Part Number: AM625-Q1
Other Parts Discussed in Thread: BQ25890, TPS51632, TAS2764, TPS65090, DP83869, TPS65912, BQ24190, TPS65910, ADS7950, CDCE925, LM95241, TVP7002, ADC161S626, SN65DSI83, LM95245, ADS7846, ADC108S102, PCM5102A, TMP117, LP8727, INA238, TMP006, LM63, LMP91000, PCM1681, AMC6821, TLC4541, LM93, LM3639, TUSB320, TLV320AIC23B, TAS5805M, TPD12S015, LM8333, ADS8688, DAC5571, HDC2010, TMP401, TAS2552, PCM3168A, TMP464, TPS65219, TPS65218, SN65DSI86, DAC7612, AFE4404, TPS65217, ADS131E08, DRV2665, DRV2667, TMP513, DAC082S085, ADS7828, TUSB1210, TPS65010, LP3972, LP3971, LM8323, ADC128S052, BQ24257, LM3642, DAC124S085, TPS23861, CDCE706, ADS1015, TAS2562, TCA6507, INA3221, LM83, TAS6424, TPS62360, LM80, LM87, THS7303, DAC7311, TPS65086, LM3630A, DP83TC811, THS8200, TAS2770, TPS65023, LP3943, LM95234, HD3SS3220, TFP410, TVP5150, TSC2004, TSC2005, OPT3001, TSC2007, LM77, LM70, LP3944, LM73, LM3530, INA209, ADS8344, TAS2780, PCF8574, ADC084S021, ADS7871, PCM3060, TSC2046, LMK04832, LM3532, LM3533, BQ24735, TCA8418, PMP, TPA6130A2, DLPC3433, TWL6040, TAS5086, AFE4403, TMP102, TMP103, ADC128D818, TS3A227E, TRF7970A, TMP421, ADS124S08, TMP108, TPIC2810, LM3560, PCM1789, BQ25980, TPS65132, LM92, TCA6416, LM90
Hi team,
Our custom board has schematics and gpio configured same as am62x-sk EVM and also Device tree is defined as same.
But still heartbeat led is not working.
# # Automatically generated file; DO NOT EDIT. # Linux/arm64 6.1.69 Kernel Configuration # CONFIG_CC_VERSION_TEXT="aarch64-agl-linux-gcc (GCC) 11.4.0" CONFIG_CC_IS_GCC=y CONFIG_GCC_VERSION=110400 CONFIG_CLANG_VERSION=0 CONFIG_AS_IS_GNU=y CONFIG_AS_VERSION=20244508 CONFIG_LD_IS_BFD=y CONFIG_LD_VERSION=20244508 CONFIG_LLD_VERSION=0 CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y CONFIG_CC_HAS_ASM_INLINE=y CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y CONFIG_PAHOLE_VERSION=0 CONFIG_IRQ_WORK=y CONFIG_BUILDTIME_TABLE_SORT=y CONFIG_THREAD_INFO_IN_TASK=y # # General setup # CONFIG_INIT_ENV_ARG_LIMIT=32 # CONFIG_COMPILE_TEST is not set # CONFIG_WERROR is not set CONFIG_LOCALVERSION="" CONFIG_LOCALVERSION_AUTO=y CONFIG_BUILD_SALT="" CONFIG_DEFAULT_INIT="" CONFIG_DEFAULT_HOSTNAME="(none)" CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_SYSVIPC_COMPAT=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y # CONFIG_WATCH_QUEUE is not set CONFIG_CROSS_MEMORY_ATTACH=y # CONFIG_USELIB is not set CONFIG_AUDIT=y CONFIG_HAVE_ARCH_AUDITSYSCALL=y CONFIG_AUDITSYSCALL=y # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_SHOW_LEVEL=y CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y CONFIG_GENERIC_IRQ_MIGRATION=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_SIM=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_GENERIC_IRQ_IPI=y CONFIG_GENERIC_MSI_IRQ=y CONFIG_GENERIC_MSI_IRQ_DOMAIN=y CONFIG_IRQ_MSI_IOMMU=y CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y # CONFIG_GENERIC_IRQ_DEBUGFS is not set # end of IRQ subsystem CONFIG_GENERIC_TIME_VSYSCALL=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_ARCH_HAS_TICK_BROADCAST=y CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y CONFIG_HAVE_POSIX_CPU_TIMERS_TASK_WORK=y CONFIG_POSIX_CPU_TIMERS_TASK_WORK=y CONFIG_CONTEXT_TRACKING=y CONFIG_CONTEXT_TRACKING_IDLE=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y # CONFIG_NO_HZ_FULL is not set # CONFIG_NO_HZ is not set CONFIG_HIGH_RES_TIMERS=y # end of Timers subsystem CONFIG_BPF=y CONFIG_HAVE_EBPF_JIT=y CONFIG_ARCH_WANT_DEFAULT_BPF_JIT=y # # BPF subsystem # CONFIG_BPF_SYSCALL=y CONFIG_BPF_JIT=y # CONFIG_BPF_JIT_ALWAYS_ON is not set CONFIG_BPF_JIT_DEFAULT_ON=y CONFIG_BPF_UNPRIV_DEFAULT_OFF=y # CONFIG_BPF_PRELOAD is not set CONFIG_BPF_LSM=y # end of BPF subsystem CONFIG_PREEMPT_BUILD=y # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_COUNT=y CONFIG_PREEMPTION=y # CONFIG_PREEMPT_DYNAMIC is not set # CONFIG_SCHED_CORE is not set # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set CONFIG_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_SCHED_AVG_IRQ=y CONFIG_SCHED_THERMAL_PRESSURE=y CONFIG_BSD_PROCESS_ACCT=y CONFIG_BSD_PROCESS_ACCT_V3=y CONFIG_TASKSTATS=y # CONFIG_TASK_DELAY_ACCT is not set CONFIG_TASK_XACCT=y CONFIG_TASK_IO_ACCOUNTING=y # CONFIG_PSI is not set # end of CPU/Task time and stats accounting CONFIG_CPU_ISOLATION=y # # RCU Subsystem # CONFIG_TREE_RCU=y CONFIG_PREEMPT_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y CONFIG_TREE_SRCU=y CONFIG_TASKS_RCU_GENERIC=y CONFIG_TASKS_RCU=y CONFIG_TASKS_TRACE_RCU=y CONFIG_RCU_STALL_COMMON=y CONFIG_RCU_NEED_SEGCBLIST=y # end of RCU Subsystem CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y # CONFIG_IKHEADERS is not set CONFIG_LOG_BUF_SHIFT=17 CONFIG_LOG_CPU_MAX_BUF_SHIFT=12 CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13 # CONFIG_PRINTK_INDEX is not set CONFIG_GENERIC_SCHED_CLOCK=y # # Scheduler features # # CONFIG_UCLAMP_TASK is not set # end of Scheduler features CONFIG_ARCH_SUPPORTS_NUMA_BALANCING=y CONFIG_CC_HAS_INT128=y CONFIG_CC_IMPLICIT_FALLTHROUGH="-Wimplicit-fallthrough=5" CONFIG_GCC11_NO_ARRAY_BOUNDS=y CONFIG_CC_NO_ARRAY_BOUNDS=y CONFIG_ARCH_SUPPORTS_INT128=y CONFIG_CGROUPS=y CONFIG_PAGE_COUNTER=y # CONFIG_CGROUP_FAVOR_DYNMODS is not set CONFIG_MEMCG=y CONFIG_MEMCG_KMEM=y CONFIG_BLK_CGROUP=y CONFIG_CGROUP_WRITEBACK=y CONFIG_CGROUP_SCHED=y CONFIG_FAIR_GROUP_SCHED=y CONFIG_CFS_BANDWIDTH=y # CONFIG_RT_GROUP_SCHED is not set CONFIG_CGROUP_PIDS=y # CONFIG_CGROUP_RDMA is not set CONFIG_CGROUP_FREEZER=y CONFIG_CGROUP_HUGETLB=y CONFIG_CPUSETS=y CONFIG_PROC_PID_CPUSET=y CONFIG_CGROUP_DEVICE=y CONFIG_CGROUP_CPUACCT=y CONFIG_CGROUP_PERF=y CONFIG_CGROUP_BPF=y # CONFIG_CGROUP_MISC is not set # CONFIG_CGROUP_DEBUG is not set CONFIG_SOCK_CGROUP_DATA=y CONFIG_NAMESPACES=y CONFIG_UTS_NS=y CONFIG_TIME_NS=y CONFIG_IPC_NS=y CONFIG_USER_NS=y CONFIG_PID_NS=y CONFIG_NET_NS=y CONFIG_CHECKPOINT_RESTORE=y CONFIG_SCHED_AUTOGROUP=y # CONFIG_SYSFS_DEPRECATED is not set CONFIG_RELAY=y CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y CONFIG_RD_LZ4=y CONFIG_RD_ZSTD=y # CONFIG_BOOT_CONFIG is not set CONFIG_INITRAMFS_PRESERVE_MTIME=y CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_LD_ORPHAN_WARN=y CONFIG_SYSCTL=y CONFIG_HAVE_UID16=y CONFIG_SYSCTL_EXCEPTION_TRACE=y CONFIG_EXPERT=y CONFIG_UID16=y CONFIG_MULTIUSER=y # CONFIG_SGETMASK_SYSCALL is not set CONFIG_SYSFS_SYSCALL=y CONFIG_FHANDLE=y CONFIG_POSIX_TIMERS=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_FUTEX_PI=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_IO_URING=y CONFIG_ADVISE_SYSCALLS=y CONFIG_MEMBARRIER=y CONFIG_KALLSYMS=y CONFIG_KALLSYMS_ALL=y CONFIG_KALLSYMS_BASE_RELATIVE=y CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y CONFIG_KCMP=y CONFIG_RSEQ=y # CONFIG_DEBUG_RSEQ is not set CONFIG_EMBEDDED=y CONFIG_HAVE_PERF_EVENTS=y # CONFIG_PC104 is not set # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_DEBUG_PERF_USE_VMALLOC is not set # end of Kernel Performance Events And Counters CONFIG_SYSTEM_DATA_VERIFICATION=y CONFIG_PROFILING=y CONFIG_TRACEPOINTS=y # end of General setup CONFIG_ARM64=y CONFIG_GCC_SUPPORTS_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_64BIT=y CONFIG_MMU=y CONFIG_ARM64_PAGE_SHIFT=12 CONFIG_ARM64_CONT_PTE_SHIFT=4 CONFIG_ARM64_CONT_PMD_SHIFT=4 CONFIG_ARCH_MMAP_RND_BITS_MIN=18 CONFIG_ARCH_MMAP_RND_BITS_MAX=33 CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MIN=11 CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MAX=16 CONFIG_STACKTRACE_SUPPORT=y CONFIG_ILLEGAL_POINTER_VALUE=0xdead000000000000 CONFIG_LOCKDEP_SUPPORT=y CONFIG_GENERIC_BUG=y CONFIG_GENERIC_BUG_RELATIVE_POINTERS=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CSUM=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_ARCH_MHP_MEMMAP_ON_MEMORY_ENABLE=y CONFIG_SMP=y CONFIG_KERNEL_MODE_NEON=y CONFIG_FIX_EARLYCON_MEM=y CONFIG_PGTABLE_LEVELS=4 CONFIG_ARCH_SUPPORTS_UPROBES=y CONFIG_ARCH_PROC_KCORE_TEXT=y # # Platform selection # # CONFIG_ARCH_ACTIONS is not set # CONFIG_ARCH_SUNXI is not set # CONFIG_ARCH_ALPINE is not set # CONFIG_ARCH_APPLE is not set # CONFIG_ARCH_BCM is not set # CONFIG_ARCH_BERLIN is not set # CONFIG_ARCH_BITMAIN is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_SPARX5 is not set CONFIG_ARCH_K3=y # CONFIG_ARCH_LG1K is not set # CONFIG_ARCH_HISI is not set # CONFIG_ARCH_KEEMBAY is not set # CONFIG_ARCH_MEDIATEK is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_ARCH_NXP is not set # CONFIG_ARCH_NPCM is not set # CONFIG_ARCH_QCOM is not set # CONFIG_ARCH_REALTEK is not set # CONFIG_ARCH_RENESAS is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_SEATTLE is not set # CONFIG_ARCH_INTEL_SOCFPGA is not set # CONFIG_ARCH_SYNQUACER is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_SPRD is not set # CONFIG_ARCH_THUNDER is not set # CONFIG_ARCH_THUNDER2 is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_VISCONTI is not set # CONFIG_ARCH_XGENE is not set # CONFIG_ARCH_ZYNQMP is not set # end of Platform selection # # Kernel Features # # # ARM errata workarounds via the alternatives framework # # CONFIG_AMPERE_ERRATUM_AC03_CPU_38 is not set CONFIG_ARM64_WORKAROUND_CLEAN_CACHE=y CONFIG_ARM64_ERRATUM_826319=y CONFIG_ARM64_ERRATUM_827319=y CONFIG_ARM64_ERRATUM_824069=y CONFIG_ARM64_ERRATUM_819472=y # CONFIG_ARM64_ERRATUM_832075 is not set CONFIG_ARM64_ERRATUM_1742098=y CONFIG_ARM64_ERRATUM_845719=y CONFIG_ARM64_ERRATUM_843419=y CONFIG_ARM64_LD_HAS_FIX_ERRATUM_843419=y # CONFIG_ARM64_ERRATUM_1024718 is not set # CONFIG_ARM64_ERRATUM_1418040 is not set CONFIG_ARM64_WORKAROUND_SPECULATIVE_AT=y # CONFIG_ARM64_ERRATUM_1165522 is not set CONFIG_ARM64_ERRATUM_1319367=y # CONFIG_ARM64_ERRATUM_1530923 is not set # CONFIG_ARM64_ERRATUM_2441007 is not set # CONFIG_ARM64_ERRATUM_1286807 is not set # CONFIG_ARM64_ERRATUM_1463225 is not set # CONFIG_ARM64_ERRATUM_1542419 is not set # CONFIG_ARM64_ERRATUM_1508412 is not set # CONFIG_ARM64_ERRATUM_2051678 is not set # CONFIG_ARM64_ERRATUM_2077057 is not set # CONFIG_ARM64_ERRATUM_2658417 is not set # CONFIG_ARM64_ERRATUM_2054223 is not set # CONFIG_ARM64_ERRATUM_2067961 is not set # CONFIG_ARM64_ERRATUM_2441009 is not set CONFIG_ARM64_ERRATUM_2457168=y CONFIG_ARM64_ERRATUM_2966298=y # CONFIG_CAVIUM_ERRATUM_22375 is not set # CONFIG_CAVIUM_ERRATUM_23154 is not set # CONFIG_CAVIUM_ERRATUM_27456 is not set # CONFIG_CAVIUM_ERRATUM_30115 is not set # CONFIG_CAVIUM_TX2_ERRATUM_219 is not set # CONFIG_FUJITSU_ERRATUM_010001 is not set # CONFIG_HISILICON_ERRATUM_161600802 is not set # CONFIG_QCOM_FALKOR_ERRATUM_1003 is not set # CONFIG_QCOM_FALKOR_ERRATUM_1009 is not set # CONFIG_QCOM_QDF2400_ERRATUM_0065 is not set # CONFIG_QCOM_FALKOR_ERRATUM_E1041 is not set # CONFIG_NVIDIA_CARMEL_CNP_ERRATUM is not set CONFIG_SOCIONEXT_SYNQUACER_PREITS=y # end of ARM errata workarounds via the alternatives framework CONFIG_ARM64_4K_PAGES=y # CONFIG_ARM64_16K_PAGES is not set # CONFIG_ARM64_64K_PAGES is not set # CONFIG_ARM64_VA_BITS_39 is not set CONFIG_ARM64_VA_BITS_48=y CONFIG_ARM64_VA_BITS=48 CONFIG_ARM64_PA_BITS_48=y CONFIG_ARM64_PA_BITS=48 # CONFIG_CPU_BIG_ENDIAN is not set CONFIG_CPU_LITTLE_ENDIAN=y CONFIG_SCHED_MC=y # CONFIG_SCHED_CLUSTER is not set CONFIG_SCHED_SMT=y CONFIG_NR_CPUS=256 CONFIG_HOTPLUG_CPU=y # CONFIG_NUMA is not set # CONFIG_HZ_100 is not set CONFIG_HZ_250=y # CONFIG_HZ_300 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=250 CONFIG_SCHED_HRTICK=y CONFIG_ARCH_SPARSEMEM_ENABLE=y CONFIG_HW_PERF_EVENTS=y CONFIG_PARAVIRT=y # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set CONFIG_KEXEC=y CONFIG_KEXEC_FILE=y # CONFIG_KEXEC_SIG is not set # CONFIG_CRASH_DUMP is not set CONFIG_TRANS_TABLE=y # CONFIG_XEN is not set CONFIG_ARCH_FORCE_MAX_ORDER=11 CONFIG_UNMAP_KERNEL_AT_EL0=y CONFIG_MITIGATE_SPECTRE_BRANCH_HISTORY=y CONFIG_RODATA_FULL_DEFAULT_ENABLED=y # CONFIG_ARM64_SW_TTBR0_PAN is not set CONFIG_ARM64_TAGGED_ADDR_ABI=y CONFIG_COMPAT=y CONFIG_KUSER_HELPERS=y # CONFIG_COMPAT_ALIGNMENT_FIXUPS is not set # CONFIG_ARMV8_DEPRECATED is not set # # ARMv8.1 architectural features # CONFIG_ARM64_HW_AFDBM=y CONFIG_ARM64_PAN=y CONFIG_AS_HAS_LDAPR=y CONFIG_AS_HAS_LSE_ATOMICS=y CONFIG_ARM64_LSE_ATOMICS=y CONFIG_ARM64_USE_LSE_ATOMICS=y # end of ARMv8.1 architectural features # # ARMv8.2 architectural features # CONFIG_AS_HAS_ARMV8_2=y CONFIG_AS_HAS_SHA3=y # CONFIG_ARM64_PMEM is not set CONFIG_ARM64_RAS_EXTN=y CONFIG_ARM64_CNP=y # end of ARMv8.2 architectural features # # ARMv8.3 architectural features # CONFIG_ARM64_PTR_AUTH=y CONFIG_ARM64_PTR_AUTH_KERNEL=y CONFIG_CC_HAS_BRANCH_PROT_PAC_RET=y CONFIG_CC_HAS_SIGN_RETURN_ADDRESS=y CONFIG_AS_HAS_PAC=y CONFIG_AS_HAS_CFI_NEGATE_RA_STATE=y # end of ARMv8.3 architectural features # # ARMv8.4 architectural features # CONFIG_ARM64_AMU_EXTN=y CONFIG_AS_HAS_ARMV8_4=y CONFIG_ARM64_TLB_RANGE=y # end of ARMv8.4 architectural features # # ARMv8.5 architectural features # CONFIG_AS_HAS_ARMV8_5=y CONFIG_ARM64_BTI=y CONFIG_CC_HAS_BRANCH_PROT_PAC_RET_BTI=y CONFIG_ARM64_E0PD=y CONFIG_ARM64_AS_HAS_MTE=y CONFIG_ARM64_MTE=y # end of ARMv8.5 architectural features # # ARMv8.7 architectural features # CONFIG_ARM64_EPAN=y # end of ARMv8.7 architectural features # CONFIG_ARM64_SVE is not set CONFIG_ARM64_MODULE_PLTS=y # CONFIG_ARM64_PSEUDO_NMI is not set CONFIG_RELOCATABLE=y CONFIG_RANDOMIZE_BASE=y CONFIG_RANDOMIZE_MODULE_REGION_FULL=y CONFIG_CC_HAVE_STACKPROTECTOR_SYSREG=y CONFIG_STACKPROTECTOR_PER_TASK=y CONFIG_ARCH_NR_GPIO=0 # end of Kernel Features # # Boot options # CONFIG_CMDLINE="" CONFIG_EFI_STUB=y CONFIG_EFI=y CONFIG_DMI=y # end of Boot options # # Power management options # CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y # CONFIG_SUSPEND_SKIP_SYNC is not set CONFIG_HIBERNATE_CALLBACKS=y CONFIG_HIBERNATION=y CONFIG_HIBERNATION_SNAPSHOT_DEV=y CONFIG_PM_STD_PARTITION="" CONFIG_PM_SLEEP=y CONFIG_PM_SLEEP_SMP=y # CONFIG_PM_AUTOSLEEP is not set # CONFIG_PM_USERSPACE_AUTOSLEEP is not set # CONFIG_PM_WAKELOCKS is not set CONFIG_PM=y # CONFIG_PM_DEBUG is not set CONFIG_PM_CLK=y CONFIG_PM_GENERIC_DOMAINS=y CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y CONFIG_PM_GENERIC_DOMAINS_SLEEP=y CONFIG_PM_GENERIC_DOMAINS_OF=y CONFIG_CPU_PM=y CONFIG_ENERGY_MODEL=y CONFIG_ARCH_HIBERNATION_POSSIBLE=y CONFIG_ARCH_HIBERNATION_HEADER=y CONFIG_ARCH_SUSPEND_POSSIBLE=y # end of Power management options # # CPU Power Management # # # CPU Idle # CONFIG_CPU_IDLE=y CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y # CONFIG_CPU_IDLE_GOV_LADDER is not set CONFIG_CPU_IDLE_GOV_MENU=y # CONFIG_CPU_IDLE_GOV_TEO is not set CONFIG_DT_IDLE_STATES=y CONFIG_DT_IDLE_GENPD=y # # ARM CPU Idle Drivers # CONFIG_ARM_PSCI_CPUIDLE=y CONFIG_ARM_PSCI_CPUIDLE_DOMAIN=y # end of ARM CPU Idle Drivers # end of CPU Idle # # CPU Frequency scaling # CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_GOV_ATTR_SET=y CONFIG_CPU_FREQ_GOV_COMMON=y CONFIG_CPU_FREQ_STAT=y # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL=y CONFIG_CPU_FREQ_GOV_PERFORMANCE=y CONFIG_CPU_FREQ_GOV_POWERSAVE=m CONFIG_CPU_FREQ_GOV_USERSPACE=y CONFIG_CPU_FREQ_GOV_ONDEMAND=y CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y # # CPU frequency scaling drivers # CONFIG_CPUFREQ_DT=y CONFIG_CPUFREQ_DT_PLATDEV=y CONFIG_ARM_SCMI_CPUFREQ=y CONFIG_ARM_TI_CPUFREQ=y # end of CPU Frequency scaling # end of CPU Power Management CONFIG_ARCH_SUPPORTS_ACPI=y # CONFIG_ACPI is not set CONFIG_IRQ_BYPASS_MANAGER=y CONFIG_HAVE_KVM=y CONFIG_VIRTUALIZATION=y # CONFIG_KVM is not set # # General architecture-dependent options # CONFIG_CRASH_CORE=y CONFIG_KEXEC_CORE=y CONFIG_ARCH_HAS_SUBPAGE_FAULTS=y CONFIG_KPROBES=y CONFIG_JUMP_LABEL=y # CONFIG_STATIC_KEYS_SELFTEST is not set CONFIG_UPROBES=y CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y CONFIG_KRETPROBES=y CONFIG_HAVE_IOREMAP_PROT=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_ARCH_CORRECT_STACKTRACE_ON_KRETPROBE=y CONFIG_HAVE_FUNCTION_ERROR_INJECTION=y CONFIG_HAVE_NMI=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_TRACE_IRQFLAGS_NMI_SUPPORT=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_ARCH_HAS_FORTIFY_SOURCE=y CONFIG_ARCH_HAS_KEEPINITRD=y CONFIG_ARCH_HAS_SET_MEMORY=y CONFIG_ARCH_HAS_SET_DIRECT_MAP=y CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y CONFIG_ARCH_WANTS_NO_INSTR=y CONFIG_HAVE_ASM_MODVERSIONS=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_RSEQ=y CONFIG_HAVE_FUNCTION_ARG_ACCESS_API=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_HAVE_ARCH_JUMP_LABEL_RELATIVE=y CONFIG_MMU_GATHER_TABLE_FREE=y CONFIG_MMU_GATHER_RCU_TABLE_FREE=y CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y CONFIG_HAVE_ALIGNED_STRUCT_PAGE=y CONFIG_HAVE_CMPXCHG_LOCAL=y CONFIG_HAVE_CMPXCHG_DOUBLE=y CONFIG_ARCH_WANT_COMPAT_IPC_PARSE_VERSION=y CONFIG_HAVE_ARCH_SECCOMP=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_SECCOMP=y CONFIG_SECCOMP_FILTER=y # CONFIG_SECCOMP_CACHE_DEBUG is not set CONFIG_HAVE_ARCH_STACKLEAK=y CONFIG_HAVE_STACKPROTECTOR=y CONFIG_STACKPROTECTOR=y CONFIG_STACKPROTECTOR_STRONG=y CONFIG_ARCH_SUPPORTS_LTO_CLANG=y CONFIG_ARCH_SUPPORTS_LTO_CLANG_THIN=y CONFIG_LTO_NONE=y CONFIG_ARCH_SUPPORTS_CFI_CLANG=y CONFIG_HAVE_CONTEXT_TRACKING_USER=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_MOVE_PUD=y CONFIG_HAVE_MOVE_PMD=y CONFIG_HAVE_ARCH_TRANSPARENT_HUGEPAGE=y CONFIG_HAVE_ARCH_HUGE_VMAP=y CONFIG_HAVE_ARCH_HUGE_VMALLOC=y CONFIG_ARCH_WANT_HUGE_PMD_SHARE=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_RELA=y CONFIG_HAVE_SOFTIRQ_ON_OWN_STACK=y CONFIG_SOFTIRQ_ON_OWN_STACK=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_ARCH_MMAP_RND_BITS=y CONFIG_ARCH_MMAP_RND_BITS=18 CONFIG_HAVE_ARCH_MMAP_RND_COMPAT_BITS=y CONFIG_ARCH_MMAP_RND_COMPAT_BITS=11 CONFIG_PAGE_SIZE_LESS_THAN_64KB=y CONFIG_PAGE_SIZE_LESS_THAN_256KB=y CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_COMPAT_OLD_SIGACTION=y CONFIG_COMPAT_32BIT_TIME=y CONFIG_HAVE_ARCH_VMAP_STACK=y CONFIG_VMAP_STACK=y CONFIG_HAVE_ARCH_RANDOMIZE_KSTACK_OFFSET=y CONFIG_RANDOMIZE_KSTACK_OFFSET=y # CONFIG_RANDOMIZE_KSTACK_OFFSET_DEFAULT is not set CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y CONFIG_STRICT_KERNEL_RWX=y CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y CONFIG_STRICT_MODULE_RWX=y CONFIG_HAVE_ARCH_COMPILER_H=y CONFIG_HAVE_ARCH_PREL32_RELOCATIONS=y CONFIG_ARCH_USE_MEMREMAP_PROT=y # CONFIG_LOCK_EVENT_COUNTS is not set CONFIG_ARCH_HAS_RELR=y CONFIG_HAVE_PREEMPT_DYNAMIC=y CONFIG_HAVE_PREEMPT_DYNAMIC_KEY=y CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y CONFIG_ARCH_SUPPORTS_PAGE_TABLE_CHECK=y CONFIG_ARCH_HAVE_TRACE_MMIO_ACCESS=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y # end of GCOV-based kernel profiling CONFIG_HAVE_GCC_PLUGINS=y CONFIG_GCC_PLUGINS=y # CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set # end of General architecture-dependent options CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y # CONFIG_MODULE_FORCE_LOAD is not set CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set # CONFIG_MODULE_UNLOAD_TAINT_TRACKING is not set # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set # CONFIG_MODULE_SIG is not set CONFIG_MODULE_COMPRESS_NONE=y # CONFIG_MODULE_COMPRESS_GZIP is not set # CONFIG_MODULE_COMPRESS_XZ is not set # CONFIG_MODULE_COMPRESS_ZSTD is not set # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set CONFIG_MODPROBE_PATH="/sbin/modprobe" # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_MODULES_TREE_LOOKUP=y CONFIG_BLOCK=y CONFIG_BLOCK_LEGACY_AUTOLOAD=y CONFIG_BLK_CGROUP_RWSTAT=y CONFIG_BLK_DEV_BSG_COMMON=y CONFIG_BLK_DEV_BSGLIB=y CONFIG_BLK_DEV_INTEGRITY=y CONFIG_BLK_DEV_INTEGRITY_T10=y # CONFIG_BLK_DEV_ZONED is not set CONFIG_BLK_DEV_THROTTLING=y # CONFIG_BLK_DEV_THROTTLING_LOW is not set # CONFIG_BLK_WBT is not set # CONFIG_BLK_CGROUP_IOLATENCY is not set # CONFIG_BLK_CGROUP_IOCOST is not set # CONFIG_BLK_CGROUP_IOPRIO is not set CONFIG_BLK_DEBUG_FS=y # CONFIG_BLK_SED_OPAL is not set # CONFIG_BLK_INLINE_ENCRYPTION is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y CONFIG_EFI_PARTITION=y # end of Partition Types CONFIG_BLOCK_COMPAT=y CONFIG_BLK_MQ_PCI=y CONFIG_BLK_MQ_VIRTIO=y CONFIG_BLK_PM=y CONFIG_BLOCK_HOLDER_DEPRECATED=y CONFIG_BLK_MQ_STACKING=y # # IO Schedulers # CONFIG_MQ_IOSCHED_DEADLINE=y CONFIG_MQ_IOSCHED_KYBER=y # CONFIG_IOSCHED_BFQ is not set # end of IO Schedulers CONFIG_ASN1=y CONFIG_UNINLINE_SPIN_UNLOCK=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y CONFIG_MUTEX_SPIN_ON_OWNER=y CONFIG_RWSEM_SPIN_ON_OWNER=y CONFIG_LOCK_SPIN_ON_OWNER=y CONFIG_ARCH_USE_QUEUED_SPINLOCKS=y CONFIG_QUEUED_SPINLOCKS=y CONFIG_ARCH_USE_QUEUED_RWLOCKS=y CONFIG_QUEUED_RWLOCKS=y CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y CONFIG_ARCH_HAS_SYSCALL_WRAPPER=y CONFIG_FREEZER=y # # Executable file formats # CONFIG_BINFMT_ELF=y CONFIG_COMPAT_BINFMT_ELF=y CONFIG_ARCH_BINFMT_ELF_STATE=y CONFIG_ARCH_BINFMT_ELF_EXTRA_PHDRS=y CONFIG_ARCH_HAVE_ELF_PROT=y CONFIG_ARCH_USE_GNU_PROPERTY=y CONFIG_ELFCORE=y # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set CONFIG_BINFMT_SCRIPT=y # CONFIG_BINFMT_MISC is not set CONFIG_COREDUMP=y # end of Executable file formats # # Memory Management options # CONFIG_SWAP=y # CONFIG_ZSWAP is not set # # SLAB allocator options # # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set CONFIG_SLAB_MERGE_DEFAULT=y # CONFIG_SLAB_FREELIST_RANDOM is not set # CONFIG_SLAB_FREELIST_HARDENED is not set # CONFIG_SLUB_STATS is not set CONFIG_SLUB_CPU_PARTIAL=y # end of SLAB allocator options # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set # CONFIG_COMPAT_BRK is not set CONFIG_SPARSEMEM=y CONFIG_SPARSEMEM_EXTREME=y CONFIG_SPARSEMEM_VMEMMAP_ENABLE=y CONFIG_SPARSEMEM_VMEMMAP=y CONFIG_HAVE_FAST_GUP=y CONFIG_ARCH_KEEP_MEMBLOCK=y CONFIG_MEMORY_ISOLATION=y CONFIG_EXCLUSIVE_SYSTEM_RAM=y CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y CONFIG_ARCH_ENABLE_MEMORY_HOTREMOVE=y CONFIG_MEMORY_HOTPLUG=y # CONFIG_MEMORY_HOTPLUG_DEFAULT_ONLINE is not set CONFIG_MEMORY_HOTREMOVE=y CONFIG_MHP_MEMMAP_ON_MEMORY=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_ARCH_ENABLE_SPLIT_PMD_PTLOCK=y CONFIG_MEMORY_BALLOON=y CONFIG_BALLOON_COMPACTION=y CONFIG_COMPACTION=y CONFIG_COMPACT_UNEVICTABLE_DEFAULT=1 CONFIG_PAGE_REPORTING=y CONFIG_MIGRATION=y CONFIG_ARCH_ENABLE_HUGEPAGE_MIGRATION=y CONFIG_ARCH_ENABLE_THP_MIGRATION=y CONFIG_CONTIG_ALLOC=y CONFIG_PHYS_ADDR_T_64BIT=y CONFIG_KSM=y CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_ARCH_SUPPORTS_MEMORY_FAILURE=y CONFIG_MEMORY_FAILURE=y # CONFIG_HWPOISON_INJECT is not set CONFIG_ARCH_WANTS_THP_SWAP=y CONFIG_TRANSPARENT_HUGEPAGE=y CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y # CONFIG_TRANSPARENT_HUGEPAGE_MADVISE is not set CONFIG_THP_SWAP=y # CONFIG_READ_ONLY_THP_FOR_FS is not set CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # CONFIG_CMA_DEBUGFS is not set # CONFIG_CMA_SYSFS is not set CONFIG_CMA_AREAS=19 CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_DEFERRED_STRUCT_PAGE_INIT is not set # CONFIG_IDLE_PAGE_TRACKING is not set CONFIG_ARCH_HAS_CACHE_LINE_SIZE=y CONFIG_ARCH_HAS_CURRENT_STACK_POINTER=y CONFIG_ARCH_HAS_PTE_DEVMAP=y CONFIG_ARCH_HAS_ZONE_DMA_SET=y CONFIG_ZONE_DMA=y CONFIG_ZONE_DMA32=y # CONFIG_ZONE_DEVICE is not set CONFIG_ARCH_USES_HIGH_VMA_FLAGS=y CONFIG_VM_EVENT_COUNTERS=y # CONFIG_PERCPU_STATS is not set # CONFIG_GUP_TEST is not set CONFIG_ARCH_HAS_PTE_SPECIAL=y # CONFIG_ANON_VMA_NAME is not set # CONFIG_USERFAULTFD is not set # CONFIG_LRU_GEN is not set CONFIG_LOCK_MM_AND_FIND_VMA=y # # Data Access Monitoring # # CONFIG_DAMON is not set # end of Data Access Monitoring # end of Memory Management options CONFIG_NET=y CONFIG_COMPAT_NETLINK_MESSAGES=y CONFIG_NET_INGRESS=y CONFIG_NET_EGRESS=y CONFIG_SKB_EXTENSIONS=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_DIAG is not set CONFIG_UNIX=y CONFIG_UNIX_SCM=y CONFIG_AF_UNIX_OOB=y # CONFIG_UNIX_DIAG is not set # CONFIG_TLS is not set CONFIG_XFRM=y CONFIG_XFRM_ALGO=y CONFIG_XFRM_USER=y # CONFIG_XFRM_INTERFACE is not set # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set CONFIG_XFRM_ESP=y # CONFIG_NET_KEY is not set CONFIG_XDP_SOCKETS=y # CONFIG_XDP_SOCKETS_DIAG is not set CONFIG_INET=y CONFIG_IP_MULTICAST=y # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_ROUTE_CLASSID=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y # CONFIG_IP_PNP_RARP is not set # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set CONFIG_NET_IP_TUNNEL=m # CONFIG_IP_MROUTE is not set # CONFIG_SYN_COOKIES is not set # CONFIG_NET_IPVTI is not set CONFIG_NET_UDP_TUNNEL=m # CONFIG_NET_FOU is not set # CONFIG_NET_FOU_IP_TUNNELS is not set # CONFIG_INET_AH is not set CONFIG_INET_ESP=y # CONFIG_INET_ESP_OFFLOAD is not set # CONFIG_INET_ESPINTCP is not set # CONFIG_INET_IPCOMP is not set CONFIG_INET_TABLE_PERTURB_ORDER=16 CONFIG_INET_TUNNEL=m CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_INET_UDP_DIAG is not set # CONFIG_INET_RAW_DIAG is not set # CONFIG_INET_DIAG_DESTROY is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set CONFIG_IPV6=m # CONFIG_IPV6_ROUTER_PREF is not set # CONFIG_IPV6_OPTIMISTIC_DAD is not set # CONFIG_INET6_AH is not set # CONFIG_INET6_ESP is not set # CONFIG_INET6_IPCOMP is not set # CONFIG_IPV6_MIP6 is not set # CONFIG_IPV6_ILA is not set # CONFIG_IPV6_VTI is not set CONFIG_IPV6_SIT=m # CONFIG_IPV6_SIT_6RD is not set CONFIG_IPV6_NDISC_NODETYPE=y # CONFIG_IPV6_TUNNEL is not set # CONFIG_IPV6_MULTIPLE_TABLES is not set # CONFIG_IPV6_MROUTE is not set # CONFIG_IPV6_SEG6_LWTUNNEL is not set # CONFIG_IPV6_SEG6_HMAC is not set # CONFIG_IPV6_RPL_LWTUNNEL is not set # CONFIG_IPV6_IOAM6_LWTUNNEL is not set # CONFIG_NETLABEL is not set # CONFIG_MPTCP is not set CONFIG_NETWORK_SECMARK=y CONFIG_NET_PTP_CLASSIFY=y # CONFIG_NETWORK_PHY_TIMESTAMPING is not set CONFIG_NETFILTER=y CONFIG_NETFILTER_ADVANCED=y CONFIG_BRIDGE_NETFILTER=m # # Core Netfilter Configuration # CONFIG_NETFILTER_INGRESS=y CONFIG_NETFILTER_EGRESS=y CONFIG_NETFILTER_SKIP_EGRESS=y CONFIG_NETFILTER_FAMILY_BRIDGE=y # CONFIG_NETFILTER_NETLINK_ACCT is not set # CONFIG_NETFILTER_NETLINK_QUEUE is not set # CONFIG_NETFILTER_NETLINK_LOG is not set # CONFIG_NETFILTER_NETLINK_OSF is not set CONFIG_NF_CONNTRACK=m CONFIG_NF_LOG_SYSLOG=m # CONFIG_NF_CONNTRACK_MARK is not set # CONFIG_NF_CONNTRACK_SECMARK is not set # CONFIG_NF_CONNTRACK_ZONES is not set # CONFIG_NF_CONNTRACK_PROCFS is not set CONFIG_NF_CONNTRACK_EVENTS=y # CONFIG_NF_CONNTRACK_TIMEOUT is not set # CONFIG_NF_CONNTRACK_TIMESTAMP is not set # CONFIG_NF_CONNTRACK_LABELS is not set CONFIG_NF_CT_PROTO_DCCP=y CONFIG_NF_CT_PROTO_SCTP=y CONFIG_NF_CT_PROTO_UDPLITE=y # CONFIG_NF_CONNTRACK_AMANDA is not set CONFIG_NF_CONNTRACK_FTP=m # CONFIG_NF_CONNTRACK_H323 is not set # CONFIG_NF_CONNTRACK_IRC is not set # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set # CONFIG_NF_CONNTRACK_SNMP is not set # CONFIG_NF_CONNTRACK_PPTP is not set # CONFIG_NF_CONNTRACK_SANE is not set # CONFIG_NF_CONNTRACK_SIP is not set CONFIG_NF_CONNTRACK_TFTP=m # CONFIG_NF_CT_NETLINK is not set CONFIG_NF_NAT=m CONFIG_NF_NAT_FTP=m CONFIG_NF_NAT_TFTP=m CONFIG_NF_NAT_REDIRECT=y CONFIG_NF_NAT_MASQUERADE=y # CONFIG_NF_TABLES is not set CONFIG_NETFILTER_XTABLES=m CONFIG_NETFILTER_XTABLES_COMPAT=y # # Xtables combined modules # CONFIG_NETFILTER_XT_MARK=m # CONFIG_NETFILTER_XT_CONNMARK is not set # # Xtables targets # # CONFIG_NETFILTER_XT_TARGET_AUDIT is not set CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m # CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set # CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set # CONFIG_NETFILTER_XT_TARGET_DSCP is not set # CONFIG_NETFILTER_XT_TARGET_HL is not set # CONFIG_NETFILTER_XT_TARGET_HMARK is not set # CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set # CONFIG_NETFILTER_XT_TARGET_LED is not set CONFIG_NETFILTER_XT_TARGET_LOG=m # CONFIG_NETFILTER_XT_TARGET_MARK is not set CONFIG_NETFILTER_XT_NAT=m # CONFIG_NETFILTER_XT_TARGET_NETMAP is not set # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set CONFIG_NETFILTER_XT_TARGET_REDIRECT=m CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m # CONFIG_NETFILTER_XT_TARGET_TEE is not set # CONFIG_NETFILTER_XT_TARGET_TPROXY is not set # CONFIG_NETFILTER_XT_TARGET_SECMARK is not set # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set # CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set # # Xtables matches # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m # CONFIG_NETFILTER_XT_MATCH_BPF is not set # CONFIG_NETFILTER_XT_MATCH_CGROUP is not set # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set # CONFIG_NETFILTER_XT_MATCH_COMMENT is not set # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set # CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m # CONFIG_NETFILTER_XT_MATCH_CPU is not set # CONFIG_NETFILTER_XT_MATCH_DCCP is not set # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set # CONFIG_NETFILTER_XT_MATCH_DSCP is not set # CONFIG_NETFILTER_XT_MATCH_ECN is not set # CONFIG_NETFILTER_XT_MATCH_ESP is not set # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set # CONFIG_NETFILTER_XT_MATCH_HELPER is not set # CONFIG_NETFILTER_XT_MATCH_HL is not set # CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set # CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set CONFIG_NETFILTER_XT_MATCH_IPVS=m # CONFIG_NETFILTER_XT_MATCH_L2TP is not set # CONFIG_NETFILTER_XT_MATCH_LENGTH is not set # CONFIG_NETFILTER_XT_MATCH_LIMIT is not set # CONFIG_NETFILTER_XT_MATCH_MAC is not set # CONFIG_NETFILTER_XT_MATCH_MARK is not set # CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set # CONFIG_NETFILTER_XT_MATCH_NFACCT is not set # CONFIG_NETFILTER_XT_MATCH_OSF is not set # CONFIG_NETFILTER_XT_MATCH_OWNER is not set # CONFIG_NETFILTER_XT_MATCH_POLICY is not set # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set # CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set # CONFIG_NETFILTER_XT_MATCH_REALM is not set # CONFIG_NETFILTER_XT_MATCH_RECENT is not set # CONFIG_NETFILTER_XT_MATCH_SCTP is not set # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set # CONFIG_NETFILTER_XT_MATCH_STATE is not set # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set # CONFIG_NETFILTER_XT_MATCH_STRING is not set # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set # CONFIG_NETFILTER_XT_MATCH_TIME is not set # CONFIG_NETFILTER_XT_MATCH_U32 is not set # end of Core Netfilter Configuration # CONFIG_IP_SET is not set CONFIG_IP_VS=m # CONFIG_IP_VS_IPV6 is not set # CONFIG_IP_VS_DEBUG is not set CONFIG_IP_VS_TAB_BITS=12 # # IPVS transport protocol load balancing support # CONFIG_IP_VS_PROTO_TCP=y CONFIG_IP_VS_PROTO_UDP=y # CONFIG_IP_VS_PROTO_ESP is not set # CONFIG_IP_VS_PROTO_AH is not set # CONFIG_IP_VS_PROTO_SCTP is not set # # IPVS scheduler # CONFIG_IP_VS_RR=m # CONFIG_IP_VS_WRR is not set # CONFIG_IP_VS_LC is not set # CONFIG_IP_VS_WLC is not set # CONFIG_IP_VS_FO is not set # CONFIG_IP_VS_OVF is not set # CONFIG_IP_VS_LBLC is not set # CONFIG_IP_VS_LBLCR is not set # CONFIG_IP_VS_DH is not set # CONFIG_IP_VS_SH is not set # CONFIG_IP_VS_MH is not set # CONFIG_IP_VS_SED is not set # CONFIG_IP_VS_NQ is not set # CONFIG_IP_VS_TWOS is not set # # IPVS SH scheduler # CONFIG_IP_VS_SH_TAB_BITS=8 # # IPVS MH scheduler # CONFIG_IP_VS_MH_TAB_INDEX=12 # # IPVS application helper # # CONFIG_IP_VS_FTP is not set CONFIG_IP_VS_NFCT=y # # IP: Netfilter Configuration # CONFIG_NF_DEFRAG_IPV4=m # CONFIG_NF_SOCKET_IPV4 is not set # CONFIG_NF_TPROXY_IPV4 is not set # CONFIG_NF_DUP_IPV4 is not set # CONFIG_NF_LOG_ARP is not set # CONFIG_NF_LOG_IPV4 is not set CONFIG_NF_REJECT_IPV4=m CONFIG_IP_NF_IPTABLES=m # CONFIG_IP_NF_MATCH_AH is not set # CONFIG_IP_NF_MATCH_ECN is not set # CONFIG_IP_NF_MATCH_RPFILTER is not set # CONFIG_IP_NF_MATCH_TTL is not set CONFIG_IP_NF_FILTER=m CONFIG_IP_NF_TARGET_REJECT=m # CONFIG_IP_NF_TARGET_SYNPROXY is not set CONFIG_IP_NF_NAT=m CONFIG_IP_NF_TARGET_MASQUERADE=m # CONFIG_IP_NF_TARGET_NETMAP is not set CONFIG_IP_NF_TARGET_REDIRECT=m CONFIG_IP_NF_MANGLE=m # CONFIG_IP_NF_TARGET_CLUSTERIP is not set # CONFIG_IP_NF_TARGET_ECN is not set # CONFIG_IP_NF_TARGET_TTL is not set # CONFIG_IP_NF_RAW is not set # CONFIG_IP_NF_SECURITY is not set # CONFIG_IP_NF_ARPTABLES is not set # end of IP: Netfilter Configuration # # IPv6: Netfilter Configuration # # CONFIG_NF_SOCKET_IPV6 is not set # CONFIG_NF_TPROXY_IPV6 is not set # CONFIG_NF_DUP_IPV6 is not set CONFIG_NF_REJECT_IPV6=m CONFIG_NF_LOG_IPV6=m CONFIG_IP6_NF_IPTABLES=m # CONFIG_IP6_NF_MATCH_AH is not set # CONFIG_IP6_NF_MATCH_EUI64 is not set # CONFIG_IP6_NF_MATCH_FRAG is not set # CONFIG_IP6_NF_MATCH_OPTS is not set # CONFIG_IP6_NF_MATCH_HL is not set # CONFIG_IP6_NF_MATCH_IPV6HEADER is not set # CONFIG_IP6_NF_MATCH_MH is not set # CONFIG_IP6_NF_MATCH_RPFILTER is not set # CONFIG_IP6_NF_MATCH_RT is not set # CONFIG_IP6_NF_MATCH_SRH is not set # CONFIG_IP6_NF_TARGET_HL is not set CONFIG_IP6_NF_FILTER=m CONFIG_IP6_NF_TARGET_REJECT=m # CONFIG_IP6_NF_TARGET_SYNPROXY is not set CONFIG_IP6_NF_MANGLE=m # CONFIG_IP6_NF_RAW is not set # CONFIG_IP6_NF_SECURITY is not set CONFIG_IP6_NF_NAT=m CONFIG_IP6_NF_TARGET_MASQUERADE=m # CONFIG_IP6_NF_TARGET_NPT is not set # end of IPv6: Netfilter Configuration CONFIG_NF_DEFRAG_IPV6=m # CONFIG_NF_CONNTRACK_BRIDGE is not set # CONFIG_BRIDGE_NF_EBTABLES is not set # CONFIG_BPFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set CONFIG_STP=m CONFIG_GARP=m CONFIG_MRP=m CONFIG_BRIDGE=m CONFIG_BRIDGE_IGMP_SNOOPING=y CONFIG_BRIDGE_VLAN_FILTERING=y # CONFIG_BRIDGE_MRP is not set # CONFIG_BRIDGE_CFM is not set CONFIG_NET_DSA=m # CONFIG_NET_DSA_TAG_AR9331 is not set CONFIG_NET_DSA_TAG_BRCM_COMMON=m CONFIG_NET_DSA_TAG_BRCM=m CONFIG_NET_DSA_TAG_BRCM_LEGACY=m CONFIG_NET_DSA_TAG_BRCM_PREPEND=m # CONFIG_NET_DSA_TAG_HELLCREEK is not set # CONFIG_NET_DSA_TAG_GSWIP is not set # CONFIG_NET_DSA_TAG_DSA is not set # CONFIG_NET_DSA_TAG_EDSA is not set # CONFIG_NET_DSA_TAG_MTK is not set # CONFIG_NET_DSA_TAG_KSZ is not set CONFIG_NET_DSA_TAG_OCELOT=m CONFIG_NET_DSA_TAG_OCELOT_8021Q=m # CONFIG_NET_DSA_TAG_QCA is not set # CONFIG_NET_DSA_TAG_RTL4_A is not set # CONFIG_NET_DSA_TAG_RTL8_4 is not set # CONFIG_NET_DSA_TAG_RZN1_A5PSW is not set # CONFIG_NET_DSA_TAG_LAN9303 is not set # CONFIG_NET_DSA_TAG_SJA1105 is not set # CONFIG_NET_DSA_TAG_TRAILER is not set # CONFIG_NET_DSA_TAG_XRS700X is not set CONFIG_VLAN_8021Q=m CONFIG_VLAN_8021Q_GVRP=y CONFIG_VLAN_8021Q_MVRP=y CONFIG_LLC=m # CONFIG_LLC2 is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_6LOWPAN is not set # CONFIG_IEEE802154 is not set CONFIG_NET_SCHED=y # # Queueing/Scheduling # # CONFIG_NET_SCH_CBQ is not set # CONFIG_NET_SCH_HTB is not set # CONFIG_NET_SCH_HFSC is not set # CONFIG_NET_SCH_PRIO is not set # CONFIG_NET_SCH_MULTIQ is not set # CONFIG_NET_SCH_RED is not set # CONFIG_NET_SCH_SFB is not set # CONFIG_NET_SCH_SFQ is not set # CONFIG_NET_SCH_TEQL is not set # CONFIG_NET_SCH_TBF is not set CONFIG_NET_SCH_CBS=m CONFIG_NET_SCH_ETF=m CONFIG_NET_SCH_TAPRIO=m # CONFIG_NET_SCH_GRED is not set # CONFIG_NET_SCH_DSMARK is not set # CONFIG_NET_SCH_NETEM is not set # CONFIG_NET_SCH_DRR is not set CONFIG_NET_SCH_MQPRIO=m # CONFIG_NET_SCH_SKBPRIO is not set # CONFIG_NET_SCH_CHOKE is not set # CONFIG_NET_SCH_QFQ is not set # CONFIG_NET_SCH_CODEL is not set # CONFIG_NET_SCH_FQ_CODEL is not set # CONFIG_NET_SCH_CAKE is not set # CONFIG_NET_SCH_FQ is not set # CONFIG_NET_SCH_HHF is not set # CONFIG_NET_SCH_PIE is not set CONFIG_NET_SCH_INGRESS=m # CONFIG_NET_SCH_PLUG is not set # CONFIG_NET_SCH_ETS is not set # CONFIG_NET_SCH_DEFAULT is not set # # Classification # CONFIG_NET_CLS=y CONFIG_NET_CLS_BASIC=m CONFIG_NET_CLS_ROUTE4=m CONFIG_NET_CLS_FW=m CONFIG_NET_CLS_U32=m # CONFIG_CLS_U32_PERF is not set CONFIG_CLS_U32_MARK=y CONFIG_NET_CLS_FLOW=m CONFIG_NET_CLS_CGROUP=m CONFIG_NET_CLS_BPF=m CONFIG_NET_CLS_FLOWER=m # CONFIG_NET_CLS_MATCHALL is not set CONFIG_NET_EMATCH=y CONFIG_NET_EMATCH_STACK=32 CONFIG_NET_EMATCH_CMP=m CONFIG_NET_EMATCH_NBYTE=m CONFIG_NET_EMATCH_U32=m CONFIG_NET_EMATCH_META=m CONFIG_NET_EMATCH_TEXT=m # CONFIG_NET_EMATCH_CANID is not set # CONFIG_NET_EMATCH_IPT is not set CONFIG_NET_CLS_ACT=y CONFIG_NET_ACT_POLICE=m CONFIG_NET_ACT_GACT=m CONFIG_GACT_PROB=y CONFIG_NET_ACT_MIRRED=m # CONFIG_NET_ACT_SAMPLE is not set CONFIG_NET_ACT_IPT=m CONFIG_NET_ACT_NAT=m CONFIG_NET_ACT_PEDIT=m CONFIG_NET_ACT_SIMP=m CONFIG_NET_ACT_SKBEDIT=m CONFIG_NET_ACT_CSUM=m # CONFIG_NET_ACT_MPLS is not set # CONFIG_NET_ACT_VLAN is not set CONFIG_NET_ACT_BPF=m # CONFIG_NET_ACT_SKBMOD is not set # CONFIG_NET_ACT_IFE is not set # CONFIG_NET_ACT_TUNNEL_KEY is not set CONFIG_NET_ACT_GATE=m # CONFIG_NET_TC_SKB_EXT is not set CONFIG_NET_SCH_FIFO=y # CONFIG_DCB is not set CONFIG_DNS_RESOLVER=y # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set # CONFIG_NETLINK_DIAG is not set # CONFIG_MPLS is not set # CONFIG_NET_NSH is not set CONFIG_HSR=m CONFIG_NET_SWITCHDEV=y CONFIG_NET_L3_MASTER_DEV=y CONFIG_QRTR=m CONFIG_QRTR_SMD=m CONFIG_QRTR_TUN=m CONFIG_QRTR_MHI=m # CONFIG_NET_NCSI is not set CONFIG_PCPU_DEV_REFCNT=y CONFIG_RPS=y CONFIG_RFS_ACCEL=y CONFIG_SOCK_RX_QUEUE_MAPPING=y CONFIG_XPS=y CONFIG_CGROUP_NET_PRIO=y CONFIG_CGROUP_NET_CLASSID=y CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y # CONFIG_BPF_STREAM_PARSER is not set CONFIG_NET_FLOW_LIMIT=y # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_NET_DROP_MONITOR is not set # end of Network testing # end of Networking options # CONFIG_HAMRADIO is not set CONFIG_CAN=m # CONFIG_CAN_RAW=m # CONFIG_CAN_BCM=m # CONFIG_CAN_GW=m # CONFIG_CAN_J1939=m # CONFIG_CAN_ISOTP is not set CONFIG_BT=m CONFIG_BT_BREDR=y CONFIG_BT_RFCOMM=m CONFIG_BT_RFCOMM_TTY=y CONFIG_BT_BNEP=m CONFIG_BT_BNEP_MC_FILTER=y CONFIG_BT_BNEP_PROTO_FILTER=y CONFIG_BT_HIDP=m CONFIG_BT_HS=y CONFIG_BT_LE=y CONFIG_BT_LEDS=y # CONFIG_BT_MSFTEXT is not set # CONFIG_BT_AOSPEXT is not set CONFIG_BT_DEBUGFS=y # CONFIG_BT_SELFTEST is not set # CONFIG_BT_FEATURE_DEBUG is not set # # Bluetooth device drivers # CONFIG_BT_INTEL=m CONFIG_BT_BCM=m CONFIG_BT_RTL=m CONFIG_BT_QCA=m CONFIG_BT_HCIBTUSB=m # CONFIG_BT_HCIBTUSB_AUTOSUSPEND is not set CONFIG_BT_HCIBTUSB_BCM=y # CONFIG_BT_HCIBTUSB_MTK is not set CONFIG_BT_HCIBTUSB_RTL=y # CONFIG_BT_HCIBTSDIO is not set CONFIG_BT_HCIUART=m CONFIG_BT_HCIUART_SERDEV=y CONFIG_BT_HCIUART_H4=y # CONFIG_BT_HCIUART_NOKIA is not set CONFIG_BT_HCIUART_BCSP=y # CONFIG_BT_HCIUART_ATH3K is not set CONFIG_BT_HCIUART_LL=y # CONFIG_BT_HCIUART_3WIRE is not set # CONFIG_BT_HCIUART_INTEL is not set CONFIG_BT_HCIUART_BCM=y # CONFIG_BT_HCIUART_RTL is not set CONFIG_BT_HCIUART_QCA=y # CONFIG_BT_HCIUART_AG6XX is not set CONFIG_BT_HCIUART_MRVL=y CONFIG_BT_HCIBCM203X=m # CONFIG_BT_HCIBPA10X is not set CONFIG_BT_HCIBFUSB=m # CONFIG_BT_HCIVHCI is not set CONFIG_BT_MRVL=m CONFIG_BT_MRVL_SDIO=m # CONFIG_BT_ATH3K is not set # CONFIG_BT_MTKSDIO is not set # CONFIG_BT_MTKUART is not set # CONFIG_BT_VIRTIO is not set # end of Bluetooth device drivers # CONFIG_AF_RXRPC is not set # CONFIG_AF_KCM is not set # CONFIG_MCTP is not set CONFIG_WIRELESS=y CONFIG_WIRELESS_EXT=y CONFIG_WEXT_CORE=y CONFIG_WEXT_PROC=y CONFIG_WEXT_PRIV=y CONFIG_CFG80211=m # CONFIG_NL80211_TESTMODE is not set # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set # CONFIG_CFG80211_CERTIFICATION_ONUS is not set CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y CONFIG_CFG80211_DEFAULT_PS=y # CONFIG_CFG80211_DEBUGFS is not set CONFIG_CFG80211_CRDA_SUPPORT=y # CONFIG_CFG80211_WEXT is not set CONFIG_LIB80211=m CONFIG_LIB80211_CRYPT_WEP=m CONFIG_LIB80211_CRYPT_CCMP=m # CONFIG_LIB80211_DEBUG is not set CONFIG_MAC80211=m CONFIG_MAC80211_HAS_RC=y CONFIG_MAC80211_RC_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT="minstrel_ht" # CONFIG_MAC80211_MESH is not set CONFIG_MAC80211_LEDS=y # CONFIG_MAC80211_DEBUGFS is not set # CONFIG_MAC80211_MESSAGE_TRACING is not set # CONFIG_MAC80211_DEBUG_MENU is not set CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 # CONFIG_RFKILL is not set # CONFIG_RFKILL_LEDS is not set # CONFIG_RFKILL_INPUT is not set # CONFIG_RFKILL_GPIO is not set # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set CONFIG_NFC=m CONFIG_NFC_DIGITAL=m CONFIG_NFC_NCI=m CONFIG_NFC_NCI_SPI=m # CONFIG_NFC_NCI_UART is not set CONFIG_NFC_HCI=m CONFIG_NFC_SHDLC=y # # Near Field Communication (NFC) devices # CONFIG_NFC_TRF7970A=m # CONFIG_NFC_SIM is not set CONFIG_NFC_PORT100=m # CONFIG_NFC_VIRTUAL_NCI is not set CONFIG_NFC_FDP=m CONFIG_NFC_FDP_I2C=m CONFIG_NFC_PN544=m CONFIG_NFC_PN544_I2C=m CONFIG_NFC_PN533=m CONFIG_NFC_PN533_USB=m CONFIG_NFC_PN533_I2C=m # CONFIG_NFC_PN532_UART is not set CONFIG_NFC_MICROREAD=m CONFIG_NFC_MICROREAD_I2C=m CONFIG_NFC_MRVL=m CONFIG_NFC_MRVL_USB=m CONFIG_NFC_MRVL_I2C=m CONFIG_NFC_MRVL_SPI=m CONFIG_NFC_ST21NFCA=m CONFIG_NFC_ST21NFCA_I2C=m CONFIG_NFC_ST_NCI=m CONFIG_NFC_ST_NCI_I2C=m CONFIG_NFC_ST_NCI_SPI=m CONFIG_NFC_NXP_NCI=m CONFIG_NFC_NXP_NCI_I2C=m CONFIG_NFC_S3FWRN5=m CONFIG_NFC_S3FWRN5_I2C=m # CONFIG_NFC_S3FWRN82_UART is not set CONFIG_NFC_ST95HF=m # end of Near Field Communication (NFC) devices # CONFIG_PSAMPLE is not set # CONFIG_NET_IFE is not set # CONFIG_LWTUNNEL is not set CONFIG_DST_CACHE=y CONFIG_GRO_CELLS=y CONFIG_NET_SELFTESTS=y CONFIG_NET_SOCK_MSG=y CONFIG_NET_DEVLINK=y CONFIG_PAGE_POOL=y CONFIG_PAGE_POOL_STATS=y CONFIG_FAILOVER=y CONFIG_ETHTOOL_NETLINK=y # # Device Drivers # CONFIG_ARM_AMBA=y CONFIG_HAVE_PCI=y CONFIG_PCI=y CONFIG_PCI_DOMAINS=y CONFIG_PCI_DOMAINS_GENERIC=y CONFIG_PCI_SYSCALL=y CONFIG_PCIEPORTBUS=y # CONFIG_HOTPLUG_PCI_PCIE is not set CONFIG_PCIEAER=y # CONFIG_PCIEAER_INJECT is not set # CONFIG_PCIE_ECRC is not set CONFIG_PCIEASPM=y CONFIG_PCIEASPM_DEFAULT=y # CONFIG_PCIEASPM_POWERSAVE is not set # CONFIG_PCIEASPM_POWER_SUPERSAVE is not set # CONFIG_PCIEASPM_PERFORMANCE is not set CONFIG_PCIE_PME=y # CONFIG_PCIE_DPC is not set # CONFIG_PCIE_PTM is not set CONFIG_PCI_MSI=y CONFIG_PCI_MSI_IRQ_DOMAIN=y CONFIG_PCI_QUIRKS=y # CONFIG_PCI_DEBUG is not set # CONFIG_PCI_REALLOC_ENABLE_AUTO is not set # CONFIG_PCI_STUB is not set # CONFIG_PCI_PF_STUB is not set CONFIG_PCI_ATS=y CONFIG_PCI_ECAM=y CONFIG_PCI_IOV=y # CONFIG_PCI_PRI is not set CONFIG_PCI_PASID=y CONFIG_PCI_LABEL=y # CONFIG_PCIE_BUS_TUNE_OFF is not set CONFIG_PCIE_BUS_DEFAULT=y # CONFIG_PCIE_BUS_SAFE is not set # CONFIG_PCIE_BUS_PERFORMANCE is not set # CONFIG_PCIE_BUS_PEER2PEER is not set # CONFIG_VGA_ARB is not set CONFIG_HOTPLUG_PCI=y # CONFIG_HOTPLUG_PCI_CPCI is not set # CONFIG_HOTPLUG_PCI_SHPC is not set # # PCI controller drivers # # CONFIG_PCI_FTPCI100 is not set CONFIG_PCI_HOST_COMMON=y CONFIG_PCI_HOST_GENERIC=y # CONFIG_PCIE_XILINX is not set # CONFIG_PCI_XGENE is not set # CONFIG_PCIE_ALTERA is not set # CONFIG_PCI_HOST_THUNDER_PEM is not set # CONFIG_PCI_HOST_THUNDER_ECAM is not set # CONFIG_PCIE_MICROCHIP_HOST is not set # # DesignWare PCI Core Support # CONFIG_PCIE_DW=y CONFIG_PCIE_DW_HOST=y CONFIG_PCIE_DW_EP=y # CONFIG_PCIE_DW_PLAT_HOST is not set # CONFIG_PCIE_DW_PLAT_EP is not set CONFIG_PCI_KEYSTONE=y CONFIG_PCI_KEYSTONE_HOST=y CONFIG_PCI_KEYSTONE_EP=y # CONFIG_PCI_HISI is not set # CONFIG_PCIE_KIRIN is not set # CONFIG_PCI_MESON is not set # CONFIG_PCIE_AL is not set # end of DesignWare PCI Core Support # # Mobiveil PCIe Core Support # # end of Mobiveil PCIe Core Support # # Cadence PCIe controllers support # CONFIG_PCIE_CADENCE=m CONFIG_PCIE_CADENCE_HOST=m CONFIG_PCIE_CADENCE_EP=m # CONFIG_PCIE_CADENCE_PLAT_HOST is not set # CONFIG_PCIE_CADENCE_PLAT_EP is not set CONFIG_PCI_J721E=m CONFIG_PCI_J721E_HOST=m CONFIG_PCI_J721E_EP=m # end of Cadence PCIe controllers support # end of PCI controller drivers # # PCI Endpoint # CONFIG_PCI_ENDPOINT=y CONFIG_PCI_ENDPOINT_CONFIGFS=y CONFIG_PCI_EPF_TEST=y CONFIG_PCI_EPF_NTB=y # end of PCI Endpoint # # PCI switch controller drivers # # CONFIG_PCI_SW_SWITCHTEC is not set # end of PCI switch controller drivers # CONFIG_CXL_BUS is not set # CONFIG_PCCARD is not set # CONFIG_RAPIDIO is not set # # Generic Driver Options # CONFIG_AUXILIARY_BUS=y # CONFIG_UEVENT_HELPER is not set CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y # CONFIG_DEVTMPFS_SAFE is not set CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y # # Firmware loader # CONFIG_FW_LOADER=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_FW_LOADER_USER_HELPER is not set # CONFIG_FW_LOADER_COMPRESS is not set CONFIG_FW_CACHE=y # CONFIG_FW_UPLOAD is not set # end of Firmware loader CONFIG_WANT_DEV_COREDUMP=y CONFIG_ALLOW_DEV_COREDUMP=y CONFIG_DEV_COREDUMP=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set CONFIG_GENERIC_CPU_AUTOPROBE=y CONFIG_GENERIC_CPU_VULNERABILITIES=y CONFIG_SOC_BUS=y CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_SPI=y CONFIG_REGMAP_MMIO=y CONFIG_REGMAP_IRQ=y CONFIG_REGMAP_SOUNDWIRE=m CONFIG_DMA_SHARED_BUFFER=y # CONFIG_DMA_FENCE_TRACE is not set CONFIG_GENERIC_ARCH_TOPOLOGY=y # end of Generic Driver Options # # Bus devices # CONFIG_ARM_CCI=y CONFIG_ARM_CCI400_COMMON=y # CONFIG_BRCMSTB_GISB_ARB is not set # CONFIG_MOXTET is not set CONFIG_TI_SYSC=y # CONFIG_VEXPRESS_CONFIG is not set CONFIG_MHI_BUS=m # CONFIG_MHI_BUS_DEBUG is not set # CONFIG_MHI_BUS_PCI_GENERIC is not set # CONFIG_MHI_BUS_EP is not set # end of Bus devices # CONFIG_CONNECTOR is not set # # Firmware Drivers # # # ARM System Control and Management Interface Protocol # CONFIG_ARM_SCMI_PROTOCOL=y CONFIG_ARM_SCMI_HAVE_TRANSPORT=y CONFIG_ARM_SCMI_HAVE_SHMEM=y CONFIG_ARM_SCMI_HAVE_MSG=y CONFIG_ARM_SCMI_TRANSPORT_MAILBOX=y CONFIG_ARM_SCMI_TRANSPORT_OPTEE=y CONFIG_ARM_SCMI_TRANSPORT_SMC=y # CONFIG_ARM_SCMI_TRANSPORT_SMC_ATOMIC_ENABLE is not set # CONFIG_ARM_SCMI_TRANSPORT_VIRTIO is not set CONFIG_ARM_SCMI_POWER_DOMAIN=y # CONFIG_ARM_SCMI_POWER_CONTROL is not set # end of ARM System Control and Management Interface Protocol # CONFIG_ARM_SCPI_PROTOCOL is not set # CONFIG_FIRMWARE_MEMMAP is not set CONFIG_DMIID=y # CONFIG_DMI_SYSFS is not set # CONFIG_FW_CFG_SYSFS is not set # CONFIG_SYSFB_SIMPLEFB is not set CONFIG_TI_SCI_PROTOCOL=y # CONFIG_ARM_FFA_TRANSPORT is not set # CONFIG_GOOGLE_FIRMWARE is not set # # EFI (Extensible Firmware Interface) Support # CONFIG_EFI_ESRT=y CONFIG_EFI_VARS_PSTORE=y # CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set CONFIG_EFI_PARAMS_FROM_FDT=y CONFIG_EFI_RUNTIME_WRAPPERS=y CONFIG_EFI_GENERIC_STUB=y # CONFIG_EFI_ZBOOT is not set CONFIG_EFI_ARMSTUB_DTB_LOADER=y # CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER is not set # CONFIG_EFI_BOOTLOADER_CONTROL is not set CONFIG_EFI_CAPSULE_LOADER=y # CONFIG_EFI_TEST is not set # CONFIG_RESET_ATTACK_MITIGATION is not set # CONFIG_EFI_DISABLE_PCI_DMA is not set CONFIG_EFI_EARLYCON=y # CONFIG_EFI_DISABLE_RUNTIME is not set # CONFIG_EFI_COCO_SECRET is not set # end of EFI (Extensible Firmware Interface) Support CONFIG_ARM_PSCI_FW=y # CONFIG_ARM_PSCI_CHECKER is not set CONFIG_HAVE_ARM_SMCCC=y CONFIG_HAVE_ARM_SMCCC_DISCOVERY=y CONFIG_ARM_SMCCC_SOC_ID=y # # Tegra firmware driver # # end of Tegra firmware driver # end of Firmware Drivers CONFIG_GNSS=m CONFIG_GNSS_SERIAL=m CONFIG_GNSS_MTK_SERIAL=m # CONFIG_GNSS_SIRF_SERIAL is not set # CONFIG_GNSS_UBX_SERIAL is not set # CONFIG_GNSS_USB is not set CONFIG_MTD=y CONFIG_MTD_TESTS=m # # Partition parsers # # CONFIG_MTD_AR7_PARTS is not set CONFIG_MTD_CMDLINE_PARTS=y CONFIG_MTD_OF_PARTS=y # CONFIG_MTD_AFS_PARTS is not set # CONFIG_MTD_REDBOOT_PARTS is not set # end of Partition parsers # # User Modules And Translation Layers # CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # # Note that in some cases UBI block is preferred. See MTD_UBI_BLOCK. # # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # CONFIG_MTD_SWAP is not set # CONFIG_MTD_PARTITIONED_MASTER is not set # # RAM/ROM/Flash chip drivers # CONFIG_MTD_CFI=y # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_GEN_PROBE=y CONFIG_MTD_CFI_ADV_OPTIONS=y CONFIG_MTD_CFI_NOSWAP=y # CONFIG_MTD_CFI_BE_BYTE_SWAP is not set # CONFIG_MTD_CFI_LE_BYTE_SWAP is not set # CONFIG_MTD_CFI_GEOMETRY is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_OTP is not set CONFIG_MTD_CFI_INTELEXT=y CONFIG_MTD_CFI_AMDSTD=y CONFIG_MTD_CFI_STAA=y CONFIG_MTD_CFI_UTIL=y # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # end of RAM/ROM/Flash chip drivers # # Mapping drivers for chip access # CONFIG_MTD_COMPLEX_MAPPINGS=y CONFIG_MTD_PHYSMAP=y # CONFIG_MTD_PHYSMAP_COMPAT is not set CONFIG_MTD_PHYSMAP_OF=y # CONFIG_MTD_PHYSMAP_VERSATILE is not set # CONFIG_MTD_PHYSMAP_GEMINI is not set # CONFIG_MTD_PHYSMAP_GPIO_ADDR is not set # CONFIG_MTD_PCI is not set # CONFIG_MTD_INTEL_VR_NOR is not set # CONFIG_MTD_PLATRAM is not set # end of Mapping drivers for chip access # # Self-contained MTD device drivers # # CONFIG_MTD_PMC551 is not set CONFIG_MTD_DATAFLASH=y # CONFIG_MTD_DATAFLASH_WRITE_VERIFY is not set # CONFIG_MTD_DATAFLASH_OTP is not set # CONFIG_MTD_MCHP23K256 is not set # CONFIG_MTD_MCHP48L640 is not set CONFIG_MTD_SST25L=y # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOCG3 is not set # end of Self-contained MTD device drivers # # NAND # CONFIG_MTD_NAND_CORE=y # CONFIG_MTD_ONENAND is not set CONFIG_MTD_RAW_NAND=y # # Raw/parallel NAND flash controllers # # CONFIG_MTD_NAND_DENALI_PCI is not set # CONFIG_MTD_NAND_DENALI_DT is not set CONFIG_MTD_NAND_OMAP2=y CONFIG_MTD_NAND_OMAP_BCH=y CONFIG_MTD_NAND_OMAP_BCH_BUILD=y # CONFIG_MTD_NAND_CAFE is not set # CONFIG_MTD_NAND_BRCMNAND is not set # CONFIG_MTD_NAND_MXIC is not set # CONFIG_MTD_NAND_GPIO is not set # CONFIG_MTD_NAND_PLATFORM is not set # CONFIG_MTD_NAND_CADENCE is not set # CONFIG_MTD_NAND_ARASAN is not set # CONFIG_MTD_NAND_INTEL_LGM is not set # # Misc # # CONFIG_MTD_NAND_NANDSIM is not set # CONFIG_MTD_NAND_RICOH is not set # CONFIG_MTD_NAND_DISKONCHIP is not set CONFIG_MTD_SPI_NAND=y # # ECC engine support # CONFIG_MTD_NAND_ECC=y CONFIG_MTD_NAND_ECC_SW_HAMMING=y # CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC is not set # CONFIG_MTD_NAND_ECC_SW_BCH is not set # CONFIG_MTD_NAND_ECC_MXIC is not set # end of ECC engine support # end of NAND # # LPDDR & LPDDR2 PCM memory drivers # # CONFIG_MTD_LPDDR is not set # end of LPDDR & LPDDR2 PCM memory drivers CONFIG_MTD_SPI_NOR=y CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y # CONFIG_MTD_SPI_NOR_SWP_DISABLE is not set CONFIG_MTD_SPI_NOR_SWP_DISABLE_ON_VOLATILE=y # CONFIG_MTD_SPI_NOR_SWP_KEEP is not set CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_LIMIT=20 # CONFIG_MTD_UBI_FASTMAP is not set # CONFIG_MTD_UBI_GLUEBI is not set # CONFIG_MTD_UBI_BLOCK is not set CONFIG_MTD_HYPERBUS=m CONFIG_HBMC_AM654=m CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_KOBJ=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_RESERVED_MEM=y # CONFIG_OF_OVERLAY is not set # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set # CONFIG_ZRAM is not set CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_LOOP_MIN_COUNT=8 # CONFIG_BLK_DEV_DRBD is not set CONFIG_BLK_DEV_NBD=m # CONFIG_BLK_DEV_RAM is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set CONFIG_VIRTIO_BLK=y # CONFIG_BLK_DEV_RBD is not set # CONFIG_BLK_DEV_UBLK is not set # # NVME Support # CONFIG_NVME_CORE=m CONFIG_BLK_DEV_NVME=m # CONFIG_NVME_MULTIPATH is not set # CONFIG_NVME_VERBOSE_ERRORS is not set # CONFIG_NVME_HWMON is not set # CONFIG_NVME_FC is not set # CONFIG_NVME_TCP is not set # CONFIG_NVME_AUTH is not set # CONFIG_NVME_TARGET is not set # end of NVME Support # # Misc devices # # CONFIG_AD525X_DPOT is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_PHANTOM is not set # CONFIG_TIFM_CORE is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_HP_ILO is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_LATTICE_ECP3_CONFIG is not set CONFIG_SRAM=y CONFIG_SRAM_DMA_HEAP=y # CONFIG_DW_XDATA_PCIE is not set CONFIG_PCI_ENDPOINT_TEST=m # CONFIG_XILINX_SDFEC is not set # CONFIG_HISI_HIKEY_USB is not set # CONFIG_OPEN_DICE is not set # CONFIG_VCPU_STALL_DETECTOR is not set CONFIG_DMA_BUF_PHYS=y CONFIG_TPS6594_ESM=y CONFIG_TPS6594_PFSM=y # CONFIG_C2PORT is not set # # EEPROM support # CONFIG_EEPROM_AT24=m CONFIG_EEPROM_AT25=m # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set # CONFIG_EEPROM_93CX6 is not set # CONFIG_EEPROM_93XX46 is not set # CONFIG_EEPROM_IDT_89HPESX is not set # CONFIG_EEPROM_EE1004 is not set # end of EEPROM support # CONFIG_CB710_CORE is not set # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # end of Texas Instruments shared transport line discipline # CONFIG_SENSORS_LIS3_SPI is not set # CONFIG_SENSORS_LIS3_I2C is not set # CONFIG_ALTERA_STAPL is not set # CONFIG_VMWARE_VMCI is not set # CONFIG_GENWQE is not set # CONFIG_ECHO is not set # CONFIG_BCM_VK is not set # CONFIG_MISC_ALCOR_PCI is not set # CONFIG_MISC_RTSX_PCI is not set # CONFIG_MISC_RTSX_USB is not set # CONFIG_HABANA_AI is not set CONFIG_UACCE=m # CONFIG_PVPANIC is not set # CONFIG_GP_PCI1XXXX is not set # end of Misc devices # # SCSI device support # CONFIG_SCSI_MOD=y CONFIG_RAID_ATTRS=m CONFIG_SCSI_COMMON=y CONFIG_SCSI=y CONFIG_SCSI_DMA=y # CONFIG_SCSI_PROC_FS is not set # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_BLK_DEV_SR is not set # CONFIG_CHR_DEV_SG is not set CONFIG_BLK_DEV_BSG=y # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set CONFIG_SCSI_SAS_ATTRS=y CONFIG_SCSI_SAS_LIBSAS=y CONFIG_SCSI_SAS_ATA=y CONFIG_SCSI_SAS_HOST_SMP=y # CONFIG_SCSI_SRP_ATTRS is not set # end of SCSI Transports CONFIG_SCSI_LOWLEVEL=y # CONFIG_ISCSI_TCP is not set # CONFIG_ISCSI_BOOT_SYSFS is not set # CONFIG_SCSI_CXGB3_ISCSI is not set # CONFIG_SCSI_CXGB4_ISCSI is not set # CONFIG_SCSI_BNX2_ISCSI is not set # CONFIG_BE2ISCSI is not set # CONFIG_BLK_DEV_3W_XXXX_RAID is not set # CONFIG_SCSI_HPSA is not set # CONFIG_SCSI_3W_9XXX is not set # CONFIG_SCSI_3W_SAS is not set # CONFIG_SCSI_ACARD is not set # CONFIG_SCSI_AACRAID is not set # CONFIG_SCSI_AIC7XXX is not set # CONFIG_SCSI_AIC79XX is not set # CONFIG_SCSI_AIC94XX is not set # CONFIG_SCSI_HISI_SAS is not set # CONFIG_SCSI_MVSAS is not set # CONFIG_SCSI_MVUMI is not set # CONFIG_SCSI_ADVANSYS is not set # CONFIG_SCSI_ARCMSR is not set # CONFIG_SCSI_ESAS2R is not set # CONFIG_MEGARAID_NEWGEN is not set # CONFIG_MEGARAID_LEGACY is not set CONFIG_MEGARAID_SAS=y CONFIG_SCSI_MPT3SAS=m CONFIG_SCSI_MPT2SAS_MAX_SGE=128 CONFIG_SCSI_MPT3SAS_MAX_SGE=128 # CONFIG_SCSI_MPT2SAS is not set # CONFIG_SCSI_MPI3MR is not set # CONFIG_SCSI_SMARTPQI is not set # CONFIG_SCSI_HPTIOP is not set # CONFIG_SCSI_BUSLOGIC is not set # CONFIG_SCSI_MYRB is not set # CONFIG_SCSI_MYRS is not set # CONFIG_SCSI_SNIC is not set # CONFIG_SCSI_DMX3191D is not set # CONFIG_SCSI_FDOMAIN_PCI is not set # CONFIG_SCSI_IPS is not set # CONFIG_SCSI_INITIO is not set # CONFIG_SCSI_INIA100 is not set # CONFIG_SCSI_STEX is not set # CONFIG_SCSI_SYM53C8XX_2 is not set # CONFIG_SCSI_IPR is not set # CONFIG_SCSI_QLOGIC_1280 is not set # CONFIG_SCSI_QLA_ISCSI is not set # CONFIG_SCSI_DC395x is not set # CONFIG_SCSI_AM53C974 is not set # CONFIG_SCSI_WD719X is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_PMCRAID is not set # CONFIG_SCSI_PM8001 is not set # CONFIG_SCSI_VIRTIO is not set # CONFIG_SCSI_DH is not set # end of SCSI device support CONFIG_ATA=y CONFIG_SATA_HOST=y CONFIG_ATA_VERBOSE_ERROR=y CONFIG_ATA_FORCE=y CONFIG_SATA_PMP=y # # Controllers with non-SFF native interface # CONFIG_SATA_AHCI=y CONFIG_SATA_MOBILE_LPM_POLICY=0 CONFIG_SATA_AHCI_PLATFORM=y # CONFIG_AHCI_DWC is not set # CONFIG_AHCI_CEVA is not set # CONFIG_AHCI_XGENE is not set # CONFIG_AHCI_QORIQ is not set # CONFIG_SATA_INIC162X is not set # CONFIG_SATA_ACARD_AHCI is not set # CONFIG_SATA_SIL24 is not set CONFIG_ATA_SFF=y # # SFF controllers with custom DMA interface # # CONFIG_PDC_ADMA is not set # CONFIG_SATA_QSTOR is not set # CONFIG_SATA_SX4 is not set CONFIG_ATA_BMDMA=y # # SATA SFF controllers with BMDMA # # CONFIG_ATA_PIIX is not set # CONFIG_SATA_DWC is not set # CONFIG_SATA_MV is not set # CONFIG_SATA_NV is not set # CONFIG_SATA_PROMISE is not set # CONFIG_SATA_SIL is not set # CONFIG_SATA_SIS is not set # CONFIG_SATA_SVW is not set # CONFIG_SATA_ULI is not set # CONFIG_SATA_VIA is not set # CONFIG_SATA_VITESSE is not set # # PATA SFF controllers with BMDMA # # CONFIG_PATA_ALI is not set # CONFIG_PATA_AMD is not set # CONFIG_PATA_ARTOP is not set # CONFIG_PATA_ATIIXP is not set # CONFIG_PATA_ATP867X is not set # CONFIG_PATA_CMD64X is not set # CONFIG_PATA_CYPRESS is not set # CONFIG_PATA_EFAR is not set # CONFIG_PATA_HPT366 is not set # CONFIG_PATA_HPT37X is not set # CONFIG_PATA_HPT3X2N is not set # CONFIG_PATA_HPT3X3 is not set # CONFIG_PATA_IT8213 is not set # CONFIG_PATA_IT821X is not set # CONFIG_PATA_JMICRON is not set # CONFIG_PATA_MARVELL is not set # CONFIG_PATA_NETCELL is not set # CONFIG_PATA_NINJA32 is not set # CONFIG_PATA_NS87415 is not set # CONFIG_PATA_OLDPIIX is not set # CONFIG_PATA_OPTIDMA is not set # CONFIG_PATA_PDC2027X is not set # CONFIG_PATA_PDC_OLD is not set # CONFIG_PATA_RADISYS is not set # CONFIG_PATA_RDC is not set # CONFIG_PATA_SCH is not set # CONFIG_PATA_SERVERWORKS is not set # CONFIG_PATA_SIL680 is not set # CONFIG_PATA_SIS is not set # CONFIG_PATA_TOSHIBA is not set # CONFIG_PATA_TRIFLEX is not set # CONFIG_PATA_VIA is not set # CONFIG_PATA_WINBOND is not set # # PIO-only SFF controllers # # CONFIG_PATA_CMD640_PCI is not set # CONFIG_PATA_MPIIX is not set # CONFIG_PATA_NS87410 is not set # CONFIG_PATA_OPTI is not set CONFIG_PATA_PLATFORM=y CONFIG_PATA_OF_PLATFORM=y # CONFIG_PATA_RZ1000 is not set # # Generic fallback / legacy drivers # # CONFIG_ATA_GENERIC is not set # CONFIG_PATA_LEGACY is not set CONFIG_MD=y CONFIG_BLK_DEV_MD=m # CONFIG_MD_LINEAR is not set # CONFIG_MD_RAID0 is not set # CONFIG_MD_RAID1 is not set # CONFIG_MD_RAID10 is not set # CONFIG_MD_RAID456 is not set # CONFIG_MD_MULTIPATH is not set # CONFIG_MD_FAULTY is not set # CONFIG_BCACHE is not set CONFIG_BLK_DEV_DM_BUILTIN=y CONFIG_BLK_DEV_DM=m # CONFIG_DM_DEBUG is not set CONFIG_DM_BUFIO=m # CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set CONFIG_DM_BIO_PRISON=m CONFIG_DM_PERSISTENT_DATA=m # CONFIG_DM_UNSTRIPED is not set # CONFIG_DM_CRYPT is not set # CONFIG_DM_SNAPSHOT is not set CONFIG_DM_THIN_PROVISIONING=m # CONFIG_DM_CACHE is not set # CONFIG_DM_WRITECACHE is not set # CONFIG_DM_EBS is not set # CONFIG_DM_ERA is not set # CONFIG_DM_CLONE is not set CONFIG_DM_MIRROR=m # CONFIG_DM_LOG_USERSPACE is not set # CONFIG_DM_RAID is not set CONFIG_DM_ZERO=m # CONFIG_DM_MULTIPATH is not set # CONFIG_DM_DELAY is not set # CONFIG_DM_DUST is not set # CONFIG_DM_UEVENT is not set # CONFIG_DM_FLAKEY is not set # CONFIG_DM_VERITY is not set # CONFIG_DM_SWITCH is not set # CONFIG_DM_LOG_WRITES is not set # CONFIG_DM_INTEGRITY is not set # CONFIG_DM_AUDIT is not set # CONFIG_TARGET_CORE is not set # CONFIG_FUSION is not set # # IEEE 1394 (FireWire) support # # CONFIG_FIREWIRE is not set # CONFIG_FIREWIRE_NOSY is not set # end of IEEE 1394 (FireWire) support CONFIG_NETDEVICES=y CONFIG_MII=m CONFIG_NET_CORE=y # CONFIG_BONDING is not set CONFIG_DUMMY=m # CONFIG_WIREGUARD is not set # CONFIG_EQUALIZER is not set # CONFIG_NET_FC is not set # CONFIG_IFB is not set # CONFIG_NET_TEAM is not set CONFIG_MACVLAN=m CONFIG_MACVTAP=m CONFIG_IPVLAN_L3S=y CONFIG_IPVLAN=m # CONFIG_IPVTAP is not set CONFIG_VXLAN=m # CONFIG_GENEVE is not set # CONFIG_BAREUDP is not set # CONFIG_GTP is not set # CONFIG_AMT is not set # CONFIG_MACSEC is not set # CONFIG_NETCONSOLE is not set CONFIG_TUN=y CONFIG_TAP=m # CONFIG_TUN_VNET_CROSS_LE is not set CONFIG_VETH=m CONFIG_VIRTIO_NET=y # CONFIG_NLMON is not set # CONFIG_MHI_NET is not set # CONFIG_ARCNET is not set # # Distributed Switch Architecture drivers # # CONFIG_B53 is not set # CONFIG_NET_DSA_BCM_SF2 is not set # CONFIG_NET_DSA_LOOP is not set # CONFIG_NET_DSA_HIRSCHMANN_HELLCREEK is not set # CONFIG_NET_DSA_LANTIQ_GSWIP is not set # CONFIG_NET_DSA_MT7530 is not set # CONFIG_NET_DSA_MV88E6060 is not set # CONFIG_NET_DSA_MICROCHIP_KSZ_COMMON is not set # CONFIG_NET_DSA_MV88E6XXX is not set # CONFIG_NET_DSA_AR9331 is not set # CONFIG_NET_DSA_QCA8K is not set # CONFIG_NET_DSA_SJA1105 is not set # CONFIG_NET_DSA_XRS700X_I2C is not set # CONFIG_NET_DSA_XRS700X_MDIO is not set # CONFIG_NET_DSA_REALTEK is not set # CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set # CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set # CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set # CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set # end of Distributed Switch Architecture drivers CONFIG_ETHERNET=y CONFIG_NET_VENDOR_3COM=y # CONFIG_VORTEX is not set # CONFIG_TYPHOON is not set CONFIG_NET_VENDOR_ADAPTEC=y # CONFIG_ADAPTEC_STARFIRE is not set CONFIG_NET_VENDOR_AGERE=y # CONFIG_ET131X is not set # CONFIG_NET_VENDOR_ALACRITECH is not set CONFIG_NET_VENDOR_ALTEON=y # CONFIG_ACENIC is not set # CONFIG_ALTERA_TSE is not set # CONFIG_NET_VENDOR_AMAZON is not set # CONFIG_NET_VENDOR_AMD is not set # CONFIG_NET_VENDOR_AQUANTIA is not set # CONFIG_NET_VENDOR_ARC is not set # CONFIG_NET_VENDOR_ASIX is not set CONFIG_NET_VENDOR_ATHEROS=y # CONFIG_ATL2 is not set # CONFIG_ATL1 is not set # CONFIG_ATL1E is not set CONFIG_ATL1C=m # CONFIG_ALX is not set # CONFIG_NET_VENDOR_BROADCOM is not set # CONFIG_NET_VENDOR_CADENCE is not set # CONFIG_NET_VENDOR_CAVIUM is not set CONFIG_NET_VENDOR_CHELSIO=y # CONFIG_CHELSIO_T1 is not set # CONFIG_CHELSIO_T3 is not set # CONFIG_CHELSIO_T4 is not set # CONFIG_CHELSIO_T4VF is not set CONFIG_NET_VENDOR_CISCO=y # CONFIG_ENIC is not set # CONFIG_NET_VENDOR_CORTINA is not set # CONFIG_NET_VENDOR_DAVICOM is not set # CONFIG_DNET is not set CONFIG_NET_VENDOR_DEC=y # CONFIG_NET_TULIP is not set CONFIG_NET_VENDOR_DLINK=y # CONFIG_DL2K is not set # CONFIG_SUNDANCE is not set CONFIG_NET_VENDOR_EMULEX=y # CONFIG_BE2NET is not set # CONFIG_NET_VENDOR_ENGLEDER is not set # CONFIG_NET_VENDOR_EZCHIP is not set # CONFIG_NET_VENDOR_FUNGIBLE is not set # CONFIG_NET_VENDOR_GOOGLE is not set # CONFIG_NET_VENDOR_HISILICON is not set # CONFIG_NET_VENDOR_HUAWEI is not set # CONFIG_NET_VENDOR_INTEL is not set # CONFIG_NET_VENDOR_WANGXUN is not set # CONFIG_JME is not set CONFIG_NET_VENDOR_ADI=y # CONFIG_ADIN1110 is not set # CONFIG_NET_VENDOR_LITEX is not set # CONFIG_NET_VENDOR_MARVELL is not set # CONFIG_NET_VENDOR_MELLANOX is not set # CONFIG_NET_VENDOR_MICREL is not set # CONFIG_NET_VENDOR_MICROCHIP is not set # CONFIG_NET_VENDOR_MICROSEMI is not set # CONFIG_NET_VENDOR_MICROSOFT is not set CONFIG_NET_VENDOR_MYRI=y # CONFIG_MYRI10GE is not set # CONFIG_FEALNX is not set # CONFIG_NET_VENDOR_NI is not set # CONFIG_NET_VENDOR_NATSEMI is not set CONFIG_NET_VENDOR_NETERION=y # CONFIG_S2IO is not set # CONFIG_NET_VENDOR_NETRONOME is not set # CONFIG_NET_VENDOR_NVIDIA is not set CONFIG_NET_VENDOR_OKI=y # CONFIG_ETHOC is not set CONFIG_NET_VENDOR_PACKET_ENGINES=y # CONFIG_HAMACHI is not set # CONFIG_YELLOWFIN is not set # CONFIG_NET_VENDOR_PENSANDO is not set CONFIG_NET_VENDOR_QLOGIC=y # CONFIG_QLA3XXX is not set # CONFIG_QLCNIC is not set # CONFIG_NETXEN_NIC is not set # CONFIG_QED is not set CONFIG_NET_VENDOR_BROCADE=y # CONFIG_BNA is not set # CONFIG_NET_VENDOR_QUALCOMM is not set CONFIG_NET_VENDOR_RDC=y # CONFIG_R6040 is not set CONFIG_NET_VENDOR_REALTEK=y # CONFIG_8139CP is not set # CONFIG_8139TOO is not set CONFIG_R8169=m # CONFIG_NET_VENDOR_RENESAS is not set # CONFIG_NET_VENDOR_ROCKER is not set # CONFIG_NET_VENDOR_SAMSUNG is not set # CONFIG_NET_VENDOR_SEEQ is not set CONFIG_NET_VENDOR_SILAN=y # CONFIG_SC92031 is not set CONFIG_NET_VENDOR_SIS=y # CONFIG_SIS900 is not set # CONFIG_SIS190 is not set # CONFIG_NET_VENDOR_SOLARFLARE is not set # CONFIG_NET_VENDOR_SMSC is not set # CONFIG_NET_VENDOR_SOCIONEXT is not set # CONFIG_NET_VENDOR_STMICRO is not set CONFIG_NET_VENDOR_SUN=y # CONFIG_HAPPYMEAL is not set # CONFIG_SUNGEM is not set # CONFIG_CASSINI is not set # CONFIG_NIU is not set # CONFIG_NET_VENDOR_SYNOPSYS is not set CONFIG_NET_VENDOR_TEHUTI=y # CONFIG_TEHUTI is not set CONFIG_NET_VENDOR_TI=y CONFIG_TI_DAVINCI_MDIO=y # CONFIG_TI_CPSW_PHY_SEL is not set CONFIG_TI_CPSW_PROXY_CLIENT=m CONFIG_TI_K3_AM65_CPSW_NUSS=y CONFIG_TI_K3_AM65_CPSW_SWITCHDEV=y CONFIG_TI_K3_AM65_CPTS=y CONFIG_TI_AM65_CPSW_TAS=y # CONFIG_TLAN is not set CONFIG_TI_RDEV_ETH_SWITCH_VIRT_EMAC=m CONFIG_TI_ICSSG_PRUETH=m CONFIG_TI_ICSS_IEP=m # CONFIG_NET_VENDOR_VERTEXCOM is not set # CONFIG_NET_VENDOR_VIA is not set # CONFIG_NET_VENDOR_WIZNET is not set # CONFIG_NET_VENDOR_XILINX is not set # CONFIG_FDDI is not set # CONFIG_HIPPI is not set CONFIG_PHYLINK=y CONFIG_PHYLIB=y CONFIG_SWPHY=y # CONFIG_LED_TRIGGER_PHY is not set CONFIG_FIXED_PHY=y # CONFIG_SFP is not set # # MII PHY device drivers # # CONFIG_AMD_PHY is not set # CONFIG_ADIN_PHY is not set # CONFIG_ADIN1100_PHY is not set CONFIG_AQUANTIA_PHY=y CONFIG_AX88796B_PHY=m # CONFIG_BROADCOM_PHY is not set # CONFIG_BCM54140_PHY is not set CONFIG_BCM7XXX_PHY=m # CONFIG_BCM84881_PHY is not set # CONFIG_BCM87XX_PHY is not set CONFIG_BCM_NET_PHYLIB=m # CONFIG_CICADA_PHY is not set # CONFIG_CORTINA_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_ICPLUS_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_INTEL_XWAY_PHY is not set # CONFIG_LSI_ET1011C_PHY is not set CONFIG_MARVELL_PHY=m CONFIG_MARVELL_10G_PHY=m # CONFIG_MARVELL_88X2222_PHY is not set # CONFIG_MAXLINEAR_GPHY is not set # CONFIG_MEDIATEK_GE_PHY is not set CONFIG_MICREL_PHY=y CONFIG_MICROCHIP_PHY=m # CONFIG_MICROCHIP_T1_PHY is not set CONFIG_MICROSEMI_PHY=y # CONFIG_MOTORCOMM_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_NXP_C45_TJA11XX_PHY is not set # CONFIG_NXP_TJA11XX_PHY is not set CONFIG_AT803X_PHY=y # CONFIG_QSEMI_PHY is not set CONFIG_REALTEK_PHY=y # CONFIG_RENESAS_PHY is not set # CONFIG_ROCKCHIP_PHY is not set CONFIG_SMSC_PHY=m # CONFIG_STE10XP is not set # CONFIG_TERANETICS_PHY is not set # CONFIG_DP83822_PHY is not set # CONFIG_DP83TC811_PHY is not set # CONFIG_DP83848_PHY is not set CONFIG_DP83867_PHY=y CONFIG_DP83869_PHY=y CONFIG_DP83TD510_PHY=y CONFIG_VITESSE_PHY=y # CONFIG_XILINX_GMII2RGMII is not set # CONFIG_MICREL_KS8995MA is not set # CONFIG_PSE_CONTROLLER is not set CONFIG_CAN_DEV=m CONFIG_CAN_VCAN=m # CONFIG_CAN_VXCAN is not set # CONFIG_CAN_NETLINK=y # CONFIG_CAN_CALC_BITTIMING=y # CONFIG_CAN_RX_OFFLOAD=y # CONFIG_CAN_CAN327 is not set CONFIG_CAN_FLEXCAN=m # CONFIG_CAN_GRCAN is not set # CONFIG_CAN_KVASER_PCIEFD is not set # CONFIG_CAN_SLCAN=m # CONFIG_CAN_XILINXCAN is not set # CONFIG_CAN_C_CAN=m # CONFIG_CAN_C_CAN_PLATFORM=m # CONFIG_CAN_C_CAN_PCI is not set # CONFIG_CAN_CC770 is not set # CONFIG_CAN_CTUCANFD_PCI is not set # CONFIG_CAN_CTUCANFD_PLATFORM is not set # CONFIG_CAN_IFI_CANFD is not set CONFIG_CAN_M_CAN=m CONFIG_CAN_M_CAN_PLATFORM=m # CONFIG_CAN_PEAK_PCIEFD is not set # CONFIG_CAN_SJA1000 is not set # CONFIG_CAN_SOFTING is not set # # CAN SPI interfaces # # CONFIG_CAN_HI311X is not set # CONFIG_CAN_MCP251X=m CONFIG_CAN_MCP251XFD=m # CONFIG_CAN_MCP251XFD_SANITY is not set # end of CAN SPI interfaces # # CAN USB interfaces # # CONFIG_CAN_8DEV_USB=m # CONFIG_CAN_EMS_USB is not set # CONFIG_CAN_ESD_USB is not set # CONFIG_CAN_ETAS_ES58X is not set # CONFIG_CAN_GS_USB=m # CONFIG_CAN_KVASER_USB=m # CONFIG_CAN_MCBA_USB=m # CONFIG_CAN_PEAK_USB=m # CONFIG_CAN_UCAN is not set # end of CAN USB interfaces # CONFIG_CAN_DEBUG_DEVICES is not set CONFIG_MDIO_DEVICE=y CONFIG_MDIO_BUS=y CONFIG_FWNODE_MDIO=y CONFIG_OF_MDIO=y CONFIG_MDIO_DEVRES=y CONFIG_MDIO_BITBANG=y CONFIG_MDIO_BCM_UNIMAC=m CONFIG_MDIO_CAVIUM=y CONFIG_MDIO_GPIO=y # CONFIG_MDIO_HISI_FEMAC is not set # CONFIG_MDIO_MVUSB is not set # CONFIG_MDIO_MSCC_MIIM is not set # CONFIG_MDIO_OCTEON is not set # CONFIG_MDIO_IPQ4019 is not set # CONFIG_MDIO_IPQ8064 is not set CONFIG_MDIO_THUNDER=y # # MDIO Multiplexers # CONFIG_MDIO_BUS_MUX=y # CONFIG_MDIO_BUS_MUX_GPIO is not set CONFIG_MDIO_BUS_MUX_MULTIPLEXER=y CONFIG_MDIO_BUS_MUX_MMIOREG=y # # PCS device drivers # # end of PCS device drivers # CONFIG_PPP is not set # CONFIG_SLIP is not set CONFIG_USB_NET_DRIVERS=y # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set CONFIG_USB_PEGASUS=m CONFIG_USB_RTL8150=m CONFIG_USB_RTL8152=m CONFIG_USB_LAN78XX=m CONFIG_USB_USBNET=m CONFIG_USB_NET_AX8817X=m CONFIG_USB_NET_AX88179_178A=m CONFIG_USB_NET_CDCETHER=m # CONFIG_USB_NET_CDC_EEM is not set CONFIG_USB_NET_CDC_NCM=m # CONFIG_USB_NET_HUAWEI_CDC_NCM is not set CONFIG_USB_NET_CDC_MBIM=m CONFIG_USB_NET_DM9601=m # CONFIG_USB_NET_SR9700 is not set CONFIG_USB_NET_SR9800=m CONFIG_USB_NET_SMSC75XX=m CONFIG_USB_NET_SMSC95XX=m # CONFIG_USB_NET_GL620A is not set CONFIG_USB_NET_NET1080=m CONFIG_USB_NET_PLUSB=m CONFIG_USB_NET_MCS7830=m # CONFIG_USB_NET_RNDIS_HOST is not set CONFIG_USB_NET_CDC_SUBSET_ENABLE=m CONFIG_USB_NET_CDC_SUBSET=m # CONFIG_USB_ALI_M5632 is not set # CONFIG_USB_AN2720 is not set CONFIG_USB_BELKIN=y CONFIG_USB_ARMLINUX=y # CONFIG_USB_EPSON2888 is not set # CONFIG_USB_KC2190 is not set CONFIG_USB_NET_ZAURUS=m # CONFIG_USB_NET_CX82310_ETH is not set # CONFIG_USB_NET_KALMIA is not set CONFIG_USB_NET_QMI_WWAN=m # CONFIG_USB_HSO is not set # CONFIG_USB_NET_INT51X1 is not set # CONFIG_USB_IPHETH is not set CONFIG_USB_SIERRA_NET=m # CONFIG_USB_VL600 is not set # CONFIG_USB_NET_CH9200 is not set # CONFIG_USB_NET_AQC111 is not set CONFIG_USB_RTL8153_ECM=m CONFIG_WLAN=y CONFIG_WLAN_VENDOR_ADMTEK=y # CONFIG_ADM8211 is not set CONFIG_ATH_COMMON=m CONFIG_WLAN_VENDOR_ATH=y # CONFIG_ATH_DEBUG is not set # CONFIG_ATH5K is not set # CONFIG_ATH5K_PCI is not set CONFIG_ATH9K_HW=m CONFIG_ATH9K_COMMON=m CONFIG_ATH9K_BTCOEX_SUPPORT=y # CONFIG_ATH9K is not set CONFIG_ATH9K_HTC=m # CONFIG_ATH9K_HTC_DEBUGFS is not set # CONFIG_CARL9170 is not set # CONFIG_ATH6KL is not set # CONFIG_AR5523 is not set # CONFIG_WIL6210 is not set CONFIG_ATH10K=m CONFIG_ATH10K_CE=y CONFIG_ATH10K_PCI=m # CONFIG_ATH10K_AHB is not set # CONFIG_ATH10K_SDIO is not set # CONFIG_ATH10K_USB is not set # CONFIG_ATH10K_DEBUG is not set # CONFIG_ATH10K_DEBUGFS is not set # CONFIG_ATH10K_TRACING is not set CONFIG_WCN36XX=m # CONFIG_WCN36XX_DEBUGFS is not set CONFIG_ATH11K=m CONFIG_ATH11K_AHB=m CONFIG_ATH11K_PCI=m # CONFIG_ATH11K_DEBUG is not set # CONFIG_ATH11K_TRACING is not set CONFIG_WLAN_VENDOR_ATMEL=y # CONFIG_ATMEL is not set # CONFIG_AT76C50X_USB is not set CONFIG_WLAN_VENDOR_BROADCOM=y # CONFIG_B43 is not set # CONFIG_B43LEGACY is not set CONFIG_BRCMUTIL=m # CONFIG_BRCMSMAC is not set CONFIG_BRCMFMAC=m CONFIG_BRCMFMAC_PROTO_BCDC=y CONFIG_BRCMFMAC_SDIO=y # CONFIG_BRCMFMAC_USB is not set # CONFIG_BRCMFMAC_PCIE is not set # CONFIG_BRCM_TRACING is not set # CONFIG_BRCMDBG is not set CONFIG_WLAN_VENDOR_CISCO=y CONFIG_WLAN_VENDOR_INTEL=y # CONFIG_IPW2100 is not set # CONFIG_IPW2200 is not set # CONFIG_IWL4965 is not set # CONFIG_IWL3945 is not set CONFIG_IWLWIFI=m CONFIG_IWLWIFI_LEDS=y CONFIG_IWLDVM=m CONFIG_IWLMVM=m CONFIG_IWLWIFI_OPMODE_MODULAR=y # # Debugging Options # # CONFIG_IWLWIFI_DEBUG is not set CONFIG_IWLWIFI_DEVICE_TRACING=y # end of Debugging Options CONFIG_WLAN_VENDOR_INTERSIL=y # CONFIG_HOSTAP is not set # CONFIG_HERMES is not set # CONFIG_P54_COMMON is not set CONFIG_WLAN_VENDOR_MARVELL=y # CONFIG_LIBERTAS is not set # CONFIG_LIBERTAS_THINFIRM is not set CONFIG_MWIFIEX=m CONFIG_MWIFIEX_SDIO=m CONFIG_MWIFIEX_PCIE=m # CONFIG_MWIFIEX_USB is not set # CONFIG_MWL8K is not set CONFIG_WLAN_VENDOR_MEDIATEK=y # CONFIG_MT7601U is not set # CONFIG_MT76x0U is not set # CONFIG_MT76x0E is not set # CONFIG_MT76x2E is not set # CONFIG_MT76x2U is not set # CONFIG_MT7603E is not set # CONFIG_MT7615E is not set # CONFIG_MT7663U is not set # CONFIG_MT7663S is not set # CONFIG_MT7915E is not set # CONFIG_MT7921E is not set # CONFIG_MT7921S is not set # CONFIG_MT7921U is not set CONFIG_WLAN_VENDOR_MICROCHIP=y # CONFIG_WILC1000_SDIO is not set # CONFIG_WILC1000_SPI is not set CONFIG_WLAN_VENDOR_PURELIFI=y # CONFIG_PLFXLC is not set CONFIG_WLAN_VENDOR_RALINK=y # CONFIG_RT2X00 is not set CONFIG_WLAN_VENDOR_REALTEK=y # CONFIG_RTL8180 is not set # CONFIG_RTL8187 is not set CONFIG_RTL_CARDS=m # CONFIG_RTL8192CE is not set # CONFIG_RTL8192SE is not set # CONFIG_RTL8192DE is not set # CONFIG_RTL8723AE is not set # CONFIG_RTL8723BE is not set # CONFIG_RTL8188EE is not set # CONFIG_RTL8192EE is not set # CONFIG_RTL8821AE is not set # CONFIG_RTL8192CU is not set # CONFIG_RTL8XXXU is not set # CONFIG_RTW88 is not set # CONFIG_RTW89 is not set CONFIG_WLAN_VENDOR_RSI=y # CONFIG_RSI_91X is not set CONFIG_WLAN_VENDOR_SILABS=y # CONFIG_WFX is not set CONFIG_WLAN_VENDOR_ST=y # CONFIG_CW1200 is not set CONFIG_WLAN_VENDOR_TI=y # CONFIG_WL1251 is not set # CONFIG_WL12XX is not set CONFIG_WL18XX=m CONFIG_WLCORE=m # CONFIG_WLCORE_SPI is not set CONFIG_WLCORE_SDIO=m CONFIG_WILINK_PLATFORM_DATA=y CONFIG_WLAN_VENDOR_ZYDAS=y # CONFIG_USB_ZD1201 is not set # CONFIG_ZD1211RW is not set CONFIG_WLAN_VENDOR_QUANTENNA=y # CONFIG_QTNFMAC_PCIE is not set # CONFIG_MAC80211_HWSIM is not set # CONFIG_USB_NET_RNDIS_WLAN is not set # CONFIG_VIRT_WIFI is not set # CONFIG_WAN is not set # # Wireless WAN # # CONFIG_WWAN is not set # end of Wireless WAN # CONFIG_VMXNET3 is not set # CONFIG_NETDEVSIM is not set CONFIG_NET_FAILOVER=y # CONFIG_ISDN is not set # # Input device support # CONFIG_INPUT=y CONFIG_INPUT_LEDS=y CONFIG_INPUT_FF_MEMLESS=y # CONFIG_INPUT_SPARSEKMAP is not set CONFIG_INPUT_MATRIXKMAP=y CONFIG_INPUT_VIVALDIFMAP=y # # Userland interfaces # # CONFIG_INPUT_MOUSEDEV is not set CONFIG_INPUT_JOYDEV=y CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y CONFIG_KEYBOARD_ADC=m # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ADP5589 is not set CONFIG_KEYBOARD_ATKBD=y # CONFIG_KEYBOARD_QT1050 is not set # CONFIG_KEYBOARD_QT1070 is not set # CONFIG_KEYBOARD_QT2160 is not set # CONFIG_KEYBOARD_DLINK_DIR685 is not set # CONFIG_KEYBOARD_LKKBD is not set CONFIG_KEYBOARD_GPIO=y # CONFIG_KEYBOARD_GPIO_POLLED is not set # CONFIG_KEYBOARD_TCA6416 is not set # CONFIG_KEYBOARD_TCA8418 is not set # CONFIG_KEYBOARD_MATRIX is not set # CONFIG_KEYBOARD_LM8323 is not set # CONFIG_KEYBOARD_LM8333 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_MCS is not set # CONFIG_KEYBOARD_MPR121 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set # CONFIG_KEYBOARD_PINEPHONE is not set # CONFIG_KEYBOARD_SAMSUNG is not set # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_OMAP4 is not set # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set # CONFIG_KEYBOARD_XTKBD is not set # CONFIG_KEYBOARD_CAP11XX is not set # CONFIG_KEYBOARD_BCM is not set # CONFIG_KEYBOARD_MTK_PMIC is not set # CONFIG_KEYBOARD_CYPRESS_SF is not set CONFIG_INPUT_MOUSE=y CONFIG_MOUSE_PS2=y CONFIG_MOUSE_PS2_ALPS=y CONFIG_MOUSE_PS2_BYD=y CONFIG_MOUSE_PS2_LOGIPS2PP=y CONFIG_MOUSE_PS2_SYNAPTICS=y CONFIG_MOUSE_PS2_SYNAPTICS_SMBUS=y CONFIG_MOUSE_PS2_CYPRESS=y CONFIG_MOUSE_PS2_TRACKPOINT=y # CONFIG_MOUSE_PS2_ELANTECH is not set # CONFIG_MOUSE_PS2_SENTELIC is not set # CONFIG_MOUSE_PS2_TOUCHKIT is not set CONFIG_MOUSE_PS2_FOCALTECH=y CONFIG_MOUSE_PS2_SMBUS=y # CONFIG_MOUSE_SERIAL is not set # CONFIG_MOUSE_APPLETOUCH is not set # CONFIG_MOUSE_BCM5974 is not set # CONFIG_MOUSE_CYAPA is not set # CONFIG_MOUSE_ELAN_I2C is not set # CONFIG_MOUSE_VSXXXAA is not set # CONFIG_MOUSE_GPIO is not set # CONFIG_MOUSE_SYNAPTICS_I2C is not set # CONFIG_MOUSE_SYNAPTICS_USB is not set CONFIG_INPUT_JOYSTICK=y # CONFIG_JOYSTICK_ANALOG is not set # CONFIG_JOYSTICK_A3D is not set # CONFIG_JOYSTICK_ADC is not set CONFIG_JOYSTICK_ADI=y # CONFIG_JOYSTICK_COBRA is not set # CONFIG_JOYSTICK_GF2K is not set # CONFIG_JOYSTICK_GRIP is not set # CONFIG_JOYSTICK_GRIP_MP is not set # CONFIG_JOYSTICK_GUILLEMOT is not set # CONFIG_JOYSTICK_INTERACT is not set # CONFIG_JOYSTICK_SIDEWINDER is not set # CONFIG_JOYSTICK_TMDC is not set # CONFIG_JOYSTICK_IFORCE is not set # CONFIG_JOYSTICK_WARRIOR is not set # CONFIG_JOYSTICK_MAGELLAN is not set # CONFIG_JOYSTICK_SPACEORB is not set # CONFIG_JOYSTICK_SPACEBALL is not set # CONFIG_JOYSTICK_STINGER is not set # CONFIG_JOYSTICK_TWIDJOY is not set # CONFIG_JOYSTICK_ZHENHUA is not set # CONFIG_JOYSTICK_AS5011 is not set # CONFIG_JOYSTICK_JOYDUMP is not set # CONFIG_JOYSTICK_XPAD is not set # CONFIG_JOYSTICK_PSXPAD_SPI is not set # CONFIG_JOYSTICK_PXRC is not set # CONFIG_JOYSTICK_QWIIC is not set # CONFIG_JOYSTICK_FSIA6B is not set # CONFIG_JOYSTICK_SENSEHAT is not set # CONFIG_INPUT_TABLET is not set CONFIG_INPUT_TOUCHSCREEN=y # CONFIG_TOUCHSCREEN_ADS7846 is not set # CONFIG_TOUCHSCREEN_AD7877 is not set # CONFIG_TOUCHSCREEN_AD7879 is not set # CONFIG_TOUCHSCREEN_ADC is not set # CONFIG_TOUCHSCREEN_AR1021_I2C is not set CONFIG_TOUCHSCREEN_ATMEL_MXT=m # CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set # CONFIG_TOUCHSCREEN_BU21013 is not set # CONFIG_TOUCHSCREEN_BU21029 is not set # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set # CONFIG_TOUCHSCREEN_CY8CTMA140 is not set # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set # CONFIG_TOUCHSCREEN_DYNAPRO is not set # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_EGALAX is not set # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set # CONFIG_TOUCHSCREEN_EXC3000 is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set CONFIG_TOUCHSCREEN_GOODIX=m # CONFIG_TOUCHSCREEN_HIDEEP is not set # CONFIG_TOUCHSCREEN_HYCON_HY46XX is not set CONFIG_TOUCHSCREEN_ILI210X=m CONFIG_TOUCHSCREEN_ILITEK=m # CONFIG_TOUCHSCREEN_S6SY761 is not set # CONFIG_TOUCHSCREEN_GUNZE is not set # CONFIG_TOUCHSCREEN_EKTF2127 is not set # CONFIG_TOUCHSCREEN_ELAN is not set # CONFIG_TOUCHSCREEN_ELO is not set # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set # CONFIG_TOUCHSCREEN_WACOM_I2C is not set # CONFIG_TOUCHSCREEN_MAX11801 is not set # CONFIG_TOUCHSCREEN_MCS5000 is not set # CONFIG_TOUCHSCREEN_MMS114 is not set # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set # CONFIG_TOUCHSCREEN_MSG2638 is not set # CONFIG_TOUCHSCREEN_MTOUCH is not set # CONFIG_TOUCHSCREEN_IMAGIS is not set # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set # CONFIG_TOUCHSCREEN_INEXIO is not set # CONFIG_TOUCHSCREEN_MK712 is not set # CONFIG_TOUCHSCREEN_PENMOUNT is not set CONFIG_TOUCHSCREEN_EDT_FT5X06=m # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set # CONFIG_TOUCHSCREEN_TOUCHWIN is not set # CONFIG_TOUCHSCREEN_TI_AM335X_TSC is not set # CONFIG_TOUCHSCREEN_PIXCIR is not set # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC_SERIO is not set # CONFIG_TOUCHSCREEN_TSC2004 is not set # CONFIG_TOUCHSCREEN_TSC2005 is not set # CONFIG_TOUCHSCREEN_TSC2007 is not set # CONFIG_TOUCHSCREEN_RM_TS is not set # CONFIG_TOUCHSCREEN_SILEAD is not set # CONFIG_TOUCHSCREEN_SIS_I2C is not set # CONFIG_TOUCHSCREEN_ST1232 is not set # CONFIG_TOUCHSCREEN_STMFTS is not set # CONFIG_TOUCHSCREEN_SUR40 is not set # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set # CONFIG_TOUCHSCREEN_SX8654 is not set # CONFIG_TOUCHSCREEN_TPS6507X is not set # CONFIG_TOUCHSCREEN_ZET6223 is not set # CONFIG_TOUCHSCREEN_ZFORCE is not set # CONFIG_TOUCHSCREEN_COLIBRI_VF50 is not set # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set # CONFIG_TOUCHSCREEN_IQS5XX is not set # CONFIG_TOUCHSCREEN_ZINITIX is not set CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_ATMEL_CAPTOUCH is not set # CONFIG_INPUT_BMA150 is not set # CONFIG_INPUT_E3X0_BUTTON is not set # CONFIG_INPUT_MMA8450 is not set # CONFIG_INPUT_GPIO_BEEPER is not set # CONFIG_INPUT_GPIO_DECODER is not set # CONFIG_INPUT_GPIO_VIBRA is not set # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_KXTJ9 is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set # CONFIG_INPUT_REGULATOR_HAPTIC is not set CONFIG_INPUT_TPS65219_PWRBUTTON=m # CONFIG_INPUT_AXP20X_PEK is not set CONFIG_INPUT_UINPUT=y # CONFIG_INPUT_PCF8574 is not set CONFIG_INPUT_PWM_BEEPER=m CONFIG_INPUT_PWM_VIBRA=m # CONFIG_INPUT_RK805_PWRKEY is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set # CONFIG_INPUT_DA7280_HAPTICS is not set # CONFIG_INPUT_ADXL34X is not set # CONFIG_INPUT_IBM_PANEL is not set # CONFIG_INPUT_IMS_PCU is not set # CONFIG_INPUT_IQS269A is not set # CONFIG_INPUT_IQS626A is not set # CONFIG_INPUT_IQS7222 is not set # CONFIG_INPUT_CMA3000 is not set # CONFIG_INPUT_DRV260X_HAPTICS is not set # CONFIG_INPUT_DRV2665_HAPTICS is not set # CONFIG_INPUT_DRV2667_HAPTICS is not set # CONFIG_RMI4_CORE is not set # # Hardware I/O ports # CONFIG_SERIO=y # CONFIG_SERIO_SERPORT is not set CONFIG_SERIO_AMBAKMI=y # CONFIG_SERIO_PCIPS2 is not set CONFIG_SERIO_LIBPS2=y # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_SERIO_ARC_PS2 is not set # CONFIG_SERIO_APBPS2 is not set # CONFIG_SERIO_GPIO_PS2 is not set # CONFIG_USERIO is not set CONFIG_GAMEPORT=y # CONFIG_GAMEPORT_NS558 is not set # CONFIG_GAMEPORT_L4 is not set # CONFIG_GAMEPORT_EMU10K1 is not set # CONFIG_GAMEPORT_FM801 is not set # end of Hardware I/O ports # end of Input device support # # Character devices # CONFIG_TTY=y CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_VT_CONSOLE_SLEEP=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y CONFIG_UNIX98_PTYS=y CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=16 CONFIG_LDISC_AUTOLOAD=y # # Serial drivers # CONFIG_SERIAL_EARLYCON=y CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y CONFIG_SERIAL_8250_16550A_VARIANTS=y # CONFIG_SERIAL_8250_FINTEK is not set CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_EXAR=y CONFIG_SERIAL_8250_NR_UARTS=12 CONFIG_SERIAL_8250_RUNTIME_UARTS=12 CONFIG_SERIAL_8250_EXTENDED=y # CONFIG_SERIAL_8250_MANY_PORTS is not set CONFIG_SERIAL_8250_SHARE_IRQ=y # CONFIG_SERIAL_8250_DETECT_IRQ is not set # CONFIG_SERIAL_8250_RSA is not set CONFIG_SERIAL_8250_FSL=y # CONFIG_SERIAL_8250_DW is not set # CONFIG_SERIAL_8250_RT288X is not set CONFIG_SERIAL_8250_OMAP=y CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y CONFIG_SERIAL_8250_PERICOM=y CONFIG_SERIAL_8250_PRUSS=m CONFIG_SERIAL_OF_PLATFORM=y # # Non-8250 serial port support # # CONFIG_SERIAL_AMBA_PL010 is not set # CONFIG_SERIAL_AMBA_PL011 is not set # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX310X is not set # CONFIG_SERIAL_UARTLITE is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_JSM is not set # CONFIG_SERIAL_SIFIVE is not set # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_SC16IS7XX is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_XILINX_PS_UART is not set # CONFIG_SERIAL_ARC is not set # CONFIG_SERIAL_RP2 is not set CONFIG_SERIAL_FSL_LPUART=y CONFIG_SERIAL_FSL_LPUART_CONSOLE=y CONFIG_SERIAL_FSL_LINFLEXUART=y CONFIG_SERIAL_FSL_LINFLEXUART_CONSOLE=y # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set # CONFIG_SERIAL_SPRD is not set # end of Serial drivers CONFIG_SERIAL_MCTRL_GPIO=y # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_N_GSM is not set # CONFIG_NOZOMI is not set # CONFIG_NULL_TTY is not set CONFIG_HVC_DRIVER=y # CONFIG_HVC_DCC is not set # CONFIG_RPMSG_TTY is not set CONFIG_SERIAL_DEV_BUS=y CONFIG_SERIAL_DEV_CTRL_TTYPORT=y # CONFIG_TTY_PRINTK is not set CONFIG_VIRTIO_CONSOLE=y CONFIG_IPMI_HANDLER=m CONFIG_IPMI_DMI_DECODE=y CONFIG_IPMI_PLAT_DATA=y # CONFIG_IPMI_PANIC_EVENT is not set CONFIG_IPMI_DEVICE_INTERFACE=m CONFIG_IPMI_SI=m # CONFIG_IPMI_SSIF is not set # CONFIG_IPMI_IPMB is not set # CONFIG_IPMI_WATCHDOG is not set # CONFIG_IPMI_POWEROFF is not set # CONFIG_IPMB_DEVICE_INTERFACE is not set CONFIG_HW_RANDOM=m # CONFIG_HW_RANDOM_TIMERIOMEM is not set # CONFIG_HW_RANDOM_BA431 is not set CONFIG_HW_RANDOM_OMAP=m # CONFIG_HW_RANDOM_VIRTIO is not set CONFIG_HW_RANDOM_OPTEE=m # CONFIG_HW_RANDOM_CCTRNG is not set # CONFIG_HW_RANDOM_XIPHERA is not set # CONFIG_HW_RANDOM_ARM_SMCCC_TRNG is not set # CONFIG_HW_RANDOM_CN10K is not set # CONFIG_APPLICOM is not set CONFIG_DEVMEM=y CONFIG_DEVPORT=y CONFIG_TCG_TPM=y # CONFIG_TCG_TIS is not set # CONFIG_TCG_TIS_SPI is not set # CONFIG_TCG_TIS_I2C is not set # CONFIG_TCG_TIS_I2C_CR50 is not set # CONFIG_TCG_TIS_I2C_ATMEL is not set CONFIG_TCG_TIS_I2C_INFINEON=y # CONFIG_TCG_TIS_I2C_NUVOTON is not set # CONFIG_TCG_ATMEL is not set # CONFIG_TCG_VTPM_PROXY is not set # CONFIG_TCG_FTPM_TEE is not set # CONFIG_TCG_TIS_ST33ZP24_I2C is not set # CONFIG_TCG_TIS_ST33ZP24_SPI is not set # CONFIG_XILLYBUS is not set # CONFIG_XILLYUSB is not set CONFIG_RANDOM_TRUST_CPU=y CONFIG_RANDOM_TRUST_BOOTLOADER=y # end of Character devices # # I2C support # CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y CONFIG_I2C_MUX=y # # Multiplexer I2C Chip support # # CONFIG_I2C_ARB_GPIO_CHALLENGE is not set # CONFIG_I2C_MUX_GPIO is not set # CONFIG_I2C_MUX_GPMUX is not set # CONFIG_I2C_MUX_LTC4306 is not set # CONFIG_I2C_MUX_PCA9541 is not set CONFIG_I2C_MUX_PCA954x=y # CONFIG_I2C_MUX_PINCTRL is not set # CONFIG_I2C_MUX_REG is not set # CONFIG_I2C_DEMUX_PINCTRL is not set # CONFIG_I2C_MUX_MLXCPLD is not set # end of Multiplexer I2C Chip support CONFIG_I2C_ATR=m CONFIG_I2C_HELPER_AUTO=y CONFIG_I2C_ALGOBIT=m # # I2C Hardware Bus support # # # PC SMBus host controller drivers # # CONFIG_I2C_ALI1535 is not set # CONFIG_I2C_ALI1563 is not set # CONFIG_I2C_ALI15X3 is not set # CONFIG_I2C_AMD756 is not set # CONFIG_I2C_AMD8111 is not set # CONFIG_I2C_I801 is not set # CONFIG_I2C_ISCH is not set # CONFIG_I2C_PIIX4 is not set # CONFIG_I2C_NFORCE2 is not set # CONFIG_I2C_NVIDIA_GPU is not set # CONFIG_I2C_SIS5595 is not set # CONFIG_I2C_SIS630 is not set # CONFIG_I2C_SIS96X is not set # CONFIG_I2C_VIA is not set # CONFIG_I2C_VIAPRO is not set # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_CADENCE is not set # CONFIG_I2C_CBUS_GPIO is not set # CONFIG_I2C_DESIGNWARE_PLATFORM is not set # CONFIG_I2C_DESIGNWARE_PCI is not set # CONFIG_I2C_EMEV2 is not set CONFIG_I2C_GPIO=m # CONFIG_I2C_GPIO_FAULT_INJECTOR is not set # CONFIG_I2C_NOMADIK is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_OMAP=y # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_RK3X is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_THUNDERX is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set # CONFIG_I2C_CP2615 is not set # CONFIG_I2C_PCI1XXXX is not set # CONFIG_I2C_ROBOTFUZZ_OSIF is not set # CONFIG_I2C_TAOS_EVM is not set CONFIG_I2C_TINY_USB=y # # Other I2C/SMBus bus drivers # # CONFIG_I2C_VIRTIO is not set # end of I2C Hardware Bus support # CONFIG_I2C_STUB is not set CONFIG_I2C_SLAVE=y # CONFIG_I2C_SLAVE_EEPROM is not set # CONFIG_I2C_SLAVE_TESTUNIT is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # end of I2C support # CONFIG_I3C is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y CONFIG_SPI_MEM=y # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_AXI_SPI_ENGINE is not set # CONFIG_SPI_BITBANG is not set # CONFIG_SPI_CADENCE is not set CONFIG_SPI_CADENCE_QUADSPI=y # CONFIG_SPI_CADENCE_XSPI is not set # CONFIG_SPI_DESIGNWARE is not set # CONFIG_SPI_NXP_FLEXSPI is not set # CONFIG_SPI_GPIO is not set # CONFIG_SPI_FSL_SPI is not set # CONFIG_SPI_MICROCHIP_CORE is not set # CONFIG_SPI_MICROCHIP_CORE_QSPI is not set # CONFIG_SPI_OC_TINY is not set CONFIG_SPI_OMAP24XX=m # CONFIG_SPI_PL022 is not set # CONFIG_SPI_PXA2XX is not set # CONFIG_SPI_ROCKCHIP is not set # CONFIG_SPI_SC18IS602 is not set # CONFIG_SPI_SIFIVE is not set # CONFIG_SPI_MXIC is not set # CONFIG_SPI_THUNDERX is not set # CONFIG_SPI_XCOMM is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_ZYNQMP_GQSPI is not set # CONFIG_SPI_AMD is not set # # SPI Multiplexer support # # CONFIG_SPI_MUX is not set # # SPI Protocol Masters # CONFIG_SPI_SPIDEV=m # CONFIG_SPI_LOOPBACK_TEST is not set # CONFIG_SPI_TLE62X0 is not set CONFIG_SPI_SLAVE=y # CONFIG_SPI_SLAVE_TIME is not set # CONFIG_SPI_SLAVE_SYSTEM_CONTROL is not set CONFIG_SPI_DYNAMIC=y # CONFIG_SPMI is not set # CONFIG_HSI is not set CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # # PPS clients support # # CONFIG_PPS_CLIENT_KTIMER is not set # CONFIG_PPS_CLIENT_LDISC is not set # CONFIG_PPS_CLIENT_GPIO is not set # # PPS generators support # # # PTP clock support # CONFIG_PTP_1588_CLOCK=y CONFIG_PTP_1588_CLOCK_OPTIONAL=y # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # CONFIG_PTP_1588_CLOCK_KVM=y # CONFIG_PTP_1588_CLOCK_IDT82P33 is not set # CONFIG_PTP_1588_CLOCK_IDTCM is not set # CONFIG_PTP_1588_CLOCK_OCP is not set # end of PTP clock support CONFIG_PINCTRL=y CONFIG_GENERIC_PINCTRL_GROUPS=y CONFIG_PINMUX=y CONFIG_GENERIC_PINMUX_FUNCTIONS=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set # CONFIG_PINCTRL_AXP209 is not set # CONFIG_PINCTRL_CY8C95X0 is not set # CONFIG_PINCTRL_MAX77620 is not set # CONFIG_PINCTRL_MCP23S08 is not set # CONFIG_PINCTRL_MICROCHIP_SGPIO is not set # CONFIG_PINCTRL_OCELOT is not set # CONFIG_PINCTRL_RK805 is not set CONFIG_PINCTRL_SINGLE=y # CONFIG_PINCTRL_STMFX is not set # CONFIG_PINCTRL_SX150X is not set CONFIG_PINCTRL_TPS6594=y # # Renesas pinctrl drivers # # end of Renesas pinctrl drivers CONFIG_GPIOLIB=y CONFIG_GPIOLIB_FASTPATH_LIMIT=512 CONFIG_OF_GPIO=y CONFIG_GPIOLIB_IRQCHIP=y # CONFIG_DEBUG_GPIO is not set # CONFIG_GPIO_SYSFS is not set CONFIG_GPIO_CDEV=y CONFIG_GPIO_CDEV_V1=y CONFIG_GPIO_GENERIC=y # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set # CONFIG_GPIO_ALTERA is not set # CONFIG_GPIO_CADENCE is not set CONFIG_GPIO_DAVINCI=y # CONFIG_GPIO_DWAPB is not set # CONFIG_GPIO_EXAR is not set # CONFIG_GPIO_FTGPIO010 is not set CONFIG_GPIO_GENERIC_PLATFORM=y # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_HLWD is not set # CONFIG_GPIO_LOGICVC is not set # CONFIG_GPIO_MB86S7X is not set # CONFIG_GPIO_PL061 is not set # CONFIG_GPIO_SIFIVE is not set # CONFIG_GPIO_SYSCON is not set # CONFIG_GPIO_XGENE is not set # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_AMD_FCH is not set # end of Memory mapped GPIO drivers # # I2C GPIO expanders # # CONFIG_GPIO_ADNP is not set # CONFIG_GPIO_GW_PLD is not set # CONFIG_GPIO_MAX7300 is not set CONFIG_GPIO_MAX732X=y # CONFIG_GPIO_MAX732X_IRQ is not set CONFIG_GPIO_PCA953X=y CONFIG_GPIO_PCA953X_IRQ=y # CONFIG_GPIO_PCA9570 is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_TPIC2810 is not set # end of I2C GPIO expanders # # MFD GPIO expanders # CONFIG_GPIO_BD9571MWV=m CONFIG_GPIO_MAX77620=y # CONFIG_GPIO_WM8994 is not set # end of MFD GPIO expanders # # PCI GPIO expanders # # CONFIG_GPIO_BT8XX is not set # CONFIG_GPIO_PCI_IDIO_16 is not set # CONFIG_GPIO_PCIE_IDIO_24 is not set # CONFIG_GPIO_RDC321X is not set # end of PCI GPIO expanders # # SPI GPIO expanders # # CONFIG_GPIO_74X164 is not set # CONFIG_GPIO_MAX3191X is not set # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MC33880 is not set # CONFIG_GPIO_PISOSR is not set # CONFIG_GPIO_XRA1403 is not set # end of SPI GPIO expanders # # USB GPIO expanders # # end of USB GPIO expanders # # Virtual GPIO drivers # # CONFIG_GPIO_AGGREGATOR is not set # CONFIG_GPIO_MOCKUP is not set # CONFIG_GPIO_VIRTIO is not set # CONFIG_GPIO_SIM is not set # end of Virtual GPIO drivers # CONFIG_W1 is not set CONFIG_POWER_RESET=y CONFIG_POWER_RESET_BRCMSTB=y # CONFIG_POWER_RESET_GPIO is not set # CONFIG_POWER_RESET_GPIO_RESTART is not set # CONFIG_POWER_RESET_LTC2952 is not set # CONFIG_POWER_RESET_MT6323 is not set # CONFIG_POWER_RESET_REGULATOR is not set # CONFIG_POWER_RESET_RESTART is not set # CONFIG_POWER_RESET_XGENE is not set CONFIG_POWER_RESET_SYSCON=y # CONFIG_POWER_RESET_SYSCON_POWEROFF is not set CONFIG_REBOOT_MODE=y CONFIG_SYSCON_REBOOT_MODE=y # CONFIG_NVMEM_REBOOT_MODE is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set CONFIG_POWER_SUPPLY_HWMON=y # CONFIG_PDA_POWER is not set # CONFIG_GENERIC_ADC_BATTERY is not set # CONFIG_IP5XXX_POWER is not set # CONFIG_TEST_POWER is not set # CONFIG_CHARGER_ADP5061 is not set # CONFIG_BATTERY_CW2015 is not set # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set # CONFIG_BATTERY_SAMSUNG_SDI is not set CONFIG_BATTERY_SBS=m # CONFIG_CHARGER_SBS is not set # CONFIG_MANAGER_SBS is not set CONFIG_BATTERY_BQ27XXX=y CONFIG_BATTERY_BQ27XXX_I2C=y # CONFIG_BATTERY_BQ27XXX_DT_UPDATES_NVM is not set # CONFIG_AXP20X_POWER is not set # CONFIG_BATTERY_MAX17040 is not set CONFIG_BATTERY_MAX17042=m # CONFIG_CHARGER_ISP1704 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_MANAGER is not set # CONFIG_CHARGER_LT3651 is not set # CONFIG_CHARGER_LTC4162L is not set # CONFIG_CHARGER_DETECTOR_MAX14656 is not set # CONFIG_CHARGER_MAX77976 is not set CONFIG_CHARGER_MT6360=m # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24190 is not set # CONFIG_CHARGER_BQ24257 is not set # CONFIG_CHARGER_BQ24735 is not set # CONFIG_CHARGER_BQ2515X is not set CONFIG_CHARGER_BQ25890=m CONFIG_CHARGER_BQ25980=m # CONFIG_CHARGER_BQ256XX is not set # CONFIG_CHARGER_RK817 is not set # CONFIG_CHARGER_SMB347 is not set # CONFIG_BATTERY_GAUGE_LTC2941 is not set # CONFIG_BATTERY_GOLDFISH is not set # CONFIG_BATTERY_RT5033 is not set # CONFIG_CHARGER_RT9455 is not set # CONFIG_CHARGER_UCS1002 is not set # CONFIG_CHARGER_BD99954 is not set # CONFIG_BATTERY_UG3105 is not set CONFIG_HWMON=y # CONFIG_HWMON_DEBUG_CHIP is not set # # Native drivers # # CONFIG_SENSORS_AD7314 is not set # CONFIG_SENSORS_AD7414 is not set # CONFIG_SENSORS_AD7418 is not set # CONFIG_SENSORS_ADM1025 is not set # CONFIG_SENSORS_ADM1026 is not set # CONFIG_SENSORS_ADM1029 is not set # CONFIG_SENSORS_ADM1031 is not set # CONFIG_SENSORS_ADM1177 is not set # CONFIG_SENSORS_ADM9240 is not set # CONFIG_SENSORS_ADT7310 is not set # CONFIG_SENSORS_ADT7410 is not set # CONFIG_SENSORS_ADT7411 is not set # CONFIG_SENSORS_ADT7462 is not set # CONFIG_SENSORS_ADT7470 is not set # CONFIG_SENSORS_ADT7475 is not set # CONFIG_SENSORS_AHT10 is not set # CONFIG_SENSORS_AQUACOMPUTER_D5NEXT is not set # CONFIG_SENSORS_AS370 is not set # CONFIG_SENSORS_ASC7621 is not set # CONFIG_SENSORS_AXI_FAN_CONTROL is not set CONFIG_SENSORS_ARM_SCMI=y # CONFIG_SENSORS_ATXP1 is not set # CONFIG_SENSORS_CORSAIR_CPRO is not set # CONFIG_SENSORS_CORSAIR_PSU is not set # CONFIG_SENSORS_DRIVETEMP is not set # CONFIG_SENSORS_DS620 is not set # CONFIG_SENSORS_DS1621 is not set # CONFIG_SENSORS_I5K_AMB is not set # CONFIG_SENSORS_F71805F is not set # CONFIG_SENSORS_F71882FG is not set # CONFIG_SENSORS_F75375S is not set # CONFIG_SENSORS_FTSTEUTATES is not set # CONFIG_SENSORS_GL518SM is not set # CONFIG_SENSORS_GL520SM is not set # CONFIG_SENSORS_G760A is not set # CONFIG_SENSORS_G762 is not set CONFIG_SENSORS_GPIO_FAN=m # CONFIG_SENSORS_HIH6130 is not set # CONFIG_SENSORS_IBMAEM is not set # CONFIG_SENSORS_IBMPEX is not set # CONFIG_SENSORS_IIO_HWMON is not set # CONFIG_SENSORS_IT87 is not set CONFIG_SENSORS_JC42=m # CONFIG_SENSORS_POWR1220 is not set # CONFIG_SENSORS_LINEAGE is not set # CONFIG_SENSORS_LTC2945 is not set # CONFIG_SENSORS_LTC2947_I2C is not set # CONFIG_SENSORS_LTC2947_SPI is not set # CONFIG_SENSORS_LTC2990 is not set # CONFIG_SENSORS_LTC2992 is not set # CONFIG_SENSORS_LTC4151 is not set # CONFIG_SENSORS_LTC4215 is not set # CONFIG_SENSORS_LTC4222 is not set # CONFIG_SENSORS_LTC4245 is not set # CONFIG_SENSORS_LTC4260 is not set # CONFIG_SENSORS_LTC4261 is not set # CONFIG_SENSORS_MAX1111 is not set # CONFIG_SENSORS_MAX127 is not set # CONFIG_SENSORS_MAX16065 is not set # CONFIG_SENSORS_MAX1619 is not set # CONFIG_SENSORS_MAX1668 is not set # CONFIG_SENSORS_MAX197 is not set # CONFIG_SENSORS_MAX31722 is not set # CONFIG_SENSORS_MAX31730 is not set # CONFIG_SENSORS_MAX31760 is not set # CONFIG_SENSORS_MAX6620 is not set # CONFIG_SENSORS_MAX6621 is not set # CONFIG_SENSORS_MAX6639 is not set # CONFIG_SENSORS_MAX6650 is not set # CONFIG_SENSORS_MAX6697 is not set # CONFIG_SENSORS_MAX31790 is not set # CONFIG_SENSORS_MCP3021 is not set # CONFIG_SENSORS_TC654 is not set # CONFIG_SENSORS_TPS23861 is not set # CONFIG_SENSORS_MR75203 is not set # CONFIG_SENSORS_ADCXX is not set # CONFIG_SENSORS_LM63 is not set # CONFIG_SENSORS_LM70 is not set # CONFIG_SENSORS_LM73 is not set CONFIG_SENSORS_LM75=m # CONFIG_SENSORS_LM77 is not set # CONFIG_SENSORS_LM78 is not set # CONFIG_SENSORS_LM80 is not set # CONFIG_SENSORS_LM83 is not set # CONFIG_SENSORS_LM85 is not set # CONFIG_SENSORS_LM87 is not set CONFIG_SENSORS_LM90=m # CONFIG_SENSORS_LM92 is not set # CONFIG_SENSORS_LM93 is not set # CONFIG_SENSORS_LM95234 is not set # CONFIG_SENSORS_LM95241 is not set # CONFIG_SENSORS_LM95245 is not set # CONFIG_SENSORS_PC87360 is not set # CONFIG_SENSORS_PC87427 is not set # CONFIG_SENSORS_NTC_THERMISTOR is not set # CONFIG_SENSORS_NCT6683 is not set # CONFIG_SENSORS_NCT6775 is not set # CONFIG_SENSORS_NCT6775_I2C is not set # CONFIG_SENSORS_NCT7802 is not set # CONFIG_SENSORS_NCT7904 is not set # CONFIG_SENSORS_NPCM7XX is not set # CONFIG_SENSORS_NZXT_KRAKEN2 is not set # CONFIG_SENSORS_NZXT_SMART2 is not set # CONFIG_SENSORS_OCC_P8_I2C is not set # CONFIG_SENSORS_PCF8591 is not set # CONFIG_PMBUS is not set CONFIG_SENSORS_PWM_FAN=m # CONFIG_SENSORS_SBTSI is not set # CONFIG_SENSORS_SBRMI is not set # CONFIG_SENSORS_SHT15 is not set # CONFIG_SENSORS_SHT21 is not set # CONFIG_SENSORS_SHT3x is not set # CONFIG_SENSORS_SHT4x is not set # CONFIG_SENSORS_SHTC1 is not set # CONFIG_SENSORS_SIS5595 is not set # CONFIG_SENSORS_DME1737 is not set # CONFIG_SENSORS_EMC1403 is not set # CONFIG_SENSORS_EMC2103 is not set # CONFIG_SENSORS_EMC2305 is not set # CONFIG_SENSORS_EMC6W201 is not set # CONFIG_SENSORS_SMSC47M1 is not set # CONFIG_SENSORS_SMSC47M192 is not set # CONFIG_SENSORS_SMSC47B397 is not set # CONFIG_SENSORS_SCH5627 is not set # CONFIG_SENSORS_SCH5636 is not set # CONFIG_SENSORS_STTS751 is not set # CONFIG_SENSORS_SMM665 is not set # CONFIG_SENSORS_ADC128D818 is not set # CONFIG_SENSORS_ADS7828 is not set # CONFIG_SENSORS_ADS7871 is not set # CONFIG_SENSORS_AMC6821 is not set # CONFIG_SENSORS_INA209 is not set CONFIG_SENSORS_INA2XX=m # CONFIG_SENSORS_INA238 is not set CONFIG_SENSORS_INA3221=m # CONFIG_SENSORS_TC74 is not set # CONFIG_SENSORS_THMC50 is not set # CONFIG_SENSORS_TMP102 is not set # CONFIG_SENSORS_TMP103 is not set # CONFIG_SENSORS_TMP108 is not set # CONFIG_SENSORS_TMP401 is not set # CONFIG_SENSORS_TMP421 is not set # CONFIG_SENSORS_TMP464 is not set # CONFIG_SENSORS_TMP513 is not set # CONFIG_SENSORS_VIA686A is not set # CONFIG_SENSORS_VT1211 is not set # CONFIG_SENSORS_VT8231 is not set # CONFIG_SENSORS_W83773G is not set # CONFIG_SENSORS_W83781D is not set # CONFIG_SENSORS_W83791D is not set # CONFIG_SENSORS_W83792D is not set # CONFIG_SENSORS_W83793 is not set # CONFIG_SENSORS_W83795 is not set # CONFIG_SENSORS_W83L785TS is not set # CONFIG_SENSORS_W83L786NG is not set # CONFIG_SENSORS_W83627HF is not set # CONFIG_SENSORS_W83627EHF is not set CONFIG_THERMAL=y # CONFIG_THERMAL_NETLINK is not set # CONFIG_THERMAL_STATISTICS is not set CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0 CONFIG_THERMAL_HWMON=y CONFIG_THERMAL_OF=y # CONFIG_THERMAL_WRITABLE_TRIPS is not set CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set # CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set # CONFIG_THERMAL_GOV_FAIR_SHARE is not set CONFIG_THERMAL_GOV_STEP_WISE=y # CONFIG_THERMAL_GOV_BANG_BANG is not set # CONFIG_THERMAL_GOV_USER_SPACE is not set CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y CONFIG_CPU_THERMAL=y CONFIG_CPU_FREQ_THERMAL=y CONFIG_DEVFREQ_THERMAL=y CONFIG_THERMAL_EMULATION=y # CONFIG_THERMAL_MMIO is not set CONFIG_K3_THERMAL=m # CONFIG_MAX77620_THERMAL is not set # CONFIG_GENERIC_ADC_THERMAL is not set CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y # CONFIG_WATCHDOG_NOWAYOUT is not set CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y CONFIG_WATCHDOG_OPEN_TIMEOUT=0 # CONFIG_WATCHDOG_SYSFS is not set # CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set # # Watchdog Pretimeout Governors # # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_GPIO_WATCHDOG is not set # CONFIG_XILINX_WATCHDOG is not set # CONFIG_ZIIRAVE_WATCHDOG is not set # CONFIG_ARM_SP805_WATCHDOG is not set # CONFIG_ARM_SBSA_WATCHDOG is not set # CONFIG_CADENCE_WATCHDOG is not set # CONFIG_DW_WATCHDOG is not set CONFIG_K3_RTI_WATCHDOG=m # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_MAX77620_WATCHDOG is not set CONFIG_ARM_SMC_WATCHDOG=y # CONFIG_ALIM7101_WDT is not set # CONFIG_I6300ESB_WDT is not set # CONFIG_HP_WATCHDOG is not set # CONFIG_MEN_A21_WDT is not set # # PCI-based Watchdog Cards # # CONFIG_PCIPCWATCHDOG is not set # CONFIG_WDTPCI is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set CONFIG_SSB_POSSIBLE=y # CONFIG_SSB is not set CONFIG_BCMA_POSSIBLE=y # CONFIG_BCMA is not set # # Multifunction device drivers # CONFIG_MFD_CORE=y # CONFIG_MFD_ACT8945A is not set # CONFIG_MFD_AS3711 is not set # CONFIG_MFD_AS3722 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_BCM590XX is not set CONFIG_MFD_BD9571MWV=y CONFIG_MFD_AXP20X=y CONFIG_MFD_AXP20X_I2C=y # CONFIG_MFD_MADERA is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9062 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_DA9150 is not set # CONFIG_MFD_DLN2 is not set # CONFIG_MFD_GATEWORKS_GSC is not set # CONFIG_MFD_MC13XXX_SPI is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_MFD_MP2629 is not set CONFIG_MFD_HI6421_PMIC=y # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_LPC_ICH is not set # CONFIG_LPC_SCH is not set # CONFIG_MFD_IQS62X is not set # CONFIG_MFD_JANZ_CMODIO is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX14577 is not set CONFIG_MFD_MAX77620=y # CONFIG_MFD_MAX77650 is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX77714 is not set # CONFIG_MFD_MAX77843 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set CONFIG_MFD_MT6360=y # CONFIG_MFD_MT6370 is not set CONFIG_MFD_MT6397=y # CONFIG_MFD_MENF21BMC is not set # CONFIG_MFD_OCELOT is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_CPCAP is not set # CONFIG_MFD_VIPERBOARD is not set # CONFIG_MFD_NTXEC is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_SY7636A is not set # CONFIG_MFD_RDC321X is not set # CONFIG_MFD_RT4831 is not set # CONFIG_MFD_RT5033 is not set # CONFIG_MFD_RT5120 is not set # CONFIG_MFD_RC5T583 is not set CONFIG_MFD_RK808=y # CONFIG_MFD_RN5T618 is not set # CONFIG_MFD_SEC_CORE is not set # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SKY81452 is not set # CONFIG_MFD_STMPE is not set CONFIG_MFD_SYSCON=y CONFIG_MFD_TI_AM335X_TSCADC=m # CONFIG_MFD_LP3943 is not set # CONFIG_MFD_LP8788 is not set # CONFIG_MFD_TI_LMU is not set # CONFIG_MFD_PALMAS is not set # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65086 is not set # CONFIG_MFD_TPS65090 is not set # CONFIG_MFD_TPS65217 is not set # CONFIG_MFD_TI_LP873X is not set # CONFIG_MFD_TI_LP87565 is not set # CONFIG_MFD_TPS65218 is not set CONFIG_MFD_TPS65219=y # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_TPS65910 is not set # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set CONFIG_MFD_TPS6594=y CONFIG_MFD_TPS6594_I2C=y # CONFIG_MFD_TPS6594_SPI is not set # CONFIG_TWL4030_CORE is not set # CONFIG_TWL6040_CORE is not set # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_TQMX86 is not set # CONFIG_MFD_VX855 is not set # CONFIG_MFD_LOCHNAGAR is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_ARIZONA_SPI is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set CONFIG_MFD_WM8994=m CONFIG_MFD_ROHM_BD718XX=y # CONFIG_MFD_ROHM_BD71828 is not set # CONFIG_MFD_ROHM_BD957XMUF is not set # CONFIG_MFD_STPMIC1 is not set # CONFIG_MFD_STMFX is not set # CONFIG_MFD_ATC260X_I2C is not set # CONFIG_MFD_QCOM_PM8008 is not set # CONFIG_RAVE_SP_CORE is not set # CONFIG_MFD_INTEL_M10_BMC is not set # CONFIG_MFD_RSMU_I2C is not set # CONFIG_MFD_RSMU_SPI is not set # end of Multifunction device drivers CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set CONFIG_REGULATOR_FIXED_VOLTAGE=y # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_88PG86X is not set # CONFIG_REGULATOR_ACT8865 is not set # CONFIG_REGULATOR_AD5398 is not set # CONFIG_REGULATOR_ARM_SCMI is not set CONFIG_REGULATOR_AXP20X=y CONFIG_REGULATOR_BD718XX=y CONFIG_REGULATOR_BD9571MWV=y # CONFIG_REGULATOR_DA9121 is not set # CONFIG_REGULATOR_DA9210 is not set # CONFIG_REGULATOR_DA9211 is not set CONFIG_REGULATOR_FAN53555=y # CONFIG_REGULATOR_FAN53880 is not set CONFIG_REGULATOR_GPIO=y # CONFIG_REGULATOR_HI6421 is not set CONFIG_REGULATOR_HI6421V530=y # CONFIG_REGULATOR_ISL9305 is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_LP872X is not set # CONFIG_REGULATOR_LP8755 is not set # CONFIG_REGULATOR_LTC3589 is not set # CONFIG_REGULATOR_LTC3676 is not set # CONFIG_REGULATOR_MAX1586 is not set CONFIG_REGULATOR_MAX77620=y # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8893 is not set # CONFIG_REGULATOR_MAX8952 is not set CONFIG_REGULATOR_MAX8973=y # CONFIG_REGULATOR_MAX20086 is not set # CONFIG_REGULATOR_MAX77826 is not set # CONFIG_REGULATOR_MCP16502 is not set # CONFIG_REGULATOR_MP5416 is not set CONFIG_REGULATOR_MP8859=y # CONFIG_REGULATOR_MP886X is not set # CONFIG_REGULATOR_MPQ7920 is not set # CONFIG_REGULATOR_MT6311 is not set # CONFIG_REGULATOR_MT6323 is not set # CONFIG_REGULATOR_MT6331 is not set # CONFIG_REGULATOR_MT6332 is not set CONFIG_REGULATOR_MT6358=y CONFIG_REGULATOR_MT6359=y CONFIG_REGULATOR_MT6360=y CONFIG_REGULATOR_MT6397=y CONFIG_REGULATOR_PCA9450=y CONFIG_REGULATOR_PF8X00=y CONFIG_REGULATOR_PFUZE100=y # CONFIG_REGULATOR_PV88060 is not set # CONFIG_REGULATOR_PV88080 is not set # CONFIG_REGULATOR_PV88090 is not set CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY=m CONFIG_REGULATOR_RK808=y CONFIG_REGULATOR_ROHM=y # CONFIG_REGULATOR_RT4801 is not set # CONFIG_REGULATOR_RT5190A is not set # CONFIG_REGULATOR_RT5759 is not set # CONFIG_REGULATOR_RT6160 is not set # CONFIG_REGULATOR_RT6245 is not set # CONFIG_REGULATOR_RTQ2134 is not set # CONFIG_REGULATOR_RTMV20 is not set # CONFIG_REGULATOR_RTQ6752 is not set # CONFIG_REGULATOR_SLG51000 is not set # CONFIG_REGULATOR_SY8106A is not set # CONFIG_REGULATOR_SY8824X is not set # CONFIG_REGULATOR_SY8827N is not set # CONFIG_REGULATOR_TPS51632 is not set # CONFIG_REGULATOR_TPS62360 is not set # CONFIG_REGULATOR_TPS6286X is not set # CONFIG_REGULATOR_TPS65023 is not set # CONFIG_REGULATOR_TPS6507X is not set CONFIG_REGULATOR_TPS65132=m CONFIG_REGULATOR_TPS65219=y CONFIG_REGULATOR_TPS6594=y # CONFIG_REGULATOR_TPS6524X is not set CONFIG_REGULATOR_VCTRL=m # CONFIG_REGULATOR_WM8994 is not set # CONFIG_RC_CORE is not set # # CEC support # CONFIG_MEDIA_CEC_SUPPORT=y # CONFIG_CEC_CH7322 is not set # CONFIG_CEC_GPIO is not set # CONFIG_USB_PULSE8_CEC is not set # CONFIG_USB_RAINSHADOW_CEC is not set # end of CEC support CONFIG_MEDIA_SUPPORT=m # CONFIG_MEDIA_SUPPORT_FILTER is not set # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set # # Media device types # CONFIG_MEDIA_CAMERA_SUPPORT=y CONFIG_MEDIA_ANALOG_TV_SUPPORT=y CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y CONFIG_MEDIA_RADIO_SUPPORT=y CONFIG_MEDIA_SDR_SUPPORT=y CONFIG_MEDIA_PLATFORM_SUPPORT=y CONFIG_MEDIA_TEST_SUPPORT=y # end of Media device types # # Media core support # CONFIG_VIDEO_DEV=m CONFIG_MEDIA_CONTROLLER=y CONFIG_DVB_CORE=m # end of Media core support # # Video4Linux options # CONFIG_VIDEO_V4L2_I2C=y CONFIG_VIDEO_V4L2_SUBDEV_API=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set CONFIG_V4L2_MEM2MEM_DEV=m CONFIG_V4L2_FWNODE=m CONFIG_V4L2_ASYNC=m # end of Video4Linux options # # Media controller options # # CONFIG_MEDIA_CONTROLLER_DVB is not set # end of Media controller options # # Digital TV options # # CONFIG_DVB_MMAP is not set # CONFIG_DVB_NET is not set CONFIG_DVB_MAX_ADAPTERS=16 CONFIG_DVB_DYNAMIC_MINORS=y # CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set # CONFIG_DVB_ULE_DEBUG is not set # end of Digital TV options # # Media drivers # # # Media drivers # CONFIG_MEDIA_USB_SUPPORT=y # # Webcam devices # # CONFIG_USB_GSPCA is not set # CONFIG_USB_PWC is not set # CONFIG_USB_S2255 is not set # CONFIG_VIDEO_USBTV is not set CONFIG_USB_VIDEO_CLASS=m CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y # # Analog TV USB devices # # CONFIG_VIDEO_GO7007 is not set # CONFIG_VIDEO_HDPVR is not set # CONFIG_VIDEO_PVRUSB2 is not set # CONFIG_VIDEO_STK1160_COMMON is not set # # Analog/digital TV USB devices # # CONFIG_VIDEO_AU0828 is not set # CONFIG_VIDEO_CX231XX is not set # # Digital TV USB devices # # CONFIG_DVB_AS102 is not set # CONFIG_DVB_B2C2_FLEXCOP_USB is not set CONFIG_DVB_USB_V2=m # CONFIG_DVB_USB_AF9015 is not set # CONFIG_DVB_USB_AF9035 is not set # CONFIG_DVB_USB_ANYSEE is not set # CONFIG_DVB_USB_AU6610 is not set # CONFIG_DVB_USB_AZ6007 is not set # CONFIG_DVB_USB_CE6230 is not set # CONFIG_DVB_USB_DVBSKY is not set # CONFIG_DVB_USB_EC168 is not set # CONFIG_DVB_USB_GL861 is not set # CONFIG_DVB_USB_MXL111SF is not set CONFIG_DVB_USB_RTL28XXU=m # CONFIG_DVB_USB_ZD1301 is not set # CONFIG_SMS_USB_DRV is not set # CONFIG_DVB_TTUSB_BUDGET is not set # CONFIG_DVB_TTUSB_DEC is not set # # Webcam, TV (analog/digital) USB devices # # CONFIG_VIDEO_EM28XX is not set # # Software defined radio USB devices # # CONFIG_USB_AIRSPY is not set # CONFIG_USB_HACKRF is not set # CONFIG_USB_MSI2500 is not set # CONFIG_MEDIA_PCI_SUPPORT is not set CONFIG_RADIO_ADAPTERS=m # CONFIG_RADIO_MAXIRADIO is not set # CONFIG_RADIO_SAA7706H is not set # CONFIG_RADIO_SHARK is not set # CONFIG_RADIO_SHARK2 is not set # CONFIG_RADIO_SI4713 is not set # CONFIG_RADIO_TEA5764 is not set # CONFIG_RADIO_TEF6862 is not set # CONFIG_RADIO_WL1273 is not set # CONFIG_USB_DSBR is not set # CONFIG_USB_KEENE is not set # CONFIG_USB_MA901 is not set # CONFIG_USB_MR800 is not set # CONFIG_USB_RAREMONO is not set # CONFIG_RADIO_SI470X is not set CONFIG_MEDIA_PLATFORM_DRIVERS=y CONFIG_V4L_PLATFORM_DRIVERS=y CONFIG_SDR_PLATFORM_DRIVERS=y # CONFIG_DVB_PLATFORM_DRIVERS is not set CONFIG_V4L_MEM2MEM_DRIVERS=y # CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set # CONFIG_VIDEO_MUX is not set # # Allegro DVT media platform drivers # # # Amlogic media platform drivers # # # Amphion drivers # # # Aspeed media platform drivers # # CONFIG_VIDEO_ASPEED is not set # # Atmel media platform drivers # # # Cadence media platform drivers # CONFIG_VIDEO_CADENCE_CSI2RX=m # CONFIG_VIDEO_CADENCE_CSI2TX is not set # # Chips&Media media platform drivers # CONFIG_VIDEO_WAVE_VPU=m # # IMG media platform drivers # CONFIG_VIDEO_IMG_VXD_DEC=m CONFIG_VIDEO_IMG_VXE_ENC=m CONFIG_VIDEO_E5010_JPEG_ENC=m # # Intel media platform drivers # # # Marvell media platform drivers # # CONFIG_VIDEO_CAFE_CCIC is not set # # Mediatek media platform drivers # # # NVidia media platform drivers # # # NXP media platform drivers # # # Qualcomm media platform drivers # # # Renesas media platform drivers # # # Rockchip media platform drivers # # # Samsung media platform drivers # # # STMicroelectronics media platform drivers # # # Sunxi media platform drivers # # # Texas Instruments drivers # # CONFIG_VIDEO_TI_CAL is not set CONFIG_VIDEO_TI_J721E_CSI2RX=m # # Verisilicon media platform drivers # # # VIA media platform drivers # # # Xilinx media platform drivers # # CONFIG_VIDEO_XILINX is not set # # MMC/SDIO DVB adapters # # CONFIG_SMS_SDIO_DRV is not set # CONFIG_V4L_TEST_DRIVERS is not set # CONFIG_DVB_TEST_DRIVERS is not set CONFIG_VIDEOBUF2_CORE=m CONFIG_VIDEOBUF2_V4L2=m CONFIG_VIDEOBUF2_MEMOPS=m CONFIG_VIDEOBUF2_DMA_CONTIG=m CONFIG_VIDEOBUF2_VMALLOC=m CONFIG_VIDEOBUF2_DMA_SG=m # end of Media drivers # # Media ancillary drivers # CONFIG_MEDIA_ATTACH=y CONFIG_VIDEO_CAMERA_SENSOR=y # CONFIG_VIDEO_AR0521 is not set # CONFIG_VIDEO_HI556 is not set # CONFIG_VIDEO_HI846 is not set # CONFIG_VIDEO_HI847 is not set # CONFIG_VIDEO_IMX208 is not set # CONFIG_VIDEO_IMX214 is not set CONFIG_VIDEO_IMX219=m # CONFIG_VIDEO_IMX258 is not set # CONFIG_VIDEO_IMX274 is not set # CONFIG_VIDEO_IMX290 is not set # CONFIG_VIDEO_IMX319 is not set # CONFIG_VIDEO_IMX334 is not set # CONFIG_VIDEO_IMX335 is not set # CONFIG_VIDEO_IMX355 is not set CONFIG_VIDEO_IMX390=m # CONFIG_VIDEO_IMX412 is not set # CONFIG_VIDEO_MT9M001 is not set # CONFIG_VIDEO_MT9M032 is not set # CONFIG_VIDEO_MT9M111 is not set # CONFIG_VIDEO_MT9P031 is not set # CONFIG_VIDEO_MT9T001 is not set # CONFIG_VIDEO_MT9T112 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_MT9V032 is not set # CONFIG_VIDEO_MT9V111 is not set # CONFIG_VIDEO_NOON010PC30 is not set # CONFIG_VIDEO_OG01A1B is not set # CONFIG_VIDEO_OV02A10 is not set # CONFIG_VIDEO_OV08D10 is not set # CONFIG_VIDEO_OV1063X is not set # CONFIG_VIDEO_OV13858 is not set # CONFIG_VIDEO_OV13B10 is not set CONFIG_VIDEO_OV2312=m # CONFIG_VIDEO_OV2640 is not set # CONFIG_VIDEO_OV2659 is not set # CONFIG_VIDEO_OV2680 is not set # CONFIG_VIDEO_OV2685 is not set CONFIG_VIDEO_OV5640=m CONFIG_VIDEO_OV5645=m # CONFIG_VIDEO_OV5647 is not set # CONFIG_VIDEO_OV5648 is not set # CONFIG_VIDEO_OV5670 is not set # CONFIG_VIDEO_OV5675 is not set # CONFIG_VIDEO_OV5693 is not set # CONFIG_VIDEO_OV5695 is not set # CONFIG_VIDEO_OV6650 is not set # CONFIG_VIDEO_OV7251 is not set # CONFIG_VIDEO_OV7640 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_OV772X is not set # CONFIG_VIDEO_OV7740 is not set # CONFIG_VIDEO_OV8856 is not set # CONFIG_VIDEO_OV8865 is not set # CONFIG_VIDEO_OV9282 is not set # CONFIG_VIDEO_OV9640 is not set # CONFIG_VIDEO_OV9650 is not set # CONFIG_VIDEO_RDACM20 is not set # CONFIG_VIDEO_RDACM21 is not set # CONFIG_VIDEO_RJ54N1 is not set # CONFIG_VIDEO_S5C73M3 is not set # CONFIG_VIDEO_S5K4ECGX is not set # CONFIG_VIDEO_S5K5BAF is not set # CONFIG_VIDEO_S5K6A3 is not set # CONFIG_VIDEO_S5K6AA is not set # CONFIG_VIDEO_SR030PC30 is not set # CONFIG_VIDEO_VS6624 is not set # CONFIG_VIDEO_CCS is not set # CONFIG_VIDEO_ET8EK8 is not set # CONFIG_VIDEO_M5MOLS is not set # # Lens drivers # # CONFIG_VIDEO_AD5820 is not set # CONFIG_VIDEO_AK7375 is not set # CONFIG_VIDEO_DW9714 is not set # CONFIG_VIDEO_DW9768 is not set # CONFIG_VIDEO_DW9807_VCM is not set # end of Lens drivers # # Flash devices # # CONFIG_VIDEO_ADP1653 is not set # CONFIG_VIDEO_LM3560 is not set # CONFIG_VIDEO_LM3646 is not set # end of Flash devices # # Audio decoders, processors and mixers # # CONFIG_VIDEO_CS3308 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_SONY_BTF_MPX is not set # CONFIG_VIDEO_TDA1997X is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_UDA1342 is not set # CONFIG_VIDEO_VP27SMPX is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_WM8775 is not set # end of Audio decoders, processors and mixers # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # end of RDS decoders # # Video decoders # # CONFIG_VIDEO_ADV7180 is not set # CONFIG_VIDEO_ADV7183 is not set # CONFIG_VIDEO_ADV748X is not set # CONFIG_VIDEO_ADV7604 is not set # CONFIG_VIDEO_ADV7842 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_ISL7998X is not set # CONFIG_VIDEO_KS0127 is not set # CONFIG_VIDEO_MAX9286 is not set # CONFIG_VIDEO_ML86V7667 is not set # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_TC358743 is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set # CONFIG_VIDEO_TVP7002 is not set # CONFIG_VIDEO_TW2804 is not set # CONFIG_VIDEO_TW9903 is not set # CONFIG_VIDEO_TW9906 is not set # CONFIG_VIDEO_TW9910 is not set # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_CX25840 is not set # end of Video decoders # # Video encoders # # CONFIG_VIDEO_AD9389B is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_ADV7393 is not set # CONFIG_VIDEO_ADV7511 is not set # CONFIG_VIDEO_AK881X is not set # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_THS8200 is not set # end of Video encoders # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set # end of Video improvement chips # # Audio/Video compression chips # # CONFIG_VIDEO_SAA6752HS is not set # end of Audio/Video compression chips # # SDR tuner chips # # CONFIG_SDR_MAX2175 is not set # end of SDR tuner chips # # Miscellaneous helper chips # # CONFIG_VIDEO_I2C is not set # CONFIG_VIDEO_M52790 is not set # CONFIG_VIDEO_ST_MIPID02 is not set # CONFIG_VIDEO_THS7303 is not set # end of Miscellaneous helper chips # # Video serializers and deserializers # # CONFIG_VIDEO_DS90UB913 is not set CONFIG_VIDEO_DS90UB953=m CONFIG_VIDEO_DS90UB960=m # end of Video serializers and deserializers # # Media SPI Adapters # # CONFIG_CXD2880_SPI_DRV is not set # CONFIG_VIDEO_GS1662 is not set # end of Media SPI Adapters CONFIG_MEDIA_TUNER=m # # Customize TV tuners # # CONFIG_MEDIA_TUNER_E4000 is not set # CONFIG_MEDIA_TUNER_FC0011 is not set # CONFIG_MEDIA_TUNER_FC0012 is not set # CONFIG_MEDIA_TUNER_FC0013 is not set # CONFIG_MEDIA_TUNER_FC2580 is not set # CONFIG_MEDIA_TUNER_IT913X is not set # CONFIG_MEDIA_TUNER_M88RS6000T is not set # CONFIG_MEDIA_TUNER_MAX2165 is not set # CONFIG_MEDIA_TUNER_MC44S803 is not set # CONFIG_MEDIA_TUNER_MSI001 is not set # CONFIG_MEDIA_TUNER_MT2060 is not set # CONFIG_MEDIA_TUNER_MT2063 is not set # CONFIG_MEDIA_TUNER_MT20XX is not set # CONFIG_MEDIA_TUNER_MT2131 is not set # CONFIG_MEDIA_TUNER_MT2266 is not set # CONFIG_MEDIA_TUNER_MXL301RF is not set # CONFIG_MEDIA_TUNER_MXL5005S is not set # CONFIG_MEDIA_TUNER_MXL5007T is not set # CONFIG_MEDIA_TUNER_QM1D1B0004 is not set # CONFIG_MEDIA_TUNER_QM1D1C0042 is not set # CONFIG_MEDIA_TUNER_QT1010 is not set # CONFIG_MEDIA_TUNER_R820T is not set # CONFIG_MEDIA_TUNER_SI2157 is not set # CONFIG_MEDIA_TUNER_SIMPLE is not set # CONFIG_MEDIA_TUNER_TDA18212 is not set # CONFIG_MEDIA_TUNER_TDA18218 is not set # CONFIG_MEDIA_TUNER_TDA18250 is not set # CONFIG_MEDIA_TUNER_TDA18271 is not set # CONFIG_MEDIA_TUNER_TDA827X is not set # CONFIG_MEDIA_TUNER_TDA8290 is not set # CONFIG_MEDIA_TUNER_TDA9887 is not set # CONFIG_MEDIA_TUNER_TEA5761 is not set # CONFIG_MEDIA_TUNER_TEA5767 is not set # CONFIG_MEDIA_TUNER_TUA9001 is not set # CONFIG_MEDIA_TUNER_XC2028 is not set # CONFIG_MEDIA_TUNER_XC4000 is not set # CONFIG_MEDIA_TUNER_XC5000 is not set # end of Customize TV tuners # # Customise DVB Frontends # # # Multistandard (satellite) frontends # # CONFIG_DVB_M88DS3103 is not set # CONFIG_DVB_MXL5XX is not set # CONFIG_DVB_STB0899 is not set # CONFIG_DVB_STB6100 is not set # CONFIG_DVB_STV090x is not set # CONFIG_DVB_STV0910 is not set # CONFIG_DVB_STV6110x is not set # CONFIG_DVB_STV6111 is not set # # Multistandard (cable + terrestrial) frontends # # CONFIG_DVB_DRXK is not set # CONFIG_DVB_MN88472 is not set # CONFIG_DVB_MN88473 is not set # CONFIG_DVB_SI2165 is not set # CONFIG_DVB_TDA18271C2DD is not set # # DVB-S (satellite) frontends # # CONFIG_DVB_CX24110 is not set # CONFIG_DVB_CX24116 is not set # CONFIG_DVB_CX24117 is not set # CONFIG_DVB_CX24120 is not set # CONFIG_DVB_CX24123 is not set # CONFIG_DVB_DS3000 is not set # CONFIG_DVB_MB86A16 is not set # CONFIG_DVB_MT312 is not set # CONFIG_DVB_S5H1420 is not set # CONFIG_DVB_SI21XX is not set # CONFIG_DVB_STB6000 is not set # CONFIG_DVB_STV0288 is not set # CONFIG_DVB_STV0299 is not set # CONFIG_DVB_STV0900 is not set # CONFIG_DVB_STV6110 is not set # CONFIG_DVB_TDA10071 is not set # CONFIG_DVB_TDA10086 is not set # CONFIG_DVB_TDA8083 is not set # CONFIG_DVB_TDA8261 is not set # CONFIG_DVB_TDA826X is not set # CONFIG_DVB_TS2020 is not set # CONFIG_DVB_TUA6100 is not set # CONFIG_DVB_TUNER_CX24113 is not set # CONFIG_DVB_TUNER_ITD1000 is not set # CONFIG_DVB_VES1X93 is not set # CONFIG_DVB_ZL10036 is not set # CONFIG_DVB_ZL10039 is not set # # DVB-T (terrestrial) frontends # # CONFIG_DVB_AF9013 is not set # CONFIG_DVB_CX22700 is not set # CONFIG_DVB_CX22702 is not set # CONFIG_DVB_CXD2820R is not set # CONFIG_DVB_CXD2841ER is not set # CONFIG_DVB_DIB3000MB is not set # CONFIG_DVB_DIB3000MC is not set # CONFIG_DVB_DIB7000M is not set # CONFIG_DVB_DIB7000P is not set # CONFIG_DVB_DIB9000 is not set # CONFIG_DVB_DRXD is not set # CONFIG_DVB_EC100 is not set # CONFIG_DVB_L64781 is not set # CONFIG_DVB_MT352 is not set # CONFIG_DVB_NXT6000 is not set CONFIG_DVB_RTL2830=m CONFIG_DVB_RTL2832=m # CONFIG_DVB_RTL2832_SDR is not set # CONFIG_DVB_S5H1432 is not set # CONFIG_DVB_SI2168 is not set # CONFIG_DVB_SP887X is not set # CONFIG_DVB_STV0367 is not set # CONFIG_DVB_TDA10048 is not set # CONFIG_DVB_TDA1004X is not set # CONFIG_DVB_ZD1301_DEMOD is not set # CONFIG_DVB_ZL10353 is not set # CONFIG_DVB_CXD2880 is not set # # DVB-C (cable) frontends # # CONFIG_DVB_STV0297 is not set # CONFIG_DVB_TDA10021 is not set # CONFIG_DVB_TDA10023 is not set # CONFIG_DVB_VES1820 is not set # # ATSC (North American/Korean Terrestrial/Cable DTV) frontends # # CONFIG_DVB_AU8522_DTV is not set # CONFIG_DVB_AU8522_V4L is not set # CONFIG_DVB_BCM3510 is not set # CONFIG_DVB_LG2160 is not set # CONFIG_DVB_LGDT3305 is not set # CONFIG_DVB_LGDT3306A is not set # CONFIG_DVB_LGDT330X is not set # CONFIG_DVB_MXL692 is not set # CONFIG_DVB_NXT200X is not set # CONFIG_DVB_OR51132 is not set # CONFIG_DVB_OR51211 is not set # CONFIG_DVB_S5H1409 is not set # CONFIG_DVB_S5H1411 is not set # # ISDB-T (terrestrial) frontends # # CONFIG_DVB_DIB8000 is not set # CONFIG_DVB_MB86A20S is not set # CONFIG_DVB_S921 is not set # # ISDB-S (satellite) & ISDB-T (terrestrial) frontends # # CONFIG_DVB_MN88443X is not set # CONFIG_DVB_TC90522 is not set # # Digital terrestrial only tuners/PLL # # CONFIG_DVB_PLL is not set # CONFIG_DVB_TUNER_DIB0070 is not set # CONFIG_DVB_TUNER_DIB0090 is not set # # SEC control devices for DVB-S # # CONFIG_DVB_A8293 is not set # CONFIG_DVB_AF9033 is not set # CONFIG_DVB_ASCOT2E is not set # CONFIG_DVB_ATBM8830 is not set # CONFIG_DVB_HELENE is not set # CONFIG_DVB_HORUS3A is not set # CONFIG_DVB_ISL6405 is not set # CONFIG_DVB_ISL6421 is not set # CONFIG_DVB_ISL6423 is not set # CONFIG_DVB_IX2505V is not set # CONFIG_DVB_LGS8GL5 is not set # CONFIG_DVB_LGS8GXX is not set # CONFIG_DVB_LNBH25 is not set # CONFIG_DVB_LNBH29 is not set # CONFIG_DVB_LNBP21 is not set # CONFIG_DVB_LNBP22 is not set # CONFIG_DVB_M88RS2000 is not set # CONFIG_DVB_TDA665x is not set # CONFIG_DVB_DRX39XYJ is not set # # Common Interface (EN50221) controller drivers # # CONFIG_DVB_CXD2099 is not set # CONFIG_DVB_SP2 is not set # end of Customise DVB Frontends # # Tools to develop new frontends # # CONFIG_DVB_DUMMY_FE is not set # end of Media ancillary drivers # # Graphics support # CONFIG_APERTURE_HELPERS=y CONFIG_DRM=y CONFIG_DRM_MIPI_DSI=y CONFIG_DRM_KMS_HELPER=y # CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set # CONFIG_DRM_DEBUG_MODESET_LOCK is not set CONFIG_DRM_FBDEV_EMULATION=y CONFIG_DRM_FBDEV_OVERALLOC=100 # CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set CONFIG_DRM_DP_AUX_BUS=m CONFIG_DRM_DISPLAY_HELPER=m CONFIG_DRM_DISPLAY_DP_HELPER=y CONFIG_DRM_DISPLAY_HDCP_HELPER=y # CONFIG_DRM_DP_AUX_CHARDEV is not set # CONFIG_DRM_DP_CEC is not set CONFIG_DRM_GEM_DMA_HELPER=m # # I2C encoder or helper chips # CONFIG_DRM_I2C_CH7006=m CONFIG_DRM_I2C_SIL164=m CONFIG_DRM_I2C_NXP_TDA998X=m # CONFIG_DRM_I2C_NXP_TDA9950 is not set # end of I2C encoder or helper chips # # ARM devices # # CONFIG_DRM_HDLCD is not set # CONFIG_DRM_MALI_DISPLAY is not set # CONFIG_DRM_KOMEDA is not set # end of ARM devices # CONFIG_DRM_RADEON is not set # CONFIG_DRM_AMDGPU is not set # CONFIG_DRM_NOUVEAU is not set # CONFIG_DRM_VGEM is not set # CONFIG_DRM_VKMS is not set # CONFIG_DRM_VMWGFX is not set # CONFIG_DRM_UDL is not set # CONFIG_DRM_AST is not set # CONFIG_DRM_MGAG200 is not set # CONFIG_DRM_RCAR_DW_HDMI is not set # CONFIG_DRM_RCAR_USE_LVDS is not set # CONFIG_DRM_RCAR_USE_MIPI_DSI is not set # CONFIG_DRM_QXL is not set # CONFIG_DRM_VIRTIO_GPU is not set CONFIG_DRM_PANEL=y # # Display Panels # # CONFIG_DRM_PANEL_ABT_Y030XX067A is not set # CONFIG_DRM_PANEL_ARM_VERSATILE is not set # CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596 is not set # CONFIG_DRM_PANEL_BOE_BF060Y8M_AJ0 is not set # CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set CONFIG_DRM_PANEL_BOE_TV101WUM_NL6=m # CONFIG_DRM_PANEL_DSI_CM is not set CONFIG_DRM_PANEL_LVDS=m CONFIG_DRM_PANEL_SIMPLE=m CONFIG_DRM_PANEL_EDP=m # CONFIG_DRM_PANEL_EBBG_FT8719 is not set # CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set # CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02 is not set # CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set # CONFIG_DRM_PANEL_ILITEK_IL9322 is not set # CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set # CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set # CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set # CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set # CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set # CONFIG_DRM_PANEL_JDI_R63452 is not set # CONFIG_DRM_PANEL_KHADAS_TS050 is not set # CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set # CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set # CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set # CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set # CONFIG_DRM_PANEL_LG_LB035Q02 is not set # CONFIG_DRM_PANEL_LG_LG4573 is not set # CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set # CONFIG_DRM_PANEL_NEWVISION_NV3052C is not set # CONFIG_DRM_PANEL_NOVATEK_NT35510 is not set # CONFIG_DRM_PANEL_NOVATEK_NT35560 is not set # CONFIG_DRM_PANEL_NOVATEK_NT35950 is not set # CONFIG_DRM_PANEL_NOVATEK_NT36672A is not set # CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set CONFIG_DRM_PANEL_MANTIX_MLAF057WE51=m # CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set # CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set # CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set # CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set # CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set CONFIG_DRM_PANEL_RAYDIUM_RM67191=m # CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set # CONFIG_DRM_PANEL_RONBO_RB070D30 is not set # CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set # CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6D27A1 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set # CONFIG_DRM_PANEL_SAMSUNG_SOFEF00 is not set # CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set # CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set # CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set # CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set # CONFIG_DRM_PANEL_SHARP_LS060T1SX01 is not set # CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set CONFIG_DRM_PANEL_SITRONIX_ST7703=m # CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set # CONFIG_DRM_PANEL_SONY_ACX565AKM is not set # CONFIG_DRM_PANEL_SONY_TULIP_TRULY_NT35521 is not set # CONFIG_DRM_PANEL_TDO_TL070WSH30 is not set # CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set # CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set # CONFIG_DRM_PANEL_TPO_TPG110 is not set CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA=m # CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set # CONFIG_DRM_PANEL_WIDECHIPS_WS2401 is not set # CONFIG_DRM_PANEL_XINPENG_XPP055C272 is not set # end of Display Panels CONFIG_DRM_BRIDGE=y CONFIG_DRM_PANEL_BRIDGE=y # # Display Interface Bridges # # CONFIG_DRM_CHIPONE_ICN6211 is not set # CONFIG_DRM_CHRONTEL_CH7033 is not set CONFIG_DRM_DISPLAY_CONNECTOR=m # CONFIG_DRM_ITE_IT6505 is not set CONFIG_DRM_LONTIUM_LT8912B=m # CONFIG_DRM_LONTIUM_LT9211 is not set CONFIG_DRM_LONTIUM_LT9611=m CONFIG_DRM_LONTIUM_LT9611UXC=m CONFIG_DRM_ITE_IT66121=m # CONFIG_DRM_LVDS_CODEC is not set # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set CONFIG_DRM_NWL_MIPI_DSI=m # CONFIG_DRM_NXP_PTN3460 is not set # CONFIG_DRM_PARADE_PS8622 is not set CONFIG_DRM_PARADE_PS8640=m # CONFIG_DRM_SIL_SII8620 is not set CONFIG_DRM_SII902X=m # CONFIG_DRM_SII9234 is not set CONFIG_DRM_SIMPLE_BRIDGE=m CONFIG_DRM_THINE_THC63LVD1024=m CONFIG_DRM_TOSHIBA_TC358762=m # CONFIG_DRM_TOSHIBA_TC358764 is not set # CONFIG_DRM_TOSHIBA_TC358767 is not set # CONFIG_DRM_TOSHIBA_TC358768 is not set # CONFIG_DRM_TOSHIBA_TC358775 is not set # CONFIG_DRM_TI_DLPC3433 is not set CONFIG_DRM_TI_TFP410=m # CONFIG_DRM_TI_SN65DSI83 is not set CONFIG_DRM_TI_SN65DSI86=m # CONFIG_DRM_TI_TPD12S015 is not set # CONFIG_DRM_ANALOGIX_ANX6345 is not set # CONFIG_DRM_ANALOGIX_ANX78XX is not set # CONFIG_DRM_ANALOGIX_ANX7625 is not set # CONFIG_DRM_I2C_ADV7511 is not set CONFIG_DRM_CDNS_DSI=m CONFIG_DRM_CDNS_DSI_J721E=y CONFIG_DRM_CDNS_MHDP8546=m CONFIG_DRM_CDNS_MHDP8546_J721E=y # end of Display Interface Bridges # CONFIG_DRM_ETNAVIV is not set # CONFIG_DRM_HISI_HIBMC is not set # CONFIG_DRM_HISI_KIRIN is not set # CONFIG_DRM_LOGICVC is not set # CONFIG_DRM_ARCPGU is not set # CONFIG_DRM_BOCHS is not set # CONFIG_DRM_CIRRUS_QEMU is not set # CONFIG_DRM_GM12U320 is not set # CONFIG_DRM_PANEL_MIPI_DBI is not set # CONFIG_DRM_SIMPLEDRM is not set # CONFIG_TINYDRM_HX8357D is not set # CONFIG_TINYDRM_ILI9163 is not set # CONFIG_TINYDRM_ILI9225 is not set # CONFIG_TINYDRM_ILI9341 is not set # CONFIG_TINYDRM_ILI9486 is not set # CONFIG_TINYDRM_MI0283QT is not set # CONFIG_TINYDRM_REPAPER is not set # CONFIG_TINYDRM_ST7586 is not set # CONFIG_TINYDRM_ST7735R is not set # CONFIG_DRM_PL111 is not set # CONFIG_DRM_LIMA is not set # CONFIG_DRM_PANFROST is not set CONFIG_DRM_TIDSS=y # CONFIG_DRM_GUD is not set # CONFIG_DRM_SSD130X is not set CONFIG_DRM_LEGACY=y # CONFIG_DRM_TDFX is not set # CONFIG_DRM_R128 is not set # CONFIG_DRM_MGA is not set # CONFIG_DRM_VIA is not set # CONFIG_DRM_SAVAGE is not set CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=m CONFIG_DRM_NOMODESET=y # # Frame buffer Devices # CONFIG_FB_CMDLINE=y CONFIG_FB_NOTIFY=y CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y CONFIG_FB_SYS_FILLRECT=m CONFIG_FB_SYS_COPYAREA=m CONFIG_FB_SYS_IMAGEBLIT=m # CONFIG_FB_FOREIGN_ENDIAN is not set CONFIG_FB_SYS_FOPS=m CONFIG_FB_DEFERRED_IO=y CONFIG_FB_MODE_HELPERS=y # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_CIRRUS is not set # CONFIG_FB_PM2 is not set # CONFIG_FB_ARMCLCD is not set # CONFIG_FB_CYBER2000 is not set # CONFIG_FB_ASILIANT is not set # CONFIG_FB_IMSTT is not set # CONFIG_FB_EFI is not set # CONFIG_FB_OPENCORES is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_NVIDIA is not set # CONFIG_FB_RIVA is not set # CONFIG_FB_I740 is not set # CONFIG_FB_MATROX is not set # CONFIG_FB_RADEON is not set # CONFIG_FB_ATY128 is not set # CONFIG_FB_ATY is not set # CONFIG_FB_S3 is not set # CONFIG_FB_SAVAGE is not set # CONFIG_FB_SIS is not set # CONFIG_FB_NEOMAGIC is not set # CONFIG_FB_KYRO is not set # CONFIG_FB_3DFX is not set # CONFIG_FB_VOODOO1 is not set # CONFIG_FB_VT8623 is not set # CONFIG_FB_TRIDENT is not set # CONFIG_FB_ARK is not set # CONFIG_FB_PM3 is not set # CONFIG_FB_CARMINE is not set # CONFIG_FB_SMSCUFX is not set # CONFIG_FB_UDL is not set # CONFIG_FB_IBM_GXT4500 is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_MB862XX is not set CONFIG_FB_SIMPLE=y # CONFIG_FB_SSD1307 is not set # CONFIG_FB_SM712 is not set # end of Frame buffer Devices # # Backlight & LCD device support # # CONFIG_LCD_CLASS_DEVICE is not set CONFIG_BACKLIGHT_CLASS_DEVICE=y # CONFIG_BACKLIGHT_KTD253 is not set CONFIG_BACKLIGHT_PWM=m # CONFIG_BACKLIGHT_QCOM_WLED is not set # CONFIG_BACKLIGHT_ADP8860 is not set # CONFIG_BACKLIGHT_ADP8870 is not set # CONFIG_BACKLIGHT_LM3630A is not set # CONFIG_BACKLIGHT_LM3639 is not set CONFIG_BACKLIGHT_LP855X=m # CONFIG_BACKLIGHT_GPIO is not set # CONFIG_BACKLIGHT_LV5207LP is not set # CONFIG_BACKLIGHT_BD6107 is not set # CONFIG_BACKLIGHT_ARCXCNN is not set # CONFIG_BACKLIGHT_LED is not set # end of Backlight & LCD device support CONFIG_VIDEOMODE_HELPERS=y CONFIG_HDMI=y # # Console display driver support # CONFIG_DUMMY_CONSOLE=y CONFIG_DUMMY_CONSOLE_COLUMNS=80 CONFIG_DUMMY_CONSOLE_ROWS=25 CONFIG_FRAMEBUFFER_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION=y CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set # CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set # end of Console display driver support CONFIG_LOGO=y # CONFIG_LOGO_LINUX_MONO is not set # CONFIG_LOGO_LINUX_VGA16 is not set CONFIG_LOGO_LINUX_CLUT224=y # end of Graphics support CONFIG_SOUND=y CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_PCM_ELD=y CONFIG_SND_PCM_IEC958=y CONFIG_SND_DMAENGINE_PCM=y CONFIG_SND_HWDEP=y CONFIG_SND_RAWMIDI=y CONFIG_SND_JACK=y CONFIG_SND_JACK_INPUT_DEV=y # CONFIG_SND_OSSEMUL is not set CONFIG_SND_PCM_TIMER=y # CONFIG_SND_HRTIMER is not set CONFIG_SND_DYNAMIC_MINORS=y CONFIG_SND_MAX_CARDS=32 CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_PROC_FS=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set CONFIG_SND_CTL_FAST_LOOKUP=y # CONFIG_SND_DEBUG is not set # CONFIG_SND_CTL_INPUT_VALIDATION is not set # CONFIG_SND_SEQUENCER is not set CONFIG_SND_DRIVERS=y # CONFIG_SND_DUMMY is not set # CONFIG_SND_ALOOP is not set # CONFIG_SND_MTPAV is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_SERIAL_GENERIC is not set # CONFIG_SND_MPU401 is not set CONFIG_SND_PCI=y # CONFIG_SND_AD1889 is not set # CONFIG_SND_ALS300 is not set # CONFIG_SND_ALI5451 is not set # CONFIG_SND_ATIIXP is not set # CONFIG_SND_ATIIXP_MODEM is not set # CONFIG_SND_AU8810 is not set # CONFIG_SND_AU8820 is not set # CONFIG_SND_AU8830 is not set # CONFIG_SND_AW2 is not set # CONFIG_SND_AZT3328 is not set # CONFIG_SND_BT87X is not set # CONFIG_SND_CA0106 is not set # CONFIG_SND_CMIPCI is not set # CONFIG_SND_OXYGEN is not set # CONFIG_SND_CS4281 is not set # CONFIG_SND_CS46XX is not set # CONFIG_SND_CTXFI is not set # CONFIG_SND_DARLA20 is not set # CONFIG_SND_GINA20 is not set # CONFIG_SND_LAYLA20 is not set # CONFIG_SND_DARLA24 is not set # CONFIG_SND_GINA24 is not set # CONFIG_SND_LAYLA24 is not set # CONFIG_SND_MONA is not set # CONFIG_SND_MIA is not set # CONFIG_SND_ECHO3G is not set # CONFIG_SND_INDIGO is not set # CONFIG_SND_INDIGOIO is not set # CONFIG_SND_INDIGODJ is not set # CONFIG_SND_INDIGOIOX is not set # CONFIG_SND_INDIGODJX is not set # CONFIG_SND_EMU10K1 is not set # CONFIG_SND_EMU10K1X is not set # CONFIG_SND_ENS1370 is not set # CONFIG_SND_ENS1371 is not set # CONFIG_SND_ES1938 is not set # CONFIG_SND_ES1968 is not set # CONFIG_SND_FM801 is not set # CONFIG_SND_HDSP is not set # CONFIG_SND_HDSPM is not set # CONFIG_SND_ICE1712 is not set # CONFIG_SND_ICE1724 is not set # CONFIG_SND_INTEL8X0 is not set # CONFIG_SND_INTEL8X0M is not set # CONFIG_SND_KORG1212 is not set # CONFIG_SND_LOLA is not set # CONFIG_SND_LX6464ES is not set # CONFIG_SND_MAESTRO3 is not set # CONFIG_SND_MIXART is not set # CONFIG_SND_NM256 is not set # CONFIG_SND_PCXHR is not set # CONFIG_SND_RIPTIDE is not set # CONFIG_SND_RME32 is not set # CONFIG_SND_RME96 is not set # CONFIG_SND_RME9652 is not set # CONFIG_SND_SE6X is not set # CONFIG_SND_SONICVIBES is not set # CONFIG_SND_TRIDENT is not set # CONFIG_SND_VIA82XX is not set # CONFIG_SND_VIA82XX_MODEM is not set # CONFIG_SND_VIRTUOSO is not set # CONFIG_SND_VX222 is not set # CONFIG_SND_YMFPCI is not set # # HD-Audio # # CONFIG_SND_HDA_INTEL is not set # end of HD-Audio CONFIG_SND_HDA_PREALLOC_SIZE=64 # CONFIG_SND_SPI is not set CONFIG_SND_USB=y CONFIG_SND_USB_AUDIO=m CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set # CONFIG_SND_USB_6FIRE is not set # CONFIG_SND_USB_HIFACE is not set # CONFIG_SND_BCD2000 is not set # CONFIG_SND_USB_POD is not set # CONFIG_SND_USB_PODHD is not set # CONFIG_SND_USB_TONEPORT is not set # CONFIG_SND_USB_VARIAX is not set CONFIG_SND_SOC=y CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y # CONFIG_SND_SOC_ADI is not set # CONFIG_SND_SOC_AMD_ACP is not set # CONFIG_SND_AMD_ACP_CONFIG is not set # CONFIG_SND_ATMEL_SOC is not set # CONFIG_SND_BCM63XX_I2S_WHISTLER is not set # CONFIG_SND_DESIGNWARE_I2S is not set # # SoC Audio for Freescale CPUs # # # Common SoC Audio options for Freescale CPUs: # # CONFIG_SND_SOC_FSL_ASRC is not set # CONFIG_SND_SOC_FSL_SAI is not set # CONFIG_SND_SOC_FSL_AUDMIX is not set # CONFIG_SND_SOC_FSL_SSI is not set # CONFIG_SND_SOC_FSL_SPDIF is not set # CONFIG_SND_SOC_FSL_ESAI is not set # CONFIG_SND_SOC_FSL_MICFIL is not set # CONFIG_SND_SOC_FSL_XCVR is not set # CONFIG_SND_SOC_FSL_RPMSG is not set # CONFIG_SND_SOC_IMX_AUDMUX is not set # end of SoC Audio for Freescale CPUs # CONFIG_SND_I2S_HI6210_I2S is not set # CONFIG_SND_SOC_IMG is not set # CONFIG_SND_SOC_MTK_BTCVSD is not set # CONFIG_SND_SOC_SOF_TOPLEVEL is not set # # STMicroelectronics STM32 SOC audio support # # end of STMicroelectronics STM32 SOC audio support # # Audio support for Texas Instruments SoCs # CONFIG_SND_SOC_TI_EDMA_PCM=m CONFIG_SND_SOC_TI_SDMA_PCM=m CONFIG_SND_SOC_TI_UDMA_PCM=m # # Texas Instruments DAI support for: # CONFIG_SND_SOC_DAVINCI_MCASP=m # # Audio support for boards with Texas Instruments SoCs # CONFIG_SND_SOC_J721E_EVM=m # end of Audio support for Texas Instruments SoCs # CONFIG_SND_SOC_XILINX_I2S is not set # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set # CONFIG_SND_SOC_XILINX_SPDIF is not set # CONFIG_SND_SOC_XTFPGA_I2S is not set CONFIG_SND_SOC_I2C_AND_SPI=y # # CODEC drivers # # CONFIG_SND_SOC_AC97_CODEC is not set # CONFIG_SND_SOC_ADAU1372_I2C is not set # CONFIG_SND_SOC_ADAU1372_SPI is not set # CONFIG_SND_SOC_ADAU1701 is not set # CONFIG_SND_SOC_ADAU1761_I2C is not set # CONFIG_SND_SOC_ADAU1761_SPI is not set CONFIG_SND_SOC_ADAU7002=m # CONFIG_SND_SOC_ADAU7118_HW is not set # CONFIG_SND_SOC_ADAU7118_I2C is not set # CONFIG_SND_SOC_AK4104 is not set # CONFIG_SND_SOC_AK4118 is not set # CONFIG_SND_SOC_AK4375 is not set # CONFIG_SND_SOC_AK4458 is not set # CONFIG_SND_SOC_AK4554 is not set # CONFIG_SND_SOC_AK4613 is not set # CONFIG_SND_SOC_AK4642 is not set # CONFIG_SND_SOC_AK5386 is not set # CONFIG_SND_SOC_AK5558 is not set # CONFIG_SND_SOC_ALC5623 is not set # CONFIG_SND_SOC_AW8738 is not set # CONFIG_SND_SOC_BD28623 is not set # CONFIG_SND_SOC_BT_SCO is not set # CONFIG_SND_SOC_CS35L32 is not set # CONFIG_SND_SOC_CS35L33 is not set # CONFIG_SND_SOC_CS35L34 is not set # CONFIG_SND_SOC_CS35L35 is not set # CONFIG_SND_SOC_CS35L36 is not set # CONFIG_SND_SOC_CS35L41_SPI is not set # CONFIG_SND_SOC_CS35L41_I2C is not set # CONFIG_SND_SOC_CS35L45_SPI is not set # CONFIG_SND_SOC_CS35L45_I2C is not set # CONFIG_SND_SOC_CS42L42 is not set # CONFIG_SND_SOC_CS42L51_I2C is not set # CONFIG_SND_SOC_CS42L52 is not set # CONFIG_SND_SOC_CS42L56 is not set # CONFIG_SND_SOC_CS42L73 is not set # CONFIG_SND_SOC_CS42L83 is not set # CONFIG_SND_SOC_CS4234 is not set # CONFIG_SND_SOC_CS4265 is not set # CONFIG_SND_SOC_CS4270 is not set # CONFIG_SND_SOC_CS4271_I2C is not set # CONFIG_SND_SOC_CS4271_SPI is not set # CONFIG_SND_SOC_CS42XX8_I2C is not set # CONFIG_SND_SOC_CS43130 is not set # CONFIG_SND_SOC_CS4341 is not set # CONFIG_SND_SOC_CS4349 is not set # CONFIG_SND_SOC_CS53L30 is not set # CONFIG_SND_SOC_CX2072X is not set # CONFIG_SND_SOC_DA7213 is not set CONFIG_SND_SOC_DMIC=m CONFIG_SND_SOC_HDMI_CODEC=m # CONFIG_SND_SOC_ES7134 is not set # CONFIG_SND_SOC_ES7241 is not set # CONFIG_SND_SOC_ES8316 is not set # CONFIG_SND_SOC_ES8326 is not set # CONFIG_SND_SOC_ES8328_I2C is not set # CONFIG_SND_SOC_ES8328_SPI is not set CONFIG_SND_SOC_GTM601=m # CONFIG_SND_SOC_HDA is not set # CONFIG_SND_SOC_ICS43432 is not set # CONFIG_SND_SOC_INNO_RK3036 is not set # CONFIG_SND_SOC_MAX98088 is not set CONFIG_SND_SOC_MAX98357A=m # CONFIG_SND_SOC_MAX98504 is not set # CONFIG_SND_SOC_MAX9867 is not set CONFIG_SND_SOC_MAX98927=m # CONFIG_SND_SOC_MAX98520 is not set # CONFIG_SND_SOC_MAX98373_I2C is not set # CONFIG_SND_SOC_MAX98373_SDW is not set # CONFIG_SND_SOC_MAX98390 is not set # CONFIG_SND_SOC_MAX98396 is not set # CONFIG_SND_SOC_MAX9860 is not set CONFIG_SND_SOC_MSM8916_WCD_DIGITAL=m # CONFIG_SND_SOC_PCM1681 is not set # CONFIG_SND_SOC_PCM1789_I2C is not set # CONFIG_SND_SOC_PCM179X_I2C is not set # CONFIG_SND_SOC_PCM179X_SPI is not set # CONFIG_SND_SOC_PCM186X_I2C is not set # CONFIG_SND_SOC_PCM186X_SPI is not set # CONFIG_SND_SOC_PCM3060_I2C is not set # CONFIG_SND_SOC_PCM3060_SPI is not set CONFIG_SND_SOC_PCM3168A=m CONFIG_SND_SOC_PCM3168A_I2C=m # CONFIG_SND_SOC_PCM3168A_SPI is not set # CONFIG_SND_SOC_PCM5102A is not set # CONFIG_SND_SOC_PCM512x_I2C is not set # CONFIG_SND_SOC_PCM512x_SPI is not set # CONFIG_SND_SOC_RK3328 is not set # CONFIG_SND_SOC_RK817 is not set CONFIG_SND_SOC_RL6231=m # CONFIG_SND_SOC_RT1308_SDW is not set # CONFIG_SND_SOC_RT1316_SDW is not set # CONFIG_SND_SOC_RT1318_SDW is not set # CONFIG_SND_SOC_RT5616 is not set # CONFIG_SND_SOC_RT5631 is not set # CONFIG_SND_SOC_RT5640 is not set CONFIG_SND_SOC_RT5659=m # CONFIG_SND_SOC_RT5682_SDW is not set # CONFIG_SND_SOC_RT700_SDW is not set # CONFIG_SND_SOC_RT711_SDW is not set # CONFIG_SND_SOC_RT711_SDCA_SDW is not set # CONFIG_SND_SOC_RT715_SDW is not set # CONFIG_SND_SOC_RT715_SDCA_SDW is not set # CONFIG_SND_SOC_RT9120 is not set # CONFIG_SND_SOC_SDW_MOCKUP is not set CONFIG_SND_SOC_SGTL5000=m CONFIG_SND_SOC_SIMPLE_AMPLIFIER=m CONFIG_SND_SOC_SIMPLE_MUX=m CONFIG_SND_SOC_SPDIF=m # CONFIG_SND_SOC_SRC4XXX_I2C is not set # CONFIG_SND_SOC_SSM2305 is not set # CONFIG_SND_SOC_SSM2518 is not set # CONFIG_SND_SOC_SSM2602_SPI is not set # CONFIG_SND_SOC_SSM2602_I2C is not set # CONFIG_SND_SOC_SSM4567 is not set # CONFIG_SND_SOC_STA32X is not set # CONFIG_SND_SOC_STA350 is not set # CONFIG_SND_SOC_STI_SAS is not set # CONFIG_SND_SOC_TAS2552 is not set # CONFIG_SND_SOC_TAS2562 is not set # CONFIG_SND_SOC_TAS2764 is not set # CONFIG_SND_SOC_TAS2770 is not set # CONFIG_SND_SOC_TAS2780 is not set # CONFIG_SND_SOC_TAS5086 is not set # CONFIG_SND_SOC_TAS571X is not set # CONFIG_SND_SOC_TAS5720 is not set # CONFIG_SND_SOC_TAS5805M is not set # CONFIG_SND_SOC_TAS6424 is not set # CONFIG_SND_SOC_TDA7419 is not set # CONFIG_SND_SOC_TFA9879 is not set # CONFIG_SND_SOC_TFA989X is not set # CONFIG_SND_SOC_TLV320ADC3XXX is not set # CONFIG_SND_SOC_TLV320AIC23_I2C is not set # CONFIG_SND_SOC_TLV320AIC23_SPI is not set CONFIG_SND_SOC_TLV320AIC31XX=m CONFIG_SND_SOC_TLV320AIC32X4=m CONFIG_SND_SOC_TLV320AIC32X4_I2C=m # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set CONFIG_SND_SOC_TLV320AIC3X=m CONFIG_SND_SOC_TLV320AIC3X_I2C=m # CONFIG_SND_SOC_TLV320AIC3X_SPI is not set # CONFIG_SND_SOC_TLV320ADCX140 is not set # CONFIG_SND_SOC_TS3A227E is not set # CONFIG_SND_SOC_TSCS42XX is not set # CONFIG_SND_SOC_TSCS454 is not set # CONFIG_SND_SOC_UDA1334 is not set CONFIG_SND_SOC_WCD_MBHC=m CONFIG_SND_SOC_WCD938X=m CONFIG_SND_SOC_WCD938X_SDW=m # CONFIG_SND_SOC_WM8510 is not set # CONFIG_SND_SOC_WM8523 is not set CONFIG_SND_SOC_WM8524=m # CONFIG_SND_SOC_WM8580 is not set # CONFIG_SND_SOC_WM8711 is not set # CONFIG_SND_SOC_WM8728 is not set # CONFIG_SND_SOC_WM8731_I2C is not set # CONFIG_SND_SOC_WM8731_SPI is not set # CONFIG_SND_SOC_WM8737 is not set # CONFIG_SND_SOC_WM8741 is not set # CONFIG_SND_SOC_WM8750 is not set # CONFIG_SND_SOC_WM8753 is not set # CONFIG_SND_SOC_WM8770 is not set # CONFIG_SND_SOC_WM8776 is not set # CONFIG_SND_SOC_WM8782 is not set # CONFIG_SND_SOC_WM8804_I2C is not set # CONFIG_SND_SOC_WM8804_SPI is not set # CONFIG_SND_SOC_WM8903 is not set CONFIG_SND_SOC_WM8904=m # CONFIG_SND_SOC_WM8940 is not set CONFIG_SND_SOC_WM8960=m CONFIG_SND_SOC_WM8962=m # CONFIG_SND_SOC_WM8974 is not set CONFIG_SND_SOC_WM8978=m # CONFIG_SND_SOC_WM8985 is not set CONFIG_SND_SOC_WSA881X=m # CONFIG_SND_SOC_WSA883X is not set # CONFIG_SND_SOC_ZL38060 is not set # CONFIG_SND_SOC_MAX9759 is not set # CONFIG_SND_SOC_MT6351 is not set # CONFIG_SND_SOC_MT6358 is not set # CONFIG_SND_SOC_MT6660 is not set # CONFIG_SND_SOC_NAU8315 is not set # CONFIG_SND_SOC_NAU8540 is not set # CONFIG_SND_SOC_NAU8810 is not set # CONFIG_SND_SOC_NAU8821 is not set CONFIG_SND_SOC_NAU8822=m # CONFIG_SND_SOC_NAU8824 is not set # CONFIG_SND_SOC_TPA6130A2 is not set CONFIG_SND_SOC_LPASS_MACRO_COMMON=m CONFIG_SND_SOC_LPASS_WSA_MACRO=m CONFIG_SND_SOC_LPASS_VA_MACRO=m CONFIG_SND_SOC_LPASS_RX_MACRO=m CONFIG_SND_SOC_LPASS_TX_MACRO=m # end of CODEC drivers CONFIG_SND_SIMPLE_CARD_UTILS=m CONFIG_SND_SIMPLE_CARD=m CONFIG_SND_AUDIO_GRAPH_CARD=m CONFIG_SND_AUDIO_GRAPH_CARD2=m # CONFIG_SND_AUDIO_GRAPH_CARD2_CUSTOM_SAMPLE is not set # CONFIG_SND_TEST_COMPONENT is not set # CONFIG_SND_VIRTIO is not set # # HID support # CONFIG_HID=y # CONFIG_HID_BATTERY_STRENGTH is not set # CONFIG_HIDRAW is not set # CONFIG_UHID is not set CONFIG_HID_GENERIC=y # # Special HID drivers # # CONFIG_HID_A4TECH is not set # CONFIG_HID_ACCUTOUCH is not set # CONFIG_HID_ACRUX is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_APPLEIR is not set # CONFIG_HID_ASUS is not set # CONFIG_HID_AUREAL is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_BETOP_FF is not set # CONFIG_HID_BIGBEN_FF is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_CORSAIR is not set # CONFIG_HID_COUGAR is not set # CONFIG_HID_MACALLY is not set # CONFIG_HID_PRODIKEYS is not set # CONFIG_HID_CMEDIA is not set # CONFIG_HID_CREATIVE_SB0540 is not set # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EMS_FF is not set # CONFIG_HID_ELAN is not set # CONFIG_HID_ELECOM is not set # CONFIG_HID_ELO is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_GEMBIRD is not set # CONFIG_HID_GFRM is not set # CONFIG_HID_GLORIOUS is not set # CONFIG_HID_HOLTEK is not set # CONFIG_HID_VIVALDI is not set # CONFIG_HID_GT683R is not set # CONFIG_HID_KEYTOUCH is not set # CONFIG_HID_KYE is not set # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_VIEWSONIC is not set # CONFIG_HID_VRC2 is not set # CONFIG_HID_XIAOMI is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_ICADE is not set # CONFIG_HID_ITE is not set # CONFIG_HID_JABRA is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LCPOWER is not set # CONFIG_HID_LED is not set # CONFIG_HID_LENOVO is not set # CONFIG_HID_LETSKETCH is not set CONFIG_HID_LOGITECH=y CONFIG_HID_LOGITECH_HIDPP=y CONFIG_LOGITECH_FF=y # CONFIG_LOGIRUMBLEPAD2_FF is not set CONFIG_LOGIG940_FF=y CONFIG_LOGIWHEELS_FF=y # CONFIG_HID_MAGICMOUSE is not set # CONFIG_HID_MALTRON is not set # CONFIG_HID_MAYFLASH is not set # CONFIG_HID_MEGAWORLD_FF is not set # CONFIG_HID_REDRAGON is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MONTEREY is not set CONFIG_HID_MULTITOUCH=y # CONFIG_HID_NINTENDO is not set # CONFIG_HID_NTI is not set # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PENMOUNT is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_PLANTRONICS is not set # CONFIG_HID_PLAYSTATION is not set # CONFIG_HID_PXRC is not set # CONFIG_HID_RAZER is not set # CONFIG_HID_PRIMAX is not set # CONFIG_HID_RETRODE is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_SAITEK is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SEMITEK is not set # CONFIG_HID_SIGMAMICRO is not set # CONFIG_HID_SONY is not set # CONFIG_HID_SPEEDLINK is not set # CONFIG_HID_STEAM is not set # CONFIG_HID_STEELSERIES is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_RMI is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TIVO is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_TOPRE is not set # CONFIG_HID_THINGM is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_UDRAW_PS3 is not set # CONFIG_HID_U2FZERO is not set # CONFIG_HID_WACOM is not set # CONFIG_HID_WIIMOTE is not set # CONFIG_HID_XINMO is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set # CONFIG_HID_SENSOR_HUB is not set # CONFIG_HID_ALPS is not set # CONFIG_HID_MCP2221 is not set # end of Special HID drivers # # USB HID support # CONFIG_USB_HID=y # CONFIG_HID_PID is not set # CONFIG_USB_HIDDEV is not set # end of USB HID support # # I2C HID support # CONFIG_I2C_HID_OF=m # CONFIG_I2C_HID_OF_ELAN is not set # CONFIG_I2C_HID_OF_GOODIX is not set # end of I2C HID support CONFIG_I2C_HID_CORE=m # end of HID support CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y # CONFIG_USB_LED_TRIG is not set CONFIG_USB_ULPI_BUS=y CONFIG_USB_CONN_GPIO=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=y CONFIG_USB_PCI=y # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set # # Miscellaneous USB options # CONFIG_USB_DEFAULT_PERSIST=y # CONFIG_USB_FEW_INIT_RETRIES is not set # CONFIG_USB_DYNAMIC_MINORS is not set CONFIG_USB_OTG=y # CONFIG_USB_OTG_PRODUCTLIST is not set # CONFIG_USB_OTG_DISABLE_EXTERNAL_HUB is not set # CONFIG_USB_OTG_FSM is not set # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set CONFIG_USB_AUTOSUSPEND_DELAY=2 # CONFIG_USB_MON is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set CONFIG_USB_XHCI_HCD=y # CONFIG_USB_XHCI_DBGCAP is not set CONFIG_USB_XHCI_PCI=m CONFIG_USB_XHCI_PCI_RENESAS=m CONFIG_USB_XHCI_PLATFORM=m CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_ROOT_HUB_TT=y CONFIG_USB_EHCI_TT_NEWSCHED=y CONFIG_USB_EHCI_PCI=y # CONFIG_USB_EHCI_FSL is not set CONFIG_USB_EHCI_HCD_PLATFORM=y # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_FOTG210_HCD is not set # CONFIG_USB_MAX3421_HCD is not set CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_HCD_PCI=y CONFIG_USB_OHCI_HCD_PLATFORM=y # CONFIG_USB_UHCI_HCD is not set # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_HCD_TEST_MODE is not set # # USB Device Class drivers # CONFIG_USB_ACM=m # CONFIG_USB_PRINTER is not set CONFIG_USB_WDM=m # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=y # CONFIG_USB_STORAGE_DEBUG is not set # CONFIG_USB_STORAGE_REALTEK is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_STORAGE_ENE_UB6250 is not set # CONFIG_USB_UAS is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # CONFIG_USBIP_CORE is not set CONFIG_USB_CDNS_SUPPORT=m CONFIG_USB_CDNS_HOST=y CONFIG_USB_CDNS3=m CONFIG_USB_CDNS3_GADGET=y CONFIG_USB_CDNS3_HOST=y CONFIG_USB_CDNS3_TI=m # CONFIG_USB_MUSB_HDRC is not set CONFIG_USB_DWC3=m # CONFIG_USB_DWC3_ULPI is not set # CONFIG_USB_DWC3_HOST is not set # CONFIG_USB_DWC3_GADGET is not set CONFIG_USB_DWC3_DUAL_ROLE=y # # Platform Glue Driver Support # CONFIG_USB_DWC3_HAPS=m CONFIG_USB_DWC3_KEYSTONE=m CONFIG_USB_DWC3_OF_SIMPLE=m CONFIG_USB_DWC3_AM62=m # CONFIG_USB_DWC2 is not set # CONFIG_USB_CHIPIDEA is not set # CONFIG_USB_ISP1760 is not set # # USB port drivers # CONFIG_USB_SERIAL=y # CONFIG_USB_SERIAL_CONSOLE is not set CONFIG_USB_SERIAL_GENERIC=y # CONFIG_USB_SERIAL_SIMPLE is not set # CONFIG_USB_SERIAL_AIRCABLE is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set # CONFIG_USB_SERIAL_CH341 is not set # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set CONFIG_USB_SERIAL_CP210X=y # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set CONFIG_USB_SERIAL_FTDI_SIO=m # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_F81232 is not set # CONFIG_USB_SERIAL_F8153X is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_IUU is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_METRO is not set # CONFIG_USB_SERIAL_MOS7720 is not set # CONFIG_USB_SERIAL_MOS7840 is not set # CONFIG_USB_SERIAL_MXUPORT is not set # CONFIG_USB_SERIAL_NAVMAN is not set # CONFIG_USB_SERIAL_PL2303 is not set # CONFIG_USB_SERIAL_OTI6858 is not set # CONFIG_USB_SERIAL_QCAUX is not set CONFIG_USB_SERIAL_QUALCOMM=m # CONFIG_USB_SERIAL_SPCP8X5 is not set # CONFIG_USB_SERIAL_SAFE is not set CONFIG_USB_SERIAL_SIERRAWIRELESS=m # CONFIG_USB_SERIAL_SYMBOL is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set CONFIG_USB_SERIAL_WWAN=m CONFIG_USB_SERIAL_OPTION=m # CONFIG_USB_SERIAL_OMNINET is not set # CONFIG_USB_SERIAL_OPTICON is not set # CONFIG_USB_SERIAL_XSENS_MT is not set # CONFIG_USB_SERIAL_WISHBONE is not set # CONFIG_USB_SERIAL_SSU100 is not set # CONFIG_USB_SERIAL_QT2 is not set # CONFIG_USB_SERIAL_UPD78F0730 is not set # CONFIG_USB_SERIAL_XR is not set # CONFIG_USB_SERIAL_DEBUG is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_APPLE_MFI_FASTCHARGE is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_EHSET_TEST_FIXTURE is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_EZUSB_FX2 is not set # CONFIG_USB_HUB_USB251XB is not set # CONFIG_USB_HSIC_USB3503 is not set # CONFIG_USB_HSIC_USB4604 is not set # CONFIG_USB_LINK_LAYER_TEST is not set # CONFIG_USB_CHAOSKEY is not set # CONFIG_USB_ONBOARD_HUB is not set # # USB Physical Layer drivers # CONFIG_USB_PHY=y CONFIG_NOP_USB_XCEIV=y # CONFIG_USB_GPIO_VBUS is not set # CONFIG_USB_ISP1301 is not set CONFIG_USB_ULPI=y CONFIG_USB_ULPI_VIEWPORT=y # end of USB Physical Layer drivers CONFIG_USB_GADGET=y # CONFIG_USB_GADGET_DEBUG is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32 # CONFIG_U_SERIAL_CONSOLE is not set # # USB Peripheral Controller # # CONFIG_USB_FOTG210_UDC is not set # CONFIG_USB_GR_UDC is not set # CONFIG_USB_R8A66597 is not set # CONFIG_USB_PXA27X is not set # CONFIG_USB_MV_UDC is not set # CONFIG_USB_MV_U3D is not set CONFIG_USB_SNP_CORE=y CONFIG_USB_SNP_UDC_PLAT=y # CONFIG_USB_M66592 is not set CONFIG_USB_BDC_UDC=y # CONFIG_USB_AMD5536UDC is not set # CONFIG_USB_NET2272 is not set # CONFIG_USB_NET2280 is not set # CONFIG_USB_GOKU is not set # CONFIG_USB_EG20T is not set # CONFIG_USB_GADGET_XILINX is not set # CONFIG_USB_MAX3420_UDC is not set # CONFIG_USB_DUMMY_HCD is not set # end of USB Peripheral Controller CONFIG_USB_LIBCOMPOSITE=m CONFIG_USB_F_ACM=m CONFIG_USB_F_SS_LB=m CONFIG_USB_U_SERIAL=m CONFIG_USB_U_ETHER=m CONFIG_USB_F_SERIAL=m CONFIG_USB_F_OBEX=m CONFIG_USB_F_NCM=m CONFIG_USB_F_ECM=m CONFIG_USB_F_EEM=m CONFIG_USB_F_SUBSET=m CONFIG_USB_F_RNDIS=m CONFIG_USB_F_MASS_STORAGE=m CONFIG_USB_F_FS=m CONFIG_USB_CONFIGFS=m CONFIG_USB_CONFIGFS_SERIAL=y CONFIG_USB_CONFIGFS_ACM=y CONFIG_USB_CONFIGFS_OBEX=y CONFIG_USB_CONFIGFS_NCM=y CONFIG_USB_CONFIGFS_ECM=y CONFIG_USB_CONFIGFS_ECM_SUBSET=y CONFIG_USB_CONFIGFS_RNDIS=y CONFIG_USB_CONFIGFS_EEM=y CONFIG_USB_CONFIGFS_MASS_STORAGE=y # CONFIG_USB_CONFIGFS_F_LB_SS is not set CONFIG_USB_CONFIGFS_F_FS=y # CONFIG_USB_CONFIGFS_F_UAC1 is not set # CONFIG_USB_CONFIGFS_F_UAC1_LEGACY is not set # CONFIG_USB_CONFIGFS_F_UAC2 is not set # CONFIG_USB_CONFIGFS_F_MIDI is not set # CONFIG_USB_CONFIGFS_F_HID is not set # CONFIG_USB_CONFIGFS_F_UVC is not set # CONFIG_USB_CONFIGFS_F_PRINTER is not set # # USB Gadget precomposed configurations # CONFIG_USB_ZERO=m # CONFIG_USB_ZERO_HNPTEST is not set # CONFIG_USB_AUDIO is not set CONFIG_USB_ETH=m CONFIG_USB_ETH_RNDIS=y # CONFIG_USB_ETH_EEM is not set CONFIG_USB_G_NCM=m # CONFIG_USB_GADGETFS is not set # CONFIG_USB_FUNCTIONFS is not set CONFIG_USB_MASS_STORAGE=m CONFIG_USB_G_SERIAL=m # CONFIG_USB_MIDI_GADGET is not set # CONFIG_USB_G_PRINTER is not set CONFIG_USB_CDC_COMPOSITE=m # CONFIG_USB_G_ACM_MS is not set CONFIG_USB_G_MULTI=m CONFIG_USB_G_MULTI_RNDIS=y CONFIG_USB_G_MULTI_CDC=y # CONFIG_USB_G_HID is not set # CONFIG_USB_G_DBGP is not set # CONFIG_USB_G_WEBCAM is not set # CONFIG_USB_RAW_GADGET is not set # end of USB Gadget precomposed configurations CONFIG_TYPEC=m CONFIG_TYPEC_TCPM=m CONFIG_TYPEC_TCPCI=m # CONFIG_TYPEC_RT1711H is not set # CONFIG_TYPEC_MT6360 is not set # CONFIG_TYPEC_TCPCI_MAXIM is not set CONFIG_TYPEC_FUSB302=m # CONFIG_TYPEC_UCSI is not set CONFIG_TYPEC_TPS6598X=m # CONFIG_TYPEC_ANX7411 is not set # CONFIG_TYPEC_RT1719 is not set CONFIG_TYPEC_HD3SS3220=m # CONFIG_TYPEC_STUSB160X is not set # CONFIG_TYPEC_WUSB3801 is not set # # USB Type-C Multiplexer/DeMultiplexer Switch support # # CONFIG_TYPEC_MUX_FSA4480 is not set # CONFIG_TYPEC_MUX_PI3USB30532 is not set # end of USB Type-C Multiplexer/DeMultiplexer Switch support # # USB Type-C Alternate Mode drivers # # CONFIG_TYPEC_DP_ALTMODE is not set # end of USB Type-C Alternate Mode drivers CONFIG_USB_ROLE_SWITCH=y CONFIG_MMC=y CONFIG_PWRSEQ_EMMC=y # CONFIG_PWRSEQ_SD8787 is not set CONFIG_PWRSEQ_SIMPLE=y CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=32 # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_DEBUG is not set # CONFIG_MMC_ARMMMCI is not set CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_IO_ACCESSORS=y # CONFIG_MMC_SDHCI_PCI is not set CONFIG_MMC_SDHCI_PLTFM=y CONFIG_MMC_SDHCI_OF_ARASAN=y # CONFIG_MMC_SDHCI_OF_AT91 is not set # CONFIG_MMC_SDHCI_OF_DWCMSHC is not set # CONFIG_MMC_SDHCI_CADENCE is not set # CONFIG_MMC_SDHCI_F_SDH30 is not set # CONFIG_MMC_SDHCI_MILBEAUT is not set # CONFIG_MMC_TIFM_SD is not set CONFIG_MMC_SPI=y # CONFIG_MMC_CB710 is not set # CONFIG_MMC_VIA_SDMMC is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MMC_USDHI6ROL0 is not set CONFIG_MMC_CQHCI=y # CONFIG_MMC_HSQ is not set # CONFIG_MMC_TOSHIBA_PCI is not set # CONFIG_MMC_MTK is not set # CONFIG_MMC_SDHCI_XENON is not set # CONFIG_MMC_SDHCI_OMAP is not set CONFIG_MMC_SDHCI_AM654=y CONFIG_SCSI_UFSHCD=y CONFIG_SCSI_UFS_BSG=y # CONFIG_SCSI_UFS_HPB is not set # CONFIG_SCSI_UFS_HWMON is not set # CONFIG_SCSI_UFSHCD_PCI is not set CONFIG_SCSI_UFSHCD_PLATFORM=y CONFIG_SCSI_UFS_CDNS_PLATFORM=m # CONFIG_SCSI_UFS_DWC_TC_PLATFORM is not set CONFIG_SCSI_UFS_TI_J721E=m # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y # CONFIG_LEDS_CLASS_FLASH is not set CONFIG_LEDS_CLASS_MULTICOLOR=m # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set # # LED drivers # # CONFIG_LEDS_AN30259A is not set # CONFIG_LEDS_AW2013 is not set # CONFIG_LEDS_BCM6328 is not set # CONFIG_LEDS_BCM6358 is not set # CONFIG_LEDS_CR0014114 is not set # CONFIG_LEDS_EL15203000 is not set # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_LM3532 is not set # CONFIG_LEDS_LM3642 is not set CONFIG_LEDS_LM3692X=m # CONFIG_LEDS_MT6323 is not set CONFIG_LEDS_PCA9532=m # CONFIG_LEDS_PCA9532_GPIO is not set CONFIG_LEDS_GPIO=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP3952 is not set # CONFIG_LEDS_LP50XX is not set # CONFIG_LEDS_LP55XX_COMMON is not set # CONFIG_LEDS_LP8860 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_PCA963X is not set # CONFIG_LEDS_DAC124S085 is not set CONFIG_LEDS_PWM=y # CONFIG_LEDS_REGULATOR is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_TCA6507 is not set # CONFIG_LEDS_TLC591XX is not set # CONFIG_LEDS_LM355x is not set # CONFIG_LEDS_IS31FL319X is not set # CONFIG_LEDS_IS31FL32XX is not set # # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM) # CONFIG_LEDS_BLINKM=y CONFIG_LEDS_SYSCON=y # CONFIG_LEDS_MLXREG is not set # CONFIG_LEDS_USER is not set # CONFIG_LEDS_SPI_BYTE is not set # CONFIG_LEDS_TI_LMU_COMMON is not set # # Flash and Torch LED drivers # # # RGB LED drivers # # CONFIG_LEDS_PWM_MULTICOLOR is not set # # LED Triggers # CONFIG_LEDS_TRIGGERS=y CONFIG_LEDS_TRIGGER_TIMER=y # CONFIG_LEDS_TRIGGER_ONESHOT is not set CONFIG_LEDS_TRIGGER_DISK=y # CONFIG_LEDS_TRIGGER_MTD is not set CONFIG_LEDS_TRIGGER_HEARTBEAT=y # CONFIG_LEDS_TRIGGER_BACKLIGHT is not set CONFIG_LEDS_TRIGGER_CPU=y # CONFIG_LEDS_TRIGGER_ACTIVITY is not set # CONFIG_LEDS_TRIGGER_GPIO is not set CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # # CONFIG_LEDS_TRIGGER_TRANSIENT is not set # CONFIG_LEDS_TRIGGER_CAMERA is not set CONFIG_LEDS_TRIGGER_PANIC=y # CONFIG_LEDS_TRIGGER_NETDEV is not set # CONFIG_LEDS_TRIGGER_PATTERN is not set # CONFIG_LEDS_TRIGGER_AUDIO is not set # CONFIG_LEDS_TRIGGER_TTY is not set # # Simple LED drivers # # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_EDAC_SUPPORT=y CONFIG_EDAC=y CONFIG_EDAC_LEGACY_SYSFS=y # CONFIG_EDAC_DEBUG is not set # CONFIG_EDAC_THUNDERX is not set # CONFIG_EDAC_XGENE is not set # CONFIG_EDAC_DMC520 is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" CONFIG_RTC_SYSTOHC=y CONFIG_RTC_SYSTOHC_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set CONFIG_RTC_NVMEM=y # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABEOZ9 is not set # CONFIG_RTC_DRV_ABX80X is not set CONFIG_RTC_DRV_DS1307=m # CONFIG_RTC_DRV_DS1307_CENTURY is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set CONFIG_RTC_DRV_HYM8563=m # CONFIG_RTC_DRV_MAX6900 is not set CONFIG_RTC_DRV_MAX77686=y # CONFIG_RTC_DRV_NCT3018Y is not set CONFIG_RTC_DRV_RK808=m # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_ISL12026 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set CONFIG_RTC_DRV_PCF85063=m CONFIG_RTC_DRV_PCF85363=m # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set CONFIG_RTC_DRV_M41T80=m # CONFIG_RTC_DRV_M41T80_WDT is not set CONFIG_RTC_DRV_BQ32K=m CONFIG_RTC_DRV_TPS6594=y # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set CONFIG_RTC_DRV_RX8581=m # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set CONFIG_RTC_DRV_RV3028=m # CONFIG_RTC_DRV_RV3032 is not set CONFIG_RTC_DRV_RV8803=m # CONFIG_RTC_DRV_SD3078 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T93 is not set # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1302 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1343 is not set # CONFIG_RTC_DRV_DS1347 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6916 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RX4581 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_PCF2123 is not set # CONFIG_RTC_DRV_MCP795 is not set CONFIG_RTC_I2C_AND_SPI=y # # SPI and I2C RTC drivers # CONFIG_RTC_DRV_DS3232=m CONFIG_RTC_DRV_DS3232_HWMON=y CONFIG_RTC_DRV_PCF2127=m # CONFIG_RTC_DRV_RV3029C2 is not set # CONFIG_RTC_DRV_RX6110 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1685_FAMILY is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_DS2404 is not set CONFIG_RTC_DRV_EFI=y # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_OPTEE is not set # CONFIG_RTC_DRV_ZYNQMP is not set # # on-CPU RTC drivers # # CONFIG_RTC_DRV_PL030 is not set # CONFIG_RTC_DRV_PL031 is not set # CONFIG_RTC_DRV_CADENCE is not set # CONFIG_RTC_DRV_FTRTC010 is not set CONFIG_RTC_DRV_MT6397=m # CONFIG_RTC_DRV_R7301 is not set CONFIG_RTC_DRV_TI_K3=m # # HID Sensor RTC drivers # # CONFIG_RTC_DRV_GOLDFISH is not set CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y # CONFIG_ALTERA_MSGDMA is not set # CONFIG_AMBA_PL08X is not set CONFIG_BCM_SBA_RAID=m # CONFIG_DW_AXI_DMAC is not set # CONFIG_FSL_EDMA is not set # CONFIG_FSL_QDMA is not set # CONFIG_INTEL_IDMA64 is not set # CONFIG_MV_XOR_V2 is not set # CONFIG_PL330_DMA is not set # CONFIG_PLX_DMA is not set # CONFIG_XILINX_DMA is not set # CONFIG_XILINX_ZYNQMP_DMA is not set # CONFIG_XILINX_ZYNQMP_DPDMA is not set # CONFIG_QCOM_HIDMA_MGMT is not set # CONFIG_QCOM_HIDMA is not set # CONFIG_DW_DMAC is not set # CONFIG_DW_DMAC_PCI is not set # CONFIG_DW_EDMA is not set # CONFIG_DW_EDMA_PCIE is not set # CONFIG_SF_PDMA is not set CONFIG_TI_K3_UDMA=y CONFIG_TI_K3_UDMA_GLUE_LAYER=y CONFIG_TI_K3_PSIL=y # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set # CONFIG_DMATEST is not set CONFIG_DMA_ENGINE_RAID=y # # DMABUF options # CONFIG_SYNC_FILE=y # CONFIG_SW_SYNC is not set # CONFIG_UDMABUF is not set # CONFIG_DMABUF_MOVE_NOTIFY is not set # CONFIG_DMABUF_DEBUG is not set # CONFIG_DMABUF_SELFTESTS is not set CONFIG_DMABUF_HEAPS=y # CONFIG_DMABUF_SYSFS_STATS is not set CONFIG_DMABUF_HEAPS_SYSTEM=y CONFIG_DMABUF_HEAPS_CMA=y CONFIG_DMABUF_HEAPS_CARVEOUT=y # end of DMABUF options # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set CONFIG_VFIO=y CONFIG_VFIO_IOMMU_TYPE1=y CONFIG_VFIO_VIRQFD=y # CONFIG_VFIO_NOIOMMU is not set CONFIG_VFIO_PCI_CORE=y CONFIG_VFIO_PCI_MMAP=y CONFIG_VFIO_PCI_INTX=y CONFIG_VFIO_PCI=y # CONFIG_VFIO_PLATFORM is not set # CONFIG_VFIO_MDEV is not set # CONFIG_VIRT_DRIVERS is not set CONFIG_VIRTIO_ANCHOR=y CONFIG_VIRTIO=y CONFIG_VIRTIO_PCI_LIB=y CONFIG_VIRTIO_PCI_LIB_LEGACY=y CONFIG_VIRTIO_MENU=y CONFIG_VIRTIO_PCI=y CONFIG_VIRTIO_PCI_LEGACY=y CONFIG_VIRTIO_BALLOON=y # CONFIG_VIRTIO_MEM is not set # CONFIG_VIRTIO_INPUT is not set CONFIG_VIRTIO_MMIO=y # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set # CONFIG_VDPA is not set CONFIG_VHOST_MENU=y # CONFIG_VHOST_NET is not set # CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set # # Microsoft Hyper-V guest support # # end of Microsoft Hyper-V guest support # CONFIG_GREYBUS is not set # CONFIG_COMEDI is not set CONFIG_STAGING=y # CONFIG_PRISM2_USB is not set # CONFIG_RTL8192U is not set # CONFIG_RTLLIB is not set # CONFIG_RTL8723BS is not set # CONFIG_R8712U is not set CONFIG_R8188EU=m # CONFIG_RTS5208 is not set # CONFIG_VT6655 is not set # CONFIG_VT6656 is not set # # IIO staging drivers # # # Accelerometers # # CONFIG_ADIS16203 is not set # CONFIG_ADIS16240 is not set # end of Accelerometers # # Analog to digital converters # # CONFIG_AD7816 is not set # end of Analog to digital converters # # Analog digital bi-direction converters # # CONFIG_ADT7316 is not set # end of Analog digital bi-direction converters # # Direct Digital Synthesis # # CONFIG_AD9832 is not set # CONFIG_AD9834 is not set # end of Direct Digital Synthesis # # Network Analyzer, Impedance Converters # # CONFIG_AD5933 is not set # end of Network Analyzer, Impedance Converters # # Active energy metering IC # # CONFIG_ADE7854 is not set # end of Active energy metering IC # # Resolver to digital converters # # CONFIG_AD2S1210 is not set # end of Resolver to digital converters # end of IIO staging drivers # CONFIG_FB_SM750 is not set CONFIG_STAGING_MEDIA=y CONFIG_VIDEO_MAX96712=m # CONFIG_STAGING_MEDIA_DEPRECATED is not set # CONFIG_STAGING_BOARD is not set # CONFIG_LTE_GDM724X is not set # CONFIG_FB_TFT is not set # CONFIG_KS7010 is not set # CONFIG_PI433 is not set # CONFIG_XIL_AXIS_FIFO is not set # CONFIG_FIELDBUS_DEV is not set # CONFIG_QLGE is not set # CONFIG_VME_BUS is not set # CONFIG_GOLDFISH is not set # CONFIG_CHROME_PLATFORMS is not set # CONFIG_MELLANOX_PLATFORM is not set # CONFIG_SURFACE_PLATFORMS is not set CONFIG_HAVE_CLK=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Clock driver for ARM Reference designs # # CONFIG_CLK_ICST is not set # CONFIG_CLK_SP810 is not set # end of Clock driver for ARM Reference designs # CONFIG_LMK04832 is not set # CONFIG_COMMON_CLK_MAX77686 is not set # CONFIG_COMMON_CLK_MAX9485 is not set # CONFIG_COMMON_CLK_RK808 is not set CONFIG_COMMON_CLK_SCMI=y # CONFIG_COMMON_CLK_SI5341 is not set # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_COMMON_CLK_SI514 is not set # CONFIG_COMMON_CLK_SI544 is not set # CONFIG_COMMON_CLK_SI570 is not set # CONFIG_COMMON_CLK_CDCE706 is not set # CONFIG_COMMON_CLK_CDCE925 is not set CONFIG_COMMON_CLK_CS2000_CP=y # CONFIG_COMMON_CLK_AXI_CLKGEN is not set # CONFIG_COMMON_CLK_XGENE is not set CONFIG_COMMON_CLK_PWM=y # CONFIG_COMMON_CLK_RS9_PCIE is not set # CONFIG_COMMON_CLK_VC5 is not set # CONFIG_COMMON_CLK_VC7 is not set # CONFIG_COMMON_CLK_BD718XX is not set # CONFIG_COMMON_CLK_FIXED_MMIO is not set CONFIG_TI_SCI_CLK=y # CONFIG_TI_SCI_CLK_PROBE_FROM_FW is not set CONFIG_TI_SYSCON_CLK=y # CONFIG_XILINX_VCU is not set # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set CONFIG_HWSPINLOCK=y # CONFIG_HWSPINLOCK_OMAP is not set # # Clock Source drivers # CONFIG_TIMER_OF=y CONFIG_TIMER_PROBE=y CONFIG_OMAP_DM_TIMER=y CONFIG_ARM_ARCH_TIMER=y CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y CONFIG_ARM_ARCH_TIMER_OOL_WORKAROUND=y # CONFIG_FSL_ERRATUM_A008585 is not set # CONFIG_HISILICON_ERRATUM_161010101 is not set CONFIG_ARM64_ERRATUM_858921=y # CONFIG_MICROCHIP_PIT64B is not set # end of Clock Source drivers CONFIG_MAILBOX=y # CONFIG_ARM_MHU is not set # CONFIG_ARM_MHU_V2 is not set # CONFIG_PLATFORM_MHU is not set # CONFIG_PL320_MBOX is not set CONFIG_OMAP2PLUS_MBOX=y CONFIG_OMAP_MBOX_KFIFO_SIZE=256 # CONFIG_ALTERA_MBOX is not set CONFIG_TI_MESSAGE_MANAGER=y # CONFIG_MAILBOX_TEST is not set CONFIG_IOMMU_IOVA=y CONFIG_IOMMU_API=y CONFIG_IOMMU_SUPPORT=y # # Generic IOMMU Pagetable Support # CONFIG_IOMMU_IO_PGTABLE=y CONFIG_IOMMU_IO_PGTABLE_LPAE=y # CONFIG_IOMMU_IO_PGTABLE_LPAE_SELFTEST is not set CONFIG_IOMMU_IO_PGTABLE_ARMV7S=y # CONFIG_IOMMU_IO_PGTABLE_ARMV7S_SELFTEST is not set CONFIG_IOMMU_IO_PGTABLE_DART=y # end of Generic IOMMU Pagetable Support # CONFIG_IOMMU_DEBUGFS is not set CONFIG_IOMMU_DEFAULT_DMA_STRICT=y # CONFIG_IOMMU_DEFAULT_DMA_LAZY is not set # CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set CONFIG_OF_IOMMU=y CONFIG_IOMMU_DMA=y CONFIG_ARM_SMMU=y # CONFIG_ARM_SMMU_LEGACY_DT_BINDINGS is not set CONFIG_ARM_SMMU_DISABLE_BYPASS_BY_DEFAULT=y CONFIG_ARM_SMMU_V3=y # CONFIG_ARM_SMMU_V3_SVA is not set # CONFIG_VIRTIO_IOMMU is not set # # Remoteproc drivers # CONFIG_REMOTEPROC=y # CONFIG_REMOTEPROC_CDEV is not set CONFIG_PRU_REMOTEPROC=m CONFIG_TI_K3_DSP_REMOTEPROC=m CONFIG_TI_K3_M4_REMOTEPROC=m CONFIG_TI_K3_R5_REMOTEPROC=m # end of Remoteproc drivers # # Rpmsg drivers # CONFIG_RPMSG=y CONFIG_RPMSG_CHAR=m CONFIG_RPMSG_CTRL=m CONFIG_RPMSG_NS=m # CONFIG_RPMSG_QCOM_GLINK_RPM is not set CONFIG_RPMSG_VIRTIO=m CONFIG_RPMSG_PRU=m # end of Rpmsg drivers # # Rpmsg virtual device drivers # CONFIG_RPMSG_KDRV=y # CONFIG_RPMSG_KDRV_DEMO is not set # CONFIG_RPMSG_KDRV_DISPLAY is not set CONFIG_RPMSG_KDRV_ETH_SWITCH=y # end of Rpmsg virtual device drivers CONFIG_SOUNDWIRE=m # # SoundWire Devices # # CONFIG_SOUNDWIRE_QCOM is not set # # SOC (System On Chip) specific Drivers # # # Amlogic SoC drivers # # end of Amlogic SoC drivers # # Broadcom SoC drivers # # CONFIG_SOC_BRCMSTB is not set # end of Broadcom SoC drivers # # NXP/Freescale QorIQ SoC drivers # # CONFIG_QUICC_ENGINE is not set CONFIG_FSL_RCPM=y # end of NXP/Freescale QorIQ SoC drivers # # fujitsu SoC drivers # # end of fujitsu SoC drivers # # i.MX SoC drivers # # end of i.MX SoC drivers # # Enable LiteX SoC Builder specific drivers # # CONFIG_LITEX_SOC_CONTROLLER is not set # end of Enable LiteX SoC Builder specific drivers # # Qualcomm SoC drivers # CONFIG_QCOM_QMI_HELPERS=m # end of Qualcomm SoC drivers CONFIG_SOC_TI=y CONFIG_TI_SCI_PM_DOMAINS=y CONFIG_TI_K3_RINGACC=y CONFIG_TI_K3_SOCINFO=y CONFIG_TI_PRUSS=m CONFIG_TI_SCI_INTA_MSI_DOMAIN=y # # Xilinx SoC drivers # # end of Xilinx SoC drivers # end of SOC (System On Chip) specific Drivers CONFIG_PM_DEVFREQ=y # # DEVFREQ Governors # CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y # CONFIG_DEVFREQ_GOV_PERFORMANCE is not set # CONFIG_DEVFREQ_GOV_POWERSAVE is not set CONFIG_DEVFREQ_GOV_USERSPACE=m # CONFIG_DEVFREQ_GOV_PASSIVE is not set # # DEVFREQ Drivers # # CONFIG_PM_DEVFREQ_EVENT is not set CONFIG_EXTCON=y # # Extcon Device Drivers # # CONFIG_EXTCON_ADC_JACK is not set # CONFIG_EXTCON_FSA9480 is not set # CONFIG_EXTCON_GPIO is not set # CONFIG_EXTCON_MAX3355 is not set CONFIG_EXTCON_PTN5150=m # CONFIG_EXTCON_RT8973A is not set # CONFIG_EXTCON_SM5502 is not set CONFIG_EXTCON_USB_GPIO=y # CONFIG_EXTCON_USBC_TUSB320 is not set CONFIG_MEMORY=y # CONFIG_ARM_PL172_MPMC is not set CONFIG_OMAP_GPMC=y # CONFIG_OMAP_GPMC_DEBUG is not set CONFIG_IIO=y CONFIG_IIO_BUFFER=y CONFIG_IIO_BUFFER_CB=y # CONFIG_IIO_BUFFER_DMA is not set # CONFIG_IIO_BUFFER_DMAENGINE is not set # CONFIG_IIO_BUFFER_HW_CONSUMER is not set CONFIG_IIO_KFIFO_BUF=y CONFIG_IIO_TRIGGERED_BUFFER=m CONFIG_IIO_CONFIGFS=m CONFIG_IIO_TRIGGER=y CONFIG_IIO_CONSUMERS_PER_TRIGGER=2 CONFIG_IIO_SW_DEVICE=m CONFIG_IIO_SW_TRIGGER=m # CONFIG_IIO_TRIGGERED_EVENT is not set # # Accelerometers # # CONFIG_ADIS16201 is not set # CONFIG_ADIS16209 is not set # CONFIG_ADXL313_I2C is not set # CONFIG_ADXL313_SPI is not set # CONFIG_ADXL345_I2C is not set # CONFIG_ADXL345_SPI is not set # CONFIG_ADXL355_I2C is not set # CONFIG_ADXL355_SPI is not set # CONFIG_ADXL367_SPI is not set # CONFIG_ADXL367_I2C is not set # CONFIG_ADXL372_SPI is not set # CONFIG_ADXL372_I2C is not set # CONFIG_BMA180 is not set # CONFIG_BMA220 is not set # CONFIG_BMA400 is not set # CONFIG_BMC150_ACCEL is not set # CONFIG_BMI088_ACCEL is not set # CONFIG_DA280 is not set # CONFIG_DA311 is not set # CONFIG_DMARD06 is not set # CONFIG_DMARD09 is not set # CONFIG_DMARD10 is not set # CONFIG_FXLS8962AF_I2C is not set # CONFIG_FXLS8962AF_SPI is not set # CONFIG_IIO_ST_ACCEL_3AXIS is not set # CONFIG_KXSD9 is not set # CONFIG_KXCJK1013 is not set # CONFIG_MC3230 is not set # CONFIG_MMA7455_I2C is not set # CONFIG_MMA7455_SPI is not set # CONFIG_MMA7660 is not set # CONFIG_MMA8452 is not set # CONFIG_MMA9551 is not set # CONFIG_MMA9553 is not set # CONFIG_MSA311 is not set # CONFIG_MXC4005 is not set # CONFIG_MXC6255 is not set # CONFIG_SCA3000 is not set # CONFIG_SCA3300 is not set # CONFIG_STK8312 is not set # CONFIG_STK8BA50 is not set # end of Accelerometers # # Analog to digital converters # # CONFIG_AD7091R5 is not set # CONFIG_AD7124 is not set # CONFIG_AD7192 is not set # CONFIG_AD7266 is not set # CONFIG_AD7280 is not set # CONFIG_AD7291 is not set # CONFIG_AD7292 is not set # CONFIG_AD7298 is not set # CONFIG_AD7476 is not set # CONFIG_AD7606_IFACE_PARALLEL is not set # CONFIG_AD7606_IFACE_SPI is not set # CONFIG_AD7766 is not set # CONFIG_AD7768_1 is not set # CONFIG_AD7780 is not set # CONFIG_AD7791 is not set # CONFIG_AD7793 is not set # CONFIG_AD7887 is not set # CONFIG_AD7923 is not set # CONFIG_AD7949 is not set # CONFIG_AD799X is not set # CONFIG_ADI_AXI_ADC is not set # CONFIG_AXP20X_ADC is not set # CONFIG_AXP288_ADC is not set # CONFIG_CC10001_ADC is not set # CONFIG_ENVELOPE_DETECTOR is not set # CONFIG_HI8435 is not set # CONFIG_HX711 is not set # CONFIG_INA2XX_ADC is not set # CONFIG_LTC2471 is not set # CONFIG_LTC2485 is not set # CONFIG_LTC2496 is not set # CONFIG_LTC2497 is not set # CONFIG_MAX1027 is not set # CONFIG_MAX11100 is not set # CONFIG_MAX1118 is not set # CONFIG_MAX11205 is not set # CONFIG_MAX1241 is not set # CONFIG_MAX1363 is not set CONFIG_MAX9611=m # CONFIG_MCP320X is not set # CONFIG_MCP3422 is not set # CONFIG_MCP3911 is not set # CONFIG_MEDIATEK_MT6360_ADC is not set # CONFIG_NAU7802 is not set # CONFIG_RICHTEK_RTQ6056 is not set # CONFIG_SD_ADC_MODULATOR is not set # CONFIG_TI_ADC081C is not set # CONFIG_TI_ADC0832 is not set # CONFIG_TI_ADC084S021 is not set # CONFIG_TI_ADC12138 is not set # CONFIG_TI_ADC108S102 is not set # CONFIG_TI_ADC128S052 is not set # CONFIG_TI_ADC161S626 is not set CONFIG_TI_ADS1015=m # CONFIG_TI_ADS7950 is not set CONFIG_TI_ADS8344=y # CONFIG_TI_ADS8688 is not set # CONFIG_TI_ADS124S08 is not set # CONFIG_TI_ADS131E08 is not set CONFIG_TI_AM335X_ADC=m # CONFIG_TI_TLC4541 is not set # CONFIG_TI_TSC2046 is not set # CONFIG_VF610_ADC is not set # CONFIG_XILINX_XADC is not set # end of Analog to digital converters # # Analog to digital and digital to analog converters # # CONFIG_AD74413R is not set # end of Analog to digital and digital to analog converters # # Analog Front Ends # # CONFIG_IIO_RESCALE is not set # end of Analog Front Ends # # Amplifiers # # CONFIG_AD8366 is not set # CONFIG_ADA4250 is not set # CONFIG_HMC425 is not set # end of Amplifiers # # Capacitance to digital converters # # CONFIG_AD7150 is not set # CONFIG_AD7746 is not set # end of Capacitance to digital converters # # Chemical Sensors # # CONFIG_ATLAS_PH_SENSOR is not set # CONFIG_ATLAS_EZO_SENSOR is not set # CONFIG_BME680 is not set # CONFIG_CCS811 is not set # CONFIG_IAQCORE is not set # CONFIG_PMS7003 is not set # CONFIG_SCD30_CORE is not set # CONFIG_SCD4X is not set # CONFIG_SENSIRION_SGP30 is not set # CONFIG_SENSIRION_SGP40 is not set # CONFIG_SPS30_I2C is not set # CONFIG_SPS30_SERIAL is not set # CONFIG_SENSEAIR_SUNRISE_CO2 is not set # CONFIG_VZ89X is not set # end of Chemical Sensors # # Hid Sensor IIO Common # # end of Hid Sensor IIO Common # # IIO SCMI Sensors # # CONFIG_IIO_SCMI is not set # end of IIO SCMI Sensors # # SSP Sensor Common # # CONFIG_IIO_SSP_SENSORHUB is not set # end of SSP Sensor Common CONFIG_IIO_ST_SENSORS_I2C=m CONFIG_IIO_ST_SENSORS_SPI=m CONFIG_IIO_ST_SENSORS_CORE=m # # Digital to analog converters # # CONFIG_AD3552R is not set # CONFIG_AD5064 is not set # CONFIG_AD5360 is not set # CONFIG_AD5380 is not set # CONFIG_AD5421 is not set # CONFIG_AD5446 is not set # CONFIG_AD5449 is not set # CONFIG_AD5592R is not set # CONFIG_AD5593R is not set # CONFIG_AD5504 is not set # CONFIG_AD5624R_SPI is not set # CONFIG_LTC2688 is not set # CONFIG_AD5686_SPI is not set # CONFIG_AD5696_I2C is not set # CONFIG_AD5755 is not set # CONFIG_AD5758 is not set # CONFIG_AD5761 is not set # CONFIG_AD5764 is not set # CONFIG_AD5766 is not set # CONFIG_AD5770R is not set # CONFIG_AD5791 is not set # CONFIG_AD7293 is not set # CONFIG_AD7303 is not set # CONFIG_AD8801 is not set # CONFIG_DPOT_DAC is not set # CONFIG_DS4424 is not set # CONFIG_LTC1660 is not set # CONFIG_LTC2632 is not set # CONFIG_M62332 is not set # CONFIG_MAX517 is not set # CONFIG_MAX5821 is not set # CONFIG_MCP4725 is not set # CONFIG_MCP4922 is not set # CONFIG_TI_DAC082S085 is not set # CONFIG_TI_DAC5571 is not set # CONFIG_TI_DAC7311 is not set # CONFIG_TI_DAC7612 is not set # CONFIG_VF610_DAC is not set # end of Digital to analog converters # # IIO dummy driver # CONFIG_IIO_DUMMY_EVGEN=m CONFIG_IIO_SIMPLE_DUMMY=m CONFIG_IIO_SIMPLE_DUMMY_EVENTS=y CONFIG_IIO_SIMPLE_DUMMY_BUFFER=y # end of IIO dummy driver # # Filters # # CONFIG_ADMV8818 is not set # end of Filters # # Frequency Synthesizers DDS/PLL # # # Clock Generator/Distribution # # CONFIG_AD9523 is not set # end of Clock Generator/Distribution # # Phase-Locked Loop (PLL) frequency synthesizers # # CONFIG_ADF4350 is not set # CONFIG_ADF4371 is not set # CONFIG_ADMV1013 is not set # CONFIG_ADMV1014 is not set # CONFIG_ADMV4420 is not set # CONFIG_ADRF6780 is not set # end of Phase-Locked Loop (PLL) frequency synthesizers # end of Frequency Synthesizers DDS/PLL # # Digital gyroscope sensors # # CONFIG_ADIS16080 is not set # CONFIG_ADIS16130 is not set # CONFIG_ADIS16136 is not set # CONFIG_ADIS16260 is not set # CONFIG_ADXRS290 is not set # CONFIG_ADXRS450 is not set # CONFIG_BMG160 is not set # CONFIG_FXAS21002C is not set # CONFIG_MPU3050_I2C is not set # CONFIG_IIO_ST_GYRO_3AXIS is not set # CONFIG_ITG3200 is not set # end of Digital gyroscope sensors # # Health Sensors # # # Heart Rate Monitors # # CONFIG_AFE4403 is not set # CONFIG_AFE4404 is not set # CONFIG_MAX30100 is not set # CONFIG_MAX30102 is not set # end of Heart Rate Monitors # end of Health Sensors # # Humidity sensors # # CONFIG_AM2315 is not set # CONFIG_DHT11 is not set # CONFIG_HDC100X is not set # CONFIG_HDC2010 is not set # CONFIG_HTS221 is not set # CONFIG_HTU21 is not set # CONFIG_SI7005 is not set # CONFIG_SI7020 is not set # end of Humidity sensors # # Inertial measurement units # # CONFIG_ADIS16400 is not set # CONFIG_ADIS16460 is not set # CONFIG_ADIS16475 is not set # CONFIG_ADIS16480 is not set # CONFIG_BMI160_I2C is not set # CONFIG_BMI160_SPI is not set # CONFIG_BOSCH_BNO055_SERIAL is not set # CONFIG_BOSCH_BNO055_I2C is not set # CONFIG_FXOS8700_I2C is not set # CONFIG_FXOS8700_SPI is not set # CONFIG_KMX61 is not set # CONFIG_INV_ICM42600_I2C is not set # CONFIG_INV_ICM42600_SPI is not set # CONFIG_INV_MPU6050_I2C is not set # CONFIG_INV_MPU6050_SPI is not set CONFIG_IIO_ST_LSM6DSX=m CONFIG_IIO_ST_LSM6DSX_I2C=m CONFIG_IIO_ST_LSM6DSX_SPI=m # CONFIG_IIO_ST_LSM9DS0 is not set # end of Inertial measurement units # # Light sensors # # CONFIG_ADJD_S311 is not set # CONFIG_ADUX1020 is not set # CONFIG_AL3010 is not set # CONFIG_AL3320A is not set # CONFIG_APDS9300 is not set # CONFIG_APDS9960 is not set # CONFIG_AS73211 is not set # CONFIG_BH1750 is not set # CONFIG_BH1780 is not set # CONFIG_CM32181 is not set # CONFIG_CM3232 is not set # CONFIG_CM3323 is not set # CONFIG_CM3605 is not set # CONFIG_CM36651 is not set # CONFIG_GP2AP002 is not set # CONFIG_GP2AP020A00F is not set CONFIG_SENSORS_ISL29018=m # CONFIG_SENSORS_ISL29028 is not set # CONFIG_ISL29125 is not set # CONFIG_JSA1212 is not set # CONFIG_RPR0521 is not set # CONFIG_LTR501 is not set # CONFIG_LTRF216A is not set # CONFIG_LV0104CS is not set # CONFIG_MAX44000 is not set # CONFIG_MAX44009 is not set # CONFIG_NOA1305 is not set # CONFIG_OPT3001 is not set # CONFIG_PA12203001 is not set # CONFIG_SI1133 is not set # CONFIG_SI1145 is not set # CONFIG_STK3310 is not set # CONFIG_ST_UVIS25 is not set # CONFIG_TCS3414 is not set # CONFIG_TCS3472 is not set # CONFIG_SENSORS_TSL2563 is not set # CONFIG_TSL2583 is not set # CONFIG_TSL2591 is not set # CONFIG_TSL2772 is not set # CONFIG_TSL4531 is not set # CONFIG_US5182D is not set CONFIG_VCNL4000=m # CONFIG_VCNL4035 is not set # CONFIG_VEML6030 is not set # CONFIG_VEML6070 is not set # CONFIG_VL6180 is not set # CONFIG_ZOPT2201 is not set # end of Light sensors # # Magnetometer sensors # # CONFIG_AK8974 is not set # CONFIG_AK8975 is not set # CONFIG_AK09911 is not set # CONFIG_BMC150_MAGN_I2C is not set # CONFIG_BMC150_MAGN_SPI is not set # CONFIG_MAG3110 is not set # CONFIG_MMC35240 is not set CONFIG_IIO_ST_MAGN_3AXIS=m CONFIG_IIO_ST_MAGN_I2C_3AXIS=m CONFIG_IIO_ST_MAGN_SPI_3AXIS=m # CONFIG_SENSORS_HMC5843_I2C is not set # CONFIG_SENSORS_HMC5843_SPI is not set # CONFIG_SENSORS_RM3100_I2C is not set # CONFIG_SENSORS_RM3100_SPI is not set # CONFIG_YAMAHA_YAS530 is not set # end of Magnetometer sensors # # Multiplexers # # CONFIG_IIO_MUX is not set # end of Multiplexers # # Inclinometer sensors # # end of Inclinometer sensors # # Triggers - standalone # CONFIG_IIO_HRTIMER_TRIGGER=m # CONFIG_IIO_INTERRUPT_TRIGGER is not set # CONFIG_IIO_TIGHTLOOP_TRIGGER is not set # CONFIG_IIO_SYSFS_TRIGGER is not set # end of Triggers - standalone # # Linear and angular position sensors # # end of Linear and angular position sensors # # Digital potentiometers # # CONFIG_AD5110 is not set # CONFIG_AD5272 is not set # CONFIG_DS1803 is not set # CONFIG_MAX5432 is not set # CONFIG_MAX5481 is not set # CONFIG_MAX5487 is not set # CONFIG_MCP4018 is not set # CONFIG_MCP4131 is not set # CONFIG_MCP4531 is not set # CONFIG_MCP41010 is not set # CONFIG_TPL0102 is not set # end of Digital potentiometers # # Digital potentiostats # # CONFIG_LMP91000 is not set # end of Digital potentiostats # # Pressure sensors # # CONFIG_ABP060MG is not set # CONFIG_BMP280 is not set # CONFIG_DLHL60D is not set # CONFIG_DPS310 is not set # CONFIG_HP03 is not set # CONFIG_ICP10100 is not set # CONFIG_MPL115_I2C is not set # CONFIG_MPL115_SPI is not set CONFIG_MPL3115=m # CONFIG_MS5611 is not set # CONFIG_MS5637 is not set # CONFIG_IIO_ST_PRESS is not set # CONFIG_T5403 is not set # CONFIG_HP206C is not set # CONFIG_ZPA2326 is not set # end of Pressure sensors # # Lightning sensors # # CONFIG_AS3935 is not set # end of Lightning sensors # # Proximity and distance sensors # # CONFIG_ISL29501 is not set # CONFIG_LIDAR_LITE_V2 is not set # CONFIG_MB1232 is not set # CONFIG_PING is not set # CONFIG_RFD77402 is not set # CONFIG_SRF04 is not set # CONFIG_SX9310 is not set # CONFIG_SX9324 is not set # CONFIG_SX9360 is not set # CONFIG_SX9500 is not set # CONFIG_SRF08 is not set # CONFIG_VCNL3020 is not set # CONFIG_VL53L0X_I2C is not set # end of Proximity and distance sensors # # Resolver to digital converters # # CONFIG_AD2S90 is not set # CONFIG_AD2S1200 is not set # end of Resolver to digital converters # # Temperature sensors # # CONFIG_LTC2983 is not set # CONFIG_MAXIM_THERMOCOUPLE is not set # CONFIG_MLX90614 is not set # CONFIG_MLX90632 is not set # CONFIG_TMP006 is not set # CONFIG_TMP007 is not set # CONFIG_TMP117 is not set # CONFIG_TSYS01 is not set # CONFIG_TSYS02D is not set # CONFIG_MAX31856 is not set # CONFIG_MAX31865 is not set # end of Temperature sensors # CONFIG_NTB is not set CONFIG_PWM=y CONFIG_PWM_SYSFS=y # CONFIG_PWM_DEBUG is not set # CONFIG_PWM_ATMEL_TCB is not set # CONFIG_PWM_CLK is not set # CONFIG_PWM_DWC is not set # CONFIG_PWM_FSL_FTM is not set CONFIG_PWM_OMAP_DMTIMER=m # CONFIG_PWM_PCA9685 is not set CONFIG_PWM_TIECAP=m CONFIG_PWM_TIEHRPWM=m # CONFIG_PWM_XILINX is not set # # IRQ chip support # CONFIG_IRQCHIP=y CONFIG_ARM_GIC=y CONFIG_ARM_GIC_MAX_NR=1 CONFIG_ARM_GIC_V2M=y CONFIG_ARM_GIC_V3=y CONFIG_ARM_GIC_V3_ITS=y CONFIG_ARM_GIC_V3_ITS_PCI=y # CONFIG_AL_FIC is not set # CONFIG_XILINX_INTC is not set CONFIG_PARTITION_PERCPU=y CONFIG_TI_SCI_INTR_IRQCHIP=y CONFIG_TI_SCI_INTA_IRQCHIP=y CONFIG_TI_PRUSS_INTC=m # end of IRQ chip support # CONFIG_IPACK_BUS is not set CONFIG_RESET_CONTROLLER=y CONFIG_RESET_SCMI=y CONFIG_RESET_SIMPLE=y CONFIG_RESET_TI_SCI=y # CONFIG_RESET_TI_SYSCON is not set # CONFIG_RESET_TI_TPS380X is not set # # PHY Subsystem # CONFIG_GENERIC_PHY=y CONFIG_GENERIC_PHY_MIPI_DPHY=y CONFIG_PHY_XGENE=y CONFIG_PHY_CAN_TRANSCEIVER=m # # PHY drivers for Broadcom platforms # # CONFIG_BCM_KONA_USB2_PHY is not set # end of PHY drivers for Broadcom platforms CONFIG_PHY_CADENCE_TORRENT=y CONFIG_PHY_CADENCE_DPHY=m CONFIG_PHY_CADENCE_DPHY_RX=m CONFIG_PHY_CADENCE_SIERRA=y # CONFIG_PHY_CADENCE_SALVO is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set # CONFIG_PHY_LAN966X_SERDES is not set # CONFIG_PHY_CPCAP_USB is not set # CONFIG_PHY_MAPPHONE_MDM6600 is not set # CONFIG_PHY_OCELOT_SERDES is not set CONFIG_PHY_QCOM_USB_HS=m # CONFIG_PHY_QCOM_USB_HSIC is not set CONFIG_PHY_AM654_SERDES=y CONFIG_PHY_J721E_WIZ=y CONFIG_OMAP_USB2=m # CONFIG_PHY_TUSB1210 is not set CONFIG_PHY_TI_GMII_SEL=y # end of PHY Subsystem # CONFIG_POWERCAP is not set # CONFIG_MCB is not set # # Performance monitor support # CONFIG_ARM_CCI_PMU=m CONFIG_ARM_CCI400_PMU=y CONFIG_ARM_CCI5xx_PMU=y CONFIG_ARM_CCN=m CONFIG_ARM_CMN=m CONFIG_ARM_PMU=y CONFIG_ARM_DSU_PMU=m CONFIG_ARM_SPE_PMU=m # CONFIG_HISI_PCIE_PMU is not set # CONFIG_HNS3_PMU is not set # end of Performance monitor support CONFIG_RAS=y # CONFIG_USB4 is not set # # Android # # CONFIG_ANDROID_BINDER_IPC is not set # end of Android # CONFIG_LIBNVDIMM is not set # CONFIG_DAX is not set CONFIG_NVMEM=y CONFIG_NVMEM_SYSFS=y CONFIG_NVMEM_RMEM=m # CONFIG_NVMEM_U_BOOT_ENV is not set # # HW tracing support # CONFIG_STM=m # CONFIG_STM_PROTO_BASIC is not set # CONFIG_STM_PROTO_SYS_T is not set # CONFIG_STM_DUMMY is not set # CONFIG_STM_SOURCE_CONSOLE is not set # CONFIG_STM_SOURCE_HEARTBEAT is not set # CONFIG_STM_SOURCE_FTRACE is not set # CONFIG_INTEL_TH is not set # CONFIG_HISI_PTT is not set # end of HW tracing support CONFIG_FPGA=y # CONFIG_ALTERA_PR_IP_CORE is not set # CONFIG_FPGA_MGR_ALTERA_PS_SPI is not set CONFIG_FPGA_MGR_ALTERA_CVP=m # CONFIG_FPGA_MGR_XILINX_SPI is not set # CONFIG_FPGA_MGR_ICE40_SPI is not set # CONFIG_FPGA_MGR_MACHXO2_SPI is not set CONFIG_FPGA_BRIDGE=m CONFIG_ALTERA_FREEZE_BRIDGE=m # CONFIG_XILINX_PR_DECOUPLER is not set CONFIG_FPGA_REGION=m CONFIG_OF_FPGA_REGION=m # CONFIG_FPGA_DFL is not set # CONFIG_FPGA_MGR_MICROCHIP_SPI is not set # CONFIG_FSI is not set CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_MULTIPLEXER=y # # Multiplexer drivers # # CONFIG_MUX_ADG792A is not set # CONFIG_MUX_ADGS1408 is not set CONFIG_MUX_GPIO=y CONFIG_MUX_MMIO=y # end of Multiplexer drivers CONFIG_PM_OPP=y # CONFIG_SIOX is not set # CONFIG_SLIMBUS is not set CONFIG_INTERCONNECT=y CONFIG_COUNTER=m # CONFIG_INTERRUPT_CNT is not set CONFIG_TI_EQEP=m # CONFIG_FTM_QUADDEC is not set # CONFIG_MICROCHIP_TCB_CAPTURE is not set # CONFIG_INTEL_QEP is not set CONFIG_TI_ECAP_CAPTURE=m # CONFIG_MOST is not set # CONFIG_PECI is not set # CONFIG_HTE is not set # end of Device Drivers # # File systems # CONFIG_DCACHE_WORD_ACCESS=y # CONFIG_VALIDATE_FS_PARSER is not set CONFIG_FS_IOMAP=y CONFIG_EXT2_FS=y # CONFIG_EXT2_FS_XATTR is not set CONFIG_EXT3_FS=y CONFIG_EXT3_FS_POSIX_ACL=y CONFIG_EXT3_FS_SECURITY=y CONFIG_EXT4_FS=y CONFIG_EXT4_FS_POSIX_ACL=y CONFIG_EXT4_FS_SECURITY=y # CONFIG_EXT4_DEBUG is not set CONFIG_JBD2=y # CONFIG_JBD2_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_OCFS2_FS is not set CONFIG_BTRFS_FS=m CONFIG_BTRFS_FS_POSIX_ACL=y # CONFIG_BTRFS_FS_CHECK_INTEGRITY is not set # CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set # CONFIG_BTRFS_DEBUG is not set # CONFIG_BTRFS_ASSERT is not set # CONFIG_BTRFS_FS_REF_VERIFY is not set # CONFIG_NILFS2_FS is not set # CONFIG_F2FS_FS is not set CONFIG_FS_POSIX_ACL=y CONFIG_EXPORTFS=y # CONFIG_EXPORTFS_BLOCK_OPS is not set CONFIG_FILE_LOCKING=y # CONFIG_FS_ENCRYPTION is not set # CONFIG_FS_VERITY is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y CONFIG_FANOTIFY=y CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y CONFIG_QUOTA=y # CONFIG_QUOTA_NETLINK_INTERFACE is not set CONFIG_PRINT_QUOTA_WARNING=y # CONFIG_QUOTA_DEBUG is not set # CONFIG_QFMT_V1 is not set # CONFIG_QFMT_V2 is not set CONFIG_QUOTACTL=y CONFIG_AUTOFS4_FS=y CONFIG_AUTOFS_FS=y CONFIG_FUSE_FS=m CONFIG_CUSE=m # CONFIG_VIRTIO_FS is not set CONFIG_OVERLAY_FS=y CONFIG_OVERLAY_FS_REDIRECT_DIR=y # CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW is not set CONFIG_OVERLAY_FS_INDEX=y CONFIG_OVERLAY_FS_XINO_AUTO=y CONFIG_OVERLAY_FS_METACOPY=y # # Caches # # CONFIG_FSCACHE is not set # end of Caches # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # end of CD-ROM/DVD Filesystems # # DOS/FAT/EXFAT/NT Filesystems # CONFIG_FAT_FS=y # CONFIG_MSDOS_FS is not set CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_FAT_DEFAULT_UTF8 is not set # CONFIG_EXFAT_FS is not set # CONFIG_NTFS_FS is not set # CONFIG_NTFS3_FS is not set # end of DOS/FAT/EXFAT/NT Filesystems # # Pseudo filesystems # CONFIG_PROC_FS=y # CONFIG_PROC_KCORE is not set CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_PROC_CHILDREN=y CONFIG_KERNFS=y CONFIG_SYSFS=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_TMPFS_XATTR=y # CONFIG_TMPFS_INODE64 is not set CONFIG_ARCH_SUPPORTS_HUGETLBFS=y CONFIG_HUGETLBFS=y CONFIG_HUGETLB_PAGE=y CONFIG_MEMFD_CREATE=y CONFIG_ARCH_HAS_GIGANTIC_PAGE=y CONFIG_CONFIGFS_FS=y CONFIG_EFIVAR_FS=y # end of Pseudo filesystems CONFIG_MISC_FILESYSTEMS=y # CONFIG_ORANGEFS_FS is not set # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set # CONFIG_JFFS2_FS is not set CONFIG_UBIFS_FS=y # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set CONFIG_UBIFS_FS_LZO=y CONFIG_UBIFS_FS_ZLIB=y CONFIG_UBIFS_FS_ZSTD=y # CONFIG_UBIFS_ATIME_SUPPORT is not set CONFIG_UBIFS_FS_XATTR=y CONFIG_UBIFS_FS_SECURITY=y # CONFIG_UBIFS_FS_AUTHENTICATION is not set # CONFIG_CRAMFS is not set CONFIG_SQUASHFS=y CONFIG_SQUASHFS_FILE_CACHE=y # CONFIG_SQUASHFS_FILE_DIRECT is not set CONFIG_SQUASHFS_DECOMP_SINGLE=y # CONFIG_SQUASHFS_DECOMP_MULTI is not set # CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set # CONFIG_SQUASHFS_XATTR is not set CONFIG_SQUASHFS_ZLIB=y # CONFIG_SQUASHFS_LZ4 is not set # CONFIG_SQUASHFS_LZO is not set # CONFIG_SQUASHFS_XZ is not set # CONFIG_SQUASHFS_ZSTD is not set # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set # CONFIG_SQUASHFS_EMBEDDED is not set CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3 # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set CONFIG_PSTORE=y CONFIG_PSTORE_DEFAULT_KMSG_BYTES=10240 CONFIG_PSTORE_DEFLATE_COMPRESS=y # CONFIG_PSTORE_LZO_COMPRESS is not set # CONFIG_PSTORE_LZ4_COMPRESS is not set # CONFIG_PSTORE_LZ4HC_COMPRESS is not set # CONFIG_PSTORE_842_COMPRESS is not set # CONFIG_PSTORE_ZSTD_COMPRESS is not set CONFIG_PSTORE_COMPRESS=y CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT=y CONFIG_PSTORE_COMPRESS_DEFAULT="deflate" # CONFIG_PSTORE_CONSOLE is not set # CONFIG_PSTORE_PMSG is not set # CONFIG_PSTORE_RAM is not set # CONFIG_PSTORE_BLK is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # CONFIG_EROFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V2=y CONFIG_NFS_V3=y # CONFIG_NFS_V3_ACL is not set CONFIG_NFS_V4=y # CONFIG_NFS_SWAP is not set CONFIG_NFS_V4_1=y CONFIG_NFS_V4_2=y CONFIG_PNFS_FILE_LAYOUT=y CONFIG_PNFS_BLOCK=m CONFIG_PNFS_FLEXFILE_LAYOUT=y CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org" # CONFIG_NFS_V4_1_MIGRATION is not set CONFIG_NFS_V4_SECURITY_LABEL=y CONFIG_ROOT_NFS=y # CONFIG_NFS_USE_LEGACY_DNS is not set CONFIG_NFS_USE_KERNEL_DNS=y CONFIG_NFS_DISABLE_UDP_SUPPORT=y # CONFIG_NFS_V4_2_READ_PLUS is not set # CONFIG_NFSD is not set CONFIG_GRACE_PERIOD=y CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_COMMON=y CONFIG_NFS_V4_2_SSC_HELPER=y CONFIG_SUNRPC=y CONFIG_SUNRPC_GSS=y CONFIG_SUNRPC_BACKCHANNEL=y # CONFIG_SUNRPC_DEBUG is not set # CONFIG_CEPH_FS is not set # CONFIG_CIFS is not set # CONFIG_SMB_SERVER is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set # CONFIG_NLS_UTF8 is not set # CONFIG_DLM is not set # CONFIG_UNICODE is not set CONFIG_IO_WQ=y # end of File systems # # Security options # CONFIG_KEYS=y # CONFIG_KEYS_REQUEST_CACHE is not set # CONFIG_PERSISTENT_KEYRINGS is not set # CONFIG_TRUSTED_KEYS is not set # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEY_DH_OPERATIONS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set CONFIG_SECURITY=y CONFIG_SECURITY_WRITABLE_HOOKS=y CONFIG_SECURITYFS=y CONFIG_SECURITY_NETWORK=y # CONFIG_SECURITY_NETWORK_XFRM is not set # CONFIG_SECURITY_PATH is not set CONFIG_LSM_MMAP_MIN_ADDR=32768 CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y # CONFIG_HARDENED_USERCOPY is not set # CONFIG_FORTIFY_SOURCE is not set # CONFIG_STATIC_USERMODEHELPER is not set CONFIG_SECURITY_SELINUX=y CONFIG_SECURITY_SELINUX_BOOTPARAM=y CONFIG_SECURITY_SELINUX_DISABLE=y CONFIG_SECURITY_SELINUX_DEVELOP=y CONFIG_SECURITY_SELINUX_AVC_STATS=y CONFIG_SECURITY_SELINUX_CHECKREQPROT_VALUE=1 CONFIG_SECURITY_SELINUX_SIDTAB_HASH_BITS=9 CONFIG_SECURITY_SELINUX_SID2STR_CACHE_SIZE=256 # CONFIG_SECURITY_SMACK is not set # CONFIG_SECURITY_TOMOYO is not set # CONFIG_SECURITY_APPARMOR is not set # CONFIG_SECURITY_LOADPIN is not set # CONFIG_SECURITY_YAMA is not set # CONFIG_SECURITY_SAFESETID is not set # CONFIG_SECURITY_LOCKDOWN_LSM is not set # CONFIG_SECURITY_LANDLOCK is not set CONFIG_INTEGRITY=y # CONFIG_INTEGRITY_SIGNATURE is not set CONFIG_INTEGRITY_AUDIT=y # CONFIG_IMA is not set # CONFIG_IMA_SECURE_AND_OR_TRUSTED_BOOT is not set # CONFIG_EVM is not set # CONFIG_DEFAULT_SECURITY_SELINUX is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,bpf" # # Kernel hardening options # # # Memory initialization # CONFIG_INIT_STACK_NONE=y # CONFIG_GCC_PLUGIN_STRUCTLEAK_USER is not set # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF is not set # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF_ALL is not set # CONFIG_GCC_PLUGIN_STACKLEAK is not set # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set CONFIG_CC_HAS_ZERO_CALL_USED_REGS=y # CONFIG_ZERO_CALL_USED_REGS is not set # end of Memory initialization CONFIG_RANDSTRUCT_NONE=y # CONFIG_RANDSTRUCT_FULL is not set # CONFIG_RANDSTRUCT_PERFORMANCE is not set # end of Kernel hardening options # end of Security options CONFIG_XOR_BLOCKS=m CONFIG_ASYNC_TX_DISABLE_PQ_VAL_DMA=y CONFIG_ASYNC_TX_DISABLE_XOR_VAL_DMA=y CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=y CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_SKCIPHER=y CONFIG_CRYPTO_SKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=y CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_RNG_DEFAULT=y CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_AKCIPHER=y CONFIG_CRYPTO_KPP2=y CONFIG_CRYPTO_KPP=m CONFIG_CRYPTO_ACOMP2=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y # CONFIG_CRYPTO_USER is not set CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y CONFIG_CRYPTO_GF128MUL=y CONFIG_CRYPTO_NULL=y CONFIG_CRYPTO_NULL2=y # CONFIG_CRYPTO_PCRYPT is not set # CONFIG_CRYPTO_CRYPTD is not set CONFIG_CRYPTO_AUTHENC=y CONFIG_CRYPTO_TEST=m CONFIG_CRYPTO_ENGINE=m # end of Crypto core or helper # # Public-key cryptography # CONFIG_CRYPTO_RSA=y CONFIG_CRYPTO_DH=m # CONFIG_CRYPTO_DH_RFC7919_GROUPS is not set CONFIG_CRYPTO_ECC=m CONFIG_CRYPTO_ECDH=m # CONFIG_CRYPTO_ECDSA is not set # CONFIG_CRYPTO_ECRDSA is not set # CONFIG_CRYPTO_SM2 is not set CONFIG_CRYPTO_CURVE25519=m # end of Public-key cryptography # # Block ciphers # CONFIG_CRYPTO_AES=y # CONFIG_CRYPTO_AES_TI is not set # CONFIG_CRYPTO_ANUBIS is not set # CONFIG_CRYPTO_ARIA is not set # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set CONFIG_CRYPTO_DES=m # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set CONFIG_CRYPTO_SM4=m CONFIG_CRYPTO_SM4_GENERIC=m # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # end of Block ciphers # # Length-preserving ciphers and modes # # CONFIG_CRYPTO_ADIANTUM is not set # CONFIG_CRYPTO_ARC4 is not set # CONFIG_CRYPTO_CHACHA20 is not set CONFIG_CRYPTO_CBC=y # CONFIG_CRYPTO_CFB is not set CONFIG_CRYPTO_CTR=y # CONFIG_CRYPTO_CTS is not set CONFIG_CRYPTO_ECB=m # CONFIG_CRYPTO_HCTR2 is not set # CONFIG_CRYPTO_KEYWRAP is not set # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_OFB is not set # CONFIG_CRYPTO_PCBC is not set CONFIG_CRYPTO_XTS=m # end of Length-preserving ciphers and modes # # AEAD (authenticated encryption with associated data) ciphers # # CONFIG_CRYPTO_AEGIS128 is not set # CONFIG_CRYPTO_CHACHA20POLY1305 is not set CONFIG_CRYPTO_CCM=m CONFIG_CRYPTO_GCM=y CONFIG_CRYPTO_SEQIV=y CONFIG_CRYPTO_ECHAINIV=y # CONFIG_CRYPTO_ESSIV is not set # end of AEAD (authenticated encryption with associated data) ciphers # # Hashes, digests, and MACs # CONFIG_CRYPTO_BLAKE2B=m CONFIG_CRYPTO_CMAC=m CONFIG_CRYPTO_GHASH=y CONFIG_CRYPTO_HMAC=y # CONFIG_CRYPTO_MD4 is not set CONFIG_CRYPTO_MD5=m CONFIG_CRYPTO_MICHAEL_MIC=m # CONFIG_CRYPTO_POLY1305 is not set # CONFIG_CRYPTO_RMD160 is not set CONFIG_CRYPTO_SHA1=y CONFIG_CRYPTO_SHA256=y CONFIG_CRYPTO_SHA512=y CONFIG_CRYPTO_SHA3=m CONFIG_CRYPTO_SM3=m CONFIG_CRYPTO_SM3_GENERIC=m # CONFIG_CRYPTO_STREEBOG is not set # CONFIG_CRYPTO_VMAC is not set # CONFIG_CRYPTO_WP512 is not set # CONFIG_CRYPTO_XCBC is not set CONFIG_CRYPTO_XXHASH=m # end of Hashes, digests, and MACs # # CRCs (cyclic redundancy checks) # CONFIG_CRYPTO_CRC32C=y # CONFIG_CRYPTO_CRC32 is not set CONFIG_CRYPTO_CRCT10DIF=y CONFIG_CRYPTO_CRC64_ROCKSOFT=y # end of CRCs (cyclic redundancy checks) # # Compression # CONFIG_CRYPTO_DEFLATE=y CONFIG_CRYPTO_LZO=y # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set CONFIG_CRYPTO_ZSTD=y # end of Compression # # Random number generation # CONFIG_CRYPTO_ANSI_CPRNG=y CONFIG_CRYPTO_DRBG_MENU=y CONFIG_CRYPTO_DRBG_HMAC=y # CONFIG_CRYPTO_DRBG_HASH is not set # CONFIG_CRYPTO_DRBG_CTR is not set CONFIG_CRYPTO_DRBG=y CONFIG_CRYPTO_JITTERENTROPY=y # end of Random number generation # # Userspace interface # CONFIG_CRYPTO_USER_API=y CONFIG_CRYPTO_USER_API_HASH=y # CONFIG_CRYPTO_USER_API_SKCIPHER is not set CONFIG_CRYPTO_USER_API_RNG=m # CONFIG_CRYPTO_USER_API_RNG_CAVP is not set # CONFIG_CRYPTO_USER_API_AEAD is not set CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE=y # end of Userspace interface CONFIG_CRYPTO_HASH_INFO=y # CONFIG_CRYPTO_NHPOLY1305_NEON is not set CONFIG_CRYPTO_CHACHA20_NEON=m # # Accelerated Cryptographic Algorithms for CPU (arm64) # CONFIG_CRYPTO_GHASH_ARM64_CE=y # CONFIG_CRYPTO_POLY1305_NEON is not set CONFIG_CRYPTO_SHA1_ARM64_CE=y CONFIG_CRYPTO_SHA256_ARM64=y CONFIG_CRYPTO_SHA2_ARM64_CE=y CONFIG_CRYPTO_SHA512_ARM64=m CONFIG_CRYPTO_SHA512_ARM64_CE=m CONFIG_CRYPTO_SHA3_ARM64=m # CONFIG_CRYPTO_SM3_NEON is not set CONFIG_CRYPTO_SM3_ARM64_CE=m # CONFIG_CRYPTO_POLYVAL_ARM64_CE is not set # CONFIG_CRYPTO_AES_ARM64 is not set CONFIG_CRYPTO_AES_ARM64_CE=y CONFIG_CRYPTO_AES_ARM64_CE_BLK=y CONFIG_CRYPTO_AES_ARM64_NEON_BLK=m CONFIG_CRYPTO_AES_ARM64_BS=m # CONFIG_CRYPTO_SM4_ARM64_CE is not set # CONFIG_CRYPTO_SM4_ARM64_CE_BLK is not set # CONFIG_CRYPTO_SM4_ARM64_NEON_BLK is not set CONFIG_CRYPTO_AES_ARM64_CE_CCM=y CONFIG_CRYPTO_CRCT10DIF_ARM64_CE=m # end of Accelerated Cryptographic Algorithms for CPU (arm64) CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set # CONFIG_CRYPTO_DEV_CCP is not set # CONFIG_CRYPTO_DEV_QAT_DH895xCC is not set # CONFIG_CRYPTO_DEV_QAT_C3XXX is not set # CONFIG_CRYPTO_DEV_QAT_C62X is not set # CONFIG_CRYPTO_DEV_QAT_4XXX is not set # CONFIG_CRYPTO_DEV_QAT_DH895xCCVF is not set # CONFIG_CRYPTO_DEV_QAT_C3XXXVF is not set # CONFIG_CRYPTO_DEV_QAT_C62XVF is not set # CONFIG_CRYPTO_DEV_NITROX_CNN55XX is not set # CONFIG_CRYPTO_DEV_CAVIUM_ZIP is not set # CONFIG_CRYPTO_DEV_VIRTIO is not set # CONFIG_CRYPTO_DEV_SAFEXCEL is not set CONFIG_CRYPTO_DEV_CCREE=m # CONFIG_CRYPTO_DEV_HISI_SEC is not set CONFIG_CRYPTO_DEV_AMLOGIC_GXL=m # CONFIG_CRYPTO_DEV_AMLOGIC_GXL_DEBUG is not set CONFIG_CRYPTO_DEV_SA2UL=m CONFIG_CRYPTO_DEV_TI_MCRC64=m CONFIG_ASYMMETRIC_KEY_TYPE=y CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y CONFIG_X509_CERTIFICATE_PARSER=y # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set CONFIG_PKCS7_MESSAGE_PARSER=y # CONFIG_PKCS7_TEST_KEY is not set # CONFIG_SIGNED_PE_FILE_VERIFICATION is not set # CONFIG_FIPS_SIGNATURE_SELFTEST is not set # # Certificates for signature checking # CONFIG_SYSTEM_TRUSTED_KEYRING=y CONFIG_SYSTEM_TRUSTED_KEYS="" # CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set # CONFIG_SECONDARY_TRUSTED_KEYRING is not set # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set # end of Certificates for signature checking CONFIG_BINARY_PRINTF=y # # Library routines # CONFIG_RAID6_PQ=m CONFIG_RAID6_PQ_BENCHMARK=y CONFIG_LINEAR_RANGES=y CONFIG_PACKING=y CONFIG_BITREVERSE=y CONFIG_HAVE_ARCH_BITREVERSE=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y # CONFIG_CORDIC is not set # CONFIG_PRIME_NUMBERS is not set CONFIG_RATIONAL=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y CONFIG_ARCH_HAS_FAST_MULTIPLIER=y CONFIG_ARCH_USE_SYM_ANNOTATIONS=y CONFIG_INDIRECT_PIO=y # CONFIG_TRACE_MMIO_ACCESS is not set # # Crypto library routines # CONFIG_CRYPTO_LIB_UTILS=y CONFIG_CRYPTO_LIB_AES=y CONFIG_CRYPTO_LIB_ARC4=m CONFIG_CRYPTO_LIB_BLAKE2S_GENERIC=y CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m CONFIG_CRYPTO_LIB_CHACHA_GENERIC=m # CONFIG_CRYPTO_LIB_CHACHA is not set CONFIG_CRYPTO_LIB_CURVE25519_GENERIC=m # CONFIG_CRYPTO_LIB_CURVE25519 is not set CONFIG_CRYPTO_LIB_DES=m CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9 # CONFIG_CRYPTO_LIB_POLY1305 is not set # CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set CONFIG_CRYPTO_LIB_SHA1=y CONFIG_CRYPTO_LIB_SHA256=y # end of Crypto library routines CONFIG_CRC_CCITT=y CONFIG_CRC16=y CONFIG_CRC_T10DIF=y CONFIG_CRC64_ROCKSOFT=y CONFIG_CRC_ITU_T=y CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set CONFIG_CRC64=y # CONFIG_CRC4 is not set CONFIG_CRC7=y CONFIG_LIBCRC32C=m CONFIG_CRC8=y CONFIG_XXHASH=y CONFIG_AUDIT_GENERIC=y CONFIG_AUDIT_ARCH_COMPAT_GENERIC=y CONFIG_AUDIT_COMPAT_GENERIC=y # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y CONFIG_LZ4_DECOMPRESS=y CONFIG_ZSTD_COMMON=y CONFIG_ZSTD_COMPRESS=y CONFIG_ZSTD_DECOMPRESS=y CONFIG_XZ_DEC=y CONFIG_XZ_DEC_X86=y CONFIG_XZ_DEC_POWERPC=y CONFIG_XZ_DEC_IA64=y CONFIG_XZ_DEC_ARM=y CONFIG_XZ_DEC_ARMTHUMB=y CONFIG_XZ_DEC_SPARC=y # CONFIG_XZ_DEC_MICROLZMA is not set CONFIG_XZ_DEC_BCJ=y # CONFIG_XZ_DEC_TEST is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_XZ=y CONFIG_DECOMPRESS_LZO=y CONFIG_DECOMPRESS_LZ4=y CONFIG_DECOMPRESS_ZSTD=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_BCH=y CONFIG_TEXTSEARCH=y CONFIG_TEXTSEARCH_KMP=m CONFIG_TEXTSEARCH_BM=m CONFIG_TEXTSEARCH_FSM=m CONFIG_INTERVAL_TREE=y CONFIG_XARRAY_MULTI=y CONFIG_ASSOCIATIVE_ARRAY=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT_MAP=y CONFIG_HAS_DMA=y CONFIG_DMA_OPS=y CONFIG_NEED_SG_DMA_LENGTH=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_ARCH_DMA_ADDR_T_64BIT=y CONFIG_DMA_DECLARE_COHERENT=y CONFIG_ARCH_HAS_SETUP_DMA_OPS=y CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y CONFIG_ARCH_HAS_DMA_PREP_COHERENT=y CONFIG_SWIOTLB=y # CONFIG_DMA_RESTRICTED_POOL is not set CONFIG_DMA_NONCOHERENT_MMAP=y CONFIG_DMA_COHERENT_POOL=y CONFIG_DMA_DIRECT_REMAP=y CONFIG_DMA_CMA=y CONFIG_DMA_PERNUMA_CMA=y # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=32 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=8 # CONFIG_DMA_API_DEBUG is not set # CONFIG_DMA_MAP_BENCHMARK is not set CONFIG_SGL_ALLOC=y # CONFIG_FORCE_NR_CPUS is not set CONFIG_CPU_RMAP=y CONFIG_DQL=y CONFIG_GLOB=y # CONFIG_GLOB_SELFTEST is not set CONFIG_NLATTR=y CONFIG_CLZ_TAB=y CONFIG_IRQ_POLL=y CONFIG_MPILIB=y CONFIG_LIBFDT=y CONFIG_OID_REGISTRY=y CONFIG_UCS2_STRING=y CONFIG_HAVE_GENERIC_VDSO=y CONFIG_GENERIC_GETTIMEOFDAY=y CONFIG_GENERIC_VDSO_TIME_NS=y CONFIG_FONT_SUPPORT=y # CONFIG_FONTS is not set CONFIG_FONT_8x8=y CONFIG_FONT_8x16=y CONFIG_SG_SPLIT=y CONFIG_SG_POOL=y CONFIG_ARCH_STACKWALK=y CONFIG_SBITMAP=y # end of Library routines CONFIG_GENERIC_IOREMAP=y CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y # CONFIG_PRINTK_CALLER is not set # CONFIG_STACKTRACE_BUILD_ID is not set CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_CONSOLE_LOGLEVEL_QUIET=4 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # CONFIG_DYNAMIC_DEBUG_CORE is not set CONFIG_SYMBOLIC_ERRNAME=y CONFIG_DEBUG_BUGVERBOSE=y # end of printk and dmesg options CONFIG_DEBUG_KERNEL=y CONFIG_DEBUG_MISC=y # # Compile-time checks and compiler options # CONFIG_DEBUG_INFO=y CONFIG_AS_HAS_NON_CONST_LEB128=y # CONFIG_DEBUG_INFO_NONE is not set CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT=y # CONFIG_DEBUG_INFO_DWARF4 is not set # CONFIG_DEBUG_INFO_DWARF5 is not set CONFIG_DEBUG_INFO_REDUCED=y # CONFIG_DEBUG_INFO_COMPRESSED is not set # CONFIG_DEBUG_INFO_SPLIT is not set # CONFIG_GDB_SCRIPTS is not set CONFIG_FRAME_WARN=2048 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_HEADERS_INSTALL is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_SECTION_MISMATCH_WARN_ONLY=y # CONFIG_DEBUG_FORCE_FUNCTION_ALIGN_64B is not set CONFIG_ARCH_WANT_FRAME_POINTERS=y CONFIG_FRAME_POINTER=y # CONFIG_VMLINUX_MAP is not set # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # end of Compile-time checks and compiler options # # Generic Kernel Debugging Instruments # CONFIG_MAGIC_SYSRQ=y CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1 CONFIG_MAGIC_SYSRQ_SERIAL=y CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE="" CONFIG_DEBUG_FS=y CONFIG_DEBUG_FS_ALLOW_ALL=y # CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set # CONFIG_DEBUG_FS_ALLOW_NONE is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set CONFIG_ARCH_HAS_UBSAN_SANITIZE_ALL=y # CONFIG_UBSAN is not set CONFIG_HAVE_ARCH_KCSAN=y CONFIG_HAVE_KCSAN_COMPILER=y # CONFIG_KCSAN is not set # end of Generic Kernel Debugging Instruments # # Networking Debugging # # CONFIG_NET_DEV_REFCNT_TRACKER is not set # CONFIG_NET_NS_REFCNT_TRACKER is not set # CONFIG_DEBUG_NET is not set # end of Networking Debugging # # Memory Debugging # # CONFIG_PAGE_EXTENSION is not set # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_SLUB_DEBUG is not set # CONFIG_PAGE_OWNER is not set # CONFIG_PAGE_TABLE_CHECK is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_PAGE_REF is not set # CONFIG_DEBUG_RODATA_TEST is not set CONFIG_ARCH_HAS_DEBUG_WX=y # CONFIG_DEBUG_WX is not set CONFIG_GENERIC_PTDUMP=y # CONFIG_PTDUMP_DEBUGFS is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SHRINKER_DEBUG is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_SCHED_STACK_END_CHECK is not set CONFIG_ARCH_HAS_DEBUG_VM_PGTABLE=y # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_VM_PGTABLE is not set CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y # CONFIG_DEBUG_VIRTUAL is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_PER_CPU_MAPS is not set CONFIG_HAVE_ARCH_KASAN=y CONFIG_HAVE_ARCH_KASAN_SW_TAGS=y CONFIG_HAVE_ARCH_KASAN_HW_TAGS=y CONFIG_HAVE_ARCH_KASAN_VMALLOC=y CONFIG_CC_HAS_KASAN_GENERIC=y CONFIG_CC_HAS_KASAN_SW_TAGS=y CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y # CONFIG_KASAN is not set CONFIG_HAVE_ARCH_KFENCE=y # CONFIG_KFENCE is not set # end of Memory Debugging # CONFIG_DEBUG_SHIRQ is not set # # Debug Oops, Lockups and Hangs # # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 # CONFIG_SOFTLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_WQ_WATCHDOG is not set # CONFIG_TEST_LOCKUP is not set # end of Debug Oops, Lockups and Hangs # # Scheduler Debugging # CONFIG_SCHED_DEBUG=y CONFIG_SCHED_INFO=y CONFIG_SCHEDSTATS=y # end of Scheduler Debugging # CONFIG_DEBUG_TIMEKEEPING is not set # CONFIG_DEBUG_PREEMPT is not set # # Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_LOCK_DEBUGGING_SUPPORT=y # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_RWSEMS is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_WW_MUTEX_SELFTEST is not set # CONFIG_SCF_TORTURE_TEST is not set # CONFIG_CSD_LOCK_WAIT_DEBUG is not set # end of Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_DEBUG_IRQFLAGS is not set CONFIG_STACKTRACE=y # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set # CONFIG_DEBUG_KOBJECT is not set # # Debug kernel data structures # # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PLIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_BUG_ON_DATA_CORRUPTION is not set # CONFIG_DEBUG_MAPLE_TREE is not set # end of Debug kernel data structures # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_RCU_SCALE_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set # CONFIG_RCU_REF_SCALE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=21 CONFIG_RCU_EXP_CPU_STALL_TIMEOUT=0 CONFIG_RCU_TRACE=y # CONFIG_RCU_EQS_DEBUG is not set # end of RCU Debugging # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set # CONFIG_LATENCYTOP is not set CONFIG_NOP_TRACER=y CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_TRACE_CLOCK=y CONFIG_RING_BUFFER=y CONFIG_EVENT_TRACING=y CONFIG_CONTEXT_SWITCH_TRACER=y CONFIG_TRACING=y CONFIG_TRACING_SUPPORT=y CONFIG_FTRACE=y # CONFIG_BOOTTIME_TRACING is not set # CONFIG_FUNCTION_TRACER is not set # CONFIG_STACK_TRACER is not set # CONFIG_IRQSOFF_TRACER is not set # CONFIG_PREEMPT_TRACER is not set # CONFIG_SCHED_TRACER is not set # CONFIG_HWLAT_TRACER is not set # CONFIG_OSNOISE_TRACER is not set # CONFIG_TIMERLAT_TRACER is not set # CONFIG_ENABLE_DEFAULT_TRACERS is not set # CONFIG_FTRACE_SYSCALLS is not set # CONFIG_TRACER_SNAPSHOT is not set CONFIG_BRANCH_PROFILE_NONE=y # CONFIG_PROFILE_ANNOTATED_BRANCHES is not set # CONFIG_PROFILE_ALL_BRANCHES is not set # CONFIG_BLK_DEV_IO_TRACE is not set CONFIG_KPROBE_EVENTS=y CONFIG_UPROBE_EVENTS=y CONFIG_BPF_EVENTS=y CONFIG_DYNAMIC_EVENTS=y CONFIG_PROBE_EVENTS=y # CONFIG_SYNTH_EVENTS is not set # CONFIG_HIST_TRIGGERS is not set # CONFIG_TRACE_EVENT_INJECT is not set # CONFIG_TRACEPOINT_BENCHMARK is not set # CONFIG_RING_BUFFER_BENCHMARK is not set # CONFIG_TRACE_EVAL_MAP_FILE is not set # CONFIG_RING_BUFFER_STARTUP_TEST is not set # CONFIG_RING_BUFFER_VALIDATE_TIME_DELTAS is not set # CONFIG_PREEMPTIRQ_DELAY_TEST is not set # CONFIG_KPROBE_EVENT_GEN_TEST is not set # CONFIG_RV is not set CONFIG_SAMPLES=y # CONFIG_SAMPLE_TRACE_EVENTS is not set # CONFIG_SAMPLE_TRACE_CUSTOM_EVENTS is not set # CONFIG_SAMPLE_TRACE_PRINTK is not set # CONFIG_SAMPLE_TRACE_ARRAY is not set # CONFIG_SAMPLE_KOBJECT is not set # CONFIG_SAMPLE_KPROBES is not set # CONFIG_SAMPLE_HW_BREAKPOINT is not set # CONFIG_SAMPLE_KFIFO is not set CONFIG_SAMPLE_RPMSG_CLIENT=m # CONFIG_SAMPLE_CONFIGFS is not set # CONFIG_SAMPLE_VFIO_MDEV_MDPY_FB is not set # CONFIG_SAMPLE_CORESIGHT_SYSCFG is not set CONFIG_STRICT_DEVMEM=y # CONFIG_IO_STRICT_DEVMEM is not set # # arm64 Debugging # # CONFIG_PID_IN_CONTEXTIDR is not set # CONFIG_DEBUG_EFI is not set # CONFIG_ARM64_RELOC_TEST is not set CONFIG_CORESIGHT=m CONFIG_CORESIGHT_LINKS_AND_SINKS=m CONFIG_CORESIGHT_LINK_AND_SINK_TMC=m CONFIG_CORESIGHT_CATU=m CONFIG_CORESIGHT_SINK_TPIU=m CONFIG_CORESIGHT_SINK_ETBV10=m # CONFIG_CORESIGHT_SOURCE_ETM4X is not set CONFIG_CORESIGHT_STM=m CONFIG_CORESIGHT_CPU_DEBUG=m # CONFIG_CORESIGHT_CPU_DEBUG_DEFAULT_ON is not set CONFIG_CORESIGHT_CTI=m # CONFIG_CORESIGHT_CTI_INTEGRATION_REGS is not set # end of arm64 Debugging # # Kernel Testing and Coverage # # CONFIG_KUNIT is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FUNCTION_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set CONFIG_ARCH_HAS_KCOV=y CONFIG_CC_HAS_SANCOV_TRACE_PC=y CONFIG_RUNTIME_TESTING_MENU=y # CONFIG_LKDTM is not set # CONFIG_TEST_MIN_HEAP is not set # CONFIG_TEST_DIV64 is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_TEST_REF_TRACKER is not set # CONFIG_RBTREE_TEST is not set # CONFIG_REED_SOLOMON_TEST is not set # CONFIG_INTERVAL_TREE_TEST is not set # CONFIG_PERCPU_TEST is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_TEST_HEXDUMP is not set # CONFIG_STRING_SELFTEST is not set # CONFIG_TEST_STRING_HELPERS is not set # CONFIG_TEST_STRSCPY is not set # CONFIG_TEST_KSTRTOX is not set # CONFIG_TEST_PRINTF is not set # CONFIG_TEST_SCANF is not set # CONFIG_TEST_BITMAP is not set # CONFIG_TEST_UUID is not set # CONFIG_TEST_XARRAY is not set # CONFIG_TEST_MAPLE_TREE is not set # CONFIG_TEST_RHASHTABLE is not set # CONFIG_TEST_SIPHASH is not set # CONFIG_TEST_IDA is not set # CONFIG_TEST_LKM is not set # CONFIG_TEST_BITOPS is not set # CONFIG_TEST_VMALLOC is not set # CONFIG_TEST_USER_COPY is not set # CONFIG_TEST_BPF is not set # CONFIG_TEST_BLACKHOLE_DEV is not set # CONFIG_FIND_BIT_BENCHMARK is not set # CONFIG_TEST_FIRMWARE is not set # CONFIG_TEST_SYSCTL is not set # CONFIG_TEST_UDELAY is not set # CONFIG_TEST_STATIC_KEYS is not set # CONFIG_TEST_KMOD is not set # CONFIG_TEST_MEMCAT_P is not set # CONFIG_TEST_MEMINIT is not set # CONFIG_TEST_FREE_PAGES is not set CONFIG_ARCH_USE_MEMTEST=y CONFIG_MEMTEST=y # end of Kernel Testing and Coverage # # Rust hacking # # end of Rust hacking # end of Kernel hacking
// SPDX-License-Identifier: GPL-2.0
* AM625 Minimal dts file
* Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
/dts-v1/;
#include <dt-bindings/leds/common.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/net/ti-dp83867.h>
#include "k3-pinctrl.h"
#include "k3-am625.dtsi"
compatible = "ti,am625-sk","ti,am625";
model = " DEBUG";
aliases {
serial0 = &mcu_uart0;
serial1 = &wkup_uart0;
serial2 = &main_uart0;
serial3 = &main_uart1;
serial4 = &main_uart4;
serial5 = &main_uart6;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
mmc2 = &sdhci2;
spi0 = &ospi0;
spi1 = &main_spi0;
gpio0 = &main_gpio0;
gpio1 = &main_gpio1;
gpio2 = &mcu_gpio0;
i2c0 = &main_i2c0;
i2c1 = &main_i2c1;
i2c2 = &main_i2c2;
i2c3 = &main_i2c3;
i2c4 = &wkup_i2c0;
i2c5 = &mcu_i2c0;
can0 = &main_mcan0;
can1 = &mcu_mcan0;
can2 = &mcu_mcan1;
chosen {
#address-cells = <2>;
#size-cells = <2>;
ranges;
stdout-path = "serial2:115200n8";
bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
framebuffer0: framebuffer@0 {
compatible = "simple-framebuffer";
power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 186 6>,
<&k3_clks 186 0>,
<&k3_clks 186 2>;
display = <&dss>;
status = "disabled";
opp-table {
/* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */
opp-1400000000 {
opp-hz = /bits/ 64 <1400000000>;
opp-supported-hw = <0x01 0x0004>;
clock-latency-ns = <6000000>;
memory@80000000 {
device_type = "memory";
/* 2G RAM */
reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
reserved-memory {
#size-cells = <2>;
ranges;
ramoops@9c700000 {
compatible = "ramoops";
reg = <0x00 0x9c700000 0x00 0x00100000>;
record-size = <0x8000>;
console-size = <0x8000>;
ftrace-size = <0x00>;
pmsg-size = <0x8000>;
/* global cma region */
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0x00 0x8000000>;
linux,cma-default;
rtos_ipc_memory_region: ipc-memories@9c800000 {
reg = <0x00 0x9c800000 0x00 0x00300000>;
no-map;
mcu_m4fss_dma_memory_region: m4f-dma-memory@9cb00000 {
reg = <0x00 0x9cb00000 0x00 0x100000>;
no-map;
mcu_m4fss_memory_region: m4f-memory@9cc00000 {
reg = <0x00 0x9cc00000 0x00 0xe00000>;
no-map;
wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9da00000 {
reg = <0x00 0x9da00000 0x00 0x00100000>;
no-map;
wkup_r5fss0_core0_memory_region: r5f-memory@9db00000 {
reg = <0x00 0x9db00000 0x00 0x00c00000>;
no-map;
secure_tfa_ddr: tfa@9e780000 {
reg = <0x00 0x9e780000 0x00 0x80000>;
alignment = <0x1000>;
no-map;
secure_ddr: optee@9e800000 {
reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
no-map;
vmain_pd: regulator-0 {
/* TPS65988 PD CONTROLLER OUTPUT */
compatible = "regulator-fixed";
regulator-name = "vmain_pd";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-always-on;
regulator-boot-on;
vcc_5v0: regulator-1 {
/* Output of LM34936 */
regulator-name = "vcc_5v0";
vin-supply = <&vmain_pd>;
regulator-boot-on;
vcc_3v3_sys: regulator-2 {
/* output of LM61460-Q1 */
regulator-name = "vcc_3v3_sys";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
vdd_mmc1: regulator-3 {
/* TPS22918DBVR */
regulator-name = "vdd_mmc1";
pinctrl-names = "default";
pinctrl-0 = <&vdd_3v3_sd_pins_default>;
regulator-boot-on;
enable-active-high;
vin-supply = <&vcc_3v3_sys>;
gpio = <&main_gpio0 76 GPIO_ACTIVE_HIGH>;
vdd_sd_dv: regulator-4 {
/* Output of TLV71033 */
compatible = "regulator-gpio";
regulator-name = "tlv71033";
pinctrl-0 = <&vdd_sd_dv_pins_default>;
regulator-min-microvolt = <1800000>;
regulator-boot-on;
vin-supply = <&vcc_5v0>;
gpios = <&main_gpio0 40 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
vcc_1v8: regulator-5 {
/* output of TPS6282518DMQ */
regulator-name = "vcc_1v8";
regulator-max-microvolt = <1800000>;
regulator-boot-on;
bt_en: regulator-6 {
regulator-name = "bt_en";
enable-active-high;
gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&bt_en_pins_default>;
wlan_en: regulator-7 {
regulator-name = "wlan_en";
enable-active-high;
gpios = <&main_gpio0 36 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&wlan_en_pins_default>;
vdd_core: regulator-8 {
/* output of TPS62826DMQ */
regulator-name = "vdd_core";
regulator-min-microvolt = <850000>;
regulator-max-microvolt = <850000>;
regulator-boot-on;
tlv320_mclk: clk-0 {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <12288000>;
codec_audio: sound {
compatible = "simple-audio-card";
simple-audio-card,name = "AM62x-SKEVM";
simple-audio-card,widgets =
"Headphone", "Headphone Jack",
"Line", "Line In",
"Microphone", "Microphone Jack";
simple-audio-card,routing =
"Headphone Jack", "HPLOUT",
"Headphone Jack", "HPROUT",
"LINE1L", "Line In",
"LINE1R", "Line In",
"MIC3R", "Microphone Jack",
"Microphone Jack", "Mic Bias";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&sound_master>;
simple-audio-card,frame-master = <&sound_master>;
simple-audio-card,bitclock-inversion;
simple-audio-card,cpu {
sound-dai = <&mcasp2>;
sound_master: simple-audio-card,codec {
sound-dai = <&tlv320aic3106>;
clocks = <&tlv320_mclk>;
hdmi0: connector {
compatible = "hdmi-connector";
label = "hdmi";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&sii9022_out>;
transceiver1: can-phy0 {
compatible = "ti,tcan1042";
#phy-cells = <0>;
max-bitrate = <5000000>;
transceiver2: can-phy1 {
#phy-cells = <0>;
transceiver3: can-phy2 {
#phy-cells = <0>;
leds {
compatible = "gpio-leds";
pinctrl-0 = <&usr_led_pins_default>;
led-0 {
label = "am62-sk:green:heartbeat";
gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
function = LED_FUNCTION_HEARTBEAT;
default-state = "off";
&main_pmx0 {
gpio0_pins_default: gpio0-pins-default {
pinctrl-single,pins = <
AM62X_IOPAD(0x0004, PIN_OUTPUT, 7) /* (G18) OSPI0_LBCLKO.GPIO0_1 */
AM62X_IOPAD(0x0030, PIN_OUTPUT, 7) /* (F17) OSPI0_CSn1 */ /* OSPI Reset */
AM62X_IOPAD(0x0034, PIN_OUTPUT, 7) /* (E17) OSPI0_CSn2 */ /* OSPI Interrupt */
AM62X_IOPAD(0x0038, PIN_OUTPUT, 7) /* (E18) OSPI0_CSn3.GPIO0_14 */
AM62X_IOPAD(0x003c, PIN_INPUT, 7) /* (K19) GPMC0_AD0.GPIO0_15 */
AM62X_IOPAD(0x0040, PIN_INPUT, 7) /* (L19) GPMC0_AD1.GPIO0_16 */
AM62X_IOPAD(0x0044, PIN_INPUT, 7) /* (L20) GPMC0_AD2.GPIO0_17 */
AM62X_IOPAD(0x0048, PIN_INPUT, 7) /* (L21) GPMC0_AD3.GPIO0_18 */
AM62X_IOPAD(0x004c, PIN_INPUT, 7) /* (M21) GPMC0_AD4.GPIO0_19 */
AM62X_IOPAD(0x0050, PIN_INPUT, 7) /* (L17) GPMC0_AD5.GPIO0_20 */
AM62X_IOPAD(0x0054, PIN_INPUT, 7) /* (L18) GPMC0_AD6.GPIO0_21 */
AM62X_IOPAD(0x00a8, PIN_OUTPUT, 7) /* (J18) GPMC0_CSn0.GPIO0_41 */
AM62X_IOPAD(0x0130, PIN_OUTPUT, 7) /* (W16) RGMII1_TXC.GPIO0_74 */
AM62X_IOPAD(0x013c, PIN_OUTPUT, 7) /* (Y17) RGMII1_TD2.GPIO0_77 */
AM62X_IOPAD(0x0140, PIN_OUTPUT, 7) /* (AA18) RGMII1_TD3.GPIO0_78 */
AM62X_IOPAD(0x0144, PIN_INPUT, 7) /* (W14) RGMII1_RX_CTL.GPIO0_79 */
AM62X_IOPAD(0x0148, PIN_INPUT, 7) /* (AA16) RGMII1_RXC.GPIO0_80 */
AM62X_IOPAD(0x014c, PIN_INPUT, 7) /* (W15) RGMII1_RD0.GPIO0_81 */
AM62X_IOPAD(0x0150, PIN_INPUT, 7) /* (Y16) RGMII1_RD1.GPIO0_82 */
AM62X_IOPAD(0x0154, PIN_INPUT, 7) /* (AA17) RGMII1_RD2.GPIO0_83 */
AM62X_IOPAD(0x0158, PIN_INPUT, 7) /* (Y15) RGMII1_RD3.GPIO0_84 */
AM62X_IOPAD(0x015c, PIN_OUTPUT, 7) /* (U16) MDIO0_MDIO.GPIO0_85 */
AM62X_IOPAD(0x0160, PIN_OUTPUT, 7) /* (V17) MDIO0_MDC.GPIO0_86 */
AM62X_IOPAD(0x0164, PIN_OUTPUT, 7) /* (Y21) RGMII2_TX_CTL.GPIO0_87 */
AM62X_IOPAD(0x0168, PIN_OUTPUT, 7) /* (Y18) RGMII2_TXC.GPIO0_88 */
gpio1_pins_default: gpio1-pins-default {
AM62X_IOPAD(0x017c, PIN_INPUT, 7) /* (W19) RGMII2_RX_CTL.GPIO1_1 */
AM62X_IOPAD(0x0188, PIN_OUTPUT, 7) /* (Y20) RGMII2_RD1.GPIO1_4 */
AM62X_IOPAD(0x0190, PIN_OUTPUT, 7) /* (W20) RGMII2_RD3.GPIO1_6 */
AM62X_IOPAD(0x01f0, PIN_OUTPUT, 7) /* (C14) EXT_REFCLK1.GPIO1_30 */ /* ADC Reset */
AM62X_IOPAD(0x01f4, PIN_INPUT, 7) /* (B16) EXTINTn.GPIO1_31 */
AM62X_IOPAD(0x0254, PIN_OUTPUT, 7) /* (D17) USB0_DRVVBUS.GPIO1_50 */
main_i2c0_pins_default: main-i2c0-pins-default {
AM62X_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (E12) I2C0_SCL */
AM62X_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (D14) I2C0_SDA */
main_i2c1_pins_default: main-i2c1-pins-default {
AM62X_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SCL */
AM62X_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A16) I2C1_SDA */
main_i2c2_pins_default: main-i2c2-pins-default {
AM62X_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (H18) GPMC0_CSn2.I2C2_SCL */
AM62X_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (H19) GPMC0_CSn3.I2C2_SDA */
main_i2c3_pins_default: main-i2c3-pins-default {
AM62X_IOPAD(0x01d0, PIN_INPUT_PULLUP, 2) /* (B14) UART0_CTSn.I2C3_SCL */
AM62X_IOPAD(0x01d4, PIN_INPUT_PULLUP, 2) /* (C13) UART0_RTSn.I2C3_SDA */
main_uart0_pins_default: main-uart0-pins-default {
AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
main_uart1_pins_default: main-uart1-pins-default {
AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19) MCASP0_AXR3.UART1_CTSn */
AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19) MCASP0_AXR2.UART1_RTSn */
AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19) MCASP0_AFSR.UART1_RXD */
AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */
main_uart4_pins_default: main-uart4-pins-default {
AM62X_IOPAD(0x0124, PIN_INPUT, 3) /* (D20) MMC2_SDCD.UART4_RXD */
AM62X_IOPAD(0x0128, PIN_OUTPUT, 3) /* (C20) MMC2_SDWP.UART4_TXD */
main_uart6_pins_default: main-uart6-pins-default {
AM62X_IOPAD(0x009c, PIN_INPUT, 3) /* (P17) GPMC0_WAIT1.UART6_RXD */
AM62X_IOPAD(0x00a0, PIN_OUTPUT, 3) /* (J20) GPMC0_WPn.UART6_TXD */
main_mmc0_pins_default: main-mmc0-pins-default {
AM62X_IOPAD(0x0220, PIN_INPUT_PULLUP, 0) /* (Y3) MMC0_CMD */
AM62X_IOPAD(0x0218, PIN_OUTPUT, 0) /* (AB1) MMC0_CLK */
AM62X_IOPAD(0x0214, PIN_INPUT_PULLUP, 0) /* (AA2) MMC0_DAT0 */
AM62X_IOPAD(0x0210, PIN_INPUT_PULLUP, 0) /* (AA1) MMC0_DAT1 */
AM62X_IOPAD(0x020c, PIN_INPUT_PULLUP, 0) /* (AA3) MMC0_DAT2 */
AM62X_IOPAD(0x0208, PIN_INPUT_PULLUP, 0) /* (Y4) MMC0_DAT3 */
AM62X_IOPAD(0x0204, PIN_INPUT_PULLUP, 0) /* (AB2) MMC0_DAT4 */
AM62X_IOPAD(0x0200, PIN_INPUT_PULLUP, 0) /* (AC1) MMC0_DAT5 */
AM62X_IOPAD(0x01fc, PIN_INPUT_PULLUP, 0) /* (AD2) MMC0_DAT6 */
AM62X_IOPAD(0x01f8, PIN_INPUT_PULLUP, 0) /* (AC2) MMC0_DAT7 */
main_mmc1_pins_default: main-mmc1-pins-default {
AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21/C18) MMC1_CMD */
AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22/A20) MMC1_CLK */
AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22/A19) MMC1_DAT0 */
AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21/B19) MMC1_DAT1 */
AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21/B20) MMC1_DAT2 */
AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22/C19) MMC1_DAT3 */
AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17/C15) MMC1_SDCD */
main_mmc2_pins_default: main-mmc2-pins-default {
AM62X_IOPAD(0x120, PIN_INPUT, 0) /* (C24) MMC2_CMD */
AM62X_IOPAD(0x118, PIN_INPUT, 0) /* (D25) MMC2_CLK */
AM62X_IOPAD(0x114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */
AM62X_IOPAD(0x110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */
AM62X_IOPAD(0x10c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */
AM62X_IOPAD(0x108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */
AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */
ospi0_pins_default: ospi0-pins-default {
AM62X_IOPAD(0x0000, PIN_OUTPUT, 0) /* (G19) OSPI0_CLK */
AM62X_IOPAD(0x002c, PIN_OUTPUT, 0) /* (F19) OSPI0_CSn0 */
AM62X_IOPAD(0x000c, PIN_INPUT, 0) /* (F18) OSPI0_D0 */
AM62X_IOPAD(0x0010, PIN_INPUT, 0) /* (G17) OSPI0_D1 */
AM62X_IOPAD(0x0014, PIN_INPUT, 0) /* (F21) OSPI0_D2 */
AM62X_IOPAD(0x0018, PIN_INPUT, 0) /* (F20) OSPI0_D3 */
AM62X_IOPAD(0x001c, PIN_INPUT, 0) /* (G21) OSPI0_D4 */
AM62X_IOPAD(0x0020, PIN_INPUT, 0) /* (H21) OSPI0_D5 */
AM62X_IOPAD(0x0024, PIN_INPUT, 0) /* (G20) OSPI0_D6 */
AM62X_IOPAD(0x0028, PIN_INPUT, 0) /* (J21) OSPI0_D7 */
AM62X_IOPAD(0x0008, PIN_INPUT, 0) /* (H20) OSPI0_DQS */
main_spi0_pins_default: main-spi0-pins-default {
AM62X_IOPAD(0x01bc, PIN_INPUT, 0) /* (D12) SPI0_CLK */
AM62X_IOPAD(0x01b4, PIN_OUTPUT, 0) /* (C11) SPI0_CS0 */
AM62X_IOPAD(0x01c0, PIN_OUTPUT, 0) /* (C12) SPI0_D0 */
AM62X_IOPAD(0x01c4, PIN_INPUT, 0) /* (A14) SPI0_D1 */
main_mcasp2_pins_default: main-mcasp2-pins-default {
AM62X_IOPAD(0x0178, PIN_INPUT, 2) /* (V16) RGMII2_TD3.MCASP2_ACLKX */
AM62X_IOPAD(0x0174, PIN_INPUT, 2) /* (W17) RGMII2_TD2.MCASP2_AFSX */
AM62X_IOPAD(0x018c, PIN_OUTPUT, 2) /* (Y19) RGMII2_RD2.MCASP2_AXR0 */
AM62X_IOPAD(0x0180, PIN_INPUT, 2) /* (V18) RGMII2_RXC.MCASP2_AXR1 */
main_dss0_pins_default: main-dss0-pins-default {
AM62X_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */
AM62X_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */
AM62X_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */
AM62X_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */
AM62X_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */
AM62X_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */
AM62X_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */
AM62X_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */
AM62X_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */
AM62X_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */
AM62X_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */
AM62X_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */
AM62X_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */
AM62X_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */
AM62X_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */
AM62X_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */
AM62X_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */
AM62X_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */
AM62X_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */
AM62X_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */
AM62X_IOPAD(0x005c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */
AM62X_IOPAD(0x0060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */
AM62X_IOPAD(0x0064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */
AM62X_IOPAD(0x0068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */
AM62X_IOPAD(0x006c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */
AM62X_IOPAD(0x0070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */
AM62X_IOPAD(0x0074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */
AM62X_IOPAD(0x0078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */
vdd_3v3_sd_pins_default: vdd-3v3-sd-pins-default {
AM62X_IOPAD(0x0138, PIN_OUTPUT, 7) /* (AA19) RGMII1_TD1.GPIO0_76 */
vdd_sd_dv_pins_default: vdd-sd-dv-pins-default {
AM62X_IOPAD(0x00a4, PIN_OUTPUT, 7) /* (J19) GPMC0_DIR.GPIO0_40 */
bt_en_pins_default: bt-en-pins-default {
AM62X_IOPAD(0x007c, PIN_OUTPUT, 7) /* (M19) GPMC0_CLK.GPIO0_31 */ /* BT Regulator */
wlan_en_pins_default: wlan-en-pins-default {
AM62X_IOPAD(0x0094, PIN_OUTPUT, 7) /* (K18) GPMC0_BE1n.GPIO0_36 */
main_wlirq_pins_default: main-wlirq-pins-default {
AM62X_IOPAD(0x00ac, PIN_INPUT, 7) /* (H17) GPMC0_CSn1.GPIO0_42 */
main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-pins-default {
AM62X_IOPAD(0x0184, PIN_INPUT, 7) /* (W18) RGMII2_RD0.GPIO1_3 */
hdmi_pins_default: hdmi-pins-default {
AM62X_IOPAD(0x0134, PIN_INPUT, 7) /* (U14) RGMII1_TD0.GPIO0_75 */ /* HDMI Interrupt */
AM62X_IOPAD(0x012c, PIN_OUTPUT, 7) /* (V15) RGMII1_TX_CTL.GPIO0_73 */ /* HDMI Reset */
main_mcan0_pins_default: main-mcan0-pins-default {
AM62X_IOPAD(0x01dc, PIN_INPUT, 0) /* (E15) MCAN0_RX */
AM62X_IOPAD(0x01d8, PIN_OUTPUT, 0) /* (C15) MCAN0_TX */
touch_pins_default: touch-pins-default {
AM62X_IOPAD(0x016c, PIN_INPUT, 7) /* (AA20) RGMII2_TD0.GPIO0_89 */ /* Touch Interrupt */
AM62X_IOPAD(0x0170, PIN_OUTPUT, 7) /* (U15) RGMII2_TD1.GPIO0_90 */ /* Touch Reset */
usr_led_pins_default: usr-led-pins-default {
AM62X_IOPAD(0x244, PIN_OUTPUT, 7) /* (C17/B15) MMC1_SDWP.GPIO1_49 */
&mcu_pmx0 {
mcu_mcan0_pins_default: mcu-mcan0-pins-default {
AM62X_MCU_IOPAD(0x0038, PIN_INPUT, 0) /* (B3) MCU_MCAN0_RX */
AM62X_MCU_IOPAD(0x0034, PIN_OUTPUT, 0) /* (D6) MCU_MCAN0_TX */
mcu_mcan1_pins_default: mcu-mcan1-pins-default {
AM62X_MCU_IOPAD(0x0040, PIN_INPUT, 0) /* (D4) MCU_MCAN1_RX */
AM62X_MCU_IOPAD(0x003c, PIN_OUTPUT, 0) /* (E5) MCU_MCAN1_TX */
&main_uart0 {
status = "okay";
pinctrl-0 = <&main_uart0_pins_default>;
interrupts-extended = <&gic500 GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>,
<&main_pmx0 0x1c8>; /* (D14) UART0_RXD PADCONFIG114 */
interrupt-names = "irq", "wakeup";
&main_uart1 {
status = "okay";
pinctrl-0 = <&main_uart1_pins_default>;
&main_uart4 {
status = "okay";
pinctrl-0 = <&main_uart4_pins_default>;
&main_uart6 {
status = "okay";
pinctrl-0 = <&main_uart6_pins_default>;
&main_uart2 {
&main_uart3 {
&main_uart5 {
&main_i2c0 {
pinctrl-0 = <&main_i2c0_pins_default>;
clock-frequency = <400000>;
status = "okay";
&main_i2c1 {
status = "okay";
pinctrl-0 = <&main_i2c1_pins_default>;
tlv320aic3106: audio-codec@18 {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x18>;
ai3x-micbias-vg = <1>; /* 2.0V */
/* Regulators */
AVDD-supply = <&vcc_3v3_sys>;
IOVDD-supply = <&vcc_3v3_sys>;
DRVDD-supply = <&vcc_3v3_sys>;
sii9022: sii9022@3b {
compatible = "sil,sii9022";
reg = <0x3b>;
pinctrl-0 = <&hdmi_pins_default>;
interrupt-parent = <&main_gpio0>;
interrupts = <75 IRQ_TYPE_EDGE_FALLING>;
irq-gpios = <&main_gpio0 75 GPIO_ACTIVE_LOW>;
reset-gpios = <&main_gpio0 73 GPIO_ACTIVE_LOW>;
sil,i2s-data-lanes = < 0 >;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
sii9022_in: endpoint {
remote-endpoint = <&dpi1_out>;
port@1 {
reg = <1>;
sii9022_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
ili2130: touchscreen@41 {
status = "okay";
compatible = "ilitek,ili2130";
reg = <0x41>;
pinctrl-0 = <&touch_pins_default>;
interrupts = <89 IRQ_TYPE_EDGE_FALLING>;
irq-gpios = <&main_gpio0 89 GPIO_ACTIVE_LOW>;
reset-gpios = <&main_gpio0 90 GPIO_ACTIVE_LOW>;
&main_i2c2 {
status = "okay";
pinctrl-0 = <&main_i2c2_pins_default>;
&main_i2c3 {
status = "okay";
pinctrl-0 = <&main_i2c3_pins_default>;
clock-frequency = <100000>;
exp1: gpio@23 {
compatible = "ti,tca6424";
reg = <0x23>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "12V_GPI1_OUT", "12V_GPI2_OUT",
"12V_GPI3_OUT", "12V_GPI4_OUT",
"12V_GPI5_OUT", "12V_GPI6_OUT",
"12V_GPI7_OUT", "12V_GPI8_OUT",
"12V_GPI9_OUT", "12V_GPI10_OUT",
"12V_GPI11_OUT", "12V_GPI12_OUT",
"12V_GPO1_IN", "12V_GPO2_IN",
"12V_GPO3_IN", "12V_GPO4_IN",
"12V_GPO5678_FAULT2", "12V_GPO5678_FAULT1",
"12V_GPO1234_FAULT2", "12V_GPO1234_FAULT1",
"12V_GPO8_IN", "12V_GPO7_IN",
"12V_GPO6_IN", "12V_GPO5_IN";
pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>;
interrupt-parent = <&main_gpio1>;
interrupts = <3 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
&main_gpio0 {
status = "okay";
pinctrl-0 = <&gpio0_pins_default>;
&main_gpio1 {
status = "okay";
pinctrl-0 = <&gpio1_pins_default>;
&sdhci0 {
status = "okay";
pinctrl-0 = <&main_mmc0_pins_default>;
disable-wp;
&sdhci1 {
/* SD/MMC */
vmmc-supply = <&vdd_mmc1>;
vqmmc-supply = <&vdd_sd_dv>;
pinctrl-0 = <&main_mmc1_pins_default>;
ti,driver-strength-ohm = <50>;
disable-wp;
no-1-8-v;
status = "okay";
&sdhci2 {
status = "okay";
vmmc-supply = <&wlan_en>;
vqmmc-supply = <&bt_en>;
pinctrl-0 = <&main_mmc2_pins_default>;
bus-width = <4>;
non-removable;
ti,fails-without-test-cd;
cap-power-off-card;
keep-power-in-suspend;
assigned-clocks = <&k3_clks 157 158>;
assigned-clock-parents = <&k3_clks 157 160>;
#size-cells = <0>;
&ospi0 {
status = "okay";
pinctrl-0 = <&ospi0_pins_default>;
flash@0{
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-tx-bus-width = <8>;
spi-rx-bus-width = <8>;
spi-max-frequency = <25000000>;
cdns,tshsl-ns = <60>;
cdns,tsd2d-ns = <60>;
cdns,tchsh-ns = <60>;
cdns,tslch-ns = <60>;
cdns,read-delay = <4>;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
partition@0 {
label = "ospi.tiboot3";
reg = <0x0 0x80000>;
partition@80000 {
label = "ospi.tispl";
reg = <0x80000 0x200000>;
partition@280000 {
label = "ospi.u-boot";
reg = <0x280000 0x400000>;
partition@680000 {
label = "ospi.env";
reg = <0x680000 0x40000>;
partition@6c0000 {
label = "ospi.env.backup";
reg = <0x6c0000 0x40000>;
partition@800000 {
label = "ospi.rootfs";
reg = <0x800000 0x37c0000>;
partition@3fc0000 {
label = "ospi.phypattern";
reg = <0x3fc0000 0x40000>;
&main_spi0 {
status = "okay";
#size-cells = <0>;
pinctrl-0 = <&main_spi0_pins_default>;
ti,pindir-d0-out-d1-in;
adc@0 {
compatible = "ti,ads8344";
reg = <0>;
spi-max-frequency = <1000000>;
vref-supply = <&vcc_5v0>;
#io-channel-cells = <1>;
&main_mcan0 {
pinctrl-0 = <&main_mcan0_pins_default>;
phys = <&transceiver1>;
status = "okay";
/* MCU periperhals */
&mcu_uart0 {
&mcu_i2c0 {
&mcu_mcan0 {
pinctrl-0 = <&mcu_mcan0_pins_default>;
phys = <&transceiver2>;
status = "okay";
&mcu_mcan1 {
pinctrl-0 = <&mcu_mcan1_pins_default>;
phys = <&transceiver3>;
status = "okay";
/* mcu_gpio0 and mcu_gpio_intr are reserved for mcu firmware usage */
&mcu_gpio_intr {
status = "reserved";
&mcu_gpio0 {
/* WKUP periperhals */
&wkup_conf {
status = "okay";
&chipid {
status = "okay";
/* wkup_uart0 is reserved for firmware usage */
&wkup_uart0 {
&wkup_i2c0 {
&mcu_m4fss {
mboxes = <&mailbox0_cluster0 &mbox_m4_0>;
memory-region = <&mcu_m4fss_dma_memory_region>,
<&mcu_m4fss_memory_region>;
&wkup_r5fss0_core0 {
mboxes = <&mailbox0_cluster0 &mbox_r5_0>;
memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
<&wkup_r5fss0_core0_memory_region>;
&mailbox0_cluster0 {
mbox_m4_0: mbox-m4-0 {
ti,mbox-rx = <0 0 0>;
ti,mbox-tx = <1 0 0>;
mbox_r5_0: mbox-r5-0 {
ti,mbox-rx = <2 0 0>;
ti,mbox-tx = <3 0 0>;
&mcasp2 {
status = "okay";
pinctrl-0 = <&main_mcasp2_pins_default>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
1 2 0 0
0 0 0 0
0 0 0 0
0 0 0 0
tx-num-evt = <0>;
rx-num-evt = <0>;
&mcasp1 {
&tlv320aic3106 {
DVDD-supply = <&vcc_1v8>;
&dphy0 {
status = "okay";
&dss {
pinctrl-0 = <&main_dss0_pins_default>;
&dss_ports {
/* VP2: DPI Output */
hdmi0_dss: port@1 {
reg = <1>;
dpi1_out: endpoint {
remote-endpoint = <&sii9022_in>;
&pruss {
&cpsw3g {
&cpsw_port1 {
&cpsw3g_mdio {
&epwm0 {
&epwm1 {
&epwm2 {
&ecap0 {
&ecap1 {
&ecap2 {
Dt and defconfig FYR
Kindly do the needful
Pawan
