Part Number: AM6442
Hi TI Experts,
Customer is working on customer AM64x board based on SDK10.0.
When they use 4MB eMMC boot, they will meet the following issue.
Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.32-g6de6e418c80e-dirty (xxxx@xxxx-xxx-N000) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Bin utils) 2.42.0.20240716) #2 SMP PREEMPT Fri Nov 1 00:40:09 CST 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments AM642 EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@90000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000090000000..0x00000000900fffff (1024 KiB) nomap non-reusable r5f-dma-memory@90000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@90100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000090100000..0x0000000090ffffff (15360 KiB) nomap non-reusable r5f-memory@90100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000091000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@91000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000091000000..0x00000000910fffff (1024 KiB) nomap non-reusable r5f-dma-memory@91000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000091100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@91100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000091100000..0x0000000091ffffff (15360 KiB) nomap non-reusable r5f-memory@91100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000092000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@92000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000092000000..0x00000000920fffff (1024 KiB) nomap non-reusable r5f-dma-memory@92000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000092100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@92100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000092100000..0x0000000092ffffff (15360 KiB) nomap non-reusable r5f-memory@92100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000093000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@93000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000093000000..0x00000000930fffff (1024 KiB) nomap non-reusable r5f-dma-memory@93000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000093100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@93100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000093100000..0x0000000093ffffff (15360 KiB) nomap non-reusable r5f-memory@93100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000094000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@94000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000094000000..0x00000000940fffff (1024 KiB) nomap non-reusable m4f-dma-memory@94000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000094100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@94100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000094100000..0x0000000094ffffff (15360 KiB) nomap non-reusable m4f-memory@94100000 [ 0.000000] OF: reserved mem: 0x0000000095000000..0x00000000957fffff (8192 KiB) nomap non-reusable ipc-memories@95000000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x000000009fffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008fffffff] [ 0.000000] node 0: [mem 0x0000000090000000-0x00000000957fffff] [ 0.000000] node 0: [mem 0x0000000095800000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x000000009fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff] [ 0.000000] cma: Reserved 32 MiB at 0x000000009be00000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.t iboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=e14aea3b-1f60-447e-b0df-37a749a38 7e9 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 2. [ 0.000000] software IO TLB: mapped [mem 0x0000000097dc0000-0x000000009bdc0000] (64MB) [ 0.000000] Memory: 280032K/524288K available (11904K kernel code, 1214K rwdata, 3996K rodata, 2368K init, 502K bss, 211488K reserved, 32768K cma- reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008641] Console: colour dummy device 80x25 [ 0.013246] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023925] pid_max: default: 32768 minimum: 301 [ 0.028735] LSM: initializing lsm=capability,integrity [ 0.034113] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear) [ 0.041595] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear) [ 0.051569] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1. [ 0.058921] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1. [ 0.066901] rcu: Hierarchical SRCU implementation. [ 0.071812] rcu: Max phase no-delay instances is 1000. [ 0.077472] Platform MSI: msi-controller@1820000 domain created [ 0.083848] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.093379] EFI services will not be available. [ 0.098350] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.112019] Detected VIPT I-cache on CPU1 [ 0.112123] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000 [ 0.112143] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000 [ 0.112202] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.112345] smp: Brought up 1 node, 2 CPUs [ 0.141731] SMP: Total of 2 processors activated. [ 0.146542] CPU features: detected: 32-bit EL0 Support [ 0.151814] CPU features: detected: CRC32 instructions [ 0.157133] CPU: All CPU(s) started at EL2 [ 0.161319] alternatives: applying system-wide alternatives [ 0.168511] devtmpfs: initialized [ 0.181473] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.191487] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.199873] pinctrl core: initialized pinctrl subsystem [ 0.205879] DMI not present or invalid. [ 0.210621] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.217704] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [ 0.225104] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.233159] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.241363] audit: initializing netlink subsys (disabled) [ 0.247181] audit: type=2000 audit(0.156:1): state=initialized audit_enabled=0 res=1 [ 0.247755] thermal_sys: Registered thermal governor 'step_wise' [ 0.255132] thermal_sys: Registered thermal governor 'power_allocator' [ 0.261534] cpuidle: using governor menu [ 0.272474] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.279482] ASID allocator initialised with 65536 entries [ 0.296859] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f4000/pinctrl@a40000/cpsw-cpts-pps [ 0.310827] Modules: 27712 pages in range for non-PLT usage [ 0.310848] Modules: 519232 pages in range for PLT usage [ 0.317656] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.330093] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.336500] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.343435] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.349840] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.356776] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.363187] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.370123] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.378409] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected [ 0.388080] iommu: Default domain type: Translated [ 0.393028] iommu: DMA domain TLB invalidation policy: strict mode [ 0.399731] SCSI subsystem initialized [ 0.404113] usbcore: registered new interface driver usbfs [ 0.409780] usbcore: registered new interface driver hub [ 0.415249] usbcore: registered new device driver usb [ 0.420960] pps_core: LinuxPPS API ver. 1 registered [ 0.426043] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.435388] PTP clock support registered [ 0.439592] EDAC MC: Ver: 3.0.0 [ 0.443674] scmi_core: SCMI protocol bus registered [ 0.449169] FPGA manager framework [ 0.452815] Advanced Linux Sound Architecture Driver Initialized. [ 0.460220] vgaarb: loaded [ 0.463498] clocksource: Switched to clocksource arch_sys_counter [ 0.470071] VFS: Disk quotas dquot_6.6.0 [ 0.474126] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.489024] NET: Registered PF_INET protocol family [ 0.494244] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.502439] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear) [ 0.511077] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.519017] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.526978] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.534497] TCP: Hash tables configured (established 4096 bind 4096) [ 0.541130] UDP hash table entries: 256 (order: 1, 8192 bytes, linear) [ 0.547831] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear) [ 0.555128] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.561520] RPC: Registered named UNIX socket transport module. [ 0.567627] RPC: Registered udp transport module. [ 0.572437] RPC: Registered tcp transport module. [ 0.577244] RPC: Registered tcp-with-tls transport module. [ 0.582850] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.589458] NET: Registered PF_XDP protocol family [ 0.594377] PCI: CLS 0 bytes, default 64 [ 0.599918] Initialise system trusted keyrings [ 0.604815] workingset: timestamp_bits=46 max_order=17 bucket_order=0 [ 0.611897] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.618322] NFS: Registering the id_resolver key type [ 0.623567] Key type id_resolver registered [ 0.627845] Key type id_legacy registered [ 0.631967] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.638820] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.686967] Key type asymmetric registered [ 0.691171] Asymmetric key parser 'x509' registered [ 0.696228] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.703791] io scheduler mq-deadline registered [ 0.708445] io scheduler kyber registered [ 0.712591] io scheduler bfq registered [ 0.719646] pinctrl-single 4084000.pinctrl: 33 pins, size 132 [ 0.726137] pinctrl-single f4000.pinctrl: 180 pins, size 720 [ 0.733622] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.746993] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.766357] loop: module loaded [ 0.770885] megasas: 07.725.01.00-rc1 [ 0.777540] tun: Universal TUN/TAP device driver, 1.6 [ 0.784173] VFIO - User Level meta-driver version: 0.3 [ 0.790739] usbcore: registered new interface driver usb-storage [ 0.797363] i2c_dev: i2c /dev entries driver [ 0.803054] sdhci: Secure Digital Host Controller Interface driver [ 0.809418] sdhci: Copyright(c) Pierre Ossman [ 0.814159] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.820735] ledtrig-cpu: registered to indicate activity on CPUs [ 0.827272] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.834748] usbcore: registered new interface driver usbhid [ 0.840460] usbhid: USB HID core driver [ 0.844816] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100 [ 0.851784] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100 [ 0.858653] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100 [ 0.867176] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.876342] optee: probing for conduit method. I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.880934] optee: revision 4.2 (12d7c4ee) [ 0.897612] optee: dynamic shared memory is enabled [ 0.907815] random: crng init done [ 0.911459] optee: initialized driver [ 0.917804] NET: Registered PF_PACKET protocol family [ 0.923127] Key type dns_resolver registered [ 0.936980] registered taskstats version 1 [ 0.941553] Loading compiled-in X.509 certificates [ 0.961510] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') [ 1.073465] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=62, clk=3, ret=-19 [ 1.112190] ti-sci-intr bus@f4000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.121626] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.130747] ti-udma 485c0100.dma-controller: Number of rings: 68 [ 1.138616] ti-udma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6) [ 1.148958] ti-udma 485c0000.dma-controller: Number of rings: 288 [ 1.166608] ti-udma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15) [ 1.178019] printk: console [ttyS2] disabled [ 1.183086] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 315, base_baud = 3000000) is a 8250 [ 1.192029] printk: console [ttyS2] enabled [ 1.192029] printk: console [ttyS2] enabled [ 1.200491] printk: bootconsole [ns16550a0] disabled [ 1.200491] printk: bootconsole [ns16550a0] disabled [ 1.215618] spi-nor spi0.0: unrecognized JEDEC id bytes: 90 80 2f 90 80 2f [ 1.224040] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.267506] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.277838] davinci_mdio 8000f00.mdio: phy[7]: device 8000f00.mdio:07, driver TI DP83826C [ 1.286102] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006 [ 1.298934] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4 [ 1.306067] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.312780] pps pps0: new PPS source ptp0 [ 1.317230] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1 [ 1.334640] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16 [ 1.346878] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0 [ 1.357137] mmc0: CQHCI version 5.10 [ 1.370279] clk: Disabling unused clocks [ 1.380208] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=62, clk=3, ret=-19 [ 1.402162] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.411236] ALSA device list: [ 1.414308] No soundcards found. [ 1.418278] Waiting for root device PARTUUID=e14aea3b-1f60-447e-b0df-37a749a387e9... [ 1.488701] mmc0: Command Queue Engine enabled [ 1.493220] mmc0: new HS200 MMC card at address 0001 [ 1.499032] mmcblk0: mmc0:0001 M04A11 3.64 GiB [ 1.508261] mmcblk0: p1 [ 1.511646] mmcblk0boot0: mmc0:0001 M04A11 4.00 MiB [ 1.517879] mmcblk0boot1: mmc0:0001 M04A11 4.00 MiB [ 1.524097] mmcblk0rpmb: mmc0:0001 M04A11 4.00 MiB, chardev (239:0) [ 1.542402] EXT4-fs (mmcblk0p1): recovery complete [ 1.547278] EXT4-fs (mmcblk0p1): mounted filesystem bef90e4d-4ff1-4f75-a999-38b6040d4747 r/w with ordered data mode. Quota mode: none. [ 1.559434] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 1.567555] devtmpfs: mounted [ 1.572300] Freeing unused kernel memory: 2368K [ 1.576959] Run /sbin/init as init process [ 62.587579] mmc0: cqhci: timeout for tag 2, qcnt 4 [ 62.592411] mmc0: cqhci: ============ CQHCI REGISTER DUMP =========== [ 62.598847] mmc0: cqhci: Caps: 0x000030c8 | Version: 0x00000510 [ 62.605282] mmc0: cqhci: Config: 0x00000101 | Control: 0x00000000 [ 62.611716] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000016 [ 62.618150] mmc0: cqhci: Int sig: 0x00000016 | Int Coal: 0x00000000 [ 62.624585] mmc0: cqhci: TDL base: 0x8142a000 | TDL up32: 0x00000000 [ 62.631019] mmc0: cqhci: Doorbell: 0x0008001c | TCN: 0x00000000 [ 62.637452] mmc0: cqhci: Dev queue: 0x00000040 | Dev Pend: 0x0008001c [ 62.643886] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000 [ 62.650324] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000000 [ 62.656758] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x00000000 [ 62.663192] mmc0: cqhci: Resp idx: 0x0000002d | Resp arg: 0x00000900 [ 62.669626] mmc0: sdhci: ============ SDHCI REGISTER DUMP =========== [ 62.676058] mmc0: sdhci: Sys addr: 0x00000090 | Version: 0x00001004 [ 62.682491] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000000 [ 62.688925] mmc0: sdhci: Argument: 0x00000282 | Trn mode: 0x00000033 [ 62.695358] mmc0: sdhci: Present: 0x01ff00f0 | Host ctl: 0x0000003c [ 62.701791] mmc0: sdhci: Power: 0x0000000b | Blk gap: 0x00000080 [ 62.708229] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007 [ 62.714662] mmc0: sdhci: Timeout: 0x0000000e | Int stat: 0x00000000 [ 62.721095] mmc0: sdhci: Int enab: 0x02ff4000 | Sig enab: 0x02ff4000 [ 62.727528] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 62.733961] mmc0: sdhci: Caps: 0x7cecc801 | Caps_1: 0x98002407 [ 62.740394] mmc0: sdhci: Cmd: 0x00002d1a | Max curr: 0x00000000 [ 62.746828] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xfff6dbff [ 62.753262] mmc0: sdhci: Resp[2]: 0x329f5903 | Resp[3]: 0x00d02701 [ 62.759695] mmc0: sdhci: Host ctl2: 0x00000003 [ 62.764135] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000009bf80618 [ 62.771266] mmc0: sdhci: ============================================ [ 62.777724] mmc0: running CQE recovery [ 124.027575] mmc0: cqhci: timeout for tag 16, qcnt 1 [ 124.032494] mmc0: cqhci: ============ CQHCI REGISTER DUMP =========== [ 124.038929] mmc0: cqhci: Caps: 0x000030c8 | Version: 0x00000510 [ 124.045364] mmc0: cqhci: Config: 0x00000101 | Control: 0x00000000 [ 124.051798] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000016 [ 124.058232] mmc0: cqhci: Int sig: 0x00000016 | Int Coal: 0x00000000 [ 124.064667] mmc0: cqhci: TDL base: 0x8142a000 | TDL up32: 0x00000000 [ 124.071100] mmc0: cqhci: Doorbell: 0x00010000 | TCN: 0x00000000 [ 124.077534] mmc0: cqhci: Dev queue: 0x00400000 | Dev Pend: 0x00010000 [ 124.083967] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000 [ 124.090405] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000000 [ 124.096839] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x00000000 [ 124.103273] mmc0: cqhci: Resp idx: 0x0000002e | Resp arg: 0x00000900 [ 124.109707] mmc0: sdhci: ============ SDHCI REGISTER DUMP =========== [ 124.116139] mmc0: sdhci: Sys addr: 0x00000028 | Version: 0x00001004 [ 124.122572] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000000 [ 124.129005] mmc0: sdhci: Argument: 0x00170000 | Trn mode: 0x00000033 [ 124.135438] mmc0: sdhci: Present: 0x01ff00f0 | Host ctl: 0x0000003c [ 124.141872] mmc0: sdhci: Power: 0x0000000b | Blk gap: 0x00000080 [ 124.148310] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007 [ 124.154744] mmc0: sdhci: Timeout: 0x0000000e | Int stat: 0x00000000 [ 124.161177] mmc0: sdhci: Int enab: 0x02ff4000 | Sig enab: 0x02ff4000 [ 124.167610] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 124.174043] mmc0: sdhci: Caps: 0x7cecc801 | Caps_1: 0x98002407 [ 124.180477] mmc0: sdhci: Cmd: 0x00002e3a | Max curr: 0x00000000 [ 124.186910] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xfff6dbff [ 124.193344] mmc0: sdhci: Resp[2]: 0x329f5903 | Resp[3]: 0x00d02701 [ 124.199777] mmc0: sdhci: Host ctl2: 0x00000003 [ 124.204216] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000009bf88a24 [ 124.211347] mmc0: sdhci: ============================================ [ 124.217802] mmc0: running CQE recovery
Could you please provide some suggestions for the customer?
Many Thanks,
Kevin
