Part Number: AM625
Hi Ti,
1. We use SDK: 09_01_00_08 , Kernel Version: 6.1.46-rt13 in our custom board.
We use KIOXIA emmc sdhci0 boot on speed HS200 ,then to test Repeatedly power on and off.
it have tidss error happen occasionally.
U-Boot SPL 2023.04-ga37da23008 (Apr 02 2024 - 05:22:32 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
SPL initial stack usage: 1856 bytes
Error: could not access storage.
Trying to boot from MMC1
Authentication passed
U-Boot 2023.04-ga37da23008 (Apr 02 2024 - 05:22:32 +0000)
SoC: AM62X SR1.0 HS-FS
Model: Texas Instruments AM625 SK
DRAM: 2 GiB
Core: 68 devices, 30 uclasses, devicetree: separate
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from MMC... OK
In: serial
Out: serial
Err: serial
[BSP] gd->boot_dev = 9
Saving Environment to MMC... Writing to redundant MMC(0)... OK
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
Running eMMC boot ...
574 bytes read in 14 ms (40 KiB/s)
EMMC Loaded env from uEnv.txt
Importing environment from mmc0 ...
16908800 bytes read in 199 ms (81 MiB/s)
63041 bytes read in 16 ms (3.8 MiB/s)
Working FDT set to 88000000
ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4)
Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
Working FDT set to 8feed000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.46-rt13-BSP_12.4--g17da321871 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT_RT Tue Apr 23 02:09:43 UTC 2024
[ 0.000000] Machine model: Texas Instruments AM625 SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[ 0.000000] node 0: [mem 0x00000000ff700000-0x00000000fffc9fff]
[ 0.000000] node 0: [mem 0x00000000fffca000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 21 pages/cpu s45952 r8192 d31872 u86016
[ 0.000000] pcpu-alloc: s45952 r8192 d31872 u86016 alloc=21*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=ac66bde0-8c17-47a9-9c94-4fa2c73e8bef rw rootfstype=ext4 rootwait systemd.show_status=no loglevel=8 syntec_extend=
[ 0.000000] Unknown kernel command line parameters "syntec_extend=", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1845668K/2097152K available (10752K kernel code, 1216K rwdata, 2600K rodata, 1856K init, 424K bss, 120412K reserved, 131072K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: 0xffff800008412db0
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080020000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080030000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000243] Console: colour dummy device 80x25
[ 0.529232] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
[ 0.529242] pid_max: default: 32768 minimum: 301
[ 0.529328] LSM: Security Framework initializing
[ 0.529454] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.529476] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.531211] rcu: Hierarchical SRCU implementation.
[ 0.531219] rcu: Max phase no-delay instances is 400.
[ 0.531267] printk: bootconsole [ns16550a0] printing thread started
[ 0.583717] Platform MSI: msi-controller@1820000 domain created
[ 0.583964] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.584048] EFI services will not be available.
[ 0.584288] smp: Bringing up secondary CPUs ...
[ 0.585059] Detected VIPT I-cache on CPU1
[ 0.585178] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.585196] GICv3: CPU1: using allocated LPI pending table @0x0000000080040000
[ 0.585253] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.635302] Detected VIPT I-cache on CPU2
[ 0.635395] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.635408] GICv3: CPU2: using allocated LPI pending table @0x0000000080050000
[ 0.635441] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.661321] Detected VIPT I-cache on CPU3
[ 0.661407] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.661419] GICv3: CPU3: using allocated LPI pending table @0x0000000080060000
[ 0.661454] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.661509] smp: Brought up 1 node, 4 CPUs
[ 0.661516] SMP: Total of 4 processors activated.
[ 0.695715] CPU features: detected: 32-bit EL0 Support
[ 0.695719] CPU features: detected: CRC32 instructions
[ 0.695764] CPU: All CPU(s) started at EL2
[ 0.695766] alternatives: applying system-wide alternatives
[ 0.697276] devtmpfs: initialized
[ 0.708906] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.708932] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.714069] pinctrl core: initialized pinctrl subsystem
[ 0.714800] DMI not present or invalid.
[ 0.715329] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.729194] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.729553] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.729774] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.729913] audit: initializing netlink subsys (disabled)
[ 0.730087] audit: type=2000 audit(0.728:1): state=initialized audit_enabled=0 res=1
[ 0.730712] thermal_sys: Registered thermal governor 'step_wise'
[ 0.730716] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.730939] ASID allocator initialised with 65536 entries
[ 0.745854] platform 30200000.dss: Fixed dependency cycle(s) with /display0
[ 0.754920] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.754930] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.754934] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.754937] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.754941] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.754943] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.754947] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.754951] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.760207] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.762350] iommu: Default domain type: Translated
[ 0.762358] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.762701] SCSI subsystem initialized
[ 0.762817] libata version 3.00 loaded.
[ 0.763065] usbcore: registered new interface driver usbfs
[ 0.763104] usbcore: registered new interface driver hub
[ 0.763134] usbcore: registered new device driver usb
[ 0.763488] pps_core: LinuxPPS API ver. 1 registered
[ 0.763491] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.763507] PTP clock support registered
[ 0.763654] EDAC MC: Ver: 3.0.0
[ 0.764510] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 0.764851] FPGA manager framework
[ 0.764964] Advanced Linux Sound Architecture Driver Initialized.
[ 0.765801] vgaarb: loaded
[ 0.766057] clocksource: Switched to clocksource arch_sys_counter
[ 0.766309] VFS: Disk quotas dquot_6.6.0
[ 0.766353] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.772561] NET: Registered PF_INET protocol family
[ 0.772856] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.774623] tcp_listen_portaddr_hash hash table entries: 1024 (order: 3, 40960 bytes, linear)
[ 0.774681] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.774696] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.774912] TCP bind hash table entries: 16384 (order: 8, 1310720 bytes, linear)
[ [ 1.042840] printk: console [ttyS2] printing thread started
0.776691] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.042859] printk: console [ttyS2] enabled
[ 1.042863] printk: bootconsole [ns16550a0] disabled
[ 1.055084] printk: bootconsole [ns16550a0] printing thread stopped
[ 1.056363] 2810000.serial: ttyS1 at MMIO 0x2810000 (irq = 288, base_baud = 3000000) is a 8250
[ 1.060350] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[ 1.065361] Console: switching to colour dummy device 80x25
[ 1.101954] Console: switching to colour frame buffer device 100x37
[ 1.118497] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
[ 1.120474] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.154087] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.154373] mdio_bus 8000f00.mdio: MDIO device at address 0 is missing.
[ 1.155957] davinci_mdio 8000f00.mdio: phy[3]: device 8000f00.mdio:03, driver TI DP83822
[ 1.156004] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.156265] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[ 1.156278] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.156283] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.157078] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[ 1.177463] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.182218] physmap-flash 50000000.fpgaBus: physmap platform flash device: [mem 0x50000000-0x50ffffff]
[ 1.183284] mmc1: CQHCI version 5.10
[ 1.183944] mmc0: CQHCI version 5.10
[ 1.185416] mmc2: CQHCI version 5.10
[ 1.186571] physmap-flash 51000000.fpgaBus: physmap platform flash device: [mem 0x51000000-0x51ffffff]
[ 1.189012] physmap-flash 52000000.fpgaBus: physmap platform flash device: [mem 0x52000000-0x52ffffff]
[ 1.199123] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 1.201674] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present!
[ 1.214010] ALSA device list:
[ 1.214023] No soundcards found.
[ 1.220472] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.226723] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[ 1.235135] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 1.235304] Waiting for root device PARTUUID=ac66bde0-8c17-47a9-9c94-4fa2c73e8bef...
[ 1.311531] mmc1: new MMC card at address 0001
[ 1.312342] mmcblk1: mmc1:0001 004GA0 3.69 GiB
[ 1.318918] mmcblk1: p1
[ 1.319740] mmcblk1boot0: mmc1:0001 004GA0 2.00 MiB
[ 1.321442] mmcblk1boot1: mmc1:0001 004GA0 2.00 MiB
[ 1.322779] mmcblk1rpmb: mmc1:0001 004GA0 512 KiB, chardev (241:0)
[ 1.336626] mmc0: Command Queue Engine enabled
[ 1.336645] mmc0: new HS200 MMC card at address 0001
[ 1.337393] mmcblk0: mmc0:0001 016GB0 14.7 GiB
[ 1.341599] mmcblk0: p1 p2 p3 p4 p5
[ 1.342669] mmcblk0boot0: mmc0:0001 016GB0 4.00 MiB
[ 1.344019] mmcblk0boot1: mmc0:0001 016GB0 4.00 MiB
[ 1.345151] mmcblk0rpmb: mmc0:0001 016GB0 4.00 MiB, chardev (241:1)
[ 1.373627] EXT4-fs (mmcblk0p4): recovery complete
[ 1.374029] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.374141] VFS: Mounted root (ext4 filesystem) on device 179:100.
[ 1.374291] devtmpfs: mounted
[ 1.375642] Freeing unused kernel memory: 1856K
[ 1.375764] Run /sbin/init as init process
[ 1.375768] with arguments:
[ 1.375770] /sbin/init
[ 1.375771] with environment:
[ 1.375773] HOME=/
[ 1.375774] TERM=linux
[ 1.375776] syntec_extend=
[ 1.500991] systemd[1]: System time before build time, advancing clock.
[ 1.533276] NET: Registered PF_INET6 protocol family
[ 1.534436] Segment Routing with IPv6
[ 1.534472] In-situ OAM (IOAM) with IPv6
[ 1.547692] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 1.548366] systemd[1]: Detected architecture arm64.
[ 1.550913] systemd[1]: Hostname set to <am62xx-evm>.
[ 1.677749] systemd-sysv-generator[182]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 1.989370] systemd[1]: Configuration file /etc/systemd/system/syntec-rename-network.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 1.992249] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 2.054416] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.057695] systemd[1]: Created slice Slice /system/modprobe.
[ 2.059269] systemd[1]: Created slice Slice /system/serial-getty.
[ 2.059744] systemd[1]: Created slice User and Session Slice.
[ 2.060142] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.060376] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.060751] systemd[1]: Reached target Path Units.
[ 2.060854] systemd[1]: Reached target Remote File Systems.
[ 2.060927] systemd[1]: Reached target Slice Units.
[ 2.061029] systemd[1]: Reached target Swaps.
[ 2.065629] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 2.065803] systemd[1]: Reached target RPC Port Mapper.
[ 2.071866] systemd[1]: Listening on Process Core Dump Socket.
[ 2.072372] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.073210] systemd[1]: Listening on Journal Audit Socket.
[ 2.073753] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.074314] systemd[1]: Listening on Journal Socket.
[ 2.075167] systemd[1]: Listening on Network Service Netlink Socket.
[ 2.077043] systemd[1]: Listening on udev Control Socket.
[ 2.077598] systemd[1]: Listening on udev Kernel Socket.
[ 2.078106] systemd[1]: Listening on User Database Manager Socket.
[ 2.106688] systemd[1]: Mounting Huge Pages File System...
[ 2.110628] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.114816] systemd[1]: Mounting Kernel Debug File System...
[ 2.115668] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[ 2.116974] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
[ 2.120867] systemd[1]: Mounting Temporary Directory /tmp...
[ 2.126371] systemd[1]: Starting Create List of Static Device Nodes...
[ 2.131653] systemd[1]: Starting Load Kernel Module configfs...
[ 2.136904] systemd[1]: Starting Load Kernel Module drm...
[ 2.142242] systemd[1]: Starting Load Kernel Module fuse...
[ 2.149038] systemd[1]: Starting RPC Bind...
[ 2.149621] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 2.150961] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 2.150985] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 2.154491] systemd[1]: Starting Journal Service...
[ 2.157897] fuse: init (API version 7.37)
[ 2.162680] systemd[1]: Starting Load Kernel Modules...
[ 2.167842] systemd[1]: Starting Generate network units from Kernel command line...
[ 2.172980] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.180858] systemd[1]: Starting Coldplug All udev Devices...
[ 2.192695] systemd[1]: Starting Setup Virtual Console...
[ 2.203680] systemd[1]: Started RPC Bind.
[ 2.205186] systemd[1]: Mounted Huge Pages File System.
[ 2.206160] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.206915] systemd[1]: Mounted Kernel Debug File System.
[ 2.207534] systemd[1]: Mounted Temporary Directory /tmp.
[ 2.208821] systemd[1]: Finished Create List of Static Device Nodes.
[ 2.211369] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.212759] systemd[1]: Finished Load Kernel Module configfs.
[ 2.214487] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.217755] systemd[1]: Finished Load Kernel Module drm.
[ 2.220235] cryptodev: loading out-of-tree module taints kernel.
[ 2.226132] cryptodev: driver 1.12 loaded.
[ 2.226210] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.226947] systemd[1]: Finished Load Kernel Module fuse.
[ 2.229557] systemd[1]: Finished Generate network units from Kernel command line.
[ 2.235935] EXT4-fs (mmcblk0p4): re-mounted. Quota mode: none.
[ 2.262411] systemd[1]: Mounting FUSE Control File System...
[ 2.269479] systemd[1]: Mounting Kernel Configuration File System...
[ 2.281913] systemd[1]: Started Journal Service.
[ 2.346969] systemd-journald[193]: Received client request to flush runtime journal.
[ 2.757137] random: crng init done
[ 2.873517] fram@0 enforce active low on chipselect handle
[ 2.894950] mc: Linux media interface: v0.10
[ 2.903171] videodev: Linux video capture interface: v2.00
[ 2.963737] rtc-s35390a 1-0030: registered as rtc0
[ 2.965918] rtc-s35390a 1-0030: setting system clock to 2022-09-24T20:13:39 UTC (1664050419)
[ 2.973602] systemd-journald[193]: Oldest entry in /run/log/journal/de178beeed9c42a5b601e629bab2738c/system.journal is older than the configured file retention duration (1month), suggesting rotation.
[ 2.973628] systemd-journald[193]: /run/log/journal/de178beeed9c42a5b601e629bab2738c/system.journal: Journal header limits reached or header out-of-date, rotating.
[ 3.005945] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[ 3.006121] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[ 3.006182] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[ 3.014500] remoteproc remoteproc0: 5000000.m4fss is available
[ 3.015949] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[ 3.015983] remoteproc remoteproc0: powering up 5000000.m4fss
[ 3.016021] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[ 3.016029] remoteproc remoteproc0: request_firmware failed: -2
[ 3.028022] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[ 3.206965] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 3.207135] platform 78000000.r5f: configured R5F for IPC-only mode
[ 3.207306] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[ 3.207683] remoteproc remoteproc1: 78000000.r5f is available
[ 3.207766] remoteproc remoteproc1: attaching to 78000000.r5f
[ 3.248148] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[ 3.306629] platform 78000000.r5f: R5F core initialized in IPC-only mode
[ 3.306672] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9da00000
[ 3.310087] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 3.310144] rproc-virtio rproc-virtio.3.auto: registered virtio0 (type 7)
[ 3.310152] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[ 3.311141] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 3.311345] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 3.324648] Init FPGA interrupt driver (1.0)
[ 3.325359] Get kick_gpio number= (418)
[ 4.056895] fm25_syntec spi2.0: 32 KByte fm25 fram, pagesize 4096
[ 4.135999] remoteproc remoteproc2: 30074000.pru is available
[ 4.136983] remoteproc remoteproc3: 30078000.pru is available
[ 4.300366] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
[ 4.457302] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 4.457361] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[ 4.462409] xhci-hcd xhci-hcd.4.auto: USB3 root hub has no ports
[ 4.462434] xhci-hcd xhci-hcd.4.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
[ 4.468325] xhci-hcd xhci-hcd.4.auto: irq 465, io mem 0x31100000
[ 4.475444] hub 1-0:1.0: USB hub found
[ 4.475523] hub 1-0:1.0: 1 port detected
[ 4.604132] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.652007] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.652926] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.652968] cfg80211: failed to load regulatory.db
[ 4.717128] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 4.845244] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:03] driver [TI DP83822] (irq=POLL)
[ 4.845337] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
[ 4.885095] hub 1-1:1.0: USB hub found
[ 4.886030] hub 1-1:1.0: 4 ports detected
[ 5.309313] EXT4-fs (mmcblk0p1): recovery complete
[ 5.309350] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
[ 5.339153] usb 1-1.3: new low-speed USB device number 3 using xhci-hcd
[ 5.476883] EXT4-fs (mmcblk0p2): recovery complete
[ 5.476923] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 5.507402] EXT4-fs (mmcblk0p3): recovery complete
[ 5.507447] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Quota mode: none.
[ 5.540912] EXT4-fs (mmcblk0p5): Using encoding defined by superblock: utf8-12.1.0 with flags 0x1
[ 5.638873] EXT4-fs (mmcblk0p5): recovery complete
[ 5.639599] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Quota mode: none.
[ 5.654558] am65-cpsw-nuss 8000000.ethernet lan1: renamed from eth0
[ 5.661782] usbcore: registered new interface driver usbhid
[ 5.661800] usbhid: USB HID core driver
[ 5.688353] input: Logitech USB Keyboard as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0001/input/input0
[ 5.710935] am65-cpsw-nuss 8000000.ethernet lan1: PHY [8000f00.mdio:03] driver [TI DP83822] (irq=POLL)
[ 5.710966] am65-cpsw-nuss 8000000.ethernet lan1: configuring for phy/rmii link mode
[ 5.741473] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.4.auto-1.3/input0
[ 5.744722] input: Logitech USB Keyboard Consumer Control as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0002/input/input1
[ 5.796657] input: Logitech USB Keyboard System Control as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0002/input/input2
[ 5.797635] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.4.auto-1.3/input1
[ 5.937456] EXT4-fs (mmcblk1p1): recovery complete
[ 5.937492] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Quota mode: none.
NOTICE: This file system contains the following GPL-3.0 packages:
adwaita-icon-theme-symbolic
bash
cifs-utils
dosfstools
grub-common
grub-editenv
grub-efi
less
lib32-libgcc1
lib32-libstdc++6
libdw1
libelf1
libgcc1
libgdbm-compat4
libgdbm6
libgmp10
libidn2-0
libreadline8
libstdc++6
libunistring2
libvte-2.91-0
nettle
onboard
parted
rxvt-unicode
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
WARNING: The runtime version supported by this application is unavailable.
Using default runtime: v4.0.30319
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project am62xx-evm -
Arago 2023.10 am62xx-evm -
am62xx-evm login: [ 33.780050] rcu: INFO: rcu_preempt self-detected stall on CPU
[ 33.780076] rcu: 0-....: (21020 ticks this GP) idle=720c/1/0x4000000000000000 softirq=0/0 fqs=4629 rcuc=21012 jiffies(starved)
[ 33.780088] (t=21000 jiffies g=6961 q=1478 ncpus=4)
[ 33.780101] CPU: 0 PID: 137 Comm: irq/289-tidss Tainted: G O 6.1.46-rt13-BSP_12.4--g17da321871 #1
[ 33.780107] Hardware name: Texas Instruments AM625 SK (DT)
[ 33.780114] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 33.780121] pc : 0xffff800008580518
[ 33.780125] lr : 0xffff80000858067c
[ 33.780128] sp : ffff000001d6bd40
[ 33.780130] x29: ffff000001d6bd40 x28: ffff800008089000 x27: ffff000001c68f10
[ 33.780141] x26: ffff000001c68edc x25: ffff000000dc6000 x24: ffff000001d49500
[ 33.780148] x23: ffff000001c68e00 x22: ffff00000124e000 x21: 0000000000000001
[ 33.780155] x20: ffff000001c68e00 x19: 0000000000000000 x18: ffff80000906f000
[ 33.780162] x17: ffff8000768ce000 x16: ffff00007f66d900 x15: 000000000000003c
[ 33.780170] x14: ffffffffffffffff x13: 0000000000000000 x12: 0000000000000000
[ 33.780179] x11: ffff000001c68a80 x10: ffff80000906f000 x9 : 0000000000000000
[ 33.780186] x8 : ffff800008b593e8 x7 : 000000000000002b x6 : ffffffffffffffff
[ 33.780194] x5 : 0000000000000015 x4 : 00000000003fffff x3 : 0000000000000002
[ 33.780201] x2 : 000000000000002c x1 : 000000000000002c x0 : 0000000000000002
[ 33.780209] Call trace:
[ 33.780212] 0xffff800008580518
[ 33.780215] 0xffff80000858067c
[ 33.780217] 0xffff80000857edbc
[ 33.780219] 0xffff800008089f18
[ 33.780221] 0xffff80000808a20c
[ 33.780223] 0xffff8000080583b4
[ 33.780225] 0xffff800008014cb0
[ 96.783053] rcu: INFO: rcu_preempt self-detected stall on CPU
[ 96.783073] rcu: 0-....: (84023 ticks this GP) idle=720c/1/0x4000000000000000 softirq=0/0 fqs=18399 rcuc=84015 jiffies(starved)
[ 96.783084] (t=84003 jiffies g=6961 q=1547 ncpus=4)
[ 96.783094] CPU: 0 PID: 137 Comm: irq/289-tidss Tainted: G O 6.1.46-rt13-BSP_12.4--g17da321871 #1
[ 96.783101] Hardware name: Texas Instruments AM625 SK (DT)
[ 96.783106] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 96.783115] pc : 0xffff8000085805d8
[ 96.783118] lr : 0xffff80000857edbc
[ 96.783120] sp : ffff000001d6bd50
[ 96.783122] x29: ffff000001d6bd50 x28: ffff800008089000 x27: ffff000001c68f10
[ 96.783132] x26: ffff000001c68edc x25: ffff000000dc6000 x24: ffff000001d49500
[ 96.783140] x23: ffff000001c68e00 x22: ffff00000124e000 x21: 0000000000000001
[ 96.783147] x20: ffff000001c68e00 x19: 0000000000000000 x18: ffff80000906f000
[ 96.783155] x17: ffff8000768ce000 x16: ffff00007f66d900 x15: 000000000000003c
[ 96.783162] x14: ffffffffffffffff x13: 0000000000000000 x12: 0000000000000000
[ 96.783169] x11: ffff000001c68a80 x10: ffff80000906f000 x9 : ffff80000906fad8
[ 96.783176] x8 : 0000000000000000 x7 : ffff000001c68a80 x6 : ffffffffffffffff
[ 96.783183] x5 : ffff00007f668808 x4 : 0000000000000000 x3 : ffff8000768ce000
[ 96.783191] x2 : ffff80000857eda0 x1 : ffff800009293000 x0 : 0000000000000000
[ 96.783199] Call trace:
[ 96.783201] 0xffff8000085805d8
[ 96.783204] 0xffff80000857edbc
[ 96.783207] 0xffff800008089f18
[ 96.783209] 0xffff80000808a20c
[ 96.783211] 0xffff8000080583b4
[ 96.783213] 0xffff800008014cb0
[ 159.786052] rcu: INFO: rcu_preempt self-detected stall on CPU
[ 159.786075] rcu: 0-....: (147026 ticks this GP) idle=720c/1/0x4000000000000000 softirq=0/0 fqs=32097 rcuc=147018 jiffies(starved)
[ 159.786086] (t=147006 jiffies g=6961 q=1652 ncpus=4)
[ 159.786098] CPU: 0 PID: 137 Comm: irq/289-tidss Tainted: G O 6.1.46-rt13-BSP_12.4--g17da321871 #1
[ 159.786104] Hardware name: Texas Instruments AM625 SK (DT)
[ 159.786108] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 159.786115] pc : 0xffff800008580638
[ 159.786118] lr : 0xffff8000085805f0
[ 159.786119] sp : ffff000001d6bd50
[ 159.786121] x29: ffff000001d6bd50 x28: ffff800008089000 x27: ffff000001c68f10
[ 159.786133] x26: ffff000001c68edc x25: ffff000000dc6000 x24: ffff000001d49500
[ 159.786142] x23: ffff000001c68e00 x22: ffff00000124e000 x21: 0000000000000001
[ 159.786149] x20: ffff000001c68e00 x19: 0000000000000000 x18: ffff80000906f000
[ 159.786157] x17: ffff8000768ce000 x16: ffff00007f66d900 x15: 000000000000003c
[ 159.786164] x14: ffffffffffffffff x13: 0000000000000000 x12: 0000000000000000
[ 159.786171] x11: ffff000001c68a80 x10: ffff80000906f000 x9 : ffff80000906fad8
[ 159.786178] x8 : 0000000000000002 x7 : ffff000001c68a80 x6 : 0000000000000100
[ 159.786185] x5 : 0000000000000200 x4 : 0000000000000001 x3 : ffff800008b593e8
[ 159.786192] x2 : 0000000000000001 x1 : 0000000000000000 x0 : ffff800009293000
[ 159.786200] Call trace:
[ 159.786203] 0xffff800008580638
[ 159.786206] 0xffff80000857edbc
[ 159.786208] 0xffff800008089f18
[ 159.786210] 0xffff80000808a20c
[ 159.786212] 0xffff8000080583b4
[ 159.786214] 0xffff800008014cb0
[ 187.215813] audit: type=1701 audit(1664050603.748:2): auid=4294967295 uid=991 gid=987 ses=4294967295 pid=861 comm="systemd-network" exe="/lib/systemd/systemd-networkd" sig=6 res=1
