AM625: AM625 Boot ATF Error follow case
Part Number: AM625
Prashant,
Follow previous w2e ticket
 https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1386509/am625-boot-atf-error
Customer use SDK: 09_01_00_08 , Kernel Version: 6.1.46-rt13 on their own board.
We use KIOXIA emmc sdhci0 boot, then do power on and off cycle test and found ATF error happen occasionally.
Customer suspend the investigation but recently got more fail cases and resume the debug.
Boot log will stop on ATF as below.
U-Boot SPL 2023.04-gd5e737886b (Dec 24 2024 - 03:25:05 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
SPL initial stack usage: 13384 bytes
Trying to boot from MMC1
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.9(rve.:.2-910-6d4ag175733-di2td
In the old discussion, two suspect points.
1. eMMC stability
2. DDR stability
From the log, previous discussion pointed there is no eMMC access and suspect more about DDR stability.
We had checked and verified customer DDR layout and setting and also done DDR test on u-boot and Linux kernel and exclude hardware design issue.
Now customer had tried to connect CCS when stuck and below contain the data print out in files.
Program Counter stop point on A53 is 0x9E788200.
Program Counter stop point on R5 is 0x2596.
May you provide clue on what could be the root cause?
Will it be possible the TIFS response stop?
A53:
A53-1
A53-2
A53-3
R5F:
R5-1
BR, Rich
  • Plz allow me jumper here to monitor / help this issue.
    In the failure case, does the customer observe the DM firmware logs on the WKUP_UART0 port?
    This is to confirm if the failure is due to the DM firmware not up and running.
    Prashant
  • Prashant,
    I am not sure whether WKUP_UART0 is reserved on customer board.
    Will there be console log on EVM when DM firmware is up?
    Do you expect any specific message on log or expect log will stop somewhere?
    Besides, customer use CCS to connect fail device when ATF happen and found the PC on A53 and R5 are always stop in same address which means it should be same reason but it is not random.
    BR, Rich
    If the DM firmware is up and running then the WKUP_UART0 console should have the logs like so:
    May I know the DM firmware customer is using here? Is it the prebuilt one that comes with the PSDK or manually built from the MCU+ SDK?
    Prashant
  • Prashant,
    Thanks, we will check WKUP_UART0 on customer board.
    Customer use only Linux SDK and they never touch MCU+ SDK so I assume it is pre-build one.
    BR, Rich
  • Customer use only Linux SDK and they never touch MCU+ SDK so I assume it is pre-build one.
    Assuming they are using prebuilt ones only, could you please ask the customer to download the following DM firmwares
    dm_firmwares.zip
    & test them one by one by replacing the prebuilt one available at $PSDK/board-support/prebuilt-images/am62xx-evm/ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.xer5f.
    cp ~/Downloads/ipc_rpmsg_echo_linux.wkup-r5f0_0.release.strip.out ~/ti/psdk/am62x/09.01.00.08/board-support/prebuilt-images/am62xx-evm/ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.xer5f
    cp ~/Downloads/ipc_rpmsg_echo_linux.wkup-r5f0_0.debug.strip.out ~/ti/psdk/am62x/09.01.00.08/board-support/prebuilt-images/am62xx-evm/ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.xer5f
    Let me know if the issue is still seen with both or only one of them.
    Prashant
  • Prashant,
    Customer tried the new DM firmware you provided for both debug and release version.
    What are the end point 13 and 14 on AM62x side?
    Starting Sciserver..... PASSED
    [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    The log for A53 and DM are attached.
    Debug version:
    Sciserver Testapp Built On: Dec 13 2023 09:20:20
    Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    RM_PM_HAL Version: v09.01.08
    [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:48:12):
    U-Boot SPL 2023.04-g7800cf88cc (Nov 27 2024 - 01:36:21 +0000)
    NOTICE:  BL31: v2.9(release):v2.9.0-614-gd7a7135d32-dirty
    NOTICE:  BL31: Built : 09:34:15, Aug 24 2023
    SPL initial stack usage: 1856 bytes
    Error: could not access storage.
    U-Boot 2023.04-g7800cf88cc (Nov 27 2024 - 01:36:21 +0000)
    SoC:   AM62X SR1.0 HS-FS
    Model: Texas Instruments AM625 SK
    DRAM:  2 GiB
    Core:  68 devices, 30 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from MMC... OK
    In:    serial
    Out:   serial
    Err:   serial
    [BSP] gd->boot_dev = 9
    Saving Environment to MMC... Writing to MMC(0)... OK
    switch to partitions #0, OK
    mmc0(part 0) is current device
    SD/MMC found on device 0
    Running eMMC boot ...
    574 bytes read in 15 ms (37.1 KiB/s)
    EMMC Loaded env from uEnv.txt
    Importing environment from mmc0 ...
    18416128 bytes read in 216 ms (81.3 MiB/s)
    62962 bytes read in 16 ms (3.8 MiB/s)
    Working FDT set to 88000000
    ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4)
       Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
    Working FDT set to 8feed000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.46-rt13-BSP_12.5.1--g2ff8ed6046 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT_RT Wed Jul  3 08:48:50 UTC 2024
    [    0.000000] Machine model: Texas Instruments AM625 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
    [    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
    [    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000fffc9fff]
    [    0.000000]   node   0: [mem 0x00000000fffca000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 21 pages/cpu s45952 r8192 d31872 u86016
    [    0.000000] pcpu-alloc: s45952 r8192 d31872 u86016 alloc=21*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=c3330aca-fc46-4890-9f49-a705e36d0736 rw rootfstype=ext4 rootwait systemd.show_status=no loglevel=8 syntec_extend=
    [    0.000000] Unknown kernel command line parameters "syntec_extend=", will be passed to user space.
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 1844200K/2097152K available (10688K kernel code, 1216K rwdata, 4084K rodata, 1856K init, 416K bss, 121880K reserved, 131072K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    [    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000]  No expedited grace period (rcu_normal_after_boot).
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000246] Console: colour dummy device 80x25
    [    0.528882] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
    [    0.528892] pid_max: default: 32768 minimum: 301
    [    0.528974] LSM: Security Framework initializing
    [    0.529096] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.529131] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.530818] rcu: Hierarchical SRCU implementation.
    [    0.530824] rcu:     Max phase no-delay instances is 400.
    [    0.530870] printk: bootconsole [ns16550a0] printing thread started
    [    0.583330] Platform MSI: msi-controller@1820000 domain created
    [    0.583565] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.583650] EFI services will not be available.
    [    0.583908] smp: Bringing up secondary CPUs ...
    [    0.584758] Detected VIPT I-cache on CPU1
    [    0.584870] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.584887] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.584942] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.635116] Detected VIPT I-cache on CPU2
    [    0.635200] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.635213] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000
    [    0.635245] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.661195] Detected VIPT I-cache on CPU3
    [    0.661283] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.661296] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000
    [    0.661328] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.661385] smp: Brought up 1 node, 4 CPUs
    [    0.661391] SMP: Total of 4 processors activated.
    [    0.695582] CPU features: detected: 32-bit EL0 Support
    [    0.695586] CPU features: detected: CRC32 instructions
    [    0.695633] CPU: All CPU(s) started at EL2
    [    0.695634] alternatives: applying system-wide alternatives
    [    0.697136] devtmpfs: initialized
    [    0.708740] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [    0.708766] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.714011] pinctrl core: initialized pinctrl subsystem
    [    0.714724] DMI not present or invalid.
    [    0.715247] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.732199] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.732491] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.732713] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.732818] audit: initializing netlink subsys (disabled)
    [    0.732960] audit: type=2000 audit(0.730:1): state=initialized audit_enabled=0 res=1
    [    0.733519] thermal_sys: Registered thermal governor 'step_wise'
    [    0.733523] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.733752] ASID allocator initialised with 65536 entries
    [    0.748663] platform 30200000.dss: Fixed dependency cycle(s) with /display0
    [    0.757695] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.757705] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.757709] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.757712] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.757716] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.757719] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.757722] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.757726] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.758883] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.759349] reg-fixed-voltage regulator-0: GPIO lookup for consumer (null)
    [    0.759356] reg-fixed-voltage regulator-0: using device tree for GPIO lookup
    [    0.759369] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-0[0]'
    [    0.759384] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-0[0]'
    [    0.759395] reg-fixed-voltage regulator-0: using lookup tables for GPIO lookup
    [    0.759401] reg-fixed-voltage regulator-0: No GPIO consumer (null) found
    [    0.759635] reg-fixed-voltage regulator-1: GPIO lookup for consumer (null)
    [    0.759640] reg-fixed-voltage regulator-1: using device tree for GPIO lookup
    [    0.759649] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-1[0]'
    [    0.759662] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-1[0]'
    [    0.759670] reg-fixed-voltage regulator-1: using lookup tables for GPIO lookup
    [    0.759674] reg-fixed-voltage regulator-1: No GPIO consumer (null) found
    [    0.759911] reg-fixed-voltage regulator-2: GPIO lookup for consumer (null)
    [    0.759916] reg-fixed-voltage regulator-2: using device tree for GPIO lookup
    [    0.759926] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-2[0]'
    [    0.759938] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-2[0]'
    [    0.759947] reg-fixed-voltage regulator-2: using lookup tables for GPIO lookup
    [    0.759950] reg-fixed-voltage regulator-2: No GPIO consumer (null) found
    [    0.760181] reg-fixed-voltage regulator-3: GPIO lookup for consumer (null)
    [ [   1.020892] printk: console [ttyS2] printing thread started
        0.760186] reg-fixed-voltage regulator-3: using device tree for GPIO lookup
    [    1.020911] printk: console [ttyS2] enabled
    [    1.020914] printk: bootconsole [ns16550a0] disabled
    [    1.033669] printk: bootconsole [ns16550a0] printing thread stopped
    [    1.034937] omap8250 2810000.serial: GPIO lookup for consumer rs485-term
    [    1.034947] omap8250 2810000.serial: using device tree for GPIO lookup
    [    1.034960] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/bus@f0000/serial@2810000[0]'
    [    1.034976] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/bus@f0000/serial@2810000[0]'
    [    1.034988] omap8250 2810000.serial: using lookup tables for GPIO lookup
    [    1.034993] omap8250 2810000.serial: No GPIO consumer rs485-term found
    [    1.035025] 2810000.serial: ttyS1 at MMIO 0x2810000 (irq = 288, base_baud = 3000000) is a 8250
    [    1.035938] panel-simple display0: GPIO lookup for consumer enable
    [    1.035947] panel-simple display0: using device tree for GPIO lookup
    [    1.035959] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/display0[0]'
    [    1.035974] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/display0[0]'
    [    1.035984] panel-simple display0: using lookup tables for GPIO lookup
    [    1.035988] panel-simple display0: No GPIO consumer enable found
    [    1.040362] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    1.045304] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
    [    1.054421] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [   1.054879] mdio_bus 8000f00.mdio: GPIO lookup for consumer reset
    [    1.054885] mdio_bus 8000f00.mdio: using device tree for GPIO lookup
    [    1.054902] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/bus@f0000/ethernet@8000000/mdio@f00[0]'
    [    1.054918] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/bus@f0000/ethernet@8000000/mdio@f00[0]'
    [    1.054933] mdio_bus 8000f00.mdio: using lookup tables for GPIO lookup
    [    1.054938] mdio_bus 8000f00.mdio: No GPIO consumer reset found
    [    1.088757] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.089043] mdio_bus 8000f00.mdio: MDIO device at address 0 is missing.
    [    1.089878] mdio_bus 8000f00.mdio:03: GPIO lookup for consumer reset
    [    1.089885] mdio_bus 8000f00.mdio:03: using device tree for GPIO lookup
    [    1.089904] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/bus@f0000/ethernet@8000000/mdio@f00/ethernet-phy@3[0]'
    [    1.089928] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/bus@f0000/ethernet@8000000/mdio@f00/ethernet-phy@3[0]'
    [    1.089942] mdio_bus 8000f00.mdio:03: using lookup tables for GPIO lookup
    [    1.089946] mdio_bus 8000f00.mdio:03: No GPIO consumer reset found
    [    1.090715] davinci_mdio 8000f00.mdio: phy[3]: device 8000f00.mdio:03, driver TI DP83822
    [    1.090803] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.091048] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    1.091065] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.091070] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.091968] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    1.111422] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.117671] physmap-flash 50000000.fpgaBus: physmap platform flash device: [mem 0x50000000-0x50ffffff]
    [    1.118144] sdhci-am654 fa00000.mmc: GPIO lookup for consumer cd
    [    1.118144] sdhci-am654 fa10000.mmc: GPIO lookup for consumer wp
    [    1.118156] sdhci-am654 fa10000.mmc: using device tree for GPIO lookup
    [    1.118156] sdhci-am654 fa00000.mmc: using device tree for GPIO lookup
    [    1.118172] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/bus@f0000/mmc@fa00000[0]'
    [    1.118172] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/mmc@fa10000[0]'
    [    1.118195] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/mmc@fa10000[0]'
    [    1.118196] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/bus@f0000/mmc@fa00000[0]'
    [    1.118206] sdhci-am654 fa10000.mmc: using lookup tables for GPIO lookup
    [    1.118206] sdhci-am654 fa00000.mmc: using lookup tables for GPIO lookup
    [    1.118216] sdhci-am654 fa10000.mmc: No GPIO consumer wp found
    [    1.118216] sdhci-am654 fa00000.mmc: No GPIO consumer cd found
    [    1.118221] sdhci-am654 fa00000.mmc: GPIO lookup for consumer wp
    [    1.118224] sdhci-am654 fa00000.mmc: using device tree for GPIO lookup
    [    1.118233] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/mmc@fa00000[0]'
    [    1.118250] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/mmc@fa00000[0]'
    [    1.118259] sdhci-am654 fa00000.mmc: using lookup tables for GPIO lookup
    [    1.118263] sdhci-am654 fa00000.mmc: No GPIO consumer wp found
    [    1.119168] mmc1: CQHCI version 5.10
    [    1.119335] sdhci-am654 fa20000.mmc: GPIO lookup for consumer wp
    [    1.119343] sdhci-am654 fa20000.mmc: using device tree for GPIO lookup
    [    1.119357] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/mmc@fa20000[0]'
    [    1.119377] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/mmc@fa20000[0]'
    [    1.119388] sdhci-am654 fa20000.mmc: using lookup tables for GPIO lookup
    [    1.119393] sdhci-am654 fa20000.mmc: No GPIO consumer wp found
    [    1.120032] mmc2: CQHCI version 5.10
    [    1.120302] mmc0: CQHCI version 5.10
    [    1.121768] physmap-flash 51000000.fpgaBus: physmap platform flash device: [mem 0x51000000-0x51ffffff]
    [    1.124223] physmap-flash 52000000.fpgaBus: physmap platform flash device: [mem 0x52000000-0x52ffffff]
    [    1.127552] gpiochip_find_base: found new base at 418
    [    1.127766] gpio gpiochip1: (600000.gpio): added GPIO chardev (254:1)
    [    1.127835] gpio gpiochip1: registered GPIOs 418 to 509 on 600000.gpio
    [    1.131145] gpiochip_find_base: found new base at 366
    [    1.131359] gpio gpiochip2: (601000.gpio): added GPIO chardev (254:2)
    [    1.131418] gpio gpiochip2: registered GPIOs 366 to 417 on 601000.gpio
    [    1.133063] gpio-regulator regulator-4: GPIO lookup for consumer (null)
    [    1.133076] gpio-regulator regulator-4: using device tree for GPIO lookup
    [    1.133096] of_get_named_gpiod_flags: parsed 'gpios' property of node '/regulator-4[0]' - status (0)
    [    1.133113] gpio gpiochip1: Persistence not supported for GPIO 31
    [    1.133126] gpio-regulator regulator-4: GPIO lookup for consumer enable
    [    1.133130] gpio-regulator regulator-4: using device tree for GPIO lookup
    [    1.133139] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/regulator-4[0]'
    [    1.133150] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/regulator-4[0]'
    [    1.133160] gpio-regulator regulator-4: using lookup tables for GPIO lookup
    [    1.133165] gpio-regulator regulator-4: No GPIO consumer enable found
    [    1.133617] gpio-backlight backlight: GPIO lookup for consumer (null)
    [    1.133622] gpio-backlight backlight: using device tree for GPIO lookup
    [    1.133635] of_get_named_gpiod_flags: parsed 'gpios' property of node '/backlight[0]' - status (0)
    [    1.133650] gpio gpiochip1: Persistence not supported for GPIO 91
    [    1.133654] gpio-509 (backlight): no flags found for (null)
    [    1.134156] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led_os[0]' - status (0)
    [    1.134170] gpio gpiochip1: Persistence not supported for GPIO 35
    [    1.134174] gpio-453 (?): no flags found for gpios
    [    1.134269] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led_boot[0]' - status (0)
    [    1.134280] gpio gpiochip2: Persistence not supported for GPIO 30
    [    1.134283] gpio-396 (?): no flags found for gpios
    [    1.134346] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led_user1[0]' - status (0)
    [    1.134356] gpio gpiochip2: Persistence not supported for GPIO 9
    [    1.134359] gpio-375 (?): no flags found for gpios
    [    1.135028] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.137835] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present!
    [    1.155872] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.157179] ALSA device list:
    [    1.157187]   No soundcards found.
    [    1.160759] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [    1.165662] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.191835] Waiting for root device PARTUUID=c3330aca-fc46-4890-9f49-a705e36d0736...
    [    1.211873] mmc1: new MMC card at address 0001
    [    1.212772] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB
    [    1.220877]  mmcblk1: p1
    [    1.221678] mmcblk1boot0: mmc1:0001 Q2J54A 2.00 MiB
    [    1.223422] mmcblk1boot1: mmc1:0001 Q2J54A 2.00 MiB
    [    1.224816] mmcblk1rpmb: mmc1:0001 Q2J54A 512 KiB, chardev (241:0)
    [    1.300583] mmc0: Command Queue Engine enabled
    [    1.300606] mmc0: new HS200 MMC card at address 0001
    [    1.301329] mmcblk0: mmc0:0001 016GB0 14.7 GiB
    [    1.305260]  mmcblk0: p1 p2 p3 p4 p5
    [    1.306341] mmcblk0boot0: mmc0:0001 016GB0 4.00 MiB
    [    1.307679] mmcblk0boot1: mmc0:0001 016GB0 4.00 MiB
    [    1.308788] mmcblk0rpmb: mmc0:0001 016GB0 4.00 MiB, chardev (241:1)
    [    1.325464] EXT4-fs (mmcblk0p4): recovery complete
    [    1.325848] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.325933] VFS: Mounted root (ext4 filesystem) on device 179:100.
    [    1.326158] devtmpfs: mounted
    [    1.327550] Freeing unused kernel memory: 1856K
    [    1.335833] Run /sbin/init as init process
    [    1.335840]   with arguments:
    [    1.335842]     /sbin/init
    [    1.335844]   with environment:
    [    1.335845]     HOME=/
    [    1.335848]     TERM=linux
    [    1.335849]     syntec_extend=
    [    1.427296] systemd[1]: System time before build time, advancing clock.
    [    1.465863] NET: Registered PF_INET6 protocol family
    [    1.467088] Segment Routing with IPv6
    [    1.467120] In-situ OAM (IOAM) with IPv6
    [    1.512199] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    1.512781] systemd[1]: Detected architecture arm64.
    [    1.516021] systemd[1]: Hostname set to <am62xx-evm>.
    [    1.647979] systemd-sysv-generator[178]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    1.957915] systemd[1]: Configuration file /etc/systemd/system/syntec-rename-network.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    1.960674] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.023442] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.026701] systemd[1]: Created slice Slice /system/modprobe.
    [    2.028293] systemd[1]: Created slice Slice /system/serial-getty.
    [    2.028841] systemd[1]: Created slice User and Session Slice.
    [    2.029198] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    2.029417] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.029792] systemd[1]: Reached target Path Units.
    [    2.029903] systemd[1]: Reached target Remote File Systems.
    [    2.029982] systemd[1]: Reached target Slice Units.
    [    2.030067] systemd[1]: Reached target Swaps.
    [    2.034291] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    2.034462] systemd[1]: Reached target RPC Port Mapper.
    [    2.040609] systemd[1]: Listening on Process Core Dump Socket.
    [    2.041109] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    2.042010] systemd[1]: Listening on Journal Audit Socket.
    [    2.042563] systemd[1]: Listening on Journal Socket (/dev/log).
    [    2.043128] systemd[1]: Listening on Journal Socket.
    [    2.043914] systemd[1]: Listening on Network Service Netlink Socket.
    [    2.045824] systemd[1]: Listening on udev Control Socket.
    [    2.046361] systemd[1]: Listening on udev Kernel Socket.
    [    2.046863] systemd[1]: Listening on User Database Manager Socket.
    [    2.071517] systemd[1]: Mounting Huge Pages File System...
    [    2.075613] systemd[1]: Mounting POSIX Message Queue File System...
    [    2.080099] systemd[1]: Mounting Kernel Debug File System...
    [    2.080949] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    2.082936] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
    [    2.088499] systemd[1]: Mounting Temporary Directory /tmp...
    [    2.094703] systemd[1]: Starting Create List of Static Device Nodes...
    [    2.099802] systemd[1]: Starting Load Kernel Module configfs...
    [    2.105077] systemd[1]: Starting Load Kernel Module drm...
    [    2.110171] systemd[1]: Starting Load Kernel Module fuse...
    [    2.116493] systemd[1]: Starting RPC Bind...
    [    2.117098] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    2.118446] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    2.118466] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    2.122329] systemd[1]: Starting Journal Service...
    [    2.123176] fuse: init (API version 7.37)
    [    2.130576] systemd[1]: Starting Load Kernel Modules...
    [    2.135620] systemd[1]: Starting Generate network units from Kernel command line...
    [    2.140704] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    2.162489] systemd[1]: Starting Coldplug All udev Devices...
    [    2.167570] systemd[1]: Starting Setup Virtual Console...
    [    2.179463] systemd[1]: Started RPC Bind.
    [    2.180567] systemd[1]: Mounted Huge Pages File System.
    [    2.181578] systemd[1]: Mounted POSIX Message Queue File System.
    [    2.182649] systemd[1]: Mounted Kernel Debug File System.
    [    2.183510] systemd[1]: Mounted Temporary Directory /tmp.
    [    2.185193] systemd[1]: Finished Create List of Static Device Nodes.
    [    2.186908] systemd[1]: modprobe@configfs.service: Deactivated successfully.
    [    2.187661] systemd[1]: Finished Load Kernel Module configfs.
    [    2.189445] systemd[1]: modprobe@drm.service: Deactivated successfully.
    [    2.190298] systemd[1]: Finished Load Kernel Module drm.
    [    2.192054] systemd[1]: modprobe@fuse.service: Deactivated successfully.
    [    2.192663] systemd[1]: Finished Load Kernel Module fuse.
    [    2.194233] systemd[1]: Finished Generate network units from Kernel command line.
    [    2.206966] EXT4-fs (mmcblk0p4): re-mounted. Quota mode: none.
    [    2.213770] cryptodev: loading out-of-tree module taints kernel.
    [    2.218226] cryptodev: driver 1.12 loaded.
    [    2.226906] systemd[1]: Mounting FUSE Control File System...
    [    2.239671] systemd[1]: Mounting Kernel Configuration File System...
    [    2.245692] systemd[1]: Finished Load Kernel Modules.
    [    2.247437] systemd[1]: Finished Remount Root and Kernel File Systems.
    [    2.249096] systemd[1]: Finished Setup Virtual Console.
    [    2.250092] systemd[1]: Mounted FUSE Control File System.
    [    2.253909] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
    [    2.254234] systemd[1]: Platform Persistent Storage Archival was skipped because of a failed condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
    [    2.258397] systemd[1]: Starting Apply Kernel Variables...
    [    2.259014] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
    [    2.263457] systemd[1]: Starting Create Static Device Nodes in /dev...
    [    2.267892] systemd[1]: Mounted Kernel Configuration File System.
    [    2.326086] systemd[1]: Started Journal Service.
    [    2.372038] systemd-journald[189]: Received client request to flush runtime journal.
    [    2.717823] random: crng init done
    [    2.830295] spi_master spi1: GPIO lookup for consumer cs
    [    2.830319] spi_master spi1: using device tree for GPIO lookup
    [    2.830339] of_get_named_gpiod_flags: can't parse 'cs-gpios' property of node '/bus@f0000/spi@20100000[0]'
    [    2.830383] of_get_named_gpiod_flags: parsed 'cs-gpio' property of node '/bus@f0000/spi@20100000[0]' - status (0)
    [    2.830405] gpio gpiochip2: Persistence not supported for GPIO 16
    [    2.854115] xlnx-slave-spi spi1.0: GPIO lookup for consumer prog_b
    [    2.854138] xlnx-slave-spi spi1.0: using device tree for GPIO lookup
    [    2.854175] of_get_named_gpiod_flags: parsed 'prog_b-gpios' property of node '/bus@f0000/spi@20100000/fpga-mgr@0[0]' - status (0)
    [    2.854200] gpio gpiochip1: Persistence not supported for GPIO 5
    [    2.854218] xlnx-slave-spi spi1.0: GPIO lookup for consumer init-b
    [    2.854222] xlnx-slave-spi spi1.0: using device tree for GPIO lookup
    [    2.854234] of_get_named_gpiod_flags: parsed 'init-b-gpios' property of node '/bus@f0000/spi@20100000/fpga-mgr@0[0]' - status (0)
    [    2.854246] gpio gpiochip1: Persistence not supported for GPIO 4
    [    2.854253] xlnx-slave-spi spi1.0: GPIO lookup for consumer done
    [    2.854257] xlnx-slave-spi spi1.0: using device tree for GPIO lookup
    [    2.854267] of_get_named_gpiod_flags: parsed 'done-gpios' property of node '/bus@f0000/spi@20100000/fpga-mgr@0[0]' - status (0)
    [    2.854279] gpio gpiochip1: Persistence not supported for GPIO 6
    [    2.886508] spi_master spi2: GPIO lookup for consumer cs
    [    2.886525] spi_master spi2: using device tree for GPIO lookup
    [    2.886553] fram@0 enforce active low on chipselect handle
    [    2.886555] of_get_named_gpiod_flags: parsed 'cs-gpios' property of node '/bus@f0000/spi@20120000[0]' - status (0)
    [    2.886583] gpio gpiochip2: Persistence not supported for GPIO 13
    [    2.971113] mc: Linux media interface: v0.10
    [    2.987681] videodev: Linux video capture interface: v2.00
    [    3.004295] rtc-s35390a 1-0030: registered as rtc0
    [    3.005442] rtc-s35390a 1-0030: setting system clock to 2023-04-05T13:04:32 UTC (1680699872)
    [    3.006373] systemd-journald[189]: Oldest entry in /run/log/journal/67780a30dabb46fe89b0720e5bd1cfad/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    [    3.006402] systemd-journald[189]: /run/log/journal/67780a30dabb46fe89b0720e5bd1cfad/system.journal: Journal header limits reached or header out-of-date, rotating.
    [    3.014435] systemd-journald[189]: Oldest entry in /run/log/journal/67780a30dabb46fe89b0720e5bd1cfad/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    [    3.014472] systemd-journald[189]: /run/log/journal/67780a30dabb46fe89b0720e5bd1cfad/system.journal: Journal header limits reached or header out-of-date, rotating.
    [    3.080486] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
    [    3.082878] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    3.083055] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    3.083436] remoteproc remoteproc0: 5000000.m4fss is available
    [    3.086977] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
    [    3.087018] remoteproc remoteproc0: powering up 5000000.m4fss
    [    3.087056] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
    [    3.087064] remoteproc remoteproc0: request_firmware failed: -2
    [    3.292697] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    3.293439] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
    [    3.293472] rtc-ti-k3 2b1f0000.rtc: GPIO lookup for consumer wp
    [    3.293478] rtc-ti-k3 2b1f0000.rtc: using device tree for GPIO lookup
    [    3.293499] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/bus@b00000/rtc@2b1f0000[0]'
    [    3.293520] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/bus@b00000/rtc@2b1f0000[0]'
    [    3.293535] rtc-ti-k3 2b1f0000.rtc: using lookup tables for GPIO lookup
    [    3.293541] rtc-ti-k3 2b1f0000.rtc: No GPIO consumer wp found
    [    3.309291] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    3.309573] platform 78000000.r5f: configured R5F for IPC-only mode
    [    3.309826] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
    [    3.310248] remoteproc remoteproc1: 78000000.r5f is available
    [    3.310335] remoteproc remoteproc1: attaching to 78000000.r5f
    [    3.329913] platform 78000000.r5f: R5F core initialized in IPC-only mode
    [    3.329959] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9da00000
    [    3.330888] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    3.330934] rproc-virtio rproc-virtio.3.auto: registered virtio0 (type 7)
    [    3.330942] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    3.334444] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    3.334766] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    3.347799] Init FPGA interrupt driver (1.0)
    [    3.348337] of_get_named_gpiod_flags: parsed 'kick-gpios' property of node '/sysintrdrv[0]' - status (0)
    [    3.348359] Get kick_gpio number= (418)
    [    4.255676] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    4.342322] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    4.343869] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    4.343906] cfg80211: failed to load regulatory.db
    [    4.495607] fm25_syntec spi2.0: GPIO lookup for consumer wp
    [    4.495633] fm25_syntec spi2.0: using device tree for GPIO lookup
    [    4.495650] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/spi@20120000/fram@0[0]'
    [    4.495678] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/spi@20120000/fram@0[0]'
    [    4.495698] fm25_syntec spi2.0: using lookup tables for GPIO lookup
    [    4.495703] fm25_syntec spi2.0: No GPIO consumer wp found
    [    4.576484] fm25_syntec spi2.0: 32 KByte fm25 fram, pagesize 4096
    [    4.591781] remoteproc remoteproc2: 30074000.pru is available
    [    4.606370] remoteproc remoteproc3: 30078000.pru is available
    [    4.666557] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:03] driver [TI DP83822] (irq=POLL)
    [    4.666606] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [    4.817603] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    4.817672] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
    [    4.818880] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
    [    4.821490] xhci-hcd xhci-hcd.4.auto: USB3 root hub has no ports
    [    4.821510] xhci-hcd xhci-hcd.4.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
    [    4.829333] xhci-hcd xhci-hcd.4.auto: irq 465, io mem 0x31100000
    [    4.833375] hub 1-0:1.0: USB hub found
    [    4.835409] hub 1-0:1.0: 1 port detected
    [    5.076834] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    5.246267] hub 1-1:1.0: USB hub found
    [    5.251150] hub 1-1:1.0: 4 ports detected
    [    5.469592] am65-cpsw-nuss 8000000.ethernet lan1: renamed from eth0
    [    5.533481] am65-cpsw-nuss 8000000.ethernet lan1: PHY [8000f00.mdio:03] driver [TI DP83822] (irq=POLL)
    [    5.533527] am65-cpsw-nuss 8000000.ethernet lan1: configuring for phy/rmii link mode
    [    5.678324] EXT4-fs (mmcblk0p1): recovery complete
    [    5.678336] EXT4-fs (mmcblk0p2): recovery complete
    [    5.678362] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    5.744390] EXT4-fs (mmcblk0p3): recovery complete
    [    5.744487] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Quota mode: none.
    [    5.935892] EXT4-fs (mmcblk0p5): Using encoding defined by superblock: utf8-12.1.0 with flags 0x1
    [    6.014219] EXT4-fs (mmcblk0p5): recovery complete
    [    6.015199] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Quota mode: none.
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            bash
            cifs-utils
            dosfstools
            grub-common
            grub-editenv
            grub-efi
            less
            lib32-libgcc1
            lib32-libstdc++6
            libdw1
            libelf1
            libgcc1
            libgdbm-compat4
            libgdbm6
            libgmp10
            libidn2-0
            libreadline8
            libstdc++6
            libunistring2
            libvte-2.91-0
            nettle
            onboard
            parted
            rxvt-unicode
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    *******[    6.421354] EXT4-fs (mmcblk1p1): recovery complete
    [    6.429077] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Quota mode: none.
    WARNING: The runtime version supported by this application is unavailable.
    Using default runtime: v4.0.30319
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62xx-evm -
    Arago 2023.10 am62xx-evm -
    am62xx-evm login: [   11.850707] gpio gpiochip1: Persistence not supported for GPIO 7
    [   11.850834] gpio gpiochip1: registered chardev handle for line 7
    [   11.850859] gpio gpiochip1: registered chardev handle for 1 lines
    [   11.850955] gpio gpiochip1: Persistence not supported for GPIO 8
    [   11.850961] gpio gpiochip1: registered chardev handle for line 8
    [   11.850969] gpio gpiochip1: registered chardev handle for 1 lines
    [   11.851007] gpio gpiochip1: Persistence not supported for GPIO 9
    [   11.851012] gpio gpiochip1: registered chardev handle for line 9
    [   11.851019] gpio gpiochip1: registered chardev handle for 1 lines
    [   11.851056] gpio gpiochip1: Persistence not supported for GPIO 10
    [   11.851061] gpio gpiochip1: registered chardev handle for line 10
    [   11.851069] gpio gpiochip1: registered chardev handle for 1 lines
    [   11.851107] gpio gpiochip1: Persistence not supported for GPIO 11
    [   11.851112] gpio gpiochip1: registered chardev handle for line 11
    [   11.851119] gpio gpiochip1: registered chardev handle for 1 lines
    [   11.851153] gpio gpiochip1: Persistence not supported for GPIO 12
    [   11.851157] gpio gpiochip1: registered chardev handle for line 12
    [   11.851165] gpio gpiochip1: registered chardev handle for 1 lines
    [   11.851202] gpio gpiochip1: Persistence not supported for GPIO 13
    [   11.851206] gpio gpiochip1: registered chardev handle for line 13
    [   11.851213] gpio gpiochip1: registered chardev handle for 1 lines
    [   11.851251] gpio gpiochip1: Persistence not supported for GPIO 14
    [   11.851257] gpio gpiochip1: registered chardev handle for line 14
    [   11.851263] gpio gpiochip1: registered chardev handle for 1 lines
    [   14.155941] gpio gpiochip1: Persistence not supported for GPIO 7
    [   14.155967] gpio gpiochip1: registered chardev handle for line 7
    [   14.155983] gpio gpiochip1: registered chardev handle for 1 lines
    [   14.156036] gpio gpiochip1: Persistence not supported for GPIO 8
    [   14.156041] gpio gpiochip1: registered chardev handle for line 8
    [   14.156048] gpio gpiochip1: registered chardev handle for 1 lines
    [   14.156082] gpio gpiochip1: Persistence not supported for GPIO 9
    [   14.156087] gpio gpiochip1: registered chardev handle for line 9
    [   14.156094] gpio gpiochip1: registered chardev handle for 1 lines
    [   14.156129] gpio gpiochip1: Persistence not supported for GPIO 10
    [   14.156134] gpio gpiochip1: registered chardev handle for line 10
    [   14.156141] gpio gpiochip1: registered chardev handle for 1 lines
    [   14.156174] gpio gpiochip1: Persistence not supported for GPIO 11
    [   14.156181] gpio gpiochip1: registered chardev handle for line 11
    [   14.156188] gpio gpiochip1: registered chardev handle for 1 lines
    [   14.156221] gpio gpiochip1: Persistence not supported for GPIO 12
    [   14.156226] gpio gpiochip1: registered chardev handle for line 12
    [   14.156233] gpio gpiochip1: registered chardev handle for 1 lines
    [   14.156267] gpio gpiochip1: Persistence not supported for GPIO 13
    [   14.156272] gpio gpiochip1: registered chardev handle for line 13
    [   14.156278] gpio gpiochip1: registered chardev handle for 1 lines
    [   14.156311] gpio gpiochip1: Persistence not supported for GPIO 14
    [   14.156317] gpio gpiochip1: registered chardev handle for line 14
    [   14.156323] gpio gpiochip1: registered chardev handle for 1 lines
    [   14.642976] fpga_manager fpga0: writing CNC2_FC_A7_50T_CSG324_M3_BUS3.bin to Xilinx Slave Serial FPGA Manager
    [   19.765314] gpio gpiochip1: Persistence not supported for GPIO 7
    [   19.765336] gpio gpiochip1: registered chardev handle for line 7
    [   19.765360] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.765414] gpio gpiochip1: Persistence not supported for GPIO 8
    [   19.765420] gpio gpiochip1: registered chardev handle for line 8
    [   19.765427] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.765462] gpio gpiochip1: Persistence not supported for GPIO 9
    [   19.765468] gpio gpiochip1: registered chardev handle for line 9
    [   19.765474] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.765513] gpio gpiochip1: Persistence not supported for GPIO 10
    [   19.765519] gpio gpiochip1: registered chardev handle for line 10
    [   19.765525] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.765562] gpio gpiochip1: Persistence not supported for GPIO 11
    [   19.765568] gpio gpiochip1: registered chardev handle for line 11
    [   19.765575] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.765610] gpio gpiochip1: Persistence not supported for GPIO 12
    [   19.765615] gpio gpiochip1: registered chardev handle for line 12
    [   19.765622] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.765658] gpio gpiochip1: Persistence not supported for GPIO 13
    [   19.765663] gpio gpiochip1: registered chardev handle for line 13
    [   19.765670] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.765704] gpio gpiochip1: Persistence not supported for GPIO 14
    [   19.765709] gpio gpiochip1: registered chardev handle for line 14
    [   19.765716] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.846360] gpio gpiochip1: Persistence not supported for GPIO 7
    [   19.846385] gpio gpiochip1: registered chardev handle for line 7
    [   19.846413] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.846503] gpio gpiochip1: Persistence not supported for GPIO 8
    [   19.846509] gpio gpiochip1: registered chardev handle for line 8
    [   19.846518] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.846558] gpio gpiochip1: Persistence not supported for GPIO 9
    [   19.846563] gpio gpiochip1: registered chardev handle for line 9
    [   19.846570] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.846606] gpio gpiochip1: Persistence not supported for GPIO 10
    [   19.846611] gpio gpiochip1: registered chardev handle for line 10
    [   19.846619] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.846654] gpio gpiochip1: Persistence not supported for GPIO 11
    [   19.846660] gpio gpiochip1: registered chardev handle for line 11
    [   19.846666] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.846708] gpio gpiochip1: Persistence not supported for GPIO 12
    [   19.846712] gpio gpiochip1: registered chardev handle for line 12
    [   19.846719] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.847085] gpio gpiochip1: Persistence not supported for GPIO 13
    [   19.847099] gpio gpiochip1: registered chardev handle for line 13
    [   19.847116] gpio gpiochip1: registered chardev handle for 1 lines
    [   19.847174] gpio gpiochip1: Persistence not supported for GPIO 14
    [   19.847179] gpio gpiochip1: registered chardev handle for line 14
    [   19.847187] gpio gpiochip1: registered chardev handle for 1 lines
    Release version:
    1230-release-test.txt
    Sciserver Testapp Built On: Dec 13 2023 09:22:42
    BR, Rich
  • Prashant,
    We checked back the old firmware and found A53 and DM log are same with the new DM version.
    It looks DM is running and it is not stuck.
    Therefore, we need to check back to the stuck PC on A53 side.
    On A53 boot log, 0x9E788200 is in early memory node range as I marked in Yellow.
    We tried to check TEE.map but it start from 0x9E800000.
    Do you know what the function put on this range is?
    Starting kernel ...
    [ 0.000000] efi: UEFI not found.
    BR, Rich
  • Prashant,
    May I confirm the intention of get WKUP_UART0 DM log console is to judge whether DM firmware has run or not?
    From current out DM log, all the log are identical and we can tell DM firmware may not stuck somewhere or error log.
    Is it possible the DM firmware not run at ATF fail case? Is this what you would like to check? (DM firmware run or not run)
    BR, Rich
  • May I confirm the intention of get WKUP_UART0 DM log console is to judge whether DM firmware has run or not?
    Yes.
    Yes, exactly. I would like to see if the DM firmware is up and running in the ATF failure case.
  • Hi Prashant:
    Sorry, Where is the DM FW SDK?
    DM is the M4F?
    BR Rio
  • plz ignore the previous of my post.
    According this pic, the customer has pass the DMSC loading? Please see the 1st post of the customer log.
  • According this pic, the customer has pass the DMSC loading? Please see the 1st post of the customer log.
    It only means the DM firmware is loaded correctly but does not necessarily mean it is running successfully after the R5 SPL.
    The customer needs to confirm if they see the DM firmware logs in the boot failure case.
  • Prashant,
    Customer add timestamp on debug logs on both UART0 (A53) and WKUP_UART0 (DM) and confirm the DM firmware log was not printed out when ATF fail case happen.
    This means DM firmware may not be loaded completely or not be run completely.
    Debug log is attached here.
    console-rel.txt
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2025.01.03 13:52:27 =~=~=~=~=~=~=~=~=~=~=~=
    [03/01/25 - 13:52:55:959] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 13:52:55:959] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 13:52:55:959] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 13:52:55:974]
    [03/01/25 - 13:52:55:974] Starting Sciserver..... PASSED
    [03/01/25 - 13:52:55:974] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 13:53:01:584] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 13:53:01:594]
    [03/01/25 - 13:53:01:594] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 13:53:01:602]
    [03/01/25 - 13:53:50:917] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 13:53:50:921]
    [03/01/25 - 13:53:50:921] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 13:53:50:927]
    [03/01/25 - 13:53:50:927] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 13:53:50:930]
    [03/01/25 - 13:53:50:930] Starting Sciserver..... PASSED
    [03/01/25 - 13:53:50:933]
    [03/01/25 - 13:53:50:933] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 13:53:50:940]
    [03/01/25 - 13:53:56:693] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 13:53:56:709]
    [03/01/25 - 13:53:56:709] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 13:54:46:209] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 13:54:46:215]
    [03/01/25 - 13:54:46:215] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 13:54:46:220]
    [03/01/25 - 13:54:46:220] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 13:54:46:222]
    [03/01/25 - 13:54:46:223] Starting Sciserver..... PASSED
    [03/01/25 - 13:54:46:225]
    [03/01/25 - 13:54:46:226] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 13:54:46:232]
    [03/01/25 - 13:54:51:924] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 13:54:51:924] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 13:54:51:940]
    [03/01/25 - 13:55:41:674] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 13:55:41:674] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 13:55:41:674] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 13:55:41:674] Starting Sciserver..... PASSED
    [03/01/25 - 13:55:41:690]
    [03/01/25 - 13:55:41:690] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 13:55:47:355] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 13:55:47:371]
    [03/01/25 - 13:55:47:371] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 13:56:36:380] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 13:56:36:380] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 13:56:36:390]
    [03/01/25 - 13:56:36:390] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 13:56:36:395]
    [03/01/25 - 13:56:36:395] Starting Sciserver..... PASSED
    [03/01/25 - 13:56:36:395] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 13:56:36:401]
    [03/01/25 - 13:56:42:184] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 13:56:42:192]
    [03/01/25 - 13:56:42:192] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 13:56:42:198]
    [03/01/25 - 13:57:31:524] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 13:57:31:530]
    [03/01/25 - 13:57:31:530] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 13:57:31:535]
    [03/01/25 - 13:57:31:535] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 13:57:31:538]
    [03/01/25 - 13:57:31:538] Starting Sciserver..... PASSED
    [03/01/25 - 13:57:31:541]
    [03/01/25 - 13:57:31:541] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 13:57:31:548]
    [03/01/25 - 13:57:37:185] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 13:57:37:192]
    [03/01/25 - 13:57:37:192] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 13:57:37:199]
    [03/01/25 - 13:58:26:035] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 13:58:26:040]
    [03/01/25 - 13:58:26:041] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 13:58:26:046]
    [03/01/25 - 13:58:26:046] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 13:58:26:049]
    [03/01/25 - 13:58:26:049] Starting Sciserver..... PASSED
    [03/01/25 - 13:58:26:051]
    [03/01/25 - 13:58:26:051] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 13:58:26:058]
    [03/01/25 - 13:58:31:872] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 13:58:31:879]
    [03/01/25 - 13:58:31:880] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 13:58:31:886]
    [03/01/25 - 13:59:20:164] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 13:59:20:164] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 13:59:20:164] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 13:59:20:164] Starting Sciserver..... PASSED
    [03/01/25 - 13:59:20:179]
    [03/01/25 - 13:59:20:179] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 13:59:25:927] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 13:59:25:934]
    [03/01/25 - 13:59:25:934] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 13:59:25:941]
    [03/01/25 - 14:00:15:031] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:00:15:047]
    [03/01/25 - 14:00:15:047] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:00:15:047] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:00:15:047] Starting Sciserver..... PASSED
    [03/01/25 - 14:00:15:047] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:00:15:063]
    [03/01/25 - 14:00:20:681] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:00:20:681] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:00:20:697]
    [03/01/25 - 14:01:10:999] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:01:11:004]
    [03/01/25 - 14:01:11:004] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:01:11:009]
    [03/01/25 - 14:01:11:009] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:01:11:011]
    [03/01/25 - 14:01:11:012] Starting Sciserver..... PASSED
    [03/01/25 - 14:01:11:015]
    [03/01/25 - 14:01:11:015] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:01:11:022]
    [03/01/25 - 14:01:16:712] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:01:16:728]
    [03/01/25 - 14:01:16:728] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:02:05:690] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:02:05:690] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:02:05:690] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:02:05:706]
    [03/01/25 - 14:02:05:706] Starting Sciserver..... PASSED
    [03/01/25 - 14:02:05:706] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:02:11:382] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:02:11:390]
    [03/01/25 - 14:02:11:390] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:02:11:396]
    [03/01/25 - 14:03:01:041] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:03:01:047]
    [03/01/25 - 14:03:01:047] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:03:01:047] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:03:01:057]
    [03/01/25 - 14:03:01:057] Starting Sciserver..... PASSED
    [03/01/25 - 14:03:01:057] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:03:07:021] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:03:07:028]
    [03/01/25 - 14:03:07:029] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:03:07:035]
    [03/01/25 - 14:03:55:733] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:03:55:733] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:03:55:749]
    [03/01/25 - 14:03:55:749] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:03:55:749] Starting Sciserver..... PASSED
    [03/01/25 - 14:03:55:749] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:04:01:497] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:04:01:504]
    [03/01/25 - 14:04:01:504] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:04:01:511]
    [03/01/25 - 14:04:50:137] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:04:50:142]
    [03/01/25 - 14:04:50:142] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:04:50:148]
    [03/01/25 - 14:04:50:148] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:04:50:150]
    [03/01/25 - 14:04:50:150] Starting Sciserver..... PASSED
    [03/01/25 - 14:04:50:153]
    [03/01/25 - 14:04:50:153] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:04:50:160]
    [03/01/25 - 14:04:55:877] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:04:55:884]
    [03/01/25 - 14:04:55:885] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:04:55:892]
    [03/01/25 - 14:05:45:444] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:05:45:460]
    [03/01/25 - 14:05:45:460] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:05:45:460] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:05:45:460] Starting Sciserver..... PASSED
    [03/01/25 - 14:05:45:460] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:05:45:475]
    [03/01/25 - 14:05:51:048] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:05:51:048] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:05:51:063]
    [03/01/25 - 14:06:41:524] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:06:41:529]
    [03/01/25 - 14:06:41:529] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:06:41:535]
    [03/01/25 - 14:06:41:535] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:06:41:537]
    [03/01/25 - 14:06:41:537] Starting Sciserver..... PASSED
    [03/01/25 - 14:06:41:540]
    [03/01/25 - 14:06:41:540] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:06:41:547]
    [03/01/25 - 14:06:47:406] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:06:47:413]
    [03/01/25 - 14:06:47:413] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:06:47:421]
    [03/01/25 - 14:07:36:844] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:07:36:844] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:07:36:860]
    [03/01/25 - 14:07:36:860] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:07:36:860] Starting Sciserver..... PASSED
    [03/01/25 - 14:07:36:860] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:07:42:623] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:07:42:623] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:07:42:644]
    [03/01/25 - 14:08:32:010] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:08:32:010] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:08:32:026]
    [03/01/25 - 14:08:32:026] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:08:32:026] Starting Sciserver..... PASSED
    [03/01/25 - 14:08:32:026] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:08:32:042]
    [03/01/25 - 14:08:37:648] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:08:37:664]
    [03/01/25 - 14:08:37:664] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:09:28:038] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:09:28:043]
    [03/01/25 - 14:09:28:043] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:09:28:048]
    [03/01/25 - 14:09:28:048] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:09:28:051]
    [03/01/25 - 14:09:28:051] Starting Sciserver..... PASSED
    [03/01/25 - 14:09:28:054]
    [03/01/25 - 14:09:28:054] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:09:28:061]
    [03/01/25 - 14:09:33:648] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:09:33:664]
    [03/01/25 - 14:09:33:664] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:09:33:667]
    [03/01/25 - 14:10:24:015] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:10:24:019]
    [03/01/25 - 14:10:24:020] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:10:24:025]
    [03/01/25 - 14:10:24:025] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:10:24:028]
    [03/01/25 - 14:10:24:028] Starting Sciserver..... PASSED
    [03/01/25 - 14:10:24:031]
    [03/01/25 - 14:10:24:031] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:10:24:038]
    [03/01/25 - 14:10:29:947] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:10:29:947] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:10:29:963]
    [03/01/25 - 14:11:18:177] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:11:18:183]
    [03/01/25 - 14:11:18:183] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:11:18:188]
    [03/01/25 - 14:11:18:188] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:11:18:190]
    [03/01/25 - 14:11:18:191] Starting Sciserver..... PASSED
    [03/01/25 - 14:11:18:193]
    [03/01/25 - 14:11:18:193] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:11:18:200]
    [03/01/25 - 14:11:23:980] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:11:23:983]
    [03/01/25 - 14:11:23:983] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:11:23:995]
    [03/01/25 - 14:12:13:568] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:12:13:568] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:12:13:588]
    [03/01/25 - 14:12:13:588] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:12:13:591]
    [03/01/25 - 14:12:13:591] Starting Sciserver..... PASSED
    [03/01/25 - 14:12:13:594]
    [03/01/25 - 14:12:13:594] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:12:13:604]
    [03/01/25 - 14:12:19:331] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:12:19:337]
    [03/01/25 - 14:12:19:338] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:12:19:344]
    [03/01/25 - 14:13:09:045] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:13:09:049]
    [03/01/25 - 14:13:09:049] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:13:09:055]
    [03/01/25 - 14:13:09:055] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:13:09:057]
    [03/01/25 - 14:13:09:057] Starting Sciserver..... PASSED
    [03/01/25 - 14:13:09:061]
    [03/01/25 - 14:13:09:062] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:13:09:068]
    [03/01/25 - 14:13:14:825] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:13:14:841]
    [03/01/25 - 14:13:14:841] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:14:04:206] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:14:04:212]
    [03/01/25 - 14:14:04:212] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:14:04:217]
    [03/01/25 - 14:14:04:217] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:14:04:219]
    [03/01/25 - 14:14:04:219] Starting Sciserver..... PASSED
    [03/01/25 - 14:14:04:222]
    [03/01/25 - 14:14:04:222] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:14:04:229]
    [03/01/25 - 14:14:09:868] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:14:09:876]
    [03/01/25 - 14:14:09:876] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:14:09:884]
    [03/01/25 - 14:14:59:252] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:14:59:257]
    [03/01/25 - 14:14:59:257] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:14:59:263]
    [03/01/25 - 14:14:59:263] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:14:59:265]
    [03/01/25 - 14:14:59:265] Starting Sciserver..... PASSED
    [03/01/25 - 14:14:59:268]
    [03/01/25 - 14:14:59:268] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:14:59:275]
    [03/01/25 - 14:15:05:010] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:15:05:026]
    [03/01/25 - 14:15:05:026] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:15:05:039]
    [03/01/25 - 14:15:54:490] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:15:54:495]
    [03/01/25 - 14:15:54:495] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:15:54:500]
    [03/01/25 - 14:15:54:500] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:15:54:504]
    [03/01/25 - 14:15:54:504] Starting Sciserver..... PASSED
    [03/01/25 - 14:15:54:507]
    [03/01/25 - 14:15:54:507] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:15:54:514]
    [03/01/25 - 14:16:00:260] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:16:00:268]
    [03/01/25 - 14:16:00:268] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:16:00:274]
    [03/01/25 - 14:16:49:711] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:16:49:727]
    [03/01/25 - 14:16:49:727] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:16:49:727] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:16:49:727] Starting Sciserver..... PASSED
    [03/01/25 - 14:16:49:727] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:16:49:743]
    [03/01/25 - 14:16:55:527] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:16:55:535]
    [03/01/25 - 14:16:55:535] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:16:55:542]
    [03/01/25 - 14:17:45:144] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:17:45:160]
    [03/01/25 - 14:17:45:160] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:17:45:160] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:17:45:160] Starting Sciserver..... PASSED
    [03/01/25 - 14:17:45:160] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:17:45:175]
    [03/01/25 - 14:17:50:847] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:17:50:854]
    [03/01/25 - 14:17:50:854] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:17:50:861]
    [03/01/25 - 14:18:41:019] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:18:41:024]
    [03/01/25 - 14:18:41:024] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:18:41:029]
    [03/01/25 - 14:18:41:029] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:18:41:032]
    [03/01/25 - 14:18:41:032] Starting Sciserver..... PASSED
    [03/01/25 - 14:18:41:035]
    [03/01/25 - 14:18:41:035] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:18:41:042]
    [03/01/25 - 14:18:46:699] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:18:46:715]
    [03/01/25 - 14:18:46:715] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:19:36:449] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:19:36:454]
    [03/01/25 - 14:19:36:454] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:19:36:459]
    [03/01/25 - 14:19:36:459] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:19:36:462]
    [03/01/25 - 14:19:36:462] Starting Sciserver..... PASSED
    [03/01/25 - 14:19:36:464]
    [03/01/25 - 14:19:36:465] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:19:36:471]
    [03/01/25 - 14:19:42:227] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:19:42:227] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:19:42:242]
    [03/01/25 - 14:20:31:692] Sciserver Testapp Built On: Dec 13 2023 09:22:42
    [03/01/25 - 14:20:31:692] Sciserver Version: v2023.12.0.0-REL.MCUSDK.09.01.00.39+
    [03/01/25 - 14:20:31:692] RM_PM_HAL Version: v09.01.08
    [03/01/25 - 14:20:31:692] Starting Sciserver..... PASSED
    [03/01/25 - 14:20:31:707]
    [03/01/25 - 14:20:31:707] [IPC RPMSG ECHO] Version: REL.MCUSDK.09.01.00.39+ (Dec 26 2024 15:47:53):
    [03/01/25 - 14:20:37:302] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
    [03/01/25 - 14:20:37:309]
    [03/01/25 - 14:20:37:309] [IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
    [03/01/25 - 14:20:37:316]
    What could be the possibility DM firmware fail to be printed?
    How to debug further?
    Will you provide a debug version DM firmware?
    BR, Rich
  • Assuming they are using prebuilt ones only, could you please ask the customer to download the following DM firmwares
    dm_firmwares.zip
    Do they see the issue with the DM firmwares available in this ZIP as well?
  • Prashant,
    Is this the same DM_firmwares.zip you provided in this thread earlier?
    If the answer is positive, then the issue remain the same on this DM firmware which customer tried it already with same result as prebuilt one.
    BR, Rich
    Yes. There were two DM firwmare built for DEBUG & RELEASE profile.
    Do they see the issue with both the DM firmwares?
    If yes, could you please ask them to load the symbols using CCS to identify where the DM is stuck?
    The procedure would be:
    • Connect to the WKUP R5F core.
    • Load the symbols: Run -> Load -> Load Symbols... -> Browse -> Path to the DM firmware executable.
    Prashant
  • Prashant,
    Yes, we see issue with both DM firmware.
    And customer build both Debug and Release version and see same result.
    Which DM firmware version do you prefer to check? The new version you provided? Build Release?
    BR, Rich
  • Which DM firmware version do you prefer to check? The new version you provided? Build Release?
    Please provide the results with the DEBUG one.
