AM6442: AM6442 SK
Part Number: AM6442
Hi , I am working on AM6442 SK. I would like to use the PRU-ICSSG core for toggling an LED on its GPO 1 pin. I have followed this link, [FAQ] AM6442( AM64X) : How to Toggle GPIO Pin on PRU? - Processors forum - Processors - TI E2E support forums, but failed. Is there anything that i have to modify while i am using AM 6442 SK other than AM6442 EVM.
Thank you
Shiny K George
  • Hi Shiny,
    Thanks for your query.
    The assigned expert is currently out of office. So responses to this thread might be delayed. Thanks for your patience.
    Tushar
  • Hi Shiny,
    No modifications should be needed in following the above FAQ for AM64x-SK.
    Also, if you are using a HS_FS device, you can skip the Step 4. Next, right click on the DMSC core and select Connect Target. under Load and Run PRU Application from CCS.
    Do let me know if you face any issues.
    Nitika
