AM625SIP: Read GPIO in R5 SPL for board detection
Part Number: AM625SIP
Other Parts Discussed in Thread: AM625
Hi TI,
We we are using multiple different AM62 for development, both AM621 with discrete memory and AM62SIP on customs boards.  I would like to support both boards with the same build.  We have 3 GPIO that can be read on boot to select the board.  Since I have to deal with different DDR configurations.  I need to select it early on in the R5 SPL.
I was attempting to copy what am642_init.c was doing in uboot with do_board_init
#ifdef CONFIG_SPL_OF_LIST
void do_dt_magic(void)
	int ret, rescan;
	/* Perform board detection */
	do_board_detect();
	 * Board detection has been done.
	 * Let us see if another dtb wouldn't be a better match
	 * for our board
	if (IS_ENABLED(CONFIG_CPU_V7R)) {
		ret = fdtdec_resetup(&rescan);
		if (!ret && rescan) {
			dm_uninit();
			dm_init_and_scan(true);
#endif
I have these set in my config
CONFIG_SPL_OF_CONTROL=y
CONFIG_SPL_DM=y
CONFIG_SPL_DM_GPIO=y
CONFIG_SPL_DM_GPIO_LOOKUP_LABEL=y
My do_board_detect
#if defined(CONFIG_SPL_LOAD_FIT)
void do_board_detect(void)
	struct gpio_desc desc;
	int ret;
	printf("do_board_detect\n");
	ret = dm_gpio_lookup_name("SOM_ID_MSB", &desc);
	if (ret)
		printf("Cannot get SOM_ID_MSB\n");
	/* Request GPIO, simply re-using the name as label */
	ret = dm_gpio_request(&desc, "SOM_ID_MSB");
	printf("dm_gpio_request %d\n",ret);
	ret = dm_gpio_set_dir_flags(&desc, GPIOD_IS_IN);
	printf("dm_gpio_set_dir_flags %d\n",ret);
	ret = dm_gpio_get_value(&desc);
	printf("dm_gpio_get_value %d\n",ret);
I am including <asm/gpio.h>
But still getting these errors.
/am62x/lgsom.c:81:(.text.do_board_detect+0x1c): undefined reference to `dm_gpio_request'
/am62x/lgsom.c:84:(.text.do_board_detect+0x2e): undefined reference to `dm_gpio_set_dir_flags'
/am62x/lgsom.c:87:(.text.do_board_detect+0x3c): undefined reference to `dm_gpio_get_value'
Before I dig into it too much more.  Would this be the recommended way to do this?  Or would there be a different better way?
  • My mistake on the errors.  I was changing the my uboot r5_defconfig, but building the r5_usbdfu_defconfig.  No SDcard so for a raw board we need the usbdfu to load the FW.
    I see there is the dm_gpio_* way to do things or the legacy gpio request.  I assume the dm_gpio way is preferred over something like this?
    	uint32_t ret = gpio_request(SOM_ID_GPIO_PIN_1, "");
    	if (ret < 0) {
    			printf("Unable to request GPIO %d\n", ret);
    	ret = gpio_direction_input(SOM_ID_GPIO_PIN_1);
    	if (ret < 0) {
    			printf("Unable to config GPIO %d\n", ret);
    I am not aware of the APIs that can work in R5 SPL. Will register write using writel() work for your usecase?
    Meanwhile, I can check internally regarding this support.
    Aparna
  • Hi Bryce,
    DM_GPIO should work fine. Just make sure there is not any dependencies on the legacy interface.
    Anshu
  • Hi Anshu and Aparna,
    I was able to get closer.  I am able to read the GPIO in the R5 spl.
    static u32 unit_id;
    const char *gpio_table_som_id[] = {
        "gpio@600000_44", "gpio@600000_43", "gpio@600000_42",
    ///Inspired by uboot/board/liebherr/display5/display5.c
    static int get_board_id(const char **pin_names, int size, u32 *id)
        int i, ret, val;
        for (i = 0; i < size; i++) {
            memset(&desc, 0, sizeof(desc));
            ret = dm_gpio_lookup_name(pin_names[i], &desc);
            if (ret) {
                printf("Can't lookup request SWx gpios %d\n",ret);
                return ret;
            ret = dm_gpio_request(&desc, pin_names[i]);
            if (ret) {
                printf("Can't lookup request SWx gpios: %d\n",ret);
                return ret;
            if (ret) {
                printf("error setting direction flag of GPIO: %d\n", ret);
                return ret;
            val = dm_gpio_get_value(&desc);
            if (val < 0) {
                printf("Can't get SW%d ID\n", i);
                return val;
            printf("Pin %d: val %d\n",i, val);
            *id |= val << i;
        return 0;
    I had to add
    &gpio0_pins_default {
        bootph-all;
    &main_gpio0 {
        bootph-all;
    To my *-uboot.dtsi
    To am625_init.c. I added do_dt_magic(); in the same way done on am642_init.c and other TI processes.
        /* Output System Firmware version info */
        k3_sysfw_print_ver();
        printf("am625_init board_init_f\n");
        do_dt_magic();
        if (IS_ENABLED(CONFIG_ESM_K3)) {
            /* Probe/configure ESM0 */
            ret = uclass_get_device_by_name(UCLASS_MISC, "esm@420000", &dev);
            if (ret)
                printf("esm main init failed: %d\n", ret);
    The problem I'm having now is i'm getting alloc space exhausted errors:
    U-Boot SPL 2024.01 (Jan 01 2024 - 01:00:00 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    Pin 0: val 1
    Pin 1: val 0
    Pin 2: val 0
    HostID 0x1
    HostID selects k3-am625-r5-lgsom-discrete dts
    esm main init failed: -12
    esm mcu init failed: -12
    DRAM init failed: -12
    resetting ...
    I tried increasing my alloc space to
    CONFIG_SPL_SYS_MALLOC_F_LEN=0xB000
    And got a different alloc error.
    Seems to happen with the dm_uninit and init and scan when it loads the new dts?  Or shortly after?
    dm_uninit();
    // SPDX-License-Identifier: GPL-2.0+
     * Board specific initialization for AM62x platforms
     * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/
     *	Suman Anna <s-anna@ti.com>
    #include <common.h>
    #include <env.h>
    #include <spl.h>
    #include <init.h>
    #include <cpu_func.h>
    #include <k3-ddrss.h>
    #include <fdt_support.h>
    #include <asm/io.h>
    #include <asm/arch/hardware.h>
    #include <dm/uclass.h>
    #include <asm/gpio.h>
    #include <linux/sizes.h>
    			// AM62X_IOPAD(0x00ac, PIN_INPUT, 7) /* (L21) GPMC0_CSn1.GPIO0_42 SOM_ID MSB*/
    			// AM62X_IOPAD(0x00b0, PIN_INPUT, 7) /* (K22) GPMC0_CSn2.GPIO0_43 SOM_ID*/
    			// AM62X_IOPAD(0x00b4, PIN_INPUT, 7) /* (K24) GPMC0_CSn3.GPIO0_44 SOM_ID LSB*/
    DECLARE_GLOBAL_DATA_PTR;
    #if defined(CONFIG_SPL_BUILD)
    static u32 unit_id;
    	int i, ret, val;
    		if (ret) {
    			return ret;
    		if (ret) {
    			return ret;
    		if (ret) {
    			return ret;
    		if (val < 0) {
    			return val;
    		*id |= val << i;
    	return 0;
    #endif
    int board_init(void)
    	printf("board_init\n");
    	return 0;
    int dram_init(void)
    	printf("dram_init\n");
    	return fdtdec_setup_mem_size_base();
    int dram_init_banksize(void)
    	return fdtdec_setup_memory_banksize();
    phys_size_t get_effective_memsize(void)
    	 * Just below 512MB are TF-A and OPTEE reserve regions, thus
    	 * SPL/U-Boot RAM has to start below that. Leave 64MB space for
    	 * all reserved memories.
    	return gd->ram_size == SZ_512M ? SZ_512M - SZ_64M  : gd->ram_size;
    	int ret;
    	ret = get_board_id(gpio_table_som_id, ARRAY_SIZE(gpio_table_som_id), &unit_id);
    	if (ret) {
    		printf("get_board_id failure %d\n",ret);
    	} else {
    		printf("HostID 0x%x\n", unit_id);
    int board_fit_config_name_match(const char *name)
    	if (unit_id == 0)
    		printf("HostID selects k3-am625-r5-lgsom-sip dts\n");
    		if (!strcmp(name, "k3-am625-r5-lgsom-sip"))
    			return 0;
    	} else if (unit_id == 1) {
    		printf("HostID selects k3-am625-r5-lgsom-discrete dts\n");
    		if (!strcmp(name, "k3-am625-r5-lgsom-discrete"))
    			return 0;
    	return -1;
    #endif
    #define CTRLMMR_USB0_PHY_CTRL	0x43004008
    #define CORE_VOLTAGE		0x80000000
    void spl_board_init(void)
    	printf("Set USB core voltage\n");
    	u32 val;
    	/* Set USB0 PHY core voltage to 0.85V */
    	val = readl(CTRLMMR_USB0_PHY_CTRL);
    	val &= ~(CORE_VOLTAGE);
    	writel(val, CTRLMMR_USB0_PHY_CTRL);
    #if defined(CONFIG_K3_AM64_DDRSS)
    static void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image)
    	struct udevice *dev;
    	int ret;
    	dram_init_banksize();
    	ret = uclass_get_device(UCLASS_RAM, 0, &dev);
    	if (ret)
    		panic("Cannot get RAM device for ddr size fixup: %d\n", ret);
    	ret = k3_ddrss_ddr_fdt_fixup(dev, spl_image->fdt_addr, gd->bd);
    	if (ret)
    		printf("Error fixing up ddr node for ECC use! %d\n", ret);
    #else
    static void fixup_memory_node(struct spl_image_info *spl_image)
    	u64 start[CONFIG_NR_DRAM_BANKS];
    	u64 size[CONFIG_NR_DRAM_BANKS];
    	int bank;
    	int ret;
    	dram_init();
    	for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) {
    		start[bank] =  gd->bd->bi_dram[bank].start;
    		size[bank] = gd->bd->bi_dram[bank].size;
    	/* dram_init functions use SPL fdt, and we must fixup u-boot fdt */
    	ret = fdt_fixup_memory_banks(spl_image->fdt_addr, start, size,
    				     CONFIG_NR_DRAM_BANKS);
    	if (ret)
    		printf("Error fixing up memory node! %d\n", ret);
    #endif
    void spl_perform_fixups(struct spl_image_info *spl_image)
    	fixup_ddr_driver_for_ecc(spl_image);
    #else
    	fixup_memory_node(spl_image);
    #endif
    #endif
    #ifdef CONFIG_BOARD_LATE_INIT
    int board_late_init(void)
    	return 0;
    #endif
  • Hello Bryce,
    Could you try increasing the size of SPL_STACK_R_MALLOC_SIMPLE_LEN and try booting again?
    Please share the boot logs of this error.
    Aparna
  • I increased it to CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200000
    Pin 0: val 1
    Pin 1: val 0
    Pin 2: val 0
    SomID 0x1
    SomID selects k3-am625-r5-lgsom-discrete dts
    ti_power_domain_probe(dev=43c38104)
    In a bunch of trial and error if I remove the dm_uninit() and dm_init_and_scan() it appears to work with to alloc errors but that doesn't seem like the right think to do.
    	int ret, rescan;
    	do_board_detect();
    	 * for our board
    		// if (!ret && rescan) {
    		// 	dm_uninit();
    		// 	dm_init_and_scan(true);
    Pin 0: val 1
    Pin 1: val 0
    Pin 2: val 0
    SomID 0x1
    dram_init
    SPL initial stack usage: 13368 bytes
    Trying to boot from DFU
    Please share the .patch file of all your changes
    Aparna
  • Here is the patch applied to 866ca972d6c3cabeaf6dbac431e8e08bb30b3c8e (Prepare v2024.01)
    From 4c79c71fda8c4fa5ca58b1d1de5a5afde7f2f974 Mon Sep 17 00:00:00 2001
    Date: Mon, 1 Jul 2024 16:33:02 +0000
    Subject: [PATCH] lgsom
     arch/arm/dts/Makefile                         |    8 +-
     arch/arm/dts/k3-am625-lgsom-binman.dtsi       |  463 ++++
     arch/arm/dts/k3-am625-lgsom-u-boot.dtsi       |  157 ++
     arch/arm/dts/k3-am625-lgsom.dts               |  433 ++++
     arch/arm/dts/k3-am625-r5-lgsom-discrete.dts   |   78 +
     arch/arm/dts/k3-am625-r5-lgsom-sip.dts        |   78 +
     .../arm/dts/k3-am62x-issi-ddr-lp4-50-800.dtsi | 2193 +++++++++++++++++
     arch/arm/dts/k3-am62x-sip-ddr-lp4-50-800.dtsi | 2191 ++++++++++++++++
     arch/arm/dts/k3-binman.dtsi                   |   36 +-
     arch/arm/mach-k3/Kconfig                      |    1 +
     arch/arm/mach-k3/am625_init.c                 |   27 +
     board/landisgyr/am62x/Kconfig                 |   58 +
     board/landisgyr/am62x/MAINTAINERS             |    8 +
     board/landisgyr/am62x/Makefile                |    8 +
     board/landisgyr/am62x/am62x.env               |   33 +
     board/landisgyr/am62x/board-cfg.yaml          |   36 +
     board/landisgyr/am62x/lgsom.c                 |  227 ++
     board/landisgyr/am62x/pm-cfg.yaml             |   12 +
     board/landisgyr/am62x/rm-cfg.yaml             | 1088 ++++++++
     board/landisgyr/am62x/sec-cfg.yaml            |  379 +++
     board/ti/am62x/am62x.env                      |    1 +
     configs/am62x_evm_a53_defconfig               |   31 +-
     configs/am62x_r5_usbdfu.config                |   28 +
     drivers/usb/dwc3/Kconfig                      |   14 +
     drivers/usb/dwc3/Makefile                     |    1 +
     drivers/usb/dwc3/core.c                       |   10 +-
     drivers/usb/dwc3/core.h                       |    1 +
     drivers/usb/dwc3/dwc3-am62.c                  |  125 +
     drivers/usb/dwc3/gadget.c                     |    6 +
     include/configs/am62x_lgsom.h                 |   15 +
     30 files changed, 7718 insertions(+), 28 deletions(-)
     create mode 100644 arch/arm/dts/k3-am625-lgsom-binman.dtsi
     create mode 100644 arch/arm/dts/k3-am625-lgsom-u-boot.dtsi
     create mode 100644 arch/arm/dts/k3-am625-lgsom.dts
     create mode 100644 arch/arm/dts/k3-am625-r5-lgsom-discrete.dts
     create mode 100644 arch/arm/dts/k3-am625-r5-lgsom-sip.dts
     create mode 100644 arch/arm/dts/k3-am62x-issi-ddr-lp4-50-800.dtsi
     create mode 100644 arch/arm/dts/k3-am62x-sip-ddr-lp4-50-800.dtsi
     create mode 100644 board/landisgyr/am62x/Kconfig
     create mode 100644 board/landisgyr/am62x/MAINTAINERS
     create mode 100644 board/landisgyr/am62x/Makefile
     create mode 100644 board/landisgyr/am62x/am62x.env
     create mode 100644 board/landisgyr/am62x/board-cfg.yaml
     create mode 100644 board/landisgyr/am62x/lgsom.c
     create mode 100644 board/landisgyr/am62x/pm-cfg.yaml
     create mode 100644 board/landisgyr/am62x/rm-cfg.yaml
     create mode 100644 board/landisgyr/am62x/sec-cfg.yaml
     create mode 100644 configs/am62x_r5_usbdfu.config
     create mode 100644 drivers/usb/dwc3/dwc3-am62.c
     create mode 100644 include/configs/am62x_lgsom.h
    diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile
    index 9d28a485be..570cd81246 100644
    --- a/arch/arm/dts/Makefile
    +++ b/arch/arm/dts/Makefile
    @@ -1410,10 +1410,10 @@ dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \
     dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-sk.dtb \
     			      k3-am625-r5-sk.dtb \
    -			      k3-am625-beagleplay.dtb \
    -			      k3-am625-r5-beagleplay.dtb \
    -			      k3-am625-verdin-wifi-dev.dtb \
    -			      k3-am625-verdin-r5.dtb
    +				  k3-am625-lgsom.dtb \
    +				  k3-am625-r5-lgsom-sip.dtb \
    +  				  k3-am625-r5-lgsom-discrete.dtb
     dtb-$(CONFIG_SOC_K3_AM62A7) += k3-am62a7-sk.dtb \
     			      k3-am62a7-r5-sk.dtb
    diff --git a/arch/arm/dts/k3-am625-lgsom-binman.dtsi b/arch/arm/dts/k3-am625-lgsom-binman.dtsi
    new file mode 100644
    index 0000000000..ecffa29fff
    --- /dev/null
    +++ b/arch/arm/dts/k3-am625-lgsom-binman.dtsi
    @@ -0,0 +1,463 @@
    +// SPDX-License-Identifier: GPL-2.0
    + * Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/
    +#include "k3-binman.dtsi"
    +#ifdef CONFIG_TARGET_AM625_R5_LGSOM
    +&binman {
    +	tiboot3-am62x-hs-evm.bin {
    +		filename = "tiboot3-am62x-hs-evm.bin";
    +		ti-secure-rom {
    +			content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>,
    +				<&combined_dm_cfg>, <&sysfw_inner_cert>;
    +			combined;
    +			dm-data;
    +			sysfw-inner-cert;
    +			keyfile = "custMpk.pem";
    +			sw-rev = <1>;
    +			content-sbl = <&u_boot_spl>;
    +			content-sysfw = <&ti_fs_enc>;
    +			content-sysfw-data = <&combined_tifs_cfg>;
    +			content-sysfw-inner-cert = <&sysfw_inner_cert>;
    +			content-dm-data = <&combined_dm_cfg>;
    +			load = <0x43c00000>;
    +			load-sysfw = <0x40000>;
    +			load-sysfw-data = <0x67000>;
    +			load-dm-data = <0x43c3a800>;
    +		u_boot_spl: u-boot-spl {
    +			no-expanded;
    +		ti_fs_enc: ti-fs-enc.bin {
    +			filename = "ti-sysfw/ti-fs-firmware-am62x-hs-enc.bin";
    +			type = "blob-ext";
    +			optional;
    +		combined_tifs_cfg: combined-tifs-cfg.bin {
    +			filename = "combined-tifs-cfg.bin";
    +		sysfw_inner_cert: sysfw-inner-cert {
    +			filename = "ti-sysfw/ti-fs-firmware-am62x-hs-cert.bin";
    +			optional;
    +		combined_dm_cfg: combined-dm-cfg.bin {
    +			filename = "combined-dm-cfg.bin";
    +&binman {
    +	tiboot3-am62x-hs-fs-evm.bin {
    +		filename = "tiboot3-am62x-hs-fs-evm.bin";
    +		symlink = "tiboot3.bin";
    +		ti-secure-rom {
    +			content = <&u_boot_spl_fs>, <&ti_fs_enc_fs>, <&combined_tifs_cfg_fs>,
    +				<&combined_dm_cfg_fs>, <&sysfw_inner_cert_fs>;
    +			combined;
    +			dm-data;
    +			sysfw-inner-cert;
    +			sw-rev = <1>;
    +			content-sbl = <&u_boot_spl_fs>;
    +			content-sysfw = <&ti_fs_enc_fs>;
    +			content-sysfw-data = <&combined_tifs_cfg_fs>;
    +			content-sysfw-inner-cert = <&sysfw_inner_cert_fs>;
    +			content-dm-data = <&combined_dm_cfg_fs>;
    +		u_boot_spl_fs: u-boot-spl {
    +			no-expanded;
    +		ti_fs_enc_fs: ti-fs-enc.bin {
    +			filename = "ti-sysfw/ti-fs-firmware-am62x-hs-fs-enc.bin";
    +			optional;
    +		combined_tifs_cfg_fs: combined-tifs-cfg.bin {
    +		sysfw_inner_cert_fs: sysfw-inner-cert {
    +			filename = "ti-sysfw/ti-fs-firmware-am62x-hs-fs-cert.bin";
    +			optional;
    +		combined_dm_cfg_fs: combined-dm-cfg.bin {
    +&binman {
    +	tiboot3-am62x-gp-evm.bin {
    +		filename = "tiboot3-am62x-gp-evm.bin";
    +		ti-secure-rom {
    +			content = <&u_boot_spl_unsigned>, <&ti_fs_gp>,
    +				<&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>;
    +			combined;
    +			dm-data;
    +			content-sbl = <&u_boot_spl_unsigned>;
    +			content-sysfw = <&ti_fs_gp>;
    +			content-sysfw-data = <&combined_tifs_cfg_gp>;
    +			content-dm-data = <&combined_dm_cfg_gp>;
    +			sw-rev = <1>;
    +			keyfile = "ti-degenerate-key.pem";
    +		u_boot_spl_unsigned: u-boot-spl {
    +			no-expanded;
    +		ti_fs_gp: ti-fs-gp.bin {
    +			filename = "ti-sysfw/ti-fs-firmware-am62x-gp.bin";
    +			optional;
    +		combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin {
    +		combined_dm_cfg_gp: combined-dm-cfg-gp.bin {
    +#endif
    +#ifdef CONFIG_TARGET_AM625_A53_LGSOM
    +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin"
    +#define SPL_AM625_LGSOM_DTB "spl/dts/k3-am625-lgsom.dtb"
    +#define UBOOT_NODTB "u-boot-nodtb.bin"
    +#define AM625_LGSOM_DTB "u-boot.dtb"
    +&binman {
    +	ti-dm {
    +		filename = "ti-dm.bin";
    +		blob-ext {
    +			filename = "ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.xer5f";
    +	ti-spl {
    +		filename = "tispl.bin";
    +		pad-byte = <0xff>;
    +		fit {
    +			description = "Configuration to load ATF and SPL";
    +			#address-cells = <1>;
    +			images {
    +				atf {
    +					description = "ARM Trusted Firmware";
    +					type = "firmware";
    +					arch = "arm64";
    +					compression = "none";
    +					os = "arm-trusted-firmware";
    +					load = <CONFIG_K3_ATF_LOAD_ADDR>;
    +					entry = <CONFIG_K3_ATF_LOAD_ADDR>;
    +					ti-secure {
    +						content = <&atf>;
    +					atf: atf-bl31 {
    +				tee {
    +					description = "OP-TEE";
    +					type = "tee";
    +					arch = "arm64";
    +					os = "tee";
    +					load = <0x9e800000>;
    +					entry = <0x9e800000>;
    +					ti-secure {
    +						content = <&tee>;
    +					tee: tee-os {
    +				dm {
    +					description = "DM binary";
    +					arch = "arm32";
    +					os = "DM";
    +					load = <0x89000000>;
    +					entry = <0x89000000>;
    +					ti-secure {
    +						content = <&dm>;
    +					dm: blob-ext {
    +				spl {
    +					description = "SPL (64-bit)";
    +					type = "standalone";
    +					os = "U-Boot";
    +					arch = "arm64";
    +					load = <CONFIG_SPL_TEXT_BASE>;
    +					entry = <CONFIG_SPL_TEXT_BASE>;
    +					ti-secure {
    +						content = <&u_boot_spl_nodtb>;
    +					u_boot_spl_nodtb: blob-ext {
    +						filename = SPL_NODTB;
    +				fdt-0 {
    +					description = "k3-am625-lgsom";
    +					type = "flat_dt";
    +					arch = "arm";
    +					ti-secure {
    +						content = <&spl_am625_lgsom_dtb>;
    +					spl_am625_lgsom_dtb: blob-ext {
    +						filename = SPL_AM625_LGSOM_DTB;
    +			configurations {
    +				default = "conf-0";
    +				conf-0 {
    +					firmware = "atf";
    +					loadables = "tee", "dm", "spl";
    +					fdt = "fdt-0";
    +&binman {
    +	u-boot {
    +		filename = "u-boot.img";
    +		fit {
    +			description = "FIT image with multiple configurations";
    +			images {
    +				uboot {
    +					description = "U-Boot for AM625 board";
    +					os = "u-boot";
    +					arch = "arm";
    +					load = <CONFIG_TEXT_BASE>;
    +					ti-secure {
    +						content = <&u_boot_nodtb>;
    +					u_boot_nodtb: u-boot-nodtb {
    +					hash {
    +						algo = "crc32";
    +				fdt-0 {
    +					type = "flat_dt";
    +					arch = "arm";
    +					ti-secure {
    +						content = <&am625_lgsom_dtb>;
    +					am625_lgsom_dtb: blob-ext {
    +						filename = AM625_LGSOM_DTB;
    +					hash {
    +						algo = "crc32";
    +			configurations {
    +				conf-0 {
    +					firmware = "uboot";
    +					loadables = "uboot";
    +					fdt = "fdt-0";
    +&binman {
    +	ti-spl_unsigned {
    +		filename = "tispl.bin_unsigned";
    +		fit {
    +			images {
    +				atf {
    +					arch = "arm64";
    +					atf-bl31 {
    +						filename = "bl31.bin";
    +				tee {
    +					type = "tee";
    +					arch = "arm64";
    +					os = "tee";
    +					tee-os {
    +						filename = "tee-raw.bin";
    +				dm {
    +					arch = "arm32";
    +					os = "DM";
    +					blob-ext {
    +				spl {
    +					os = "U-Boot";
    +					arch = "arm64";
    +					blob {
    +						filename = "spl/u-boot-spl-nodtb.bin";
    +				fdt-0 {
    +					type = "flat_dt";
    +					arch = "arm";
    +					spl_am625_lgsom_dtb_unsigned: blob {
    +			configurations {
    +				conf-0 {
    +					firmware = "atf";
    +					fdt = "fdt-0";
    +&binman {
    +	u-boot_unsigned {
    +		filename = "u-boot.img_unsigned";
    +		fit {
    +			images {
    +				uboot {
    +					os = "u-boot";
    +					arch = "arm";
    +					blob {
    +						filename = UBOOT_NODTB;
    +					hash {
    +						algo = "crc32";
    +				fdt-0 {
    +					type = "flat_dt";
    +					arch = "arm";
    +					am625_lgsom_dtb_unsigned: blob {
    +					hash {
    +						algo = "crc32";
    +			configurations {
    +				conf-0 {
    +					fdt = "fdt-0";
    +#endif
    diff --git a/arch/arm/dts/k3-am625-lgsom-u-boot.dtsi b/arch/arm/dts/k3-am625-lgsom-u-boot.dtsi
    index 0000000000..e41de98e35
    --- /dev/null
    +++ b/arch/arm/dts/k3-am625-lgsom-u-boot.dtsi
    @@ -0,0 +1,157 @@
    + * Common AM62x SK dts file for SPLs
    + * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
    +#include "k3-am625-lgsom-binman.dtsi"
    +	chosen {
    +		stdout-path = "serial2:115200n8";
    +		tick-timer = &main_timer0;
    +	aliases {
    +		mmc0 = &sdhci0;
    +	memory@80000000 {
    +		bootph-all;
    +&cbass_main {
    +	bootph-all;
    +&main_timer0 {
    +	clock-frequency = <25000000>;
    +	bootph-all;
    +&dmss {
    +	bootph-all;
    +&secure_proxy_main {
    +	bootph-all;
    +&dmsc {
    +	bootph-all;
    +&k3_pds {
    +	bootph-all;
    +&k3_clks {
    +	bootph-all;
    +&k3_reset {
    +	bootph-all;
    +&dmsc {
    +	bootph-all;
    +	k3_sysreset: sysreset-controller {
    +		compatible = "ti,sci-sysreset";
    +		bootph-all;
    +&wkup_conf {
    +	bootph-all;
    +&chipid {
    +	bootph-all;
    +&main_pmx0 {
    +	bootph-all;
    +&main_uart0 {
    +	bootph-all;
    +&linuxcli_pins_default {
    +	bootph-all;
    +&main_uart1 {
    +	bootph-pre-ram;
    +&cbass_mcu {
    +	bootph-all;
    +&cbass_wakeup {
    +	bootph-all;
    +&mcu_pmx0 {
    +	bootph-all;
    +&sdhci0 {
    +	bootph-all;
    +&fss {
    +	bootph-all;
    +&pmici2c_pins_default {
    +	bootph-all;
    +&usbss0 {
    +	bootph-all;
    +&usb0 {
    +	dr_mode = "peripheral";
    +	/* Since role switching is not supported in U-Boot */
    +	/delete-property/ extcon;
    +	bootph-all;
    +&main_bcdma {
    +	reg = <0x00 0x485c0100 0x00 0x100>,
    +	      <0x00 0x4c000000 0x00 0x20000>,
    +	      <0x00 0x4a820000 0x00 0x20000>,
    +	      <0x00 0x4aa40000 0x00 0x20000>,
    +	      <0x00 0x4bc00000 0x00 0x100000>,
    +	      <0x00 0x48600000 0x00 0x8000>,
    +	      <0x00 0x484a4000 0x00 0x2000>,
    +	      <0x00 0x484c2000 0x00 0x2000>;
    +	reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt",
    +		    "ringrt" , "cfg", "tchan", "rchan";
    +&main_pktdma {
    +	reg = <0x00 0x485c0000 0x00 0x100>,
    +	      <0x00 0x4a800000 0x00 0x20000>,
    +	      <0x00 0x4aa00000 0x00 0x20000>,
    +	      <0x00 0x4b800000 0x00 0x200000>,
    +	      <0x00 0x485e0000 0x00 0x10000>,
    +	      <0x00 0x484a0000 0x00 0x2000>,
    +	      <0x00 0x484c0000 0x00 0x2000>,
    +	      <0x00 0x48430000 0x00 0x1000>;
    +	reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt",
    +		    "cfg", "tchan", "rchan", "rflow";
    +	bootph-all;
    +&gpio0_pins_default {
    +	bootph-all;
    +&main_gpio0 {
    +	bootph-all;
    diff --git a/arch/arm/dts/k3-am625-lgsom.dts b/arch/arm/dts/k3-am625-lgsom.dts
    index 0000000000..616368ff71
    --- /dev/null
    +++ b/arch/arm/dts/k3-am625-lgsom.dts
    @@ -0,0 +1,433 @@
    + * AM625 SK: https://www.ti.com/lit/zip/sprr448
    +/dts-v1/;
    +#include <dt-bindings/leds/common.h>
    +#include <dt-bindings/gpio/gpio.h>
    +#include <dt-bindings/interrupt-controller/arm-gic.h>
    +#include "k3-am625.dtsi"
    +	compatible = "ti,am625-sk", "ti,am625";
    +	model = "LandisGyr TI SOM";
    +	aliases {
    +		serial2 = &main_uart0;
    +		serial3 = &main_uart2;
    +		serial4 = &main_uart5;
    +		mmc0 = &sdhci0;
    +		usb0 = &usb0;
    +	chosen {
    +		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
    +	opp-table {
    +		/* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */
    +		opp-1400000000 {
    +			opp-hz = /bits/ 64 <1400000000>;
    +			opp-supported-hw = <0x01 0x0004>;
    +			clock-latency-ns = <6000000>;
    +	memory@80000000 {
    +		device_type = "memory";
    +		/* 512MB RAM */
    +		reg = <0x00000000 0x80000000 0x00000000 0x20000000>;
    +	vcc_3v3_sys: regulator-2 {
    +		/* output of USB with diode drop or battery? */
    +		compatible = "regulator-fixed";
    +		regulator-name = "vcc_3v3_sys";
    +		regulator-min-microvolt = <3300000>;
    +		regulator-max-microvolt = <3300000>;
    +		regulator-always-on;
    +		regulator-boot-on;
    +reserved-memory {
    +		#address-cells = <2>;
    +		#size-cells = <2>;
    +		ranges;
    +		ramoops@9ca00000 {
    +			compatible = "ramoops";
    +			reg = <0x00 0x9ca00000 0x00 0x00100000>;
    +			record-size = <0x8000>;
    +			console-size = <0x8000>;
    +			ftrace-size = <0x00>;
    +			pmsg-size = <0x8000>;
    +		secure_tfa_ddr: tfa@9e780000 {
    +			reg = <0x00 0x9e780000 0x00 0x80000>;
    +			alignment = <0x1000>;
    +			no-map;
    +		secure_ddr: optee@9e800000 {
    +			reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
    +			no-map;
    +		wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 {
    +			compatible = "shared-dma-pool";
    +			reg = <0x00 0x9db00000 0x00 0xc00000>;
    +			no-map;
    +	leds {
    +		compatible = "gpio-leds";
    +		pinctrl-names = "default";
    +		pinctrl-0 = <&usr_led_pins_default>;
    +		green {
    +			label = "green";
    +			gpios = <&main_gpio1 45 GPIO_ACTIVE_HIGH>;
    +			linux,default-trigger = "heartbeat";
    +			function = LED_FUNCTION_HEARTBEAT;
    +			default-state = "blink";
    +		amber {
    +			label = "amber";
    +			gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
    +			default-state = "on";
    +&main_pmx0 {
    +	gpio1_pins_default: gpio1-default-pins {
    +		pinctrl-single,pins = <
    +			AM62X_IOPAD(0x0194, PIN_INPUT_PULLDOWN, 7) /* (B19) MCASP0_AXR3.GPIO1_7 HEADER_GPIO_1 */
    +			AM62X_IOPAD(0x0198, PIN_INPUT, 7) /* (A19) MCASP0_AXR2.GPIO1_8 HEADER_PWR_FLAG#*/
    +			AM62X_IOPAD(0x019c, PIN_OUTPUT_PULLDOWN, 7) /* (B18) MCASP0_AXR1.GPIO1_9 HEADER_EIC_LAST_GASP*/
    +			AM62X_IOPAD(0x01a0, PIN_OUTPUT_PULLDOWN, 7) /* (E18) MCASP0_AXR0.GPIO1_10 HEADER_EIC_REMAIN_ON*/
    +			AM62X_IOPAD(0x01a4, PIN_OUTPUT, 7) /* (B20) MCASP0_ACLKX.GPIO1_11 HEADER_GPIO_11 (FAN_RST#)*/
    +			AM62X_IOPAD(0x01ac, PIN_INPUT_PULLDOWN, 7) /* (E19) MCASP0_AFSR.GPIO1_13 HEADER_GPIO_5*/
    +			AM62X_IOPAD(0x01b0, PIN_OUTPUT, 7) /* (A20) MCASP0_ACLKR.GPIO1_14 HEADER_GPIO_3 (RESETSTATZ#)*/
    +			AM62X_IOPAD(0x01b8, PIN_INPUT_PULLDOWN, 7) /* (C13) SPI0_CS1.GPIO1_16 HEADER_GPIO_8*/
    +			AM62X_IOPAD(0x01e8, PIN_INPUT_PULLDOWN, 7) /* (B17) I2C1_SCL.GPIO1_28 HEADER_GPIO_9 */
    +			AM62X_IOPAD(0x01ec, PIN_INPUT_PULLDOWN, 7) /* (A17) I2C1_SDA.GPIO1_29 HEADER_GPIO_10*/
    +			AM62X_IOPAD(0x01f0, PIN_INPUT_PULLDOWN, 7) /* (A18) EXT_REFCLK1.GPIO1_30 HEADER_GPIO_2 */
    +			AM62X_IOPAD(0x022c, PIN_INPUT, 7) /* (B21) MMC1_DAT1.GPIO1_44 HEADER_GPIO_16 (WAKE#)*/
    +			AM62X_IOPAD(0x0240, PIN_OUTPUT_PULLDOWN, 7) /* (D17) MMC1_SDCD.GPIO1_48 HEADER_GPIO_12 (WAN_RST#)*/
    +	gpio0_pins_default: gpio0-default-pins {
    +			AM62X_IOPAD(0x0084, PIN_OUTPUT, 7) /* (L23) GPMC0_ADVn_ALE.GPIO0_32 VPP_LDO_EN*/
    +			AM62X_IOPAD(0x0090, PIN_INPUT_PULLUP, 7) /* (M24) GPMC0_BE0n_CLE.GPIO0_35 */
    +			AM62X_IOPAD(0x0094, PIN_INPUT_PULLUP, 7) /* (N20) GPMC0_BE1n.GPIO0_36 */
    +			AM62X_IOPAD(0x00a4, PIN_INPUT_PULLUP, 7) /* (M22) GPMC0_DIR.GPIO0_40 */
    +			AM62X_IOPAD(0x00a8, PIN_OUTPUT, 7) /* (M21) GPMC0_CSn0.GPIO0_41 EMMC_RST#*/
    +			AM62X_IOPAD(0x00ac, PIN_INPUT, 7) /* (L21) GPMC0_CSn1.GPIO0_42 SOM_ID MSB*/
    +			AM62X_IOPAD(0x00b0, PIN_INPUT, 7) /* (K22) GPMC0_CSn2.GPIO0_43 SOM_ID*/
    +			AM62X_IOPAD(0x00b4, PIN_INPUT, 7) /* (K24) GPMC0_CSn3.GPIO0_44 SOM_ID LSB*/
    +	bootstrap_pins_default: bootstrap-default-pins {
    +			AM62X_IOPAD(0x003c, PIN_INPUT, 0) /* (M25) GPMC0_AD0 */
    +			AM62X_IOPAD(0x0040, PIN_INPUT, 0) /* (N23) GPMC0_AD1 */
    +	pmici2c_pins_default: pmici2c-default-pins {
    +			AM62X_IOPAD(0x01e0, PIN_OUTPUT, 0) /* (B16) I2C0_SCL */
    +			AM62X_IOPAD(0x01e4, PIN_OUTPUT, 0) /* (A16) I2C0_SDA */
    +	mdio_pins_default: mdio-default-pins {
    +			AM62X_IOPAD(0x0160, PIN_OUTPUT, 0) /* (AD24) MDIO0_MDC */
    +			AM62X_IOPAD(0x015c, PIN_INPUT, 0) /* (AB22) MDIO0_MDIO */
    +	emmc_pins_default: emmc-default-pins {
    +			AM62X_IOPAD(0x0220, PIN_INPUT_PULLUP, 0) /* (Y3) MMC0_CMD */
    +			AM62X_IOPAD(0x0218, PIN_OUTPUT, 0) /* (AB1) MMC0_CLK */
    +			AM62X_IOPAD(0x0214, PIN_INPUT_PULLUP, 0) /* (AA2) MMC0_DAT0 */
    +			AM62X_IOPAD(0x0210, PIN_INPUT_PULLUP, 0) /* (AA1) MMC0_DAT1 */
    +			AM62X_IOPAD(0x020c, PIN_INPUT_PULLUP, 0) /* (AA3) MMC0_DAT2 */
    +			AM62X_IOPAD(0x0208, PIN_INPUT_PULLUP, 0) /* (Y4) MMC0_DAT3 */
    +			AM62X_IOPAD(0x0204, PIN_INPUT_PULLUP, 0) /* (AB2) MMC0_DAT4 */
    +			AM62X_IOPAD(0x0200, PIN_INPUT_PULLUP, 0) /* (AC1) MMC0_DAT5 */
    +			AM62X_IOPAD(0x01fc, PIN_INPUT_PULLUP, 0) /* (AD2) MMC0_DAT6 */
    +			AM62X_IOPAD(0x01f8, PIN_INPUT_PULLUP, 0) /* (AC2) MMC0_DAT7 */
    +	wifi_rst_pins_default: wifi-rst-pins-default {
    +			AM62X_IOPAD(0x0124, PIN_OUTPUT_PULLDOWN, 7) /* (A23) MMC2_SDCD.GPIO0_71 */
    +	wifi_irq_pins_default: wifi-irq-pins-default {
    +			AM62X_IOPAD(0x0128, PIN_INPUT_PULLDOWN, 7) /* (B23) MMC2_SDWP.GPIO0_72 */
    +	wifisdio_pins_default: wifisdio-default-pins {
    +			AM62X_IOPAD(0x0120, PIN_INPUT, 0) /* (C24) MMC2_CMD */
    +			AM62X_IOPAD(0x0118, PIN_OUTPUT, 0) /* (D25) MMC2_CLK */
    +			AM62X_IOPAD(0x011C, PIN_INPUT, 0) /* () MMC2_CLKLB */
    +			AM62X_IOPAD(0x0114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */
    +			AM62X_IOPAD(0x0110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */
    +			AM62X_IOPAD(0x010c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */
    +			AM62X_IOPAD(0x0108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */
    +	rmii_pins_default: rmii-default-pins {
    +			AM62X_IOPAD(0x0130, PIN_INPUT, 1) /* (AE19) RGMII1_TXC.RMII1_CRS_DV */
    +			AM62X_IOPAD(0x0148, PIN_INPUT, 1) /* (AD17) RGMII1_RXC.RMII1_REF_CLK */
    +			AM62X_IOPAD(0x014c, PIN_INPUT, 1) /* (AB17) RGMII1_RD0.RMII1_RXD0 */
    +			AM62X_IOPAD(0x0150, PIN_INPUT, 1) /* (AC17) RGMII1_RD1.RMII1_RXD1 */
    +			AM62X_IOPAD(0x0144, PIN_INPUT, 1) /* (AE17) RGMII1_RX_CTL.RMII1_RX_ER */
    +			AM62X_IOPAD(0x0134, PIN_OUTPUT, 1) /* (AE20) RGMII1_TD0.RMII1_TXD0 */
    +			AM62X_IOPAD(0x0138, PIN_OUTPUT, 1) /* (AD20) RGMII1_TD1.RMII1_TXD1 */
    +			AM62X_IOPAD(0x012c, PIN_OUTPUT, 1) /* (AD19) RGMII1_TX_CTL.RMII1_TX_EN */
    +			AM62X_IOPAD(0x01a8, PIN_OUTPUT, 7) /* (D20) MCASP0_AFSX.GPIO1_12 HEADER_GPIO_4 (ENET_RST#)*/
    +	spi0_pins_default: spi0-default-pins {
    +			AM62X_IOPAD(0x01bc, PIN_OUTPUT_PULLDOWN, 0) /* (A14) SPI0_CLK */
    +			AM62X_IOPAD(0x01c0, PIN_OUTPUT_PULLDOWN, 0) /* (B13) SPI0_D0 */
    +			AM62X_IOPAD(0x01c4, PIN_INPUT_PULLDOWN, 0) /* (B14) SPI0_D1 */
    +			AM62X_IOPAD(0x01b4, PIN_OUTPUT_PULLDOWN, 0) /* (A13) SPI0_CS0 */
    +	system_pins_default: system-default-pins {
    +			AM62X_IOPAD(0x024c, PIN_OUTPUT, 0) /* (F22) RESETSTATz */
    +			AM62X_IOPAD(0x0248, PIN_INPUT_PULLUP, 0) /* (F20) RESET_REQz */
    +	linuxcli_pins_default: linuxcli-default-pins {
    +			AM62X_IOPAD(0x01c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
    +			AM62X_IOPAD(0x01cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
    +	uart2_pins_default: uart2-default-pins {
    +			AM62X_IOPAD(0x01d0, PIN_INPUT, 3) /* (A15) UART0_CTSn.UART2_RXD */
    +			AM62X_IOPAD(0x01d4, PIN_OUTPUT, 3) /* (B15) UART0_RTSn.UART2_TXD */
    +	uart1_pins_default: uart1-default-pins {
    +			AM62X_IOPAD(0x01d8, PIN_INPUT, 1) /* (C15) MCAN0_TX.UART5_RXD */
    +			AM62X_IOPAD(0x01dc, PIN_OUTPUT, 1) /* (E15) MCAN0_RX.UART5_TXD */
    +	usr_led_pins_default: usr-led-pins-default {
    +			AM62X_IOPAD(0x0230, PIN_OUTPUT, 7) /* (A22) MMC1_DAT0.GPIO1_45 */
    +			AM62X_IOPAD(0x0244, PIN_OUTPUT, 7) /* (C17) MMC1_SDWP.GPIO1_49 */
    +&mcu_pmx0 {
    +	jtagdebug_pins_default: jtagdebug-default-pins {
    +			AM62X_MCU_IOPAD(0x0078, PIN_INPUT_PULLUP, 0) /* (E12) EMU0 */
    +			AM62X_MCU_IOPAD(0x007c, PIN_INPUT_PULLUP, 0) /* (C11) EMU1 */
    +			AM62X_MCU_IOPAD(0x0064, PIN_INPUT_PULLUP, 0) /* (A10) TCK */
    +			AM62X_MCU_IOPAD(0x006c, PIN_INPUT_PULLUP, 0) /* (A11) TDI */
    +			AM62X_MCU_IOPAD(0x0070, PIN_OUTPUT_PULLUP, 0) /* (D12) TDO */
    +			AM62X_MCU_IOPAD(0x0074, PIN_INPUT_PULLUP, 0) /* (B11) TMS */
    +			AM62X_MCU_IOPAD(0x0068, PIN_INPUT_PULLDOWN, 0) /* (B10) TRSTn */
    +	mcui2c_pins_default: mcui2c-default-pins {
    +			AM62X_MCU_IOPAD(0x0044, PIN_INPUT, 0) /* (A8) MCU_I2C0_SCL */
    +			AM62X_MCU_IOPAD(0x0048, PIN_INPUT, 0) /* (D10) MCU_I2C0_SDA */
    +	system0_pins_default: system0-default-pins {
    +			AM62X_MCU_IOPAD(0x0060, PIN_INPUT_PULLDOWN, 0) /* (D1) MCU_ERRORn */
    +			AM62X_MCU_IOPAD(0x0058, PIN_INPUT, 0) /* (D2) MCU_PORz */
    +			AM62X_MCU_IOPAD(0x0054, PIN_INPUT_PULLUP, 0) /* (E11) MCU_RESETz */
    +	pmic_irq_pins_default: pmic-irq-default-pins {
    +			AM62X_IOPAD(0x01f4, PIN_INPUT_PULLUP, 0) /* (D16) EXTINTn */
    +	i2c_pins_default: i2c-default-pins {
    +			AM62X_MCU_IOPAD(0x004c, PIN_INPUT, 0) /* (B9) WKUP_I2C0_SCL */
    +			AM62X_MCU_IOPAD(0x0050, PIN_INPUT, 0) /* (A9) WKUP_I2C0_SDA */
    +	usbmtr_pins_default: usbmtr-default-pins {
    +			AM62X_IOPAD(0x0254, PIN_OUTPUT, 0) /* (C20) USB0_DRVVBUS */
    +	usblan_pins_default: usblan-default-pins {
    +			AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */
    +&main_uart0 {
    +	status = "okay";
    +	pinctrl-0 = <&linuxcli_pins_default>;
    +&main_uart2 {
    +	status = "okay";
    +	pinctrl-0 = <&uart2_pins_default>;
    +&main_uart5 {
    +	status = "okay";
    +	pinctrl-0 = <&uart1_pins_default>;
    +&main_gpio0 {
    +	pinctrl-0 = <&gpio0_pins_default>;
    +	gpio-line-names = "VPP_LDO_EN", "EMMC_RST#", "SOM_ID_MSB", "SOM_ID", "SOM_ID_LSB";
    +&main_gpio1 {
    +	pinctrl-0 = <&gpio1_pins_default>;
    +	gpio-line-names = "HEADER_GPIO_1", "HEADER_PWR_FLAG#", "HEADER_EIC_LAST_GASP",
    +		"HEADER_EIC_REMAIN_ON", "HEADER_GPIO_11 (FAN_RST#)","HEADER_GPIO_5",
    +		"HEADER_GPIO_3 (RESETSTATZ#)","HEADER_GPIO_8","HEADER_GPIO_9","HEADER_GPIO_10",
    +		"HEADER_GPIO_2","HEADER_GPIO_16 (WAKE#)","HEADER_GPIO_12 (WAN_RST#)";
    +&main_i2c0 {
    +	status = "okay";
    +	pinctrl-0 = <&pmici2c_pins_default>;
    +	clock-frequency = <400000>;
    +	tps65219: pmic@30 {
    +		compatible = "ti,tps65219";
    +		reg = <0x30>;
    +		buck1-supply = <&vcc_3v3_sys>;
    +		buck2-supply = <&vcc_3v3_sys>;
    +		buck3-supply = <&vcc_3v3_sys>;
    +		ldo1-supply = <&buck2_reg>;
    +		ldo3-supply = <&buck2_reg>;
    +		ldo4-supply = <&buck2_reg>;
    +		pinctrl-0 = <&pmic_irq_pins_default>;
    +		interrupt-parent = <&gic500>;
    +		interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>;
    +		interrupt-controller;
    +		#interrupt-cells = <1>;
    +		system-power-controller;
    +		regulators {
    +			buck1_reg: buck1 {
    +				regulator-name = "VDD_CORE_0V85";
    +				regulator-min-microvolt = <850000>;
    +				regulator-max-microvolt = <850000>;
    +			buck2_reg: buck2 {
    +				regulator-name = "DVDD3V3";
    +			buck3_reg: buck3 {
    +				regulator-name = "VDDS_DDR_1V1";
    +				regulator-min-microvolt = <1100000>;
    +				regulator-max-microvolt = <1100000>;
    +			ldo1_reg: ldo1 {
    +				regulator-name = "WIFI_1V8";
    +				regulator-min-microvolt = <1800000>;
    +				regulator-max-microvolt = <1800000>;
    +			ldo3_reg: ldo3 {
    +				regulator-name = "VDDA_1V8";
    +			ldo4_reg: ldo4 {
    +				regulator-name = "DVDD1V8";
    +&sdhci0 {
    +	/* EMMC */
    +	status = "okay";
    +	pinctrl-0 = <&emmc_pins_default>;
    +	ti,driver-strength-ohm = <50>;
    +	disable-wp;
    +&mailbox0_cluster0 {
    + 	mbox_r5_0: mbox-r5-0 {
    + 		ti,mbox-rx = <2 0 0>;
    + 		ti,mbox-tx = <3 0 0>;
    +&usbss0 {
    +	ti,vbus-divider;
    +	status = "okay";
    +&usb0 {
    diff --git a/arch/arm/dts/k3-am625-r5-lgsom-discrete.dts b/arch/arm/dts/k3-am625-r5-lgsom-discrete.dts
    index 0000000000..0c0cbceb2c
    --- /dev/null
    +++ b/arch/arm/dts/k3-am625-r5-lgsom-discrete.dts
    @@ -0,0 +1,78 @@
    + * AM625 SK dts file for R5 SPL
    +#include "k3-am625-lgsom.dts"
    +#include "k3-am62x-issi-ddr-lp4-50-800.dtsi"
    +#include "k3-am62-ddr.dtsi"
    +#include "k3-am625-lgsom-u-boot.dtsi"
    +	aliases {
    +		remoteproc0 = &sysctrler;
    +		remoteproc1 = &a53_0;
    +	a53_0: a53@0 {
    +		compatible = "ti,am654-rproc";
    +		reg = <0x00 0x00a90000 0x00 0x10>;
    +		power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>,
    +				<&k3_pds 135 TI_SCI_PD_EXCLUSIVE>,
    +				<&k3_pds 166 TI_SCI_PD_EXCLUSIVE>;
    +		resets = <&k3_reset 135 0>;
    +		clocks = <&k3_clks 61 0>;
    +		assigned-clocks = <&k3_clks 61 0>, <&k3_clks 135 0>;
    +		assigned-clock-parents = <&k3_clks 61 2>;
    +		assigned-clock-rates = <200000000>, <1200000000>;
    +		ti,sci = <&dmsc>;
    +		ti,sci-proc-id = <32>;
    +		ti,sci-host-id = <10>;
    +		bootph-pre-ram;
    +	dm_tifs: dm-tifs {
    +		compatible = "ti,j721e-dm-sci";
    +		ti,host-id = <36>;
    +		ti,secure-host;
    +		mbox-names = "rx", "tx";
    +		mboxes= <&secure_proxy_main 22>,
    +			<&secure_proxy_main 23>;
    +		bootph-pre-ram;
    +&dmsc {
    +	mboxes= <&secure_proxy_main 0>,
    +		<&secure_proxy_main 1>,
    +		<&secure_proxy_main 0>;
    +	mbox-names = "rx", "tx", "notify";
    +	ti,host-id = <35>;
    +	ti,secure-host;
    +&mcu_esm {
    +	bootph-pre-ram;
    +&secure_proxy_sa3 {
    +	bootph-pre-ram;
    +	/* We require this for boot handshake */
    +	status = "okay";
    +&main_esm {
    +	bootph-pre-ram;
    +&cbass_main {
    +	sysctrler: sysctrler {
    +		compatible = "ti,am654-system-controller";
    +		mboxes= <&secure_proxy_main 1>, <&secure_proxy_main 0>, <&secure_proxy_sa3 0>;
    +		mbox-names = "tx", "rx", "boot_notify";
    +		bootph-pre-ram;
    diff --git a/arch/arm/dts/k3-am625-r5-lgsom-sip.dts b/arch/arm/dts/k3-am625-r5-lgsom-sip.dts
    index 0000000000..90d680a668
    --- /dev/null
    +++ b/arch/arm/dts/k3-am625-r5-lgsom-sip.dts
    @@ -0,0 +1,78 @@
    +#include "k3-am62x-sip-ddr-lp4-50-800.dtsi"
    +	aliases {
    +	a53_0: a53@0 {
    +		ti,sci = <&dmsc>;
    +		bootph-pre-ram;
    +		ti,secure-host;
    +		bootph-pre-ram;
    +&dmsc {
    +	ti,secure-host;
    +&mcu_esm {
    +	bootph-pre-ram;
    +	bootph-pre-ram;
    +	status = "okay";
    +&main_esm {
    +	bootph-pre-ram;
    +&cbass_main {
    +		bootph-pre-ram;
    diff --git a/arch/arm/dts/k3-am62x-issi-ddr-lp4-50-800.dtsi b/arch/arm/dts/k3-am62x-issi-ddr-lp4-50-800.dtsi
    index 0000000000..faaa9c9762
    --- /dev/null
    +++ b/arch/arm/dts/k3-am62x-issi-ddr-lp4-50-800.dtsi
    @@ -0,0 +1,2193 @@
    +// SPDX-License-Identifier: GPL-2.0+
    + * This file was generated with the
    + * AM62x SysConfig DDR Subsystem Register Configuration Tool v0.10.01
    + * Mon May 13 2024 07:49:06 GMT-0500 (Central Daylight Time)
    + * DDR Type: LPDDR4
    + * F0 = 50MHz    F1 = NA     F2 = 800MHz
    + * Density (per channel): 4Gb
    + * Write DBI: Enable
    + * Number of Ranks: 1
    +#define DDRSS_PLL_FHS_CNT 3
    +#define DDRSS_PLL_FREQUENCY_1 400000000
    +#define DDRSS_PLL_FREQUENCY_2 400000000
    +#define DDRSS_SDRAM_IDX 13
    +#define DDRSS_CTL_0_DATA 0x00000B00
    +#define DDRSS_CTL_1_DATA 0x00000000
    +#define DDRSS_CTL_2_DATA 0x00000000
    +#define DDRSS_CTL_3_DATA 0x00000000
    +#define DDRSS_CTL_4_DATA 0x00000000
    +#define DDRSS_CTL_5_DATA 0x00000000
    +#define DDRSS_CTL_6_DATA 0x00000000
    +#define DDRSS_CTL_7_DATA 0x00002710
    +#define DDRSS_CTL_8_DATA 0x000186A0
    +#define DDRSS_CTL_9_DATA 0x00000005
    +#define DDRSS_CTL_10_DATA 0x00000064
    +#define DDRSS_CTL_11_DATA 0x00027100
    +#define DDRSS_CTL_12_DATA 0x00186A00
    +#define DDRSS_CTL_13_DATA 0x00000005
    +#define DDRSS_CTL_14_DATA 0x00000640
    +#define DDRSS_CTL_15_DATA 0x00027100
    +#define DDRSS_CTL_16_DATA 0x00186A00
    +#define DDRSS_CTL_17_DATA 0x00000005
    +#define DDRSS_CTL_18_DATA 0x00000640
    +#define DDRSS_CTL_19_DATA 0x01010100
    +#define DDRSS_CTL_20_DATA 0x01010100
    +#define DDRSS_CTL_21_DATA 0x01000110
    +#define DDRSS_CTL_22_DATA 0x02010002
    +#define DDRSS_CTL_23_DATA 0x0000000A
    +#define DDRSS_CTL_24_DATA 0x000186A0
    +#define DDRSS_CTL_25_DATA 0x00000000
    +#define DDRSS_CTL_26_DATA 0x00000000
    +#define DDRSS_CTL_27_DATA 0x00000000
    +#define DDRSS_CTL_28_DATA 0x00000000
    +#define DDRSS_CTL_29_DATA 0x00020200
    +#define DDRSS_CTL_30_DATA 0x00000000
    +#define DDRSS_CTL_31_DATA 0x00000000
    +#define DDRSS_CTL_32_DATA 0x00000000
    +#define DDRSS_CTL_33_DATA 0x00000000
    +#define DDRSS_CTL_34_DATA 0x08000010
    +#define DDRSS_CTL_35_DATA 0x00002020
    +#define DDRSS_CTL_36_DATA 0x00000000
    +#define DDRSS_CTL_37_DATA 0x00000000
    +#define DDRSS_CTL_38_DATA 0x0000040C
    +#define DDRSS_CTL_39_DATA 0x00000000
    +#define DDRSS_CTL_40_DATA 0x0000081C
    +#define DDRSS_CTL_41_DATA 0x00000000
    +#define DDRSS_CTL_42_DATA 0x0000081C
    +#define DDRSS_CTL_43_DATA 0x00000000
    +#define DDRSS_CTL_44_DATA 0x05000804
    +#define DDRSS_CTL_45_DATA 0x00000A00
    +#define DDRSS_CTL_46_DATA 0x09090004
    +#define DDRSS_CTL_47_DATA 0x00000203
    +#define DDRSS_CTL_48_DATA 0x00370008
    +#define DDRSS_CTL_49_DATA 0x09090024
    +#define DDRSS_CTL_50_DATA 0x00001910
    +#define DDRSS_CTL_51_DATA 0x00370008
    +#define DDRSS_CTL_52_DATA 0x09090024
    +#define DDRSS_CTL_53_DATA 0x09001910
    +#define DDRSS_CTL_54_DATA 0x000A0A09
    +#define DDRSS_CTL_55_DATA 0x040001B6
    +#define DDRSS_CTL_56_DATA 0x09092004
    +#define DDRSS_CTL_57_DATA 0x00000C0A
    +#define DDRSS_CTL_58_DATA 0x06001B6C
    +#define DDRSS_CTL_59_DATA 0x09092006
    +#define DDRSS_CTL_60_DATA 0x00000C0A
    +#define DDRSS_CTL_61_DATA 0x06001B6C
    +#define DDRSS_CTL_62_DATA 0x03042006
    +#define DDRSS_CTL_63_DATA 0x04050002
    +#define DDRSS_CTL_64_DATA 0x10111011
    +#define DDRSS_CTL_65_DATA 0x01010008
    +#define DDRSS_CTL_66_DATA 0x04202007
    +#define DDRSS_CTL_67_DATA 0x03131303
    +#define DDRSS_CTL_68_DATA 0x00001313
    +#define DDRSS_CTL_69_DATA 0x00000101
    +#define DDRSS_CTL_70_DATA 0x00000000
    +#define DDRSS_CTL_71_DATA 0x01000000
    +#define DDRSS_CTL_72_DATA 0x00130803
    +#define DDRSS_CTL_73_DATA 0x00000028
    +#define DDRSS_CTL_74_DATA 0x00000130
    +#define DDRSS_CTL_75_DATA 0x00000304
    +#define DDRSS_CTL_76_DATA 0x00000130
    +#define DDRSS_CTL_77_DATA 0x00000304
    +#define DDRSS_CTL_78_DATA 0x00000005
    +#define DDRSS_CTL_79_DATA 0x0000000A
    +#define DDRSS_CTL_80_DATA 0x00000001
    +#define DDRSS_CTL_81_DATA 0x00000098
    +#define DDRSS_CTL_82_DATA 0x00000059
    +#define DDRSS_CTL_83_DATA 0x00000098
    +#define DDRSS_CTL_84_DATA 0x00000059
    +#define DDRSS_CTL_85_DATA 0x03004000
    +#define DDRSS_CTL_86_DATA 0x00001201
    +#define DDRSS_CTL_87_DATA 0x00060005
    +#define DDRSS_CTL_88_DATA 0x00000006
    +#define DDRSS_CTL_89_DATA 0x00000000
    +#define DDRSS_CTL_90_DATA 0x05141408
    +#define DDRSS_CTL_91_DATA 0x05030A05
    +#define DDRSS_CTL_92_DATA 0x05030C06
    +#define DDRSS_CTL_93_DATA 0x01030C06
    +#define DDRSS_CTL_94_DATA 0x02010201
    +#define DDRSS_CTL_95_DATA 0x00001401
    +#define DDRSS_CTL_96_DATA 0x01360014
    +#define DDRSS_CTL_97_DATA 0x01360136
    +#define DDRSS_CTL_98_DATA 0x00000136
    +#define DDRSS_CTL_99_DATA 0x00000000
    +#define DDRSS_CTL_100_DATA 0x05010303
    +#define DDRSS_CTL_101_DATA 0x0C040505
    +#define DDRSS_CTL_102_DATA 0x06050203
    +#define DDRSS_CTL_103_DATA 0x030C0605
    +#define DDRSS_CTL_104_DATA 0x05060502
    +#define DDRSS_CTL_105_DATA 0x03030306
    +#define DDRSS_CTL_106_DATA 0x03010000
    +#define DDRSS_CTL_107_DATA 0x00010000
    +#define DDRSS_CTL_108_DATA 0x00000000
    +#define DDRSS_CTL_109_DATA 0x01000000
    +#define DDRSS_CTL_110_DATA 0x80104002
    +#define DDRSS_CTL_111_DATA 0x00040003
    +#define DDRSS_CTL_112_DATA 0x00040005
    +#define DDRSS_CTL_113_DATA 0x00030000
    +#define DDRSS_CTL_114_DATA 0x00050004
    +#define DDRSS_CTL_115_DATA 0x00000004
    +#define DDRSS_CTL_116_DATA 0x00040003
    +#define DDRSS_CTL_117_DATA 0x00040005
    +#define DDRSS_CTL_118_DATA 0x00000000
    +#define DDRSS_CTL_119_DATA 0x00000A00
    +#define DDRSS_CTL_120_DATA 0x00000A00
    +#define DDRSS_CTL_121_DATA 0x00000A00
    +#define DDRSS_CTL_122_DATA 0x00000A00
    +#define DDRSS_CTL_123_DATA 0x00000A00
    +#define DDRSS_CTL_124_DATA 0x00000000
    +#define DDRSS_CTL_125_DATA 0x00000118
    +#define DDRSS_CTL_126_DATA 0x0000C100
    +#define DDRSS_CTL_127_DATA 0x0000C100
    +#define DDRSS_CTL_128_DATA 0x0000C100
    +#define DDRSS_CTL_129_DATA 0x0000C100
    +#define DDRSS_CTL_130_DATA 0x0000C100
    +#define DDRSS_CTL_131_DATA 0x00000000
    +#define DDRSS_CTL_132_DATA 0x0000151C
    +#define DDRSS_CTL_133_DATA 0x0000C100
    +#define DDRSS_CTL_134_DATA 0x0000C100
    +#define DDRSS_CTL_135_DATA 0x0000C100
    +#define DDRSS_CTL_136_DATA 0x0000C100
    +#define DDRSS_CTL_137_DATA 0x0000C100
    +#define DDRSS_CTL_138_DATA 0x00000000
    +#define DDRSS_CTL_139_DATA 0x0000151C
    +#define DDRSS_CTL_140_DATA 0x00000000
    +#define DDRSS_CTL_141_DATA 0x00000000
    +#define DDRSS_CTL_142_DATA 0x00000000
    +#define DDRSS_CTL_143_DATA 0x00000000
    +#define DDRSS_CTL_144_DATA 0x00000000
    +#define DDRSS_CTL_145_DATA 0x00000000
    +#define DDRSS_CTL_146_DATA 0x00000000
    +#define DDRSS_CTL_147_DATA 0x00000000
    +#define DDRSS_CTL_148_DATA 0x00000000
    +#define DDRSS_CTL_149_DATA 0x00000000
    +#define DDRSS_CTL_150_DATA 0x00000000
    +#define DDRSS_CTL_151_DATA 0x00000000
    +#define DDRSS_CTL_152_DATA 0x00000000
    +#define DDRSS_CTL_153_DATA 0x00000000
    +#define DDRSS_CTL_154_DATA 0x00000000
    +#define DDRSS_CTL_155_DATA 0x00000000
    +#define DDRSS_CTL_156_DATA 0x03050000
    +#define DDRSS_CTL_157_DATA 0x03050305
    +#define DDRSS_CTL_158_DATA 0x00000000
    +#define DDRSS_CTL_159_DATA 0x08010000
    +#define DDRSS_CTL_160_DATA 0x000E0808
    +#define DDRSS_CTL_161_DATA 0x01000000
    +#define DDRSS_CTL_162_DATA 0x0E080808
    +#define DDRSS_CTL_163_DATA 0x00000000
    +#define DDRSS_CTL_164_DATA 0x08080801
    +#define DDRSS_CTL_165_DATA 0x0000080E
    +#define DDRSS_CTL_166_DATA 0x00040003
    +#define DDRSS_CTL_167_DATA 0x00000007
    +#define DDRSS_CTL_168_DATA 0x00000000
    +#define DDRSS_CTL_169_DATA 0x00000000
    +#define DDRSS_CTL_170_DATA 0x00000000
    +#define DDRSS_CTL_171_DATA 0x00000000
    +#define DDRSS_CTL_172_DATA 0x00000000
    +#define DDRSS_CTL_173_DATA 0x00000000
    +#define DDRSS_CTL_174_DATA 0x01000000
    +#define DDRSS_CTL_175_DATA 0x00000000
    +#define DDRSS_CTL_176_DATA 0x00001500
    +#define DDRSS_CTL_177_DATA 0x0000100E
    +#define DDRSS_CTL_178_DATA 0x00000002
    +#define DDRSS_CTL_179_DATA 0x00000000
    +#define DDRSS_CTL_180_DATA 0x00000001
    +#define DDRSS_CTL_181_DATA 0x00000002
    +#define DDRSS_CTL_182_DATA 0x00000C00
    +#define DDRSS_CTL_183_DATA 0x00001000
    +#define DDRSS_CTL_184_DATA 0x00000C00
    +#define DDRSS_CTL_185_DATA 0x00001000
    +#define DDRSS_CTL_186_DATA 0x00000C00
    +#define DDRSS_CTL_187_DATA 0x00001000
    +#define DDRSS_CTL_188_DATA 0x00000000
    +#define DDRSS_CTL_189_DATA 0x00000000
    +#define DDRSS_CTL_190_DATA 0x00000000
    +#define DDRSS_CTL_191_DATA 0x00000000
    +#define DDRSS_CTL_192_DATA 0x0005000A
    +#define DDRSS_CTL_193_DATA 0x0404000D
    +#define DDRSS_CTL_194_DATA 0x0000000D
    +#define DDRSS_CTL_195_DATA 0x005000A0
    +#define DDRSS_CTL_196_DATA 0x060600C8
    +#define DDRSS_CTL_197_DATA 0x000000C8
    +#define DDRSS_CTL_198_DATA 0x005000A0
    +#define DDRSS_CTL_199_DATA 0x060600C8
    +#define DDRSS_CTL_200_DATA 0x000000C8
    +#define DDRSS_CTL_201_DATA 0x00000000
    +#define DDRSS_CTL_202_DATA 0x00000000
    +#define DDRSS_CTL_203_DATA 0x00000000
    +#define DDRSS_CTL_204_DATA 0x00000000
    +#define DDRSS_CTL_205_DATA 0x00000004
    +#define DDRSS_CTL_206_DATA 0x00000000
    +#define DDRSS_CTL_207_DATA 0x00000000
    +#define DDRSS_CTL_208_DATA 0x00000024
    +#define DDRSS_CTL_209_DATA 0x00000012
    +#define DDRSS_CTL_210_DATA 0x00000000
    +#define DDRSS_CTL_211_DATA 0x00000024
    +#define DDRSS_CTL_212_DATA 0x00000012
    +#define DDRSS_CTL_213_DATA 0x00000000
    +#define DDRSS_CTL_214_DATA 0x00000004
    +#define DDRSS_CTL_215_DATA 0x00000000
    +#define DDRSS_CTL_216_DATA 0x00000000
    +#define DDRSS_CTL_217_DATA 0x00000024
    +#define DDRSS_CTL_218_DATA 0x00000012
    +#define DDRSS_CTL_219_DATA 0x00000000
    +#define DDRSS_CTL_220_DATA 0x00000024
    +#define DDRSS_CTL_221_DATA 0x00000012
    +#define DDRSS_CTL_222_DATA 0x00000000
    +#define DDRSS_CTL_223_DATA 0x00000000
    +#define DDRSS_CTL_224_DATA 0x00000031
    +#define DDRSS_CTL_225_DATA 0x000000B1
    +#define DDRSS_CTL_226_DATA 0x000000B1
    +#define DDRSS_CTL_227_DATA 0x00000031
    +#define DDRSS_CTL_228_DATA 0x000000B1
    +#define DDRSS_CTL_229_DATA 0x000000B1
    +#define DDRSS_CTL_230_DATA 0x00000000
    +#define DDRSS_CTL_231_DATA 0x00000000
    +#define DDRSS_CTL_232_DATA 0x00000000
    +#define DDRSS_CTL_233_DATA 0x00000000
    +#define DDRSS_CTL_234_DATA 0x00000000
    +#define DDRSS_CTL_235_DATA 0x00000000
    +#define DDRSS_CTL_236_DATA 0x00000000
    +#define DDRSS_CTL_237_DATA 0x00000000
    +#define DDRSS_CTL_238_DATA 0x00000000
    +#define DDRSS_CTL_239_DATA 0x00000000
    +#define DDRSS_CTL_240_DATA 0x00000000
    +#define DDRSS_CTL_241_DATA 0x00000000
    +#define DDRSS_CTL_242_DATA 0x00000000
    +#define DDRSS_CTL_243_DATA 0x00000000
    +#define DDRSS_CTL_244_DATA 0x00000000
    +#define DDRSS_CTL_245_DATA 0x00000000
    +#define DDRSS_CTL_246_DATA 0x00000000
    +#define DDRSS_CTL_247_DATA 0x00000000
    +#define DDRSS_CTL_248_DATA 0x00000000
    +#define DDRSS_CTL_249_DATA 0x00000000
    +#define DDRSS_CTL_250_DATA 0x00000000
    +#define DDRSS_CTL_251_DATA 0x00000000
    +#define DDRSS_CTL_252_DATA 0x00000000
    +#define DDRSS_CTL_253_DATA 0x00000000
    +#define DDRSS_CTL_254_DATA 0x46004646
    +#define DDRSS_CTL_255_DATA 0x00002746
    +#define DDRSS_CTL_256_DATA 0x00000027
    +#define DDRSS_CTL_257_DATA 0x00000027
    +#define DDRSS_CTL_258_DATA 0x00000027
    +#define DDRSS_CTL_259_DATA 0x00000027
    +#define DDRSS_CTL_260_DATA 0x00000027
    +#define DDRSS_CTL_261_DATA 0x00000000
    +#define DDRSS_CTL_262_DATA 0x00000000
    +#define DDRSS_CTL_263_DATA 0x0000000F
    +#define DDRSS_CTL_264_DATA 0x0000000F
    +#define DDRSS_CTL_265_DATA 0x0000000F
    +#define DDRSS_CTL_266_DATA 0x0000000F
    +#define DDRSS_CTL_267_DATA 0x0000000F
    +#define DDRSS_CTL_268_DATA 0x0000000F
    +#define DDRSS_CTL_269_DATA 0x00000000
    +#define DDRSS_CTL_270_DATA 0x00001000
    +#define DDRSS_CTL_271_DATA 0x00000015
    +#define DDRSS_CTL_272_DATA 0x00000015
    +#define DDRSS_CTL_273_DATA 0x00000010
    +#define DDRSS_CTL_274_DATA 0x00000015
    +#define DDRSS_CTL_275_DATA 0x00000015
    +#define DDRSS_CTL_276_DATA 0x00000020
    +#define DDRSS_CTL_277_DATA 0x00010000
    +#define DDRSS_CTL_278_DATA 0x00000100
    +#define DDRSS_CTL_279_DATA 0x00000000
    +#define DDRSS_CTL_280_DATA 0x00000000
    +#define DDRSS_CTL_281_DATA 0x00000101
    +#define DDRSS_CTL_282_DATA 0x00000000
    +#define DDRSS_CTL_283_DATA 0x00000000
    +#define DDRSS_CTL_284_DATA 0x00000000
    +#define DDRSS_CTL_285_DATA 0x00000000
    +#define DDRSS_CTL_286_DATA 0x00000000
    +#define DDRSS_CTL_287_DATA 0x00000000
    +#define DDRSS_CTL_288_DATA 0x00000000
    +#define DDRSS_CTL_289_DATA 0x00000000
    +#define DDRSS_CTL_290_DATA 0x0C181511
    +#define DDRSS_CTL_291_DATA 0x00000304
    +#define DDRSS_CTL_292_DATA 0x00000000
    +#define DDRSS_CTL_293_DATA 0x00000000
    +#define DDRSS_CTL_294_DATA 0x00000000
    +#define DDRSS_CTL_295_DATA 0x00000000
    +#define DDRSS_CTL_296_DATA 0x00000000
    +#define DDRSS_CTL_297_DATA 0x00000000
    +#define DDRSS_CTL_298_DATA 0x00000000
    +#define DDRSS_CTL_299_DATA 0x00000000
    +#define DDRSS_CTL_300_DATA 0x00000000
    +#define DDRSS_CTL_301_DATA 0x00000000
    +#define DDRSS_CTL_302_DATA 0x00000000
    +#define DDRSS_CTL_303_DATA 0x00000000
    +#define DDRSS_CTL_304_DATA 0x00000000
    +#define DDRSS_CTL_305_DATA 0x00020000
    +#define DDRSS_CTL_306_DATA 0x00400100
    +#define DDRSS_CTL_307_DATA 0x00080032
    +#define DDRSS_CTL_308_DATA 0x01000200
    +#define DDRSS_CTL_309_DATA 0x03200040
    +#define DDRSS_CTL_310_DATA 0x00020018
    +#define DDRSS_CTL_311_DATA 0x00400100
    +#define DDRSS_CTL_312_DATA 0x00180320
    +#define DDRSS_CTL_313_DATA 0x00030000
    +#define DDRSS_CTL_314_DATA 0x00280028
    +#define DDRSS_CTL_315_DATA 0x00000100
    +#define DDRSS_CTL_316_DATA 0x01010000
    +#define DDRSS_CTL_317_DATA 0x00000202
    +#define DDRSS_CTL_318_DATA 0x0FFF0000
    +#define DDRSS_CTL_319_DATA 0x000FFF00
    +#define DDRSS_CTL_320_DATA 0xFFFFFFFF
    +#define DDRSS_CTL_321_DATA 0x00FFFF00
    +#define DDRSS_CTL_322_DATA 0x0B000000
    +#define DDRSS_CTL_323_DATA 0x0001FFFF
    +#define DDRSS_CTL_324_DATA 0x01010101
    +#define DDRSS_CTL_325_DATA 0x01010101
    +#define DDRSS_CTL_326_DATA 0x00000118
    +#define DDRSS_CTL_327_DATA 0x00000C01
    +#define DDRSS_CTL_328_DATA 0x01000100
    +#define DDRSS_CTL_329_DATA 0x00000000
    +#define DDRSS_CTL_330_DATA 0x00000000
    +#define DDRSS_CTL_331_DATA 0x01030303
    +#define DDRSS_CTL_332_DATA 0x00000001
    +#define DDRSS_CTL_333_DATA 0x00000000
    +#define DDRSS_CTL_334_DATA 0x00000000
    +#define DDRSS_CTL_335_DATA 0x00000000
    +#define DDRSS_CTL_336_DATA 0x00000000
    +#define DDRSS_CTL_337_DATA 0x00000000
    +#define DDRSS_CTL_338_DATA 0x00000000
    +#define DDRSS_CTL_339_DATA 0x00000000
    +#define DDRSS_CTL_340_DATA 0x00000000
    +#define DDRSS_CTL_341_DATA 0x00000000
    +#define DDRSS_CTL_342_DATA 0x00000000
    +#define DDRSS_CTL_343_DATA 0x00000000
    +#define DDRSS_CTL_344_DATA 0x00000000
    +#define DDRSS_CTL_345_DATA 0x00000000
    +#define DDRSS_CTL_346_DATA 0x00000000
    +#define DDRSS_CTL_347_DATA 0x00000000
    +#define DDRSS_CTL_348_DATA 0x00000000
    +#define DDRSS_CTL_349_DATA 0x00000000
    +#define DDRSS_CTL_350_DATA 0x00000000
    +#define DDRSS_CTL_351_DATA 0x00000000
    +#define DDRSS_CTL_352_DATA 0x00000000
    +#define DDRSS_CTL_353_DATA 0x00000000
    +#define DDRSS_CTL_354_DATA 0x00000000
    +#define DDRSS_CTL_355_DATA 0x00000000
    +#define DDRSS_CTL_356_DATA 0x00000000
    +#define DDRSS_CTL_357_DATA 0x00000000
    +#define DDRSS_CTL_358_DATA 0x00000000
    +#define DDRSS_CTL_359_DATA 0x00000000
    +#define DDRSS_CTL_360_DATA 0x00000000
    +#define DDRSS_CTL_361_DATA 0x00000000
    +#define DDRSS_CTL_362_DATA 0x00000000
    +#define DDRSS_CTL_363_DATA 0x00000000
    +#define DDRSS_CTL_364_DATA 0x00000000
    +#define DDRSS_CTL_365_DATA 0x00000000
    +#define DDRSS_CTL_366_DATA 0x00000000
    +#define DDRSS_CTL_367_DATA 0x00000000
    +#define DDRSS_CTL_368_DATA 0x00000000
    +#define DDRSS_CTL_369_DATA 0x00000000
    +#define DDRSS_CTL_370_DATA 0x00000000
    +#define DDRSS_CTL_371_DATA 0x01000101
    +#define DDRSS_CTL_372_DATA 0x01010001
    +#define DDRSS_CTL_373_DATA 0x00010101
    +#define DDRSS_CTL_374_DATA 0x01050503
    +#define DDRSS_CTL_375_DATA 0x05020201
    +#define DDRSS_CTL_376_DATA 0x08080C0C
    +#define DDRSS_CTL_377_DATA 0x00080308
    +#define DDRSS_CTL_378_DATA 0x000B030E
    +#define DDRSS_CTL_379_DATA 0x000B0310
    +#define DDRSS_CTL_380_DATA 0x0B0B0810
    +#define DDRSS_CTL_381_DATA 0x01000000
    +#define DDRSS_CTL_382_DATA 0x03020301
    +#define DDRSS_CTL_383_DATA 0x04000102
    +#define DDRSS_CTL_384_DATA 0x1B000004
    +#define DDRSS_CTL_385_DATA 0x00000050
    +#define DDRSS_CTL_386_DATA 0x00000200
    +#define DDRSS_CTL_387_DATA 0x00000200
    +#define DDRSS_CTL_388_DATA 0x00000200
    +#define DDRSS_CTL_389_DATA 0x00000200
    +#define DDRSS_CTL_390_DATA 0x00000168
    +#define DDRSS_CTL_391_DATA 0x00000320
    +#define DDRSS_CTL_392_DATA 0x03050202
    +#define DDRSS_CTL_393_DATA 0x00260201
    +#define DDRSS_CTL_394_DATA 0x00000608
    +#define DDRSS_CTL_395_DATA 0x00000200
    +#define DDRSS_CTL_396_DATA 0x00000200
    +#define DDRSS_CTL_397_DATA 0x00000200
    +#define DDRSS_CTL_398_DATA 0x00000200
    +#define DDRSS_CTL_399_DATA 0x00001B24
    +#define DDRSS_CTL_400_DATA 0x00003C50
    +#define DDRSS_CTL_401_DATA 0x070D0402
    +#define DDRSS_CTL_402_DATA 0x00260405
    +#define DDRSS_CTL_403_DATA 0x00000608
    +#define DDRSS_CTL_404_DATA 0x00000200
    +#define DDRSS_CTL_405_DATA 0x00000200
    +#define DDRSS_CTL_406_DATA 0x00000200
    +#define DDRSS_CTL_407_DATA 0x00000200
    +#define DDRSS_CTL_408_DATA 0x00001B24
    +#define DDRSS_CTL_409_DATA 0x00003C50
    +#define DDRSS_CTL_410_DATA 0x070D0402
    +#define DDRSS_CTL_411_DATA 0x00000405
    +#define DDRSS_CTL_412_DATA 0x00000000
    +#define DDRSS_CTL_413_DATA 0x0302000A
    +#define DDRSS_CTL_414_DATA 0x01000500
    +#define DDRSS_CTL_415_DATA 0x01010001
    +#define DDRSS_CTL_416_DATA 0x00010001
    +#define DDRSS_CTL_417_DATA 0x01010001
    +#define DDRSS_CTL_418_DATA 0x02010000
    +#define DDRSS_CTL_419_DATA 0x00000200
    +#define DDRSS_CTL_420_DATA 0x02000201
    +#define DDRSS_CTL_421_DATA 0x10100600
    +#define DDRSS_CTL_422_DATA 0x00202020
    +#define DDRSS_PI_0_DATA 0x00000B00
    +#define DDRSS_PI_1_DATA 0x00000000
    +#define DDRSS_PI_2_DATA 0x00000000
    +#define DDRSS_PI_3_DATA 0x01000000
    +#define DDRSS_PI_4_DATA 0x00000001
    +#define DDRSS_PI_5_DATA 0x00010064
    +#define DDRSS_PI_6_DATA 0x00000000
    +#define DDRSS_PI_7_DATA 0x00000000
    +#define DDRSS_PI_8_DATA 0x00000000
    +#define DDRSS_PI_9_DATA 0x00000000
    +#define DDRSS_PI_10_DATA 0x00000000
    +#define DDRSS_PI_11_DATA 0x00000002
    +#define DDRSS_PI_12_DATA 0x00000005
    +#define DDRSS_PI_13_DATA 0x00010001
    +#define DDRSS_PI_14_DATA 0x08000000
    +#define DDRSS_PI_15_DATA 0x00010300
    +#define DDRSS_PI_16_DATA 0x00000005
    +#define DDRSS_PI_17_DATA 0x00000000
    +#define DDRSS_PI_18_DATA 0x00000000
    +#define DDRSS_PI_19_DATA 0x00000000
    +#define DDRSS_PI_20_DATA 0x00000000
    +#define DDRSS_PI_21_DATA 0x00000000
    +#define DDRSS_PI_22_DATA 0x00000000
    +#define DDRSS_PI_23_DATA 0x00010000
    +#define DDRSS_PI_24_DATA 0x280A0001
    +#define DDRSS_PI_25_DATA 0x00000000
    +#define DDRSS_PI_26_DATA 0x00010000
    +#define DDRSS_PI_27_DATA 0x00003200
    +#define DDRSS_PI_28_DATA 0x00000000
    +#define DDRSS_PI_29_DATA 0x00000000
    +#define DDRSS_PI_30_DATA 0x01010102
    +#define DDRSS_PI_31_DATA 0x00000000
    +#define DDRSS_PI_32_DATA 0x00000000
    +#define DDRSS_PI_33_DATA 0x00000000
    +#define DDRSS_PI_34_DATA 0x00000001
    +#define DDRSS_PI_35_DATA 0x000000AA
    +#define DDRSS_PI_36_DATA 0x00000055
    +#define DDRSS_PI_37_DATA 0x000000B5
    +#define DDRSS_PI_38_DATA 0x0000004A
    +#define DDRSS_PI_39_DATA 0x00000056
    +#define DDRSS_PI_40_DATA 0x000000A9
    +#define DDRSS_PI_41_DATA 0x000000A9
    +#define DDRSS_PI_42_DATA 0x000000B5
    +#define DDRSS_PI_43_DATA 0x00000000
    +#define DDRSS_PI_44_DATA 0x00000000
    +#define DDRSS_PI_45_DATA 0x00010100
    +#define DDRSS_PI_46_DATA 0x00000015
    +#define DDRSS_PI_47_DATA 0x000007D0
    +#define DDRSS_PI_48_DATA 0x00000300
    +#define DDRSS_PI_49_DATA 0x00000000
    +#define DDRSS_PI_50_DATA 0x00000000
    +#define DDRSS_PI_51_DATA 0x01000000
    +#define DDRSS_PI_52_DATA 0x00010101
    +#define DDRSS_PI_53_DATA 0x01000000
    +#define DDRSS_PI_54_DATA 0x03000000
    +#define DDRSS_PI_55_DATA 0x00000000
    +#define DDRSS_PI_56_DATA 0x00001701
    +#define DDRSS_PI_57_DATA 0x00000000
    +#define DDRSS_PI_58_DATA 0x00000000
    +#define DDRSS_PI_59_DATA 0x00000000
    +#define DDRSS_PI_60_DATA 0x0A0A140A
    +#define DDRSS_PI_61_DATA 0x10020101
    +#define DDRSS_PI_62_DATA 0x01000210
    +#define DDRSS_PI_63_DATA 0x05000404
    +#define DDRSS_PI_64_DATA 0x00010001
    +#define DDRSS_PI_65_DATA 0x0001000E
    +#define DDRSS_PI_66_DATA 0x01010100
    +#define DDRSS_PI_67_DATA 0x00010000
    +#define DDRSS_PI_68_DATA 0x00000034
    +#define DDRSS_PI_69_DATA 0x00000000
    +#define DDRSS_PI_70_DATA 0x00000000
    +#define DDRSS_PI_71_DATA 0x0000FFFF
    +#define DDRSS_PI_72_DATA 0x00000000
    +#define DDRSS_PI_73_DATA 0x00000000
    +#define DDRSS_PI_74_DATA 0x00000000
    +#define DDRSS_PI_75_DATA 0x00000000
    +#define DDRSS_PI_76_DATA 0x01000000
    +#define DDRSS_PI_77_DATA 0x08020100
    +#define DDRSS_PI_78_DATA 0x00020000
    +#define DDRSS_PI_79_DATA 0x00010002
    +#define DDRSS_PI_80_DATA 0x00000001
    +#define DDRSS_PI_81_DATA 0x00020001
    +#define DDRSS_PI_82_DATA 0x00020002
    +#define DDRSS_PI_83_DATA 0x00000000
    +#define DDRSS_PI_84_DATA 0x00000000
    +#define DDRSS_PI_85_DATA 0x00000000
    +#define DDRSS_PI_86_DATA 0x00000000
    +#define DDRSS_PI_87_DATA 0x00000000
    +#define DDRSS_PI_88_DATA 0x00000000
    +#define DDRSS_PI_89_DATA 0x00000000
    +#define DDRSS_PI_90_DATA 0x00000000
    +#define DDRSS_PI_91_DATA 0x00000400
    +#define DDRSS_PI_92_DATA 0x0A090B0C
    +#define DDRSS_PI_93_DATA 0x04060708
    +#define DDRSS_PI_94_DATA 0x01000005
    +#define DDRSS_PI_95_DATA 0x00000800
    +#define DDRSS_PI_96_DATA 0x00000000
    +#define DDRSS_PI_97_DATA 0x00010008
    +#define DDRSS_PI_98_DATA 0x00000000
    +#define DDRSS_PI_99_DATA 0x0000AA00
    +#define DDRSS_PI_100_DATA 0x00000000
    +#define DDRSS_PI_101_DATA 0x00010000
    +#define DDRSS_PI_102_DATA 0x00000000
    +#define DDRSS_PI_103_DATA 0x00000000
    +#define DDRSS_PI_104_DATA 0x00000000
    +#define DDRSS_PI_105_DATA 0x00000000
    +#define DDRSS_PI_106_DATA 0x00000000
    +#define DDRSS_PI_107_DATA 0x00000000
    +#define DDRSS_PI_108_DATA 0x00000000
    +#define DDRSS_PI_109_DATA 0x00000000
    +#define DDRSS_PI_110_DATA 0x00000000
    +#define DDRSS_PI_111_DATA 0x00000000
    +#define DDRSS_PI_112_DATA 0x00000000
    +#define DDRSS_PI_113_DATA 0x00000000
    +#define DDRSS_PI_114_DATA 0x00000000
    +#define DDRSS_PI_115_DATA 0x00000000
    +#define DDRSS_PI_116_DATA 0x00000000
    +#define DDRSS_PI_117_DATA 0x00000000
    +#define DDRSS_PI_118_DATA 0x00000000
    +#define DDRSS_PI_119_DATA 0x00000000
    +#define DDRSS_PI_120_DATA 0x00000000
    +#define DDRSS_PI_121_DATA 0x00000000
    +#define DDRSS_PI_122_DATA 0x00000000
    +#define DDRSS_PI_123_DATA 0x00000000
    +#define DDRSS_PI_124_DATA 0x00000008
    +#define DDRSS_PI_125_DATA 0x00000000
    +#define DDRSS_PI_126_DATA 0x00000000
    +#define DDRSS_PI_127_DATA 0x00000000
    +#define DDRSS_PI_128_DATA 0x00000000
    +#define DDRSS_PI_129_DATA 0x00000000
    +#define DDRSS_PI_130_DATA 0x00000000
    +#define DDRSS_PI_131_DATA 0x00000000
    +#define DDRSS_PI_132_DATA 0x00000000
    +#define DDRSS_PI_133_DATA 0x00010000
    +#define DDRSS_PI_134_DATA 0x00000000
    +#define DDRSS_PI_135_DATA 0x00000000
    +#define DDRSS_PI_136_DATA 0x0000000A
    +#define DDRSS_PI_137_DATA 0x000186A0
    +#define DDRSS_PI_138_DATA 0x00000100
    +#define DDRSS_PI_139_DATA 0x00000000
    +#define DDRSS_PI_140_DATA 0x00000000
    +#define DDRSS_PI_141_DATA 0x00000000
    +#define DDRSS_PI_142_DATA 0x00000000
    +#define DDRSS_PI_143_DATA 0x00000000
    +#define DDRSS_PI_144_DATA 0x01000000
    +#define DDRSS_PI_145_DATA 0x00010003
    +#define DDRSS_PI_146_DATA 0x02000101
    +#define DDRSS_PI_147_DATA 0x01030001
    +#define DDRSS_PI_148_DATA 0x00010400
    +#define DDRSS_PI_149_DATA 0x06000105
    +#define DDRSS_PI_150_DATA 0x01070001
    +#define DDRSS_PI_151_DATA 0x00000000
    +#define DDRSS_PI_152_DATA 0x00000000
    +#define DDRSS_PI_153_DATA 0x00000000
    +#define DDRSS_PI_154_DATA 0x00010001
    +#define DDRSS_PI_155_DATA 0x00000000
    +#define DDRSS_PI_156_DATA 0x00000000
    +#define DDRSS_PI_157_DATA 0x00000000
    +#define DDRSS_PI_158_DATA 0x00000000
    +#define DDRSS_PI_159_DATA 0x00010000
    +#define DDRSS_PI_160_DATA 0x00000004
    +#define DDRSS_PI_161_DATA 0x00000000
    +#define DDRSS_PI_162_DATA 0x00000000
    +#define DDRSS_PI_163_DATA 0x00000000
    +#define DDRSS_PI_164_DATA 0x00000800
    +#define DDRSS_PI_165_DATA 0x00780078
    +#define DDRSS_PI_166_DATA 0x00101001
    +#define DDRSS_PI_167_DATA 0x00000034
    +#define DDRSS_PI_168_DATA 0x00000043
    +#define DDRSS_PI_169_DATA 0x00020043
    +#define DDRSS_PI_170_DATA 0x02000200
    +#define DDRSS_PI_171_DATA 0x00000004
    +#define DDRSS_PI_172_DATA 0x0000080C
    +#define DDRSS_PI_173_DATA 0x00081C00
    +#define DDRSS_PI_174_DATA 0x001C0000
    +#define DDRSS_PI_175_DATA 0x00000013
    +#define DDRSS_PI_176_DATA 0x00000028
    +#define DDRSS_PI_177_DATA 0x00000130
    +#define DDRSS_PI_178_DATA 0x00000304
    +#define DDRSS_PI_179_DATA 0x00000130
    +#define DDRSS_PI_180_DATA 0x04000304
    +#define DDRSS_PI_181_DATA 0x01010404
    +#define DDRSS_PI_182_DATA 0x00001501
    +#define DDRSS_PI_183_DATA 0x001D001D
    +#define DDRSS_PI_184_DATA 0x01000100
    +#define DDRSS_PI_185_DATA 0x00000100
    +#define DDRSS_PI_186_DATA 0x00000000
    +#define DDRSS_PI_187_DATA 0x05050503
    +#define DDRSS_PI_188_DATA 0x01010C0C
    +#define DDRSS_PI_189_DATA 0x01010101
    +#define DDRSS_PI_190_DATA 0x000C0C0A
    +#define DDRSS_PI_191_DATA 0x00000000
    +#define DDRSS_PI_192_DATA 0x00000000
    +#define DDRSS_PI_193_DATA 0x04000000
    +#define DDRSS_PI_194_DATA 0x04020808
    +#define DDRSS_PI_195_DATA 0x04040204
    +#define DDRSS_PI_196_DATA 0x00090031
    +#define DDRSS_PI_197_DATA 0x00110039
    +#define DDRSS_PI_198_DATA 0x00110039
    +#define DDRSS_PI_199_DATA 0x01010101
    +#define DDRSS_PI_200_DATA 0x0002000D
    +#define DDRSS_PI_201_DATA 0x000200C8
    +#define DDRSS_PI_202_DATA 0x010000C8
    +#define DDRSS_PI_203_DATA 0x000E000E
    +#define DDRSS_PI_204_DATA 0x00C90100
    +#define DDRSS_PI_205_DATA 0x010000C9
    +#define DDRSS_PI_206_DATA 0x00C900C9
    +#define DDRSS_PI_207_DATA 0x32103200
    +#define DDRSS_PI_208_DATA 0x01013210
    +#define DDRSS_PI_209_DATA 0x0A070601
    +#define DDRSS_PI_210_DATA 0x0D09070D
    +#define DDRSS_PI_211_DATA 0x0D09070D
    +#define DDRSS_PI_212_DATA 0x000C000D
    +#define DDRSS_PI_213_DATA 0x00001000
    +#define DDRSS_PI_214_DATA 0x00000C00
    +#define DDRSS_PI_215_DATA 0x00001000
    +#define DDRSS_PI_216_DATA 0x00000C00
    +#define DDRSS_PI_217_DATA 0x02001000
    +#define DDRSS_PI_218_DATA 0x0016000D
    +#define DDRSS_PI_219_DATA 0x001600C8
    +#define DDRSS_PI_220_DATA 0x000000C8
    +#define DDRSS_PI_221_DATA 0x00001900
    +#define DDRSS_PI_222_DATA 0x32000056
    +#define DDRSS_PI_223_DATA 0x06000101
    +#define DDRSS_PI_224_DATA 0x001D0204
    +#define DDRSS_PI_225_DATA 0x32120058
    +#define DDRSS_PI_226_DATA 0x05000101
    +#define DDRSS_PI_227_DATA 0x001D0408
    +#define DDRSS_PI_228_DATA 0x32120058
    +#define DDRSS_PI_229_DATA 0x05000101
    +#define DDRSS_PI_230_DATA 0x00000408
    +#define DDRSS_PI_231_DATA 0x05030900
    +#define DDRSS_PI_232_DATA 0x00040900
    +#define DDRSS_PI_233_DATA 0x0000018A
    +#define DDRSS_PI_234_DATA 0x20010004
    +#define DDRSS_PI_235_DATA 0x0A0A0A03
    +#define DDRSS_PI_236_DATA 0x13090000
    +#define DDRSS_PI_237_DATA 0x10090011
    +#define DDRSS_PI_238_DATA 0x000018AE
    +#define DDRSS_PI_239_DATA 0x20030024
    +#define DDRSS_PI_240_DATA 0x0C0A0C0C
    +#define DDRSS_PI_241_DATA 0x13090000
    +#define DDRSS_PI_242_DATA 0x10090011
    +#define DDRSS_PI_243_DATA 0x000018AE
    +#define DDRSS_PI_244_DATA 0x20030024
    +#define DDRSS_PI_245_DATA 0x0C0A0C0C
    +#define DDRSS_PI_246_DATA 0x00000000
    +#define DDRSS_PI_247_DATA 0x00000050
    +#define DDRSS_PI_248_DATA 0x00000320
    +#define DDRSS_PI_249_DATA 0x00000608
    +#define DDRSS_PI_250_DATA 0x00003C50
    +#define DDRSS_PI_251_DATA 0x00000608
    +#define DDRSS_PI_252_DATA 0x00003C50
    +#define DDRSS_PI_253_DATA 0x01360014
    +#define DDRSS_PI_254_DATA 0x03030136
    +#define DDRSS_PI_255_DATA 0x00000003
    +#define DDRSS_PI_256_DATA 0x00000000
    +#define DDRSS_PI_257_DATA 0x05030503
    +#define DDRSS_PI_258_DATA 0x00000503
    +#define DDRSS_PI_259_DATA 0x00002710
    +#define DDRSS_PI_260_DATA 0x000186A0
    +#define DDRSS_PI_261_DATA 0x00000005
    +#define DDRSS_PI_262_DATA 0x00000064
    +#define DDRSS_PI_263_DATA 0x00000014
    +#define DDRSS_PI_264_DATA 0x00027100
    +#define DDRSS_PI_265_DATA 0x000186A0
    +#define DDRSS_PI_266_DATA 0x00000005
    +#define DDRSS_PI_267_DATA 0x00000640
    +#define DDRSS_PI_268_DATA 0x00000136
    +#define DDRSS_PI_269_DATA 0x00027100
    +#define DDRSS_PI_270_DATA 0x000186A0
    +#define DDRSS_PI_271_DATA 0x00000005
    +#define DDRSS_PI_272_DATA 0x00000640
    +#define DDRSS_PI_273_DATA 0x01000136
    +#define DDRSS_PI_274_DATA 0x00320040
    +#define DDRSS_PI_275_DATA 0x00010008
    +#define DDRSS_PI_276_DATA 0x03200040
    +#define DDRSS_PI_277_DATA 0x00010018
    +#define DDRSS_PI_278_DATA 0x03200040
    +#define DDRSS_PI_279_DATA 0x00000318
    +#define DDRSS_PI_280_DATA 0x00280028
    +#define DDRSS_PI_281_DATA 0x03040404
    +#define DDRSS_PI_282_DATA 0x00000303
    +#define DDRSS_PI_283_DATA 0x02020101
    +#define DDRSS_PI_284_DATA 0x67676767
    +#define DDRSS_PI_285_DATA 0x00000000
    +#define DDRSS_PI_286_DATA 0x55000000
    +#define DDRSS_PI_287_DATA 0x00000000
    +#define DDRSS_PI_288_DATA 0x3C00005A
    +#define DDRSS_PI_289_DATA 0x00005500
    +#define DDRSS_PI_290_DATA 0x00005A00
    +#define DDRSS_PI_291_DATA 0x0D100F3C
    +#define DDRSS_PI_292_DATA 0x0003020E
    +#define DDRSS_PI_293_DATA 0x00000001
    +#define DDRSS_PI_294_DATA 0x01000000
    +#define DDRSS_PI_295_DATA 0x00020201
    +#define DDRSS_PI_296_DATA 0x00000000
    +#define DDRSS_PI_297_DATA 0x00000000
    +#define DDRSS_PI_298_DATA 0x00000004
    +#define DDRSS_PI_299_DATA 0x00000000
    +#define DDRSS_PI_300_DATA 0x00000031
    +#define DDRSS_PI_301_DATA 0x00000000
    +#define DDRSS_PI_302_DATA 0x00000000
    +#define DDRSS_PI_303_DATA 0x00000000
    +#define DDRSS_PI_304_DATA 0x00100F27
    +#define DDRSS_PI_305_DATA 0x00000000
    +#define DDRSS_PI_306_DATA 0x00000024
    +#define DDRSS_PI_307_DATA 0x00000012
    +#define DDRSS_PI_308_DATA 0x000000B1
    +#define DDRSS_PI_309_DATA 0x00000000
    +#define DDRSS_PI_310_DATA 0x00000000
    +#define DDRSS_PI_311_DATA 0x46000000
    +#define DDRSS_PI_312_DATA 0x00150F27
    +#define DDRSS_PI_313_DATA 0x00000000
    +#define DDRSS_PI_314_DATA 0x00000024
    +#define DDRSS_PI_315_DATA 0x00000012
    +#define DDRSS_PI_316_DATA 0x000000B1
    +#define DDRSS_PI_317_DATA 0x00000000
    +#define DDRSS_PI_318_DATA 0x00000000
    +#define DDRSS_PI_319_DATA 0x46000000
    +#define DDRSS_PI_320_DATA 0x00150F27
    +#define DDRSS_PI_321_DATA 0x00000000
    +#define DDRSS_PI_322_DATA 0x00000004
    +#define DDRSS_PI_323_DATA 0x00000000
    +#define DDRSS_PI_324_DATA 0x00000031
    +#define DDRSS_PI_325_DATA 0x00000000
    +#define DDRSS_PI_326_DATA 0x00000000
    +#define DDRSS_PI_327_DATA 0x00000000
    +#define DDRSS_PI_328_DATA 0x00100F27
    +#define DDRSS_PI_329_DATA 0x00000000
    +#define DDRSS_PI_330_DATA 0x00000024
    +#define DDRSS_PI_331_DATA 0x00000012
    +#define DDRSS_PI_332_DATA 0x000000B1
    +#define DDRSS_PI_333_DATA 0x00000000
    +#define DDRSS_PI_334_DATA 0x00000000
    +#define DDRSS_PI_335_DATA 0x46000000
    +#define DDRSS_PI_336_DATA 0x00150F27
    +#define DDRSS_PI_337_DATA 0x00000000
    +#define DDRSS_PI_338_DATA 0x00000024
    +#define DDRSS_PI_339_DATA 0x00000012
    +#define DDRSS_PI_340_DATA 0x000000B1
    +#define DDRSS_PI_341_DATA 0x00000000
    +#define DDRSS_PI_342_DATA 0x00000000
    +#define DDRSS_PI_343_DATA 0x46000000
    +#define DDRSS_PI_344_DATA 0x00150F27
    +#define DDRSS_PHY_0_DATA 0x04F00000
    +#define DDRSS_PHY_1_DATA 0x00000000
    +#define DDRSS_PHY_2_DATA 0x00030200
    +#define DDRSS_PHY_3_DATA 0x00000000
    +#define DDRSS_PHY_4_DATA 0x00000000
    +#define DDRSS_PHY_5_DATA 0x01000000
    +#define DDRSS_PHY_6_DATA 0x03000400
    +#define DDRSS_PHY_7_DATA 0x00000001
    +#define DDRSS_PHY_8_DATA 0x00000001
    +#define DDRSS_PHY_9_DATA 0x00000000
    +#define DDRSS_PHY_10_DATA 0x00000000
    +#define DDRSS_PHY_11_DATA 0x01010000
    +#define DDRSS_PHY_12_DATA 0x00010000
    +#define DDRSS_PHY_13_DATA 0x00C00001
    +#define DDRSS_PHY_14_DATA 0x00CC0008
    +#define DDRSS_PHY_15_DATA 0x00660601
    +#define DDRSS_PHY_16_DATA 0x00000003
    +#define DDRSS_PHY_17_DATA 0x00000000
    +#define DDRSS_PHY_18_DATA 0x00000000
    +#define DDRSS_PHY_19_DATA 0x0000AAAA
    +#define DDRSS_PHY_20_DATA 0x00005555
    +#define DDRSS_PHY_21_DATA 0x0000B5B5
    +#define DDRSS_PHY_22_DATA 0x00004A4A
    +#define DDRSS_PHY_23_DATA 0x00005656
    +#define DDRSS_PHY_24_DATA 0x0000A9A9
    +#define DDRSS_PHY_25_DATA 0x0000B7B7
    +#define DDRSS_PHY_26_DATA 0x00004848
    +#define DDRSS_PHY_27_DATA 0x00000000
    +#define DDRSS_PHY_28_DATA 0x00000000
    +#define DDRSS_PHY_29_DATA 0x08000000
    +#define DDRSS_PHY_30_DATA 0x0F000008
    +#define DDRSS_PHY_31_DATA 0x00000F0F
    +#define DDRSS_PHY_32_DATA 0x00E4E400
    +#define DDRSS_PHY_33_DATA 0x00071020
    +#define DDRSS_PHY_34_DATA 0x000C0020
    +#define DDRSS_PHY_35_DATA 0x00062000
    +#define DDRSS_PHY_36_DATA 0x00000000
    +#define DDRSS_PHY_37_DATA 0x55555555
    +#define DDRSS_PHY_38_DATA 0xAAAAAAAA
    +#define DDRSS_PHY_39_DATA 0x55555555
    +#define DDRSS_PHY_40_DATA 0xAAAAAAAA
    +#define DDRSS_PHY_41_DATA 0x00005555
    +#define DDRSS_PHY_42_DATA 0x01000100
    +#define DDRSS_PHY_43_DATA 0x00800180
    +#define DDRSS_PHY_44_DATA 0x00000001
    +#define DDRSS_PHY_45_DATA 0x00000000
    +#define DDRSS_PHY_46_DATA 0x00000000
    +#define DDRSS_PHY_47_DATA 0x00000000
    +#define DDRSS_PHY_48_DATA 0x00000000
    +#define DDRSS_PHY_49_DATA 0x00000000
    +#define DDRSS_PHY_50_DATA 0x00000000
    +#define DDRSS_PHY_51_DATA 0x00000000
    +#define DDRSS_PHY_52_DATA 0x00000000
    +#define DDRSS_PHY_53_DATA 0x00000000
    +#define DDRSS_PHY_54_DATA 0x00000000
    +#define DDRSS_PHY_55_DATA 0x00000000
    +#define DDRSS_PHY_56_DATA 0x00000000
    +#define DDRSS_PHY_57_DATA 0x00000000
    +#define DDRSS_PHY_58_DATA 0x00000000
    +#define DDRSS_PHY_59_DATA 0x00000000
    +#define DDRSS_PHY_60_DATA 0x00000000
    +#define DDRSS_PHY_61_DATA 0x00000000
    +#define DDRSS_PHY_62_DATA 0x00000000
    +#define DDRSS_PHY_63_DATA 0x00000000
    +#define DDRSS_PHY_64_DATA 0x00000000
    +#define DDRSS_PHY_65_DATA 0x00000004
    +#define DDRSS_PHY_66_DATA 0x00000000
    +#define DDRSS_PHY_67_DATA 0x00000000
    +#define DDRSS_PHY_68_DATA 0x00000000
    +#define DDRSS_PHY_69_DATA 0x00000000
    +#define DDRSS_PHY_70_DATA 0x00000000
    +#define DDRSS_PHY_71_DATA 0x00000000
    +#define DDRSS_PHY_72_DATA 0x041F07FF
    +#define DDRSS_PHY_73_DATA 0x00000000
    +#define DDRSS_PHY_74_DATA 0x01CC0B01
    +#define DDRSS_PHY_75_DATA 0x1003CC0B
    +#define DDRSS_PHY_76_DATA 0x20000140
    +#define DDRSS_PHY_77_DATA 0x07FF0200
    +#define DDRSS_PHY_78_DATA 0x0000DD01
    +#define DDRSS_PHY_79_DATA 0x00100303
    +#define DDRSS_PHY_80_DATA 0x00000000
    +#define DDRSS_PHY_81_DATA 0x00000000
    +#define DDRSS_PHY_82_DATA 0x00021000
    +#define DDRSS_PHY_83_DATA 0x00100010
    +#define DDRSS_PHY_84_DATA 0x00100010
    +#define DDRSS_PHY_85_DATA 0x00100010
    +#define DDRSS_PHY_86_DATA 0x00100010
    +#define DDRSS_PHY_87_DATA 0x02020010
    +#define DDRSS_PHY_88_DATA 0x51516041
    +#define DDRSS_PHY_89_DATA 0x31C06000
    +#define DDRSS_PHY_90_DATA 0x07AB0340
    +#define DDRSS_PHY_91_DATA 0x0000C0C0
    +#define DDRSS_PHY_92_DATA 0x04050000
    +#define DDRSS_PHY_93_DATA 0x00000504
    +#define DDRSS_PHY_94_DATA 0x42100010
    +#define DDRSS_PHY_95_DATA 0x010C053E
    +#define DDRSS_PHY_96_DATA 0x000F0C1D
    +#define DDRSS_PHY_97_DATA 0x01000140
    +#define DDRSS_PHY_98_DATA 0x007A0120
    +#define DDRSS_PHY_99_DATA 0x00000C00
    +#define DDRSS_PHY_100_DATA 0x000001CC
    +#define DDRSS_PHY_101_DATA 0x20100200
    +#define DDRSS_PHY_102_DATA 0x00000005
    +#define DDRSS_PHY_103_DATA 0x76543210
    +#define DDRSS_PHY_104_DATA 0x00000008
    +#define DDRSS_PHY_105_DATA 0x034C034C
    +#define DDRSS_PHY_106_DATA 0x034C034C
    +#define DDRSS_PHY_107_DATA 0x034C034C
    +#define DDRSS_PHY_108_DATA 0x034C034C
    +#define DDRSS_PHY_109_DATA 0x0000034C
    +#define DDRSS_PHY_110_DATA 0x00008000
    +#define DDRSS_PHY_111_DATA 0x00800080
    +#define DDRSS_PHY_112_DATA 0x00800080
    +#define DDRSS_PHY_113_DATA 0x00800080
    +#define DDRSS_PHY_114_DATA 0x00800080
    +#define DDRSS_PHY_115_DATA 0x00800080
    +#define DDRSS_PHY_116_DATA 0x00800080
    +#define DDRSS_PHY_117_DATA 0x00800080
    +#define DDRSS_PHY_118_DATA 0x00800080
    +#define DDRSS_PHY_119_DATA 0x01800080
    +#define DDRSS_PHY_120_DATA 0x01000000
    +#define DDRSS_PHY_121_DATA 0x00000000
    +#define DDRSS_PHY_122_DATA 0x00000000
    +#define DDRSS_PHY_123_DATA 0x00080200
    +#define DDRSS_PHY_124_DATA 0x00000000
    +#define DDRSS_PHY_125_DATA 0x0000F0F0
    +#define DDRSS_PHY_126_DATA 0x00000000
    +#define DDRSS_PHY_127_DATA 0x00000000
    +#define DDRSS_PHY_128_DATA 0x00000000
    +#define DDRSS_PHY_129_DATA 0x00000000
    +#define DDRSS_PHY_130_DATA 0x00000000
    +#define DDRSS_PHY_131_DATA 0x00000000
    +#define DDRSS_PHY_132_DATA 0x00000000
    +#define DDRSS_PHY_133_DATA 0x00000000
    +#define DDRSS_PHY_134_DATA 0x00000000
    +#define DDRSS_PHY_135_DATA 0x00000000
    +#define DDRSS_PHY_136_DATA 0x00000000
    +#define DDRSS_PHY_137_DATA 0x00000000
    +#define DDRSS_PHY_138_DATA 0x00000000
    +#define DDRSS_PHY_139_DATA 0x00000000
    +#define DDRSS_PHY_140_DATA 0x00000000
    +#define DDRSS_PHY_141_DATA 0x00000000
    +#define DDRSS_PHY_142_DATA 0x00000000
    +#define DDRSS_PHY_143_DATA 0x00000000
    +#define DDRSS_PHY_144_DATA 0x00000000
    +#define DDRSS_PHY_145_DATA 0x00000000
    +#define DDRSS_PHY_146_DATA 0x00000000
    +#define DDRSS_PHY_147_DATA 0x00000000
    +#define DDRSS_PHY_148_DATA 0x00000000
    +#define DDRSS_PHY_149_DATA 0x00000000
    +#define DDRSS_PHY_150_DATA 0x00000000
    +#define DDRSS_PHY_151_DATA 0x00000000
    +#define DDRSS_PHY_152_DATA 0x00000000
    +#define DDRSS_PHY_153_DATA 0x00000000
    +#define DDRSS_PHY_154_DATA 0x00000000
    +#define DDRSS_PHY_155_DATA 0x00000000
    +#define DDRSS_PHY_156_DATA 0x00000000
    +#define DDRSS_PHY_157_DATA 0x00000000
    +#define DDRSS_PHY_158_DATA 0x00000000
    +#define DDRSS_PHY_159_DATA 0x00000000
    +#define DDRSS_PHY_160_DATA 0x00000000
    +#define DDRSS_PHY_161_DATA 0x00000000
    +#define DDRSS_PHY_162_DATA 0x00000000
    +#define DDRSS_PHY_163_DATA 0x00000000
    +#define DDRSS_PHY_164_DATA 0x00000000
    +#define DDRSS_PHY_165_DATA 0x00000000
    +#define DDRSS_PHY_166_DATA 0x00000000
    +#define DDRSS_PHY_167_DATA 0x00000000
    +#define DDRSS_PHY_168_DATA 0x00000000
    +#define DDRSS_PHY_169_DATA 0x00000000
    +#define DDRSS_PHY_170_DATA 0x00000000
    +#define DDRSS_PHY_171_DATA 0x00000000
    +#define DDRSS_PHY_172_DATA 0x00000000
    +#define DDRSS_PHY_173_DATA 0x00000000
    +#define DDRSS_PHY_174_DATA 0x00000000
    +#define DDRSS_PHY_175_DATA 0x00000000
    +#define DDRSS_PHY_176_DATA 0x00000000
    +#define DDRSS_PHY_177_DATA 0x00000000
    +#define DDRSS_PHY_178_DATA 0x00000000
    +#define DDRSS_PHY_179_DATA 0x00000000
    +#define DDRSS_PHY_180_DATA 0x00000000
    +#define DDRSS_PHY_181_DATA 0x00000000
    +#define DDRSS_PHY_182_DATA 0x00000000
    +#define DDRSS_PHY_183_DATA 0x00000000
    +#define DDRSS_PHY_184_DATA 0x00000000
    +#define DDRSS_PHY_185_DATA 0x00000000
    +#define DDRSS_PHY_186_DATA 0x00000000
    +#define DDRSS_PHY_187_DATA 0x00000000
    +#define DDRSS_PHY_188_DATA 0x00000000
    +#define DDRSS_PHY_189_DATA 0x00000000
    +#define DDRSS_PHY_190_DATA 0x00000000
    +#define DDRSS_PHY_191_DATA 0x00000000
    +#define DDRSS_PHY_192_DATA 0x00000000
    +#define DDRSS_PHY_193_DATA 0x00000000
    +#define DDRSS_PHY_194_DATA 0x00000000
    +#define DDRSS_PHY_195_DATA 0x00000000
    +#define DDRSS_PHY_196_DATA 0x00000000
    +#define DDRSS_PHY_197_DATA 0x00000000
    +#define DDRSS_PHY_198_DATA 0x00000000
    +#define DDRSS_PHY_199_DATA 0x00000000
    +#define DDRSS_PHY_200_DATA 0x00000000
    +#define DDRSS_PHY_201_DATA 0x00000000
    +#define DDRSS_PHY_202_DATA 0x00000000
    +#define DDRSS_PHY_203_DATA 0x00000000
    +#define DDRSS_PHY_204_DATA 0x00000000
    +#define DDRSS_PHY_205_DATA 0x00000000
    +#define DDRSS_PHY_206_DATA 0x00000000
    +#define DDRSS_PHY_207_DATA 0x00000000
    +#define DDRSS_PHY_208_DATA 0x00000000
    +#define DDRSS_PHY_209_DATA 0x00000000
    +#define DDRSS_PHY_210_DATA 0x00000000
    +#define DDRSS_PHY_211_DATA 0x00000000
    +#define DDRSS_PHY_212_DATA 0x00000000
    +#define DDRSS_PHY_213_DATA 0x00000000
    +#define DDRSS_PHY_214_DATA 0x00000000
    +#define DDRSS_PHY_215_DATA 0x00000000
    +#define DDRSS_PHY_216_DATA 0x00000000
    +#define DDRSS_PHY_217_DATA 0x00000000
    +#define DDRSS_PHY_218_DATA 0x00000000
    +#define DDRSS_PHY_219_DATA 0x00000000
    +#define DDRSS_PHY_220_DATA 0x00000000
    +#define DDRSS_PHY_221_DATA 0x00000000
    +#define DDRSS_PHY_222_DATA 0x00000000
    +#define DDRSS_PHY_223_DATA 0x00000000
    +#define DDRSS_PHY_224_DATA 0x00000000
    +#define DDRSS_PHY_225_DATA 0x00000000
    +#define DDRSS_PHY_226_DATA 0x00000000
    +#define DDRSS_PHY_227_DATA 0x00000000
    +#define DDRSS_PHY_228_DATA 0x00000000
    +#define DDRSS_PHY_229_DATA 0x00000000
    +#define DDRSS_PHY_230_DATA 0x00000000
    +#define DDRSS_PHY_231_DATA 0x00000000
    +#define DDRSS_PHY_232_DATA 0x00000000
    +#define DDRSS_PHY_233_DATA 0x00000000
    +#define DDRSS_PHY_234_DATA 0x00000000
    +#define DDRSS_PHY_235_DATA 0x00000000
    +#define DDRSS_PHY_236_DATA 0x00000000
    +#define DDRSS_PHY_237_DATA 0x00000000
    +#define DDRSS_PHY_238_DATA 0x00000000
    +#define DDRSS_PHY_239_DATA 0x00000000
    +#define DDRSS_PHY_240_DATA 0x00000000
    +#define DDRSS_PHY_241_DATA 0x00000000
    +#define DDRSS_PHY_242_DATA 0x00000000
    +#define DDRSS_PHY_243_DATA 0x00000000
    +#define DDRSS_PHY_244_DATA 0x00000000
    +#define DDRSS_PHY_245_DATA 0x00000000
    +#define DDRSS_PHY_246_DATA 0x00000000
    +#define DDRSS_PHY_247_DATA 0x00000000
    +#define DDRSS_PHY_248_DATA 0x00000000
    +#define DDRSS_PHY_249_DATA 0x00000000
    +#define DDRSS_PHY_250_DATA 0x00000000
    +#define DDRSS_PHY_251_DATA 0x00000000
    +#define DDRSS_PHY_252_DATA 0x00000000
    +#define DDRSS_PHY_253_DATA 0x00000000
    +#define DDRSS_PHY_254_DATA 0x00000000
    +#define DDRSS_PHY_255_DATA 0x00000000
    +#define DDRSS_PHY_256_DATA 0x04F00000
    +#define DDRSS_PHY_257_DATA 0x00000000
    +#define DDRSS_PHY_258_DATA 0x00030200
    +#define DDRSS_PHY_259_DATA 0x00000000
    +#define DDRSS_PHY_260_DATA 0x00000000
    +#define DDRSS_PHY_261_DATA 0x01000000
    +#define DDRSS_PHY_262_DATA 0x03000400
    +#define DDRSS_PHY_263_DATA 0x00000001
    +#define DDRSS_PHY_264_DATA 0x00000001
    +#define DDRSS_PHY_265_DATA 0x00000000
    +#define DDRSS_PHY_266_DATA 0x00000000
    +#define DDRSS_PHY_267_DATA 0x01010000
    +#define DDRSS_PHY_268_DATA 0x00010000
    +#define DDRSS_PHY_269_DATA 0x00C00001
    +#define DDRSS_PHY_270_DATA 0x00CC0008
    +#define DDRSS_PHY_271_DATA 0x00660601
    +#define DDRSS_PHY_272_DATA 0x00000003
    +#define DDRSS_PHY_273_DATA 0x00000000
    +#define DDRSS_PHY_274_DATA 0x00000000
    +#define DDRSS_PHY_275_DATA 0x0000AAAA
    +#define DDRSS_PHY_276_DATA 0x00005555
    +#define DDRSS_PHY_277_DATA 0x0000B5B5
    +#define DDRSS_PHY_278_DATA 0x00004A4A
    +#define DDRSS_PHY_279_DATA 0x00005656
    +#define DDRSS_PHY_280_DATA 0x0000A9A9
    +#define DDRSS_PHY_281_DATA 0x0000B7B7
    +#define DDRSS_PHY_282_DATA 0x00004848
    +#define DDRSS_PHY_283_DATA 0x00000000
    +#define DDRSS_PHY_284_DATA 0x00000000
    +#define DDRSS_PHY_285_DATA 0x08000000
    +#define DDRSS_PHY_286_DATA 0x0F000008
    +#define DDRSS_PHY_287_DATA 0x00000F0F
    +#define DDRSS_PHY_288_DATA 0x00E4E400
    +#define DDRSS_PHY_289_DATA 0x00071020
    +#define DDRSS_PHY_290_DATA 0x000C0020
    +#define DDRSS_PHY_291_DATA 0x00062000
    +#define DDRSS_PHY_292_DATA 0x00000000
    +#define DDRSS_PHY_293_DATA 0x55555555
    +#define DDRSS_PHY_294_DATA 0xAAAAAAAA
    +#define DDRSS_PHY_295_DATA 0x55555555
    +#define DDRSS_PHY_296_DATA 0xAAAAAAAA
    +#define DDRSS_PHY_297_DATA 0x00005555
    +#define DDRSS_PHY_298_DATA 0x01000100
    +#define DDRSS_PHY_299_DATA 0x00800180
    +#define DDRSS_PHY_300_DATA 0x00000000
    +#define DDRSS_PHY_301_DATA 0x00000000
    +#define DDRSS_PHY_302_DATA 0x00000000
    +#define DDRSS_PHY_303_DATA 0x00000000
    +#define DDRSS_PHY_304_DATA 0x00000000
    +#define DDRSS_PHY_305_DATA 0x00000000
    +#define DDRSS_PHY_306_DATA 0x00000000
    +#define DDRSS_PHY_307_DATA 0x00000000
    +#define DDRSS_PHY_308_DATA 0x00000000
    +#define DDRSS_PHY_309_DATA 0x00000000
    +#define DDRSS_PHY_310_DATA 0x00000000
    +#define DDRSS_PHY_311_DATA 0x00000000
    +#define DDRSS_PHY_312_DATA 0x00000000
    +#define DDRSS_PHY_313_DATA 0x00000000
    +#define DDRSS_PHY_314_DATA 0x00000000
    +#define DDRSS_PHY_315_DATA 0x00000000
    +#define DDRSS_PHY_316_DATA 0x00000000
    +#define DDRSS_PHY_317_DATA 0x00000000
    +#define DDRSS_PHY_318_DATA 0x00000000
    +#define DDRSS_PHY_319_DATA 0x00000000
    +#define DDRSS_PHY_320_DATA 0x00000000
    +#define DDRSS_PHY_321_DATA 0x00000004
    +#define DDRSS_PHY_322_DATA 0x00000000
    +#define DDRSS_PHY_323_DATA 0x00000000
    +#define DDRSS_PHY_324_DATA 0x00000000
    +#define DDRSS_PHY_325_DATA 0x00000000
    +#define DDRSS_PHY_326_DATA 0x00000000
    +#define DDRSS_PHY_327_DATA 0x00000000
    +#define DDRSS_PHY_328_DATA 0x041F07FF
    +#define DDRSS_PHY_329_DATA 0x00000000
    +#define DDRSS_PHY_330_DATA 0x01CC0B01
    +#define DDRSS_PHY_331_DATA 0x1003CC0B
    +#define DDRSS_PHY_332_DATA 0x20000140
    +#define DDRSS_PHY_333_DATA 0x07FF0200
    +#define DDRSS_PHY_334_DATA 0x0000DD01
    +#define DDRSS_PHY_335_DATA 0x00100303
    +#define DDRSS_PHY_336_DATA 0x00000000
    +#define DDRSS_PHY_337_DATA 0x00000000
    +#define DDRSS_PHY_338_DATA 0x00021000
    +#define DDRSS_PHY_339_DATA 0x00100010
    +#define DDRSS_PHY_340_DATA 0x00100010
    +#define DDRSS_PHY_341_DATA 0x00100010
    +#define DDRSS_PHY_342_DATA 0x00100010
    +#define DDRSS_PHY_343_DATA 0x02020010
    +#define DDRSS_PHY_344_DATA 0x51516041
    +#define DDRSS_PHY_345_DATA 0x31C06000
    +#define DDRSS_PHY_346_DATA 0x07AB0340
    +#define DDRSS_PHY_347_DATA 0x0000C0C0
    +#define DDRSS_PHY_348_DATA 0x04050000
    +#define DDRSS_PHY_349_DATA 0x00000504
    +#define DDRSS_PHY_350_DATA 0x42100010
    +#define DDRSS_PHY_351_DATA 0x010C053E
    +#define DDRSS_PHY_352_DATA 0x000F0C1D
    +#define DDRSS_PHY_353_DATA 0x01000140
    +#define DDRSS_PHY_354_DATA 0x007A0120
    +#define DDRSS_PHY_355_DATA 0x00000C00
    +#define DDRSS_PHY_356_DATA 0x000001CC
    +#define DDRSS_PHY_357_DATA 0x20100200
    +#define DDRSS_PHY_358_DATA 0x00000005
    +#define DDRSS_PHY_359_DATA 0x76543210
    +#define DDRSS_PHY_360_DATA 0x00000008
    +#define DDRSS_PHY_361_DATA 0x034C034C
    +#define DDRSS_PHY_362_DATA 0x034C034C
    +#define DDRSS_PHY_363_DATA 0x034C034C
    +#define DDRSS_PHY_364_DATA 0x034C034C
    +#define DDRSS_PHY_365_DATA 0x0000034C
    +#define DDRSS_PHY_366_DATA 0x00008000
    +#define DDRSS_PHY_367_DATA 0x00800080
    +#define DDRSS_PHY_368_DATA 0x00800080
    +#define DDRSS_PHY_369_DATA 0x00800080
    +#define DDRSS_PHY_370_DATA 0x00800080
    +#define DDRSS_PHY_371_DATA 0x00800080
    +#define DDRSS_PHY_372_DATA 0x00800080
    +#define DDRSS_PHY_373_DATA 0x00800080
    +#define DDRSS_PHY_374_DATA 0x00800080
    +#define DDRSS_PHY_375_DATA 0x01800080
    +#define DDRSS_PHY_376_DATA 0x01000000
    +#define DDRSS_PHY_377_DATA 0x00000000
    +#define DDRSS_PHY_378_DATA 0x00000000
    +#define DDRSS_PHY_379_DATA 0x00080200
    +#define DDRSS_PHY_380_DATA 0x00000000
    +#define DDRSS_PHY_381_DATA 0x0000F0F0
    +#define DDRSS_PHY_382_DATA 0x00000000
    +#define DDRSS_PHY_383_DATA 0x00000000
    +#define DDRSS_PHY_384_DATA 0x00000000
    +#define DDRSS_PHY_385_DATA 0x00000000
    +#define DDRSS_PHY_386_DATA 0x00000000
    +#define DDRSS_PHY_387_DATA 0x00000000
    +#define DDRSS_PHY_388_DATA 0x00000000
    +#define DDRSS_PHY_389_DATA 0x00000000
    +#define DDRSS_PHY_390_DATA 0x00000000
    +#define DDRSS_PHY_391_DATA 0x00000000
    +#define DDRSS_PHY_392_DATA 0x00000000
    +#define DDRSS_PHY_393_DATA 0x00000000
    +#define DDRSS_PHY_394_DATA 0x00000000
    +#define DDRSS_PHY_395_DATA 0x00000000
    +#define DDRSS_PHY_396_DATA 0x00000000
    +#define DDRSS_PHY_397_DATA 0x00000000
    +#define DDRSS_PHY_398_DATA 0x00000000
    +#define DDRSS_PHY_399_DATA 0x00000000
    +#define DDRSS_PHY_400_DATA 0x00000000
    +#define DDRSS_PHY_401_DATA 0x00000000
    +#define DDRSS_PHY_402_DATA 0x00000000
    +#define DDRSS_PHY_403_DATA 0x00000000
    +#define DDRSS_PHY_404_DATA 0x00000000
    +#define DDRSS_PHY_405_DATA 0x00000000
    +#define DDRSS_PHY_406_DATA 0x00000000
    +#define DDRSS_PHY_407_DATA 0x00000000
    +#define DDRSS_PHY_408_DATA 0x00000000
    +#define DDRSS_PHY_409_DATA 0x00000000
    +#define DDRSS_PHY_410_DATA 0x00000000
    +#define DDRSS_PHY_411_DATA 0x00000000
    +#define DDRSS_PHY_412_DATA 0x00000000
    +#define DDRSS_PHY_413_DATA 0x00000000
    +#define DDRSS_PHY_414_DATA 0x00000000
    +#define DDRSS_PHY_415_DATA 0x00000000
    +#define DDRSS_PHY_416_DATA 0x00000000
    +#define DDRSS_PHY_417_DATA 0x00000000
    +#define DDRSS_PHY_418_DATA 0x00000000
    +#define DDRSS_PHY_419_DATA 0x00000000
    +#define DDRSS_PHY_420_DATA 0x00000000
    +#define DDRSS_PHY_421_DATA 0x00000000
    +#define DDRSS_PHY_422_DATA 0x00000000
    +#define DDRSS_PHY_423_DATA 0x00000000
    +#define DDRSS_PHY_424_DATA 0x00000000
    +#define DDRSS_PHY_425_DATA 0x00000000
    +#define DDRSS_PHY_426_DATA 0x00000000
    +#define DDRSS_PHY_427_DATA 0x00000000
    +#define DDRSS_PHY_428_DATA 0x00000000
    +#define DDRSS_PHY_429_DATA 0x00000000
    +#define DDRSS_PHY_430_DATA 0x00000000
    +#define DDRSS_PHY_431_DATA 0x00000000
    +#define DDRSS_PHY_432_DATA 0x00000000
    +#define DDRSS_PHY_433_DATA 0x00000000
    +#define DDRSS_PHY_434_DATA 0x00000000
    +#define DDRSS_PHY_435_DATA 0x00000000
    +#define DDRSS_PHY_436_DATA 0x00000000
    +#define DDRSS_PHY_437_DATA 0x00000000
    +#define DDRSS_PHY_438_DATA 0x00000000
    +#define DDRSS_PHY_439_DATA 0x00000000
    +#define DDRSS_PHY_440_DATA 0x00000000
    +#define DDRSS_PHY_441_DATA 0x00000000
    +#define DDRSS_PHY_442_DATA 0x00000000
    +#define DDRSS_PHY_443_DATA 0x00000000
    +#define DDRSS_PHY_444_DATA 0x00000000
    +#define DDRSS_PHY_445_DATA 0x00000000
    +#define DDRSS_PHY_446_DATA 0x00000000
    +#define DDRSS_PHY_447_DATA 0x00000000
    +#define DDRSS_PHY_448_DATA 0x00000000
    +#define DDRSS_PHY_449_DATA 0x00000000
    +#define DDRSS_PHY_450_DATA 0x00000000
    +#define DDRSS_PHY_451_DATA 0x00000000
    +#define DDRSS_PHY_452_DATA 0x00000000
    +#define DDRSS_PHY_453_DATA 0x00000000
    +#define DDRSS_PHY_454_DATA 0x00000000
    +#define DDRSS_PHY_455_DATA 0x00000000
    +#define DDRSS_PHY_456_DATA 0x00000000
    +#define DDRSS_PHY_457_DATA 0x00000000
    +#define DDRSS_PHY_458_DATA 0x00000000
    +#define DDRSS_PHY_459_DATA 0x00000000
    +#define DDRSS_PHY_460_DATA 0x00000000
    +#define DDRSS_PHY_461_DATA 0x00000000
    +#define DDRSS_PHY_462_DATA 0x00000000
    +#define DDRSS_PHY_463_DATA 0x00000000
    +#define DDRSS_PHY_464_DATA 0x00000000
    +#define DDRSS_PHY_465_DATA 0x00000000
    +#define DDRSS_PHY_466_DATA 0x00000000
    +#define DDRSS_PHY_467_DATA 0x00000000
    +#define DDRSS_PHY_468_DATA 0x00000000
    +#define DDRSS_PHY_469_DATA 0x00000000
    +#define DDRSS_PHY_470_DATA 0x00000000
    +#define DDRSS_PHY_471_DATA 0x00000000
    +#define DDRSS_PHY_472_DATA 0x00000000
    +#define DDRSS_PHY_473_DATA 0x00000000
    +#define DDRSS_PHY_474_DATA 0x00000000
    +#define DDRSS_PHY_475_DATA 0x00000000
    +#define DDRSS_PHY_476_DATA 0x00000000
    +#define DDRSS_PHY_477_DATA 0x00000000
    +#define DDRSS_PHY_478_DATA 0x00000000
    +#define DDRSS_PHY_479_DATA 0x00000000
    +#define DDRSS_PHY_480_DATA 0x00000000
    +#define DDRSS_PHY_481_DATA 0x00000000
    +#define DDRSS_PHY_482_DATA 0x00000000
    +#define DDRSS_PHY_483_DATA 0x00000000
    +#define DDRSS_PHY_484_DATA 0x00000000
    +#define DDRSS_PHY_485_DATA 0x00000000
    +#define DDRSS_PHY_486_DATA 0x00000000
    +#define DDRSS_PHY_487_DATA 0x00000000
    +#define DDRSS_PHY_488_DATA 0x00000000
    +#define DDRSS_PHY_489_DATA 0x00000000
    +#define DDRSS_PHY_490_DATA 0x00000000
    +#define DDRSS_PHY_491_DATA 0x00000000
    +#define DDRSS_PHY_492_DATA 0x00000000
    +#define DDRSS_PHY_493_DATA 0x00000000
    +#define DDRSS_PHY_494_DATA 0x00000000
    +#define DDRSS_PHY_495_DATA 0x00000000
    +#define DDRSS_PHY_496_DATA 0x00000000
    +#define DDRSS_PHY_497_DATA 0x00000000
    +#define DDRSS_PHY_498_DATA 0x00000000
    +#define DDRSS_PHY_499_DATA 0x00000000
    +#define DDRSS_PHY_500_DATA 0x00000000
    +#define DDRSS_PHY_501_DATA 0x00000000
    +#define DDRSS_PHY_502_DATA 0x00000000
    +#define DDRSS_PHY_503_DATA 0x00000000
    +#define DDRSS_PHY_504_DATA 0x00000000
    +#define DDRSS_PHY_505_DATA 0x00000000
    +#define DDRSS_PHY_506_DATA 0x00000000
    +#define DDRSS_PHY_507_DATA 0x00000000
    +#define DDRSS_PHY_508_DATA 0x00000000
    +#define DDRSS_PHY_509_DATA 0x00000000
    +#define DDRSS_PHY_510_DATA 0x00000000
    +#define DDRSS_PHY_511_DATA 0x00000000
    +#define DDRSS_PHY_512_DATA 0x00000000
    +#define DDRSS_PHY_513_DATA 0x00000000
    +#define DDRSS_PHY_514_DATA 0x00000000
    +#define DDRSS_PHY_515_DATA 0x00000000
    +#define DDRSS_PHY_516_DATA 0x00000000
    +#define DDRSS_PHY_517_DATA 0x00000100
    +#define DDRSS_PHY_518_DATA 0x00000200
    +#define DDRSS_PHY_519_DATA 0x00000000
    +#define DDRSS_PHY_520_DATA 0x00000000
    +#define DDRSS_PHY_521_DATA 0x00000000
    +#define DDRSS_PHY_522_DATA 0x00000000
    +#define DDRSS_PHY_523_DATA 0x00400000
    +#define DDRSS_PHY_524_DATA 0x00000080
    +#define DDRSS_PHY_525_DATA 0x00DCBA98
    +#define DDRSS_PHY_526_DATA 0x03000000
    +#define DDRSS_PHY_527_DATA 0x00200000
    +#define DDRSS_PHY_528_DATA 0x00000000
    +#define DDRSS_PHY_529_DATA 0x00000000
    +#define DDRSS_PHY_530_DATA 0x00000000
    +#define DDRSS_PHY_531_DATA 0x00000000
    +#define DDRSS_PHY_532_DATA 0x0000002A
    +#define DDRSS_PHY_533_DATA 0x00000015
    +#define DDRSS_PHY_534_DATA 0x00000015
    +#define DDRSS_PHY_535_DATA 0x0000002A
    +#define DDRSS_PHY_536_DATA 0x00000033
    +#define DDRSS_PHY_537_DATA 0x0000000C
    +#define DDRSS_PHY_538_DATA 0x0000000C
    +#define DDRSS_PHY_539_DATA 0x00000033
    +#define DDRSS_PHY_540_DATA 0x0A418820
    +#define DDRSS_PHY_541_DATA 0x003F0000
    +#define DDRSS_PHY_542_DATA 0x000F013F
    +#define DDRSS_PHY_543_DATA 0x0000000F
    +#define DDRSS_PHY_544_DATA 0x020002CC
    +#define DDRSS_PHY_545_DATA 0x00030000
    +#define DDRSS_PHY_546_DATA 0x00000300
    +#define DDRSS_PHY_547_DATA 0x00000300
    +#define DDRSS_PHY_548_DATA 0x00000300
    +#define DDRSS_PHY_549_DATA 0x00000300
    +#define DDRSS_PHY_550_DATA 0x00000300
    +#define DDRSS_PHY_551_DATA 0x42080010
    +#define DDRSS_PHY_552_DATA 0x0000803E
    +#define DDRSS_PHY_553_DATA 0x00000003
    +#define DDRSS_PHY_554_DATA 0x00000002
    +#define DDRSS_PHY_555_DATA 0x00000000
    +#define DDRSS_PHY_556_DATA 0x00000000
    +#define DDRSS_PHY_557_DATA 0x00000000
    +#define DDRSS_PHY_558_DATA 0x00000000
    +#define DDRSS_PHY_559_DATA 0x00000000
    +#define DDRSS_PHY_560_DATA 0x00000000
    +#define DDRSS_PHY_561_DATA 0x00000000
    +#define DDRSS_PHY_562_DATA 0x00000000
    +#define DDRSS_PHY_563_DATA 0x00000000
    +#define DDRSS_PHY_564_DATA 0x00000000
    +#define DDRSS_PHY_565_DATA 0x00000000
    +#define DDRSS_PHY_566_DATA 0x00000000
    +#define DDRSS_PHY_567_DATA 0x00000000
    +#define DDRSS_PHY_568_DATA 0x00000000
    +#define DDRSS_PHY_569_DATA 0x00000000
    +#define DDRSS_PHY_570_DATA 0x00000000
    +#define DDRSS_PHY_571_DATA 0x00000000
    +#define DDRSS_PHY_572_DATA 0x00000000
    +#define DDRSS_PHY_573_DATA 0x00000000
    +#define DDRSS_PHY_574_DATA 0x00000000
    +#define DDRSS_PHY_575_DATA 0x00000000
    +#define DDRSS_PHY_576_DATA 0x00000000
    +#define DDRSS_PHY_577_DATA 0x00000000
    +#define DDRSS_PHY_578_DATA 0x00000000
    +#define DDRSS_PHY_579_DATA 0x00000000
    +#define DDRSS_PHY_580_DATA 0x00000000
    +#define DDRSS_PHY_581_DATA 0x00000000
    +#define DDRSS_PHY_582_DATA 0x00000000
    +#define DDRSS_PHY_583_DATA 0x00000000
    +#define DDRSS_PHY_584_DATA 0x00000000
    +#define DDRSS_PHY_585_DATA 0x00000000
    +#define DDRSS_PHY_586_DATA 0x00000000
    +#define DDRSS_PHY_587_DATA 0x00000000
    +#define DDRSS_PHY_588_DATA 0x00000000
    +#define DDRSS_PHY_589_DATA 0x00000000
    +#define DDRSS_PHY_590_DATA 0x00000000
    +#define DDRSS_PHY_591_DATA 0x00000000
    +#define DDRSS_PHY_592_DATA 0x00000000
    +#define DDRSS_PHY_593_DATA 0x00000000
    +#define DDRSS_PHY_594_DATA 0x00000000
    +#define DDRSS_PHY_595_DATA 0x00000000
    +#define DDRSS_PHY_596_DATA 0x00000000
    +#define DDRSS_PHY_597_DATA 0x00000000
    +#define DDRSS_PHY_598_DATA 0x00000000
    +#define DDRSS_PHY_599_DATA 0x00000000
    +#define DDRSS_PHY_600_DATA 0x00000000
    +#define DDRSS_PHY_601_DATA 0x00000000
    +#define DDRSS_PHY_602_DATA 0x00000000
    +#define DDRSS_PHY_603_DATA 0x00000000
    +#define DDRSS_PHY_604_DATA 0x00000000
    +#define DDRSS_PHY_605_DATA 0x00000000
    +#define DDRSS_PHY_606_DATA 0x00000000
    +#define DDRSS_PHY_607_DATA 0x00000000
    +#define DDRSS_PHY_608_DATA 0x00000000
    +#define DDRSS_PHY_609_DATA 0x00000000
    +#define DDRSS_PHY_610_DATA 0x00000000
    +#define DDRSS_PHY_611_DATA 0x00000000
    +#define DDRSS_PHY_612_DATA 0x00000000
    +#define DDRSS_PHY_613_DATA 0x00000000
    +#define DDRSS_PHY_614_DATA 0x00000000
    +#define DDRSS_PHY_615_DATA 0x00000000
    +#define DDRSS_PHY_616_DATA 0x00000000
    +#define DDRSS_PHY_617_DATA 0x00000000
    +#define DDRSS_PHY_618_DATA 0x00000000
    +#define DDRSS_PHY_619_DATA 0x00000000
    +#define DDRSS_PHY_620_DATA 0x00000000
    +#define DDRSS_PHY_621_DATA 0x00000000
    +#define DDRSS_PHY_622_DATA 0x00000000
    +#define DDRSS_PHY_623_DATA 0x00000000
    +#define DDRSS_PHY_624_DATA 0x00000000
    +#define DDRSS_PHY_625_DATA 0x00000000
    +#define DDRSS_PHY_626_DATA 0x00000000
    +#define DDRSS_PHY_627_DATA 0x00000000
    +#define DDRSS_PHY_628_DATA 0x00000000
    +#define DDRSS_PHY_629_DATA 0x00000000
    +#define DDRSS_PHY_630_DATA 0x00000000
    +#define DDRSS_PHY_631_DATA 0x00000000
    +#define DDRSS_PHY_632_DATA 0x00000000
    +#define DDRSS_PHY_633_DATA 0x00000000
    +#define DDRSS_PHY_634_DATA 0x00000000
    +#define DDRSS_PHY_635_DATA 0x00000000
    +#define DDRSS_PHY_636_DATA 0x00000000
    +#define DDRSS_PHY_637_DATA 0x00000000
    +#define DDRSS_PHY_638_DATA 0x00000000
    +#define DDRSS_PHY_639_DATA 0x00000000
    +#define DDRSS_PHY_640_DATA 0x00000000
    +#define DDRSS_PHY_641_DATA 0x00000000
    +#define DDRSS_PHY_642_DATA 0x00000000
    +#define DDRSS_PHY_643_DATA 0x00000000
    +#define DDRSS_PHY_644_DATA 0x00000000
    +#define DDRSS_PHY_645_DATA 0x00000000
    +#define DDRSS_PHY_646_DATA 0x00000000
    +#define DDRSS_PHY_647_DATA 0x00000000
    +#define DDRSS_PHY_648_DATA 0x00000000
    +#define DDRSS_PHY_649_DATA 0x00000000
    +#define DDRSS_PHY_650_DATA 0x00000000
    +#define DDRSS_PHY_651_DATA 0x00000000
    +#define DDRSS_PHY_652_DATA 0x00000000
    +#define DDRSS_PHY_653_DATA 0x00000000
    +#define DDRSS_PHY_654_DATA 0x00000000
    +#define DDRSS_PHY_655_DATA 0x00000000
    +#define DDRSS_PHY_656_DATA 0x00000000
    +#define DDRSS_PHY_657_DATA 0x00000000
    +#define DDRSS_PHY_658_DATA 0x00000000
    +#define DDRSS_PHY_659_DATA 0x00000000
    +#define DDRSS_PHY_660_DATA 0x00000000
    +#define DDRSS_PHY_661_DATA 0x00000000
    +#define DDRSS_PHY_662_DATA 0x00000000
    +#define DDRSS_PHY_663_DATA 0x00000000
    +#define DDRSS_PHY_664_DATA 0x00000000
    +#define DDRSS_PHY_665_DATA 0x00000000
    +#define DDRSS_PHY_666_DATA 0x00000000
    +#define DDRSS_PHY_667_DATA 0x00000000
    +#define DDRSS_PHY_668_DATA 0x00000000
    +#define DDRSS_PHY_669_DATA 0x00000000
    +#define DDRSS_PHY_670_DATA 0x00000000
    +#define DDRSS_PHY_671_DATA 0x00000000
    +#define DDRSS_PHY_672_DATA 0x00000000
    +#define DDRSS_PHY_673_DATA 0x00000000
    +#define DDRSS_PHY_674_DATA 0x00000000
    +#define DDRSS_PHY_675_DATA 0x00000000
    +#define DDRSS_PHY_676_DATA 0x00000000
    +#define DDRSS_PHY_677_DATA 0x00000000
    +#define DDRSS_PHY_678_DATA 0x00000000
    +#define DDRSS_PHY_679_DATA 0x00000000
    +#define DDRSS_PHY_680_DATA 0x00000000
    +#define DDRSS_PHY_681_DATA 0x00000000
    +#define DDRSS_PHY_682_DATA 0x00000000
    +#define DDRSS_PHY_683_DATA 0x00000000
    +#define DDRSS_PHY_684_DATA 0x00000000
    +#define DDRSS_PHY_685_DATA 0x00000000
    +#define DDRSS_PHY_686_DATA 0x00000000
    +#define DDRSS_PHY_687_DATA 0x00000000
    +#define DDRSS_PHY_688_DATA 0x00000000
    +#define DDRSS_PHY_689_DATA 0x00000000
    +#define DDRSS_PHY_690_DATA 0x00000000
    +#define DDRSS_PHY_691_DATA 0x00000000
    +#define DDRSS_PHY_692_DATA 0x00000000
    +#define DDRSS_PHY_693_DATA 0x00000000
    +#define DDRSS_PHY_694_DATA 0x00000000
    +#define DDRSS_PHY_695_DATA 0x00000000
    +#define DDRSS_PHY_696_DATA 0x00000000
    +#define DDRSS_PHY_697_DATA 0x00000000
    +#define DDRSS_PHY_698_DATA 0x00000000
    +#define DDRSS_PHY_699_DATA 0x00000000
    +#define DDRSS_PHY_700_DATA 0x00000000
    +#define DDRSS_PHY_701_DATA 0x00000000
    +#define DDRSS_PHY_702_DATA 0x00000000
    +#define DDRSS_PHY_703_DATA 0x00000000
    +#define DDRSS_PHY_704_DATA 0x00000000
    +#define DDRSS_PHY_705_DATA 0x00000000
    +#define DDRSS_PHY_706_DATA 0x00000000
    +#define DDRSS_PHY_707_DATA 0x00000000
    +#define DDRSS_PHY_708_DATA 0x00000000
    +#define DDRSS_PHY_709_DATA 0x00000000
    +#define DDRSS_PHY_710_DATA 0x00000000
    +#define DDRSS_PHY_711_DATA 0x00000000
    +#define DDRSS_PHY_712_DATA 0x00000000
    +#define DDRSS_PHY_713_DATA 0x00000000
    +#define DDRSS_PHY_714_DATA 0x00000000
    +#define DDRSS_PHY_715_DATA 0x00000000
    +#define DDRSS_PHY_716_DATA 0x00000000
    +#define DDRSS_PHY_717_DATA 0x00000000
    +#define DDRSS_PHY_718_DATA 0x00000000
    +#define DDRSS_PHY_719_DATA 0x00000000
    +#define DDRSS_PHY_720_DATA 0x00000000
    +#define DDRSS_PHY_721_DATA 0x00000000
    +#define DDRSS_PHY_722_DATA 0x00000000
    +#define DDRSS_PHY_723_DATA 0x00000000
    +#define DDRSS_PHY_724_DATA 0x00000000
    +#define DDRSS_PHY_725_DATA 0x00000000
    +#define DDRSS_PHY_726_DATA 0x00000000
    +#define DDRSS_PHY_727_DATA 0x00000000
    +#define DDRSS_PHY_728_DATA 0x00000000
    +#define DDRSS_PHY_729_DATA 0x00000000
    +#define DDRSS_PHY_730_DATA 0x00000000
    +#define DDRSS_PHY_731_DATA 0x00000000
    +#define DDRSS_PHY_732_DATA 0x00000000
    +#define DDRSS_PHY_733_DATA 0x00000000
    +#define DDRSS_PHY_734_DATA 0x00000000
    +#define DDRSS_PHY_735_DATA 0x00000000
    +#define DDRSS_PHY_736_DATA 0x00000000
    +#define DDRSS_PHY_737_DATA 0x00000000
    +#define DDRSS_PHY_738_DATA 0x00000000
    +#define DDRSS_PHY_739_DATA 0x00000000
    +#define DDRSS_PHY_740_DATA 0x00000000
    +#define DDRSS_PHY_741_DATA 0x00000000
    +#define DDRSS_PHY_742_DATA 0x00000000
    +#define DDRSS_PHY_743_DATA 0x00000000
    +#define DDRSS_PHY_744_DATA 0x00000000
    +#define DDRSS_PHY_745_DATA 0x00000000
    +#define DDRSS_PHY_746_DATA 0x00000000
    +#define DDRSS_PHY_747_DATA 0x00000000
    +#define DDRSS_PHY_748_DATA 0x00000000
    +#define DDRSS_PHY_749_DATA 0x00000000
    +#define DDRSS_PHY_750_DATA 0x00000000
    +#define DDRSS_PHY_751_DATA 0x00000000
    +#define DDRSS_PHY_752_DATA 0x00000000
    +#define DDRSS_PHY_753_DATA 0x00000000
    +#define DDRSS_PHY_754_DATA 0x00000000
    +#define DDRSS_PHY_755_DATA 0x00000000
    +#define DDRSS_PHY_756_DATA 0x00000000
    +#define DDRSS_PHY_757_DATA 0x00000000
    +#define DDRSS_PHY_758_DATA 0x00000000
    +#define DDRSS_PHY_759_DATA 0x00000000
    +#define DDRSS_PHY_760_DATA 0x00000000
    +#define DDRSS_PHY_761_DATA 0x00000000
    +#define DDRSS_PHY_762_DATA 0x00000000
    +#define DDRSS_PHY_763_DATA 0x00000000
    +#define DDRSS_PHY_764_DATA 0x00000000
    +#define DDRSS_PHY_765_DATA 0x00000000
    +#define DDRSS_PHY_766_DATA 0x00000000
    +#define DDRSS_PHY_767_DATA 0x00000000
    +#define DDRSS_PHY_768_DATA 0x00000000
    +#define DDRSS_PHY_769_DATA 0x00000000
    +#define DDRSS_PHY_770_DATA 0x00000000
    +#define DDRSS_PHY_771_DATA 0x00000000
    +#define DDRSS_PHY_772_DATA 0x00000000
    +#define DDRSS_PHY_773_DATA 0x00000100
    +#define DDRSS_PHY_774_DATA 0x00000200
    +#define DDRSS_PHY_775_DATA 0x00000000
    +#define DDRSS_PHY_776_DATA 0x00000000
    +#define DDRSS_PHY_777_DATA 0x00000000
    +#define DDRSS_PHY_778_DATA 0x00000000
    +#define DDRSS_PHY_779_DATA 0x00400000
    +#define DDRSS_PHY_780_DATA 0x00000080
    +#define DDRSS_PHY_781_DATA 0x00DCBA98
    +#define DDRSS_PHY_782_DATA 0x03000000
    +#define DDRSS_PHY_783_DATA 0x00200000
    +#define DDRSS_PHY_784_DATA 0x00000000
    +#define DDRSS_PHY_785_DATA 0x00000000
    +#define DDRSS_PHY_786_DATA 0x00000000
    +#define DDRSS_PHY_787_DATA 0x00000000
    +#define DDRSS_PHY_788_DATA 0x0000002A
    +#define DDRSS_PHY_789_DATA 0x00000015
    +#define DDRSS_PHY_790_DATA 0x00000015
    +#define DDRSS_PHY_791_DATA 0x0000002A
    +#define DDRSS_PHY_792_DATA 0x00000033
    +#define DDRSS_PHY_793_DATA 0x0000000C
    +#define DDRSS_PHY_794_DATA 0x0000000C
    +#define DDRSS_PHY_795_DATA 0x00000033
    +#define DDRSS_PHY_796_DATA 0x00000000
    +#define DDRSS_PHY_797_DATA 0x00000000
    +#define DDRSS_PHY_798_DATA 0x000F0000
    +#define DDRSS_PHY_799_DATA 0x0000000F
    +#define DDRSS_PHY_800_DATA 0x020002CC
    +#define DDRSS_PHY_801_DATA 0x00030000
    +#define DDRSS_PHY_802_DATA 0x00000300
    +#define DDRSS_PHY_803_DATA 0x00000300
    +#define DDRSS_PHY_804_DATA 0x00000300
    +#define DDRSS_PHY_805_DATA 0x00000300
    +#define DDRSS_PHY_806_DATA 0x00000300
    +#define DDRSS_PHY_807_DATA 0x42080010
    +#define DDRSS_PHY_808_DATA 0x0000803E
    +#define DDRSS_PHY_809_DATA 0x00000003
    +#define DDRSS_PHY_810_DATA 0x00000002
    +#define DDRSS_PHY_811_DATA 0x00000000
    +#define DDRSS_PHY_812_DATA 0x00000000
    +#define DDRSS_PHY_813_DATA 0x00000000
    +#define DDRSS_PHY_814_DATA 0x00000000
    +#define DDRSS_PHY_815_DATA 0x00000000
    +#define DDRSS_PHY_816_DATA 0x00000000
    +#define DDRSS_PHY_817_DATA 0x00000000
    +#define DDRSS_PHY_818_DATA 0x00000000
    +#define DDRSS_PHY_819_DATA 0x00000000
    +#define DDRSS_PHY_820_DATA 0x00000000
    +#define DDRSS_PHY_821_DATA 0x00000000
    +#define DDRSS_PHY_822_DATA 0x00000000
    +#define DDRSS_PHY_823_DATA 0x00000000
    +#define DDRSS_PHY_824_DATA 0x00000000
    +#define DDRSS_PHY_825_DATA 0x00000000
    +#define DDRSS_PHY_826_DATA 0x00000000
    +#define DDRSS_PHY_827_DATA 0x00000000
    +#define DDRSS_PHY_828_DATA 0x00000000
    +#define DDRSS_PHY_829_DATA 0x00000000
    +#define DDRSS_PHY_830_DATA 0x00000000
    +#define DDRSS_PHY_831_DATA 0x00000000
    +#define DDRSS_PHY_832_DATA 0x00000000
    +#define DDRSS_PHY_833_DATA 0x00000000
    +#define DDRSS_PHY_834_DATA 0x00000000
    +#define DDRSS_PHY_835_DATA 0x00000000
    +#define DDRSS_PHY_836_DATA 0x00000000
    +#define DDRSS_PHY_837_DATA 0x00000000
    +#define DDRSS_PHY_838_DATA 0x00000000
    +#define DDRSS_PHY_839_DATA 0x00000000
    +#define DDRSS_PHY_840_DATA 0x00000000
    +#define DDRSS_PHY_841_DATA 0x00000000
    +#define DDRSS_PHY_842_DATA 0x00000000
    +#define DDRSS_PHY_843_DATA 0x00000000
    +#define DDRSS_PHY_844_DATA 0x00000000
    +#define DDRSS_PHY_845_DATA 0x00000000
    +#define DDRSS_PHY_846_DATA 0x00000000
    +#define DDRSS_PHY_847_DATA 0x00000000
    +#define DDRSS_PHY_848_DATA 0x00000000
    +#define DDRSS_PHY_849_DATA 0x00000000
    +#define DDRSS_PHY_850_DATA 0x00000000
    +#define DDRSS_PHY_851_DATA 0x00000000
    +#define DDRSS_PHY_852_DATA 0x00000000
    +#define DDRSS_PHY_853_DATA 0x00000000
    +#define DDRSS_PHY_854_DATA 0x00000000
    +#define DDRSS_PHY_855_DATA 0x00000000
    +#define DDRSS_PHY_856_DATA 0x00000000
    +#define DDRSS_PHY_857_DATA 0x00000000
    +#define DDRSS_PHY_858_DATA 0x00000000
    +#define DDRSS_PHY_859_DATA 0x00000000
    +#define DDRSS_PHY_860_DATA 0x00000000
    +#define DDRSS_PHY_861_DATA 0x00000000
    +#define DDRSS_PHY_862_DATA 0x00000000
    +#define DDRSS_PHY_863_DATA 0x00000000
    +#define DDRSS_PHY_864_DATA 0x00000000
    +#define DDRSS_PHY_865_DATA 0x00000000
    +#define DDRSS_PHY_866_DATA 0x00000000
    +#define DDRSS_PHY_867_DATA 0x00000000
    +#define DDRSS_PHY_868_DATA 0x00000000
    +#define DDRSS_PHY_869_DATA 0x00000000
    +#define DDRSS_PHY_870_DATA 0x00000000
    +#define DDRSS_PHY_871_DATA 0x00000000
    +#define DDRSS_PHY_872_DATA 0x00000000
    +#define DDRSS_PHY_873_DATA 0x00000000
    +#define DDRSS_PHY_874_DATA 0x00000000
    +#define DDRSS_PHY_875_DATA 0x00000000
    +#define DDRSS_PHY_876_DATA 0x00000000
    +#define DDRSS_PHY_877_DATA 0x00000000
    +#define DDRSS_PHY_878_DATA 0x00000000
    +#define DDRSS_PHY_879_DATA 0x00000000
    +#define DDRSS_PHY_880_DATA 0x00000000
    +#define DDRSS_PHY_881_DATA 0x00000000
    +#define DDRSS_PHY_882_DATA 0x00000000
    +#define DDRSS_PHY_883_DATA 0x00000000
    +#define DDRSS_PHY_884_DATA 0x00000000
    +#define DDRSS_PHY_885_DATA 0x00000000
    +#define DDRSS_PHY_886_DATA 0x00000000
    +#define DDRSS_PHY_887_DATA 0x00000000
    +#define DDRSS_PHY_888_DATA 0x00000000
    +#define DDRSS_PHY_889_DATA 0x00000000
    +#define DDRSS_PHY_890_DATA 0x00000000
    +#define DDRSS_PHY_891_DATA 0x00000000
    +#define DDRSS_PHY_892_DATA 0x00000000
    +#define DDRSS_PHY_893_DATA 0x00000000
    +#define DDRSS_PHY_894_DATA 0x00000000
    +#define DDRSS_PHY_895_DATA 0x00000000
    +#define DDRSS_PHY_896_DATA 0x00000000
    +#define DDRSS_PHY_897_DATA 0x00000000
    +#define DDRSS_PHY_898_DATA 0x00000000
    +#define DDRSS_PHY_899_DATA 0x00000000
    +#define DDRSS_PHY_900_DATA 0x00000000
    +#define DDRSS_PHY_901_DATA 0x00000000
    +#define DDRSS_PHY_902_DATA 0x00000000
    +#define DDRSS_PHY_903_DATA 0x00000000
    +#define DDRSS_PHY_904_DATA 0x00000000
    +#define DDRSS_PHY_905_DATA 0x00000000
    +#define DDRSS_PHY_906_DATA 0x00000000
    +#define DDRSS_PHY_907_DATA 0x00000000
    +#define DDRSS_PHY_908_DATA 0x00000000
    +#define DDRSS_PHY_909_DATA 0x00000000
    +#define DDRSS_PHY_910_DATA 0x00000000
    +#define DDRSS_PHY_911_DATA 0x00000000
    +#define DDRSS_PHY_912_DATA 0x00000000
    +#define DDRSS_PHY_913_DATA 0x00000000
    +#define DDRSS_PHY_914_DATA 0x00000000
    +#define DDRSS_PHY_915_DATA 0x00000000
    +#define DDRSS_PHY_916_DATA 0x00000000
    +#define DDRSS_PHY_917_DATA 0x00000000
    +#define DDRSS_PHY_918_DATA 0x00000000
    +#define DDRSS_PHY_919_DATA 0x00000000
    +#define DDRSS_PHY_920_DATA 0x00000000
    +#define DDRSS_PHY_921_DATA 0x00000000
    +#define DDRSS_PHY_922_DATA 0x00000000
    +#define DDRSS_PHY_923_DATA 0x00000000
    +#define DDRSS_PHY_924_DATA 0x00000000
    +#define DDRSS_PHY_925_DATA 0x00000000
    +#define DDRSS_PHY_926_DATA 0x00000000
    +#define DDRSS_PHY_927_DATA 0x00000000
    +#define DDRSS_PHY_928_DATA 0x00000000
    +#define DDRSS_PHY_929_DATA 0x00000000
    +#define DDRSS_PHY_930_DATA 0x00000000
    +#define DDRSS_PHY_931_DATA 0x00000000
    +#define DDRSS_PHY_932_DATA 0x00000000
    +#define DDRSS_PHY_933_DATA 0x00000000
    +#define DDRSS_PHY_934_DATA 0x00000000
    +#define DDRSS_PHY_935_DATA 0x00000000
    +#define DDRSS_PHY_936_DATA 0x00000000
    +#define DDRSS_PHY_937_DATA 0x00000000
    +#define DDRSS_PHY_938_DATA 0x00000000
    +#define DDRSS_PHY_939_DATA 0x00000000
    +#define DDRSS_PHY_940_DATA 0x00000000
    +#define DDRSS_PHY_941_DATA 0x00000000
    +#define DDRSS_PHY_942_DATA 0x00000000
    +#define DDRSS_PHY_943_DATA 0x00000000
    +#define DDRSS_PHY_944_DATA 0x00000000
    +#define DDRSS_PHY_945_DATA 0x00000000
    +#define DDRSS_PHY_946_DATA 0x00000000
    +#define DDRSS_PHY_947_DATA 0x00000000
    +#define DDRSS_PHY_948_DATA 0x00000000
    +#define DDRSS_PHY_949_DATA 0x00000000
    +#define DDRSS_PHY_950_DATA 0x00000000
    +#define DDRSS_PHY_951_DATA 0x00000000
    +#define DDRSS_PHY_952_DATA 0x00000000
    +#define DDRSS_PHY_953_DATA 0x00000000
    +#define DDRSS_PHY_954_DATA 0x00000000
    +#define DDRSS_PHY_955_DATA 0x00000000
    +#define DDRSS_PHY_956_DATA 0x00000000
    +#define DDRSS_PHY_957_DATA 0x00000000
    +#define DDRSS_PHY_958_DATA 0x00000000
    +#define DDRSS_PHY_959_DATA 0x00000000
    +#define DDRSS_PHY_960_DATA 0x00000000
    +#define DDRSS_PHY_961_DATA 0x00000000
    +#define DDRSS_PHY_962_DATA 0x00000000
    +#define DDRSS_PHY_963_DATA 0x00000000
    +#define DDRSS_PHY_964_DATA 0x00000000
    +#define DDRSS_PHY_965_DATA 0x00000000
    +#define DDRSS_PHY_966_DATA 0x00000000
    +#define DDRSS_PHY_967_DATA 0x00000000
    +#define DDRSS_PHY_968_DATA 0x00000000
    +#define DDRSS_PHY_969_DATA 0x00000000
    +#define DDRSS_PHY_970_DATA 0x00000000
    +#define DDRSS_PHY_971_DATA 0x00000000
    +#define DDRSS_PHY_972_DATA 0x00000000
    +#define DDRSS_PHY_973_DATA 0x00000000
    +#define DDRSS_PHY_974_DATA 0x00000000
    +#define DDRSS_PHY_975_DATA 0x00000000
    +#define DDRSS_PHY_976_DATA 0x00000000
    +#define DDRSS_PHY_977_DATA 0x00000000
    +#define DDRSS_PHY_978_DATA 0x00000000
    +#define DDRSS_PHY_979_DATA 0x00000000
    +#define DDRSS_PHY_980_DATA 0x00000000
    +#define DDRSS_PHY_981_DATA 0x00000000
    +#define DDRSS_PHY_982_DATA 0x00000000
    +#define DDRSS_PHY_983_DATA 0x00000000
    +#define DDRSS_PHY_984_DATA 0x00000000
    +#define DDRSS_PHY_985_DATA 0x00000000
    +#define DDRSS_PHY_986_DATA 0x00000000
    +#define DDRSS_PHY_987_DATA 0x00000000
    +#define DDRSS_PHY_988_DATA 0x00000000
    +#define DDRSS_PHY_989_DATA 0x00000000
    +#define DDRSS_PHY_990_DATA 0x00000000
    +#define DDRSS_PHY_991_DATA 0x00000000
    +#define DDRSS_PHY_992_DATA 0x00000000
    +#define DDRSS_PHY_993_DATA 0x00000000
    +#define DDRSS_PHY_994_DATA 0x00000000
    +#define DDRSS_PHY_995_DATA 0x00000000
    +#define DDRSS_PHY_996_DATA 0x00000000
    +#define DDRSS_PHY_997_DATA 0x00000000
    +#define DDRSS_PHY_998_DATA 0x00000000
    +#define DDRSS_PHY_999_DATA 0x00000000
    +#define DDRSS_PHY_1000_DATA 0x00000000
    +#define DDRSS_PHY_1001_DATA 0x00000000
    +#define DDRSS_PHY_1002_DATA 0x00000000
    +#define DDRSS_PHY_1003_DATA 0x00000000
    +#define DDRSS_PHY_1004_DATA 0x00000000
    +#define DDRSS_PHY_1005_DATA 0x00000000
    +#define DDRSS_PHY_1006_DATA 0x00000000
    +#define DDRSS_PHY_1007_DATA 0x00000000
    +#define DDRSS_PHY_1008_DATA 0x00000000
    +#define DDRSS_PHY_1009_DATA 0x00000000
    +#define DDRSS_PHY_1010_DATA 0x00000000
    +#define DDRSS_PHY_1011_DATA 0x00000000
    +#define DDRSS_PHY_1012_DATA 0x00000000
    +#define DDRSS_PHY_1013_DATA 0x00000000
    +#define DDRSS_PHY_1014_DATA 0x00000000
    +#define DDRSS_PHY_1015_DATA 0x00000000
    +#define DDRSS_PHY_1016_DATA 0x00000000
    +#define DDRSS_PHY_1017_DATA 0x00000000
    +#define DDRSS_PHY_1018_DATA 0x00000000
    +#define DDRSS_PHY_1019_DATA 0x00000000
    +#define DDRSS_PHY_1020_DATA 0x00000000
    +#define DDRSS_PHY_1021_DATA 0x00000000
    +#define DDRSS_PHY_1022_DATA 0x00000000
    +#define DDRSS_PHY_1023_DATA 0x00000000
    +#define DDRSS_PHY_1024_DATA 0x00000000
    +#define DDRSS_PHY_1025_DATA 0x00000000
    +#define DDRSS_PHY_1026_DATA 0x00000000
    +#define DDRSS_PHY_1027_DATA 0x00000000
    +#define DDRSS_PHY_1028_DATA 0x00000000
    +#define DDRSS_PHY_1029_DATA 0x00000100
    +#define DDRSS_PHY_1030_DATA 0x00000200
    +#define DDRSS_PHY_1031_DATA 0x00000000
    +#define DDRSS_PHY_1032_DATA 0x00000000
    +#define DDRSS_PHY_1033_DATA 0x00000000
    +#define DDRSS_PHY_1034_DATA 0x00000000
    +#define DDRSS_PHY_1035_DATA 0x00400000
    +#define DDRSS_PHY_1036_DATA 0x00000080
    +#define DDRSS_PHY_1037_DATA 0x00DCBA98
    +#define DDRSS_PHY_1038_DATA 0x03000000
    +#define DDRSS_PHY_1039_DATA 0x00200000
    +#define DDRSS_PHY_1040_DATA 0x00000000
    +#define DDRSS_PHY_1041_DATA 0x00000000
    +#define DDRSS_PHY_1042_DATA 0x00000000
    +#define DDRSS_PHY_1043_DATA 0x00000000
    +#define DDRSS_PHY_1044_DATA 0x0000002A
    +#define DDRSS_PHY_1045_DATA 0x00000015
    +#define DDRSS_PHY_1046_DATA 0x00000015
    +#define DDRSS_PHY_1047_DATA 0x0000002A
    +#define DDRSS_PHY_1048_DATA 0x00000033
    +#define DDRSS_PHY_1049_DATA 0x0000000C
    +#define DDRSS_PHY_1050_DATA 0x0000000C
    +#define DDRSS_PHY_1051_DATA 0x00000033
    +#define DDRSS_PHY_1052_DATA 0x2307B9AC
    +#define DDRSS_PHY_1053_DATA 0x10000000
    +#define DDRSS_PHY_1054_DATA 0x000F0000
    +#define DDRSS_PHY_1055_DATA 0x0000000F
    +#define DDRSS_PHY_1056_DATA 0x020002CC
    +#define DDRSS_PHY_1057_DATA 0x00030000
    +#define DDRSS_PHY_1058_DATA 0x00000300
    +#define DDRSS_PHY_1059_DATA 0x00000300
    +#define DDRSS_PHY_1060_DATA 0x00000300
    +#define DDRSS_PHY_1061_DATA 0x00000300
    +#define DDRSS_PHY_1062_DATA 0x00000300
    +#define DDRSS_PHY_1063_DATA 0x42080010
    +#define DDRSS_PHY_1064_DATA 0x0000803E
    +#define DDRSS_PHY_1065_DATA 0x00000003
    +#define DDRSS_PHY_1066_DATA 0x00000002
    +#define DDRSS_PHY_1067_DATA 0x00000000
    +#define DDRSS_PHY_1068_DATA 0x00000000
    +#define DDRSS_PHY_1069_DATA 0x00000000
    +#define DDRSS_PHY_1070_DATA 0x00000000
    +#define DDRSS_PHY_1071_DATA 0x00000000
    +#define DDRSS_PHY_1072_DATA 0x00000000
    +#define DDRSS_PHY_1073_DATA 0x00000000
    +#define DDRSS_PHY_1074_DATA 0x00000000
    +#define DDRSS_PHY_1075_DATA 0x00000000
    +#define DDRSS_PHY_1076_DATA 0x00000000
    +#define DDRSS_PHY_1077_DATA 0x00000000
    +#define DDRSS_PHY_1078_DATA 0x00000000
    +#define DDRSS_PHY_1079_DATA 0x00000000
    +#define DDRSS_PHY_1080_DATA 0x00000000
    +#define DDRSS_PHY_1081_DATA 0x00000000
    +#define DDRSS_PHY_1082_DATA 0x00000000
    +#define DDRSS_PHY_1083_DATA 0x00000000
    +#define DDRSS_PHY_1084_DATA 0x00000000
    +#define DDRSS_PHY_1085_DATA 0x00000000
    +#define DDRSS_PHY_1086_DATA 0x00000000
    +#define DDRSS_PHY_1087_DATA 0x00000000
    +#define DDRSS_PHY_1088_DATA 0x00000000
    +#define DDRSS_PHY_1089_DATA 0x00000000
    +#define DDRSS_PHY_1090_DATA 0x00000000
    +#define DDRSS_PHY_1091_DATA 0x00000000
    +#define DDRSS_PHY_1092_DATA 0x00000000
    +#define DDRSS_PHY_1093_DATA 0x00000000
    +#define DDRSS_PHY_1094_DATA 0x00000000
    +#define DDRSS_PHY_1095_DATA 0x00000000
    +#define DDRSS_PHY_1096_DATA 0x00000000
    +#define DDRSS_PHY_1097_DATA 0x00000000
    +#define DDRSS_PHY_1098_DATA 0x00000000
    +#define DDRSS_PHY_1099_DATA 0x00000000
    +#define DDRSS_PHY_1100_DATA 0x00000000
    +#define DDRSS_PHY_1101_DATA 0x00000000
    +#define DDRSS_PHY_1102_DATA 0x00000000
    +#define DDRSS_PHY_1103_DATA 0x00000000
    +#define DDRSS_PHY_1104_DATA 0x00000000
    +#define DDRSS_PHY_1105_DATA 0x00000000
    +#define DDRSS_PHY_1106_DATA 0x00000000
    +#define DDRSS_PHY_1107_DATA 0x00000000
    +#define DDRSS_PHY_1108_DATA 0x00000000
    +#define DDRSS_PHY_1109_DATA 0x00000000
    +#define DDRSS_PHY_1110_DATA 0x00000000
    +#define DDRSS_PHY_1111_DATA 0x00000000
    +#define DDRSS_PHY_1112_DATA 0x00000000
    +#define DDRSS_PHY_1113_DATA 0x00000000
    +#define DDRSS_PHY_1114_DATA 0x00000000
    +#define DDRSS_PHY_1115_DATA 0x00000000
    +#define DDRSS_PHY_1116_DATA 0x00000000
    +#define DDRSS_PHY_1117_DATA 0x00000000
    +#define DDRSS_PHY_1118_DATA 0x00000000
    +#define DDRSS_PHY_1119_DATA 0x00000000
    +#define DDRSS_PHY_1120_DATA 0x00000000
    +#define DDRSS_PHY_1121_DATA 0x00000000
    +#define DDRSS_PHY_1122_DATA 0x00000000
    +#define DDRSS_PHY_1123_DATA 0x00000000
    +#define DDRSS_PHY_1124_DATA 0x00000000
    +#define DDRSS_PHY_1125_DATA 0x00000000
    +#define DDRSS_PHY_1126_DATA 0x00000000
    +#define DDRSS_PHY_1127_DATA 0x00000000
    +#define DDRSS_PHY_1128_DATA 0x00000000
    +#define DDRSS_PHY_1129_DATA 0x00000000
    +#define DDRSS_PHY_1130_DATA 0x00000000
    +#define DDRSS_PHY_1131_DATA 0x00000000
    +#define DDRSS_PHY_1132_DATA 0x00000000
    +#define DDRSS_PHY_1133_DATA 0x00000000
    +#define DDRSS_PHY_1134_DATA 0x00000000
    +#define DDRSS_PHY_1135_DATA 0x00000000
    +#define DDRSS_PHY_1136_DATA 0x00000000
    +#define DDRSS_PHY_1137_DATA 0x00000000
    +#define DDRSS_PHY_1138_DATA 0x00000000
    +#define DDRSS_PHY_1139_DATA 0x00000000
    +#define DDRSS_PHY_1140_DATA 0x00000000
    +#define DDRSS_PHY_1141_DATA 0x00000000
    +#define DDRSS_PHY_1142_DATA 0x00000000
    +#define DDRSS_PHY_1143_DATA 0x00000000
    +#define DDRSS_PHY_1144_DATA 0x00000000
    +#define DDRSS_PHY_1145_DATA 0x00000000
    +#define DDRSS_PHY_1146_DATA 0x00000000
    +#define DDRSS_PHY_1147_DATA 0x00000000
    +#define DDRSS_PHY_1148_DATA 0x00000000
    +#define DDRSS_PHY_1149_DATA 0x00000000
    +#define DDRSS_PHY_1150_DATA 0x00000000
    +#define DDRSS_PHY_1151_DATA 0x00000000
    +#define DDRSS_PHY_1152_DATA 0x00000000
    +#define DDRSS_PHY_1153_DATA 0x00000000
    +#define DDRSS_PHY_1154_DATA 0x00000000
    +#define DDRSS_PHY_1155_DATA 0x00000000
    +#define DDRSS_PHY_1156_DATA 0x00000000
    +#define DDRSS_PHY_1157_DATA 0x00000000
    +#define DDRSS_PHY_1158_DATA 0x00000000
    +#define DDRSS_PHY_1159_DATA 0x00000000
    +#define DDRSS_PHY_1160_DATA 0x00000000
    +#define DDRSS_PHY_1161_DATA 0x00000000
    +#define DDRSS_PHY_1162_DATA 0x00000000
    +#define DDRSS_PHY_1163_DATA 0x00000000
    +#define DDRSS_PHY_1164_DATA 0x00000000
    +#define DDRSS_PHY_1165_DATA 0x00000000
    +#define DDRSS_PHY_1166_DATA 0x00000000
    +#define DDRSS_PHY_1167_DATA 0x00000000
    +#define DDRSS_PHY_1168_DATA 0x00000000
    +#define DDRSS_PHY_1169_DATA 0x00000000
    +#define DDRSS_PHY_1170_DATA 0x00000000
    +#define DDRSS_PHY_1171_DATA 0x00000000
    +#define DDRSS_PHY_1172_DATA 0x00000000
    +#define DDRSS_PHY_1173_DATA 0x00000000
    +#define DDRSS_PHY_1174_DATA 0x00000000
    +#define DDRSS_PHY_1175_DATA 0x00000000
    +#define DDRSS_PHY_1176_DATA 0x00000000
    +#define DDRSS_PHY_1177_DATA 0x00000000
    +#define DDRSS_PHY_1178_DATA 0x00000000
    +#define DDRSS_PHY_1179_DATA 0x00000000
    +#define DDRSS_PHY_1180_DATA 0x00000000
    +#define DDRSS_PHY_1181_DATA 0x00000000
    +#define DDRSS_PHY_1182_DATA 0x00000000
    +#define DDRSS_PHY_1183_DATA 0x00000000
    +#define DDRSS_PHY_1184_DATA 0x00000000
    +#define DDRSS_PHY_1185_DATA 0x00000000
    +#define DDRSS_PHY_1186_DATA 0x00000000
    +#define DDRSS_PHY_1187_DATA 0x00000000
    +#define DDRSS_PHY_1188_DATA 0x00000000
    +#define DDRSS_PHY_1189_DATA 0x00000000
    +#define DDRSS_PHY_1190_DATA 0x00000000
    +#define DDRSS_PHY_1191_DATA 0x00000000
    +#define DDRSS_PHY_1192_DATA 0x00000000
    +#define DDRSS_PHY_1193_DATA 0x00000000
    +#define DDRSS_PHY_1194_DATA 0x00000000
    +#define DDRSS_PHY_1195_DATA 0x00000000
    +#define DDRSS_PHY_1196_DATA 0x00000000
    +#define DDRSS_PHY_1197_DATA 0x00000000
    +#define DDRSS_PHY_1198_DATA 0x00000000
    +#define DDRSS_PHY_1199_DATA 0x00000000
    +#define DDRSS_PHY_1200_DATA 0x00000000
    +#define DDRSS_PHY_1201_DATA 0x00000000
    +#define DDRSS_PHY_1202_DATA 0x00000000
    +#define DDRSS_PHY_1203_DATA 0x00000000
    +#define DDRSS_PHY_1204_DATA 0x00000000
    +#define DDRSS_PHY_1205_DATA 0x00000000
    +#define DDRSS_PHY_1206_DATA 0x00000000
    +#define DDRSS_PHY_1207_DATA 0x00000000
    +#define DDRSS_PHY_1208_DATA 0x00000000
    +#define DDRSS_PHY_1209_DATA 0x00000000
    +#define DDRSS_PHY_1210_DATA 0x00000000
    +#define DDRSS_PHY_1211_DATA 0x00000000
    +#define DDRSS_PHY_1212_DATA 0x00000000
    +#define DDRSS_PHY_1213_DATA 0x00000000
    +#define DDRSS_PHY_1214_DATA 0x00000000
    +#define DDRSS_PHY_1215_DATA 0x00000000
    +#define DDRSS_PHY_1216_DATA 0x00000000
    +#define DDRSS_PHY_1217_DATA 0x00000000
    +#define DDRSS_PHY_1218_DATA 0x00000000
    +#define DDRSS_PHY_1219_DATA 0x00000000
    +#define DDRSS_PHY_1220_DATA 0x00000000
    +#define DDRSS_PHY_1221_DATA 0x00000000
    +#define DDRSS_PHY_1222_DATA 0x00000000
    +#define DDRSS_PHY_1223_DATA 0x00000000
    +#define DDRSS_PHY_1224_DATA 0x00000000
    +#define DDRSS_PHY_1225_DATA 0x00000000
    +#define DDRSS_PHY_1226_DATA 0x00000000
    +#define DDRSS_PHY_1227_DATA 0x00000000
    +#define DDRSS_PHY_1228_DATA 0x00000000
    +#define DDRSS_PHY_1229_DATA 0x00000000
    +#define DDRSS_PHY_1230_DATA 0x00000000
    +#define DDRSS_PHY_1231_DATA 0x00000000
    +#define DDRSS_PHY_1232_DATA 0x00000000
    +#define DDRSS_PHY_1233_DATA 0x00000000
    +#define DDRSS_PHY_1234_DATA 0x00000000
    +#define DDRSS_PHY_1235_DATA 0x00000000
    +#define DDRSS_PHY_1236_DATA 0x00000000
    +#define DDRSS_PHY_1237_DATA 0x00000000
    +#define DDRSS_PHY_1238_DATA 0x00000000
    +#define DDRSS_PHY_1239_DATA 0x00000000
    +#define DDRSS_PHY_1240_DATA 0x00000000
    +#define DDRSS_PHY_1241_DATA 0x00000000
    +#define DDRSS_PHY_1242_DATA 0x00000000
    +#define DDRSS_PHY_1243_DATA 0x00000000
    +#define DDRSS_PHY_1244_DATA 0x00000000
    +#define DDRSS_PHY_1245_DATA 0x00000000
    +#define DDRSS_PHY_1246_DATA 0x00000000
    +#define DDRSS_PHY_1247_DATA 0x00000000
    +#define DDRSS_PHY_1248_DATA 0x00000000
    +#define DDRSS_PHY_1249_DATA 0x00000000
    +#define DDRSS_PHY_1250_DATA 0x00000000
    +#define DDRSS_PHY_1251_DATA 0x00000000
    +#define DDRSS_PHY_1252_DATA 0x00000000
    +#define DDRSS_PHY_1253_DATA 0x00000000
    +#define DDRSS_PHY_1254_DATA 0x00000000
    +#define DDRSS_PHY_1255_DATA 0x00000000
    +#define DDRSS_PHY_1256_DATA 0x00000000
    +#define DDRSS_PHY_1257_DATA 0x00000000
    +#define DDRSS_PHY_1258_DATA 0x00000000
    +#define DDRSS_PHY_1259_DATA 0x00000000
    +#define DDRSS_PHY_1260_DATA 0x00000000
    +#define DDRSS_PHY_1261_DATA 0x00000000
    +#define DDRSS_PHY_1262_DATA 0x00000000
    +#define DDRSS_PHY_1263_DATA 0x00000000
    +#define DDRSS_PHY_1264_DATA 0x00000000
    +#define DDRSS_PHY_1265_DATA 0x00000000
    +#define DDRSS_PHY_1266_DATA 0x00000000
    +#define DDRSS_PHY_1267_DATA 0x00000000
    +#define DDRSS_PHY_1268_DATA 0x00000000
    +#define DDRSS_PHY_1269_DATA 0x00000000
    +#define DDRSS_PHY_1270_DATA 0x00000000
    +#define DDRSS_PHY_1271_DATA 0x00000000
    +#define DDRSS_PHY_1272_DATA 0x00000000
    +#define DDRSS_PHY_1273_DATA 0x00000000
    +#define DDRSS_PHY_1274_DATA 0x00000000
    +#define DDRSS_PHY_1275_DATA 0x00000000
    +#define DDRSS_PHY_1276_DATA 0x00000000
    +#define DDRSS_PHY_1277_DATA 0x00000000
    +#define DDRSS_PHY_1278_DATA 0x00000000
    +#define DDRSS_PHY_1279_DATA 0x00000000
    +#define DDRSS_PHY_1280_DATA 0x00000000
    +#define DDRSS_PHY_1281_DATA 0x00010100
    +#define DDRSS_PHY_1282_DATA 0x00000000
    +#define DDRSS_PHY_1283_DATA 0x00000000
    +#define DDRSS_PHY_1284_DATA 0x00000000
    +#define DDRSS_PHY_1285_DATA 0x00000000
    +#define DDRSS_PHY_1286_DATA 0x00050000
    +#define DDRSS_PHY_1287_DATA 0x04000000
    +#define DDRSS_PHY_1288_DATA 0x00000055
    +#define DDRSS_PHY_1289_DATA 0x00000000
    +#define DDRSS_PHY_1290_DATA 0x00000000
    +#define DDRSS_PHY_1291_DATA 0x00000000
    +#define DDRSS_PHY_1292_DATA 0x00000000
    +#define DDRSS_PHY_1293_DATA 0x00002001
    +#define DDRSS_PHY_1294_DATA 0x00004001
    +#define DDRSS_PHY_1295_DATA 0x00020028
    +#define DDRSS_PHY_1296_DATA 0x01010100
    +#define DDRSS_PHY_1297_DATA 0x00000000
    +#define DDRSS_PHY_1298_DATA 0x00000000
    +#define DDRSS_PHY_1299_DATA 0x0F0F0E06
    +#define DDRSS_PHY_1300_DATA 0x00010101
    +#define DDRSS_PHY_1301_DATA 0x010F0004
    +#define DDRSS_PHY_1302_DATA 0x00000000
    +#define DDRSS_PHY_1303_DATA 0x00000000
    +#define DDRSS_PHY_1304_DATA 0x00000064
    +#define DDRSS_PHY_1305_DATA 0x00000000
    +#define DDRSS_PHY_1306_DATA 0x00000000
    +#define DDRSS_PHY_1307_DATA 0x01020103
    +#define DDRSS_PHY_1308_DATA 0x0F020102
    +#define DDRSS_PHY_1309_DATA 0x03030303
    +#define DDRSS_PHY_1310_DATA 0x03030303
    +#define DDRSS_PHY_1311_DATA 0x00041B42
    +#define DDRSS_PHY_1312_DATA 0x00005201
    +#define DDRSS_PHY_1313_DATA 0x00000000
    +#define DDRSS_PHY_1314_DATA 0x00000000
    +#define DDRSS_PHY_1315_DATA 0x00000000
    +#define DDRSS_PHY_1316_DATA 0x00000000
    +#define DDRSS_PHY_1317_DATA 0x00000000
    +#define DDRSS_PHY_1318_DATA 0x00000000
    +#define DDRSS_PHY_1319_DATA 0x07030101
    +#define DDRSS_PHY_1320_DATA 0x00005400
    +#define DDRSS_PHY_1321_DATA 0x000040A2
    +#define DDRSS_PHY_1322_DATA 0x00024410
    +#define DDRSS_PHY_1323_DATA 0x00004410
    +#define DDRSS_PHY_1324_DATA 0x00004410
    +#define DDRSS_PHY_1325_DATA 0x00004410
    +#define DDRSS_PHY_1326_DATA 0x00004410
    +#define DDRSS_PHY_1327_DATA 0x00004410
    +#define DDRSS_PHY_1328_DATA 0x00004410
    +#define DDRSS_PHY_1329_DATA 0x00004410
    +#define DDRSS_PHY_1330_DATA 0x00004410
    +#define DDRSS_PHY_1331_DATA 0x00004410
    +#define DDRSS_PHY_1332_DATA 0x00000000
    +#define DDRSS_PHY_1333_DATA 0x00000076
    +#define DDRSS_PHY_1334_DATA 0x00000400
    +#define DDRSS_PHY_1335_DATA 0x00000008
    +#define DDRSS_PHY_1336_DATA 0x00000000
    +#define DDRSS_PHY_1337_DATA 0x00000000
    +#define DDRSS_PHY_1338_DATA 0x00000000
    +#define DDRSS_PHY_1339_DATA 0x00000000
    +#define DDRSS_PHY_1340_DATA 0x00000000
    +#define DDRSS_PHY_1341_DATA 0x03000000
    +#define DDRSS_PHY_1342_DATA 0x00000000
    +#define DDRSS_PHY_1343_DATA 0x00000000
    +#define DDRSS_PHY_1344_DATA 0x00000000
    +#define DDRSS_PHY_1345_DATA 0x04102006
    +#define DDRSS_PHY_1346_DATA 0x00041020
    +#define DDRSS_PHY_1347_DATA 0x01C98C98
    +#define DDRSS_PHY_1348_DATA 0x3F400000
    +#define DDRSS_PHY_1349_DATA 0x3F3F1F3F
    +#define DDRSS_PHY_1350_DATA 0x0000001F
    +#define DDRSS_PHY_1351_DATA 0x00000000
    +#define DDRSS_PHY_1352_DATA 0x00000000
    +#define DDRSS_PHY_1353_DATA 0x00000000
    +#define DDRSS_PHY_1354_DATA 0x00000001
    +#define DDRSS_PHY_1355_DATA 0x00000000
    +#define DDRSS_PHY_1356_DATA 0x00000000
    +#define DDRSS_PHY_1357_DATA 0x00000000
    +#define DDRSS_PHY_1358_DATA 0x00000000
    +#define DDRSS_PHY_1359_DATA 0x76543210
    +#define DDRSS_PHY_1360_DATA 0x00040198
    +#define DDRSS_PHY_1361_DATA 0x00000000
    +#define DDRSS_PHY_1362_DATA 0x00000000
    +#define DDRSS_PHY_1363_DATA 0x00000000
    +#define DDRSS_PHY_1364_DATA 0x00040700
    +#define DDRSS_PHY_1365_DATA 0x00000000
    +#define DDRSS_PHY_1366_DATA 0x00000000
    +#define DDRSS_PHY_1367_DATA 0x00000000
    +#define DDRSS_PHY_1368_DATA 0x00000002
    +#define DDRSS_PHY_1369_DATA 0x00000000
    +#define DDRSS_PHY_1370_DATA 0x00000000
    +#define DDRSS_PHY_1371_DATA 0x0001F7C2
    +#define DDRSS_PHY_1372_DATA 0x00020002
    +#define DDRSS_PHY_1373_DATA 0x00000000
    +#define DDRSS_PHY_1374_DATA 0x00001142
    +#define DDRSS_PHY_1375_DATA 0x03020000
    +#define DDRSS_PHY_1376_DATA 0x00000080
    +#define DDRSS_PHY_1377_DATA 0x03900390
    +#define DDRSS_PHY_1378_DATA 0x03900390
    +#define DDRSS_PHY_1379_DATA 0x03900390
    +#define DDRSS_PHY_1380_DATA 0x03900390
    +#define DDRSS_PHY_1381_DATA 0x03000300
    +#define DDRSS_PHY_1382_DATA 0x03000300
    +#define DDRSS_PHY_1383_DATA 0x00000300
    +#define DDRSS_PHY_1384_DATA 0x00000300
    +#define DDRSS_PHY_1385_DATA 0x00000300
    +#define DDRSS_PHY_1386_DATA 0x00000300
    +#define DDRSS_PHY_1387_DATA 0x3183BF77
    +#define DDRSS_PHY_1388_DATA 0x00000000
    +#define DDRSS_PHY_1389_DATA 0x0C000DFF
    +#define DDRSS_PHY_1390_DATA 0x30000DFF
    +#define DDRSS_PHY_1391_DATA 0x3F0DFF11
    +#define DDRSS_PHY_1392_DATA 0x01990000
    +#define DDRSS_PHY_1393_DATA 0x780DFFCC
    +#define DDRSS_PHY_1394_DATA 0x00000C11
    +#define DDRSS_PHY_1395_DATA 0x00018011
    +#define DDRSS_PHY_1396_DATA 0x0089FF00
    +#define DDRSS_PHY_1397_DATA 0x000C3F11
    +#define DDRSS_PHY_1398_DATA 0x01990000
    +#define DDRSS_PHY_1399_DATA 0x000C3F91
    +#define DDRSS_PHY_1400_DATA 0x01990000
    +#define DDRSS_PHY_1401_DATA 0x3F0DFF11
    +#define DDRSS_PHY_1402_DATA 0x01990000
    +#define DDRSS_PHY_1403_DATA 0x00018011
    +#define DDRSS_PHY_1404_DATA 0x0089FF00
    +#define DDRSS_PHY_1405_DATA 0x20040004
    diff --git a/arch/arm/dts/k3-am62x-sip-ddr-lp4-50-800.dtsi b/arch/arm/dts/k3-am62x-sip-ddr-lp4-50-800.dtsi
    new file mode 100644
    index 0000000000..f3ec0c91c3
    --- /dev/null
    +++ b/arch/arm/dts/k3-am62x-sip-ddr-lp4-50-800.dtsi
    @@ -0,0 +1,2191 @@
    +// SPDX-License-Identifier: GPL-2.0+
    + * This file was generated with the
    + * AM62x SysConfig DDR Subsystem Register Configuration Tool v0.09.03
    + * Mon Nov 21 2022 09:04:01 GMT-0600 (Central Standard Time)
    + * DDR Type: LPDDR4
    + * F0 = 50MHz    F1 = NA     F2 = 800MHz
    + * Density (per channel): 4Gb
    + * Write DBI: Enable
    + * Number of Ranks: 1
    +#define DDRSS_PLL_FHS_CNT 3
    +#define DDRSS_PLL_FREQUENCY_1 400000000
    +#define DDRSS_PLL_FREQUENCY_2 400000000
    +#define DDRSS_CTL_0_DATA 0x00000B00
    +#define DDRSS_CTL_1_DATA 0x00000000
    +#define DDRSS_CTL_2_DATA 0x00000000
    +#define DDRSS_CTL_3_DATA 0x00000000
    +#define DDRSS_CTL_4_DATA 0x00000000
    +#define DDRSS_CTL_5_DATA 0x00000000
    +#define DDRSS_CTL_6_DATA 0x00000000
    +#define DDRSS_CTL_7_DATA 0x00002710
    +#define DDRSS_CTL_8_DATA 0x000186A0
    +#define DDRSS_CTL_9_DATA 0x00000005
    +#define DDRSS_CTL_10_DATA 0x00000064
    +#define DDRSS_CTL_11_DATA 0x00027100
    +#define DDRSS_CTL_12_DATA 0x00186A00
    +#define DDRSS_CTL_13_DATA 0x00000005
    +#define DDRSS_CTL_14_DATA 0x00000640
    +#define DDRSS_CTL_15_DATA 0x00027100
    +#define DDRSS_CTL_16_DATA 0x00186A00
    +#define DDRSS_CTL_17_DATA 0x00000005
    +#define DDRSS_CTL_18_DATA 0x00000640
    +#define DDRSS_CTL_19_DATA 0x01010100
    +#define DDRSS_CTL_20_DATA 0x01010100
    +#define DDRSS_CTL_21_DATA 0x01000110
    +#define DDRSS_CTL_22_DATA 0x02010002
    +#define DDRSS_CTL_23_DATA 0x0000000A
    +#define DDRSS_CTL_24_DATA 0x000186A0
    +#define DDRSS_CTL_25_DATA 0x00000000
    +#define DDRSS_CTL_26_DATA 0x00000000
    +#define DDRSS_CTL_27_DATA 0x00000000
    +#define DDRSS_CTL_28_DATA 0x00000000
    +#define DDRSS_CTL_29_DATA 0x00020200
    +#define DDRSS_CTL_30_DATA 0x00000000
    +#define DDRSS_CTL_31_DATA 0x00000000
    +#define DDRSS_CTL_32_DATA 0x00000000
    +#define DDRSS_CTL_33_DATA 0x00000000
    +#define DDRSS_CTL_34_DATA 0x08000010
    +#define DDRSS_CTL_35_DATA 0x00002020
    +#define DDRSS_CTL_36_DATA 0x00000000
    +#define DDRSS_CTL_37_DATA 0x00000000
    +#define DDRSS_CTL_38_DATA 0x0000040C
    +#define DDRSS_CTL_39_DATA 0x00000000
    +#define DDRSS_CTL_40_DATA 0x0000081C
    +#define DDRSS_CTL_41_DATA 0x00000000
    +#define DDRSS_CTL_42_DATA 0x0000081C
    +#define DDRSS_CTL_43_DATA 0x00000000
    +#define DDRSS_CTL_44_DATA 0x05000804
    +#define DDRSS_CTL_45_DATA 0x00000700
    +#define DDRSS_CTL_46_DATA 0x09090004
    +#define DDRSS_CTL_47_DATA 0x00000303
    +#define DDRSS_CTL_48_DATA 0x00320007
    +#define DDRSS_CTL_49_DATA 0x09090023
    +#define DDRSS_CTL_50_DATA 0x0000210F
    +#define DDRSS_CTL_51_DATA 0x00320007
    +#define DDRSS_CTL_52_DATA 0x09090023
    +#define DDRSS_CTL_53_DATA 0x0900210F
    +#define DDRSS_CTL_54_DATA 0x000A0A09
    +#define DDRSS_CTL_55_DATA 0x040006DB
    +#define DDRSS_CTL_56_DATA 0x09092004
    +#define DDRSS_CTL_57_DATA 0x00000C0A
    +#define DDRSS_CTL_58_DATA 0x06006DB0
    +#define DDRSS_CTL_59_DATA 0x09092006
    +#define DDRSS_CTL_60_DATA 0x00000C0A
    +#define DDRSS_CTL_61_DATA 0x06006DB0
    +#define DDRSS_CTL_62_DATA 0x03042006
    +#define DDRSS_CTL_63_DATA 0x04050002
    +#define DDRSS_CTL_64_DATA 0x100F100F
    +#define DDRSS_CTL_65_DATA 0x01010008
    +#define DDRSS_CTL_66_DATA 0x041F1F07
    +#define DDRSS_CTL_67_DATA 0x03111103
    +#define DDRSS_CTL_68_DATA 0x00001111
    +#define DDRSS_CTL_69_DATA 0x00000101
    +#define DDRSS_CTL_70_DATA 0x00000000
    +#define DDRSS_CTL_71_DATA 0x01000000
    +#define DDRSS_CTL_72_DATA 0x00090803
    +#define DDRSS_CTL_73_DATA 0x000000BB
    +#define DDRSS_CTL_74_DATA 0x00000090
    +#define DDRSS_CTL_75_DATA 0x00000C2B
    +#define DDRSS_CTL_76_DATA 0x00000090
    +#define DDRSS_CTL_77_DATA 0x00000C2B
    +#define DDRSS_CTL_78_DATA 0x00000005
    +#define DDRSS_CTL_79_DATA 0x00000005
    +#define DDRSS_CTL_80_DATA 0x00000010
    +#define DDRSS_CTL_81_DATA 0x00000048
    +#define DDRSS_CTL_82_DATA 0x0000017E
    +#define DDRSS_CTL_83_DATA 0x00000048
    +#define DDRSS_CTL_84_DATA 0x0000017E
    +#define DDRSS_CTL_85_DATA 0x03004000
    +#define DDRSS_CTL_86_DATA 0x00001201
    +#define DDRSS_CTL_87_DATA 0x00060005
    +#define DDRSS_CTL_88_DATA 0x00000006
    +#define DDRSS_CTL_89_DATA 0x00000000
    +#define DDRSS_CTL_90_DATA 0x05121208
    +#define DDRSS_CTL_91_DATA 0x05030A05
    +#define DDRSS_CTL_92_DATA 0x05030C06
    +#define DDRSS_CTL_93_DATA 0x01030C06
    +#define DDRSS_CTL_94_DATA 0x02010201
    +#define DDRSS_CTL_95_DATA 0x00000A01
    +#define DDRSS_CTL_96_DATA 0x0096000A
    +#define DDRSS_CTL_97_DATA 0x00960096
    +#define DDRSS_CTL_98_DATA 0x00000096
    +#define DDRSS_CTL_99_DATA 0x00000000
    +#define DDRSS_CTL_100_DATA 0x05010303
    +#define DDRSS_CTL_101_DATA 0x0C040505
    +#define DDRSS_CTL_102_DATA 0x06050203
    +#define DDRSS_CTL_103_DATA 0x030C0605
    +#define DDRSS_CTL_104_DATA 0x05060502
    +#define DDRSS_CTL_105_DATA 0x03030306
    +#define DDRSS_CTL_106_DATA 0x03010000
    +#define DDRSS_CTL_107_DATA 0x00010000
    +#define DDRSS_CTL_108_DATA 0x00000000
    +#define DDRSS_CTL_109_DATA 0x01000000
    +#define DDRSS_CTL_110_DATA 0x80104002
    +#define DDRSS_CTL_111_DATA 0x00040003
    +#define DDRSS_CTL_112_DATA 0x00040005
    +#define DDRSS_CTL_113_DATA 0x00030000
    +#define DDRSS_CTL_114_DATA 0x00050004
    +#define DDRSS_CTL_115_DATA 0x00000004
    +#define DDRSS_CTL_116_DATA 0x00040003
    +#define DDRSS_CTL_117_DATA 0x00040005
    +#define DDRSS_CTL_118_DATA 0x00000000
    +#define DDRSS_CTL_119_DATA 0x00002EC0
    +#define DDRSS_CTL_120_DATA 0x00002EC0
    +#define DDRSS_CTL_121_DATA 0x00002EC0
    +#define DDRSS_CTL_122_DATA 0x00002EC0
    +#define DDRSS_CTL_123_DATA 0x00002EC0
    +#define DDRSS_CTL_124_DATA 0x00000000
    +#define DDRSS_CTL_125_DATA 0x0000051D
    +#define DDRSS_CTL_126_DATA 0x00030AC0
    +#define DDRSS_CTL_127_DATA 0x00030AC0
    +#define DDRSS_CTL_128_DATA 0x00030AC0
    +#define DDRSS_CTL_129_DATA 0x00030AC0
    +#define DDRSS_CTL_130_DATA 0x00030AC0
    +#define DDRSS_CTL_131_DATA 0x00000000
    +#define DDRSS_CTL_132_DATA 0x0000552D
    +#define DDRSS_CTL_133_DATA 0x00030AC0
    +#define DDRSS_CTL_134_DATA 0x00030AC0
    +#define DDRSS_CTL_135_DATA 0x00030AC0
    +#define DDRSS_CTL_136_DATA 0x00030AC0
    +#define DDRSS_CTL_137_DATA 0x00030AC0
    +#define DDRSS_CTL_138_DATA 0x00000000
    +#define DDRSS_CTL_139_DATA 0x0000552D
    +#define DDRSS_CTL_140_DATA 0x00000000
    +#define DDRSS_CTL_141_DATA 0x00000000
    +#define DDRSS_CTL_142_DATA 0x00000000
    +#define DDRSS_CTL_143_DATA 0x00000000
    +#define DDRSS_CTL_144_DATA 0x00000000
    +#define DDRSS_CTL_145_DATA 0x00000000
    +#define DDRSS_CTL_146_DATA 0x00000000
    +#define DDRSS_CTL_147_DATA 0x00000000
    +#define DDRSS_CTL_148_DATA 0x00000000
    +#define DDRSS_CTL_149_DATA 0x00000000
    +#define DDRSS_CTL_150_DATA 0x00000000
    +#define DDRSS_CTL_151_DATA 0x00000000
    +#define DDRSS_CTL_152_DATA 0x00000000
    +#define DDRSS_CTL_153_DATA 0x00000000
    +#define DDRSS_CTL_154_DATA 0x00000000
    +#define DDRSS_CTL_155_DATA 0x00000000
    +#define DDRSS_CTL_156_DATA 0x03050000
    +#define DDRSS_CTL_157_DATA 0x03050305
    +#define DDRSS_CTL_158_DATA 0x00000000
    +#define DDRSS_CTL_159_DATA 0x08010000
    +#define DDRSS_CTL_160_DATA 0x000E0808
    +#define DDRSS_CTL_161_DATA 0x01000000
    +#define DDRSS_CTL_162_DATA 0x0E080808
    +#define DDRSS_CTL_163_DATA 0x00000000
    +#define DDRSS_CTL_164_DATA 0x08080801
    +#define DDRSS_CTL_165_DATA 0x0000080E
    +#define DDRSS_CTL_166_DATA 0x00040003
    +#define DDRSS_CTL_167_DATA 0x00000007
    +#define DDRSS_CTL_168_DATA 0x00000000
    +#define DDRSS_CTL_169_DATA 0x00000000
    +#define DDRSS_CTL_170_DATA 0x00000000
    +#define DDRSS_CTL_171_DATA 0x00000000
    +#define DDRSS_CTL_172_DATA 0x00000000
    +#define DDRSS_CTL_173_DATA 0x00000000
    +#define DDRSS_CTL_174_DATA 0x01000000
    +#define DDRSS_CTL_175_DATA 0x00000000
    +#define DDRSS_CTL_176_DATA 0x00001500
    +#define DDRSS_CTL_177_DATA 0x0000100E
    +#define DDRSS_CTL_178_DATA 0x00000002
    +#define DDRSS_CTL_179_DATA 0x00000000
    +#define DDRSS_CTL_180_DATA 0x00000001
    +#define DDRSS_CTL_181_DATA 0x00000002
    +#define DDRSS_CTL_182_DATA 0x00000C00
    +#define DDRSS_CTL_183_DATA 0x00001000
    +#define DDRSS_CTL_184_DATA 0x00000C00
    +#define DDRSS_CTL_185_DATA 0x00001000
    +#define DDRSS_CTL_186_DATA 0x00000C00
    +#define DDRSS_CTL_187_DATA 0x00001000
    +#define DDRSS_CTL_188_DATA 0x00000000
    +#define DDRSS_CTL_189_DATA 0x00000000
    +#define DDRSS_CTL_190_DATA 0x00000000
    +#define DDRSS_CTL_191_DATA 0x00000000
    +#define DDRSS_CTL_192_DATA 0x0005000A
    +#define DDRSS_CTL_193_DATA 0x0404000D
    +#define DDRSS_CTL_194_DATA 0x0000000D
    +#define DDRSS_CTL_195_DATA 0x005000A0
    +#define DDRSS_CTL_196_DATA 0x060600C8
    +#define DDRSS_CTL_197_DATA 0x000000C8
    +#define DDRSS_CTL_198_DATA 0x005000A0
    +#define DDRSS_CTL_199_DATA 0x060600C8
    +#define DDRSS_CTL_200_DATA 0x000000C8
    +#define DDRSS_CTL_201_DATA 0x00000000
    +#define DDRSS_CTL_202_DATA 0x00000000
    +#define DDRSS_CTL_203_DATA 0x00000000
    +#define DDRSS_CTL_204_DATA 0x00000000
    +#define DDRSS_CTL_205_DATA 0x00000004
    +#define DDRSS_CTL_206_DATA 0x00000000
    +#define DDRSS_CTL_207_DATA 0x00000000
    +#define DDRSS_CTL_208_DATA 0x00000024
    +#define DDRSS_CTL_209_DATA 0x00000012
    +#define DDRSS_CTL_210_DATA 0x00000000
    +#define DDRSS_CTL_211_DATA 0x00000024
    +#define DDRSS_CTL_212_DATA 0x00000012
    +#define DDRSS_CTL_213_DATA 0x00000000
    +#define DDRSS_CTL_214_DATA 0x00000004
    +#define DDRSS_CTL_215_DATA 0x00000000
    +#define DDRSS_CTL_216_DATA 0x00000000
    +#define DDRSS_CTL_217_DATA 0x00000024
    +#define DDRSS_CTL_218_DATA 0x00000012
    +#define DDRSS_CTL_219_DATA 0x00000000
    +#define DDRSS_CTL_220_DATA 0x00000024
    +#define DDRSS_CTL_221_DATA 0x00000012
    +#define DDRSS_CTL_222_DATA 0x00000000
    +#define DDRSS_CTL_223_DATA 0x00000000
    +#define DDRSS_CTL_224_DATA 0x00000031
    +#define DDRSS_CTL_225_DATA 0x000000B1
    +#define DDRSS_CTL_226_DATA 0x000000B1
    +#define DDRSS_CTL_227_DATA 0x00000031
    +#define DDRSS_CTL_228_DATA 0x000000B1
    +#define DDRSS_CTL_229_DATA 0x000000B1
    +#define DDRSS_CTL_230_DATA 0x00000000
    +#define DDRSS_CTL_231_DATA 0x00000000
    +#define DDRSS_CTL_232_DATA 0x00000000
    +#define DDRSS_CTL_233_DATA 0x00000000
    +#define DDRSS_CTL_234_DATA 0x00000000
    +#define DDRSS_CTL_235_DATA 0x00000000
    +#define DDRSS_CTL_236_DATA 0x00000000
    +#define DDRSS_CTL_237_DATA 0x00000000
    +#define DDRSS_CTL_238_DATA 0x00000000
    +#define DDRSS_CTL_239_DATA 0x00000000
    +#define DDRSS_CTL_240_DATA 0x00000000
    +#define DDRSS_CTL_241_DATA 0x00000000
    +#define DDRSS_CTL_242_DATA 0x00000000
    +#define DDRSS_CTL_243_DATA 0x00000000
    +#define DDRSS_CTL_244_DATA 0x00000000
    +#define DDRSS_CTL_245_DATA 0x00000000
    +#define DDRSS_CTL_246_DATA 0x00000000
    +#define DDRSS_CTL_247_DATA 0x00000000
    +#define DDRSS_CTL_248_DATA 0x00000000
    +#define DDRSS_CTL_249_DATA 0x00000000
    +#define DDRSS_CTL_250_DATA 0x00000000
    +#define DDRSS_CTL_251_DATA 0x00000000
    +#define DDRSS_CTL_252_DATA 0x00000000
    +#define DDRSS_CTL_253_DATA 0x00000000
    +#define DDRSS_CTL_254_DATA 0x65006565
    +#define DDRSS_CTL_255_DATA 0x00002765
    +#define DDRSS_CTL_256_DATA 0x00000027
    +#define DDRSS_CTL_257_DATA 0x00000027
    +#define DDRSS_CTL_258_DATA 0x00000027
    +#define DDRSS_CTL_259_DATA 0x00000027
    +#define DDRSS_CTL_260_DATA 0x00000027
    +#define DDRSS_CTL_261_DATA 0x00000000
    +#define DDRSS_CTL_262_DATA 0x00000000
    +#define DDRSS_CTL_263_DATA 0x0000000F
    +#define DDRSS_CTL_264_DATA 0x0000000F
    +#define DDRSS_CTL_265_DATA 0x0000000F
    +#define DDRSS_CTL_266_DATA 0x0000000F
    +#define DDRSS_CTL_267_DATA 0x0000000F
    +#define DDRSS_CTL_268_DATA 0x0000000F
    +#define DDRSS_CTL_269_DATA 0x00000000
    +#define DDRSS_CTL_270_DATA 0x00001000
    +#define DDRSS_CTL_271_DATA 0x00000015
    +#define DDRSS_CTL_272_DATA 0x00000015
    +#define DDRSS_CTL_273_DATA 0x00000010
    +#define DDRSS_CTL_274_DATA 0x00000015
    +#define DDRSS_CTL_275_DATA 0x00000015
    +#define DDRSS_CTL_276_DATA 0x00000020
    +#define DDRSS_CTL_277_DATA 0x00010000
    +#define DDRSS_CTL_278_DATA 0x00000100
    +#define DDRSS_CTL_279_DATA 0x00000000
    +#define DDRSS_CTL_280_DATA 0x00000000
    +#define DDRSS_CTL_281_DATA 0x00000101
    +#define DDRSS_CTL_282_DATA 0x00000000
    +#define DDRSS_CTL_283_DATA 0x00000000
    +#define DDRSS_CTL_284_DATA 0x00000000
    +#define DDRSS_CTL_285_DATA 0x00000000
    +#define DDRSS_CTL_286_DATA 0x00000000
    +#define DDRSS_CTL_287_DATA 0x00000000
    +#define DDRSS_CTL_288_DATA 0x00000000
    +#define DDRSS_CTL_289_DATA 0x00000000
    +#define DDRSS_CTL_290_DATA 0x0C181511
    +#define DDRSS_CTL_291_DATA 0x00000304
    +#define DDRSS_CTL_292_DATA 0x00000000
    +#define DDRSS_CTL_293_DATA 0x00000000
    +#define DDRSS_CTL_294_DATA 0x00000000
    +#define DDRSS_CTL_295_DATA 0x00000000
    +#define DDRSS_CTL_296_DATA 0x00000000
    +#define DDRSS_CTL_297_DATA 0x00000000
    +#define DDRSS_CTL_298_DATA 0x00000000
    +#define DDRSS_CTL_299_DATA 0x00000000
    +#define DDRSS_CTL_300_DATA 0x00000000
    +#define DDRSS_CTL_301_DATA 0x00000000
    +#define DDRSS_CTL_302_DATA 0x00000000
    +#define DDRSS_CTL_303_DATA 0x00000000
    +#define DDRSS_CTL_304_DATA 0x00000000
    +#define DDRSS_CTL_305_DATA 0x00020000
    +#define DDRSS_CTL_306_DATA 0x00400100
    +#define DDRSS_CTL_307_DATA 0x00080032
    +#define DDRSS_CTL_308_DATA 0x01000200
    +#define DDRSS_CTL_309_DATA 0x03200040
    +#define DDRSS_CTL_310_DATA 0x00020018
    +#define DDRSS_CTL_311_DATA 0x00400100
    +#define DDRSS_CTL_312_DATA 0x00180320
    +#define DDRSS_CTL_313_DATA 0x00030000
    +#define DDRSS_CTL_314_DATA 0x00280028
    +#define DDRSS_CTL_315_DATA 0x00000100
    +#define DDRSS_CTL_316_DATA 0x01010000
    +#define DDRSS_CTL_317_DATA 0x00000202
    +#define DDRSS_CTL_318_DATA 0x0FFF0000
    +#define DDRSS_CTL_319_DATA 0x000FFF00
    +#define DDRSS_CTL_320_DATA 0xFFFFFFFF
    +#define DDRSS_CTL_321_DATA 0x00FFFF00
    +#define DDRSS_CTL_322_DATA 0x0B000000
    +#define DDRSS_CTL_323_DATA 0x0001FFFF
    +#define DDRSS_CTL_324_DATA 0x01010101
    +#define DDRSS_CTL_325_DATA 0x01010101
    +#define DDRSS_CTL_326_DATA 0x00000118
    +#define DDRSS_CTL_327_DATA 0x00000C01
    +#define DDRSS_CTL_328_DATA 0x01000100
    +#define DDRSS_CTL_329_DATA 0x00000000
    +#define DDRSS_CTL_330_DATA 0x00000000
    +#define DDRSS_CTL_331_DATA 0x01030303
    +#define DDRSS_CTL_332_DATA 0x00000001
    +#define DDRSS_CTL_333_DATA 0x00000000
    +#define DDRSS_CTL_334_DATA 0x00000000
    +#define DDRSS_CTL_335_DATA 0x00000000
    +#define DDRSS_CTL_336_DATA 0x00000000
    +#define DDRSS_CTL_337_DATA 0x00000000
    +#define DDRSS_CTL_338_DATA 0x00000000
    +#define DDRSS_CTL_339_DATA 0x00000000
    +#define DDRSS_CTL_340_DATA 0x00000000
    +#define DDRSS_CTL_341_DATA 0x00000000
    +#define DDRSS_CTL_342_DATA 0x00000000
    +#define DDRSS_CTL_343_DATA 0x00000000
    +#define DDRSS_CTL_344_DATA 0x00000000
    +#define DDRSS_CTL_345_DATA 0x00000000
    +#define DDRSS_CTL_346_DATA 0x00000000
    +#define DDRSS_CTL_347_DATA 0x00000000
    +#define DDRSS_CTL_348_DATA 0x00000000
    +#define DDRSS_CTL_349_DATA 0x00000000
    +#define DDRSS_CTL_350_DATA 0x00000000
    +#define DDRSS_CTL_351_DATA 0x00000000
    +#define DDRSS_CTL_352_DATA 0x00000000
    +#define DDRSS_CTL_353_DATA 0x00000000
    +#define DDRSS_CTL_354_DATA 0x00000000
    +#define DDRSS_CTL_355_DATA 0x00000000
    +#define DDRSS_CTL_356_DATA 0x00000000
    +#define DDRSS_CTL_357_DATA 0x00000000
    +#define DDRSS_CTL_358_DATA 0x00000000
    +#define DDRSS_CTL_359_DATA 0x00000000
    +#define DDRSS_CTL_360_DATA 0x00000000
    +#define DDRSS_CTL_361_DATA 0x00000000
    +#define DDRSS_CTL_362_DATA 0x00000000
    +#define DDRSS_CTL_363_DATA 0x00000000
    +#define DDRSS_CTL_364_DATA 0x00000000
    +#define DDRSS_CTL_365_DATA 0x00000000
    +#define DDRSS_CTL_366_DATA 0x00000000
    +#define DDRSS_CTL_367_DATA 0x00000000
    +#define DDRSS_CTL_368_DATA 0x00000000
    +#define DDRSS_CTL_369_DATA 0x00000000
    +#define DDRSS_CTL_370_DATA 0x00000000
    +#define DDRSS_CTL_371_DATA 0x01000101
    +#define DDRSS_CTL_372_DATA 0x01010001
    +#define DDRSS_CTL_373_DATA 0x00010101
    +#define DDRSS_CTL_374_DATA 0x01050503
    +#define DDRSS_CTL_375_DATA 0x05020201
    +#define DDRSS_CTL_376_DATA 0x08080C0C
    +#define DDRSS_CTL_377_DATA 0x00080308
    +#define DDRSS_CTL_378_DATA 0x000B030E
    +#define DDRSS_CTL_379_DATA 0x000B0310
    +#define DDRSS_CTL_380_DATA 0x0B0B0810
    +#define DDRSS_CTL_381_DATA 0x01000000
    +#define DDRSS_CTL_382_DATA 0x03020301
    +#define DDRSS_CTL_383_DATA 0x04000102
    +#define DDRSS_CTL_384_DATA 0x1B000004
    +#define DDRSS_CTL_385_DATA 0x00000176
    +#define DDRSS_CTL_386_DATA 0x00000200
    +#define DDRSS_CTL_387_DATA 0x00000200
    +#define DDRSS_CTL_388_DATA 0x00000200
    +#define DDRSS_CTL_389_DATA 0x00000200
    +#define DDRSS_CTL_390_DATA 0x00000693
    +#define DDRSS_CTL_391_DATA 0x00000E9C
    +#define DDRSS_CTL_392_DATA 0x03050202
    +#define DDRSS_CTL_393_DATA 0x00250201
    +#define DDRSS_CTL_394_DATA 0x00001856
    +#define DDRSS_CTL_395_DATA 0x00000200
    +#define DDRSS_CTL_396_DATA 0x00000200
    +#define DDRSS_CTL_397_DATA 0x00000200
    +#define DDRSS_CTL_398_DATA 0x00000200
    +#define DDRSS_CTL_399_DATA 0x00006D83
    +#define DDRSS_CTL_400_DATA 0x0000F35C
    +#define DDRSS_CTL_401_DATA 0x070D0402
    +#define DDRSS_CTL_402_DATA 0x00250405
    +#define DDRSS_CTL_403_DATA 0x00001856
    +#define DDRSS_CTL_404_DATA 0x00000200
    +#define DDRSS_CTL_405_DATA 0x00000200
    +#define DDRSS_CTL_406_DATA 0x00000200
    +#define DDRSS_CTL_407_DATA 0x00000200
    +#define DDRSS_CTL_408_DATA 0x00006D83
    +#define DDRSS_CTL_409_DATA 0x0000F35C
    +#define DDRSS_CTL_410_DATA 0x070D0402
    +#define DDRSS_CTL_411_DATA 0x00000405
    +#define DDRSS_CTL_412_DATA 0x00000000
    +#define DDRSS_CTL_413_DATA 0x0302000A
    +#define DDRSS_CTL_414_DATA 0x01000500
    +#define DDRSS_CTL_415_DATA 0x01010001
    +#define DDRSS_CTL_416_DATA 0x00010001
    +#define DDRSS_CTL_417_DATA 0x01010001
    +#define DDRSS_CTL_418_DATA 0x02010000
    +#define DDRSS_CTL_419_DATA 0x00000200
    +#define DDRSS_CTL_420_DATA 0x02000201
    +#define DDRSS_CTL_421_DATA 0x10100600
    +#define DDRSS_CTL_422_DATA 0x00202020
    +#define DDRSS_PI_0_DATA 0x00000B00
    +#define DDRSS_PI_1_DATA 0x00000000
    +#define DDRSS_PI_2_DATA 0x00000000
    +#define DDRSS_PI_3_DATA 0x01000000
    +#define DDRSS_PI_4_DATA 0x00000001
    +#define DDRSS_PI_5_DATA 0x00010064
    +#define DDRSS_PI_6_DATA 0x00000000
    +#define DDRSS_PI_7_DATA 0x00000000
    +#define DDRSS_PI_8_DATA 0x00000000
    +#define DDRSS_PI_9_DATA 0x00000000
    +#define DDRSS_PI_10_DATA 0x00000000
    +#define DDRSS_PI_11_DATA 0x00000002
    +#define DDRSS_PI_12_DATA 0x00000005
    +#define DDRSS_PI_13_DATA 0x00010001
    +#define DDRSS_PI_14_DATA 0x08000000
    +#define DDRSS_PI_15_DATA 0x00010300
    +#define DDRSS_PI_16_DATA 0x00000005
    +#define DDRSS_PI_17_DATA 0x00000000
    +#define DDRSS_PI_18_DATA 0x00000000
    +#define DDRSS_PI_19_DATA 0x00000000
    +#define DDRSS_PI_20_DATA 0x00000000
    +#define DDRSS_PI_21_DATA 0x00000000
    +#define DDRSS_PI_22_DATA 0x00000000
    +#define DDRSS_PI_23_DATA 0x00010000
    +#define DDRSS_PI_24_DATA 0x280A0001
    +#define DDRSS_PI_25_DATA 0x00000000
    +#define DDRSS_PI_26_DATA 0x00010000
    +#define DDRSS_PI_27_DATA 0x00003200
    +#define DDRSS_PI_28_DATA 0x00000000
    +#define DDRSS_PI_29_DATA 0x00000000
    +#define DDRSS_PI_30_DATA 0x01010102
    +#define DDRSS_PI_31_DATA 0x00000000
    +#define DDRSS_PI_32_DATA 0x00000000
    +#define DDRSS_PI_33_DATA 0x00000000
    +#define DDRSS_PI_34_DATA 0x00000001
    +#define DDRSS_PI_35_DATA 0x000000AA
    +#define DDRSS_PI_36_DATA 0x00000055
    +#define DDRSS_PI_37_DATA 0x000000B5
    +#define DDRSS_PI_38_DATA 0x0000004A
    +#define DDRSS_PI_39_DATA 0x00000056
    +#define DDRSS_PI_40_DATA 0x000000A9
    +#define DDRSS_PI_41_DATA 0x000000A9
    +#define DDRSS_PI_42_DATA 0x000000B5
    +#define DDRSS_PI_43_DATA 0x00000000
    +#define DDRSS_PI_44_DATA 0x00000000
    +#define DDRSS_PI_45_DATA 0x00010100
    +#define DDRSS_PI_46_DATA 0x00000015
    +#define DDRSS_PI_47_DATA 0x000007D0
    +#define DDRSS_PI_48_DATA 0x00000300
    +#define DDRSS_PI_49_DATA 0x00000000
    +#define DDRSS_PI_50_DATA 0x00000000
    +#define DDRSS_PI_51_DATA 0x01000000
    +#define DDRSS_PI_52_DATA 0x00010101
    +#define DDRSS_PI_53_DATA 0x01000000
    +#define DDRSS_PI_54_DATA 0x03000000
    +#define DDRSS_PI_55_DATA 0x00000000
    +#define DDRSS_PI_56_DATA 0x00001701
    +#define DDRSS_PI_57_DATA 0x00000000
    +#define DDRSS_PI_58_DATA 0x00000000
    +#define DDRSS_PI_59_DATA 0x00000000
    +#define DDRSS_PI_60_DATA 0x0A0A140A
    +#define DDRSS_PI_61_DATA 0x10020101
    +#define DDRSS_PI_62_DATA 0x01000210
    +#define DDRSS_PI_63_DATA 0x05000404
    +#define DDRSS_PI_64_DATA 0x00010001
    +#define DDRSS_PI_65_DATA 0x0001000E
    +#define DDRSS_PI_66_DATA 0x01010100
    +#define DDRSS_PI_67_DATA 0x00010000
    +#define DDRSS_PI_68_DATA 0x00000034
    +#define DDRSS_PI_69_DATA 0x00000000
    +#define DDRSS_PI_70_DATA 0x00000000
    +#define DDRSS_PI_71_DATA 0x0000FFFF
    +#define DDRSS_PI_72_DATA 0x00000000
    +#define DDRSS_PI_73_DATA 0x00000000
    +#define DDRSS_PI_74_DATA 0x00000000
    +#define DDRSS_PI_75_DATA 0x00000000
    +#define DDRSS_PI_76_DATA 0x01000000
    +#define DDRSS_PI_77_DATA 0x08020100
    +#define DDRSS_PI_78_DATA 0x00020000
    +#define DDRSS_PI_79_DATA 0x00010002
    +#define DDRSS_PI_80_DATA 0x00000001
    +#define DDRSS_PI_81_DATA 0x00020001
    +#define DDRSS_PI_82_DATA 0x00020002
    +#define DDRSS_PI_83_DATA 0x00000000
    +#define DDRSS_PI_84_DATA 0x00000000
    +#define DDRSS_PI_85_DATA 0x00000000
    +#define DDRSS_PI_86_DATA 0x00000000
    +#define DDRSS_PI_87_DATA 0x00000000
    +#define DDRSS_PI_88_DATA 0x00000000
    +#define DDRSS_PI_89_DATA 0x00000000
    +#define DDRSS_PI_90_DATA 0x00000000
    +#define DDRSS_PI_91_DATA 0x00000400
    +#define DDRSS_PI_92_DATA 0x0A090B0C
    +#define DDRSS_PI_93_DATA 0x04060708
    +#define DDRSS_PI_94_DATA 0x01000005
    +#define DDRSS_PI_95_DATA 0x00000800
    +#define DDRSS_PI_96_DATA 0x00000000
    +#define DDRSS_PI_97_DATA 0x00010008
    +#define DDRSS_PI_98_DATA 0x00000000
    +#define DDRSS_PI_99_DATA 0x0000AA00
    +#define DDRSS_PI_100_DATA 0x00000000
    +#define DDRSS_PI_101_DATA 0x00010000
    +#define DDRSS_PI_102_DATA 0x00000000
    +#define DDRSS_PI_103_DATA 0x00000000
    +#define DDRSS_PI_104_DATA 0x00000000
    +#define DDRSS_PI_105_DATA 0x00000000
    +#define DDRSS_PI_106_DATA 0x00000000
    +#define DDRSS_PI_107_DATA 0x00000000
    +#define DDRSS_PI_108_DATA 0x00000000
    +#define DDRSS_PI_109_DATA 0x00000000
    +#define DDRSS_PI_110_DATA 0x00000000
    +#define DDRSS_PI_111_DATA 0x00000000
    +#define DDRSS_PI_112_DATA 0x00000000
    +#define DDRSS_PI_113_DATA 0x00000000
    +#define DDRSS_PI_114_DATA 0x00000000
    +#define DDRSS_PI_115_DATA 0x00000000
    +#define DDRSS_PI_116_DATA 0x00000000
    +#define DDRSS_PI_117_DATA 0x00000000
    +#define DDRSS_PI_118_DATA 0x00000000
    +#define DDRSS_PI_119_DATA 0x00000000
    +#define DDRSS_PI_120_DATA 0x00000000
    +#define DDRSS_PI_121_DATA 0x00000000
    +#define DDRSS_PI_122_DATA 0x00000000
    +#define DDRSS_PI_123_DATA 0x00000000
    +#define DDRSS_PI_124_DATA 0x00000008
    +#define DDRSS_PI_125_DATA 0x00000000
    +#define DDRSS_PI_126_DATA 0x00000000
    +#define DDRSS_PI_127_DATA 0x00000000
    +#define DDRSS_PI_128_DATA 0x00000000
    +#define DDRSS_PI_129_DATA 0x00000000
    +#define DDRSS_PI_130_DATA 0x00000000
    +#define DDRSS_PI_131_DATA 0x00000000
    +#define DDRSS_PI_132_DATA 0x00000000
    +#define DDRSS_PI_133_DATA 0x00010000
    +#define DDRSS_PI_134_DATA 0x00000000
    +#define DDRSS_PI_135_DATA 0x00000000
    +#define DDRSS_PI_136_DATA 0x0000000A
    +#define DDRSS_PI_137_DATA 0x000186A0
    +#define DDRSS_PI_138_DATA 0x00000100
    +#define DDRSS_PI_139_DATA 0x00000000
    +#define DDRSS_PI_140_DATA 0x00000000
    +#define DDRSS_PI_141_DATA 0x00000000
    +#define DDRSS_PI_142_DATA 0x00000000
    +#define DDRSS_PI_143_DATA 0x00000000
    +#define DDRSS_PI_144_DATA 0x01000000
    +#define DDRSS_PI_145_DATA 0x00010003
    +#define DDRSS_PI_146_DATA 0x02000101
    +#define DDRSS_PI_147_DATA 0x01030001
    +#define DDRSS_PI_148_DATA 0x00010400
    +#define DDRSS_PI_149_DATA 0x06000105
    +#define DDRSS_PI_150_DATA 0x01070001
    +#define DDRSS_PI_151_DATA 0x00000000
    +#define DDRSS_PI_152_DATA 0x00000000
    +#define DDRSS_PI_153_DATA 0x00000000
    +#define DDRSS_PI_154_DATA 0x00010001
    +#define DDRSS_PI_155_DATA 0x00000000
    +#define DDRSS_PI_156_DATA 0x00000000
    +#define DDRSS_PI_157_DATA 0x00000000
    +#define DDRSS_PI_158_DATA 0x00000000
    +#define DDRSS_PI_159_DATA 0x00010000
    +#define DDRSS_PI_160_DATA 0x00000004
    +#define DDRSS_PI_161_DATA 0x00000000
    +#define DDRSS_PI_162_DATA 0x00000000
    +#define DDRSS_PI_163_DATA 0x00000000
    +#define DDRSS_PI_164_DATA 0x00000800
    +#define DDRSS_PI_165_DATA 0x00780078
    +#define DDRSS_PI_166_DATA 0x00101001
    +#define DDRSS_PI_167_DATA 0x00000034
    +#define DDRSS_PI_168_DATA 0x00000042
    +#define DDRSS_PI_169_DATA 0x00020042
    +#define DDRSS_PI_170_DATA 0x02000200
    +#define DDRSS_PI_171_DATA 0x00000004
    +#define DDRSS_PI_172_DATA 0x0000080C
    +#define DDRSS_PI_173_DATA 0x00081C00
    +#define DDRSS_PI_174_DATA 0x001C0000
    +#define DDRSS_PI_175_DATA 0x00000009
    +#define DDRSS_PI_176_DATA 0x000000BB
    +#define DDRSS_PI_177_DATA 0x00000090
    +#define DDRSS_PI_178_DATA 0x00000C2B
    +#define DDRSS_PI_179_DATA 0x00000090
    +#define DDRSS_PI_180_DATA 0x04000C2B
    +#define DDRSS_PI_181_DATA 0x01010404
    +#define DDRSS_PI_182_DATA 0x00001501
    +#define DDRSS_PI_183_DATA 0x001D001D
    +#define DDRSS_PI_184_DATA 0x01000100
    +#define DDRSS_PI_185_DATA 0x00000100
    +#define DDRSS_PI_186_DATA 0x00000000
    +#define DDRSS_PI_187_DATA 0x05050503
    +#define DDRSS_PI_188_DATA 0x01010C0C
    +#define DDRSS_PI_189_DATA 0x01010101
    +#define DDRSS_PI_190_DATA 0x000C0C0A
    +#define DDRSS_PI_191_DATA 0x00000000
    +#define DDRSS_PI_192_DATA 0x00000000
    +#define DDRSS_PI_193_DATA 0x04000000
    +#define DDRSS_PI_194_DATA 0x04020808
    +#define DDRSS_PI_195_DATA 0x04040204
    +#define DDRSS_PI_196_DATA 0x00090031
    +#define DDRSS_PI_197_DATA 0x00110039
    +#define DDRSS_PI_198_DATA 0x00110039
    +#define DDRSS_PI_199_DATA 0x01010101
    +#define DDRSS_PI_200_DATA 0x0002000D
    +#define DDRSS_PI_201_DATA 0x000200C8
    +#define DDRSS_PI_202_DATA 0x010000C8
    +#define DDRSS_PI_203_DATA 0x000E000E
    +#define DDRSS_PI_204_DATA 0x00C90100
    +#define DDRSS_PI_205_DATA 0x010000C9
    +#define DDRSS_PI_206_DATA 0x00C900C9
    +#define DDRSS_PI_207_DATA 0x32103200
    +#define DDRSS_PI_208_DATA 0x01013210
    +#define DDRSS_PI_209_DATA 0x0A070601
    +#define DDRSS_PI_210_DATA 0x0D09070D
    +#define DDRSS_PI_211_DATA 0x0D09070D
    +#define DDRSS_PI_212_DATA 0x000C000D
    +#define DDRSS_PI_213_DATA 0x00001000
    +#define DDRSS_PI_214_DATA 0x00000C00
    +#define DDRSS_PI_215_DATA 0x00001000
    +#define DDRSS_PI_216_DATA 0x00000C00
    +#define DDRSS_PI_217_DATA 0x02001000
    +#define DDRSS_PI_218_DATA 0x0016000D
    +#define DDRSS_PI_219_DATA 0x001600C8
    +#define DDRSS_PI_220_DATA 0x000000C8
    +#define DDRSS_PI_221_DATA 0x00001900
    +#define DDRSS_PI_222_DATA 0x32000056
    +#define DDRSS_PI_223_DATA 0x06000101
    +#define DDRSS_PI_224_DATA 0x001D0204
    +#define DDRSS_PI_225_DATA 0x32120058
    +#define DDRSS_PI_226_DATA 0x05000101
    +#define DDRSS_PI_227_DATA 0x001D0408
    +#define DDRSS_PI_228_DATA 0x32120058
    +#define DDRSS_PI_229_DATA 0x05000101
    +#define DDRSS_PI_230_DATA 0x00000408
    +#define DDRSS_PI_231_DATA 0x05030900
    +#define DDRSS_PI_232_DATA 0x00040900
    +#define DDRSS_PI_233_DATA 0x0000062B
    +#define DDRSS_PI_234_DATA 0x20010004
    +#define DDRSS_PI_235_DATA 0x0A0A0A03
    +#define DDRSS_PI_236_DATA 0x11090000
    +#define DDRSS_PI_237_DATA 0x1009000F
    +#define DDRSS_PI_238_DATA 0x000062B8
    +#define DDRSS_PI_239_DATA 0x20030023
    +#define DDRSS_PI_240_DATA 0x0C0A0C0C
    +#define DDRSS_PI_241_DATA 0x11090000
    +#define DDRSS_PI_242_DATA 0x1009000F
    +#define DDRSS_PI_243_DATA 0x000062B8
    +#define DDRSS_PI_244_DATA 0x20030023
    +#define DDRSS_PI_245_DATA 0x0C0A0C0C
    +#define DDRSS_PI_246_DATA 0x00000000
    +#define DDRSS_PI_247_DATA 0x00000176
    +#define DDRSS_PI_248_DATA 0x00000E9C
    +#define DDRSS_PI_249_DATA 0x00001856
    +#define DDRSS_PI_250_DATA 0x0000F35C
    +#define DDRSS_PI_251_DATA 0x00001856
    +#define DDRSS_PI_252_DATA 0x0000F35C
    +#define DDRSS_PI_253_DATA 0x0096000A
    +#define DDRSS_PI_254_DATA 0x03030096
    +#define DDRSS_PI_255_DATA 0x00000003
    +#define DDRSS_PI_256_DATA 0x00000000
    +#define DDRSS_PI_257_DATA 0x05030503
    +#define DDRSS_PI_258_DATA 0x00000503
    +#define DDRSS_PI_259_DATA 0x00002710
    +#define DDRSS_PI_260_DATA 0x000186A0
    +#define DDRSS_PI_261_DATA 0x00000005
    +#define DDRSS_PI_262_DATA 0x00000064
    +#define DDRSS_PI_263_DATA 0x0000000A
    +#define DDRSS_PI_264_DATA 0x00027100
    +#define DDRSS_PI_265_DATA 0x000186A0
    +#define DDRSS_PI_266_DATA 0x00000005
    +#define DDRSS_PI_267_DATA 0x00000640
    +#define DDRSS_PI_268_DATA 0x00000096
    +#define DDRSS_PI_269_DATA 0x00027100
    +#define DDRSS_PI_270_DATA 0x000186A0
    +#define DDRSS_PI_271_DATA 0x00000005
    +#define DDRSS_PI_272_DATA 0x00000640
    +#define DDRSS_PI_273_DATA 0x01000096
    +#define DDRSS_PI_274_DATA 0x00320040
    +#define DDRSS_PI_275_DATA 0x00010008
    +#define DDRSS_PI_276_DATA 0x03200040
    +#define DDRSS_PI_277_DATA 0x00010018
    +#define DDRSS_PI_278_DATA 0x03200040
    +#define DDRSS_PI_279_DATA 0x00000318
    +#define DDRSS_PI_280_DATA 0x00280028
    +#define DDRSS_PI_281_DATA 0x03040404
    +#define DDRSS_PI_282_DATA 0x00000303
    +#define DDRSS_PI_283_DATA 0x02020101
    +#define DDRSS_PI_284_DATA 0x67676767
    +#define DDRSS_PI_285_DATA 0x00000000
    +#define DDRSS_PI_286_DATA 0x55000000
    +#define DDRSS_PI_287_DATA 0x00000000
    +#define DDRSS_PI_288_DATA 0x3C00005A
    +#define DDRSS_PI_289_DATA 0x00005500
    +#define DDRSS_PI_290_DATA 0x00005A00
    +#define DDRSS_PI_291_DATA 0x0D100F3C
    +#define DDRSS_PI_292_DATA 0x0003020E
    +#define DDRSS_PI_293_DATA 0x00000001
    +#define DDRSS_PI_294_DATA 0x01000000
    +#define DDRSS_PI_295_DATA 0x00020201
    +#define DDRSS_PI_296_DATA 0x00000000
    +#define DDRSS_PI_297_DATA 0x00000000
    +#define DDRSS_PI_298_DATA 0x00000004
    +#define DDRSS_PI_299_DATA 0x00000000
    +#define DDRSS_PI_300_DATA 0x00000031
    +#define DDRSS_PI_301_DATA 0x00000000
    +#define DDRSS_PI_302_DATA 0x00000000
    +#define DDRSS_PI_303_DATA 0x00000000
    +#define DDRSS_PI_304_DATA 0x00100F27
    +#define DDRSS_PI_305_DATA 0x00000000
    +#define DDRSS_PI_306_DATA 0x00000024
    +#define DDRSS_PI_307_DATA 0x00000012
    +#define DDRSS_PI_308_DATA 0x000000B1
    +#define DDRSS_PI_309_DATA 0x00000000
    +#define DDRSS_PI_310_DATA 0x00000000
    +#define DDRSS_PI_311_DATA 0x65000000
    +#define DDRSS_PI_312_DATA 0x00150F27
    +#define DDRSS_PI_313_DATA 0x00000000
    +#define DDRSS_PI_314_DATA 0x00000024
    +#define DDRSS_PI_315_DATA 0x00000012
    +#define DDRSS_PI_316_DATA 0x000000B1
    +#define DDRSS_PI_317_DATA 0x00000000
    +#define DDRSS_PI_318_DATA 0x00000000
    +#define DDRSS_PI_319_DATA 0x65000000
    +#define DDRSS_PI_320_DATA 0x00150F27
    +#define DDRSS_PI_321_DATA 0x00000000
    +#define DDRSS_PI_322_DATA 0x00000004
    +#define DDRSS_PI_323_DATA 0x00000000
    +#define DDRSS_PI_324_DATA 0x00000031
    +#define DDRSS_PI_325_DATA 0x00000000
    +#define DDRSS_PI_326_DATA 0x00000000
    +#define DDRSS_PI_327_DATA 0x00000000
    +#define DDRSS_PI_328_DATA 0x00100F27
    +#define DDRSS_PI_329_DATA 0x00000000
    +#define DDRSS_PI_330_DATA 0x00000024
    +#define DDRSS_PI_331_DATA 0x00000012
    +#define DDRSS_PI_332_DATA 0x000000B1
    +#define DDRSS_PI_333_DATA 0x00000000
    +#define DDRSS_PI_334_DATA 0x00000000
    +#define DDRSS_PI_335_DATA 0x65000000
    +#define DDRSS_PI_336_DATA 0x00150F27
    +#define DDRSS_PI_337_DATA 0x00000000
    +#define DDRSS_PI_338_DATA 0x00000024
    +#define DDRSS_PI_339_DATA 0x00000012
    +#define DDRSS_PI_340_DATA 0x000000B1
    +#define DDRSS_PI_341_DATA 0x00000000
    +#define DDRSS_PI_342_DATA 0x00000000
    +#define DDRSS_PI_343_DATA 0x65000000
    +#define DDRSS_PI_344_DATA 0x00150F27
    +#define DDRSS_PHY_0_DATA 0x04F00000
    +#define DDRSS_PHY_1_DATA 0x00000000
    +#define DDRSS_PHY_2_DATA 0x00030200
    +#define DDRSS_PHY_3_DATA 0x00000000
    +#define DDRSS_PHY_4_DATA 0x00000000
    +#define DDRSS_PHY_5_DATA 0x01000000
    +#define DDRSS_PHY_6_DATA 0x03000400
    +#define DDRSS_PHY_7_DATA 0x00000001
    +#define DDRSS_PHY_8_DATA 0x00000001
    +#define DDRSS_PHY_9_DATA 0x00000000
    +#define DDRSS_PHY_10_DATA 0x00000000
    +#define DDRSS_PHY_11_DATA 0x01010000
    +#define DDRSS_PHY_12_DATA 0x00010000
    +#define DDRSS_PHY_13_DATA 0x00C00001
    +#define DDRSS_PHY_14_DATA 0x00CC0008
    +#define DDRSS_PHY_15_DATA 0x00660601
    +#define DDRSS_PHY_16_DATA 0x00000003
    +#define DDRSS_PHY_17_DATA 0x00000000
    +#define DDRSS_PHY_18_DATA 0x00000000
    +#define DDRSS_PHY_19_DATA 0x0000AAAA
    +#define DDRSS_PHY_20_DATA 0x00005555
    +#define DDRSS_PHY_21_DATA 0x0000B5B5
    +#define DDRSS_PHY_22_DATA 0x00004A4A
    +#define DDRSS_PHY_23_DATA 0x00005656
    +#define DDRSS_PHY_24_DATA 0x0000A9A9
    +#define DDRSS_PHY_25_DATA 0x0000B7B7
    +#define DDRSS_PHY_26_DATA 0x00004848
    +#define DDRSS_PHY_27_DATA 0x00000000
    +#define DDRSS_PHY_28_DATA 0x00000000
    +#define DDRSS_PHY_29_DATA 0x08000000
    +#define DDRSS_PHY_30_DATA 0x0F000008
    +#define DDRSS_PHY_31_DATA 0x00000F0F
    +#define DDRSS_PHY_32_DATA 0x00E4E400
    +#define DDRSS_PHY_33_DATA 0x00071020
    +#define DDRSS_PHY_34_DATA 0x000C0020
    +#define DDRSS_PHY_35_DATA 0x00062000
    +#define DDRSS_PHY_36_DATA 0x00000000
    +#define DDRSS_PHY_37_DATA 0x55555555
    +#define DDRSS_PHY_38_DATA 0xAAAAAAAA
    +#define DDRSS_PHY_39_DATA 0x55555555
    +#define DDRSS_PHY_40_DATA 0xAAAAAAAA
    +#define DDRSS_PHY_41_DATA 0x00005555
    +#define DDRSS_PHY_42_DATA 0x01000100
    +#define DDRSS_PHY_43_DATA 0x00800180
    +#define DDRSS_PHY_44_DATA 0x00000000 // [SWAP] PHY_CALVL_VREF_DRIVING_SLICE_0 //0x00000001 Normal
    +#define DDRSS_PHY_45_DATA 0x00000000
    +#define DDRSS_PHY_46_DATA 0x00000000
    +#define DDRSS_PHY_47_DATA 0x00000000
    +#define DDRSS_PHY_48_DATA 0x00000000
    +#define DDRSS_PHY_49_DATA 0x00000000
    +#define DDRSS_PHY_50_DATA 0x00000000
    +#define DDRSS_PHY_51_DATA 0x00000000
    +#define DDRSS_PHY_52_DATA 0x00000000
    +#define DDRSS_PHY_53_DATA 0x00000000
    +#define DDRSS_PHY_54_DATA 0x00000000
    +#define DDRSS_PHY_55_DATA 0x00000000
    +#define DDRSS_PHY_56_DATA 0x00000000
    +#define DDRSS_PHY_57_DATA 0x00000000
    +#define DDRSS_PHY_58_DATA 0x00000000
    +#define DDRSS_PHY_59_DATA 0x00000000
    +#define DDRSS_PHY_60_DATA 0x00000000
    +#define DDRSS_PHY_61_DATA 0x00000000
    +#define DDRSS_PHY_62_DATA 0x00000000
    +#define DDRSS_PHY_63_DATA 0x00000000
    +#define DDRSS_PHY_64_DATA 0x00000000
    +#define DDRSS_PHY_65_DATA 0x00000004
    +#define DDRSS_PHY_66_DATA 0x00000000
    +#define DDRSS_PHY_67_DATA 0x00000000
    +#define DDRSS_PHY_68_DATA 0x00000000
    +#define DDRSS_PHY_69_DATA 0x00000000
    +#define DDRSS_PHY_70_DATA 0x00000000
    +#define DDRSS_PHY_71_DATA 0x00000000
    +#define DDRSS_PHY_72_DATA 0x041F07FF
    +#define DDRSS_PHY_73_DATA 0x00000000
    +#define DDRSS_PHY_74_DATA 0x01CC0B01
    +#define DDRSS_PHY_75_DATA 0x1003CC0B
    +#define DDRSS_PHY_76_DATA 0x20000140
    +#define DDRSS_PHY_77_DATA 0x07FF0200
    +#define DDRSS_PHY_78_DATA 0x0000DD01
    +#define DDRSS_PHY_79_DATA 0x00100303
    +#define DDRSS_PHY_80_DATA 0x00000000
    +#define DDRSS_PHY_81_DATA 0x00000000
    +#define DDRSS_PHY_82_DATA 0x00021000
    +#define DDRSS_PHY_83_DATA 0x00100010
    +#define DDRSS_PHY_84_DATA 0x00100010
    +#define DDRSS_PHY_85_DATA 0x00100010
    +#define DDRSS_PHY_86_DATA 0x00100010
    +#define DDRSS_PHY_87_DATA 0x02020010
    +#define DDRSS_PHY_88_DATA 0x51516041
    +#define DDRSS_PHY_89_DATA 0x31C06000
    +#define DDRSS_PHY_90_DATA 0x07AB0340
    +#define DDRSS_PHY_91_DATA 0x0000C0C0
    +#define DDRSS_PHY_92_DATA 0x04050000
    +#define DDRSS_PHY_93_DATA 0x00000504
    +#define DDRSS_PHY_94_DATA 0x42100010
    +#define DDRSS_PHY_95_DATA 0x010C053E
    +#define DDRSS_PHY_96_DATA 0x000F0C1D
    +#define DDRSS_PHY_97_DATA 0x01000140
    +#define DDRSS_PHY_98_DATA 0x007A0120
    +#define DDRSS_PHY_99_DATA 0x00000C00
    +#define DDRSS_PHY_100_DATA 0x000001CC
    +#define DDRSS_PHY_101_DATA 0x20100200
    +#define DDRSS_PHY_102_DATA 0x00000005
    +#define DDRSS_PHY_103_DATA 0x56743210 // [SWIZZLE] PHY_DQ_DM_SWIZZLE0_0 //0x76543210 Swizzle DV
    +#define DDRSS_PHY_104_DATA 0x00000008
    +#define DDRSS_PHY_105_DATA 0x034C034C
    +#define DDRSS_PHY_106_DATA 0x034C034C
    +#define DDRSS_PHY_107_DATA 0x034C034C
    +#define DDRSS_PHY_108_DATA 0x034C034C
    +#define DDRSS_PHY_109_DATA 0x0000034C
    +#define DDRSS_PHY_110_DATA 0x00008000
    +#define DDRSS_PHY_111_DATA 0x00800080
    +#define DDRSS_PHY_112_DATA 0x00800080
    +#define DDRSS_PHY_113_DATA 0x00800080
    +#define DDRSS_PHY_114_DATA 0x00800080
    +#define DDRSS_PHY_115_DATA 0x00800080
    +#define DDRSS_PHY_116_DATA 0x00800080
    +#define DDRSS_PHY_117_DATA 0x00800080
    +#define DDRSS_PHY_118_DATA 0x00800080
    +#define DDRSS_PHY_119_DATA 0x01800080
    +#define DDRSS_PHY_120_DATA 0x01000000
    +#define DDRSS_PHY_121_DATA 0x00000000
    +#define DDRSS_PHY_122_DATA 0x00000000
    +#define DDRSS_PHY_123_DATA 0x00080200
    +#define DDRSS_PHY_124_DATA 0x00000000
    +#define DDRSS_PHY_125_DATA 0x0000F0F0
    +#define DDRSS_PHY_126_DATA 0x00000000
    +#define DDRSS_PHY_127_DATA 0x00000000
    +#define DDRSS_PHY_128_DATA 0x00000000
    +#define DDRSS_PHY_129_DATA 0x00000000
    +#define DDRSS_PHY_130_DATA 0x00000000
    +#define DDRSS_PHY_131_DATA 0x00000000
    +#define DDRSS_PHY_132_DATA 0x00000000
    +#define DDRSS_PHY_133_DATA 0x00000000
    +#define DDRSS_PHY_134_DATA 0x00000000
    +#define DDRSS_PHY_135_DATA 0x00000000
    +#define DDRSS_PHY_136_DATA 0x00000000
    +#define DDRSS_PHY_137_DATA 0x00000000
    +#define DDRSS_PHY_138_DATA 0x00000000
    +#define DDRSS_PHY_139_DATA 0x00000000
    +#define DDRSS_PHY_140_DATA 0x00000000
    +#define DDRSS_PHY_141_DATA 0x00000000
    +#define DDRSS_PHY_142_DATA 0x00000000
    +#define DDRSS_PHY_143_DATA 0x00000000
    +#define DDRSS_PHY_144_DATA 0x00000000
    +#define DDRSS_PHY_145_DATA 0x00000000
    +#define DDRSS_PHY_146_DATA 0x00000000
    +#define DDRSS_PHY_147_DATA 0x00000000
    +#define DDRSS_PHY_148_DATA 0x00000000
    +#define DDRSS_PHY_149_DATA 0x00000000
    +#define DDRSS_PHY_150_DATA 0x00000000
    +#define DDRSS_PHY_151_DATA 0x00000000
    +#define DDRSS_PHY_152_DATA 0x00000000
    +#define DDRSS_PHY_153_DATA 0x00000000
    +#define DDRSS_PHY_154_DATA 0x00000000
    +#define DDRSS_PHY_155_DATA 0x00000000
    +#define DDRSS_PHY_156_DATA 0x00000000
    +#define DDRSS_PHY_157_DATA 0x00000000
    +#define DDRSS_PHY_158_DATA 0x00000000
    +#define DDRSS_PHY_159_DATA 0x00000000
    +#define DDRSS_PHY_160_DATA 0x00000000
    +#define DDRSS_PHY_161_DATA 0x00000000
    +#define DDRSS_PHY_162_DATA 0x00000000
    +#define DDRSS_PHY_163_DATA 0x00000000
    +#define DDRSS_PHY_164_DATA 0x00000000
    +#define DDRSS_PHY_165_DATA 0x00000000
    +#define DDRSS_PHY_166_DATA 0x00000000
    +#define DDRSS_PHY_167_DATA 0x00000000
    +#define DDRSS_PHY_168_DATA 0x00000000
    +#define DDRSS_PHY_169_DATA 0x00000000
    +#define DDRSS_PHY_170_DATA 0x00000000
    +#define DDRSS_PHY_171_DATA 0x00000000
    +#define DDRSS_PHY_172_DATA 0x00000000
    +#define DDRSS_PHY_173_DATA 0x00000000
    +#define DDRSS_PHY_174_DATA 0x00000000
    +#define DDRSS_PHY_175_DATA 0x00000000
    +#define DDRSS_PHY_176_DATA 0x00000000
    +#define DDRSS_PHY_177_DATA 0x00000000
    +#define DDRSS_PHY_178_DATA 0x00000000
    +#define DDRSS_PHY_179_DATA 0x00000000
    +#define DDRSS_PHY_180_DATA 0x00000000
    +#define DDRSS_PHY_181_DATA 0x00000000
    +#define DDRSS_PHY_182_DATA 0x00000000
    +#define DDRSS_PHY_183_DATA 0x00000000
    +#define DDRSS_PHY_184_DATA 0x00000000
    +#define DDRSS_PHY_185_DATA 0x00000000
    +#define DDRSS_PHY_186_DATA 0x00000000
    +#define DDRSS_PHY_187_DATA 0x00000000
    +#define DDRSS_PHY_188_DATA 0x00000000
    +#define DDRSS_PHY_189_DATA 0x00000000
    +#define DDRSS_PHY_190_DATA 0x00000000
    +#define DDRSS_PHY_191_DATA 0x00000000
    +#define DDRSS_PHY_192_DATA 0x00000000
    +#define DDRSS_PHY_193_DATA 0x00000000
    +#define DDRSS_PHY_194_DATA 0x00000000
    +#define DDRSS_PHY_195_DATA 0x00000000
    +#define DDRSS_PHY_196_DATA 0x00000000
    +#define DDRSS_PHY_197_DATA 0x00000000
    +#define DDRSS_PHY_198_DATA 0x00000000
    +#define DDRSS_PHY_199_DATA 0x00000000
    +#define DDRSS_PHY_200_DATA 0x00000000
    +#define DDRSS_PHY_201_DATA 0x00000000
    +#define DDRSS_PHY_202_DATA 0x00000000
    +#define DDRSS_PHY_203_DATA 0x00000000
    +#define DDRSS_PHY_204_DATA 0x00000000
    +#define DDRSS_PHY_205_DATA 0x00000000
    +#define DDRSS_PHY_206_DATA 0x00000000
    +#define DDRSS_PHY_207_DATA 0x00000000
    +#define DDRSS_PHY_208_DATA 0x00000000
    +#define DDRSS_PHY_209_DATA 0x00000000
    +#define DDRSS_PHY_210_DATA 0x00000000
    +#define DDRSS_PHY_211_DATA 0x00000000
    +#define DDRSS_PHY_212_DATA 0x00000000
    +#define DDRSS_PHY_213_DATA 0x00000000
    +#define DDRSS_PHY_214_DATA 0x00000000
    +#define DDRSS_PHY_215_DATA 0x00000000
    +#define DDRSS_PHY_216_DATA 0x00000000
    +#define DDRSS_PHY_217_DATA 0x00000000
    +#define DDRSS_PHY_218_DATA 0x00000000
    +#define DDRSS_PHY_219_DATA 0x00000000
    +#define DDRSS_PHY_220_DATA 0x00000000
    +#define DDRSS_PHY_221_DATA 0x00000000
    +#define DDRSS_PHY_222_DATA 0x00000000
    +#define DDRSS_PHY_223_DATA 0x00000000
    +#define DDRSS_PHY_224_DATA 0x00000000
    +#define DDRSS_PHY_225_DATA 0x00000000
    +#define DDRSS_PHY_226_DATA 0x00000000
    +#define DDRSS_PHY_227_DATA 0x00000000
    +#define DDRSS_PHY_228_DATA 0x00000000
    +#define DDRSS_PHY_229_DATA 0x00000000
    +#define DDRSS_PHY_230_DATA 0x00000000
    +#define DDRSS_PHY_231_DATA 0x00000000
    +#define DDRSS_PHY_232_DATA 0x00000000
    +#define DDRSS_PHY_233_DATA 0x00000000
    +#define DDRSS_PHY_234_DATA 0x00000000
    +#define DDRSS_PHY_235_DATA 0x00000000
    +#define DDRSS_PHY_236_DATA 0x00000000
    +#define DDRSS_PHY_237_DATA 0x00000000
    +#define DDRSS_PHY_238_DATA 0x00000000
    +#define DDRSS_PHY_239_DATA 0x00000000
    +#define DDRSS_PHY_240_DATA 0x00000000
    +#define DDRSS_PHY_241_DATA 0x00000000
    +#define DDRSS_PHY_242_DATA 0x00000000
    +#define DDRSS_PHY_243_DATA 0x00000000
    +#define DDRSS_PHY_244_DATA 0x00000000
    +#define DDRSS_PHY_245_DATA 0x00000000
    +#define DDRSS_PHY_246_DATA 0x00000000
    +#define DDRSS_PHY_247_DATA 0x00000000
    +#define DDRSS_PHY_248_DATA 0x00000000
    +#define DDRSS_PHY_249_DATA 0x00000000
    +#define DDRSS_PHY_250_DATA 0x00000000
    +#define DDRSS_PHY_251_DATA 0x00000000
    +#define DDRSS_PHY_252_DATA 0x00000000
    +#define DDRSS_PHY_253_DATA 0x00000000
    +#define DDRSS_PHY_254_DATA 0x00000000
    +#define DDRSS_PHY_255_DATA 0x00000000
    +#define DDRSS_PHY_256_DATA 0x04F00000
    +#define DDRSS_PHY_257_DATA 0x00000000
    +#define DDRSS_PHY_258_DATA 0x00030200
    +#define DDRSS_PHY_259_DATA 0x00000000
    +#define DDRSS_PHY_260_DATA 0x00000000
    +#define DDRSS_PHY_261_DATA 0x01000000
    +#define DDRSS_PHY_262_DATA 0x03000400
    +#define DDRSS_PHY_263_DATA 0x00000001
    +#define DDRSS_PHY_264_DATA 0x00000001
    +#define DDRSS_PHY_265_DATA 0x00000000
    +#define DDRSS_PHY_266_DATA 0x00000000
    +#define DDRSS_PHY_267_DATA 0x01010000
    +#define DDRSS_PHY_268_DATA 0x00010000
    +#define DDRSS_PHY_269_DATA 0x00C00001
    +#define DDRSS_PHY_270_DATA 0x00CC0008
    +#define DDRSS_PHY_271_DATA 0x00660601
    +#define DDRSS_PHY_272_DATA 0x00000003
    +#define DDRSS_PHY_273_DATA 0x00000000
    +#define DDRSS_PHY_274_DATA 0x00000000
    +#define DDRSS_PHY_275_DATA 0x0000AAAA
    +#define DDRSS_PHY_276_DATA 0x00005555
    +#define DDRSS_PHY_277_DATA 0x0000B5B5
    +#define DDRSS_PHY_278_DATA 0x00004A4A
    +#define DDRSS_PHY_279_DATA 0x00005656
    +#define DDRSS_PHY_280_DATA 0x0000A9A9
    +#define DDRSS_PHY_281_DATA 0x0000B7B7
    +#define DDRSS_PHY_282_DATA 0x00004848
    +#define DDRSS_PHY_283_DATA 0x00000000
    +#define DDRSS_PHY_284_DATA 0x00000000
    +#define DDRSS_PHY_285_DATA 0x08000000
    +#define DDRSS_PHY_286_DATA 0x0F000008
    +#define DDRSS_PHY_287_DATA 0x00000F0F
    +#define DDRSS_PHY_288_DATA 0x00E4E400
    +#define DDRSS_PHY_289_DATA 0x00071020
    +#define DDRSS_PHY_290_DATA 0x000C0020
    +#define DDRSS_PHY_291_DATA 0x00062000
    +#define DDRSS_PHY_292_DATA 0x00000000
    +#define DDRSS_PHY_293_DATA 0x55555555
    +#define DDRSS_PHY_294_DATA 0xAAAAAAAA
    +#define DDRSS_PHY_295_DATA 0x55555555
    +#define DDRSS_PHY_296_DATA 0xAAAAAAAA
    +#define DDRSS_PHY_297_DATA 0x00005555
    +#define DDRSS_PHY_298_DATA 0x01000100
    +#define DDRSS_PHY_299_DATA 0x00800180
    +#define DDRSS_PHY_300_DATA 0x00000001 // [SWAP] PHY_CALVL_VREF_DRIVING_SLICE_1 //0x00000000 Normal
    +#define DDRSS_PHY_301_DATA 0x00000000
    +#define DDRSS_PHY_302_DATA 0x00000000
    +#define DDRSS_PHY_303_DATA 0x00000000
    +#define DDRSS_PHY_304_DATA 0x00000000
    +#define DDRSS_PHY_305_DATA 0x00000000
    +#define DDRSS_PHY_306_DATA 0x00000000
    +#define DDRSS_PHY_307_DATA 0x00000000
    +#define DDRSS_PHY_308_DATA 0x00000000
    +#define DDRSS_PHY_309_DATA 0x00000000
    +#define DDRSS_PHY_310_DATA 0x00000000
    +#define DDRSS_PHY_311_DATA 0x00000000
    +#define DDRSS_PHY_312_DATA 0x00000000
    +#define DDRSS_PHY_313_DATA 0x00000000
    +#define DDRSS_PHY_314_DATA 0x00000000
    +#define DDRSS_PHY_315_DATA 0x00000000
    +#define DDRSS_PHY_316_DATA 0x00000000
    +#define DDRSS_PHY_317_DATA 0x00000000
    +#define DDRSS_PHY_318_DATA 0x00000000
    +#define DDRSS_PHY_319_DATA 0x00000000
    +#define DDRSS_PHY_320_DATA 0x00000000
    +#define DDRSS_PHY_321_DATA 0x00000004
    +#define DDRSS_PHY_322_DATA 0x00000000
    +#define DDRSS_PHY_323_DATA 0x00000000
    +#define DDRSS_PHY_324_DATA 0x00000000
    +#define DDRSS_PHY_325_DATA 0x00000000
    +#define DDRSS_PHY_326_DATA 0x00000000
    +#define DDRSS_PHY_327_DATA 0x00000000
    +#define DDRSS_PHY_328_DATA 0x041F07FF
    +#define DDRSS_PHY_329_DATA 0x00000000
    +#define DDRSS_PHY_330_DATA 0x01CC0B01
    +#define DDRSS_PHY_331_DATA 0x1003CC0B
    +#define DDRSS_PHY_332_DATA 0x20000140
    +#define DDRSS_PHY_333_DATA 0x07FF0200
    +#define DDRSS_PHY_334_DATA 0x0000DD01
    +#define DDRSS_PHY_335_DATA 0x00100303
    +#define DDRSS_PHY_336_DATA 0x00000000
    +#define DDRSS_PHY_337_DATA 0x00000000
    +#define DDRSS_PHY_338_DATA 0x00021000
    +#define DDRSS_PHY_339_DATA 0x00100010
    +#define DDRSS_PHY_340_DATA 0x00100010
    +#define DDRSS_PHY_341_DATA 0x00100010
    +#define DDRSS_PHY_342_DATA 0x00100010
    +#define DDRSS_PHY_343_DATA 0x02020010
    +#define DDRSS_PHY_344_DATA 0x51516041
    +#define DDRSS_PHY_345_DATA 0x31C06000
    +#define DDRSS_PHY_346_DATA 0x07AB0340
    +#define DDRSS_PHY_347_DATA 0x0000C0C0
    +#define DDRSS_PHY_348_DATA 0x04050000
    +#define DDRSS_PHY_349_DATA 0x00000504
    +#define DDRSS_PHY_350_DATA 0x42100010
    +#define DDRSS_PHY_351_DATA 0x010C053E
    +#define DDRSS_PHY_352_DATA 0x000F0C1D
    +#define DDRSS_PHY_353_DATA 0x01000140
    +#define DDRSS_PHY_354_DATA 0x007A0120
    +#define DDRSS_PHY_355_DATA 0x00000C00
    +#define DDRSS_PHY_356_DATA 0x000001CC
    +#define DDRSS_PHY_357_DATA 0x20100200
    +#define DDRSS_PHY_358_DATA 0x00000005
    +#define DDRSS_PHY_359_DATA 0x01324567 // [SWIZZLE] PHY_DQ_DM_SWIZZLE0_1 //0x76543210 //Normal
    +#define DDRSS_PHY_360_DATA 0x00000008
    +#define DDRSS_PHY_361_DATA 0x034C034C
    +#define DDRSS_PHY_362_DATA 0x034C034C
    +#define DDRSS_PHY_363_DATA 0x034C034C
    +#define DDRSS_PHY_364_DATA 0x034C034C
    +#define DDRSS_PHY_365_DATA 0x0000034C
    +#define DDRSS_PHY_366_DATA 0x00008000
    +#define DDRSS_PHY_367_DATA 0x00800080
    +#define DDRSS_PHY_368_DATA 0x00800080
    +#define DDRSS_PHY_369_DATA 0x00800080
    +#define DDRSS_PHY_370_DATA 0x00800080
    +#define DDRSS_PHY_371_DATA 0x00800080
    +#define DDRSS_PHY_372_DATA 0x00800080
    +#define DDRSS_PHY_373_DATA 0x00800080
    +#define DDRSS_PHY_374_DATA 0x00800080
    +#define DDRSS_PHY_375_DATA 0x01800080
    +#define DDRSS_PHY_376_DATA 0x01000000
    +#define DDRSS_PHY_377_DATA 0x00000000
    +#define DDRSS_PHY_378_DATA 0x00000000
    +#define DDRSS_PHY_379_DATA 0x00080200
    +#define DDRSS_PHY_380_DATA 0x00000000
    +#define DDRSS_PHY_381_DATA 0x0000F0F0
    +#define DDRSS_PHY_382_DATA 0x00000000
    +#define DDRSS_PHY_383_DATA 0x00000000
    +#define DDRSS_PHY_384_DATA 0x00000000
    +#define DDRSS_PHY_385_DATA 0x00000000
    +#define DDRSS_PHY_386_DATA 0x00000000
    +#define DDRSS_PHY_387_DATA 0x00000000
    +#define DDRSS_PHY_388_DATA 0x00000000
    +#define DDRSS_PHY_389_DATA 0x00000000
    +#define DDRSS_PHY_390_DATA 0x00000000
    +#define DDRSS_PHY_391_DATA 0x00000000
    +#define DDRSS_PHY_392_DATA 0x00000000
    +#define DDRSS_PHY_393_DATA 0x00000000
    +#define DDRSS_PHY_394_DATA 0x00000000
    +#define DDRSS_PHY_395_DATA 0x00000000
    +#define DDRSS_PHY_396_DATA 0x00000000
    +#define DDRSS_PHY_397_DATA 0x00000000
    +#define DDRSS_PHY_398_DATA 0x00000000
    +#define DDRSS_PHY_399_DATA 0x00000000
    +#define DDRSS_PHY_400_DATA 0x00000000
    +#define DDRSS_PHY_401_DATA 0x00000000
    +#define DDRSS_PHY_402_DATA 0x00000000
    +#define DDRSS_PHY_403_DATA 0x00000000
    +#define DDRSS_PHY_404_DATA 0x00000000
    +#define DDRSS_PHY_405_DATA 0x00000000
    +#define DDRSS_PHY_406_DATA 0x00000000
    +#define DDRSS_PHY_407_DATA 0x00000000
    +#define DDRSS_PHY_408_DATA 0x00000000
    +#define DDRSS_PHY_409_DATA 0x00000000
    +#define DDRSS_PHY_410_DATA 0x00000000
    +#define DDRSS_PHY_411_DATA 0x00000000
    +#define DDRSS_PHY_412_DATA 0x00000000
    +#define DDRSS_PHY_413_DATA 0x00000000
    +#define DDRSS_PHY_414_DATA 0x00000000
    +#define DDRSS_PHY_415_DATA 0x00000000
    +#define DDRSS_PHY_416_DATA 0x00000000
    +#define DDRSS_PHY_417_DATA 0x00000000
    +#define DDRSS_PHY_418_DATA 0x00000000
    +#define DDRSS_PHY_419_DATA 0x00000000
    +#define DDRSS_PHY_420_DATA 0x00000000
    +#define DDRSS_PHY_421_DATA 0x00000000
    +#define DDRSS_PHY_422_DATA 0x00000000
    +#define DDRSS_PHY_423_DATA 0x00000000
    +#define DDRSS_PHY_424_DATA 0x00000000
    +#define DDRSS_PHY_425_DATA 0x00000000
    +#define DDRSS_PHY_426_DATA 0x00000000
    +#define DDRSS_PHY_427_DATA 0x00000000
    +#define DDRSS_PHY_428_DATA 0x00000000
    +#define DDRSS_PHY_429_DATA 0x00000000
    +#define DDRSS_PHY_430_DATA 0x00000000
    +#define DDRSS_PHY_431_DATA 0x00000000
    +#define DDRSS_PHY_432_DATA 0x00000000
    +#define DDRSS_PHY_433_DATA 0x00000000
    +#define DDRSS_PHY_434_DATA 0x00000000
    +#define DDRSS_PHY_435_DATA 0x00000000
    +#define DDRSS_PHY_436_DATA 0x00000000
    +#define DDRSS_PHY_437_DATA 0x00000000
    +#define DDRSS_PHY_438_DATA 0x00000000
    +#define DDRSS_PHY_439_DATA 0x00000000
    +#define DDRSS_PHY_440_DATA 0x00000000
    +#define DDRSS_PHY_441_DATA 0x00000000
    +#define DDRSS_PHY_442_DATA 0x00000000
    +#define DDRSS_PHY_443_DATA 0x00000000
    +#define DDRSS_PHY_444_DATA 0x00000000
    +#define DDRSS_PHY_445_DATA 0x00000000
    +#define DDRSS_PHY_446_DATA 0x00000000
    +#define DDRSS_PHY_447_DATA 0x00000000
    +#define DDRSS_PHY_448_DATA 0x00000000
    +#define DDRSS_PHY_449_DATA 0x00000000
    +#define DDRSS_PHY_450_DATA 0x00000000
    +#define DDRSS_PHY_451_DATA 0x00000000
    +#define DDRSS_PHY_452_DATA 0x00000000
    +#define DDRSS_PHY_453_DATA 0x00000000
    +#define DDRSS_PHY_454_DATA 0x00000000
    +#define DDRSS_PHY_455_DATA 0x00000000
    +#define DDRSS_PHY_456_DATA 0x00000000
    +#define DDRSS_PHY_457_DATA 0x00000000
    +#define DDRSS_PHY_458_DATA 0x00000000
    +#define DDRSS_PHY_459_DATA 0x00000000
    +#define DDRSS_PHY_460_DATA 0x00000000
    +#define DDRSS_PHY_461_DATA 0x00000000
    +#define DDRSS_PHY_462_DATA 0x00000000
    +#define DDRSS_PHY_463_DATA 0x00000000
    +#define DDRSS_PHY_464_DATA 0x00000000
    +#define DDRSS_PHY_465_DATA 0x00000000
    +#define DDRSS_PHY_466_DATA 0x00000000
    +#define DDRSS_PHY_467_DATA 0x00000000
    +#define DDRSS_PHY_468_DATA 0x00000000
    +#define DDRSS_PHY_469_DATA 0x00000000
    +#define DDRSS_PHY_470_DATA 0x00000000
    +#define DDRSS_PHY_471_DATA 0x00000000
    +#define DDRSS_PHY_472_DATA 0x00000000
    +#define DDRSS_PHY_473_DATA 0x00000000
    +#define DDRSS_PHY_474_DATA 0x00000000
    +#define DDRSS_PHY_475_DATA 0x00000000
    +#define DDRSS_PHY_476_DATA 0x00000000
    +#define DDRSS_PHY_477_DATA 0x00000000
    +#define DDRSS_PHY_478_DATA 0x00000000
    +#define DDRSS_PHY_479_DATA 0x00000000
    +#define DDRSS_PHY_480_DATA 0x00000000
    +#define DDRSS_PHY_481_DATA 0x00000000
    +#define DDRSS_PHY_482_DATA 0x00000000
    +#define DDRSS_PHY_483_DATA 0x00000000
    +#define DDRSS_PHY_484_DATA 0x00000000
    +#define DDRSS_PHY_485_DATA 0x00000000
    +#define DDRSS_PHY_486_DATA 0x00000000
    +#define DDRSS_PHY_487_DATA 0x00000000
    +#define DDRSS_PHY_488_DATA 0x00000000
    +#define DDRSS_PHY_489_DATA 0x00000000
    +#define DDRSS_PHY_490_DATA 0x00000000
    +#define DDRSS_PHY_491_DATA 0x00000000
    +#define DDRSS_PHY_492_DATA 0x00000000
    +#define DDRSS_PHY_493_DATA 0x00000000
    +#define DDRSS_PHY_494_DATA 0x00000000
    +#define DDRSS_PHY_495_DATA 0x00000000
    +#define DDRSS_PHY_496_DATA 0x00000000
    +#define DDRSS_PHY_497_DATA 0x00000000
    +#define DDRSS_PHY_498_DATA 0x00000000
    +#define DDRSS_PHY_499_DATA 0x00000000
    +#define DDRSS_PHY_500_DATA 0x00000000
    +#define DDRSS_PHY_501_DATA 0x00000000
    +#define DDRSS_PHY_502_DATA 0x00000000
    +#define DDRSS_PHY_503_DATA 0x00000000
    +#define DDRSS_PHY_504_DATA 0x00000000
    +#define DDRSS_PHY_505_DATA 0x00000000
    +#define DDRSS_PHY_506_DATA 0x00000000
    +#define DDRSS_PHY_507_DATA 0x00000000
    +#define DDRSS_PHY_508_DATA 0x00000000
    +#define DDRSS_PHY_509_DATA 0x00000000
    +#define DDRSS_PHY_510_DATA 0x00000000
    +#define DDRSS_PHY_511_DATA 0x00000000
    +#define DDRSS_PHY_512_DATA 0x00000000
    +#define DDRSS_PHY_513_DATA 0x00000000
    +#define DDRSS_PHY_514_DATA 0x00000000
    +#define DDRSS_PHY_515_DATA 0x00000000
    +#define DDRSS_PHY_516_DATA 0x00000000
    +#define DDRSS_PHY_517_DATA 0x00000100
    +#define DDRSS_PHY_518_DATA 0x00000200
    +#define DDRSS_PHY_519_DATA 0x00000000
    +#define DDRSS_PHY_520_DATA 0x00000000
    +#define DDRSS_PHY_521_DATA 0x00000000
    +#define DDRSS_PHY_522_DATA 0x00000000
    +#define DDRSS_PHY_523_DATA 0x00400000
    +#define DDRSS_PHY_524_DATA 0x00000080
    +#define DDRSS_PHY_525_DATA 0x00DCBA98
    +#define DDRSS_PHY_526_DATA 0x03000000
    +#define DDRSS_PHY_527_DATA 0x00200000
    +#define DDRSS_PHY_528_DATA 0x00000000
    +#define DDRSS_PHY_529_DATA 0x00000000
    +#define DDRSS_PHY_530_DATA 0x00000000
    +#define DDRSS_PHY_531_DATA 0x00000000
    +#define DDRSS_PHY_532_DATA 0x0000002A
    +#define DDRSS_PHY_533_DATA 0x00000015
    +#define DDRSS_PHY_534_DATA 0x00000015
    +#define DDRSS_PHY_535_DATA 0x0000002A
    +#define DDRSS_PHY_536_DATA 0x00000033
    +#define DDRSS_PHY_537_DATA 0x0000000C
    +#define DDRSS_PHY_538_DATA 0x0000000C
    +#define DDRSS_PHY_539_DATA 0x00000033
    +#define DDRSS_PHY_540_DATA 0x0A418820
    +#define DDRSS_PHY_541_DATA 0x003F0000
    +#define DDRSS_PHY_542_DATA 0x000F013F
    +#define DDRSS_PHY_543_DATA 0x0000000F
    +#define DDRSS_PHY_544_DATA 0x020002CC
    +#define DDRSS_PHY_545_DATA 0x00030000
    +#define DDRSS_PHY_546_DATA 0x00000300
    +#define DDRSS_PHY_547_DATA 0x00000300
    +#define DDRSS_PHY_548_DATA 0x00000300
    +#define DDRSS_PHY_549_DATA 0x00000300
    +#define DDRSS_PHY_550_DATA 0x00000300
    +#define DDRSS_PHY_551_DATA 0x42080010
    +#define DDRSS_PHY_552_DATA 0x0000803E
    +#define DDRSS_PHY_553_DATA 0x00000003
    +#define DDRSS_PHY_554_DATA 0x00000002
    +#define DDRSS_PHY_555_DATA 0x00000000
    +#define DDRSS_PHY_556_DATA 0x00000000
    +#define DDRSS_PHY_557_DATA 0x00000000
    +#define DDRSS_PHY_558_DATA 0x00000000
    +#define DDRSS_PHY_559_DATA 0x00000000
    +#define DDRSS_PHY_560_DATA 0x00000000
    +#define DDRSS_PHY_561_DATA 0x00000000
    +#define DDRSS_PHY_562_DATA 0x00000000
    +#define DDRSS_PHY_563_DATA 0x00000000
    +#define DDRSS_PHY_564_DATA 0x00000000
    +#define DDRSS_PHY_565_DATA 0x00000000
    +#define DDRSS_PHY_566_DATA 0x00000000
    +#define DDRSS_PHY_567_DATA 0x00000000
    +#define DDRSS_PHY_568_DATA 0x00000000
    +#define DDRSS_PHY_569_DATA 0x00000000
    +#define DDRSS_PHY_570_DATA 0x00000000
    +#define DDRSS_PHY_571_DATA 0x00000000
    +#define DDRSS_PHY_572_DATA 0x00000000
    +#define DDRSS_PHY_573_DATA 0x00000000
    +#define DDRSS_PHY_574_DATA 0x00000000
    +#define DDRSS_PHY_575_DATA 0x00000000
    +#define DDRSS_PHY_576_DATA 0x00000000
    +#define DDRSS_PHY_577_DATA 0x00000000
    +#define DDRSS_PHY_578_DATA 0x00000000
    +#define DDRSS_PHY_579_DATA 0x00000000
    +#define DDRSS_PHY_580_DATA 0x00000000
    +#define DDRSS_PHY_581_DATA 0x00000000
    +#define DDRSS_PHY_582_DATA 0x00000000
    +#define DDRSS_PHY_583_DATA 0x00000000
    +#define DDRSS_PHY_584_DATA 0x00000000
    +#define DDRSS_PHY_585_DATA 0x00000000
    +#define DDRSS_PHY_586_DATA 0x00000000
    +#define DDRSS_PHY_587_DATA 0x00000000
    +#define DDRSS_PHY_588_DATA 0x00000000
    +#define DDRSS_PHY_589_DATA 0x00000000
    +#define DDRSS_PHY_590_DATA 0x00000000
    +#define DDRSS_PHY_591_DATA 0x00000000
    +#define DDRSS_PHY_592_DATA 0x00000000
    +#define DDRSS_PHY_593_DATA 0x00000000
    +#define DDRSS_PHY_594_DATA 0x00000000
    +#define DDRSS_PHY_595_DATA 0x00000000
    +#define DDRSS_PHY_596_DATA 0x00000000
    +#define DDRSS_PHY_597_DATA 0x00000000
    +#define DDRSS_PHY_598_DATA 0x00000000
    +#define DDRSS_PHY_599_DATA 0x00000000
    +#define DDRSS_PHY_600_DATA 0x00000000
    +#define DDRSS_PHY_601_DATA 0x00000000
    +#define DDRSS_PHY_602_DATA 0x00000000
    +#define DDRSS_PHY_603_DATA 0x00000000
    +#define DDRSS_PHY_604_DATA 0x00000000
    +#define DDRSS_PHY_605_DATA 0x00000000
    +#define DDRSS_PHY_606_DATA 0x00000000
    +#define DDRSS_PHY_607_DATA 0x00000000
    +#define DDRSS_PHY_608_DATA 0x00000000
    +#define DDRSS_PHY_609_DATA 0x00000000
    +#define DDRSS_PHY_610_DATA 0x00000000
    +#define DDRSS_PHY_611_DATA 0x00000000
    +#define DDRSS_PHY_612_DATA 0x00000000
    +#define DDRSS_PHY_613_DATA 0x00000000
    +#define DDRSS_PHY_614_DATA 0x00000000
    +#define DDRSS_PHY_615_DATA 0x00000000
    +#define DDRSS_PHY_616_DATA 0x00000000
    +#define DDRSS_PHY_617_DATA 0x00000000
    +#define DDRSS_PHY_618_DATA 0x00000000
    +#define DDRSS_PHY_619_DATA 0x00000000
    +#define DDRSS_PHY_620_DATA 0x00000000
    +#define DDRSS_PHY_621_DATA 0x00000000
    +#define DDRSS_PHY_622_DATA 0x00000000
    +#define DDRSS_PHY_623_DATA 0x00000000
    +#define DDRSS_PHY_624_DATA 0x00000000
    +#define DDRSS_PHY_625_DATA 0x00000000
    +#define DDRSS_PHY_626_DATA 0x00000000
    +#define DDRSS_PHY_627_DATA 0x00000000
    +#define DDRSS_PHY_628_DATA 0x00000000
    +#define DDRSS_PHY_629_DATA 0x00000000
    +#define DDRSS_PHY_630_DATA 0x00000000
    +#define DDRSS_PHY_631_DATA 0x00000000
    +#define DDRSS_PHY_632_DATA 0x00000000
    +#define DDRSS_PHY_633_DATA 0x00000000
    +#define DDRSS_PHY_634_DATA 0x00000000
    +#define DDRSS_PHY_635_DATA 0x00000000
    +#define DDRSS_PHY_636_DATA 0x00000000
    +#define DDRSS_PHY_637_DATA 0x00000000
    +#define DDRSS_PHY_638_DATA 0x00000000
    +#define DDRSS_PHY_639_DATA 0x00000000
    +#define DDRSS_PHY_640_DATA 0x00000000
    +#define DDRSS_PHY_641_DATA 0x00000000
    +#define DDRSS_PHY_642_DATA 0x00000000
    +#define DDRSS_PHY_643_DATA 0x00000000
    +#define DDRSS_PHY_644_DATA 0x00000000
    +#define DDRSS_PHY_645_DATA 0x00000000
    +#define DDRSS_PHY_646_DATA 0x00000000
    +#define DDRSS_PHY_647_DATA 0x00000000
    +#define DDRSS_PHY_648_DATA 0x00000000
    +#define DDRSS_PHY_649_DATA 0x00000000
    +#define DDRSS_PHY_650_DATA 0x00000000
    +#define DDRSS_PHY_651_DATA 0x00000000
    +#define DDRSS_PHY_652_DATA 0x00000000
    +#define DDRSS_PHY_653_DATA 0x00000000
    +#define DDRSS_PHY_654_DATA 0x00000000
    +#define DDRSS_PHY_655_DATA 0x00000000
    +#define DDRSS_PHY_656_DATA 0x00000000
    +#define DDRSS_PHY_657_DATA 0x00000000
    +#define DDRSS_PHY_658_DATA 0x00000000
    +#define DDRSS_PHY_659_DATA 0x00000000
    +#define DDRSS_PHY_660_DATA 0x00000000
    +#define DDRSS_PHY_661_DATA 0x00000000
    +#define DDRSS_PHY_662_DATA 0x00000000
    +#define DDRSS_PHY_663_DATA 0x00000000
    +#define DDRSS_PHY_664_DATA 0x00000000
    +#define DDRSS_PHY_665_DATA 0x00000000
    +#define DDRSS_PHY_666_DATA 0x00000000
    +#define DDRSS_PHY_667_DATA 0x00000000
    +#define DDRSS_PHY_668_DATA 0x00000000
    +#define DDRSS_PHY_669_DATA 0x00000000
    +#define DDRSS_PHY_670_DATA 0x00000000
    +#define DDRSS_PHY_671_DATA 0x00000000
    +#define DDRSS_PHY_672_DATA 0x00000000
    +#define DDRSS_PHY_673_DATA 0x00000000
    +#define DDRSS_PHY_674_DATA 0x00000000
    +#define DDRSS_PHY_675_DATA 0x00000000
    +#define DDRSS_PHY_676_DATA 0x00000000
    +#define DDRSS_PHY_677_DATA 0x00000000
    +#define DDRSS_PHY_678_DATA 0x00000000
    +#define DDRSS_PHY_679_DATA 0x00000000
    +#define DDRSS_PHY_680_DATA 0x00000000
    +#define DDRSS_PHY_681_DATA 0x00000000
    +#define DDRSS_PHY_682_DATA 0x00000000
    +#define DDRSS_PHY_683_DATA 0x00000000
    +#define DDRSS_PHY_684_DATA 0x00000000
    +#define DDRSS_PHY_685_DATA 0x00000000
    +#define DDRSS_PHY_686_DATA 0x00000000
    +#define DDRSS_PHY_687_DATA 0x00000000
    +#define DDRSS_PHY_688_DATA 0x00000000
    +#define DDRSS_PHY_689_DATA 0x00000000
    +#define DDRSS_PHY_690_DATA 0x00000000
    +#define DDRSS_PHY_691_DATA 0x00000000
    +#define DDRSS_PHY_692_DATA 0x00000000
    +#define DDRSS_PHY_693_DATA 0x00000000
    +#define DDRSS_PHY_694_DATA 0x00000000
    +#define DDRSS_PHY_695_DATA 0x00000000
    +#define DDRSS_PHY_696_DATA 0x00000000
    +#define DDRSS_PHY_697_DATA 0x00000000
    +#define DDRSS_PHY_698_DATA 0x00000000
    +#define DDRSS_PHY_699_DATA 0x00000000
    +#define DDRSS_PHY_700_DATA 0x00000000
    +#define DDRSS_PHY_701_DATA 0x00000000
    +#define DDRSS_PHY_702_DATA 0x00000000
    +#define DDRSS_PHY_703_DATA 0x00000000
    +#define DDRSS_PHY_704_DATA 0x00000000
    +#define DDRSS_PHY_705_DATA 0x00000000
    +#define DDRSS_PHY_706_DATA 0x00000000
    +#define DDRSS_PHY_707_DATA 0x00000000
    +#define DDRSS_PHY_708_DATA 0x00000000
    +#define DDRSS_PHY_709_DATA 0x00000000
    +#define DDRSS_PHY_710_DATA 0x00000000
    +#define DDRSS_PHY_711_DATA 0x00000000
    +#define DDRSS_PHY_712_DATA 0x00000000
    +#define DDRSS_PHY_713_DATA 0x00000000
    +#define DDRSS_PHY_714_DATA 0x00000000
    +#define DDRSS_PHY_715_DATA 0x00000000
    +#define DDRSS_PHY_716_DATA 0x00000000
    +#define DDRSS_PHY_717_DATA 0x00000000
    +#define DDRSS_PHY_718_DATA 0x00000000
    +#define DDRSS_PHY_719_DATA 0x00000000
    +#define DDRSS_PHY_720_DATA 0x00000000
    +#define DDRSS_PHY_721_DATA 0x00000000
    +#define DDRSS_PHY_722_DATA 0x00000000
    +#define DDRSS_PHY_723_DATA 0x00000000
    +#define DDRSS_PHY_724_DATA 0x00000000
    +#define DDRSS_PHY_725_DATA 0x00000000
    +#define DDRSS_PHY_726_DATA 0x00000000
    +#define DDRSS_PHY_727_DATA 0x00000000
    +#define DDRSS_PHY_728_DATA 0x00000000
    +#define DDRSS_PHY_729_DATA 0x00000000
    +#define DDRSS_PHY_730_DATA 0x00000000
    +#define DDRSS_PHY_731_DATA 0x00000000
    +#define DDRSS_PHY_732_DATA 0x00000000
    +#define DDRSS_PHY_733_DATA 0x00000000
    +#define DDRSS_PHY_734_DATA 0x00000000
    +#define DDRSS_PHY_735_DATA 0x00000000
    +#define DDRSS_PHY_736_DATA 0x00000000
    +#define DDRSS_PHY_737_DATA 0x00000000
    +#define DDRSS_PHY_738_DATA 0x00000000
    +#define DDRSS_PHY_739_DATA 0x00000000
    +#define DDRSS_PHY_740_DATA 0x00000000
    +#define DDRSS_PHY_741_DATA 0x00000000
    +#define DDRSS_PHY_742_DATA 0x00000000
    +#define DDRSS_PHY_743_DATA 0x00000000
    +#define DDRSS_PHY_744_DATA 0x00000000
    +#define DDRSS_PHY_745_DATA 0x00000000
    +#define DDRSS_PHY_746_DATA 0x00000000
    +#define DDRSS_PHY_747_DATA 0x00000000
    +#define DDRSS_PHY_748_DATA 0x00000000
    +#define DDRSS_PHY_749_DATA 0x00000000
    +#define DDRSS_PHY_750_DATA 0x00000000
    +#define DDRSS_PHY_751_DATA 0x00000000
    +#define DDRSS_PHY_752_DATA 0x00000000
    +#define DDRSS_PHY_753_DATA 0x00000000
    +#define DDRSS_PHY_754_DATA 0x00000000
    +#define DDRSS_PHY_755_DATA 0x00000000
    +#define DDRSS_PHY_756_DATA 0x00000000
    +#define DDRSS_PHY_757_DATA 0x00000000
    +#define DDRSS_PHY_758_DATA 0x00000000
    +#define DDRSS_PHY_759_DATA 0x00000000
    +#define DDRSS_PHY_760_DATA 0x00000000
    +#define DDRSS_PHY_761_DATA 0x00000000
    +#define DDRSS_PHY_762_DATA 0x00000000
    +#define DDRSS_PHY_763_DATA 0x00000000
    +#define DDRSS_PHY_764_DATA 0x00000000
    +#define DDRSS_PHY_765_DATA 0x00000000
    +#define DDRSS_PHY_766_DATA 0x00000000
    +#define DDRSS_PHY_767_DATA 0x00000000
    +#define DDRSS_PHY_768_DATA 0x00000000
    +#define DDRSS_PHY_769_DATA 0x00000000
    +#define DDRSS_PHY_770_DATA 0x00000000
    +#define DDRSS_PHY_771_DATA 0x00000000
    +#define DDRSS_PHY_772_DATA 0x00000000
    +#define DDRSS_PHY_773_DATA 0x00000100
    +#define DDRSS_PHY_774_DATA 0x00000200
    +#define DDRSS_PHY_775_DATA 0x00000000
    +#define DDRSS_PHY_776_DATA 0x00000000
    +#define DDRSS_PHY_777_DATA 0x00000000
    +#define DDRSS_PHY_778_DATA 0x00000000
    +#define DDRSS_PHY_779_DATA 0x00400000
    +#define DDRSS_PHY_780_DATA 0x00000080
    +#define DDRSS_PHY_781_DATA 0x00DCBA98
    +#define DDRSS_PHY_782_DATA 0x03000000
    +#define DDRSS_PHY_783_DATA 0x00200000
    +#define DDRSS_PHY_784_DATA 0x00000000
    +#define DDRSS_PHY_785_DATA 0x00000000
    +#define DDRSS_PHY_786_DATA 0x00000000
    +#define DDRSS_PHY_787_DATA 0x00000000
    +#define DDRSS_PHY_788_DATA 0x0000002A
    +#define DDRSS_PHY_789_DATA 0x00000015
    +#define DDRSS_PHY_790_DATA 0x00000015
    +#define DDRSS_PHY_791_DATA 0x0000002A
    +#define DDRSS_PHY_792_DATA 0x00000033
    +#define DDRSS_PHY_793_DATA 0x0000000C
    +#define DDRSS_PHY_794_DATA 0x0000000C
    +#define DDRSS_PHY_795_DATA 0x00000033
    +#define DDRSS_PHY_796_DATA 0x00000000
    +#define DDRSS_PHY_797_DATA 0x00000000
    +#define DDRSS_PHY_798_DATA 0x000F0000
    +#define DDRSS_PHY_799_DATA 0x0000000F
    +#define DDRSS_PHY_800_DATA 0x020002CC
    +#define DDRSS_PHY_801_DATA 0x00030000
    +#define DDRSS_PHY_802_DATA 0x00000300
    +#define DDRSS_PHY_803_DATA 0x00000300
    +#define DDRSS_PHY_804_DATA 0x00000300
    +#define DDRSS_PHY_805_DATA 0x00000300
    +#define DDRSS_PHY_806_DATA 0x00000300
    +#define DDRSS_PHY_807_DATA 0x42080010
    +#define DDRSS_PHY_808_DATA 0x0000803E
    +#define DDRSS_PHY_809_DATA 0x00000003
    +#define DDRSS_PHY_810_DATA 0x00000002
    +#define DDRSS_PHY_811_DATA 0x00000000
    +#define DDRSS_PHY_812_DATA 0x00000000
    +#define DDRSS_PHY_813_DATA 0x00000000
    +#define DDRSS_PHY_814_DATA 0x00000000
    +#define DDRSS_PHY_815_DATA 0x00000000
    +#define DDRSS_PHY_816_DATA 0x00000000
    +#define DDRSS_PHY_817_DATA 0x00000000
    +#define DDRSS_PHY_818_DATA 0x00000000
    +#define DDRSS_PHY_819_DATA 0x00000000
    +#define DDRSS_PHY_820_DATA 0x00000000
    +#define DDRSS_PHY_821_DATA 0x00000000
    +#define DDRSS_PHY_822_DATA 0x00000000
    +#define DDRSS_PHY_823_DATA 0x00000000
    +#define DDRSS_PHY_824_DATA 0x00000000
    +#define DDRSS_PHY_825_DATA 0x00000000
    +#define DDRSS_PHY_826_DATA 0x00000000
    +#define DDRSS_PHY_827_DATA 0x00000000
    +#define DDRSS_PHY_828_DATA 0x00000000
    +#define DDRSS_PHY_829_DATA 0x00000000
    +#define DDRSS_PHY_830_DATA 0x00000000
    +#define DDRSS_PHY_831_DATA 0x00000000
    +#define DDRSS_PHY_832_DATA 0x00000000
    +#define DDRSS_PHY_833_DATA 0x00000000
    +#define DDRSS_PHY_834_DATA 0x00000000
    +#define DDRSS_PHY_835_DATA 0x00000000
    +#define DDRSS_PHY_836_DATA 0x00000000
    +#define DDRSS_PHY_837_DATA 0x00000000
    +#define DDRSS_PHY_838_DATA 0x00000000
    +#define DDRSS_PHY_839_DATA 0x00000000
    +#define DDRSS_PHY_840_DATA 0x00000000
    +#define DDRSS_PHY_841_DATA 0x00000000
    +#define DDRSS_PHY_842_DATA 0x00000000
    +#define DDRSS_PHY_843_DATA 0x00000000
    +#define DDRSS_PHY_844_DATA 0x00000000
    +#define DDRSS_PHY_845_DATA 0x00000000
    +#define DDRSS_PHY_846_DATA 0x00000000
    +#define DDRSS_PHY_847_DATA 0x00000000
    +#define DDRSS_PHY_848_DATA 0x00000000
    +#define DDRSS_PHY_849_DATA 0x00000000
    +#define DDRSS_PHY_850_DATA 0x00000000
    +#define DDRSS_PHY_851_DATA 0x00000000
    +#define DDRSS_PHY_852_DATA 0x00000000
    +#define DDRSS_PHY_853_DATA 0x00000000
    +#define DDRSS_PHY_854_DATA 0x00000000
    +#define DDRSS_PHY_855_DATA 0x00000000
    +#define DDRSS_PHY_856_DATA 0x00000000
    +#define DDRSS_PHY_857_DATA 0x00000000
    +#define DDRSS_PHY_858_DATA 0x00000000
    +#define DDRSS_PHY_859_DATA 0x00000000
    +#define DDRSS_PHY_860_DATA 0x00000000
    +#define DDRSS_PHY_861_DATA 0x00000000
    +#define DDRSS_PHY_862_DATA 0x00000000
    +#define DDRSS_PHY_863_DATA 0x00000000
    +#define DDRSS_PHY_864_DATA 0x00000000
    +#define DDRSS_PHY_865_DATA 0x00000000
    +#define DDRSS_PHY_866_DATA 0x00000000
    +#define DDRSS_PHY_867_DATA 0x00000000
    +#define DDRSS_PHY_868_DATA 0x00000000
    +#define DDRSS_PHY_869_DATA 0x00000000
    +#define DDRSS_PHY_870_DATA 0x00000000
    +#define DDRSS_PHY_871_DATA 0x00000000
    +#define DDRSS_PHY_872_DATA 0x00000000
    +#define DDRSS_PHY_873_DATA 0x00000000
    +#define DDRSS_PHY_874_DATA 0x00000000
    +#define DDRSS_PHY_875_DATA 0x00000000
    +#define DDRSS_PHY_876_DATA 0x00000000
    +#define DDRSS_PHY_877_DATA 0x00000000
    +#define DDRSS_PHY_878_DATA 0x00000000
    +#define DDRSS_PHY_879_DATA 0x00000000
    +#define DDRSS_PHY_880_DATA 0x00000000
    +#define DDRSS_PHY_881_DATA 0x00000000
    +#define DDRSS_PHY_882_DATA 0x00000000
    +#define DDRSS_PHY_883_DATA 0x00000000
    +#define DDRSS_PHY_884_DATA 0x00000000
    +#define DDRSS_PHY_885_DATA 0x00000000
    +#define DDRSS_PHY_886_DATA 0x00000000
    +#define DDRSS_PHY_887_DATA 0x00000000
    +#define DDRSS_PHY_888_DATA 0x00000000
    +#define DDRSS_PHY_889_DATA 0x00000000
    +#define DDRSS_PHY_890_DATA 0x00000000
    +#define DDRSS_PHY_891_DATA 0x00000000
    +#define DDRSS_PHY_892_DATA 0x00000000
    +#define DDRSS_PHY_893_DATA 0x00000000
    +#define DDRSS_PHY_894_DATA 0x00000000
    +#define DDRSS_PHY_895_DATA 0x00000000
    +#define DDRSS_PHY_896_DATA 0x00000000
    +#define DDRSS_PHY_897_DATA 0x00000000
    +#define DDRSS_PHY_898_DATA 0x00000000
    +#define DDRSS_PHY_899_DATA 0x00000000
    +#define DDRSS_PHY_900_DATA 0x00000000
    +#define DDRSS_PHY_901_DATA 0x00000000
    +#define DDRSS_PHY_902_DATA 0x00000000
    +#define DDRSS_PHY_903_DATA 0x00000000
    +#define DDRSS_PHY_904_DATA 0x00000000
    +#define DDRSS_PHY_905_DATA 0x00000000
    +#define DDRSS_PHY_906_DATA 0x00000000
    +#define DDRSS_PHY_907_DATA 0x00000000
    +#define DDRSS_PHY_908_DATA 0x00000000
    +#define DDRSS_PHY_909_DATA 0x00000000
    +#define DDRSS_PHY_910_DATA 0x00000000
    +#define DDRSS_PHY_911_DATA 0x00000000
    +#define DDRSS_PHY_912_DATA 0x00000000
    +#define DDRSS_PHY_913_DATA 0x00000000
    +#define DDRSS_PHY_914_DATA 0x00000000
    +#define DDRSS_PHY_915_DATA 0x00000000
    +#define DDRSS_PHY_916_DATA 0x00000000
    +#define DDRSS_PHY_917_DATA 0x00000000
    +#define DDRSS_PHY_918_DATA 0x00000000
    +#define DDRSS_PHY_919_DATA 0x00000000
    +#define DDRSS_PHY_920_DATA 0x00000000
    +#define DDRSS_PHY_921_DATA 0x00000000
    +#define DDRSS_PHY_922_DATA 0x00000000
    +#define DDRSS_PHY_923_DATA 0x00000000
    +#define DDRSS_PHY_924_DATA 0x00000000
    +#define DDRSS_PHY_925_DATA 0x00000000
    +#define DDRSS_PHY_926_DATA 0x00000000
    +#define DDRSS_PHY_927_DATA 0x00000000
    +#define DDRSS_PHY_928_DATA 0x00000000
    +#define DDRSS_PHY_929_DATA 0x00000000
    +#define DDRSS_PHY_930_DATA 0x00000000
    +#define DDRSS_PHY_931_DATA 0x00000000
    +#define DDRSS_PHY_932_DATA 0x00000000
    +#define DDRSS_PHY_933_DATA 0x00000000
    +#define DDRSS_PHY_934_DATA 0x00000000
    +#define DDRSS_PHY_935_DATA 0x00000000
    +#define DDRSS_PHY_936_DATA 0x00000000
    +#define DDRSS_PHY_937_DATA 0x00000000
    +#define DDRSS_PHY_938_DATA 0x00000000
    +#define DDRSS_PHY_939_DATA 0x00000000
    +#define DDRSS_PHY_940_DATA 0x00000000
    +#define DDRSS_PHY_941_DATA 0x00000000
    +#define DDRSS_PHY_942_DATA 0x00000000
    +#define DDRSS_PHY_943_DATA 0x00000000
    +#define DDRSS_PHY_944_DATA 0x00000000
    +#define DDRSS_PHY_945_DATA 0x00000000
    +#define DDRSS_PHY_946_DATA 0x00000000
    +#define DDRSS_PHY_947_DATA 0x00000000
    +#define DDRSS_PHY_948_DATA 0x00000000
    +#define DDRSS_PHY_949_DATA 0x00000000
    +#define DDRSS_PHY_950_DATA 0x00000000
    +#define DDRSS_PHY_951_DATA 0x00000000
    +#define DDRSS_PHY_952_DATA 0x00000000
    +#define DDRSS_PHY_953_DATA 0x00000000
    +#define DDRSS_PHY_954_DATA 0x00000000
    +#define DDRSS_PHY_955_DATA 0x00000000
    +#define DDRSS_PHY_956_DATA 0x00000000
    +#define DDRSS_PHY_957_DATA 0x00000000
    +#define DDRSS_PHY_958_DATA 0x00000000
    +#define DDRSS_PHY_959_DATA 0x00000000
    +#define DDRSS_PHY_960_DATA 0x00000000
    +#define DDRSS_PHY_961_DATA 0x00000000
    +#define DDRSS_PHY_962_DATA 0x00000000
    +#define DDRSS_PHY_963_DATA 0x00000000
    +#define DDRSS_PHY_964_DATA 0x00000000
    +#define DDRSS_PHY_965_DATA 0x00000000
    +#define DDRSS_PHY_966_DATA 0x00000000
    +#define DDRSS_PHY_967_DATA 0x00000000
    +#define DDRSS_PHY_968_DATA 0x00000000
    +#define DDRSS_PHY_969_DATA 0x00000000
    +#define DDRSS_PHY_970_DATA 0x00000000
    +#define DDRSS_PHY_971_DATA 0x00000000
    +#define DDRSS_PHY_972_DATA 0x00000000
    +#define DDRSS_PHY_973_DATA 0x00000000
    +#define DDRSS_PHY_974_DATA 0x00000000
    +#define DDRSS_PHY_975_DATA 0x00000000
    +#define DDRSS_PHY_976_DATA 0x00000000
    +#define DDRSS_PHY_977_DATA 0x00000000
    +#define DDRSS_PHY_978_DATA 0x00000000
    +#define DDRSS_PHY_979_DATA 0x00000000
    +#define DDRSS_PHY_980_DATA 0x00000000
    +#define DDRSS_PHY_981_DATA 0x00000000
    +#define DDRSS_PHY_982_DATA 0x00000000
    +#define DDRSS_PHY_983_DATA 0x00000000
    +#define DDRSS_PHY_984_DATA 0x00000000
    +#define DDRSS_PHY_985_DATA 0x00000000
    +#define DDRSS_PHY_986_DATA 0x00000000
    +#define DDRSS_PHY_987_DATA 0x00000000
    +#define DDRSS_PHY_988_DATA 0x00000000
    +#define DDRSS_PHY_989_DATA 0x00000000
    +#define DDRSS_PHY_990_DATA 0x00000000
    +#define DDRSS_PHY_991_DATA 0x00000000
    +#define DDRSS_PHY_992_DATA 0x00000000
    +#define DDRSS_PHY_993_DATA 0x00000000
    +#define DDRSS_PHY_994_DATA 0x00000000
    +#define DDRSS_PHY_995_DATA 0x00000000
    +#define DDRSS_PHY_996_DATA 0x00000000
    +#define DDRSS_PHY_997_DATA 0x00000000
    +#define DDRSS_PHY_998_DATA 0x00000000
    +#define DDRSS_PHY_999_DATA 0x00000000
    +#define DDRSS_PHY_1000_DATA 0x00000000
    +#define DDRSS_PHY_1001_DATA 0x00000000
    +#define DDRSS_PHY_1002_DATA 0x00000000
    +#define DDRSS_PHY_1003_DATA 0x00000000
    +#define DDRSS_PHY_1004_DATA 0x00000000
    +#define DDRSS_PHY_1005_DATA 0x00000000
    +#define DDRSS_PHY_1006_DATA 0x00000000
    +#define DDRSS_PHY_1007_DATA 0x00000000
    +#define DDRSS_PHY_1008_DATA 0x00000000
    +#define DDRSS_PHY_1009_DATA 0x00000000
    +#define DDRSS_PHY_1010_DATA 0x00000000
    +#define DDRSS_PHY_1011_DATA 0x00000000
    +#define DDRSS_PHY_1012_DATA 0x00000000
    +#define DDRSS_PHY_1013_DATA 0x00000000
    +#define DDRSS_PHY_1014_DATA 0x00000000
    +#define DDRSS_PHY_1015_DATA 0x00000000
    +#define DDRSS_PHY_1016_DATA 0x00000000
    +#define DDRSS_PHY_1017_DATA 0x00000000
    +#define DDRSS_PHY_1018_DATA 0x00000000
    +#define DDRSS_PHY_1019_DATA 0x00000000
    +#define DDRSS_PHY_1020_DATA 0x00000000
    +#define DDRSS_PHY_1021_DATA 0x00000000
    +#define DDRSS_PHY_1022_DATA 0x00000000
    +#define DDRSS_PHY_1023_DATA 0x00000000
    +#define DDRSS_PHY_1024_DATA 0x00000000
    +#define DDRSS_PHY_1025_DATA 0x00000000
    +#define DDRSS_PHY_1026_DATA 0x00000000
    +#define DDRSS_PHY_1027_DATA 0x00000000
    +#define DDRSS_PHY_1028_DATA 0x00000000
    +#define DDRSS_PHY_1029_DATA 0x00000100
    +#define DDRSS_PHY_1030_DATA 0x00000200
    +#define DDRSS_PHY_1031_DATA 0x00000000
    +#define DDRSS_PHY_1032_DATA 0x00000000
    +#define DDRSS_PHY_1033_DATA 0x00000000
    +#define DDRSS_PHY_1034_DATA 0x00000000
    +#define DDRSS_PHY_1035_DATA 0x00400000
    +#define DDRSS_PHY_1036_DATA 0x00000080
    +#define DDRSS_PHY_1037_DATA 0x00DCBA98
    +#define DDRSS_PHY_1038_DATA 0x03000000
    +#define DDRSS_PHY_1039_DATA 0x00200000
    +#define DDRSS_PHY_1040_DATA 0x00000000
    +#define DDRSS_PHY_1041_DATA 0x00000000
    +#define DDRSS_PHY_1042_DATA 0x00000000
    +#define DDRSS_PHY_1043_DATA 0x00000000
    +#define DDRSS_PHY_1044_DATA 0x0000002A
    +#define DDRSS_PHY_1045_DATA 0x00000015
    +#define DDRSS_PHY_1046_DATA 0x00000015
    +#define DDRSS_PHY_1047_DATA 0x0000002A
    +#define DDRSS_PHY_1048_DATA 0x00000033
    +#define DDRSS_PHY_1049_DATA 0x0000000C
    +#define DDRSS_PHY_1050_DATA 0x0000000C
    +#define DDRSS_PHY_1051_DATA 0x00000033
    +#define DDRSS_PHY_1052_DATA 0x2307B9AC
    +#define DDRSS_PHY_1053_DATA 0x10000000
    +#define DDRSS_PHY_1054_DATA 0x000F0000
    +#define DDRSS_PHY_1055_DATA 0x0000000F
    +#define DDRSS_PHY_1056_DATA 0x020002CC
    +#define DDRSS_PHY_1057_DATA 0x00030000
    +#define DDRSS_PHY_1058_DATA 0x00000300
    +#define DDRSS_PHY_1059_DATA 0x00000300
    +#define DDRSS_PHY_1060_DATA 0x00000300
    +#define DDRSS_PHY_1061_DATA 0x00000300
    +#define DDRSS_PHY_1062_DATA 0x00000300
    +#define DDRSS_PHY_1063_DATA 0x42080010
    +#define DDRSS_PHY_1064_DATA 0x0000803E
    +#define DDRSS_PHY_1065_DATA 0x00000003
    +#define DDRSS_PHY_1066_DATA 0x00000002
    +#define DDRSS_PHY_1067_DATA 0x00000000
    +#define DDRSS_PHY_1068_DATA 0x00000000
    +#define DDRSS_PHY_1069_DATA 0x00000000
    +#define DDRSS_PHY_1070_DATA 0x00000000
    +#define DDRSS_PHY_1071_DATA 0x00000000
    +#define DDRSS_PHY_1072_DATA 0x00000000
    +#define DDRSS_PHY_1073_DATA 0x00000000
    +#define DDRSS_PHY_1074_DATA 0x00000000
    +#define DDRSS_PHY_1075_DATA 0x00000000
    +#define DDRSS_PHY_1076_DATA 0x00000000
    +#define DDRSS_PHY_1077_DATA 0x00000000
    +#define DDRSS_PHY_1078_DATA 0x00000000
    +#define DDRSS_PHY_1079_DATA 0x00000000
    +#define DDRSS_PHY_1080_DATA 0x00000000
    +#define DDRSS_PHY_1081_DATA 0x00000000
    +#define DDRSS_PHY_1082_DATA 0x00000000
    +#define DDRSS_PHY_1083_DATA 0x00000000
    +#define DDRSS_PHY_1084_DATA 0x00000000
    +#define DDRSS_PHY_1085_DATA 0x00000000
    +#define DDRSS_PHY_1086_DATA 0x00000000
    +#define DDRSS_PHY_1087_DATA 0x00000000
    +#define DDRSS_PHY_1088_DATA 0x00000000
    +#define DDRSS_PHY_1089_DATA 0x00000000
    +#define DDRSS_PHY_1090_DATA 0x00000000
    +#define DDRSS_PHY_1091_DATA 0x00000000
    +#define DDRSS_PHY_1092_DATA 0x00000000
    +#define DDRSS_PHY_1093_DATA 0x00000000
    +#define DDRSS_PHY_1094_DATA 0x00000000
    +#define DDRSS_PHY_1095_DATA 0x00000000
    +#define DDRSS_PHY_1096_DATA 0x00000000
    +#define DDRSS_PHY_1097_DATA 0x00000000
    +#define DDRSS_PHY_1098_DATA 0x00000000
    +#define DDRSS_PHY_1099_DATA 0x00000000
    +#define DDRSS_PHY_1100_DATA 0x00000000
    +#define DDRSS_PHY_1101_DATA 0x00000000
    +#define DDRSS_PHY_1102_DATA 0x00000000
    +#define DDRSS_PHY_1103_DATA 0x00000000
    +#define DDRSS_PHY_1104_DATA 0x00000000
    +#define DDRSS_PHY_1105_DATA 0x00000000
    +#define DDRSS_PHY_1106_DATA 0x00000000
    +#define DDRSS_PHY_1107_DATA 0x00000000
    +#define DDRSS_PHY_1108_DATA 0x00000000
    +#define DDRSS_PHY_1109_DATA 0x00000000
    +#define DDRSS_PHY_1110_DATA 0x00000000
    +#define DDRSS_PHY_1111_DATA 0x00000000
    +#define DDRSS_PHY_1112_DATA 0x00000000
    +#define DDRSS_PHY_1113_DATA 0x00000000
    +#define DDRSS_PHY_1114_DATA 0x00000000
    +#define DDRSS_PHY_1115_DATA 0x00000000
    +#define DDRSS_PHY_1116_DATA 0x00000000
    +#define DDRSS_PHY_1117_DATA 0x00000000
    +#define DDRSS_PHY_1118_DATA 0x00000000
    +#define DDRSS_PHY_1119_DATA 0x00000000
    +#define DDRSS_PHY_1120_DATA 0x00000000
    +#define DDRSS_PHY_1121_DATA 0x00000000
    +#define DDRSS_PHY_1122_DATA 0x00000000
    +#define DDRSS_PHY_1123_DATA 0x00000000
    +#define DDRSS_PHY_1124_DATA 0x00000000
    +#define DDRSS_PHY_1125_DATA 0x00000000
    +#define DDRSS_PHY_1126_DATA 0x00000000
    +#define DDRSS_PHY_1127_DATA 0x00000000
    +#define DDRSS_PHY_1128_DATA 0x00000000
    +#define DDRSS_PHY_1129_DATA 0x00000000
    +#define DDRSS_PHY_1130_DATA 0x00000000
    +#define DDRSS_PHY_1131_DATA 0x00000000
    +#define DDRSS_PHY_1132_DATA 0x00000000
    +#define DDRSS_PHY_1133_DATA 0x00000000
    +#define DDRSS_PHY_1134_DATA 0x00000000
    +#define DDRSS_PHY_1135_DATA 0x00000000
    +#define DDRSS_PHY_1136_DATA 0x00000000
    +#define DDRSS_PHY_1137_DATA 0x00000000
    +#define DDRSS_PHY_1138_DATA 0x00000000
    +#define DDRSS_PHY_1139_DATA 0x00000000
    +#define DDRSS_PHY_1140_DATA 0x00000000
    +#define DDRSS_PHY_1141_DATA 0x00000000
    +#define DDRSS_PHY_1142_DATA 0x00000000
    +#define DDRSS_PHY_1143_DATA 0x00000000
    +#define DDRSS_PHY_1144_DATA 0x00000000
    +#define DDRSS_PHY_1145_DATA 0x00000000
    +#define DDRSS_PHY_1146_DATA 0x00000000
    +#define DDRSS_PHY_1147_DATA 0x00000000
    +#define DDRSS_PHY_1148_DATA 0x00000000
    +#define DDRSS_PHY_1149_DATA 0x00000000
    +#define DDRSS_PHY_1150_DATA 0x00000000
    +#define DDRSS_PHY_1151_DATA 0x00000000
    +#define DDRSS_PHY_1152_DATA 0x00000000
    +#define DDRSS_PHY_1153_DATA 0x00000000
    +#define DDRSS_PHY_1154_DATA 0x00000000
    +#define DDRSS_PHY_1155_DATA 0x00000000
    +#define DDRSS_PHY_1156_DATA 0x00000000
    +#define DDRSS_PHY_1157_DATA 0x00000000
    +#define DDRSS_PHY_1158_DATA 0x00000000
    +#define DDRSS_PHY_1159_DATA 0x00000000
    +#define DDRSS_PHY_1160_DATA 0x00000000
    +#define DDRSS_PHY_1161_DATA 0x00000000
    +#define DDRSS_PHY_1162_DATA 0x00000000
    +#define DDRSS_PHY_1163_DATA 0x00000000
    +#define DDRSS_PHY_1164_DATA 0x00000000
    +#define DDRSS_PHY_1165_DATA 0x00000000
    +#define DDRSS_PHY_1166_DATA 0x00000000
    +#define DDRSS_PHY_1167_DATA 0x00000000
    +#define DDRSS_PHY_1168_DATA 0x00000000
    +#define DDRSS_PHY_1169_DATA 0x00000000
    +#define DDRSS_PHY_1170_DATA 0x00000000
    +#define DDRSS_PHY_1171_DATA 0x00000000
    +#define DDRSS_PHY_1172_DATA 0x00000000
    +#define DDRSS_PHY_1173_DATA 0x00000000
    +#define DDRSS_PHY_1174_DATA 0x00000000
    +#define DDRSS_PHY_1175_DATA 0x00000000
    +#define DDRSS_PHY_1176_DATA 0x00000000
    +#define DDRSS_PHY_1177_DATA 0x00000000
    +#define DDRSS_PHY_1178_DATA 0x00000000
    +#define DDRSS_PHY_1179_DATA 0x00000000
    +#define DDRSS_PHY_1180_DATA 0x00000000
    +#define DDRSS_PHY_1181_DATA 0x00000000
    +#define DDRSS_PHY_1182_DATA 0x00000000
    +#define DDRSS_PHY_1183_DATA 0x00000000
    +#define DDRSS_PHY_1184_DATA 0x00000000
    +#define DDRSS_PHY_1185_DATA 0x00000000
    +#define DDRSS_PHY_1186_DATA 0x00000000
    +#define DDRSS_PHY_1187_DATA 0x00000000
    +#define DDRSS_PHY_1188_DATA 0x00000000
    +#define DDRSS_PHY_1189_DATA 0x00000000
    +#define DDRSS_PHY_1190_DATA 0x00000000
    +#define DDRSS_PHY_1191_DATA 0x00000000
    +#define DDRSS_PHY_1192_DATA 0x00000000
    +#define DDRSS_PHY_1193_DATA 0x00000000
    +#define DDRSS_PHY_1194_DATA 0x00000000
    +#define DDRSS_PHY_1195_DATA 0x00000000
    +#define DDRSS_PHY_1196_DATA 0x00000000
    +#define DDRSS_PHY_1197_DATA 0x00000000
    +#define DDRSS_PHY_1198_DATA 0x00000000
    +#define DDRSS_PHY_1199_DATA 0x00000000
    +#define DDRSS_PHY_1200_DATA 0x00000000
    +#define DDRSS_PHY_1201_DATA 0x00000000
    +#define DDRSS_PHY_1202_DATA 0x00000000
    +#define DDRSS_PHY_1203_DATA 0x00000000
    +#define DDRSS_PHY_1204_DATA 0x00000000
    +#define DDRSS_PHY_1205_DATA 0x00000000
    +#define DDRSS_PHY_1206_DATA 0x00000000
    +#define DDRSS_PHY_1207_DATA 0x00000000
    +#define DDRSS_PHY_1208_DATA 0x00000000
    +#define DDRSS_PHY_1209_DATA 0x00000000
    +#define DDRSS_PHY_1210_DATA 0x00000000
    +#define DDRSS_PHY_1211_DATA 0x00000000
    +#define DDRSS_PHY_1212_DATA 0x00000000
    +#define DDRSS_PHY_1213_DATA 0x00000000
    +#define DDRSS_PHY_1214_DATA 0x00000000
    +#define DDRSS_PHY_1215_DATA 0x00000000
    +#define DDRSS_PHY_1216_DATA 0x00000000
    +#define DDRSS_PHY_1217_DATA 0x00000000
    +#define DDRSS_PHY_1218_DATA 0x00000000
    +#define DDRSS_PHY_1219_DATA 0x00000000
    +#define DDRSS_PHY_1220_DATA 0x00000000
    +#define DDRSS_PHY_1221_DATA 0x00000000
    +#define DDRSS_PHY_1222_DATA 0x00000000
    +#define DDRSS_PHY_1223_DATA 0x00000000
    +#define DDRSS_PHY_1224_DATA 0x00000000
    +#define DDRSS_PHY_1225_DATA 0x00000000
    +#define DDRSS_PHY_1226_DATA 0x00000000
    +#define DDRSS_PHY_1227_DATA 0x00000000
    +#define DDRSS_PHY_1228_DATA 0x00000000
    +#define DDRSS_PHY_1229_DATA 0x00000000
    +#define DDRSS_PHY_1230_DATA 0x00000000
    +#define DDRSS_PHY_1231_DATA 0x00000000
    +#define DDRSS_PHY_1232_DATA 0x00000000
    +#define DDRSS_PHY_1233_DATA 0x00000000
    +#define DDRSS_PHY_1234_DATA 0x00000000
    +#define DDRSS_PHY_1235_DATA 0x00000000
    +#define DDRSS_PHY_1236_DATA 0x00000000
    +#define DDRSS_PHY_1237_DATA 0x00000000
    +#define DDRSS_PHY_1238_DATA 0x00000000
    +#define DDRSS_PHY_1239_DATA 0x00000000
    +#define DDRSS_PHY_1240_DATA 0x00000000
    +#define DDRSS_PHY_1241_DATA 0x00000000
    +#define DDRSS_PHY_1242_DATA 0x00000000
    +#define DDRSS_PHY_1243_DATA 0x00000000
    +#define DDRSS_PHY_1244_DATA 0x00000000
    +#define DDRSS_PHY_1245_DATA 0x00000000
    +#define DDRSS_PHY_1246_DATA 0x00000000
    +#define DDRSS_PHY_1247_DATA 0x00000000
    +#define DDRSS_PHY_1248_DATA 0x00000000
    +#define DDRSS_PHY_1249_DATA 0x00000000
    +#define DDRSS_PHY_1250_DATA 0x00000000
    +#define DDRSS_PHY_1251_DATA 0x00000000
    +#define DDRSS_PHY_1252_DATA 0x00000000
    +#define DDRSS_PHY_1253_DATA 0x00000000
    +#define DDRSS_PHY_1254_DATA 0x00000000
    +#define DDRSS_PHY_1255_DATA 0x00000000
    +#define DDRSS_PHY_1256_DATA 0x00000000
    +#define DDRSS_PHY_1257_DATA 0x00000000
    +#define DDRSS_PHY_1258_DATA 0x00000000
    +#define DDRSS_PHY_1259_DATA 0x00000000
    +#define DDRSS_PHY_1260_DATA 0x00000000
    +#define DDRSS_PHY_1261_DATA 0x00000000
    +#define DDRSS_PHY_1262_DATA 0x00000000
    +#define DDRSS_PHY_1263_DATA 0x00000000
    +#define DDRSS_PHY_1264_DATA 0x00000000
    +#define DDRSS_PHY_1265_DATA 0x00000000
    +#define DDRSS_PHY_1266_DATA 0x00000000
    +#define DDRSS_PHY_1267_DATA 0x00000000
    +#define DDRSS_PHY_1268_DATA 0x00000000
    +#define DDRSS_PHY_1269_DATA 0x00000000
    +#define DDRSS_PHY_1270_DATA 0x00000000
    +#define DDRSS_PHY_1271_DATA 0x00000000
    +#define DDRSS_PHY_1272_DATA 0x00000000
    +#define DDRSS_PHY_1273_DATA 0x00000000
    +#define DDRSS_PHY_1274_DATA 0x00000000
    +#define DDRSS_PHY_1275_DATA 0x00000000
    +#define DDRSS_PHY_1276_DATA 0x00000000
    +#define DDRSS_PHY_1277_DATA 0x00000000
    +#define DDRSS_PHY_1278_DATA 0x00000000
    +#define DDRSS_PHY_1279_DATA 0x00000000
    +#define DDRSS_PHY_1280_DATA 0x00000000
    +#define DDRSS_PHY_1281_DATA 0x00010100
    +#define DDRSS_PHY_1282_DATA 0x00000000
    +#define DDRSS_PHY_1283_DATA 0x00000000
    +#define DDRSS_PHY_1284_DATA 0x00000000
    +#define DDRSS_PHY_1285_DATA 0x00000000
    +#define DDRSS_PHY_1286_DATA 0x00050000
    +#define DDRSS_PHY_1287_DATA 0x04000000
    +#define DDRSS_PHY_1288_DATA 0x00000055
    +#define DDRSS_PHY_1289_DATA 0x00000000
    +#define DDRSS_PHY_1290_DATA 0x00000000
    +#define DDRSS_PHY_1291_DATA 0x00000000
    +#define DDRSS_PHY_1292_DATA 0x00000000
    +#define DDRSS_PHY_1293_DATA 0x00002001
    +#define DDRSS_PHY_1294_DATA 0x00004001
    +#define DDRSS_PHY_1295_DATA 0x00020028
    +#define DDRSS_PHY_1296_DATA 0x01010100
    +#define DDRSS_PHY_1297_DATA 0x00000000
    +#define DDRSS_PHY_1298_DATA 0x00000000
    +#define DDRSS_PHY_1299_DATA 0x0F0F0E06
    +#define DDRSS_PHY_1300_DATA 0x00010101
    +#define DDRSS_PHY_1301_DATA 0x010F0004
    +#define DDRSS_PHY_1302_DATA 0x00000000
    +#define DDRSS_PHY_1303_DATA 0x00000000
    +#define DDRSS_PHY_1304_DATA 0x00000064
    +#define DDRSS_PHY_1305_DATA 0x00000000
    +#define DDRSS_PHY_1306_DATA 0x00000000
    +#define DDRSS_PHY_1307_DATA 0x01020103
    +#define DDRSS_PHY_1308_DATA 0x0F020102
    +#define DDRSS_PHY_1309_DATA 0x03030303
    +#define DDRSS_PHY_1310_DATA 0x03030303
    +#define DDRSS_PHY_1311_DATA 0x00041B42
    +#define DDRSS_PHY_1312_DATA 0x00005201
    +#define DDRSS_PHY_1313_DATA 0x00000000
    +#define DDRSS_PHY_1314_DATA 0x00000000
    +#define DDRSS_PHY_1315_DATA 0x00000000
    +#define DDRSS_PHY_1316_DATA 0x00000000
    +#define DDRSS_PHY_1317_DATA 0x00000000
    +#define DDRSS_PHY_1318_DATA 0x00000000
    +#define DDRSS_PHY_1319_DATA 0x07030101
    +#define DDRSS_PHY_1320_DATA 0x00005400
    +#define DDRSS_PHY_1321_DATA 0x000040A2
    +#define DDRSS_PHY_1322_DATA 0x00024410
    +#define DDRSS_PHY_1323_DATA 0x00004410
    +#define DDRSS_PHY_1324_DATA 0x00004410
    +#define DDRSS_PHY_1325_DATA 0x00004410
    +#define DDRSS_PHY_1326_DATA 0x00004410
    +#define DDRSS_PHY_1327_DATA 0x00004410
    +#define DDRSS_PHY_1328_DATA 0x00004410
    +#define DDRSS_PHY_1329_DATA 0x00004410
    +#define DDRSS_PHY_1330_DATA 0x00004410
    +#define DDRSS_PHY_1331_DATA 0x00004410
    +#define DDRSS_PHY_1332_DATA 0x00000000
    +#define DDRSS_PHY_1333_DATA 0x00000076
    +#define DDRSS_PHY_1334_DATA 0x00000400
    +#define DDRSS_PHY_1335_DATA 0x00000008
    +#define DDRSS_PHY_1336_DATA 0x00000000
    +#define DDRSS_PHY_1337_DATA 0x00000000
    +#define DDRSS_PHY_1338_DATA 0x00000000
    +#define DDRSS_PHY_1339_DATA 0x00000000
    +#define DDRSS_PHY_1340_DATA 0x00000000
    +#define DDRSS_PHY_1341_DATA 0x03000000
    +#define DDRSS_PHY_1342_DATA 0x00000000
    +#define DDRSS_PHY_1343_DATA 0x00000000
    +#define DDRSS_PHY_1344_DATA 0x00000000
    +#define DDRSS_PHY_1345_DATA 0x04102006
    +#define DDRSS_PHY_1346_DATA 0x00041020
    +#define DDRSS_PHY_1347_DATA 0x01C98C98
    +#define DDRSS_PHY_1348_DATA 0x3F400000
    +#define DDRSS_PHY_1349_DATA 0x3F3F1F3F
    +#define DDRSS_PHY_1350_DATA 0x0000001F
    +#define DDRSS_PHY_1351_DATA 0x00000000
    +#define DDRSS_PHY_1352_DATA 0x00000000
    +#define DDRSS_PHY_1353_DATA 0x00000000
    +#define DDRSS_PHY_1354_DATA 0x00000001
    +#define DDRSS_PHY_1355_DATA 0x00000000
    +#define DDRSS_PHY_1356_DATA 0x00000000
    +#define DDRSS_PHY_1357_DATA 0x00000000
    +#define DDRSS_PHY_1358_DATA 0x00000000
    +#define DDRSS_PHY_1359_DATA 0x76543201 // [SWAP] PHY_DATA_BYTE_ORDER_SEL //0x76543210 //Normal
    +#define DDRSS_PHY_1360_DATA 0x00040198
    +#define DDRSS_PHY_1361_DATA 0x00000000
    +#define DDRSS_PHY_1362_DATA 0x00000000
    +#define DDRSS_PHY_1363_DATA 0x00000000
    +#define DDRSS_PHY_1364_DATA 0x00040700
    +#define DDRSS_PHY_1365_DATA 0x00000000
    +#define DDRSS_PHY_1366_DATA 0x00000000
    +#define DDRSS_PHY_1367_DATA 0x00000000
    +#define DDRSS_PHY_1368_DATA 0x00000002
    +#define DDRSS_PHY_1369_DATA 0x00000000
    +#define DDRSS_PHY_1370_DATA 0x00000000
    +#define DDRSS_PHY_1371_DATA 0x00000AC3
    +#define DDRSS_PHY_1372_DATA 0x00020002
    +#define DDRSS_PHY_1373_DATA 0x00000000
    +#define DDRSS_PHY_1374_DATA 0x00001142
    +#define DDRSS_PHY_1375_DATA 0x03020000
    +#define DDRSS_PHY_1376_DATA 0x00000080
    +#define DDRSS_PHY_1377_DATA 0x03900390
    +#define DDRSS_PHY_1378_DATA 0x03900390
    +#define DDRSS_PHY_1379_DATA 0x03900390
    +#define DDRSS_PHY_1380_DATA 0x03900390
    +#define DDRSS_PHY_1381_DATA 0x03000300
    +#define DDRSS_PHY_1382_DATA 0x03000300
    +#define DDRSS_PHY_1383_DATA 0x00000300
    +#define DDRSS_PHY_1384_DATA 0x00000300
    +#define DDRSS_PHY_1385_DATA 0x00000300
    +#define DDRSS_PHY_1386_DATA 0x00000300
    +#define DDRSS_PHY_1387_DATA 0x3183BF77
    +#define DDRSS_PHY_1388_DATA 0x00000000
    +#define DDRSS_PHY_1389_DATA 0x0C000DFF
    +#define DDRSS_PHY_1390_DATA 0x30000DFF
    +#define DDRSS_PHY_1391_DATA 0x3F0DFF11
    +#define DDRSS_PHY_1392_DATA 0x01990000
    +#define DDRSS_PHY_1393_DATA 0x780DFFCC
    +#define DDRSS_PHY_1394_DATA 0x00000C11
    +#define DDRSS_PHY_1395_DATA 0x00018011
    +#define DDRSS_PHY_1396_DATA 0x0089FF00
    +#define DDRSS_PHY_1397_DATA 0x000C3F11
    +#define DDRSS_PHY_1398_DATA 0x01990000
    +#define DDRSS_PHY_1399_DATA 0x000C3F11
    +#define DDRSS_PHY_1400_DATA 0x01990000
    +#define DDRSS_PHY_1401_DATA 0x3F0DFF11
    +#define DDRSS_PHY_1402_DATA 0x01990000
    +#define DDRSS_PHY_1403_DATA 0x00018011
    +#define DDRSS_PHY_1404_DATA 0x0089FF00
    +#define DDRSS_PHY_1405_DATA 0x20040002
    diff --git a/arch/arm/dts/k3-binman.dtsi b/arch/arm/dts/k3-binman.dtsi
    index 2ea2dd18a1..4f03615d3e 100644
    --- a/arch/arm/dts/k3-binman.dtsi
    +++ b/arch/arm/dts/k3-binman.dtsi
    @@ -12,15 +12,15 @@
     &binman {
     	custMpk {
     		filename = "custMpk.pem";
    -		custmpk_pem: blob-ext {
    -			filename = "../keys/custMpk.pem";
    +		blob-ext {
    +			filename = "../../ti/keys/custMpk.pem";
     	ti-degenerate-key {
     		filename = "ti-degenerate-key.pem";
    -		dkey_pem: blob-ext {
    -			filename = "../keys/ti-degenerate-key.pem";
    +		blob-ext {
    +			filename = "../../ti/keys/ti-degenerate-key.pem";
    @@ -32,28 +32,28 @@
     		filename = "board-cfg.bin";
     		bcfg_yaml: ti-board-config {
     			config = "board-cfg.yaml";
    -			schema = "../common/schema.yaml";
    +			schema = "../../ti/common/schema.yaml";
     	pm-cfg {
     		filename = "pm-cfg.bin";
     		pcfg_yaml: ti-board-config {
     			config = "pm-cfg.yaml";
     	rm-cfg {
     		filename = "rm-cfg.bin";
     		rcfg_yaml: ti-board-config {
     			config = "rm-cfg.yaml";
     	sec-cfg {
     		filename = "sec-cfg.bin";
     		scfg_yaml: ti-board-config {
     			config = "sec-cfg.yaml";
     	combined-tifs-cfg {
    @@ -61,19 +61,19 @@
     		ti-board-config {
     			bcfg_yaml_tifs: board-cfg {
     			scfg_yaml_tifs: sec-cfg {
     			pcfg_yaml_tifs: pm-cfg {
     			rcfg_yaml_tifs: rm-cfg {
    @@ -82,11 +82,11 @@
     		ti-board-config {
     			pcfg_yaml_dm: pm-cfg {
     			rcfg_yaml_dm: rm-cfg {
    @@ -95,19 +95,19 @@
     		ti-board-config {
     			bcfg_yaml_sysfw: board-cfg {
     			scfg_yaml_sysfw: sec-cfg {
     			pcfg_yaml_sysfw: pm-cfg {
     			rcfg_yaml_sysfw: rm-cfg {
    diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig
    index 9168bf842d..52d034634f 100644
    --- a/arch/arm/mach-k3/Kconfig
    +++ b/arch/arm/mach-k3/Kconfig
    @@ -195,4 +195,5 @@ source "board/ti/j721e/Kconfig"
     source "board/siemens/iot2050/Kconfig"
     source "board/ti/j721s2/Kconfig"
     source "board/toradex/verdin-am62/Kconfig"
    +source "board/landisgyr/am62x/Kconfig"
     endif
    diff --git a/arch/arm/mach-k3/am625_init.c b/arch/arm/mach-k3/am625_init.c
    index 8fa36f7b91..7329f183db 100644
    --- a/arch/arm/mach-k3/am625_init.c
    +++ b/arch/arm/mach-k3/am625_init.c
    @@ -112,6 +112,30 @@ static __maybe_unused void rtc_erratumi2327_init(void)
     	writel(K3RTC_KICK1_UNLOCK_VALUE, REG_K3RTC_KICK1);
    +#ifdef CONFIG_SPL_OF_LIST
    +void do_dt_magic(void)
    +	int ret, rescan;
    +	/* Perform board detection */
    +	do_board_detect();
    +	 * Board detection has been done.
    +	 * Let us see if another dtb wouldn't be a better match
    +	 * for our board
    +	if (IS_ENABLED(CONFIG_CPU_V7R)) {
    +	 	ret = fdtdec_resetup(&rescan);
    +	// 	if (!ret && rescan) {
    +	// 		dm_uninit();
    +	// 		dm_init_and_scan(true);
    +#endif
     void board_init_f(ulong dummy)
     	struct udevice *dev;
    @@ -190,6 +214,9 @@ void board_init_f(ulong dummy)
     	/* Output System Firmware version info */
     	k3_sysfw_print_ver();
    +	printf("am625_init board_init_f\n");
    +	do_dt_magic();
     	if (IS_ENABLED(CONFIG_ESM_K3)) {
     		/* Probe/configure ESM0 */
     		ret = uclass_get_device_by_name(UCLASS_MISC, "esm@420000", &dev);
    diff --git a/board/landisgyr/am62x/Kconfig b/board/landisgyr/am62x/Kconfig
    new file mode 100644
    index 0000000000..d9aeff4d59
    --- /dev/null
    +++ b/board/landisgyr/am62x/Kconfig
    @@ -0,0 +1,58 @@
    +# SPDX-License-Identifier: GPL-2.0+
    +# Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/
    +#	Suman Anna <s-anna@ti.com>
    +choice
    +	prompt "Landisgyr K3 AM62x based boards"
    +	optional
    +config TARGET_AM625_A53_LGSOM
    +	bool "Landisgyr K3 based AM625 LGSOM running on A53"
    +	select ARM64
    +	select BINMAN
    +config TARGET_AM625_R5_LGSOM
    +	bool "Landisgyr K3 based AM625 LGSOM running on R5"
    +	select CPU_V7R
    +	select SYS_THUMB_BUILD
    +	select K3_LOAD_SYSFW
    +	select RAM
    +	select SPL_RAM
    +	select K3_DDRSS
    +	select BINMAN
    +	imply SYS_K3_SPL_ATF
    +endchoice
    +if TARGET_AM625_A53_LGSOM
    +config SYS_BOARD
    +       default "am62x"
    +config SYS_VENDOR
    +       default "landisgyr"
    +config SYS_CONFIG_NAME
    +       default "am62x_lgsom"
    +source "board/ti/common/Kconfig"
    +endif
    +if TARGET_AM625_R5_LGSOM
    +config SYS_BOARD
    +       default "am62x"
    +config SYS_VENDOR
    +config SPL_LDSCRIPT
    +	default "arch/arm/mach-omap2/u-boot-spl.lds"
    +endif
    diff --git a/board/landisgyr/am62x/MAINTAINERS b/board/landisgyr/am62x/MAINTAINERS
    index 0000000000..7e47bccc3e
    --- /dev/null
    +++ b/board/landisgyr/am62x/MAINTAINERS
    @@ -0,0 +1,8 @@
    +LGSOM BOARD
    +M:	Bryce Johnson <bryce.johnson@landisgyr.com>
    +S:	Maintained
    +F:	board/ti/am62x/
    +F:	include/configs/am62x_lgsom.h
    +F:	configs/am62x_lgsom_r5_defconfig
    +F:	configs/am62x_lgsom_a53_defconfig
    diff --git a/board/landisgyr/am62x/Makefile b/board/landisgyr/am62x/Makefile
    index 0000000000..6435357f48
    --- /dev/null
    +++ b/board/landisgyr/am62x/Makefile
    @@ -0,0 +1,8 @@
    +obj-y	+= lgsom.o
    diff --git a/board/landisgyr/am62x/am62x.env b/board/landisgyr/am62x/am62x.env
    index 0000000000..ffe676f37a
    --- /dev/null
    +++ b/board/landisgyr/am62x/am62x.env
    @@ -0,0 +1,33 @@
    +#include <env/ti/ti_common.env>
    +#include <env/ti/default_findfdt.env>
    +#include <env/ti/mmc.env>
    +#include <env/ti/k3_dfu.env>
    +default_device_tree=k3-am62-lgsom.dtb
    +findfdt=
    +	setenv name_fdt ${default_device_tree};
    +	setenv fdtfile ${name_fdt}
    +name_kern=Image
    +console=ttyS2,115200n8
    +args_all=setenv optargs ${optargs}
    +	${mtdparts}
    +	panic=3 lgplatform=${lgplatform} overlay=${overlay} bootdir=${bootdir}
    +run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
    +dfu_alt_info=
    +	rawemmc raw 0 0x800000 mmcpart 1;
    +	rootfs part 0 1;
    +	tiboot3.bin.raw raw 0x0 0x400 mmcpart 1;
    +	tispl.bin.raw raw 0x400 0x1000 mmcpart 1;
    +	u-boot.img.raw raw 0x1400 0x2000 mmcpart 1;
    +	u-env.raw raw 0x3400 0x100 mmcpart 1;
    +	sysfw.itb.raw raw 0x3600 0x800 mmcpart 1
    +boot=mmc
    +mmcdev=0
    +bootpart=0:1
    +bootdir=/boot0
    +rd_spec=-
    +silent=
    diff --git a/board/landisgyr/am62x/board-cfg.yaml b/board/landisgyr/am62x/board-cfg.yaml
    index 0000000000..36cfb550ad
    --- /dev/null
    +++ b/board/landisgyr/am62x/board-cfg.yaml
    @@ -0,0 +1,36 @@
    +# Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/
    +# Board configuration for AM62
    +board-cfg:
    +    rev:
    +        boardcfg_abi_maj : 0x0
    +        boardcfg_abi_min : 0x1
    +    control:
    +        subhdr:
    +            magic: 0xC1D3
    +            size: 7
    +        main_isolation_enable : 0x5A
    +        main_isolation_hostid : 0x2
    +    secproxy:
    +        subhdr:
    +            magic: 0x1207
    +            size: 7
    +        scaling_factor : 0x1
    +        scaling_profile : 0x1
    +        disable_main_nav_secure_proxy : 0
    +    msmc:
    +        subhdr:
    +            magic: 0xA5C3
    +            size: 5
    +        msmc_cache_size : 0x0
    +    debug_cfg:
    +        subhdr:
    +            magic: 0x020C
    +            size: 8
    +        trace_dst_enables : 0x00
    +        trace_src_enables : 0x00
    diff --git a/board/landisgyr/am62x/lgsom.c b/board/landisgyr/am62x/lgsom.c
    index 0000000000..7de9ce86a0
    --- /dev/null
    +++ b/board/landisgyr/am62x/lgsom.c
    @@ -0,0 +1,227 @@
    +// SPDX-License-Identifier: GPL-2.0+
    + * Board specific initialization for AM62x platforms
    + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/
    + *	Suman Anna <s-anna@ti.com>
    +#include <common.h>
    +#include <env.h>
    +#include <spl.h>
    +#include <init.h>
    +#include <cpu_func.h>
    +#include <k3-ddrss.h>
    +#include <fdt_support.h>
    +#include <asm/io.h>
    +#include <asm/arch/hardware.h>
    +#include <dm/uclass.h>
    +#include <asm/gpio.h>
    +#include <linux/sizes.h>
    +DECLARE_GLOBAL_DATA_PTR;
    +static u32 som_id;
    +static u32 host_board_id;
    +const char *gpio_table_som_id[] = {
    +	"gpio@600000_44", "gpio@600000_43", "gpio@600000_42",
    +const char *gpio_table_host_id[] = {
    +	"gpio@600000_40", "gpio@600000_36", "gpio@600000_35",
    +///Inspired by uboot/board/liebherr/display5/display5.c
    +static int get_board_id(const char **pin_names, int size, u32 *id)
    +	struct gpio_desc desc;
    +	int i, ret, val;
    +	for (i = 0; i < size; i++) {
    +		memset(&desc, 0, sizeof(desc));
    +		ret = dm_gpio_lookup_name(pin_names[i], &desc);
    +		if (ret) {
    +			printf("Can't lookup request SWx gpios %d\n",ret);
    +			return ret;
    +		/* Request GPIO, simply re-using the name as label */
    +		ret = dm_gpio_request(&desc, pin_names[i]);
    +		if (ret) {
    +			printf("Can't lookup request SWx gpios: %d\n",ret);
    +			return ret;
    +		ret = dm_gpio_set_dir_flags(&desc, GPIOD_IS_IN);
    +		if (ret) {
    +			printf("error setting direction flag of GPIO: %d\n", ret);
    +			return ret;
    +		val = dm_gpio_get_value(&desc);
    +		if (val < 0) {
    +			printf("Can't get SW%d ID\n", i);
    +			return val;
    +		printf("Pin %d: val %d\n",i, val);
    +		*id |= val << i;
    +	return 0;
    +int board_init(void)
    +	printf("board_init\n");
    +	int ret;
    +	host_board_id = 0;
    +	ret = get_board_id(gpio_table_host_id, ARRAY_SIZE(gpio_table_host_id), &host_board_id);
    +	if (ret) {
    +		printf("get_host_board_id failure %d\n",ret);
    +	} else {
    +		printf("Host_Board_ID 0x%x\n", host_board_id);
    +	return 0;
    +int dram_init(void)
    +	printf("dram_init\n");
    +	return fdtdec_setup_mem_size_base();
    +int dram_init_banksize(void)
    +	return fdtdec_setup_memory_banksize();
    +phys_size_t get_effective_memsize(void)
    +	 * Just below 512MB are TF-A and OPTEE reserve regions, thus
    +	 * SPL/U-Boot RAM has to start below that. Leave 64MB space for
    +	 * all reserved memories.
    +	return gd->ram_size == SZ_512M ? SZ_512M - SZ_64M  : gd->ram_size;
    +#if defined(CONFIG_SPL_BUILD)
    +#if defined(CONFIG_SPL_LOAD_FIT)
    +void do_board_detect(void)
    +	int ret;
    +	som_id = 0;
    +	ret = get_board_id(gpio_table_som_id, ARRAY_SIZE(gpio_table_som_id), &som_id);
    +	if (ret) {
    +		printf("get_board_id SomID failure %d\n",ret);
    +	} else {
    +		printf("SomID 0x%x\n", som_id);
    +int board_fit_config_name_match(const char *name)
    +	if (som_id == 0)
    +		printf("SomID selects k3-am625-r5-lgsom-sip dts\n");
    +		if (!strcmp(name, "k3-am625-r5-lgsom-sip"))
    +			return 0;
    +	} else if (som_id == 1) {
    +		printf("SomID selects k3-am625-r5-lgsom-discrete dts\n");
    +		if (!strcmp(name, "k3-am625-r5-lgsom-discrete"))
    +			return 0;
    +	} else {
    +		printf("Unknown SomID 0x%x\n",som_id);
    +	return -1;
    +#endif
    +#define CTRLMMR_USB0_PHY_CTRL	0x43004008
    +#define CORE_VOLTAGE		0x80000000
    +void spl_board_init(void)
    +	printf("Set USB core voltage\n");
    +	u32 val;
    +	/* Set USB0 PHY core voltage to 0.85V */
    +	val = readl(CTRLMMR_USB0_PHY_CTRL);
    +	val &= ~(CORE_VOLTAGE);
    +	writel(val, CTRLMMR_USB0_PHY_CTRL);
    +#if defined(CONFIG_K3_AM64_DDRSS)
    +static void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image)
    +	struct udevice *dev;
    +	int ret;
    +	dram_init_banksize();
    +	ret = uclass_get_device(UCLASS_RAM, 0, &dev);
    +	if (ret)
    +		panic("Cannot get RAM device for ddr size fixup: %d\n", ret);
    +	ret = k3_ddrss_ddr_fdt_fixup(dev, spl_image->fdt_addr, gd->bd);
    +	if (ret)
    +		printf("Error fixing up ddr node for ECC use! %d\n", ret);
    +#else
    +static void fixup_memory_node(struct spl_image_info *spl_image)
    +	u64 start[CONFIG_NR_DRAM_BANKS];
    +	u64 size[CONFIG_NR_DRAM_BANKS];
    +	int bank;
    +	int ret;
    +	dram_init();
    +	for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) {
    +		start[bank] =  gd->bd->bi_dram[bank].start;
    +		size[bank] = gd->bd->bi_dram[bank].size;
    +	/* dram_init functions use SPL fdt, and we must fixup u-boot fdt */
    +	ret = fdt_fixup_memory_banks(spl_image->fdt_addr, start, size,
    +				     CONFIG_NR_DRAM_BANKS);
    +	if (ret)
    +		printf("Error fixing up memory node! %d\n", ret);
    +#endif
    +void spl_perform_fixups(struct spl_image_info *spl_image)
    +	fixup_ddr_driver_for_ecc(spl_image);
    +#else
    +	fixup_memory_node(spl_image);
    +#endif
    +#endif
    +#ifdef CONFIG_BOARD_LATE_INIT
    +int board_late_init(void)
    +	return 0;
    +#endif
    diff --git a/board/landisgyr/am62x/pm-cfg.yaml b/board/landisgyr/am62x/pm-cfg.yaml
    index 0000000000..5d04cf82ef
    --- /dev/null
    +++ b/board/landisgyr/am62x/pm-cfg.yaml
    @@ -0,0 +1,12 @@
    +# Power management configuration for AM62
    +pm-cfg:
    +    rev:
    diff --git a/board/landisgyr/am62x/rm-cfg.yaml b/board/landisgyr/am62x/rm-cfg.yaml
    index 0000000000..c28707be8e
    --- /dev/null
    +++ b/board/landisgyr/am62x/rm-cfg.yaml
    @@ -0,0 +1,1088 @@
    +# Resource management configuration for AM62
    +rm-cfg:
    +    rm_boardcfg:
    +        rev:
    +        host_cfg:
    +            subhdr:
    +                magic: 0x4C41
    +                size : 356
    +            host_cfg_entries:
    +                - #1
    +                    host_id: 12
    +                    allowed_atype : 0x2A
    +                    allowed_qos : 0xAAAA
    +                    allowed_orderid : 0xAAAAAAAA
    +                    allowed_priority : 0xAAAA
    +                    allowed_sched_priority : 0xAA
    +                - #2
    +                    host_id: 30
    +                - #3
    +                    host_id: 36
    +                - #4
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #5
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #6
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #7
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #8
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #9
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #10
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #11
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #12
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #13
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #14
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #15
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #16
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #17
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #18
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #19
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #20
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #21
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #22
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #23
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #24
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #25
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #26
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #27
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #28
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #29
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #30
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #31
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +                - #32
    +                    host_id: 0
    +                    allowed_atype : 0
    +                    allowed_qos : 0
    +        resasg:
    +            subhdr:
    +                magic: 0x7B25
    +                size : 8
    +            resasg_entries_size: 960
    +            reserved : 0
    +    resasg_entries:
    +                start_resource: 0
    +                num_resource: 16
    +                type: 64
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 16
    +                num_resource: 4
    +                type: 64
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 4
    +                type: 64
    +                host_id: 36
    +                reserved: 0
    +                start_resource: 20
    +                num_resource: 22
    +                type: 64
    +                host_id: 30
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 16
    +                type: 192
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 34
    +                num_resource: 2
    +                type: 192
    +                host_id: 30
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 4
    +                type: 320
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 4
    +                num_resource: 4
    +                type: 320
    +                host_id: 30
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 26
    +                type: 384
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 50176
    +                num_resource: 164
    +                type: 1666
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 1
    +                type: 1667
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 18
    +                type: 1677
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 18
    +                num_resource: 6
    +                type: 1677
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 6
    +                type: 1677
    +                host_id: 36
    +                reserved: 0
    +                start_resource: 24
    +                num_resource: 2
    +                type: 1677
    +                host_id: 30
    +                reserved: 0
    +                start_resource: 26
    +                num_resource: 6
    +                type: 1677
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 54
    +                num_resource: 18
    +                type: 1678
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 72
    +                num_resource: 6
    +                type: 1678
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 6
    +                type: 1678
    +                host_id: 36
    +                reserved: 0
    +                start_resource: 78
    +                num_resource: 2
    +                type: 1678
    +                host_id: 30
    +                reserved: 0
    +                start_resource: 80
    +                num_resource: 2
    +                type: 1678
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 32
    +                num_resource: 12
    +                type: 1679
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 44
    +                num_resource: 6
    +                type: 1679
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 6
    +                type: 1679
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 2
    +                type: 1679
    +                host_id: 30
    +                reserved: 0
    +                start_resource: 52
    +                num_resource: 2
    +                type: 1679
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 18
    +                type: 1696
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 6
    +                type: 1696
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 6
    +                type: 1696
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 2
    +                type: 1696
    +                host_id: 30
    +                reserved: 0
    +                num_resource: 6
    +                type: 1696
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 18
    +                type: 1697
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 6
    +                type: 1697
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 6
    +                type: 1697
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 2
    +                type: 1697
    +                host_id: 30
    +                reserved: 0
    +                num_resource: 2
    +                type: 1697
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 12
    +                type: 1698
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 12
    +                num_resource: 6
    +                type: 1698
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 6
    +                type: 1698
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 2
    +                type: 1698
    +                host_id: 30
    +                reserved: 0
    +                num_resource: 2
    +                type: 1698
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 5
    +                num_resource: 35
    +                type: 1802
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 36
    +                type: 1802
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 36
    +                type: 1802
    +                host_id: 36
    +                reserved: 0
    +                start_resource: 168
    +                num_resource: 8
    +                type: 1802
    +                host_id: 30
    +                reserved: 0
    +                start_resource: 13
    +                num_resource: 512
    +                type: 1805
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 525
    +                num_resource: 256
    +                type: 1805
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 256
    +                type: 1805
    +                host_id: 36
    +                reserved: 0
    +                start_resource: 781
    +                num_resource: 128
    +                type: 1805
    +                host_id: 30
    +                reserved: 0
    +                start_resource: 909
    +                num_resource: 627
    +                type: 1805
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 1024
    +                type: 1807
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 4096
    +                num_resource: 29
    +                type: 1808
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 4608
    +                num_resource: 99
    +                type: 1809
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 5120
    +                num_resource: 24
    +                type: 1810
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 5632
    +                num_resource: 51
    +                type: 1811
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 6144
    +                num_resource: 51
    +                type: 1812
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 6656
    +                num_resource: 51
    +                type: 1813
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 8192
    +                num_resource: 32
    +                type: 1814
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 8704
    +                num_resource: 32
    +                type: 1815
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 9216
    +                num_resource: 32
    +                type: 1816
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 9728
    +                num_resource: 22
    +                type: 1817
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 10240
    +                num_resource: 22
    +                type: 1818
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 10752
    +                num_resource: 22
    +                type: 1819
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 11264
    +                num_resource: 28
    +                type: 1820
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 11776
    +                num_resource: 28
    +                type: 1821
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 12288
    +                num_resource: 28
    +                type: 1822
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 1
    +                type: 1923
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 10
    +                type: 1936
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 3
    +                type: 1936
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 3
    +                type: 1936
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 3
    +                type: 1936
    +                host_id: 30
    +                reserved: 0
    +                num_resource: 3
    +                type: 1936
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 19
    +                num_resource: 64
    +                type: 1937
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 64
    +                type: 1937
    +                host_id: 36
    +                reserved: 0
    +                start_resource: 83
    +                num_resource: 8
    +                type: 1938
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 91
    +                num_resource: 8
    +                type: 1939
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 99
    +                num_resource: 10
    +                type: 1942
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 109
    +                num_resource: 3
    +                type: 1942
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 3
    +                type: 1942
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 3
    +                type: 1942
    +                host_id: 30
    +                reserved: 0
    +                start_resource: 115
    +                num_resource: 3
    +                type: 1942
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 118
    +                num_resource: 16
    +                type: 1943
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 16
    +                type: 1943
    +                host_id: 36
    +                reserved: 0
    +                start_resource: 134
    +                num_resource: 8
    +                type: 1944
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 8
    +                type: 1945
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 142
    +                num_resource: 8
    +                type: 1946
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 8
    +                type: 1947
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 10
    +                type: 1955
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 3
    +                type: 1955
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 3
    +                type: 1955
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 3
    +                type: 1955
    +                host_id: 30
    +                reserved: 0
    +                num_resource: 3
    +                type: 1955
    +                host_id: 128
    +                reserved: 0
    +                num_resource: 8
    +                type: 1956
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 8
    +                type: 1956
    +                host_id: 36
    +                reserved: 0
    +                start_resource: 27
    +                num_resource: 1
    +                type: 1957
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 28
    +                num_resource: 1
    +                type: 1958
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 10
    +                type: 1961
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 3
    +                type: 1961
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 3
    +                type: 1961
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 3
    +                type: 1961
    +                host_id: 30
    +                reserved: 0
    +                num_resource: 3
    +                type: 1961
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 10
    +                type: 1962
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 3
    +                type: 1962
    +                host_id: 35
    +                reserved: 0
    +                num_resource: 3
    +                type: 1962
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 3
    +                type: 1962
    +                host_id: 30
    +                reserved: 0
    +                num_resource: 3
    +                type: 1962
    +                host_id: 128
    +                reserved: 0
    +                num_resource: 1
    +                type: 1963
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 1
    +                type: 1963
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 16
    +                type: 1964
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 16
    +                type: 1964
    +                host_id: 36
    +                reserved: 0
    +                num_resource: 1
    +                type: 1965
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 35
    +                num_resource: 8
    +                type: 1966
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 21
    +                num_resource: 1
    +                type: 1967
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 8
    +                type: 1968
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 22
    +                num_resource: 1
    +                type: 1969
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 43
    +                num_resource: 8
    +                type: 1970
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 23
    +                num_resource: 1
    +                type: 1971
    +                host_id: 12
    +                reserved: 0
    +                num_resource: 8
    +                type: 1972
    +                host_id: 12
    +                reserved: 0
    +                start_resource: 0
    +                num_resource: 1
    +                type: 2112
    +                host_id: 128
    +                reserved: 0
    +                start_resource: 2
    +                num_resource: 2
    +                type: 2122
    +                host_id: 12
    +                reserved: 0
    diff --git a/board/landisgyr/am62x/sec-cfg.yaml b/board/landisgyr/am62x/sec-cfg.yaml
    index 0000000000..07081ce06c
    --- /dev/null
    +++ b/board/landisgyr/am62x/sec-cfg.yaml
    @@ -0,0 +1,379 @@
    +# Security management configuration for AM62
    +sec-cfg:
    +    rev:
    +    processor_acl_list:
    +        subhdr:
    +            magic: 0xF1EA
    +            size: 164
    +        proc_acl_entries:
    +            - #1
    +                processor_id: 0
    +                proc_access_master: 0
    +                proc_access_secondary: [0, 0, 0]
    +            - #2
    +                processor_id: 0
    +            - #3
    +                processor_id: 0
    +            - #4
    +                processor_id: 0
    +            - #5
    +                processor_id: 0
    +            - #6
    +                processor_id: 0
    +            - #7
    +                processor_id: 0
    +            - #8
    +                processor_id: 0
    +            - #9
    +                processor_id: 0
    +            - #10
    +                processor_id: 0
    +            - #11
    +                processor_id: 0
    +            - #12
    +                processor_id: 0
    +            - #13
    +                processor_id: 0
    +            - #14
    +                processor_id: 0
    +            - #15
    +                processor_id: 0
    +            - #16
    +                processor_id: 0
    +            - #17
    +                processor_id: 0
    +            - #18
    +                processor_id: 0
    +            - #19
    +                processor_id: 0
    +            - #20
    +                processor_id: 0
    +            - #21
    +                processor_id: 0
    +            - #22
    +                processor_id: 0
    +            - #23
    +                processor_id: 0
    +            - #24
    +                processor_id: 0
    +            - #25
    +                processor_id: 0
    +            - #26
    +                processor_id: 0
    +            - #27
    +                processor_id: 0
    +            - #28
    +                processor_id: 0
    +            - #29
    +                processor_id: 0
    +            - #30
    +                processor_id: 0
    +            - #31
    +                processor_id: 0
    +            - #32
    +                processor_id: 0
    +    host_hierarchy:
    +        subhdr:
    +            magic: 0x8D27
    +            size: 68
    +        host_hierarchy_entries:
    +            - #1
    +                host_id: 0
    +                supervisor_host_id: 0
    +            - #2
    +                host_id: 0
    +            - #3
    +                host_id: 0
    +            - #4
    +                host_id: 0
    +            - #5
    +                host_id: 0
    +            - #6
    +                host_id: 0
    +            - #7
    +                host_id: 0
    +            - #8
    +                host_id: 0
    +            - #9
    +                host_id: 0
    +            - #10
    +                host_id: 0
    +            - #11
    +                host_id: 0
    +            - #12
    +                host_id: 0
    +            - #13
    +                host_id: 0
    +            - #14
    +                host_id: 0
    +            - #15
    +                host_id: 0
    +            - #16
    +                host_id: 0
    +            - #17
    +                host_id: 0
    +            - #18
    +                host_id: 0
    +            - #19
    +                host_id: 0
    +            - #20
    +                host_id: 0
    +            - #21
    +                host_id: 0
    +            - #22
    +                host_id: 0
    +            - #23
    +                host_id: 0
    +            - #24
    +                host_id: 0
    +            - #25
    +                host_id: 0
    +            - #26
    +                host_id: 0
    +            - #27
    +                host_id: 0
    +            - #28
    +                host_id: 0
    +            - #29
    +                host_id: 0
    +            - #30
    +                host_id: 0
    +            - #31
    +                host_id: 0
    +            - #32
    +                host_id: 0
    +    otp_config:
    +        subhdr:
    +            magic: 0x4081
    +            size: 69
    +        write_host_id : 0
    +        otp_entry:
    +            - #1
    +                host_id: 0
    +                host_perms: 0
    +            - #2
    +                host_id: 0
    +                host_perms: 0
    +            - #3
    +                host_id: 0
    +                host_perms: 0
    +            - #4
    +                host_id: 0
    +                host_perms: 0
    +            - #5
    +                host_id: 0
    +                host_perms: 0
    +            - #6
    +                host_id: 0
    +                host_perms: 0
    +            - #7
    +                host_id: 0
    +                host_perms: 0
    +            - #8
    +                host_id: 0
    +                host_perms: 0
    +            - #9
    +                host_id: 0
    +                host_perms: 0
    +            - #10
    +                host_id: 0
    +                host_perms: 0
    +            - #11
    +                host_id: 0
    +                host_perms: 0
    +            - #12
    +                host_id: 0
    +                host_perms: 0
    +            - #13
    +                host_id: 0
    +                host_perms: 0
    +            - #14
    +                host_id: 0
    +                host_perms: 0
    +            - #15
    +                host_id: 0
    +                host_perms: 0
    +            - #16
    +                host_id: 0
    +                host_perms: 0
    +            - #17
    +                host_id: 0
    +                host_perms: 0
    +            - #18
    +                host_id: 0
    +                host_perms: 0
    +            - #19
    +                host_id: 0
    +                host_perms: 0
    +            - #20
    +                host_id: 0
    +                host_perms: 0
    +            - #21
    +                host_id: 0
    +                host_perms: 0
    +            - #22
    +                host_id: 0
    +                host_perms: 0
    +            - #23
    +                host_id: 0
    +                host_perms: 0
    +            - #24
    +                host_id: 0
    +                host_perms: 0
    +            - #25
    +                host_id: 0
    +                host_perms: 0
    +            - #26
    +                host_id: 0
    +                host_perms: 0
    +            - #27
    +                host_id: 0
    +                host_perms: 0
    +            - #28
    +                host_id: 0
    +                host_perms: 0
    +            - #29
    +                host_id: 0
    +                host_perms: 0
    +            - #30
    +                host_id: 0
    +                host_perms: 0
    +            - #31
    +                host_id: 0
    +                host_perms: 0
    +            - #32
    +                host_id: 0
    +                host_perms: 0
    +    dkek_config:
    +        subhdr:
    +            magic: 0x5170
    +            size: 12
    +        allowed_hosts: [128, 0, 0, 0]
    +        allow_dkek_export_tisci : 0x5A
    +        rsvd: [0, 0, 0]
    +    sa2ul_cfg:
    +        subhdr:
    +            magic: 0x23BE
    +            size : 0
    +        auth_resource_owner: 0
    +        enable_saul_psil_global_config_writes: 0x5A
    +        rsvd: [0, 0]
    +    sec_dbg_config:
    +        subhdr:
    +            magic: 0x42AF
    +            size: 16
    +        allow_jtag_unlock : 0x5A
    +        allow_wildcard_unlock : 0x5A
    +        allowed_debug_level_rsvd: 0
    +        rsvd: 0
    +        min_cert_rev : 0x0
    +        jtag_unlock_hosts: [0, 0, 0, 0]
    +    sec_handover_cfg:
    +        subhdr:
    +            magic: 0x608F
    +            size: 10
    +        handover_msg_sender : 0
    +        handover_to_host_id : 0
    +        rsvd: [0, 0, 0, 0]
    diff --git a/board/ti/am62x/am62x.env b/board/ti/am62x/am62x.env
    index e53a55c38f..0651b9cd7c 100644
    --- a/board/ti/am62x/am62x.env
    +++ b/board/ti/am62x/am62x.env
    @@ -1,6 +1,7 @@
     name_kern=Image
    diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig
    index df2511546e..1bd8f0fd9e 100644
    --- a/configs/am62x_evm_a53_defconfig
    +++ b/configs/am62x_evm_a53_defconfig
    @@ -1,5 +1,6 @@
     CONFIG_ARM=y
     CONFIG_ARCH_K3=y
    +CONFIG_SYS_MALLOC_LEN=0x2000000
     CONFIG_SYS_MALLOC_F_LEN=0x8000
     CONFIG_SPL_LIBCOMMON_SUPPORT=y
     CONFIG_SPL_LIBGENERIC_SUPPORT=y
    @@ -40,17 +41,23 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y
     CONFIG_SPL_STACK_R=y
     CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
     CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400
    +CONFIG_SPL_ENV_SUPPORT=y
     CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img"
     CONFIG_SPL_DM_MAILBOX=y
     CONFIG_SPL_DM_SPI_FLASH=y
     CONFIG_SPL_POWER_DOMAIN=y
    +CONFIG_SPL_RAM_SUPPORT=y
    +CONFIG_SPL_RAM_DEVICE=y
     # CONFIG_SPL_SPI_FLASH_TINY is not set
     CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y
     CONFIG_SPL_SPI_LOAD=y
     CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000
    +CONFIG_SPL_USB_GADGET=y
    +CONFIG_SPL_DFU=y
     CONFIG_SPL_YMODEM_SUPPORT=y
    -CONFIG_SYS_BOOTM_LEN=0x800000
    +CONFIG_CMD_DFU=y
     CONFIG_CMD_MMC=y
    +CONFIG_CMD_USB=y
     CONFIG_OF_CONTROL=y
     CONFIG_SPL_OF_CONTROL=y
     CONFIG_MULTI_DTB_FIT=y
    @@ -61,10 +68,17 @@ CONFIG_SPL_DM=y
     CONFIG_SPL_DM_SEQ_ALIAS=y
     CONFIG_REGMAP=y
     CONFIG_SPL_REGMAP=y
    +CONFIG_SYSCON=y
    +CONFIG_SPL_SYSCON=y
     CONFIG_SPL_OF_TRANSLATE=y
     CONFIG_CLK=y
     CONFIG_SPL_CLK=y
     CONFIG_CLK_TI_SCI=y
    +CONFIG_DFU_MMC=y
    +CONFIG_DFU_RAM=y
    +CONFIG_DFU_SF=y
    +CONFIG_SYS_DFU_DATA_BUF_SIZE=0x5000
    +CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000
     CONFIG_DMA_CHANNELS=y
     CONFIG_TI_K3_NAVSS_UDMA=y
     CONFIG_TI_SCI_PROTOCOL=y
    @@ -103,4 +117,19 @@ CONFIG_CADENCE_QSPI=y
     CONFIG_SYSRESET=y
     CONFIG_SPL_SYSRESET=y
     CONFIG_SYSRESET_TI_SCI=y
    +CONFIG_USB=y
    +CONFIG_DM_USB_GADGET=y
    +CONFIG_SPL_DM_USB_GADGET=y
    +CONFIG_USB_XHCI_HCD=y
    +CONFIG_USB_XHCI_DWC3=y
    +CONFIG_USB_DWC3=y
    +CONFIG_USB_DWC3_GENERIC=y
    +CONFIG_SPL_USB_DWC3_GENERIC=y
    +CONFIG_SPL_USB_DWC3_AM62=y
    +CONFIG_USB_DWC3_AM62=y
    +CONFIG_USB_GADGET=y
    +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments"
    +CONFIG_USB_GADGET_VENDOR_NUM=0x0451
    +CONFIG_USB_GADGET_PRODUCT_NUM=0x6165
    +CONFIG_USB_GADGET_DOWNLOAD=y
     CONFIG_FS_FAT_MAX_CLUSTSIZE=16384
    diff --git a/configs/am62x_r5_usbdfu.config b/configs/am62x_r5_usbdfu.config
    index 0000000000..772bb2ab93
    --- /dev/null
    +++ b/configs/am62x_r5_usbdfu.config
    @@ -0,0 +1,28 @@
    +CONFIG_SYSCON=y
    +CONFIG_MISC=y
    +CONFIG_USB=y
    +CONFIG_USB_DWC3=y
    +CONFIG_SPL_DFU=y
    +# CONFIG_SPL_MMC is not set
    +# CONFIG_SPL_FS_FAT is not set
    +# CONFIG_SPL_LIBDISK_SUPPORT is not set
    +# CONFIG_SPL_SPI is not set
    +# CONFIG_SPL_SYS_MALLOC is not set
    +# CONFIG_CMD_GPT is not set
    +# CONFIG_CMD_MMC is not set
    +# CONFIG_CMD_FAT is not set
    +# CONFIG_MMC_SDHCI is not set
    diff --git a/drivers/usb/dwc3/Kconfig b/drivers/usb/dwc3/Kconfig
    index c0c8c16fd9..0100723a68 100644
    --- a/drivers/usb/dwc3/Kconfig
    +++ b/drivers/usb/dwc3/Kconfig
    @@ -37,6 +37,20 @@ config SPL_USB_DWC3_GENERIC
     	  Select this for Xilinx ZynqMP and similar Platforms.
     	  This wrapper supports Host and Peripheral operation modes.
    +config SPL_USB_DWC3_AM62
    +	bool "TI AM62 USB wrapper"
    +	depends on SPL_DM_USB && SPL_USB_DWC3_GENERIC && SPL_SYSCON
    +	help
    +	  Select this for TI AM62 Platforms.
    +	  This wrapper supports Host and Peripheral operation modes.
    +config USB_DWC3_AM62
    +	depends on DM_USB && USB_DWC3_GENERIC && SYSCON
    +	help
     config USB_DWC3_MESON_G12A
     	bool "Amlogic Meson G12A USB wrapper"
     	depends on DM_USB && USB_DWC3 && ARCH_MESON
    diff --git a/drivers/usb/dwc3/Makefile b/drivers/usb/dwc3/Makefile
    index 97b4f7191c..a46b6824ab 100644
    --- a/drivers/usb/dwc3/Makefile
    +++ b/drivers/usb/dwc3/Makefile
    @@ -6,6 +6,7 @@ dwc3-y					:= core.o
     obj-$(CONFIG_USB_DWC3_GADGET)		+= gadget.o ep0.o
    +obj-$(CONFIG_$(SPL_)USB_DWC3_AM62)	+= dwc3-am62.o
     obj-$(CONFIG_USB_DWC3_OMAP)		+= dwc3-omap.o
     obj-$(CONFIG_USB_DWC3_MESON_G12A)	+= dwc3-meson-g12a.o
     obj-$(CONFIG_USB_DWC3_MESON_GXL)	+= dwc3-meson-gxl.o
    diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c
    index 3aec8b0d94..31e2f95f4b 100644
    --- a/drivers/usb/dwc3/core.c
    +++ b/drivers/usb/dwc3/core.c
    @@ -43,7 +43,7 @@
     static LIST_HEAD(dwc3_list);
    -static void dwc3_set_mode(struct dwc3 *dwc, u32 mode)
    +void dwc3_core_set_mode(struct dwc3 *dwc, u32 mode)
     	u32 reg;
    @@ -737,7 +737,7 @@ static int dwc3_core_init_mode(struct dwc3 *dwc)
     	switch (dwc->dr_mode) {
     	case USB_DR_MODE_PERIPHERAL:
    -		dwc3_set_mode(dwc, DWC3_GCTL_PRTCAP_DEVICE);
    +		dwc3_core_set_mode(dwc, DWC3_GCTL_PRTCAP_DEVICE);
     		ret = dwc3_gadget_init(dwc);
     		if (ret) {
     			dev_err(dwc->dev, "failed to initialize gadget\n");
    @@ -745,7 +745,7 @@ static int dwc3_core_init_mode(struct dwc3 *dwc)
     		break;
     	case USB_DR_MODE_HOST:
    -		dwc3_set_mode(dwc, DWC3_GCTL_PRTCAP_HOST);
    +		dwc3_core_set_mode(dwc, DWC3_GCTL_PRTCAP_HOST);
     		ret = dwc3_host_init(dwc);
     		if (ret) {
     			dev_err(dwc->dev, "failed to initialize host\n");
    @@ -753,7 +753,7 @@ static int dwc3_core_init_mode(struct dwc3 *dwc)
     		break;
     	case USB_DR_MODE_OTG:
    -		dwc3_set_mode(dwc, DWC3_GCTL_PRTCAP_OTG);
    +		dwc3_core_set_mode(dwc, DWC3_GCTL_PRTCAP_OTG);
     		if (ret) {
    @@ -811,7 +811,7 @@ static void dwc3_core_exit_mode(struct dwc3 *dwc)
     	 * switch back to peripheral mode
     	 * This enables the phy to enter idle and then, if enabled, suspend.
     	dwc3_gadget_run(dwc);
    diff --git a/drivers/usb/dwc3/core.h b/drivers/usb/dwc3/core.h
    index 4162a68229..1e7eda89a3 100644
    --- a/drivers/usb/dwc3/core.h
    +++ b/drivers/usb/dwc3/core.h
    @@ -1057,6 +1057,7 @@ int dwc3_gadget_resize_tx_fifos(struct dwc3 *dwc);
     void dwc3_of_parse(struct dwc3 *dwc);
     int dwc3_init(struct dwc3 *dwc);
     void dwc3_remove(struct dwc3 *dwc);
    +void dwc3_core_set_mode(struct dwc3 *dwc, u32 mode);
     static inline int dwc3_host_init(struct dwc3 *dwc)
     { return 0; }
    diff --git a/drivers/usb/dwc3/dwc3-am62.c b/drivers/usb/dwc3/dwc3-am62.c
    index 0000000000..99519602eb
    --- /dev/null
    +++ b/drivers/usb/dwc3/dwc3-am62.c
    @@ -0,0 +1,125 @@
    + * TI AM62 specific glue layer for DWC3
    +#include <dm.h>
    +#include <dm/device_compat.h>
    +#include <regmap.h>
    +#include <syscon.h>
    +#include "dwc3-generic.h"
    +#define USBSS_MODE_CONTROL		0x1c
    +#define USBSS_PHY_CONFIG		0x8
    +#define USBSS_PHY_VBUS_SEL_MASK		GENMASK(2, 1)
    +#define USBSS_PHY_VBUS_SEL_SHIFT	1
    +#define USBSS_MODE_VALID	BIT(0)
    +#define PHY_PLL_REFCLK_MASK	GENMASK(3, 0)
    +static const int dwc3_ti_am62_rate_table[] = {	/* in KHZ */
    +	9600,
    +	10000,
    +	12000,
    +	19200,
    +	20000,
    +	24000,
    +	25000,
    +	26000,
    +	38400,
    +	40000,
    +	58000,
    +	50000,
    +	52000,
    +static void dwc3_ti_am62_glue_configure(struct udevice *dev, int index,
    +					enum usb_dr_mode mode)
    +	struct clk usb2_refclk;
    +	int rate_code, i, ret;
    +	unsigned long rate;
    +	u32 reg;
    +	void *usbss;
    +	bool vbus_divider;
    +	struct regmap *syscon;
    +	struct ofnode_phandle_args args;
    +	usbss = dev_remap_addr_index(dev, 0);
    +	if (IS_ERR(usbss)) {
    +		dev_err(dev, "can't map IOMEM resource\n");
    +		return;
    +	ret = clk_get_by_name(dev, "ref", &usb2_refclk);
    +	if (ret) {
    +		dev_err(dev, "can't get usb2_refclk\n");
    +		return;
    +	/* Calculate the rate code */
    +	rate = clk_get_rate(&usb2_refclk);
    +	rate /= 1000;	/* To KHz */
    +	for (i = 0; i < ARRAY_SIZE(dwc3_ti_am62_rate_table); i++) {
    +		if (dwc3_ti_am62_rate_table[i] == rate)
    +			break;
    +	if (i == ARRAY_SIZE(dwc3_ti_am62_rate_table)) {
    +		dev_err(dev, "unsupported usb2_refclk rate: %lu KHz\n", rate);
    +		return;
    +	rate_code = i;
    +	/* Read the syscon property */
    +	syscon = syscon_regmap_lookup_by_phandle(dev, "ti,syscon-phy-pll-refclk");
    +	if (IS_ERR(syscon)) {
    +		dev_err(dev, "unable to get ti,syscon-phy-pll-refclk regmap\n");
    +		return;
    +	ret = ofnode_parse_phandle_with_args(dev_ofnode(dev), "ti,syscon-phy-pll-refclk", NULL, 1,
    +					     0, &args);
    +	if (ret)
    +		return;
    +	/* Program PHY PLL refclk by reading syscon property */
    +	ret = regmap_update_bits(syscon, args.args[0], PHY_PLL_REFCLK_MASK, rate_code);
    +	if (ret) {
    +		dev_err(dev, "failed to set phy pll reference clock rate\n");
    +		return;
    +	/* VBUS divider select */
    +	reg = readl(usbss + USBSS_PHY_CONFIG);
    +	vbus_divider = dev_read_bool(dev, "ti,vbus-divider");
    +	if (vbus_divider)
    +		reg |= 1 << USBSS_PHY_VBUS_SEL_SHIFT;
    +	writel(reg, usbss + USBSS_PHY_CONFIG);
    +	/* Set mode valid */
    +	reg = readl(usbss + USBSS_MODE_CONTROL);
    +	reg |= USBSS_MODE_VALID;
    +	writel(reg, usbss + USBSS_MODE_CONTROL);
    +struct dwc3_glue_ops ti_am62_ops = {
    +	.glue_configure = dwc3_ti_am62_glue_configure,
    +static const struct udevice_id dwc3_am62_match[] = {
    +	{ .compatible = "ti,am62-usb", .data = (ulong)&ti_am62_ops },
    +	{ /* sentinel */ }
    +U_BOOT_DRIVER(dwc3_am62_wrapper) = {
    +	.name	= "dwc3-am62",
    +	.id	= UCLASS_SIMPLE_BUS,
    +	.of_match = dwc3_am62_match,
    +	.bind = dwc3_glue_bind,
    +	.probe = dwc3_glue_probe,
    +	.remove = dwc3_glue_remove,
    +	.plat_auto	= sizeof(struct dwc3_glue_data),
    diff --git a/drivers/usb/dwc3/gadget.c b/drivers/usb/dwc3/gadget.c
    index 406d36ceaf..69d9fe40e2 100644
    --- a/drivers/usb/dwc3/gadget.c
    +++ b/drivers/usb/dwc3/gadget.c
    @@ -1468,6 +1468,9 @@ static int dwc3_gadget_start(struct usb_gadget *g,
     	dwc->gadget_driver	= driver;
    +	if (dwc->dr_mode == DWC3_GCTL_PRTCAP_OTG)
     	reg = dwc3_readl(dwc->regs, DWC3_DCFG);
     	reg &= ~(DWC3_DCFG_SPEED_MASK);
    @@ -1559,6 +1562,9 @@ static int dwc3_gadget_stop(struct usb_gadget *g)
     	__dwc3_gadget_ep_disable(dwc->eps[0]);
     	__dwc3_gadget_ep_disable(dwc->eps[1]);
     	dwc->gadget_driver	= NULL;
     	spin_unlock_irqrestore(&dwc->lock, flags);
    diff --git a/include/configs/am62x_lgsom.h b/include/configs/am62x_lgsom.h
    index 0000000000..c8fe59b753
    --- /dev/null
    +++ b/include/configs/am62x_lgsom.h
    @@ -0,0 +1,15 @@
    +/* SPDX-License-Identifier: GPL-2.0+ */
    + * Configuration header file for K3 AM625 SoC family
    +#ifndef __CONFIG_AM625_EVM_H
    +#define __CONFIG_AM625_EVM_H
    +/* Now for the remaining common defines */
    +#include <configs/ti_armv7_common.h>
    +#endif /* __CONFIG_AM625_EVM_H */
    2.34.1
    Apologies I had missed out on the thread.
    Is this issue still open?
    Aparna
  • Yes, I provided a patch of all my changes above
  • Hi Bryce,
    Aparna will be out of office for the next few days. Please expect an update by the end of this week.
    Thank you for your patience.
    Nitika
