AM625: Problem Enabling Additional UART Clocks in the R5 SPL
Part Number: AM625
I am attempting to switch the UART console port on my board. I have been following a process similar to the post here:
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1345922/am625-console-output-uart0-to-uart2
However I am switching to UART1 instead of UART2. I am beginning first with the R5 modifications alone to the clock tree. See my below changes to add the additional nodes needed:
diff --git a/arch/arm/mach-k3/am62x/clk-data.c b/arch/arm/mach-k3/am62x/clk-data.c
index c0881778fe..7ba8f2f187 100644
--- a/arch/arm/mach-k3/am62x/clk-data.c
+++ b/arch/arm/mach-k3/am62x/clk-data.c
@@ -125,6 +125,11 @@ static const char * const main_usart0_fclk_sel_out0_parents[] = {
        "hsdiv4_16fft_main_1_hsdivout1_clk",
+static const char * const main_usart1_fclk_sel_out0_parents[] = {
+       "usart_programmable_clock_divider_out1",
+       "hsdiv4_16fft_main_1_hsdivout1_clk",
 static const struct clk_data clk_list[] = {
        CLK_FIXED_RATE("osc_26_mhz", 26000000, 0),
        CLK_FIXED_RATE("osc_25_mhz", 25000000, 0),
@@ -209,9 +214,11 @@ static const struct clk_data clk_list[] = {
        CLK_MUX("main_gtcclk_sel_out0", main_gtcclk_sel_out0_parents, 8, 0x43008030, 0, 3, 0),
        CLK_MUX("main_ospi_ref_clk_sel_out0", main_ospi_ref_clk_sel_out0_parents, 2, 0x108500, 0, 1, 0),
        CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x108240, 0, 2, 0, 0, 48000000),
+       CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out1", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x108244, 0, 2, 0, 0, 48000000),
        CLK_MUX("wkup_clkout_sel_out0", wkup_clkout_sel_out0_parents, 8, 0x43008020, 0, 3, 0),
        CLK_MUX("wkup_clksel_out0", wkup_clksel_out0_parents, 2, 0x43008010, 0, 1, 0),
        CLK_MUX("main_usart0_fclk_sel_out0", main_usart0_fclk_sel_out0_parents, 2, 0x108280, 0, 1, 0),
+       CLK_MUX("main_usart1_fclk_sel_out0", main_usart1_fclk_sel_out0_parents, 2, 0x108284, 0, 1, 0),
        CLK_DIV("hsdiv4_16fft_mcu_0_hsdivout1_clk", "pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", 0x4040084, 0, 7, 0, 0),
        CLK_FIXED_RATE("mshsi2c_wkup_0_porscl", 0, 0),
        CLK_DIV("sam62_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "sam62_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0, 0),
@@ -311,6 +318,10 @@ static const struct dev_clk soc_dev_clk_data[] = {
        DEV_CLK(146, 1, "usart_programmable_clock_divider_out0"),
        DEV_CLK(146, 2, "hsdiv4_16fft_main_1_hsdivout1_clk"),
        DEV_CLK(146, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"),
+       DEV_CLK(152, 0, "main_usart1_fclk_sel_out0"),
+       DEV_CLK(152, 1, "usart_programmable_clock_divider_out1"),
+       DEV_CLK(152, 2, "hsdiv4_16fft_main_1_hsdivout1_clk"),
+       DEV_CLK(152, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"),
        DEV_CLK(157, 20, "clkout0_ctrl_out0"),
        DEV_CLK(157, 21, "hsdiv4_16fft_main_2_hsdivout1_clk"),
        DEV_CLK(157, 22, "hsdiv4_16fft_main_2_hsdivout1_clk"),
diff --git a/arch/arm/mach-k3/am62x/dev-data.c b/arch/arm/mach-k3/am62x/dev-data.c
index 140dca4bd1..e8cb8c51b6 100644
--- a/arch/arm/mach-k3/am62x/dev-data.c
+++ b/arch/arm/mach-k3/am62x/dev-data.c
@@ -61,6 +61,7 @@ static struct ti_dev soc_dev_list[] = {
        PSC_DEV(36, &soc_lpsc_list[11]),
        PSC_DEV(102, &soc_lpsc_list[11]),
        PSC_DEV(146, &soc_lpsc_list[11]),
+       PSC_DEV(152, &soc_lpsc_list[11]),
        PSC_DEV(13, &soc_lpsc_list[12]),
        PSC_DEV(166, &soc_lpsc_list[13]),
        PSC_DEV(135, &soc_lpsc_list[14])
In booting tiboot3.bin, I am running into the same error message that person in the other post did (they never provided a resolution):
U-Boot SPL 2023.04-ti-g2c09eee5084d (Nov 15 2024 - 14:58:45 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
k3_ddrss memorycontroller@f300000: clk get failed-2
I enabled DEBUG prints as suggested, and see the additional output:
clk_set_defaults(sysctrler)
clk_set_default_parents: could not read assigned-clock-parents for 43c345a8
clk_set_defaults(secproxy@44880000)
clk_set_default_parents: could not read assigned-clock-parents for 43c34540
clk_set_defaults(esm@420000)
clk_set_default_parents: could not read assigned-clock-parents for 43c34608
clk_set_defaults(esm@4100000)
clk_set_default_parents: could not read assigned-clock-parents for 43c33a28
clk_set_defaults(memorycontroller@f300000)
clk_set_default_parents: could not read assigned-clock-parents for 43c34670
of_xlate() failed: -2
clk_request(dev=43c33e7c, clk=43c3a048)
clk_get_rate(clk=43c3a048)
clk_get_rate(clk=43c358c0)
clk_get_parent_rate(clk=43c358c0)
clk_get_parent(clk=43c358c0)
clk_set_rate(clk=43c3a028, rate=25000000)
clk_get_rate(clk=43c35740)
clk_get_parent(clk=43c35740)
clk_get_rate(clk=ffffffed)
I am wondering if someone from TI can provide guidance here before I spend additional time trying to debug this:
