HI:
we now use the ethernat native driver base on SDK9.1 , but counter some problem:
- config Serdes1 LN2 and LN3 for SGMII-1 and SGMII2 ,Serdes2 LN0 for SGMII5 , now linux can detect phy and linked normal, but ping not work
some infomatione as folw:
- sch
serdes1-ln2 for SGMII1 - phy dp83tg720
serdes1-ln3 for SGMII2 - phy dp83tg720
serdes2-ln0 for SGMII5 - phy dp83tc812
- ethfw status
now disabled
- patch code
&serdes_refclk { clock-frequency = <100000000>; }; &serdes_ln_ctrl { idle-states = <J784S4_SERDES0_LANE0_IP4_UNUSED>, <J784S4_SERDES0_LANE1_IP1_UNUSED>, <J784S4_SERDES0_LANE2_IP3_UNUSED>, <J784S4_SERDES0_LANE3_IP4_UNUSED>, <J784S4_SERDES1_LANE0_IP3_UNUSED>, <J784S4_SERDES1_LANE1_IP3_UNUSED>, <J784S4_SERDES1_LANE2_QSGMII_LANE1>, <J784S4_SERDES1_LANE3_QSGMII_LANE2>, <J784S4_SERDES2_LANE0_QSGMII_LANE5>, <J784S4_SERDES2_LANE1_IP3_UNUSED>, <J784S4_SERDES2_LANE2_IP3_UNUSED>, <J784S4_SERDES2_LANE3_IP3_UNUSED>; }; &serdes_wiz1 { status = "okay"; }; &serdes1 { status = "okay"; #address-cells = <1>; #size-cells = <0>; serdes1_sgmii_link: phy@0 { reg = <2>; cdns,num-lanes = <2>; #phy-cells = <0>; cdns,phy-type = <PHY_TYPE_SGMII>; resets = <&serdes_wiz1 3>,<&serdes_wiz1 4>; }; }; &serdes_wiz2 { status = "okay"; }; &serdes2 { status = "okay"; #address-cells = <1>; #size-cells = <0>; serdes2_sgmii_link: phy@0 { reg = <0>; cdns,num-lanes = <1>; #phy-cells = <0>; cdns,phy-type = <PHY_TYPE_SGMII>; resets = <&serdes_wiz2 1>; }; }; &main_cpsw0 { status = "okay"; }; &main_cpsw0_port1 { status = "okay"; phy-handle = <&cpsw9g_phy0>; phy-mode = "sgmii"; mac-address = [00 00 00 00 00 01]; phys = <&cpsw0_phy_gmii_sel 1>, <&serdes1_sgmii_link>; phy-names = "portmode", "serdes-phy"; }; &main_cpsw0_port2 { status = "okay"; phy-handle = <&cpsw9g_phy1>; phy-mode = "sgmii"; mac-address = [00 00 00 00 00 02]; phys = <&cpsw0_phy_gmii_sel 2>, <&serdes1_sgmii_link>; phy-names = "portmode", "serdes-phy"; }; &main_cpsw0_port5 { status = "okay"; phy-handle = <&cpsw9g_phy2>; phy-mode = "sgmii"; mac-address = [00 00 00 00 00 03]; phys = <&cpsw0_phy_gmii_sel 5>, <&serdes2_sgmii_link>; phy-names = "portmode", "serdes-phy"; }; &main_cpsw0_mdio { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&mdio0_pins_default>; cpsw9g_phy0: ethernet-phy@10 { reg = <10>; compatible = "ethernet-phy-ieee802.3-c22"; ethphy-mode = "master"; ethphy-speed = <1000>; }; cpsw9g_phy1: ethernet-phy@4 { reg = <4>; compatible = "ethernet-phy-ieee802.3-c22"; ethphy-mode = "master"; ethphy-speed = <1000>; }; cpsw9g_phy2: ethernet-phy@8 { reg = <8>; compatible = "ethernet-phy-ieee802.3-c22"; ethphy-mode = "master"; ethphy-speed = <100>; }; };
- dts
- network card
eth0 Link encap:Ethernet HWaddr 00:00:00:00:00:01 inet addr:172.16.0.1 Bcast:172.16.15.255 Mask:255.255.240.0 inet6 addr: fe80::200:ff:fe00:1/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:22 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:1744 (1.7 KiB) eth1 Link encap:Ethernet HWaddr 00:00:00:00:00:02 inet addr:198.18.36.1 Bcast:198.18.255.255 Mask:255.255.0.0 inet6 addr: fe80::200:ff:fe00:2/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:168 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:7876 (7.6 KiB) eth2 Link encap:Ethernet HWaddr 00:00:00:00:00:03 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:2182 errors:0 dropped:0 overruns:0 frame:0 TX packets:2182 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:190896 (186.4 KiB) TX bytes:190896 (186.4 KiB)
- ethtool info
Settings for eth0: Supported ports: [ TP MII ] Supported link modes: 1000baseT/Full Supported pause frame use: Symmetric Supports auto-negotiation: No Supported FEC modes: Not reported Advertised link modes: Not reported Advertised pause frame use: Symmetric Advertised auto-negotiation: No Advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Auto-negotiation: off master-slave cfg: forced master master-slave status: master Port: Twisted Pair PHYAD: 10 Transceiver: external MDI-X: Unknown Supports Wake-on: d Wake-on: d Current message level: 0x000020f7 (8439) drv probe link ifdown ifup rx_err tx_err hw Link detected: yes SQI: 7/7
- regster dump
[0x00104080] SERDES0_LN0_CTRL : 0x00000003 [0x00104084] SERDES0_LN1_CTRL : 0x00000000 [0x00104088] SERDES0_LN2_CTRL : 0x00000002 [0x0010408C] SERDES0_LN3_CTRL : 0x00000003 [0x00104090] SERDES1_LN0_CTRL : 0x00000002 [0x00104094] SERDES1_LN1_CTRL : 0x00000002 [0x00104098] SERDES1_LN2_CTRL : 0x00000000 [0x0010409C] SERDES1_LN3_CTRL : 0x00000000 [0x001040A0] SERDES2_LN0_CTRL : 0x00000000 [0x001040A4] SERDES2_LN1_CTRL : 0x00000002 [0x001040A8] SERDES2_LN2_CTRL : 0x00000002 [0x001040AC] SERDES2_LN3_CTRL : 0x00000002 [0x001040C0] SERDES4_LN0_CTRL : 0x00000000 [0x001040C4] SERDES4_LN1_CTRL : 0x00000000 [0x001040C8] SERDES4_LN2_CTRL : 0x00000000 [0x001040CC] SERDES4_LN3_CTRL : 0x00000000 [0x001040E0] SERDES0_CTRL : 0x00000000 [0x001040E4] SERDES1_CTRL : 0x00000000 [0x001040E8] SERDES2_CTRL : 0x00000000 [0x001040F0] SERDES4_CTRL : 0x00000000 [0x0c000078] CPSW9_STATUS_SGMII_LINK : 0x00000000 [0x0c000100] CPSW9_SGMII_IDVER0 : 0x00000000 [0x0c000200] CPSW9_SGMII_IDVER1 : 0x00000000 [0x0c000300] CPSW9_SGMII_IDVER2 : 0x4EC21102 [0x0c000400] CPSW9_SGMII_IDVER3 : 0x4EC21102 [0x0c000500] CPSW9_SGMII_IDVER4 : 0x00000000 [0x0c000600] CPSW9_SGMII_IDVER5 : 0x4EC21102 [0x0c000700] CPSW9_SGMII_IDVER6 : 0x4EC21102 [0x0c000800] CPSW9_SGMII_IDVER7 : 0x4EC21102 [0x0c000104] CPSW9_SGMII_SOFT_RST0 : 0x00000000 [0x0c000204] CPSW9_SGMII_SOFT_RST1 : 0x00000000 [0x0c000304] CPSW9_SGMII_SOFT_RST2 : 0x00000000 [0x0c000404] CPSW9_SGMII_SOFT_RST3 : 0x00000000 [0x0c000504] CPSW9_SGMII_SOFT_RST4 : 0x00000000 [0x0c000604] CPSW9_SGMII_SOFT_RST5 : 0x00000000 [0x0c000704] CPSW9_SGMII_SOFT_RST6 : 0x00000000 [0x0c000804] CPSW9_SGMII_SOFT_RST7 : 0x00000000 [0x0c000110] CPSW9_SGMII_CTRL0 : 0x00000000 [0x0c000210] CPSW9_SGMII_CTRL1 : 0x00000000 [0x0c000310] CPSW9_SGMII_CTRL2 : 0x00000000 [0x0c000410] CPSW9_SGMII_CTRL3 : 0x00000000 [0x0c000510] CPSW9_SGMII_CTRL4 : 0x00000000 [0x0c000610] CPSW9_SGMII_CTRL5 : 0x00000000 [0x0c000710] CPSW9_SGMII_CTRL6 : 0x00000000 [0x0c000810] CPSW9_SGMII_CTRL7 : 0x00000000 [0x0c000114] CPSW9_SGMII_STATUS0 : 0x00000000 [0x0c000214] CPSW9_SGMII_STATUS1 : 0x00000000 [0x0c000314] CPSW9_SGMII_STATUS2 : 0x00000028 [0x0c000414] CPSW9_SGMII_STATUS3 : 0x00000020 [0x0c000514] CPSW9_SGMII_STATUS4 : 0x00000000 [0x0c000614] CPSW9_SGMII_STATUS5 : 0x00000022 [0x0c000714] CPSW9_SGMII_STATUS6 : 0x00000020 [0x0c000814] CPSW9_SGMII_STATUS7 : 0x00000020 [0x0c000118] CPSW9_SGMII_MR_ADV_ABLT0 : 0x00000000 [0x0c000218] CPSW9_SGMII_MR_ADV_ABLT1 : 0x00000000 [0x0c000318] CPSW9_SGMII_MR_ADV_ABLT2 : 0x00000000 [0x0c000418] CPSW9_SGMII_MR_ADV_ABLT3 : 0x00000000 [0x0c000518] CPSW9_SGMII_MR_ADV_ABLT4 : 0x00000000 [0x0c000618] CPSW9_SGMII_MR_ADV_ABLT5 : 0x00000000 [0x0c000718] CPSW9_SGMII_MR_ADV_ABLT6 : 0x00000000 [0x0c000818] CPSW9_SGMII_MR_ADV_ABLT7 : 0x00000000 [0x0c00011C] CPSW9_SGMII_MR_NP_TX0 : 0x00000000 [0x0c00021C] CPSW9_SGMII_MR_NP_TX1 : 0x00000000 [0x0c00031C] CPSW9_SGMII_MR_NP_TX2 : 0x00000000 [0x0c00041C] CPSW9_SGMII_MR_NP_TX3 : 0x00000000 [0x0c00051C] CPSW9_SGMII_MR_NP_TX4 : 0x00000000 [0x0c00061C] CPSW9_SGMII_MR_NP_TX5 : 0x00000000 [0x0c00071C] CPSW9_SGMII_MR_NP_TX6 : 0x00000000 [0x0c00081C] CPSW9_SGMII_MR_NP_TX7 : 0x00000000 [0x0c000120] CPSW9_SGMII_MR_LP_ADV_ABLT0 : 0x00000000 [0x0c000220] CPSW9_SGMII_MR_LP_ADV_ABLT1 : 0x00000000 [0x0c000320] CPSW9_SGMII_MR_LP_ADV_ABLT2 : 0x00000213 [0x0c000420] CPSW9_SGMII_MR_LP_ADV_ABLT3 : 0x00000000 [0x0c000520] CPSW9_SGMII_MR_LP_ADV_ABLT4 : 0x00000000 [0x0c000620] CPSW9_SGMII_MR_LP_ADV_ABLT5 : 0x000080C6 [0x0c000720] CPSW9_SGMII_MR_LP_ADV_ABLT6 : 0x00000000 [0x0c000820] CPSW9_SGMII_MR_LP_ADV_ABLT7 : 0x00000000 [0x0c000124] CPSW9_SGMII_MR_LP_NP_RX0 : 0x00000000 [0x0c000224] CPSW9_SGMII_MR_LP_NP_RX1 : 0x00000000 [0x0c000324] CPSW9_SGMII_MR_LP_NP_RX2 : 0x00000160 [0x0c000424] CPSW9_SGMII_MR_LP_NP_RX3 : 0x00000000 [0x0c000524] CPSW9_SGMII_MR_LP_NP_RX4 : 0x00000000 [0x0c000624] CPSW9_SGMII_MR_LP_NP_RX5 : 0x00000013 [0x0c000724] CPSW9_SGMII_MR_LP_NP_RX6 : 0x00000000 [0x0c000824] CPSW9_SGMII_MR_LP_NP_RX7 : 0x00000000 [0x0c000140] CPSW9_SGMII_DIAG0 : 0x00000000 [0x0c000240] CPSW9_SGMII_DIAG1 : 0x00000000 [0x0c000340] CPSW9_SGMII_DIAG2 : 0x00000000 [0x0c000440] CPSW9_SGMII_DIAG3 : 0x00000000 [0x0c000540] CPSW9_SGMII_DIAG4 : 0x00000000 [0x0c000640] CPSW9_SGMII_DIAG5 : 0x00000000 [0x0c000740] CPSW9_SGMII_DIAG6 : 0x00000000 [0x0c000840] CPSW9_SGMII_DIAG7 : 0x00000000 [0x0c000144] CPSW9_SGMII_DIAG_CTRL0 : 0x00000000 [0x0c000244] CPSW9_SGMII_DIAG_CTRL1 : 0x00000000 [0x0c000344] CPSW9_SGMII_DIAG_CTRL2 : 0x00000000 [0x0c000444] CPSW9_SGMII_DIAG_CTRL3 : 0x00000000 [0x0c000544] CPSW9_SGMII_DIAG_CTRL4 : 0x00000000 [0x0c000644] CPSW9_SGMII_DIAG_CTRL5 : 0x00000000 [0x0c000744] CPSW9_SGMII_DIAG_CTRL6 : 0x00000000 [0x0c000844] CPSW9_SGMII_DIAG_CTRL7 : 0x00000000 [0x0c000148] CPSW9_SGMII_DIAG_STATUS0 : 0x00000000 [0x0c000248] CPSW9_SGMII_DIAG_STATUS1 : 0x00000000 [0x0c000348] CPSW9_SGMII_DIAG_STATUS2 : 0x00000004 [0x0c000448] CPSW9_SGMII_DIAG_STATUS3 : 0x00000000 [0x0c000548] CPSW9_SGMII_DIAG_STATUS4 : 0x00000000 [0x0c000648] CPSW9_SGMII_DIAG_STATUS5 : 0x00000680 [0x0c000748] CPSW9_SGMII_DIAG_STATUS6 : 0x00000000 [0x0c000848] CPSW9_SGMII_DIAG_STATUS7 : 0x00000000 [0x00104044] ENET1_CTRL : 0x00000003 [0x00104048] ENET2_CTRL : 0x00000003 [0x0010404C] ENET3_CTRL : 0x00000002 [0x00104050] ENET4_CTRL : 0x00000002 [0x00104054] ENET5_CTRL : 0x00000003 [0x00104058] ENET6_CTRL : 0x00000002 [0x0010405C] ENET7_CTRL : 0x00000002 [0x00104060] ENET8_CTRL : 0x00000002 [0x0c021014] PORT0_VLAN_REG : 0x00000000 [0x0c022014] PORT1_VLAN_REG : 0x00000000 [0x0c023014] PORT2_VLAN_REG : 0x00000000 [0x0c024014] PORT3_VLAN_REG : 0x00000000 [0x0c025014] PORT4_VLAN_REG : 0x00000000 [0x0c026014] PORT5_VLAN_REG : 0x00000000 [0x0c027014] PORT6_VLAN_REG : 0x00000000 [0x0c028014] PORT7_VLAN_REG : 0x00000000 [0x0c029014] PORT8_VLAN_REG : 0x00000000 [0x01008400] CTRL_MMR_SERDES0_CLKSEL : 0x00000000 [0x01008410] CTRL_MMR_SERDES1_CLKSEL : 0x00000000 [0x01008420] CTRL_MMR_SERDES2_CLKSEL : 0x00000000 [0x01008440] CTRL_MMR_SERDES4_CLKSEL : 0x00000000 [0x05060408] SERDES0_TOP_CTRL : 0x08000000 [0x0506040C] SERDES0_RST : 0x00000000 [0x05060480] SERDES0_CONFIG_LANECTL0T : 0x00000000 [0x0506C01C] SERDES0_PHY_PLL_CFG : 0x00000001 [0x05060340] SERDES0_CMN_PDIAG_PLL0_CTRL_M0 : 0x00000000 [0x050641C8] SERDES0_XCVR_DIAG_XDP_PWRI_STAT0 : 0x00000000 [0x050645C8] SERDES0_XCVR_DIAG_XDP_PWRI_STAT1 : 0x00000000 [0x050649C8] SERDES0_XCVR_DIAG_XDP_PWRI_STAT2 : 0x00000000 [0x05064DC8] SERDES0_XCVR_DIAG_XDP_PWRI_STAT3 : 0x00000000 [0x050641CC] SERDES0_XCVR_DIAG_HSCLK_SEL0 : 0x00000000 [0x050645CC] SERDES0_XCVR_DIAG_HSCLK_SEL1 : 0x00000000 [0x050649CC] SERDES0_XCVR_DIAG_HSCLK_SEL2 : 0x00000000 [0x05064DCC] SERDES0_XCVR_DIAG_HSCLK_SEL3 : 0x00000000 [0x05060104] SERDES0_CMN_PLL0_VCOCAL_TCTRL : 0x00000000 [0x05060184] SERDES0_CMN_PLL1_VCOCAL_TCTRL : 0x00000000 [0x05064200] SERDES0_TX_PSC_A1__TX_PSC_A0_0 : 0x00000000 [0x05064600] SERDES0_TX_PSC_A1__TX_PSC_A0_1 : 0x00000000 [0x05064a00] SERDES0_TX_PSC_A1__TX_PSC_A0_2 : 0x00000000 [0x05064e00] SERDES0_TX_PSC_A1__TX_PSC_A0_3 : 0x00000000 [0x05064204] SERDES0_TX_PSC_A3__TX_PSC_A2_0 : 0x00000000 [0x05064604] SERDES0_TX_PSC_A3__TX_PSC_A2_1 : 0x00000000 [0x05064a04] SERDES0_TX_PSC_A3__TX_PSC_A2_2 : 0x00000000 [0x05064e04] SERDES0_TX_PSC_A3__TX_PSC_A2_3 : 0x00000000 [0x05068000] SERDES0_RX_PSC_A1__RX_PSC_A0_0 : 0x00000000 [0x05068400] SERDES0_RX_PSC_A1__RX_PSC_A0_1 : 0x00000000 [0x05068800] SERDES0_RX_PSC_A1__RX_PSC_A0_2 : 0x00000000 [0x05068B00] SERDES0_RX_PSC_A1__RX_PSC_A0_3 : 0x00000000 [0x05068004] SERDES0_RX_PSC_A3__RX_PSC_A2_0 : 0x00000000 [0x05068404] SERDES0_RX_PSC_A3__RX_PSC_A2_1 : 0x00000000 [0x05068804] SERDES0_RX_PSC_A3__RX_PSC_A2_2 : 0x00000000 [0x05068B04] SERDES0_RX_PSC_A3__RX_PSC_A2_3 : 0x00000000 [0x05064098] SERDES0_TX_TXCC_CPOST_MULT_00_0 : 0x00000000 [0x05064498] SERDES0_TX_TXCC_CPOST_MULT_00_1 : 0x00000000 [0x05064898] SERDES0_TX_TXCC_CPOST_MULT_00_2 : 0x00000000 [0x05064B98] SERDES0_TX_TXCC_CPOST_MULT_00_3 : 0x00000000 [0x0506418c] SERDES0_DRV_DIAG_TX_DRV_0 : 0x00000000 [0x0506458c] SERDES0_DRV_DIAG_TX_DRV_1 : 0x00000000 [0x0506498c] SERDES0_DRV_DIAG_TX_DRV_2 : 0x00000000 [0x05064D8c] SERDES0_DRV_DIAG_TX_DRV_3 : 0x00000000 [0x05068210] SERDES0_RX_REE_GCSM1_CTRL_0 : 0x00000000 [0x05068610] SERDES0_RX_REE_GCSM1_CTRL_1 : 0x00000000 [0x05068a10] SERDES0_RX_REE_GCSM1_CTRL_2 : 0x00000000 [0x05068e10] SERDES0_RX_REE_GCSM1_CTRL_3 : 0x00000000 [0x05068214] SERDES0_RX_REE_GCSM1_EQENM_PH2_0 : 0x00000000 [0x05068614] SERDES0_RX_REE_GCSM1_EQENM_PH2_1 : 0x00000000 [0x05068a14] SERDES0_RX_REE_GCSM1_EQENM_PH2_2 : 0x00000000 [0x05068e14] SERDES0_RX_REE_GCSM1_EQENM_PH2_3 : 0x00000000 [0x050683c0] SERDES0_RX_DIAG_DFE_CTRL_0 : 0x4DDD0004 [0x050687c0] SERDES0_RX_DIAG_DFE_CTRL_1 : 0x4DDD0004 [0x05068bc0] SERDES0_RX_DIAG_DFE_CTRL_2 : 0x4DDD0004 [0x05068fc0] SERDES0_RX_DIAG_DFE_CTRL_3 : 0x4DDD0004 [0x050682e0] SERDES0_RX_REE_ADDR_CFG_0 : 0x00000000 [0x050686e0] SERDES0_RX_REE_ADDR_CFG_1 : 0x00000000 [0x05068ae0] SERDES0_RX_REE_ADDR_CFG_2 : 0x00000000 [0x05068ee0] SERDES0_RX_REE_ADDR_CFG_3 : 0x00000000 [0x050682e4] SERDES0_RX_REE_TAP2TON_CLIP_0 : 0x00000000 [0x050686e4] SERDES0_RX_REE_TAP2TON_CLIP_1 : 0x00000000 [0x05068ae4] SERDES0_RX_REE_TAP2TON_CLIP_2 : 0x00000000 [0x05068ee4] SERDES0_RX_REE_TAP2TON_CLIP_3 : 0x00000000 [0x050683c8] SERDES0_RX_DIAG_REE_DAC_CTRL_0 : 0x0B980004 [0x050687c8] SERDES0_RX_DIAG_REE_DAC_CTRL_1 : 0x0B980004 [0x05068bc8] SERDES0_RX_DIAG_REE_DAC_CTRL_2 : 0x0B980004 [0x05068fc8] SERDES0_RX_DIAG_REE_DAC_CTRL_3 : 0x0B980004 [0x050683c4] SERDES0_RX_DIAG_DFE_AMP_TUNE_2_0 : 0x00000C01 [0x050687c4] SERDES0_RX_DIAG_DFE_AMP_TUNE_2_1 : 0x00000C01 [0x05068bc4] SERDES0_RX_DIAG_DFE_AMP_TUNE_2_2 : 0x00000C01 [0x05068fc4] SERDES0_RX_DIAG_DFE_AMP_TUNE_2_3 : 0x00000C01 [0x050683e8] SERDES0_RX_DIAG_PI_RATE_0 : 0x00000311 [0x050687e8] SERDES0_RX_DIAG_PI_RATE_1 : 0x00000311 [0x05068be8] SERDES0_RX_DIAG_PI_RATE_2 : 0x00000311 [0x05068fe8] SERDES0_RX_DIAG_PI_RATE_3 : 0x00000311 [0x050683fc] SERDES0_RX_DIAG_DCYA_0 : 0x00000000 [0x050687fc] SERDES0_RX_DIAG_DCYA_1 : 0x00000000 [0x05068bfc] SERDES0_RX_DIAG_DCYA_2 : 0x00000000 [0x05068ffc] SERDES0_RX_DIAG_DCYA_3 : 0x00000000 [0x05068100] SERDES0_RX_CDRLF_CNFG_0 : 0x00000000 [0x05068500] SERDES0_RX_CDRLF_CNFG_1 : 0x00000000 [0x05068900] SERDES0_RX_CDRLF_CNFG_2 : 0x00000000 [0x05068d00] SERDES0_RX_CDRLF_CNFG_3 : 0x00000000 [0x050603c0] SERDES0_CMN_DIAG_BANDGAP_OVRD : 0x36000005 [0x05060204] SERDES0_CMN_TXPUCAL_START : 0x00000000 [0x05060214] SERDES0_CMN_TXPDCAL_START : 0x00000000 [0x05070408] SERDES1_TOP_CTRL : 0x18100000 [0x0507040C] SERDES1_RST : 0x22800000 [0x05070480] SERDES1_CONFIG_LANECTL0T : 0x30000000 [0x0507C01C] SERDES1_PHY_PLL_CFG : 0x00000001 [0x05070340] SERDES1_CMN_PDIAG_PLL0_CTRL_M0 : 0x06011012 [0x050741C8] SERDES1_XCVR_DIAG_XDP_PWRI_STAT0 : 0x00120024 [0x050745C8] SERDES1_XCVR_DIAG_XDP_PWRI_STAT1 : 0x00120024 [0x050749C8] SERDES1_XCVR_DIAG_XDP_PWRI_STAT2 : 0x00120024 [0x05074DC8] SERDES1_XCVR_DIAG_XDP_PWRI_STAT3 : 0x00120024 [0x050741CC] SERDES1_XCVR_DIAG_HSCLK_SEL0 : 0x00010000 [0x050745CC] SERDES1_XCVR_DIAG_HSCLK_SEL1 : 0x00010000 [0x050749CC] SERDES1_XCVR_DIAG_HSCLK_SEL2 : 0x00010000 [0x05074DCC] SERDES1_XCVR_DIAG_HSCLK_SEL3 : 0x00010000 [0x05070104] SERDES1_CMN_PLL0_VCOCAL_TCTRL : 0x00000004 [0x05070184] SERDES1_CMN_PLL1_VCOCAL_TCTRL : 0x00000004 [0x05074200] SERDES1_TX_PSC_A1__TX_PSC_A0_0 : 0x04AF00FF [0x05074600] SERDES1_TX_PSC_A1__TX_PSC_A0_1 : 0x04AF00FF [0x05074a00] SERDES1_TX_PSC_A1__TX_PSC_A0_2 : 0x04AF00FF [0x05074e00] SERDES1_TX_PSC_A1__TX_PSC_A0_3 : 0x04AF00FF [0x05074204] SERDES1_TX_PSC_A3__TX_PSC_A2_0 : 0x04AE04AE [0x05074604] SERDES1_TX_PSC_A3__TX_PSC_A2_1 : 0x04AE04AE [0x05074a04] SERDES1_TX_PSC_A3__TX_PSC_A2_2 : 0x04AE04AE [0x05074e04] SERDES1_TX_PSC_A3__TX_PSC_A2_3 : 0x04AE04AE [0x05078000] SERDES1_RX_PSC_A1__RX_PSC_A0_0 : 0x091D091D [0x05078400] SERDES1_RX_PSC_A1__RX_PSC_A0_1 : 0x091D091D [0x05078800] SERDES1_RX_PSC_A1__RX_PSC_A0_2 : 0x091D091D [0x05078B00] SERDES1_RX_PSC_A1__RX_PSC_A0_3 : 0x00000000 [0x05078004] SERDES1_RX_PSC_A3__RX_PSC_A2_0 : 0x00000900 [0x05078404] SERDES1_RX_PSC_A3__RX_PSC_A2_1 : 0x00000900 [0x05078804] SERDES1_RX_PSC_A3__RX_PSC_A2_2 : 0x00000900 [0x05078B04] SERDES1_RX_PSC_A3__RX_PSC_A2_3 : 0x00000000 [0x05074098] SERDES1_TX_TXCC_CPOST_MULT_00_0 : 0x0011001C [0x05074498] SERDES1_TX_TXCC_CPOST_MULT_00_1 : 0x0011001C [0x05074898] SERDES1_TX_TXCC_CPOST_MULT_00_2 : 0x0011001C [0x05074B98] SERDES1_TX_TXCC_CPOST_MULT_00_3 : 0x00000000 [0x0507418c] SERDES1_DRV_DIAG_TX_DRV_0 : 0x000000A3 [0x0507458c] SERDES1_DRV_DIAG_TX_DRV_1 : 0x000000A3 [0x0507498c] SERDES1_DRV_DIAG_TX_DRV_2 : 0x000000A3 [0x05074D8c] SERDES1_DRV_DIAG_TX_DRV_3 : 0x000000A3 [0x05078210] SERDES1_RX_REE_GCSM1_CTRL_0 : 0x03E70009 [0x05078610] SERDES1_RX_REE_GCSM1_CTRL_1 : 0x03E70009 [0x05078a10] SERDES1_RX_REE_GCSM1_CTRL_2 : 0x03E70009 [0x05078e10] SERDES1_RX_REE_GCSM1_CTRL_3 : 0x03E70009 [0x05078214] SERDES1_RX_REE_GCSM1_EQENM_PH2_0 : 0x000001E7 [0x05078614] SERDES1_RX_REE_GCSM1_EQENM_PH2_1 : 0x000001E7 [0x05078a14] SERDES1_RX_REE_GCSM1_EQENM_PH2_2 : 0x000001E7 [0x05078e14] SERDES1_RX_REE_GCSM1_EQENM_PH2_3 : 0x000001E7 [0x050783c0] SERDES1_RX_DIAG_DFE_CTRL_0 : 0x4DDD0004 [0x050787c0] SERDES1_RX_DIAG_DFE_CTRL_1 : 0x4DDD0004 [0x05078bc0] SERDES1_RX_DIAG_DFE_CTRL_2 : 0x4DDD0004 [0x05078fc0] SERDES1_RX_DIAG_DFE_CTRL_3 : 0x4DDD0004 [0x050782e0] SERDES1_RX_REE_ADDR_CFG_0 : 0x05190101 [0x050786e0] SERDES1_RX_REE_ADDR_CFG_1 : 0x05190101 [0x05078ae0] SERDES1_RX_REE_ADDR_CFG_2 : 0x05190101 [0x05078ee0] SERDES1_RX_REE_ADDR_CFG_3 : 0x05190101 [0x050782e4] SERDES1_RX_REE_TAP2TON_CLIP_0 : 0x40000519 [0x050786e4] SERDES1_RX_REE_TAP2TON_CLIP_1 : 0x40000519 [0x05078ae4] SERDES1_RX_REE_TAP2TON_CLIP_2 : 0x40000519 [0x05078ee4] SERDES1_RX_REE_TAP2TON_CLIP_3 : 0x40000519 [0x050783c8] SERDES1_RX_DIAG_REE_DAC_CTRL_0 : 0x0B980004 [0x050787c8] SERDES1_RX_DIAG_REE_DAC_CTRL_1 : 0x0B980004 [0x05078bc8] SERDES1_RX_DIAG_REE_DAC_CTRL_2 : 0x0B980004 [0x05078fc8] SERDES1_RX_DIAG_REE_DAC_CTRL_3 : 0x0B980004 [0x050783c4] SERDES1_RX_DIAG_DFE_AMP_TUNE_2_0 : 0x00000C01 [0x050787c4] SERDES1_RX_DIAG_DFE_AMP_TUNE_2_1 : 0x00000C01 [0x05078bc4] SERDES1_RX_DIAG_DFE_AMP_TUNE_2_2 : 0x00000C01 [0x05078fc4] SERDES1_RX_DIAG_DFE_AMP_TUNE_2_3 : 0x00000C01 [0x050783e8] SERDES1_RX_DIAG_PI_RATE_0 : 0x00000311 [0x050787e8] SERDES1_RX_DIAG_PI_RATE_1 : 0x00000311 [0x05078be8] SERDES1_RX_DIAG_PI_RATE_2 : 0x00000311 [0x05078fe8] SERDES1_RX_DIAG_PI_RATE_3 : 0x00000311 [0x050783fc] SERDES1_RX_DIAG_DCYA_0 : 0x00000000 [0x050787fc] SERDES1_RX_DIAG_DCYA_1 : 0x00000000 [0x05078bfc] SERDES1_RX_DIAG_DCYA_2 : 0x00000000 [0x05078ffc] SERDES1_RX_DIAG_DCYA_3 : 0x00000000 [0x05078100] SERDES1_RX_CDRLF_CNFG_0 : 0x0A33018C [0x05078500] SERDES1_RX_CDRLF_CNFG_1 : 0x0A33018C [0x05078900] SERDES1_RX_CDRLF_CNFG_2 : 0x0A33018C [0x05078d00] SERDES1_RX_CDRLF_CNFG_3 : 0x0A33018C [0x050703c0] SERDES1_CMN_DIAG_BANDGAP_OVRD : 0x36000005 [0x05070204] SERDES1_CMN_TXPUCAL_START : 0x0000002D [0x05070214] SERDES1_CMN_TXPDCAL_START : 0x0000802D [0x05020408] SERDES2_TOP_CTRL : 0x18100000 [0x0502040C] SERDES2_RST : 0x22800000 [0x05020480] SERDES2_CONFIG_LANECTL0T : 0x30000000 [0x0502C01C] SERDES2_PHY_PLL_CFG : 0x00000001 [0x05020340] SERDES2_CMN_PDIAG_PLL0_CTRL_M0 : 0x06011012 [0x050241C8] SERDES2_XCVR_DIAG_XDP_PWRI_STAT0 : 0x00120024 [0x050245C8] SERDES2_XCVR_DIAG_XDP_PWRI_STAT1 : 0x00120024 [0x050249C8] SERDES2_XCVR_DIAG_XDP_PWRI_STAT2 : 0x00120024 [0x05024DC8] SERDES2_XCVR_DIAG_XDP_PWRI_STAT3 : 0x00120024 [0x050241CC] SERDES2_XCVR_DIAG_HSCLK_SEL0 : 0x00010000 [0x050245CC] SERDES2_XCVR_DIAG_HSCLK_SEL1 : 0x00010000 [0x050249CC] SERDES2_XCVR_DIAG_HSCLK_SEL2 : 0x00010000 [0x05024DCC] SERDES2_XCVR_DIAG_HSCLK_SEL3 : 0x00010000 [0x05020104] SERDES2_CMN_PLL0_VCOCAL_TCTRL : 0x00000004 [0x05020184] SERDES2_CMN_PLL1_VCOCAL_TCTRL : 0x00000004 [0x05024200] SERDES2_TX_PSC_A1__TX_PSC_A0_0 : 0x04AF00FF [0x05024600] SERDES2_TX_PSC_A1__TX_PSC_A0_1 : 0x04AF00FF [0x05024a00] SERDES2_TX_PSC_A1__TX_PSC_A0_2 : 0x04AF00FF [0x05024e00] SERDES2_TX_PSC_A1__TX_PSC_A0_3 : 0x04AF00FF [0x05024204] SERDES2_TX_PSC_A3__TX_PSC_A2_0 : 0x04AE04AE [0x05024604] SERDES2_TX_PSC_A3__TX_PSC_A2_1 : 0x04AE04AE [0x05024a04] SERDES2_TX_PSC_A3__TX_PSC_A2_2 : 0x04AE04AE [0x05024e04] SERDES2_TX_PSC_A3__TX_PSC_A2_3 : 0x04AE04AE [0x05028000] SERDES2_RX_PSC_A1__RX_PSC_A0_0 : 0x091D091D [0x05028400] SERDES2_RX_PSC_A1__RX_PSC_A0_1 : 0x091D091D [0x05028800] SERDES2_RX_PSC_A1__RX_PSC_A0_2 : 0x091D091D [0x05028B00] SERDES2_RX_PSC_A1__RX_PSC_A0_3 : 0x00000000 [0x05028004] SERDES2_RX_PSC_A3__RX_PSC_A2_0 : 0x00000900 [0x05028404] SERDES2_RX_PSC_A3__RX_PSC_A2_1 : 0x00000900 [0x05028804] SERDES2_RX_PSC_A3__RX_PSC_A2_2 : 0x00000900 [0x05028B04] SERDES2_RX_PSC_A3__RX_PSC_A2_3 : 0x00000000 [0x05024098] SERDES2_TX_TXCC_CPOST_MULT_00_0 : 0x0011001C [0x05024498] SERDES2_TX_TXCC_CPOST_MULT_00_1 : 0x0011001C [0x05024898] SERDES2_TX_TXCC_CPOST_MULT_00_2 : 0x0011001C [0x05024B98] SERDES2_TX_TXCC_CPOST_MULT_00_3 : 0x00000000 [0x0502418c] SERDES2_DRV_DIAG_TX_DRV_0 : 0x000000A3 [0x0502458c] SERDES2_DRV_DIAG_TX_DRV_1 : 0x000000A3 [0x0502498c] SERDES2_DRV_DIAG_TX_DRV_2 : 0x000000A3 [0x05024D8c] SERDES2_DRV_DIAG_TX_DRV_3 : 0x000000A3 [0x05028210] SERDES2_RX_REE_GCSM1_CTRL_0 : 0x03E70009 [0x05028610] SERDES2_RX_REE_GCSM1_CTRL_1 : 0x03E70009 [0x05028a10] SERDES2_RX_REE_GCSM1_CTRL_2 : 0x03E70009 [0x05028e10] SERDES2_RX_REE_GCSM1_CTRL_3 : 0x03E70009 [0x05028214] SERDES2_RX_REE_GCSM1_EQENM_PH2_0 : 0x000001E7 [0x05028614] SERDES2_RX_REE_GCSM1_EQENM_PH2_1 : 0x000001E7 [0x05028a14] SERDES2_RX_REE_GCSM1_EQENM_PH2_2 : 0x000001E7 [0x05028e14] SERDES2_RX_REE_GCSM1_EQENM_PH2_3 : 0x000001E7 [0x050283c0] SERDES2_RX_DIAG_DFE_CTRL_0 : 0x4DDD0004 [0x050287c0] SERDES2_RX_DIAG_DFE_CTRL_1 : 0x4DDD0004 [0x05028bc0] SERDES2_RX_DIAG_DFE_CTRL_2 : 0x4DDD0004 [0x05028fc0] SERDES2_RX_DIAG_DFE_CTRL_3 : 0x4DDD0004 [0x050282e0] SERDES2_RX_REE_ADDR_CFG_0 : 0x05190101 [0x050286e0] SERDES2_RX_REE_ADDR_CFG_1 : 0x05190101 [0x05028ae0] SERDES2_RX_REE_ADDR_CFG_2 : 0x05190101 [0x05028ee0] SERDES2_RX_REE_ADDR_CFG_3 : 0x05190101 [0x050282e4] SERDES2_RX_REE_TAP2TON_CLIP_0 : 0x40000519 [0x050286e4] SERDES2_RX_REE_TAP2TON_CLIP_1 : 0x40000519 [0x05028ae4] SERDES2_RX_REE_TAP2TON_CLIP_2 : 0x40000519 [0x05028ee4] SERDES2_RX_REE_TAP2TON_CLIP_3 : 0x40000519 [0x050283c8] SERDES2_RX_DIAG_REE_DAC_CTRL_0 : 0x0B980004 [0x050287c8] SERDES2_RX_DIAG_REE_DAC_CTRL_1 : 0x0B980004 [0x05028bc8] SERDES2_RX_DIAG_REE_DAC_CTRL_2 : 0x0B980004 [0x05028fc8] SERDES2_RX_DIAG_REE_DAC_CTRL_3 : 0x0B980004 [0x050283c4] SERDES2_RX_DIAG_DFE_AMP_TUNE_2_0 : 0x00000C01 [0x050287c4] SERDES2_RX_DIAG_DFE_AMP_TUNE_2_1 : 0x00000C01 [0x05028bc4] SERDES2_RX_DIAG_DFE_AMP_TUNE_2_2 : 0x00000C01 [0x05028fc4] SERDES2_RX_DIAG_DFE_AMP_TUNE_2_3 : 0x00000C01 [0x050283e8] SERDES2_RX_DIAG_PI_RATE_0 : 0x00000311 [0x050287e8] SERDES2_RX_DIAG_PI_RATE_1 : 0x00000311 [0x05028be8] SERDES2_RX_DIAG_PI_RATE_2 : 0x00000311 [0x05028fe8] SERDES2_RX_DIAG_PI_RATE_3 : 0x00000311 [0x050283fc] SERDES2_RX_DIAG_DCYA_0 : 0x00000000 [0x050287fc] SERDES2_RX_DIAG_DCYA_1 : 0x00000000 [0x05028bfc] SERDES2_RX_DIAG_DCYA_2 : 0x00000000 [0x05028ffc] SERDES2_RX_DIAG_DCYA_3 : 0x00000000 [0x05028100] SERDES2_RX_CDRLF_CNFG_0 : 0x0A33018C [0x05028500] SERDES2_RX_CDRLF_CNFG_1 : 0x0A33018C [0x05028900] SERDES2_RX_CDRLF_CNFG_2 : 0x0A33018C [0x05028d00] SERDES2_RX_CDRLF_CNFG_3 : 0x0A33018C [0x050203c0] SERDES2_CMN_DIAG_BANDGAP_OVRD : 0x36000005 [0x05020204] SERDES2_CMN_TXPUCAL_START : 0x0000002D [0x05020214] SERDES2_CMN_TXPDCAL_START : 0x0000802D [0x05050408] SERDES4_TOP_CTRL : 0x30000000 [0x0505040C] SERDES4_RST : 0x2A800000 [0x05050480] SERDES4_CONFIG_LANECTL0T : 0x70000000 [0x0505C01C] SERDES4_PHY_PLL_CFG : 0x00000000 [0x05050340] SERDES4_CMN_PDIAG_PLL0_CTRL_M0 : 0x07011012 [0x050541C8] SERDES4_XCVR_DIAG_XDP_PWRI_STAT0 : 0x00010024 [0x050545C8] SERDES4_XCVR_DIAG_XDP_PWRI_STAT1 : 0x00010024 [0x050549C8] SERDES4_XCVR_DIAG_XDP_PWRI_STAT2 : 0x00010024 [0x05054DC8] SERDES4_XCVR_DIAG_XDP_PWRI_STAT3 : 0x00010024 [0x050541CC] SERDES4_XCVR_DIAG_HSCLK_SEL0 : 0x00010000 [0x050545CC] SERDES4_XCVR_DIAG_HSCLK_SEL1 : 0x00010000 [0x050549CC] SERDES4_XCVR_DIAG_HSCLK_SEL2 : 0x00010000 [0x05054DCC] SERDES4_XCVR_DIAG_HSCLK_SEL3 : 0x00010000 [0x05050104] SERDES4_CMN_PLL0_VCOCAL_TCTRL : 0x00000003 [0x05050184] SERDES4_CMN_PLL1_VCOCAL_TCTRL : 0x00000003 [0x05054200] SERDES4_TX_PSC_A1__TX_PSC_A0_0 : 0x04AF00FB [0x05054600] SERDES4_TX_PSC_A1__TX_PSC_A0_1 : 0x04AF00FB [0x05054a00] SERDES4_TX_PSC_A1__TX_PSC_A0_2 : 0x04AF00FB [0x05054e00] SERDES4_TX_PSC_A1__TX_PSC_A0_3 : 0x04AF00FB [0x05054204] SERDES4_TX_PSC_A3__TX_PSC_A2_0 : 0x04AA04AA [0x05054604] SERDES4_TX_PSC_A3__TX_PSC_A2_1 : 0x04AA04AA [0x05054a04] SERDES4_TX_PSC_A3__TX_PSC_A2_2 : 0x04AA04AA [0x05054e04] SERDES4_TX_PSC_A3__TX_PSC_A2_3 : 0x04AA04AA [0x05058000] SERDES4_RX_PSC_A1__RX_PSC_A0_0 : 0x091D0000 [0x05058400] SERDES4_RX_PSC_A1__RX_PSC_A0_1 : 0x091D0000 [0x05058800] SERDES4_RX_PSC_A1__RX_PSC_A0_2 : 0x091D0000 [0x05058B00] SERDES4_RX_PSC_A1__RX_PSC_A0_3 : 0x00000000 [0x05058004] SERDES4_RX_PSC_A3__RX_PSC_A2_0 : 0x00000000 [0x05058404] SERDES4_RX_PSC_A3__RX_PSC_A2_1 : 0x00000000 [0x05058804] SERDES4_RX_PSC_A3__RX_PSC_A2_2 : 0x00000000 [0x05058B04] SERDES4_RX_PSC_A3__RX_PSC_A2_3 : 0x00000000 [0x05054098] SERDES4_TX_TXCC_CPOST_MULT_00_0 : 0x0011001C [0x05054498] SERDES4_TX_TXCC_CPOST_MULT_00_1 : 0x0011001C [0x05054898] SERDES4_TX_TXCC_CPOST_MULT_00_2 : 0x0011001C [0x05054B98] SERDES4_TX_TXCC_CPOST_MULT_00_3 : 0x00000000 [0x0505418c] SERDES4_DRV_DIAG_TX_DRV_0 : 0x000000A3 [0x0505458c] SERDES4_DRV_DIAG_TX_DRV_1 : 0x000000A3 [0x0505498c] SERDES4_DRV_DIAG_TX_DRV_2 : 0x000000A3 [0x05054D8c] SERDES4_DRV_DIAG_TX_DRV_3 : 0x000000A3 [0x05058210] SERDES4_RX_REE_GCSM1_CTRL_0 : 0x03E70000 [0x05058610] SERDES4_RX_REE_GCSM1_CTRL_1 : 0x03E70000 [0x05058a10] SERDES4_RX_REE_GCSM1_CTRL_2 : 0x03E70000 [0x05058e10] SERDES4_RX_REE_GCSM1_CTRL_3 : 0x03E70000 [0x05058214] SERDES4_RX_REE_GCSM1_EQENM_PH2_0 : 0x000001E7 [0x05058614] SERDES4_RX_REE_GCSM1_EQENM_PH2_1 : 0x000001E7 [0x05058a14] SERDES4_RX_REE_GCSM1_EQENM_PH2_2 : 0x000001E7 [0x05058e14] SERDES4_RX_REE_GCSM1_EQENM_PH2_3 : 0x000001E7 [0x050583c0] SERDES4_RX_DIAG_DFE_CTRL_0 : 0x4DDD0004 [0x050587c0] SERDES4_RX_DIAG_DFE_CTRL_1 : 0x4DDD0004 [0x05058bc0] SERDES4_RX_DIAG_DFE_CTRL_2 : 0x4DDD0004 [0x05058fc0] SERDES4_RX_DIAG_DFE_CTRL_3 : 0x4DDD0004 [0x050582e0] SERDES4_RX_REE_ADDR_CFG_0 : 0x05190101 [0x050586e0] SERDES4_RX_REE_ADDR_CFG_1 : 0x05190101 [0x05058ae0] SERDES4_RX_REE_ADDR_CFG_2 : 0x05190101 [0x05058ee0] SERDES4_RX_REE_ADDR_CFG_3 : 0x05190101 [0x050582e4] SERDES4_RX_REE_TAP2TON_CLIP_0 : 0x40000519 [0x050586e4] SERDES4_RX_REE_TAP2TON_CLIP_1 : 0x40000519 [0x05058ae4] SERDES4_RX_REE_TAP2TON_CLIP_2 : 0x40000519 [0x05058ee4] SERDES4_RX_REE_TAP2TON_CLIP_3 : 0x40000519 [0x050583c8] SERDES4_RX_DIAG_REE_DAC_CTRL_0 : 0x0B980004 [0x050587c8] SERDES4_RX_DIAG_REE_DAC_CTRL_1 : 0x0B980004 [0x05058bc8] SERDES4_RX_DIAG_REE_DAC_CTRL_2 : 0x0B980004 [0x05058fc8] SERDES4_RX_DIAG_REE_DAC_CTRL_3 : 0x0B980004 [0x050583c4] SERDES4_RX_DIAG_DFE_AMP_TUNE_2_0 : 0x00000C01 [0x050587c4] SERDES4_RX_DIAG_DFE_AMP_TUNE_2_1 : 0x00000C01 [0x05058bc4] SERDES4_RX_DIAG_DFE_AMP_TUNE_2_2 : 0x00000C01 [0x05058fc4] SERDES4_RX_DIAG_DFE_AMP_TUNE_2_3 : 0x00000C01 [0x050583e8] SERDES4_RX_DIAG_PI_RATE_0 : 0x00000311 [0x050587e8] SERDES4_RX_DIAG_PI_RATE_1 : 0x00000311 [0x05058be8] SERDES4_RX_DIAG_PI_RATE_2 : 0x00000311 [0x05058fe8] SERDES4_RX_DIAG_PI_RATE_3 : 0x00000311 [0x050583fc] SERDES4_RX_DIAG_DCYA_0 : 0x00000000 [0x050587fc] SERDES4_RX_DIAG_DCYA_1 : 0x00000000 [0x05058bfc] SERDES4_RX_DIAG_DCYA_2 : 0x00000000 [0x05058ffc] SERDES4_RX_DIAG_DCYA_3 : 0x00000000 [0x05058100] SERDES4_RX_CDRLF_CNFG_0 : 0x0A33018C [0x05058500] SERDES4_RX_CDRLF_CNFG_1 : 0x0A33018C [0x05058900] SERDES4_RX_CDRLF_CNFG_2 : 0x0A33018C [0x05058d00] SERDES4_RX_CDRLF_CNFG_3 : 0x0A33018C [0x050503c0] SERDES4_CMN_DIAG_BANDGAP_OVRD : 0x36000005 [0x05050204] SERDES4_CMN_TXPUCAL_START : 0x0000002D [0x05050214] SERDES4_CMN_TXPDCAL_START : 0x0000802D
- boot log
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 6.1.46-g5892b80d6b (root@5c99d703c1e0) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Sun Jul 21 14:10:05 UTC 2024 [ 0.000000] Machine model: Texas Instruments J784S4 EVM [ 0.000000] efi: UEFI not found. [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node freetech_shared-memories_mcu@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2c00000, size 4 MiB [ 0.000000] OF: reserved mem: initialized node freetech_shared-memories_product@a2c00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 16 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo-mcu@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 47 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 23 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8900000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8900000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@aa800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa900000, size 23 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@aa900000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 48 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@b6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@b6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@b8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b8100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@b8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ba000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@ba000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ba800000, size 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@ba800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000bc000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@bc000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000bc100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@bc100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000be000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@be000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000be100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@be100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 800 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000008fa000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo-main@8fa000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x000000093c000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node freetech_shared-memories_mem@93c000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000940000000, size 352 MiB [ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@940000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000009ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000bfffffff] [ 0.000000] node 0: [mem 0x00000000c0000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008b1ffffff] [ 0.000000] node 0: [mem 0x00000008b2000000-0x00000008f9ffffff] [ 0.000000] node 0: [mem 0x00000008fa000000-0x00000008ffffffff] [ 0.000000] node 0: [mem 0x0000000900000000-0x000000093bffffff] [ 0.000000] node 0: [mem 0x000000093c000000-0x000000093fffffff] [ 0.000000] node 0: [mem 0x0000000940000000-0x00000009ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Spectre-v3a [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384 [ 0.000000] Kernel command line: root=/dev/mmcblk1p2 loglevel=7 rw rootfstype=ext4 rootwait nokaslr gpt [ 0.000000] Unknown kernel command line parameters "nokaslr", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 8. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 5269588K/8388608K available (11712K kernel code, 1256K rwdata, 3796K rodata, 1984K init, 427K bss, 2758572K reserved, 360448K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: [Firmware Bug]: GICR region 0x0000000001900000 has overlapping address [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8b2800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008b2050000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008b2060000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.000242] Console: colour dummy device 80x25 [ 0.000792] printk: console [tty0] enabled [ 0.000825] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.000836] pid_max: default: 32768 minimum: 301 [ 0.000864] LSM: Security Framework initializing [ 0.000934] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.000961] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.002022] cblist_init_generic: Setting adjustable number of callback queues. [ 0.002039] cblist_init_generic: Setting shift to 3 and lim to 1. [ 0.002091] cblist_init_generic: Setting adjustable number of callback queues. [ 0.002098] cblist_init_generic: Setting shift to 3 and lim to 1. [ 0.002194] rcu: Hierarchical SRCU implementation. [ 0.002201] rcu: Max phase no-delay instances is 1000. [ 0.002377] Platform MSI: msi-controller@1820000 domain created [ 0.002550] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.002722] EFI services will not be available. [ 0.002986] smp: Bringing up secondary CPUs ... [ 0.012736] Detected PIPT I-cache on CPU1 [ 0.012800] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.012814] GICv3: CPU1: using allocated LPI pending table @0x00000008b2070000 [ 0.012848] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.022568] Detected PIPT I-cache on CPU2 [ 0.022619] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000 [ 0.022633] GICv3: CPU2: using allocated LPI pending table @0x00000008b2080000 [ 0.022659] CPU2: Booted secondary processor 0x0000000002 [0x411fd080] [ 0.032338] Detected PIPT I-cache on CPU3 [ 0.032388] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000 [ 0.032401] GICv3: CPU3: using allocated LPI pending table @0x00000008b2090000 [ 0.032426] CPU3: Booted secondary processor 0x0000000003 [0x411fd080] [ 0.042415] Detected PIPT I-cache on CPU4 [ 0.042499] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000 [ 0.042513] GICv3: CPU4: using allocated LPI pending table @0x00000008b20a0000 [ 0.042548] CPU4: Booted secondary processor 0x0000000100 [0x411fd080] [ 0.052188] Detected PIPT I-cache on CPU5 [ 0.052248] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000 [ 0.052262] GICv3: CPU5: using allocated LPI pending table @0x00000008b20b0000 [ 0.052288] CPU5: Booted secondary processor 0x0000000101 [0x411fd080] [ 0.061990] Detected PIPT I-cache on CPU6 [ 0.062050] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000 [ 0.062064] GICv3: CPU6: using allocated LPI pending table @0x00000008b20c0000 [ 0.062090] CPU6: Booted secondary processor 0x0000000102 [0x411fd080] [ 0.071772] Detected PIPT I-cache on CPU7 [ 0.071831] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000 [ 0.071844] GICv3: CPU7: using allocated LPI pending table @0x00000008b20d0000 [ 0.071869] CPU7: Booted secondary processor 0x0000000103 [0x411fd080] [ 0.071920] smp: Brought up 1 node, 8 CPUs [ 0.072015] SMP: Total of 8 processors activated. [ 0.072021] CPU features: detected: 32-bit EL0 Support [ 0.072026] CPU features: detected: CRC32 instructions [ 0.072083] CPU: All CPU(s) started at EL2 [ 0.072088] alternatives: applying system-wide alternatives [ 0.073275] devtmpfs: initialized [ 0.080148] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.080187] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.085151] pinctrl core: initialized pinctrl subsystem [ 0.085499] DMI not present or invalid. [ 0.085883] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.086811] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.087030] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.087220] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.087299] audit: initializing netlink subsys (disabled) [ 0.087462] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1 [ 0.087686] thermal_sys: Registered thermal governor 'step_wise' [ 0.087691] thermal_sys: Registered thermal governor 'power_allocator' [ 0.087808] cpuidle: using governor menu [ 0.087925] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.088055] ASID allocator initialised with 32768 entries [ 0.096442] KASLR disabled on command line [ 0.099194] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.099211] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.099217] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.099223] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.099228] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.099234] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.099239] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.099244] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.100125] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected [ 0.101066] iommu: Default domain type: Translated [ 0.101081] iommu: DMA domain TLB invalidation policy: strict mode [ 0.101221] SCSI subsystem initialized [ 0.101482] pps_core: LinuxPPS API ver. 1 registered [ 0.101491] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.101502] PTP clock support registered [ 0.101580] EDAC MC: Ver: 3.0.0 [ 0.102115] FPGA manager framework [ 0.102603] clocksource: Switched to clocksource arch_sys_counter [ 0.102773] VFS: Disk quotas dquot_6.6.0 [ 0.102805] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.105793] Carveout Heap: Exported 960 MiB at 0x0000000900000000 [ 0.105879] NET: Registered PF_INET protocol family [ 0.106154] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.108917] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [ 0.108995] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.109014] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.109248] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.110195] TCP: Hash tables configured (established 65536 bind 65536) [ 0.110326] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.110429] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.110689] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.111015] RPC: Registered named UNIX socket transport module. [ 0.111027] RPC: Registered udp transport module. [ 0.111032] RPC: Registered tcp transport module. [ 0.111036] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.111044] NET: Registered PF_XDP protocol family [ 0.111060] PCI: CLS 0 bytes, default 64 [ 0.111779] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.112716] Initialise system trusted keyrings [ 0.112859] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 0.114990] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.115308] NFS: Registering the id_resolver key type [ 0.115330] Key type id_resolver registered [ 0.115336] Key type id_legacy registered [ 0.115368] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.115376] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.135158] Key type asymmetric registered [ 0.135171] Asymmetric key parser 'x509' registered [ 0.135215] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.135329] io scheduler mq-deadline registered [ 0.135338] io scheduler kyber registered [ 0.137646] pinctrl-single 4301c000.pinctrl: 13 pins, size 52 [ 0.137743] pinctrl-single 4301c038.pinctrl: 11 pins, size 44 [ 0.137858] pinctrl-single 4301c068.pinctrl: 72 pins, size 288 [ 0.137937] pinctrl-single 4301c190.pinctrl: 1 pins, size 4 [ 0.138071] pinctrl-single 11c000.pinctrl: 72 pins, size 288 [ 0.141688] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.147074] loop: module loaded [ 0.147883] megasas: 07.719.03.00-rc1 [ 0.149464] tun: Universal TUN/TAP device driver, 1.6 [ 0.149832] thunder_xcv, ver 1.0 [ 0.149856] thunder_bgx, ver 1.0 [ 0.149873] nicpf, ver 1.0 [ 0.149960] e1000: Intel(R) PRO/1000 Network Driver [ 0.149965] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 0.149991] e1000e: Intel(R) PRO/1000 Network Driver [ 0.149996] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 0.150014] igb: Intel(R) Gigabit Ethernet Network Driver [ 0.150021] igb: Copyright (c) 2007-2014 Intel Corporation. [ 0.150036] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.150044] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.150110] sky2: driver version 1.30 [ 0.150501] VFIO - User Level meta-driver version: 0.3 [ 0.150921] i2c_dev: i2c /dev entries driver [ 0.151517] sdhci: Secure Digital Host Controller Interface driver [ 0.151528] sdhci: Copyright(c) Pierre Ossman [ 0.151645] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.152104] ledtrig-cpu: registered to indicate activity on CPUs [ 0.152228] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.152896] optee: probing for conduit method. [ 0.152925] optee: revision 4.0 (2a5b1d12) [ 0.169377] optee: dynamic shared memory is enabled [ 0.169619] optee: initialized driver [ 0.170477] Initializing XFRM netlink socket [ 0.170512] NET: Registered PF_PACKET protocol family [ 0.170557] Key type dns_resolver registered [ 0.170827] registered taskstats version 1 [ 0.170853] Loading compiled-in X.509 certificates [ 0.178434] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.2--v09.01.02 (Kool Koala)') [ 0.529425] omap_i2c 42120000.i2c: bus 1 rev0.12 at 400 kHz [ 0.530487] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created [ 0.531347] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created [ 0.532111] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created [ 0.533815] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created [ 0.544255] ti-udma 311a0000.dma-controller: Number of rings: 48 [ 0.546577] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16) [ 0.548407] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328 [ 0.548427] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 0.548434] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 0.550646] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315 [ 0.550662] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 0.550668] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 0.551890] 2850000.serial: ttyS3 at MMIO 0x2850000 (irq = 213, base_baud = 3000000) is a 8250 [ 0.553131] 2880000.serial: ttyS0 at MMIO 0x2880000 (irq = 214, base_baud = 3000000) is a 8250 [ 2.671681] printk: console [ttyS0] enabled [ 2.714617] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 3.423776] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver TI DP83TG720CS1.1 [ 3.432475] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver TI DP83TC814CS2.0 [ 3.441159] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver TI DP83TG720CS1.1 [ 3.449953] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA03102, cpsw version 0x6BA82902 Ports: 9 quirks:00000000 [ 3.462770] am65-cpsw-nuss c000000.ethernet: initialized cpsw ale version 1.5 [ 3.469898] am65-cpsw-nuss c000000.ethernet: ALE Table size 512 [ 3.477711] am65-cpsw-nuss c000000.ethernet: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0 [ 3.497789] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0 [ 3.514504] mmc0: CQHCI version 5.10 [ 3.518345] mmc1: CQHCI version 5.10 [ 3.559081] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 3.559099] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 3.606970] mmc1: new high speed SDHC card at address 0001 [ 3.612922] mmcblk1: mmc1:0001 SD32G 29.1 GiB [ 3.619596] mmcblk1: p1 p2 [ 3.813577] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100 [ 3.821880] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100 [ 3.830181] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100 [ 3.838466] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100 [ 3.846773] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100 [ 3.855048] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100 [ 3.871536] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8) [ 3.887721] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16) [ 3.898045] mmc0: Command Queue Engine enabled [ 3.902522] mmc0: new HS200 MMC card at address 0001 [ 3.907961] mmcblk0: mmc0:0001 A8A58B 29.1 GiB [ 3.914888] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 [ 3.926890] mmcblk0boot0: mmc0:0001 A8A58B 31.9 MiB [ 3.932608] mmcblk0boot1: mmc0:0001 A8A58B 31.9 MiB [ 3.938207] mmcblk0rpmb: mmc0:0001 A8A58B 4.00 MiB, chardev (240:0) [ 3.942637] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 4.653705] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver TI DP83TG720CS1.1 [ 4.662407] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver TI DP83TC814CS2.0 [ 4.671091] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver TI DP83TG720CS1.1 [ 4.679885] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA03102, cpsw version 0x6BA82902 Ports: 9 quirks:00000000 [ 4.692708] am65-cpsw-nuss c000000.ethernet: initialized cpsw ale version 1.5 [ 4.699837] am65-cpsw-nuss c000000.ethernet: ALE Table size 512 [ 4.707718] am65-cpsw-nuss c000000.ethernet: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0 [ 4.725892] am65-cpsw-nuss c000000.ethernet: set new flow-id-base 82 [ 4.740911] debugfs: Directory 'pd:74' with parent 'pm_genpd' already present! [ 4.748176] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present! [ 4.755475] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present! [ 4.763266] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present! [ 4.770598] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present! [ 4.777919] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present! [ 5.050089] EXT4-fs (mmcblk1p2): recovery complete [ 5.055935] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none. [ 5.064499] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 5.071474] devtmpfs: mounted [ 5.075244] Freeing unused kernel memory: 1984K [ 5.079891] Run /sbin/init as init process [ 5.453765] systemd[1]: System time before build time, advancing clock. [ 5.526249] NET: Registered PF_INET6 protocol family [ 5.531995] Segment Routing with IPv6 [ 5.535689] In-situ OAM (IOAM) with IPv6 [ 5.567646] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid) [ 5.599245] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.10! [ 5.671522] systemd[1]: Hostname set to <j784s4-evm>. [ 5.930737] systemd[1]: Configuration file /etc/systemd/system/app_init.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 5.998263] systemd[1]: Queued start job for default target Multi-User System. [ 6.043211] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 6.063638] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 6.087464] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 6.111312] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 6.134797] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password …ts to Console Directory Watch. [ 6.158760] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 6.182772] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 6.198666] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 6.218645] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 6.234666] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 6.253548] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 6.274835] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 6.299024] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 6.318887] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 6.338876] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 6.354920] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 6.378935] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 6.398803] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 6.418827] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 6.458922] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 6.477145] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 6.501134] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 6.518924] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing). [ 6.534964] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 6.553475] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 6.577376] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 6.597257] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 6.617520] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 6.634819] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/). [ 6.651537] systemd[1]: Starting Journal Service... Starting Journal Service... [ 6.656773] fuse: init (API version 7.37) [ 6.668693] systemd[1]: Load Kernel Modules was skipped because all trigger condition checks failed. [ 6.680944] systemd[1]: Starting Generate network units from Kernel command line... Starting Generate network …ts from Kernel command line... [ 6.747268] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none. [0m... [ 6.777630] systemd[1]: Starting Apply Kernel Variables... Starting Apply Kernel Variables... [ 6.797684] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ 6.819174] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. [ OK ] Finished Apply Kernel Variables. [ OK ] Reached target Preparation for Network. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 7.115760] systemd-journald[207]: Received client request to flush runtime journal. Starting Create Static Device Nodes in /dev... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Preparation for Local File Systems. Mounting /media/ram... Mounting /var/volatile... [ 7.288920] audit: type=1334 audit(1651167746.832:2): prog-id=5 op=LOAD [ 7.295606] audit: type=1334 audit(1651167746.840:3): prog-id=6 op=LOAD Starting Rule-based Manage…for Device Events and Files... [ OK ] Finished Coldplug All udev Devices. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Rule-based Manager for Device Events and Files. Starting Network Configuration... [ 7.486051] random: crng init done [ OK ] Finished Create Volatile Files and [ 7.500279] mc: Linux media interface: v0.10 Directories. [ OK ] Found device /dev/ttyS0. Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ 7.621923] videodev: Linux video capture interface: v2.00 [ 7.623801] pvrsrvkm: loading out-of-tree module taints kernel. [ 7.629466] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: MCU cluster requires both R5F cores to be enabled but num_cores is set to = 0 [ OK ] Finished Record System Boot/Shutdown in UTMP. [ 7.662444] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 7.676412] PVR_K: 254: Device: 4e20000000.gpu [ 7.678356] platform 5c00000.r5f: configured R5F for IPC-only mode [ 7.687758] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 7.689676] PVR_K: 254: Read BVNC 36.53.104.796 from HW device registers [ 7.689819] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000 [ 7.691298] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 7.692533] remoteproc remoteproc1: 64800000.dsp is available [ 7.692598] remoteproc remoteproc1: attaching to 64800000.dsp [ 7.693376] remoteproc remoteproc1: unsupported resource 65538 [ 7.693489] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ 7.693502] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000 [ 7.693588] rproc-virtio rproc-virtio.5.auto: registered virtio0 (type 7) [ 7.693595] remoteproc remoteproc1: remote processor 64800000.dsp is now attached [ 7.695096] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000 [ 7.697003] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode [ 7.705624] PVR_K: 254: RGX Device registered BVNC 36.53.104.796 with 1 core in the system [ 7.716145] remoteproc remoteproc0: 5c00000.r5f is available [ 7.761683] remoteproc remoteproc2: 65800000.dsp is available [ 7.771072] remoteproc remoteproc0: attaching to 5c00000.r5f [ 7.776222] [drm] Initialized pvr 23.2.6460340 20170530 for 4e20000000.gpu on minor 0 [ 7.778301] remoteproc remoteproc2: attaching to 65800000.dsp [ 7.786172] platform 5c00000.r5f: R5F core initialized in IPC-only mode [ 7.795140] remoteproc remoteproc2: unsupported resource 65538 [ 7.799117] rproc-virtio rproc-virtio.6.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 7.805773] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode [ 7.811039] rproc-virtio rproc-virtio.6.auto: registered virtio1 (type 7) [ 7.819382] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000 [ 7.824410] remoteproc remoteproc0: remote processor 5c00000.r5f is now attached [ 7.830777] rproc-virtio rproc-virtio.7.auto: registered virtio2 (type 7) [ 7.837844] platform 5d00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 7.846674] remoteproc remoteproc2: remote processor 65800000.dsp is now attached [ 7.856239] platform 5d00000.r5f: configured R5F for IPC-only mode [ 7.871916] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000 [ 7.878088] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 7.890051] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 7.898179] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode [ 7.899595] remoteproc remoteproc3: 5d00000.r5f is available [ 7.899666] remoteproc remoteproc3: attaching to 5d00000.r5f [ 7.900097] platform 5d00000.r5f: R5F core initialized in IPC-only mode [ 7.900117] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 7.900188] rproc-virtio rproc-virtio.8.auto: registered virtio3 (type 7) [ 7.900194] remoteproc remoteproc3: remote processor 5d00000.r5f is now attached [ 7.906796] platform 5e00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 7.910122] remoteproc remoteproc4: 66800000.dsp is available [ 7.923370] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 7.924099] platform 5e00000.r5f: configured R5F for IPC-only mode [ 7.924305] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@bc000000 [ 7.924975] remoteproc remoteproc5: 5e00000.r5f is available [ 7.925028] remoteproc remoteproc5: attaching to 5e00000.r5f [ 7.925607] platform 5e00000.r5f: R5F core initialized in IPC-only mode [ 7.925622] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node vision-apps-r5f-dma-memory@bc000000 [ 7.925690] rproc-virtio rproc-virtio.9.auto: registered virtio4 (type 7) [ 7.925697] remoteproc remoteproc5: remote processor 5e00000.r5f is now attached [ 7.927037] platform 5f00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 7.929085] remoteproc remoteproc4: attaching to 66800000.dsp [ 7.929439] platform 5f00000.r5f: configured R5F for IPC-only mode [ 7.929744] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@be000000 [ 7.933720] remoteproc remoteproc6: 5f00000.r5f is available [ 7.933783] remoteproc remoteproc6: attaching to 5f00000.r5f [ 7.936891] platform 5f00000.r5f: R5F core initialized in IPC-only mode [ 7.945429] remoteproc remoteproc4: unsupported resource 65538 [ 7.949922] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node vision-apps-r5f-dma-memory@be000000 [ 7.954898] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode [ 7.961909] rproc-virtio rproc-virtio.10.auto: registered virtio5 (type 7) [ 7.971642] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000 [ 7.971787] rproc-virtio rproc-virtio.11.auto: registered virtio6 (type 7) [ 7.978552] remoteproc remoteproc6: remote processor 5f00000.r5f is now attached [ 7.998755] platform 5900000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 8.003443] remoteproc remoteproc4: remote processor 66800000.dsp is now attached [ 8.012181] platform 5900000.r5f: configured R5F for IPC-only mode [ 8.025943] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ 8.031424] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000 [ 8.031441] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8800000 [ 8.033459] remoteproc remoteproc7: 5900000.r5f is available [ 8.033538] remoteproc remoteproc7: attaching to 5900000.r5f [ 8.033995] platform 5900000.r5f: R5F core initialized in IPC-only mode [ 8.034015] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a8800000 [ 8.034188] rproc-virtio rproc-virtio.12.auto: registered virtio7 (type 7) [ 8.034196] remoteproc remoteproc7: remote processor 5900000.r5f is now attached [ 8.035095] platform 5a00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 8.037067] platform 5a00000.r5f: configured R5F for IPC-only mode [ 8.045153] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode [ 8.054034] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@aa800000 [ 8.060447] remoteproc remoteproc8: 67800000.dsp is available [ 8.069505] remoteproc remoteproc9: 5a00000.r5f is available [ 8.079506] remoteproc remoteproc8: attaching to 67800000.dsp [ 8.085221] remoteproc remoteproc9: attaching to 5a00000.r5f [ 8.091679] remoteproc remoteproc8: unsupported resource 65538 [ 8.100749] platform 5a00000.r5f: R5F core initialized in IPC-only mode [ 8.106124] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode [ 8.111728] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node vision-apps-r5f-dma-memory@aa800000 [ 8.118328] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000 [ 8.124226] rproc-virtio rproc-virtio.14.auto: registered virtio8 (type 7) [ 8.134355] rproc-virtio rproc-virtio.13.auto: registered virtio9 (type 7) [ 8.140916] remoteproc remoteproc9: remote processor 5a00000.r5f is now attached [ 8.147772] remoteproc remoteproc8: remote processor 67800000.dsp is now attached [ 8.184597] virtio_rpmsg_bus virtio0: rpmsg host is online [ 8.199148] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 8.204980] virtio_rpmsg_bus virtio1: rpmsg host is online [ 8.220369] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 8.223739] virtio_rpmsg_bus virtio2: rpmsg host is online [ 8.235052] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd [ 8.241680] virtio_rpmsg_bus virtio3: rpmsg host is online [ 8.254508] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 8.258705] virtio_rpmsg_bus virtio4: rpmsg host is online [ 8.271138] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 8.277604] virtio_rpmsg_bus virtio5: rpmsg host is online [ 8.289942] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd [ 8.290385] virtio_rpmsg_bus virtio6: rpmsg host is online [ 8.299830] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd [ 8.305148] virtio_rpmsg_bus virtio7: rpmsg host is online [ 8.317055] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd [ 8.322201] virtio_rpmsg_bus virtio8: rpmsg host is online [ 8.328267] am65-cpsw-nuss c000000.ethernet eth2: PHY [c000f00.mdio:08] driver [TI DP83TC814CS2.0] (irq=POLL) [ 8.334214] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd [ 8.334717] virtio_rpmsg_bus virtio9: rpmsg host is online [ 8.340929] am65-cpsw-nuss c000000.ethernet eth2: configuring for phy/sgmii link mode [ 8.343907] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd [ 8.344087] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15 [ 8.344191] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 8.344307] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15 [ 8.344373] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15 [ 8.344437] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 8.344532] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [ 8.344609] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15 [ 8.344675] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15 [ 8.344812] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 8.344988] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15 [ 8.345056] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x17 [ 8.345135] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x17 [ 8.345196] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x17 [ 8.345258] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x17 [ 8.345319] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x17 [ 8.345379] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x17 [ 8.345432] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x17 [ 8.345485] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x17 [ 8.345540] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x17 [ 8.345645] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x17 [ 8.347149] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 8.348344] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe [ 8.348705] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 8.348785] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe [ 8.365362] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe [ 8.368326] am65_cpsw_nuss_mac_config writel addr 0x:e600518 value:9801 [ OK ] Finished Load/Save Random Seed.[ 8.719949] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe [ 8.733025] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe [ 8.740665] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 8.748350] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe [ 8.756016] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe [ OK ] Started Network Time Synchronization. [ OK ] Started Network Configuration. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Reached target Timer Units.[ 9.058994] am65-cpsw-nuss c000000.ethernet eth1: PHY [c000f00.mdio:04] driver [TI DP83TG720CS1.1] (irq=POLL) [ 9.069855] am65-cpsw-nuss c000000.ethernet eth1: configuring for phy/sgmii link mode [ 9.077820] am65_cpsw_nuss_mac_config writel addr 0x:e600218 value:9801 [ OK ] Listening on D-Bus System Message B[ 9.087282] am65-cpsw-nuss c000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off us Socket. [ OK ] Reached target Socket Units. [ OK ] Reached target Basic System. [ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch. Starting app-init... Starting D-Bus System Message Bus... [ 9.286352] audit: type=1334 audit(1651186240.044:4): prog-id=7 op=LOAD [ 9.293077] audit: type=1334 audit(1651186240.052:5): prog-id=8 op=LOAD Starting User Login Management... Starting Network Name Resolution... [ 9.445743] am65-cpsw-nuss c000000.ethernet eth0: PHY [c000f00.mdio:0a] driver [TI DP83TG720CS1.1] (irq=POLL) [ 9.455683] am65-cpsw-nuss c000000.ethernet eth0: configuring for phy/sgmii link mode [ 9.463530] am65_cpsw_nuss_mac_config writel addr 0x:e600118 value:9801 [ 9.473220] am65-cpsw-nuss c000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Nam[ 9.543753] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. e Lookups. [ 9.585287] EXT4-fs (mmcblk0p18): recovery complete [ 9.590231] EXT4-fs (mmcblk0p18): mounted filesystem with ordered data mode. Quota mode: none. Starting Permit User Sessions... [ OK ] Started D-Bus System Message Bus. [ OK ] Finished app-init. [ OK ] Finished Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS0. [ OK ] Reached target Login Prompts. [ OK ] Started User Login Management. [ OK ] Reached target Multi-User System. Starting Record Runlevel Change in UTMP... [ OK ] Finished Record Runlevel Change in UTMP.
- other info
when we add ethfw code for serdes config, all is ok
static Board_Serdes_Config gBoardSerdesConfig[]= { { .Serdes_Base = CSL_WIZ16B8M4CT3_1_WIZ16B8M4CT3_BASE, .Serdes_Ins = CSL_TORRENT_SERDES1, .Serdes_Lane_Count = 2, .Serdes_Lane_Num = 2, .Serdes_Select_CPSW = 0 }, { .Serdes_Base = CSL_WIZ16B8M4CT3_2_WIZ16B8M4CT3_BASE, .Serdes_Ins = CSL_TORRENT_SERDES2, .Serdes_Lane_Count = 1, .Serdes_Lane_Num = 0, .Serdes_Select_CPSW = 0 } }; static Board_STATUS Board_CfgSgmii() { uint32_t i = 0; CSL_SerdesResult result; CSL_SerdesLaneEnableStatus laneRetVal = CSL_SERDES_LANE_ENABLE_NO_ERR; CSL_SerdesLaneEnableParams serdesLaneEnableParams; for (i = 0; i < (sizeof(gBoardSerdesConfig)/sizeof(gBoardSerdesConfig[0U])); i++) { uint32_t j = 0; uint32_t laneMask = 0; memset(&serdesLaneEnableParams, 0, sizeof(serdesLaneEnableParams)); /* SGMII Config */ serdesLaneEnableParams.serdesInstance = gBoardSerdesConfig[i].Serdes_Ins; serdesLaneEnableParams.baseAddr = gBoardSerdesConfig[i].Serdes_Base; serdesLaneEnableParams.refClock = CSL_SERDES_REF_CLOCK_100M; serdesLaneEnableParams.refClkSrc = CSL_SERDES_REF_CLOCK_INT0; serdesLaneEnableParams.linkRate = CSL_SERDES_LINK_RATE_1p25G; serdesLaneEnableParams.numLanes = CSL_SERDES_MAX_LANES; serdesLaneEnableParams.SSC_mode = CSL_SERDES_NO_SSC; serdesLaneEnableParams.phyType = CSL_SERDES_PHY_TYPE_SGMII; serdesLaneEnableParams.operatingMode = CSL_SERDES_FUNCTIONAL_MODE; serdesLaneEnableParams.phyInstanceNum = gBoardSerdesConfig[i].Serdes_Select_CPSW; serdesLaneEnableParams.pcieGenType = CSL_SERDES_PCIE_GEN3; for (j = gBoardSerdesConfig[i].Serdes_Lane_Num; j < gBoardSerdesConfig[i].Serdes_Lane_Num + gBoardSerdesConfig[i].Serdes_Lane_Count; j++) { serdesLaneEnableParams.laneCtrlRate[j] = CSL_SERDES_LANE_FULL_RATE; serdesLaneEnableParams.loopbackMode[j] = CSL_SERDES_LOOPBACK_DISABLED; laneMask |= (1<<j); } serdesLaneEnableParams.laneMask = laneMask; CSL_serdesPorReset(serdesLaneEnableParams.baseAddr); for (j = gBoardSerdesConfig[i].Serdes_Lane_Num; j < gBoardSerdesConfig[i].Serdes_Lane_Num + gBoardSerdesConfig[i].Serdes_Lane_Count; j++) { /* Select the IP type, IP instance num, Serdes Lane Number */ CSL_serdesIPSelect(CSL_CTRL_MMR0_CFG0_BASE, serdesLaneEnableParams.phyType, serdesLaneEnableParams.phyInstanceNum, serdesLaneEnableParams.serdesInstance, j); } result = CSL_serdesRefclkSel(CSL_CTRL_MMR0_CFG0_BASE, serdesLaneEnableParams.baseAddr, serdesLaneEnableParams.refClock, serdesLaneEnableParams.refClkSrc, serdesLaneEnableParams.serdesInstance, serdesLaneEnableParams.phyType); if (result != CSL_SERDES_NO_ERR) { return BOARD_FAIL; } /* Assert PHY reset and disable all lanes */ CSL_serdesDisablePllAndLanes(serdesLaneEnableParams.baseAddr, serdesLaneEnableParams.numLanes, serdesLaneEnableParams.laneMask); /* Load the Serdes Config File */ result = CSL_serdesEthernetInit(&serdesLaneEnableParams); /* Return error if input params are invalid */ if (result != CSL_SERDES_NO_ERR) { return BOARD_FAIL; } /* Common Lane Enable API for lane enable, pll enable etc */ laneRetVal = CSL_serdesLaneEnable(&serdesLaneEnableParams); if (laneRetVal != 0) { return BOARD_FAIL; } } return BOARD_SOK; }
