i have created mcu0_freertos.xer5f image with example SDL
how to use it with SBL and execute
Yogesh Asati
Aptiv Bangalore
Yogesh Asati
Aptiv Bangalore
Yogesh,
The engineer assigned is out of office until Oct. 4th.
Please expect a delay in response.
-Josue
Hi Yogesh,
For booting via SD boot mode: 5.2. J784S4 SBL — Platform Development Kit (PDK) - J784S4 User Guide (ti.com)
For booting via OSPI mode: 5.2. J784S4 SBL — Platform Development Kit (PDK) - J784S4 User Guide (ti.com)
Josiitaa
Hi Josiitaa,
Thanks for reply,
i am building TI SDk example:
command to build sdl example
ti-processor-sdk-rtos-j784s4-evm-10_00_00_05/sdl$ make esm_main_app SOC=j784s4 BUILD_OS_TYPE=freertos PROFILE=debug
Execution logs below
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB5, 12:59:15
Press CTRL-A Z for help on special keys
SBL Revision: 01.00.10.01 (Aug 12 2024 - 09:19:00)
TIFS ver: 10.0.8--v10.00.08 (Fiery Fox)
mcuClkFreq 1000000000
ESM Example Application
ESM_ECC_Example_init: Init MAIN ESM complete
Failed to configure the RAT index 2 address 0x20000000
SDTF_init: Error initializing R5F core ECC: result = -1
ESM Safety Example tests: unsuccessful
ESM UC-6 and UC-7 Test Failed.
Some tests have failed.
main.c:297:esm_app:FAIL
1 Tests 1 Failures 0 Ignored
FAIL
I can RAT failed
i tried other apps also all failing on
there are no my local changes.
Yogesh
Hi Josiitaa,
these are my contains of SD card BOOT partition:
dlb58q5j3@diagdenali:/media/dlb58q5j3/BOOT$ ll
total 5772
drwxr-xr-x 3 dlb58q5j3 dlb58q5j3 4096 Jan 1 1970 ./
drwxr-x---+ 4 root root 4096 Oct 5 14:04 ../
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 1246324 Oct 5 12:51 app
drwxr-xr-x 2 dlb58q5j3 dlb58q5j3 4096 Oct 3 22:03 'System Volume Information'/
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 303967 Oct 5 12:47 tiboot3.bin
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 476225 Oct 1 19:48 tiboot3-j784s4-gp-evm.bin
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 476225 Oct 1 19:48 tiboot3-j784s4-gp-evm-j784s4-evm-k3r5-2024.04+git-r0_tisdk_5_edgeai_4.bin
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 478814 Oct 1 19:48 tiboot3-j784s4-hs-evm.bin
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 478814 Oct 1 19:48 tiboot3-j784s4-hs-fs-evm.bin
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 158666 Oct 5 12:57 tifs.bin
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 1086687 Oct 1 19:48 tispl.bin
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 1164635 Oct 1 19:48 u-boot.img
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 1135 Oct 1 19:48 uEnv.txt
-rw-r--r-- 1 dlb58q5j3 dlb58q5j3 14 Oct 1 19:48 version
Yogesh
HI Josiitaa,
if i build for baremetal esm_main its passed
build command: make esm_main_app SOC=j784s4
am i doing any mistake for building freertos same esm_main_app ?
regards,
Yogesh
Hi Yogesh,
Are you planning on executing all the examples on freertos?
I will try executing the SDL example on freertos and see if I can reproduce the issue by Monday(7/10).
Josiitaa
hi josiitaa,
for now, i am just planning to execute freertos main_esm0.appimage
I am blocek here.
Can we have joined debug seesion today at 3 to 4 PM.
let me know i will send meeting invite.
you can include your expert engineer if you need.
regards,
Yogesh
Hi Yogesh,
I am able to reproduce this issue as well. I will check with the internal team and get back to you in a few days.
I see that you have created an E2E with the same discussion - https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1421461/tda4vh-q1-freertos-sdl-example-apps-failed-but-pass-on-baremetal
Let us continue the discussion there.
Josiitaa
