PROCESSOR-SDK-AM62X: Invalid engine "devcrypto"
Part Number: PROCESSOR-SDK-AM62X
We have the same problem like
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1305761/processor-sdk-am62x-cryptodev-hardware-accelerator-does-not-take-effect?keyMatch=cryptodev&tisearch=universal_search
We used
https://software-dl.ti.com/processor-sdk-linux/esd/AM335X/09_01_00_001/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/Crypto.html
to solve this.
No success. How to resolve. Using no SDK, using Yocto Kirkstone
root@beagtae:~# openssl speed -evp aes-128-cbc -engine devcrypto
2030F7B6:error:12800067:DSO support routines:dlfcn_load:could not load the shared library:../openssl-3.0.14/crypto/dso/dso_dlfcn.c:118:filename(/usr/lib/engines-3/devcrypto.so): /usr/lib/engines-3/devcrypto.so: cannot open shared object file: No such file or directory
2030F7B6:error:12800067:DSO support routines:DSO_load:could not load the shared library:../openssl-3.0.14/crypto/dso/dso_lib.c:152:
2030F7B6:error:13000084:engine routines:dynamic_load:dso not found:../openssl-3.0.14/crypto/engine/eng_dyn.c:442:
2030F7B6:error:13000074:engine routines:ENGINE_by_id:no such engine:../openssl-3.0.14/crypto/engine/eng_list.c:433:id=devcrypto
2030F7B6:error:12800067:DSO support routines:dlfcn_load:could not load the shared library:../openssl-3.0.14/crypto/dso/dso_dlfcn.c:118:filename(libdevcrypto.so): libdevcrypto.so: cannot open shared object file: No such file or directory
Doing AES-128-CBC for 3s on 16 size blocks: 4298544 AES-128-CBC's in 3.00s
Doing AES-128-CBC for 3s on 64 size blocks: 1484106 AES-128-CBC's in 3.00s
Doing AES-128-CBC for 3s on 256 size blocks: 413602 AES-128-CBC's in 2.99s
Doing AES-128-CBC for 3s on 1024 size blocks: 106466 AES-128-CBC's in 3.00s
Doing AES-128-CBC for 3s on 8192 size blocks: 13422 AES-128-CBC's in 3.00s
Doing AES-128-CBC for 3s on 16384 size blocks: 6673 AES-128-CBC's in 2.98s
version: 3.0.14
built on: Tue Jun  4 14:27:20 2024 UTC
options: bn(64,32)
compiler: arm-poky-linux-gnueabi-gcc  -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -fstack-protector-strong  -O2 -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=                      -fdebug-prefix-map=                      -fdebug-prefix-map=                      -fdebug-prefix-map=  -DOPENSSL_USE_NODELETE -DOPENSSL_PIC -DOPENSSL_BUILDING_OPENSSL -DNDEBUG
CPUINFO: OPENSSL_armcap=0x1
The 'numbers' are in 1000s of bytes per second processed.
type             16 bytes     64 bytes    256 bytes   1024 bytes   8192 bytes  16384 bytes
AES-128-CBC      22925.57k    31660.93k    35412.08k    36340.39k    36651.01k    36688.06k
hat Kontextmenü
