SK-AM62B-P1: fit signature failure
Part Number: SK-AM62B-P1
Hi Team,
Trying to boot fit image on HSSE device and following error occurred ,
=> bootm 0x90000000
## Loading kernel from FIT Image at 90000000 ...
   Using 'conf-ti_k3-am625-art.dtb' configuration
   Verifying Hash Integrity ... fit_config_verify_required_keys: No signature node found: FDT_ERR_NOTFOUND
Bad Data Hash
ERROR: can't get kernel image!
Q1. why is this error occurred, i didn't sign fitimage.
Q2. How to achieve  root of trust between u-boot.img and fitimage.bin(dtb,kernel,fs). i have gone through software-dl.ti.com/.../Foundational_Components_Kernel_Users_Guide.html this how to get this fit configuration file , the above motioned documents mention about the .its file , when i add the config , at time of build it will be lost right ? , and when looked into fitImage.its file already configuration is added, also attaching conf below
configurations {
                default = "conf-ti_k3-am625-art.dtb";
                conf-ti_k3-am625-art.dtb {
                        description = "1 Linux kernel, FDT blob, ramdisk";
                        kernel = "kernel-1";
                        fdt = "fdt-ti_k3-am625-art.dtb";
                        ramdisk = "ramdisk-1";
                        hash-1 {
                                algo = "sha512";
                        signature-1 {
                                algo = "sha512,rsa4096";
                                key-name-hint = "custMpk";
                                padding = "pkcs-1.5";
                                sign-images = "kernel", "fdt", "ramdisk";
regards,
-RJ
  • 1/. which SDK release is used?
    2/. Is testing on TI board or customer board?
    -Hong
  • Hi Hong,
    Not sdk yocto krikstone
    TI board : SK-AM62B-P1
  • hi Hong ,
    I had gone through this already, but didn't understand how the root of trust is established between uboot and fit .
    Q1. should i replace the custMpk.key with the key generated at time of efuse ?
  • Hi Hong,
    Thanks for the reference!
    I'm using yocto krikstone for build, what i had done is attaching below ,
    for testing - i replaced the smpk.pem from key writer of ti/keys/custMpk.pem  in my yocto build, and
    enabled the below in conf files ,
    UBOOT_SIGN_ENABLE = "1"
    UBOOT_SIGN_KEYDIR = "..../keys"
    UBOOT_SIGN_KEYNAME = "dev"
    then build , uboot and fitImage,
    but still same error occurred
    => able boot till u-boot
    => bootm 0x90000000
    Bad Data Hash
    attaching fitimage.its file below
    /dts-v1/;
            description = "Kernel fitImage ..../6.1.83+gitAUTOINC+c1c2f1971f/am62xx";
            #address-cells = <1>;
            images {
                    kernel-1 {
                            description = "Linux kernel";
                            data = /incbin/("linux.bin");
                            type = "kernel";
                            arch = "arm64";
                            os = "linux";
                            compression = "gzip";
                            load = <0x81000000>;
                            entry = <0x81000000>;
                            hash-1 {
                                    algo = "sha512";
                    fdt-ti_k3-am625-art.dtb {
                            description = "Flattened Device Tree blob";
                            data = /incbin/("arch/arm64/boot/dts/ti/k3-am625-art`.dtb");
                            type = "flat_dt";
                            arch = "arm64";
                            compression = "none";
                            load = <0x83000000>;
                            hash-1 {
                                    algo = "sha512";
                    ramdisk-1 {
                            description = "*****-image-dev";
                            data = /incbin/("/home/................/tisdk/build/deploy-ti/images/am62xx/*****-image-dev-am62xx.cpio.xz");
                            type = "ramdisk";
                            arch = "arm64";
                            os = "linux";
                            load = <0x84000000>;
                            entry = <0x84000000>;
                            hash-1 {
                                    algo = "sha512";
            configurations {
                            hash-1 {
                                    algo = "sha512";
                            signature-1 {
                                    key-name-hint = "dev";
  • Let me pass your questions on Yocto to my colleague to follow up.
    -Hong
  • RJ DJ,
    Did you verify the timestamp of your U-Boot builds to make sure you are actually using/deploying your updated U-Boot binaries? Yocto can be tricky in this regard.
    # Build and deploy "tiboot3.bin" (and it's device-specific variants)
    $ MACHINE=am62xx-evm bitbake -c deploy mc:k3r5:u-boot
    # Build and deploy "tispl.bin" and "u-boot.img"
    $ MACHINE=am62xx-evm bitbake -c deploy u-boot
    Regards, Andreas
  • Hi Andreas Dannenberg,
    Rebuild both but same error occurred ,
    Q1  Is key-name-hint should be folder name?
    here is it key name ,I'm i missing something ?  and also can you also point which class is appending public key to uboot.img, i already fit image kernel class.
    Q2,  For testing purpose i disabled below configs , cleaned and rebuild k3r5,uboot,fitimage
    and it booted till root, i assume that custMpk.pem i used to flash to OTP is same ,that's why it boot but how it authenticate between uboot and fit image? is it user responsibility to add fitimage image signing ? ,attaching log below,
    U-Boot SPL 2023.04-ti-g836606420854 (May 09 2024 - 05:42:45 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    SPL initial stack usage: 13408 bytes
    Trying to boot from DFU
    ##########################################################DOWNLOAD ... OK
    Ctrl+C to exit ...
    Authentication passed
    Loading Environment from nowhere... OK
    init_env from device 10 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    SPL initial stack usage: 1856 bytes
    MMC: no card present
    ** Bad device specification mmc 1 **
    Couldn't find partition mmc 1:1
    Error: could not access storage.
    ####DOWNLOAD ... OK
    Ctrl+C to exit ...
    U-Boot 2023.04-ti-g836606420854 (May 09 2024 - 05:42:45 +0000)
    SoC:   AM62X SR1.0 HS-SE
    Model: Texas Instruments AM625 SK
    EEPROM not available at 80, trying to read at 81
    Board: AM62B-SKEVM-P1 rev A
    DRAM:  no bloblist found!2 GiB
    Core:  72 devices, 32 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Hit any key to stop autoboot:  0
    => bdinfo
    boot_params = 0x0000000000000000
    DRAM bank   = 0x0000000000000000
    -> start    = 0x0000000080000000
    -> size     = 0x0000000080000000
    flashstart  = 0x0000000000000000
    flashsize   = 0x0000000000000000
    flashoffset = 0x0000000000000000
    baudrate    = 115200 bps
    relocaddr   = 0x00000000fff06000
    reloc off   = 0x000000007f706000
    Build       = 64-bit
    current eth = ethernet@8000000port@1
    ethaddr     = 1c:63:49:1f:d9:2e
    IP addr     = <NULL>
    fdt_blob    = 0x00000000fded7840
    new_fdt     = 0x00000000fded7840
    fdt_size    = 0x000000000000f540
    Video       = dss@30200000 inactive
    multi_dtb_fit= 0x0000000000000000
    lmb_dump_all:
    memory.cnt  = 0x1
    memory[0]      [0x80000000-0xffffffff], 0x80000000 bytes flags: 0
    reserved.cnt  = 0x4
    reserved[0]    [0x9ca00000-0x9cafffff], 0x00100000 bytes flags: 0
    reserved[1]    [0x9cb00000-0x9e6fffff], 0x01c00000 bytes flags: 4
    reserved[2]    [0x9e780000-0x9fffffff], 0x01880000 bytes flags: 4
    reserved[3]    [0xfced2000-0xffffffff], 0x0312e000 bytes flags: 0
    devicetree  = separate
    arch_number = 0x0000000000000000
    TLB addr    = 0x00000000ffff0000
    irq_sp      = 0x00000000fded6ff0
    sp start    = 0x00000000fded6ff0
    Early malloc usage: 3c28 / 8000
    => fdt addr 0x00000000fded7840
    Working FDT set to fded7840
    => fdt list/signature
            model = "Texas Instruments AM625 SK";
            compatible = "ti,am625-sk", "ti,am625";
            interrupt-parent = <0x00000001>;
            #address-cells = <0x00000002>;
            #size-cells = <0x00000002>;
            signature {
            chosen {
            firmware {
            timer-cl0-cpu0 {
            pmu {
            bus@f0000 {
            cpus {
            opp-table {
            l2-cache0 {
            aliases {
            memory@80000000 {
            reserved-memory {
            regulator-0 {
            regulator-1 {
            regulator-2 {
            regulator-3 {
            regulator-4 {
            leds {
            panel-lvds {
            binman {
            __symbols__ {
    ----------- here signature is listed but which is used is not shown---?
    => bootm 0x90000000
       Using 'conf-ti_k3-am625-XXX.dtb' configuration
       Verifying Hash Integrity ... sha512,rsa4096:custMpk+ OK
       Trying 'kernel-1' kernel subimage
         Description:  Linux kernel
         Type:         Kernel Image
         Compression:  gzip compressed
         Data Start:   0x900000f4
         Data Size:    8246853 Bytes = 7.9 MiB
         Architecture: AArch64
         OS:           Linux
         Load Address: 0x81000000
         Entry Point:  0x81000000
         Hash algo:    sha512
         Hash value:   1b42c827f92afac2653db3a482937882904f2c2daceab0f3bc6215f89f22395939a98442e560403acf43a915311552a8c78fdb2182e65993234c2a54ef8209db
       Verifying Hash Integrity ... sha512+ OK
    ## Loading ramdisk from FIT Image at 90000000 ...
       Trying 'ramdisk-1' ramdisk subimage
         Description:  artemis-image-dev
         Type:         RAMDisk Image
         Compression:  uncompressed
         Data Start:   0x907ec444
         Data Size:    19734856 Bytes = 18.8 MiB
         OS:           Linux
         Load Address: 0x84000000
         Entry Point:  0x84000000
         Hash algo:    sha512
         Hash value:   be307e738f462572b9cb84044113a30d0281eb550b17c7cf7163f353f4651f671c2057cf819ed53b72e76682d1d440942316d81489de72f04ec097b32a5d10b4
       Loading ramdisk from 0x907ec444 to 0x84000000
    ## Loading fdt from FIT Image at 90000000 ...
       Trying 'fdt-ti_k3-am625-XXX.dtb' fdt subimage
         Description:  Flattened Device Tree blob
         Type:         Flat Device Tree
         Data Start:   0x907dd870
         Data Size:    60118 Bytes = 58.7 KiB
         Load Address: 0x83000000
         Hash algo:    sha512
         Hash value:   7bf126eefc13ccad05daf33f6e7554653e8ffab051a1baf70219f9a339d9ae0d6718cc6a660d991f83ffa6b3046cad148b7a08a7f05a18312518988170e36fe6
       Loading fdt from 0x907dd870 to 0x83000000
       Booting using the fdt blob at 0x83000000
    Working FDT set to 83000000
       Uncompressing Kernel Image
       Loading Ramdisk to 8ed2d000, end 8ffff148 ... OK
       Loading Device Tree to 000000008ed1b000, end 000000008ed2cad5 ... OK
    Working FDT set to 8ed1b000
    Starting kernel ...
    Q3. when i enabled  configs
    and rebuild all images , still it getting signature error......! attaching logs below
    => bdinfo
            chosen {
            firmware {
            timer-cl0-cpu0 {
            pmu {
            bus@f0000 {
            cpus {
            opp-table {
            l2-cache0 {
            aliases {
            memory@80000000 {
            reserved-memory {
            regulator-0 {
            regulator-1 {
            regulator-2 {
            regulator-3 {
            regulator-4 {
            leds {
            panel-lvds {
            binman {
            __symbols__ {
    => bootm 0x90000000
       Using 'conf-ti_k3-am625-xxx.dtb' configuration
    Bad Data Hash
    see the signature node difference in both logs , is it a build issue ?..
    warm regards
    -RJ
    Any updates , I'm also attaching a log iminfo log , you can see that hash value is unavailable
    ## Checking Image at 90000000 ...
       FIT image found
       FIT description: Kernel fitImage for xxxxxx/6.1.83+gitAUTOINC+c1c2f1971f/am62xx-xxx
        Image 0 (kernel-1)
         Type:         Kernel Image
         OS:           Linux
         Hash algo:    sha512
        Image 1 (fdt-ti_k3-am625-xxx.dtb)
         Hash algo:    sha512
        Image 2 (ramdisk-1)
         Description:  xxxxxxxx-image-dev
         Type:         RAMDisk Image
         OS:           Linux
         Hash algo:    sha512
        Default Configuration: 'conf-ti_k3-am625-xxx.dtb'
        Configuration 0 (conf-ti_k3-am625-xxx.dtb)
         Description:  1 Linux kernel, FDT blob, ramdisk
         Kernel:       kernel-1
         Init Ramdisk: ramdisk-1
         FDT:          fdt-ti_k3-am625-xxx.dtb
         Hash algo:    sha512
         Hash value:   unavailable
         Sign algo:    sha512,rsa4096:custMpk
         Sign padding: pkcs-1.5
         Sign value:   0c349e6ddddac43ae4ac431c994128664c2dcb08b5f6ff11204b3a0685921489cc7fa76ead4080344d7b2527070a6c66489106ce4a56e9e0f29331dab7a115ecd9b2661c75b409b4326cc4604ee2347188d9a92869bde4f92abf46e662950318
    ## Checking hash(es) for FIT Image at 90000000 ...
       Hash(es) for Image 0 (kernel-1): sha512+
       Hash(es) for Image 1 (fdt-ti_k3-am625-xxx.dtb): sha512+
       Hash(es) for Image 2 (ramdisk-1): sha512+
    And also attaching log.do_assemble_fitImage log , here you can see signature-1 node error its comes from uboot/tools/image-host.c line number 951, I'm scratching in dark why this happens ..?
    DEBUG: Executing python function extend_recipe_sysroot
    NOTE: Direct dependencies are [..........................]
    NOTE: Invalidating stamps for task do_deploy
    NOTE: Installed into sysroot: []
    NOTE: Skipping as already exists in sysroot: ['u-boot-ti-staging', 'binutils-cross-aarch64', 'gcc-cross-aarch64', 'quilt-native', 'ti-k3-secdev-native', 'u-boot-tools-native', 'openssl-native', 'bison-native', 'patch-native', 'pkgconfig-native', 'pseudo-native', 'bc-native', 'dtc-native', 'kmod-native', 'gmp-native', 'libmpc-native', 'python3-native', 'flex-native', 'trusted-firmware-a', 'ti-dm-fw', 'optee-os', 'ti-sci-fw', 'glibc', 'gcc-runtime', 'libtool-native', 'attr-native', 'zlib-native', 'gnu-config-native', 'texinfo-dummy-native', 'readline-native', 'xz-native', 'gettext-minimal-native', 'perl-native', 'mpfr-native', 'zstd-native', 'linux-libc-headers', 'sqlite3-native', 'bzip2-native', 'ncurses-native', 'libnsl2-native', 'gdbm-native', 'libffi-native', 'libtirpc-native', 'util-linux-libuuid-native', 'm4-native', 'opkg-utils', 'libgcc', 'make-native']
    DEBUG: Python function extend_recipe_sysroot finished
    DEBUG: Executing shell function do_assemble_fitimage
    gzip
    Created:         Mon May 13 20:19:51 2024
    Image 0 (kernel-1)
      Type:         Kernel Image
      Data Size:    8243836 Bytes = 8050.62 KiB = 7.86 MiB
      OS:           Linux
      Hash algo:    sha512
      Hash value:   90153f6b9e995d8d0e6364e4c169ca7266f21d96a8ba91676875db40883b25ecae731fdfc944891ca0dcfad65d35580ad4faabd3313e58a64f4d5eb7dcc619b7
      Data Size:    60118 Bytes = 58.71 KiB = 0.06 MiB
      Hash algo:    sha512
      Kernel:       kernel-1
      Hash algo:    sha512
      Sign algo:    sha512,rsa4096:dev
      Sign value:   unavailable
      Timestamp:    unavailable
    WARNING: debug ****************************************************************
    Failed to add verification data for 'signature-1' signature node in 'conf-ti_k3-am625-xxx.dtb' configuration node
    Image 0 (kernel-1)
      Type:         Kernel Image
      OS:           Linux
      Hash algo:    sha512
      Hash algo:    sha512
      Kernel:       kernel-1
      Hash algo:    sha512
      Sign value:   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
      Timestamp:    Mon May 13 20:19:51 2024
    DEBUG: Shell function do_assemble_fitimage finished
    warm regards
    -RJ
  • Hi RJ,
    have you tried using an absolute path for UBOOT_SIGN_KEYDIR and double checked it is valid? I've encountered this being a common issue in other build-type scenarios, that the system is actually not looking where you think it's looking when using relative paths. Or sometimes the build systems garble/mangle or otherwise incorrectly handle relative paths. Something worth checking I think.
    Regards, Andreas
    I'm already using an absolute path ,
    UBOOT_SIGN_KEYDIR = "/home/rj/avoided/avoided/meta-avoided/keys"
    UBOOT_MKIMAGE_DTCOPTS = "-I dts -O dtb -p 2000"
    i checked by , changing the path of UBOOT_SIGN_KEYDIR  to out workspace directory and , and logs shown an permission denied error . i think its not the issue any other ways to check ..
    meanwhile i found an other e2e thread of similar issue but I'm not able to crack the solution from it attaching link below,
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1275844/tmds64evm-issue-to-boot-fitimage-with-secure-boot-enabled
    BEST REGARDS,
    -RJ
    I also checked by  disabling  all that i done for signing FIT image ,
    line 109 shows the Failed to add verification data for 'signature-1' signature node   error in by using default custMpk .
    FIT signing is default enabled right ?
    attaching log log.do_assemble_fitimage_initramfs
    DEBUG: Executing shell function do_assemble_fitimage_initramfs
    gzip
    NOTE: Did not find initramfs image: /home/
    NOTE: Found initramfs image: /home/
    FIT description: Kernel fitImage for AAAAAAAA/6.1.105+gitAUTOINC+92ce8d7d2a/am62xx-XXX
    Created:         Tue Oct  8 22:45:21 2024
    Image 0 (kernel-1)
      Type:         Kernel Image
      Data Size:    8240981 Bytes = 8047.83 KiB = 7.86 MiB
      OS:           Linux
      Hash algo:    sha512
      Hash value:   0d9d4d380c51a7770f74d630dff8e86668f756a4b1eb4f564581805eb5528d8f53aeb39b848142a046b5f8ac243b3342fc6002ef93e9c390ac888a5616c15f7f
    Image 1 (fdt-ti_k3-am625-XXX.dtb)
      Data Size:    60266 Bytes = 58.85 KiB = 0.06 MiB
      Hash algo:    sha512
      Hash value:   fca9782226539c2c200a8d6d14d4f69ceac227d030a0c4109117f0b4061bdd87d26703893891da83f499d79a1527bb4843375ba6382a12f74123582a093f4ac8
    Image 2 (ramdisk-1)
      Description:  AAAAAAAA-image-dev
      Type:         RAMDisk Image
      Data Size:    20019024 Bytes = 19549.83 KiB = 19.09 MiB
      OS:           Linux
      Hash algo:    sha512
      Hash value:   431fb5b55bd08e14353ac4120d0342743eea8f64fbc5f74b2215fc635e011da95e506d8c3cf56d0a446eb7fd7a86e4faedbc5e941480c9a20ffb5974cb8c4537
    Default Configuration: 'conf-ti_k3-am625-XXX.dtb'
    Configuration 0 (conf-ti_k3-am625-XXX.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-XXX.dtb
      Hash algo:    sha512
    Failed to add verification data for 'signature-1' signature node in 'conf-ti_k3-am625-XX.dtb' configuration node
    DEBUG: Shell function do_assemble_fitimage_initramfs finished
    BEST REGARDS,
    -RJ
  • Hi RJ,
    for testing purposes, can you try editing/overwriting the default settings directly where they are defined here:
    meta-ti/meta-ti-bsp/conf/machine/include/k3.inc
    UBOOT_SIGN_KEYNAME ?= "custMpk"
    UBOOT_SIGN_KEYDIR ?= "${TI_SECURE_DEV_PKG}/keys"
    Or is this where you made those changes?
    Regards, Andreas
    edited the below line in meta-ti/meta-ti-bsp/conf/machine/include/k3.inc
    # UBOOT_SIGN_KEYNAME ?= "custMpk"
    # UBOOT_SIGN_KEYDIR ?= "${TI_SECURE_DEV_PKG}/keys"
    UBOOT_SIGN_KEYDIR  = "/home/rj/avoided/avoided/avoided/avoided/avoided/meta-avoided/keys"
    still same error in log.do_assemble_fitimage_initramfs
    before edited in my conf file where k3.inc is included .
    can you also check this
    regards,
    RJ
  • RJ,
    I'll ask our security-expert to give this another look here. If he can perhaps point to specifically what might be missing then I can help fix this in Yocto, but I'm not sure myself what to make out of these error messages or what specifically goes wrong here without spending a good amount of time digging through how all this signing process works.
    Also perhaps what you can do is clone the "TI Secure Dev Package" that's used for singing for regular HS-FS devices manually (https://git.ti.com/cgit/security-development-tools/core-secdev-k3) and then get the keys from there and point your Yocto config to those keys to see if the general process works? This might help decide whether there's an issue with your setup / paths etc., or perhaps the key(?) you generated?
    Andreas
  • Hi Andreas Dannenberg ,
    Thanks for the input !
    Any help is appreciated, this is starting to drive me nuts.
    And also Can you point out where the  (file path/name ) signature node is  generated by the kernel recipe .
    Thanks and Regards,
    -RJ
  • When building the kernel fitImage from Yocto, have we checked all steps as listed in the SDK link are all executed? especially "3.2.1.6.3. Build uboot again"
    https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/10_00_07_04/exports/docs/linux/Foundational_Components_Kernel_Users_Guide.html#creating-the-kernel-fitimage-for-high-security-device-gp-devices
    -Hong
    I was able to remove the one of the error , but ran into other
       Verifying Hash Integrity ... sha512,rsa4096:dev-  error!
    Verification failed for '<NULL>' hash node in 'conf-ti_k3-am625-xxx.dtb' config node
    Failed to verify required signature 'key-dev'
    Bad Data Hash
    also attaching  log.do_assemble_fitimage_initramfs , here in you can see hash value
      Kernel:       kernel-1
      Hash algo:    sha512
      Sign value:   18de4161f63429c9dc32cd74******************
    -RJ
  • I'd highly recommend testing Linux SDK package first as reference.
    Once you install the Linux SDK, run "make linux" would carry out all steps as described in the link on generating kernel fitImage
    -Hong
  • Hi @  ,
    Thanks for the input,  downloaded the linux sdk and tried running "make linux " same kind of error also occurred , with out doing nothing to sign fitimage in SDK,
    SDK version - sdk-linux-am62xx-evm-09.02.01.10
    attaching sdk build log,
    :~/ti-processor-sdk-linux-am62xx-evm-09.02.01.10$ make linux
    Building the Linux Kernel DTBs
    # Build FitImage
    cd /home/rj/ti-processor-sdk-linux-am62xx-evm-09.02.01.10/board-support/ti-linux-kernel* ; cp arch/arm64/boot/Image.gz ./linux.bin ; cd ..
    cp /home/rj/ti-processor-sdk-linux-am62xx-evm-09.02.01.10/board-support/prebuilt-images/am62xx-evm/fitImage-its-am62xx-evm /home/rj/ti-processor-sdk-linux-am62xx-evm-09.02.01.10/board-support/ti-linux-kernel*
    mkimage -r -f /home/rj/ti-processor-sdk-linux-am62xx-evm-09.02.01.10/board-support/ti-linux-kernel*/fitImage-its-am62xx-evm -k /home/rj/ti-processor-sdk-linux-am62xx-evm-09.02.01.10/board-support/ti-u-boot*/board/ti/keys -K /home/rj/ti-processor-sdk-linux-am62xx-evm-09.02.01.10/board-support/u-boot-build/a53/arch/arm/dts/k3-am625-sk.dtb /home/roopak/ti-processor-sdk-linux-am62xx-evm-09.02.01.10/board-support/built-images/fitImage
    Can't set hash 'value' property for 'hash-1' node(FDT_ERR_NOSPACE)
    Can't set hash value for 'hash-1' hash node in 'fdt-ti_k3-am625-sk-microtips-mf103hie-lcd2.dtbo' image node
    Invalid key name '/home/rj/keys': contains '/'
    Failed to sign 'signature-1' signature node in 'conf-ti_k3-am625-sk.dtb' conf node
    mkimage Can't add hashes to FIT blob: -1
    make: *** [makerules/Makefile_linux:13: linux] Error 255
    -RJ
  • I'm attaching the build log from running "make linux" with AM62x SDK 10.0.7.4 for your reference.
    The kernel fitImage was created even though some build error in the log, and the kernel fitImage booted ok on HS-SE.
    -Hong
    # Build FitImage
    cd /home/jason/am6/am62_10.0.7.4/board-support/ti-linux-kernel* ; cp arch/arm64/boot/Image.gz ./linux.bin ; cd ..
    cp /home/jason/am6/am62_10.0.7.4/board-support/prebuilt-images/am62xx-evm/fitImage-its-am62xx-evm /home/jason/am6/am62_10.0.7.4/board-support/ti-linux-kernel*
    mkimage -r -f /home/jason/am6/am62_10.0.7.4/board-support/ti-linux-kernel*/fitImage-its-am62xx-evm -k /home/jason/am6/am62_10.0.7.4/board-support/ti-u-boot*/arch/arm/mach-k3/keys -K /home/jason/am6/am62_10.0.7.4/board-support/u-boot-build/a53/arch/arm/dts/k3-am625-sk.dtb /home/jason/am6/am62_10.0.7.4/board-support/built-images/fitImage
    Can't set hash value for 'hash-1' hash node in 'fdt-ti_k3-am625-sk-pwm.dtbo' image node
    FIT description: Kernel fitImage for Arago/6.6.32+git/am62xx-evm
    Created:         Tue Dec 17 22:27:31 2024
     Image 0 (kernel-1)
      Type:         Kernel Image
      Data Size:    8489259 Bytes = 8290.29 KiB = 8.10 MiB
      OS:           Linux
      Hash algo:    sha512
      Hash value:   f811501b00cc11541092984defe9d675c721d9d59e43e02b8068ee00944b1480fc9ac19c50fc655a7d59cb0b893e334fb8b94a9c8ab045db44e50b4876ef200b
     Image 1 (fdt-ti_k3-am625-verdin-wifi-dev.dtb)
      Data Size:    70985 Bytes = 69.32 KiB = 0.07 MiB
      Hash algo:    sha512
      Hash value:   9aa0d6fa399c2b4d27fe73afbce809a26573304a8cfb64927d7d9fa6772243e378f167c9340df3e042901d45d1f5a8f1e97caef69ff8d2c6ca2e14448db15841
     Image 2 (fdt-ti_k3-am625-verdin-nonwifi-dahlia.dtb)
      Data Size:    70281 Bytes = 68.63 KiB = 0.07 MiB
      Hash algo:    sha512
      Hash value:   a0c66c1eef1219cbb6b0bd74667c80732777c8e37cc84109dcfc1e39c640783a4e17eb55b5be384098be4085995f9799592ab6b4e8f94b02590072e02c9fd687
     Image 3 (fdt-ti_k3-am625-beagleplay.dtb)
      Data Size:    61975 Bytes = 60.52 KiB = 0.06 MiB
      Hash algo:    sha512
      Hash value:   2c8c61863e3d081e6b16507cab8a360fba316fae15b0122e5bd0f505ff554a10cd0fea6f9487d95ccfab62d25d6473d4279a890bb75ddd08c91aaef3d8ddcabd
     Image 4 (fdt-ti_k3-am625-verdin-nonwifi-yavia.dtb)
      Data Size:    69666 Bytes = 68.03 KiB = 0.07 MiB
      Hash algo:    sha512
      Hash value:   40afac47eab9f513371755324b1965795fb66405a0a0d2ee5933eca2434195066242615b814a36272822840567f0236ecb4a879583d615a94955e5517a46c28c
     Image 5 (fdt-ti_k3-am625-verdin-wifi-mallow.dtb)
      Data Size:    69885 Bytes = 68.25 KiB = 0.07 MiB
      Hash algo:    sha512
      Hash value:   6f6f0431f2440b20462e71fde2139d17df915b8648264d3b5a52ff9b05177f0e8301597caa42e1e4606df42abc31a400c7dda1ba0738cc7fb63035057f58dfbd
     Image 6 (fdt-ti_k3-am625-verdin-nonwifi-dev.dtb)
      Data Size:    70543 Bytes = 68.89 KiB = 0.07 MiB
      Hash algo:    sha512
      Hash value:   d455beb1a6d812214a6824f689318d5f8527f6eae6d75f4575b4a037ce43572a7fec79bebf055826af4025b8d3839e1ed807bbbe92dc5d68c3db2e681720fb81
     Image 7 (fdt-ti_k3-am625-verdin-wifi-yavia.dtb)
      Data Size:    70112 Bytes = 68.47 KiB = 0.07 MiB
      Hash algo:    sha512
      Hash value:   91e5d8a318e9263b10fee0e9da3cfb95c31772f56d78ddd961d5e504b13b4f225e51a6a5709c91b127b5724a85e16bddc5574f5b361853dd868668fa97298cd9
     Image 8 (fdt-ti_k3-am625-verdin-nonwifi-mallow.dtb)
      Data Size:    69439 Bytes = 67.81 KiB = 0.07 MiB
      Hash algo:    sha512
      Hash value:   4297e43c798ff4c80970132a2d8b1a2113a3c79f06a2922fb3447c4ff035603f0eeabe1b9851cace5e364e7f8c38e29ee727e91b81409ff6ea1e79ba213063ff
     Image 9 (fdt-ti_k3-am625-verdin-wifi-dahlia.dtb)
      Data Size:    70727 Bytes = 69.07 KiB = 0.07 MiB
      Hash algo:    sha512
      Hash value:   424f9591c7ed79a27219326267ff59dc33482351e1316b6b60f8bffd970a6887cc872d5503d167d0edee78662d38f121a33bacfd258b4e5550642191e6f24a4d
     Image 10 (fdt-ti_k3-am625-sk.dtb)
      Data Size:    60191 Bytes = 58.78 KiB = 0.06 MiB
      Hash algo:    sha512
      Hash value:   fca01e6ac0fa8f97172ae142490dd7342b2b7fdf42a573a41ec5932d5158b33c84ed9f894b49b8bdbc128121c482310a0c14e974015acc1f223f4abf92f0b48c
     Image 11 (fdt-ti_k3-am625-phyboard-lyra-rdk.dtb)
      Data Size:    57041 Bytes = 55.70 KiB = 0.05 MiB
      Hash algo:    sha512
      Hash value:   a7bce17b52240190e1171bcf3d833ea3ad254226695dc02552b0f9b49e7385fd7bca76461cd333eac886d8cfa8ae3beb727a9ef273461ec88a906f7e5d0c0d1d
     Image 12 (fdt-ti_k3-am625-sk-rpi-hdr-ehrpwm.dtbo)
      Data Size:    2360 Bytes = 2.30 KiB = 0.00 MiB
      Load Address: 0x83080000
      Hash algo:    sha512
      Hash value:   2f39134aae200909bd647500d126aaf215472c07102d77f79f78439fa77a6876d596f8433893ebf9e4d420a2d6c938aa93db3b9a51d41f22fc1a41ea5238a9e6
     Image 13 (fdt-ti_k3-am625-sk-pwm.dtbo)
      Data Size:    1652 Bytes = 1.61 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   be5eb9122a68fb6de65a2315588f0b4b1171cd989966a3b287b6b9e1a3883a635cb08cb4dfa1c84e7ea463bf2c060352582203fe1091d32a4791d32c56f00d1b
     Image 14 (fdt-ti_k3-am625-beagleplay-lincolntech-lcd185-panel.dtbo)
      Data Size:    4528 Bytes = 4.42 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   b97d1a41347e25ef621aef821e7fbfb6e8b5a03733feb0f862aa6d805f2452dec5d46d5ec1fa15b6e8281309e13c4f0c1480eee82b5df885c38f332c3030a0b3
     Image 15 (fdt-ti_k3-am625-sk-lincolntech-lcd185-panel.dtbo)
      Data Size:    3622 Bytes = 3.54 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   ee2225d4e3d9447da499ed97c0cd5f409962b2e26178ef3afe23bd0690e3fd16207b67fea6cc5662adda5c4e4000c236b26c6cc12b2c06122dc4d674d8d2b0a6
     Image 16 (fdt-ti_k3-am625-beagleplay-csi2-ov5640.dtbo)
      Data Size:    2195 Bytes = 2.14 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   b9c2704b166fde2134b4cde4e641e43d28c0f53eaf80309c283f6162df8611a258f512409fee513f710bf7f423b2040c8202f99b952de3b25af3b5028f1b2f01
     Image 17 (fdt-ti_k3-am625-sk-microtips-mf101hie-panel.dtbo)
      Data Size:    3402 Bytes = 3.32 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   830b9a754e3f283d8741e71b40ff476c5b0cf14d0f36b729522b53aa57eaa3645b8c91f65a2c77b52461894e52fa0cb688c9e37f12e7f241d11ed5446fcce0f5
     Image 18 (fdt-ti_k3-am625-beagleplay-csi2-tevi-ov5640.dtbo)
      Hash algo:    sha512
      Hash value:   21d2d909d9f81afb1151422c6d15ac43df9411802a38b8b80380cc2f3f9d1441e0c723b8a047c67361c36be16f001f54dd576738bb830ba3a0576f45273b3ffb
     Image 19 (fdt-ti_k3-am625-sk-mcspi-loopback.dtbo)
      Data Size:    1116 Bytes = 1.09 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   8da891b3678549af4ed13f3581cafc0e3568c99ffcdf980d0733755c15a93b8377607ca7e8b106b643b2e844ed4f520ca9f42100e08f5175a5584c8e63d3d900
     Image 20 (fdt-ti_k3-am625-sk-m2-cc3301.dtbo)
      Data Size:    2650 Bytes = 2.59 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   43dd9a5a39d3f49aed466ace8682900d28c7c615d3ecba010521a6951d930f813392a51cbda41887dcc55a887836b648f4781395ac9a940af84a1e887e349deb
     Image 21 (fdt-ti_k3-am625-sk-ecap-capture.dtbo)
      Data Size:    872 Bytes = 0.85 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   f67978246b46b80c7b3dc2919d70f1d1688e36e68e6cfe69a50641fd9f30333c5a513288cfad3b255bf6cb5ab8dead394b19f90b78acaf268ba99334f7796bc2
     Image 22 (fdt-ti_k3-am625-sk-dmtimer-pwm.dtbo)
      Data Size:    2299 Bytes = 2.25 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   a1a759ad703dc74aa84e26952234a1d42ef2bff17803d884656248f0731ecc21c3a6f08d3205f0e350941bf9c851cc3e2e73b737e911a19cd4201143dff0b5d9
     Image 23 (fdt-ti_k3-am62x-sk-lpm-wkup-sources.dtbo)
      Data Size:    4232 Bytes = 4.13 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   e85f4c7cd3e49fcf7602fa037cfed60831c561fd756e72f03badc2a2c290a1a69cfb04dd413982add652dbb73ca968081b18a7e4c7888001ed7bdfe319baabe1
     Image 24 (fdt-ti_k3-am62x-sk-microtips-mf103hie-lcd2.dtbo)
      Data Size:    3059 Bytes = 2.99 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   9daabfe4590a4a7c343e1597616c677fd419076116b66aedd544cbac009a1caf4e070784153496ea3b88b32fe2e5fec910077077046ebadb672d00b1cf8b4781
     Image 25 (fdt-ti_k3-am62x-sk-csi2-tevi-ov5640.dtbo)
      Data Size:    2332 Bytes = 2.28 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   6f7634f07a06b415e2d55a9dddc3c6e547ee37fa56b3c087a30684ab6da40bdff70730a0cffeee55468b679fce2b9b664a73b49786f3636393c16d8a563badcf
     Image 26 (fdt-ti_k3-am62x-sk-fastboot-disable-hdmi.dtbo)
      Data Size:    478 Bytes = 0.47 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   0f29c1aa157fb46e9be8e60d90aa4ff1351402f8ff8ad11adb4f3c999728611faad214e819247f363cb1c19acea1dbb71c921b7b5fb1148c9b7292c4b0378142
     Image 27 (fdt-ti_k3-am62x-sk-eqep.dtbo)
      Data Size:    1063 Bytes = 1.04 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   430685944eb95c206db7ff20213855b9fb73304ed04c35471c9cf79ef4b5e00e62e0b48150f8c630ffd62dc605c0aad8c7e8c2691f14fff86c6e076af792702c
     Image 28 (fdt-ti_k3-am62x-sk-mcan.dtbo)
      Data Size:    2192 Bytes = 2.14 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   e90dec3663e0ef78cdd3c6b5bc0638d439822f378d9049e4c216f9cceb3cb329cdc26e05eabfebca12d85d3cdc582c5ec5508abc38e7b1596b02ea6610571405
     Image 29 (fdt-ti_k3-am62x-sk-csi2-imx219.dtbo)
      Data Size:    2361 Bytes = 2.31 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   be600fab56804dc0d5b2a920e49d3ca63dd0a5e64c9b7659d1f03db42619d255d474c2d79d082a43cbd7ed931357555312cf7f6fcd01277815c6cf02089b15c6
     Image 30 (fdt-ti_k3-am62x-sk-csi2-v3link-fusion.dtbo)
      Data Size:    2577 Bytes = 2.52 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   0ccd475ad94abbe6384d46fc93621f32806f46245a023100605026ed41df571e3f57bb3865a496ac14745493922534439ff7b1f914f6f87242ac8a1cfc1fd10d
     Image 31 (fdt-ti_k3-am62x-sk-hdmi-audio.dtbo)
      Data Size:    1345 Bytes = 1.31 KiB = 0.00 MiB
      Hash algo:    sha512
      Hash value:   924bd5ccccd9c096181803a1e8e8c126e9b4e866ca3572375abf5ffabb657b2340520630ddc0ffdf41a7a4efa216428f57cb0035c8a634bb9ba944784243e1de
     Image 32 (fdt-ti_k3-am62x-sk-csi2-ov5640.dtbo)
      Hash algo:    sha512
      Hash value:   dcf599a5d4aaae0d489d112836987c9fe47ad6dad243e27413ae860038cbbe49cffd461ff5b387c66721b950af8c9d506e1e2f0867177fa1d92591c246ea3f3a
     Default Configuration: 'conf-ti_k3-am625-verdin-wifi-dev.dtb'
     Configuration 0 (conf-ti_k3-am625-verdin-wifi-dev.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-verdin-wifi-dev.dtb
      Hash algo:    sha512
      Sign value:   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
      Timestamp:    Tue Dec 17 22:27:31 2024
     Configuration 1 (conf-ti_k3-am625-verdin-nonwifi-dahlia.dtb)
      Description:  0 Linux kernel, FDT blob
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-verdin-nonwifi-dahlia.dtb
      Hash algo:    sha512
      Sign value:   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
     Configuration 2 (conf-ti_k3-am625-beagleplay.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-beagleplay.dtb
      Hash algo:    sha512
      Sign value:   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
     Configuration 3 (conf-ti_k3-am625-verdin-nonwifi-yavia.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-verdin-nonwifi-yavia.dtb
      Hash algo:    sha512
      Sign value:   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
     Configuration 4 (conf-ti_k3-am625-verdin-wifi-mallow.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-verdin-wifi-mallow.dtb
      Hash algo:    sha512
      Sign value:   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
     Configuration 5 (conf-ti_k3-am625-verdin-nonwifi-dev.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-verdin-nonwifi-dev.dtb
      Hash algo:    sha512
      Sign value:   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
     Configuration 6 (conf-ti_k3-am625-verdin-wifi-yavia.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-verdin-wifi-yavia.dtb
      Hash algo:    sha512
      Sign value:   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
     Configuration 7 (conf-ti_k3-am625-verdin-nonwifi-mallow.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-verdin-nonwifi-mallow.dtb
      Hash algo:    sha512
      Sign value:   69c03569bce7df6b34265818fe9a2e63401e1fd6a0e48effcd6b70c6957f8caee084ff778814995207a2ddaffd19b08afb5d461885dda44f65d522989240a766c33a9b3cf1a129186f4fc9063dab83a6cc7990cabf16a1d6bdd24c7806e37b3461a784d9b7d52fe515edb742dc671e927cfc045a1356b3860a4f7ef4f2479d2948929cc40446ceb62c8bb24c0ec364a1746b4c0b8272e5ab60a4ffd3de005badd00959555596d25414051f9ffe061e9186cb4cf1bfa6cb56394f1e656f2a9c4d72622607eb552c3e98a82a0b5ec49080d7108858868256c1ec510d144b74009b87eaf3639bad78c1e9a6877bff8bc26e36891378212da64c3ba7918be80ccdaee2fc8ab48156b3d35493be73b47addd66b71ecc69b12256b88702a0a775720ec30f4cc6e4b0a004c07519c4f3b605856456cab81250cb7b0e5e4044a2a8b36f169a7afdad982037751c4cdeb984f9f399853a1e9c08d45f49d20ab4e39135dcbeeb91cba40768031b82d4cc6b5323506547cb9267b3cd021fde620649b6eff408d98950123df67848e39e1e0e6ec0b6fd48acd4b4eec387592a7f9776b1595ae2291c3f029bab64f9db24be9b1d3cca85d24af7d170ea9be1e2d696845693859d3fa4fca6f597f8337f0117589e47cc677abac04d402791176c1cc5ab996c08adfff5fcf8333cca1dad886789a74b3b50a2bd7161eda685127009076dc588010
     Configuration 8 (conf-ti_k3-am625-verdin-wifi-dahlia.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-verdin-wifi-dahlia.dtb
      Hash algo:    sha512
      Sign value:   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
     Configuration 9 (conf-ti_k3-am625-sk.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-sk.dtb
      Hash algo:    sha512
      Sign value:   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
     Configuration 10 (conf-ti_k3-am625-phyboard-lyra-rdk.dtb)
      Kernel:       kernel-1
      FDT:          fdt-ti_k3-am625-phyboard-lyra-rdk.dtb
      Hash algo:    sha512
      Sign value:   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
     Configuration 11 (conf-ti_k3-am625-sk-rpi-hdr-ehrpwm.dtbo)
      Description:  0 FDT blob
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-sk-rpi-hdr-ehrpwm.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 12 (conf-ti_k3-am625-sk-pwm.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-sk-pwm.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 13 (conf-ti_k3-am625-beagleplay-lincolntech-lcd185-panel.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-beagleplay-lincolntech-lcd185-panel.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 14 (conf-ti_k3-am625-sk-lincolntech-lcd185-panel.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-sk-lincolntech-lcd185-panel.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 15 (conf-ti_k3-am625-beagleplay-csi2-ov5640.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-beagleplay-csi2-ov5640.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 16 (conf-ti_k3-am625-sk-microtips-mf101hie-panel.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-sk-microtips-mf101hie-panel.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 17 (conf-ti_k3-am625-beagleplay-csi2-tevi-ov5640.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-beagleplay-csi2-tevi-ov5640.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 18 (conf-ti_k3-am625-sk-mcspi-loopback.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-sk-mcspi-loopback.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 19 (conf-ti_k3-am625-sk-m2-cc3301.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-sk-m2-cc3301.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 20 (conf-ti_k3-am625-sk-ecap-capture.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-sk-ecap-capture.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 21 (conf-ti_k3-am625-sk-dmtimer-pwm.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am625-sk-dmtimer-pwm.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 22 (conf-ti_k3-am62x-sk-lpm-wkup-sources.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-lpm-wkup-sources.dtbo
      Hash algo:    sha512
      Sign value:   aa5e8d369702e333d41c2c0d01eb160c0dbc35439831fb8ba1360009dec071f89437b0a31b8e6dd3a6994ac851504f18be1369be99473eba9cda5eadda9275e806745de8ae87dd57deebe68c7375fea945d2f11c4db1ceb7a473c1cae82828d4f76279b51c3192232485b83b8e7cef718502bcbce444486007f6de4e4a6bd553e1b7979762e1d0173a2fa767ad5c96126d44b9bc491fe46bc1f70023d2c8b5779cf5c13b9b99c841a13ff10c0636c7170e7ebe7860d7f37534c111a9bd996fcdd30b4ced19ae934ba8884b528b04c30a538d9cdaeffd04ac779f7d61e3c93c8a72a8efce4efa60c441c358776fa78d94a5c0138fe704f9f365c173b29233a4c940182944ec8046f8e384f8c9c27659abc03f2949f8864aa5c5c42b0def05ca2fdce6801eaf626ef15033b08b61b9f2f9b784a3cb4e187f6ffd5bcbda2989eb93a444bc8921b37184c8ed1d2f3a4bbbab72e245e9ecc520736886b3dfac5a7f0b9ea46891cd90b2df5ddf4342d3cd32d1cde281da3c9763eaccb46f103d575c4debb7d01016215ff7bc1797d29fa53800663e60096854b6a43973bd632d186c80053269ac9dc249bd86c874babf82e3864829aa637f937fe3a77581ebef5e81e2c299b432997b631090a0432db0e38e9ee3e5d4c239fe4bfc9367587cc3123315297288cf536683d472496e0d2049a3b19b11bdbaa24abe72e952f199975c635a
     Configuration 23 (conf-ti_k3-am62x-sk-microtips-mf103hie-lcd2.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-microtips-mf103hie-lcd2.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 24 (conf-ti_k3-am62x-sk-csi2-tevi-ov5640.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-csi2-tevi-ov5640.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 25 (conf-ti_k3-am62x-sk-fastboot-disable-hdmi.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-fastboot-disable-hdmi.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 26 (conf-ti_k3-am62x-sk-eqep.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-eqep.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 27 (conf-ti_k3-am62x-sk-mcan.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-mcan.dtbo
      Hash algo:    sha512
      Sign value:   3fdfd324ed1dc4c2ad9b1cc75b1f9b83aaeb9964de34f6c26d92f6310485046c5458981d3cfc091ec089be80c229d5e6120d3700320043a0e494374b6d21e2c0122210d8c0a8374c0f5c1824961ea99407b6c2918b9cafa4740eaa6731f01594dae88e0bccceb104f1d4f3565f8c7427c1bef1bdf6de8232ce1906fcf9fc02d5f7e5a937092aceabbe8e36569228dcd199181c4928e8c2d97747ccf0f6d3ee0486140d2bc322b8043cb8c1c7a8170e9fd354caef564b6eb53b8ae7aeb31aea33a5df2b0beaff3730c546ac15cdb3d26cf91034a381b614ff2fe027763cdb545e6804774805fafcaf5b4d8d80a0a924ad74839e5bb34269cab975e5cc1d7487c9271d00701628039484cc17609971b27644070dac2989ee0555caf1ace3bb3de7143b7870a3f7785937d9404a60a797b4de9e43bc7f435ac3d0cb8100517946a803a2a33cd502f45d04d740a851be9fbaa6763d0b865ec032b3ee12022dc833d4198584afc003e92c98bad0215408cb7c6372c28dfae31eb20b7d1f56066b699f03da33090abe02e6a187ef13e1b169305c6f981e5e449252761c8c2c35f8f0546480c54478b9b40f03839f27752c4fb33104cea7284f920811a9cecb8cbb6d10f25c12ddf51cb517e7d4a6f3dcdcc1c6102b2887b0b133d8b2fe991aba098cb12bfce185146f2b53fd5940ba354c6004b9ae2740d8d5bedfa79bbf4c154883a3
     Configuration 28 (conf-ti_k3-am62x-sk-csi2-imx219.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-csi2-imx219.dtbo
      Hash algo:    sha512
      Sign value:   23d61dd79f27d3f8ea5335cc5967a4da063798e0e2cb2b7cd1fa898a60dfeb55dad1ba0201caef72ed116aa90c7e987602a4a992b139d2b3680c882600ec7ab35f84b5a01f9b548df29ea40a2f02ac22e286e9c457eb0120b96950c3ba2b553cfe89d536dd5079c993fc18c24720b9ae607f8daa611607ea9e6a9bc08d186fe1bb7ac7537e072d5bfd71266a0b5299ee0eea445f9d2afe36d860351434e565e485768f0f5951fd5967cdb8b83db22d479423ccbe39c36821d557a7c65f9ac93dfbff4e20b2208d5c48d792c3ca3f4e8e2652454d5ae6b8c5c32fc6f9ae421f3ab295c60aeda2ca423b1ea3382a82e614e8ada30c8bc2882400634058224ccbf754c97e9322ad115c72f85cb89e90296e78321073564f053f18fbbd5c01fd214a6b1537d6ab37f1351645299c8ad3434d8e302d7e814c223d2cc4b961bef35eace5006880cc4803ca816af2628b3af57f7f1b1df4ee9cacf30d587a9991853e9d8128a9d703c543d61eea4a9f10d8adbf4021fa024b950e8b55296ff1bc93da189f2e18b629fecea3ef3d74f2527d971e3d5a592fb83996f6805c61ff501480d9c5273678b745c2ba45f6423b267748df300135f4324d660f86dd72801f7293a6898807fa2265fab184c99e13c5f1283917711c856425f4a7372e6aff7c00c9b8e31263dcfda6b76a5944412ec759c07eec23d6d90dc0149b99a694ff14e0fe18
     Configuration 29 (conf-ti_k3-am62x-sk-csi2-v3link-fusion.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-csi2-v3link-fusion.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 30 (conf-ti_k3-am62x-sk-hdmi-audio.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-hdmi-audio.dtbo
      Hash algo:    sha512
      Sign value:   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
     Configuration 31 (conf-ti_k3-am62x-sk-csi2-ov5640.dtbo)
      Kernel:       unavailable
      FDT:          fdt-ti_k3-am62x-sk-csi2-ov5640.dtbo
      Hash algo:    sha512
      Sign value:   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
    # Rebuild uboot a53 for FitImage
    make -j 8 -C /home/jason/am6/am62_10.0.7.4/board-support/ti-u-boot* ARCH=arm CROSS_COMPILE=/home/jason/am6/am62_10.0.7.4/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux- CC="/home/jason/am6/am62_10.0.7.4/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-gcc --sysroot=/home/jason/am6/am62_10.0.7.4/linux-devkit/sysroots/aarch64-oe-linux" \
        BINMAN_INDIRS=/home/jason/am6/am62_10.0.7.4/board-support/prebuilt-images/am62xx-evm BL31=/home/jason/am6/am62_10.0.7.4/board-support/prebuilt-images/am62xx-evm/bl31.bin TEE=/home/jason/am6/am62_10.0.7.4/board-support/prebuilt-images/am62xx-evm/bl32.bin O=/home/jason/am6/am62_10.0.7.4/board-support/u-boot-build/a53
    make[1]: Entering directory '/home/jason/am6/am62_10.0.7.4/board-support/ti-u-boot-2024.04+git'
    make[2]: Entering directory '/home/jason/am6/am62_10.0.7.4/board-support/u-boot-build/a53'
      GEN     Makefile
      UPD     include/generated/timestamp_autogenerated.h
      Using /home/jason/am6/am62_10.0.7.4/board-support/ti-u-boot-2024.04+git as source for U-Boot
      CC      common/version.o
      AR      common/built-in.o
      LD      u-boot
      OBJCOPY u-boot.srec
      OBJCOPY u-boot-nodtb.bin
      SYM     u-boot.sym
      SHIPPED dts/dt.dtb
      RELOC   u-boot-nodtb.bin
      MKIMAGE fit-dtb.blob
      COPY    u-boot.dtb
      CAT     u-boot-fit-dtb.bin
      MKIMAGE u-boot.img
      MKIMAGE u-boot-dtb.img
      COPY    u-boot.bin
      FDTGREP spl/dts/k3-am625-sk.dtb
      MKIMAGE spl/u-boot-spl.multidtb.fit
      CC      spl/common/spl/spl.o
      AR      spl/common/spl/built-in.o
      LD      spl/u-boot-spl
      OBJCOPY spl/u-boot-spl-nodtb.bin
      SYM     spl/u-boot-spl.sym
      CAT     spl/u-boot-spl-dtb.bin
      COPY    spl/u-boot-spl.bin
      BINMAN  .binman_stamp
      OFCHK   .config
    make[2]: Leaving directory '/home/jason/am6/am62_10.0.7.4/board-support/u-boot-build/a53'
    make[1]: Leaving directory '/home/jason/am6/am62_10.0.7.4/board-support/ti-u-boot-2024.04+git'
  • Hi Hong ,
    Downloaded the AM62x SDK 10.0.7.4 , attaching the build log from running "make linux" still the error , And  ti/keys path is missing in my latest sdk , why?
    # Build FitImage
    cd /home/user1/ti-processor-sdk-linux-am62xx-evm-10.00.07.04/board-support/ti-linux-kernel* ; cp arch/arm64/boot/Image.gz ./linux.bin ; cd ..
    cp /home/user1/ti-processor-sdk-linux-am62xx-evm-10.00.07.04/board-support/prebuilt-images/am62xx-evm/fitImage-its-am62xx-evm /home/user1/ti-processor-sdk-linux-am62xx-evm-10.00.07.04/board-support/ti-linux-kernel*
    mkimage -r -f /home/user1/ti-processor-sdk-linux-am62xx-evm-10.00.07.04/board-support/ti-linux-kernel*/fitImage-its-am62xx-evm -k /home/user1/ti-processor-sdk-linux-am62xx-evm-10.00.07.04/board-support/ti-u-boot*/board/ti/keys -K /home/user1/ti-processor-sdk-linux-am62xx-evm-10.00.07.04/board-support/u-boot-build/a53/arch/arm/dts/k3-am625-sk.dtb /home/user1/ti-processor-sdk-linux-am62xx-evm-10.00.07.04/board-support/built-images/fitImage
    Couldn't open RSA private key: '/home/user1/ti-processor-sdk-linux-am62xx-evm-10.00.07.04/board-support/ti-u-boot*/board/ti/keys/custMpk.key': No such file or directory
    Created:         Fri Dec 20 14:42:10 2024
    Image 0 (kernel-1)
      Description:  Linux kernel
      Type:         Kernel Image
  • There was a change on the key folder location starting from SDK 10.x
    https://git.ti.com/cgit/ti-u-boot/ti-u-boot/commit/arch/arm/dts/k3-binman.dtsi?h=10.00.07&id=110b07c8bcb611ddf5b6bed44f5eb9ac14ebecec
    I forgot to mention that I made one change as below in makerules/Makefile_linux when I ran "make linux" with SDK 10.0.7.4 in my last reply
    - -k $(UBOOT_SRC_DIR)/board/ti/keys
    + -k $(UBOOT_SRC_DIR)/arch/arm/mach-k3/keys
    -Hong
