Part Number: AM3352
Andreas Dannenberg i accidently close the previous thread as resolved.. actually its not solved regarding build error ((+) AM3352: Build Error - Processors forum - Processors - TI E2E support forums)
I found observations as below..
I figured it out that there is memory space issue as below, also mentioned below memory configurations..
please let me know we need to increase any memory in any of the source directory.
Also i have used
"MACHINE=am335x-evm bitbake tisdk-base-image" instead of "MACHINE=am335x-evm bitbake -k tisdk-default-image" is that fine?
sem3user@INBLRPRODDC9LN:~/from_tisdk/tisdk/build$ MACHINE=am335x-evm bitbake -k tisdk-default-image
NOTE: Started PRServer with DBfile: /home/sem3user/from_tisdk/tisdk/build/cache/prserv.sqlite3, Address: 127.0.0.1:46819, PID: 2469083
Loading cache: 100% |#########################################################################################################################################################| Time: 0:00:01
Loaded 4782 entries from dependency cache.
WARNING: No recipes in default available for:
/home/sem3user/from_tisdk/tisdk/sources/meta-processor-sdk/recipes-core/packagegroups/packagegroup-arago-base-tisdk.bbappend
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "2.0.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-22.04"
TARGET_SYS = "arm-oe-linux-gnueabi"
MACHINE = "am335x-evm"
DISTRO = "arago"
DISTRO_VERSION = "2023.04"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-processor-sdk = "HEAD:3cbe955ce03d9c25e59e3a401f378132163a3569"
meta-arago-distro
meta-arago-extras
meta-arago-demos
meta-arago-test = "HEAD:a9dcc0583f44bd7a7d8780759c2091b85d280ec2"
meta-qt5 = "HEAD:ae8a97f79364bed1abc297636f7933d0e35f22be"
meta-virtualization = "HEAD:2d8b3cba8ff27c9ec2187a52b6a551fe1dcfaa07"
meta-networking
meta-python
meta-oe
meta-gnome
meta-filesystems
meta-multimedia = "HEAD:9c5541f7e18a1fac3b8dea71e1ebb8398d58e6ff"
meta-ti-extras
meta-ti-bsp = "HEAD:59edb4e886df468edeb683355c36f06004b29925"
meta-arm
meta-arm-toolchain = "HEAD:b187fb9232ca0a6b5f8f90b4715958546fc41d73"
meta = "HEAD:2572b32e729831762790ebfbf930a1140657faea"
Initialising tasks: 100% |####################################################################################################################################################| Time: 0:00:06
Sstate summary: Wanted 20 Local 0 Mirrors 0 Missed 20 Current 4061 (0% match, 99% complete)
NOTE: Executing Tasks
ERROR: lmbench-3.0-a9-r2 do_compile: oe_runmake failed
ERROR: lmbench-3.0-a9-r2 do_compile: ExecutionError('/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/temp/run.do_compile.2469149', 1, None, None)
ERROR: Logfile of failure stored in: /home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/temp/log.do_compile.2469149
Log data follows:
| DEBUG: Executing python function autotools_aclocals
| DEBUG: SITE files ['endian-little', 'bit-32', 'arm-common', 'arm-32', 'common-linux', 'common-glibc', 'arm-linux', 'arm-linux-gnueabi', 'common']
| DEBUG: Python function autotools_aclocals finished
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8 CC=arm-oe-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot AR=arm-oe-linux-gnueabi-gcc-ar RANLIB=arm-oe-linux-gnueabi-gcc-ranlib CFLAGS= -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -I/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/tirpc LDFLAGS=-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= LDLIBS= -ltirpc LD=arm-oe-linux-gnueabi-ld --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot OS=arm-oe-linux-gnueabi TARGET=linux-gnueabi BASE=/usr MANDIR=/usr/share/man -C src
| make: Entering directory '/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/lmbench-3.0-a9/src'
| ../scripts/build: line 24: echo: write error: No space left on device
| ../scripts/build: line 53: echo: write error: No space left on device
| ../scripts/build: line 54: echo: write error: No space left on device
| ../scripts/build: line 60: echo: write error: No space left on device
| ../scripts/build: line 61: echo: write error: No space left on device
| ../scripts/build: line 67: echo: write error: No space left on device
| ../scripts/build: line 68: echo: write error: No space left on device
| ../scripts/build: line 69: echo: write error: No space left on device
| ../scripts/build: line 70: echo: write error: No space left on device
| ../scripts/build: line 76: echo: write error: No space left on device
| ../scripts/build: line 77: echo: write error: No space left on device
| ../scripts/build: line 78: echo: write error: No space left on device
| ../scripts/build: line 79: echo: write error: No space left on device
| ../scripts/build: line 85: echo: write error: No space left on device
| ../scripts/build: line 86: echo: write error: No space left on device
| ../scripts/build: line 87: echo: write error: No space left on device
| ../scripts/build: line 88: echo: write error: No space left on device
| ../scripts/build: line 89: echo: write error: No space left on device
| ../scripts/build: line 90: echo: write error: No space left on device
| ../scripts/build: line 91: echo: write error: No space left on device
| ../scripts/build: line 97: echo: write error: No space left on device
| ../scripts/build: line 108: echo: write error: No space left on device
| ../scripts/build: line 118: echo: write error: No space left on device
| ../scripts/build: line 128: echo: write error: No space left on device
| ../scripts/build: line 138: echo: write error: No space left on device
| ../scripts/build: line 139: echo: write error: No space left on device
| ../scripts/build: line 144: echo: write error: No space left on device
| ../scripts/build: line 145: echo: write error: No space left on device
| ../scripts/build: line 152: echo: write error: No space left on device
| ../scripts/build: line 153: echo: write error: No space left on device
| ../scripts/build: line 154: echo: write error: No space left on device
| ../scripts/build: line 161: echo: write error: No space left on device
| ../scripts/build: line 162: echo: write error: No space left on device
| ../scripts/build: line 163: echo: write error: No space left on device
| ../scripts/build: line 164: echo: write error: No space left on device
| ../scripts/build: line 171: echo: write error: No space left on device
| ../scripts/build: line 172: echo: write error: No space left on device
| ../scripts/build: line 173: echo: write error: No space left on device
| ../scripts/build: line 181: echo: write error: No space left on device
| ../scripts/build: line 182: echo: write error: No space left on device
| ../scripts/build: line 183: echo: write error: No space left on device
| ../scripts/build: line 184: echo: write error: No space left on device
| ../scripts/build: line 191: echo: write error: No space left on device
| ../scripts/build: line 192: echo: write error: No space left on device
| ../scripts/build: line 193: echo: write error: No space left on device
| ../scripts/build: line 200: echo: write error: No space left on device
| ../scripts/build: line 201: echo: write error: No space left on device
| ../scripts/build: line 202: echo: write error: No space left on device
| ../scripts/build: line 203: echo: write error: No space left on device
| ../scripts/build: line 209: echo: write error: No space left on device
| ../scripts/build: line 210: echo: write error: No space left on device
| ../scripts/build: line 211: echo: write error: No space left on device
| ../scripts/build: line 212: echo: write error: No space left on device
| ../scripts/build: line 219: echo: write error: No space left on device
| ../scripts/build: line 220: echo: write error: No space left on device
| ../scripts/build: line 228: echo: write error: No space left on device
| ../scripts/build: line 229: echo: write error: No space left on device
| ../scripts/build: line 238: echo: write error: No space left on device
| ../scripts/build: line 239: echo: write error: No space left on device
| ../scripts/build: line 248: echo: write error: No space left on device
| ../scripts/build: line 249: echo: write error: No space left on device
| ../scripts/build: line 250: echo: write error: No space left on device
| ../scripts/build: line 256: echo: write error: No space left on device
| ../scripts/build: line 257: echo: write error: No space left on device
| ../scripts/build: line 258: echo: write error: No space left on device
| ../scripts/build: line 259: echo: write error: No space left on device
| ../scripts/build: line 260: echo: write error: No space left on device
| ../scripts/build: line 266: echo: write error: No space left on device
| ../scripts/build: line 267: echo: write error: No space left on device
| ../scripts/build: line 268: echo: write error: No space left on device
| ../scripts/build: line 269: echo: write error: No space left on device
| ../scripts/build: line 270: echo: write error: No space left on device
| ../scripts/build: line 276: echo: write error: No space left on device
| ../scripts/build: line 277: echo: write error: No space left on device
| ../scripts/build: line 278: echo: write error: No space left on device
| ../scripts/build: line 279: echo: write error: No space left on device
| make[1]: Entering directory '/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/lmbench-3.0-a9/src'
| arm-oe-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -I/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/tirpc -DSYS5 -Dvalloc=malloc -DS_IFIFO=S_IFFIFO -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -c lib_tcp.c -o ../bin/arm-oe-linux-gnueabi/lib_tcp.o
| arm-oe-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -I/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/tirpc -DSYS5 -Dvalloc=malloc -DS_IFIFO=S_IFFIFO -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -c lib_udp.c -o ../bin/arm-oe-linux-gnueabi/lib_udp.o
| arm-oe-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -I/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/tirpc -DSYS5 -Dvalloc=malloc -DS_IFIFO=S_IFFIFO -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -c lib_unix.c -o ../bin/arm-oe-linux-gnueabi/lib_unix.o
| arm-oe-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -I/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/tirpc -DSYS5 -Dvalloc=malloc -DS_IFIFO=S_IFFIFO -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -c lib_timing.c -o ../bin/arm-oe-linux-gnueabi/lib_timing.o
| arm-oe-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -I/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/tirpc -DSYS5 -Dvalloc=malloc -DS_IFIFO=S_IFFIFO -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -c lib_mem.c -o ../bin/arm-oe-linux-gnueabi/lib_mem.o
| arm-oe-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -I/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/tirpc -DSYS5 -Dvalloc=malloc -DS_IFIFO=S_IFFIFO -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -c lib_stats.c -o ../bin/arm-oe-linux-gnueabi/lib_stats.o
| arm-oe-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -I/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/tirpc -DSYS5 -Dvalloc=malloc -DS_IFIFO=S_IFFIFO -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -c lib_debug.c -o ../bin/arm-oe-linux-gnueabi/lib_debug.o
| arm-oe-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -I/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/tirpc -DSYS5 -Dvalloc=malloc -DS_IFIFO=S_IFFIFO -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2=/usr/src/debug/lmbench/3.0-a9-r2 -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot= -fdebug-prefix-map=/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot-native= -c getopt.c -o ../bin/arm-oe-linux-gnueabi/getopt.o
| In file included from lib_unix.c:9:
| bench.h:81:13: error: conflicting types for 'socklen_t'; have 'int'
| 81 | typedef int socklen_t;
| In file included from bench.h:17,
| from lib_unix.c:9:
| /home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/recipe-sysroot/usr/include/unistd.h:274:21: note: previous declaration of 'socklen_t' with type 'socklen_t' {aka 'unsigned int'}
| 274 | typedef __socklen_t socklen_t;
| make[1]: *** [Makefile:232: ../bin/arm-oe-linux-gnueabi/lib_unix.o] Error 1
| make[1]: *** Waiting for unfinished jobs....
| In file included from lib_timing.c:17:
| In file included from lib_udp.c:9:
| from lib_udp.c:9:
| In file included from getopt.c:24:
| from getopt.c:24:
| In file included from lib_debug.c:1:
| from lib_debug.c:1:
| make[1]: *** [Makefile:230: ../bin/arm-oe-linux-gnueabi/lib_udp.o] Error 1
| make[1]: *** [Makefile:240: ../bin/arm-oe-linux-gnueabi/getopt.o] Error 1
| lib_debug.c: In function 'print_mem':
| lib_debug.c:107:16: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
| 107 | base = (uint64)addr;
| lib_debug.c:109:23: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
| 109 | off = (uint64)p - base;
| make[1]: *** [Makefile:234: ../bin/arm-oe-linux-gnueabi/lib_debug.o] Error 1
| In file included from lib_stats.c:2:
| from lib_stats.c:2:
| make[1]: *** [Makefile:224: ../bin/arm-oe-linux-gnueabi/lib_timing.o] Error 1
| In file included from lib_tcp.c:9:
| from lib_tcp.c:9:
| make[1]: *** [Makefile:236: ../bin/arm-oe-linux-gnueabi/lib_stats.o] Error 1
| make[1]: *** [Makefile:228: ../bin/arm-oe-linux-gnueabi/lib_tcp.o] Error 1
| In file included from lib_mem.c:15:
| from lib_mem.c:15:
| make[1]: *** [Makefile:226: ../bin/arm-oe-linux-gnueabi/lib_mem.o] Error 1
| make[1]: Leaving directory '/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/lmbench-3.0-a9/src'
| make: *** [Makefile:115: lmbench] Error 2
| make: Leaving directory '/home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/lmbench-3.0-a9/src'
| ERROR: oe_runmake failed
| WARNING: /home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/temp/run.do_compile.2469149:184 exit 1 from 'exit 1'
| WARNING: Backtrace (BB generated script):
| #1: bbfatal_log, /home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/temp/run.do_compile.2469149, line 184
| #2: die, /home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/temp/run.do_compile.2469149, line 168
| #3: oe_runmake, /home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/temp/run.do_compile.2469149, line 163
| #4: do_compile, /home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/temp/run.do_compile.2469149, line 158
| #5: main, /home/sem3user/from_tisdk/tisdk/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/lmbench/3.0-a9-r2/temp/run.do_compile.2469149, line 197
ERROR: Task (/home/sem3user/from_tisdk/tisdk/sources/meta-openembedded/meta-oe/recipes-benchmark/lmbench/lmbench_3.0-a9.bb:do_compile) failed with exit code '1'
Keyboard Interrupt, closing down...
Second Keyboard Interrupt, stopping...
Summary: 1 task failed:
Summary: There was 1 WARNING message.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
Execution was interrupted, returning a non-zero exit code.
sem3user@INBLRPRODDC9LN:~/from_tisdk/tisdk/build$ ^C
sem3user@INBLRPRODDC9LN:~/from_tisdk/tisdk/build$ df -H
Filesystem Size Used Avail Use% Mounted on
tmpfs 3.4G 1.7M 3.4G 1% /run
/dev/mapper/ubuntu--vg-root 53G 12G 39G 24% /
tmpfs 17G 66k 17G 1% /dev/shm
tmpfs 5.3M 0 5.3M 0% /run/lock
/dev/sda2 2.1G 278M 1.7G 15% /boot
/dev/mapper/ubuntu--vg-var 21G 5.3G 15G 27% /var
tmpfs 17G 25k 17G 1% /tmp
/dev/mapper/ubuntu--vg-home 1.6T 837G 610G 58% /home
tmpfs 17G 17G 0 100% /var/tmp
/dev/mapper/ubuntu--vg-var--log 16G 1.3G 14G 9% /var/log
tmpfs 3.4G 82k 3.4G 1% /run/user/130
tmpfs 3.4G 70k 3.4G 1% /run/user/1002
