Part Number: TDA4VM
I have made this changes in the boot.c:
What should I build after modifications?
Part Number: TDA4VM
Could you please clarify which application you are trying to modify and which version of the SDK you are using?
Is this boot.c or lpl_boot.c?
CSL_REG32_WR(CSL_GTC0_GTC_CFG1_BASE + CSL_GTC_CFG1_CNTCR, 0x1);CSL_REG32_WR(CSL_GTC0_GTC_CFG1_BASE + CSL_GTC_CFG1_CNTFID0, 200000000);But after building and booting, I still get the errors and still not booting the board.
if it is lpl_boot.c can you please try this command for building.
make lpm_example_freertos BOARD=j721e_evm CORE=mcu1_0 -sj8 BUILD_PROFILE=release
Karthik
Hi Karthik,
I am modifying the boot.c located under: $(PSDK)/mcusw/mcuss_demos/boot_app_mcu_rtos/boot.c.
The SDK I am using is ti-processor-sdk-rtos-j721e-evm-09_02_00_05.
Tamas
Can boot app is obsolete and it is being removed in the upcoming releases. If you intend to use boot app , please use PDK boot app
software-dl.ti.com/.../boot_app.html
Tarun Mukesh
