CCSTUDIO: V20 not detecting my board
Part Number: CCSTUDIO
Other Parts Discussed in Thread: TMDSCNCD28388D
We have just installed Code composer studio V20 and are having trouble running an existing program on the TMDSCNCD28388D evaluation board.
We are observing the following:
  • When launching the app, there is no compatible board detected while the board is present.
  • When using the detect my board function in the resource explorer, we are getting an error.
  • When clicking on debug, the app get stucked on the starting CCS debug session.
Could it be that your new version need to perform some write operation to location in system files other than the workspace folder ?
In which case this would be a problem for big companies with stringent security restrictions.
Clément
    This board has an onboard XDS100v2. Auto-detect is typically only supported on newer launchpads/kits with an onboard XDS110 or MSP430 based kits.
    As for your other issues:
    Yes, there are several folders inside your user directory that CCS uses to cache information. It likely also needs write access to the CCS installation folder and it will install new packages inside c:\ti by default. Are any of these locations potential issues?
    ki
    Oh ok, understood for the board.
    Writing to the user directory should be fine, is the write access to the CCS installation folder needed for debug to run ?
    Because yes, the tool won't have write access to that location due to security restrictions from our IT.
    So far I haven't been able to get the debug to run so there must be some restriction that is blocking, issue is to know what.
    Clément
  • Writing to the user directory should be fine, is the write access to the CCS installation folder needed for debug to run ?
    There are some files that are generated inside the CCS installation folder. I'm not sure if it is specifically related to debug launches. But we require users to allows CCS write access to the installation folder. Can IT allow CCS write access and see if that helps?
  • I'll investigate but I am not sure it will be possible.
    Why did you change that compared to previous CSS versions ?
    Also, do you know which folders should be writable ?
  • Previous CCS versions have also required write access to the installation folder. Perhaps more current CCS versions have more a dependency on this.
    There are several, for example one is in the cloudagent folder:
    For this issue:
    Can you generate a debug server log and attach to this thread?
    https://software-dl.ti.com/ccs/esd/documents/ccs_diagnostic-logs.html
    ki
  • Well we did have issue on some feature in the past (e.g. updates) but this were not features we really cared about as they were not blocking for development/debug.
    I tried generating a debug log, I got blocked at first, the tool does not not seem to be able to create a new log file if the file is not created manually in the filesystem .
    0x0000634C 0 3  JSON R: {"response":4}
    0x0000634C 1 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x00006388 1 3  WBSKT D: [2025-01-15 09:05:27] [frame_header] Dispatching write containing 1 message(s) containing 2 header bytes and 14 payload bytes
    0x00006388 1 3  WBSKT D: [2025-01-15 09:05:27] [frame_header] Header Bytes:
    [0] (2) 81 0E
    0x00006388 1 3  WBSKT D: [2025-01-15 09:05:27] [frame_payload] Payload Bytes:
    [0] (14) [1] {"response":4}
    0x0000634C 5002 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 10003 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 13664 3  JSON C: {"command":"debuggerSettings.createFromConfigFile","id":5,"data":["1736928341399:1:","C:\\Users\\a871258\\AppData\\Local\\Temp\\ti_cloud_storage\\TMS320F28386D.ccxml"]}
    0x0000634C 15642 3  SETUP C: OpenDatabase( C:\Users\a871258\AppData\Local\TEXASI~1\CCS\ccs2000\0\0\targetdb.dat, C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\common\targetdb\timestamp )
    0x0000634C 15649 3  SETUP I: SELECT sql FROM sqlite_master ORDER BY tbl_name, name
    0x0000634C 15649 3  SETUP R: OpenDatabase( C:\Users\a871258\AppData\Local\TEXASI~1\CCS\ccs2000\0\0\targetdb.dat, C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\common\targetdb\timestamp ) = 0000026A9F3CBAE0
    0x0000634C 15649 3  SETUP I: Loading repository "C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\common\targetdb\"
    0x0000634C 15649 3  SETUP I: SELECT * FROM TargetDB_Repositories
    0x0000634C 15651 3  SETUP I: SELECT * FROM TargetDB_Repositories WHERE dbid=1
    0x0000634C 15652 3  SETUP I: PRAGMA journal_mode = MEMORY
    0x0000634C 15652 3  SETUP I: PRAGMA synchronous = OFF
    0x0000634C 15652 3  SETUP I: BEGIN IMMEDIATE TRANSACTION
    0x0000634C 15664 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_0_regids.xml"
    0x0000634C 15666 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=1
    0x0000634C 15666 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_PC_0_regids.xml"
    0x0000634C 15668 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=2
    0x0000634C 15669 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_C_regids.xml"
    0x0000634C 15670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=3
    0x0000634C 15671 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_D_regids.xml"
    0x0000634C 15672 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=4
    0x0000634C 15673 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_M_regids.xml"
    0x0000634C 15675 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=5
    0x0000634C 15675 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="MSP430_regids.xml"
    0x0000634C 15677 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=6
    0x0000634C 15678 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="regids_mapping.xml"
    0x0000634C 15680 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=7
    0x0000634C 15681 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2000_regids.xml"
    0x0000634C 15682 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=8
    0x0000634C 15683 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2001_regids.xml"
    0x0000634C 15684 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=9
    0x0000634C 15685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2002_regids.xml"
    0x0000634C 15687 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=10
    0x0000634C 15687 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2003_regids.xml"
    0x0000634C 15689 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=11
    0x0000634C 15690 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2004_regids.xml"
    0x0000634C 15692 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=12
    0x0000634C 15692 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2005_regids.xml"
    0x0000634C 15694 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=13
    0x0000634C 15695 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2006_regids.xml"
    0x0000634C 15697 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=14
    0x0000634C 15697 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2007_regids.xml"
    0x0000634C 15699 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=15
    0x0000634C 15700 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2008_regids.xml"
    0x0000634C 15701 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=16
    0x0000634C 15702 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2010_regids.xml"
    0x0000634C 15704 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=17
    0x0000634C 15704 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2011_regids.xml"
    0x0000634C 15706 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=18
    0x0000634C 15707 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2012_regids.xml"
    0x0000634C 15708 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=19
    0x0000634C 15709 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2013_regids.xml"
    0x0000634C 15711 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=20
    0x0000634C 15712 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2014_regids.xml"
    0x0000634C 15713 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=21
    0x0000634C 15714 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2015_regids.xml"
    0x0000634C 15715 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=22
    0x0000634C 15716 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2026_regids.xml"
    0x0000634C 15718 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=23
    0x0000634C 15718 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2027_regids.xml"
    0x0000634C 15720 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=24
    0x0000634C 15721 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2028_regids.xml"
    0x0000634C 15723 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=25
    0x0000634C 15723 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2029_regids.xml"
    0x0000634C 15725 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=26
    0x0000634C 15726 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2030_regids.xml"
    0x0000634C 15727 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=27
    0x0000634C 15728 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2031_regids.xml"
    0x0000634C 15730 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=28
    0x0000634C 15730 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2032_regids.xml"
    0x0000634C 15732 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=29
    0x0000634C 15732 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C00_regids.xml"
    0x0000634C 15734 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=30
    0x0000634C 15734 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C100_regids.xml"
    0x0000634C 15736 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=31
    0x0000634C 15736 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C28XX_regids.xml"
    0x0000634C 15738 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=32
    0x0000634C 15739 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C29XX_regids.xml"
    0x0000634C 15741 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=33
    0x0000634C 15741 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C55XX_regids.xml"
    0x0000634C 15743 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=34
    0x0000634C 15744 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C64XX_regids.xml"
    0x0000634C 15745 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=35
    0x0000634C 15746 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C66XX_regids.xml"
    0x0000634C 15748 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=36
    0x0000634C 15748 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C674X_regids.xml"
    0x0000634C 15750 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=37
    0x0000634C 15750 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C6XXX_regids.xml"
    0x0000634C 15752 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=38
    0x0000634C 15753 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C71XX_regids.xml"
    0x0000634C 15755 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=39
    0x0000634C 15755 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C75XX_regids.xml"
    0x0000634C 15757 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=40
    0x0000634C 15758 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS3CXX_regids.xml"
    0x0000634C 15759 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=41
    0x0000634C 15760 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R15X_regids.xml"
    0x0000634C 15762 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=42
    0x0000634C 15762 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R25X_regids.xml"
    0x0000634C 15764 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=43
    0x0000634C 15764 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R2X_regids.xml"
    0x0000634C 15766 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=44
    0x0000634C 15767 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R33X_regids.xml"
    0x0000634C 15768 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=45
    0x0000634C 15769 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R4X_regids.xml"
    0x0000634C 15771 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=46
    0x0000634C 15771 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R53X_regids.xml"
    0x0000634C 15773 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=47
    0x0000634C 15773 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R7X_regids.xml"
    0x0000634C 15775 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=48
    0x0000634C 15776 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R9X_regids.xml"
    0x0000634C 15777 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=49
    0x0000634C 15778 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RAX_regids.xml"
    0x0000634C 15780 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=50
    0x0000634C 15780 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RCX_regids.xml"
    0x0000634C 15782 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=51
    0x0000634C 15782 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RDX_regids.xml"
    0x0000634C 15784 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=52
    0x0000634C 15784 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470REX_regids.xml"
    0x0000634C 15786 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=53
    0x0000634C 15787 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RXX_regids.xml"
    0x0000634C 15788 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=54
    0x0000634C 15789 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C40XX_regids.xml"
    0x0000634C 15790 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=55
    0x0000634C 15791 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C41XX_regids.xml"
    0x0000634C 15793 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=56
    0x0000634C 15793 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C4X_regids.xml"
    0x0000634C 15795 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=57
    0x0000634C 15795 3  SETUP I: END TRANSACTION
    0x0000634C 15795 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
    0x0000634C 15795 3  SETUP I: Scrubbing database
    0x0000634C 16102 3  SETUP I: Loading file "C:\Users\a871258\AppData\Local\TEXASI~1\CCS\ccs2000\0\0\12614468752239429983.cache"
    0x0000634C 16102 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="12614468752239429983.cache"
    0x0000634C 16104 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=58
    0x0000634C 16104 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
    0x0000634C 16105 3  SETUP I: SELECT Systems.dbid FROM Systems, TargetDB_Files WHERE Systems.Source_File = TargetDB_Files.dbid AND TargetDB_Files.dbid = 58
    0x0000634C 16105 3  SETUP I: SELECT * FROM Systems WHERE dbid=1
    0x0000634C 16136 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 0000026AA1521E78)
    0x0000634C 16144 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16145 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16145 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 0000026AA13AD008)
    0x0000634C 16149 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16149 3  JSON R: {"data":{"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/Cortex_M4_0","propertyId":"HaltOnConnect","value":true},"event":"debuggerSettings.propertyChanged"}
    0x0000634C 16149 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16149 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x00006388 16149 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 1 message(s) containing 4 header bytes and 184 payload bytes
    0x00006388 16149 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Header Bytes:
    [0] (4) 81 7E 00 B8
    0x00006388 16149 3  WBSKT D: [2025-01-15 09:05:43] [frame_payload] Payload Bytes:
    [0] (184) [1] {"data":{"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/Cortex_M4_0","propertyId":"HaltOnConnect","value":true},"event":"debuggerSettings.propertyChanged"}
    0x0000634C 16149 3  JSON R: {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/Cortex_M4_0","propertyId":"HaltOnConnect"},"event":"debuggerSettings.disableStatusChanged"}
    0x0000634C 16149 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x00006388 16149 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 2 message(s) containing 8 header bytes and 377 payload bytes
    0x00006388 16150 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Header Bytes:
    [0] (4) 81 7E 00 B8
    [1] (4) 81 7E 00 C1
    0x00006388 16150 3  WBSKT D: [2025-01-15 09:05:43] [frame_payload] Payload Bytes:
    [1] (193) [1] {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/Cortex_M4_0","propertyId":"HaltOnConnect"},"event":"debuggerSettings.disableStatusChanged"}
    0x00006388 16150 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 1 message(s) containing 4 header bytes and 193 payload bytes
    [0] (4) 81 7E 00 C1
    [0] (193) [1] {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/Cortex_M4_0","propertyId":"HaltOnConnect"},"event":"debuggerSettings.disableStatusChanged"}
    0x0000634C 16153 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x0000634C 16153 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x0000634C 16153 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 0000026AA13AB528)
    0x0000634C 16161 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16161 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16161 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 0000026AA134F4E8)
    0x0000634C 16169 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16169 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16169 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 0000026A9F3E12B8)
    0x0000634C 16174 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x0000634C 16174 3  JSON R: {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","propertyId":"AllowInterruptsWhenHalted"},"event":"debuggerSettings.disableStatusChanged"}
    0x0000634C 16174 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x0000634C 16174 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x00006388 16174 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 1 message(s) containing 4 header bytes and 204 payload bytes
    0x00006388 16174 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Header Bytes:
    [0] (4) 81 7E 00 CC
    0x00006388 16174 3  WBSKT D: [2025-01-15 09:05:43] [frame_payload] Payload Bytes:
    [0] (204) [1] {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","propertyId":"AllowInterruptsWhenHalted"},"event":"debuggerSettings.disableStatusChanged"}
    0x0000634C 16174 3  JSON R: {"data":{"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","propertyId":"HaltOnConnect","value":true},"event":"debuggerSettings.propertyChanged"}
    0x0000634C 16174 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16174 3  JSON R: {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","propertyId":"HaltOnConnect"},"event":"debuggerSettings.disableStatusChanged"}
    0x00006388 16174 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 3 message(s) containing 12 header bytes and 579 payload bytes
    [0] (4) 81 7E 00 CC
    [1] (4) 81 7E 00 B7
    [2] (4) 81 7E 00 C0
    [1] (183) [1] {"data":{"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","propertyId":"HaltOnConnect","value":true},"event":"debuggerSettings.propertyChanged"}
    [2] (192) [1] {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","propertyId":"HaltOnConnect"},"event":"debuggerSettings.disableStatusChanged"}
    0x00006388 16175 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 2 message(s) containing 8 header bytes and 375 payload bytes
    0x00006388 16175 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Header Bytes:
    [0] (4) 81 7E 00 B7
    [1] (4) 81 7E 00 C0
    0x00006388 16175 3  WBSKT D: [2025-01-15 09:05:43] [frame_payload] Payload Bytes:
    [0] (183) [1] {"data":{"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","propertyId":"HaltOnConnect","value":true},"event":"debuggerSettings.propertyChanged"}
    [1] (192) [1] {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","propertyId":"HaltOnConnect"},"event":"debuggerSettings.disableStatusChanged"}
    0x0000634C 16182 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16182 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16182 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 0000026AA1301EE8)
    0x0000634C 16190 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16190 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16190 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 0000026AA13FEE08)
    0x0000634C 16195 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x0000634C 16195 3  JSON R: {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1","propertyId":"AllowInterruptsWhenHalted"},"event":"debuggerSettings.disableStatusChanged"}
    0x0000634C 16195 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x0000634C 16195 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x00006388 16195 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 1 message(s) containing 4 header bytes and 204 payload bytes
    0x00006388 16195 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Header Bytes:
    [0] (4) 81 7E 00 CC
    0x00006388 16195 3  WBSKT D: [2025-01-15 09:05:43] [frame_payload] Payload Bytes:
    [0] (204) [1] {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1","propertyId":"AllowInterruptsWhenHalted"},"event":"debuggerSettings.disableStatusChanged"}
    0x0000634C 16195 3  JSON R: {"data":{"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1","propertyId":"HaltOnConnect","value":true},"event":"debuggerSettings.propertyChanged"}
    0x0000634C 16195 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
    0x0000634C 16195 3  JSON R: {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1","propertyId":"HaltOnConnect"},"event":"debuggerSettings.disableStatusChanged"}
    0x00006388 16195 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 3 message(s) containing 12 header bytes and 579 payload bytes
    [0] (4) 81 7E 00 CC
    [1] (4) 81 7E 00 B7
    [2] (4) 81 7E 00 C0
    [1] (183) [1] {"data":{"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1","propertyId":"HaltOnConnect","value":true},"event":"debuggerSettings.propertyChanged"}
    [2] (192) [1] {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1","propertyId":"HaltOnConnect"},"event":"debuggerSettings.disableStatusChanged"}
    0x00006388 16196 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 2 message(s) containing 8 header bytes and 375 payload bytes
    0x00006388 16196 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Header Bytes:
    [0] (4) 81 7E 00 B7
    [1] (4) 81 7E 00 C0
    0x00006388 16196 3  WBSKT D: [2025-01-15 09:05:43] [frame_payload] Payload Bytes:
    [0] (183) [1] {"data":{"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1","propertyId":"HaltOnConnect","value":true},"event":"debuggerSettings.propertyChanged"}
    [1] (192) [1] {"data":{"disabled":false,"propertiesKey":"1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1","propertyId":"HaltOnConnect"},"event":"debuggerSettings.disableStatusChanged"}
    0x0000634C 16201 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x0000634C 16201 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnDisableStatusChanged()
    0x0000634C 16201 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 0000026AA1403D68)
    0x0000634C 16206 3  JSON R: {"data":{"cores":["1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/Cortex_M4_0","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/CPU2_CLA1","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/CPU1_CLA1","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1"],"nonDebugCores":["1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/JLM","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/CS_DAP_0","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/IcePick_C_0"]},"response":5}
    0x0000634C 16206 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x00006388 16206 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Dispatching write containing 1 message(s) containing 4 header bytes and 618 payload bytes
    0x00006388 16206 3  WBSKT D: [2025-01-15 09:05:43] [frame_header] Header Bytes:
    [0] (4) 81 7E 02 6A
    0x00006388 16206 3  WBSKT D: [2025-01-15 09:05:43] [frame_payload] Payload Bytes:
    [0] (618) [1] {"data":{"cores":["1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/Cortex_M4_0","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/CPU2_CLA1","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU2","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/CPU1_CLA1","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/C28xx_CPU1"],"nonDebugCores":["1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/JLM","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/CS_DAP_0","1736928341399:1:Texas Instruments XDS100v2 USB Debug Probe/IcePick_C_0"]},"response":5}
    0x0000634C 21210 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 26225 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 31233 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 36238 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 41251 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 46265 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 51269 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 56277 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 61291 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 66303 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 71305 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 76310 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 81316 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 86324 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 91325 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 96326 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 101326 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 106341 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 111352 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 116365 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 121379 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 126389 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 131390 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 136391 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 141393 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 146405 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
    0x0000634C 151408 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::CommandSink
  • Thank you for the log. Engineering is currently investigating the issue. I'll pass on any updates as I receive them.
    Any news ?
    Clément
  • Sorry for the delay in response. Engineering has analyzed the logs but it didn't have any specific information that would help us debug this issue.
    They also tried to prevent write access to the whole CCS install directory. They did run into one issue and a ticket has been filed to address it so it is not dependent on write access to the CCS installation directory.
    https://sir.ext.ti.com/jira/browse/EXT_EP-12180
    However, it seems unrelated to the debug launch issue. We are trying some more experiments.
    Can you try deleting the cache files mentioned in: https://software-dl.ti.com/ccs/esd/documents/users_guide_ccs/ccs_faqs.html#i-want-to-restart-code-composer-studio-with-a-fresh-environment-how-do-i-do-this
  • No worries.
    I just followed what you linked but it's still stuck... Disappointed
  • Engineering does not feel that the lack of write access should block your debug launch.
    Please try clearing out the caches in your user folder:
    If that does not help, can your try installing the latest CCS 20.0.2?
  • I had already tried clearing the cache as pointed out in your previous message but it didn't work.
    I tried again, same result.
    I'll see with the IT if we can get the new version installed, I'll keep you updated.
  • Can you try generating a debug server log again? But this time, enable it from the command line BEFORE you launch CCS. Then launch CCS and try to start a debug session again. Apparently there may be some additional debug message that can be captured when CCS IDE is first launching up so we would need the logging enabled before launching CCS.
    In the below link:
    Look for the "Command Line" section under "Debug Server Logs".
    ki
  • Here you go:
    4645.export.log
    It also auto generated this file:
    2025-01-29T07:18:21.632Z: Overridden Proxy =
    2025-01-29T07:18:21.799Z: main: Staring directory = C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\cloudagent\src
    2025-01-29T07:18:21.800Z: Starting Agent!
    2025-01-29T07:18:22.060Z: Discovered Module : DeviceDetector
    2025-01-29T07:18:22.070Z: Discovered Module : DS
    2025-01-29T07:18:22.075Z: Discovered Module : EventBroker
    2025-01-29T07:18:22.088Z: Discovered Module : File
    2025-01-29T07:18:27.149Z: Discovered Module : Tirex
    2025-01-29T07:18:27.170Z: rov_server_redirect: looking in: C:\Tools\AH-Applications\ti\ccs2000\ccs\eclipse\dropins
    2025-01-29T07:18:27.176Z: rov_server_redirect: looking in: C:\Tools\AH-Applications\ti\ccs2000\ccs\eclipse\plugins
    2025-01-29T07:18:27.181Z: rov_server_redirect: looking in: C:\Tools\AH-Applications\ti\ccs2000\ccs\eclipse\Eclipse.app\Contents\Eclipse\dropins
    2025-01-29T07:18:27.190Z: rov_server_redirect: looking in: C:\Tools\AH-Applications\ti\ccs2000\ccs\eclipse\Eclipse.app\Contents\Eclipse\plugins
    2025-01-29T07:18:27.192Z: Failed to load module : rov_server_redirect.js : Error: rov_server.js was not found (this is expected in cloud)
        at Object.<anonymous> (C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\cloudagent\src\modules\rov_server_redirect.js:65:11)
        at Module._compile (node:internal/modules/cjs/loader:1254:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
        at Module.load (node:internal/modules/cjs/loader:1117:32)
        at Module._load (node:internal/modules/cjs/loader:958:12)
        at Module.require (node:internal/modules/cjs/loader:1141:19)
        at require (node:internal/modules/cjs/helpers:110:18)
        at C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\cloudagent\src\host_agent.js:95:42
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2025-01-29T07:18:28.068Z: Discovered Module : Serial
    2025-01-29T07:18:28.071Z: Discovered Module : TargetSupport
    2025-01-29T07:18:28.075Z: Discovered Module : USB
    2025-01-29T07:18:28.106Z: Discovered Module : USB-HID
    2025-01-29T07:18:28.108Z: Set up lazy-loading for module : DSUtils
    2025-01-29T07:18:28.110Z: Agent main module running on port 56419
    2025-01-29T07:18:28.118Z: Module( Agent )->[wss.onConnection]
    2025-01-29T07:18:28.123Z: Module( Agent )->[wss.onConnection]
    2025-01-29T07:18:28.125Z: Module( Agent )->[ws.onMessage]{"command":"listCommands","id":1,"data":[]}
    2025-01-29T07:18:28.126Z: Module( Agent )->[ResponseHandler]{"data":{"commands":["listSubModules","createSubModule","listCommands","addConfigProperty","registerModuleWebSocket","registerModuleByPath"]},"response":1}
    2025-01-29T07:18:28.129Z: Module( Agent )->[ws.onMessage]{"command":"addConfigProperty","id":2,"data":["cloudAgentInstallerServerURL","http://localhost:56357/ticloudagent"]}
    2025-01-29T07:18:28.131Z: Setting property cloudAgentInstallerServerURL : http://localhost:56357/ticloudagent
    2025-01-29T07:18:28.132Z: Module( Agent )->[ResponseHandler]{"response":2}
    2025-01-29T07:18:28.134Z: Module( Agent )->[ws.onMessage]{"command":"createSubModule","id":3,"data":["DeviceDetector"]}
    2025-01-29T07:18:28.135Z: Module( Agent )->Creating new module (module id: 1)
    2025-01-29T07:18:28.187Z: detected usb id 0bda_8153
    2025-01-29T07:18:28.188Z: detected usb id 0424_2807
    2025-01-29T07:18:28.189Z: detected usb id 2109_0820
    2025-01-29T07:18:28.190Z: detected usb id 0424_5807
    2025-01-29T07:18:28.191Z: detected usb id 8086_15ec
    2025-01-29T07:18:28.192Z: detected usb id 8087_0026
    2025-01-29T07:18:28.193Z: detected usb id 06cb_00f0
    2025-01-29T07:18:28.194Z: detected usb id 8087_0aca
    2025-01-29T07:18:28.195Z: detected usb id 8086_43ed
    2025-01-29T07:18:28.196Z: detected usb id 8086_7360
    2025-01-29T07:18:28.197Z: detected usb id 8087_0af1
    2025-01-29T07:18:28.198Z: detected usb id 03f0_0269
    2025-01-29T07:18:28.199Z: detected usb id 03f0_0667
    2025-01-29T07:18:28.200Z: detected usb id 2109_2820
    2025-01-29T07:18:28.201Z: detected usb id 2109_8888
    2025-01-29T07:18:28.202Z: detected usb id 30c9_000f
    2025-01-29T07:18:28.203Z: detected usb id 8086_9a17
    2025-01-29T07:18:28.203Z: detected usb id 0403_a6d0
    2025-01-29T07:18:28.204Z: detected usb id 8087_0ac9
    2025-01-29T07:18:28.233Z: Module( Agent )->[ResponseHandler]{"data":{"port":56423},"response":3}
    2025-01-29T07:18:28.234Z: Module( Agent )->[ws.onMessage]{"command":"createSubModule","id":4,"data":["Tirex"]}
    2025-01-29T07:18:28.236Z: Module( Agent )->Creating new module (module id: 2)
    2025-01-29T07:18:28.237Z: Module( Agent )->[ws.onMessage]{"command":"createSubModule","id":5,"data":["DS"]}
    2025-01-29T07:18:28.238Z: Module( Agent )->Creating new module (module id: 3)
    2025-01-29T07:18:28.239Z: Starting DS!!!!!
    2025-01-29T07:18:28.241Z: spawnDS : execFile = ./DSLite cwd = C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\DebugServer\bin
    2025-01-29T07:18:28.242Z: args =
    2025-01-29T07:18:28.279Z: Module( Agent )->[ws.onMessage]{"command":"createSubModule","id":6,"data":["EventBroker"]}
    2025-01-29T07:18:28.281Z: Module( Agent )->Creating new module (module id: 4)
    2025-01-29T07:18:28.284Z: Module( Agent )->[ResponseHandler]{"data":{"port":56425},"response":4}
    2025-01-29T07:18:28.285Z: Module( Agent )->[ResponseHandler]{"data":{"port":56426},"response":6}
    2025-01-29T07:18:28.288Z: Module( DeviceDetector )->[wss.onConnection]
    2025-01-29T07:18:28.291Z: Module( Tirex )->[wss.onConnection]
    2025-01-29T07:18:28.292Z: Module( Tirex )->[ws.onMessage]{"command":"listCommands","id":1,"data":[]}
    2025-01-29T07:18:28.293Z: Module( Tirex )->[ResponseHandler]{"data":{"commands":["listSubModules","createSubModule","listCommands","triggerEvent","getProxy","init","getEntryModuleType","getCCSEclipseInitValues","getPackageInstallInfo","getInstalledPackages","getProgress","clearTaskProgress","installPackage","uninstallPackage","getCcsDevices","getCcsDeviceDetail","getProjectTemplates","importProject","importProjectTemplate","openExternally","openFilePath","onProductsChanged","startupDesktopServer","getBoardAndDeviceInfo","getInstallInfoForPackageDependencies","getInstallInfoForPackages","getConfig","getVersion","getLocalInfo"]},"response":1}
    2025-01-29T07:18:28.295Z: Module( EventBroker )->[wss.onConnection]
    2025-01-29T07:18:28.297Z: Module( DeviceDetector )->[ws.onMessage]{"command":"listCommands","id":1,"data":[]}
    2025-01-29T07:18:28.298Z: Module( DeviceDetector )->[ResponseHandler]{"data":{"commands":["listSubModules","createSubModule","listCommands","detectDebugProbes","detectDevice","detectDeviceWithProbe","identifyProbe","filesNeeded","populateDeviceList"]},"response":1}
    2025-01-29T07:18:28.299Z: Module( Tirex )->[ws.onMessage]{"command":"getConfig","id":2,"data":[]}
    2025-01-29T07:18:28.302Z: Module( Tirex )->[ws.onMessage]{"command":"getConfig","id":3,"data":[]}
    2025-01-29T07:18:28.303Z: Module( EventBroker )->[ws.onMessage]{"command":"listCommands","id":1,"data":[]}
    2025-01-29T07:18:28.304Z: Module( EventBroker )->[ResponseHandler]{"data":{"commands":["listSubModules","createSubModule","listCommands","fireEvent","registerData","fetchData"]},"response":1}
    2025-01-29T07:18:28.306Z: Module( DeviceDetector )->[ws.onMessage]{"command":"detectDebugProbes","id":2,"data":[]}
    2025-01-29T07:18:28.308Z: Module( DeviceDetector )->[ResponseHandler]{"data":{"probes":[{"connectionXml":"TIXDS100v2_Connection","id":"0"}]},"response":2}
    2025-01-29T07:18:28.309Z: Module( EventBroker )->[ws.onMessage]{"command":"registerData","id":2,"data":["activeCore",{}]}
    2025-01-29T07:18:28.311Z: Module( EventBroker )->[ResponseHandler]{"response":2}
    2025-01-29T07:18:28.312Z: Module( DeviceDetector )->[ws.onMessage]{"command":"detectDeviceWithProbe","id":3,"data":[{"connectionXml":"TIXDS100v2_Connection","id":"0"}]}
    2025-01-29T07:18:28.313Z: Module( DeviceDetector )->[ResponseHandler]{"data":{},"response":3}
    2025-01-29T07:18:28.315Z: Module( EventBroker )->[ws.onMessage]{"command":"registerData","id":3,"data":["debugSession",{}]}
    2025-01-29T07:18:28.316Z: Module( EventBroker )->[ResponseHandler]{"response":3}
    2025-01-29T07:18:28.323Z: Module( Tirex )->[ResponseHandler]{"data":{"preset":"","mode":"localserver","myHttpPort":"0","myRole":"","dbTablePrefix":"tirex","dbUseMode":"sqlite","webComponentsServer":"","ccsCloudUrl":"","remoteBundleZips":"https://software-dl.ti.com/ccs/esd/tirex/zips/","localBundleZips":"C:\\Users\\a871258\\ccs-cloud-storage\\ti-rex\\git\\zips","sysconfigTestServerURL":"","contentPath":"C:\\ti","dbPath":"C:\\Users\\a871258\\tmp\\tirex\\invalid-db-path","seoPath":"ti-rex\\seo","dbResourcePrefix":"/tirex","serveContentFromFs":true,"contentPackagesConfig":"C:\\Users\\a871258\\tmp\\tirex\\invalid-content-packages-config-path","refreshDB":"false","allowRefreshFromWeb":"false","seaportHostIP":"","seaportPort":"","mailingList":"","handoffServer":false,"useConsole":"false","useFakeRoutes":false,"enableMetricsMiddleware":false,"testingServer":false,"serverMode":"https","handoffChecklistsFolder":"C:\\Users\\a871258\\ccs-cloud-storage\\ti-rex\\handoffChecklists","buHandoffTestingServer":false,"//comments":["myHttpPort of 0 will auto assign port",
    2025-01-29T07:18:28.324Z: Module( Tirex )->[ResponseHandler]{"data":{"preset":"","mode":"localserver","myHttpPort":"0","myRole":"","dbTablePrefix":"tirex","dbUseMode":"sqlite","webComponentsServer":"","ccsCloudUrl":"","remoteBundleZips":"https://software-dl.ti.com/ccs/esd/tirex/zips/","localBundleZips":"C:\\Users\\a871258\\ccs-cloud-storage\\ti-rex\\git\\zips","sysconfigTestServerURL":"","contentPath":"C:\\ti","dbPath":"C:\\Users\\a871258\\tmp\\tirex\\invalid-db-path","seoPath":"ti-rex\\seo","dbResourcePrefix":"/tirex","serveContentFromFs":true,"contentPackagesConfig":"C:\\Users\\a871258\\tmp\\tirex\\invalid-content-packages-config-path","refreshDB":"false","allowRefreshFromWeb":"false","seaportHostIP":"","seaportPort":"","mailingList":"","handoffServer":false,"useConsole":"false","useFakeRoutes":false,"enableMetricsMiddleware":false,"testingServer":false,"serverMode":"https","handoffChecklistsFolder":"C:\\Users\\a871258\\ccs-cloud-storage\\ti-rex\\handoffChecklists","buHandoffTestingServer":false,"//comments":["myHttpPort of 0 will auto assign port",
    2025-01-29T07:18:28.329Z: Module( Tirex )->[ws.onMessage]{"command":"init","id":4,"data":[{"ccsPort":"56357","proxy":"http://proxy-ec.eu.eurocopter.corp:8080;DIRECT","isTheia":true}]}
    2025-01-29T07:18:28.331Z: Module( Tirex )->[ws.onMessage]{"command":"init","id":5,"data":[{"ccsPort":"56357","proxy":"http://proxy-ec.eu.eurocopter.corp:8080;DIRECT","isTheia":true}]}
    2025-01-29T07:18:28.338Z: tirex4: {"name":"tirex-cloudagent-module","message":"httpProxy http://proxy-ec.eu.eurocopter.corp:8080;DIRECT httpsProxy http://proxy-ec.eu.eurocopter.corp:8080;DIRECT\n","tags":[]}
    2025-01-29T07:18:28.339Z: tirex4: {"name":"tirex-cloudagent-module","message":"process.env values (final): HTTP_PROXY http://proxy-ec.eu.eurocopter.corp:8080;DIRECT NO_PROXY localhost,127.0.0.1,.toro.design.ti.com,.dhcp.ti.com HTTPS_PROXY http://proxy-ec.eu.eurocopter.corp:8080;DIRECT\n","tags":[]}
    2025-01-29T07:18:28.357Z: Module( Tirex )->[triggerEvent]{"event":"OnProgressUpdated","data":{"1":{"subActivity":"","progressType":"Indefinite","isFirstUpdate":true,"isComplete":false,"error":null,"name":"Scanning for file system changes"}}}
    2025-01-29T07:18:28.358Z: tirex4: {"name":"tirex-cloudagent-module","message":"Registered task with progressId 1 and initialProgress {\"progressType\":\"Indefinite\"}\n","tags":[]}
    2025-01-29T07:18:28.376Z: Module( Tirex )->[ResponseHandler]{"response":4}
    2025-01-29T07:18:28.377Z: Module( Tirex )->[ResponseHandler]{"response":5}
    2025-01-29T07:18:28.383Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackages","id":6,"data":[{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:28.386Z: Module( Tirex )->[ws.onMessage]{"command":"getConfig","id":7,"data":[]}
    2025-01-29T07:18:28.387Z: Module( Tirex )->[ResponseHandler]{"data":{"preset":"","mode":"localserver","myHttpPort":"0","myRole":"","dbTablePrefix":"tirex","dbUseMode":"sqlite","webComponentsServer":"","ccsCloudUrl":"","remoteBundleZips":"https://software-dl.ti.com/ccs/esd/tirex/zips/","localBundleZips":"C:\\Users\\a871258\\ccs-cloud-storage\\ti-rex\\git\\zips","sysconfigTestServerURL":"","contentPath":"C:\\ti","dbPath":"C:\\Users\\a871258\\tmp\\tirex\\invalid-db-path","seoPath":"ti-rex\\seo","dbResourcePrefix":"/tirex","serveContentFromFs":true,"contentPackagesConfig":"C:\\Users\\a871258\\tmp\\tirex\\invalid-content-packages-config-path","refreshDB":"false","allowRefreshFromWeb":"false","seaportHostIP":"","seaportPort":"","mailingList":"","handoffServer":false,"useConsole":"false","useFakeRoutes":false,"enableMetricsMiddleware":false,"testingServer":false,"serverMode":"https","handoffChecklistsFolder":"C:\\Users\\a871258\\ccs-cloud-storage\\ti-rex\\handoffChecklists","buHandoffTestingServer":false,"//comments":["myHttpPort of 0 will auto assign port",
    2025-01-29T07:18:28.392Z: Module( Tirex )->[ws.onMessage]{"command":"getBoardAndDeviceInfo","id":8,"data":[]}
    2025-01-29T07:18:28.397Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:28.451Z: tirex4: {"name":"tirex-cloudagent-module","message":"Ide packages reported: [{\"name\":\"SysConfig\",\"packagePublicId\":\"sysconfig\",\"packageVersion\":\"1.22.0\",\"packagePublicUid\":\"sysconfig__1.22.0\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"subType\":null,\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]},{\"name\":\"AM2x Arm®-based MCU Device Support Files\",\"packagePublicId\":\"ARM-MCU-DEVICE-SUPPORT\",\"packageVersion\":\"1.3.10\",\"packagePublicUid\":\"ARM-MCU-DEVICE-SUPPORT__1.3.10\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]},{\"name\":\"AM2x Arm®-based MCU Feature Support\",\"packagePublicId\":\"ARM-MCU-FEATURE\",\"packageVersion\":\"1.3.10\",\"packagePublicUid\":\"ARM-MCU-FEATURE__1.3.10\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":\"deviceSupport\",\"ccsVersion\":\"^1.4\",\"dependencies\":[{\"packagePublicId\":\"ARM-MCU-DEVICE-SUPPORT\",\"versionRange\":\"1.3.10\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"Arm®-based Processors Device Support Files\",\"packagePublicId\":\"SITARA-MPU-DEVICE-SUPPORT\",\"packageVersion\":\"1.6.7\",\"packagePublicUid\":\"SITARA-MPU-DEVICE-SUPPORT__1.6.7\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]},{\"name\":\"Arm®-based Processors Feature Support\",\"packagePublicId\":\"SITARA-MPU-FEATURE\",\"packageVersion\":\"1.6.7\",\"packagePublicUid\":\"SITARA-MPU-FEATURE__1.6.7\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":\"deviceSupport\",\"ccsVersion\":\"^1.4\",\"dependencies\":[{\"packagePublicId\":\"SITARA-MPU-DEVICE-SUPPORT\",\"versionRange\":\"1.6.7\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"TDAx DRAx J7x Auto Device Support Files\",\"packagePublicId\":\"AUTO-DEVICE-SUPPORT\",\"packageVersion\":\"1.1.17\",\"packagePublicUid\":\"AUTO-DEVICE-SUPPORT__1.1.17\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]},{\"name\":\"TDAx DRAx J7x Auto Feature Support\",\"packagePublicId\":\"AUTO-FEATURE\",\"packageVersion\":\"1.1.17\",\"packagePublicUid\":\"AUTO-FEATURE__1.1.17\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":\"deviceSupport\",\"ccsVersion\":\"^1.4\",\"dependencies\":[{\"packagePublicId\":\"AUTO-DEVICE-SUPPORT\",\"versionRange\":\"1.1.17\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"C2000 Device Support Files\",\"packagePublicId\":\"C2000-DEVICE-SUPPORT\",\"packageVersion\":\"6.23.1.0\",\"packagePublicUid\":\"C2000-DEVICE-SUPPORT__6.23.1.0\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]},{\"name\":\"C2000 Feature Support\",\"packagePublicId\":\"C2000-FEATURE\",\"packageVersion\":\"6.23.1.0\",\"packagePublicUid\":\"C2000-FEATURE__6.23.1.0\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":\"deviceSupport\",\"ccsVersion\":\"^1.2\",\"dependencies\":[{\"packagePublicId\":\"C2000-DEVICE-SUPPORT\",\"versionRange\":\"6.23.1.0\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"C29 Device Support Files\",\"packagePublicId\":\"C29-DEVICE-SUPPORT\",\"packageVersion\":\"1.2.2.0\",\"packagePublicUid\":\"C29-DEVICE-SUPPORT__1.2.2.0\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]},{\"name\":\"C29 Feature Support\",\"packagePublicId\":\"C29-FEATURE\",\"packageVersion\":\"1.2.2.0\",\"packagePublicUid\":\"C29-FEATURE__1.2.2.0\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":\"deviceSupport\",\"ccsVersion\":\"^1.5\",\"dependencies\":[{\"packagePublicId\":\"C29-DEVICE-SUPPORT\",\"versionRange\":\"1.2.2.0\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"IDE Core Feature\",\"packagePublicId\":\"IDE-CORE-FEATURE\",\"packageVersion\":\"20.0.0.12\",\"packagePublicUid\":\"IDE-CORE-FEATURE__20.0.0.12\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"featureSupport\",\"featureType\":\"ccsCore\",\"ccsVersion\":\"1\",\"dependencies\":[{\"packagePublicId\":\"TIREX\",\"versionRange\":\"*\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"LPCS Device Support Files\",\"packagePublicId\":\"LPCS-DEVICE-SUPPORT\",\"packageVersion\":\"3.21.1.57\",\"packagePublicUid\":\"LPCS-DEVICE-SUPPORT__3.21.1.57\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]},{\"name\":\"LPCS Feature Support\",\"packagePublicId\":\"LPCS-FEATURE\",\"packageVersion\":\"3.21.1.57\",\"packagePublicUid\":\"LPCS-FEATURE__3.21.1.57\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":\"deviceSupport\",\"ccsVersion\":\"^1.3\",\"dependencies\":[{\"packagePublicId\":\"LPCS-DEVICE-SUPPORT\",\"versionRange\":\"3.21.1.57\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"MSPM0 Device Support Files\",\"packagePublicId\":\"MSPM0-DEVICE-SUPPORT\",\"packageVersion\":\"1.11.00.09\",\"packagePublicUid\":\"MSPM0-DEVICE-SUPPORT__1.11.00.09\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]},{\"name\":\"MSPM0 Feature Support\",\"packagePublicId\":\"MSPM0-FEATURE\",\"packageVersion\":\"1.11.00.09\",\"packagePublicUid\":\"MSPM0-FEATURE__1.11.00.09\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":\"deviceSupport\",\"ccsVersion\":\"^1.2\",\"dependencies\":[{\"packagePublicId\":\"MSPM0-DEVICE-SUPPORT\",\"versionRange\":\"1.11.0\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"RADAR Device Support Files\",\"packagePublicId\":\"RADAR-DEVICE-SUPPORT\",\"packageVersion\":\"1.7.17\",\"packagePublicUid\":\"RADAR-DEVICE-SUPPORT__1.7.17\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]},{\"name\":\"RADAR Feature Support\",\"packagePublicId\":\"RADAR-FEATURE\",\"packageVersion\":\"1.7.17\",\"packagePublicUid\":\"RADAR-FEATURE__1.7.17\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":\"deviceSupport\",\"ccsVersion\":\"^1.4\",\"dependencies\":[{\"packagePublicId\":\"RADAR-DEVICE-SUPPORT\",\"versionRange\":\"1.7.17\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"Arm®-based Signal Processing MCU Device Support Files\",\"packagePublicId\":\"SP-MCU-FEATURE\",\"packageVersion\":\"1.0.0\",\"packagePublicUid\":\"SP-MCU-FEATURE__1.0.0\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":\"deviceSupport\",\"ccsVersion\":\"^12.0\",\"dependencies\":[{\"packagePublicId\":\"SP-MCU-DEVICE-SUPPORT\",\"versionRange\":\"1.0.0\",\"dependencyType\":\"mandatory\"}]},{\"name\":\"Arm®-based Signal Processing MCU Device Support Files\",\"packagePublicId\":\"SP-MCU-DEVICE-SUPPORT\",\"packageVersion\":\"1.0.0\",\"packagePublicUid\":\"SP-MCU-DEVICE-SUPPORT__1.0.0\",\"localPackagePath\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base\",\"subType\":\"ccsComponent\",\"featureType\":null,\"ccsVersion\":null,\"dependencies\":[]}]\n","tags":[]}
    2025-01-29T07:18:28.472Z: Module( Tirex )->[triggerEvent]{"event":"OnProgressUpdated","data":{"1":{"progressType":"Indefinite","name":"Scanning for file system changes - Success","subActivity":"","isFirstUpdate":false,"isComplete":true,"error":null}}}
    2025-01-29T07:18:28.473Z: Module( Tirex )->[triggerEvent]{"event":"OnProgressUpdated","data":{}}
    2025-01-29T07:18:28.475Z: tirex4: {"name":"tirex-cloudagent-module","message":"Successfully finished task with progressId 1\n","tags":[]}
    2025-01-29T07:18:29.329Z: Module( Tirex )->[ResponseHandler]{"data":{"devices":[{"publicId":"AM2431","name":"AM2431","type":"device","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM2432","name":"AM2432","type":"device","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM2434","name":"AM2434","type":"device","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM243X","name":"AM243x","type":"family","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM2631","name":"AM2631","type":"device","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM2631-Q1","name":"AM2631-Q1","type":"device","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM2632","name":"AM2632","type":"device","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM2632-Q1","name":"AM2632-Q1","type":"device","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM2634","name":"AM2634","type":"device","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM2634-Q1","name":"AM2634-Q1","type":"device","featureSupport":["ARM-MCU-FEATURE"]},{"publicId":"AM263P4","name":"AM263P4","type":"device","fea
    2025-01-29T07:18:29.363Z: Module( DeviceDetector )->[ws.onMessage]{"command":"detectDebugProbes","id":4,"data":[]}
    2025-01-29T07:18:29.365Z: Module( DeviceDetector )->[ResponseHandler]{"data":{"probes":[{"connectionXml":"TIXDS100v2_Connection","id":"0"}]},"response":4}
    2025-01-29T07:18:29.367Z: Module( DeviceDetector )->[ws.onMessage]{"command":"detectDeviceWithProbe","id":5,"data":[{"connectionXml":"TIXDS100v2_Connection","id":"0"}]}
    2025-01-29T07:18:29.368Z: Module( DeviceDetector )->[ResponseHandler]{"data":{},"response":5}
    2025-01-29T07:18:29.513Z: DS Lite : { "port" : 63762 }
    2025-01-29T07:18:29.515Z: Started DS Lite : { "port" : 63762 }
    2025-01-29T07:18:29.517Z: Module( Agent )->[ResponseHandler]{"data":{"port":63762},"response":5}
    2025-01-29T07:18:29.521Z: DSLite keepalive open
    2025-01-29T07:18:29.756Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:30.593Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"AM243x Development Tools","packageId":"am243x_devtools","packageVersion":"1.01.00.00","dependencyType":"mandatory","installInfoType":"available","packageType":"software","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//tirex-product-tree/am243x_devtools_1_01_00_00/all/am243x_devtools_1_01_00_00__all.zip","installCommand":null,"installSize":814811,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"userFolder"},{"name":"AM243x Devices","packageId":"am243x-devices","packageVersion":"1.01.00.00","dependencyType":"mandatory","installInfoType":"available","packageType":"software","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//tirex-product-tree/am243x_devices_1_01_00_00/all/am243x_devices_1_01_00_00__all.zip","installCommand":null,"installSize":44290,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"userFolder"},{"name":"AM24x Academy","packageId":"AM24X-ACADEMY","packageVersion":"
    2025-01-29T07:18:30.611Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackages","id":9,"data":[{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:31.705Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:32.495Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"AM243x Development Tools","packageId":"am243x_devtools","packageVersion":"1.01.00.00","dependencyType":"mandatory","installInfoType":"available","packageType":"software","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//tirex-product-tree/am243x_devtools_1_01_00_00/all/am243x_devtools_1_01_00_00__all.zip","installCommand":null,"installSize":814811,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"userFolder"},{"name":"AM243x Devices","packageId":"am243x-devices","packageVersion":"1.01.00.00","dependencyType":"mandatory","installInfoType":"available","packageType":"software","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//tirex-product-tree/am243x_devices_1_01_00_00/all/am243x_devices_1_01_00_00__all.zip","installCommand":null,"installSize":44290,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"userFolder"},{"name":"AM24x Academy","packageId":"AM24X-ACADEMY","packageVersion":"
    2025-01-29T07:18:32.523Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":10,"data":[{"packageId":"IDE-CORE-FEATURE","version":"20.0.0.12"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:33.596Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:33.607Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"TIREX","packageId":"TIREX","packageVersion":"*","dependencyType":"mandatory","installInfoType":"notAvailable"},{"name":"IDE Core Feature","packageId":"IDE-CORE-FEATURE","packageVersion":"20.0.0.12","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":"ccsCore","installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":{"installInfo":{"name":"IDE Core Feature","packageId":"IDE-CORE-FEATURE","packageVersion":"20.0.1.4","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":"ccsCore","downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//IDE-CORE-FEATURE__20.0.1.4/ccs/ccs_base/win/CCS_20.0.1.00004_win.zip","installCommand":"ccs_setup_20.0.1.00004.exe --mode unattended --unattendedmodeui minimal --update --prefix @install-location","installSize":912541747,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"productFolder"}},"updateAval
    2025-01-29T07:18:33.610Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":11,"data":[{"packageId":"IDE-CORE-FEATURE","version":"20.0.1.4"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:34.849Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:34.859Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"TIREX","packageId":"TIREX","packageVersion":"*","dependencyType":"mandatory","installInfoType":"notAvailable"},{"name":"IDE Core Feature","packageId":"IDE-CORE-FEATURE","packageVersion":"20.0.1.4","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":"ccsCore","downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//IDE-CORE-FEATURE__20.0.1.4/ccs/ccs_base/win/CCS_20.0.1.00004_win.zip","installCommand":"ccs_setup_20.0.1.00004.exe --mode unattended --unattendedmodeui minimal --update --prefix @install-location","installSize":912541747,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"productFolder"}],"response":11}
    2025-01-29T07:18:34.862Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackages","id":12,"data":[{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:35.932Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:36.933Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"AM243x Development Tools","packageId":"am243x_devtools","packageVersion":"1.01.00.00","dependencyType":"mandatory","installInfoType":"available","packageType":"software","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//tirex-product-tree/am243x_devtools_1_01_00_00/all/am243x_devtools_1_01_00_00__all.zip","installCommand":null,"installSize":814811,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"userFolder"},{"name":"AM243x Devices","packageId":"am243x-devices","packageVersion":"1.01.00.00","dependencyType":"mandatory","installInfoType":"available","packageType":"software","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//tirex-product-tree/am243x_devices_1_01_00_00/all/am243x_devices_1_01_00_00__all.zip","installCommand":null,"installSize":44290,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"userFolder"},{"name":"AM24x Academy","packageId":"AM24X-ACADEMY","packageVersion":"
    2025-01-29T07:18:36.950Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":13,"data":[{"packageId":"ARM-MCU-FEATURE","version":"1.3.10"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:36.954Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":14,"data":[{"packageId":"SITARA-MPU-FEATURE","version":"1.6.7"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:36.956Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":15,"data":[{"packageId":"C2000-FEATURE","version":"6.23.1.0"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:36.958Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":16,"data":[{"packageId":"LPCS-FEATURE","version":"3.21.1.57"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:36.959Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":17,"data":[{"packageId":"MSPM0-FEATURE","version":"1.11.00.09"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:36.961Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":18,"data":[{"packageId":"RADAR-FEATURE","version":"1.7.17"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:36.963Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":19,"data":[{"packageId":"AUTO-FEATURE","version":"1.1.17"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:36.965Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":20,"data":[{"packageId":"C29-FEATURE","version":"1.2.2.0"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:36.967Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":21,"data":[{"packageId":"SP-MCU-FEATURE","version":"1.0.0"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:38.187Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:38.204Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"AM2x Arm®-based MCU Device Support Files","packageId":"ARM-MCU-DEVICE-SUPPORT","packageVersion":"1.3.10","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":null,"installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false},{"name":"AM2x Arm®-based MCU Feature Support","packageId":"ARM-MCU-FEATURE","packageVersion":"1.3.10","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":"deviceSupport","installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false}],"response":13}
    2025-01-29T07:18:38.265Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:38.275Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"LPCS Device Support Files","packageId":"LPCS-DEVICE-SUPPORT","packageVersion":"3.21.1.57","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":null,"installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false},{"name":"LPCS Feature Support","packageId":"LPCS-FEATURE","packageVersion":"3.21.1.57","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":"deviceSupport","installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false}],"response":16}
    2025-01-29T07:18:38.290Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:38.302Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"C2000 Device Support Files","packageId":"C2000-DEVICE-SUPPORT","packageVersion":"6.23.1.0","dependencyType":"mandatory","installInfoType":"installed","packageType":null,"featureType":null,"installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":{"installInfo":{"name":"C2000 Device Support Files","packageId":"C2000-DEVICE-SUPPORT","packageVersion":"6.23.2.0","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//C2000-DEVICE-SUPPORT__6.23.2.0/ccs_base/win/ti_c2000support_setup_win_6.23.2.0.zip","installCommand":null,"installSize":5896300,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"}},"updateAvaliableInNewerCCSVersion":false},{"name":"C2000 Feature Support","packageId":"C2000-FEATURE","packageVersion":"6.23.1.0","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureT
    2025-01-29T07:18:38.305Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":22,"data":[{"packageId":"C2000-FEATURE","version":"6.23.2.0"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:38.533Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:38.543Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:38.545Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:38.555Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:38.566Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"MSPM0 Device Support Files","packageId":"MSPM0-DEVICE-SUPPORT","packageVersion":"1.11.00.09","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":null,"installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":{"installInfo":{"name":"MSPM0 Device Support Files","packageId":"MSPM0-DEVICE-SUPPORT","packageVersion":"1.12.00.02","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//MSPM0-DEVICE-SUPPORT__1.12.00.02/ccs_base/win/mspm0_device_support_win_1.12.00.02.zip","installCommand":null,"installSize":2446077,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"}},"updateAvaliableInNewerCCSVersion":false},{"name":"MSPM0 Feature Support","packageId":"MSPM0-FEATURE","packageVersion":"1.11.00.09","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsC
    2025-01-29T07:18:38.568Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":23,"data":[{"packageId":"MSPM0-FEATURE","version":"1.12.00.02"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:38.572Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"RADAR Device Support Files","packageId":"RADAR-DEVICE-SUPPORT","packageVersion":"1.7.17","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":null,"installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false},{"name":"RADAR Feature Support","packageId":"RADAR-FEATURE","packageVersion":"1.7.17","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":"deviceSupport","installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false}],"response":18}
    2025-01-29T07:18:38.578Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"C29 Device Support Files","packageId":"C29-DEVICE-SUPPORT","packageVersion":"1.2.2.0","dependencyType":"mandatory","installInfoType":"installed","packageType":null,"featureType":null,"installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":{"installInfo":{"name":"C29 Device Support Files","packageId":"C29-DEVICE-SUPPORT","packageVersion":"1.2.8.0","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//C29-DEVICE-SUPPORT__1.2.8.0/ccs_base/win/c29_device_support_win_1.2.8.0.zip","installCommand":null,"installSize":888383,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"}},"updateAvaliableInNewerCCSVersion":false},{"name":"C29 Feature Support","packageId":"C29-FEATURE","packageVersion":"1.2.2.0","dependencyType":"mandatory","installInfoType":"installed","packageType":null,"featureType":"deviceSupport","installLoca
    2025-01-29T07:18:38.580Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":24,"data":[{"packageId":"C29-FEATURE","version":"1.2.8.0"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:38.585Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"TDAx DRAx J7x Auto Device Support Files","packageId":"AUTO-DEVICE-SUPPORT","packageVersion":"1.1.17","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":null,"installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false},{"name":"TDAx DRAx J7x Auto Feature Support","packageId":"AUTO-FEATURE","packageVersion":"1.1.17","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":"deviceSupport","installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false}],"response":19}
    2025-01-29T07:18:38.647Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:38.657Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"Arm®-based Processors Device Support Files","packageId":"SITARA-MPU-DEVICE-SUPPORT","packageVersion":"1.6.7","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":null,"installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false},{"name":"Arm®-based Processors Feature Support","packageId":"SITARA-MPU-FEATURE","packageVersion":"1.6.7","dependencyType":"mandatory","installInfoType":"installed","packageType":"ccsComponent","featureType":"deviceSupport","installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":null,"updateAvaliableInNewerCCSVersion":false}],"response":14}
    2025-01-29T07:18:38.946Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:38.957Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"Arm®-based Signal Processing MCU Device Support Files","packageId":"SP-MCU-DEVICE-SUPPORT","packageVersion":"1.0.0","dependencyType":"mandatory","installInfoType":"installed","packageType":null,"featureType":null,"installLocation":"C:/Tools/AH-Applications/ti/ccs2000/ccs/ccs_base","updateAvaliable":{"installInfo":{"name":"Arm®-based Signal Processing MCU Device Support Files","packageId":"SP-MCU-DEVICE-SUPPORT","packageVersion":"1.0.1","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//SP-MCU-DEVICE-SUPPORT__1.0.1/ccs_base/all/sp_mcu_device_support_1.0.1.zip","installCommand":null,"installSize":804672,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"}},"updateAvaliableInNewerCCSVersion":false},{"name":"Arm®-based Signal Processing MCU Device Support Files","packageId":"SP-MCU-FEATURE","packageVersion":"1.0.0","dependencyType":"mandatory
    2025-01-29T07:18:38.962Z: Module( Tirex )->[ws.onMessage]{"command":"getInstallInfoForPackageDependencies","id":25,"data":[{"packageId":"SP-MCU-FEATURE","version":"1.0.1"},{"ccsVersion":"1.6.0"}]}
    2025-01-29T07:18:39.214Z: Module( Agent )->[ws.onMessage]{"command":"createSubModule","id":7,"data":["File"]}
    2025-01-29T07:18:39.215Z: Module( Agent )->Creating new module (module id: 5)
    2025-01-29T07:18:39.218Z: Module( Agent )->[ResponseHandler]{"data":{"port":56465},"response":7}
    2025-01-29T07:18:39.223Z: Module( File )->[wss.onConnection]
    2025-01-29T07:18:39.225Z: Module( File )->[ws.onMessage]{"command":"listCommands","id":1,"data":[]}
    2025-01-29T07:18:39.226Z: Module( File )->[ResponseHandler]{"data":{"commands":["listSubModules","createSubModule","listCommands","write"]},"response":1}
    2025-01-29T07:18:39.229Z: Module( File )->[ws.onMessage]{"command":"write","id":2,"data":["local.ccxml","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
    2025-01-29T07:18:39.243Z: Module( File )->[ResponseHandler]{"data":{"path":"C:\\Users\\a871258\\AppData\\Local\\Temp\\ti_cloud_storage\\local.ccxml"},"response":2}
    2025-01-29T07:18:39.246Z: Module( Agent )->[ws.onMessage]{"command":"createSubModule","id":8,"data":["TargetSupport"]}
    2025-01-29T07:18:39.248Z: Module( Agent )->Creating new module (module id: 6)
    2025-01-29T07:18:39.250Z: DriverInstaller options: {}
    2025-01-29T07:18:39.252Z: Creating db dir : C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\cloudagent\db
    2025-01-29T07:18:39.255Z: Module( Agent )->[ResponseHandler]{"data":{"message":"EPERM: operation not permitted, mkdir 'C:\\Tools\\AH-Applications\\ti\\ccs2000\\ccs\\ccs_base\\cloudagent\\db'","stack":"Error: EPERM: operation not permitted, mkdir 'C:\\Tools\\AH-Applications\\ti\\ccs2000\\ccs\\ccs_base\\cloudagent\\db'\n    at Object.mkdirSync (node:fs:1396:3)\n    at new DB (C:\\Tools\\AH-Applications\\ti\\ccs2000\\ccs\\ccs_base\\cloudagent\\src\\installer\\db.js:24:16)\n    at new Installer (C:\\Tools\\AH-Applications\\ti\\ccs2000\\ccs\\ccs_base\\cloudagent\\src\\installer\\installer.js:19:19)\n    at new CloudInstaller (C:\\Tools\\AH-Applications\\ti\\ccs2000\\ccs\\ccs_base\\cloudagent\\src\\modules\\target_support.js:12:30)\n    at Object.instance (C:\\Tools\\AH-Applications\\ti\\ccs2000\\ccs\\ccs_base\\cloudagent\\src\\modules\\target_support.js:36:19)\n    at adaptModuleFactory (C:\\Tools\\AH-Applications\\ti\\ccs2000\\ccs\\ccs_base\\cloudagent\\src\\module.js:24:40)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5
    2025-01-29T07:18:39.358Z: Module( File )->[ws.onMessage]{"command":"write","id":3,"data":["TMS320F28386D.ccxml","PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiIHN0YW5kYWxvbmU9Im5vIj8+DQo8Y29uZmlndXJhdGlvbnMgWE1MX3ZlcnNpb249IjEuMiIgaWQ9ImNvbmZpZ3VyYXRpb25zXzAiPg0KICAgICAgICAgICAgICAgICAgICAgICAgDQogICAgDQogICAgDQogICAgDQogICAgDQogICAgPGNvbmZpZ3VyYXRpb24gWE1MX3ZlcnNpb249IjEuMiIgaWQ9ImNvbmZpZ3VyYXRpb25fMCI+DQogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICANCiAgICAgICAgDQogICAgICAgIA0KICAgICAgICANCiAgICAgICAgDQogICAgICAgIDxpbnN0YW5jZSBYTUxfdmVyc2lvbj0iMS4yIiBkZXNjPSJUZXhhcyBJbnN0cnVtZW50cyBYRFMxMDB2MiBVU0IgRGVidWcgUHJvYmUiIGhyZWY9ImNvbm5lY3Rpb25zL1RJWERTMTAwdjJfQ29ubmVjdGlvbi54bWwiIGlkPSJUZXhhcyBJbnN0cnVtZW50cyBYRFMxMDB2MiBVU0IgRGVidWcgUHJvYmUiIHhtbD0iVElYRFMxMDB2Ml9Db25uZWN0aW9uLnhtbCIgeG1scGF0aD0iY29ubmVjdGlvbnMiLz4NCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIA0KICAgICAgICANCiAgICAgICAgDQogICAgICAgIA0KICAgICAgICANCiAgICAgICAgPGNvbm5lY3Rpb24gWE1MX3ZlcnNpb249IjEuMiIgaWQ9IlRleGFzIEluc3RydW1lbnRzIFhEUzEwMHYyIFVTQiBEZ
    2025-01-29T07:18:39.367Z: Module( File )->[ResponseHandler]{"data":{"path":"C:\\Users\\a871258\\AppData\\Local\\Temp\\ti_cloud_storage\\TMS320F28386D.ccxml"},"response":3}
    2025-01-29T07:18:39.451Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:39.464Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"C2000 Device Support Files","packageId":"C2000-DEVICE-SUPPORT","packageVersion":"6.23.2.0","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//C2000-DEVICE-SUPPORT__6.23.2.0/ccs_base/win/ti_c2000support_setup_win_6.23.2.0.zip","installCommand":null,"installSize":5896300,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"},{"name":"C2000 Feature Support","packageId":"C2000-FEATURE","packageVersion":"6.23.2.0","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":"deviceSupport","downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//C2000-FEATURE__6.23.2.0/ccs_base/all/c2000_feature_6.23.2.0.zip","installCommand":null,"installSize":1058,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"}],"response":22}
    2025-01-29T07:18:39.845Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:39.856Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"MSPM0 Device Support Files","packageId":"MSPM0-DEVICE-SUPPORT","packageVersion":"1.12.00.02","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//MSPM0-DEVICE-SUPPORT__1.12.00.02/ccs_base/win/mspm0_device_support_win_1.12.00.02.zip","installCommand":null,"installSize":2446077,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"},{"name":"MSPM0 Feature Support","packageId":"MSPM0-FEATURE","packageVersion":"1.12.00.02","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":"deviceSupport","downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//MSPM0-FEATURE__1.12.00.02/ccs_base/all/mspm0_feature_1.12.00.02.zip","installCommand":null,"installSize":1043,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"}],"response":23}
    2025-01-29T07:18:39.892Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:39.901Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"C29 Device Support Files","packageId":"C29-DEVICE-SUPPORT","packageVersion":"1.2.8.0","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//C29-DEVICE-SUPPORT__1.2.8.0/ccs_base/win/c29_device_support_win_1.2.8.0.zip","installCommand":null,"installSize":888383,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"},{"name":"C29 Feature Support","packageId":"C29-FEATURE","packageVersion":"1.2.8.0","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":"deviceSupport","downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//C29-FEATURE__1.2.8.0/ccs_base/all/c29_feature_1.2.8.0.zip","installCommand":null,"installSize":999,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"}],"response":24}
    2025-01-29T07:18:40.315Z: tirex4: {"name":"tirex-cloudagent-module","message":"http://127.0.0.1:56357/api/ccsserver/getProducts returned [{\"id\":\"sysconfig\",\"name\":\"SysConfig\",\"version\":\"1.22.0\",\"location\":\"C:/Tools/AH-Applications/ti/ccs2000/ccs/utils/sysconfig_1.22.0\",\"style\":\"json\"}]\n","tags":[]}
    2025-01-29T07:18:40.333Z: Module( Tirex )->[ResponseHandler]{"data":[{"name":"Arm®-based Signal Processing MCU Device Support Files","packageId":"SP-MCU-DEVICE-SUPPORT","packageVersion":"1.0.1","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":null,"downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//SP-MCU-DEVICE-SUPPORT__1.0.1/ccs_base/all/sp_mcu_device_support_1.0.1.zip","installCommand":null,"installSize":804672,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"},{"name":"Arm®-based Signal Processing MCU Device Support Files","packageId":"SP-MCU-FEATURE","packageVersion":"1.0.1","dependencyType":"mandatory","installInfoType":"available","packageType":"ccsComponent","featureType":"deviceSupport","downloadUrl":"https://software-dl.ti.com/ccs/esd/tirex/zips//SP-MCU-FEATURE__1.0.1/ccs_base/all/sp_mcu_feature_1.0.1.zip","installCommand":null,"installSize":1041,"licenses":[],"updateAvaliableInNewerCCSVersion":false,"installTo":"ccs"}],"response":25}
    2025-01-29T07:18:51.117Z: Module( File )->[ws.onMessage]{"command":"write","id":4,"data":["TMS320F28386D.ccxml","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
    2025-01-29T07:18:51.120Z: Module( File )->[ResponseHandler]{"data":{"path":"C:\\Users\\a871258\\AppData\\Local\\Temp\\ti_cloud_storage\\TMS320F28386D.ccxml"},"response":4}
    2025-01-29T07:18:51.122Z: Module( EventBroker )->[ws.onMessage]{"command":"fetchData","id":4,"data":["sourceMapLocalToTemp"]}
    2025-01-29T07:18:51.123Z: Module( EventBroker )->[ResponseHandler]{"data":"No data is registered under sourceMapLocalToTemp","error":4}
    2025-01-29T07:18:51.128Z: Module( EventBroker )->[ws.onMessage]{"command":"registerData","id":5,"data":["sourceMapLocalToTemp",[]]}
    2025-01-29T07:18:51.129Z: Module( EventBroker )->[ResponseHandler]{"response":5}
    2025-01-29T07:18:51.131Z: Module( EventBroker )->[ws.onMessage]{"command":"fetchData","id":6,"data":["sourceMapLocalToTemp"]}
    2025-01-29T07:18:51.132Z: Module( EventBroker )->[ResponseHandler]{"data":{"data":[]},"response":6}
    2025-01-29T07:18:51.133Z: Module( EventBroker )->[ws.onMessage]{"command":"registerData","id":7,"data":["sourceMapLocalToTemp",[{"userPath":"C:\\Users\\a871258\\workspace_ccstheia\\TstClaLVDT\\targetConfigs\\TMS320F28386D.ccxml","tempPath":"C:\\Users\\a871258\\AppData\\Local\\Temp\\ti_cloud_storage\\TMS320F28386D.ccxml"}]]}
    2025-01-29T07:18:51.134Z: Module( EventBroker )->[ResponseHandler]{"response":7}
    2025-01-29T07:19:38.982Z: Module( TargetSupport )->server: on close
    2025-01-29T07:23:48.423Z: Module( Agent )->Socket closed, wss.clients.size = 1
    2025-01-29T07:23:48.432Z: Module( File )->Socket closed, wss.clients.size = 0
    2025-01-29T07:23:48.434Z: Module( EventBroker )->Socket closed, wss.clients.size = 0
    2025-01-29T07:23:48.435Z: Module( Tirex )->Socket closed, wss.clients.size = 0
    2025-01-29T07:23:48.437Z: Module( DeviceDetector )->Socket closed, wss.clients.size = 0
    2025-01-29T07:23:48.440Z: Module( Agent )->Socket closed, wss.clients.size = 0
    2025-01-29T07:23:48.442Z: Module( Agent )->Exiting immediately as there are no more connections on Agent module
    Clément
  • Thank you. It is possible that there is a dependency on write access to "C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\cloudagent" (and containing subfolders) for debug launch. We are investigating.
  • Oh ok so it's not worth me trying to investigate the 20.0.2 ? Better wait for the new one.
  • It could be nice to try. But I am not sure if it will help. I don't want to promise anything, especially if it is a lot of effort to install
  • I was able to reproduce this issue on my home PC by explicitly denying write access to my secondary user account and then trying to start a debug session from that account.
  • Ok great, then I'll have to wait till that get fixed.
    It would also be good to raise that as a general requirement for your different software, I doubt we are the only company blocking access to installation folders for security reasons.
  • It would also be good to raise that as a general requirement for your different software, I doubt we are the only company blocking access to installation folders for security reasons.
    Yes, I agree. IT everywhere is always tightening access more and more as cybersecurity threats increase.
  • It is possible that there is a dependency on write access to "C:\Tools\AH-Applications\ti\ccs2000\ccs\ccs_base\cloudagent" (and containing subfolders) for debug launch.
    We are narrowing down the root cause and it appears the above is very likely...
  • Thanks for keeping me posted.
  • Note that i did open a ticket for this issue. We are having some issues with out public tracking portal right now but once that is resolved I will provide a link to the ticket ID.
  • We are having some issues with out public tracking portal right now but once that is resolved I will provide a link to the ticket ID.
    The portal is still having issues I have no idea when it will be resolved, I wanted to provide the internal ID: TICLD-3978. You can use this ID to reference this issue and have someone with access (like myself) provide an update.
    ki
  • Ki,
    I am sorry but I am not accepting this as being resolved as the issue is there and not fixed.
    I am keeping this open until it is fixed by a CCS release.
    Do you have any rough idea of when this will be fixed ?
    Clément
  • Do you have any rough idea of when this will be fixed ?
    That is yet to be determined.
    As for why this thread was proposed as "resolved", please see the first FAQ in the thread below:
    https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/3131/please-read-first-ccs-forum-usage-guidelines
    Q: Why did TI mark my post as "TI Thinks Resolved" when all that was done was a bug or enhancement request being filed?
    A: This is done more for thread tracking purposes. When a bug or enhancement request is filed, the support team has effectively handed off the issue to the engineering teams to address. From a support standpoint, the issue has been closed and no more action will be done from a support standpoint. Marking the thread as "TI thinks Resolved" is a way of communicating this. Note that by no means do we think the issue is closed overall. Further progress of the issue can be tracked through the online public bug tracking portal as mentioned above.
    Do you have any news about the fix ?
    Clément
  • We are aiming to address this for the CCS 20.2.0 release end of May.
  • End of May ?
    Hum, that's quite far away, would you be able to provide a patch ahead of that deadline ?
    Right now CCS V20 is unusable for companies with strict right resctrictions.
  • The portal is still having issues I have no idea when it will be resolved, I wanted to provide the internal ID: TICLD-3978. You can use this ID to reference this issue and have someone with access (like myself) provide an update.
    The external portal issues have been resolved. You can track the above issue using this public link: https://sir.ext.ti.com/jira/browse/EXT_EP-12202
  • Hum, that's quite far away, would you be able to provide a patch ahead of that deadline ?
    I will look into providing a an early build or a patch when available.
  • Thank you, much appreciated.
