Other Parts Discussed in Thread: TDA2, PGA460
Hi.
Why can't I open the link in this document?
Where did this document go?
7801.VisionSDK_Linux_UserGuide.pdf
Regard,
gj
Hi.
Regard,
gj
Hi gj yang,
Do you want to build TDA2x filesystem using Yocto? I think Processor Wiki is no longer supported, this is why it is not accessible.
Brijesh
Hello gj,
Please Download the files from the following address:
https://www.ti.com/tool/download/PROCESSOR-SDK-VISION
This can be found under Design and Development in the product page for TDA2x.
Then download the Docs only:
Then it will be in the folder as such:
Please let us know if that works for you.
-Josue
gj,
Understood, This link is not alive any longer so I will have to dig a little deeper to see if this file can be recovered.
This SW is at best 5 years old so it is a possibility that some of the layers might not be supported any longer.
I will look into it today.
-Josue
The expert (Josue) taking care of the AM57x device is on year-end holidays, so E2E responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
gg,
This document is very different from VSDK. Can you send me the original link document?
Can you please explain what is the difference that you are referring to?
You asked for the file that is pointed to by the link:
This is the file that was being pointed to.
The original link does not exist any longer. processors.wiki.ti.com has been decommissioned for good.
Josue
HI Josue
Customer's board
TDA2e VSDK3.05
PVR:(Error): WSEGL_InitialiseDisplay: Failed to open primary device: No such file or directory [0, ]
EGL: eglInitialize() returned 0
EGL: after eglInitialize() eglError (0x3001)
ASSERT (sgxFrmcpyLink_drv.c|SgxFrmcpyLink_drvDoProcessEglInfo|225)
[HOST] [HOST ] 3449.518697 s: EGL: version -1225504076.11
[HOST] [HOST ] 3449.518697 s: EGL: eglInitialize() failed !!!
root@dra7xx-evm:/opt/vision_sdk# ./pvrscope -f 0
Initialised services connection.
Total counters enabled: 52.PVRScope up and running.
Group -1 2D active 1
Group -1 Compute active 1
Group -1 Frame time 0
Group -1 Frames per second (FPS) 0
Group -1 GPU clock speed 0
Group -1 Renderer active 1
Group -1 Tiler active 1
Group -1 2D time per frame 0
Group -1 Compute time per frame 0
Group -1 Renderer time per frame 0
Group -1 Tiler time per frame 0
Group 0 HSR efficiency 1
Group 0 Cycles per pixel 0
Group 0 Cycles per vertex 0
Group 0 Processing load: pixel 1
Group 0 Processing load: vertex 1
Group 0 Shaded pixels per frame 0
Group 0 Shaded pixels per second 0
Group 0 Shaded vertices per frame 0
Group 0 Shaded vertices per second 0
Group 1 Triangles output per frame 0
Group 1 Triangles output per second 0
Group 1 Shaded vertices per frame 0
Group 1 Shaded vertices per second 0
Group 2 Triangles output per frame 0
Group 2 Triangles output per second 0
Group 3 Shader processing load 1
Group 3 Triangles input per frame 0
Group 3 Triangles input per second 0
Group 3 Processing load: pixel 1
Group 4 Shader processing load 1
Group 4 HSR efficiency 1
Group 4 Cycles per pixel 0
Group 4 Processing load: pixel 1
Group 4 Shaded pixels per frame 0
Group 4 Shaded pixels per second 0
Group 5 Shader processing load 1
Group 5 HSR efficiency 1
Group 5 Cycles per pixel 0
Group 5 Cycles per vertex 0
Group 5 Processing load: pixel 1
Group 5 Processing load: vertex 1
Group 5 Shaded pixels per frame 0
Group 5 Shaded pixels per second 0
Group 5 Shaded vertices per frame 0
Group 5 Shaded vertices per second 0
Group 9 Triangles input per draw 0
Group 9 Triangles input per frame 0
Group 9 Triangles input per second 0
Group 9 Vertices per triangle 0
Group 9 Shaded vertices per frame 0
Group 9 Shaded vertices per second 0
PVRScope profiling FIFO opened Successfully
[HOST] [HOST ] 3432.781156 s:
cp: can't stat '/mnt/TDA2X/LENS.BIN': No such file or directory
[HOST] [HOST ] 3432.867168 s: CHAINS: --------------------------------------------------
[HOST] [HOST ] 3432.867199 s: CHAINS: TDA2X Folder not present in MMC/SD
[HOST] [HOST ] 3432.867199 s: CHAINS: Create TDA2X folder and copy the following files from
[HOST] [HOST ] 3432.867199 s: CHAINS: '/vision_sdk/tools/surround_vision_tools/Srv_LUTs':
[HOST] [HOST ] 3432.867199 s: CHAINS: 1. CHARTPOS.BIN
[HOST] [HOST ] 3432.867229 s: CHAINS: 2. LENS.BIN
[HOST] [HOST ] 3432.867229 s: CHAINS: 3. LENS_2D.BIN
[HOST] [HOST ] 3432.867229 s: CHAINS: --------------------------------------------------
[HOST] [HOST ]
[HOST] [HOST ] Multi-Camera LVDS Usecases
[HOST] [HOST ] ----------------------------
[HOST] [HOST ] 1: 4CH VIP LVDS capture + SGX MOSAIC + DISPLAY
[HOST] [HOST ] 2: 4CH VIP LVDS capture + Scale + Encode + Null (file dump)
[HOST] [HOST ] 3: 4CH VIP LVDS capture + 3D SRV (SGX/A15) + DISPLAY - Only HDMI 1080p display supported
[HOST] [HOST ] 7: Surround View Calibration
[HOST] [HOST ] 8: CSI2 CAL Surround View Calibration
[HOST] [HOST ] a: 4CH CSI2 CAL capture + SgxFrmCpy + DISPLAY - Only HDMI 1080p display supported
[HOST] [HOST ] b: 4CH CSI2 CAL capture + 3D SRV (SGX/A15) + DISPLAY - Only HDMI 1080p display supported
[HOST] [HOST ] c: 4CH CSI2 CAL capture + 3D SRV (SGX/A15) + Car Black Box + DISPLAY - Only HDMI 1080p display supported
[HOST] [HOST ]
[HOST] [HOST ] x: Exit
[HOST] [HOST ]
[HOST] [HOST ] Enter Choice:
[HOST] [HOST ]
a
[HOST] [HOST ] 3448.014640 s:
[HOST] [HOST ] 3448.014701 s: ======chains_csi2CalMultiCam_View======
[HOST] [HOST ] 3448.014701 s: camera CAPTURE_SENSOR_HEIGH= 800
[HOST] [HOST ] 3448.014701 s: inOutDataFormat SYSTEM_DF_YUV422I_UYVY
[HOST] [HOST ] 3448.014731 s: FPD_720P_30FPS_DISPLAY
[HOST] [HOST ] 3448.014731 s: CHERY_DISPLAY_1920X720x30fps
[HOST] [HOST ]
[HOST] [IPU2 ] 3448.346611 s: ISSCAPTURE: Create in progress !!!
[HOST] [IPU2 ] 3448.961965 s: ISSCAPTURE: Create Done !!!
[HOST] [IPU2 ] 3448.962453 s: VPE: Create in progress !!!
[HOST] [HOST ] 3449.399499 s: IPC_IN_0 : Create in progress !!!
[HOST] [HOST ] 3449.400048 s: IPC_IN_0 : Create Done !!!
[HOST] [HOST ] 3449.400170 s: SGXFRMCPY: Create in progress for resolution: 1920x720 !!!
[HOST] [HOST ] 3449.400262 s: SYSTEM_PVRSCOPE: FIFO /opt/vision_sdk/gpufifo opened successfully
[HOST] [IPU2 ] 3449.397364 s: VPE: Loading Down-scaling Co-effs
[HOST] [IPU2 ] 3449.397639 s: VPE: Co-effs Loading ... DONE !!!
[HOST] [IPU2 ] 3449.397883 s: VPE: Create Done !!!
[HOST] [IPU2 ] 3449.398828 s: IPC_OUT_0 : Create in progress !!!
[HOST] [IPU2 ] 3449.399194 s: IPC_OUT_0 : Create Done !!!
PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/build$ make -s showconfig
# Build Config is [ tda2ex_evm_linux_all ]
# Build Config file is @ /media/gstar/mydisk/tda2/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/configs/tda2ex_evm_linux_all/cfg.mk
# Build Config .h file is @ /media/gstar/mydisk/tda2/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/links_fw/include/config/apps/tda2ex_evm_linux_all/system_cfg.h
# Build CPUs is @ ipu2 a15_0
# CPUs included in application,
# PROC_IPU1_0_INCLUDE=no
# PROC_IPU1_1_INCLUDE=no
# PROC_IPU2_INCLUDE=yes
# PROC_DSP1_INCLUDE=no
# PROC_DSP2_INCLUDE=no
# PROC_EVE1_INCLUDE=no
# PROC_EVE2_INCLUDE=no
# PROC_EVE3_INCLUDE=no
# PROC_EVE4_INCLUDE=no
# PROC_A15_0_INCLUDE=yes
# Platform config,
# VSDK_BOARD_TYPE=TDA2EX_EVM [options: TDA2XX_EVM TDA2EX_EVM TDA3XX_EVM TDA3XX_RVP TDA2XX_RVP]
# PLATFORM=tda2ex-evm
# DUAL_A15_SMP_BIOS=no
# IPU1_SMP_BIOS=no
# DDR_MEM=DDR_MEM_1024M [options: DDR_MEM_128M DDR_MEM_512M DDR_MEM_1024M]
# EMIFMODE=SINGLE_EMIF_512MB [options: SINGLE_EMIF_512MB SINGLE_EMIF_1GB ref build_pdk.mk]
# NDK_PROC_TO_USE=none [options: a15_0 ipu1_0 ipu1_1 ipu2 none]
# NSP_TFDTP_INCLUDE=no [options: yes no]
# TDA2EX_ETHSRV_BOARD=no [options: yes no]
# FATFS_PROC_TO_USE=none [options: ipu1_0 none]
# RADAR_BOARD=none [options: TDA3XX_AR12_ALPS TDA3XX_AR12_VIB_DAB_BOOSTER TDA3XX_RADAR_RVP none]
# Build config,
# BUILD_OS=Linux [options: Windows_NT Linux]
# BUILD_DEPENDENCY_ALWAYS=no
# BUILD_ALGORITHMS=no
# BUILD_INFOADAS=no
# PROFILE=release [options: debug release]
# KW_BUILD=no
# CPLUSPLUS_BUILD=no
# IPU_PRIMARY_CORE=ipu2 [options: ipu1_0 ipu2]
# IPU_SECONDARY_CORE=ipu1_0 [options: ipu1_0 ipu2]
# A15_TARGET_OS=Linux [options: Bios Linux Qnx]
# BSP_STW_PACKAGE_SELECT=all [options: all vps-iss-dss-only vps-vip-vpe]
# Safety Module config,
# RTI_INCLUDE=no
# ECC_FFI_INCLUDE=no
# DCC_ESM_INCLUDE=no
# Video Module config,
# IVAHD_INCLUDE=yes
# VPE_INCLUDE=yes
# CAL_INCLUDE=yes
# ISS_INCLUDE=no
# ISS_ENABLE_DEBUG_TAPS=no
# WDR_LDC_INCLUDE=no
# DSS_INCLUDE=yes
# Open Compute config,
# OPENCL_INCLUDE=no
# TARGET_ROOTDIR=/media/gstar/mydisk/tda2/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/../ti_components/os_tools/linux/targetfs
# ENABLE_OPENCV=no
# ENABLE_OPENCV_TESTS=no
# OPENVX_INCLUDE=no
# Log config,
# ENABLE_UART_LOG=yes
# ENABLE_NETWORK_LOG=no
# ENABLE_CCS_LOG=no
# CIO_REDIRECT=yes
# IPC config,
# WORKQ_INCLUDE=no
# IPC_LIB_INCLUDE=no
# AUTOSAR_APP=no
# Surround View config,
# SRV_FAST_BOOT_INCLUDE=no
# Other Module config,
# AVB_INCLUDE=no
# DCAN_INCLUDE=no
# RADAR_ONLY=no
# CPU_IDLE_ENABLED=yes
# FAST_BOOT_INCLUDE=no
# DATA_VIS_INCLUDE=no
# HS_DEVICE=no
# ULTRASONIC_INCLUDE=no
# PGA450=
# PGA460=
# ENABLE_ALL_DEPTH=
# Linux config,
# DEFAULT_UBOOT_CONFIG=dra7xx_evm_vision_config
# DEFAULT_KERNEL_CONFIG=ti_sdk_dra7x_release_defconfig
# DEFAULT_DTB=dra72-evm-infoadas.dtb dra72-evm-infoadas-lcd-lg.dtb
# CMEM_INCLUDE=yes
# IPUMM_INCLUDE=no
# IPU1_EVELOADER_INCLUDE=no
# ROBUST_RVC_INCLUDE=no
# BUILD_ADAM_CAR=no
# Alg plugins included in build,
# ALG_autocalibration ALG_dmaSwMs ALG_framecopy ALG_surroundview
# Use-cases included in build,
# UC_srv_calibration UC_lvds_vip_multi_cam_3d_srv UC_csi2Cal_multi_cam_3d_srv UC_csi2Cal_multi_cam_3d_srv_cbb UC_csi2Cal_multi_cam_view UC_lvds_vip_multi_cam_view_sgx_display UC_lvds_vip_multi_cam_vpe_enc_null UC_null_src_decode_display UC_vip_single_cam_connectorLinksA15_sgx_display UC_vip_single_cam_enc_dec_sgx_display UC_vip_single_cam_framecopy_sgx_display UC_vip_single_cam_sgx_display
# CPUs that are NOT required but included in config [ tda2ex_evm_linux_all ],
# CPUs that are required but not included in config [ tda2ex_evm_linux_all ],
# ERROR: IPU1_0 MUST be included in application
# ERROR: DSP1 MUST be included in application
# Edit /media/gstar/mydisk/tda2/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/build/configs/tda2ex_evm_linux_all/cfg.mk to include or exclude CPUs in an application
Hello gg,
This is not a question and it is not related to the title on this E2E. If you have an unrelated question with regards to TDA2, please open anew E2E in order for the forum to be more helpful and organized.
-Josue
gg,
Can you please click on the answer on this post that resolved your question?
