Part Number: 66AK2H12
I want to upgrade the SDK version of 66AK2H, but the following error occurred while executing setup.sh. What is the reason for this? The SDK version is 06.03.00.106.
root@athena-VirtualBox:/home/ym/python-build/TiBuild/SDK# ./setup.sh
TISDK setup script
This script will set up your development host for SDK development.
Parts of this script require administrator priviliges (sudo access).
Verifying Linux host distribution
Ubuntu 12.04 LTS, Ubuntu 14.04, or Ubuntu 14.04 LTS is being used, continuing..
Starting with Ubuntu 12.04 serial devices are only accessible by members of the 'dialout' group.
A user must be apart of this group to have the proper permissions to access a serial device.
Are you running this script using sudo? The detected username is 'root'.
Verify and enter your Linux username below
[ root ]
User 'root' is already apart of the 'dialout' group
setup package script
This script will make sure you have the proper host support packages installed
This script requires administrator priviliges (sudo access) if packages are to be installed.
System has required packages!
Package verification and installation successfully completed
In which directory do you want to install the target filesystem?(if this directory does not exist it will be created)
[ /root/project/TiBuild/SDK/targetNFS ]
This step will extract the target filesystem to /root/project/TiBuild/SDK/targetNFS
Note! This command requires you to have administrator priviliges (sudo access)
on your host.
Press return to continue
/root/project/TiBuild/SDK/targetNFS already exists
(r) rename existing filesystem (o) overwrite existing filesystem (s) skip filesystem extraction
[r] o
Old /root/project/TiBuild/SDK/targetNFS removed
Multiple filesystems found.
1:tisdk-server-rootfs-image-k2hk-evm.tar.xz
2:tisdk-docker-rootfs-image-k2hk-evm.tar.xz
Enter Number of rootfs Tarball: [1]
Successfully extracted tisdk-server-rootfs-image-k2hk-evm.tar.xz to /root/project/TiBuild/SDK/targetNFS
This step will set up the SDK to install binaries in to:
/root/project/TiBuild/SDK/targetNFS/home/root/k2hk-evm
The files will be available from /home/root/k2hk-evm on the target.
This setting can be changed later by editing Rules.make and changing the
EXEC_DIR or DESTDIR variable (depending on your SDK).
Rules.make edited successfully..
This step will export your target filesystem for NFS access.
on your host.
/root/project/TiBuild/SDK/targetNFS already NFS exported, skipping..
[ ok ] Stopping nfs-kernel-server (via systemctl): nfs-kernel-server.service.
[ ok ] Starting nfs-kernel-server (via systemctl): nfs-kernel-server.service.
Which directory do you want to be your tftp root directory?(if this directory does not exist it will be created for you)
[ /tftpboot ]
This step will set up the tftp server in the /tftpboot directory.
on your host.
/tftpboot already exists, not creating..
/tftpboot/*Image-k2hk-evm.bin already exists. The existing installed file can be renamed and saved under the new name.
(r) rename (o) overwrite (s) skip copy
[r] o
Successfully overwritten *Image-k2hk-evm.bin in tftp root directory /tftpboot
/tftpboot/keystone-k2hk-evm.dtb already exists. The existing installed file can be renamed and saved under the new name.
[o] o
Successfully overwritten keystone-k2hk-evm.dtb in tftp root directory /tftpboot
/tftpboot/keystone-k2hk-evm-k2hk-evm.dtb already exists. The existing installed file can be renamed and saved under the new name.
[o] o
Successfully overwritten keystone-k2hk-evm-k2hk-evm.dtb in tftp root directory /tftpboot
ls: cannot access '*.dtbo': No such file or directory
/tftpboot/u-boot-spi-k2hk-evm.gph already exists. The existing installed file can be renamed and saved under the new name.
[o] o
Successfully overwritten u-boot-spi-k2hk-evm.gph in tftp root directory /tftpboot
/tftpboot/skern-k2hk.bin already exists. The existing installed file can be renamed and saved under the new name.
[o] o
Successfully overwritten skern-k2hk.bin in tftp root directory /tftpboot
/tftpboot/k2-fw-initrd.cpio.gz already exists. The existing installed file can be renamed and saved under the new name.
[o] o
Successfully overwritten k2-fw-initrd.cpio.gz in tftp root directory /tftpboot
/etc/xinetd.d/tftp already exists..
/tftpboot already exported for TFTP, skipping..
Restarting tftp server
This step will set up minicom (serial communication application) for
SDK development
For boards that contain a USB-to-Serial converter on the board such as:
* BeagleBone
* Beaglebone Black
* AM335x EVM-SK
* AM57xx EVM
* K2H, K2L, and K2E EVMs
the port used for minicom will be automatically detected. By default Ubuntu
will not recognize this device. Setup will add a udev rule to
/etc/udev/ so that from now on it will be recognized as soon as the board is
plugged in.
For other boards, the serial will defualt to /dev/ttyS0. Please update based
on your setup.
NOTE: If your using any of the above boards simply hit enter
and the correct port will be determined automatically at a
later step. For all other boards select the serial port
that the board is connected to.
Which serial port do you want to use with minicom?
[ /dev/ttyS0 ] /dev/ttyUSB0
Copied existing /root/.minirc.dfl to /root/.minirc.dfl.old
Configuration saved to /root/.minirc.dfl. You can change it further from inside
minicom, see the Software Development Guide for more information.
This step will set up the u-boot variables for booting the EVM.
Autodetected the following ip address of your host, correct it if necessary (10.0.2.15/192.168.1.25/172.17.0.1)
[ 10.0.2.15 ] 192.168.1.25
ls: cannot access './bin/../filesystem/tisdk-server-rootfs-image-k2hk-evm.ubi': No such file or directory
basename: missing operand
Try 'basename --help' for more information.
Successfully copied arago-base-tisdk-image-k2hk-evm.ubi to tftp root directory /tftpboot
/tftpboot/arago-tiny-image-k2hk-evm.ubi already exists. The existing installed file can be renamed and saved under the new name.
[ o ]
Successfully overwritten arago-tiny-image-k2hk-evm.ubi in tftp root directory /tftpboot
Successfully copied tisdk-docker-rootfs-image-k2hk-evm.ubi to tftp root directory /tftpboot
Would you like to update U-boot on the board? (y/n)
[ y ]
Would you like to update the UBI filesystem on the board? (y/n)
[ y ]
Available ubi images in /tftpboot:
./bin/setup-uboot-env.sh: 74: shift: can't shift that many
Failed setup, aborting..
