeagleBoard-X15
Board: UNKNOWN(BeagleBoard X15?) REV UNKNOWN
DRAM: 2 GiB
ti_i2c_eeprom_init failed -1
ti_emmc_boardid_get failed -5
Core: 66 devices, 22 uclasses, devicetree: separate
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net: eth2: ethernet@48484000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
This will not be a case any time
7913984 bytes read in 372 ms (20.3 MiB/s)
215706 bytes read in 41 ms (5 MiB/s)
Working FDT set to 88000000
Kernel image @ 0x82000000 [ 0x000000 - 0x78c200 ]
Loading Device Tree to 8fec8000, end 8fffffff ... OK
Working FDT set to 8fec8000
ft_fixup_clocks failed for DSP voltage domain: <valid offset/length>
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (arm-oe-linux-gnueabi-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM5728 BeagleBoard-X15
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fb800000
[ 0.000000] OMAP4: Map 0x00000000afd00000 to (ptrval) for dram barrier
[ 0.000000] Hit pending asynchronous external abort (FSR=0x00001211) during first unmask, this is most likely caused by a firmware/bootloader bug.
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000afcfffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x00000000afd00000-0x00000000ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000afcfffff]
[ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] On node 0, zone HighMem: 768 pages in unavailable ranges
[ 0.000000] DRA752 ES2.0
[ 0.000000] percpu: Embedded 16 pages/cpu s34324 r8192 d23020 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 521990
[ 0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=8444f28e-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 2.
[ 0.000000] software IO TLB: mapped [mem 0x00000000aab3f000-0x00000000aeb3f000] (64MB)
[ 0.000000] Memory: 1760080K/2094080K available (12288K kernel code, 1465K rwdata, 3248K rodata, 2048K init, 306K bss, 104624K reserved, 229376K cma-reserved, 1245184K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000000] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000000] sched_clock: 32 bits at 33kHz, resolution 30517ns, wraps every 65535999984741ns
[ 0.001403] TI gptimer clockevent: always-on 32786 Hz at /ocp/interconnect@4ae00000/segment@10000/target-module@8000
[ 0.003143] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2c000
[ 0.003326] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2e000
[ 0.004425] Console: colour dummy device 80x30
[ 0.004455] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664)
[ 0.062072] CPU: Testing write buffer coherency: ok
[ 0.062103] CPU0: Spectre v2: using ICIALLU workaround
[ 0.062103] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[ 0.062103] pid_max: default: 32768 minimum: 301
[ 0.062255] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.062255] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.062866] /cpus/cpu@0 missing clock-frequency property
[ 0.062896] /cpus/cpu@1 missing clock-frequency property
[ 0.062927] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.063568] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.063568] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.063659] Setting up static identity map for 0x80200000 - 0x80200138
[ 0.063751] rcu: Hierarchical SRCU implementation.
[ 0.063751] rcu: Max phase no-delay instances is 1000.
[ 0.066040] EFI services will not be available.
[ 0.066589] smp: Bringing up secondary CPUs ...
[ 0.126800] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.126831] CPU1: Spectre v2: using ICIALLU workaround
[ 0.126922] smp: Brought up 1 node, 2 CPUs
[ 0.126922] SMP: Total of 2 processors activated (3994.41 BogoMIPS).
[ 0.126953] CPU: All CPU(s) started in HYP mode.
[ 0.126953] CPU: Virtualization extensions available.
[ 0.127349] devtmpfs: initialized
[ 0.152679] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.152862] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.152893] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.157012] pinctrl core: initialized pinctrl subsystem
[ 0.157623] DMI not present or invalid.
[ 0.158020] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.159729] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.160644] thermal_sys: Registered thermal governor 'step_wise'
[ 0.160675] cpuidle: using governor menu
[ 0.187164] platform ocp: Fixed dependency cycle(s) with /ocp/interconnect@4a000000/segment@0/target-module@8000/cm_core@0/clock@e00/clock@20
[ 0.187225] platform ocp: Fixed dependency cycle(s) with /ocp/interconnect@4a000000/segment@0/target-module@8000/cm_core@0/clock@700/clock@20
[ 0.190917] No ATAGs?
[ 0.190979] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.190979] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.209472] iommu: Default domain type: Translated
[ 0.209472] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.210815] SCSI subsystem initialized
[ 0.211120] usbcore: registered new interface driver usbfs
[ 0.211151] usbcore: registered new interface driver hub
[ 0.211181] usbcore: registered new device driver usb
[ 0.211578] pps_core: LinuxPPS API ver. 1 registered
[ 0.211578] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.211608] PTP clock support registered
[ 0.211730] EDAC MC: Ver: 3.0.0
[ 0.213409] clocksource: Switched to clocksource 32k_counter
[ 0.221160] NET: Registered PF_INET protocol family
[ 0.221343] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.233703] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.233734] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.233734] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.233795] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.234039] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.234100] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.234130] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.234252] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.234619] RPC: Registered named UNIX socket transport module.
[ 0.234619] RPC: Registered udp transport module.
[ 0.234619] RPC: Registered tcp transport module.
[ 0.234619] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.234619] PCI: CLS 0 bytes, default 64
[ 0.234985] armv7-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
[ 0.235168] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.235992] Initialise system trusted keyrings
[ 0.236328] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ 0.241577] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.242156] NFS: Registering the id_resolver key type
[ 0.242187] Key type id_resolver registered
[ 0.242187] Key type id_legacy registered
[ 0.242248] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.242279] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.242309] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.242736] Key type asymmetric registered
[ 0.242767] Asymmetric key parser 'x509' registered
[ 0.242889] bounce: pool size: 64 pages
[ 0.242950] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.242980] io scheduler mq-deadline registered
[ 0.242980] io scheduler kyber registered
[ 0.291625] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
[ 0.293579] STMicroelectronics ASC driver initialized
[ 0.302215] brd: module loaded
[ 0.306854] loop: module loaded
[ 0.311096] CAN device driver interface
[ 0.311462] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.311462] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.311492] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.311523] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.312316] pegasus: Pegasus/Pegasus II USB Ethernet driver
[ 0.312347] usbcore: registered new interface driver pegasus
[ 0.312377] usbcore: registered new interface driver asix
[ 0.312408] usbcore: registered new interface driver ax88179_178a
[ 0.312438] usbcore: registered new interface driver cdc_ether
[ 0.312469] usbcore: registered new interface driver smsc75xx
[ 0.312530] usbcore: registered new interface driver smsc95xx
[ 0.312561] usbcore: registered new interface driver net1080
[ 0.312561] usbcore: registered new interface driver cdc_subset
[ 0.312591] usbcore: registered new interface driver zaurus
[ 0.312652] usbcore: registered new interface driver cdc_ncm
[ 0.313323] usbcore: registered new interface driver usb-storage
[ 0.314086] i2c_dev: i2c /dev entries driver
[ 0.316040] cpu cpu0: Failed to set OPP config
[ 0.316436] sdhci: Secure Digital Host Controller Interface driver
[ 0.316467] sdhci: Copyright(c) Pierre Ossman
[ 0.316619] Synopsys Designware Multimedia Card Interface Driver
[ 0.316833] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.317474] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.317779] usbcore: registered new interface driver usbhid
[ 0.317779] usbhid: USB HID core driver
[ 0.320312] NET: Registered PF_INET6 protocol family
[ 0.321166] Segment Routing with IPv6
[ 0.321228] In-situ OAM (IOAM) with IPv6
[ 0.321289] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 0.321746] NET: Registered PF_PACKET protocol family
[ 0.321746] can: controller area network core
[ 0.321807] NET: Registered PF_CAN protocol family
[ 0.321807] can: raw protocol
[ 0.321807] can: broadcast manager protocol
[ 0.321838] can: netlink gateway - max_hops=1
[ 0.321990] Key type dns_resolver registered
[ 0.322021] ThumbEE CPU extension supported.
[ 0.322052] Registering SWP/SWPB emulation handler
[ 0.322448] omap_voltage_late_init: Voltage driver support not added
[ 0.322479] Power Management for TI OMAP4+ devices.
[ 0.323303] Loading compiled-in X.509 certificates
[ 0.357055] platform 4a000000.interconnect: Fixed dependency cycle(s) with /ocp/interconnect@4a000000/segment@0/target-module@8000/cm_core@0/clock@d00/clock@20
[ 0.362762] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[ 0.385070] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.401092] gpio gpiochip0: (gpio-0-31): not an immutable chip, please consider fixing it!
[ 0.401397] OMAP GPIO hardware version 0.1
[ 0.403717] ti-sysc: probe of 4ae18000.target-module failed with error -16
[ 0.410522] printk: console [ttyS2] disabled
[ 0.410583] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 100, base_baud = 3000000) is a 8250
[ 1.604156] printk: console [ttyS2] enabled
[ 1.616149] gpio gpiochip1: (gpio-32-63): not an immutable chip, please consider fixing it!
[ 1.625915] gpio gpiochip2: (gpio-64-95): not an immutable chip, please consider fixing it!
[ 1.635681] gpio gpiochip3: (gpio-96-127): not an immutable chip, please consider fixing it!
[ 1.645446] gpio gpiochip4: (gpio-128-159): not an immutable chip, please consider fixing it!
[ 1.655334] gpio gpiochip5: (gpio-160-191): not an immutable chip, please consider fixing it!
[ 1.665222] gpio gpiochip6: (gpio-192-223): not an immutable chip, please consider fixing it!
[ 1.675079] gpio gpiochip7: (gpio-224-255): not an immutable chip, please consider fixing it!
[ 1.685791] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.697570] palmas 0-0058: Irq flag is 0x00000008
[ 1.725311] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 1.757141] at24 0-0050: supply vcc not found, using dummy regulator
[ 1.763977] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
[ 1.770782] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.783538] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 1.790374] random: crng init done
[ 1.796386] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 1.813446] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 1.818389] sdhci-omap 4809c000.mmc: supply vqmmc not found, using dummy regulator
[ 1.826843] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[ 1.860656] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 1.883422] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.895721] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[ 1.905456] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY
[ 1.915802] cpsw-switch 48484000.switch: initialized cpsw ale version 1.4
[ 1.922637] cpsw-switch 48484000.switch: ALE Table size 1024
[ 1.928405] cpsw-switch 48484000.switch: cpts: overflow check period 500 (jiffies)
[ 1.936096] cpsw-switch 48484000.switch: CPTS: ref_clk_freq:266000000 calc_mult:4036623398 calc_shift:30 error:-1 nsec/sec
[ 1.947235] cpsw-switch 48484000.switch: Detected MACID = 5c:f8:21:0f:82:be
[ 1.954315] cpsw-switch 48484000.switch: Detected MACID = 5c:f8:21:0f:82:bf
[ 1.963073] cpsw-switch 48484000.switch: initialized (regs 0x0000000048484000, pool size 256) hw_ver:0019010F 1.15 (0)
[ 1.983795] mmc0: new high speed SDHC card at address aaaa
[ 1.987030] ti-sysc: probe of 4882c000.target-module failed with error -16
[ 1.996551] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 1.997161] ti-sysc: probe of 4882e000.target-module failed with error -16
[ 2.012084] mmcblk0: p1 p2
[ 2.027069] dra7-pcie 51000000.pcie: host bridge /ocp/target-module@51000000/pcie@51000000 ranges:
[ 2.036163] dra7-pcie 51000000.pcie: IO 0x0020003000..0x0020012fff -> 0x0000000000
[ 2.044342] dra7-pcie 51000000.pcie: MEM 0x0020013000..0x002fffffff -> 0x0020013000
[ 2.052642] dra7-pcie 51000000.pcie: iATU unroll: disabled
[ 2.058197] dra7-pcie 51000000.pcie: iATU regions: 16 ob, 4 ib, align 4K, limit 4G
[ 3.066711] dra7-pcie 51000000.pcie: Phy link never came up
[ 3.072448] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 3.078765] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.084289] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 3.090515] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 3.097473] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400
[ 3.103546] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 3.109832] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[ 3.116210] pci 0000:00:00.0: supports D1
[ 3.120239] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 3.133575] PCI: bus0: Fast back to back transfers disabled
[ 3.139526] PCI: bus1: Fast back to back transfers enabled
[ 3.145050] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 3.151885] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 3.158752] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 3.164367] pcieport 0000:00:00.0: PME: Signaling with IRQ 133
[ 3.176177] edma 43300000.dma: memcpy is disabled
[ 3.184295] edma 43300000.dma: TI EDMA DMA engine driver
[ 3.195983] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 3.203735] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 3.210388] platform 40800000.dsp: Adding to iommu group 0
[ 3.217498] platform 58820000.ipu: Adding to iommu group 1
[ 3.223175] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 3.231079] platform 55020000.ipu: Adding to iommu group 2
[ 3.236663] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 3.255340] ti_opp_supply: probe of 4a003b20.opp-supply failed with error 1
[ 3.264465] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 3.271728] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 3.278564] platform 41000000.dsp: Adding to iommu group 3
[ 3.286529] ti-sysc 4ae06000.target-module: Failed to create device link (0x180) with ocp
[ 3.325714] rtc-ds1307 2-006f: registered as rtc0
[ 3.330749] rtc-ds1307 2-006f: setting system clock to 2022-04-28T19:01:48 UTC (1651172508)
[ 3.342254] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: registered as rtc1
[ 3.352661] sdhci-omap 480b4000.mmc: supply pbias not found, using dummy regulator
[ 3.359069] l3init-clkctrl:0030:0: failed to disable
[ 3.391113] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 3.416198] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: disabled.
[ 3.425201] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.434478] devtmpfs: mounted
[ 3.438476] Freeing unused kernel image (initmem) memory: 2048K
[ 3.453521] Run /sbin/init as init process
[ 3.469482] mmc1: new DDR MMC card at address 0001
[ 3.474822] mmcblk1: mmc1:0001 S10004 3.56 GiB
[ 3.480682] mmcblk1: p1 p2 p3
[ 3.484344] mmcblk1boot0: mmc1:0001 S10004 4.00 MiB
[ 3.490386] mmcblk1boot1: mmc1:0001 S10004 4.00 MiB
[ 3.496276] mmcblk1rpmb: mmc1:0001 S10004 4.00 MiB, chardev (243:0)
[ 3.850372] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -L
IBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 3.882446] systemd[1]: Detected architecture arm.
Welcome to Arago 2023.10!
[ 3.927185] systemd[1]: Hostname set to <am57xx-evm>.
[ 4.067413] systemd-sysv-generator[108]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to
include a native systemd unit file, in order to make it more safe and robust.
[ 4.096557] systemd-sysv-generator[108]: SysV service '/etc/init.d/gdbserverproxy' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to in
[ 4.372100] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the set
ting altogether.
[ 4.444458] systemd[1]: /etc/systemd/system/sys-clock-drift.service:10: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing
the setting altogether.
[ 4.468780] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the
setting altogether.
[ 4.549285] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.558685] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 4.594390] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 4.634582] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 4.673919] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.713806] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 4.753662] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 4.794067] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 4.823638] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.863555] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 4.893585] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 4.941619] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 4.983612] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 5.035888] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 5.073791] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 5.150726] systemd[1]: Journal Audit Socket was skipped because of a failed condition check (ConditionSecurity=audit).
[ 5.162200] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 5.204040] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 5.234588] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 5.273986] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 5.314300] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 5.353851] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 5.394012] systemd[1]: Huge Pages File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 5.453826] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.495819] systemd[1]: Mounting Kernel Debug File System...
[ 5.536132] systemd[1]: Mounting Kernel Trace File System...
[ 5.570526] systemd[1]: Mounting Temporary Directory /tmp...
[ 5.607421] systemd[1]: Starting Create List of Static Device Nodes...
[ 5.657348] systemd[1]: Starting Load Kernel Module configfs...
[ 5.698028] systemd[1]: Starting Load Kernel Module drm...
[ 5.736297] systemd[1]: Starting Load Kernel Module fuse...
[ 5.833984] systemd[1]: Starting Start psplash boot splash screen...
[ 5.877014] systemd[1]: Starting RPC Bind...
[ 5.913879] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 5.927185] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 5.940124] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 5.950927] systemd[1]: Starting Journal Service...
[ 5.988098] systemd[1]: Starting Load Kernel Modules...
[ 6.012756] cryptodev: loading out-of-tree module taints kernel.
[ 6.020599] cryptodev: driver 1.12 loaded.
[ 6.026916] systemd[1]: Starting Generate network units from Kernel command line...
Starting Generate network …ts from Kernel command line...
[ 6.065673] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.095397] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: disabled.
[ 6.106567] systemd[1]: Starting Coldplug All udev Devices...
[ 6.151306] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 6.183837] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Trace File System.
[ OK ] Mounted Temporary Directory /tmp.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 6.800537] systemd-journald[121]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /media/ram...
Mounting /var/volatile...
Starting Rule-based Manage…for Device Events and Files...
[ OK ] Mounted /media/ram.
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Mounted /var/volatile.
[ OK ] Started Rule-based Manager for Device Events and Files.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Create Volatile Files and Directories.
[ 7.608520] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
Starting Network Time Synchronization...
[ 7.642517] omap-sham 4b101000.sham: will run requests pump with realtime priority
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Found device /dev/ttyS2.[ 7.861145] omap-sham 42701000.sham: hw accel on OMAP rev 4.3
[ 7.874816] omap-sham 42701000.sham: will run requests pump with realtime priority
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ 7.990142] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 8.028961] omap-des 480a5000.des: will run requests pump with realtime priority
[ 8.201690] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 8.211730] omap_rtc 48838000.rtc: registered as rtc2
[ 8.234619] mc: Linux media interface: v0.10
[ 8.259796] videodev: Linux video capture interface: v2.00
[ 8.276519] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[ 8.300079] remoteproc remoteproc0: 58820000.ipu is available
[ 8.312438] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 8.321990] remoteproc remoteproc1: 40800000.dsp is available
[ 8.328063] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 8.370086] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[ 8.393615] remoteproc remoteproc2: 41000000.dsp is available
[ 8.430419] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[ 8.460449] remoteproc remoteproc3: 55020000.ipu is available
[ 8.778930] remoteproc remoteproc0: powering up 58820000.ipu
[ 8.784759] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4959964
[ 8.820556] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 8.847869] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node ipu1-memory@9d000000
[ 8.864196] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 8.865997] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
[ 8.878356] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
[ 8.882690] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
[ 8.893432] remoteproc remoteproc0: remote processor 58820000.ipu is now up
[ 8.900909] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
[ 8.910491] ahci-dwc 4a140000.sata: supply ahci not found, using dummy regulator
[ 8.918823] ahci-dwc 4a140000.sata: supply phy not found, using dummy regulator
[ 8.926818] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[ 8.935058] ahci-dwc 4a140000.sata: supply target not found, using dummy regulator
[ 8.943786] ahci-dwc 4a140000.sata: forcing port_map 0x0 -> 0x1
[ 8.949951] ahci-dwc 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 8.959045] ahci-dwc 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
[ 8.969757] scsi host0: ahci-dwc
[ 8.978240] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 159
[ 9.111938] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 9.197326] remoteproc remoteproc1: powering up 40800000.dsp
[ 9.203033] remoteproc remoteproc1: Booting fw image dra7-dsp1-fw.xe66, size 5648812
[ 9.212677] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 9.218597] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 9.233276] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node dsp1-memory@99000000
[ 9.244323] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 9.245605] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x32
[ 9.250305] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
[ 9.260223] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x33
[ 9.264770] remoteproc remoteproc1: remote processor 40800000.dsp is now up
[ 9.273468] virtio_rpmsg_bus virtio1: creating channel rpmsg-omx addr 0x3c
[ 9.287109] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[ 9.295623] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 9.295684] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on minor 0
[ 9.301666] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 9.316711] ata1: SATA link down (SStatus 0 SControl 300)
[ 9.317352] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 9.328338] omap-aes 4b700000.aes: will run requests pump with realtime priority
[ 9.430816] remoteproc remoteproc2: powering up 41000000.dsp
[ 9.438323] remoteproc remoteproc2: Booting fw image dra7-dsp2-fw.xe66, size 5648940
[ OK ] Started Network Time Synchronizatio[ 9.451629] remoteproc remoteproc3: powering up 55020000.ipu
n.
[ OK ] Reached target System Initializatio[ 9.498779] remoteproc remoteproc3: Booting fw image dra7-ipu2-fw.xem4, size 3751356
n.
[ 9.514495] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 9.520477] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ OK ] Started Daily Cleanup of Temporary [ 9.549163] DSS: OMAP DSS rev 6.1
Directories.
[ 9.556060] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ OK ] Reached target System Time Set.
[ 9.612731] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timer Units.
[ 9.694274] vpe 489d0000.vpe: Device registered as /dev/video0
[ 9.694702] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops [omapdrm])
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API...
[ 9.835021] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops [omapdrm])
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on PC/SC Smart Card Daemon Activation Socket.
Starting Weston socket...
Starting D-Bus System Message Bus...
[ 9.959259] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node dsp2-memory@9f000000
Starting Reboot and dump vmcore via kexec...
[ OK ] Listening on Docker Socket for the [ 10.040344] dmm 4e000000.dmm: workaround for errata i878 in use
API.
[ OK ] Listening on Weston socket.
[ OK ] Reached target Socket Units.
[ OK ] Finished Reboot and dump vmcore via kexec.
[ 10.230316] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node ipu2-memory@95800000
[ 10.422149] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 10.433349] rproc-virtio rproc-virtio.3.auto: registered virtio2 (type 7)
[ 10.501800] remoteproc remoteproc2: remote processor 41000000.dsp is now up
[ OK ] Started D-Bus System Message Bus.
[ 10.578155] virtio_rpmsg_bus virtio2: creating channel rpmsg-client-sample addr 0x32
[ 10.708038] dmm 4e000000.dmm: initialized all PAT entries
[ 10.719085] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 10.726959] virtio_rpmsg_bus virtio3: creating channel rpmsg-rpc addr 0x65
[ 10.761352] virtio_rpmsg_bus virtio2: creating channel rpmsg-client-sample addr 0x33
[ 10.769195] rproc-virtio rproc-virtio.4.auto: registered virtio3 (type 7)
[ OK ] Reached target Basic System.
[ 10.784545] virtio_rpmsg_bus virtio3: creating channel rpmsg-rpc addr 0x66
[ 10.797729] omapdss error: HDMI I2C Master Error
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[ 10.829498] virtio_rpmsg_bus virtio2: creating channel rpmsg-omx addr 0x3c
[ 10.849914] remoteproc remoteproc3: remote processor 55020000.ipu is now up
[ 10.859649] [drm] Enabling DMM ywrap scrolling
[ OK ] Started Job spooling tools.
[ 10.904663] virtio_rpmsg_bus virtio2: creating channel rpmsg-rpc addr 0x65
[ OK ] Started Periodic Command Scheduler.
[ 10.952545] Console: switching to colour frame buffer device 128x48
[ 10.988677] omapdrm omapdrm.0: [drm] fb0: omapdrmdrmfb frame buffer device
Starting DEMO...
[ 11.020172] ------------[ cut here ]------------
[ 11.291656] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 1
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
Starting Telephony service...
Starting Expand the rootfs…ll size of the boot device....
[ OK ] Started strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
Starting User Login Management...
[ 11.647033] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
Starting Telnet Server...
Starting TI IPC Daemon...
[ 11.672943] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 1
[ OK ] Started DEMO.
[ OK ] Finished IPv6 Packet Filtering Framework.
[ OK ] Finished IPv4 Packet Filtering Framework.
[ 11.817535] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[ 11.884246] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000008002010010
[ 11.925109] xhci-hcd xhci-hcd.6.auto: irq 165, io mem 0x48890000
[ 11.932525] omap-hdmi-audio omap-hdmi-audio.5.auto: ASoC: driver name too long 'HDMI 58040000.encoder' -> 'HDMI_58040000_e'
[ 11.985443] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ OK ] Finished Telnet Server.
[ OK ] Started TI IPC Daemon.
[ OK ] Started Telephony service.
[ 12.034576] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 2
[ 12.042327] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[ 12.057952] Bluetooth: Core ver 2.22
[ 12.062042] NET: Registered PF_BLUETOOTH protocol family
[ 12.070648] Bluetooth: HCI device and connection manager initialized
[ 12.082519] Bluetooth: HCI socket layer initialized
[ 12.083282] hub 1-0:1.0: USB hub found
[ 12.095825] Bluetooth: L2CAP socket layer initialized
[ 12.112304] hub 1-0:1.0: 1 port detected
[ 12.118255] Bluetooth: SCO socket layer initialized
[ 12.121459] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 12.139892] hub 2-0:1.0: USB hub found
[ 12.148162] hub 2-0:1.0: 1 port detected
[ OK ] Finished Expand the rootfs…full size of the boot device..
[ 12.413482] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 12.659790] hub 1-1:1.0: USB hub found
[ 12.667999] hub 1-1:1.0: 4 ports detected
[ 12.774230] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 12.835388] hub 2-1:1.0: USB hub found
[ 12.847381] hub 2-1:1.0: 4 ports detected
[ 12.865966] usbcore: registered new device driver onboard-usb-hub
[ 12.937316] Initializing XFRM netlink socket
[ 13.139587] hub 1-1:1.0: USB hub found
[ 13.144439] hub 1-1:1.0: 4 ports detected
[ 13.314300] omapdss error: HDMI I2C Master Error
[ 13.320068] hub 1-1:1.0: USB hub found
[ 13.325195] hub 1-1:1.0: 4 ports detected
[ 13.475799] hub 2-1:1.0: USB hub found
[ 13.479583] hub 2-1:1.0: 4 ports detected
[ 13.524688] hub 2-1:1.0: USB hub found
[ 13.531829] hub 2-1:1.0: 4 ports detected
[ 13.703430] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd
[ 13.879486] input: Logitech USB Optical Mouse as /devices/platform/ocp/48800000.interconnect/48800000.interconnect:segment@0/48880000.target-module/48880000.omap_dwc3_1/48890000.usb/xhci-hcd.6.auto/us
b1/1-1/1-1.1/1-1.1:1.0/0003:046D:C077.0001/input/input0
[ 13.904113] hid-generic 0003:046D:C077.0001: input: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-xhci-hcd.6.auto-1.1/input0
[ OK ] Created slice Slice /system/systemd-fsck.
[ OK ] Reached target Preparation for Network.
[ OK ] Reached target Hardware activated USB gadget.
Starting Save/Restore Sound Card State...
Starting File System Check on /dev/mmcblk0p1...
Starting File System Check on /dev/mmcblk1p1...
Starting File System Check on /dev/mmcblk1p2...
Starting File System Check on /dev/mmcblk1p3...
Starting Network Configuration...
[ 14.033447] usb 1-1.2: new low-speed USB device number 4 using xhci-hcd
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
[ OK ] Finished File System Check on /dev/mmcblk1p1.
Mounting /run/media/mmcblk1p1...
[ OK ] Finished File System Check on /dev/mmcblk0p1.
[ OK ] Finished File System Check on /dev/mmcblk1p2.
Mounting /run/media/boot-mmcblk0p1...
[ 14.266387] input: Logitech USB Keyboard as /devices/platform/ocp/48800000.interconnect/48800000.interconnect:segment@0/48880000.target-module/48880000.omap_dwc3_1/48890000.usb/xhci-hcd.6.auto/usb1/1-
1/1-1.2/1-1.2:1.0/0003:046D:C31D.0002/input/input1
Mounting /run/media/mmcblk1p2...
[ 14.350372] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 14.358917] hid-generic 0003:046D:C31D.0002: input: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.6.auto-1.2/input0
[ OK ] Mounted /run/media/mmcblk1p1.
[ 14.394927] input: Logitech USB Keyboard Consumer Control as /devices/platform/ocp/48800000.interconnect/48800000.interconnect:segment@0/48880000.target-module/48880000.omap_dwc3_1/48890000.usb/xhci-h
cd.6.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C31D.0003/input/input2
[ OK ] Finished File System Check on /dev/mmcblk1p3.
[ OK ] Mounted /run/media/mmcblk1p2.
[ 14.448547] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 14.456024] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Mounting /run/media/mmcblk1p3...
[ 14.496398] input: Logitech USB Keyboard System Control as /devices/platform/ocp/48800000.interconnect/48800000.interconnect:segment@0/48880000.target-module/48880000.omap_dwc3_1/48890000.usb/xhci-hcd
.6.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C31D.0003/input/input3
[ OK ] Mounted /run/media/boot-mmcblk0p1 14.521087] hid-generic 0003:046D:C31D.0003: input: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.6.auto-1.2/input1
0m.
[ OK ] Mounted /run/media/mmcblk1p3.
[ OK ] Started Network Configuration.
[ 14.650115] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
Starting Network Name Resolution...
[ 14.754425] Micrel KSZ9031 Gigabit PHY 48485000.mdio:02: attached PHY driver (mii_bus:phy_addr=48485000.mdio:02, irq=POLL)
[ 14.778808] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
[ 14.884948] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver (mii_bus:phy_addr=48485000.mdio:01, irq=POLL)
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
Starting Enable and configure wl18xx bluetooth stack...
Starting containerd container runtime...
[ OK ] Started Netperf Benchmark Server.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Finished Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
Starting Weston, a Wayland…ositor, as a system service...
[ OK ] Finished Enable and configure wl18xx bluetooth stack.
Starting User Database Manager...
[ OK ] Started User Database Manager.
[ OK ] Created slice User Slice of UID 1000.
Starting User Runtime Directory /run/user/1000...
[ OK ] Finished User Runtime Directory /run/user/1000.
Starting User Manager for UID 1000...
[ OK ] Finished Synchronize System and HW clocks.
[ OK ] Started system clock drift service.
NOTICE: This file system contains the following GPL-3.0 packages:
adwaita-icon-theme-symbolic
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbc6x
gdbserver
gettext
glmark2
gnu-config
gzip
hidapi
less
libasm1
libatomic-dev
libatomic1
libbfd
libdebuginfod1
libdw1
libelf1
libgcc-s-dev
libgcc1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp10
libgomp1
libidn2-0
libmpc3
libmpfr6
libopcodes
libqt5charts-examples
libqt5charts-plugins
libqt5charts-qmlplugins
libqt5charts5
libqt5sensors-plugins
libqt5sensors-qmlplugins
libqt5sensors5
libqt5serialport-examples
libqt5serialport-plugins
libqt5serialport-qmlplugins
libqt5serialport5
libqt5svg-examples
libqt5svg-plugins
libqt5svg-qmlplugins
libqt5svg5
libqt5virtualkeyboard-plugins
libqt5virtualkeyboard-qmlplugins
libqt5virtualkeyboard5
libqt5webchannel-plugins
libqt5webchannel-qmlplugins
libqt5webchannel5
libreadline-dev
libreadline8
libstdc++-dev
libstdc++6
libunistring2
m4-dev
m4
make
nettle
parted
pdm-anomaly-detection
piglit
qt3d-plugins
qt3d-qmlplugins
qt3d
qtbase-examples
qtbase-plugins
qtbase-qmlplugins
qtbase
qtconnectivity-plugins
qtconnectivity-qmlplugins
qtconnectivity
qtdeclarative-plugins
qtdeclarative-qmlplugins
qtdeclarative-tools
qtdeclarative
qtgraphicaleffects-qmlplugins
qtlocation-examples
qtlocation-plugins
qtlocation-qmlplugins
qtlocation
qtmultimedia-examples
qtmultimedia-plugins
qtmultimedia-qmlplugins
qtmultimedia
qtquics-qmlplugins.control
qtquics2-plugins.control
qtquics2-qmlplugins.control
qtquics2.control
qtscript-examples
qtscript-plugins
qtscript-qmlplugins
qtscript
qtwayland-examples
qtwayland-plugins
qtwayland-qmlplugins
qtwayland
tar
which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[ OK ] Finished Print notice about GPLv3 packages.
[ OK ] Started containerd container runtime.
[ OK ] Reached target Multi-User System.
[ OK ] Started User Manager for UID 1000.
[ OK ] Started Session c1 of User weston.
[ 18.558135] omapdss error: HDMI I2C Master Error
[ OK ] Started Weston, a Wayland …mpositor, as a system service.
[ OK ] Reached target Graphical Interface.
Starting Record Runlevel Change in UTMP...
[ OK ] Finished Record Runlevel Change in UTMP.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project am57xx-evm -
Arago 2023.10 am57xx-evm -
am57xx-evm login: root
root@am57xx-evm:~#
root@am57xx-evm:~# uname -a
Linux am57xx-evm 6.1.80-ti-g2e423244f8c0 #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024 armv7l armv7l armv7l GNU/Linux
2dpainting/ contextinfo/ hellogl2/ hellowindow/ paintedwindow/ qopenglwindow/ threadedqopenglwidget/
computegles31/ cube/ hellogles3/ legacy/ qopenglwidget/ textures/
root@am57xx-evm:~# /usr/share/examples/opengl/hellowindow/hellowindow -platform wayland
root@am57xx-evm:~# /usr/share/examples/opengl/hellowindow/hellowindow -platform wayland-egl
root@am57xx-evm:~# /usr/share/examples/opengl/hellowindow/hellowindow -platform w^C
root@am57xx-evm:~# /usr/share/examples/opengl/hellogl2/hellogl2
root@am57xx-evm:~#
