CCSTUDIO: Migration of C5505Project to C5517Project
Part Number: CCSTUDIO
Experiment_5505to5517prj.doc Tst_CODEC.zip
Hi,Ki-san. We are going to migrate a project of C5505(working) to a new system with C5517.So we modified several parts of the C5505 source cord(about PLL CLK of the DSP)to met to C5517.Then CCS build has succeed correctly.The other hand, the Test connection(on the window of .ccxml file) was succeed, too.(We are using XDS100v2 USB-JTAG Emulator) But there appeared "Error connecting to the Target"(like as attatched picture and doccument) by clicking the Dubug Button. Are there any mismatching to C5517 on the attatched C5505 Project? Best regards.Takahiro Okutsu
  • Okutsu-san,
    The project will not have an impact regarding this error. This type of error is typically due to a hardware configuration issue. Is the customer using a custom C5517 board?
    Thank you
    ki
  • Hi,Ki-san.Thank you for advice.As you mentioned,RESET line was half voltage by mistaking of CCT design.And  after improvement,our system works correctly(resolved).Thank you for your accurate advice.Best regards,Takahiro Okutsu.
