hi teams:
sdk:806
env:~22.04.1-Ubuntu
We used the following link to build the wic.xz file system for burning, but found a compilation error and failed to generate the corresponding burning package in the path
\tisdk\build\arago-tmp-external-arm-glibc\deploy\images\am62axx-evm
~/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/deploy/images/am62axx-evm$ ls bl31.bin bl31.bin.unsigned bl31.elf bl31-k3.bin bl31-k3.elf bl32.bin bl32.bin.unsigned bl32.elf fitImage fitImage--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.bin fitImage-am62axx-evm.bin fitImage-its--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.its fitImage-its-am62axx-evm.its fitImage-its.its fitImage-linux.bin--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.itb fitImage-linux.bin-am62axx-evm.itb fitImage-linux.bin.itb Image Image--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.bin Image-am62axx-evm.bin ipc_echo_testb_mcu1_0_release_strip.xer5f k3-am62a7-fpdlink-ov2312-0-0--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-am62a7-fpdlink-ov2312-0-0-am62axx-evm.dtbo k3-am62a7-fpdlink-ov2312-0-0.dtbo k3-am62a7-fpdlink-ov2312-0-1--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-am62a7-fpdlink-ov2312-0-1-am62axx-evm.dtbo k3-am62a7-fpdlink-ov2312-0-1.dtbo k3-am62a7-fpdlink-ov2312-0-2--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-am62a7-fpdlink-ov2312-0-2-am62axx-evm.dtbo k3-am62a7-fpdlink-ov2312-0-2.dtbo k3-am62a7-fpdlink-ov2312-0-3--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-am62a7-fpdlink-ov2312-0-3-am62axx-evm.dtbo k3-am62a7-fpdlink-ov2312-0-3.dtbo k3-am62a7-fpdlink-sk-fusion--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-am62a7-fpdlink-sk-fusion-am62axx-evm.dtbo k3-am62a7-fpdlink-sk-fusion.dtbo k3-am62a7-sk--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtb k3-am62a7-sk-am62axx-evm.dtb k3-am62a7-sk-csi2-imx219--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-am62a7-sk-csi2-imx219-am62axx-evm.dtbo k3-am62a7-sk-csi2-imx219.dtbo k3-am62a7-sk.dtb k3-j721e-fpdlink-imx390-cm-0-0--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-j721e-fpdlink-imx390-cm-0-0-am62axx-evm.dtbo k3-j721e-fpdlink-imx390-cm-0-0.dtbo k3-j721e-fpdlink-imx390-cm-0-1--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-j721e-fpdlink-imx390-cm-0-1-am62axx-evm.dtbo k3-j721e-fpdlink-imx390-cm-0-1.dtbo k3-j721e-fpdlink-imx390-cm-0-2--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-j721e-fpdlink-imx390-cm-0-2-am62axx-evm.dtbo k3-j721e-fpdlink-imx390-cm-0-2.dtbo k3-j721e-fpdlink-imx390-cm-0-3--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-j721e-fpdlink-imx390-cm-0-3-am62axx-evm.dtbo k3-j721e-fpdlink-imx390-cm-0-3.dtbo k3-j721e-fpdlink-imx390-rcm-0-0--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-j721e-fpdlink-imx390-rcm-0-0-am62axx-evm.dtbo k3-j721e-fpdlink-imx390-rcm-0-0.dtbo k3-j721e-fpdlink-imx390-rcm-0-1--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-j721e-fpdlink-imx390-rcm-0-1-am62axx-evm.dtbo k3-j721e-fpdlink-imx390-rcm-0-1.dtbo k3-j721e-fpdlink-imx390-rcm-0-2--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-j721e-fpdlink-imx390-rcm-0-2-am62axx-evm.dtbo k3-j721e-fpdlink-imx390-rcm-0-2.dtbo k3-j721e-fpdlink-imx390-rcm-0-3--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.dtbo k3-j721e-fpdlink-imx390-rcm-0-3-am62axx-evm.dtbo k3-j721e-fpdlink-imx390-rcm-0-3.dtbo modules--5.10.168+gitAUTOINC+2c23e6c538-r0b.arago5.0-am62axx-evm-20240626010743.tgz modules-am62axx-evm.tgz optee sysfw-2022.01-am62ax-gp-evm.itb sysfw-2022.01-am62ax-hs-evm.itb sysfw-2022.01-am62ax-hs-fs-evm.itb sysfw-am62ax-gp-evm.itb sysfw-am62ax-hs-evm.itb sysfw-am62ax-hs-fs-evm.itb sysfw.itb tiboot3-am62ax-gp-evm.bin tiboot3-am62ax-hs-evm.bin tiboot3-am62ax-hs-fs-evm.bin tiboot3.bin ti-fs-firmware-am62ax-gp.bin ti-fs-firmware-am62ax-hs-cert.bin ti-fs-firmware-am62ax-hs-enc.bin ti-fs-firmware-am62ax-hs-fs-cert.bin ti-fs-firmware-am62ax-hs-fs-enc.bin tispl.bin tispl.bin-am62axx-evm tispl.bin-am62axx-evm-2021.01+gitAUTOINC+2ee8efd654-r33 u-boot-am62axx-evm-2021.01+gitAUTOINC+2ee8efd654-r33.img u-boot.img u-boot.img_HS u-boot-r5spl-am62axx-evm-2021.01+gitAUTOINC+2ee8efd654-r33.bin u-boot-r5spl.bin u-boot-r5spl-gp-am62axx-evm-2021.01+gitAUTOINC+2ee8efd654-r33.bin u-boot-r5spl-gp.bin u-boot-r5spl-hs-se-am62axx-evm-2021.01+gitAUTOINC+2ee8efd654-r33.bin u-boot-r5spl-hs-se.bin u-boot-spl.bin u-boot-spl.bin-am62axx-evm u-boot-spl.bin-am62axx-evm-2021.01+gitAUTOINC+2ee8efd654-r33 uEnv.txt
1.2. Building the SDK — Processor SDK AM62Ax Documentation
ops:
git clone https://git.ti.com/git/arago-project/oe-layersetup.git tisdk cd tisdk ./oe-layertool-setup.sh -f configs/processor-sdk/processor-sdk-08.06.00-config.txt cd build . conf/setenv export TOOLCHAIN_PATH_ARMV7=/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf export TOOLCHAIN_PATH_ARMV8=/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu git clone https://git.ti.com/git/security-development-tools/core-secdev-k3.git -b master export TI_SECURE_DEV_PKG_K3=`pwd`/core-secdev-k3 MACHINE=am62axx-evm bitbake -k tisdk-edgeai-image
compile print
--- Starting bitbake server pid 389425 at 2024-06-25 08:50:09.987111 --- Started bitbake server pid 389425 NOTE: Your conf/bblayers.conf has been automatically updated. NOTE: Your conf/bblayers.conf has been automatically updated. Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/extstorage/zyk/Soft/tisdk/tisdk/build/core-secdev-k3', 'PWD': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'LOGNAME': 'zyk', 'OEBASE': '/extstorage/zyk/Soft/tisdk/tisdk', 'HOME': '/extstorage/zyk', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm', 'USER': 'zyk', 'TOOLCHAIN_PATH_ARMV8': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/.local/bin:/extstorage/zyk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin', 'LC_ALL': 'en_US.UTF-8', 'LC_ADDRESS': 'zh_CN.UTF-8', 'LC_NAME': 'zh_CN.UTF-8', 'LC_MONETARY': 'zh_CN.UTF-8', 'XDG_SESSION_TYPE': 'tty', 'MOTD_SHOWN': 'pam', 'LC_PAPER': 'zh_CN.UTF-8', 'LANG': 'en_US.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SSH_CONNECTION': '192.168.1.13 59310 192.168.2.99 22', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'LC_IDENTIFICATION': 'zh_CN.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'SHLVL': '1', 'LC_TELEPHONE': 'zh_CN.UTF-8', 'LC_MEASUREMENT': 'zh_CN.UTF-8', 'XDG_SESSION_ID': '243', 'XDG_RUNTIME_DIR': '/run/user/1002', 'SSH_CLIENT': '192.168.1.13 59310 22', 'LC_TIME': 'zh_CN.UTF-8', 'XDG_DATA_DIRS': '/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1002/bus', 'BUILDDIR': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'SSH_TTY': '/dev/pts/5', 'LC_NUMERIC': 'zh_CN.UTF-8', 'OLDPWD': '/extstorage/zyk/Soft/tisdk', '_': '/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake'}, ['/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-edgeai-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.RunQueue.HashEquiv': 19, 'BitBake.SigGen.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-edgeai-image'], 'build'] Command Completed Processing Client Disconnecting Client No timeout, exiting. Exiting --- Starting bitbake server pid 1807528 at 2024-06-26 09:07:31.573607 --- Started bitbake server pid 1807528 Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/extstorage/zyk/Soft/tisdk/tisdk/build/core-secdev-k3', 'PWD': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'LOGNAME': 'zyk', 'OEBASE': '/extstorage/zyk/Soft/tisdk/tisdk', 'HOME': '/extstorage/zyk', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm', 'USER': 'zyk', 'TOOLCHAIN_PATH_ARMV8': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/.local/bin:/extstorage/zyk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin', 'LC_ALL': 'en_US.UTF-8', 'LC_ADDRESS': 'zh_CN.UTF-8', 'LC_NAME': 'zh_CN.UTF-8', 'LC_MONETARY': 'zh_CN.UTF-8', 'XDG_SESSION_TYPE': 'tty', 'MOTD_SHOWN': 'pam', 'LC_PAPER': 'zh_CN.UTF-8', 'LANG': 'en_US.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SSH_CONNECTION': '192.168.1.13 59310 192.168.2.99 22', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'LC_IDENTIFICATION': 'zh_CN.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'SHLVL': '1', 'LC_TELEPHONE': 'zh_CN.UTF-8', 'LC_MEASUREMENT': 'zh_CN.UTF-8', 'XDG_SESSION_ID': '243', 'XDG_RUNTIME_DIR': '/run/user/1002', 'SSH_CLIENT': '192.168.1.13 59310 22', 'LC_TIME': 'zh_CN.UTF-8', 'XDG_DATA_DIRS': '/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1002/bus', 'BUILDDIR': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'SSH_TTY': '/dev/pts/5', 'LC_NUMERIC': 'zh_CN.UTF-8', 'OLDPWD': '/extstorage/zyk/Soft/tisdk/tisdk', '_': '/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake'}, ['/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-edgeai-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.RunQueue.HashEquiv': 19, 'BitBake.SigGen.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-edgeai-image'], 'build'] Command Completed Auto packing the repository in background for optimum performance. See "git help gc" for manual housekeeping. Auto packing the repository in background for optimum performance. See "git help gc" for manual housekeeping. Processing Client Disconnecting Client No timeout, exiting. Exiting --- Starting bitbake server pid 728583 at 2024-06-26 13:07:15.127465 --- Started bitbake server pid 728583 Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/extstorage/zyk/Soft/tisdk/tisdk/build/core-secdev-k3', 'PWD': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'LOGNAME': 'zyk', 'OEBASE': '/extstorage/zyk/Soft/tisdk/tisdk', 'HOME': '/extstorage/zyk', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm', 'USER': 'zyk', 'TOOLCHAIN_PATH_ARMV8': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/.local/bin:/extstorage/zyk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin', 'LC_ALL': 'en_US.UTF-8', 'LC_ADDRESS': 'zh_CN.UTF-8', 'LC_NAME': 'zh_CN.UTF-8', 'LC_MONETARY': 'zh_CN.UTF-8', 'XDG_SESSION_TYPE': 'tty', 'MOTD_SHOWN': 'pam', 'LC_PAPER': 'zh_CN.UTF-8', 'LANG': 'en_US.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SSH_CONNECTION': '192.168.1.13 59310 192.168.2.99 22', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'LC_IDENTIFICATION': 'zh_CN.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'SHLVL': '1', 'LC_TELEPHONE': 'zh_CN.UTF-8', 'LC_MEASUREMENT': 'zh_CN.UTF-8', 'XDG_SESSION_ID': '243', 'XDG_RUNTIME_DIR': '/run/user/1002', 'SSH_CLIENT': '192.168.1.13 59310 22', 'LC_TIME': 'zh_CN.UTF-8', 'XDG_DATA_DIRS': '/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1002/bus', 'BUILDDIR': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'SSH_TTY': '/dev/pts/5', 'LC_NUMERIC': 'zh_CN.UTF-8', 'OLDPWD': '/extstorage/zyk/Soft/tisdk/tisdk', '_': '/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake'}, ['/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-default-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.SigGen.HashEquiv': 19, 'BitBake.RunQueue.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-default-image'], 'build'] Command Completed Processing Client Disconnecting Client No timeout, exiting. Exiting --- Starting bitbake server pid 780859 at 2024-06-26 16:57:48.082148 --- Started bitbake server pid 780859 Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/extstorage/zyk/Soft/tisdk/tisdk/build/core-secdev-k3', 'PWD': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'LOGNAME': 'zyk', 'OEBASE': '/extstorage/zyk/Soft/tisdk/tisdk', 'HOME': '/extstorage/zyk', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm', 'USER': 'zyk', 'TOOLCHAIN_PATH_ARMV8': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/.local/bin:/extstorage/zyk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin', 'LC_ALL': 'en_US.UTF-8', 'LC_ADDRESS': 'zh_CN.UTF-8', 'LC_NAME': 'zh_CN.UTF-8', 'LC_MONETARY': 'zh_CN.UTF-8', 'XDG_SESSION_TYPE': 'tty', 'MOTD_SHOWN': 'pam', 'LC_PAPER': 'zh_CN.UTF-8', 'LANG': 'en_US.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SSH_CONNECTION': '192.168.1.13 59310 192.168.2.99 22', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'LC_IDENTIFICATION': 'zh_CN.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'SHLVL': '1', 'LC_TELEPHONE': 'zh_CN.UTF-8', 'LC_MEASUREMENT': 'zh_CN.UTF-8', 'XDG_SESSION_ID': '243', 'XDG_RUNTIME_DIR': '/run/user/1002', 'SSH_CLIENT': '192.168.1.13 59310 22', 'LC_TIME': 'zh_CN.UTF-8', 'XDG_DATA_DIRS': '/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1002/bus', 'BUILDDIR': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'SSH_TTY': '/dev/pts/5', 'LC_NUMERIC': 'zh_CN.UTF-8', 'OLDPWD': '/extstorage/zyk/Soft/tisdk/tisdk', '_': '/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake'}, ['/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-edgeai-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.SigGen.HashEquiv': 19, 'BitBake.RunQueue.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-edgeai-image'], 'build'] Command Completed Processing Client Disconnecting Client No timeout, exiting. Exiting --- Starting bitbake server pid 780966 at 2024-06-26 16:58:48.220869 --- Started bitbake server pid 780966 Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/extstorage/zyk/Soft/tisdk/tisdk/build/core-secdev-k3', 'PWD': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'LOGNAME': 'zyk', 'OEBASE': '/extstorage/zyk/Soft/tisdk/tisdk', 'HOME': '/extstorage/zyk', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm', 'USER': 'zyk', 'TOOLCHAIN_PATH_ARMV8': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/.local/bin:/extstorage/zyk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin', 'LC_ALL': 'en_US.UTF-8', 'LC_ADDRESS': 'zh_CN.UTF-8', 'LC_NAME': 'zh_CN.UTF-8', 'LC_MONETARY': 'zh_CN.UTF-8', 'XDG_SESSION_TYPE': 'tty', 'MOTD_SHOWN': 'pam', 'LC_PAPER': 'zh_CN.UTF-8', 'LANG': 'en_US.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SSH_CONNECTION': '192.168.1.13 59310 192.168.2.99 22', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'LC_IDENTIFICATION': 'zh_CN.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'SHLVL': '0', 'LC_TELEPHONE': 'zh_CN.UTF-8', 'LC_MEASUREMENT': 'zh_CN.UTF-8', 'XDG_SESSION_ID': '243', 'XDG_RUNTIME_DIR': '/run/user/1002', 'SSH_CLIENT': '192.168.1.13 59310 22', 'LC_TIME': 'zh_CN.UTF-8', 'XDG_DATA_DIRS': '/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1002/bus', 'BUILDDIR': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'SSH_TTY': '/dev/pts/5', 'LC_NUMERIC': 'zh_CN.UTF-8', 'OLDPWD': '/extstorage/zyk/Soft/tisdk/tisdk', '_': '/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake'}, ['/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-edgeai-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.RunQueue.HashEquiv': 19, 'BitBake.SigGen.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-edgeai-image'], 'build'] Command Completed Processing Client Disconnecting Client No timeout, exiting. Exiting --- Starting bitbake server pid 782328 at 2024-06-26 17:05:17.499190 --- Started bitbake server pid 782328 Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/extstorage/zyk/Soft/tisdk/tisdk/build/core-secdev-k3', 'PWD': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'LOGNAME': 'zyk', 'OEBASE': '/extstorage/zyk/Soft/tisdk/tisdk', 'HOME': '/extstorage/zyk', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm', 'USER': 'zyk', 'TOOLCHAIN_PATH_ARMV8': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/.local/bin:/extstorage/zyk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin', 'LC_ALL': 'en_US.UTF-8', 'LC_ADDRESS': 'zh_CN.UTF-8', 'LC_NAME': 'zh_CN.UTF-8', 'LC_MONETARY': 'zh_CN.UTF-8', 'XDG_SESSION_TYPE': 'tty', 'MOTD_SHOWN': 'pam', 'LC_PAPER': 'zh_CN.UTF-8', 'LANG': 'en_US.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SSH_CONNECTION': '192.168.1.13 59310 192.168.2.99 22', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'LC_IDENTIFICATION': 'zh_CN.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'SHLVL': '0', 'LC_TELEPHONE': 'zh_CN.UTF-8', 'LC_MEASUREMENT': 'zh_CN.UTF-8', 'XDG_SESSION_ID': '243', 'XDG_RUNTIME_DIR': '/run/user/1002', 'SSH_CLIENT': '192.168.1.13 59310 22', 'LC_TIME': 'zh_CN.UTF-8', 'XDG_DATA_DIRS': '/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1002/bus', 'BUILDDIR': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'SSH_TTY': '/dev/pts/5', 'LC_NUMERIC': 'zh_CN.UTF-8', 'OLDPWD': '/extstorage/zyk/Soft/tisdk/tisdk', '_': '/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake'}, ['/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-edgeai-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.RunQueue.HashEquiv': 19, 'BitBake.SigGen.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-edgeai-image'], 'build'] Command Completed Running command ['stateShutdown'] Command Completed Running command ['stateForceShutdown'] Command Completed Processing Client Disconnecting Client No timeout, exiting. Exiting --- Starting bitbake server pid 967235 at 2024-06-26 17:30:07.794667 --- Started bitbake server pid 967235 Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/extstorage/zyk/Soft/tisdk/tisdk/build/core-secdev-k3', 'PWD': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'LOGNAME': 'zyk', 'OEBASE': '/extstorage/zyk/Soft/tisdk/tisdk', 'HOME': '/extstorage/zyk', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm', 'USER': 'zyk', 'TOOLCHAIN_PATH_ARMV8': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-virtualization/scripts:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/.local/bin:/extstorage/zyk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin', 'LC_ALL': 'en_US.UTF-8', 'LC_ADDRESS': 'zh_CN.UTF-8', 'LC_NAME': 'zh_CN.UTF-8', 'LC_MONETARY': 'zh_CN.UTF-8', 'XDG_SESSION_TYPE': 'tty', 'MOTD_SHOWN': 'pam', 'LC_PAPER': 'zh_CN.UTF-8', 'LANG': 'en_US.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SSH_CONNECTION': '192.168.1.13 59310 192.168.2.99 22', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'LC_IDENTIFICATION': 'zh_CN.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'SHLVL': '0', 'LC_TELEPHONE': 'zh_CN.UTF-8', 'LC_MEASUREMENT': 'zh_CN.UTF-8', 'XDG_SESSION_ID': '243', 'XDG_RUNTIME_DIR': '/run/user/1002', 'SSH_CLIENT': '192.168.1.13 59310 22', 'LC_TIME': 'zh_CN.UTF-8', 'XDG_DATA_DIRS': '/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1002/bus', 'BUILDDIR': '/extstorage/zyk/Soft/tisdk/tisdk/build', 'SSH_TTY': '/dev/pts/5', 'LC_NUMERIC': 'zh_CN.UTF-8', 'OLDPWD': '/extstorage/zyk/Soft/tisdk/tisdk', '_': '/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake'}, ['/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-edgeai-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.SigGen.HashEquiv': 19, 'BitBake.RunQueue.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-edgeai-image'], 'build'] Command Completed Auto packing the repository in background for optimum performance. See "git help gc" for manual housekeeping. Processing Client Disconnecting Client No timeout, exiting. Exiting
NOTE: Started PRServer with DBfile: /extstorage/zyk/Soft/tisdk/tisdk/build/cache/prserv.sqlite3, IP: 127.0.0.1, PORT: 36209, PID: 968012 Loading cache...done. Loaded 17408 entries from dependency cache. NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies Build Configuration: BB_VERSION = "1.46.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "ubuntu-22.04" TARGET_SYS = "aarch64-linux" MACHINE = "am62axx-evm" DISTRO = "arago" DISTRO_VERSION = "2021.09" TUNE_FEATURES = "aarch64" TARGET_FPU = "" meta-processor-sdk = "HEAD:fab130c5c3c2fb43c432d294c9783e92a4b67401" meta-arago-distro meta-arago-extras = "HEAD:e4fcc247b2fadc457efaff8edabdf12a6b4fa4d1" meta-qt5 = "HEAD:5ef3a0ffd3324937252790266e2b2e64d33ef34f" meta-virtualization = "HEAD:beea119eb529b4a11f266004aee8b548427aea39" meta-networking meta-python meta-oe meta-gnome meta-filesystems meta-multimedia = "HEAD:87571345059f82fb7599e3aa82e6fdcfbd361098" meta-ti = "HEAD:45bdaf7da0bc79fa73f1e01bb30b5c3b2eb34545" meta-arm meta-arm-toolchain = "HEAD:c4f04f3fb66f8f4365b08b553af8206372e90a63" meta = "HEAD:daaee6fcb0d201f041678af433d8e1cd6f924d09" meta-sysrepo = "HEAD:8bcc6151897c0e67c2931c78340477bf3a12d8cb" meta-jupyter = "HEAD:82db248e2eca36e52cbeafe599b755dc87720383" Build Configuration: BB_VERSION = "1.46.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "ubuntu-22.04" TARGET_SYS = "arm-linux-gnueabi" MACHINE = "am62axx-evm-k3r5-hs-fs" DISTRO = "arago" DISTRO_VERSION = "2021.09" TUNE_FEATURES = "arm armv7a vfp thumb callconvention-hard" TARGET_FPU = "hard" meta-processor-sdk = "HEAD:fab130c5c3c2fb43c432d294c9783e92a4b67401" meta-arago-distro meta-arago-extras = "HEAD:e4fcc247b2fadc457efaff8edabdf12a6b4fa4d1" meta-qt5 = "HEAD:5ef3a0ffd3324937252790266e2b2e64d33ef34f" meta-virtualization = "HEAD:beea119eb529b4a11f266004aee8b548427aea39" meta-networking meta-python meta-oe meta-gnome meta-filesystems meta-multimedia = "HEAD:87571345059f82fb7599e3aa82e6fdcfbd361098" meta-ti = "HEAD:45bdaf7da0bc79fa73f1e01bb30b5c3b2eb34545" meta-arm meta-arm-toolchain = "HEAD:c4f04f3fb66f8f4365b08b553af8206372e90a63" meta = "HEAD:daaee6fcb0d201f041678af433d8e1cd6f924d09" meta-sysrepo = "HEAD:8bcc6151897c0e67c2931c78340477bf3a12d8cb" meta-jupyter = "HEAD:82db248e2eca36e52cbeafe599b755dc87720383" Build Configuration: BB_VERSION = "1.46.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "ubuntu-22.04" TARGET_SYS = "arm-linux-gnueabi" MACHINE = "am62axx-evm-k3r5-gp" DISTRO = "arago" DISTRO_VERSION = "2021.09" TUNE_FEATURES = "arm armv7a vfp thumb callconvention-hard" TARGET_FPU = "hard" meta-processor-sdk = "HEAD:fab130c5c3c2fb43c432d294c9783e92a4b67401" meta-arago-distro meta-arago-extras = "HEAD:e4fcc247b2fadc457efaff8edabdf12a6b4fa4d1" meta-qt5 = "HEAD:5ef3a0ffd3324937252790266e2b2e64d33ef34f" meta-virtualization = "HEAD:beea119eb529b4a11f266004aee8b548427aea39" meta-networking meta-python meta-oe meta-gnome meta-filesystems meta-multimedia = "HEAD:87571345059f82fb7599e3aa82e6fdcfbd361098" meta-ti = "HEAD:45bdaf7da0bc79fa73f1e01bb30b5c3b2eb34545" meta-arm meta-arm-toolchain = "HEAD:c4f04f3fb66f8f4365b08b553af8206372e90a63" meta = "HEAD:daaee6fcb0d201f041678af433d8e1cd6f924d09" meta-sysrepo = "HEAD:8bcc6151897c0e67c2931c78340477bf3a12d8cb" meta-jupyter = "HEAD:82db248e2eca36e52cbeafe599b755dc87720383" Build Configuration: BB_VERSION = "1.46.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "ubuntu-22.04" TARGET_SYS = "arm-linux-gnueabi" MACHINE = "am62axx-evm-k3r5-hs-se" DISTRO = "arago" DISTRO_VERSION = "2021.09" TUNE_FEATURES = "arm armv7a vfp thumb callconvention-hard" TARGET_FPU = "hard" meta-processor-sdk = "HEAD:fab130c5c3c2fb43c432d294c9783e92a4b67401" meta-arago-distro meta-arago-extras = "HEAD:e4fcc247b2fadc457efaff8edabdf12a6b4fa4d1" meta-qt5 = "HEAD:5ef3a0ffd3324937252790266e2b2e64d33ef34f" meta-virtualization = "HEAD:beea119eb529b4a11f266004aee8b548427aea39" meta-networking meta-python meta-oe meta-gnome meta-filesystems meta-multimedia = "HEAD:87571345059f82fb7599e3aa82e6fdcfbd361098" meta-ti = "HEAD:45bdaf7da0bc79fa73f1e01bb30b5c3b2eb34545" meta-arm meta-arm-toolchain = "HEAD:c4f04f3fb66f8f4365b08b553af8206372e90a63" meta = "HEAD:daaee6fcb0d201f041678af433d8e1cd6f924d09" meta-sysrepo = "HEAD:8bcc6151897c0e67c2931c78340477bf3a12d8cb" meta-jupyter = "HEAD:82db248e2eca36e52cbeafe599b755dc87720383" Initialising tasks...done. Sstate summary: Wanted 49 Found 0 Missed 49 Current 4132 (0% match, 98% complete) NOTE: Executing Tasks NOTE: Running task 2051 of 12608 (/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-processor-sdk/recipes-tisdk/ti-tisdk-firmware/ti-tisdk-firmware.bb:do_fetch) NOTE: recipe ti-tisdk-firmware-1.0-r1: task do_fetch: Started WARNING: ti-tisdk-firmware-1.0-r1 do_fetch: Failed to fetch URL repo://git.ti.com/processor-sdk/psdk_repo_manifests.git;protocol=git;branch=refs/tags/REL.PSDK.JACINTO.08.06.00.04;manifest=vision_apps_yocto.xml, attempting MIRRORS if available ERROR: ti-tisdk-firmware-1.0-r1 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/tisdk/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/ti-tisdk-firmware/1.0-r1/recipe-sysroot-native/usr/bin/aarch64-linux:/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/ti-tisdk-firmware/1.0-r1/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/ti-tisdk-firmware/1.0-r1/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/ti-tisdk-firmware/1.0-r1/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/ti-tisdk-firmware/1.0-r1/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/ti-tisdk-firmware/1.0-r1/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/bin:/extstorage/zyk/Soft/tisdk/tisdk/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env repo init -m vision_apps_yocto.xml -b refs/tags/REL.PSDK.JACINTO.08.06.00.04 -u git://git.ti.com/processor-sdk/psdk_repo_manifests.git failed with exit code 1, output: Traceback (most recent call last): File "/extstorage/zyk/Soft/.repo/repo/main.py", line 55, in <module> from subcmds.version import Version File "/extstorage/zyk/Soft/.repo/repo/subcmds/__init__.py", line 34, in <module> mod = __import__(__name__, File "/extstorage/zyk/Soft/.repo/repo/subcmds/help.py", line 20, in <module> from formatter import AbstractFormatter, DumbWriter ModuleNotFoundError: No module named 'formatter' ERROR: ti-tisdk-firmware-1.0-r1 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/processor-sdk/psdk_repo_manifests.git;protocol=git;branch=refs/tags/REL.PSDK.JACINTO.08.06.00.04;manifest=vision_apps_yocto.xml') ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/ti-tisdk-firmware/1.0-r1/temp/log.do_fetch.1006961 NOTE: recipe ti-tisdk-firmware-1.0-r1: task do_fetch: Failed ERROR: Task (/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-processor-sdk/recipes-tisdk/ti-tisdk-firmware/ti-tisdk-firmware.bb:do_fetch) failed with exit code '1' NOTE: Running task 4825 of 12608 (/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-arago/meta-arago-extras/recipes-devtools/websocketd/websocketd_0.4.1.bb:do_compile) NOTE: recipe websocketd-0.4.1-r0: task do_compile: Started ERROR: websocketd-0.4.1-r0 do_compile: Execution of '/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/websocketd/0.4.1-r0/temp/run.do_compile.1014632' failed with exit code 1 ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/websocketd/0.4.1-r0/temp/log.do_compile.1014632 Log data follows: | DEBUG: Executing shell function do_compile | go: github.com/gorilla/websocket@v1.4.0: Get "https://proxy.golang.org/github.com/gorilla/websocket/@v/v1.4.0.mod": dial tcp 142.251.42.241:443: i/o timeout | go: github.com/gorilla/websocket@v1.4.0: Get "https://proxy.golang.org/github.com/gorilla/websocket/@v/v1.4.0.mod": dial tcp 142.251.43.17:443: i/o timeout | WARNING: /extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/websocketd/0.4.1-r0/temp/run.do_compile.1014632:1 exit 1 from 'aarch64-none-linux-gnu-go install -p 8 -v -ldflags="-r /usr/lib/go/pkg/linux_arm64_dynlink -extldflags ' --sysroot=/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/websocketd/0.4.1-r0/recipe-sysroot -Wl,-rpath-link=/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/websocketd/0.4.1-r0/recipe-sysroot/usr/lib/go/pkg/linux_arm64_dynlink -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed'" -modcacherw -buildmode=pie `go_list_packages`' | ERROR: Execution of '/extstorage/zyk/Soft/tisdk/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/websocketd/0.4.1-r0/temp/run.do_compile.1014632' failed with exit code 1 NOTE: recipe websocketd-0.4.1-r0: task do_compile: Failed ERROR: Task (/extstorage/zyk/Soft/tisdk/tisdk/sources/meta-arago/meta-arago-extras/recipes-devtools/websocketd/websocketd_0.4.1.bb:do_compile) failed with exit code '1' NOTE: Tasks Summary: Attempted 12504 tasks of which 12502 didn't need to be rerun and 2 failed. NOTE: Writing buildhistory NOTE: Writing buildhistory took: 49 seconds NOTE: Writing buildhistory NOTE: Writing buildhistory took: 6 seconds NOTE: Writing buildhistory NOTE: Writing buildhistory took: 6 seconds NOTE: Writing buildhistory NOTE: Writing buildhistory took: 6 seconds Summary: 2 tasks failed: /extstorage/zyk/Soft/tisdk/tisdk/sources/meta-processor-sdk/recipes-tisdk/ti-tisdk-firmware/ti-tisdk-firmware.bb:do_fetch /extstorage/zyk/Soft/tisdk/tisdk/sources/meta-arago/meta-arago-extras/recipes-devtools/websocketd/websocketd_0.4.1.bb:do_compile Summary: There was 1 WARNING message shown. Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
Wu,
sdk:806
The SDK v8.6 you are trying to use is over one year old; please upgrade to/use the latest SDK v9.2. It has many important fixes/improvements over the earlier SDKs.
The issues you are facing regarding `websocketd` and `ti-tisdk-firmware` recipes have been discussed several times in the E2E forum, you can probably just search for and find solutions. However rather than spending effort getting the older SDK to work I'd highly recommend you move to the current SDK.
Regards, Andreas
hi andreas:
I test v9.02,the same as v8.6
I follow below link,and test
./oe-layertool-setup.sh -f configs/processor-sdk-analytics/processor-sdk-analytics-09.02.00-config.txtcd build . conf/setenv echo 'ARAGO_BRAND = "edgeai"' >> conf/local.conf MACHINE="am62axx-evm" bitbake -k tisdk-edgeai-image
It show the web link timeout or other error
行 1771: NOTE: recipe libgpg-error-native-1.44-r0: task do_populate_sysroot: Succeeded 行 5557: ERROR: ti-vision-apps-1.0-r0_edgeai_4 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env repo init -m vision_apps_yocto.xml -b refs/tags/REL.PSDK.ANALYTICS.09.02.00.05 -u https://git.ti.com/git/processor-sdk/psdk_repo_manifests.git failed with exit code 1, output: 行 5565: ModuleNotFoundError: No module named 'formatter' 行 5567: ERROR: ti-vision-apps-1.0-r0_edgeai_4 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.09.02.00.05;manifest=vision_apps_yocto.xml') 行 5567: ERROR: ti-vision-apps-1.0-r0_edgeai_4 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.09.02.00.05;manifest=vision_apps_yocto.xml') 行 5567: ERROR: ti-vision-apps-1.0-r0_edgeai_4 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.09.02.00.05;manifest=vision_apps_yocto.xml') 行 5568: ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/temp/log.do_fetch.3139808 行 5570: ERROR: Task (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-vision-apps.bb:do_fetch) failed with exit code '1' 行 6024: NOTE: Running task 1973 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/meta/recipes-support/libgpg-error/libgpg-error_1.44.bb:do_fetch)
details log, the the total print during compilation is below file
I saw that the post has similar issues to those I encountered, but they have not been resolved
thx
From your log file...
Can you provide the specific log file for the 'fetch' operation as highlighted above?
It should list the Git commands that are issued by Yocto. Then, we should manually try those step by step to see where things break down.
Regards, Andreas
DEBUG: Executing python function extend_recipe_sysroot NOTE: Direct dependencies are ['virtual:native:/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/meta/recipes-devtools/repo/repo_2.22.bb:do_populate_sysroot'] NOTE: Installed into sysroot: ['repo-native', 'python3-native', 'libffi-native', 'libtool-native', 'sqlite3-native', 'libnsl2-native', 'gdbm-native', 'xz-native', 'ncurses-native', 'bzip2-native', 'openssl-native', 'util-linux-libuuid-native', 'zlib-native', 'libtirpc-native', 'readline-native', 'texinfo-dummy-native', 'gettext-minimal-native', 'perl-native', 'make-native'] NOTE: Skipping as already exists in sysroot: [] DEBUG: sed -e 's:^[^/]*/:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/:g' /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/sysroots-components/x86_64/python3-native/fixmepath /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/sysroots-components/x86_64/libtool-native/fixmepath /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/sysroots-components/x86_64/ncurses-native/fixmepath /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/sysroots-components/x86_64/openssl-native/fixmepath /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/sysroots-components/x86_64/perl-native/fixmepath | xargs sed -i -e 's:FIXMESTAGINGDIRTARGET:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot:g; s:FIXMESTAGINGDIRHOST:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native:g' -e 's:FIXME_PSEUDO_SYSROOT:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/sysroots-components/x86_64/pseudo-native:g' -e 's:FIXME_HOSTTOOLS_DIR:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools:g' -e 's:FIXME_PKGDATA_DIR:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/pkgdata/am62axx-evm:g' -e 's:FIXME_PSEUDO_LOCALSTATEDIR:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/pseudo/:g' -e 's:FIXME_LOGFIFO:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/temp/fifo.3139808:g' DEBUG: Python function extend_recipe_sysroot finished DEBUG: Executing python function do_fetch DEBUG: Executing python function base_do_fetch DEBUG: Trying PREMIRRORS DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', 'sourceware.org', '/git/glibc.git', '', '', OrderedDict()] to ['https', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', 'sourceware.org', '/git/binutils-gdb.git', '', '', OrderedDict()] to ['https', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: Trying Upstream DEBUG: Fetcher accessed the network with the command /usr/bin/env repo init -m vision_apps_yocto.xml -b refs/tags/REL.PSDK.ANALYTICS.09.02.00.05 -u https://git.ti.com/git/processor-sdk/psdk_repo_manifests.git DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env repo init -m vision_apps_yocto.xml -b refs/tags/REL.PSDK.ANALYTICS.09.02.00.05 -u https://git.ti.com/git/processor-sdk/psdk_repo_manifests.git' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/repo/git.ti.com.git.processor-sdk.psdk_repo_manifests.git/vision_apps_yocto.xml/repo WARNING: Failed to fetch URL repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.09.02.00.05;manifest=vision_apps_yocto.xml, attempting MIRRORS if available DEBUG: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env repo init -m vision_apps_yocto.xml -b refs/tags/REL.PSDK.ANALYTICS.09.02.00.05 -u https://git.ti.com/git/processor-sdk/psdk_repo_manifests.git failed with exit code 1, output: Traceback (most recent call last): File "/extstorage/zyk/Soft/.repo/repo/main.py", line 55, in <module> from subcmds.version import Version File "/extstorage/zyk/Soft/.repo/repo/subcmds/__init__.py", line 34, in <module> mod = __import__(__name__, File "/extstorage/zyk/Soft/.repo/repo/subcmds/help.py", line 20, in <module> from formatter import AbstractFormatter, DumbWriter ModuleNotFoundError: No module named 'formatter' DEBUG: Trying MIRRORS DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['npm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?$', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian/20180310T215105Z/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20120328T092752Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20110127T084257Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20090802T004153Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.de.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.au.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.cl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.fi.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hk.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hu.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ie.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.it.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.jp.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.no.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.pl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ro.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.si.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.es.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.se.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.tr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'ftp.gnu.org', '/gnu', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/gnu', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'cdn.kernel.org', '/pub', '', '', OrderedDict()] to ['http', 'www.kernel.org', '/pub', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.gnupg.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.franken.de', '/pub/crypt/mirror/ftp.gnupg.org/gcrypt', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'mirrors.dotsrc.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['ftp', 'ftp.fu-berlin.de', '/tex/CTAN', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'sunsite.sut.ac.jp', '/pub/archives/ctan/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'ctan.unsw.edu.au', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'ftp.gnutls.org', '/gcrypt/gnutls', '', '', OrderedDict()] to ['https', 'www.gnupg.org', '/ftp/gcrypt/gnutls', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.info-zip.org', '/pub/infozip/src/', '', '', OrderedDict()] to ['ftp', 'sunsite.icm.edu.pl', '/pub/unix/archiving/info-zip/src/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/', '', '', OrderedDict()] to ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/OLD/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'www.us.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'archive.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'downloads.sourceforge.net', '/watchdog/', '', '', OrderedDict()] to ['http', 'fossies.org', '/linux/misc/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'download.savannah.gnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.gnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'download.savannah.nongnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.nongnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'mirrors.kernel.org', '/sourceware', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'gd.tuwien.ac.at', '/gnu/sourceware', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'ftp.gwdg.de', '/pub/linux/sources.redhat.com/sourceware', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'search.cpan.org', '/CPAN', '', '', OrderedDict()] to ['https', 'cpan.metacpan.org', '/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?', 'downloads.yoctoproject.org', '/releases/uninative/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto/uninative/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto-sources/', '', '', OrderedDict()] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', 'salsa.debian.org', '/.*', '', '', OrderedDict()] to ['git', 'salsa.debian.org', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', 'git.gnome.org', '/.*', '', '', OrderedDict()] to ['git', 'gitlab.gnome.org', '/GNOME/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.09.02.00.05'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/git/PATH', '', '', OrderedDict([('protocol', 'https')])] ERROR: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env repo init -m vision_apps_yocto.xml -b refs/tags/REL.PSDK.ANALYTICS.09.02.00.05 -u https://git.ti.com/git/processor-sdk/psdk_repo_manifests.git failed with exit code 1, output: Traceback (most recent call last): File "/extstorage/zyk/Soft/.repo/repo/main.py", line 55, in <module> from subcmds.version import Version File "/extstorage/zyk/Soft/.repo/repo/subcmds/__init__.py", line 34, in <module> mod = __import__(__name__, File "/extstorage/zyk/Soft/.repo/repo/subcmds/help.py", line 20, in <module> from formatter import AbstractFormatter, DumbWriter ModuleNotFoundError: No module named 'formatter' ERROR: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.09.02.00.05;manifest=vision_apps_yocto.xml') DEBUG: Python function base_do_fetch finished DEBUG: Python function do_fetch finished
compiler again,fail
NOTE: Started PRServer with DBfile: /extstorage/zyk/Soft/tisdk/yocto-build/build/cache/prserv.sqlite3, Address: 127.0.0.1:34281, PID: 2922419 Loading cache...done. Loaded 9396 entries from dependency cache. Parsing recipes...done. Parsing of 6326 .bb files complete (6322 cached, 4 parsed). 9400 targets, 1109 skipped, 0 masked, 0 errors. NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies Build Configuration (mc:default): BB_VERSION = "2.0.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "ubuntu-22.04" TARGET_SYS = "aarch64-oe-linux" MACHINE = "am62axx-evm" DISTRO = "arago" DISTRO_VERSION = "2023.10" TUNE_FEATURES = "aarch64" TARGET_FPU = "" meta-arago-distro meta-arago-extras meta-arago-demos meta-arago-test = "HEAD:98f178314931635c8641d1394dfd4341b86b6be2" meta-qt5 = "HEAD:ae8a97f79364bed1abc297636f7933d0e35f22be" meta-virtualization = "HEAD:cb2bc17e96552cdfc141d27bd9f4dbd95a872846" meta-networking meta-python meta-oe meta-gnome meta-filesystems = "HEAD:8bb16533532b6abc2eded7d9961ab2a108fd7a5b" meta-ti-extras meta-ti-bsp = "HEAD:376a2143533c6497b4e79304eccca2a630784436" meta-arm meta-arm-toolchain = "HEAD:d7b7b6fb6c7c5545e718e44f38853d1718ce5446" meta = "HEAD:1b5405955c7c2579ed1f52522e2e177d0281fa33" meta-tisdk = "HEAD:b127f5f2a16fdc092a339939cf04c2fc92f15a34" meta-edgeai = "HEAD:0de8484d01ea85a7c366e6b56b1119613321dddb" Build Configuration: BB_VERSION = "2.0.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "ubuntu-22.04" TARGET_SYS = "arm-oe-eabi" MACHINE = "am62axx-evm-k3r5" DISTRO = "arago" DISTRO_VERSION = "2023.10" TUNE_FEATURES = "arm armv7a vfp thumb callconvention-hard" TARGET_FPU = "hard" meta-arago-distro meta-arago-extras meta-arago-demos meta-arago-test = "HEAD:98f178314931635c8641d1394dfd4341b86b6be2" meta-qt5 = "HEAD:ae8a97f79364bed1abc297636f7933d0e35f22be" meta-virtualization = "HEAD:cb2bc17e96552cdfc141d27bd9f4dbd95a872846" meta-networking meta-python meta-oe meta-gnome meta-filesystems = "HEAD:8bb16533532b6abc2eded7d9961ab2a108fd7a5b" meta-ti-extras meta-ti-bsp = "HEAD:376a2143533c6497b4e79304eccca2a630784436" meta-arm meta-arm-toolchain = "HEAD:d7b7b6fb6c7c5545e718e44f38853d1718ce5446" meta = "HEAD:1b5405955c7c2579ed1f52522e2e177d0281fa33" meta-tisdk = "HEAD:b127f5f2a16fdc092a339939cf04c2fc92f15a34" meta-edgeai = "HEAD:0de8484d01ea85a7c366e6b56b1119613321dddb" Initialising tasks...done. Sstate summary: Wanted 224 Local 79 Mirrors 0 Missed 145 Current 4004 (35% match, 96% complete) NOTE: Executing Tasks NOTE: Running task 2131 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-vision-apps.bb:do_fetch) NOTE: recipe ti-vision-apps-1.0-r0_edgeai_4: task do_fetch: Started WARNING: ti-vision-apps-1.0-r0_edgeai_4 do_fetch: Failed to fetch URL repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.09.02.00.05;manifest=vision_apps_yocto.xml, attempting MIRRORS if available ERROR: ti-vision-apps-1.0-r0_edgeai_4 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env repo init -m vision_apps_yocto.xml -b refs/tags/REL.PSDK.ANALYTICS.09.02.00.05 -u https://git.ti.com/git/processor-sdk/psdk_repo_manifests.git failed with exit code 1, output: Traceback (most recent call last): File "/extstorage/zyk/Soft/.repo/repo/main.py", line 55, in <module> from subcmds.version import Version File "/extstorage/zyk/Soft/.repo/repo/subcmds/__init__.py", line 34, in <module> mod = __import__(__name__, File "/extstorage/zyk/Soft/.repo/repo/subcmds/help.py", line 20, in <module> from formatter import AbstractFormatter, DumbWriter ModuleNotFoundError: No module named 'formatter' ERROR: ti-vision-apps-1.0-r0_edgeai_4 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.09.02.00.05;manifest=vision_apps_yocto.xml') ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_4/temp/log.do_fetch.2922520 NOTE: recipe ti-vision-apps-1.0-r0_edgeai_4: task do_fetch: Failed ERROR: Task (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-vision-apps.bb:do_fetch) failed with exit code '1' NOTE: Running task 2988 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-arago/meta-arago-extras/recipes-sysrepo/libnetconf2/libnetconf2_git.bb:do_fetch) NOTE: recipe libnetconf2-2.1.34+gitAUTOINC+91cd6d7572-r0: task do_fetch: Started NOTE: Running task 3836 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-virtualization/recipes-containers/docker/docker-ce_git.bb:do_fetch) NOTE: Running task 3837 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_fetch) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_fetch: Started NOTE: recipe docker-ce-20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0: task do_fetch: Started NOTE: Running task 4183 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-dependencies/gpiozero.bb:do_fetch) NOTE: recipe gpiozero-1.0-r0_edgeai_0: task do_fetch: Started NOTE: Running task 4631 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-tidl/ti-tidl.bb:do_fetch) NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_fetch: Started NOTE: Running task 5202 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-tiovx-apps.bb:do_fetch) NOTE: recipe edgeai-tiovx-apps-AUTOINC+c441577b22-r0_edgeai_3: task do_fetch: Started NOTE: Running task 5657 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-tidl-models.bb:do_fetch) NOTE: Running task 5658 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-test-data.bb:do_fetch) NOTE: recipe edgeai-test-data-1.0-r0_edgeai_0: task do_fetch: Started NOTE: recipe edgeai-tidl-models-1.0-r0_edgeai_0: task do_fetch: Started ERROR: edgeai-tidl-models-1.0-r0_edgeai_0 do_fetch: ExecutionError('/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tidl-models/1.0-r0_edgeai_0/temp/run.do_fetch.2922618', 4, None, None) ERROR: edgeai-test-data-1.0-r0_edgeai_0 do_fetch: ExecutionError('/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-test-data/1.0-r0_edgeai_0/temp/run.do_fetch.2922619', 4, None, None) ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tidl-models/1.0-r0_edgeai_0/temp/log.do_fetch.2922618 Log data follows: | DEBUG: Executing shell function do_fetch | Will not apply HSTS. The HSTS database must be a regular and non-world-writable file. | ERROR: could not open HSTS store at '/extstorage/zyk/.wget-hsts'. HSTS will be disabled. | --2024-06-28 09:56:15-- https://raw.githubusercontent.com/TexasInstruments/edgeai-gst-apps/21dce9bd8daa40722a3483adf586f8499f52262c/download_models.sh | Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 0.0.0.0, :: | Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refused. | Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|::|:443... failed: Connection refused. | WARNING: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tidl-models/1.0-r0_edgeai_0/temp/run.do_fetch.2922618:148 exit 4 from 'wget https://raw.githubusercontent.com/TexasInstruments/edgeai-gst-apps/${VERSION}/download_models.sh' | WARNING: Backtrace (BB generated script): | #1: do_fetch, /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tidl-models/1.0-r0_edgeai_0/temp/run.do_fetch.2922618, line 148 | #2: main, /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tidl-models/1.0-r0_edgeai_0/temp/run.do_fetch.2922618, line 157 NOTE: recipe edgeai-tidl-models-1.0-r0_edgeai_0: task do_fetch: Failed ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-test-data/1.0-r0_edgeai_0/temp/log.do_fetch.2922619 Log data follows: | DEBUG: Executing shell function do_fetch | Will not apply HSTS. The HSTS database must be a regular and non-world-writable file. | ERROR: could not open HSTS store at '/extstorage/zyk/.wget-hsts'. HSTS will be disabled. | --2024-06-28 09:56:15-- https://raw.githubusercontent.com/TexasInstruments/edgeai-gst-apps/21dce9bd8daa40722a3483adf586f8499f52262c/download_test_data.sh | Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 0.0.0.0, :: | Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refused. | Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|::|:443... failed: Connection refused. | WARNING: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-test-data/1.0-r0_edgeai_0/temp/run.do_fetch.2922619:148 exit 4 from 'wget https://raw.githubusercontent.com/TexasInstruments/edgeai-gst-apps/${VERSION}/download_test_data.sh' | WARNING: Backtrace (BB generated script): | #1: do_fetch, /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-test-data/1.0-r0_edgeai_0/temp/run.do_fetch.2922619, line 148 | #2: main, /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-test-data/1.0-r0_edgeai_0/temp/run.do_fetch.2922619, line 166 NOTE: recipe edgeai-test-data-1.0-r0_edgeai_0: task do_fetch: Failed ERROR: Task (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-tidl-models.bb:do_fetch) failed with exit code '1' ERROR: Task (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-test-data.bb:do_fetch) failed with exit code '1' NOTE: Running task 5682 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-arago/meta-arago-extras/recipes-devtools/websocketd/websocketd_0.4.1.bb:do_compile) NOTE: recipe websocketd-0.4.1-r0: task do_compile: Started NOTE: Running task 6005 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_compile) NOTE: recipe nodejs-16.20.2-r0: task do_compile: Started WARNING: libnetconf2-2.1.34+gitAUTOINC+91cd6d7572-r0 do_fetch: Failed to fetch URL git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel, attempting MIRRORS if available NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_fetch: Succeeded NOTE: Running task 6006 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_unpack) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_unpack: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_unpack: Succeeded NOTE: Running task 6007 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_patch) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_patch: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_patch: Succeeded NOTE: Running task 6008 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_deploy_source_date_epoch) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_deploy_source_date_epoch: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_deploy_source_date_epoch: Succeeded NOTE: Running task 6009 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_generate_qt_config_file) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_generate_qt_config_file: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_generate_qt_config_file: Succeeded NOTE: Running task 6010 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_create_srcipk) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_create_srcipk: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_create_srcipk: Succeeded NOTE: Running task 6011 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_prepare_recipe_sysroot) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_prepare_recipe_sysroot: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_prepare_recipe_sysroot: Succeeded NOTE: Running task 6012 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_configure) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_configure: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_configure: Succeeded NOTE: Running task 6013 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_compile) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_compile: Started ERROR: websocketd-0.4.1-r0 do_compile: ExecutionError('/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/temp/run.do_compile.2922630', 1, None, None) ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/temp/log.do_compile.2922630 Log data follows: | DEBUG: Executing shell function do_compile | go: github.com/gorilla/websocket@v1.4.0: Get "https://proxy.golang.org/github.com/gorilla/websocket/@v/v1.4.0.mod": dial tcp 142.251.42.241:443: i/o timeout | go: downloading github.com/gorilla/websocket v1.4.0 | go: github.com/gorilla/websocket@v1.4.0: Get "https://proxy.golang.org/github.com/gorilla/websocket/@v/v1.4.0.mod": dial tcp 142.251.42.241:443: i/o timeout | go: github.com/gorilla/websocket@v1.4.0: Get "https://proxy.golang.org/github.com/gorilla/websocket/@v/v1.4.0.mod": dial tcp 142.251.43.17:443: i/o timeout | go: downloading github.com/gorilla/websocket v1.4.0 | go: github.com/gorilla/websocket@v1.4.0: Get "https://proxy.golang.org/github.com/gorilla/websocket/@v/v1.4.0.mod": dial tcp 142.251.43.17:443: i/o timeout | WARNING: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/temp/run.do_compile.2922630:171 exit 1 from 'aarch64-oe-linux-go install -p 8 -v -ldflags="-r /usr/lib/go/pkg/linux_arm64_dynlink -extldflags ' -mbranch-protection=standard --sysroot=/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/recipe-sysroot -Wl,-rpath-link=/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/recipe-sysroot/usr/lib/go/pkg/linux_arm64_dynlink -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fmacro-prefix-map=/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0=/usr/src/debug/websocketd/0.4.1-r0 -fdebug-prefix-map=/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0=/usr/src/debug/websocketd/0.4.1-r0 -fdebug-prefix-map=/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/recipe-sysroot= -fdebug-prefix-map=/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/recipe-sysroot-native= '" -trimpath -modcacherw -buildmode=pie `go_list_packages`' | WARNING: Backtrace (BB generated script): | #1: go_do_compile, /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/temp/run.do_compile.2922630, line 171 | #2: do_compile, /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/temp/run.do_compile.2922630, line 163 | #3: main, /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/websocketd/0.4.1-r0/temp/run.do_compile.2922630, line 185 NOTE: recipe websocketd-0.4.1-r0: task do_compile: Failed ERROR: Task (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-arago/meta-arago-extras/recipes-devtools/websocketd/websocketd_0.4.1.bb:do_compile) failed with exit code '1' NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_compile: Succeeded NOTE: Running task 6606 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_install) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_install: Started NOTE: Running task 6803 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-gui-app_0.1.bb:do_create_srcipk) NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_create_srcipk: Started NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_create_srcipk: Succeeded NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_install: Succeeded NOTE: Running task 7744 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_package) NOTE: Running task 7745 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_populate_sysroot) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_package: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_populate_sysroot: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_populate_sysroot: Succeeded NOTE: Running task 7746 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-gui-app_0.1.bb:do_prepare_recipe_sysroot) WARNING: docker-ce-20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0 do_fetch: Failed to fetch URL git://github.com/docker/docker.git;branch=20.10;name=docker;protocol=https, attempting MIRRORS if available NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_prepare_recipe_sysroot: Started WARNING: ti-tidl-AUTOINC+default-r0_edgeai_2 do_fetch: Failed to fetch URL git://github.com/TexasInstruments/tensorflow;branch=tidl-j7-2.12-latest;protocol=https;name=tensorflow;destsuffix=git/tensorflow, attempting MIRRORS if available WARNING: gpiozero-1.0-r0_edgeai_0 do_fetch: Failed to fetch URL git://github.com/gpiozero/gpiozero.git;protocol=https;branch=master, attempting MIRRORS if available WARNING: edgeai-tiovx-apps-AUTOINC+c441577b22-r0_edgeai_3 do_fetch: Failed to fetch URL git://github.com/TexasInstruments/edgeai-tiovx-apps.git;branch=main;protocol=https, attempting MIRRORS if available NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_prepare_recipe_sysroot: Succeeded NOTE: Running task 7747 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-gui-app_0.1.bb:do_configure) NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_configure: Started NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_configure: Succeeded NOTE: Running task 7748 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-gui-app_0.1.bb:do_compile) NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_compile: Started NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_compile: Succeeded NOTE: Running task 7749 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-gui-app_0.1.bb:do_install) NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_install: Started NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_install: Succeeded NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_package: Succeeded NOTE: Running task 8207 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_packagedata) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_packagedata: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_packagedata: Succeeded NOTE: Running task 8521 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-gui-app_0.1.bb:do_package) NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_package: Started NOTE: Running task 9067 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_populate_lic) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_populate_lic: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_populate_lic: Succeeded NOTE: Running task 10271 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_package_write_ipk) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_package_write_ipk: Started NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_package: Succeeded NOTE: Running task 10272 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-gui-app_0.1.bb:do_packagedata) NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_packagedata: Started NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_packagedata: Succeeded NOTE: Running task 10273 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-gui-app_0.1.bb:do_package_write_ipk) NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_package_write_ipk: Started NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_package_write_ipk: Succeeded NOTE: Running task 10274 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquick3d_git.bb:do_package_qa) NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_package_qa: Started NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_package_qa: Succeeded NOTE: Running task 10374 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-gui-app_0.1.bb:do_package_qa) NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_package_qa: Started NOTE: recipe edgeai-gui-app-AUTOINC+44fd7f54f7-r0_edgeai_1: task do_package_qa: Succeeded NOTE: recipe qtquick3d-5.15.7+gitAUTOINC+cb8f82eeeb_8f0c6b04b2-r0: task do_package_write_ipk: Succeeded ERROR: libnetconf2-2.1.34+gitAUTOINC+91cd6d7572-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat fetch -f --progress https://github.com/CESNET/libnetconf2.git refs/heads/*:refs/heads/* refs/tags/*:refs/tags/* failed with exit code 128, no output ERROR: libnetconf2-2.1.34+gitAUTOINC+91cd6d7572-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel') ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/temp/log.do_fetch.2922522 NOTE: recipe libnetconf2-2.1.34+gitAUTOINC+91cd6d7572-r0: task do_fetch: Failed ERROR: Task (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-arago/meta-arago-extras/recipes-sysrepo/libnetconf2/libnetconf2_git.bb:do_fetch) failed with exit code '1' ERROR: edgeai-tiovx-apps-AUTOINC+c441577b22-r0_edgeai_3 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tiovx-apps/AUTOINC+c441577b22-r0_edgeai_3/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tiovx-apps/AUTOINC+c441577b22-r0_edgeai_3/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tiovx-apps/AUTOINC+c441577b22-r0_edgeai_3/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tiovx-apps/AUTOINC+c441577b22-r0_edgeai_3/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tiovx-apps/AUTOINC+c441577b22-r0_edgeai_3/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tiovx-apps/AUTOINC+c441577b22-r0_edgeai_3/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone --bare --mirror https://github.com/TexasInstruments/edgeai-tiovx-apps.git /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.TexasInstruments.edgeai-tiovx-apps.git --progress failed with exit code 128, no output ERROR: edgeai-tiovx-apps-AUTOINC+c441577b22-r0_edgeai_3 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/TexasInstruments/edgeai-tiovx-apps.git;branch=main;protocol=https') ERROR: gpiozero-1.0-r0_edgeai_0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/gpiozero/1.0-r0_edgeai_0/recipe-sysroot-native/usr/bin/python3-native:/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/gpiozero/1.0-r0_edgeai_0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/gpiozero/1.0-r0_edgeai_0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/gpiozero/1.0-r0_edgeai_0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/gpiozero/1.0-r0_edgeai_0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/gpiozero/1.0-r0_edgeai_0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/gpiozero/1.0-r0_edgeai_0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone --bare --mirror https://github.com/gpiozero/gpiozero.git /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.gpiozero.gpiozero.git --progress failed with exit code 128, no output ERROR: gpiozero-1.0-r0_edgeai_0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/gpiozero/gpiozero.git;protocol=https;branch=master') ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/gpiozero/1.0-r0_edgeai_0/temp/log.do_fetch.2922560 NOTE: recipe gpiozero-1.0-r0_edgeai_0: task do_fetch: Failed ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tiovx-apps/AUTOINC+c441577b22-r0_edgeai_3/temp/log.do_fetch.2922595 NOTE: recipe edgeai-tiovx-apps-AUTOINC+c441577b22-r0_edgeai_3: task do_fetch: Failed ERROR: Task (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-dependencies/gpiozero.bb:do_fetch) failed with exit code '1' ERROR: Task (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-tiovx-apps.bb:do_fetch) failed with exit code '1' ERROR: docker-ce-20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/docker-ce/20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/docker-ce/20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/docker-ce/20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/docker-ce/20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/docker-ce/20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/docker-ce/20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone --bare --mirror https://github.com/docker/docker.git /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.docker.docker.git --progress failed with exit code 128, no output ERROR: docker-ce-20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/docker/docker.git;branch=20.10;name=docker;protocol=https') ERROR: Logfile of failure stored in: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/docker-ce/20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0/temp/log.do_fetch.2922533 NOTE: recipe docker-ce-20.10.25-ce+git791d8ab87747169b4cbfcdf2fd57c81952bae6d5-r0.arago0_tisdk_0: task do_fetch: Failed ERROR: Task (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-virtualization/recipes-containers/docker/docker-ce_git.bb:do_fetch) failed with exit code '1' Bitbake still alive (no events for 600s). Active tasks: /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-tidl/ti-tidl.bb:do_fetch /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_compile NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_fetch: Succeeded NOTE: Running task 10537 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-tidl/ti-tidl.bb:do_unpack) NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_unpack: Started NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_unpack: Succeeded NOTE: Running task 10538 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-tidl/ti-tidl.bb:do_cp_downloaded_build_deps) NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_cp_downloaded_build_deps: Started NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_cp_downloaded_build_deps: Succeeded NOTE: Running task 10539 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-tidl/ti-tidl.bb:do_patch) NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_patch: Started NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_patch: Succeeded NOTE: Running task 10540 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-tidl/ti-tidl.bb:do_deploy_source_date_epoch) NOTE: Running task 10541 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-tidl/ti-tidl.bb:do_populate_lic) NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_deploy_source_date_epoch: Started NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_populate_lic: Started NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_populate_lic: Succeeded NOTE: recipe ti-tidl-AUTOINC+default-r0_edgeai_2: task do_deploy_source_date_epoch: Succeeded Bitbake still alive (no events for 600s). Active tasks: /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_compile Bitbake still alive (no events for 1200s). Active tasks: /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_compile Bitbake still alive (no events for 1800s). Active tasks: /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_compile NOTE: recipe nodejs-16.20.2-r0: task do_compile: Succeeded NOTE: Running task 10542 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_install) NOTE: recipe nodejs-16.20.2-r0: task do_install: Started Bitbake still alive (no events for 600s). Active tasks: /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_install NOTE: recipe nodejs-16.20.2-r0: task do_install: Succeeded NOTE: Running task 10543 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_package) NOTE: recipe nodejs-16.20.2-r0: task do_package: Started NOTE: recipe nodejs-16.20.2-r0: task do_package: Succeeded NOTE: Running task 10544 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_packagedata) NOTE: recipe nodejs-16.20.2-r0: task do_packagedata: Started NOTE: recipe nodejs-16.20.2-r0: task do_packagedata: Succeeded NOTE: Running task 10545 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-dependencies/cors_2.8.5.bb:do_package_write_ipk) NOTE: Running task 10546 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-dependencies/cors_2.8.5.bb:do_package_qa) NOTE: Running task 10547 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-dependencies/express_4.18.2.bb:do_package_write_ipk) NOTE: Running task 10548 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-dependencies/express_4.18.2.bb:do_package_qa) NOTE: Running task 10549 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_package_write_ipk) NOTE: Running task 10550 of 10796 (/extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_16.20.2.bb:do_package_qa) NOTE: recipe nodejs-16.20.2-r0: task do_package_qa: Started NOTE: recipe nodejs-16.20.2-r0: task do_package_write_ipk: Started NOTE: recipe cors-2.8.5-r0: task do_package_write_ipk: Started NOTE: recipe cors-2.8.5-r0: task do_package_qa: Started NOTE: recipe express-4.18.2-r0: task do_package_qa: Started NOTE: recipe express-4.18.2-r0: task do_package_write_ipk: Started NOTE: recipe cors-2.8.5-r0: task do_package_qa: Succeeded NOTE: recipe express-4.18.2-r0: task do_package_qa: Succeeded NOTE: recipe cors-2.8.5-r0: task do_package_write_ipk: Succeeded NOTE: recipe express-4.18.2-r0: task do_package_write_ipk: Succeeded NOTE: recipe nodejs-16.20.2-r0: task do_package_qa: Succeeded NOTE: recipe nodejs-16.20.2-r0: task do_package_write_ipk: Succeeded NOTE: Tasks Summary: Attempted 10550 tasks of which 10501 didn't need to be rerun and 8 failed. NOTE: Writing buildhistory NOTE: Writing buildhistory took: 62 seconds NOTE: Writing buildhistory NOTE: Writing buildhistory took: 4 seconds Summary: 8 tasks failed: /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-vision-apps.bb:do_fetch /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-tidl-models.bb:do_fetch /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-test-data.bb:do_fetch /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-arago/meta-arago-extras/recipes-devtools/websocketd/websocketd_0.4.1.bb:do_compile /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-arago/meta-arago-extras/recipes-sysrepo/libnetconf2/libnetconf2_git.bb:do_fetch /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-dependencies/gpiozero.bb:do_fetch /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-edgeai/recipes-tisdk/edgeai-components/edgeai-tiovx-apps.bb:do_fetch /extstorage/zyk/Soft/tisdk/yocto-build/sources/meta-virtualization/recipes-containers/docker/docker-ce_git.bb:do_fetch Summary: There were 6 WARNING messages. Summary: There were 13 ERROR messages, returning a non-zero exit code.
log
DEBUG: Executing python function extend_recipe_sysroot NOTE: Direct dependencies are [] NOTE: Installed into sysroot: [] NOTE: Skipping as already exists in sysroot: [] DEBUG: Python function extend_recipe_sysroot finished DEBUG: Executing python function do_fetch DEBUG: Executing python function base_do_fetch DEBUG: Trying Upstream DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat branch --contains 91cd6d75722c65de5c005d908f6d645b48cee89b --list devel 2> /dev/null | wc -l' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat remote' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat remote rm origin' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat remote add --mirror=fetch origin https://github.com/CESNET/libnetconf2.git' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Fetcher accessed the network with the command LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat fetch -f --progress https://github.com/CESNET/libnetconf2.git refs/heads/*:refs/heads/* refs/tags/*:refs/tags/* DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat fetch -f --progress https://github.com/CESNET/libnetconf2.git refs/heads/*:refs/heads/* refs/tags/*:refs/tags/*' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git fatal: unable to access 'https://github.com/CESNET/libnetconf2.git/': GnuTLS recv error (-110): The TLS connection was non-properly terminated. WARNING: Failed to fetch URL git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel, attempting MIRRORS if available DEBUG: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat fetch -f --progress https://github.com/CESNET/libnetconf2.git refs/heads/*:refs/heads/* refs/tags/*:refs/tags/* failed with exit code 128, no output NOTE: Removing /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Trying MIRRORS DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel returning http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?$', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian/20180310T215105Z/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20120328T092752Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20110127T084257Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20090802T004153Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.de.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.au.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.cl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.fi.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hk.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hu.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ie.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.it.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.jp.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.no.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.pl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ro.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.si.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.es.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.se.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.tr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'ftp.gnu.org', '/gnu', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/gnu', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'cdn.kernel.org', '/pub', '', '', OrderedDict()] to ['http', 'www.kernel.org', '/pub', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.gnupg.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.franken.de', '/pub/crypt/mirror/ftp.gnupg.org/gcrypt', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'mirrors.dotsrc.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['ftp', 'ftp.fu-berlin.de', '/tex/CTAN', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'sunsite.sut.ac.jp', '/pub/archives/ctan/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'ctan.unsw.edu.au', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'ftp.gnutls.org', '/gcrypt/gnutls', '', '', OrderedDict()] to ['https', 'www.gnupg.org', '/ftp/gcrypt/gnutls', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.info-zip.org', '/pub/infozip/src/', '', '', OrderedDict()] to ['ftp', 'sunsite.icm.edu.pl', '/pub/unix/archiving/info-zip/src/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/', '', '', OrderedDict()] to ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/OLD/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'www.us.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'archive.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'downloads.sourceforge.net', '/watchdog/', '', '', OrderedDict()] to ['http', 'fossies.org', '/linux/misc/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'download.savannah.gnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.gnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'download.savannah.nongnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.nongnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'mirrors.kernel.org', '/sourceware', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'gd.tuwien.ac.at', '/gnu/sourceware', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'ftp.gwdg.de', '/pub/linux/sources.redhat.com/sourceware', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz returning http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?$', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz returning http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian/20180310T215105Z/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20120328T092752Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20110127T084257Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20090802T004153Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.de.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.au.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.cl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.fi.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hk.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hu.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ie.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.it.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.jp.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.no.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.pl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ro.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.si.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.es.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.se.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.tr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'ftp.gnu.org', '/gnu', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/gnu', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'cdn.kernel.org', '/pub', '', '', OrderedDict()] to ['http', 'www.kernel.org', '/pub', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.gnupg.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.franken.de', '/pub/crypt/mirror/ftp.gnupg.org/gcrypt', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'mirrors.dotsrc.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['ftp', 'ftp.fu-berlin.de', '/tex/CTAN', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'sunsite.sut.ac.jp', '/pub/archives/ctan/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'ctan.unsw.edu.au', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'ftp.gnutls.org', '/gcrypt/gnutls', '', '', OrderedDict()] to ['https', 'www.gnupg.org', '/ftp/gcrypt/gnutls', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.info-zip.org', '/pub/infozip/src/', '', '', OrderedDict()] to ['ftp', 'sunsite.icm.edu.pl', '/pub/unix/archiving/info-zip/src/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/', '', '', OrderedDict()] to ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/OLD/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'www.us.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'archive.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'downloads.sourceforge.net', '/watchdog/', '', '', OrderedDict()] to ['http', 'fossies.org', '/linux/misc/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'download.savannah.gnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.gnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'download.savannah.nongnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.nongnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'mirrors.kernel.org', '/sourceware', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'gd.tuwien.ac.at', '/gnu/sourceware', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'ftp.gwdg.de', '/pub/linux/sources.redhat.com/sourceware', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz returning http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?$', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz returning http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian/20180310T215105Z/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20120328T092752Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20110127T084257Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20090802T004153Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.de.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.au.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.cl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.fi.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hk.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hu.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ie.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.it.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.jp.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.no.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.pl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ro.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.si.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.es.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.se.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.tr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'ftp.gnu.org', '/gnu', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/gnu', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'cdn.kernel.org', '/pub', '', '', OrderedDict()] to ['http', 'www.kernel.org', '/pub', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.gnupg.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.franken.de', '/pub/crypt/mirror/ftp.gnupg.org/gcrypt', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'mirrors.dotsrc.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['ftp', 'ftp.fu-berlin.de', '/tex/CTAN', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'sunsite.sut.ac.jp', '/pub/archives/ctan/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'ctan.unsw.edu.au', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'ftp.gnutls.org', '/gcrypt/gnutls', '', '', OrderedDict()] to ['https', 'www.gnupg.org', '/ftp/gcrypt/gnutls', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.info-zip.org', '/pub/infozip/src/', '', '', OrderedDict()] to ['ftp', 'sunsite.icm.edu.pl', '/pub/unix/archiving/info-zip/src/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/', '', '', OrderedDict()] to ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/OLD/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'www.us.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'archive.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'downloads.sourceforge.net', '/watchdog/', '', '', OrderedDict()] to ['http', 'fossies.org', '/linux/misc/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'download.savannah.gnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.gnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'download.savannah.nongnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.nongnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'mirrors.kernel.org', '/sourceware', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'gd.tuwien.ac.at', '/gnu/sourceware', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'ftp.gwdg.de', '/pub/linux/sources.redhat.com/sourceware', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'search.cpan.org', '/CPAN', '', '', OrderedDict()] to ['https', 'cpan.metacpan.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', 'downloads.yoctoproject.org', '/releases/uninative/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto/uninative/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto-sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', 'salsa.debian.org', '/.*', '', '', OrderedDict()] to ['git', 'salsa.debian.org', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', 'git.gnome.org', '/.*', '', '', OrderedDict()] to ['git', 'gitlab.gnome.org', '/GNOME/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'sources.openembedded.org', '/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/git/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'search.cpan.org', '/CPAN', '', '', OrderedDict()] to ['https', 'cpan.metacpan.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', 'downloads.yoctoproject.org', '/releases/uninative/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto/uninative/', '', '', OrderedDict()] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto-sources/', '', '', OrderedDict()] DEBUG: For url http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz returning https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?$', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz returning http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian/20180310T215105Z/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20120328T092752Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20110127T084257Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20090802T004153Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.de.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.au.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.cl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.fi.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hk.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hu.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ie.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.it.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.jp.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.no.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.pl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ro.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.si.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.es.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.se.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.tr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'ftp.gnu.org', '/gnu', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/gnu', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'cdn.kernel.org', '/pub', '', '', OrderedDict()] to ['http', 'www.kernel.org', '/pub', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.gnupg.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.franken.de', '/pub/crypt/mirror/ftp.gnupg.org/gcrypt', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'mirrors.dotsrc.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['ftp', 'ftp.fu-berlin.de', '/tex/CTAN', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'sunsite.sut.ac.jp', '/pub/archives/ctan/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'ctan.unsw.edu.au', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'ftp.gnutls.org', '/gcrypt/gnutls', '', '', OrderedDict()] to ['https', 'www.gnupg.org', '/ftp/gcrypt/gnutls', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'ftp.info-zip.org', '/pub/infozip/src/', '', '', OrderedDict()] to ['ftp', 'sunsite.icm.edu.pl', '/pub/unix/archiving/info-zip/src/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/', '', '', OrderedDict()] to ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/OLD/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'www.us.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'archive.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['http', 'downloads.sourceforge.net', '/watchdog/', '', '', OrderedDict()] to ['http', 'fossies.org', '/linux/misc/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'download.savannah.gnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.gnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'download.savannah.nongnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.nongnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'mirrors.kernel.org', '/sourceware', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'gd.tuwien.ac.at', '/gnu/sourceware', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'ftp.gwdg.de', '/pub/linux/sources.redhat.com/sourceware', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz returning http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'search.cpan.org', '/CPAN', '', '', OrderedDict()] to ['https', 'cpan.metacpan.org', '/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', 'downloads.yoctoproject.org', '/releases/uninative/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto/uninative/', '', '', OrderedDict()] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', 'salsa.debian.org', '/.*', '', '', OrderedDict()] to ['git', 'salsa.debian.org', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', 'git.gnome.org', '/.*', '', '', OrderedDict()] to ['git', 'gitlab.gnome.org', '/GNOME/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['https', 'mirrors.kernel.org', '/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/git/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', 'salsa.debian.org', '/.*', '', '', OrderedDict()] to ['git', 'salsa.debian.org', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', 'git.gnome.org', '/.*', '', '', OrderedDict()] to ['git', 'gitlab.gnome.org', '/GNOME/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'downloads.yoctoproject.org', '/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/git/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz returning http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https', 'search.cpan.org', '/CPAN', '', '', OrderedDict()] to ['https', 'cpan.metacpan.org', '/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', 'downloads.yoctoproject.org', '/releases/uninative/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto/uninative/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['https?', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto-sources/', '', '', OrderedDict()] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', 'salsa.debian.org', '/.*', '', '', OrderedDict()] to ['git', 'salsa.debian.org', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', 'git.gnome.org', '/.*', '', '', OrderedDict()] to ['git', 'gitlab.gnome.org', '/GNOME/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz', '', '', OrderedDict()] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/git/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['npm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?$', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian/20180310T215105Z/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20120328T092752Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20110127T084257Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20090802T004153Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.de.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.au.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.cl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.fi.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hk.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hu.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ie.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.it.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.jp.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.no.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.pl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ro.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.si.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.es.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.se.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.tr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'ftp.gnu.org', '/gnu', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/gnu', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'cdn.kernel.org', '/pub', '', '', OrderedDict()] to ['http', 'www.kernel.org', '/pub', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.gnupg.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.franken.de', '/pub/crypt/mirror/ftp.gnupg.org/gcrypt', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'mirrors.dotsrc.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['ftp', 'ftp.fu-berlin.de', '/tex/CTAN', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'sunsite.sut.ac.jp', '/pub/archives/ctan/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'ctan.unsw.edu.au', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'ftp.gnutls.org', '/gcrypt/gnutls', '', '', OrderedDict()] to ['https', 'www.gnupg.org', '/ftp/gcrypt/gnutls', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.info-zip.org', '/pub/infozip/src/', '', '', OrderedDict()] to ['ftp', 'sunsite.icm.edu.pl', '/pub/unix/archiving/info-zip/src/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/', '', '', OrderedDict()] to ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/OLD/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'www.us.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'archive.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'downloads.sourceforge.net', '/watchdog/', '', '', OrderedDict()] to ['http', 'fossies.org', '/linux/misc/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'download.savannah.gnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.gnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'download.savannah.nongnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.nongnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'mirrors.kernel.org', '/sourceware', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'gd.tuwien.ac.at', '/gnu/sourceware', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'ftp.gwdg.de', '/pub/linux/sources.redhat.com/sourceware', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel returning http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel returning http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'search.cpan.org', '/CPAN', '', '', OrderedDict()] to ['https', 'cpan.metacpan.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?', 'downloads.yoctoproject.org', '/releases/uninative/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto/uninative/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto-sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', 'salsa.debian.org', '/.*', '', '', OrderedDict()] to ['git', 'salsa.debian.org', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', 'git.gnome.org', '/.*', '', '', OrderedDict()] to ['git', 'gitlab.gnome.org', '/GNOME/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['git', 'github.com', '/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/git/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel returning git://github.com/git/CESNET/libnetconf2.git;protocol=https;branch=devel DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url git://github.com/git/CESNET/libnetconf2.git;protocol=https;branch=devel returning http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['npm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?$', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian/20180310T215105Z/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20120328T092752Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20110127T084257Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20090802T004153Z/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.de.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.au.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.cl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.fi.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hk.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hu.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ie.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.it.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.jp.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.no.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.pl.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ro.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.si.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.es.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.se.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.tr.debian.org', '/debian/pool', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'ftp.gnu.org', '/gnu', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/gnu', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'cdn.kernel.org', '/pub', '', '', OrderedDict()] to ['http', 'www.kernel.org', '/pub', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.gnupg.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.franken.de', '/pub/crypt/mirror/ftp.gnupg.org/gcrypt', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'mirrors.dotsrc.org', '/gcrypt', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['ftp', 'ftp.fu-berlin.de', '/tex/CTAN', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'sunsite.sut.ac.jp', '/pub/archives/ctan/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'ctan.unsw.edu.au', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'ftp.gnutls.org', '/gcrypt/gnutls', '', '', OrderedDict()] to ['https', 'www.gnupg.org', '/ftp/gcrypt/gnutls', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'ftp.info-zip.org', '/pub/infozip/src/', '', '', OrderedDict()] to ['ftp', 'sunsite.icm.edu.pl', '/pub/unix/archiving/info-zip/src/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/', '', '', OrderedDict()] to ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/OLD/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'www.us.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'archive.apache.org', '/dist', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['http', 'downloads.sourceforge.net', '/watchdog/', '', '', OrderedDict()] to ['http', 'fossies.org', '/linux/misc/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'download.savannah.gnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.gnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'download.savannah.nongnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.nongnu.org', '/releases', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'mirrors.kernel.org', '/sourceware', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'gd.tuwien.ac.at', '/gnu/sourceware', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'ftp.gwdg.de', '/pub/linux/sources.redhat.com/sourceware', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url git://github.com/git/CESNET/libnetconf2.git;protocol=https;branch=devel returning http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url git://github.com/git/CESNET/libnetconf2.git;protocol=https;branch=devel returning http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https', 'search.cpan.org', '/CPAN', '', '', OrderedDict()] to ['https', 'cpan.metacpan.org', '/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?', 'downloads.yoctoproject.org', '/releases/uninative/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto/uninative/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['https?', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto-sources/', '', '', OrderedDict()] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', 'salsa.debian.org', '/.*', '', '', OrderedDict()] to ['git', 'salsa.debian.org', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', 'git.gnome.org', '/.*', '', '', OrderedDict()] to ['git', 'gitlab.gnome.org', '/GNOME/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url ['git', 'github.com', '/git/CESNET/libnetconf2.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'devel')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/PATH', '', '', OrderedDict([('protocol', 'https')])] DEBUG: For url git://github.com/git/CESNET/libnetconf2.git;protocol=https;branch=devel returning git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel DEBUG: Fetching http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz using command '/usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz'' DEBUG: Fetcher accessed the network with the command /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz' DEBUG: Running export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz' --progress=dot -v Will not apply HSTS. The HSTS database must be a regular and non-world-writable file. ERROR: could not open HSTS store at '/extstorage/zyk/.wget-hsts'. HSTS will be disabled. --2024-06-28 09:56:22-- http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz Resolving software-dl.ti.com (software-dl.ti.com)... 23.206.27.173, 2600:1406:bc00:39b::b48, 2600:1406:bc00:3b9::b48 Connecting to software-dl.ti.com (software-dl.ti.com)|23.206.27.173|:80... connected. HTTP request sent, awaiting response... 302 Moved Temporarily Location: https://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz [following] --2024-06-28 09:56:22-- https://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz Connecting to software-dl.ti.com (software-dl.ti.com)|23.206.27.173|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 3641707 (3.5M) [application/gzip] Saving to: ‘/extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2_github.com.CESNET.libnetconf2.git.tar.gz’ 2024-06-28 09:56:29 (656 KB/s) - ‘/extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2_github.com.CESNET.libnetconf2.git.tar.gz’ saved [3641707/3641707] DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; tar -xzf /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2_github.com.CESNET.libnetconf2.git.tar.gz' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat branch --contains 91cd6d75722c65de5c005d908f6d645b48cee89b --list devel 2> /dev/null | wc -l' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat remote' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat remote rm origin' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat remote add --mirror=fetch origin https://github.com/CESNET/libnetconf2.git' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git DEBUG: Fetcher accessed the network with the command LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat fetch -f --progress https://github.com/CESNET/libnetconf2.git refs/heads/*:refs/heads/* refs/tags/*:refs/tags/* DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat fetch -f --progress https://github.com/CESNET/libnetconf2.git refs/heads/*:refs/heads/* refs/tags/*:refs/tags/*' in /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.CESNET.libnetconf2.git fatal: unable to access 'https://github.com/CESNET/libnetconf2.git/': Failed to connect to github.com port 443 after 134469 ms: Connection timed out DEBUG: Mirror fetch failure for url http://software-dl.ti.com/processor-sdk-mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz (original url: git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel) DEBUG: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat fetch -f --progress https://github.com/CESNET/libnetconf2.git refs/heads/*:refs/heads/* refs/tags/*:refs/tags/* failed with exit code 128, no output DEBUG: Fetching http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz using command '/usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz'' DEBUG: Fetcher accessed the network with the command /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz' DEBUG: Running export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz' --progress=dot -v Will not apply HSTS. The HSTS database must be a regular and non-world-writable file. ERROR: could not open HSTS store at '/extstorage/zyk/.wget-hsts'. HSTS will be disabled. --2024-06-28 09:58:44-- http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz Resolving downloads.yoctoproject.org (downloads.yoctoproject.org)... 198.145.29.62 Connecting to downloads.yoctoproject.org (downloads.yoctoproject.org)|198.145.29.62|:80... connected. HTTP request sent, awaiting response... 404 Not Found 2024-06-28 09:58:45 ERROR 404: Not Found. DEBUG: Mirror fetch failure for url http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz (original url: git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel) DEBUG: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://downloads.yoctoproject.org/mirror/sources/git2_github.com.CESNET.libnetconf2.git.tar.gz' --progress=dot -v failed with exit code 8, no output DEBUG: Fetching http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz using command '/usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz'' DEBUG: Fetcher accessed the network with the command /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz' DEBUG: Running export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz' --progress=dot -v Will not apply HSTS. The HSTS database must be a regular and non-world-writable file. ERROR: could not open HSTS store at '/extstorage/zyk/.wget-hsts'. HSTS will be disabled. --2024-06-28 09:58:45-- http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz Resolving sources.openembedded.org (sources.openembedded.org)... 198.145.29.27 Connecting to sources.openembedded.org (sources.openembedded.org)|198.145.29.27|:80... connected. HTTP request sent, awaiting response... 404 Not Found 2024-06-28 09:58:46 ERROR 404: Not Found. DEBUG: Mirror fetch failure for url http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz (original url: git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel) DEBUG: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'http://sources.openembedded.org/git2_github.com.CESNET.libnetconf2.git.tar.gz' --progress=dot -v failed with exit code 8, no output DEBUG: Fetching https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz using command '/usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz'' DEBUG: Fetcher accessed the network with the command /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz' DEBUG: Running export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz' --progress=dot -v Will not apply HSTS. The HSTS database must be a regular and non-world-writable file. ERROR: could not open HSTS store at '/extstorage/zyk/.wget-hsts'. HSTS will be disabled. --2024-06-28 09:58:46-- https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz Resolving mirrors.kernel.org (mirrors.kernel.org)... 139.178.88.99, 2604:1380:45e3:2400::1 Connecting to mirrors.kernel.org (mirrors.kernel.org)|139.178.88.99|:443... connected. HTTP request sent, awaiting response... 404 Not Found 2024-06-28 09:58:48 ERROR 404: Not Found. DEBUG: Mirror fetch failure for url https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz (original url: git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel) DEBUG: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; /usr/bin/env wget -t 2 -T 30 --passive-ftp -P /extstorage/zyk/Soft/tisdk/yocto-build/downloads 'https://mirrors.kernel.org/yocto-sources/git2_github.com.CESNET.libnetconf2.git.tar.gz' --progress=dot -v failed with exit code 8, no output DEBUG: Fetcher accessed the network with the command LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone --bare --mirror https://github.com/git/CESNET/libnetconf2.git /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.git.CESNET.libnetconf2.git --progress DEBUG: Running export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone --bare --mirror https://github.com/git/CESNET/libnetconf2.git /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.git.CESNET.libnetconf2.git --progress Cloning into bare repository '/extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.git.CESNET.libnetconf2.git'... remote: Not Found fatal: repository 'https://github.com/git/CESNET/libnetconf2.git/' not found DEBUG: Mirror fetch failure for url git://github.com/git/CESNET/libnetconf2.git;protocol=https;branch=devel (original url: git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel) DEBUG: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone --bare --mirror https://github.com/git/CESNET/libnetconf2.git /extstorage/zyk/Soft/tisdk/yocto-build/downloads/git2/github.com.git.CESNET.libnetconf2.git --progress failed with exit code 128, no output ERROR: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1002/bus"; export PATH="/extstorage/zyk/Soft/tisdk/yocto-build/sources/oe-core/scripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot/usr/bin/crossscripts:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/usr/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/sbin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/libnetconf2/2.1.34+gitAUTOINC+91cd6d7572-r0/recipe-sysroot-native/bin:/extstorage/zyk/Soft/tisdk/yocto-build/sources/bitbake/bin:/extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/extstorage/zyk"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat fetch -f --progress https://github.com/CESNET/libnetconf2.git refs/heads/*:refs/heads/* refs/tags/*:refs/tags/* failed with exit code 128, no output ERROR: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/CESNET/libnetconf2.git;protocol=https;branch=devel') DEBUG: Python function base_do_fetch finished DEBUG: Python function do_fetch finished
Does it seem that some GitHub addresses are inaccessible?
DEBUG: Executing shell function do_fetch
--2024-07-01 05:43:56-- raw.githubusercontent.com/.../download_models.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 0.0.0.0, ::
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refused.
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|::|:443... failed: Connection refused.
WARNING: /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tidl-models/1.0-r0_edgeai_0/temp/run.do_fetch.3000927:148 exit 4 from 'wget raw.githubusercontent.com/.../download_models.sh'
WARNING: Backtrace (BB generated script):
#1: do_fetch, /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tidl-models/1.0-r0_edgeai_0/temp/run.do_fetch.3000927, line 148
#2: main, /extstorage/zyk/Soft/tisdk/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/edgeai-tidl-models/1.0-r0_edgeai_0/temp/run.do_fetch.3000927, line 157
It seems that some GitHub addresses cannot be accessed? If the address that reported an error is like this
Can you create a temporary directory, and execute the failing `repo` command from your log directly on the command line, like this (I've added two more commands for testing purposes).
a0797059@dasso:~/tmp/vision-test $ /usr/bin/env repo init -m vision_apps_yocto.xml -b refs/tags/REL.PSDK.ANALYTICS.09.02.00.05 -u https://git.ti.com/git/processor-sdk/psdk_repo_manifests.git Downloading Repo source from https://gerrit.googlesource.com/git-repo ... A new version of repo (2.45) is available. ... New version is available at: /home/a0797059/tmp/vision-test/.repo/repo/repo ... The launcher is run from: /usr/bin/repo !!! The launcher is not writable. Please talk to your sysadmin or distro !!! to get an update installed. Your identity is: Andreas Dannenberg <dannenberg@ti.com> If you want to change this, please re-run 'repo init' with --config-name repo has been initialized in /home/a0797059/tmp/vision-test a0797059@dasso:~/tmp/vision-test $ repo info ... A new version of repo (2.45) is available. ... New version is available at: /home/a0797059/tmp/vision-test/.repo/repo/repo ... The launcher is run from: /usr/bin/repo !!! The launcher is not writable. Please talk to your sysadmin or distro !!! to get an update installed. Manifest branch: Manifest merge branch: refs/tags/REL.PSDK.ANALYTICS.09.02.00.05 Manifest groups: default,platform-linux ---------------------------- a0797059@dasso:~/tmp/vision-test $ repo sync ... A new version of repo (2.45) is available. ... New version is available at: /home/a0797059/tmp/vision-test/.repo/repo/repo ... The launcher is run from: /usr/bin/repo !!! The launcher is not writable. Please talk to your sysadmin or distro !!! to get an update installed. Fetching: 100% (10/10), done in 14.243s Checking out: 80% (8/10), done in 1.431s repo sync has finished successfully.
Are you working behind a firewall? Perhaps the settings don't get picked up by `repo`. Looks like `repo` relies on the `http_proxy` environmental variable to be set for this.
Regards, Andreas
~/Soft/tisdk/tmp$ /usr/bin/env repo init -m vision_apps_yocto.xml -b refs/tags/REL.PSDK.ANALYTICS.09.02.00.05 -u git.ti.com/.../psdk_repo_manifests.git Traceback (most recent call last): File "/extstorage/zyk/Soft/.repo/repo/main.py", line 55, in <module> from subcmds.version import Version File "/extstorage/zyk/Soft/.repo/repo/subcmds/__init__.py", line 34, in <module> mod = __import__(__name__, File "/extstorage/zyk/Soft/.repo/repo/subcmds/help.py", line 20, in <module> from formatter import AbstractFormatter, DumbWriter ModuleNotFoundError: No module named 'formatter'
Excuse me, do you have a domestic environment in China, or could you please provide us with a link that can be accessed domestically and has already been downloaded
Actually that looks more like a Python issue, with a module/dependency missing ('formatter'). Can you setup a clean Ubuntu 22.04 installation, then install all the pre-requisites as per SDK documentation https://software-dl.ti.com/processor-sdk-linux/esd/AM62AX/09_02_00/exports/docs/linux/Overview_Building_the_SDK.html#prerequisites-one-time-setup, and re-try? I'm worried just fixing this one issue here will only lead to more issues. So better start from a clean baseline.
Regards, Andreas
gpg: keybox '/home/zyk/.repoconfig/gnupg/pubring.kbx' created
gpg: /home/zyk/.repoconfig/gnupg/trustdb.gpg: trustdb created
gpg: key 16530D5E920F5C65: public key "Repo Maintainer <repo@android.kernel.org>" imported
gpg: key 67B7E448692B382C: public key "Conley Owens <cco3@android.com>" imported
gpg: Total number processed: 2
gpg: imported: 2
fatal: Cannot get gerrit.googlesource.com/.../clone.bundle
fatal: error [Errno 101] Network is unreachable
As part of the repo tool initialization it clones the https://gerrit.googlesource.com/git-repo repository. Can you try that manually? If you have the http_proxy/https_proxy ENV variables setup this should just work.
a0797059@dasso:~/tmp/vision-test $ git clone https://gerrit.googlesource.com/git-repo Cloning into 'git-repo'... remote: Finding sources: 100% (7/7) remote: Total 8851 (delta 4238), reused 8847 (delta 4238) Receiving objects: 100% (8851/8851), 11.39 MiB | 20.46 MiB/s, done. Resolving deltas: 100% (4238/4238), done.
Regards, Andreas
git clone gerrit.googlesource.com/git-repo
fatal: unable to access 'gerrit.googlesource.com/.../': Failed to connect to gerrit.googlesource.com port 443: Connection refused
Have you configured a proxy for Git? Try searching for how to do that on the Internet, there's plenty of resources.
In summary you can do that by using environmental variables, or by setting up ~/.gitconfig accordingly. Usually in the context of Yocto which is what you ultimately want the use of environmental variables is preferred, as they'll propagate into the Yocto build environment, and will be used for everything during build.
At this point this is a basic IT setup issue that you need to debug yourself, perhaps with the help of your IT support or a knowledgeable colleague. There's not much I can do here to help further.
Regards, Andreas
So we need to climb over the wall to complete the download and compilation of yocto build
Yocto builds can be challenging to get going as by nature they fetch from a large selection of internet servers/resources. So any type of corporate firewall, other firewall, or even possibly country/location specific aspects can come into play here, but usually you can work through those concerns. Also once packages are fetched successfully at least once they are stored in the 'downloads' folder and will not need to be fetched again during future builds (always keep the 'downloads' folder contents!)
We have planned also to provide a TI-hosted download mirror like we had in the past to make this process more smooth, but this isn't something that's available for SDK v9.x.
Regards, Andreas
--- Starting bitbake server pid 54027 at 2024-07-02 17:57:46.501654 --- Started bitbake server pid 54027 NOTE: Your conf/bblayers.conf has been automatically updated. NOTE: Your conf/bblayers.conf has been automatically updated. Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/build/core-secdev-k3', 'PWD': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/build', 'LOGNAME': 'root', 'OEBASE': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk', 'HOME': '/root', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm-256color', 'USER': 'root', 'TOOLCHAIN_PATH_ARMV8': '/mnt/vol1/xinlu/yocto/yoctobuild/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/mnt/vol1/xinlu/yocto/yoctobuild/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/meta-virtualization/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/oe-core/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin', 'LC_ALL': 'en_US.UTF-8', 'COLORTERM': 'truecolor', 'SUDO_GID': '1004', 'SUDO_COMMAND': '/bin/bash yoctobuild.sh', 'SUDO_USER': 'xiang', 'LANG': 'en_US.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SHLVL': '0', 'SUDO_UID': '1004', 'BUILDDIR': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/build', 'MAIL': '/var/mail/root', 'OLDPWD': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk', '_': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin/bitbake'}, ['/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-edgeai-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.RunQueue.HashEquiv': 19, 'BitBake.SigGen.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-edgeai-image'], 'build'] Command Completed Processing Client Disconnecting Client No timeout, exiting. Exiting --- Starting bitbake server pid 64729 at 2024-07-02 18:46:52.515183 --- Started bitbake server pid 64729 Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/home/xiang/workspace/yocto/yoctobuild/tisdk/build/core-secdev-k3', 'PWD': '/home/xiang/workspace/yocto/yoctobuild/tisdk/build', 'LOGNAME': 'xiang', 'OEBASE': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk', 'HOME': '/home/xiang', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm-256color', 'USER': 'xiang', 'TOOLCHAIN_PATH_ARMV8': '/home/xiang/workspace/yocto/yoctobuild/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/home/xiang/workspace/yocto/yoctobuild/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/meta-virtualization/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/oe-core/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/meta-virtualization/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/oe-core/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/meta-virtualization/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/oe-core/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin:/opt/ros/noetic/bin:/usr/local/cuda-9.0/bin:/home/xiang/anaconda2/bin:/home/xiang/anaconda2/bin:/usr/local/cuda/bin:/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/bin/remote-cli:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/arm_cross/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/bin', 'LC_ALL': 'en_US.UTF-8', 'ROS_VERSION': '1', 'COLORTERM': 'truecolor', 'TERM_PROGRAM_VERSION': '1.90.2', 'CONDA_EXE': '/home/xiang/anaconda2/bin/conda', 'PKG_CONFIG_PATH': '/opt/ros/noetic/lib/pkgconfig:/opt/ros/melodic/lib/pkgconfig', 'ROS_PYTHON_VERSION': '3', 'ROS_PACKAGE_PATH': '/opt/ros/noetic/share', 'ROSLISP_PACKAGE_DIRECTORIES': '', 'XDG_SESSION_TYPE': 'tty', 'CONDA_PREFIX': '/home/xiang/anaconda2', 'VSCODE_GIT_ASKPASS_NODE': '/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/node', 'MOTD_SHOWN': 'pam', 'LANG': 'en_US.UTF-8', 'ROS_ETC_DIR': '/opt/ros/noetic/etc/ros', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SSL_CERT_DIR': '/usr/lib/ssl/certs', 'CONDA_PROMPT_MODIFIER': '(base) ', 'GIT_ASKPASS': '/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/extensions/git/dist/askpass.sh', 'CMAKE_PREFIX_PATH': '/opt/ros/noetic:/opt/ros/melodic', 'SSH_CONNECTION': '192.168.120.242 62783 192.168.120.101 22', 'VSCODE_GIT_ASKPASS_EXTRA_ARGS': '', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'PYTHONPATH': '/opt/ros/noetic/lib/python3/dist-packages:/home/xiang/workspace/workspace/devel/lib/python2.7/dist-packages', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'VSCODE_GIT_IPC_HANDLE': '/run/user/1004/vscode-git-daecf10fd2.sock', 'CONDA_SHLVL': '1', 'SHLVL': '1', 'ROS_MASTER_URI': 'http://localhost:11311', 'XDG_SESSION_ID': '4', 'CONDA_PYTHON_EXE': '/home/xiang/anaconda2/bin/python', 'LD_LIBRARY_PATH': '/opt/ros/noetic/lib:/opt/ros/melodic/lib:/usr/local/cuda-9.0/lib64:/usr/local/cuda/lib64', 'XDG_RUNTIME_DIR': '/run/user/1004', 'SSL_CERT_FILE': '/usr/lib/ssl/certs/ca-certificates.crt', 'SSH_CLIENT': '192.168.120.242 62783 22', 'CONDA_DEFAULT_ENV': 'base', 'VSCODE_GIT_ASKPASS_MAIN': '/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/extensions/git/dist/askpass-main.js', 'GAZEBO_MODEL_PATH': '/home/xiang/workspace/workspace/install/share/gazebo_models_tsinc/models:/home/xiang/workspace/workspace/src/TauristarPlatformRecipe/developer_launch/models:/home/xiang/workspace/workspace/install/share/gazebo_models_tsinc/models:/home/xiang/workspace/workspace/src/autonomous_park_ros/project_gazebo/models:', 'BROWSER': '/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/bin/helpers/browser.sh', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1004/bus', 'BUILDDIR': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/build', 'ROS_ROOT': '/opt/ros/noetic/share/ros', 'ROS_DISTRO': 'noetic', 'OLDPWD': '/home/xiang/workspace/yocto/yoctobuild', 'TERM_PROGRAM': 'vscode', 'VSCODE_IPC_HOOK_CLI': '/run/user/1004/vscode-ipc-f5e36bd1-3a5f-4d64-93ee-4f77854d6116.sock', '_': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin/bitbake'}, ['/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-edgeai-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.RunQueue.HashEquiv': 19, 'BitBake.SigGen.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-edgeai-image'], 'build'] Command Completed Processing Client Disconnecting Client No timeout, exiting. Exiting --- Starting bitbake server pid 2178927 at 2024-07-03 14:27:55.304763 --- Started bitbake server pid 2178927 Entering server connection loop Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([]) Processing Client Connecting Client Running command ['setFeatures', [2]] Command Completed Running command ['updateConfig', {'abort': False, 'force': False, 'invalidate_stamp': None, 'debug': 0, 'dry_run': False, 'dump_signatures': [], 'debug_domains': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'build_verbose_shell': False, 'build_verbose_stdout': False}, {'MACHINE': 'am62axx-evm', 'SHELL': '/bin/bash', 'TI_SECURE_DEV_PKG_K3': '/home/xiang/workspace/yocto/yoctobuild/tisdk/build/core-secdev-k3', 'PWD': '/home/xiang/workspace/yocto/yoctobuild/tisdk/build', 'LOGNAME': 'xiang', 'OEBASE': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk', 'HOME': '/home/xiang', 'BB_ENV_EXTRAWHITE': 'MACHINE DISTRO TCMODE TCLIBC http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS PARALLEL_MAKE GIT_PROXY_COMMAND GIT_PROXY_IGNORE SOCKS5_PASSWD SOCKS5_USER OEBASE META_SDK_PATH TOOLCHAIN_TYPE TOOLCHAIN_BRAND TOOLCHAIN_BASE TOOLCHAIN_PATH TOOLCHAIN_PATH_ARMV5 TOOLCHAIN_PATH_ARMV7 TOOLCHAIN_PATH_ARMV8 EXTRA_TISDK_FILES TISDK_VERSION ARAGO_BRAND ARAGO_RT_ENABLE ARAGO_SYSTEST_ENABLE ARAGO_KERNEL_SUFFIX TI_SECURE_DEV_PKG_CAT TI_SECURE_DEV_PKG_AUTO TI_SECURE_DEV_PKG_K3 ARAGO_SYSVINIT SYSFW_FILE', 'TERM': 'xterm-256color', 'USER': 'xiang', 'TOOLCHAIN_PATH_ARMV8': '/home/xiang/workspace/yocto/yoctobuild/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu', 'TOOLCHAIN_PATH_ARMV7': '/home/xiang/workspace/yocto/yoctobuild/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf', 'PATH': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/meta-virtualization/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/oe-core/scripts:/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin:/opt/ros/noetic/bin:/usr/local/cuda-9.0/bin:/home/xiang/anaconda2/bin:/home/xiang/anaconda2/bin:/usr/local/cuda/bin:/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/bin/remote-cli:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/arm_cross/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/bin', 'LC_ALL': 'en_US.UTF-8', 'ROS_VERSION': '1', 'COLORTERM': 'truecolor', 'TERM_PROGRAM_VERSION': '1.90.2', 'CONDA_EXE': '/home/xiang/anaconda2/bin/conda', 'PKG_CONFIG_PATH': '/opt/ros/noetic/lib/pkgconfig:/opt/ros/melodic/lib/pkgconfig', 'ROS_PYTHON_VERSION': '3', 'ROS_PACKAGE_PATH': '/opt/ros/noetic/share', 'ROSLISP_PACKAGE_DIRECTORIES': '', 'XDG_SESSION_TYPE': 'tty', 'CONDA_PREFIX': '/home/xiang/anaconda2', 'VSCODE_GIT_ASKPASS_NODE': '/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/node', 'MOTD_SHOWN': 'pam', 'LANG': 'en_US.UTF-8', 'ROS_ETC_DIR': '/opt/ros/noetic/etc/ros', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'SSL_CERT_DIR': '/usr/lib/ssl/certs', 'CONDA_PROMPT_MODIFIER': '(base) ', 'GIT_ASKPASS': '/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/extensions/git/dist/askpass.sh', 'CMAKE_PREFIX_PATH': '/opt/ros/noetic:/opt/ros/melodic', 'SSH_CONNECTION': '192.168.120.242 50211 192.168.120.101 22', 'VSCODE_GIT_ASKPASS_EXTRA_ARGS': '', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'PYTHONPATH': '/opt/ros/noetic/lib/python3/dist-packages:/home/xiang/workspace/workspace/devel/lib/python2.7/dist-packages', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'VSCODE_GIT_IPC_HANDLE': '/run/user/1004/vscode-git-a6e16abeb8.sock', 'CONDA_SHLVL': '1', 'SHLVL': '1', 'ROS_MASTER_URI': 'http://localhost:11311', 'XDG_SESSION_ID': '53', 'CONDA_PYTHON_EXE': '/home/xiang/anaconda2/bin/python', 'LD_LIBRARY_PATH': '/opt/ros/noetic/lib:/opt/ros/melodic/lib:/usr/local/cuda-9.0/lib64:/usr/local/cuda/lib64', 'XDG_RUNTIME_DIR': '/run/user/1004', 'SSL_CERT_FILE': '/usr/lib/ssl/certs/ca-certificates.crt', 'SSH_CLIENT': '192.168.120.242 50211 22', 'CONDA_DEFAULT_ENV': 'base', 'VSCODE_GIT_ASKPASS_MAIN': '/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/extensions/git/dist/askpass-main.js', 'GAZEBO_MODEL_PATH': '/home/xiang/workspace/workspace/install/share/gazebo_models_tsinc/models:/home/xiang/workspace/workspace/src/TauristarPlatformRecipe/developer_launch/models:/home/xiang/workspace/workspace/install/share/gazebo_models_tsinc/models:/home/xiang/workspace/workspace/src/autonomous_park_ros/project_gazebo/models:', 'BROWSER': '/home/xiang/.vscode-server/cli/servers/Stable-5437499feb04f7a586f677b155b039bc2b3669eb/server/bin/helpers/browser.sh', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1004/bus', 'BUILDDIR': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/build', 'ROS_ROOT': '/opt/ros/noetic/share/ros', 'ROS_DISTRO': 'noetic', 'OLDPWD': '/home/xiang/workspace/yocto/yoctobuild', 'TERM_PROGRAM': 'vscode', 'VSCODE_IPC_HOOK_CLI': '/run/user/1004/vscode-ipc-8269ba19-6584-40fb-97ec-3b976bb07d46.sock', '_': '/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin/bitbake'}, ['/mnt/vol1/xinlu/yocto/yoctobuild/tisdk/sources/bitbake/bin/bitbake', '-k', 'tisdk-edgeai-image']] Command Completed Running command ['getVariable', 'BBINCLUDELOGS'] Command Completed Running command ['getVariable', 'BBINCLUDELOGS_LINES'] Command Completed Running command ['getSetVariable', 'BB_CONSOLELOG'] Command Completed Running command ['getSetVariable', 'BB_LOGCONFIG'] Command Completed Running command ['getUIHandlerNum'] Command Completed Running command ['setEventMask', 1, 20, {'BitBake.SigGen.HashEquiv': 19, 'BitBake.RunQueue.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']] Command Completed Running command ['getVariable', 'BB_DEFAULT_TASK'] Command Completed Running command ['setConfig', 'cmd', 'build'] Command Completed Running command ['buildTargets', ['tisdk-edgeai-image'], 'build'] Command Completed Auto packing the repository in background for optimum performance. See "git help gc" for manual housekeeping. Processing Client Disconnecting Client No timeout, exiting. Exiting
I asked one of my colleagues to help download and compile it. He is in Pittsburgh, but still cannot compile tisdk edgeai image am62axx evm tar. xz
I just setup a new build environment from scratch using the very instructions you shared earlier (link) in this thread. Usually I would reconfigure the download directory and shared state setting variables directly after running oe-layertool-setup.sh to use my local cache but I didn't do that this time, this way making sure any and all content is being pulled from the Internet, and build from scratch, just like you are using it. Of course my network setup is different, but this will help checking if all servers are accessible.
Will report back once the build is done.
Regards, Andreas
so I tried the build using the exact steps you had posted https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1379745/sk-am62a-lp-sk-am62a-lp-yocto-build-sdk/5275791#5275791 which match the documentation at https://software-dl.ti.com/processor-sdk-linux/esd/AM62AX/09_02_00/exports/docs/linux/Overview_Building_the_SDK.html#build-steps and it worked (almost) without issues. One of the recipes failed ...
ERROR: Task (/home/a0797059/tisdk/am62axx-evm-test/sources/meta-arago/meta-arago-distro/recipes-graphics/vk-gl-cts/vulkan-cts_1.3.3.1.bb:do_compile) failed wi th exit code '1'
...but after simply re-starting the build went through without any other issues:
a0797059@dasso:~/tisdk/am62axx-evm-test/build (dev) $ MACHINE="am62axx-evm" bitbake -k tisdk-edgeai-image NOTE: Started PRServer with DBfile: /home/a0797059/tisdk/am62axx-evm-test/build/cache/prserv.sqlite3, Address: 127.0.0.1:33957, PID: 2623058 Loading cache: 100% |##########################################################################################################################| Time: 0:00:01 Loaded 9396 entries from dependency cache. Parsing recipes: 100% |########################################################################################################################| Time: 0:00:01 Parsing of 6326 .bb files complete (6322 cached, 4 parsed). 9400 targets, 1109 skipped, 0 masked, 0 errors. NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies NOTE: Resolving any missing task queue dependencies Build Configuration (mc:default): BB_VERSION = "2.0.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "ubuntu-22.04" TARGET_SYS = "aarch64-oe-linux" MACHINE = "am62axx-evm" DISTRO = "arago" DISTRO_VERSION = "2023.10" TUNE_FEATURES = "aarch64" TARGET_FPU = "" meta-arago-distro meta-arago-extras meta-arago-demos meta-arago-test = "HEAD:98f178314931635c8641d1394dfd4341b86b6be2" meta-qt5 = "HEAD:ae8a97f79364bed1abc297636f7933d0e35f22be" meta-virtualization = "HEAD:cb2bc17e96552cdfc141d27bd9f4dbd95a872846" meta-networking meta-python meta-oe meta-gnome meta-filesystems = "HEAD:8bb16533532b6abc2eded7d9961ab2a108fd7a5b" meta-ti-extras meta-ti-bsp = "HEAD:376a2143533c6497b4e79304eccca2a630784436" meta-arm meta-arm-toolchain = "HEAD:d7b7b6fb6c7c5545e718e44f38853d1718ce5446" meta = "HEAD:1b5405955c7c2579ed1f52522e2e177d0281fa33" meta-tisdk = "HEAD:b127f5f2a16fdc092a339939cf04c2fc92f15a34" meta-edgeai = "HEAD:0de8484d01ea85a7c366e6b56b1119613321dddb" Initialising tasks: 100% |#####################################################################################################################| Time: 0:00:04 Sstate summary: Wanted 277 Local 269 Mirrors 0 Missed 8 Current 3951 (97% match, 99% complete) NOTE: Executing Tasks NOTE: Tasks Summary: Attempted 10796 tasks of which 10778 didn't need to be rerun and all succeeded. NOTE: Writing buildhistory NOTE: Writing buildhistory took: 3 seconds NOTE: Writing buildhistory NOTE: Writing buildhistory took: 2 seconds a0797059@dasso:~/tisdk/am62axx-evm-test/build (dev) $
This basically means all servers/repositories are accessible and in working order. If there are any fetch-related issues then it should be due to the local setup/network environment etc.
Regards, Andreas
