Hi, TI expert!
I have a development environment for am6234, with our own evaluation board.
The software SDK version is PROCESSOR-SDK-LINUX-RT-AM62X-10.01.10.04.
We are currently porting the camera driver from SDK 8.6 to SDK 10.1.
In SDK 8.6, the camera can record videos normally, but it cannot in SDK 10.1.
The hardware related information is as follows:
1.The am6234 SoC chip does not have a GPU module inside.
2.The model of the MiPi CSI sensor we use is nvp6188, which supports the following video formats as shown in the picture
1.Device tree configuration information:
compatible = "ti,am62x-sk", "ti,am62x";
chosen {
stdout-path = "serial2:115200n8";
framebuffer0: framebuffer@0 {
compatible = "simple-framebuffer";
power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 186 6>,
<&dss_vp1_clk>,
<&k3_clks 186 2>;
display = <&dss>;
status = "disabled";
memory@80000000 {
bootph-pre-ram;
device_type = "memory";
/* 1G RAM */
reg = <0x00000000 0x80000000 0x00000000 0x40000000>;
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
ramoops@9c700000 {
compatible = "ramoops";
reg = <0x00 0x9c700000 0x00 0x00100000>;
record-size = <0x8000>;
console-size = <0x8000>;
ftrace-size = <0x00>;
pmsg-size = <0x8000>;
rtos_ipc_memory_region: ipc-memories@9c800000 {
compatible = "shared-dma-pool";
reg = <0x00 0x9c800000 0x00 0x00300000>;
no-map;
mcu_m4fss_dma_memory_region: m4f-dma-memory@9cb00000 {
reg = <0x00 0x9cb00000 0x00 0x100000>;
no-map;
mcu_m4fss_memory_region: m4f-memory@9cc00000 {
reg = <0x00 0x9cc00000 0x00 0xe00000>;
no-map;
/* global cma region */
linux,cma {
reusable;
size = <0x00 0x8000000>;
linux,cma-default;
wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9da00000 {
reg = <0x00 0x9da00000 0x00 0x00100000>;
no-map;
wkup_r5fss0_core0_memory_region: r5f-memory@9db00000 {
reg = <0x00 0x9db00000 0x00 0x00c00000>;
no-map;
secure_tfa_ddr: tfa@9e780000 {
reg = <0x00 0x9e780000 0x00 0x80000>;
alignment = <0x1000>;
no-map;
secure_ddr: optee@9e800000 {
reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
no-map;
// SPDX-License-Identifier: GPL-2.0
* DT overlay for Camera in main domain on AM62x SK
* Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/
/dts-v1/;
/plugin/;
#include "../k3-pinctrl.h"
#include <dt-bindings/gpio/gpio.h>
clk_nvp6188_fixed: nvp6188-xvclk {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <27000000>;
&main_pmx0 {
mipi_csi_rst_pins_default: mipi-csi-rst-pins-default {
pinctrl-single,pins = <
AM62X_IOPAD(0x00a0, PIN_OUTPUT, 7) /* (K25) GPMC0_WPn.GPIO0_39 */
&main_i2c1 {
status = "okay";
nvp6188: nvp6188@30 {
compatible = "nvp6188";
reg = <0x30>;
clocks = <&clk_nvp6188_fixed>;
clock-names = "xvclk";
pinctrl-names = "rockchip,camera_default";
pinctrl-0 = <&mipi_csi_rst_pins_default>;
reset-gpios = <&main_gpio0 39 GPIO_ACTIVE_HIGH>;
rockchip,camera-module-index = <0>;
rockchip,camera-module-facing = "back";
rockchip,camera-module-name = "nvp6188";
rockchip,camera-module-lens-name = "nvp6188";
port {
csi2_cam0: endpoint {
remote-endpoint = <&csi2rx0_in_sensor>;
clock-lanes = <0>;
data-lanes = <1 2 3 4>;
&csi0_port0 {
status = "okay";
csi2rx0_in_sensor: endpoint {
remote-endpoint = <&csi2_cam0>;
bus-type = <4>; /* CSI2 DPHY. */
clock-lanes = <0>;
&ti_csi2rx0 {
status = "okay";
&dphy0 {
status = "okay";
2.The driver program corresponding to nvp6188 is as follows:
Then I run the following tests:
root@AM62x:~# media-ctl -p -d /dev/media0
Media controller API version 6.6.58
[ 230.206488] nvp6188 1-0030: nvp6188_open
Media device information
driver j721e-csi2rx
[ 230.206565] nvp6188 1-0030: nvp6188_get_fmt: 2006 1280x720 vc 0
model TI-CSI2RX
serial
bus info platform:30102000.ticsi2rx
hw revision 0x1
driver version 6.6.58
Device topology
- entity 1: 30102000.ticsi2rx (5 pads, 5 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
[fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
<- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE]
pad1: Source
-> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
pad2: Source
-> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
pad3: Source
-> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
pad4: Source
-> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
- entity 7: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links)
device node name /dev/v4l-subdev1
pad0: Sink
<- "m00_b_nvp6188 1-0030":0 [ENABLED,IMMUTABLE]
pad1: Source
-> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE]
pad2: Source
pad3: Source
pad4: Source
- entity 13: m00_b_nvp6188 1-0030 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
[fmt:UYVY8_2X8/1280x720@10000/250000 field:none]
-> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE]
- entity 19: 30102000.ticsi2rx context 0 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE]
- entity 25: 30102000.ticsi2rx context 1 (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
<- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE]
- entity 31: 30102000.ticsi2rx context 2 (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
<- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE]
- entity 37: 30102000.ticsi2rx context 3 (1 pad, 1 link)
device node name /dev/video3
pad0: Sink
<- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE]root@AM62x:~# gst-launch-1.0 -vvv v4l2src device="/dev/video0" ! video/x-raw, width=1280, height=720 ! kmssink driver-name=tidss [ 467.207245] nvp6188 1-0030: nvp6188_open [ 467.687902] nvp6188 1-0030: nvp6188_open 设置暂停管道 ... 管道正在使用且不需要 PREROLL ... /GstPipeline:pipeline0/GstKMSSink:kmssink0: display-width = 1280 /GstPipeline:pipeline0/GstKMSSink:kmssink0: display-height = 800 管道被 PREROLLED ... 设置播放管道 ... New clock: GstSystemClock /GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt709 [ 467.742017] j721e-csi2rx 30102000.ticsi2rx: Width does not match (source 640, sink 1280) /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt709 /GstPipeline:pipeline0/GstKMSSink:kmssink0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt709 /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt709 错误:来自组件 /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:分配请求的内存失败。 额外的调试信息: ../sys/v4l2/gstv4l2src.c(759): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Buffer pool activation failed Execution ended after 0:00:00.044573185 错误:来自组件 /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:Internal data stream error. 设置 NULL 管道 ... 额外的调试信息: ../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: streaming stopped, reason not-negotiated (-4) 释放管道资源 ...
There are the following errors in the log above:
More detailed logs are as follows:
root@AM62x:~# GST_DEBUG=3 gst-launch-1.0 -vvv v4l2src device="/dev/video0" ! video/x-raw, width=1280, height=720 ! kmssink driver-name=tidss
[ 543.301905] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
管道被 PREROLLED ...
设置播放管道 ...
/GstPipeline:pipel[ 543.358165] j721e-csi2rx 30102000.ticsi2rx: Width does not match (source 640, sink 1280)
0:00:00.132054125 930 0xaaaae7e9e800 ERROR v4l2bufferpool gstv4l2bufferpool.c:706:gst_v4l2_buffer_pool_streamon:<v4l2src0:pool0:src> error with STREAMON 32 (Broken pipe)
0:00:00.144053555 930 0xaaaae7e9e800 ERROR bufferpool gstbufferpool.c:556:gst_buffer_pool_set_active:<v4l2src0:pool0:src> start failed
0:00:00.144556945 930 0xaaaae7e9e800 WARN v4l2src gstv4l2src.c:759:gst_v4l2src_decide_allocation:<v4l2src0> error: 分配请求的内存失败。
0:00:00.144612050 930 0xaaaae7e9e800 WARN v4l2src gstv4l2src.c:759:gst_v4l2src_decide_allocation:<v4l2src0> error: Buffer pool activation failed
额外的调试信息:
0:00:00.144952110 930 0xaaaae7e9e800 WARN basesrc gstbasesrc.c:3347:gst_base_src_prepare_allocation:<v4l2src0> Subclass failed to decide allocation
0:00:00.145037120 930 0xaaaae7e9e800 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop:<v4l2src0> error: Internal data stream error.
Execution ended after 0:00:00.050935055
0:00:00.145071360 930 0xaaaae7e9e800 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason not-negotiated (-4)
设置 NULL 管道 ...
额外的调试信息:
释放管道资源 ...
root@AM62x:~# gst-launch-1.0 -m -vvv v4l2src device="/dev/video0" ! video/x-raw, width=1280, height=720 ! kmssink driver-name=tidss
[ 585.093766] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
从组件“kmssink0”获得消息 #9(property-notify): GstMessagePropertyNotify, property-name=(string)display-width, property-value=(int)1280;
从组件“kmssink0”获得消息 #10(property-notify): GstMessagePropertyNotify, property-name=(string)display-height, property-value=(int)800;
从组件[ 585.150014] j721e-csi2rx 30102000.ticsi2rx: Width does not match (source 640, sink 1280)
“kmssink0”获得消息 #11(state-changed): GstMessageStateChanged, old-state=(GstState)null, new-state=(GstState)ready, pending-state=(GstState)void-pending;
从组件“capsfilter0”获得消息 #12(state-changed): GstMessageStateChanged, old-state=(GstState)null, new-state=(GstState)ready, pending-state=(GstState)void-pending;
从组件“v4l2src0”获得消息 #13(state-changed): GstMessageStateChanged, old-state=(GstState)null, new-state=(GstState)ready, pending-state=(GstState)void-pending;
从组件“pipeline0”获得消息 #14(state-changed): GstMessageStateChanged, old-state=(GstState)null, new-state=(GstState)ready, pending-state=(GstState)paused;
从组件“capsfilter0”获得消息 #16(state-changed): GstMessageStateChanged, old-state=(GstState)ready, new-state=(GstState)paused, pending-state=(GstState)void-pending;
从填充“v4l2src0:src”获得消息 #19(stream-status): GstMessageStreamStatus, type=(GstStreamStatusType)create, owner=(GstElement)"\(GstV4l2Src\)\ v4l2src0", object=(GstTask)"\(GstTask\)\ v4l2src0:src";
从组件“v4l2src0”获得消息 #20(state-changed): GstMessageStateChanged, old-state=(GstState)ready, new-state=(GstState)paused, pending-state=(GstState)void-pending;
从组件“pipeline0”获得消息 #21(state-changed): GstMessageStateChanged, old-state=(GstState)ready, new-state=(GstState)paused, pending-state=(GstState)void-pending;
管道被 PREROLLED ...
设置播放管道 ...
从填充“v4l2src0:src”获得消息 #22(stream-status): GstMessageStreamStatus, type=(GstStreamStatusType)enter, owner=(GstElement)"\(GstV4l2Src\)\ v4l2src0", object=(GstTask)"\(GstTask\)\ v4l2src0:src";
从组件“pipeline0”获得消息 #23(stream-start): GstMessageStreamStart, group-id=(uint)1;
从组件“pipeline0”获得消息 #27(new-clock): GstMessageNewClock, clock=(GstClock)"\(GstSystemClock\)\ GstSystemClock";
从填充“v4l2src0:src”获得消息 #28(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt709";
从组件“capsfilter0”获得消息 #31(state-changed): GstMessageStateChanged, old-state=(GstState)paused, new-state=(GstState)playing, pending-state=(GstState)void-pending;
从填充“capsfilter0:src”获得消息 #32(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt709";
从组件“v4l2src0”获得消息 #33(state-changed): GstMessageStateChanged, old-state=(GstState)paused, new-state=(GstState)playing, pending-state=(GstState)void-pending;
从填充“kmssink0:sink”获得消息 #34(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt709";
额外的调试信息:
Execution ended after 0:00:00.338779490
设置 NULL 管道 ...
额外的调试信息:
释放管道资源 ...
Command pass width=640, height=480 , the log after is as follows:
root@AM62x:~# gst-launch-1.0 -vvv v4l2src device="/dev/video0" ! video/x-raw, width=640, height=480 ! kmssink driver-name=tidss
[ 660.291623] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
管道被 PREROLLED ...
设置播放管道 ...
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeli[ 660.348371] j721e-csi2rx 30102000.ticsi2rx: Cannot transform "30102000.ticsi2rx":1 format UYVY little-endian (0x59565955) to YUYV little-endian (0x56595559)
ne0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstKMSSink:kmssink0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
额外的调试信息:
Execution ended after 0:00:00.055974765
设置 NULL 管道 ...
额外的调试信息:
释放管道资源 ...
root@AM62x:~# GST_DEBUG=3 gst-launch-1.0 -vvv v4l2src device="/dev/video0" ! video/x-raw, width=640, height=480 ! kmssink driver-name=tidss
[ 727.648371] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
管道被 PREROLLED ...
设置播放管道 ...
/GstPipeline:pipeli[ 727.706338] j721e-csi2rx 30102000.ticsi2rx: Cannot transform "30102000.ticsi2rx":1 format UYVY little-endian (0x59565955) to YUYV little-endian (0x56595559)
0:00:00.133094060 964 0xaaaaceaff800 ERROR v4l2bufferpool gstv4l2bufferpool.c:706:gst_v4l2_buffer_pool_streamon:<v4l2src0:pool0:src> error with STREAMON 32 (Broken pipe)
0:00:00.149553270 964 0xaaaaceaff800 ERROR bufferpool gstbufferpool.c:556:gst_buffer_pool_set_active:<v4l2src0:pool0:src> start failed
0:00:00.150011810 964 0xaaaaceaff800 WARN v4l2src gstv4l2src.c:759:gst_v4l2src_decide_allocation:<v4l2src0> error: 分配请求的内存失败。
0:00:00.150066840 964 0xaaaaceaff800 WARN v4l2src gstv4l2src.c:759:gst_v4l2src_decide_allocation:<v4l2src0> error: Buffer pool activation failed
额外的调试信息:
0:00:00.150455700 964 0xaaaaceaff800 WARN basesrc gstbasesrc.c:3347:gst_base_src_prepare_allocation:<v4l2src0> Subclass failed to decide allocation
0:00:00.150549910 964 0xaaaaceaff800 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop:<v4l2src0> error: Internal data stream error.
0:00:00.150589445 964 0xaaaaceaff800 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.056849745
设置 NULL 管道 ...
额外的调试信息:
释放管道资源 ...
root@AM62x:~# gst-launch-1.0 -m -vvv v4l2src device="/dev/video0" ! video/x-raw, width=640, height=480 ! kmssink driver-name=tidss
[ 772.584734] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
/GstPipelin[ 772.635316] j721e-csi2rx 30102000.ticsi2rx: Cannot transform "30102000.ticsi2rx":1 format UYVY little-endian (0x59565955) to YUYV little-endian (0x56595559)
从组件“kmssink0”获得消息 #11(state-changed): GstMessageStateChanged, old-state=(GstState)null, new-state=(GstState)ready, pending-state=(GstState)void-pending;
管道被 PREROLLED ...
设置播放管道 ...
从填充“v4l2src0:src”获得消息 #27(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt601";
从组件“pipeline0”获得消息 #28(new-clock): GstMessageNewClock, clock=(GstClock)"\(GstSystemClock\)\ GstSystemClock";
从填充“capsfilter0:src”获得消息 #31(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt601";
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
从组件“capsfilter0”获得消息 #32(state-changed): GstMessageStateChanged, old-state=(GstState)paused, new-state=(GstState)playing, pending-state=(GstState)void-pending;
从填充“kmssink0:sink”获得消息 #33(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt601";
额外的调试信息:
从组件“v4l2src0”获得消息 #34(state-changed): GstMessageStateChanged, old-state=(GstState)paused, new-state=(GstState)playing, pending-state=(GstState)void-pending;
额外的调试信息:
Execution ended after 0:00:00.344994650
设置 NULL 管道 ...
释放管道资源 ...
Execute the following command:
media-ctl -V '"m00_b_nvp6188 1-0030":0 [fmt:UYVY8_1X16/1280x720 field:none]'
media-ctl -V '"cdns_csi2rx.30101000.csi-bridge":0 [fmt:UYVY8_1X16/1280x720 field:none]'
media-ctl -V '"30102000.ticsi2rx":0 [fmt:UYVY8_1X16/1280x720 field:none]'
yavta -s 1280x720 -f UYVY /dev/video0 -c5 -Fimage-#.yuv
The output log is as follows:
root@AM62x:~# media-ctl -V '"m00_b_nvp6188 1-0030":0 [fmt:UYVY8_1X16/1280x720 field:none]'
[ 109.540872] nvp6188 1-0030: nvp6188_open
[ 109.541031] nvp6188 1-0030: mipi_freq_idx 0
[ 109.541038] nvp6188 1-0030: pixel_rate 729000000
root@AM62x:~# media-ctl -V '"cdns_csi2rx.30101000.csi-bridge":0 [fmt:UYVY8_1X16/1280x720 field:none]'
root@AM62x:~# media-ctl -V '"30102000.ticsi2rx":0 [fmt:UYVY8_1X16/1280x720 field:none]'
root@AM62x:~# yavta -s 1280x720 -f UYVY /dev/video0 -c5 -Fimage-#.yuv
Device /dev/video0 opened.
Device `j721e-csi2rx' on `platform:30102000.ticsi2rx' (driver 'j721e-csi2rx') supports video, capture, without mplanes.
Video format set: UYVY (59565955) 1280x720 (stride 2560) field none buffer size 1843200
Video format: UYVY (59565955) 1280x720 (stride 2560) field none buffer size 1843200
8 buffers requested.
length: 1843200 offset: 0 timestamp type/source: mono/EoF
Buf[ 124.280233] nvp6188 1-0030: nvp6188_get_fmt: 2006 1280x720 vc 0
fer 0/0 mapped at address 0xffffb9f08000.
length: 1843200 offset: 1843200 timestamp type/source: mono/EoF
Buffer 1/0 mapped at address 0xffffb9d46000.
length: 1843200 offset: 3686400 timestamp type/source: mono/EoF
Buffer 2/0 mapped at address 0xffffb9b84000.
length: 1843200 offset: 5529600 timestamp type/source: mono/EoF
Buffer 3/0 mapped at address 0xffffb99c2000.
length: 1843200 offset: 7372800 timestamp type/source: mono/EoF
Buffer 4/0 mapped at address 0xffffb9800000.
length: 1843200 offset: 9216000 timestamp type/source: mono/EoF
Buffer 5/0 mapped at address 0xffffb963e000.
length: 1843200 offset: 11059200 timestamp type/source: mono/EoF
Buffer 6/0 mapped at address 0xffffb947c000.
length: 1843200 offset: 12902400 timestamp type/source: mono/EoF
Buffer 7/0 mapped at address 0xffffb92ba000.
Unable to start streaming: Broken pipe (32).
8 buffers released.
Simultaneously execute the following commands:
v4l2-ctl -z platform:30102000.ticsi2rx -d "30102000.ticsi2rx context 0" -v width=1280,height=720,pixelformat=UYVY
v4l2-ctl -d2 --set-fmt-video=width=1280,height=720,pixelformat='UYVY' --stream-mmap
root@AM62x:~# v4l2-ctl -z platform:30102000.ticsi2rx -d "30102000.ticsi2rx context 0" -v width=1280,height=720,pixelformat=UYVY
root@AM62x:~# v4l2-ctl -d2 --set-fmt-video=width=1280,height=720,pixelformat='UYVY' --stream-mmap
[ 39.531797] nvp6188 1-0030: nvp6188_get_fmt: 2006 1280x720 vc 0
VIDIOC_STREAMON returned -1 (Broken pipe)
Other supplementary logs are as follows:
root@AM62x:~# uname -a
Linux AM62x 6.6.58-rt45 #3 SMP PREEMPT_RT Thu Feb 13 11:11:26 CST 2025 aarch64 GNU/Linux
root@AM62x:~# dmesg | grep nvp
[ 0.043461] /bus@f0000/i2c@20010000/nvp6188@30: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[ 0.044260] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/nvp6188@30
[ 0.051140] /bus@f0000/i2c@20010000/nvp6188@30: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[ 0.055734] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/nvp6188@30
[ 0.309318] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/nvp6188@30
[ 0.309500] /bus@f0000/i2c@20010000/nvp6188@30: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[ 8.001108] nvp6188 1-0030: driver version: 00.02.00
[ 8.001166] nvp6188 1-0030: using DT '/bus@f0000/i2c@20010000/nvp6188@30' for 'reset' GPIO lookup
[ 8.001216] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/bus@f0000/i2c@20010000/nvp6188@30[0]' - status (0)
[ 8.001272] nvp6188 1-0030: using DT '/bus@f0000/i2c@20010000/nvp6188@30' for 'power' GPIO lookup
[ 8.001288] of_get_named_gpiod_flags: can't parse 'power-gpios' property of node '/bus@f0000/i2c@20010000/nvp6188@30[0]'
[ 8.001305] of_get_named_gpiod_flags: can't parse 'power-gpio' property of node '/bus@f0000/i2c@20010000/nvp6188@30[0]'
[ 8.001318] nvp6188 1-0030: using lookup tables for GPIO lookup
[ 8.001324] nvp6188 1-0030: No GPIO consumer power found
[ 8.001328] nvp6188 1-0030: using DT '/bus@f0000/i2c@20010000/nvp6188@30' for 'vi' GPIO lookup
[ 8.001346] of_get_named_gpiod_flags: can't parse 'vi-gpios' property of node '/bus@f0000/i2c@20010000/nvp6188@30[0]'
[ 8.001363] of_get_named_gpiod_flags: can't parse 'vi-gpio' property of node '/bus@f0000/i2c@20010000/nvp6188@30[0]'
[ 8.001374] nvp6188 1-0030: using lookup tables for GPIO lookup
[ 8.001379] nvp6188 1-0030: No GPIO consumer vi found
[ 8.004823] nvp6188 1-0030: could not get sleep pinstate
[ 8.004877] nvp6188 1-0030: mipi_freq_idx 0
[ 8.004882] nvp6188 1-0030: pixel_rate 729000000
[ 8.004888] nvp6188 1-0030: link_freq 729000000
[ 8.074611] /bus@f0000/i2c@20010000/nvp6188@30: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[ 8.074744] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/nvp6188@30
[ 8.176609] nvp6188 1-0030: chip_id : 0xd0 chip_revid : 0x 0
[ 8.176893] input: nvp6188_input_event as /devices/platform/bus@f0000/20010000.i2c/i2c-1/1-0030/input/input3
[ 8.593728] nvp6188 1-0030: nv6188_set_chn_1080p ch 0 ntpal 0
[ 8.660612] nvp6188 1-0030: channel 0 not detect
[ 8.665109] nvp6188 1-0030: nv6188_set_chn_1080p ch 1 ntpal 0
[ 8.724879] nvp6188 1-0030: channel 1 not detect
[ 8.730094] nvp6188 1-0030: nv6188_set_chn_1080p ch 2 ntpal 0
[ 8.797859] nvp6188 1-0030: channel 2 not detect
[ 8.803571] nvp6188 1-0030: nv6188_set_chn_1080p ch 3 ntpal 0
[ 8.905745] nvp6188 1-0030: channel 3 not detect
[ 8.911447] nvp6188 1-0030: [nvp6188_auto_det_set::2108]
[ 9.118073] nvp6188 1-0030: channel 0 not detect
[ 9.122197] nvp6188 1-0030: channel 1 not detect
[ 9.125079] nvp6188 1-0030: channel 2 not detect
[ 9.133795] nvp6188 1-0030: channel 3 not detect
[ 10.366415] nvp6188 1-0030: nvp6188_open
root@AM62x:~# lsmod | grep v4l
v4l2_fwnode 16384 2 cdns_csi2rx,nvp6188
videobuf2_v4l2 20480 1 j721e_csi2rx
v4l2_async 16384 4 v4l2_fwnode,j721e_csi2rx,cdns_csi2rx,nvp6188
videobuf2_common 40960 4 j721e_csi2rx,videobuf2_dma_contig,videobuf2_v4l2,videobuf2_memops
videodev 180224 6 v4l2_async,v4l2_fwnode,j721e_csi2rx,videobuf2_v4l2,cdns_csi2rx,nvp6188
mc 32768 7 v4l2_async,videodev,j721e_csi2rx,videobuf2_v4l2,cdns_csi2rx,videobuf2_common,nvp6188
root@AM62x:~# lsmod | grep j721
j721e_csi2rx 20480 0
videobuf2_dma_contig 16384 1 j721e_csi2rx
root@AM62x:~# lsmod | grep video
videobuf2_memops 12288 1 videobuf2_dma_contig
root@AM62x:~# lsmod | grep nvp
nvp6188 32768 1
root@AM62x:~# cat /proc/bus/input/devices
I: Bus=0019 Vendor=001f Product=0001 Version=0100
N: Name="pwm-beeper"
P: Phys=pwm/input0
S: Sysfs=/devices/platform/buzzer/input/input0
U: Uniq=
H: Handlers=kbd event0
B: PROP=0
B: EV=40001
B: SND=6
I: Bus=0018 Vendor=dead Product=beef Version=28bb
N: Name="goodix-ts"
P: Phys=input/ts
S: Sysfs=/devices/virtual/input/input1
U: Uniq=
H: Handlers=event1
B: PROP=2
B: EV=b
B: KEY=0
B: ABS=265800000000000
N: Name="goodix-ts"
P: Phys=input/ts
S: Sysfs=/devices/virtual/input/input2
U: Uniq=
H: Handlers=event2
B: PROP=2
B: EV=b
B: KEY=0
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="nvp6188_input_event"
P: Phys=
S: Sysfs=/devices/platform/bus@f0000/20010000.i2c/i2c-1/1-0030/input/input3
U: Uniq=
H: Handlers=event3
B: PROP=0
B: EV=11
B: MSC=8
root@AM62x:~# ls -l /dev/input/
total 0
drwxr-xr-x 2 root root 80 11月 11 18:54 by-path
crw-rw---- 1 root input 13, 64 11月 11 18:54 event0
crw-rw---- 1 root input 13, 65 11月 11 18:54 event1
crw-rw---- 1 root input 13, 66 11月 11 18:54 event2
crw-rw---- 1 root input 13, 67 11月 11 18:54 event3
lrwxrwxrwx 1 root root 6 11月 11 18:54 touchscreen0 -> event2
root@AM62x:~# ls -l /dev/media*
crw-rw---- 1 root video 236, 0 11月 11 18:54 /dev/media0
root@AM62x:~#
root@AM62x:~# ls -l /dev/v4l*
crw-rw---- 1 root video 81, 4 11月 11 18:54 /dev/v4l-subdev0
crw-rw---- 1 root video 81, 5 11月 11 18:54 /dev/v4l-subdev1
crw-rw---- 1 root video 81, 6 11月 11 18:54 /dev/v4l-subdev2
/dev/v4l:
total 0
drwxr-xr-x 2 root root 120 11月 11 18:54 by-path
root@AM62x:~# ls -l /dev/video*
crw-rw---- 1 root video 81, 0 11月 11 18:54 /dev/video0
crw-rw---- 1 root video 81, 1 11月 11 18:54 /dev/video1
crw-rw---- 1 root video 81, 2 11月 11 18:54 /dev/video2
crw-rw---- 1 root video 81, 3 11月 11 18:54 /dev/video3
root@AM62x:~# ls -l /sys/class/video4linux
total 0
lrwxrwxrwx 1 root root 0 11月 11 18:56 v4l-subdev0 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/v4l-subdev0
lrwxrwxrwx 1 root root 0 11月 11 18:56 v4l-subdev1 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/30101000.csi-bridge/video4linux/v4l-subdev1
lrwxrwxrwx 1 root root 0 11月 11 18:56 v4l-subdev2 -> ../../devices/platform/bus@f0000/20010000.i2c/i2c-1/1-0030/video4linux/v4l-subdev2
lrwxrwxrwx 1 root root 0 11月 11 18:56 video0 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/video0
lrwxrwxrwx 1 root root 0 11月 11 18:56 video1 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/video1
lrwxrwxrwx 1 root root 0 11月 11 18:56 video2 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/video2
lrwxrwxrwx 1 root root 0 11月 11 18:56 video3 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/video3
root@AM62x:~# v4l2-ctl --list-devices
[ 198.332682] nvp6188 1-0030: nvp6188_open
j721e-csi2rx (platform:30102000.ticsi2rx):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
/dev/media0
root@AM62x:~# v4l2-ctl -d /dev/video0 --all
Driver Info:
Driver name : j721e-csi2rx
Card type : j721e-csi2rx
Bus info : platform:30102000.ticsi2rx
Driver version : 6.6.58
Capabilities : 0xa4200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x24200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : TI-CSI2RX
Serial :
Media version : 6.6.58
Hardware revision: 0x00000001 (1)
Interface Info:
Type : V4L Video
Entity Info:
Name : 30102000.ticsi2rx context 0
Function : V4L2 I/O
Pad 0x01000014 : 0: Sink
Link 0x02000017: from remote pad 0x1000003 of entity '30102000.ticsi2rx' (Video Interface Bridge): Data, Enabled, Immutable
Priority: 2
Video input : 0 (30102000.ticsi2rx context 0: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'UYVY' (UYVY 4:2:2)
Field : None
Bytes per Line : 1280
Size Image : 614400
Colorspace : sRGB
Transfer Function : sRGB
YCbCr/HSV Encoding: ITU-R 601
Quantization : Limited Range
Flags :
driver j721e-csi2rx
model TI-CSI2RX
serial
hw revision 0x1
Device topology
pad0: Sink
pad1: Source
pad2: Source
pad3: Source
pad4: Source
pad0: Sink
pad1: Source
pad2: Source
pad3: Source
pad4: Source
pad0: Source
pad0: Sink
pad0: Sink
pad0: Sink
pad0: Sink
root@AM62x:~# media-ctl -d /dev/media0 -e 'm00_b_nvp6188 1-0030'
/dev/v4l-subdev2
root@AM62x:~# media-ctl --known-mbus-fmts
RGB444_1X12 0x1016
RGB444_2X8_PADHI_BE 0x1001
RGB444_2X8_PADHI_LE 0x1002
RGB555_2X8_PADHI_BE 0x1003
RGB555_2X8_PADHI_LE 0x1004
RGB565_1X16 0x1017
BGR565_2X8_BE 0x1005
BGR565_2X8_LE 0x1006
RGB565_2X8_BE 0x1007
RGB565_2X8_LE 0x1008
RGB666_1X18 0x1009
RBG888_1X24 0x100e
RGB666_1X24_CPADHI 0x1015
RGB666_1X7X3_SPWG 0x1010
BGR888_1X24 0x1013
BGR888_3X8 0x101b
GBR888_1X24 0x1014
RGB888_1X24 0x100a
RGB888_2X12_BE 0x100b
RGB888_2X12_LE 0x100c
RGB888_3X8 0x101c
RGB888_3X8_DELTA 0x101d
RGB888_1X7X4_SPWG 0x1011
RGB888_1X7X4_JEIDA 0x1012
ARGB8888_1X32 0x100d
RGB888_1X32_PADHI 0x100f
RGB101010_1X30 0x1018
RGB121212_1X36 0x1019
RGB161616_1X48 0x101a
Y8_1X8 0x2001
UV8_1X8 0x2015
UYVY8_1_5X8 0x2002
VYUY8_1_5X8 0x2003
YUYV8_1_5X8 0x2004
YVYU8_1_5X8 0x2005
UYVY8_2X8 0x2006
VYUY8_2X8 0x2007
YUYV8_2X8 0x2008
YVYU8_2X8 0x2009
Y10_1X10 0x200a
Y10_2X8_PADHI_LE 0x202c
UYVY10_2X10 0x2018
VYUY10_2X10 0x2019
YUYV10_2X10 0x200b
YVYU10_2X10 0x200c
Y12_1X12 0x2013
UYVY12_2X12 0x201c
VYUY12_2X12 0x201d
YUYV12_2X12 0x201e
YVYU12_2X12 0x201f
Y14_1X14 0x202d
UYVY8_1X16 0x200f
VYUY8_1X16 0x2010
YUYV8_1X16 0x2011
YVYU8_1X16 0x2012
YDYUYDYV8_1X16 0x2014
UYVY10_1X20 0x201a
VYUY10_1X20 0x201b
YUYV10_1X20 0x200d
YVYU10_1X20 0x200e
VUY8_1X24 0x2024
YUV8_1X24 0x2025
UYYVYY8_0_5X24 0x2026
UYVY12_1X24 0x2020
VYUY12_1X24 0x2021
YUYV12_1X24 0x2022
YVYU12_1X24 0x2023
YUV10_1X30 0x2016
UYYVYY10_0_5X30 0x2027
AYUV8_1X32 0x2017
UYYVYY12_0_5X36 0x2028
YUV12_1X36 0x2029
YUV16_1X48 0x202a
UYYVYY16_0_5X48 0x202b
SBGGR8_1X8 0x3001
SGBRG8_1X8 0x3013
SGRBG8_1X8 0x3002
SRGGB8_1X8 0x3014
SBGGR10_ALAW8_1X8 0x3015
SGBRG10_ALAW8_1X8 0x3016
SGRBG10_ALAW8_1X8 0x3017
SRGGB10_ALAW8_1X8 0x3018
SBGGR10_DPCM8_1X8 0x300b
SGBRG10_DPCM8_1X8 0x300c
SGRBG10_DPCM8_1X8 0x3009
SRGGB10_DPCM8_1X8 0x300d
SBGGR10_2X8_PADHI_BE 0x3003
SBGGR10_2X8_PADHI_LE 0x3004
SBGGR10_2X8_PADLO_BE 0x3005
SBGGR10_2X8_PADLO_LE 0x3006
SBGGR10_1X10 0x3007
SGBRG10_1X10 0x300e
SGRBG10_1X10 0x300a
SRGGB10_1X10 0x300f
SBGGR12_1X12 0x3008
SGBRG12_1X12 0x3010
SGRBG12_1X12 0x3011
SRGGB12_1X12 0x3012
SBGGR14_1X14 0x3019
SGBRG14_1X14 0x301a
SGRBG14_1X14 0x301b
SRGGB14_1X14 0x301c
SBGGR16_1X16 0x301d
SGBRG16_1X16 0x301e
SGRBG16_1X16 0x301f
SRGGB16_1X16 0x3020
JPEG_1X8 0x4001
S5C_UYVY_JPEG_1X8 0x5001
AHSV8888_1X32 0x6001
root@AM62x:~# v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Size: Stepwise 8x1 - 8192x16384 with step 8/1
[1]: 'UYVY' (UYVY 4:2:2)
[2]: 'YVYU' (YVYU 4:2:2)
[3]: 'VYUY' (VYUY 4:2:2)
[4]: 'BA81' (8-bit Bayer BGBG/GRGR)
Size: Stepwise 16x1 - 16384x16384 with step 16/1
[5]: 'GBRG' (8-bit Bayer GBGB/RGRG)
[6]: 'GRBG' (8-bit Bayer GRGR/BGBG)
[7]: 'RGGB' (8-bit Bayer RGRG/GBGB)
[8]: 'GREY' (8-bit Greyscale)
[9]: 'BG10' (10-bit Bayer BGBG/GRGR)
[10]: 'GB10' (10-bit Bayer GBGB/RGRG)
[11]: 'BA10' (10-bit Bayer GRGR/BGBG)
[12]: 'RG10' (10-bit Bayer RGRG/GBGB)
[13]: 'RGI0' (10-bit Bayer RGBG/GIrGIr)
[14]: 'GRI0' (10-bit Bayer GRGB/IrGIrG)
[15]: 'BGI0' (10-bit Bayer BGRG/GIrGIr)
[16]: 'GBI0' (10-bit Bayer GBGR/IrGIrG)
[17]: 'GIR0' (10-bit Bayer GIrGIr/RGBG)
[18]: 'IGR0' (10-bit Bayer IrGIrG/GRGB)
[19]: 'GIB0' (10-bit Bayer GIrGIr/BGRG)
[20]: 'IGB0' (10-bit Bayer IrGIrG/GBGR)
[21]: 'BG12' (12-bit Bayer BGBG/GRGR)
[22]: 'GB12' (12-bit Bayer GBGB/RGRG)
[23]: 'BA12' (12-bit Bayer GRGR/BGBG)
[24]: 'RG12' (12-bit Bayer RGRG/GBGB)
[25]: 'RGBR' (16-bit RGB 5-6-5 BE)
[26]: 'XR24' (32-bit BGRX 8-8-8-8)
Size: Stepwise 4x1 - 4096x16384 with step 4/1
[27]: 'XB24' (32-bit RGBX 8-8-8-8)
root@AM62x:~# v4l2-ctl -d /dev/v4l-subdev2 --list-subdev-mbus-codes pad=0
[ 326.929497] nvp6188 1-0030: nvp6188_open
ioctl: VIDIOC_SUBDEV_ENUM_MBUS_CODE (pad=0)
0x2006: MEDIA_BUS_FMT_UYVY8_2X8
root@AM62x:~# v4l2-ctl -d /dev/v4l-subdev2 --list-subdev-framesizes pad=0,code=0x2006
[ 344.161576] nvp6188 1-0030: nvp6188_open
ioctl: VIDIOC_SUBDEV_ENUM_FRAME_SIZE (pad=0)
[ 344.165756] nvp6188 1-0030: nvp6188_enum_frame_sizes:
Size Range: 1280x720 - 1280x720
[ 344.174852] nvp6188 1-0030: nvp6188_enum_frame_sizes:
Size Range: 1920x1080 - 1920x1080
[ 344.182881] nvp6188 1-0030: nvp6188_enum_frame_sizes:
Size Range: 960x480 - 960x480
[ 344.191079] nvp6188 1-0030: nvp6188_enum_frame_sizes:
root@AM62x:~# v4l2-ctl -d /dev/v4l-subdev2 --list-subdev-frameintervals pad=0,width=1920,height=1080,code=0x2006
ioctl: VIDIOC_SUBDEV_ENUM_FRAME_INTERVAL (pad=0)
[ 360.548919] nvp6188 1-0030: nvp6188_open
Interval: 0.040s (25.000 fps)
root@AM62x:~# v4l2-ctl -d /dev/v4l-subdev2 --list-subdev-frameintervals pad=0,width=1280,height=720,code=0x2006
[ 374.232898] nvp6188 1-0030: nvp6188_open
root@AM62x:~# v4l2-ctl -d /dev/v4l-subdev2 --list-subdev-frameintervals pad=0,width=960,height=480,code=0x2006
[ 387.223505] nvp6188 1-0030: nvp6188_open
root@AM62x:~# v4l2-ctl -d2 --stream-mmap
[ 408.438040] nvp6188 1-0030: nvp6188_get_fmt: 2006 1280x720 vc 0
Video can be collected normally in SDK 8.6, and the corresponding logs are as follows:
Linux AM62x 5.10.168-rt83-gc1a1291911 #1 SMP PREEMPT_RT Thu Jan 23 08:09:06 UTC 2025 aarch64 GNU/Linux
[ 7.247453] nvp6188 1-0030: driver version: 00.01.00
[ 7.247615] nvp6188 1-0030: could not get sleep pinstate
[ 7.248189] nvp6188 1-0030: mipi_freq_idx 0
[ 7.248198] nvp6188 1-0030: pixel_rate 729000000
[ 7.248203] nvp6188 1-0030: link_freq 729000000
[ 7.311060] nvp6188 1-0030: chip_id : 0xd0 chip_revid : 0x 0
[ 7.338557] input: nvp6188_input_event as /devices/platform/bus@f0000/20010000.i2c/i2c-1/1-0030/input/input3
[ 10.643346] nvp6188 1-0030: nvp6188_open
v4l2_fwnode 24576 2 cdns_csi2rx,nvp6188
j721e_csi2rx 24576 0
videobuf2_dma_contig 24576 1 j721e_csi2rx
nvp6188 45056 1
P: Phys=pwm/input0
U: Uniq=
B: PROP=0
B: EV=40001
B: SND=6
N: Name="goodix-ts"
P: Phys=input/ts
U: Uniq=
H: Handlers=event1
B: PROP=2
B: EV=b
B: KEY=0
N: Name="goodix-ts"
P: Phys=input/ts
U: Uniq=
H: Handlers=event2
B: PROP=2
B: EV=b
B: KEY=0
P: Phys=
U: Uniq=
H: Handlers=event3
B: PROP=0
B: EV=11
B: MSC=8
total 0
drwxr-xr-x 2 root root 80 10月 22 17:47 by-path
crw-rw---- 1 root input 13, 64 10月 22 17:47 event0
crw-rw---- 1 root input 13, 65 10月 22 17:47 event1
crw-rw---- 1 root input 13, 66 10月 22 17:47 event2
crw-rw---- 1 root input 13, 67 10月 22 17:47 event3
lrwxrwxrwx 1 root root 6 10月 22 17:47 touchscreen0 -> event2
crw-rw---- 1 root video 250, 0 10月 22 17:47 /dev/media0
crw-rw---- 1 root video 81, 4 10月 22 17:47 /dev/v4l-subdev0
crw-rw---- 1 root video 81, 5 10月 22 17:47 /dev/v4l-subdev1
crw-rw---- 1 root video 81, 6 10月 22 17:47 /dev/v4l-subdev2
/dev/v4l:
total 0
drwxr-xr-x 2 root root 120 10月 22 17:47 by-path
crw-rw---- 1 root video 81, 0 10月 22 17:47 /dev/video0
crw-rw---- 1 root video 81, 1 10月 22 17:47 /dev/video1
crw-rw---- 1 root video 81, 2 10月 22 17:47 /dev/video2
crw-rw---- 1 root video 81, 3 10月 22 17:47 /dev/video3
total 0
lrwxrwxrwx 1 root root 0 10月 22 18:09 v4l-subdev0 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/v4l-subdev0
lrwxrwxrwx 1 root root 0 10月 22 18:09 v4l-subdev1 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/30101000.csi-bridge/video4linux/v4l-subdev1
lrwxrwxrwx 1 root root 0 10月 22 18:09 v4l-subdev2 -> ../../devices/platform/bus@f0000/20010000.i2c/i2c-1/1-0030/video4linux/v4l-subdev2
lrwxrwxrwx 1 root root 0 10月 22 18:09 video0 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/video0
lrwxrwxrwx 1 root root 0 10月 22 18:09 video1 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/video1
lrwxrwxrwx 1 root root 0 10月 22 18:09 video2 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/video2
lrwxrwxrwx 1 root root 0 10月 22 18:09 video3 -> ../../devices/platform/bus@f0000/30102000.ticsi2rx/video4linux/video3
j721e-csi2rx (platform:30102000.ticsi2rx):[ 1334.906938] nvp6188 1-0030: nvp6188_open
/dev/video0
/dev/video1
/dev/video2
/dev/video3
/dev/media0
Driver Info:
Driver version : 5.10.168
Capabilities : 0xa5200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x25200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Media Driver Info:
Model : TI-CSI2RX
Serial :
Media version : 5.10.168
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Priority: 2
Field : Any
Size Image : 614400
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
Media controller API version 5.10.168[ 1363.684331] nvp6188 1-0030: nvp6188_open
driver [ 1363.684365] nvp6188 1-0030: nvp6188_get_fmt: 2006 1280x720 vc 0
j721e-csi2rx
model TI-CSI2RX
serial
hw revision 0x1
driver version 5.10.168
Device topology
pad0: Sink
pad1: Source
pad2: Source
pad3: Source
pad4: Source
pad0: Sink
pad1: Source
pad2: Source
pad3: Source
pad4: Source
pad0: Source
pad0: Sink
pad0: Sink
pad0: Sink
pad0: Sink
/dev/v4l-subdev2
RGB444_1X12 0x1016
RGB565_1X16 0x1017
RGB666_1X18 0x1009
RBG888_1X24 0x100e
BGR888_1X24 0x1013
BGR888_3X8 0x101b
GBR888_1X24 0x1014
RGB888_1X24 0x100a
RGB888_3X8 0x101c
Y8_1X8 0x2001
UV8_1X8 0x2015
UYVY8_1_5X8 0x2002
VYUY8_1_5X8 0x2003
YUYV8_1_5X8 0x2004
YVYU8_1_5X8 0x2005
UYVY8_2X8 0x2006
VYUY8_2X8 0x2007
YUYV8_2X8 0x2008
YVYU8_2X8 0x2009
Y10_1X10 0x200a
UYVY10_2X10 0x2018
VYUY10_2X10 0x2019
YUYV10_2X10 0x200b
YVYU10_2X10 0x200c
Y12_1X12 0x2013
UYVY12_2X12 0x201c
VYUY12_2X12 0x201d
YUYV12_2X12 0x201e
YVYU12_2X12 0x201f
Y14_1X14 0x202d
UYVY8_1X16 0x200f
VYUY8_1X16 0x2010
YUYV8_1X16 0x2011
YVYU8_1X16 0x2012
UYVY10_1X20 0x201a
VYUY10_1X20 0x201b
YUYV10_1X20 0x200d
YVYU10_1X20 0x200e
VUY8_1X24 0x2024
YUV8_1X24 0x2025
UYVY12_1X24 0x2020
VYUY12_1X24 0x2021
YUYV12_1X24 0x2022
YVYU12_1X24 0x2023
YUV10_1X30 0x2016
AYUV8_1X32 0x2017
YUV12_1X36 0x2029
YUV16_1X48 0x202a
SBGGR8_1X8 0x3001
SGBRG8_1X8 0x3013
SGRBG8_1X8 0x3002
SRGGB8_1X8 0x3014
SBGGR10_1X10 0x3007
SGBRG10_1X10 0x300e
SGRBG10_1X10 0x300a
SRGGB10_1X10 0x300f
SBGGR12_1X12 0x3008
SGBRG12_1X12 0x3010
SGRBG12_1X12 0x3011
SRGGB12_1X12 0x3012
SBGGR14_1X14 0x3019
SGBRG14_1X14 0x301a
SGRBG14_1X14 0x301b
SRGGB14_1X14 0x301c
SBGGR16_1X16 0x301d
SGBRG16_1X16 0x301e
SGRBG16_1X16 0x301f
SRGGB16_1X16 0x3020
JPEG_1X8 0x4001
Type: Video Capture
Size: Stepwise 8x1 - 16777216x16777216 with step 8/1
Size: Stepwise 16x1 - 16777216x16777216 with step 16/1
[8]: 'BG10' (10-bit Bayer BGBG/GRGR)
[9]: 'GB10' (10-bit Bayer GBGB/RGRG)
[10]: 'BA10' (10-bit Bayer GRGR/BGBG)
[11]: 'RG10' (10-bit Bayer RGRG/GBGB)
[12]: 'BG12' (12-bit Bayer BGBG/GRGR)
[13]: 'GB12' (12-bit Bayer GBGB/RGRG)
[14]: 'BA12' (12-bit Bayer GRGR/BGBG)
[15]: 'RG12' (12-bit Bayer RGRG/GBGB)
[16]: 'RGI0' (10-bit Bayer RGBG/GIrGIr)
[17]: 'GRI0' (10-bit Bayer GRGB/IrGIrG)
[18]: 'BGI0' (10-bit Bayer BGRG/GIrGIr)
[19]: 'GBI0' (10-bit Bayer GBGR/IrGIrG)
[20]: 'GIR0' (10-bit Bayer GIrGIr/RGBG)
[21]: 'IGR0' (10-bit Bayer IrGIrG/GRGB)
[22]: 'GIB0' (10-bit Bayer GIrGIr/BGRG)
[23]: 'IGB0' (10-bit Bayer IrGIrG/GBGR)
[ 1422.830313] nvp6188 1-0030: nvp6188_open
[ 1427.915439] nvp6188 1-0030: nvp6188_open
[ 1427.919914] nvp6188 1-0030: nvp6188_enum_frame_sizes:
[ 1427.919964] nvp6188 1-0030: nvp6188_enum_frame_sizes:
[ 1427.919981] nvp6188 1-0030: nvp6188_enum_frame_sizes:
[ 1427.919996] nvp6188 1-0030: nvp6188_enum_frame_sizes:
[ 29.314048] nvp6188 1-0030: nvp6188_open
[ 29.484506] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
/GstPipeline:pipeline0/GstKMSSink:kmssink0: display-height =[ 29.528822] nvp6188 1-0030: s_stream: 1. 1280x720
800
管道被 PREROLLED ...
设置播放管道 ...
[ 30.262754] nvp6188 1-0030: read vfc 0x21 0xff 0xff 0xff
[ 30.271176] nvp6188 1-0030: channel 0 det 720p pal
[ 30.274280] nvp6188 1-0030: channel 1 not detect, def 1080p pal
[ 30.277387] nvp6188 1-0030: channel 2 not detect, def 1080p pal
[ 30.280502] nvp6188 1-0030: channel 3 not detect, def 1080p pal
[ 30.280509] nvp6188 1-0030: nv6188_set_chn_1080p ch 3 ntpal 1
[ 30.322567] nvp6188 1-0030: nv6188_set_chn_1080p ch 2 ntpal 1
[ 30.364684] nvp6188 1-0030: nv6188_set_chn_1080p ch 1 ntpal 1
[ 30.412045] nvp6188 1-0030: nv6188_set_chn_720p ch 0 ntpal 1
重新分配延迟时间...
handling interrupt.:99.
中断: 中止管道 ...
Execution ended after 0:00:05.769800320
设置 NULL 管道 ...
[ 35.408428] nvp6188 1-0030: s_stream: 0. 1280x720
释放管道资源 ...
[ 55.588958] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
/GstPipeline:pipeline0/GstKMSSink:kmssink0: display-height =[ 55.615869] nvp6188 1-0030: s_stream: 1. 1280x720
800
管道被 PREROLLED ...
设置播放管道 ...
[ 56.336793] nvp6188 1-0030: read vfc 0x21 0xff 0xff 0xff
[ 56.342828] nvp6188 1-0030: channel 0 det 720p pal
[ 56.345950] nvp6188 1-0030: channel 1 not detect, def 1080p pal
[ 56.349101] nvp6188 1-0030: channel 2 not detect, def 1080p pal
[ 56.352190] nvp6188 1-0030: channel 3 not detect, def 1080p pal
[ 56.352197] nvp6188 1-0030: nv6188_set_chn_1080p ch 3 ntpal 1
[ 56.394209] nvp6188 1-0030: nv6188_set_chn_1080p ch 2 ntpal 1
[ 56.439040] nvp6188 1-0030: nv6188_set_chn_1080p ch 1 ntpal 1
[ 56.481080] nvp6188 1-0030: nv6188_set_chn_720p ch 0 ntpal 1
0:00:01.013977945 1075 0xaaaab3cc7800 WARN v4l2bufferpool gstv4l2bufferpool.c:1373:gst_v4l2_buffer_pool_dqbuf:<v4l2src0:pool0:src> Driver should never set v4l2_buffer.field to ANY
重新分配延迟时间...
^Chandling interrupt.
中断: 中止管道 ...
Execution ended after 0:00:07.131747715
设置 NULL 管道 ...
[ 62.823811] nvp6188 1-0030: s_stream: 0. 1280x720
释放管道资源 ...
[ 87.517401] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
从组件“kmssink0”获得消息 #9(property-notify): GstMessagePropertyNotify, property-name=(string)display-width, pr[ 87.544881] nvp6188 1-0030: s_stream: 1. 1280x720
管道被 PREROLLED ...
设置播放管道 ...
从填充“v4l2src0:src”获得消息 #27(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt709";
从填充“capsfilter0:src”获得消息 #29(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt709";
从填充“kmssink0:sink”获得消息 #30(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt709";
从填充“capsfilter0:sink”获得消息 #31(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)bt709";
从组件“pipeline0”获得消息 #32(new-clock): GstMessageNewClock, clock=(GstClock)"\(GstSystemClock\)\ GstSystemClock";
从组件“capsfilter0”获得消息 #34(state-changed): GstMessageStateChanged, old-state=(GstState)paused, new-state=(GstState)playing, pending-state=(GstState)void-pending;
从组件“v4l2src0”获得消息 #35(state-changed): GstMessageStateChanged, old-state=(GstState)paused, new-state=(GstState)playing, pending-state=(GstState)void-pending;
[ 88.267209] nvp6188 1-0030: read vfc 0x21 0xff 0xff 0xff
[ 88.270465] nvp6188 1-0030: channel 0 det 720p pal
[ 88.273595] nvp6188 1-0030: channel 1 not detect, def 1080p pal
[ 88.276704] nvp6188 1-0030: channel 2 not detect, def 1080p pal
[ 88.279890] nvp6188 1-0030: channel 3 not detect, def 1080p pal
[ 88.279898] nvp6188 1-0030: nv6188_set_chn_1080p ch 3 ntpal 1
[ 88.321948] nvp6188 1-0030: nv6188_set_chn_1080p ch 2 ntpal 1
[ 88.364144] nvp6188 1-0030: nv6188_set_chn_1080p ch 1 ntpal 1
[ 88.406244] nvp6188 1-0030: nv6188_set_chn_720p ch 0 ntpal 1
从组件“kmssink0”获得消息 #38(state-changed): GstMessageStateChanged, old-state=(GstState)ready, new-state=(GstState)paused, pending-state=(GstState)void-pending;
从组件“pipeline0”获得消息 #40(async-done): GstMessageAsyncDone, running-time=(guint64)18446744073709551615;
从组件“kmssink0”获得消息 #41(latency): no message details
重新分配延迟时间...
从组件“kmssink0”获得消息 #44(state-changed): GstMessageStateChanged, old-state=(GstState)paused, new-state=(GstState)playing, pending-state=(GstState)void-pending;
从组件“pipeline0”获得消息 #45(state-changed): GstMessageStateChanged, old-state=(GstState)paused, new-state=(GstState)playing, pending-state=(GstState)void-pending;
从组件“kmssink0”获得消息 #47(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)999886825, stream-time=(guint64)999886825, timestamp=(guint64)999886825, duration=(guint64)8333333, jitter=(gint64)19856317, proportion=(double)0.96042432356465368, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)2, dropped=(guint64)1;
从组件“kmssink0”获得消息 #53(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1239878750, stream-time=(guint64)1239878750, timestamp=(guint64)1239878750, duration=(guint64)8333333, jitter=(gint64)15219577, proportion=(double)0.96172722315250392, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)6, dropped=(guint64)2;
从组件“kmssink0”获得消息 #57(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1359886570, stream-time=(guint64)1359886570, timestamp=(guint64)1359886570, duration=(guint64)8333333, jitter=(gint64)13574777, proportion=(double)0.91875242877685204, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)8, dropped=(guint64)3;
从组件“kmssink0”获得消息 #62(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1519907895, stream-time=(guint64)1519907895, timestamp=(guint64)1519907895, duration=(guint64)8333333, jitter=(gint64)20599327, proportion=(double)0.89321967381884981, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)11, dropped=(guint64)4;
从组件“kmssink0”获得消息 #68(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1759898860, stream-time=(guint64)1759898860, timestamp=(guint64)1759898860, duration=(guint64)8333333, jitter=(gint64)15948497, proportion=(double)0.90000314104136581, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)15, dropped=(guint64)5;
从组件“kmssink0”获得消息 #72(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1879894455, stream-time=(guint64)1879894455, timestamp=(guint64)1879894455, duration=(guint64)8333333, jitter=(gint64)14363192, proportion=(double)0.88552703082642703, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)17, dropped=(guint64)6;
从组件“kmssink0”获得消息 #77(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2039889730, stream-time=(guint64)2039889730, timestamp=(guint64)2039889730, duration=(guint64)8333333, jitter=(gint64)21389962, proportion=(double)0.86998036509633259, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)20, dropped=(guint64)7;
从组件“kmssink0”获得消息 #83(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2279899260, stream-time=(guint64)2279899260, timestamp=(guint64)2279899260, duration=(guint64)8333333, jitter=(gint64)56907477, proportion=(double)0.88715067618470544, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)24, dropped=(guint64)8;
从组件“kmssink0”获得消息 #85(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2319884605, stream-time=(guint64)2319884605, timestamp=(guint64)2319884605, duration=(guint64)8333333, jitter=(gint64)17136457, proportion=(double)1.0028570048782315, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)24, dropped=(guint64)9;
从组件“kmssink0”获得消息 #90(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2519903115, stream-time=(guint64)2519903115, timestamp=(guint64)2519903115, duration=(guint64)8333333, jitter=(gint64)13516962, proportion=(double)0.87894688174959845, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)27, dropped=(guint64)10;
从组件“kmssink0”获得消息 #95(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2679905625, stream-time=(guint64)2679905625, timestamp=(guint64)2679905625, duration=(guint64)8333333, jitter=(gint64)20569092, proportion=(double)0.88654380626723206, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)30, dropped=(guint64)11;
从组件“kmssink0”获得消息 #101(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2919902525, stream-time=(guint64)2919902525, timestamp=(guint64)2919902525, duration=(guint64)8333333, jitter=(gint64)15942337, proportion=(double)0.89590568883081323, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)34, dropped=(guint64)12;
从组件“kmssink0”获得消息 #105(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)3039900350, stream-time=(guint64)3039900350, timestamp=(guint64)3039900350, duration=(guint64)8333333, jitter=(gint64)14351312, proportion=(double)0.88340738903620741, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)36, dropped=(guint64)13;
从组件“kmssink0”获得消息 #110(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)3199910100, stream-time=(guint64)3199910100, timestamp=(guint64)3199910100, duration=(guint64)8333333, jitter=(gint64)21403242, proportion=(double)0.86855986545633246, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)39, dropped=(guint64)14;
从组件“kmssink0”获得消息 #116(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)3439907195, stream-time=(guint64)3439907195, timestamp=(guint64)3439907195, duration=(guint64)8333333, jitter=(gint64)56992017, proportion=(double)0.88632183567579859, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)43, dropped=(guint64)15;
从组件“kmssink0”获得消息 #118(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)3479906980, stream-time=(guint64)3479906980, timestamp=(guint64)3479906980, duration=(guint64)8333333, jitter=(gint64)17330412, proportion=(double)1.0024019212123585, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)43, dropped=(guint64)16;
从组件“kmssink0”获得消息 #123(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)3679916170, stream-time=(guint64)3679916170, timestamp=(guint64)3679916170, duration=(guint64)8333333, jitter=(gint64)13515977, proportion=(double)0.87888680349227055, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)46, dropped=(guint64)17;
从组件“kmssink0”获得消息 #128(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)3839910245, stream-time=(guint64)3839910245, timestamp=(guint64)3839910245, duration=(guint64)8333333, jitter=(gint64)20559172, proportion=(double)0.88622380311692162, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)49, dropped=(guint64)18;
从组件“kmssink0”获得消息 #134(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)4079921160, stream-time=(guint64)4079921160, timestamp=(guint64)4079921160, duration=(guint64)8333333, jitter=(gint64)16016092, proportion=(double)0.89568960728142366, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)53, dropped=(guint64)19;
从组件“kmssink0”获得消息 #138(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)4199933655, stream-time=(guint64)4199933655, timestamp=(guint64)4199933655, duration=(guint64)8333333, jitter=(gint64)14339132, proportion=(double)0.88354378787654386, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)55, dropped=(guint64)20;
从组件“kmssink0”获得消息 #143(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)4359921260, stream-time=(guint64)4359921260, timestamp=(guint64)4359921260, duration=(guint64)8333333, jitter=(gint64)21388402, proportion=(double)0.86848288659772799, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)58, dropped=(guint64)21;
从组件“pipeline0”获得消息 #146(application): GstLaunchInterrupt, message=(string)"Pipeline\ interrupted";
中断: 中止管道 ...
Execution ended after 0:00:04.536596065
设置 NULL 管道 ...
[ 92.130539] nvp6188 1-0030: s_stream: 0. 1280x720
释放管道资源 ...
[ 112.530468] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
/GstPipeline:pipel[ 112.555704] nvp6188 1-0030: s_stream: 1. 1280x720
管道被 PREROLLED ...
设置播放管道 ...
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:16:1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:16:1
/GstPipeline:pipeline0/GstKMSSink:kmssink0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:16:1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:16:1
[ 113.319042] nvp6188 1-0030: read vfc 0x21 0xff 0xff 0xff
[ 113.322479] nvp6188 1-0030: channel 0 det 720p pal
[ 113.325582] nvp6188 1-0030: channel 1 not detect, def 1080p pal
[ 113.328686] nvp6188 1-0030: channel 2 not detect, def 1080p pal
[ 113.331779] nvp6188 1-0030: channel 3 not detect, def 1080p pal
[ 113.331793] nvp6188 1-0030: nv6188_set_chn_1080p ch 3 ntpal 1
[ 113.374047] nvp6188 1-0030: nv6188_set_chn_1080p ch 2 ntpal 1
[ 113.416190] nvp6188 1-0030: nv6188_set_chn_1080p ch 1 ntpal 1
[ 113.458283] nvp6188 1-0030: nv6188_set_chn_720p ch 0 ntpal 1
重新分配延迟时间...9.
[ 117.132526] nvp6188 1-0030: s_stream: 0. 1280x720
中断: 中止管道 ...
Execution ended after 0:00:04.581424855
设置 NULL 管道 ...
释放管道资源 ...
[ 134.563520] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
/GstPipeline:pipeline0/GstKMSSink:kmssink0: display-width = 1280[ 134.587397] nvp6188 1-0030: s_stream: 1. 1280x720
管道被 PREROLLED ...
设置播放管道 ...
[ 135.332079] nvp6188 1-0030: read vfc 0x21 0xff 0xff 0xff
[ 135.335448] nvp6188 1-0030: channel 0 det 720p pal
[ 135.338574] nvp6188 1-0030: channel 1 not detect, def 1080p pal
[ 135.341668] nvp6188 1-0030: channel 2 not detect, def 1080p pal
[ 135.344693] nvp6188 1-0030: channel 3 not detect, def 1080p pal
[ 135.344701] nvp6188 1-0030: nv6188_set_chn_1080p ch 3 ntpal 1
[ 135.386749] nvp6188 1-0030: nv6188_set_chn_1080p ch 2 ntpal 1
[ 135.428915] nvp6188 1-0030: nv6188_set_chn_1080p ch 1 ntpal 1
[ 135.471134] nvp6188 1-0030: nv6188_set_chn_720p ch 0 ntpal 1
0:00:01.023507300 1092 0xaaaaddbee800 WARN v4l2bufferpool gstv4l2bufferpool.c:1373:gst_v4l2_buffer_pool_dqbuf:<v4l2src0:pool0:src> Driver should never set v4l2_buffer.field to ANY
重新分配延迟时间...
中断: 中止管道 ...
Execution ended after 0:00:04.289882635
设置 NULL 管道 ...
[ 138.909449] nvp6188 1-0030: s_stream: 0. 1280x720
释放管道资源 ...
[ 160.481189] nvp6188 1-0030: nvp6188_open
设置暂停管道 ...
从组件“kmssink0”获得消息 #9(property-notify):[ 160.505755] nvp6188 1-0030: s_stream: 1. 1280x720
管道被 PREROLLED ...
设置播放管道 ...
从填充“v4l2src0:src”获得消息 #27(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:16:1";
从填充“capsfilter0:src”获得消息 #29(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:16:1";
从填充“kmssink0:sink”获得消息 #30(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:16:1";
从填充“capsfilter0:sink”获得消息 #31(property-notify): GstMessagePropertyNotify, property-name=(string)caps, property-value=(GstCaps)"video/x-raw\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ format\=\(string\)YUY2\,\ framerate\=\(fraction\)120/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:16:1";
[ 161.258239] nvp6188 1-0030: read vfc 0x21 0xff 0xff 0xff
[ 161.261463] nvp6188 1-0030: channel 0 det 720p pal
[ 161.264593] nvp6188 1-0030: channel 1 not detect, def 1080p pal
[ 161.267699] nvp6188 1-0030: channel 2 not detect, def 1080p pal
[ 161.270878] nvp6188 1-0030: channel 3 not detect, def 1080p pal
[ 161.270886] nvp6188 1-0030: nv6188_set_chn_1080p ch 3 ntpal 1
[ 161.312962] nvp6188 1-0030: nv6188_set_chn_1080p ch 2 ntpal 1
[ 161.355146] nvp6188 1-0030: nv6188_set_chn_1080p ch 1 ntpal 1
[ 161.397260] nvp6188 1-0030: nv6188_set_chn_720p ch 0 ntpal 1
重新分配延迟时间...
从组件“kmssink0”获得消息 #46(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)938440550, stream-time=(guint64)938440550, timestamp=(guint64)938440550, duration=(guint64)8333333, jitter=(gint64)54108347, proportion=(double)-1, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)1, dropped=(guint64)1;
从组件“kmssink0”获得消息 #51(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1116633115, stream-time=(guint64)1116633115, timestamp=(guint64)1116633115, duration=(guint64)8333333, jitter=(gint64)56947742, proportion=(double)777.67874569344656, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)4, dropped=(guint64)2;
从组件“kmssink0”获得消息 #53(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1156630480, stream-time=(guint64)1156630480, timestamp=(guint64)1156630480, duration=(guint64)8333333, jitter=(gint64)17094482, proportion=(double)2.6162870561319531, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)4, dropped=(guint64)3;
从组件“kmssink0”获得消息 #58(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1356636650, stream-time=(guint64)1356636650, timestamp=(guint64)1356636650, duration=(guint64)8333333, jitter=(gint64)14651382, proportion=(double)1.6413509200477527, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)7, dropped=(guint64)4;
从组件“kmssink0”获得消息 #63(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1516635650, stream-time=(guint64)1516635650, timestamp=(guint64)1516635650, duration=(guint64)8333333, jitter=(gint64)20939482, proportion=(double)1.2157563764350099, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)10, dropped=(guint64)5;
从组件“kmssink0”获得消息 #69(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1756645495, stream-time=(guint64)1756645495, timestamp=(guint64)1756645495, duration=(guint64)8333333, jitter=(gint64)56873622, proportion=(double)1.104817523086367, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)14, dropped=(guint64)6;
从组件“kmssink0”获得消息 #71(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1796634460, stream-time=(guint64)1796634460, timestamp=(guint64)1796634460, duration=(guint64)8333333, jitter=(gint64)17041667, proportion=(double)1.1163862675074891, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)14, dropped=(guint64)7;
从组件“kmssink0”获得消息 #76(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)1996647290, stream-time=(guint64)1996647290, timestamp=(guint64)1996647290, duration=(guint64)8333333, jitter=(gint64)13856017, proportion=(double)0.96500711663782934, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)17, dropped=(guint64)8;
从组件“kmssink0”获得消息 #81(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2156652140, stream-time=(guint64)2156652140, timestamp=(guint64)2156652140, duration=(guint64)8333333, jitter=(gint64)20092102, proportion=(double)0.93601643318637529, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)20, dropped=(guint64)9;
从组件“kmssink0”获得消息 #87(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2396654120, stream-time=(guint64)2396654120, timestamp=(guint64)2396654120, duration=(guint64)8333333, jitter=(gint64)16243727, proportion=(double)0.92315706014469012, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)24, dropped=(guint64)10;
从组件“kmssink0”获得消息 #91(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2516658295, stream-time=(guint64)2516658295, timestamp=(guint64)2516658295, duration=(guint64)8333333, jitter=(gint64)14680797, proportion=(double)0.89782682638199696, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)26, dropped=(guint64)11;
从组件“kmssink0”获得消息 #96(qos): GstMessageQOS, live=(boolean)true, running-time=(guint64)2676655435, stream-time=(guint64)2676655435, timestamp=(guint64)2676655435, duration=(guint64)8333333, jitter=(gint64)20885077, proportion=(double)0.87842984631932786, quality=(int)1000000, format=(GstFormat)buffers, processed=(guint64)29, dropped=(guint64)12;
从组件“kmssink0”获得消息 #102(qos): GstMessageQ^Chandling interrupt.
从组件“pipeline0”获得消息 #106[ 163.506208] nvp6188 1-0030: s_stream: 0. 1280x720
中断: 中止管道 ...
Execution ended after 0:00:03.003976665
设置 NULL 管道 ...
释放管道资源 ...
I would like to ask what caused this problem and how to solve it?
Li
