AM4378: Ethernet phy not working during 6.1 migration with updated dts.
Part Number: AM4378
We are working on am437x based custom board, Migrating from 4.19 to 6.1 kernel.  I updated the dts changes specific to ethernet & cpsw switch taking am437x-sk dts as reference.
After updating my dts ethernet phy's are not working.
dmesg gives error messages.
root@picv6-1:~# dmesg | grep "cpsw"
[ 3.391245] cpsw-switch 4a100000.switch: /ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/ethernet-ports/port@1 read phy-mode err -19
root@picv6-1:~#
root@picv6-1:~# dmesg | grep "mdio"
[ 3.363963] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 3.374624] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver unknown
[ 3.382696] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver unknown
Updated dts ethernet nodes with 6.1 kernel.
&mac_sw {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&cpsw_default>;
pinctrl-1 = <&cpsw_sleep>;
status = "okay";
&davinci_mdio_sw {
pinctrl-0 = <&davinci_mdio_default>;
pinctrl-1 = <&davinci_mdio_sleep>;
ethphy0: ethernet-phy@0 {
reg = <0>;
ethphy1: ethernet-phy@1 {
reg = <1>;
&cpsw_port1 {
phy-handle = <&ethphy0>;
phy-mode = "rmii-rxid";
ti,dual-emac-pvid = <1>;
&cpsw_port2 {
phy-handle = <&ethphy1>;
ti,dual-emac-pvid = <2>;
please review my changes and let me know if i miss anything.
  • The query has been assigned to the expert. Please expect a response within a day or two.
    Thanks!
    Since you are changing kernel versions there a few things causing the issue.
    - Are the PHYs in use compiled into the 6.1 kernel? Were the PHY drivers configured in the kernel config?
    - Are you able to connect to one interface at a time get a link up and able to ping another device?
    - If the PHYs are in RMII mode I don't believe rmii-rxid is a valid selection. I suggest trying rmii.
    The DTS looks comparable to the example that TI provides for the AM437x SK EVM.
    Schuyler
  • Hi Schuyler,
    As suggested changed "phy-mode" to rmii instead of rmii-rxid.  with this phy detected as Generic PHY driver.(i.e same in 4.19 kernel also)
    I can see the Link state change when i connect ethernet cable and interfaces are visible with ifconfig.
    But packets are not going out.  tx count incretments & rx count is zero.
    Any other areas i need to look further.
    Siva.
  • Hi Schuyler,
    Here is the Logs output after changing phy mode.
    dmesg | grep "cpsw"
    [ 3.361711] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
    [ 3.368616] cpsw-switch 4a100000.switch: ALE Table size 1024
    [ 3.374470] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
    [ 3.382088] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
    [ 3.393233] cpsw-switch 4a100000.switch: Detected MACID = 64:8c:bb:d2:5b:51
    [ 3.400317] cpsw-switch 4a100000.switch: Detected MACID = 64:8c:bb:d2:5b:53
    [ 3.410043] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010F 1.15 (0)
    [ 12.384382] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
    [ 12.455661] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
    [ 213.365334] cpsw-switch 4a100000.switch eth1: Link is Up - 10Mbps/Full - flow control off
    [ 724.005509] cpsw-switch 4a100000.switch eth1: Link is Down
    [ 729.205596] cpsw-switch 4a100000.switch eth1: Link is Up - 10Mbps/Full - flow control off
    root@picv6-1:~#
    [ 3.333971] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [ 3.344636] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver unknown
    [ 3.352706] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver unknown
    [ 12.418931] Generic PHY 4a101000.mdio:01: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL)
    [ 12.480557] Generic PHY 4a101000.mdio:00: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
    Siva.
    That is a low bit rate, which PHYs are you using?
    Also could you please post the results of ethtool eth0 and ethtool eth1 as well ethtool -S eth0 and ethtool -S eth1?
    Schuyler
  • LAN8740AI-EN-TR is the ethernet phy used on the board.
    Here is the output of ethtool command for eth0 & eth1 interface. Ethernet cable connected eth0.
    root@picv6-1:~# ethtool eth0
    Settings for eth0:
    Supported ports: [ TP MII ]
    Supported link modes: 10baseT/Half 10baseT/Full
    Supported pause frame use: Symmetric Receive-only
    Supports auto-negotiation: Yes
    Supported FEC modes: Not reported
    Advertised link modes: 10baseT/Half 10baseT/Full
    Advertised pause frame use: No
    Advertised auto-negotiation: Yes
    Advertised FEC modes: Not reported
    Speed: Unknown!
    Duplex: Unknown! (255)
    Auto-negotiation: on
    Port: MII
    PHYAD: 0
    Transceiver: external
    Supports Wake-on: d
    Wake-on: d
    Current message level: 0x00000000 (0)
    Link detected: no
    root@picv6-1:~# ethtool eth1
    Settings for eth1:
    Speed: Unknown!
    Port: MII
    PHYAD: 1
    Supports Wake-on: d
    Wake-on: d
    Link detected: no
    root@picv6-1:~#
    root@picv6-1:~# ethtool -S eth0
    NIC statistics:
    Good Rx Frames: 0
    Broadcast Rx Frames: 0
    Multicast Rx Frames: 0
    Pause Rx Frames: 0
    Rx CRC Errors: 0
    Rx Align/Code Errors: 0
    Oversize Rx Frames: 0
    Rx Jabbers: 0
    Undersize (Short) Rx Frames: 0
    Rx Fragments: 0
    Rx Octets: 0
    Good Tx Frames: 0
    Broadcast Tx Frames: 0
    Multicast Tx Frames: 0
    Pause Tx Frames: 0
    Deferred Tx Frames: 0
    Collisions: 0
    Single Collision Tx Frames: 0
    Multiple Collision Tx Frames: 0
    Excessive Collisions: 0
    Late Collisions: 0
    Tx Underrun: 0
    Carrier Sense Errors: 0
    Tx Octets: 0
    Rx + Tx 64 Octet Frames: 0
    Rx + Tx 65-127 Octet Frames: 0
    Rx + Tx 128-255 Octet Frames: 0
    Rx + Tx 256-511 Octet Frames: 0
    Rx + Tx 512-1023 Octet Frames: 0
    Rx + Tx 1024-Up Octet Frames: 0
    Net Octets: 0
    Rx Start of Frame Overruns: 0
    Rx Middle of Frame Overruns: 0
    Rx DMA Overruns: 0
    Rx DMA chan 0: head_enqueue: 1
    Rx DMA chan 0: tail_enqueue: 127
    Rx DMA chan 0: pad_enqueue: 0
    Rx DMA chan 0: misqueued: 0
    Rx DMA chan 0: desc_alloc_fail: 0
    Rx DMA chan 0: pad_alloc_fail: 0
    Rx DMA chan 0: runt_receive_buf: 0
    Rx DMA chan 0: runt_transmit_bu: 0
    Rx DMA chan 0: empty_dequeue: 0
    Rx DMA chan 0: busy_dequeue: 0
    Rx DMA chan 0: good_dequeue: 0
    Rx DMA chan 0: requeue: 0
    Rx DMA chan 0: teardown_dequeue: 0
    Tx DMA chan 0: head_enqueue: 0
    Tx DMA chan 0: tail_enqueue: 0
    Tx DMA chan 0: pad_enqueue: 0
    Tx DMA chan 0: misqueued: 0
    Tx DMA chan 0: desc_alloc_fail: 0
    Tx DMA chan 0: pad_alloc_fail: 0
    Tx DMA chan 0: runt_receive_buf: 0
    Tx DMA chan 0: runt_transmit_bu: 0
    Tx DMA chan 0: empty_dequeue: 0
    Tx DMA chan 0: busy_dequeue: 0
    Tx DMA chan 0: good_dequeue: 0
    Tx DMA chan 0: requeue: 0
    Tx DMA chan 0: teardown_dequeue: 0
    root@picv6-1:~#
    root@picv6-1:~#
    root@picv6-1:~# ethtool -S eth1
    NIC statistics:
    Good Rx Frames: 0
    Pause Rx Frames: 0
    Rx CRC Errors: 0
    Rx Jabbers: 0
    Rx Fragments: 0
    Rx Octets: 0
    Good Tx Frames: 0
    Pause Tx Frames: 0
    Collisions: 0
    Late Collisions: 0
    Tx Underrun: 0
    Tx Octets: 0
    Net Octets: 0
    Rx DMA Overruns: 0
    Is this PHY configured to be built in the kernel configuration?
    Based on the ethtool results, is each PHY configured only for 10Mbps half and full Duplex? I am looking to see if the ethtool output matches what the PHY is configured for.
    Could you please attach the full boot log (not cut and paste, use the insert file option when posting).  Also please attach the .config file from the kernel build.
    Schuyler
  • root@picv6-1:~# dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 6.1.33-g40c32565ca (oe-user@oe-host) (arm-poky-linux-gnueabi-gcc (GCC) 11.5.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP Thu Jul  6 14:17:24 UTC 2023
    [    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: TI AM437x PIC6.1 Default 19-07-2024
    [    0.000000] Memory policy: Data cache writeback
    [    0.000000] cma: Reserved 64 MiB at 0x9c000000
    [    0.000000] Zone ranges:
    [    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fffffff]
    [    0.000000]   HighMem  empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
    [    0.000000] CPU: All CPU(s) started in SVC mode.
    [    0.000000] AM437x ES1.2 (sgx neon)
    [    0.000000] percpu: Embedded 12 pages/cpu s17364 r8192 d23596 u49152
    [    0.000000] pcpu-alloc: s17364 r8192 d23596 u49152 alloc=12*4096
    [    0.000000] pcpu-alloc: [0] 0
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 130048
    [    0.000000] Kernel command line: console=ttyS4,115200n8 root=/dev/sda2 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 434072K/524288K available (13312K kernel code, 854K rwdata, 3400K rodata, 1024K init, 321K bss, 24680K reserved, 65536K cma-reserved, 0K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=1.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
    [    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
    [    0.000000] L2C-310 erratum 769419 enabled
    [    0.000000] L2C-310 enabling early BRESP for Cortex-A9
    [    0.000000] OMAP L2C310: ROM does not support power control setting
    [    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
    [    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
    [    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] TI gptimer clocksource: always-on /ocp@44000000/interconnect@44c00000/segment@200000/target-module@31000
    [    0.000001] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    [    0.000022] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000177] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000185] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000564] TI gptimer clockevent: 24000000 Hz at /ocp@44000000/interconnect@48000000/segment@0/target-module@40000
    [    0.002861] Console: colour dummy device 80x30
    [    0.002930] Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
    [    0.087166] pid_max: default: 32768 minimum: 301
    [    0.087295] LSM: Security Framework initializing
    [    0.087426] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    [    0.087450] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    [    0.088239] CPU: Testing write buffer coherency: ok
    [    0.088309] CPU0: Spectre v2: using BPIALL workaround
    [    0.088666] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.089565] Setting up static identity map for 0x80100000 - 0x80100060
    [    0.089767] rcu: Hierarchical SRCU implementation.
    [    0.089775] rcu:     Max phase no-delay instances is 1000.
    [    0.092226] EFI services will not be available.
    [    0.092492] smp: Bringing up secondary CPUs ...
    [    0.092500] smp: Brought up 1 node, 1 CPU
    [    0.092509] SMP: Total of 1 processors activated (1594.16 BogoMIPS).
    [    0.092522] CPU: All CPU(s) started in SVC mode.
    [    0.093174] devtmpfs: initialized
    [    0.111320] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [    0.111618] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.111647] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
    [    0.117400] pinctrl core: initialized pinctrl subsystem
    [    0.118393] DMI not present or invalid.
    [    0.119326] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.122090] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.122735] audit: initializing netlink subsys (disabled)
    [    0.123919] thermal_sys: Registered thermal governor 'step_wise'
    [    0.124022] cpuidle: using governor menu
    [    0.144548] platform display: Fixed dependency cycle(s) with /ocp@44000000/interconnect@48000000/segment@300000/target-module@2a000/dss@0
    [    0.145246] No ATAGs?
    [    0.145347] audit: type=2000 audit(0.120:1): state=initialized audit_enabled=0 res=1
    [    0.145379] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    [    0.145390] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [    0.148257] Serial: AMBA PL011 UART driver
    [    0.327150] raid6: neonx8   gen()   548 MB/s
    [    0.497152] raid6: neonx4   gen()  1276 MB/s
    [    0.667169] raid6: neonx2   gen()  1180 MB/s
    [    0.837161] raid6: neonx1   gen()  1034 MB/s
    [    1.007194] raid6: int32x8  gen()   249 MB/s
    [    1.177182] raid6: int32x4  gen()   267 MB/s
    [    1.347183] raid6: int32x2  gen()   368 MB/s
    [    1.517164] raid6: int32x1  gen()   322 MB/s
    [    1.517171] raid6: using algorithm neonx4 gen() 1276 MB/s
    [    1.687158] raid6: .... xor() 807 MB/s, rmw enabled
    [    1.687165] raid6: using neon recovery algorithm
    [    1.688459] reg-fixed-voltage fixedregulator-v3_3d: GPIO lookup for consumer (null)
    [    1.688476] reg-fixed-voltage fixedregulator-v3_3d: using device tree for GPIO lookup
    [    1.688496] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-v3_3d[0]'
    [    1.688531] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-v3_3d[0]'
    [    1.688553] reg-fixed-voltage fixedregulator-v3_3d: using lookup tables for GPIO lookup
    [    1.688562] reg-fixed-voltage fixedregulator-v3_3d: No GPIO consumer (null) found
    [    1.689869] SCSI subsystem initialized
    [    1.690316] libata version 3.00 loaded.
    [    1.690685] usbcore: registered new interface driver usbfs
    [    1.690750] usbcore: registered new interface driver hub
    [    1.690807] usbcore: registered new device driver usb
    [    1.691273] pps_core: LinuxPPS API ver. 1 registered
    [    1.691282] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.691319] PTP clock support registered
    [    1.691470] EDAC MC: Ver: 3.0.0
    [    1.694150] clocksource: Switched to clocksource dmtimer
    [    1.694502] VFS: Disk quotas dquot_6.6.0
    [    1.694589] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.705221] NET: Registered PF_INET protocol family
    [    1.705572] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    1.706834] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
    [    1.706872] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    1.706888] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
    [    1.706937] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    1.707093] TCP: Hash tables configured (established 4096 bind 4096)
    [    1.707230] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    1.707272] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    1.707493] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    1.708334] RPC: Registered named UNIX socket transport module.
    [    1.708350] RPC: Registered udp transport module.
    [    1.708356] RPC: Registered tcp transport module.
    [    1.708361] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.708374] PCI: CLS 0 bytes, default 64
    [    1.709669] Initialise system trusted keyrings
    [    1.710142] workingset: timestamp_bits=30 max_order=17 bucket_order=0
    [    1.716296] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    1.717665] NFS: Registering the id_resolver key type
    [    1.717731] Key type id_resolver registered
    [    1.717738] Key type id_legacy registered
    [    1.717845] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.717855] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    1.717900] ntfs: driver 2.1.32 [Flags: R/O].
    [    1.718128] ntfs3: Max link count 4000
    [    1.718228] jffs2: version 2.2. (NAND) (SUMMARY)  \xc2\xa9 2001-2006 Red Hat, Inc.
    [    1.719001] JFS: nTxBlock = 3903, nTxLock = 31225
    [    1.725186] xor: measuring software checksum speed
    [    1.732821]    arm4regs        :  1295 MB/sec
    [    1.742423]    8regs           :  1034 MB/sec
    [    1.751969]    32regs          :  1034 MB/sec
    [    1.762076]    neon            :   975 MB/sec
    [    1.762083] xor: using function: arm4regs (1295 MB/sec)
    [    1.762103] Key type asymmetric registered
    [    1.762112] Asymmetric key parser 'x509' registered
    [    1.762339] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    1.762353] io scheduler mq-deadline registered
    [    1.762374] io scheduler kyber registered
    [    1.829488] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
    [    1.832473] STMicroelectronics ASC driver initialized
    [    1.848972] brd: module loaded
    [    1.856628] loop: module loaded
    [    1.862171] mdio_bus fixed-0: GPIO lookup for consumer reset
    [    1.862192] mdio_bus fixed-0: using lookup tables for GPIO lookup
    [    1.862202] mdio_bus fixed-0: No GPIO consumer reset found
    [    1.863804] CAN device driver interface
    [    1.864403] e1000e: Intel(R) PRO/1000 Network Driver
    [    1.864412] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    1.864496] igb: Intel(R) Gigabit Ethernet Network Driver
    [    1.864503] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    1.866383] pegasus: Pegasus/Pegasus II USB Ethernet driver
    [    1.866470] usbcore: registered new interface driver pegasus
    [    1.866521] usbcore: registered new interface driver asix
    [    1.866558] usbcore: registered new interface driver ax88179_178a
    [    1.866595] usbcore: registered new interface driver cdc_ether
    [    1.866650] usbcore: registered new interface driver smsc75xx
    [    1.866710] usbcore: registered new interface driver smsc95xx
    [    1.866749] usbcore: registered new interface driver net1080
    [    1.866785] usbcore: registered new interface driver cdc_subset
    [    1.866818] usbcore: registered new interface driver zaurus
    [    1.866895] usbcore: registered new interface driver cdc_ncm
    [    1.868975] usbcore: registered new interface driver cdc_acm
    [    1.868985] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [    1.869347] usbcore: registered new interface driver uas
    [    1.869414] usbcore: registered new interface driver usb-storage
    [    1.870481] [FTS_TS]fts_ts_i2c_init: Enter
    [    1.870517] [FTS_TS]fts_ts_i2c_init: Exit(321)
    [    1.870995] i2c_dev: i2c /dev entries driver
    [    1.874062] cpuidle: enable-method property 'ti,am4372' found operations
    [    1.875003] sdhci: Secure Digital Host Controller Interface driver
    [    1.875013] sdhci: Copyright(c) Pierre Ossman
    [    1.875331] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.876093] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.876673] usbcore: registered new interface driver usbhid
    [    1.876682] usbhid: USB HID core driver
    [    1.880232] NET: Registered PF_INET6 protocol family
    [    1.881985] Segment Routing with IPv6
    [    1.882056] In-situ OAM (IOAM) with IPv6
    [    1.882166] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    1.883010] NET: Registered PF_PACKET protocol family
    [    1.883026] can: controller area network core
    [    1.883136] NET: Registered PF_CAN protocol family
    [    1.883147] can: raw protocol
    [    1.883157] can: broadcast manager protocol
    [    1.883170] can: netlink gateway - max_hops=1
    [    1.883493] Key type dns_resolver registered
    [    1.883674] ThumbEE CPU extension supported.
    [    1.883692] Registering SWP/SWPB emulation handler
    [    1.884550] omap_voltage_late_init: Voltage driver support not added
    [    1.885783] Loading compiled-in X.509 certificates
    [    1.892283] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
    [    1.933582] pinctrl-single 44e10800.pinmux: 199 pins, size 796
    [    1.938483] ti-sysc: probe of 44e31000.target-module failed with error -16
    [    1.951247] i2c i2c-1: GPIO lookup for consumer scl
    [    1.951267] i2c i2c-1: using device tree for GPIO lookup
    [    1.951289] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0[0]'
    [    1.951329] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0[0]'
    [    1.951363] i2c i2c-1: using lookup tables for GPIO lookup
    [    1.951373] i2c i2c-1: No GPIO consumer scl found
    [    1.951393] i2c i2c-1: GPIO lookup for consumer sda
    [    1.951400] i2c i2c-1: using device tree for GPIO lookup
    [    1.951412] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0[0]'
    [    1.951447] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0[0]'
    [    1.951477] i2c i2c-1: using lookup tables for GPIO lookup
    [    1.951483] i2c i2c-1: No GPIO consumer sda found
    [    1.951884] at24 1-0050: supply vcc not found, using dummy regulator
    [    1.952134] at24 1-0050: GPIO lookup for consumer wp
    [    1.952146] at24 1-0050: using device tree for GPIO lookup
    [    1.952176] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/eeprom@50[0]'
    [    1.952226] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/eeprom@50[0]'
    [    1.952263] at24 1-0050: using lookup tables for GPIO lookup
    [    1.952270] at24 1-0050: No GPIO consumer wp found
    [    1.974360] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    1.974993] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.978043] ti-sysc: probe of 48040000.target-module failed with error -16
    [    1.992564] gpio gpiochip0: (gpio-0-31): not an immutable chip, please consider fixing it!
    [    1.993500] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0)
    [    1.993617] gpio gpiochip0: registered GPIOs 0 to 31 on gpio-0-31
    [    1.993696] OMAP GPIO hardware version 0.1
    [    2.008655] omap8250 481a8000.serial: No clock speed specified: using default: 48000000
    [    2.010934] sdhci-omap 48060000.mmc: GPIO lookup for consumer wp
    [    2.010954] sdhci-omap 48060000.mmc: using device tree for GPIO lookup
    [    2.010974] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    2.011021] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    2.011056] sdhci-omap 48060000.mmc: using lookup tables for GPIO lookup
    [    2.011066] sdhci-omap 48060000.mmc: No GPIO consumer wp found
    [    2.011218] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
    [    2.011599] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
    [    2.013869] printk: console [ttyS4] disabled
    [    2.013911] omap8250 481a8000.serial: GPIO lookup for consumer rs485-term
    [    2.013925] omap8250 481a8000.serial: using device tree for GPIO lookup
    [    2.013946] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@a8000/serial@0[0]'
    [    2.013998] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@a8000/serial@0[0]'
    [    2.014032] omap8250 481a8000.serial: using lookup tables for GPIO lookup
    [    2.014042] omap8250 481a8000.serial: No GPIO consumer rs485-term found
    [    2.014083] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 70, base_baud = 3000000) is a 8250
    [    3.172033] printk: console [ttyS4] enabled
    [    3.179799] gpio gpiochip1: Persistence not supported for GPIO 1
    [    3.179828] gpio-33 (LCD_PDB): hogged as output/high
    [    3.184974] gpio gpiochip1: (gpio-32-63): not an immutable chip, please consider fixing it!
    [    3.193804] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1)
    [    3.193920] gpio gpiochip1: registered GPIOs 32 to 63 on gpio-32-63
    [    3.196350] gpio gpiochip2: Persistence not supported for GPIO 17
    [    3.196378] gpio-81 (ADC Enable): hogged as output/high
    [    3.201683] gpio gpiochip2: (gpio-64-95): not an immutable chip, please consider fixing it!
    [    3.210541] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2)
    [    3.210652] gpio gpiochip2: registered GPIOs 64 to 95 on gpio-64-95
    [    3.224771] omap_rng 48310000.rng: Random Number Generator ver. 20
    [    3.233358] gpio gpiochip3: (gpio-96-127): not an immutable chip, please consider fixing it!
    [    3.242143] random: crng init done
    [    3.245800] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3)
    [    3.245924] gpio gpiochip3: registered GPIOs 96 to 127 on gpio-96-127
    [    3.248373] gpio gpiochip4: (gpio-128-159): not an immutable chip, please consider fixing it!
    [    3.257408] gpio gpiochip4: (gpio-128-159): added GPIO chardev (254:4)
    [    3.257534] gpio gpiochip4: registered GPIOs 128 to 159 on gpio-128-159
    [    3.283398] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset
    [    3.283426] mdio_bus 4a101000.mdio: using device tree for GPIO lookup
    [    3.283450] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000[0]'
    [    3.283497] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000[0]'
    [    3.283538] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup
    [    3.283549] mdio_bus 4a101000.mdio: No GPIO consumer reset found
    [    3.334186] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    3.343054] mdio_bus 4a101000.mdio:00: GPIO lookup for consumer reset
    [    3.343076] mdio_bus 4a101000.mdio:00: using device tree for GPIO lookup
    [    3.343097] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000/ethernet-phy@0[0]'
    [    3.343158] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000/ethernet-phy@0[0]'
    [    3.343202] mdio_bus 4a101000.mdio:00: using lookup tables for GPIO lookup
    [    3.343213] mdio_bus 4a101000.mdio:00: No GPIO consumer reset found
    [    3.344670] mdio_bus 4a101000.mdio:01: GPIO lookup for consumer reset
    [    3.344694] mdio_bus 4a101000.mdio:01: using device tree for GPIO lookup
    [    3.344716] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000/ethernet-phy@1[0]'
    [    3.344774] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000/ethernet-phy@1[0]'
    [    3.344818] mdio_bus 4a101000.mdio:01: using lookup tables for GPIO lookup
    [    3.344830] mdio_bus 4a101000.mdio:01: No GPIO consumer reset found
    [    3.345143] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver unknown
    [    3.353204] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver unknown
    [    3.362201] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
    [    3.369102] cpsw-switch 4a100000.switch: ALE Table size 1024
    [    3.374961] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
    [    3.382578] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
    [    3.393722] cpsw-switch 4a100000.switch: Detected MACID = b8:94:d9:c7:4b:17
    [    3.400801] cpsw-switch 4a100000.switch: Detected MACID = b8:94:d9:c7:4b:19
    [    3.410529] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010F 1.15 (0)
    [    3.429369] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
    [    3.437444] edma 49000000.dma: TI EDMA DMA engine driver
    [    3.462764] pwm-backlight backlight: GPIO lookup for consumer enable
    [    3.462793] pwm-backlight backlight: using device tree for GPIO lookup
    [    3.462815] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
    [    3.462846] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
    [    3.462870] pwm-backlight backlight: using lookup tables for GPIO lookup
    [    3.462881] pwm-backlight backlight: No GPIO consumer enable found
    [    3.462906] pwm-backlight backlight: supply power not found, using dummy regulator
    [    3.471713] panel-simple display: supply power not found, using dummy regulator
    [    3.479355] panel-simple display: GPIO lookup for consumer enable
    [    3.479372] panel-simple display: using device tree for GPIO lookup
    [    3.479392] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/display[0]'
    [    3.479426] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/display[0]'
    [    3.479447] panel-simple display: using lookup tables for GPIO lookup
    [    3.479458] panel-simple display: No GPIO consumer enable found
    [    3.479475] panel-simple display: Specify missing connector_type
    [    3.487033] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led0[0]' - status (0)
    [    3.487151] gpio gpiochip4: Persistence not supported for GPIO 4
    [    3.487165] gpio-132 (?): no flags found for gpios
    [    3.487403] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led1[0]' - status (0)
    [    3.487436] gpio gpiochip4: Persistence not supported for GPIO 5
    [    3.487446] gpio-133 (?): no flags found for gpios
    [    3.487551] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led2[0]' - status (0)
    [    3.487579] gpio gpiochip4: Persistence not supported for GPIO 6
    [    3.487588] gpio-134 (?): no flags found for gpios
    [    3.488510] omap_uart 44e09000.serial: no wakeirq for uart0
    [    3.494211] omap_uart 44e09000.serial: (null) (0): RTS delay before sending not supported
    [    3.502435] omap_uart 44e09000.serial: (null) (0): RTS delay after sending not supported
    [    3.510589] omap_uart 44e09000.serial: GPIO lookup for consumer rs485-term
    [    3.510601] omap_uart 44e09000.serial: using device tree for GPIO lookup
    [    3.510624] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]'
    [    3.510673] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]'
    [    3.510710] omap_uart 44e09000.serial: using lookup tables for GPIO lookup
    [    3.510722] omap_uart 44e09000.serial: No GPIO consumer rs485-term found
    [    3.510734] omap_uart 44e09000.serial: GPIO lookup for consumer rts
    [    3.510743] omap_uart 44e09000.serial: using device tree for GPIO lookup
    [    3.510759] of_get_named_gpiod_flags: can't parse 'rts-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]'
    [    3.510810] of_get_named_gpiod_flags: parsed 'rts-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]' - status (0)
    [    3.510902] gpio gpiochip3: Persistence not supported for GPIO 8
    [    3.510925] omap_uart 44e09000.serial: No clock speed specified: using default: 48000000
    [    3.519324] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 85, base_baud = 3000000) is a OMAP UART0
    [    3.531317] i2c i2c-0: GPIO lookup for consumer scl
    [    3.531342] i2c i2c-0: using device tree for GPIO lookup
    [    3.531365] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    3.531410] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    3.531447] i2c i2c-0: using lookup tables for GPIO lookup
    [    3.531458] i2c i2c-0: No GPIO consumer scl found
    [    3.531481] i2c i2c-0: GPIO lookup for consumer sda
    [    3.531489] i2c i2c-0: using device tree for GPIO lookup
    [    3.531503] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    3.531540] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    3.531570] i2c i2c-0: using lookup tables for GPIO lookup
    [    3.531579] i2c i2c-0: No GPIO consumer sda found
    [    3.555271] tps65218-pwrbutton: Failed to locate of_node [id: -2]
    [    3.561915] tps65218-gpio: Failed to locate of_node [id: -2]
    [    3.575203] PCF85263_REG_OSC read (dbbae0d0)
    [    3.579680] PCF85263_REG_OSC after 12H (16)
    [    3.584001] PCF85263_REG_OSC write (16)
    [    3.588051] PCF85263_REG_0x26 read (1)
    [    3.591927] PCF85263_REG_0x26 write (1)
    [    3.595963] PCF85263_REG_0x26 next read (1)
    [    3.602492] rtc-pcf85263 0-0051: registered as rtc0
    [    3.607797] rtc-pcf85263 0-0051: setting system clock to 2023-10-04T13:16:10 UTC (1696425370)
    [    3.616414] rtc-pcf85263 0-0051: PCF85263 RTC (irqpin=INTA irq=0)
    [    3.622692] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 400 kHz
    [    3.631243] [FTS_TS/I]fts_ts_probe:Touch Screen(I2C BUS) driver prboe...
    [    3.638094] [FTS_TS]fts_ts_probe_entry: Enter
    [    3.638106] [FTS_TS/I]fts_ts_probe_entry:FocalTech V4.2 20240407
    [    3.644159] [FTS_TS]fts_parse_dt: Enter
    [    3.644171] [FTS_TS/I]fts_get_dt_coords:display x(0 1024) y(0 600)
    [    3.650413] of_get_named_gpiod_flags: parsed 'focaltech,reset-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/focaltech@38[0]' - status (0)
    [    3.650482] of_get_named_gpiod_flags: parsed 'focaltech,irq-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/focaltech@38[0]' - status (0)
    [    3.650519] [FTS_TS/I]fts_parse_dt:max touch number:5, irq gpio:86, reset gpio:34
    [    3.658057] [FTS_TS]fts_parse_dt: Exit(1904)
    [    3.658406] [FTS_TS]fts_bus_init: Enter
    [    3.658429] [FTS_TS]fts_bus_init: Exit(1781)
    [    3.658444] [FTS_TS]fts_gpio_configure: Enter
    [    3.658468] [FTS_TS]fts_gpio_configure: Exit(1755)
    [    3.658477] [FTS_TS]fts_power_source_init: Enter
    [    3.658739] fts_ts 1-0038: supply iovcc not found, using dummy regulator
    [    3.665688] [FTS_TS]fts_power_source_ctrl: Enter
    [    3.665699] [FTS_TS/I]fts_set_reset:set reset to 0
    [    3.674170] [FTS_TS/I]fts_power_source_ctrl:set power to on
    [    3.683808] [FTS_TS/I]fts_set_reset:set reset to 1
    [    3.688647] [FTS_TS]fts_power_source_ctrl: Exit(1548)
    [    3.688658] [FTS_TS]fts_power_source_init: Exit(1602)
    [    3.904213] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    3.910234] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    3.916273] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    3.922277] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    3.928300] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    3.934324] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    3.940271] [FTS_TS/I]fts_get_ic_information:chip id read invalid, read:0x0000
    [    4.164200] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.170215] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.176239] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.182248] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.188266] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.194281] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.200228] [FTS_TS/I]fts_get_ic_information:chip id read invalid, read:0x0000
    [    4.424188] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.430200] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.436219] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.442225] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.448249] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.454267] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.460215] [FTS_TS/I]fts_get_ic_information:chip id read invalid, read:0x0000
    [    4.684195] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.690203] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.696222] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.702227] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.708252] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.714270] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.720217] [FTS_TS/I]fts_get_ic_information:chip id read invalid, read:0x0000
    [    4.944198] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.950215] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.956237] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.962247] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.968267] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.974284] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    4.980230] [FTS_TS/I]fts_get_ic_information:chip id read invalid, read:0x0000
    [    5.204135] [FTS_TS/I]fts_get_ic_information:fw is invalid, need read boot id
    [    5.211363] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.217567] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.223746] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.229884] [FTS_TS/E]fts_hid2std:hid2std cmd write fail
    [    5.235288] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.241467] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.247659] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.253781] [FTS_TS/E]fts_read_bootid:start cmd write fail
    [    5.259304] [FTS_TS/E]fts_get_ic_information:read boot id fail
    [    5.265238] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.271420] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.277622] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.283746] [FTS_TS/E]fts_hid2std:hid2std cmd write fail
    [    5.289152] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.295346] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.301524] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.307661] [FTS_TS/E]fts_read_bootid:start cmd write fail
    [    5.313171] [FTS_TS/E]fts_get_ic_information:read boot id fail
    [    5.319040] [FTS_TS/I]fts_set_reset:set reset to 0
    [    5.327870] [FTS_TS/I]fts_set_reset:set reset to 1
    [    5.344728] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.350734] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.356755] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.362702] [FTS_TS/E]fts_hid2std:send hid2std cmd failed
    [    5.368196] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.374385] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.380564] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.400778] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.406797] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.412804] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.418765] [FTS_TS/E]fts_hid2std:send hid2std cmd failed
    [    5.424256] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.430438] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.436631] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.442753] [FTS_TS/E]fts_read_bootid:start cmd write fail
    [    5.448275] [FTS_TS/E]fts_get_ic_information:read boot id fail
    [    5.454144] [FTS_TS/I]fts_set_reset:set reset to 0
    [    5.462971] [FTS_TS/I]fts_set_reset:set reset to 1
    [    5.487806] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.493813] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.499838] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.505799] [FTS_TS/E]fts_hid2std:send hid2std cmd failed
    [    5.511281] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.517473] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.523653] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.543861] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.549881] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.555898] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.561846] [FTS_TS/E]fts_hid2std:send hid2std cmd failed
    [    5.567338] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.573518] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.579712] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.585846] [FTS_TS/E]fts_read_bootid:start cmd write fail
    [    5.591354] [FTS_TS/E]fts_get_ic_information:read boot id fail
    [    5.597223] [FTS_TS/I]fts_set_reset:set reset to 0
    [    5.604128] [FTS_TS/I]fts_set_reset:set reset to 1
    [    5.636936] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.642941] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.648959] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.654919] [FTS_TS/E]fts_hid2std:send hid2std cmd failed
    [    5.660398] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.666590] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.672767] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.692973] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.698992] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.705014] [FTS_TS/E]fts_read:i2c_transfer(read) fail,ret:-121
    [    5.710960] [FTS_TS/E]fts_hid2std:send hid2std cmd failed
    [    5.716454] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.722633] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.728825] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-121
    [    5.734959] [FTS_TS/E]fts_read_bootid:start cmd write fail
    [    5.740468] [FTS_TS/E]fts_get_ic_information:read boot id fail
    [    5.746336] [FTS_TS/I]fts_get_ic_information:get ic information, chip id = 0x0000(cid type=0x0)
    [    5.755087] [FTS_TS/E]fts_ts_probe_entry:not focal IC, unregister driver
    [    5.761817] [FTS_TS]fts_power_source_ctrl: Enter
    [    5.761824] [FTS_TS/I]fts_set_reset:set reset to 0
    [    5.770663] [FTS_TS/I]fts_power_source_ctrl:set power to off
    [    5.776376] [FTS_TS]fts_power_source_ctrl: Exit(1548)
    [    5.777071] [FTS_TS]fts_ts_probe_entry: Exit(2355)
    [    5.777090] [FTS_TS/E]fts_ts_probe:Touch Screen(I2C BUS) driver probe fail
    [    5.784008] fts_ts: probe of 1-0038 failed with error -121
    [    5.793139] sdhci-omap 48060000.mmc: GPIO lookup for consumer wp
    [    5.793169] sdhci-omap 48060000.mmc: using device tree for GPIO lookup
    [    5.793191] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    5.793242] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    5.793280] sdhci-omap 48060000.mmc: using lookup tables for GPIO lookup
    [    5.793291] sdhci-omap 48060000.mmc: No GPIO consumer wp found
    [    5.793456] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
    [    5.801643] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
    [    5.810994] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    5.816654] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
    [    5.826710] xhci-hcd xhci-hcd.4.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010
    [    5.836347] xhci-hcd xhci-hcd.4.auto: irq 89, io mem 0x48390000
    [    5.842579] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    5.848158] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
    [    5.855893] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
    [    5.863787] hub 1-0:1.0: USB hub found
    [    5.867724] hub 1-0:1.0: 1 port detected
    [    5.872273] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    5.880521] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
    [    5.889562] hub 2-0:1.0: USB hub found
    [    5.893507] hub 2-0:1.0: 1 port detected
    [    5.901004] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
    [    5.906651] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 3
    [    5.915206] xhci-hcd xhci-hcd.5.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010
    [    5.924826] xhci-hcd xhci-hcd.5.auto: irq 90, io mem 0x483d0000
    [    5.931036] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
    [    5.936624] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 4
    [    5.944377] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
    [    5.952189] hub 3-0:1.0: USB hub found
    [    5.956210] hub 3-0:1.0: 1 port detected
    [    5.961001] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [    5.970323] hub 4-0:1.0: USB hub found
    [    5.974331] hub 4-0:1.0: 1 port detected
    [    5.985095] Waiting for root device /dev/sda2...
    [    6.031641] mmc0: new high speed MMC card at address 0001
    [    6.039292] mmcblk0: mmc0:0001 S0J35A 3.57 GiB
    [    6.053796]  mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 >
    [    6.065561] mmcblk0boot0: mmc0:0001 S0J35A 31.5 MiB
    [    6.072745] mmcblk0boot1: mmc0:0001 S0J35A 31.5 MiB
    [    6.080519] mmcblk0rpmb: mmc0:0001 S0J35A 4.00 MiB, chardev (241:0)
    [    6.154231] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    6.644276] usb 3-1: new high-speed USB device number 2 using xhci-hcd
    [    6.828311] usb-storage 3-1:1.0: USB Mass Storage device detected
    [    6.836658] scsi host0: usb-storage 3-1:1.0
    [    7.845632] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.00 PQ: 0 ANSI: 6
    [    7.859805] sd 0:0:0:0: [sda] 60125184 512-byte logical blocks: (30.8 GB/28.7 GiB)
    [    7.868826] sd 0:0:0:0: [sda] Write Protect is off
    [    7.873663] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
    [    7.874767] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
    [    7.900070]  sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 sda8 sda9 sda10 >
    [    7.909318] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [    7.983018] EXT4-fs (sda2): recovery complete
    [    7.995226] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [    8.003474] VFS: Mounted root (ext4 filesystem) on device 8:2.
    [    8.014849] devtmpfs: mounted
    [    8.019848] Freeing unused kernel image (initmem) memory: 1024K
    [    8.026234] Run /sbin/init as init process
    [    8.030356]   with arguments:
    [    8.030363]     /sbin/init
    [    8.030371]   with environment:
    [    8.030378]     HOME=/
    [    8.030384]     TERM=linux
    [    8.548999] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    8.766701] udevd[122]: starting version 3.2.10
    [    8.872351] udevd[123]: starting eudev-3.2.10
    [    9.076142] rnet: loading out-of-tree module taints kernel.
    [    9.082898] Initializing RNET network device driver version 1.00-002
    [    9.098756] Initializing MS/TP network device driver version 1.02-003
    [   10.796395] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator
    [   10.804984] DSS: OMAP DSS rev 2.0
    [   10.813529] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops [omapdrm])
    [   11.155033] omapdrm omapdrm.0: DMM not available, disable DMM support
    [   11.399572] Console: switching to colour frame buffer device 128x37
    [   11.506775] omapdrm omapdrm.0: [drm] fb0: omapdrmdrmfb frame buffer device
    [   11.543058] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
    [   11.631393] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   11.838783] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   11.856920] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
    [   12.955148] RTW: module init start
    [   12.958828] RTW: rtl88x2bu v5.13.1.1-1-g6f2541ef2.20240507_COEX20220812-18317b7b
    [   12.966347] RTW: build time: Jan  7 2025 10:09:40
    [   12.971076] RTW: rtl88x2bu BT-Coex version = COEX20220812-18317b7b
    [   12.977370] RTW: rtw_inetaddr_notifier_register
    [   12.982085] RTW:
                   usb_endpoint_descriptor(0):
    [   12.987904] RTW: bLength=7
    [   12.990625] RTW: bDescriptorType=5
    [   12.994039] RTW: bEndpointAddress=84
    [   12.997642] RTW: wMaxPacketSize=512
    [   13.001144] RTW: bInterval=0
    [   13.004034] RTW: RT_usb_endpoint_is_bulk_in = 4
    [   13.008610] RTW:
                   usb_endpoint_descriptor(1):
    [   13.014394] RTW: bLength=7
    [   13.017111] RTW: bDescriptorType=5
    [   13.020523] RTW: bEndpointAddress=5
    [   13.024022] RTW: wMaxPacketSize=512
    [   13.027534] RTW: bInterval=0
    [   13.030434] RTW: RT_usb_endpoint_is_bulk_out = 5
    [   13.035084] RTW:
                   usb_endpoint_descriptor(2):
    [   13.040854] RTW: bLength=7
    [   13.043569] RTW: bDescriptorType=5
    [   13.047013] RTW: bEndpointAddress=6
    [   13.050515] RTW: wMaxPacketSize=512
    [   13.054024] RTW: bInterval=0
    [   13.056935] RTW: RT_usb_endpoint_is_bulk_out = 6
    [   13.061572] RTW:
                   usb_endpoint_descriptor(3):
    [   13.067356] RTW: bLength=7
    [   13.070073] RTW: bDescriptorType=5
    [   13.073486] RTW: bEndpointAddress=87
    [   13.077090] RTW: wMaxPacketSize=64
    [   13.080513] RTW: bInterval=3
    [   13.083404] RTW: RT_usb_endpoint_is_int_in = 7, Interval = 3
    [   13.089101] RTW:
                   usb_endpoint_descriptor(4):
    [   13.094882] RTW: bLength=7
    [   13.097597] RTW: bDescriptorType=5
    [   13.101011] RTW: bEndpointAddress=8
    [   13.104530] RTW: wMaxPacketSize=512
    [   13.108034] RTW: bInterval=0
    [   13.110924] RTW: RT_usb_endpoint_is_bulk_out = 8
    [   13.115572] RTW: nr_endpoint=5, in_num=2, out_num=3
    [   13.121956] RTW: USB_SPEED_HIGH
    [   13.125149] RTW: CHIP TYPE: RTL8822B
    [   13.286476] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
    [   13.351495] Generic PHY 4a101000.mdio:00: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
    [   13.479858] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
    [   13.554910] Generic PHY 4a101000.mdio:01: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL)
    [   14.055758] RTW: loadparam, Select P2P interface: iface_id:1
    [   14.061628] RTW: [HALMAC]55772M
                   HALMAC_MAJOR_VER = 1
                   HALMAC_PROTOTYPE_VER = 6
                   HALMAC_MINOR_VER = 6
                   HALMAC_PATCH_VER = 22
    [   14.161231] RTW: Chip Version Info: CHIP_8822B_U4_2T2R_RomVer(3)
    [   14.167406] RTW: config_chip_out_EP OutEpQueueSel(0x07), OutEpNumber(3)
    [   14.213165] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
    [   14.657135] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_LOGICAL_EFUSE
    [   14.663815] RTW: HW EFUSE
    [   14.666563] RTW: 0x000: 29 81 00 3C  09 00 A1 00  B6 04 64 10  00 00 A3 00
    [   14.673719] RTW: 0x010: 2B 2B 2B 2B  2B 2B 28 28  29 29 29 FF  00 00 FF FF
    [   14.680903] RTW: 0x020: FF FF 1F 1F  1F 1F 1F 1F  20 21 22 22  23 24 25 24
    [   14.688079] RTW: 0x030: 56 00 FF FF  00 FF F0 00  FF FF 2F 2F  2F 2F 2F 2F
    [   14.695245] RTW: 0x040: 2C 2C 2C 2C  2C 11 00 00  FF FF FF FF  23 23 25 26
    [   14.702393] RTW: 0x050: 24 25 25 26  26 26 2A 2B  2C 2C 46 00  FF FF 00 FF
    [   14.709561] RTW: 0x060: 00 00 FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.716722] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.723872] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.731030] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.738199] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.745360] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 1A 1B 00  FF FF FF FF
    [   14.752508] RTW: 0x0C0: FF 01 00 11  00 00 00 00  00 FF 03 FF  FF FF FF FF
    [   14.759673] RTW: 0x0D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.766843] RTW: 0x0E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.773993] RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.781153] RTW: 0x100: DA 0B 12 B8  E1 67 02 30  EB 1F 45 80  B4 09 03 52
    [   14.788322] RTW: 0x110: 65 61 6C 74  65 6B 0E 03  38 30 32 2E  31 31 61 63
    [   14.795484] RTW: 0x120: 20 4E 49 43  08 03 31 32  33 34 35 36  FF FF FF FF
    [   14.802631] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.809796] RTW: 0x140: 33 0A 1F 01  00 00 21 0F  FF FF FF FF  FF FF FF FF
    [   14.816956] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.824119] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.831275] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.838437] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.845596] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.852744] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.859910] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.867070] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.874230] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.881385] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.888546] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.895706] RTW: 0x200: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.902853] RTW: 0x210: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.910018] RTW: 0x220: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.917179] RTW: 0x230: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.924338] RTW: 0x240: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.931493] RTW: 0x250: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.938655] RTW: 0x260: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.945814] RTW: 0x270: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.952962] RTW: 0x280: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.960130] RTW: 0x290: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.967291] RTW: 0x2A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.974452] RTW: 0x2B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.981607] RTW: 0x2C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.988767] RTW: 0x2D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   14.995926] RTW: 0x2E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   15.003080] RTW: 0x2F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    [   15.010245] RTW: EEPROM ID = 0x8129
    [   15.013749] RTW: EEPROM Version = 0
    [   15.017267] RTW: EEPROM Regulatory=0x01
    [   15.021119] RTW: EEPROM Board Type=0x00
    [   15.024983] RTW: EEPROM Disable BT-coex, ant_num=1
    [   15.029808] RTW: hal_com_config_channel_plan chplan:0x7F
    [   15.035159] RTW: EEPROM crystal_cap=0x1a
    [   15.039099] RTW: EEPROM ThermalMeter=0x1b
    [   15.043123] RTW: EEPROM Customer ID=0x00
    [   15.047074] RTW: EEPROM SupportRemoteWakeup=0
    [   15.051457] RTW: EEPROM PAType_2G is 0x0, ExternalPA_2G = 0
    [   15.057068] RTW: EEPROM PAType_5G is 0x0, external_pa_5g = 0
    [   15.062752] RTW: EEPROM LNAType_2G is 0x0, ExternalLNA_2G = 0
    [   15.068535] RTW: EEPROM LNAType_5G is 0x0, external_lna_5g = 0
    [   15.074405] RTW: EEPROM TypeGPA = 0x0
    [   15.078089] RTW: EEPROM TypeAPA = 0x0
    [   15.081766] RTW: EEPROM TypeGLNA = 0x0
    [   15.085541] RTW: EEPROM TypeALNA = 0x0
    [   15.089306] RTW: EEPROM rfe_type=0x3
    [   15.092907] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
    [   15.333595] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
    [   15.340405] RTW: EEPROM efuse[0x3D7]=0xf3
    [   15.344485] RTW: EEPROM efuse[0x3D8]=0xf3
    [   15.348514] RTW: EEPROM USB Switch=1
    [   15.352103] RTW: EEPROM VID = 0x0BDA, PID = 0xB812
    [   15.365193] RTW: [HALMAC][ALWAYS]shall R reg twice!!
    [   15.370876] RTW: SetHwReg: bMacPwrCtrlOn=1
    [   15.375220] RTW: rtl8822b_fw_dl fw source from array
    [   15.431838] RTW: _rtw_hal_set_fw_rsvd_page((null)) Get [ NOR ] RsvdPageNUm  ==>
    [   15.439279] RTW: LocPsPoll: 4
    [   15.442294] RTW: WARN Invalid rate 0x0 in MRateToHwRate
    [   15.447570] RTW: LocNullData: 5
    [   15.450728] RTW: WARN Invalid rate 0x0 in MRateToHwRate
    [   15.456012] RTW: LocQosNull: 6
    [   15.459086] RTW: WARN Invalid rate 0x0 in MRateToHwRate
    [   15.464355] RTW: LocBTQosNull: 7
    [   15.467609] RTW: WARN Invalid rate 0x0 in MRateToHwRate
    [   15.472861] RTW: _rtw_hal_set_fw_rsvd_page((null)) Get [ NOR ] RsvdPageNUm <==
    [   15.486956] RTW: rtl8822b_fw_dl Download Firmware from array success
    [   15.493376] RTW: NIC FW Version:30 SubVersion:20 FW size:161240
    [   15.500336] RTW: SetHwReg: bMacPwrCtrlOn=0
    [   15.508466] RTW: hal_read_mac_hidden_rpt OK! (1, 10ms), fwdl:1, id:0x19
    [   15.515175] RTW: EEPROM Disable BT-coex by hal_spec
    [   15.520091] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
    [   15.526071] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
    [   15.532774] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
    [   15.538510] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
    [   15.545205] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
    [   15.550876] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
    [   15.557570] RTW: rtw_hal_read_chip_info in 1390 ms
    [   15.562444] RTW: [RF_PATH] ver_id.RF_TYPE:RF_2T2R
    [   15.567193] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x33, rf_reg_path_avail_num:2, max_tx_cnt:2
    [   15.576384] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
    [   15.582330] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0
    [   15.590216] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x33, max_tx_cnt:2
    [   15.596621] RTW: [RF_PATH] HALDATA's rf_type:RF_2T2R, NumTotalRFPath:2
    [   15.603179] RTW: rtw_hal_rfpath_init trx_path_bmp:0x33(RF_2T2R), NumTotalRFPath:2, max_tx_cnt:2
    [   15.611954] RTW: [TRX_Nss] HALSPEC - tx_nss:2, rx_nss:2
    [   15.617218] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
    [   15.622553] RTW: [TRX_Nss] HALDATA - tx_nss:2, rx_nss:2
    [   15.627811] RTW: rtw_hal_trxnss_init tx_nss:2, rx_nss:2
    [   15.633063] RTW: txpath=0x3, rxpath=0x3
    [   15.636934] RTW: txpath_1ss:0x1, num:1
    [   15.640699] RTW: txpath_2ss:0x3, num:2
    [   15.644993] RTW: init_mlme_default_rate_set: support CCK
    [   15.650344] RTW: init_mlme_default_rate_set: support OFDM
    [   15.656690] RTW: NR_RECVBUFF: 8, recvbuf_nr: 8
    [   15.661205] RTW: MAX_RECVBUF_SZ: 32768
    [   15.665055] RTW: NR_PREALLOC_RECV_SKB: 8
    [   15.669614] RTW: rtw_alloc_macid((null)) if1, mac_addr:ff:ff:ff:ff:ff:ff macid:1
    [   15.677144] RTW: rtw_init_pwrctrl_priv: IPS_mode=1, LPS_mode=2, LPS_level=0
    [   15.684411] RTW: IQK FW offload:enable
    [   15.688212] RTW: init_phydm_cominfo: Fv=1 Cv=3
    [   15.692794] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
    [   15.702046] RTW: phy_ConfigBBWithPgParaFile(): No File PHY_REG_PG.txt, Load from HWImg Array!
    [   15.710710] RTW: default power by rate loaded
    [   15.715132] RTW: init_channel_set_from_rtk_priv((null)) ChannelPlan ID:0x7f, ch num:37
    [   15.725414] RTW: can't get autopm:
    [   15.728836] RTW: rtw_macaddr_cfg mac addr:30:eb:1f:45:80:b4
    [   15.734488] RTW: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
    [   15.742772] RTW: loadparam, Select P2P interface: iface_id:1
    [   15.749059] RTW: init_mlme_default_rate_set: support CCK
    [   15.754463] RTW: init_mlme_default_rate_set: support OFDM
    [   15.760791] RTW: NR_RECVBUFF: 8, recvbuf_nr: 8
    [   15.765327] RTW: MAX_RECVBUF_SZ: 32768
    [   15.769114] RTW: NR_PREALLOC_RECV_SKB: 8
    [   15.773614] RTW: rtw_alloc_macid((null)) if2, mac_addr:ff:ff:ff:ff:ff:ff macid:1
    [   15.781147] RTW: rtw_drv_add_vir_if if2 mac_addr : 32:eb:1f:45:80:b4
    [   15.787620] RTW: rtw_cfg80211_init_wiphy_band:rf_type=2
    [   15.792886] RTW: [HT] HAL Support LDPC = 0x03
    [   15.797293] RTW: [HT] HAL Support STBC = 0x01
    [   15.801683] RTW: [HT] HAL Support LDPC = 0x03
    [   15.806088] RTW: [HT] HAL Support STBC = 0x01
    [   15.810467] RTW: [VHT] Support LDPC = 0x03
    [   15.814607] RTW: [VHT] Support STBC = 0x03
    [   15.818722] RTW: [VHT] Support Beamformee
    [   15.822746] RTW: [VHT] Support MU-MIMO STA
    [   15.826884] RTW: rtw_build_vht_cap_ie, line821, Set MAX MPDU len = 11454 bytes
    [   15.834165] RTW: [VHT] Declare supporting RX LDPC
    [   15.838889] RTW: [VHT] Declare supporting SGI 80MHz
    [   15.843785] RTW: [VHT] Declare supporting TX STBC
    [   15.848521] RTW: [VHT] Declare supporting RX STBC = 1
    [   15.853594] RTW: [VHT] Declare supporting SU Bfee
    [   15.858337] RTW: [VHT] Declare supporting MU Bfee
    [   15.863101] RTW: rtw_wiphy_alloc(phy0)
    [   15.866944] RTW: rtw_wdev_alloc(padapter=3307dc20)
    [   15.871789] RTW: rtw_wdev_alloc(padapter=4b5c87e9)
    [   15.876633] RTW: rtw_wiphy_register(phy0)
    [   15.880674] RTW: Register RTW cfg80211 vendor cmd(0x67) interface
    [   15.887175] RTW: rtw_reg_notifier(phy0)
    [   15.891041] RTW: initiator:CORE, wiphy_idx:-1, type:USER
    [   15.896415] RTW: alpha2:00
    [   15.899134] RTW: dfs_region:UNSET
    [   15.902460] RTW: intersect:0
    [   15.905380] RTW: processed:0
    [   15.908273] RTW: country_ie_env:ANY
    [   15.912023] RTW: rtw_ndev_init(wlan0) if1 mac_addr=30:eb:1f:45:80:b4
    [   15.918894] RTW: rtw_ndev_notifier_call(wlan0) state:17
    [   15.925190] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
    [   15.931807] RTW: rtw_ndev_notifier_call(wlan0) state:5
    [   15.937149] RTW: rtw_ndev_init(wlan1) if2 mac_addr=32:eb:1f:45:80:b4
    [   15.943972] RTW: rtw_ndev_notifier_call(wlan1) state:17
    [   15.950233] RTW: cfg80211_rtw_get_txpower(wlan1) total max: -10000 mbm
    [   15.956883] RTW: rtw_ndev_notifier_call(wlan1) state:5
    [   15.962317] usbcore: registered new interface driver rtl88x2bu
    [   15.968226] RTW: module init ret=0
    [   16.177800] EXT4-fs (sda2): re-mounted. Quota mode: none.
    [   27.914412] Bluetooth: Core ver 2.22
    [   27.918186] NET: Registered PF_BLUETOOTH protocol family
    [   27.923528] Bluetooth: HCI device and connection manager initialized
    [   27.930024] Bluetooth: HCI socket layer initialized
    [   27.934971] Bluetooth: L2CAP socket layer initialized
    [   27.940075] Bluetooth: SCO socket layer initialized
    [   28.126527] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
    [   28.133265] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
    [   28.146083] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
    [   28.152812] RTW: cfg80211_rtw_change_iface(wlan0) type=3, hw_port:0
    [   28.159227] RTW: cfg80211_rtw_change_iface(wlan0) call netdev_open
    [   28.165464] RTW: _netdev_open(wlan0) , bup=0
    [   28.169764] RTW: rtl8822b_hal_init fw source from array
    [   28.183798] RTW: [HALMAC][ALWAYS]shall R reg twice!!
    [   28.189391] RTW: SetHwReg: bMacPwrCtrlOn=1
    [   28.247066] RTW: _rtw_hal_set_fw_rsvd_page(wlan0) Get [ NOR ] RsvdPageNUm  ==>
    [   28.254394] RTW: LocPsPoll: 4
    [   28.257385] RTW: LocNullData: 5
    [   28.260544] RTW: LocQosNull: 6
    [   28.263615] RTW: LocBTQosNull: 7
    [   28.266913] RTW: _rtw_hal_set_fw_rsvd_page(wlan0) Get [ NOR ] RsvdPageNUm <==
    [   28.280340] RTW: rtw_start_drv_threads(wlan0) enter
    [   28.285322] RTW: rtw_start_drv_threads(wlan0) start RTW_CMD_THREAD
    [   29.210132] RTW: rtl8822b_hal_init Download Firmware from array success
    [   29.216863] RTW: NIC FW Version:30 SubVersion:20 FW size:161240
    [   29.272768] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
    [   29.279763] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
    [   29.287302] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
    [   29.299379] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
    [   29.311000] RTW: rtw_hal_set_default_port_id_cmd (wlan0) port_id :0, mad_id:0
    [   29.323003] RTW: rtl8822b_init_misc: AMPDU agg retry with new/break when rate fall back: true / true
    [   29.333752] RTW: rtl8822bu_init in 1160ms
    [   29.337843] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =30:eb:1f:45:80:b4
    [   29.346553] RTW: rtw_hal_set_macaddr_port wlan1- hw port(1) mac_addr =32:eb:1f:45:80:b4
    [   29.355751] RTW: [HW_VAR_ENABLE_RX_BAR] 0x6A2=0x100
    [   29.385147] RTW: wlan0: hw_port(0) will set mode to 2
    [   29.390632] RTW: set_opmode_port0(wlan0): hw_port(0) mode=2
    [   29.397979] RTW: rtw_hal_init: padapter->registrypriv.set_rrsr_value=0xffffffff
    [   29.405427] RTW: MAC Address = 30:eb:1f:45:80:b4
    [   29.410095] RTW: _netdev_vir_if_open(wlan1) , bup=0
    [   29.415041] RTW: rtw_start_drv_threads(wlan1) enter
    [   29.419950] RTW: _netdev_vir_if_open(wlan1) (bup=1) exit
    [   29.425324] RTW: -871x_drv - drv_open, bup=1
    [   29.429781] RTW: cfg80211_rtw_change_iface(wlan0) old_iftype=2, new_iftype=3
    [   29.437011] RTW: rtw_release_macid(wlan0) if1, mac_addr:ff:ff:ff:ff:ff:ff macid:1
    [   29.444604] RTW: rtw_alloc_macid(wlan0) if1, mac_addr:ff:ff:ff:ff:ff:ff macid:0
    [   29.452353] RTW: wlan0: hw_port(0) will set mode to 3
    [   29.458972] RTW: set_opmode_port0(wlan0): hw_port(0) mode=3
    [   29.466785] RTW: cfg80211_rtw_change_iface(wlan0) ret:0
    [   29.472072] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
    [   29.481276] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
    [   29.488083] RTW: rtw_ndev_notifier_call(wlan0) state:14
    [   29.493352] RTW: _netdev_open(wlan0) , bup=1
    [   29.497712] RTW: -871x_drv - drv_open, bup=1
    [   29.502275] RTW: rtw_ndev_notifier_call(wlan0) state:1
    [   29.511030] RTW: cfg80211_rtw_set_wiphy_params
    [   29.515701] RTW: cfg80211_rtw_set_wiphy_params
    [   29.520235] RTW: +cfg80211_rtw_del_station(wlan0) mac=(null)
    [   29.525993] RTW: flush all sta, and cam_entry
    [   29.530382] RTW: rtw_sta_flush(wlan0)
    [   29.534061] RTW: issue_deauth reason(3) to ff:ff:ff:ff:ff:ff
    [   29.541122] RTW: cfg80211_rtw_start_ap(wlan0) hidden_ssid:0, auth_type:8
    [   29.548009] RTW: rtw_add_beacon beacon_head_len=55, beacon_tail_len=35
    [   29.554624] RTW: rtw_check_beacon_data, len=66
    [   29.560129] RTW: rtw_hal_set_bssid wlan0- hw port -0 BSSID: 30:eb:1f:45:80:b4
    [   29.568003] RTW: rtw_ap_chbw_decision ifbmp:0x01 excl_ifbmp:0x00 req:0,-1,-1
    [   29.575155] RTW: rtw_ap_chbw_decision others ld_sta_num:0, lg_sta_num:0, ap_num:0, mesh_num:0
    [   29.583731] RTW: rtw_ap_chbw_decision ifbmp:0x01 tmp union:1,0,0
    [   29.589803] RTW: rtw_ap_chbw_decision(wlan0) 1,0,0 => 1,0,0
    [   29.595439] RTW: rtw_ap_chbw_decision union:1,0,0
    [   29.600181] RTW: HW_VAR_BASIC_RATE: 0x15f->0x15f->0x15f
    [   29.607015] RTW: rtw_get_sta_tx_nss: 2 SS
    [   29.611065] RTW: rtw_get_sta_rx_nss: 2 ss
    [   29.615150] RTW: STA - MAC_ID:0, Tx - 2 SS, Rx - 2 SS
    [   29.620229] RTW: STA - MAC_ID:0, SM_PS 3
    [   29.625380] RTW: wlan0 BMC Init Tx rate - CCK_11M
    [   29.630148] RTW: rtw_dfs_rd_en_decision(wlan0) needed:0, mlme_act:11, excl_ifbmp:0x00
    [   29.638070] RTW: rtw_dfs_rd_en_decision(wlan0) ld_sta_num:0, lg_sta_num:0, ap_num:1, mesh_num:0, 1,0,0
    [   29.680151] RTW: is_valid_id_status: HALMAC_FEATURE_IQK
    [   29.690470] RTW: hw_var_set_correct_tsf(wlan0)
    [   29.695082] RTW: [TSF_SYNC] p0 sync port = N/A
    [   29.699564] RTW: [TSF_SYNC] timer offset = 0
    [   29.706691] RTW: rtw_cfg80211_indicate_connect(wlan0)
    [   29.711798] RTW: assoc success
    [   29.715241] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   29.721827] RTW: rtw_ndev_notifier_call(wlan0) state:4
    [   29.728308] RTW: cfg80211_rtw_change_bss(wlan0)
    [   29.732917] RTW: ap_isolate=0
    [   29.736776] RTW: +cfg80211_rtw_del_station(wlan0) mac=ff:ff:ff:ff:ff:ff
    [   29.743452] RTW: free sta macaddr =ff:ff:ff:ff:ff:ff
    [   29.749191] RTW: rtw_ac_parm_cmd_hdl(wlan0) AC_VO = 0x002f3213
    [   29.755544] RTW: cfg80211_rtw_set_mac_acl(wlan0) acl_policy:0, entry_num:0
    [   29.762473] RTW: rtw_set_macaddr_acl(wlan0) p=1, mode=1
    [   29.768244] RTW: rtw_ac_parm_cmd_hdl(wlan0) AC_VI = 0x005e4313
    [   29.774377] RTW: rtw_ac_parm_cmd_hdl(wlan0) AC_BE = 0x00006425
    [   29.786814] RTW: rtw_ac_parm_cmd_hdl(wlan0) AC_BK = 0x0000a449
    [   47.765059] cpsw-switch 4a100000.switch eth0: Link is Up - 10Mbps/Full - flow control off
    [   47.773437] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   50.885467] cpsw-switch 4a100000.switch eth0: Link is Down
    [  108.085001] cpsw-switch 4a100000.switch eth0: Link is Up - 10Mbps/Full - flow control off
    [  162.165472] cpsw-switch 4a100000.switch eth0: Link is Down
    [  171.524995] cpsw-switch 4a100000.switch eth0: Link is Up - 10Mbps/Full - flow control off
    [  172.565487] cpsw-switch 4a100000.switch eth0: Link is Down
    [  173.605026] cpsw-switch 4a100000.switch eth0: Link is Up - 10Mbps/Full - flow control off
    please find the dmesg output.
    The PHYs are communicating with the, otherwise there would not be a link up or link down. The changing is that due to the cable being plugged or un-plugged.
    - are the PHYs only configured to operate at 10Mbps?
    - is the PHY driver built into the kernel or as a module, please a section of the kernel config (typically stored as .config in the kernel source directory)
    -  these message is something that probably needs investigating. They appear to indicate the gpios used to reset the PHY are accessible.
    Schuyler
  • Hi Schuyler
    Not sure, ethernet cable is connected to wifi router LAN.
    PHY driver built as a part of kernel.  Please find the .config generated for am437x based custom board.
    # Automatically generated file; DO NOT EDIT.
    # Linux/arm 6.1.33 Kernel Configuration
    CONFIG_CC_VERSION_TEXT="arm-poky-linux-gnueabi-gcc (GCC) 11.5.0"
    CONFIG_CC_IS_GCC=y
    CONFIG_GCC_VERSION=110500
    CONFIG_CLANG_VERSION=0
    CONFIG_AS_IS_GNU=y
    CONFIG_AS_VERSION=20244508
    CONFIG_LD_IS_BFD=y
    CONFIG_LD_VERSION=20244508
    CONFIG_LLD_VERSION=0
    CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y
    CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y
    CONFIG_CC_HAS_ASM_INLINE=y
    CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y
    CONFIG_PAHOLE_VERSION=0
    CONFIG_IRQ_WORK=y
    CONFIG_BUILDTIME_TABLE_SORT=y
    CONFIG_THREAD_INFO_IN_TASK=y
    # General setup
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_COMPILE_TEST=y
    # CONFIG_WERROR is not set
    CONFIG_LOCALVERSION=""
    CONFIG_BUILD_SALT=""
    CONFIG_HAVE_KERNEL_GZIP=y
    CONFIG_HAVE_KERNEL_LZMA=y
    CONFIG_HAVE_KERNEL_XZ=y
    CONFIG_HAVE_KERNEL_LZO=y
    CONFIG_HAVE_KERNEL_LZ4=y
    CONFIG_KERNEL_GZIP=y
    # CONFIG_KERNEL_LZMA is not set
    # CONFIG_KERNEL_XZ is not set
    # CONFIG_KERNEL_LZO is not set
    # CONFIG_KERNEL_LZ4 is not set
    CONFIG_DEFAULT_INIT=""
    CONFIG_DEFAULT_HOSTNAME="(none)"
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_WATCH_QUEUE is not set
    CONFIG_CROSS_MEMORY_ATTACH=y
    # CONFIG_USELIB is not set
    CONFIG_AUDIT=y
    CONFIG_HAVE_ARCH_AUDITSYSCALL=y
    CONFIG_AUDITSYSCALL=y
    # IRQ subsystem
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_GENERIC_IRQ_SHOW=y
    CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
    CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
    CONFIG_GENERIC_IRQ_MIGRATION=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_CHIP=y
    CONFIG_IRQ_DOMAIN=y
    CONFIG_IRQ_DOMAIN_HIERARCHY=y
    CONFIG_GENERIC_IRQ_IPI=y
    CONFIG_GENERIC_MSI_IRQ=y
    CONFIG_GENERIC_MSI_IRQ_DOMAIN=y
    CONFIG_IRQ_FORCED_THREADING=y
    CONFIG_SPARSE_IRQ=y
    # CONFIG_GENERIC_IRQ_DEBUGFS is not set
    # end of IRQ subsystem
    CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
    CONFIG_GENERIC_TIME_VSYSCALL=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_ARCH_HAS_TICK_BROADCAST=y
    CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
    CONFIG_CONTEXT_TRACKING=y
    CONFIG_CONTEXT_TRACKING_IDLE=y
    # Timers subsystem
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ_COMMON=y
    # CONFIG_HZ_PERIODIC is not set
    CONFIG_NO_HZ_IDLE=y
    # CONFIG_NO_HZ_FULL is not set
    # CONFIG_NO_HZ is not set
    CONFIG_HIGH_RES_TIMERS=y
    # end of Timers subsystem
    CONFIG_BPF=y
    CONFIG_HAVE_EBPF_JIT=y
    # BPF subsystem
    # CONFIG_BPF_SYSCALL is not set
    # CONFIG_BPF_JIT is not set
    # end of BPF subsystem
    CONFIG_PREEMPT_NONE_BUILD=y
    CONFIG_PREEMPT_NONE=y
    # CONFIG_PREEMPT_VOLUNTARY is not set
    # CONFIG_PREEMPT is not set
    # CPU/Task time and stats accounting
    CONFIG_TICK_CPU_ACCOUNTING=y
    # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
    # CONFIG_IRQ_TIME_ACCOUNTING is not set
    CONFIG_SCHED_THERMAL_PRESSURE=y
    # CONFIG_BSD_PROCESS_ACCT is not set
    # CONFIG_TASKSTATS is not set
    # CONFIG_PSI is not set
    # end of CPU/Task time and stats accounting
    CONFIG_CPU_ISOLATION=y
    # RCU Subsystem
    CONFIG_TREE_RCU=y
    CONFIG_RCU_EXPERT=y
    CONFIG_SRCU=y
    CONFIG_TREE_SRCU=y
    # CONFIG_FORCE_TASKS_RCU is not set
    # CONFIG_FORCE_TASKS_RUDE_RCU is not set
    # CONFIG_FORCE_TASKS_TRACE_RCU is not set
    CONFIG_RCU_STALL_COMMON=y
    CONFIG_RCU_NEED_SEGCBLIST=y
    CONFIG_RCU_FANOUT=32
    CONFIG_RCU_FANOUT_LEAF=16
    # CONFIG_RCU_NOCB_CPU is not set
    # end of RCU Subsystem
    # CONFIG_IKCONFIG is not set
    # CONFIG_IKHEADERS is not set
    CONFIG_LOG_BUF_SHIFT=17
    CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
    CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
    # CONFIG_PRINTK_INDEX is not set
    CONFIG_GENERIC_SCHED_CLOCK=y
    # Scheduler features
    # CONFIG_UCLAMP_TASK is not set
    # end of Scheduler features
    CONFIG_CC_IMPLICIT_FALLTHROUGH="-Wimplicit-fallthrough=5"
    CONFIG_GCC11_NO_ARRAY_BOUNDS=y
    CONFIG_CC_NO_ARRAY_BOUNDS=y
    CONFIG_CGROUPS=y
    # CONFIG_CGROUP_FAVOR_DYNMODS is not set
    # CONFIG_MEMCG is not set
    # CONFIG_BLK_CGROUP is not set
    # CONFIG_CGROUP_SCHED is not set
    # CONFIG_CGROUP_PIDS is not set
    # CONFIG_CGROUP_RDMA is not set
    # CONFIG_CGROUP_FREEZER is not set
    # CONFIG_CPUSETS is not set
    # CONFIG_CGROUP_DEVICE is not set
    # CONFIG_CGROUP_CPUACCT is not set
    # CONFIG_CGROUP_PERF is not set
    # CONFIG_CGROUP_MISC is not set
    # CONFIG_CGROUP_DEBUG is not set
    # CONFIG_NAMESPACES is not set
    # CONFIG_CHECKPOINT_RESTORE is not set
    # CONFIG_SCHED_AUTOGROUP is not set
    # CONFIG_SYSFS_DEPRECATED is not set
    # CONFIG_RELAY is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    CONFIG_RD_BZIP2=y
    CONFIG_RD_LZMA=y
    CONFIG_RD_XZ=y
    CONFIG_RD_LZO=y
    CONFIG_RD_LZ4=y
    CONFIG_RD_ZSTD=y
    # CONFIG_BOOT_CONFIG is not set
    CONFIG_INITRAMFS_PRESERVE_MTIME=y
    CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
    # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
    CONFIG_LD_ORPHAN_WARN=y
    CONFIG_SYSCTL=y
    CONFIG_HAVE_UID16=y
    CONFIG_EXPERT=y
    CONFIG_UID16=y
    CONFIG_MULTIUSER=y
    # CONFIG_SGETMASK_SYSCALL is not set
    CONFIG_SYSFS_SYSCALL=y
    CONFIG_FHANDLE=y
    CONFIG_POSIX_TIMERS=y
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_FUTEX_PI=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_IO_URING=y
    CONFIG_ADVISE_SYSCALLS=y
    CONFIG_MEMBARRIER=y
    CONFIG_KALLSYMS=y
    # CONFIG_KALLSYMS_ALL is not set
    CONFIG_KALLSYMS_BASE_RELATIVE=y
    CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
    CONFIG_KCMP=y
    CONFIG_RSEQ=y
    # CONFIG_DEBUG_RSEQ is not set
    CONFIG_EMBEDDED=y
    CONFIG_HAVE_PERF_EVENTS=y
    CONFIG_PERF_USE_VMALLOC=y
    # CONFIG_PC104 is not set
    # Kernel Performance Events And Counters
    CONFIG_PERF_EVENTS=y
    # CONFIG_DEBUG_PERF_USE_VMALLOC is not set
    # end of Kernel Performance Events And Counters
    CONFIG_SYSTEM_DATA_VERIFICATION=y
    # CONFIG_PROFILING is not set
    # end of General setup
    CONFIG_ARM=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_HAVE_PROC_CPU=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_ARCH_HAS_BANDGAP=y
    CONFIG_FIX_EARLYCON_MEM=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_ARCH_SUPPORTS_UPROBES=y
    CONFIG_ARM_PATCH_PHYS_VIRT=y
    CONFIG_GENERIC_BUG=y
    CONFIG_PGTABLE_LEVELS=2
    # System Type
    CONFIG_MMU=y
    CONFIG_ARCH_MMAP_RND_BITS_MIN=8
    CONFIG_ARCH_MMAP_RND_BITS_MAX=16
    CONFIG_ARCH_MULTIPLATFORM=y
    # Platform selection
    # CPU Core family selection
    # CONFIG_ARCH_MULTI_V6 is not set
    CONFIG_ARCH_MULTI_V7=y
    CONFIG_ARCH_MULTI_V6_V7=y
    # end of Platform selection
    # CONFIG_ARCH_VIRT is not set
    # CONFIG_ARCH_AIROHA is not set
    # CONFIG_ARCH_ACTIONS is not set
    # CONFIG_ARCH_ALPINE is not set
    # CONFIG_ARCH_ARTPEC is not set
    # CONFIG_ARCH_ASPEED is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_BCM is not set
    # CONFIG_ARCH_BERLIN is not set
    # CONFIG_ARCH_DIGICOLOR is not set
    # CONFIG_ARCH_DOVE is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_HIGHBANK is not set
    # CONFIG_ARCH_HISI is not set
    # CONFIG_ARCH_HPE is not set
    # CONFIG_ARCH_MXC is not set
    CONFIG_ARCH_KEYSTONE=y
    # CONFIG_ARCH_MEDIATEK is not set
    # CONFIG_ARCH_MESON is not set
    # CONFIG_ARCH_MILBEAUT is not set
    # CONFIG_ARCH_MMP is not set
    # CONFIG_ARCH_MSTARV7 is not set
    # CONFIG_ARCH_MVEBU is not set
    # CONFIG_ARCH_NPCM is not set
    CONFIG_ARCH_OMAP=y
    CONFIG_MACH_OMAP_GENERIC=y
    # TI OMAP/AM/DM/DRA Family
    CONFIG_OMAP_HWMOD=y
    CONFIG_ARCH_OMAP3=y
    CONFIG_ARCH_OMAP4=y
    CONFIG_SOC_OMAP5=y
    CONFIG_SOC_AM33XX=y
    CONFIG_SOC_AM43XX=y
    CONFIG_SOC_DRA7XX=y
    CONFIG_ARCH_OMAP2PLUS=y
    CONFIG_OMAP_INTERCONNECT_BARRIER=y
    # TI OMAP2/3/4 Specific Features
    CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
    CONFIG_SOC_HAS_OMAP2_SDRC=y
    CONFIG_SOC_HAS_REALTIME_COUNTER=y
    # CONFIG_POWER_AVS_OMAP is not set
    # CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set
    CONFIG_SOC_OMAP3430=y
    CONFIG_SOC_TI81XX=y
    # OMAP Legacy Platform Data Board Type
    # CONFIG_OMAP3_SDRC_AC_TIMING is not set
    # end of TI OMAP2/3/4 Specific Features
    # CONFIG_OMAP5_ERRATA_801819 is not set
    # end of TI OMAP/AM/DM/DRA Family
    # CONFIG_ARCH_QCOM is not set
    # CONFIG_ARCH_RDA is not set
    # CONFIG_ARCH_REALTEK is not set
    # CONFIG_ARCH_ROCKCHIP is not set
    # CONFIG_ARCH_S5PV210 is not set
    # CONFIG_ARCH_RENESAS is not set
    CONFIG_ARCH_INTEL_SOCFPGA=y
    # CONFIG_SOCFPGA_SUSPEND is not set
    # CONFIG_PLAT_SPEAR is not set
    # CONFIG_ARCH_STI is not set
    # CONFIG_ARCH_STM32 is not set
    CONFIG_ARCH_SUNPLUS=y
    CONFIG_SOC_SP7021=y
    # CONFIG_ARCH_SUNXI is not set
    # CONFIG_ARCH_TEGRA is not set
    # CONFIG_ARCH_UNIPHIER is not set
    # CONFIG_ARCH_U8500 is not set
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_VEXPRESS is not set
    # CONFIG_ARCH_WM8850 is not set
    # CONFIG_ARCH_ZYNQ is not set
    # Processor Type
    CONFIG_CPU_V7=y
    CONFIG_CPU_THUMB_CAPABLE=y
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_V7=y
    CONFIG_CPU_CACHE_V7=y
    CONFIG_CPU_CACHE_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_CPU_HAS_ASID=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    # Processor Features
    # CONFIG_ARM_LPAE is not set
    CONFIG_ARM_THUMB=y
    CONFIG_ARM_THUMBEE=y
    CONFIG_ARM_VIRT_EXT=y
    CONFIG_SWP_EMULATE=y
    CONFIG_CPU_LITTLE_ENDIAN=y
    # CONFIG_CPU_BIG_ENDIAN is not set
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_ICACHE_MISMATCH_WORKAROUND is not set
    # CONFIG_CPU_BPREDICT_DISABLE is not set
    CONFIG_CPU_SPECTRE=y
    CONFIG_HARDEN_BRANCH_PREDICTOR=y
    CONFIG_HARDEN_BRANCH_HISTORY=y
    CONFIG_KUSER_HELPERS=y
    CONFIG_VDSO=y
    CONFIG_OUTER_CACHE=y
    CONFIG_OUTER_CACHE_SYNC=y
    CONFIG_MIGHT_HAVE_CACHE_L2X0=y
    CONFIG_CACHE_L2X0=y
    # CONFIG_CACHE_L2X0_PMU is not set
    CONFIG_PL310_ERRATA_588369=y
    CONFIG_PL310_ERRATA_727915=y
    CONFIG_PL310_ERRATA_753970=y
    CONFIG_PL310_ERRATA_769419=y
    CONFIG_ARM_L1_CACHE_SHIFT_6=y
    CONFIG_ARM_L1_CACHE_SHIFT=6
    CONFIG_ARM_DMA_MEM_BUFFERABLE=y
    CONFIG_ARM_HEAVY_MB=y
    CONFIG_DEBUG_ALIGN_RODATA=y
    CONFIG_ARM_ERRATA_430973=y
    CONFIG_ARM_ERRATA_643719=y
    CONFIG_ARM_ERRATA_720789=y
    CONFIG_ARM_ERRATA_754322=y
    CONFIG_ARM_ERRATA_754327=y
    CONFIG_ARM_ERRATA_764369=y
    # CONFIG_ARM_ERRATA_764319 is not set
    CONFIG_ARM_ERRATA_775420=y
    CONFIG_ARM_ERRATA_798181=y
    # CONFIG_ARM_ERRATA_773022 is not set
    # CONFIG_ARM_ERRATA_818325_852422 is not set
    # CONFIG_ARM_ERRATA_821420 is not set
    # CONFIG_ARM_ERRATA_825619 is not set
    # CONFIG_ARM_ERRATA_857271 is not set
    # CONFIG_ARM_ERRATA_852421 is not set
    # CONFIG_ARM_ERRATA_852423 is not set
    # CONFIG_ARM_ERRATA_857272 is not set
    # end of System Type
    # Bus support
    CONFIG_ARM_ERRATA_814220=y
    # end of Bus support
    # Kernel Features
    CONFIG_HAVE_SMP=y
    CONFIG_SMP=y
    CONFIG_SMP_ON_UP=y
    CONFIG_CURRENT_POINTER_IN_TPIDRURO=y
    CONFIG_IRQSTACKS=y
    CONFIG_ARM_CPU_TOPOLOGY=y
    # CONFIG_SCHED_MC is not set
    # CONFIG_SCHED_SMT is not set
    CONFIG_HAVE_ARM_SCU=y
    CONFIG_HAVE_ARM_ARCH_TIMER=y
    CONFIG_HAVE_ARM_TWD=y
    CONFIG_MCPM=y
    # CONFIG_BIG_LITTLE is not set
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_3G_OPT is not set
    # CONFIG_VMSPLIT_2G is not set
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
    CONFIG_NR_CPUS=16
    CONFIG_HOTPLUG_CPU=y
    CONFIG_ARM_PSCI=y
    CONFIG_ARCH_NR_GPIO=2048
    CONFIG_HZ_FIXED=0
    CONFIG_HZ_100=y
    # CONFIG_HZ_200 is not set
    # CONFIG_HZ_250 is not set
    # CONFIG_HZ_300 is not set
    # CONFIG_HZ_500 is not set
    # CONFIG_HZ_1000 is not set
    CONFIG_HZ=100
    CONFIG_SCHED_HRTICK=y
    # CONFIG_THUMB2_KERNEL is not set
    CONFIG_ARM_PATCH_IDIV=y
    CONFIG_AEABI=y
    # CONFIG_OABI_COMPAT is not set
    CONFIG_ARCH_SELECT_MEMORY_MODEL=y
    CONFIG_ARCH_FLATMEM_ENABLE=y
    CONFIG_ARCH_SPARSEMEM_ENABLE=y
    CONFIG_HIGHMEM=y
    CONFIG_HIGHPTE=y
    CONFIG_CPU_SW_DOMAIN_PAN=y
    CONFIG_HW_PERF_EVENTS=y
    CONFIG_ARM_MODULE_PLTS=y
    CONFIG_ARCH_FORCE_MAX_ORDER=12
    CONFIG_ALIGNMENT_TRAP=y
    # CONFIG_UACCESS_WITH_MEMCPY is not set
    # CONFIG_PARAVIRT is not set
    # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
    # CONFIG_XEN is not set
    CONFIG_STACKPROTECTOR_PER_TASK=y
    # end of Kernel Features
    # Boot options
    CONFIG_USE_OF=y
    CONFIG_ATAGS=y
    # CONFIG_UNUSED_BOARD_FILES is not set
    # CONFIG_DEPRECATED_PARAM_STRUCT is not set
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_ARM_APPENDED_DTB=y
    CONFIG_ARM_ATAG_DTB_COMPAT=y
    CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
    # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
    CONFIG_CMDLINE=""
    CONFIG_KEXEC=y
    CONFIG_ATAGS_PROC=y
    # CONFIG_CRASH_DUMP is not set
    CONFIG_AUTO_ZRELADDR=y
    CONFIG_EFI_STUB=y
    CONFIG_EFI=y
    CONFIG_DMI=y
    # end of Boot options
    # CPU Power Management
    # CPU Frequency scaling
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_GOV_ATTR_SET=y
    CONFIG_CPU_FREQ_GOV_COMMON=y
    CONFIG_CPU_FREQ_STAT=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=m
    CONFIG_CPU_FREQ_GOV_USERSPACE=m
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m
    CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
    # CPU frequency scaling drivers
    CONFIG_CPUFREQ_DT=y
    CONFIG_CPUFREQ_DT_PLATDEV=y
    CONFIG_ARM_BRCMSTB_AVS_CPUFREQ=y
    CONFIG_ARM_MEDIATEK_CPUFREQ_HW=m
    CONFIG_ARM_OMAP2PLUS_CPUFREQ=y
    # CONFIG_ARM_QCOM_CPUFREQ_HW is not set
    # CONFIG_ARM_RASPBERRYPI_CPUFREQ is not set
    # CONFIG_ARM_SCMI_CPUFREQ is not set
    CONFIG_ARM_TI_CPUFREQ=y
    # CONFIG_QORIQ_CPUFREQ is not set
    # end of CPU Frequency scaling
    # CPU Idle
    CONFIG_CPU_IDLE=y
    CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y
    # CONFIG_CPU_IDLE_GOV_LADDER is not set
    CONFIG_CPU_IDLE_GOV_MENU=y
    # CONFIG_CPU_IDLE_GOV_TEO is not set
    CONFIG_DT_IDLE_STATES=y
    CONFIG_DT_IDLE_GENPD=y
    # ARM CPU Idle Drivers
    CONFIG_ARM_CPUIDLE=y
    CONFIG_ARM_PSCI_CPUIDLE=y
    CONFIG_ARM_PSCI_CPUIDLE_DOMAIN=y
    # CONFIG_ARM_BIG_LITTLE_CPUIDLE is not set
    # CONFIG_ARM_CLPS711X_CPUIDLE is not set
    # CONFIG_ARM_HIGHBANK_CPUIDLE is not set
    # CONFIG_ARM_KIRKWOOD_CPUIDLE is not set
    # CONFIG_ARM_ZYNQ_CPUIDLE is not set
    CONFIG_ARM_AT91_CPUIDLE=y
    # CONFIG_ARM_EXYNOS_CPUIDLE is not set
    # CONFIG_ARM_MVEBU_V7_CPUIDLE is not set
    # CONFIG_ARM_TEGRA_CPUIDLE is not set
    # CONFIG_ARM_QCOM_SPM_CPUIDLE is not set
    # end of ARM CPU Idle Drivers
    CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED=y
    # end of CPU Idle
    # end of CPU Power Management
    # Floating point emulation
    # At least one emulation must be selected
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON=y
    CONFIG_KERNEL_MODE_NEON=y
    # end of Floating point emulation
    # Power management options
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    # CONFIG_SUSPEND_SKIP_SYNC is not set
    # CONFIG_HIBERNATION is not set
    CONFIG_PM_SLEEP=y
    CONFIG_PM_SLEEP_SMP=y
    # CONFIG_PM_AUTOSLEEP is not set
    # CONFIG_PM_USERSPACE_AUTOSLEEP is not set
    # CONFIG_PM_WAKELOCKS is not set
    CONFIG_PM=y
    # CONFIG_PM_DEBUG is not set
    # CONFIG_APM_EMULATION is not set
    CONFIG_PM_CLK=y
    CONFIG_PM_GENERIC_DOMAINS=y
    # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
    CONFIG_PM_GENERIC_DOMAINS_SLEEP=y
    CONFIG_PM_GENERIC_DOMAINS_OF=y
    CONFIG_CPU_PM=y
    # CONFIG_ENERGY_MODEL is not set
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_ARM_CPU_SUSPEND=y
    CONFIG_ARCH_HIBERNATION_POSSIBLE=y
    # end of Power management options
    CONFIG_AS_VFP_VMRS_FPINST=y
    # General architecture-dependent options
    CONFIG_CRASH_CORE=y
    CONFIG_KEXEC_CORE=y
    # CONFIG_KPROBES is not set
    # CONFIG_JUMP_LABEL is not set
    CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
    CONFIG_ARCH_USE_BUILTIN_BSWAP=y
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_OPTPROBES=y
    CONFIG_HAVE_NMI=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_HAVE_ARCH_TRACEHOOK=y
    CONFIG_HAVE_DMA_CONTIGUOUS=y
    CONFIG_GENERIC_SMP_IDLE_THREAD=y
    CONFIG_GENERIC_IDLE_POLL_SETUP=y
    CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
    CONFIG_ARCH_HAS_KEEPINITRD=y
    CONFIG_ARCH_HAS_SET_MEMORY=y
    CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
    CONFIG_ARCH_32BIT_OFF_T=y
    CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
    CONFIG_HAVE_RSEQ=y
    CONFIG_HAVE_HW_BREAKPOINT=y
    CONFIG_HAVE_PERF_REGS=y
    CONFIG_HAVE_PERF_USER_STACK_DUMP=y
    CONFIG_HAVE_ARCH_JUMP_LABEL=y
    CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y
    CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
    CONFIG_HAVE_ARCH_SECCOMP=y
    CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
    CONFIG_SECCOMP=y
    CONFIG_SECCOMP_FILTER=y
    # CONFIG_SECCOMP_CACHE_DEBUG is not set
    CONFIG_HAVE_STACKPROTECTOR=y
    CONFIG_STACKPROTECTOR=y
    CONFIG_STACKPROTECTOR_STRONG=y
    CONFIG_LTO_NONE=y
    CONFIG_HAVE_CONTEXT_TRACKING_USER=y
    CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
    CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
    CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
    CONFIG_MODULES_USE_ELF_REL=y
    CONFIG_HAVE_IRQ_EXIT_ON_IRQ_STACK=y
    CONFIG_HAVE_SOFTIRQ_ON_OWN_STACK=y
    CONFIG_SOFTIRQ_ON_OWN_STACK=y
    CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
    CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
    CONFIG_HAVE_EXIT_THREAD=y
    CONFIG_ARCH_MMAP_RND_BITS=8
    CONFIG_PAGE_SIZE_LESS_THAN_64KB=y
    CONFIG_PAGE_SIZE_LESS_THAN_256KB=y
    CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
    CONFIG_CLONE_BACKWARDS=y
    CONFIG_OLD_SIGSUSPEND3=y
    CONFIG_OLD_SIGACTION=y
    CONFIG_COMPAT_32BIT_TIME=y
    CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
    CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
    CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
    CONFIG_STRICT_KERNEL_RWX=y
    CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
    CONFIG_STRICT_MODULE_RWX=y
    # CONFIG_LOCK_EVENT_COUNTS is not set
    CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y
    CONFIG_HAVE_ARCH_PFN_VALID=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
    # end of GCOV-based kernel profiling
    CONFIG_HAVE_GCC_PLUGINS=y
    CONFIG_GCC_PLUGINS=y
    # CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set
    CONFIG_GCC_PLUGIN_ARM_SSP_PER_TASK=y
    # end of General architecture-dependent options
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    # CONFIG_MODULE_FORCE_LOAD is not set
    CONFIG_MODULE_UNLOAD=y
    # CONFIG_MODULE_FORCE_UNLOAD is not set
    # CONFIG_MODULE_UNLOAD_TAINT_TRACKING is not set
    # CONFIG_MODVERSIONS is not set
    # CONFIG_MODULE_SRCVERSION_ALL is not set
    # CONFIG_MODULE_SIG is not set
    CONFIG_MODULE_COMPRESS_NONE=y
    # CONFIG_MODULE_COMPRESS_GZIP is not set
    # CONFIG_MODULE_COMPRESS_XZ is not set
    # CONFIG_MODULE_COMPRESS_ZSTD is not set
    # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
    CONFIG_MODPROBE_PATH="/sbin/modprobe"
    CONFIG_MODULES_TREE_LOOKUP=y
    CONFIG_BLOCK=y
    CONFIG_BLOCK_LEGACY_AUTOLOAD=y
    CONFIG_BLK_DEV_BSG_COMMON=y
    # CONFIG_BLK_DEV_BSGLIB is not set
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # CONFIG_BLK_DEV_ZONED is not set
    # CONFIG_BLK_WBT is not set
    CONFIG_BLK_DEBUG_FS=y
    # CONFIG_BLK_SED_OPAL is not set
    # CONFIG_BLK_INLINE_ENCRYPTION is not set
    # Partition Types
    CONFIG_PARTITION_ADVANCED=y
    # CONFIG_ACORN_PARTITION is not set
    # CONFIG_AIX_PARTITION is not set
    # CONFIG_OSF_PARTITION is not set
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_ATARI_PARTITION is not set
    # CONFIG_MAC_PARTITION is not set
    CONFIG_MSDOS_PARTITION=y
    # CONFIG_BSD_DISKLABEL is not set
    # CONFIG_MINIX_SUBPARTITION is not set
    # CONFIG_SOLARIS_X86_PARTITION is not set
    # CONFIG_UNIXWARE_DISKLABEL is not set
    # CONFIG_LDM_PARTITION is not set
    # CONFIG_SGI_PARTITION is not set
    # CONFIG_ULTRIX_PARTITION is not set
    # CONFIG_SUN_PARTITION is not set
    # CONFIG_KARMA_PARTITION is not set
    CONFIG_EFI_PARTITION=y
    # CONFIG_SYSV68_PARTITION is not set
    CONFIG_CMDLINE_PARTITION=y
    # end of Partition Types
    CONFIG_BLK_MQ_PCI=y
    CONFIG_BLK_MQ_VIRTIO=y
    CONFIG_BLK_PM=y
    # IO Schedulers
    CONFIG_MQ_IOSCHED_DEADLINE=y
    CONFIG_MQ_IOSCHED_KYBER=y
    # CONFIG_IOSCHED_BFQ is not set
    # end of IO Schedulers
    CONFIG_ASN1=y
    CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
    CONFIG_INLINE_READ_UNLOCK=y
    CONFIG_INLINE_READ_UNLOCK_IRQ=y
    CONFIG_INLINE_WRITE_UNLOCK=y
    CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
    CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
    CONFIG_MUTEX_SPIN_ON_OWNER=y
    CONFIG_RWSEM_SPIN_ON_OWNER=y
    CONFIG_LOCK_SPIN_ON_OWNER=y
    CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y
    CONFIG_FREEZER=y
    # Executable file formats
    CONFIG_BINFMT_ELF=y
    # CONFIG_BINFMT_ELF_FDPIC is not set
    CONFIG_ELFCORE=y
    CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
    CONFIG_BINFMT_SCRIPT=y
    CONFIG_ARCH_HAS_BINFMT_FLAT=y
    # CONFIG_BINFMT_FLAT is not set
    CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y
    # CONFIG_BINFMT_MISC is not set
    CONFIG_COREDUMP=y
    # end of Executable file formats
    # Memory Management options
    CONFIG_SWAP=y
    # CONFIG_ZSWAP is not set
    # SLAB allocator options
    # CONFIG_SLAB is not set
    CONFIG_SLUB=y
    # CONFIG_SLOB is not set
    CONFIG_SLAB_MERGE_DEFAULT=y
    # CONFIG_SLAB_FREELIST_RANDOM is not set
    # CONFIG_SLAB_FREELIST_HARDENED is not set
    # CONFIG_SLUB_STATS is not set
    CONFIG_SLUB_CPU_PARTIAL=y
    # end of SLAB allocator options
    # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
    CONFIG_COMPAT_BRK=y
    CONFIG_SELECT_MEMORY_MODEL=y
    CONFIG_FLATMEM_MANUAL=y
    # CONFIG_SPARSEMEM_MANUAL is not set
    CONFIG_FLATMEM=y
    CONFIG_ARCH_KEEP_MEMBLOCK=y
    CONFIG_MEMORY_ISOLATION=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    CONFIG_COMPACTION=y
    CONFIG_COMPACT_UNEVICTABLE_DEFAULT=1
    # CONFIG_PAGE_REPORTING is not set
    CONFIG_MIGRATION=y
    CONFIG_CONTIG_ALLOC=y
    CONFIG_BOUNCE=y
    # CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
    CONFIG_CMA=y
    # CONFIG_CMA_DEBUG is not set
    # CONFIG_CMA_DEBUGFS is not set
    # CONFIG_CMA_SYSFS is not set
    CONFIG_CMA_AREAS=7
    CONFIG_GENERIC_EARLY_IOREMAP=y
    # CONFIG_IDLE_PAGE_TRACKING is not set
    CONFIG_ARCH_HAS_CURRENT_STACK_POINTER=y
    CONFIG_VM_EVENT_COUNTERS=y
    # CONFIG_PERCPU_STATS is not set
    # CONFIG_GUP_TEST is not set
    CONFIG_KMAP_LOCAL=y
    CONFIG_KMAP_LOCAL_NON_LINEAR_PTE_ARRAY=y
    # CONFIG_ANON_VMA_NAME is not set
    # CONFIG_USERFAULTFD is not set
    # CONFIG_LRU_GEN is not set
    # Data Access Monitoring
    # CONFIG_DAMON is not set
    # end of Data Access Monitoring
    # end of Memory Management options
    CONFIG_NET=y
    CONFIG_SKB_EXTENSIONS=y
    # Networking options
    CONFIG_PACKET=y
    # CONFIG_PACKET_DIAG is not set
    CONFIG_UNIX=y
    CONFIG_UNIX_SCM=y
    CONFIG_AF_UNIX_OOB=y
    # CONFIG_UNIX_DIAG is not set
    # CONFIG_TLS is not set
    CONFIG_XFRM=y
    CONFIG_XFRM_ALGO=m
    # CONFIG_XFRM_USER is not set
    # CONFIG_XFRM_INTERFACE is not set
    # CONFIG_XFRM_SUB_POLICY is not set
    # CONFIG_XFRM_MIGRATE is not set
    # CONFIG_XFRM_STATISTICS is not set
    CONFIG_XFRM_AH=m
    CONFIG_XFRM_ESP=m
    CONFIG_XFRM_IPCOMP=m
    # CONFIG_NET_KEY is not set
    CONFIG_INET=y
    # CONFIG_IP_MULTICAST is not set
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    CONFIG_IP_PNP_RARP=y
    # CONFIG_NET_IPIP is not set
    # CONFIG_NET_IPGRE_DEMUX is not set
    CONFIG_NET_IP_TUNNEL=y
    # CONFIG_SYN_COOKIES is not set
    # CONFIG_NET_IPVTI is not set
    # CONFIG_NET_FOU is not set
    # CONFIG_NET_FOU_IP_TUNNELS is not set
    # CONFIG_INET_AH is not set
    # CONFIG_INET_ESP is not set
    # CONFIG_INET_IPCOMP is not set
    CONFIG_INET_TABLE_PERTURB_ORDER=16
    CONFIG_INET_TUNNEL=y
    CONFIG_INET_DIAG=y
    CONFIG_INET_TCP_DIAG=y
    # CONFIG_INET_UDP_DIAG is not set
    # CONFIG_INET_RAW_DIAG is not set
    # CONFIG_INET_DIAG_DESTROY is not set
    # CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    CONFIG_IPV6=y
    CONFIG_IPV6_ROUTER_PREF=y
    # CONFIG_IPV6_ROUTE_INFO is not set
    CONFIG_IPV6_OPTIMISTIC_DAD=y
    CONFIG_INET6_AH=m
    CONFIG_INET6_ESP=m
    # CONFIG_INET6_ESP_OFFLOAD is not set
    # CONFIG_INET6_ESPINTCP is not set
    CONFIG_INET6_IPCOMP=m
    CONFIG_IPV6_MIP6=m
    CONFIG_INET6_XFRM_TUNNEL=m
    CONFIG_INET6_TUNNEL=m
    # CONFIG_IPV6_VTI is not set
    CONFIG_IPV6_SIT=y
    # CONFIG_IPV6_SIT_6RD is not set
    CONFIG_IPV6_NDISC_NODETYPE=y
    CONFIG_IPV6_TUNNEL=m
    CONFIG_IPV6_MULTIPLE_TABLES=y
    # CONFIG_IPV6_SUBTREES is not set
    # CONFIG_IPV6_MROUTE is not set
    # CONFIG_IPV6_SEG6_LWTUNNEL is not set
    # CONFIG_IPV6_SEG6_HMAC is not set
    # CONFIG_IPV6_RPL_LWTUNNEL is not set
    # CONFIG_IPV6_IOAM6_LWTUNNEL is not set
    # CONFIG_NETLABEL is not set
    # CONFIG_MPTCP is not set
    CONFIG_NETWORK_SECMARK=y
    CONFIG_NET_PTP_CLASSIFY=y
    # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
    # CONFIG_NETFILTER is not set
    # CONFIG_BPFILTER is not set
    # CONFIG_IP_DCCP is not set
    # CONFIG_IP_SCTP is not set
    # CONFIG_RDS is not set
    # CONFIG_TIPC is not set
    # CONFIG_ATM is not set
    # CONFIG_L2TP is not set
    # CONFIG_BRIDGE is not set
    CONFIG_NET_DSA=m
    # CONFIG_NET_DSA_TAG_AR9331 is not set
    CONFIG_NET_DSA_TAG_BRCM_COMMON=m
    CONFIG_NET_DSA_TAG_BRCM=m
    CONFIG_NET_DSA_TAG_BRCM_LEGACY=m
    CONFIG_NET_DSA_TAG_BRCM_PREPEND=m
    # CONFIG_NET_DSA_TAG_HELLCREEK is not set
    # CONFIG_NET_DSA_TAG_GSWIP is not set
    # CONFIG_NET_DSA_TAG_DSA is not set
    # CONFIG_NET_DSA_TAG_EDSA is not set
    # CONFIG_NET_DSA_TAG_MTK is not set
    # CONFIG_NET_DSA_TAG_KSZ is not set
    # CONFIG_NET_DSA_TAG_OCELOT is not set
    # CONFIG_NET_DSA_TAG_OCELOT_8021Q is not set
    # CONFIG_NET_DSA_TAG_QCA is not set
    # CONFIG_NET_DSA_TAG_RTL4_A is not set
    # CONFIG_NET_DSA_TAG_RTL8_4 is not set
    # CONFIG_NET_DSA_TAG_RZN1_A5PSW is not set
    # CONFIG_NET_DSA_TAG_LAN9303 is not set
    # CONFIG_NET_DSA_TAG_SJA1105 is not set
    # CONFIG_NET_DSA_TAG_TRAILER is not set
    # CONFIG_NET_DSA_TAG_XRS700X is not set
    # CONFIG_VLAN_8021Q is not set
    # CONFIG_LLC2 is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_PHONET is not set
    # CONFIG_6LOWPAN is not set
    # CONFIG_IEEE802154 is not set
    # CONFIG_NET_SCHED is not set
    # CONFIG_DCB is not set
    CONFIG_DNS_RESOLVER=y
    # CONFIG_BATMAN_ADV is not set
    # CONFIG_OPENVSWITCH is not set
    # CONFIG_VSOCKETS is not set
    # CONFIG_NETLINK_DIAG is not set
    # CONFIG_MPLS is not set
    # CONFIG_NET_NSH is not set
    # CONFIG_HSR is not set
    CONFIG_NET_SWITCHDEV=y
    # CONFIG_NET_L3_MASTER_DEV is not set
    CONFIG_QRTR=m
    CONFIG_QRTR_SMD=m
    # CONFIG_QRTR_TUN is not set
    # CONFIG_NET_NCSI is not set
    CONFIG_PCPU_DEV_REFCNT=y
    CONFIG_RPS=y
    CONFIG_RFS_ACCEL=y
    CONFIG_SOCK_RX_QUEUE_MAPPING=y
    CONFIG_XPS=y
    # CONFIG_CGROUP_NET_PRIO is not set
    # CONFIG_CGROUP_NET_CLASSID is not set
    CONFIG_NET_RX_BUSY_POLL=y
    CONFIG_BQL=y
    CONFIG_NET_FLOW_LIMIT=y
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # end of Network testing
    # end of Networking options
    # CONFIG_HAMRADIO is not set
    CONFIG_CAN=y
    CONFIG_CAN_RAW=y
    CONFIG_CAN_BCM=y
    CONFIG_CAN_GW=y
    # CONFIG_CAN_J1939 is not set
    # CONFIG_CAN_ISOTP is not set
    CONFIG_BT=m
    CONFIG_BT_BREDR=y
    # CONFIG_BT_RFCOMM is not set
    # CONFIG_BT_BNEP is not set
    # CONFIG_BT_HIDP is not set
    # CONFIG_BT_HS is not set
    CONFIG_BT_LE=y
    # CONFIG_BT_LEDS is not set
    # CONFIG_BT_MSFTEXT is not set
    # CONFIG_BT_AOSPEXT is not set
    CONFIG_BT_DEBUGFS=y
    # CONFIG_BT_SELFTEST is not set
    # CONFIG_BT_FEATURE_DEBUG is not set
    # Bluetooth device drivers
    CONFIG_BT_BCM=m
    # CONFIG_BT_HCIBTUSB is not set
    # CONFIG_BT_HCIBTSDIO is not set
    CONFIG_BT_HCIUART=m
    CONFIG_BT_HCIUART_SERDEV=y
    CONFIG_BT_HCIUART_H4=y
    # CONFIG_BT_HCIUART_NOKIA is not set
    # CONFIG_BT_HCIUART_BCSP is not set
    # CONFIG_BT_HCIUART_ATH3K is not set
    # CONFIG_BT_HCIUART_LL is not set
    # CONFIG_BT_HCIUART_3WIRE is not set
    # CONFIG_BT_HCIUART_INTEL is not set
    CONFIG_BT_HCIUART_BCM=y
    # CONFIG_BT_HCIUART_RTL is not set
    # CONFIG_BT_HCIUART_QCA is not set
    # CONFIG_BT_HCIUART_AG6XX is not set
    # CONFIG_BT_HCIUART_MRVL is not set
    # CONFIG_BT_HCIBCM203X is not set
    # CONFIG_BT_HCIBPA10X is not set
    # CONFIG_BT_HCIBFUSB is not set
    # CONFIG_BT_HCIVHCI is not set
    CONFIG_BT_MRVL=m
    CONFIG_BT_MRVL_SDIO=m
    # CONFIG_BT_MTKSDIO is not set
    # CONFIG_BT_MTKUART is not set
    # CONFIG_BT_QCOMSMD is not set
    # CONFIG_BT_VIRTIO is not set
    # end of Bluetooth device drivers
    # CONFIG_AF_RXRPC is not set
    # CONFIG_AF_KCM is not set
    # CONFIG_MCTP is not set
    CONFIG_FIB_RULES=y
    CONFIG_WIRELESS=y
    CONFIG_CFG80211=m
    # CONFIG_NL80211_TESTMODE is not set
    # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
    # CONFIG_CFG80211_CERTIFICATION_ONUS is not set
    CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
    CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
    CONFIG_CFG80211_DEFAULT_PS=y
    # CONFIG_CFG80211_DEBUGFS is not set
    CONFIG_CFG80211_CRDA_SUPPORT=y
    # CONFIG_CFG80211_WEXT is not set
    CONFIG_MAC80211=m
    CONFIG_MAC80211_HAS_RC=y
    CONFIG_MAC80211_RC_MINSTREL=y
    CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
    CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
    # CONFIG_MAC80211_MESH is not set
    # CONFIG_MAC80211_LEDS is not set
    # CONFIG_MAC80211_DEBUGFS is not set
    # CONFIG_MAC80211_MESSAGE_TRACING is not set
    # CONFIG_MAC80211_DEBUG_MENU is not set
    CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
    CONFIG_RFKILL=y
    CONFIG_RFKILL_LEDS=y
    CONFIG_RFKILL_INPUT=y
    CONFIG_RFKILL_GPIO=y
    # CONFIG_NET_9P is not set
    # CONFIG_CAIF is not set
    # CONFIG_CEPH_LIB is not set
    CONFIG_NFC=m
    CONFIG_NFC_DIGITAL=m
    CONFIG_NFC_NCI=m
    CONFIG_NFC_NCI_SPI=m
    CONFIG_NFC_NCI_UART=m
    CONFIG_NFC_HCI=m
    CONFIG_NFC_SHDLC=y
    # Near Field Communication (NFC) devices
    # CONFIG_NFC_TRF7970A is not set
    # CONFIG_NFC_SIM is not set
    # CONFIG_NFC_PORT100 is not set
    # CONFIG_NFC_VIRTUAL_NCI is not set
    # CONFIG_NFC_FDP is not set
    # CONFIG_NFC_PN544_I2C is not set
    # CONFIG_NFC_PN533_USB is not set
    # CONFIG_NFC_PN533_I2C is not set
    # CONFIG_NFC_PN532_UART is not set
    # CONFIG_NFC_MICROREAD_I2C is not set
    # CONFIG_NFC_MRVL_USB is not set
    # CONFIG_NFC_MRVL_UART is not set
    # CONFIG_NFC_ST21NFCA_I2C is not set
    # CONFIG_NFC_ST_NCI_I2C is not set
    # CONFIG_NFC_ST_NCI_SPI is not set
    # CONFIG_NFC_NXP_NCI is not set
    CONFIG_NFC_S3FWRN5=m
    CONFIG_NFC_S3FWRN5_I2C=m
    # CONFIG_NFC_S3FWRN82_UART is not set
    # CONFIG_NFC_ST95HF is not set
    # end of Near Field Communication (NFC) devices
    # CONFIG_PSAMPLE is not set
    # CONFIG_NET_IFE is not set
    # CONFIG_LWTUNNEL is not set
    CONFIG_DST_CACHE=y
    CONFIG_GRO_CELLS=y
    CONFIG_NET_SELFTESTS=y
    CONFIG_NET_DEVLINK=y
    CONFIG_PAGE_POOL=y
    CONFIG_PAGE_POOL_STATS=y
    CONFIG_FAILOVER=y
    CONFIG_ETHTOOL_NETLINK=y
    # Device Drivers
    CONFIG_ARM_AMBA=y
    CONFIG_HAVE_PCI=y
    CONFIG_PCI=y
    CONFIG_PCI_DOMAINS=y
    CONFIG_PCI_DOMAINS_GENERIC=y
    CONFIG_PCI_SYSCALL=y
    CONFIG_PCIEPORTBUS=y
    # CONFIG_PCIEAER is not set
    CONFIG_PCIEASPM=y
    CONFIG_PCIEASPM_DEFAULT=y
    # CONFIG_PCIEASPM_POWERSAVE is not set
    # CONFIG_PCIEASPM_POWER_SUPERSAVE is not set
    # CONFIG_PCIEASPM_PERFORMANCE is not set
    CONFIG_PCIE_PME=y
    # CONFIG_PCIE_PTM is not set
    CONFIG_PCI_MSI=y
    CONFIG_PCI_MSI_IRQ_DOMAIN=y
    CONFIG_PCI_QUIRKS=y
    # CONFIG_PCI_DEBUG is not set
    # CONFIG_PCI_STUB is not set
    CONFIG_PCI_ECAM=y
    # CONFIG_PCI_IOV is not set
    # CONFIG_PCI_PRI is not set
    # CONFIG_PCI_PASID is not set
    CONFIG_PCI_LABEL=y
    # CONFIG_PCIE_BUS_TUNE_OFF is not set
    CONFIG_PCIE_BUS_DEFAULT=y
    # CONFIG_PCIE_BUS_SAFE is not set
    # CONFIG_PCIE_BUS_PERFORMANCE is not set
    # CONFIG_PCIE_BUS_PEER2PEER is not set
    # CONFIG_VGA_ARB is not set
    # CONFIG_HOTPLUG_PCI is not set
    # PCI controller drivers
    # CONFIG_PCI_AARDVARK is not set
    # CONFIG_PCIE_XILINX_NWL is not set
    # CONFIG_PCI_FTPCI100 is not set
    # CONFIG_PCI_IXP4XX is not set
    # CONFIG_PCI_TEGRA is not set
    # CONFIG_PCI_RCAR_GEN2 is not set
    # CONFIG_PCIE_RCAR_HOST is not set
    # CONFIG_PCIE_RCAR_EP is not set
    CONFIG_PCI_HOST_COMMON=y
    CONFIG_PCI_HOST_GENERIC=y
    # CONFIG_PCIE_XILINX is not set
    # CONFIG_PCIE_XILINX_CPM is not set
    # CONFIG_PCI_XGENE is not set
    # CONFIG_PCI_V3_SEMI is not set
    # CONFIG_PCI_VERSATILE is not set
    # CONFIG_PCIE_IPROC_PLATFORM is not set
    # CONFIG_PCIE_IPROC_BCMA is not set
    # CONFIG_PCIE_ALTERA is not set
    # CONFIG_PCI_HOST_THUNDER_PEM is not set
    # CONFIG_PCI_HOST_THUNDER_ECAM is not set
    # CONFIG_PCIE_ROCKCHIP_HOST is not set
    # CONFIG_PCIE_ROCKCHIP_EP is not set
    # CONFIG_PCIE_MEDIATEK is not set
    # CONFIG_PCIE_MEDIATEK_GEN3 is not set
    # CONFIG_PCIE_BRCMSTB is not set
    # CONFIG_PCI_LOONGSON is not set
    # CONFIG_PCIE_MICROCHIP_HOST is not set
    # CONFIG_PCIE_APPLE is not set
    # CONFIG_PCIE_MT7621 is not set
    # DesignWare PCI Core Support
    CONFIG_PCIE_DW=y
    CONFIG_PCIE_DW_HOST=y
    # CONFIG_PCI_DRA7XX_HOST is not set
    # CONFIG_PCI_DRA7XX_EP is not set
    # CONFIG_PCIE_DW_PLAT_HOST is not set
    # CONFIG_PCIE_DW_PLAT_EP is not set
    # CONFIG_PCI_EXYNOS is not set
    # CONFIG_PCI_IMX6 is not set
    # CONFIG_PCIE_SPEAR13XX is not set
    # CONFIG_PCI_KEYSTONE_HOST is not set
    # CONFIG_PCI_KEYSTONE_EP is not set
    # CONFIG_PCI_LAYERSCAPE is not set
    # CONFIG_PCI_LAYERSCAPE_EP is not set
    # CONFIG_PCI_HISI is not set
    # CONFIG_PCIE_QCOM is not set
    # CONFIG_PCIE_QCOM_EP is not set
    # CONFIG_PCIE_ARMADA_8K is not set
    # CONFIG_PCIE_ARTPEC6_HOST is not set
    # CONFIG_PCIE_ARTPEC6_EP is not set
    # CONFIG_PCIE_ROCKCHIP_DW_HOST is not set
    # CONFIG_PCIE_INTEL_GW is not set
    # CONFIG_PCIE_KEEMBAY_HOST is not set
    # CONFIG_PCIE_KEEMBAY_EP is not set
    # CONFIG_PCIE_KIRIN is not set
    # CONFIG_PCIE_HISI_STB is not set
    CONFIG_PCI_MESON=m
    # CONFIG_PCIE_TEGRA194_HOST is not set
    # CONFIG_PCIE_TEGRA194_EP is not set
    # CONFIG_PCIE_VISCONTI_HOST is not set
    # CONFIG_PCIE_UNIPHIER is not set
    # CONFIG_PCIE_UNIPHIER_EP is not set
    # CONFIG_PCIE_AL is not set
    # CONFIG_PCIE_FU740 is not set
    # end of DesignWare PCI Core Support
    # Mobiveil PCIe Core Support
    # CONFIG_PCIE_MOBIVEIL_PLAT is not set
    # CONFIG_PCIE_LAYERSCAPE_GEN4 is not set
    # end of Mobiveil PCIe Core Support
    # Cadence PCIe controllers support
    # CONFIG_PCIE_CADENCE_PLAT_HOST is not set
    # CONFIG_PCIE_CADENCE_PLAT_EP is not set
    # CONFIG_PCI_J721E_HOST is not set
    # CONFIG_PCI_J721E_EP is not set
    # end of Cadence PCIe controllers support
    # end of PCI controller drivers
    # PCI Endpoint
    CONFIG_PCI_ENDPOINT=y
    CONFIG_PCI_ENDPOINT_CONFIGFS=y
    CONFIG_PCI_EPF_TEST=m
    # CONFIG_PCI_EPF_NTB is not set
    # end of PCI Endpoint
    # PCI switch controller drivers
    # CONFIG_PCI_SW_SWITCHTEC is not set
    # end of PCI switch controller drivers
    # CONFIG_CXL_BUS is not set
    # CONFIG_PCCARD is not set
    # CONFIG_RAPIDIO is not set
    # Generic Driver Options
    # CONFIG_UEVENT_HELPER is not set
    CONFIG_DEVTMPFS=y
    CONFIG_DEVTMPFS_MOUNT=y
    # CONFIG_DEVTMPFS_SAFE is not set
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    # Firmware loader
    CONFIG_FW_LOADER=y
    CONFIG_EXTRA_FIRMWARE=""
    # CONFIG_FW_LOADER_USER_HELPER is not set
    # CONFIG_FW_LOADER_COMPRESS is not set
    CONFIG_FW_CACHE=y
    # CONFIG_FW_UPLOAD is not set
    # end of Firmware loader
    CONFIG_WANT_DEV_COREDUMP=y
    CONFIG_ALLOW_DEV_COREDUMP=y
    CONFIG_DEV_COREDUMP=y
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
    # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
    CONFIG_GENERIC_CPU_AUTOPROBE=y
    CONFIG_GENERIC_CPU_VULNERABILITIES=y
    CONFIG_SOC_BUS=y
    CONFIG_REGMAP=y
    CONFIG_REGMAP_I2C=y
    CONFIG_REGMAP_SPI=y
    CONFIG_REGMAP_SPMI=m
    CONFIG_REGMAP_MMIO=y
    CONFIG_REGMAP_IRQ=y
    CONFIG_DMA_SHARED_BUFFER=y
    # CONFIG_DMA_FENCE_TRACE is not set
    CONFIG_GENERIC_ARCH_TOPOLOGY=y
    # end of Generic Driver Options
    # Bus devices
    # CONFIG_ARM_INTEGRATOR_LM is not set
    CONFIG_BRCMSTB_GISB_ARB=y
    # CONFIG_BT1_APB is not set
    # CONFIG_BT1_AXI is not set
    # CONFIG_MOXTET is not set
    # CONFIG_HISILICON_LPC is not set
    # CONFIG_INTEL_IXP4XX_EB is not set
    CONFIG_OMAP_INTERCONNECT=y
    CONFIG_OMAP_OCP2SCP=y
    # CONFIG_QCOM_EBI2 is not set
    CONFIG_TI_SYSC=y
    CONFIG_VEXPRESS_CONFIG=y
    # CONFIG_FSL_MC_BUS is not set
    # CONFIG_MHI_BUS is not set
    # CONFIG_MHI_BUS_EP is not set
    # end of Bus devices
    # CONFIG_CONNECTOR is not set
    # Firmware Drivers
    # ARM System Control and Management Interface Protocol
    CONFIG_ARM_SCMI_PROTOCOL=y
    CONFIG_ARM_SCMI_HAVE_TRANSPORT=y
    CONFIG_ARM_SCMI_HAVE_SHMEM=y
    CONFIG_ARM_SCMI_TRANSPORT_MAILBOX=y
    CONFIG_ARM_SCMI_TRANSPORT_SMC=y
    # CONFIG_ARM_SCMI_TRANSPORT_SMC_ATOMIC_ENABLE is not set
    # CONFIG_ARM_SCMI_TRANSPORT_VIRTIO is not set
    CONFIG_ARM_SCMI_POWER_DOMAIN=y
    # CONFIG_ARM_SCMI_POWER_CONTROL is not set
    # end of ARM System Control and Management Interface Protocol
    # CONFIG_ARM_SCPI_PROTOCOL is not set
    CONFIG_ARM_SCPI_POWER_DOMAIN=y
    # CONFIG_FIRMWARE_MEMMAP is not set
    CONFIG_DMIID=y
    # CONFIG_DMI_SYSFS is not set
    # CONFIG_FW_CFG_SYSFS is not set
    # CONFIG_SYSFB_SIMPLEFB is not set
    CONFIG_TRUSTED_FOUNDATIONS=y
    # CONFIG_TURRIS_MOX_RWTM is not set
    # CONFIG_BCM47XX_NVRAM is not set
    # CONFIG_GOOGLE_FIRMWARE is not set
    # EFI (Extensible Firmware Interface) Support
    CONFIG_EFI_ESRT=y
    CONFIG_EFI_VARS_PSTORE=y
    # CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set
    CONFIG_EFI_PARAMS_FROM_FDT=y
    CONFIG_EFI_RUNTIME_WRAPPERS=y
    CONFIG_EFI_GENERIC_STUB=y
    CONFIG_EFI_ARMSTUB_DTB_LOADER=y
    # CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER is not set
    # CONFIG_EFI_BOOTLOADER_CONTROL is not set
    CONFIG_EFI_CAPSULE_LOADER=m
    # CONFIG_EFI_TEST is not set
    # CONFIG_RESET_ATTACK_MITIGATION is not set
    # CONFIG_EFI_RCI2_TABLE is not set
    # CONFIG_EFI_DISABLE_PCI_DMA is not set
    # CONFIG_EFI_DISABLE_RUNTIME is not set
    # CONFIG_EFI_COCO_SECRET is not set
    # end of EFI (Extensible Firmware Interface) Support
    CONFIG_ARM_PSCI_FW=y
    # CONFIG_ARM_PSCI_CHECKER is not set
    CONFIG_HAVE_ARM_SMCCC=y
    CONFIG_HAVE_ARM_SMCCC_DISCOVERY=y
    CONFIG_ARM_SMCCC_SOC_ID=y
    # Tegra firmware driver
    # end of Tegra firmware driver
    # end of Firmware Drivers
    # CONFIG_GNSS is not set
    CONFIG_MTD=y
    # CONFIG_MTD_TESTS is not set
    # Partition parsers
    # CONFIG_MTD_AR7_PARTS is not set
    # CONFIG_MTD_BCM63XX_PARTS is not set
    # CONFIG_MTD_BRCM_U_BOOT is not set
    CONFIG_MTD_CMDLINE_PARTS=y
    CONFIG_MTD_OF_PARTS=y
    # CONFIG_MTD_OF_PARTS_BCM4908 is not set
    # CONFIG_MTD_OF_PARTS_LINKSYS_NS is not set
    # CONFIG_MTD_PARSER_IMAGETAG is not set
    # CONFIG_MTD_AFS_PARTS is not set
    # CONFIG_MTD_PARSER_TRX is not set
    # CONFIG_MTD_SHARPSL_PARTS is not set
    # CONFIG_MTD_REDBOOT_PARTS is not set
    # end of Partition parsers
    # User Modules And Translation Layers
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # Note that in some cases UBI block is preferred. See MTD_UBI_BLOCK.
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_SM_FTL is not set
    # CONFIG_MTD_OOPS is not set
    # CONFIG_MTD_SWAP is not set
    # CONFIG_MTD_PARTITIONED_MASTER is not set
    # RAM/ROM/Flash chip drivers
    CONFIG_MTD_CFI=y
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_GEN_PROBE=y
    # CONFIG_MTD_CFI_ADV_OPTIONS is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    CONFIG_MTD_CFI_INTELEXT=y
    # CONFIG_MTD_CFI_AMDSTD is not set
    # CONFIG_MTD_CFI_STAA is not set
    CONFIG_MTD_CFI_UTIL=y
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # end of RAM/ROM/Flash chip drivers
    # Mapping drivers for chip access
    # CONFIG_MTD_COMPLEX_MAPPINGS is not set
    CONFIG_MTD_PHYSMAP=y
    # CONFIG_MTD_PHYSMAP_COMPAT is not set
    CONFIG_MTD_PHYSMAP_OF=y
    # CONFIG_MTD_PHYSMAP_BT1_ROM is not set
    # CONFIG_MTD_PHYSMAP_VERSATILE is not set
    # CONFIG_MTD_PHYSMAP_GEMINI is not set
    # CONFIG_MTD_PHYSMAP_IXP4XX is not set
    # CONFIG_MTD_SC520CDP is not set
    # CONFIG_MTD_NETSC520 is not set
    # CONFIG_MTD_TS5500 is not set
    # CONFIG_MTD_INTEL_VR_NOR is not set
    # CONFIG_MTD_PLATRAM is not set
    # end of Mapping drivers for chip access
    # Self-contained MTD device drivers
    # CONFIG_MTD_PMC551 is not set
    # CONFIG_MTD_DATAFLASH is not set
    # CONFIG_MTD_MCHP23K256 is not set
    # CONFIG_MTD_MCHP48L640 is not set
    CONFIG_MTD_SPEAR_SMI=y
    # CONFIG_MTD_SST25L is not set
    # CONFIG_MTD_BCM47XXSFLASH is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOCG3 is not set
    # end of Self-contained MTD device drivers
    # NAND
    CONFIG_MTD_NAND_CORE=y
    # CONFIG_MTD_ONENAND is not set
    CONFIG_MTD_RAW_NAND=y
    # Raw/parallel NAND flash controllers
    CONFIG_MTD_NAND_DENALI=y
    # CONFIG_MTD_NAND_DENALI_PCI is not set
    CONFIG_MTD_NAND_DENALI_DT=y
    CONFIG_MTD_NAND_AMS_DELTA=y
    CONFIG_MTD_NAND_OMAP2=y
    CONFIG_MTD_NAND_OMAP_BCH=y
    CONFIG_MTD_NAND_OMAP_BCH_BUILD=y
    # CONFIG_MTD_NAND_SHARPSL is not set
    # CONFIG_MTD_NAND_CAFE is not set
    CONFIG_MTD_NAND_ATMEL=y
    CONFIG_MTD_NAND_MARVELL=y
    # CONFIG_MTD_NAND_SLC_LPC32XX is not set
    # CONFIG_MTD_NAND_MLC_LPC32XX is not set
    CONFIG_MTD_NAND_BRCMNAND=y
    # CONFIG_MTD_NAND_BRCMNAND_BCM63XX is not set
    CONFIG_MTD_NAND_BRCMNAND_BCMBCA=y
    CONFIG_MTD_NAND_BRCMNAND_BRCMSTB=y
    CONFIG_MTD_NAND_BRCMNAND_IPROC=y
    # CONFIG_MTD_NAND_OXNAS is not set
    # CONFIG_MTD_NAND_FSL_IFC is not set
    CONFIG_MTD_NAND_VF610_NFC=y
    # CONFIG_MTD_NAND_MXC is not set
    # CONFIG_MTD_NAND_SH_FLCTL is not set
    CONFIG_MTD_NAND_DAVINCI=y
    # CONFIG_MTD_NAND_TXX9NDFMC is not set
    # CONFIG_MTD_NAND_FSMC is not set
    # CONFIG_MTD_NAND_SUNXI is not set
    # CONFIG_MTD_NAND_HISI504 is not set
    # CONFIG_MTD_NAND_QCOM is not set
    # CONFIG_MTD_NAND_MXIC is not set
    # CONFIG_MTD_NAND_TEGRA is not set
    CONFIG_MTD_NAND_STM32_FMC2=y
    # CONFIG_MTD_NAND_MESON is not set
    # CONFIG_MTD_NAND_GPIO is not set
    # CONFIG_MTD_NAND_PLATFORM is not set
    # CONFIG_MTD_NAND_CADENCE is not set
    # CONFIG_MTD_NAND_ARASAN is not set
    # CONFIG_MTD_NAND_INTEL_LGM is not set
    CONFIG_MTD_NAND_PL35X=y
    # CONFIG_MTD_NAND_RENESAS is not set
    # Misc
    # CONFIG_MTD_NAND_NANDSIM is not set
    # CONFIG_MTD_NAND_RICOH is not set
    # CONFIG_MTD_NAND_DISKONCHIP is not set
    # CONFIG_MTD_SPI_NAND is not set
    # ECC engine support
    CONFIG_MTD_NAND_ECC=y
    CONFIG_MTD_NAND_ECC_SW_HAMMING=y
    # CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC is not set
    # CONFIG_MTD_NAND_ECC_SW_BCH is not set
    # CONFIG_MTD_NAND_ECC_MXIC is not set
    # CONFIG_MTD_NAND_ECC_MEDIATEK is not set
    # end of ECC engine support
    # end of NAND
    # LPDDR & LPDDR2 PCM memory drivers
    # CONFIG_MTD_LPDDR is not set
    # CONFIG_MTD_LPDDR2_NVM is not set
    # end of LPDDR & LPDDR2 PCM memory drivers
    CONFIG_MTD_SPI_NOR=y
    CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
    # CONFIG_MTD_SPI_NOR_SWP_DISABLE is not set
    CONFIG_MTD_SPI_NOR_SWP_DISABLE_ON_VOLATILE=y
    # CONFIG_MTD_SPI_NOR_SWP_KEEP is not set
    # CONFIG_SPI_HISI_SFC is not set
    # CONFIG_SPI_NXP_SPIFI is not set
    CONFIG_MTD_UBI=y
    CONFIG_MTD_UBI_WL_THRESHOLD=4096
    CONFIG_MTD_UBI_BEB_LIMIT=20
    # CONFIG_MTD_UBI_FASTMAP is not set
    # CONFIG_MTD_UBI_GLUEBI is not set
    # CONFIG_MTD_UBI_BLOCK is not set
    # CONFIG_MTD_HYPERBUS is not set
    CONFIG_DTC=y
    CONFIG_OF=y
    # CONFIG_OF_UNITTEST is not set
    # CONFIG_OF_ALL_DTBS is not set
    CONFIG_OF_FLATTREE=y
    CONFIG_OF_EARLY_FLATTREE=y
    CONFIG_OF_KOBJ=y
    CONFIG_OF_DYNAMIC=y
    CONFIG_OF_ADDRESS=y
    CONFIG_OF_IRQ=y
    CONFIG_OF_RESERVED_MEM=y
    # CONFIG_OF_OVERLAY is not set
    CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_NULL_BLK is not set
    CONFIG_CDROM=y
    # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set
    # CONFIG_ZRAM is not set
    CONFIG_BLK_DEV_LOOP=y
    CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
    # CONFIG_BLK_DEV_DRBD is not set
    # CONFIG_BLK_DEV_NBD is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=65536
    # CONFIG_CDROM_PKTCDVD is not set
    # CONFIG_ATA_OVER_ETH is not set
    CONFIG_VIRTIO_BLK=y
    # CONFIG_BLK_DEV_RBD is not set
    # CONFIG_BLK_DEV_UBLK is not set
    # NVME Support
    # CONFIG_BLK_DEV_NVME is not set
    # CONFIG_NVME_FC is not set
    # CONFIG_NVME_TCP is not set
    # CONFIG_NVME_TARGET is not set
    # end of NVME Support
    # Misc devices
    CONFIG_AD525X_DPOT=y
    CONFIG_AD525X_DPOT_I2C=y
    # CONFIG_AD525X_DPOT_SPI is not set
    # CONFIG_DUMMY_IRQ is not set
    # CONFIG_PHANTOM is not set
    # CONFIG_TIFM_CORE is not set
    CONFIG_ICS932S401=y
    # CONFIG_ATMEL_SSC is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_GEHC_ACHC is not set
    # CONFIG_HI6421V600_IRQ is not set
    # CONFIG_HP_ILO is not set
    # CONFIG_QCOM_COINCELL is not set
    # CONFIG_QCOM_FASTRPC is not set
    CONFIG_APDS9802ALS=y
    CONFIG_ISL29003=y
    # CONFIG_ISL29020 is not set
    # CONFIG_SENSORS_TSL2550 is not set
    # CONFIG_SENSORS_BH1770 is not set
    # CONFIG_SENSORS_APDS990X is not set
    # CONFIG_HMC6352 is not set
    # CONFIG_DS1682 is not set
    # CONFIG_PCH_PHUB is not set
    # CONFIG_LATTICE_ECP3_CONFIG is not set
    CONFIG_SRAM=y
    CONFIG_SRAM_EXEC=y
    CONFIG_SRAM_DMA_HEAP=y
    # CONFIG_DW_XDATA_PCIE is not set
    CONFIG_PCI_ENDPOINT_TEST=m
    # CONFIG_XILINX_SDFEC is not set
    # CONFIG_HISI_HIKEY_USB is not set
    # CONFIG_OPEN_DICE is not set
    # CONFIG_VCPU_STALL_DETECTOR is not set
    CONFIG_DMA_BUF_PHYS=y
    # CONFIG_C2PORT is not set
    # EEPROM support
    CONFIG_EEPROM_AT24=y
    # CONFIG_EEPROM_AT25 is not set
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    CONFIG_EEPROM_93CX6=y
    # CONFIG_EEPROM_93XX46 is not set
    # CONFIG_EEPROM_IDT_89HPESX is not set
    # CONFIG_EEPROM_EE1004 is not set
    # end of EEPROM support
    # CONFIG_CB710_CORE is not set
    # Texas Instruments shared transport line discipline
    # CONFIG_TI_ST is not set
    # end of Texas Instruments shared transport line discipline
    # CONFIG_SENSORS_LIS3_SPI is not set
    # CONFIG_SENSORS_LIS3_I2C is not set
    # CONFIG_ALTERA_STAPL is not set
    # CONFIG_ECHO is not set
    # CONFIG_BCM_VK is not set
    # CONFIG_MISC_ALCOR_PCI is not set
    # CONFIG_MISC_RTSX_PCI is not set
    # CONFIG_MISC_RTSX_USB is not set
    # CONFIG_HABANA_AI is not set
    # CONFIG_PVPANIC is not set
    # CONFIG_GP_PCI1XXXX is not set
    # end of Misc devices
    # SCSI device support
    CONFIG_SCSI_MOD=y
    # CONFIG_RAID_ATTRS is not set
    CONFIG_SCSI_COMMON=y
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    CONFIG_BLK_DEV_SR=y
    # CONFIG_CHR_DEV_SG is not set
    CONFIG_BLK_DEV_BSG=y
    # CONFIG_CHR_DEV_SCH is not set
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    # CONFIG_SCSI_SCAN_ASYNC is not set
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    # CONFIG_SCSI_ISCSI_ATTRS is not set
    # CONFIG_SCSI_SAS_ATTRS is not set
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    # end of SCSI Transports
    CONFIG_SCSI_LOWLEVEL=y
    # CONFIG_ISCSI_TCP is not set
    # CONFIG_ISCSI_BOOT_SYSFS is not set
    # CONFIG_SCSI_CXGB3_ISCSI is not set
    # CONFIG_SCSI_CXGB4_ISCSI is not set
    # CONFIG_SCSI_BNX2_ISCSI is not set
    # CONFIG_BE2ISCSI is not set
    # CONFIG_BLK_DEV_3W_XXXX_RAID is not set
    # CONFIG_SCSI_HPSA is not set
    # CONFIG_SCSI_3W_9XXX is not set
    # CONFIG_SCSI_3W_SAS is not set
    # CONFIG_SCSI_ACARD is not set
    # CONFIG_SCSI_AACRAID is not set
    # CONFIG_SCSI_AIC7XXX is not set
    # CONFIG_SCSI_AIC79XX is not set
    # CONFIG_SCSI_AIC94XX is not set
    # CONFIG_SCSI_HISI_SAS is not set
    # CONFIG_SCSI_MVSAS is not set
    # CONFIG_SCSI_MVUMI is not set
    # CONFIG_SCSI_ADVANSYS is not set
    # CONFIG_SCSI_ARCMSR is not set
    # CONFIG_SCSI_ESAS2R is not set
    # CONFIG_MEGARAID_NEWGEN is not set
    # CONFIG_MEGARAID_LEGACY is not set
    # CONFIG_MEGARAID_SAS is not set
    # CONFIG_SCSI_MPT3SAS is not set
    # CONFIG_SCSI_MPT2SAS is not set
    # CONFIG_SCSI_MPI3MR is not set
    # CONFIG_SCSI_SMARTPQI is not set
    # CONFIG_SCSI_HPTIOP is not set
    # CONFIG_SCSI_BUSLOGIC is not set
    # CONFIG_SCSI_MYRB is not set
    # CONFIG_SCSI_MYRS is not set
    # CONFIG_SCSI_SNIC is not set
    # CONFIG_SCSI_DMX3191D is not set
    # CONFIG_SCSI_FDOMAIN_PCI is not set
    # CONFIG_SCSI_IPS is not set
    # CONFIG_SCSI_INITIO is not set
    # CONFIG_SCSI_INIA100 is not set
    # CONFIG_SCSI_STEX is not set
    # CONFIG_SCSI_SYM53C8XX_2 is not set
    # CONFIG_SCSI_IPR is not set
    # CONFIG_SCSI_QLOGIC_1280 is not set
    # CONFIG_SCSI_QLA_ISCSI is not set
    # CONFIG_SCSI_DC395x is not set
    # CONFIG_SCSI_AM53C974 is not set
    # CONFIG_SCSI_NSP32 is not set
    # CONFIG_SCSI_WD719X is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_PMCRAID is not set
    # CONFIG_SCSI_PM8001 is not set
    # CONFIG_SCSI_VIRTIO is not set
    # CONFIG_SCSI_DH is not set
    # end of SCSI device support
    CONFIG_ATA=y
    CONFIG_SATA_HOST=y
    CONFIG_ATA_VERBOSE_ERROR=y
    CONFIG_ATA_FORCE=y
    CONFIG_SATA_PMP=y
    # Controllers with non-SFF native interface
    CONFIG_SATA_AHCI=y
    CONFIG_SATA_MOBILE_LPM_POLICY=0
    CONFIG_SATA_AHCI_PLATFORM=y
    # CONFIG_AHCI_BRCM is not set
    # CONFIG_AHCI_DA850 is not set
    CONFIG_AHCI_DM816=y
    # CONFIG_AHCI_DWC is not set
    # CONFIG_AHCI_ST is not set
    # CONFIG_AHCI_IMX is not set
    # CONFIG_AHCI_CEVA is not set
    # CONFIG_AHCI_MTK is not set
    # CONFIG_AHCI_MVEBU is not set
    # CONFIG_AHCI_SUNXI is not set
    # CONFIG_AHCI_TEGRA is not set
    # CONFIG_AHCI_XGENE is not set
    # CONFIG_AHCI_QORIQ is not set
    # CONFIG_SATA_FSL is not set
    # CONFIG_SATA_GEMINI is not set
    # CONFIG_SATA_AHCI_SEATTLE is not set
    # CONFIG_SATA_INIC162X is not set
    # CONFIG_SATA_ACARD_AHCI is not set
    # CONFIG_SATA_SIL24 is not set
    CONFIG_ATA_SFF=y
    # SFF controllers with custom DMA interface
    # CONFIG_PDC_ADMA is not set
    # CONFIG_SATA_QSTOR is not set
    # CONFIG_SATA_SX4 is not set
    CONFIG_ATA_BMDMA=y
    # SATA SFF controllers with BMDMA
    # CONFIG_ATA_PIIX is not set
    # CONFIG_SATA_DWC is not set
    # CONFIG_SATA_HIGHBANK is not set
    CONFIG_SATA_MV=y
    # CONFIG_SATA_NV is not set
    # CONFIG_SATA_PROMISE is not set
    # CONFIG_SATA_RCAR is not set
    # CONFIG_SATA_SIL is not set
    # CONFIG_SATA_SIS is not set
    # CONFIG_SATA_SVW is not set
    # CONFIG_SATA_ULI is not set
    # CONFIG_SATA_VIA is not set
    # CONFIG_SATA_VITESSE is not set
    # PATA SFF controllers with BMDMA
    # CONFIG_PATA_ALI is not set
    # CONFIG_PATA_AMD is not set
    # CONFIG_PATA_ARASAN_CF is not set
    # CONFIG_PATA_ARTOP is not set
    # CONFIG_PATA_ATIIXP is not set
    # CONFIG_PATA_ATP867X is not set
    # CONFIG_PATA_BK3710 is not set
    # CONFIG_PATA_CMD64X is not set
    # CONFIG_PATA_CS5520 is not set
    # CONFIG_PATA_CS5530 is not set
    # CONFIG_PATA_CS5536 is not set
    # CONFIG_PATA_CYPRESS is not set
    # CONFIG_PATA_EFAR is not set
    # CONFIG_PATA_HPT366 is not set
    # CONFIG_PATA_HPT37X is not set
    # CONFIG_PATA_HPT3X2N is not set
    # CONFIG_PATA_HPT3X3 is not set
    # CONFIG_PATA_IMX is not set
    # CONFIG_PATA_IT8213 is not set
    # CONFIG_PATA_IT821X is not set
    # CONFIG_PATA_JMICRON is not set
    # CONFIG_PATA_MARVELL is not set
    # CONFIG_PATA_NETCELL is not set
    # CONFIG_PATA_NINJA32 is not set
    # CONFIG_PATA_NS87415 is not set
    # CONFIG_PATA_OLDPIIX is not set
    # CONFIG_PATA_OPTIDMA is not set
    # CONFIG_PATA_PDC2027X is not set
    # CONFIG_PATA_PDC_OLD is not set
    # CONFIG_PATA_RADISYS is not set
    # CONFIG_PATA_RDC is not set
    # CONFIG_PATA_SC1200 is not set
    # CONFIG_PATA_SCH is not set
    # CONFIG_PATA_SERVERWORKS is not set
    # CONFIG_PATA_SIL680 is not set
    # CONFIG_PATA_SIS is not set
    # CONFIG_PATA_TOSHIBA is not set
    # CONFIG_PATA_TRIFLEX is not set
    # CONFIG_PATA_VIA is not set
    # CONFIG_PATA_PXA is not set
    # CONFIG_PATA_WINBOND is not set
    # PIO-only SFF controllers
    # CONFIG_PATA_CMD640_PCI is not set
    # CONFIG_PATA_IXP4XX_CF is not set
    # CONFIG_PATA_MPIIX is not set
    # CONFIG_PATA_NS87410 is not set
    # CONFIG_PATA_OPTI is not set
    # CONFIG_PATA_OF_PLATFORM is not set
    # CONFIG_PATA_RZ1000 is not set
    # CONFIG_PATA_SAMSUNG_CF is not set
    # Generic fallback / legacy drivers
    # CONFIG_ATA_GENERIC is not set
    # CONFIG_PATA_LEGACY is not set
    # CONFIG_MD is not set
    # CONFIG_TARGET_CORE is not set
    # CONFIG_FUSION is not set
    # IEEE 1394 (FireWire) support
    # CONFIG_FIREWIRE is not set
    # CONFIG_FIREWIRE_NOSY is not set
    # end of IEEE 1394 (FireWire) support
    CONFIG_NETDEVICES=y
    CONFIG_MII=y
    CONFIG_NET_CORE=y
    # CONFIG_BONDING is not set
    CONFIG_DUMMY=y
    # CONFIG_WIREGUARD is not set
    # CONFIG_EQUALIZER is not set
    # CONFIG_NET_FC is not set
    # CONFIG_NET_TEAM is not set
    # CONFIG_MACVLAN is not set
    # CONFIG_IPVLAN is not set
    # CONFIG_VXLAN is not set
    # CONFIG_GENEVE is not set
    # CONFIG_BAREUDP is not set
    # CONFIG_GTP is not set
    # CONFIG_MACSEC is not set
    # CONFIG_NETCONSOLE is not set
    # CONFIG_TUN is not set
    # CONFIG_TUN_VNET_CROSS_LE is not set
    # CONFIG_VETH is not set
    CONFIG_VIRTIO_NET=y
    # CONFIG_NLMON is not set
    # CONFIG_ARCNET is not set
    # Distributed Switch Architecture drivers
    CONFIG_B53=m
    CONFIG_B53_SPI_DRIVER=m
    CONFIG_B53_MDIO_DRIVER=m
    CONFIG_B53_MMAP_DRIVER=m
    CONFIG_B53_SRAB_DRIVER=m
    CONFIG_B53_SERDES=m
    CONFIG_NET_DSA_BCM_SF2=m
    # CONFIG_NET_DSA_LOOP is not set
    # CONFIG_NET_DSA_LANTIQ_GSWIP is not set
    # CONFIG_NET_DSA_MT7530 is not set
    # CONFIG_NET_DSA_MV88E6060 is not set
    # CONFIG_NET_DSA_MICROCHIP_KSZ_COMMON is not set
    # CONFIG_NET_DSA_MV88E6XXX is not set
    # CONFIG_NET_DSA_MSCC_FELIX is not set
    # CONFIG_NET_DSA_MSCC_SEVILLE is not set
    # CONFIG_NET_DSA_AR9331 is not set
    # CONFIG_NET_DSA_QCA8K is not set
    # CONFIG_NET_DSA_SJA1105 is not set
    # CONFIG_NET_DSA_XRS700X_I2C is not set
    # CONFIG_NET_DSA_XRS700X_MDIO is not set
    # CONFIG_NET_DSA_REALTEK is not set
    # CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set
    # CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set
    # CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set
    # CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set
    # end of Distributed Switch Architecture drivers
    CONFIG_ETHERNET=y
    CONFIG_NET_VENDOR_3COM=y
    # CONFIG_VORTEX is not set
    # CONFIG_TYPHOON is not set
    # CONFIG_NET_VENDOR_ACTIONS is not set
    CONFIG_NET_VENDOR_ADAPTEC=y
    # CONFIG_ADAPTEC_STARFIRE is not set
    CONFIG_NET_VENDOR_AGERE=y
    # CONFIG_ET131X is not set
    CONFIG_NET_VENDOR_ALACRITECH=y
    # CONFIG_SLICOSS is not set
    CONFIG_NET_VENDOR_ALTEON=y
    # CONFIG_ACENIC is not set
    # CONFIG_ALTERA_TSE is not set
    CONFIG_NET_VENDOR_AMAZON=y
    # CONFIG_ENA_ETHERNET is not set
    CONFIG_NET_VENDOR_AMD=y
    # CONFIG_AMD8111_ETH is not set
    # CONFIG_PCNET32 is not set
    # CONFIG_AMD_XGBE is not set
    # CONFIG_NET_XGENE is not set
    # CONFIG_NET_XGENE_V2 is not set
    CONFIG_NET_VENDOR_AQUANTIA=y
    # CONFIG_AQTION is not set
    CONFIG_NET_VENDOR_ARC=y
    # CONFIG_ARC_EMAC is not set
    # CONFIG_EMAC_ROCKCHIP is not set
    CONFIG_NET_VENDOR_ASIX=y
    CONFIG_SPI_AX88796C=m
    # CONFIG_SPI_AX88796C_COMPRESSION is not set
    CONFIG_NET_VENDOR_ATHEROS=y
    # CONFIG_ATL2 is not set
    # CONFIG_ATL1 is not set
    # CONFIG_ATL1E is not set
    # CONFIG_ATL1C is not set
    # CONFIG_ALX is not set
    # CONFIG_CX_ECAT is not set
    CONFIG_NET_VENDOR_BROADCOM=y
    # CONFIG_B44 is not set
    # CONFIG_BCM4908_ENET is not set
    CONFIG_BCMGENET=m
    # CONFIG_BNX2 is not set
    # CONFIG_CNIC is not set
    # CONFIG_TIGON3 is not set
    # CONFIG_BNX2X is not set
    # CONFIG_BGMAC_BCMA is not set
    # CONFIG_BGMAC_PLATFORM is not set
    CONFIG_SYSTEMPORT=m
    # CONFIG_BNXT is not set
    CONFIG_NET_VENDOR_CADENCE=y
    CONFIG_MACB=y
    CONFIG_MACB_USE_HWSTAMP=y
    # CONFIG_MACB_PCI is not set
    # CONFIG_NET_CALXEDA_XGMAC is not set
    CONFIG_NET_VENDOR_CAVIUM=y
    CONFIG_NET_VENDOR_CHELSIO=y
    # CONFIG_CHELSIO_T1 is not set
    # CONFIG_CHELSIO_T3 is not set
    # CONFIG_CHELSIO_T4 is not set
    # CONFIG_CHELSIO_T4VF is not set
    CONFIG_NET_VENDOR_CIRRUS=y
    # CONFIG_CS89x0_PLATFORM is not set
    # CONFIG_EP93XX_ETH is not set
    CONFIG_NET_VENDOR_CISCO=y
    # CONFIG_ENIC is not set
    CONFIG_NET_VENDOR_CORTINA=y
    # CONFIG_GEMINI_ETHERNET is not set
    CONFIG_NET_VENDOR_DAVICOM=y
    # CONFIG_DM9000 is not set
    # CONFIG_DM9051 is not set
    # CONFIG_DNET is not set
    CONFIG_NET_VENDOR_DEC=y
    # CONFIG_NET_TULIP is not set
    CONFIG_NET_VENDOR_DLINK=y
    # CONFIG_DL2K is not set
    # CONFIG_SUNDANCE is not set
    CONFIG_NET_VENDOR_EMULEX=y
    # CONFIG_BE2NET is not set
    CONFIG_NET_VENDOR_ENGLEDER=y
    # CONFIG_TSNEP is not set
    CONFIG_NET_VENDOR_EZCHIP=y
    # CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set
    CONFIG_NET_VENDOR_FARADAY=y
    # CONFIG_FTMAC100 is not set
    CONFIG_FTGMAC100=m
    CONFIG_NET_VENDOR_FREESCALE=y
    # CONFIG_FEC is not set
    # CONFIG_FSL_FMAN is not set
    # CONFIG_FSL_PQ_MDIO is not set
    # CONFIG_FSL_XGMAC_MDIO is not set
    # CONFIG_GIANFAR is not set
    # CONFIG_FSL_DPAA2_SWITCH is not set
    # CONFIG_FSL_ENETC is not set
    # CONFIG_FSL_ENETC_VF is not set
    # CONFIG_FSL_ENETC_IERB is not set
    # CONFIG_FSL_ENETC_MDIO is not set
    CONFIG_NET_VENDOR_FUNGIBLE=y
    # CONFIG_FUN_ETH is not set
    CONFIG_NET_VENDOR_GOOGLE=y
    # CONFIG_GVE is not set
    CONFIG_NET_VENDOR_HISILICON=y
    CONFIG_HIX5HD2_GMAC=y
    # CONFIG_HISI_FEMAC is not set
    # CONFIG_HIP04_ETH is not set
    # CONFIG_HNS_DSAF is not set
    # CONFIG_HNS_ENET is not set
    # CONFIG_HNS3 is not set
    CONFIG_NET_VENDOR_HUAWEI=y
    CONFIG_NET_VENDOR_I825XX=y
    CONFIG_NET_VENDOR_INTEL=y
    # CONFIG_E100 is not set
    # CONFIG_E1000 is not set
    CONFIG_E1000E=y
    CONFIG_IGB=y
    CONFIG_IGB_HWMON=y
    # CONFIG_IGBVF is not set
    # CONFIG_IXGB is not set
    # CONFIG_IXGBE is not set
    # CONFIG_IXGBEVF is not set
    # CONFIG_I40E is not set
    # CONFIG_I40EVF is not set
    # CONFIG_ICE is not set
    # CONFIG_FM10K is not set
    # CONFIG_IGC is not set
    CONFIG_NET_VENDOR_WANGXUN=y
    # CONFIG_NGBE is not set
    # CONFIG_TXGBE is not set
    # CONFIG_JME is not set
    # CONFIG_KORINA is not set
    CONFIG_NET_VENDOR_ADI=y
    # CONFIG_ADIN1110 is not set
    CONFIG_NET_VENDOR_LITEX=y
    # CONFIG_LITEX_LITEETH is not set
    CONFIG_NET_VENDOR_MARVELL=y
    # CONFIG_MV643XX_ETH is not set
    CONFIG_MVMDIO=y
    # CONFIG_MVNETA is not set
    # CONFIG_MVPP2 is not set
    # CONFIG_PXA168_ETH is not set
    # CONFIG_SKGE is not set
    # CONFIG_SKY2 is not set
    # CONFIG_NET_VENDOR_MEDIATEK is not set
    CONFIG_NET_VENDOR_MELLANOX=y
    # CONFIG_MLX4_EN is not set
    # CONFIG_MLX5_CORE is not set
    # CONFIG_MLXSW_CORE is not set
    # CONFIG_MLXFW is not set
    # CONFIG_MLXBF_GIGE is not set
    CONFIG_NET_VENDOR_MICREL=y
    # CONFIG_KS8842 is not set
    CONFIG_KS8851=y
    # CONFIG_KS8851_MLL is not set
    # CONFIG_KSZ884X_PCI is not set
    CONFIG_NET_VENDOR_MICROCHIP=y
    # CONFIG_ENC28J60 is not set
    # CONFIG_ENCX24J600 is not set
    # CONFIG_LAN743X is not set
    CONFIG_LAN966X_SWITCH=m
    # CONFIG_SPARX5_SWITCH is not set
    CONFIG_NET_VENDOR_MICROSEMI=y
    # CONFIG_MSCC_OCELOT_SWITCH is not set
    CONFIG_NET_VENDOR_MICROSOFT=y
    CONFIG_NET_VENDOR_MYRI=y
    # CONFIG_MYRI10GE is not set
    # CONFIG_FEALNX is not set
    CONFIG_NET_VENDOR_NI=y
    # CONFIG_NI_XGE_MANAGEMENT_ENET is not set
    CONFIG_NET_VENDOR_NATSEMI=y
    # CONFIG_NATSEMI is not set
    # CONFIG_NS83820 is not set
    CONFIG_NET_VENDOR_NETERION=y
    # CONFIG_S2IO is not set
    CONFIG_NET_VENDOR_NETRONOME=y
    # CONFIG_NFP is not set
    CONFIG_NET_VENDOR_8390=y
    # CONFIG_AX88796 is not set
    # CONFIG_NE2K_PCI is not set
    CONFIG_NET_VENDOR_NVIDIA=y
    # CONFIG_FORCEDETH is not set
    # CONFIG_LPC_ENET is not set
    CONFIG_NET_VENDOR_OKI=y
    # CONFIG_PCH_GBE is not set
    # CONFIG_ETHOC is not set
    CONFIG_NET_VENDOR_PACKET_ENGINES=y
    # CONFIG_HAMACHI is not set
    # CONFIG_YELLOWFIN is not set
    CONFIG_NET_VENDOR_PENSANDO=y
    CONFIG_NET_VENDOR_QLOGIC=y
    # CONFIG_QLA3XXX is not set
    # CONFIG_QLCNIC is not set
    # CONFIG_NETXEN_NIC is not set
    # CONFIG_QED is not set
    CONFIG_NET_VENDOR_BROCADE=y
    # CONFIG_BNA is not set
    CONFIG_NET_VENDOR_QUALCOMM=y
    # CONFIG_QCA7000_SPI is not set
    # CONFIG_QCA7000_UART is not set
    # CONFIG_QCOM_EMAC is not set
    # CONFIG_RMNET is not set
    CONFIG_NET_VENDOR_RDC=y
    # CONFIG_R6040 is not set
    CONFIG_NET_VENDOR_REALTEK=y
    # CONFIG_8139CP is not set
    # CONFIG_8139TOO is not set
    CONFIG_R8169=y
    CONFIG_NET_VENDOR_RENESAS=y
    CONFIG_SH_ETH=y
    # CONFIG_RAVB is not set
    CONFIG_NET_VENDOR_ROCKER=y
    CONFIG_NET_VENDOR_SAMSUNG=y
    # CONFIG_SXGBE_ETH is not set
    CONFIG_NET_VENDOR_SEEQ=y
    CONFIG_NET_VENDOR_SILAN=y
    # CONFIG_SC92031 is not set
    CONFIG_NET_VENDOR_SIS=y
    # CONFIG_SIS900 is not set
    # CONFIG_SIS190 is not set
    CONFIG_NET_VENDOR_SOLARFLARE=y
    # CONFIG_SFC is not set
    # CONFIG_SFC_FALCON is not set
    # CONFIG_SFC_SIENA is not set
    CONFIG_NET_VENDOR_SMSC=y
    # CONFIG_SMC91X is not set
    # CONFIG_EPIC100 is not set
    # CONFIG_SMC911X is not set
    CONFIG_SMSC911X=y
    # CONFIG_SMSC9420 is not set
    CONFIG_NET_VENDOR_SOCIONEXT=y
    # CONFIG_SNI_AVE is not set
    # CONFIG_SNI_NETSEC is not set
    CONFIG_NET_VENDOR_STMICRO=y
    CONFIG_STMMAC_ETH=y
    # CONFIG_STMMAC_SELFTESTS is not set
    CONFIG_STMMAC_PLATFORM=y
    CONFIG_DWMAC_DWC_QOS_ETH=y
    CONFIG_DWMAC_GENERIC=y
    # CONFIG_DWMAC_ANARION is not set
    # CONFIG_DWMAC_INGENIC is not set
    CONFIG_DWMAC_IPQ806X=y
    # CONFIG_DWMAC_LPC18XX is not set
    # CONFIG_DWMAC_MEDIATEK is not set
    CONFIG_DWMAC_MESON=y
    # CONFIG_DWMAC_OXNAS is not set
    CONFIG_DWMAC_QCOM_ETHQOS=y
    CONFIG_DWMAC_ROCKCHIP=y
    CONFIG_DWMAC_SOCFPGA=y
    CONFIG_DWMAC_STI=y
    CONFIG_DWMAC_STM32=y
    CONFIG_DWMAC_SUNXI=y
    CONFIG_DWMAC_SUN8I=y
    CONFIG_DWMAC_IMX8=y
    # CONFIG_DWMAC_INTEL_PLAT is not set
    # CONFIG_DWMAC_VISCONTI is not set
    # CONFIG_DWMAC_LOONGSON is not set
    # CONFIG_STMMAC_PCI is not set
    CONFIG_NET_VENDOR_SUN=y
    # CONFIG_HAPPYMEAL is not set
    # CONFIG_SUNGEM is not set
    # CONFIG_CASSINI is not set
    # CONFIG_NIU is not set
    CONFIG_NET_VENDOR_SUNPLUS=y
    # CONFIG_SP7021_EMAC is not set
    CONFIG_NET_VENDOR_SYNOPSYS=y
    # CONFIG_DWC_XLGMAC is not set
    CONFIG_NET_VENDOR_TEHUTI=y
    # CONFIG_TEHUTI is not set
    CONFIG_NET_VENDOR_TI=y
    # CONFIG_TI_DAVINCI_EMAC is not set
    CONFIG_TI_DAVINCI_MDIO=y
    # CONFIG_TI_CPSW_PHY_SEL is not set
    CONFIG_TI_CPSW=y
    CONFIG_TI_CPSW_SWITCHDEV=y
    CONFIG_TI_CPTS=y
    # CONFIG_TLAN is not set
    CONFIG_NET_VENDOR_VERTEXCOM=y
    # CONFIG_MSE102X is not set
    CONFIG_NET_VENDOR_VIA=y
    # CONFIG_VIA_RHINE is not set
    # CONFIG_VIA_VELOCITY is not set
    CONFIG_NET_VENDOR_WIZNET=y
    # CONFIG_WIZNET_W5100 is not set
    # CONFIG_WIZNET_W5300 is not set
    CONFIG_NET_VENDOR_XILINX=y
    CONFIG_XILINX_EMACLITE=y
    # CONFIG_XILINX_AXI_EMAC is not set
    # CONFIG_XILINX_LL_TEMAC is not set
    # CONFIG_FDDI is not set
    # CONFIG_HIPPI is not set
    CONFIG_PHYLINK=y
    CONFIG_PHYLIB=y
    CONFIG_SWPHY=y
    # CONFIG_LED_TRIGGER_PHY is not set
    CONFIG_FIXED_PHY=y
    CONFIG_SFP=m
    # MII PHY device drivers
    # CONFIG_AMD_PHY is not set
    # CONFIG_MESON_GXL_PHY is not set
    # CONFIG_ADIN_PHY is not set
    # CONFIG_ADIN1100_PHY is not set
    # CONFIG_AQUANTIA_PHY is not set
    CONFIG_AX88796B_PHY=y
    CONFIG_BROADCOM_PHY=y
    # CONFIG_BCM54140_PHY is not set
    # CONFIG_BCM63XX_PHY is not set
    CONFIG_BCM7XXX_PHY=m
    # CONFIG_BCM84881_PHY is not set
    # CONFIG_BCM87XX_PHY is not set
    CONFIG_BCM_NET_PHYLIB=y
    # CONFIG_CICADA_PHY is not set
    # CONFIG_CORTINA_PHY is not set
    # CONFIG_DAVICOM_PHY is not set
    CONFIG_ICPLUS_PHY=y
    # CONFIG_LXT_PHY is not set
    # CONFIG_INTEL_XWAY_PHY is not set
    # CONFIG_LSI_ET1011C_PHY is not set
    CONFIG_MARVELL_PHY=y
    # CONFIG_MARVELL_10G_PHY is not set
    # CONFIG_MARVELL_88X2222_PHY is not set
    # CONFIG_MAXLINEAR_GPHY is not set
    # CONFIG_MEDIATEK_GE_PHY is not set
    CONFIG_MICREL_PHY=y
    CONFIG_MICROCHIP_PHY=y
    # CONFIG_MICROCHIP_T1_PHY is not set
    # CONFIG_MICROSEMI_PHY is not set
    # CONFIG_MOTORCOMM_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_NXP_C45_TJA11XX_PHY is not set
    # CONFIG_NXP_TJA11XX_PHY is not set
    CONFIG_AT803X_PHY=y
    # CONFIG_QSEMI_PHY is not set
    CONFIG_REALTEK_PHY=y
    # CONFIG_RENESAS_PHY is not set
    CONFIG_ROCKCHIP_PHY=y
    CONFIG_SMSC_PHY=y
    # CONFIG_STE10XP is not set
    # CONFIG_TERANETICS_PHY is not set
    # CONFIG_DP83822_PHY is not set
    # CONFIG_DP83TC811_PHY is not set
    # CONFIG_DP83848_PHY is not set
    CONFIG_DP83867_PHY=y
    # CONFIG_DP83869_PHY is not set
    # CONFIG_DP83TD510_PHY is not set
    # CONFIG_VITESSE_PHY is not set
    # CONFIG_XILINX_GMII2RGMII is not set
    # CONFIG_MICREL_KS8995MA is not set
    # CONFIG_PSE_CONTROLLER is not set
    CONFIG_CAN_DEV=y
    # CONFIG_CAN_VCAN is not set
    # CONFIG_CAN_VXCAN is not set
    CONFIG_CAN_NETLINK=y
    CONFIG_CAN_CALC_BITTIMING=y
    CONFIG_CAN_RX_OFFLOAD=y
    # CONFIG_CAN_AT91 is not set
    # CONFIG_CAN_CAN327 is not set
    CONFIG_CAN_FLEXCAN=m
    # CONFIG_CAN_GRCAN is not set
    # CONFIG_CAN_KVASER_PCIEFD is not set
    # CONFIG_CAN_SLCAN is not set
    # CONFIG_CAN_SUN4I is not set
    # CONFIG_CAN_TI_HECC is not set
    # CONFIG_CAN_XILINXCAN is not set
    # CONFIG_PCH_CAN is not set
    # CONFIG_CAN_C_CAN is not set
    # CONFIG_CAN_CC770 is not set
    # CONFIG_CAN_CTUCANFD is not set
    # CONFIG_CAN_CTUCANFD_PCI is not set
    # CONFIG_CAN_CTUCANFD_PLATFORM is not set
    # CONFIG_CAN_IFI_CANFD is not set
    # CONFIG_CAN_M_CAN is not set
    # CONFIG_CAN_PEAK_PCIEFD is not set
    # CONFIG_CAN_RCAR is not set
    # CONFIG_CAN_RCAR_CANFD is not set
    # CONFIG_CAN_SJA1000 is not set
    # CONFIG_CAN_SOFTING is not set
    # CAN SPI interfaces
    # CONFIG_CAN_HI311X is not set
    CONFIG_CAN_MCP251X=y
    # CONFIG_CAN_MCP251XFD is not set
    # end of CAN SPI interfaces
    # CAN USB interfaces
    # CONFIG_CAN_8DEV_USB is not set
    # CONFIG_CAN_EMS_USB is not set
    # CONFIG_CAN_ESD_USB is not set
    # CONFIG_CAN_ETAS_ES58X is not set
    # CONFIG_CAN_GS_USB is not set
    # CONFIG_CAN_KVASER_USB is not set
    # CONFIG_CAN_MCBA_USB is not set
    # CONFIG_CAN_PEAK_USB is not set
    # CONFIG_CAN_UCAN is not set
    # end of CAN USB interfaces
    # CONFIG_CAN_DEBUG_DEVICES is not set
    CONFIG_MDIO_DEVICE=y
    CONFIG_MDIO_BUS=y
    CONFIG_FWNODE_MDIO=y
    CONFIG_OF_MDIO=y
    CONFIG_MDIO_DEVRES=y
    # CONFIG_MDIO_SUN4I is not set
    # CONFIG_MDIO_XGENE is not set
    # CONFIG_MDIO_ASPEED is not set
    CONFIG_MDIO_BITBANG=y
    # CONFIG_MDIO_BCM_IPROC is not set
    CONFIG_MDIO_BCM_UNIMAC=m
    # CONFIG_MDIO_GPIO is not set
    # CONFIG_MDIO_HISI_FEMAC is not set
    CONFIG_MDIO_I2C=m
    # CONFIG_MDIO_MVUSB is not set
    CONFIG_MDIO_MSCC_MIIM=m
    # CONFIG_MDIO_MOXART is not set
    # CONFIG_MDIO_OCTEON is not set
    # CONFIG_MDIO_IPQ4019 is not set
    # CONFIG_MDIO_IPQ8064 is not set
    # MDIO Multiplexers
    CONFIG_MDIO_BUS_MUX=y
    # CONFIG_MDIO_BUS_MUX_MESON_G12A is not set
    # CONFIG_MDIO_BUS_MUX_BCM6368 is not set
    # CONFIG_MDIO_BUS_MUX_BCM_IPROC is not set
    # CONFIG_MDIO_BUS_MUX_GPIO is not set
    # CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set
    # CONFIG_MDIO_BUS_MUX_MMIOREG is not set
    # PCS device drivers
    CONFIG_PCS_XPCS=y
    # CONFIG_PCS_RZN1_MIIC is not set
    # end of PCS device drivers
    # CONFIG_PPP is not set
    # CONFIG_SLIP is not set
    CONFIG_USB_NET_DRIVERS=y
    # CONFIG_USB_CATC is not set
    # CONFIG_USB_KAWETH is not set
    CONFIG_USB_PEGASUS=y
    # CONFIG_USB_RTL8150 is not set
    CONFIG_USB_RTL8152=m
    CONFIG_USB_LAN78XX=m
    CONFIG_USB_USBNET=y
    CONFIG_USB_NET_AX8817X=y
    CONFIG_USB_NET_AX88179_178A=y
    CONFIG_USB_NET_CDCETHER=y
    # CONFIG_USB_NET_CDC_EEM is not set
    CONFIG_USB_NET_CDC_NCM=y
    # CONFIG_USB_NET_HUAWEI_CDC_NCM is not set
    # CONFIG_USB_NET_CDC_MBIM is not set
    # CONFIG_USB_NET_DM9601 is not set
    # CONFIG_USB_NET_SR9700 is not set
    # CONFIG_USB_NET_SR9800 is not set
    CONFIG_USB_NET_SMSC75XX=y
    CONFIG_USB_NET_SMSC95XX=y
    # CONFIG_USB_NET_GL620A is not set
    CONFIG_USB_NET_NET1080=y
    # CONFIG_USB_NET_PLUSB is not set
    # CONFIG_USB_NET_MCS7830 is not set
    # CONFIG_USB_NET_RNDIS_HOST is not set
    CONFIG_USB_NET_CDC_SUBSET_ENABLE=y
    CONFIG_USB_NET_CDC_SUBSET=y
    # CONFIG_USB_ALI_M5632 is not set
    # CONFIG_USB_AN2720 is not set
    CONFIG_USB_BELKIN=y
    CONFIG_USB_ARMLINUX=y
    # CONFIG_USB_EPSON2888 is not set
    # CONFIG_USB_KC2190 is not set
    CONFIG_USB_NET_ZAURUS=y
    # CONFIG_USB_NET_CX82310_ETH is not set
    # CONFIG_USB_NET_KALMIA is not set
    # CONFIG_USB_NET_QMI_WWAN is not set
    # CONFIG_USB_HSO is not set
    # CONFIG_USB_NET_INT51X1 is not set
    # CONFIG_USB_IPHETH is not set
    # CONFIG_USB_SIERRA_NET is not set
    # CONFIG_USB_VL600 is not set
    # CONFIG_USB_NET_CH9200 is not set
    # CONFIG_USB_NET_AQC111 is not set
    CONFIG_USB_RTL8153_ECM=m
    CONFIG_WLAN=y
    CONFIG_WLAN_VENDOR_ADMTEK=y
    # CONFIG_ADM8211 is not set
    CONFIG_WLAN_VENDOR_ATH=y
    # CONFIG_ATH_DEBUG is not set
    # CONFIG_ATH5K is not set
    # CONFIG_ATH5K_PCI is not set
    # CONFIG_ATH9K is not set
    # CONFIG_ATH9K_HTC is not set
    # CONFIG_CARL9170 is not set
    # CONFIG_ATH6KL is not set
    # CONFIG_AR5523 is not set
    # CONFIG_WIL6210 is not set
    # CONFIG_ATH10K is not set
    CONFIG_WCN36XX=m
    # CONFIG_WCN36XX_DEBUGFS is not set
    CONFIG_WLAN_VENDOR_ATMEL=y
    # CONFIG_ATMEL is not set
    # CONFIG_AT76C50X_USB is not set
    CONFIG_WLAN_VENDOR_BROADCOM=y
    # CONFIG_B43 is not set
    # CONFIG_B43LEGACY is not set
    CONFIG_BRCMUTIL=m
    # CONFIG_BRCMSMAC is not set
    CONFIG_BRCMFMAC=m
    CONFIG_BRCMFMAC_PROTO_BCDC=y
    CONFIG_BRCMFMAC_SDIO=y
    # CONFIG_BRCMFMAC_USB is not set
    # CONFIG_BRCMFMAC_PCIE is not set
    # CONFIG_BRCM_TRACING is not set
    # CONFIG_BRCMDBG is not set
    CONFIG_WLAN_VENDOR_CISCO=y
    CONFIG_WLAN_VENDOR_INTEL=y
    # CONFIG_IPW2100 is not set
    # CONFIG_IPW2200 is not set
    # CONFIG_IWL4965 is not set
    # CONFIG_IWL3945 is not set
    # CONFIG_IWLWIFI is not set
    CONFIG_WLAN_VENDOR_INTERSIL=y
    # CONFIG_HOSTAP is not set
    # CONFIG_HERMES is not set
    # CONFIG_P54_COMMON is not set
    CONFIG_WLAN_VENDOR_MARVELL=y
    # CONFIG_LIBERTAS is not set
    # CONFIG_LIBERTAS_THINFIRM is not set
    CONFIG_MWIFIEX=m
    CONFIG_MWIFIEX_SDIO=m
    # CONFIG_MWIFIEX_PCIE is not set
    # CONFIG_MWIFIEX_USB is not set
    # CONFIG_MWL8K is not set
    CONFIG_WLAN_VENDOR_MEDIATEK=y
    # CONFIG_MT7601U is not set
    # CONFIG_MT76x0U is not set
    # CONFIG_MT76x0E is not set
    # CONFIG_MT76x2E is not set
    # CONFIG_MT76x2U is not set
    # CONFIG_MT7603E is not set
    # CONFIG_MT7615E is not set
    # CONFIG_MT7663U is not set
    # CONFIG_MT7663S is not set
    # CONFIG_MT7915E is not set
    # CONFIG_MT7921E is not set
    # CONFIG_MT7921S is not set
    # CONFIG_MT7921U is not set
    CONFIG_WLAN_VENDOR_MICROCHIP=y
    # CONFIG_WILC1000_SDIO is not set
    # CONFIG_WILC1000_SPI is not set
    CONFIG_WLAN_VENDOR_PURELIFI=y
    # CONFIG_PLFXLC is not set
    CONFIG_WLAN_VENDOR_RALINK=y
    CONFIG_RT2X00=m
    # CONFIG_RT2400PCI is not set
    # CONFIG_RT2500PCI is not set
    # CONFIG_RT61PCI is not set
    # CONFIG_RT2800PCI is not set
    # CONFIG_RT2500USB is not set
    # CONFIG_RT73USB is not set
    CONFIG_RT2800USB=m
    CONFIG_RT2800USB_RT33XX=y
    CONFIG_RT2800USB_RT35XX=y
    # CONFIG_RT2800USB_RT3573 is not set
    # CONFIG_RT2800USB_RT53XX is not set
    # CONFIG_RT2800USB_RT55XX is not set
    # CONFIG_RT2800USB_UNKNOWN is not set
    CONFIG_RT2800_LIB=m
    CONFIG_RT2X00_LIB_USB=m
    CONFIG_RT2X00_LIB=m
    CONFIG_RT2X00_LIB_FIRMWARE=y
    CONFIG_RT2X00_LIB_CRYPTO=y
    CONFIG_RT2X00_LIB_LEDS=y
    # CONFIG_RT2X00_DEBUG is not set
    CONFIG_WLAN_VENDOR_REALTEK=y
    # CONFIG_RTL8180 is not set
    # CONFIG_RTL8187 is not set
    CONFIG_RTL_CARDS=m
    # CONFIG_RTL8192CE is not set
    # CONFIG_RTL8192SE is not set
    # CONFIG_RTL8192DE is not set
    # CONFIG_RTL8723AE is not set
    # CONFIG_RTL8723BE is not set
    # CONFIG_RTL8188EE is not set
    # CONFIG_RTL8192EE is not set
    # CONFIG_RTL8821AE is not set
    # CONFIG_RTL8192CU is not set
    # CONFIG_RTL8XXXU is not set
    # CONFIG_RTW88 is not set
    # CONFIG_RTW89 is not set
    CONFIG_WLAN_VENDOR_RSI=y
    # CONFIG_RSI_91X is not set
    CONFIG_WLAN_VENDOR_SILABS=y
    # CONFIG_WFX is not set
    CONFIG_WLAN_VENDOR_ST=y
    # CONFIG_CW1200 is not set
    CONFIG_WLAN_VENDOR_TI=y
    # CONFIG_WL1251 is not set
    # CONFIG_WL12XX is not set
    # CONFIG_WL18XX is not set
    # CONFIG_WLCORE is not set
    CONFIG_WLAN_VENDOR_ZYDAS=y
    # CONFIG_USB_ZD1201 is not set
    # CONFIG_ZD1211RW is not set
    CONFIG_WLAN_VENDOR_QUANTENNA=y
    # CONFIG_QTNFMAC_PCIE is not set
    # CONFIG_MAC80211_HWSIM is not set
    # CONFIG_USB_NET_RNDIS_WLAN is not set
    # CONFIG_VIRT_WIFI is not set
    # CONFIG_WAN is not set
    # Wireless WAN
    # CONFIG_WWAN is not set
    # end of Wireless WAN
    # CONFIG_VMXNET3 is not set
    # CONFIG_NETDEVSIM is not set
    CONFIG_NET_FAILOVER=y
    # CONFIG_ISDN is not set
    # Input device support
    CONFIG_INPUT=y
    CONFIG_INPUT_LEDS=y
    CONFIG_INPUT_FF_MEMLESS=m
    # CONFIG_INPUT_SPARSEKMAP is not set
    CONFIG_INPUT_MATRIXKMAP=y
    CONFIG_INPUT_VIVALDIFMAP=y
    # Userland interfaces
    # CONFIG_INPUT_MOUSEDEV is not set
    CONFIG_INPUT_JOYDEV=y
    CONFIG_INPUT_EVDEV=y
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    # CONFIG_KEYBOARD_ADC is not set
    # CONFIG_KEYBOARD_ADP5588 is not set
    # CONFIG_KEYBOARD_ADP5589 is not set
    CONFIG_KEYBOARD_ATKBD=y
    # CONFIG_KEYBOARD_QT1050 is not set
    CONFIG_KEYBOARD_QT1070=m
    # CONFIG_KEYBOARD_QT2160 is not set
    # CONFIG_KEYBOARD_CLPS711X is not set
    # CONFIG_KEYBOARD_DLINK_DIR685 is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    # CONFIG_KEYBOARD_EP93XX is not set
    CONFIG_KEYBOARD_GPIO=y
    # CONFIG_KEYBOARD_GPIO_POLLED is not set
    # CONFIG_KEYBOARD_TCA6416 is not set
    # CONFIG_KEYBOARD_TCA8418 is not set
    # CONFIG_KEYBOARD_MATRIX is not set
    # CONFIG_KEYBOARD_LM8323 is not set
    # CONFIG_KEYBOARD_LM8333 is not set
    # CONFIG_KEYBOARD_MAX7359 is not set
    # CONFIG_KEYBOARD_MCS is not set
    # CONFIG_KEYBOARD_MPR121 is not set
    # CONFIG_KEYBOARD_SNVS_PWRKEY is not set
    # CONFIG_KEYBOARD_IMX is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_OPENCORES is not set
    # CONFIG_KEYBOARD_PINEPHONE is not set
    CONFIG_KEYBOARD_SAMSUNG=m
    # CONFIG_KEYBOARD_GOLDFISH_EVENTS is not set
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_ST_KEYSCAN is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    # CONFIG_KEYBOARD_SH_KEYSC is not set
    # CONFIG_KEYBOARD_OMAP4 is not set
    # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
    # CONFIG_KEYBOARD_TWL4030 is not set
    # CONFIG_KEYBOARD_XTKBD is not set
    # CONFIG_KEYBOARD_CAP11XX is not set
    CONFIG_KEYBOARD_BCM=y
    # CONFIG_KEYBOARD_MT6779 is not set
    # CONFIG_KEYBOARD_MTK_PMIC is not set
    # CONFIG_KEYBOARD_CYPRESS_SF is not set
    CONFIG_INPUT_MOUSE=y
    CONFIG_MOUSE_PS2=y
    CONFIG_MOUSE_PS2_ALPS=y
    CONFIG_MOUSE_PS2_BYD=y
    CONFIG_MOUSE_PS2_LOGIPS2PP=y
    CONFIG_MOUSE_PS2_SYNAPTICS=y
    CONFIG_MOUSE_PS2_SYNAPTICS_SMBUS=y
    CONFIG_MOUSE_PS2_CYPRESS=y
    CONFIG_MOUSE_PS2_TRACKPOINT=y
    CONFIG_MOUSE_PS2_ELANTECH=y
    CONFIG_MOUSE_PS2_ELANTECH_SMBUS=y
    # CONFIG_MOUSE_PS2_SENTELIC is not set
    # CONFIG_MOUSE_PS2_TOUCHKIT is not set
    CONFIG_MOUSE_PS2_FOCALTECH=y
    CONFIG_MOUSE_PS2_SMBUS=y
    # CONFIG_MOUSE_SERIAL is not set
    # CONFIG_MOUSE_APPLETOUCH is not set
    # CONFIG_MOUSE_BCM5974 is not set
    CONFIG_MOUSE_CYAPA=m
    CONFIG_MOUSE_ELAN_I2C=y
    CONFIG_MOUSE_ELAN_I2C_I2C=y
    # CONFIG_MOUSE_ELAN_I2C_SMBUS is not set
    # CONFIG_MOUSE_VSXXXAA is not set
    # CONFIG_MOUSE_GPIO is not set
    # CONFIG_MOUSE_SYNAPTICS_I2C is not set
    # CONFIG_MOUSE_SYNAPTICS_USB is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    CONFIG_INPUT_TOUCHSCREEN=y
    # CONFIG_TOUCHSCREEN_ADS7846 is not set
    # CONFIG_TOUCHSCREEN_AD7877 is not set
    # CONFIG_TOUCHSCREEN_AD7879 is not set
    CONFIG_TOUCHSCREEN_ADC=m
    # CONFIG_TOUCHSCREEN_AR1021_I2C is not set
    CONFIG_TOUCHSCREEN_ATMEL_MXT=m
    # CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set
    # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_BU21013 is not set
    # CONFIG_TOUCHSCREEN_BU21029 is not set
    # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMA140 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
    # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
    # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
    # CONFIG_TOUCHSCREEN_DYNAPRO is not set
    # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
    # CONFIG_TOUCHSCREEN_EETI is not set
    # CONFIG_TOUCHSCREEN_EGALAX is not set
    # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
    # CONFIG_TOUCHSCREEN_EXC3000 is not set
    # CONFIG_TOUCHSCREEN_FUJITSU is not set
    # CONFIG_TOUCHSCREEN_GOODIX is not set
    # CONFIG_TOUCHSCREEN_HIDEEP is not set
    # CONFIG_TOUCHSCREEN_HYCON_HY46XX is not set
    CONFIG_TOUCHSCREEN_ILI210X=y
    CONFIG_TOUCHSCREEN_ILITEK=y
    # CONFIG_TOUCHSCREEN_IPROC is not set
    # CONFIG_TOUCHSCREEN_S6SY761 is not set
    # CONFIG_TOUCHSCREEN_GUNZE is not set
    # CONFIG_TOUCHSCREEN_EKTF2127 is not set
    CONFIG_TOUCHSCREEN_ELAN=m
    # CONFIG_TOUCHSCREEN_ELO is not set
    # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
    # CONFIG_TOUCHSCREEN_WACOM_I2C is not set
    # CONFIG_TOUCHSCREEN_MAX11801 is not set
    # CONFIG_TOUCHSCREEN_MCS5000 is not set
    CONFIG_TOUCHSCREEN_MMS114=m
    # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
    # CONFIG_TOUCHSCREEN_MSG2638 is not set
    # CONFIG_TOUCHSCREEN_MTOUCH is not set
    # CONFIG_TOUCHSCREEN_IMAGIS is not set
    # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
    # CONFIG_TOUCHSCREEN_INEXIO is not set
    # CONFIG_TOUCHSCREEN_MK712 is not set
    # CONFIG_TOUCHSCREEN_PENMOUNT is not set
    # CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set
    # CONFIG_TOUCHSCREEN_RASPBERRYPI_FW is not set
    # CONFIG_TOUCHSCREEN_MIGOR is not set
    # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
    # CONFIG_TOUCHSCREEN_TOUCHWIN is not set
    # CONFIG_TOUCHSCREEN_TI_AM335X_TSC is not set
    # CONFIG_TOUCHSCREEN_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
    CONFIG_TOUCHSCREEN_WM97XX=m
    CONFIG_TOUCHSCREEN_WM9705=y
    CONFIG_TOUCHSCREEN_WM9712=y
    CONFIG_TOUCHSCREEN_WM9713=y
    # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
    # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
    # CONFIG_TOUCHSCREEN_TS4800 is not set
    # CONFIG_TOUCHSCREEN_TSC_SERIO is not set
    # CONFIG_TOUCHSCREEN_TSC2004 is not set
    # CONFIG_TOUCHSCREEN_TSC2005 is not set
    # CONFIG_TOUCHSCREEN_TSC2007 is not set
    # CONFIG_TOUCHSCREEN_RM_TS is not set
    # CONFIG_TOUCHSCREEN_SILEAD is not set
    # CONFIG_TOUCHSCREEN_SIS_I2C is not set
    CONFIG_TOUCHSCREEN_ST1232=m
    # CONFIG_TOUCHSCREEN_STMFTS is not set
    # CONFIG_TOUCHSCREEN_SUN4I is not set
    # CONFIG_TOUCHSCREEN_SUR40 is not set
    # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
    # CONFIG_TOUCHSCREEN_SX8654 is not set
    # CONFIG_TOUCHSCREEN_TPS6507X is not set
    # CONFIG_TOUCHSCREEN_ZET6223 is not set
    # CONFIG_TOUCHSCREEN_ZFORCE is not set
    # CONFIG_TOUCHSCREEN_COLIBRI_VF50 is not set
    # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
    # CONFIG_TOUCHSCREEN_IQS5XX is not set
    # CONFIG_TOUCHSCREEN_ZINITIX is not set
    CONFIG_TOUCHSCREEN_FTS=y
    CONFIG_INPUT_MISC=y
    # CONFIG_INPUT_AD714X is not set
    # CONFIG_INPUT_ARIEL_PWRBUTTON is not set
    # CONFIG_INPUT_ATMEL_CAPTOUCH is not set
    # CONFIG_INPUT_BMA150 is not set
    # CONFIG_INPUT_E3X0_BUTTON is not set
    # CONFIG_INPUT_MMA8450 is not set
    # CONFIG_INPUT_GPIO_BEEPER is not set
    # CONFIG_INPUT_GPIO_DECODER is not set
    # CONFIG_INPUT_GPIO_VIBRA is not set
    CONFIG_INPUT_CPCAP_PWRBUTTON=m
    # CONFIG_INPUT_ATI_REMOTE2 is not set
    # CONFIG_INPUT_KEYSPAN_REMOTE is not set
    # CONFIG_INPUT_KXTJ9 is not set
    # CONFIG_INPUT_POWERMATE is not set
    # CONFIG_INPUT_YEALINK is not set
    # CONFIG_INPUT_CM109 is not set
    # CONFIG_INPUT_REGULATOR_HAPTIC is not set
    # CONFIG_INPUT_TPS65218_PWRBUTTON is not set
    # CONFIG_INPUT_TWL4030_PWRBUTTON is not set
    # CONFIG_INPUT_TWL4030_VIBRA is not set
    # CONFIG_INPUT_UINPUT is not set
    # CONFIG_INPUT_PALMAS_PWRBUTTON is not set
    # CONFIG_INPUT_PCF8574 is not set
    # CONFIG_INPUT_PWM_BEEPER is not set
    # CONFIG_INPUT_PWM_VIBRA is not set
    # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
    # CONFIG_INPUT_DA7280_HAPTICS is not set
    CONFIG_INPUT_ADXL34X=m
    CONFIG_INPUT_ADXL34X_I2C=m
    CONFIG_INPUT_ADXL34X_SPI=m
    # CONFIG_INPUT_IBM_PANEL is not set
    # CONFIG_INPUT_IMS_PCU is not set
    # CONFIG_INPUT_IQS269A is not set
    # CONFIG_INPUT_IQS626A is not set
    # CONFIG_INPUT_IQS7222 is not set
    # CONFIG_INPUT_CMA3000 is not set
    # CONFIG_INPUT_DRV260X_HAPTICS is not set
    # CONFIG_INPUT_DRV2665_HAPTICS is not set
    # CONFIG_INPUT_DRV2667_HAPTICS is not set
    # CONFIG_INPUT_HISI_POWERKEY is not set
    # CONFIG_INPUT_SC27XX_VIBRA is not set
    # CONFIG_INPUT_RT5120_PWRKEY is not set
    CONFIG_INPUT_STPMIC1_ONKEY=y
    # CONFIG_RMI4_CORE is not set
    # Hardware I/O ports
    CONFIG_SERIO=y
    CONFIG_SERIO_SERPORT=y
    CONFIG_SERIO_AMBAKMI=y
    # CONFIG_SERIO_PCIPS2 is not set
    CONFIG_SERIO_LIBPS2=y
    # CONFIG_SERIO_RAW is not set
    # CONFIG_SERIO_ALTERA_PS2 is not set
    # CONFIG_SERIO_PS2MULT is not set
    # CONFIG_SERIO_ARC_PS2 is not set
    # CONFIG_SERIO_APBPS2 is not set
    # CONFIG_SERIO_OLPC_APSP is not set
    # CONFIG_SERIO_SUN4I_PS2 is not set
    # CONFIG_SERIO_GPIO_PS2 is not set
    # CONFIG_USERIO is not set
    # CONFIG_GAMEPORT is not set
    # end of Hardware I/O ports
    # end of Input device support
    # Character devices
    CONFIG_TTY=y
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_VT_CONSOLE_SLEEP=y
    CONFIG_HW_CONSOLE=y
    CONFIG_VT_HW_CONSOLE_BINDING=y
    CONFIG_UNIX98_PTYS=y
    CONFIG_LEGACY_PTYS=y
    CONFIG_LEGACY_PTY_COUNT=256
    CONFIG_LDISC_AUTOLOAD=y
    # Serial drivers
    CONFIG_SERIAL_EARLYCON=y
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
    CONFIG_SERIAL_8250_16550A_VARIANTS=y
    # CONFIG_SERIAL_8250_FINTEK is not set
    CONFIG_SERIAL_8250_CONSOLE=y
    CONFIG_SERIAL_8250_DMA=y
    CONFIG_SERIAL_8250_PCI=y
    CONFIG_SERIAL_8250_EXAR=y
    CONFIG_SERIAL_8250_NR_UARTS=5
    CONFIG_SERIAL_8250_RUNTIME_UARTS=5
    CONFIG_SERIAL_8250_EXTENDED=y
    CONFIG_SERIAL_8250_MANY_PORTS=y
    # CONFIG_SERIAL_8250_ASPEED_VUART is not set
    CONFIG_SERIAL_8250_SHARE_IRQ=y
    CONFIG_SERIAL_8250_DETECT_IRQ=y
    CONFIG_SERIAL_8250_RSA=y
    CONFIG_SERIAL_8250_DWLIB=y
    # CONFIG_SERIAL_8250_BCM2835AUX is not set
    CONFIG_SERIAL_8250_FSL=y
    CONFIG_SERIAL_8250_DW=y
    # CONFIG_SERIAL_8250_EM is not set
    # CONFIG_SERIAL_8250_IOC3 is not set
    # CONFIG_SERIAL_8250_RT288X is not set
    CONFIG_SERIAL_8250_OMAP=y
    CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y
    # CONFIG_SERIAL_8250_LPC18XX is not set
    # CONFIG_SERIAL_8250_MT6577 is not set
    # CONFIG_SERIAL_8250_UNIPHIER is not set
    # CONFIG_SERIAL_8250_INGENIC is not set
    CONFIG_SERIAL_8250_LPSS=y
    CONFIG_SERIAL_8250_MID=y
    CONFIG_SERIAL_8250_PERICOM=y
    # CONFIG_SERIAL_8250_PXA is not set
    CONFIG_SERIAL_8250_TEGRA=y
    # CONFIG_SERIAL_8250_BCM7271 is not set
    CONFIG_SERIAL_OF_PLATFORM=y
    # Non-8250 serial port support
    # CONFIG_SERIAL_AMBA_PL010 is not set
    CONFIG_SERIAL_AMBA_PL011=y
    CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
    # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
    # CONFIG_SERIAL_ATMEL is not set
    # CONFIG_SERIAL_MESON is not set
    # CONFIG_SERIAL_CLPS711X is not set
    # CONFIG_SERIAL_SAMSUNG is not set
    # CONFIG_SERIAL_TEGRA is not set
    # CONFIG_SERIAL_TEGRA_TCU is not set
    # CONFIG_SERIAL_MAX3100 is not set
    # CONFIG_SERIAL_MAX310X is not set
    # CONFIG_SERIAL_IMX is not set
    # CONFIG_SERIAL_IMX_EARLYCON is not set
    # CONFIG_SERIAL_UARTLITE is not set
    # CONFIG_SERIAL_SH_SCI is not set
    # CONFIG_SERIAL_HS_LPC32XX is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    # CONFIG_SERIAL_ICOM is not set
    # CONFIG_SERIAL_JSM is not set
    # CONFIG_SERIAL_MSM is not set
    # CONFIG_SERIAL_VT8500 is not set
    CONFIG_SERIAL_OMAP=y
    CONFIG_SERIAL_OMAP_CONSOLE=y
    # CONFIG_SERIAL_SIFIVE is not set
    # CONFIG_SERIAL_LANTIQ is not set
    # CONFIG_SERIAL_SCCNXP is not set
    # CONFIG_SERIAL_SC16IS7XX is not set
    # CONFIG_SERIAL_TIMBERDALE is not set
    # CONFIG_SERIAL_BCM63XX is not set
    # CONFIG_SERIAL_ALTERA_JTAGUART is not set
    # CONFIG_SERIAL_ALTERA_UART is not set
    # CONFIG_SERIAL_PCH_UART is not set
    # CONFIG_SERIAL_MXS_AUART is not set
    CONFIG_SERIAL_XILINX_PS_UART=y
    CONFIG_SERIAL_XILINX_PS_UART_CONSOLE=y
    # CONFIG_SERIAL_MPS2_UART is not set
    # CONFIG_SERIAL_ARC is not set
    # CONFIG_SERIAL_RP2 is not set
    CONFIG_SERIAL_FSL_LPUART=y
    CONFIG_SERIAL_FSL_LPUART_CONSOLE=y
    # CONFIG_SERIAL_FSL_LINFLEXUART is not set
    CONFIG_SERIAL_CONEXANT_DIGICOLOR=y
    CONFIG_SERIAL_CONEXANT_DIGICOLOR_CONSOLE=y
    CONFIG_SERIAL_ST_ASC=y
    CONFIG_SERIAL_ST_ASC_CONSOLE=y
    # CONFIG_SERIAL_SPRD is not set
    # CONFIG_SERIAL_STM32 is not set
    # CONFIG_SERIAL_MVEBU_UART is not set
    # CONFIG_SERIAL_OWL is not set
    # CONFIG_SERIAL_RDA is not set
    # CONFIG_SERIAL_MILBEAUT_USIO is not set
    # CONFIG_SERIAL_LITEUART is not set
    CONFIG_SERIAL_SUNPLUS=y
    CONFIG_SERIAL_SUNPLUS_CONSOLE=y
    # end of Serial drivers
    CONFIG_SERIAL_MCTRL_GPIO=y
    # CONFIG_SERIAL_NONSTANDARD is not set
    # CONFIG_N_GSM is not set
    # CONFIG_NOZOMI is not set
    # CONFIG_NULL_TTY is not set
    CONFIG_HVC_DRIVER=y
    # CONFIG_HVC_DCC is not set
    # CONFIG_RPMSG_TTY is not set
    CONFIG_SERIAL_DEV_BUS=y
    CONFIG_SERIAL_DEV_CTRL_TTYPORT=y
    # CONFIG_TTY_PRINTK is not set
    CONFIG_VIRTIO_CONSOLE=y
    # CONFIG_IPMI_HANDLER is not set
    # CONFIG_ASPEED_KCS_IPMI_BMC is not set
    # CONFIG_NPCM7XX_KCS_IPMI_BMC is not set
    # CONFIG_ASPEED_BT_IPMI_BMC is not set
    # CONFIG_IPMB_DEVICE_INTERFACE is not set
    CONFIG_HW_RANDOM=y
    # CONFIG_HW_RANDOM_TIMERIOMEM is not set
    CONFIG_HW_RANDOM_ATMEL=y
    # CONFIG_HW_RANDOM_BA431 is not set
    CONFIG_HW_RANDOM_BCM2835=y
    CONFIG_HW_RANDOM_IPROC_RNG200=y
    CONFIG_HW_RANDOM_IXP4XX=y
    CONFIG_HW_RANDOM_OMAP=y
    CONFIG_HW_RANDOM_OMAP3_ROM=y
    # CONFIG_HW_RANDOM_VIRTIO is not set
    CONFIG_HW_RANDOM_IMX_RNGC=y
    CONFIG_HW_RANDOM_NOMADIK=y
    CONFIG_HW_RANDOM_STM32=y
    CONFIG_HW_RANDOM_MESON=y
    CONFIG_HW_RANDOM_MTK=y
    CONFIG_HW_RANDOM_EXYNOS=y
    CONFIG_HW_RANDOM_NPCM=y
    CONFIG_HW_RANDOM_KEYSTONE=y
    # CONFIG_HW_RANDOM_CCTRNG is not set
    # CONFIG_HW_RANDOM_XIPHERA is not set
    CONFIG_HW_RANDOM_ARM_SMCCC_TRNG=y
    # CONFIG_APPLICOM is not set
    CONFIG_DEVMEM=y
    CONFIG_DEVPORT=y
    CONFIG_TCG_TPM=m
    CONFIG_HW_RANDOM_TPM=y
    # CONFIG_TCG_TIS is not set
    # CONFIG_TCG_TIS_SPI is not set
    # CONFIG_TCG_TIS_I2C is not set
    # CONFIG_TCG_TIS_SYNQUACER is not set
    # CONFIG_TCG_TIS_I2C_CR50 is not set
    # CONFIG_TCG_TIS_I2C_ATMEL is not set
    CONFIG_TCG_TIS_I2C_INFINEON=m
    # CONFIG_TCG_TIS_I2C_NUVOTON is not set
    # CONFIG_TCG_ATMEL is not set
    # CONFIG_TCG_VTPM_PROXY is not set
    # CONFIG_TCG_TIS_ST33ZP24_I2C is not set
    # CONFIG_TCG_TIS_ST33ZP24_SPI is not set
    # CONFIG_XILLYBUS is not set
    # CONFIG_XILLYUSB is not set
    CONFIG_RANDOM_TRUST_CPU=y
    CONFIG_RANDOM_TRUST_BOOTLOADER=y
    # end of Character devices
    # I2C support
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    CONFIG_I2C_MUX=y
    # Multiplexer I2C Chip support
    CONFIG_I2C_ARB_GPIO_CHALLENGE=m
    CONFIG_I2C_MUX_GPIO=y
    # CONFIG_I2C_MUX_GPMUX is not set
    # CONFIG_I2C_MUX_LTC4306 is not set
    # CONFIG_I2C_MUX_PCA9541 is not set
    CONFIG_I2C_MUX_PCA954x=y
    CONFIG_I2C_MUX_PINCTRL=y
    # CONFIG_I2C_MUX_REG is not set
    CONFIG_I2C_DEMUX_PINCTRL=y
    # CONFIG_I2C_MUX_MLXCPLD is not set
    # end of Multiplexer I2C Chip support
    # CONFIG_I2C_ATR is not set
    CONFIG_I2C_HELPER_AUTO=y
    CONFIG_I2C_ALGOBIT=y
    # I2C Hardware Bus support
    # PC SMBus host controller drivers
    # CONFIG_I2C_ALI1535 is not set
    # CONFIG_I2C_ALI1563 is not set
    # CONFIG_I2C_ALI15X3 is not set
    # CONFIG_I2C_AMD756 is not set
    # CONFIG_I2C_AMD8111 is not set
    # CONFIG_I2C_HIX5HD2 is not set
    # CONFIG_I2C_I801 is not set
    # CONFIG_I2C_ISCH is not set
    # CONFIG_I2C_PIIX4 is not set
    # CONFIG_I2C_NFORCE2 is not set
    # CONFIG_I2C_NVIDIA_GPU is not set
    # CONFIG_I2C_SIS5595 is not set
    # CONFIG_I2C_SIS630 is not set
    # CONFIG_I2C_SIS96X is not set
    # CONFIG_I2C_VIA is not set
    # CONFIG_I2C_VIAPRO is not set
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_ALTERA is not set
    # CONFIG_I2C_ASPEED is not set
    # CONFIG_I2C_AT91 is not set
    # CONFIG_I2C_AXXIA is not set
    # CONFIG_I2C_BCM2835 is not set
    # CONFIG_I2C_BCM_IPROC is not set
    # CONFIG_I2C_BCM_KONA is not set
    CONFIG_I2C_BRCMSTB=y
    # CONFIG_I2C_CADENCE is not set
    # CONFIG_I2C_CBUS_GPIO is not set
    # CONFIG_I2C_DAVINCI is not set
    CONFIG_I2C_DESIGNWARE_CORE=y
    # CONFIG_I2C_DESIGNWARE_SLAVE is not set
    CONFIG_I2C_DESIGNWARE_PLATFORM=y
    # CONFIG_I2C_DESIGNWARE_PCI is not set
    # CONFIG_I2C_DIGICOLOR is not set
    # CONFIG_I2C_EG20T is not set
    CONFIG_I2C_EMEV2=m
    # CONFIG_I2C_EXYNOS5 is not set
    CONFIG_I2C_GPIO=m
    # CONFIG_I2C_GPIO_FAULT_INJECTOR is not set
    # CONFIG_I2C_HIGHLANDER is not set
    # CONFIG_I2C_HISI is not set
    # CONFIG_I2C_IMG is not set
    # CONFIG_I2C_IMX is not set
    # CONFIG_I2C_IMX_LPI2C is not set
    # CONFIG_I2C_IOP3XX is not set
    # CONFIG_I2C_JZ4780 is not set
    # CONFIG_I2C_LPC2K is not set
    # CONFIG_I2C_MESON is not set
    # CONFIG_I2C_MICROCHIP_CORE is not set
    # CONFIG_I2C_MT65XX is not set
    # CONFIG_I2C_MT7621 is not set
    # CONFIG_I2C_MV64XXX is not set
    # CONFIG_I2C_MXS is not set
    CONFIG_I2C_NOMADIK=y
    # CONFIG_I2C_NPCM is not set
    # CONFIG_I2C_OCORES is not set
    CONFIG_I2C_OMAP=y
    # CONFIG_I2C_OWL is not set
    # CONFIG_I2C_APPLE is not set
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_PNX is not set
    # CONFIG_I2C_PXA is not set
    # CONFIG_I2C_QCOM_CCI is not set
    # CONFIG_I2C_QUP is not set
    # CONFIG_I2C_RIIC is not set
    CONFIG_I2C_RK3X=y
    # CONFIG_I2C_RZV2M is not set
    # CONFIG_I2C_S3C2410 is not set
    # CONFIG_I2C_SH_MOBILE is not set
    # CONFIG_I2C_SIMTEC is not set
    # CONFIG_I2C_SPRD is not set
    # CONFIG_I2C_ST is not set
    # CONFIG_I2C_STM32F4 is not set
    # CONFIG_I2C_STM32F7 is not set
    # CONFIG_I2C_SUN6I_P2WI is not set
    # CONFIG_I2C_SYNQUACER is not set
    # CONFIG_I2C_TEGRA is not set
    # CONFIG_I2C_TEGRA_BPMP is not set
    # CONFIG_I2C_UNIPHIER is not set
    # CONFIG_I2C_UNIPHIER_F is not set
    # CONFIG_I2C_VERSATILE is not set
    # CONFIG_I2C_WMT is not set
    CONFIG_I2C_XILINX=y
    # CONFIG_I2C_XLP9XX is not set
    # CONFIG_I2C_RCAR is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_DIOLAN_U2C is not set
    # CONFIG_I2C_CP2615 is not set
    # CONFIG_I2C_PCI1XXXX is not set
    # CONFIG_I2C_ROBOTFUZZ_OSIF is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_MLXCPLD is not set
    # CONFIG_I2C_FSI is not set
    # CONFIG_I2C_VIRTIO is not set
    # end of I2C Hardware Bus support
    # CONFIG_I2C_STUB is not set
    CONFIG_I2C_SLAVE=y
    CONFIG_I2C_SLAVE_EEPROM=y
    # CONFIG_I2C_SLAVE_TESTUNIT is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    # end of I2C support
    # CONFIG_I3C is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    CONFIG_SPI_MEM=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_ALTERA is not set
    # CONFIG_SPI_ALTERA_CORE is not set
    # CONFIG_SPI_AR934X is not set
    # CONFIG_SPI_ATH79 is not set
    # CONFIG_SPI_ARMADA_3700 is not set
    # CONFIG_SPI_ASPEED_SMC is not set
    # CONFIG_SPI_ATMEL is not set
    # CONFIG_SPI_ATMEL_QUADSPI is not set
    # CONFIG_SPI_AXI_SPI_ENGINE is not set
    # CONFIG_SPI_BCM2835 is not set
    # CONFIG_SPI_BCM2835AUX is not set
    # CONFIG_SPI_BCM63XX is not set
    # CONFIG_SPI_BCM63XX_HSSPI is not set
    # CONFIG_SPI_BCM_QSPI is not set
    CONFIG_SPI_BITBANG=y
    CONFIG_SPI_CADENCE=y
    # CONFIG_SPI_CADENCE_QUADSPI is not set
    # CONFIG_SPI_CADENCE_XSPI is not set
    # CONFIG_SPI_CLPS711X is not set
    CONFIG_SPI_DAVINCI=y
    # CONFIG_SPI_DESIGNWARE is not set
    # CONFIG_SPI_EP93XX is not set
    # CONFIG_SPI_FSI is not set
    # CONFIG_SPI_FSL_LPSPI is not set
    # CONFIG_SPI_FSL_QUADSPI is not set
    # CONFIG_SPI_GXP is not set
    # CONFIG_SPI_HISI_KUNPENG is not set
    # CONFIG_SPI_HISI_SFC_V3XX is not set
    # CONFIG_SPI_NXP_FLEXSPI is not set
    CONFIG_SPI_GPIO=m
    # CONFIG_SPI_IMG_SPFI is not set
    # CONFIG_SPI_IMX is not set
    # CONFIG_SPI_INGENIC is not set
    # CONFIG_SPI_INTEL_PCI is not set
    # CONFIG_SPI_INTEL_PLATFORM is not set
    # CONFIG_SPI_JCORE is not set
    # CONFIG_SPI_LP8841_RTC is not set
    # CONFIG_SPI_FSL_SPI is not set
    # CONFIG_SPI_FSL_DSPI is not set
    # CONFIG_SPI_MESON_SPICC is not set
    # CONFIG_SPI_MESON_SPIFC is not set
    # CONFIG_SPI_MICROCHIP_CORE is not set
    # CONFIG_SPI_MICROCHIP_CORE_QSPI is not set
    # CONFIG_SPI_MT65XX is not set
    # CONFIG_SPI_MT7621 is not set
    # CONFIG_SPI_MTK_NOR is not set
    # CONFIG_SPI_NPCM_FIU is not set
    # CONFIG_SPI_NPCM_PSPI is not set
    # CONFIG_SPI_LANTIQ_SSC is not set
    # CONFIG_SPI_OC_TINY is not set
    # CONFIG_SPI_OMAP_UWIRE is not set
    CONFIG_SPI_OMAP24XX=y
    # CONFIG_SPI_TI_QSPI is not set
    # CONFIG_SPI_OMAP_100K is not set
    # CONFIG_SPI_ORION is not set
    # CONFIG_SPI_PIC32 is not set
    # CONFIG_SPI_PIC32_SQI is not set
    CONFIG_SPI_PL022=y
    # CONFIG_SPI_PXA2XX is not set
    CONFIG_SPI_ROCKCHIP=m
    # CONFIG_SPI_ROCKCHIP_SFC is not set
    # CONFIG_SPI_RSPI is not set
    # CONFIG_SPI_QUP is not set
    # CONFIG_SPI_S3C64XX is not set
    # CONFIG_SPI_SC18IS602 is not set
    # CONFIG_SPI_SH_MSIOF is not set
    # CONFIG_SPI_SH is not set
    # CONFIG_SPI_SH_HSPI is not set
    # CONFIG_SPI_SIFIVE is not set
    # CONFIG_SPI_SPRD is not set
    # CONFIG_SPI_SPRD_ADI is not set
    # CONFIG_SPI_STM32 is not set
    # CONFIG_SPI_STM32_QSPI is not set
    # CONFIG_SPI_ST_SSC4 is not set
    # CONFIG_SPI_SUN4I is not set
    # CONFIG_SPI_SUN6I is not set
    # CONFIG_SPI_SUNPLUS_SP7021 is not set
    # CONFIG_SPI_SYNQUACER is not set
    # CONFIG_SPI_MXIC is not set
    # CONFIG_SPI_TEGRA210_QUAD is not set
    # CONFIG_SPI_TEGRA114 is not set
    # CONFIG_SPI_TEGRA20_SFLASH is not set
    # CONFIG_SPI_TEGRA20_SLINK is not set
    # CONFIG_SPI_TOPCLIFF_PCH is not set
    # CONFIG_SPI_UNIPHIER is not set
    # CONFIG_SPI_XCOMM is not set
    CONFIG_SPI_XILINX=y
    # CONFIG_SPI_XLP is not set
    # CONFIG_SPI_XTENSA_XTFPGA is not set
    # CONFIG_SPI_ZYNQ_QSPI is not set
    # CONFIG_SPI_ZYNQMP_GQSPI is not set
    # CONFIG_SPI_AMD is not set
    # SPI Multiplexer support
    # CONFIG_SPI_MUX is not set
    # SPI Protocol Masters
    CONFIG_SPI_SPIDEV=y
    # CONFIG_SPI_LOOPBACK_TEST is not set
    # CONFIG_SPI_TLE62X0 is not set
    # CONFIG_SPI_SLAVE is not set
    CONFIG_SPI_DYNAMIC=y
    CONFIG_SPMI=y
    # CONFIG_SPMI_HISI3670 is not set
    # CONFIG_SPMI_MSM_PMIC_ARB is not set
    # CONFIG_SPMI_MTK_PMIF is not set
    # CONFIG_HSI is not set
    CONFIG_PPS=y
    # CONFIG_PPS_DEBUG is not set
    # PPS clients support
    # CONFIG_PPS_CLIENT_KTIMER is not set
    # CONFIG_PPS_CLIENT_LDISC is not set
    # CONFIG_PPS_CLIENT_GPIO is not set
    # PPS generators support
    # PTP clock support
    CONFIG_PTP_1588_CLOCK=y
    CONFIG_PTP_1588_CLOCK_OPTIONAL=y
    CONFIG_PTP_1588_CLOCK_DTE=y
    CONFIG_PTP_1588_CLOCK_QORIQ=y
    # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
    # CONFIG_PTP_1588_CLOCK_PCH is not set
    CONFIG_PTP_1588_CLOCK_KVM=y
    # CONFIG_PTP_1588_CLOCK_IDT82P33 is not set
    # CONFIG_PTP_1588_CLOCK_IDTCM is not set
    # CONFIG_PTP_1588_CLOCK_OCP is not set
    # end of PTP clock support
    CONFIG_PINCTRL=y
    CONFIG_GENERIC_PINCTRL_GROUPS=y
    CONFIG_PINMUX=y
    CONFIG_GENERIC_PINMUX_FUNCTIONS=y
    CONFIG_PINCONF=y
    CONFIG_GENERIC_PINCONF=y
    # CONFIG_DEBUG_PINCTRL is not set
    # CONFIG_PINCTRL_AMD is not set
    # CONFIG_PINCTRL_AT91PIO4 is not set
    # CONFIG_PINCTRL_BM1880 is not set
    # CONFIG_PINCTRL_CY8C95X0 is not set
    # CONFIG_PINCTRL_DA850_PUPD is not set
    # CONFIG_PINCTRL_EQUILIBRIUM is not set
    # CONFIG_PINCTRL_INGENIC is not set
    # CONFIG_PINCTRL_LPC18XX is not set
    # CONFIG_PINCTRL_MCP23S08 is not set
    CONFIG_PINCTRL_MICROCHIP_SGPIO=y
    CONFIG_PINCTRL_OCELOT=y
    CONFIG_PINCTRL_PALMAS=y
    # CONFIG_PINCTRL_PISTACHIO is not set
    # CONFIG_PINCTRL_ROCKCHIP is not set
    CONFIG_PINCTRL_SINGLE=y
    CONFIG_PINCTRL_STMFX=y
    # CONFIG_PINCTRL_SX150X is not set
    # CONFIG_PINCTRL_OWL is not set
    # CONFIG_PINCTRL_ASPEED_G4 is not set
    # CONFIG_PINCTRL_ASPEED_G5 is not set
    # CONFIG_PINCTRL_ASPEED_G6 is not set
    # CONFIG_PINCTRL_BCM281XX is not set
    # CONFIG_PINCTRL_BCM2835 is not set
    # CONFIG_PINCTRL_BCM4908 is not set
    # CONFIG_PINCTRL_BCM6318 is not set
    # CONFIG_PINCTRL_BCM6328 is not set
    # CONFIG_PINCTRL_BCM6358 is not set
    # CONFIG_PINCTRL_BCM6362 is not set
    # CONFIG_PINCTRL_BCM6368 is not set
    # CONFIG_PINCTRL_BCM63268 is not set
    # CONFIG_PINCTRL_IPROC_GPIO is not set
    # CONFIG_PINCTRL_CYGNUS_MUX is not set
    # CONFIG_PINCTRL_NS is not set
    # CONFIG_PINCTRL_NSP_GPIO is not set
    # CONFIG_PINCTRL_NS2_MUX is not set
    # CONFIG_PINCTRL_NSP_MUX is not set
    # CONFIG_PINCTRL_AS370 is not set
    # CONFIG_PINCTRL_BERLIN_BG4CT is not set
    # Intel pinctrl drivers
    # end of Intel pinctrl drivers
    # MediaTek pinctrl drivers
    # CONFIG_EINT_MTK is not set
    # CONFIG_PINCTRL_MT2701 is not set
    # CONFIG_PINCTRL_MT7623 is not set
    # CONFIG_PINCTRL_MT7629 is not set
    # CONFIG_PINCTRL_MT8135 is not set
    # CONFIG_PINCTRL_MT8127 is not set
    # CONFIG_PINCTRL_MT2712 is not set
    # CONFIG_PINCTRL_MT6765 is not set
    # CONFIG_PINCTRL_MT6779 is not set
    # CONFIG_PINCTRL_MT6795 is not set
    # CONFIG_PINCTRL_MT6797 is not set
    # CONFIG_PINCTRL_MT7622 is not set
    # CONFIG_PINCTRL_MT7986 is not set
    # CONFIG_PINCTRL_MT8167 is not set
    # CONFIG_PINCTRL_MT8173 is not set
    # CONFIG_PINCTRL_MT8183 is not set
    # CONFIG_PINCTRL_MT8186 is not set
    # CONFIG_PINCTRL_MT8188 is not set
    # CONFIG_PINCTRL_MT8192 is not set
    # CONFIG_PINCTRL_MT8195 is not set
    # CONFIG_PINCTRL_MT8365 is not set
    # CONFIG_PINCTRL_MT8516 is not set
    # CONFIG_PINCTRL_MT6397 is not set
    # end of MediaTek pinctrl drivers
    CONFIG_PINCTRL_MESON=y
    CONFIG_PINCTRL_MESON8=y
    CONFIG_PINCTRL_MESON8B=y
    CONFIG_PINCTRL_MESON8_PMX=y
    # CONFIG_PINCTRL_WPCM450 is not set
    # CONFIG_PINCTRL_NPCM7XX is not set
    # CONFIG_PINCTRL_PXA25X is not set
    # CONFIG_PINCTRL_PXA27X is not set
    # CONFIG_PINCTRL_MSM is not set
    # CONFIG_PINCTRL_QCOM_SPMI_PMIC is not set
    # CONFIG_PINCTRL_QCOM_SSBI_PMIC is not set
    # CONFIG_PINCTRL_LPASS_LPI is not set
    # Renesas pinctrl drivers
    # CONFIG_PINCTRL_RENESAS is not set
    # CONFIG_PINCTRL_PFC_EMEV2 is not set
    # CONFIG_PINCTRL_PFC_R8A77995 is not set
    # CONFIG_PINCTRL_PFC_R8A7794 is not set
    # CONFIG_PINCTRL_PFC_R8A77990 is not set
    # CONFIG_PINCTRL_PFC_R8A7779 is not set
    # CONFIG_PINCTRL_PFC_R8A7790 is not set
    # CONFIG_PINCTRL_PFC_R8A77950 is not set
    # CONFIG_PINCTRL_PFC_R8A77951 is not set
    # CONFIG_PINCTRL_PFC_R8A7778 is not set
    # CONFIG_PINCTRL_PFC_R8A7793 is not set
    # CONFIG_PINCTRL_PFC_R8A7791 is not set
    # CONFIG_PINCTRL_PFC_R8A77965 is not set
    # CONFIG_PINCTRL_PFC_R8A77960 is not set
    # CONFIG_PINCTRL_PFC_R8A77961 is not set
    # CONFIG_PINCTRL_PFC_R8A779F0 is not set
    # CONFIG_PINCTRL_PFC_R8A7792 is not set
    # CONFIG_PINCTRL_PFC_R8A77980 is not set
    # CONFIG_PINCTRL_PFC_R8A77970 is not set
    # CONFIG_PINCTRL_PFC_R8A779A0 is not set
    # CONFIG_PINCTRL_PFC_R8A779G0 is not set
    # CONFIG_PINCTRL_PFC_R8A7740 is not set
    # CONFIG_PINCTRL_PFC_R8A73A4 is not set
    # CONFIG_PINCTRL_RZA1 is not set
    # CONFIG_PINCTRL_RZA2 is not set
    # CONFIG_PINCTRL_RZG2L is not set
    # CONFIG_PINCTRL_PFC_R8A77470 is not set
    # CONFIG_PINCTRL_PFC_R8A7745 is not set
    # CONFIG_PINCTRL_PFC_R8A7742 is not set
    # CONFIG_PINCTRL_PFC_R8A7743 is not set
    # CONFIG_PINCTRL_PFC_R8A7744 is not set
    # CONFIG_PINCTRL_PFC_R8A774C0 is not set
    # CONFIG_PINCTRL_PFC_R8A774E1 is not set
    # CONFIG_PINCTRL_PFC_R8A774A1 is not set
    # CONFIG_PINCTRL_PFC_R8A774B1 is not set
    # CONFIG_PINCTRL_RZN1 is not set
    # CONFIG_PINCTRL_RZV2M is not set
    # CONFIG_PINCTRL_PFC_SH7203 is not set
    # CONFIG_PINCTRL_PFC_SH7264 is not set
    # CONFIG_PINCTRL_PFC_SH7269 is not set
    # CONFIG_PINCTRL_PFC_SH7720 is not set
    # CONFIG_PINCTRL_PFC_SH7722 is not set
    # CONFIG_PINCTRL_PFC_SH7734 is not set
    # CONFIG_PINCTRL_PFC_SH7757 is not set
    # CONFIG_PINCTRL_PFC_SH7785 is not set
    # CONFIG_PINCTRL_PFC_SH7786 is not set
    # CONFIG_PINCTRL_PFC_SH73A0 is not set
    # CONFIG_PINCTRL_PFC_SH7723 is not set
    # CONFIG_PINCTRL_PFC_SH7724 is not set
    # CONFIG_PINCTRL_PFC_SHX3 is not set
    # end of Renesas pinctrl drivers
    # CONFIG_PINCTRL_EXYNOS is not set
    # CONFIG_PINCTRL_S3C24XX is not set
    # CONFIG_PINCTRL_S3C64XX is not set
    # CONFIG_PINCTRL_SPRD_SC9860 is not set
    # CONFIG_PINCTRL_STARFIVE_JH7100 is not set
    # CONFIG_PINCTRL_STM32F429 is not set
    # CONFIG_PINCTRL_STM32F469 is not set
    # CONFIG_PINCTRL_STM32F746 is not set
    # CONFIG_PINCTRL_STM32F769 is not set
    # CONFIG_PINCTRL_STM32H743 is not set
    # CONFIG_PINCTRL_STM32MP135 is not set
    # CONFIG_PINCTRL_STM32MP157 is not set
    CONFIG_PINCTRL_SPPCTL=y
    CONFIG_PINCTRL_TI_IODELAY=y
    CONFIG_PINCTRL_UNIPHIER=y
    CONFIG_PINCTRL_UNIPHIER_LD4=y
    CONFIG_PINCTRL_UNIPHIER_PRO4=y
    CONFIG_PINCTRL_UNIPHIER_SLD8=y
    CONFIG_PINCTRL_UNIPHIER_PRO5=y
    CONFIG_PINCTRL_UNIPHIER_PXS2=y
    CONFIG_PINCTRL_UNIPHIER_LD6B=y
    # CONFIG_PINCTRL_UNIPHIER_LD11 is not set
    # CONFIG_PINCTRL_UNIPHIER_LD20 is not set
    # CONFIG_PINCTRL_UNIPHIER_PXS3 is not set
    # CONFIG_PINCTRL_UNIPHIER_NX1 is not set
    # CONFIG_PINCTRL_TMPV7700 is not set
    CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
    CONFIG_GPIOLIB=y
    CONFIG_GPIOLIB_FASTPATH_LIMIT=512
    CONFIG_OF_GPIO=y
    CONFIG_GPIOLIB_IRQCHIP=y
    CONFIG_DEBUG_GPIO=y
    CONFIG_GPIO_SYSFS=y
    CONFIG_GPIO_CDEV=y
    CONFIG_GPIO_CDEV_V1=y
    CONFIG_GPIO_GENERIC=y
    # Memory mapped GPIO drivers
    # CONFIG_GPIO_74XX_MMIO is not set
    # CONFIG_GPIO_ALTERA is not set
    # CONFIG_GPIO_ASPEED is not set
    # CONFIG_GPIO_ASPEED_SGPIO is not set
    # CONFIG_GPIO_ATH79 is not set
    # CONFIG_GPIO_RASPBERRYPI_EXP is not set
    # CONFIG_GPIO_BCM_KONA is not set
    # CONFIG_GPIO_BCM_XGS_IPROC is not set
    # CONFIG_GPIO_BRCMSTB is not set
    # CONFIG_GPIO_CADENCE is not set
    # CONFIG_GPIO_CLPS711X is not set
    CONFIG_GPIO_DAVINCI=y
    # CONFIG_GPIO_DWAPB is not set
    # CONFIG_GPIO_EIC_SPRD is not set
    # CONFIG_GPIO_EM is not set
    # CONFIG_GPIO_EXAR is not set
    # CONFIG_GPIO_FTGPIO010 is not set
    CONFIG_GPIO_GENERIC_PLATFORM=y
    # CONFIG_GPIO_GRGPIO is not set
    # CONFIG_GPIO_HISI is not set
    # CONFIG_GPIO_HLWD is not set
    # CONFIG_GPIO_IOP is not set
    # CONFIG_GPIO_LOGICVC is not set
    # CONFIG_GPIO_LPC18XX is not set
    # CONFIG_GPIO_LPC32XX is not set
    # CONFIG_GPIO_MB86S7X is not set
    # CONFIG_GPIO_MPC8XXX is not set
    # CONFIG_GPIO_MT7621 is not set
    # CONFIG_GPIO_MXC is not set
    # CONFIG_GPIO_MXS is not set
    CONFIG_GPIO_OMAP=y
    CONFIG_GPIO_PL061=y
    # CONFIG_GPIO_PMIC_EIC_SPRD is not set
    # CONFIG_GPIO_PXA is not set
    # CONFIG_GPIO_RCAR is not set
    # CONFIG_GPIO_RDA is not set
    # CONFIG_GPIO_ROCKCHIP is not set
    # CONFIG_GPIO_SAMA5D2_PIOBU is not set
    # CONFIG_GPIO_SIFIVE is not set
    # CONFIG_GPIO_SNPS_CREG is not set
    # CONFIG_GPIO_SPRD is not set
    # CONFIG_GPIO_STP_XWAY is not set
    CONFIG_GPIO_SYSCON=y
    # CONFIG_GPIO_TEGRA is not set
    # CONFIG_GPIO_TEGRA186 is not set
    # CONFIG_GPIO_TS4800 is not set
    # CONFIG_GPIO_UNIPHIER is not set
    # CONFIG_GPIO_VISCONTI is not set
    # CONFIG_GPIO_VX855 is not set
    # CONFIG_GPIO_XGENE_SB is not set
    # CONFIG_GPIO_XILINX is not set
    # CONFIG_GPIO_XLP is not set
    # CONFIG_GPIO_ZEVIO is not set
    # CONFIG_GPIO_AMD_FCH is not set
    # CONFIG_GPIO_IDT3243X is not set
    # end of Memory mapped GPIO drivers
    # I2C GPIO expanders
    # CONFIG_GPIO_ADNP is not set
    # CONFIG_GPIO_GW_PLD is not set
    # CONFIG_GPIO_MAX7300 is not set
    # CONFIG_GPIO_MAX732X is not set
    CONFIG_GPIO_PCA953X=y
    CONFIG_GPIO_PCA953X_IRQ=y
    # CONFIG_GPIO_PCA9570 is not set
    CONFIG_GPIO_PCF857X=y
    # CONFIG_GPIO_TPIC2810 is not set
    # CONFIG_GPIO_TS4900 is not set
    # end of I2C GPIO expanders
    # MFD GPIO expanders
    # CONFIG_HTC_EGPIO is not set
    CONFIG_GPIO_PALMAS=y
    # CONFIG_GPIO_SL28CPLD is not set
    # CONFIG_GPIO_TPS65218 is not set
    # CONFIG_GPIO_TPS6586X is not set
    CONFIG_GPIO_TPS65910=y
    # CONFIG_GPIO_TQMX86 is not set
    CONFIG_GPIO_TWL4030=y
    # CONFIG_GPIO_WM8994 is not set
    # end of MFD GPIO expanders
    # PCI GPIO expanders
    # CONFIG_GPIO_AMD8111 is not set
    # CONFIG_GPIO_BT8XX is not set
    # CONFIG_GPIO_ML_IOH is not set
    # CONFIG_GPIO_PCH is not set
    # CONFIG_GPIO_PCI_IDIO_16 is not set
    # CONFIG_GPIO_PCIE_IDIO_24 is not set
    # CONFIG_GPIO_RDC321X is not set
    # end of PCI GPIO expanders
    # SPI GPIO expanders
    # CONFIG_GPIO_74X164 is not set
    # CONFIG_GPIO_MAX3191X is not set
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MC33880 is not set
    # CONFIG_GPIO_PISOSR is not set
    # CONFIG_GPIO_XRA1403 is not set
    # end of SPI GPIO expanders
    # USB GPIO expanders
    # end of USB GPIO expanders
    # Virtual GPIO drivers
    # CONFIG_GPIO_AGGREGATOR is not set
    # CONFIG_GPIO_MOCKUP is not set
    # CONFIG_GPIO_VIRTIO is not set
    # CONFIG_GPIO_SIM is not set
    # end of Virtual GPIO drivers
    # CONFIG_W1 is not set
    CONFIG_POWER_RESET=y
    CONFIG_POWER_RESET_BRCMKONA=y
    CONFIG_POWER_RESET_BRCMSTB=y
    # CONFIG_POWER_RESET_GEMINI_POWEROFF is not set
    CONFIG_POWER_RESET_GPIO=y
    CONFIG_POWER_RESET_GPIO_RESTART=y
    # CONFIG_POWER_RESET_LINKSTATION is not set
    # CONFIG_POWER_RESET_OCELOT_RESET is not set
    # CONFIG_POWER_RESET_PIIX4_POWEROFF is not set
    # CONFIG_POWER_RESET_LTC2952 is not set
    # CONFIG_POWER_RESET_REGULATOR is not set
    # CONFIG_POWER_RESET_RESTART is not set
    # CONFIG_POWER_RESET_VERSATILE is not set
    CONFIG_POWER_RESET_VEXPRESS=y
    # CONFIG_POWER_RESET_KEYSTONE is not set
    CONFIG_POWER_RESET_SYSCON=y
    CONFIG_POWER_RESET_SYSCON_POWEROFF=y
    # CONFIG_POWER_RESET_RMOBILE is not set
    # CONFIG_SYSCON_REBOOT_MODE is not set
    # CONFIG_POWER_RESET_SC27XX is not set
    # CONFIG_NVMEM_REBOOT_MODE is not set
    CONFIG_POWER_SUPPLY=y
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    CONFIG_POWER_SUPPLY_HWMON=y
    # CONFIG_PDA_POWER is not set
    # CONFIG_GENERIC_ADC_BATTERY is not set
    # CONFIG_IP5XXX_POWER is not set
    # CONFIG_TEST_POWER is not set
    # CONFIG_CHARGER_ADP5061 is not set
    CONFIG_BATTERY_ACT8945A=y
    CONFIG_BATTERY_CPCAP=m
    # CONFIG_BATTERY_CW2015 is not set
    # CONFIG_BATTERY_DS2780 is not set
    # CONFIG_BATTERY_DS2781 is not set
    # CONFIG_BATTERY_DS2782 is not set
    # CONFIG_BATTERY_LEGO_EV3 is not set
    # CONFIG_BATTERY_SAMSUNG_SDI is not set
    CONFIG_BATTERY_SBS=y
    # CONFIG_CHARGER_SBS is not set
    # CONFIG_MANAGER_SBS is not set
    CONFIG_BATTERY_BQ27XXX=m
    CONFIG_BATTERY_BQ27XXX_I2C=m
    # CONFIG_BATTERY_BQ27XXX_DT_UPDATES_NVM is not set
    CONFIG_BATTERY_MAX17040=m
    CONFIG_BATTERY_MAX17042=m
    CONFIG_CHARGER_CPCAP=m
    # CONFIG_CHARGER_ISP1704 is not set
    # CONFIG_CHARGER_MAX8903 is not set
    # CONFIG_CHARGER_TWL4030 is not set
    # CONFIG_CHARGER_LP8727 is not set
    CONFIG_CHARGER_GPIO=m
    # CONFIG_CHARGER_MANAGER is not set
    # CONFIG_CHARGER_LT3651 is not set
    # CONFIG_CHARGER_LTC4162L is not set
    # CONFIG_CHARGER_DETECTOR_MAX14656 is not set
    # CONFIG_CHARGER_MAX77976 is not set
    # CONFIG_CHARGER_QCOM_SMBB is not set
    # CONFIG_CHARGER_BQ2415X is not set
    # CONFIG_CHARGER_BQ24190 is not set
    # CONFIG_CHARGER_BQ24257 is not set
    # CONFIG_CHARGER_BQ24735 is not set
    # CONFIG_CHARGER_BQ2515X is not set
    # CONFIG_CHARGER_BQ25890 is not set
    # CONFIG_CHARGER_BQ25980 is not set
    # CONFIG_CHARGER_BQ256XX is not set
    CONFIG_CHARGER_SMB347=m
    CONFIG_CHARGER_TPS65090=y
    # CONFIG_CHARGER_TPS65217 is not set
    # CONFIG_BATTERY_GAUGE_LTC2941 is not set
    # CONFIG_BATTERY_GOLDFISH is not set
    # CONFIG_BATTERY_RT5033 is not set
    # CONFIG_CHARGER_RT9455 is not set
    # CONFIG_CHARGER_SC2731 is not set
    # CONFIG_FUEL_GAUGE_SC27XX is not set
    # CONFIG_CHARGER_UCS1002 is not set
    # CONFIG_CHARGER_BD99954 is not set
    # CONFIG_BATTERY_UG3105 is not set
    CONFIG_HWMON=y
    # CONFIG_HWMON_DEBUG_CHIP is not set
    # Native drivers
    # CONFIG_SENSORS_AD7314 is not set
    # CONFIG_SENSORS_AD7414 is not set
    # CONFIG_SENSORS_AD7418 is not set
    # CONFIG_SENSORS_ADM1025 is not set
    # CONFIG_SENSORS_ADM1026 is not set
    # CONFIG_SENSORS_ADM1029 is not set
    # CONFIG_SENSORS_ADM1031 is not set
    # CONFIG_SENSORS_ADM1177 is not set
    # CONFIG_SENSORS_ADM9240 is not set
    # CONFIG_SENSORS_ADT7310 is not set
    # CONFIG_SENSORS_ADT7410 is not set
    # CONFIG_SENSORS_ADT7411 is not set
    # CONFIG_SENSORS_ADT7462 is not set
    # CONFIG_SENSORS_ADT7470 is not set
    # CONFIG_SENSORS_ADT7475 is not set
    # CONFIG_SENSORS_AHT10 is not set
    # CONFIG_SENSORS_AQUACOMPUTER_D5NEXT is not set
    # CONFIG_SENSORS_AS370 is not set
    # CONFIG_SENSORS_ASC7621 is not set
    # CONFIG_SENSORS_AXI_FAN_CONTROL is not set
    CONFIG_SENSORS_ARM_SCMI=y
    # CONFIG_SENSORS_ASB100 is not set
    # CONFIG_SENSORS_ASPEED is not set
    # CONFIG_SENSORS_ATXP1 is not set
    # CONFIG_SENSORS_BT1_PVT is not set
    # CONFIG_SENSORS_CORSAIR_CPRO is not set
    # CONFIG_SENSORS_CORSAIR_PSU is not set
    # CONFIG_SENSORS_DRIVETEMP is not set
    # CONFIG_SENSORS_DS620 is not set
    # CONFIG_SENSORS_DS1621 is not set
    # CONFIG_SENSORS_I5K_AMB is not set
    # CONFIG_SENSORS_SPARX5 is not set
    # CONFIG_SENSORS_F71805F is not set
    # CONFIG_SENSORS_F71882FG is not set
    # CONFIG_SENSORS_F75375S is not set
    # CONFIG_SENSORS_FSCHMD is not set
    # CONFIG_SENSORS_FTSTEUTATES is not set
    # CONFIG_SENSORS_GL518SM is not set
    # CONFIG_SENSORS_GL520SM is not set
    # CONFIG_SENSORS_G760A is not set
    # CONFIG_SENSORS_G762 is not set
    # CONFIG_SENSORS_GPIO_FAN is not set
    # CONFIG_SENSORS_HIH6130 is not set
    CONFIG_SENSORS_IIO_HWMON=y
    # CONFIG_SENSORS_IT87 is not set
    # CONFIG_SENSORS_JC42 is not set
    # CONFIG_SENSORS_POWR1220 is not set
    # CONFIG_SENSORS_LAN966X is not set
    # CONFIG_SENSORS_LINEAGE is not set
    # CONFIG_SENSORS_LTC2945 is not set
    # CONFIG_SENSORS_LTC2947_I2C is not set
    # CONFIG_SENSORS_LTC2947_SPI is not set
    # CONFIG_SENSORS_LTC2990 is not set
    # CONFIG_SENSORS_LTC2992 is not set
    # CONFIG_SENSORS_LTC4151 is not set
    # CONFIG_SENSORS_LTC4215 is not set
    # CONFIG_SENSORS_LTC4222 is not set
    # CONFIG_SENSORS_LTC4245 is not set
    # CONFIG_SENSORS_LTC4260 is not set
    # CONFIG_SENSORS_LTC4261 is not set
    # CONFIG_SENSORS_MAX1111 is not set
    # CONFIG_SENSORS_MAX127 is not set
    # CONFIG_SENSORS_MAX16065 is not set
    # CONFIG_SENSORS_MAX1619 is not set
    # CONFIG_SENSORS_MAX1668 is not set
    # CONFIG_SENSORS_MAX197 is not set
    # CONFIG_SENSORS_MAX31722 is not set
    # CONFIG_SENSORS_MAX31730 is not set
    # CONFIG_SENSORS_MAX31760 is not set
    # CONFIG_SENSORS_MAX6620 is not set
    # CONFIG_SENSORS_MAX6621 is not set
    # CONFIG_SENSORS_MAX6639 is not set
    # CONFIG_SENSORS_MAX6650 is not set
    # CONFIG_SENSORS_MAX6697 is not set
    # CONFIG_SENSORS_MAX31790 is not set
    # CONFIG_SENSORS_MCP3021 is not set
    # CONFIG_SENSORS_TC654 is not set
    # CONFIG_SENSORS_TPS23861 is not set
    # CONFIG_SENSORS_MR75203 is not set
    # CONFIG_SENSORS_ADCXX is not set
    # CONFIG_SENSORS_LM63 is not set
    # CONFIG_SENSORS_LM70 is not set
    # CONFIG_SENSORS_LM73 is not set
    # CONFIG_SENSORS_LM75 is not set
    # CONFIG_SENSORS_LM77 is not set
    # CONFIG_SENSORS_LM78 is not set
    # CONFIG_SENSORS_LM80 is not set
    # CONFIG_SENSORS_LM83 is not set
    # CONFIG_SENSORS_LM85 is not set
    # CONFIG_SENSORS_LM87 is not set
    CONFIG_SENSORS_LM90=y
    # CONFIG_SENSORS_LM92 is not set
    # CONFIG_SENSORS_LM93 is not set
    # CONFIG_SENSORS_LM95234 is not set
    # CONFIG_SENSORS_LM95241 is not set
    CONFIG_SENSORS_LM95245=y
    # CONFIG_SENSORS_PC87360 is not set
    # CONFIG_SENSORS_PC87427 is not set
    CONFIG_SENSORS_NTC_THERMISTOR=m
    # CONFIG_SENSORS_NCT6683 is not set
    # CONFIG_SENSORS_NCT6775_I2C is not set
    # CONFIG_SENSORS_NCT7802 is not set
    # CONFIG_SENSORS_NCT7904 is not set
    # CONFIG_SENSORS_NPCM7XX is not set
    # CONFIG_SENSORS_NSA320 is not set
    # CONFIG_SENSORS_NZXT_KRAKEN2 is not set
    # CONFIG_SENSORS_NZXT_SMART2 is not set
    # CONFIG_SENSORS_OCC_P8_I2C is not set
    # CONFIG_SENSORS_OCC_P9_SBE is not set
    # CONFIG_SENSORS_PCF8591 is not set
    # CONFIG_PMBUS is not set
    # CONFIG_SENSORS_PWM_FAN is not set
    # CONFIG_SENSORS_RASPBERRYPI_HWMON is not set
    # CONFIG_SENSORS_SL28CPLD is not set
    # CONFIG_SENSORS_SBTSI is not set
    # CONFIG_SENSORS_SBRMI is not set
    # CONFIG_SENSORS_SHT15 is not set
    # CONFIG_SENSORS_SHT21 is not set
    # CONFIG_SENSORS_SHT3x is not set
    # CONFIG_SENSORS_SHT4x is not set
    # CONFIG_SENSORS_SHTC1 is not set
    # CONFIG_SENSORS_SIS5595 is not set
    # CONFIG_SENSORS_DME1737 is not set
    # CONFIG_SENSORS_EMC1403 is not set
    # CONFIG_SENSORS_EMC2103 is not set
    # CONFIG_SENSORS_EMC2305 is not set
    # CONFIG_SENSORS_EMC6W201 is not set
    # CONFIG_SENSORS_SMSC47M1 is not set
    # CONFIG_SENSORS_SMSC47M192 is not set
    # CONFIG_SENSORS_SMSC47B397 is not set
    # CONFIG_SENSORS_SCH5627 is not set
    # CONFIG_SENSORS_SCH5636 is not set
    # CONFIG_SENSORS_STTS751 is not set
    # CONFIG_SENSORS_SMM665 is not set
    # CONFIG_SENSORS_ADC128D818 is not set
    # CONFIG_SENSORS_ADS7828 is not set
    # CONFIG_SENSORS_ADS7871 is not set
    # CONFIG_SENSORS_AMC6821 is not set
    # CONFIG_SENSORS_INA209 is not set
    CONFIG_SENSORS_INA2XX=m
    # CONFIG_SENSORS_INA238 is not set
    # CONFIG_SENSORS_INA3221 is not set
    # CONFIG_SENSORS_TC74 is not set
    # CONFIG_SENSORS_THMC50 is not set
    # CONFIG_SENSORS_TMP102 is not set
    # CONFIG_SENSORS_TMP103 is not set
    # CONFIG_SENSORS_TMP108 is not set
    # CONFIG_SENSORS_TMP401 is not set
    # CONFIG_SENSORS_TMP421 is not set
    # CONFIG_SENSORS_TMP464 is not set
    # CONFIG_SENSORS_TMP513 is not set
    # CONFIG_SENSORS_VEXPRESS is not set
    # CONFIG_SENSORS_VIA686A is not set
    # CONFIG_SENSORS_VT1211 is not set
    # CONFIG_SENSORS_VT8231 is not set
    # CONFIG_SENSORS_W83773G is not set
    # CONFIG_SENSORS_W83781D is not set
    # CONFIG_SENSORS_W83791D is not set
    # CONFIG_SENSORS_W83792D is not set
    # CONFIG_SENSORS_W83793 is not set
    # CONFIG_SENSORS_W83795 is not set
    # CONFIG_SENSORS_W83L785TS is not set
    # CONFIG_SENSORS_W83L786NG is not set
    # CONFIG_SENSORS_W83627HF is not set
    # CONFIG_SENSORS_W83627EHF is not set
    CONFIG_THERMAL=y
    # CONFIG_THERMAL_NETLINK is not set
    # CONFIG_THERMAL_STATISTICS is not set
    CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
    CONFIG_THERMAL_HWMON=y
    CONFIG_THERMAL_OF=y
    # CONFIG_THERMAL_WRITABLE_TRIPS is not set
    CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
    # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
    # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
    # CONFIG_THERMAL_GOV_FAIR_SHARE is not set
    CONFIG_THERMAL_GOV_STEP_WISE=y
    # CONFIG_THERMAL_GOV_BANG_BANG is not set
    # CONFIG_THERMAL_GOV_USER_SPACE is not set
    CONFIG_CPU_THERMAL=y
    CONFIG_CPU_FREQ_THERMAL=y
    # CONFIG_DEVFREQ_THERMAL is not set
    # CONFIG_THERMAL_EMULATION is not set
    # CONFIG_THERMAL_MMIO is not set
    CONFIG_HISI_THERMAL=y
    # CONFIG_IMX_THERMAL is not set
    # CONFIG_IMX8MM_THERMAL is not set
    # CONFIG_K3_THERMAL is not set
    # CONFIG_QORIQ_THERMAL is not set
    # CONFIG_SPEAR_THERMAL is not set
    # CONFIG_SUN8I_THERMAL is not set
    # CONFIG_ROCKCHIP_THERMAL is not set
    # CONFIG_RCAR_THERMAL is not set
    # CONFIG_RCAR_GEN3_THERMAL is not set
    # CONFIG_RZG2L_THERMAL is not set
    # CONFIG_KIRKWOOD_THERMAL is not set
    # CONFIG_DOVE_THERMAL is not set
    # CONFIG_ARMADA_THERMAL is not set
    # CONFIG_DA9062_THERMAL is not set
    CONFIG_MTK_THERMAL=y
    # Intel thermal drivers
    # ACPI INT340X thermal drivers
    # end of ACPI INT340X thermal drivers
    # end of Intel thermal drivers
    # Broadcom thermal drivers
    # CONFIG_BCM2711_THERMAL is not set
    # CONFIG_BCM2835_THERMAL is not set
    # CONFIG_BRCMSTB_THERMAL is not set
    # CONFIG_BCM_NS_THERMAL is not set
    # CONFIG_BCM_SR_THERMAL is not set
    # end of Broadcom thermal drivers
    # Texas Instruments thermal drivers
    CONFIG_TI_SOC_THERMAL=y
    # CONFIG_TI_THERMAL is not set
    # CONFIG_OMAP3_THERMAL is not set
    # CONFIG_OMAP4_THERMAL is not set
    # CONFIG_OMAP5_THERMAL is not set
    # CONFIG_DRA752_THERMAL is not set
    # end of Texas Instruments thermal drivers
    # Samsung thermal drivers
    # CONFIG_EXYNOS_THERMAL is not set
    # end of Samsung thermal drivers
    # NVIDIA Tegra thermal drivers
    # CONFIG_TEGRA_SOCTHERM is not set
    # CONFIG_TEGRA_BPMP_THERMAL is not set
    # CONFIG_TEGRA30_TSENSOR is not set
    # end of NVIDIA Tegra thermal drivers
    CONFIG_GENERIC_ADC_THERMAL=m
    # Qualcomm thermal drivers
    # CONFIG_QCOM_SPMI_ADC_TM5 is not set
    # CONFIG_QCOM_SPMI_TEMP_ALARM is not set
    # end of Qualcomm thermal drivers
    # CONFIG_UNIPHIER_THERMAL is not set
    # CONFIG_SPRD_THERMAL is not set
    CONFIG_WATCHDOG=y
    CONFIG_WATCHDOG_CORE=y
    # CONFIG_WATCHDOG_NOWAYOUT is not set
    CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
    CONFIG_WATCHDOG_OPEN_TIMEOUT=0
    # CONFIG_WATCHDOG_SYSFS is not set
    # CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set
    # Watchdog Pretimeout Governors
    # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    # CONFIG_DA9052_WATCHDOG is not set
    # CONFIG_DA9055_WATCHDOG is not set
    # CONFIG_DA9063_WATCHDOG is not set
    # CONFIG_DA9062_WATCHDOG is not set
    # CONFIG_GPIO_WATCHDOG is not set
    # CONFIG_MENF21BMC_WATCHDOG is not set
    # CONFIG_XILINX_WATCHDOG is not set
    # CONFIG_ZIIRAVE_WATCHDOG is not set
    # CONFIG_SL28CPLD_WATCHDOG is not set
    CONFIG_ARM_SP805_WATCHDOG=y
    # CONFIG_ARMADA_37XX_WATCHDOG is not set
    # CONFIG_ASM9260_WATCHDOG is not set
    # CONFIG_AT91RM9200_WATCHDOG is not set
    # CONFIG_AT91SAM9X_WATCHDOG is not set
    # CONFIG_SAMA5D4_WATCHDOG is not set
    # CONFIG_CADENCE_WATCHDOG is not set
    # CONFIG_977_WATCHDOG is not set
    # CONFIG_FTWDT010_WATCHDOG is not set
    # CONFIG_S3C2410_WATCHDOG is not set
    # CONFIG_DW_WATCHDOG is not set
    # CONFIG_EP93XX_WATCHDOG is not set
    # CONFIG_OMAP_WATCHDOG is not set
    # CONFIG_PNX4008_WATCHDOG is not set
    # CONFIG_DAVINCI_WATCHDOG is not set
    # CONFIG_K3_RTI_WATCHDOG is not set
    # CONFIG_ORION_WATCHDOG is not set
    # CONFIG_RN5T618_WATCHDOG is not set
    # CONFIG_SUNXI_WATCHDOG is not set
    # CONFIG_NPCM7XX_WATCHDOG is not set
    # CONFIG_TWL4030_WATCHDOG is not set
    # CONFIG_STMP3XXX_RTC_WATCHDOG is not set
    # CONFIG_TS4800_WATCHDOG is not set
    # CONFIG_TS72XX_WATCHDOG is not set
    # CONFIG_MAX63XX_WATCHDOG is not set
    # CONFIG_MAX77620_WATCHDOG is not set
    # CONFIG_IMX2_WDT is not set
    # CONFIG_IMX7ULP_WDT is not set
    # CONFIG_MOXART_WDT is not set
    # CONFIG_ST_LPC_WATCHDOG is not set
    # CONFIG_TEGRA_WATCHDOG is not set
    # CONFIG_QCOM_WDT is not set
    # CONFIG_MESON_GXBB_WATCHDOG is not set
    # CONFIG_MESON_WATCHDOG is not set
    # CONFIG_MEDIATEK_WATCHDOG is not set
    # CONFIG_DIGICOLOR_WATCHDOG is not set
    # CONFIG_ARM_SMC_WATCHDOG is not set
    # CONFIG_LPC18XX_WATCHDOG is not set
    # CONFIG_RENESAS_WDT is not set
    # CONFIG_RENESAS_RZAWDT is not set
    # CONFIG_RENESAS_RZN1WDT is not set
    # CONFIG_RENESAS_RZG2LWDT is not set
    # CONFIG_ASPEED_WATCHDOG is not set
    CONFIG_STPMIC1_WATCHDOG=y
    # CONFIG_UNIPHIER_WATCHDOG is not set
    # CONFIG_RTD119X_WATCHDOG is not set
    # CONFIG_REALTEK_OTTO_WDT is not set
    # CONFIG_SPRD_WATCHDOG is not set
    # CONFIG_VISCONTI_WATCHDOG is not set
    # CONFIG_MSC313E_WATCHDOG is not set
    # CONFIG_APPLE_WATCHDOG is not set
    # CONFIG_SUNPLUS_WATCHDOG is not set
    # CONFIG_ALIM7101_WDT is not set
    # CONFIG_SC520_WDT is not set
    # CONFIG_I6300ESB_WDT is not set
    # CONFIG_RDC321X_WDT is not set
    # CONFIG_ATH79_WDT is not set
    # CONFIG_BCM47XX_WDT is not set
    # CONFIG_BCM2835_WDT is not set
    # CONFIG_BCM_KONA_WDT is not set
    # CONFIG_BCM7038_WDT is not set
    # CONFIG_IMGPDC_WDT is not set
    # CONFIG_MPC5200_WDT is not set
    # CONFIG_MEN_A21_WDT is not set
    # CONFIG_UML_WATCHDOG is not set
    # PCI-based Watchdog Cards
    # CONFIG_PCIPCWATCHDOG is not set
    # CONFIG_WDTPCI is not set
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # CONFIG_SSB is not set
    CONFIG_BCMA_POSSIBLE=y
    CONFIG_BCMA=y
    CONFIG_BCMA_HOST_PCI_POSSIBLE=y
    CONFIG_BCMA_HOST_PCI=y
    CONFIG_BCMA_HOST_SOC=y
    CONFIG_BCMA_DRIVER_PCI=y
    # CONFIG_BCMA_DRIVER_MIPS is not set
    CONFIG_BCMA_SFLASH=y
    CONFIG_BCMA_DRIVER_GMAC_CMN=y
    CONFIG_BCMA_DRIVER_GPIO=y
    # CONFIG_BCMA_DEBUG is not set
    # Multifunction device drivers
    CONFIG_MFD_CORE=y
    # CONFIG_MFD_ALTERA_A10SR is not set
    # CONFIG_MFD_ALTERA_SYSMGR is not set
    CONFIG_MFD_ACT8945A=y
    # CONFIG_MFD_SUN4I_GPADC is not set
    # CONFIG_MFD_AS3711 is not set
    # CONFIG_MFD_AS3722 is not set
    # CONFIG_PMIC_ADP5520 is not set
    # CONFIG_MFD_AAT2870_CORE is not set
    # CONFIG_MFD_AT91_USART is not set
    # CONFIG_MFD_ATMEL_FLEXCOM is not set
    # CONFIG_MFD_ATMEL_HLCDC is not set
    CONFIG_MFD_ATMEL_SMC=y
    # CONFIG_MFD_BCM590XX is not set
    # CONFIG_MFD_BD9571MWV is not set
    # CONFIG_MFD_AXP20X_I2C is not set
    # CONFIG_MFD_MADERA is not set
    # CONFIG_MFD_ASIC3 is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_DA9052_SPI is not set
    # CONFIG_MFD_DA9052_I2C is not set
    # CONFIG_MFD_DA9055 is not set
    # CONFIG_MFD_DA9062 is not set
    # CONFIG_MFD_DA9063 is not set
    # CONFIG_MFD_DA9150 is not set
    # CONFIG_MFD_DLN2 is not set
    # CONFIG_MFD_ENE_KB3930 is not set
    # CONFIG_MFD_EXYNOS_LPASS is not set
    # CONFIG_MFD_GATEWORKS_GSC is not set
    # CONFIG_MFD_MC13XXX_SPI is not set
    # CONFIG_MFD_MC13XXX_I2C is not set
    # CONFIG_MFD_MP2629 is not set
    # CONFIG_MFD_MXS_LRADC is not set
    # CONFIG_MFD_MX25_TSADC is not set
    # CONFIG_MFD_HI6421_PMIC is not set
    # CONFIG_MFD_HI6421_SPMI is not set
    # CONFIG_MFD_HI655X_PMIC is not set
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_HTC_I2CPLD is not set
    # CONFIG_LPC_ICH is not set
    # CONFIG_LPC_SCH is not set
    # CONFIG_INTEL_SOC_PMIC is not set
    # CONFIG_MFD_IQS62X is not set
    # CONFIG_MFD_JANZ_CMODIO is not set
    # CONFIG_MFD_KEMPLD is not set
    # CONFIG_MFD_88PM800 is not set
    # CONFIG_MFD_88PM805 is not set
    # CONFIG_MFD_88PM860X is not set
    # CONFIG_MFD_MAX14577 is not set
    # CONFIG_MFD_MAX77620 is not set
    # CONFIG_MFD_MAX77650 is not set
    # CONFIG_MFD_MAX77686 is not set
    # CONFIG_MFD_MAX77693 is not set
    # CONFIG_MFD_MAX77714 is not set
    # CONFIG_MFD_MAX77843 is not set
    # CONFIG_MFD_MAX8907 is not set
    # CONFIG_MFD_MAX8925 is not set
    # CONFIG_MFD_MAX8997 is not set
    # CONFIG_MFD_MAX8998 is not set
    # CONFIG_MFD_MT6360 is not set
    # CONFIG_MFD_MT6370 is not set
    # CONFIG_MFD_MT6397 is not set
    # CONFIG_MFD_MENF21BMC is not set
    # CONFIG_MFD_OCELOT is not set
    # CONFIG_EZX_PCAP is not set
    CONFIG_MFD_CPCAP=y
    # CONFIG_MFD_VIPERBOARD is not set
    # CONFIG_MFD_NTXEC is not set
    # CONFIG_MFD_RETU is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_UCB1400_CORE is not set
    # CONFIG_MFD_PM8XXX is not set
    # CONFIG_MFD_SPMI_PMIC is not set
    # CONFIG_MFD_SY7636A is not set
    # CONFIG_MFD_RDC321X is not set
    # CONFIG_MFD_RT4831 is not set
    # CONFIG_MFD_RT5033 is not set
    # CONFIG_MFD_RT5120 is not set
    # CONFIG_MFD_RC5T583 is not set
    # CONFIG_MFD_RK808 is not set
    # CONFIG_MFD_RN5T618 is not set
    # CONFIG_MFD_SEC_CORE is not set
    # CONFIG_MFD_SI476X_CORE is not set
    # CONFIG_MFD_SL28CPLD is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_SKY81452 is not set
    # CONFIG_MFD_SC27XX_PMIC is not set
    # CONFIG_ABX500_CORE is not set
    # CONFIG_MFD_STMPE is not set
    # CONFIG_MFD_SUN6I_PRCM is not set
    CONFIG_MFD_SYSCON=y
    CONFIG_MFD_TI_AM335X_TSCADC=y
    # CONFIG_MFD_LP3943 is not set
    # CONFIG_MFD_LP8788 is not set
    # CONFIG_MFD_TI_LMU is not set
    CONFIG_MFD_OMAP_USB_HOST=y
    CONFIG_MFD_PALMAS=y
    # CONFIG_TPS6105X is not set
    # CONFIG_TPS65010 is not set
    # CONFIG_TPS6507X is not set
    # CONFIG_MFD_TPS65086 is not set
    CONFIG_MFD_TPS65090=y
    CONFIG_MFD_TPS65217=y
    # CONFIG_MFD_TI_LP873X is not set
    # CONFIG_MFD_TI_LP87565 is not set
    CONFIG_MFD_TPS65218=y
    # CONFIG_MFD_TPS65219 is not set
    CONFIG_MFD_TPS6586X=y
    CONFIG_MFD_TPS65910=y
    # CONFIG_MFD_TPS65912_I2C is not set
    # CONFIG_MFD_TPS65912_SPI is not set
    # CONFIG_MFD_TPS6594_I2C is not set
    # CONFIG_MFD_TPS6594_SPI is not set
    CONFIG_TWL4030_CORE=y
    CONFIG_TWL4030_POWER=y
    # CONFIG_MFD_TWL4030_AUDIO is not set
    # CONFIG_TWL6040_CORE is not set
    # CONFIG_MFD_WL1273_CORE is not set
    # CONFIG_MFD_LM3533 is not set
    # CONFIG_MFD_TIMBERDALE is not set
    # CONFIG_MFD_TC3589X is not set
    # CONFIG_MFD_T7L66XB is not set
    # CONFIG_MFD_TC6387XB is not set
    # CONFIG_MFD_TC6393XB is not set
    # CONFIG_MFD_TQMX86 is not set
    # CONFIG_MFD_VX855 is not set
    # CONFIG_MFD_LOCHNAGAR is not set
    # CONFIG_MFD_ARIZONA_I2C is not set
    # CONFIG_MFD_ARIZONA_SPI is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X_I2C is not set
    # CONFIG_MFD_WM831X_SPI is not set
    # CONFIG_MFD_WM8350_I2C is not set
    CONFIG_MFD_WM8994=m
    # CONFIG_MFD_STW481X is not set
    # CONFIG_MFD_ROHM_BD718XX is not set
    # CONFIG_MFD_ROHM_BD71828 is not set
    # CONFIG_MFD_ROHM_BD957XMUF is not set
    # CONFIG_MFD_STM32_LPTIMER is not set
    # CONFIG_MFD_STM32_TIMERS is not set
    CONFIG_MFD_STPMIC1=y
    CONFIG_MFD_STMFX=y
    # CONFIG_MFD_ATC260X_I2C is not set
    # CONFIG_MFD_KHADAS_MCU is not set
    # CONFIG_MFD_ACER_A500_EC is not set
    # CONFIG_MFD_QCOM_PM8008 is not set
    CONFIG_MFD_VEXPRESS_SYSREG=y
    # CONFIG_RAVE_SP_CORE is not set
    # CONFIG_MFD_INTEL_M10_BMC is not set
    # CONFIG_MFD_RSMU_I2C is not set
    # CONFIG_MFD_RSMU_SPI is not set
    # end of Multifunction device drivers
    CONFIG_REGULATOR=y
    # CONFIG_REGULATOR_DEBUG is not set
    CONFIG_REGULATOR_FIXED_VOLTAGE=y
    # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
    # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
    # CONFIG_REGULATOR_88PG86X is not set
    # CONFIG_REGULATOR_ACT8865 is not set
    CONFIG_REGULATOR_ACT8945A=y
    # CONFIG_REGULATOR_AD5398 is not set
    # CONFIG_REGULATOR_ANATOP is not set
    # CONFIG_REGULATOR_ARM_SCMI is not set
    CONFIG_REGULATOR_CPCAP=y
    # CONFIG_REGULATOR_DA9121 is not set
    # CONFIG_REGULATOR_DA9210 is not set
    # CONFIG_REGULATOR_DA9211 is not set
    # CONFIG_REGULATOR_FAN53555 is not set
    # CONFIG_REGULATOR_FAN53880 is not set
    CONFIG_REGULATOR_GPIO=y
    # CONFIG_REGULATOR_ISL9305 is not set
    # CONFIG_REGULATOR_ISL6271A is not set
    # CONFIG_REGULATOR_LP3971 is not set
    # CONFIG_REGULATOR_LP3972 is not set
    # CONFIG_REGULATOR_LP872X is not set
    # CONFIG_REGULATOR_LP8755 is not set
    # CONFIG_REGULATOR_LTC3589 is not set
    # CONFIG_REGULATOR_LTC3676 is not set
    # CONFIG_REGULATOR_MAX1586 is not set
    # CONFIG_REGULATOR_MAX77620 is not set
    # CONFIG_REGULATOR_MAX77650 is not set
    # CONFIG_REGULATOR_MAX8649 is not set
    # CONFIG_REGULATOR_MAX8660 is not set
    # CONFIG_REGULATOR_MAX8893 is not set
    # CONFIG_REGULATOR_MAX8907 is not set
    # CONFIG_REGULATOR_MAX8952 is not set
    # CONFIG_REGULATOR_MAX8973 is not set
    # CONFIG_REGULATOR_MAX20086 is not set
    # CONFIG_REGULATOR_MAX77686 is not set
    # CONFIG_REGULATOR_MAX77693 is not set
    # CONFIG_REGULATOR_MAX77802 is not set
    # CONFIG_REGULATOR_MAX77826 is not set
    # CONFIG_REGULATOR_MCP16502 is not set
    # CONFIG_REGULATOR_MP5416 is not set
    # CONFIG_REGULATOR_MP8859 is not set
    # CONFIG_REGULATOR_MP886X is not set
    # CONFIG_REGULATOR_MPQ7920 is not set
    # CONFIG_REGULATOR_MT6311 is not set
    # CONFIG_REGULATOR_MT6315 is not set
    CONFIG_REGULATOR_PALMAS=y
    CONFIG_REGULATOR_PBIAS=y
    # CONFIG_REGULATOR_PCA9450 is not set
    # CONFIG_REGULATOR_PF8X00 is not set
    # CONFIG_REGULATOR_PFUZE100 is not set
    # CONFIG_REGULATOR_PV88060 is not set
    # CONFIG_REGULATOR_PV88080 is not set
    # CONFIG_REGULATOR_PV88090 is not set
    # CONFIG_REGULATOR_PWM is not set
    # CONFIG_REGULATOR_QCOM_RPMH is not set
    CONFIG_REGULATOR_QCOM_SPMI=y
    # CONFIG_REGULATOR_QCOM_USB_VBUS is not set
    # CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY is not set
    # CONFIG_REGULATOR_RT4801 is not set
    # CONFIG_REGULATOR_RT5190A is not set
    # CONFIG_REGULATOR_RT5759 is not set
    # CONFIG_REGULATOR_RT6160 is not set
    # CONFIG_REGULATOR_RT6245 is not set
    # CONFIG_REGULATOR_RTQ2134 is not set
    # CONFIG_REGULATOR_RTMV20 is not set
    # CONFIG_REGULATOR_RTQ6752 is not set
    # CONFIG_REGULATOR_S2MPA01 is not set
    # CONFIG_REGULATOR_S2MPS11 is not set
    # CONFIG_REGULATOR_S5M8767 is not set
    # CONFIG_REGULATOR_SC2731 is not set
    # CONFIG_REGULATOR_SLG51000 is not set
    # CONFIG_REGULATOR_STM32_BOOSTER is not set
    # CONFIG_REGULATOR_STM32_VREFBUF is not set
    # CONFIG_REGULATOR_STM32_PWR is not set
    CONFIG_REGULATOR_STPMIC1=y
    CONFIG_REGULATOR_TI_ABB=y
    # CONFIG_REGULATOR_STW481X_VMMC is not set
    # CONFIG_REGULATOR_SY8106A is not set
    # CONFIG_REGULATOR_SY8824X is not set
    # CONFIG_REGULATOR_SY8827N is not set
    # CONFIG_REGULATOR_TPS51632 is not set
    CONFIG_REGULATOR_TPS62360=y
    # CONFIG_REGULATOR_TPS6286X is not set
    # CONFIG_REGULATOR_TPS65023 is not set
    # CONFIG_REGULATOR_TPS6507X is not set
    CONFIG_REGULATOR_TPS65090=y
    # CONFIG_REGULATOR_TPS65132 is not set
    CONFIG_REGULATOR_TPS65217=y
    CONFIG_REGULATOR_TPS65218=y
    # CONFIG_REGULATOR_TPS6524X is not set
    CONFIG_REGULATOR_TPS6586X=y
    CONFIG_REGULATOR_TPS65910=y
    # CONFIG_REGULATOR_TPS68470 is not set
    # CONFIG_REGULATOR_TWL4030 is not set
    # CONFIG_REGULATOR_UNIPHIER is not set
    # CONFIG_REGULATOR_VCTRL is not set
    CONFIG_REGULATOR_VEXPRESS=y
    CONFIG_REGULATOR_WM8994=m
    # CONFIG_REGULATOR_QCOM_LABIBB is not set
    # CONFIG_RC_CORE is not set
    CONFIG_CEC_CORE=m
    # CEC support
    CONFIG_MEDIA_CEC_SUPPORT=y
    # CONFIG_CEC_CH7322 is not set
    # CONFIG_CEC_MESON_AO is not set
    # CONFIG_CEC_MESON_G12A_AO is not set
    # CONFIG_CEC_GPIO is not set
    # CONFIG_CEC_SAMSUNG_S5P is not set
    # CONFIG_CEC_STI is not set
    # CONFIG_CEC_STM32 is not set
    # CONFIG_CEC_TEGRA is not set
    # CONFIG_CEC_SECO is not set
    # CONFIG_USB_PULSE8_CEC is not set
    # CONFIG_USB_RAINSHADOW_CEC is not set
    # end of CEC support
    CONFIG_MEDIA_SUPPORT=m
    # CONFIG_MEDIA_SUPPORT_FILTER is not set
    # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
    # Media device types
    CONFIG_MEDIA_CAMERA_SUPPORT=y
    CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
    CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
    CONFIG_MEDIA_RADIO_SUPPORT=y
    CONFIG_MEDIA_SDR_SUPPORT=y
    CONFIG_MEDIA_PLATFORM_SUPPORT=y
    CONFIG_MEDIA_TEST_SUPPORT=y
    # end of Media device types
    # Media core support
    CONFIG_VIDEO_DEV=m
    CONFIG_MEDIA_CONTROLLER=y
    CONFIG_DVB_CORE=m
    # end of Media core support
    # Video4Linux options
    CONFIG_VIDEO_V4L2_I2C=y
    CONFIG_VIDEO_V4L2_SUBDEV_API=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    # CONFIG_V4L2_FLASH_LED_CLASS is not set
    CONFIG_V4L2_FWNODE=m
    CONFIG_V4L2_ASYNC=m
    # end of Video4Linux options
    # Media controller options
    # CONFIG_MEDIA_CONTROLLER_DVB is not set
    CONFIG_MEDIA_CONTROLLER_REQUEST_API=y
    # end of Media controller options
    # Digital TV options
    # CONFIG_DVB_MMAP is not set
    CONFIG_DVB_NET=y
    CONFIG_DVB_MAX_ADAPTERS=16
    CONFIG_DVB_DYNAMIC_MINORS=y
    # CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
    # CONFIG_DVB_ULE_DEBUG is not set
    # end of Digital TV options
    # Media drivers
    # Media drivers
    CONFIG_MEDIA_USB_SUPPORT=y
    # Webcam devices
    # CONFIG_USB_GSPCA is not set
    # CONFIG_USB_PWC is not set
    # CONFIG_USB_S2255 is not set
    # CONFIG_VIDEO_USBTV is not set
    CONFIG_USB_VIDEO_CLASS=m
    CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
    # Analog TV USB devices
    # CONFIG_VIDEO_GO7007 is not set
    # CONFIG_VIDEO_HDPVR is not set
    # CONFIG_VIDEO_PVRUSB2 is not set
    # CONFIG_VIDEO_STK1160_COMMON is not set
    # Analog/digital TV USB devices
    # CONFIG_VIDEO_AU0828 is not set
    # CONFIG_VIDEO_CX231XX is not set
    # Digital TV USB devices
    # CONFIG_DVB_AS102 is not set
    # CONFIG_DVB_B2C2_FLEXCOP_USB is not set
    # CONFIG_DVB_USB_V2 is not set
    # CONFIG_SMS_USB_DRV is not set
    # CONFIG_DVB_TTUSB_BUDGET is not set
    # CONFIG_DVB_TTUSB_DEC is not set
    # Webcam, TV (analog/digital) USB devices
    # CONFIG_VIDEO_EM28XX is not set
    # Software defined radio USB devices
    # CONFIG_USB_AIRSPY is not set
    # CONFIG_USB_HACKRF is not set
    # CONFIG_USB_MSI2500 is not set
    # CONFIG_MEDIA_PCI_SUPPORT is not set
    CONFIG_RADIO_ADAPTERS=m
    # CONFIG_RADIO_MAXIRADIO is not set
    # CONFIG_RADIO_SAA7706H is not set
    # CONFIG_RADIO_SHARK is not set
    # CONFIG_RADIO_SHARK2 is not set
    # CONFIG_RADIO_SI4713 is not set
    # CONFIG_RADIO_TEA5764 is not set
    # CONFIG_RADIO_TEF6862 is not set
    # CONFIG_RADIO_WL1273 is not set
    # CONFIG_USB_DSBR is not set
    # CONFIG_USB_KEENE is not set
    # CONFIG_USB_MA901 is not set
    # CONFIG_USB_MR800 is not set
    # CONFIG_USB_RAREMONO is not set
    # CONFIG_RADIO_SI470X is not set
    # CONFIG_V4L_RADIO_ISA_DRIVERS is not set
    CONFIG_MEDIA_PLATFORM_DRIVERS=y
    CONFIG_V4L_PLATFORM_DRIVERS=y
    # CONFIG_SDR_PLATFORM_DRIVERS is not set
    # CONFIG_DVB_PLATFORM_DRIVERS is not set
    CONFIG_V4L_MEM2MEM_DRIVERS=y
    # CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set
    # CONFIG_VIDEO_MUX is not set
    # Allegro DVT media platform drivers
    # CONFIG_VIDEO_ALLEGRO_DVT is not set
    # Amlogic media platform drivers
    # CONFIG_VIDEO_MESON_GE2D is not set
    # Amphion drivers
    # CONFIG_VIDEO_AMPHION_VPU is not set
    # Aspeed media platform drivers
    CONFIG_VIDEO_ASPEED=m
    # Atmel media platform drivers
    # CONFIG_VIDEO_ATMEL_ISC is not set
    # CONFIG_VIDEO_ATMEL_XISC is not set
    # CONFIG_VIDEO_ATMEL_ISI is not set
    # CONFIG_VIDEO_MICROCHIP_CSI2DC is not set
    # Cadence media platform drivers
    # CONFIG_VIDEO_CADENCE_CSI2RX is not set
    # CONFIG_VIDEO_CADENCE_CSI2TX is not set
    # Chips&Media media platform drivers
    # CONFIG_VIDEO_CODA is not set
    # CONFIG_VIDEO_WAVE_VPU is not set
    # IMG media platform drivers
    # CONFIG_VIDEO_IMG_VXD_DEC is not set
    # CONFIG_VIDEO_IMG_VXE_ENC is not set
    # CONFIG_VIDEO_E5010_JPEG_ENC is not set
    # Intel media platform drivers
    # CONFIG_VIDEO_PXA27x is not set
    # Marvell media platform drivers
    # CONFIG_VIDEO_CAFE_CCIC is not set
    # CONFIG_VIDEO_MMP_CAMERA is not set
    # Mediatek media platform drivers
    # CONFIG_VIDEO_MEDIATEK_JPEG is not set
    # CONFIG_VIDEO_MEDIATEK_MDP is not set
    # CONFIG_VIDEO_MEDIATEK_VPU is not set
    # NVidia media platform drivers
    # CONFIG_VIDEO_TEGRA_VDE is not set
    # NXP media platform drivers
    # CONFIG_VIDEO_IMX_MIPI_CSIS is not set
    # CONFIG_VIDEO_IMX_PXP is not set
    # CONFIG_VIDEO_MX2_EMMAPRP is not set
    # CONFIG_VIDEO_DW100 is not set
    # CONFIG_VIDEO_IMX8_JPEG is not set
    # Qualcomm media platform drivers
    # CONFIG_VIDEO_QCOM_CAMSS is not set
    # Renesas media platform drivers
    # CONFIG_VIDEO_RENESAS_CEU is not set
    # CONFIG_VIDEO_RCAR_ISP is not set
    # CONFIG_VIDEO_SH_VOU is not set
    # CONFIG_VIDEO_RCAR_CSI2 is not set
    # CONFIG_VIDEO_RCAR_VIN is not set
    # CONFIG_VIDEO_RENESAS_FCP is not set
    # CONFIG_VIDEO_RENESAS_FDP1 is not set
    # CONFIG_VIDEO_RENESAS_JPU is not set
    # CONFIG_VIDEO_RENESAS_VSP1 is not set
    # Rockchip media platform drivers
    # CONFIG_VIDEO_ROCKCHIP_RGA is not set
    # CONFIG_VIDEO_ROCKCHIP_ISP1 is not set
    # Samsung media platform drivers
    # CONFIG_VIDEO_SAMSUNG_EXYNOS_GSC is not set
    # CONFIG_VIDEO_SAMSUNG_EXYNOS4_IS is not set
    # CONFIG_VIDEO_S3C_CAMIF is not set
    # CONFIG_VIDEO_SAMSUNG_S5P_G2D is not set
    # CONFIG_VIDEO_SAMSUNG_S5P_JPEG is not set
    # CONFIG_VIDEO_SAMSUNG_S5P_MFC is not set
    # STMicroelectronics media platform drivers
    # CONFIG_VIDEO_STI_BDISP is not set
    # CONFIG_VIDEO_STI_DELTA is not set
    # CONFIG_VIDEO_STI_HVA is not set
    # CONFIG_VIDEO_STM32_DCMI is not set
    # CONFIG_VIDEO_STM32_DMA2D is not set
    # Sunxi media platform drivers
    # CONFIG_VIDEO_SUN4I_CSI is not set
    # CONFIG_VIDEO_SUN6I_CSI is not set
    # CONFIG_VIDEO_SUN8I_A83T_MIPI_CSI2 is not set
    # CONFIG_VIDEO_SUN8I_DEINTERLACE is not set
    # CONFIG_VIDEO_SUN8I_ROTATE is not set
    # Texas Instruments drivers
    # CONFIG_VIDEO_TI_CAL is not set
    # CONFIG_VIDEO_TI_VPE is not set
    # CONFIG_VIDEO_AM437X_VPFE is not set
    # CONFIG_VIDEO_DAVINCI_VPIF_DISPLAY is not set
    # CONFIG_VIDEO_DAVINCI_VPIF_CAPTURE is not set
    # CONFIG_VIDEO_DAVINCI_VPBE_DISPLAY is not set
    # CONFIG_VIDEO_OMAP2_VOUT is not set
    # CONFIG_VIDEO_OMAP3 is not set
    # Verisilicon media platform drivers
    # CONFIG_VIDEO_HANTRO is not set
    # VIA media platform drivers
    # Xilinx media platform drivers
    # CONFIG_VIDEO_XILINX is not set
    # MMC/SDIO DVB adapters
    # CONFIG_SMS_SDIO_DRV is not set
    CONFIG_V4L_TEST_DRIVERS=y
    # CONFIG_VIDEO_VIM2M is not set
    # CONFIG_VIDEO_VICODEC is not set
    # CONFIG_VIDEO_VIMC is not set
    CONFIG_VIDEO_VIVID=m
    # CONFIG_VIDEO_VIVID_CEC is not set
    CONFIG_VIDEO_VIVID_MAX_DEVS=64
    # CONFIG_DVB_TEST_DRIVERS is not set
    CONFIG_VIDEO_V4L2_TPG=m
    CONFIG_VIDEOBUF2_CORE=m
    CONFIG_VIDEOBUF2_V4L2=m
    CONFIG_VIDEOBUF2_MEMOPS=m
    CONFIG_VIDEOBUF2_DMA_CONTIG=m
    CONFIG_VIDEOBUF2_VMALLOC=m
    CONFIG_VIDEOBUF2_DMA_SG=m
    # end of Media drivers
    # Media ancillary drivers
    CONFIG_MEDIA_ATTACH=y
    # Camera sensor devices
    # CONFIG_VIDEO_AR0521 is not set
    # CONFIG_VIDEO_HI556 is not set
    # CONFIG_VIDEO_HI846 is not set
    # CONFIG_VIDEO_HI847 is not set
    # CONFIG_VIDEO_IMX208 is not set
    # CONFIG_VIDEO_IMX214 is not set
    # CONFIG_VIDEO_IMX219 is not set
    # CONFIG_VIDEO_IMX258 is not set
    # CONFIG_VIDEO_IMX274 is not set
    # CONFIG_VIDEO_IMX290 is not set
    # CONFIG_VIDEO_IMX319 is not set
    # CONFIG_VIDEO_IMX334 is not set
    # CONFIG_VIDEO_IMX335 is not set
    # CONFIG_VIDEO_IMX355 is not set
    # CONFIG_VIDEO_IMX390 is not set
    # CONFIG_VIDEO_IMX412 is not set
    # CONFIG_VIDEO_MT9M001 is not set
    # CONFIG_VIDEO_MT9M032 is not set
    # CONFIG_VIDEO_MT9M111 is not set
    # CONFIG_VIDEO_MT9P031 is not set
    # CONFIG_VIDEO_MT9T001 is not set
    # CONFIG_VIDEO_MT9T112 is not set
    # CONFIG_VIDEO_MT9V011 is not set
    # CONFIG_VIDEO_MT9V032 is not set
    # CONFIG_VIDEO_MT9V111 is not set
    # CONFIG_VIDEO_NOON010PC30 is not set
    # CONFIG_VIDEO_OG01A1B is not set
    # CONFIG_VIDEO_OV02A10 is not set
    # CONFIG_VIDEO_OV08D10 is not set
    # CONFIG_VIDEO_OV13858 is not set
    # CONFIG_VIDEO_OV13B10 is not set
    # CONFIG_VIDEO_OV2312 is not set
    # CONFIG_VIDEO_OV2640 is not set
    # CONFIG_VIDEO_OV2659 is not set
    # CONFIG_VIDEO_OV2680 is not set
    # CONFIG_VIDEO_OV2685 is not set
    # CONFIG_VIDEO_OV2740 is not set
    # CONFIG_VIDEO_OV5640 is not set
    # CONFIG_VIDEO_OV5645 is not set
    # CONFIG_VIDEO_OV5647 is not set
    # CONFIG_VIDEO_OV5648 is not set
    # CONFIG_VIDEO_OV5670 is not set
    # CONFIG_VIDEO_OV5675 is not set
    # CONFIG_VIDEO_OV5693 is not set
    # CONFIG_VIDEO_OV5695 is not set
    # CONFIG_VIDEO_OV6650 is not set
    # CONFIG_VIDEO_OV7251 is not set
    # CONFIG_VIDEO_OV7640 is not set
    CONFIG_VIDEO_OV7670=m
    # CONFIG_VIDEO_OV772X is not set
    # CONFIG_VIDEO_OV7740 is not set
    # CONFIG_VIDEO_OV8856 is not set
    # CONFIG_VIDEO_OV8865 is not set
    # CONFIG_VIDEO_OV9282 is not set
    # CONFIG_VIDEO_OV9640 is not set
    # CONFIG_VIDEO_OV9650 is not set
    # CONFIG_VIDEO_OV9734 is not set
    # CONFIG_VIDEO_RDACM20 is not set
    # CONFIG_VIDEO_RDACM21 is not set
    # CONFIG_VIDEO_RJ54N1 is not set
    # CONFIG_VIDEO_S5C73M3 is not set
    # CONFIG_VIDEO_S5K4ECGX is not set
    # CONFIG_VIDEO_S5K5BAF is not set
    # CONFIG_VIDEO_S5K6A3 is not set
    # CONFIG_VIDEO_S5K6AA is not set
    # CONFIG_VIDEO_SR030PC30 is not set
    # CONFIG_VIDEO_VS6624 is not set
    # CONFIG_VIDEO_CCS is not set
    # CONFIG_VIDEO_ET8EK8 is not set
    # CONFIG_VIDEO_M5MOLS is not set
    # end of Camera sensor devices
    # Lens drivers
    # CONFIG_VIDEO_AD5820 is not set
    # CONFIG_VIDEO_AK7375 is not set
    # CONFIG_VIDEO_DW9714 is not set
    # CONFIG_VIDEO_DW9768 is not set
    # CONFIG_VIDEO_DW9807_VCM is not set
    # end of Lens drivers
    # Flash devices
    # CONFIG_VIDEO_ADP1653 is not set
    # CONFIG_VIDEO_LM3560 is not set
    # CONFIG_VIDEO_LM3646 is not set
    # end of Flash devices
    # Audio decoders, processors and mixers
    # CONFIG_VIDEO_CS3308 is not set
    # CONFIG_VIDEO_CS5345 is not set
    # CONFIG_VIDEO_CS53L32A is not set
    # CONFIG_VIDEO_MSP3400 is not set
    # CONFIG_VIDEO_SONY_BTF_MPX is not set
    # CONFIG_VIDEO_TDA1997X is not set
    # CONFIG_VIDEO_TDA7432 is not set
    # CONFIG_VIDEO_TDA9840 is not set
    # CONFIG_VIDEO_TEA6415C is not set
    # CONFIG_VIDEO_TEA6420 is not set
    # CONFIG_VIDEO_TLV320AIC23B is not set
    # CONFIG_VIDEO_TVAUDIO is not set
    # CONFIG_VIDEO_UDA1342 is not set
    # CONFIG_VIDEO_VP27SMPX is not set
    # CONFIG_VIDEO_WM8739 is not set
    # CONFIG_VIDEO_WM8775 is not set
    # end of Audio decoders, processors and mixers
    # RDS decoders
    # CONFIG_VIDEO_SAA6588 is not set
    # end of RDS decoders
    # Video decoders
    CONFIG_VIDEO_ADV7180=m
    # CONFIG_VIDEO_ADV7183 is not set
    # CONFIG_VIDEO_ADV748X is not set
    CONFIG_VIDEO_ADV7604=m
    CONFIG_VIDEO_ADV7604_CEC=y
    # CONFIG_VIDEO_ADV7842 is not set
    # CONFIG_VIDEO_BT819 is not set
    # CONFIG_VIDEO_BT856 is not set
    # CONFIG_VIDEO_BT866 is not set
    # CONFIG_VIDEO_ISL7998X is not set
    # CONFIG_VIDEO_KS0127 is not set
    # CONFIG_VIDEO_MAX9286 is not set
    CONFIG_VIDEO_ML86V7667=m
    # CONFIG_VIDEO_SAA7110 is not set
    # CONFIG_VIDEO_SAA711X is not set
    # CONFIG_VIDEO_TC358743 is not set
    # CONFIG_VIDEO_TVP514X is not set
    # CONFIG_VIDEO_TVP5150 is not set
    # CONFIG_VIDEO_TVP7002 is not set
    # CONFIG_VIDEO_TW2804 is not set
    # CONFIG_VIDEO_TW9903 is not set
    # CONFIG_VIDEO_TW9906 is not set
    # CONFIG_VIDEO_TW9910 is not set
    # CONFIG_VIDEO_VPX3220 is not set
    # Video and audio decoders
    # CONFIG_VIDEO_SAA717X is not set
    # CONFIG_VIDEO_CX25840 is not set
    # end of Video decoders
    # Video encoders
    # CONFIG_VIDEO_AD9389B is not set
    # CONFIG_VIDEO_ADV7170 is not set
    # CONFIG_VIDEO_ADV7175 is not set
    # CONFIG_VIDEO_ADV7343 is not set
    # CONFIG_VIDEO_ADV7393 is not set
    # CONFIG_VIDEO_ADV7511 is not set
    # CONFIG_VIDEO_AK881X is not set
    # CONFIG_VIDEO_SAA7127 is not set
    # CONFIG_VIDEO_SAA7185 is not set
    # CONFIG_VIDEO_THS8200 is not set
    # end of Video encoders
    # Video improvement chips
    # CONFIG_VIDEO_UPD64031A is not set
    # CONFIG_VIDEO_UPD64083 is not set
    # end of Video improvement chips
    # Audio/Video compression chips
    # CONFIG_VIDEO_SAA6752HS is not set
    # end of Audio/Video compression chips
    # SDR tuner chips
    # CONFIG_SDR_MAX2175 is not set
    # end of SDR tuner chips
    # Miscellaneous helper chips
    # CONFIG_VIDEO_I2C is not set
    # CONFIG_VIDEO_M52790 is not set
    # CONFIG_VIDEO_ST_MIPID02 is not set
    # CONFIG_VIDEO_THS7303 is not set
    # end of Miscellaneous helper chips
    # Video serializers and deserializers
    # CONFIG_VIDEO_DS90UB913 is not set
    # CONFIG_VIDEO_DS90UB953 is not set
    # CONFIG_VIDEO_DS90UB960 is not set
    # end of Video serializers and deserializers
    # Media SPI Adapters
    CONFIG_CXD2880_SPI_DRV=m
    # CONFIG_VIDEO_GS1662 is not set
    # end of Media SPI Adapters
    CONFIG_MEDIA_TUNER=m
    # Customize TV tuners
    CONFIG_MEDIA_TUNER_E4000=m
    CONFIG_MEDIA_TUNER_FC0011=m
    CONFIG_MEDIA_TUNER_FC0012=m
    CONFIG_MEDIA_TUNER_FC0013=m
    CONFIG_MEDIA_TUNER_FC2580=m
    CONFIG_MEDIA_TUNER_IT913X=m
    CONFIG_MEDIA_TUNER_M88RS6000T=m
    CONFIG_MEDIA_TUNER_MAX2165=m
    CONFIG_MEDIA_TUNER_MC44S803=m
    CONFIG_MEDIA_TUNER_MSI001=m
    CONFIG_MEDIA_TUNER_MT2060=m
    CONFIG_MEDIA_TUNER_MT2063=m
    CONFIG_MEDIA_TUNER_MT20XX=m
    CONFIG_MEDIA_TUNER_MT2131=m
    CONFIG_MEDIA_TUNER_MT2266=m
    CONFIG_MEDIA_TUNER_MXL301RF=m
    CONFIG_MEDIA_TUNER_MXL5005S=m
    CONFIG_MEDIA_TUNER_MXL5007T=m
    CONFIG_MEDIA_TUNER_QM1D1B0004=m
    CONFIG_MEDIA_TUNER_QM1D1C0042=m
    CONFIG_MEDIA_TUNER_QT1010=m
    CONFIG_MEDIA_TUNER_R820T=m
    CONFIG_MEDIA_TUNER_SI2157=m
    CONFIG_MEDIA_TUNER_SIMPLE=m
    CONFIG_MEDIA_TUNER_TDA18212=m
    CONFIG_MEDIA_TUNER_TDA18218=m
    CONFIG_MEDIA_TUNER_TDA18250=m
    CONFIG_MEDIA_TUNER_TDA18271=m
    CONFIG_MEDIA_TUNER_TDA827X=m
    CONFIG_MEDIA_TUNER_TDA8290=m
    CONFIG_MEDIA_TUNER_TDA9887=m
    CONFIG_MEDIA_TUNER_TEA5761=m
    CONFIG_MEDIA_TUNER_TEA5767=m
    CONFIG_MEDIA_TUNER_TUA9001=m
    CONFIG_MEDIA_TUNER_XC2028=m
    CONFIG_MEDIA_TUNER_XC4000=m
    CONFIG_MEDIA_TUNER_XC5000=m
    # end of Customize TV tuners
    # Customise DVB Frontends
    # Multistandard (satellite) frontends
    CONFIG_DVB_M88DS3103=m
    CONFIG_DVB_MXL5XX=m
    CONFIG_DVB_STB0899=m
    CONFIG_DVB_STB6100=m
    CONFIG_DVB_STV090x=m
    CONFIG_DVB_STV0910=m
    CONFIG_DVB_STV6110x=m
    CONFIG_DVB_STV6111=m
    # Multistandard (cable + terrestrial) frontends
    CONFIG_DVB_DRXK=m
    CONFIG_DVB_MN88472=m
    CONFIG_DVB_MN88473=m
    CONFIG_DVB_SI2165=m
    CONFIG_DVB_TDA18271C2DD=m
    # DVB-S (satellite) frontends
    CONFIG_DVB_CX24110=m
    CONFIG_DVB_CX24116=m
    CONFIG_DVB_CX24117=m
    CONFIG_DVB_CX24120=m
    CONFIG_DVB_CX24123=m
    CONFIG_DVB_DS3000=m
    CONFIG_DVB_MB86A16=m
    CONFIG_DVB_MT312=m
    CONFIG_DVB_S5H1420=m
    CONFIG_DVB_SI21XX=m
    CONFIG_DVB_STB6000=m
    CONFIG_DVB_STV0288=m
    CONFIG_DVB_STV0299=m
    CONFIG_DVB_STV0900=m
    CONFIG_DVB_STV6110=m
    CONFIG_DVB_TDA10071=m
    CONFIG_DVB_TDA10086=m
    CONFIG_DVB_TDA8083=m
    CONFIG_DVB_TDA8261=m
    CONFIG_DVB_TDA826X=m
    CONFIG_DVB_TS2020=m
    CONFIG_DVB_TUA6100=m
    CONFIG_DVB_TUNER_CX24113=m
    CONFIG_DVB_TUNER_ITD1000=m
    CONFIG_DVB_VES1X93=m
    CONFIG_DVB_ZL10036=m
    CONFIG_DVB_ZL10039=m
    # DVB-T (terrestrial) frontends
    CONFIG_DVB_AF9013=m
    CONFIG_DVB_CX22700=m
    CONFIG_DVB_CX22702=m
    CONFIG_DVB_CXD2820R=m
    CONFIG_DVB_CXD2841ER=m
    CONFIG_DVB_DIB3000MB=m
    CONFIG_DVB_DIB3000MC=m
    CONFIG_DVB_DIB7000M=m
    CONFIG_DVB_DIB7000P=m
    CONFIG_DVB_DIB9000=m
    CONFIG_DVB_DRXD=m
    CONFIG_DVB_EC100=m
    CONFIG_DVB_L64781=m
    CONFIG_DVB_MT352=m
    CONFIG_DVB_NXT6000=m
    CONFIG_DVB_RTL2830=m
    CONFIG_DVB_RTL2832=m
    CONFIG_DVB_RTL2832_SDR=m
    CONFIG_DVB_S5H1432=m
    CONFIG_DVB_SI2168=m
    CONFIG_DVB_SP887X=m
    CONFIG_DVB_STV0367=m
    CONFIG_DVB_TDA10048=m
    CONFIG_DVB_TDA1004X=m
    CONFIG_DVB_ZD1301_DEMOD=m
    CONFIG_DVB_ZL10353=m
    CONFIG_DVB_CXD2880=m
    # DVB-C (cable) frontends
    CONFIG_DVB_STV0297=m
    CONFIG_DVB_TDA10021=m
    CONFIG_DVB_TDA10023=m
    CONFIG_DVB_VES1820=m
    # ATSC (North American/Korean Terrestrial/Cable DTV) frontends
    CONFIG_DVB_AU8522=m
    CONFIG_DVB_AU8522_DTV=m
    CONFIG_DVB_AU8522_V4L=m
    CONFIG_DVB_BCM3510=m
    CONFIG_DVB_LG2160=m
    CONFIG_DVB_LGDT3305=m
    CONFIG_DVB_LGDT3306A=m
    CONFIG_DVB_LGDT330X=m
    CONFIG_DVB_MXL692=m
    CONFIG_DVB_NXT200X=m
    CONFIG_DVB_OR51132=m
    CONFIG_DVB_OR51211=m
    CONFIG_DVB_S5H1409=m
    CONFIG_DVB_S5H1411=m
    # ISDB-T (terrestrial) frontends
    CONFIG_DVB_DIB8000=m
    CONFIG_DVB_MB86A20S=m
    CONFIG_DVB_S921=m
    # ISDB-S (satellite) & ISDB-T (terrestrial) frontends
    CONFIG_DVB_MN88443X=m
    CONFIG_DVB_TC90522=m
    # Digital terrestrial only tuners/PLL
    CONFIG_DVB_PLL=m
    CONFIG_DVB_TUNER_DIB0070=m
    CONFIG_DVB_TUNER_DIB0090=m
    # SEC control devices for DVB-S
    CONFIG_DVB_A8293=m
    CONFIG_DVB_AF9033=m
    CONFIG_DVB_ASCOT2E=m
    CONFIG_DVB_ATBM8830=m
    CONFIG_DVB_HELENE=m
    CONFIG_DVB_HORUS3A=m
    CONFIG_DVB_ISL6405=m
    CONFIG_DVB_ISL6421=m
    CONFIG_DVB_ISL6423=m
    CONFIG_DVB_IX2505V=m
    CONFIG_DVB_LGS8GL5=m
    CONFIG_DVB_LGS8GXX=m
    CONFIG_DVB_LNBH25=m
    CONFIG_DVB_LNBH29=m
    CONFIG_DVB_LNBP21=m
    CONFIG_DVB_LNBP22=m
    CONFIG_DVB_M88RS2000=m
    CONFIG_DVB_TDA665x=m
    CONFIG_DVB_DRX39XYJ=m
    # Common Interface (EN50221) controller drivers
    CONFIG_DVB_CXD2099=m
    CONFIG_DVB_SP2=m
    # end of Customise DVB Frontends
    # Tools to develop new frontends
    # CONFIG_DVB_DUMMY_FE is not set
    # end of Media ancillary drivers
    # Graphics support
    # CONFIG_TEGRA_HOST1X is not set
    CONFIG_IMX_IPUV3_CORE=m
    CONFIG_DRM=y
    CONFIG_DRM_MIPI_DSI=y
    # CONFIG_DRM_DEBUG_MM is not set
    CONFIG_DRM_KMS_HELPER=y
    # CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set
    # CONFIG_DRM_DEBUG_MODESET_LOCK is not set
    CONFIG_DRM_FBDEV_EMULATION=y
    CONFIG_DRM_FBDEV_OVERALLOC=100
    # CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set
    # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
    CONFIG_DRM_DP_AUX_BUS=y
    CONFIG_DRM_DISPLAY_HELPER=y
    CONFIG_DRM_DISPLAY_DP_HELPER=y
    CONFIG_DRM_DISPLAY_HDMI_HELPER=y
    # CONFIG_DRM_DP_AUX_CHARDEV is not set
    # CONFIG_DRM_DP_CEC is not set
    CONFIG_DRM_GEM_DMA_HELPER=m
    # I2C encoder or helper chips
    # CONFIG_DRM_I2C_CH7006 is not set
    # CONFIG_DRM_I2C_SIL164 is not set
    CONFIG_DRM_I2C_NXP_TDA998X=m
    # CONFIG_DRM_I2C_NXP_TDA9950 is not set
    # end of I2C encoder or helper chips
    # ARM devices
    # CONFIG_DRM_HDLCD is not set
    # CONFIG_DRM_MALI_DISPLAY is not set
    # CONFIG_DRM_KOMEDA is not set
    # end of ARM devices
    # CONFIG_DRM_RADEON is not set
    # CONFIG_DRM_AMDGPU is not set
    # CONFIG_DRM_NOUVEAU is not set
    # CONFIG_DRM_KMB_DISPLAY is not set
    # CONFIG_DRM_VGEM is not set
    # CONFIG_DRM_VKMS is not set
    # CONFIG_DRM_EXYNOS is not set
    # CONFIG_DRM_UDL is not set
    # CONFIG_DRM_AST is not set
    # CONFIG_DRM_MGAG200 is not set
    # CONFIG_DRM_ARMADA is not set
    # CONFIG_DRM_RCAR_DU is not set
    # CONFIG_DRM_RCAR_DW_HDMI is not set
    CONFIG_DRM_RCAR_USE_LVDS=y
    CONFIG_DRM_RCAR_USE_MIPI_DSI=y
    # CONFIG_DRM_SHMOBILE is not set
    # CONFIG_DRM_SUN4I is not set
    CONFIG_DRM_OMAP=m
    # CONFIG_OMAP2_DSS_DEBUG is not set
    # CONFIG_OMAP2_DSS_DEBUGFS is not set
    CONFIG_OMAP2_DSS_DPI=y
    CONFIG_OMAP2_DSS_VENC=y
    CONFIG_OMAP2_DSS_HDMI_COMMON=y
    CONFIG_OMAP4_DSS_HDMI=y
    CONFIG_OMAP4_DSS_HDMI_CEC=y
    CONFIG_OMAP5_DSS_HDMI=y
    # CONFIG_OMAP2_DSS_SDI is not set
    # CONFIG_OMAP2_DSS_DSI is not set
    CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0
    CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y
    # CONFIG_DRM_TILCDC is not set
    # CONFIG_DRM_QXL is not set
    # CONFIG_DRM_VIRTIO_GPU is not set
    # CONFIG_DRM_MSM is not set
    # CONFIG_DRM_FSL_DCU is not set
    # CONFIG_DRM_TEGRA is not set
    # CONFIG_DRM_STM is not set
    CONFIG_DRM_PANEL=y
    # Display Panels
    # CONFIG_DRM_PANEL_ABT_Y030XX067A is not set
    # CONFIG_DRM_PANEL_ARM_VERSATILE is not set
    # CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596 is not set
    # CONFIG_DRM_PANEL_BOE_BF060Y8M_AJ0 is not set
    # CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set
    # CONFIG_DRM_PANEL_BOE_TV101WUM_NL6 is not set
    # CONFIG_DRM_PANEL_DSI_CM is not set
    CONFIG_DRM_PANEL_LVDS=m
    CONFIG_DRM_PANEL_SIMPLE=y
    CONFIG_DRM_PANEL_EDP=y
    # CONFIG_DRM_PANEL_EBBG_FT8719 is not set
    # CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set
    # CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02 is not set
    # CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set
    # CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
    # CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set
    # CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
    # CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set
    # CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
    # CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
    # CONFIG_DRM_PANEL_JDI_R63452 is not set
    # CONFIG_DRM_PANEL_KHADAS_TS050 is not set
    # CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
    # CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set
    # CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
    # CONFIG_DRM_PANEL_LG_LB035Q02 is not set
    # CONFIG_DRM_PANEL_LG_LG4573 is not set
    # CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set
    # CONFIG_DRM_PANEL_NEWVISION_NV3052C is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT35510 is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT35560 is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT35950 is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT36672A is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set
    # CONFIG_DRM_PANEL_MANTIX_MLAF057WE51 is not set
    # CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
    # CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
    # CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set
    # CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
    # CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set
    # CONFIG_DRM_PANEL_RAYDIUM_RM67191 is not set
    # CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
    # CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6D27A1 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_SOFEF00 is not set
    # CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
    CONFIG_DRM_PANEL_SHARP_LQ101R1SX01=m
    # CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set
    # CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
    # CONFIG_DRM_PANEL_SHARP_LS060T1SX01 is not set
    # CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
    # CONFIG_DRM_PANEL_SITRONIX_ST7703 is not set
    # CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
    # CONFIG_DRM_PANEL_SONY_ACX565AKM is not set
    # CONFIG_DRM_PANEL_SONY_TULIP_TRULY_NT35521 is not set
    # CONFIG_DRM_PANEL_TDO_TL070WSH30 is not set
    # CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set
    # CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set
    # CONFIG_DRM_PANEL_TPO_TPG110 is not set
    # CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set
    # CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set
    # CONFIG_DRM_PANEL_WIDECHIPS_WS2401 is not set
    # CONFIG_DRM_PANEL_XINPENG_XPP055C272 is not set
    # end of Display Panels
    CONFIG_DRM_BRIDGE=y
    CONFIG_DRM_PANEL_BRIDGE=y
    # Display Interface Bridges
    # CONFIG_DRM_CHIPONE_ICN6211 is not set
    # CONFIG_DRM_CHRONTEL_CH7033 is not set
    # CONFIG_DRM_CROS_EC_ANX7688 is not set
    CONFIG_DRM_DISPLAY_CONNECTOR=m
    # CONFIG_DRM_FSL_LDB is not set
    # CONFIG_DRM_ITE_IT6505 is not set
    # CONFIG_DRM_LONTIUM_LT8912B is not set
    # CONFIG_DRM_LONTIUM_LT9211 is not set
    # CONFIG_DRM_LONTIUM_LT9611 is not set
    # CONFIG_DRM_LONTIUM_LT9611UXC is not set
    # CONFIG_DRM_ITE_IT66121 is not set
    CONFIG_DRM_LVDS_CODEC=m
    # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
    # CONFIG_DRM_NWL_MIPI_DSI is not set
    # CONFIG_DRM_NXP_PTN3460 is not set
    # CONFIG_DRM_PARADE_PS8622 is not set
    # CONFIG_DRM_PARADE_PS8640 is not set
    # CONFIG_DRM_SIL_SII8620 is not set
    CONFIG_DRM_SII902X=m
    # CONFIG_DRM_SII9234 is not set
    CONFIG_DRM_SIMPLE_BRIDGE=m
    # CONFIG_DRM_THINE_THC63LVD1024 is not set
    # CONFIG_DRM_TOSHIBA_TC358762 is not set
    # CONFIG_DRM_TOSHIBA_TC358764 is not set
    # CONFIG_DRM_TOSHIBA_TC358767 is not set
    CONFIG_DRM_TOSHIBA_TC358768=m
    # CONFIG_DRM_TOSHIBA_TC358775 is not set
    # CONFIG_DRM_TI_DLPC3433 is not set
    CONFIG_DRM_TI_TFP410=m
    # CONFIG_DRM_TI_SN65DSI83 is not set
    # CONFIG_DRM_TI_SN65DSI86 is not set
    CONFIG_DRM_TI_TPD12S015=m
    # CONFIG_DRM_ANALOGIX_ANX6345 is not set
    # CONFIG_DRM_ANALOGIX_ANX78XX is not set
    # CONFIG_DRM_ANALOGIX_ANX7625 is not set
    # CONFIG_DRM_I2C_ADV7511 is not set
    # CONFIG_DRM_CDNS_DSI is not set
    # CONFIG_DRM_CDNS_MHDP8546 is not set
    # CONFIG_DRM_IMX8QM_LDB is not set
    # CONFIG_DRM_IMX8QXP_LDB is not set
    # CONFIG_DRM_IMX8QXP_PIXEL_COMBINER is not set
    # CONFIG_DRM_IMX8QXP_PIXEL_LINK_TO_DPI is not set
    CONFIG_DRM_DW_HDMI=m
    # CONFIG_DRM_DW_HDMI_AHB_AUDIO is not set
    # CONFIG_DRM_DW_HDMI_I2S_AUDIO is not set
    # CONFIG_DRM_DW_HDMI_GP_AUDIO is not set
    # CONFIG_DRM_DW_HDMI_CEC is not set
    # end of Display Interface Bridges
    # CONFIG_DRM_STI is not set
    CONFIG_DRM_IMX=m
    CONFIG_DRM_IMX_PARALLEL_DISPLAY=m
    CONFIG_DRM_IMX_TVE=m
    CONFIG_DRM_IMX_LDB=m
    CONFIG_DRM_IMX_HDMI=m
    # CONFIG_DRM_INGENIC is not set
    # CONFIG_DRM_V3D is not set
    # CONFIG_DRM_VC4 is not set
    # CONFIG_DRM_ETNAVIV is not set
    # CONFIG_DRM_HISI_HIBMC is not set
    # CONFIG_DRM_LOGICVC is not set
    # CONFIG_DRM_MXSFB is not set
    # CONFIG_DRM_IMX_LCDIF is not set
    # CONFIG_DRM_MESON is not set
    # CONFIG_DRM_ARCPGU is not set
    # CONFIG_DRM_BOCHS is not set
    # CONFIG_DRM_CIRRUS_QEMU is not set
    # CONFIG_DRM_GM12U320 is not set
    # CONFIG_DRM_PANEL_MIPI_DBI is not set
    # CONFIG_DRM_SIMPLEDRM is not set
    # CONFIG_TINYDRM_HX8357D is not set
    # CONFIG_TINYDRM_ILI9163 is not set
    # CONFIG_TINYDRM_ILI9225 is not set
    # CONFIG_TINYDRM_ILI9341 is not set
    # CONFIG_TINYDRM_ILI9486 is not set
    # CONFIG_TINYDRM_MI0283QT is not set
    # CONFIG_TINYDRM_REPAPER is not set
    # CONFIG_TINYDRM_ST7586 is not set
    # CONFIG_TINYDRM_ST7735R is not set
    # CONFIG_DRM_PL111 is not set
    # CONFIG_DRM_TVE200 is not set
    # CONFIG_DRM_LIMA is not set
    # CONFIG_DRM_PANFROST is not set
    # CONFIG_DRM_ASPEED_GFX is not set
    # CONFIG_DRM_MCDE is not set
    # CONFIG_DRM_TIDSS is not set
    # CONFIG_DRM_GUD is not set
    # CONFIG_DRM_SSD130X is not set
    # CONFIG_DRM_SPRD is not set
    CONFIG_DRM_LEGACY=y
    # CONFIG_DRM_TDFX is not set
    # CONFIG_DRM_R128 is not set
    # CONFIG_DRM_MGA is not set
    # CONFIG_DRM_VIA is not set
    # CONFIG_DRM_SAVAGE is not set
    CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y
    CONFIG_DRM_NOMODESET=y
    # Frame buffer Devices
    CONFIG_FB_CMDLINE=y
    CONFIG_FB_NOTIFY=y
    CONFIG_FB=y
    # CONFIG_FIRMWARE_EDID is not set
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    CONFIG_FB_SYS_FILLRECT=y
    CONFIG_FB_SYS_COPYAREA=y
    CONFIG_FB_SYS_IMAGEBLIT=y
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    CONFIG_FB_SYS_FOPS=y
    CONFIG_FB_DEFERRED_IO=y
    CONFIG_FB_BACKLIGHT=y
    CONFIG_FB_MODE_HELPERS=y
    # CONFIG_FB_TILEBLITTING is not set
    # Frame buffer hardware drivers
    # CONFIG_FB_CIRRUS is not set
    # CONFIG_FB_PM2 is not set
    # CONFIG_FB_ARMCLCD is not set
    # CONFIG_FB_CLPS711X is not set
    # CONFIG_FB_IMX is not set
    # CONFIG_FB_CYBER2000 is not set
    # CONFIG_FB_ARC is not set
    # CONFIG_FB_CONTROL is not set
    # CONFIG_FB_ASILIANT is not set
    # CONFIG_FB_IMSTT is not set
    # CONFIG_FB_EFI is not set
    # CONFIG_FB_GBE is not set
    # CONFIG_FB_PVR2 is not set
    # CONFIG_FB_OPENCORES is not set
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_ATMEL is not set
    # CONFIG_FB_NVIDIA is not set
    # CONFIG_FB_RIVA is not set
    # CONFIG_FB_I740 is not set
    # CONFIG_FB_MATROX is not set
    # CONFIG_FB_RADEON is not set
    # CONFIG_FB_ATY128 is not set
    # CONFIG_FB_ATY is not set
    # CONFIG_FB_S3 is not set
    # CONFIG_FB_SAVAGE is not set
    # CONFIG_FB_SIS is not set
    # CONFIG_FB_VIA is not set
    # CONFIG_FB_NEOMAGIC is not set
    # CONFIG_FB_KYRO is not set
    # CONFIG_FB_3DFX is not set
    # CONFIG_FB_VOODOO1 is not set
    # CONFIG_FB_VT8623 is not set
    # CONFIG_FB_TRIDENT is not set
    # CONFIG_FB_ARK is not set
    # CONFIG_FB_PM3 is not set
    # CONFIG_FB_CARMINE is not set
    CONFIG_FB_WM8505=y
    # CONFIG_FB_WMT_GE_ROPS is not set
    # CONFIG_FB_PXA168 is not set
    # CONFIG_FB_W100 is not set
    CONFIG_FB_SH_MOBILE_LCDC=y
    # CONFIG_FB_TMIO is not set
    # CONFIG_FB_S3C is not set
    # CONFIG_FB_SMSCUFX is not set
    # CONFIG_FB_UDL is not set
    # CONFIG_FB_IBM_GXT4500 is not set
    # CONFIG_FB_GOLDFISH is not set
    # CONFIG_FB_DA8XX is not set
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    # CONFIG_FB_MB862XX is not set
    # CONFIG_FB_BROADSHEET is not set
    # CONFIG_FB_SIMPLE is not set
    # CONFIG_FB_SSD1307 is not set
    # CONFIG_FB_SM712 is not set
    # CONFIG_FB_OMAP is not set
    # CONFIG_MMP_DISP is not set
    # end of Frame buffer Devices
    # Backlight & LCD device support
    # CONFIG_LCD_CLASS_DEVICE is not set
    CONFIG_BACKLIGHT_CLASS_DEVICE=y
    # CONFIG_BACKLIGHT_KTD253 is not set
    # CONFIG_BACKLIGHT_OMAP1 is not set
    CONFIG_BACKLIGHT_PWM=y
    # CONFIG_BACKLIGHT_QCOM_WLED is not set
    # CONFIG_BACKLIGHT_ADP8860 is not set
    # CONFIG_BACKLIGHT_ADP8870 is not set
    # CONFIG_BACKLIGHT_LM3630A is not set
    # CONFIG_BACKLIGHT_LM3639 is not set
    # CONFIG_BACKLIGHT_LP855X is not set
    # CONFIG_BACKLIGHT_PANDORA is not set
    # CONFIG_BACKLIGHT_TPS65217 is not set
    CONFIG_BACKLIGHT_GPIO=y
    # CONFIG_BACKLIGHT_LV5207LP is not set
    # CONFIG_BACKLIGHT_BD6107 is not set
    # CONFIG_BACKLIGHT_ARCXCNN is not set
    # CONFIG_BACKLIGHT_LED is not set
    # end of Backlight & LCD device support
    CONFIG_VIDEOMODE_HELPERS=y
    CONFIG_HDMI=y
    # Console display driver support
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE=y
    # CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION is not set
    CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
    # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
    # CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
    # end of Console display driver support
    # CONFIG_LOGO is not set
    # end of Graphics support
    CONFIG_SOUND=m
    CONFIG_SND=m
    CONFIG_SND_TIMER=m
    CONFIG_SND_PCM=m
    CONFIG_SND_PCM_ELD=y
    CONFIG_SND_PCM_IEC958=y
    CONFIG_SND_DMAENGINE_PCM=m
    CONFIG_SND_HWDEP=m
    CONFIG_SND_RAWMIDI=m
    CONFIG_SND_JACK=y
    CONFIG_SND_JACK_INPUT_DEV=y
    # CONFIG_SND_OSSEMUL is not set
    CONFIG_SND_PCM_TIMER=y
    # CONFIG_SND_HRTIMER is not set
    CONFIG_SND_DYNAMIC_MINORS=y
    CONFIG_SND_MAX_CARDS=32
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_PROC_FS=y
    CONFIG_SND_VERBOSE_PROCFS=y
    # CONFIG_SND_VERBOSE_PRINTK is not set
    CONFIG_SND_CTL_FAST_LOOKUP=y
    # CONFIG_SND_DEBUG is not set
    # CONFIG_SND_CTL_INPUT_VALIDATION is not set
    CONFIG_SND_VMASTER=y
    # CONFIG_SND_SEQUENCER is not set
    CONFIG_SND_AC97_CODEC=m
    CONFIG_SND_DRIVERS=y
    # CONFIG_SND_DUMMY is not set
    # CONFIG_SND_ALOOP is not set
    # CONFIG_SND_MTPAV is not set
    # CONFIG_SND_SERIAL_U16550 is not set
    # CONFIG_SND_SERIAL_GENERIC is not set
    # CONFIG_SND_MPU401 is not set
    # CONFIG_SND_AC97_POWER_SAVE is not set
    CONFIG_SND_PCI=y
    # CONFIG_SND_AD1889 is not set
    # CONFIG_SND_ATIIXP is not set
    # CONFIG_SND_ATIIXP_MODEM is not set
    # CONFIG_SND_AU8810 is not set
    # CONFIG_SND_AU8820 is not set
    # CONFIG_SND_AU8830 is not set
    # CONFIG_SND_AW2 is not set
    # CONFIG_SND_BT87X is not set
    # CONFIG_SND_CA0106 is not set
    # CONFIG_SND_CMIPCI is not set
    # CONFIG_SND_OXYGEN is not set
    # CONFIG_SND_CS4281 is not set
    # CONFIG_SND_CS46XX is not set
    # CONFIG_SND_CS5535AUDIO is not set
    # CONFIG_SND_CTXFI is not set
    # CONFIG_SND_DARLA20 is not set
    # CONFIG_SND_GINA20 is not set
    # CONFIG_SND_LAYLA20 is not set
    # CONFIG_SND_DARLA24 is not set
    # CONFIG_SND_GINA24 is not set
    # CONFIG_SND_LAYLA24 is not set
    # CONFIG_SND_MONA is not set
    # CONFIG_SND_MIA is not set
    # CONFIG_SND_ECHO3G is not set
    # CONFIG_SND_INDIGO is not set
    # CONFIG_SND_INDIGOIO is not set
    # CONFIG_SND_INDIGODJ is not set
    # CONFIG_SND_INDIGOIOX is not set
    # CONFIG_SND_INDIGODJX is not set
    # CONFIG_SND_ENS1370 is not set
    # CONFIG_SND_ENS1371 is not set
    # CONFIG_SND_FM801 is not set
    # CONFIG_SND_HDSP is not set
    # CONFIG_SND_HDSPM is not set
    # CONFIG_SND_ICE1724 is not set
    # CONFIG_SND_INTEL8X0 is not set
    # CONFIG_SND_INTEL8X0M is not set
    # CONFIG_SND_KORG1212 is not set
    # CONFIG_SND_LOLA is not set
    # CONFIG_SND_LX6464ES is not set
    # CONFIG_SND_MIXART is not set
    # CONFIG_SND_NM256 is not set
    # CONFIG_SND_PCXHR is not set
    # CONFIG_SND_RIPTIDE is not set
    # CONFIG_SND_RME32 is not set
    # CONFIG_SND_RME96 is not set
    # CONFIG_SND_RME9652 is not set
    # CONFIG_SND_SE6X is not set
    # CONFIG_SND_VIA82XX is not set
    # CONFIG_SND_VIA82XX_MODEM is not set
    # CONFIG_SND_VIRTUOSO is not set
    # CONFIG_SND_VX222 is not set
    # CONFIG_SND_YMFPCI is not set
    # HD-Audio
    # CONFIG_SND_HDA_INTEL is not set
    # end of HD-Audio
    CONFIG_SND_HDA_PREALLOC_SIZE=64
    # CONFIG_SND_ARM is not set
    # CONFIG_SND_SPI is not set
    CONFIG_SND_USB=y
    CONFIG_SND_USB_AUDIO=m
    CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y
    # CONFIG_SND_USB_UA101 is not set
    # CONFIG_SND_USB_CAIAQ is not set
    # CONFIG_SND_USB_US122L is not set
    # CONFIG_SND_USB_6FIRE is not set
    # CONFIG_SND_USB_HIFACE is not set
    # CONFIG_SND_BCD2000 is not set
    # CONFIG_SND_USB_POD is not set
    # CONFIG_SND_USB_PODHD is not set
    # CONFIG_SND_USB_TONEPORT is not set
    # CONFIG_SND_USB_VARIAX is not set
    CONFIG_SND_SOC=m
    CONFIG_SND_SOC_AC97_BUS=y
    CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
    # CONFIG_SND_SOC_ADI is not set
    # CONFIG_SND_SOC_AMD_ACP is not set
    # CONFIG_SND_AMD_ACP_CONFIG is not set
    # CONFIG_SND_SOC_APPLE_MCA is not set
    # CONFIG_SND_ATMEL_SOC is not set
    # CONFIG_SND_BCM2835_SOC_I2S is not set
    # CONFIG_SND_SOC_CYGNUS is not set
    # CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
    # CONFIG_SND_EP93XX_SOC is not set
    # CONFIG_SND_DESIGNWARE_I2S is not set
    # SoC Audio for Freescale CPUs
    # Common SoC Audio options for Freescale CPUs:
    # CONFIG_SND_SOC_FSL_ASRC is not set
    # CONFIG_SND_SOC_FSL_SAI is not set
    # CONFIG_SND_SOC_FSL_AUDMIX is not set
    CONFIG_SND_SOC_FSL_SSI=m
    # CONFIG_SND_SOC_FSL_SPDIF is not set
    CONFIG_SND_SOC_FSL_ESAI=m
    # CONFIG_SND_SOC_FSL_MICFIL is not set
    # CONFIG_SND_SOC_FSL_XCVR is not set
    # CONFIG_SND_SOC_FSL_AUD2HTX is not set
    # CONFIG_SND_SOC_FSL_RPMSG is not set
    CONFIG_SND_SOC_IMX_AUDMUX=m
    # CONFIG_SND_IMX_SOC is not set
    # end of SoC Audio for Freescale CPUs
    # CONFIG_SND_I2S_HI6210_I2S is not set
    # CONFIG_SND_JZ4740_SOC_I2S is not set
    # CONFIG_SND_KIRKWOOD_SOC is not set
    # CONFIG_SND_SOC_IMG is not set
    CONFIG_SND_SOC_INTEL_SST_TOPLEVEL=y
    # CONFIG_SND_SOC_INTEL_KEEMBAY is not set
    # CONFIG_SND_SOC_INTEL_AVS is not set
    CONFIG_SND_SOC_INTEL_MACH=y
    # CONFIG_SND_SOC_INTEL_USER_FRIENDLY_LONG_NAMES is not set
    # CONFIG_SND_SOC_MT8186 is not set
    # CONFIG_SND_SOC_MTK_BTCVSD is not set
    # CONFIG_SND_SOC_MT8195 is not set
    # ASoC support for Amlogic platforms
    # CONFIG_SND_MESON_AIU is not set
    # CONFIG_SND_MESON_AXG_FRDDR is not set
    # CONFIG_SND_MESON_AXG_TODDR is not set
    # CONFIG_SND_MESON_AXG_TDMIN is not set
    # CONFIG_SND_MESON_AXG_TDMOUT is not set
    # CONFIG_SND_MESON_AXG_SOUND_CARD is not set
    # CONFIG_SND_MESON_AXG_SPDIFOUT is not set
    # CONFIG_SND_MESON_AXG_SPDIFIN is not set
    # CONFIG_SND_MESON_AXG_PDM is not set
    # CONFIG_SND_MESON_GX_SOUND_CARD is not set
    # CONFIG_SND_MESON_G12A_TOACODEC is not set
    # CONFIG_SND_MESON_G12A_TOHDMITX is not set
    # CONFIG_SND_SOC_MESON_T9015 is not set
    # end of ASoC support for Amlogic platforms
    # CONFIG_SND_MXS_SOC is not set
    # CONFIG_SND_PXA2XX_SOC is not set
    # CONFIG_SND_SOC_QCOM is not set
    # CONFIG_SND_SOC_ROCKCHIP is not set
    # CONFIG_SND_SOC_SAMSUNG is not set
    # SoC Audio support for Renesas SoCs
    # CONFIG_SND_SOC_SH4_FSI is not set
    # CONFIG_SND_SOC_RCAR is not set
    # CONFIG_SND_SOC_RZ is not set
    # end of SoC Audio support for Renesas SoCs
    # CONFIG_SND_SOC_SOF_TOPLEVEL is not set
    # CONFIG_SND_SOC_SPRD is not set
    # CONFIG_SND_SOC_STI is not set
    # STMicroelectronics STM32 SOC audio support
    # CONFIG_SND_SOC_STM32_SAI is not set
    # CONFIG_SND_SOC_STM32_I2S is not set
    # CONFIG_SND_SOC_STM32_SPDIFRX is not set
    # end of STMicroelectronics STM32 SOC audio support
    # Allwinner SoC Audio support
    # CONFIG_SND_SUN4I_CODEC is not set
    # CONFIG_SND_SUN8I_CODEC is not set
    # CONFIG_SND_SUN8I_CODEC_ANALOG is not set
    # CONFIG_SND_SUN50I_CODEC_ANALOG is not set
    # CONFIG_SND_SUN4I_I2S is not set
    # CONFIG_SND_SUN4I_SPDIF is not set
    # CONFIG_SND_SUN50I_DMIC is not set
    # end of Allwinner SoC Audio support
    # CONFIG_SND_SOC_TEGRA is not set
    # Audio support for Texas Instruments SoCs
    CONFIG_SND_SOC_TI_EDMA_PCM=m
    CONFIG_SND_SOC_TI_SDMA_PCM=m
    CONFIG_SND_SOC_TI_UDMA_PCM=m
    # Texas Instruments DAI support for:
    # CONFIG_SND_SOC_DAVINCI_ASP is not set
    CONFIG_SND_SOC_DAVINCI_MCASP=m
    # CONFIG_SND_SOC_DAVINCI_VCIF is not set
    # CONFIG_SND_SOC_OMAP_DMIC is not set
    # CONFIG_SND_SOC_OMAP_MCBSP is not set
    # CONFIG_SND_SOC_OMAP_MCPDM is not set
    # Audio support for boards with Texas Instruments SoCs
    # CONFIG_SND_SOC_NOKIA_RX51 is not set
    # CONFIG_SND_SOC_OMAP3_PANDORA is not set
    # CONFIG_SND_SOC_OMAP3_TWL4030 is not set
    # CONFIG_SND_SOC_OMAP_HDMI is not set
    # CONFIG_SND_SOC_J721E_EVM is not set
    # end of Audio support for Texas Instruments SoCs
    # CONFIG_SND_SOC_UNIPHIER is not set
    # CONFIG_SND_SOC_XILINX_I2S is not set
    # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
    # CONFIG_SND_SOC_XILINX_SPDIF is not set
    # CONFIG_SND_SOC_XTFPGA_I2S is not set
    CONFIG_SND_SOC_I2C_AND_SPI=m
    # CODEC drivers
    # CONFIG_SND_SOC_ALL_CODECS is not set
    CONFIG_SND_SOC_AC97_CODEC=m
    # CONFIG_SND_SOC_ADAU1372_I2C is not set
    # CONFIG_SND_SOC_ADAU1372_SPI is not set
    # CONFIG_SND_SOC_ADAU1701 is not set
    # CONFIG_SND_SOC_ADAU1761_I2C is not set
    # CONFIG_SND_SOC_ADAU1761_SPI is not set
    # CONFIG_SND_SOC_ADAU7002 is not set
    # CONFIG_SND_SOC_ADAU7118_HW is not set
    # CONFIG_SND_SOC_ADAU7118_I2C is not set
    # CONFIG_SND_SOC_AK4104 is not set
    # CONFIG_SND_SOC_AK4118 is not set
    # CONFIG_SND_SOC_AK4375 is not set
    # CONFIG_SND_SOC_AK4458 is not set
    # CONFIG_SND_SOC_AK4554 is not set
    # CONFIG_SND_SOC_AK4613 is not set
    # CONFIG_SND_SOC_AK4642 is not set
    # CONFIG_SND_SOC_AK5386 is not set
    # CONFIG_SND_SOC_AK5558 is not set
    # CONFIG_SND_SOC_ALC5623 is not set
    # CONFIG_SND_SOC_AW8738 is not set
    # CONFIG_SND_SOC_BD28623 is not set
    # CONFIG_SND_SOC_BT_SCO is not set
    # CONFIG_SND_SOC_CPCAP is not set
    # CONFIG_SND_SOC_CS35L32 is not set
    # CONFIG_SND_SOC_CS35L33 is not set
    # CONFIG_SND_SOC_CS35L34 is not set
    # CONFIG_SND_SOC_CS35L35 is not set
    # CONFIG_SND_SOC_CS35L36 is not set
    # CONFIG_SND_SOC_CS35L41_SPI is not set
    # CONFIG_SND_SOC_CS35L41_I2C is not set
    # CONFIG_SND_SOC_CS35L45_SPI is not set
    # CONFIG_SND_SOC_CS35L45_I2C is not set
    # CONFIG_SND_SOC_CS42L42 is not set
    CONFIG_SND_SOC_CS42L51=m
    CONFIG_SND_SOC_CS42L51_I2C=m
    # CONFIG_SND_SOC_CS42L52 is not set
    # CONFIG_SND_SOC_CS42L56 is not set
    # CONFIG_SND_SOC_CS42L73 is not set
    # CONFIG_SND_SOC_CS42L83 is not set
    # CONFIG_SND_SOC_CS4234 is not set
    # CONFIG_SND_SOC_CS4265 is not set
    # CONFIG_SND_SOC_CS4270 is not set
    # CONFIG_SND_SOC_CS4271_I2C is not set
    # CONFIG_SND_SOC_CS4271_SPI is not set
    # CONFIG_SND_SOC_CS42XX8_I2C is not set
    # CONFIG_SND_SOC_CS43130 is not set
    # CONFIG_SND_SOC_CS4341 is not set
    # CONFIG_SND_SOC_CS4349 is not set
    # CONFIG_SND_SOC_CS53L30 is not set
    # CONFIG_SND_SOC_CX2072X is not set
    # CONFIG_SND_SOC_JZ4740_CODEC is not set
    # CONFIG_SND_SOC_JZ4725B_CODEC is not set
    # CONFIG_SND_SOC_JZ4760_CODEC is not set
    # CONFIG_SND_SOC_JZ4770_CODEC is not set
    # CONFIG_SND_SOC_DA7213 is not set
    CONFIG_SND_SOC_DMIC=m
    CONFIG_SND_SOC_HDMI_CODEC=m
    # CONFIG_SND_SOC_ES7134 is not set
    # CONFIG_SND_SOC_ES7241 is not set
    # CONFIG_SND_SOC_ES8316 is not set
    # CONFIG_SND_SOC_ES8326 is not set
    # CONFIG_SND_SOC_ES8328_I2C is not set
    # CONFIG_SND_SOC_ES8328_SPI is not set
    # CONFIG_SND_SOC_GTM601 is not set
    # CONFIG_SND_SOC_HDA is not set
    # CONFIG_SND_SOC_ICS43432 is not set
    # CONFIG_SND_SOC_INNO_RK3036 is not set
    # CONFIG_SND_SOC_LOCHNAGAR_SC is not set
    # CONFIG_SND_SOC_MAX98088 is not set
    # CONFIG_SND_SOC_MAX98357A is not set
    # CONFIG_SND_SOC_MAX98504 is not set
    # CONFIG_SND_SOC_MAX9867 is not set
    # CONFIG_SND_SOC_MAX98927 is not set
    # CONFIG_SND_SOC_MAX98520 is not set
    # CONFIG_SND_SOC_MAX98373_I2C is not set
    # CONFIG_SND_SOC_MAX98390 is not set
    # CONFIG_SND_SOC_MAX98396 is not set
    # CONFIG_SND_SOC_MAX9860 is not set
    CONFIG_SND_SOC_MSM8916_WCD_ANALOG=m
    CONFIG_SND_SOC_MSM8916_WCD_DIGITAL=m
    # CONFIG_SND_SOC_PCM1681 is not set
    # CONFIG_SND_SOC_PCM1789_I2C is not set
    # CONFIG_SND_SOC_PCM179X_I2C is not set
    # CONFIG_SND_SOC_PCM179X_SPI is not set
    # CONFIG_SND_SOC_PCM186X_I2C is not set
    # CONFIG_SND_SOC_PCM186X_SPI is not set
    # CONFIG_SND_SOC_PCM3060_I2C is not set
    # CONFIG_SND_SOC_PCM3060_SPI is not set
    # CONFIG_SND_SOC_PCM3168A_I2C is not set
    # CONFIG_SND_SOC_PCM3168A_SPI is not set
    # CONFIG_SND_SOC_PCM5102A is not set
    # CONFIG_SND_SOC_PCM512x_I2C is not set
    # CONFIG_SND_SOC_PCM512x_SPI is not set
    # CONFIG_SND_SOC_RK3328 is not set
    # CONFIG_SND_SOC_RK817 is not set
    CONFIG_SND_SOC_RL6231=m
    # CONFIG_SND_SOC_RT5616 is not set
    CONFIG_SND_SOC_RT5631=m
    CONFIG_SND_SOC_RT5640=m
    # CONFIG_SND_SOC_RT5659 is not set
    # CONFIG_SND_SOC_RT9120 is not set
    # CONFIG_SND_SOC_SGTL5000 is not set
    # CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
    # CONFIG_SND_SOC_SIMPLE_MUX is not set
    CONFIG_SND_SOC_SPDIF=m
    # CONFIG_SND_SOC_SRC4XXX_I2C is not set
    # CONFIG_SND_SOC_SSM2305 is not set
    # CONFIG_SND_SOC_SSM2518 is not set
    # CONFIG_SND_SOC_SSM2602_SPI is not set
    # CONFIG_SND_SOC_SSM2602_I2C is not set
    # CONFIG_SND_SOC_SSM4567 is not set
    # CONFIG_SND_SOC_STA32X is not set
    # CONFIG_SND_SOC_STA350 is not set
    # CONFIG_SND_SOC_STI_SAS is not set
    # CONFIG_SND_SOC_TAS2552 is not set
    # CONFIG_SND_SOC_TAS2562 is not set
    # CONFIG_SND_SOC_TAS2764 is not set
    # CONFIG_SND_SOC_TAS2770 is not set
    # CONFIG_SND_SOC_TAS2780 is not set
    # CONFIG_SND_SOC_TAS5086 is not set
    # CONFIG_SND_SOC_TAS571X is not set
    # CONFIG_SND_SOC_TAS5720 is not set
    # CONFIG_SND_SOC_TAS5805M is not set
    # CONFIG_SND_SOC_TAS6424 is not set
    # CONFIG_SND_SOC_TDA7419 is not set
    # CONFIG_SND_SOC_TFA9879 is not set
    # CONFIG_SND_SOC_TFA989X is not set
    # CONFIG_SND_SOC_TLV320ADC3XXX is not set
    CONFIG_SND_SOC_TLV320AIC23=m
    CONFIG_SND_SOC_TLV320AIC23_I2C=m
    # CONFIG_SND_SOC_TLV320AIC23_SPI is not set
    CONFIG_SND_SOC_TLV320AIC31XX=m
    # CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set
    # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
    CONFIG_SND_SOC_TLV320AIC3X=m
    CONFIG_SND_SOC_TLV320AIC3X_I2C=m
    # CONFIG_SND_SOC_TLV320AIC3X_SPI is not set
    # CONFIG_SND_SOC_TLV320ADCX140 is not set
    CONFIG_SND_SOC_TS3A227E=m
    # CONFIG_SND_SOC_TSCS42XX is not set
    # CONFIG_SND_SOC_TSCS454 is not set
    # CONFIG_SND_SOC_UDA1334 is not set
    # CONFIG_SND_SOC_WM8510 is not set
    # CONFIG_SND_SOC_WM8523 is not set
    # CONFIG_SND_SOC_WM8524 is not set
    # CONFIG_SND_SOC_WM8580 is not set
    # CONFIG_SND_SOC_WM8711 is not set
    # CONFIG_SND_SOC_WM8728 is not set
    # CONFIG_SND_SOC_WM8731_I2C is not set
    # CONFIG_SND_SOC_WM8731_SPI is not set
    # CONFIG_SND_SOC_WM8737 is not set
    # CONFIG_SND_SOC_WM8741 is not set
    # CONFIG_SND_SOC_WM8750 is not set
    CONFIG_SND_SOC_WM8753=m
    # CONFIG_SND_SOC_WM8770 is not set
    # CONFIG_SND_SOC_WM8776 is not set
    # CONFIG_SND_SOC_WM8782 is not set
    # CONFIG_SND_SOC_WM8804_I2C is not set
    # CONFIG_SND_SOC_WM8804_SPI is not set
    CONFIG_SND_SOC_WM8903=m
    CONFIG_SND_SOC_WM8904=m
    # CONFIG_SND_SOC_WM8940 is not set
    # CONFIG_SND_SOC_WM8960 is not set
    # CONFIG_SND_SOC_WM8962 is not set
    # CONFIG_SND_SOC_WM8974 is not set
    # CONFIG_SND_SOC_WM8978 is not set
    # CONFIG_SND_SOC_WM8985 is not set
    # CONFIG_SND_SOC_ZL38060 is not set
    # CONFIG_SND_SOC_MAX9759 is not set
    # CONFIG_SND_SOC_MT6351 is not set
    # CONFIG_SND_SOC_MT6358 is not set
    # CONFIG_SND_SOC_MT6660 is not set
    # CONFIG_SND_SOC_NAU8315 is not set
    # CONFIG_SND_SOC_NAU8540 is not set
    # CONFIG_SND_SOC_NAU8810 is not set
    # CONFIG_SND_SOC_NAU8821 is not set
    # CONFIG_SND_SOC_NAU8822 is not set
    # CONFIG_SND_SOC_NAU8824 is not set
    # CONFIG_SND_SOC_TPA6130A2 is not set
    # CONFIG_SND_SOC_LPASS_WSA_MACRO is not set
    # CONFIG_SND_SOC_LPASS_VA_MACRO is not set
    # CONFIG_SND_SOC_LPASS_RX_MACRO is not set
    # CONFIG_SND_SOC_LPASS_TX_MACRO is not set
    # end of CODEC drivers
    CONFIG_SND_SIMPLE_CARD_UTILS=m
    CONFIG_SND_SIMPLE_CARD=m
    CONFIG_SND_AUDIO_GRAPH_CARD=m
    # CONFIG_SND_AUDIO_GRAPH_CARD2 is not set
    # CONFIG_SND_TEST_COMPONENT is not set
    # CONFIG_SND_VIRTIO is not set
    CONFIG_AC97_BUS=m
    # HID support
    CONFIG_HID=y
    # CONFIG_HID_BATTERY_STRENGTH is not set
    # CONFIG_HIDRAW is not set
    # CONFIG_UHID is not set
    CONFIG_HID_GENERIC=y
    # Special HID drivers
    # CONFIG_HID_A4TECH is not set
    # CONFIG_HID_ACCUTOUCH is not set
    # CONFIG_HID_ACRUX is not set
    # CONFIG_HID_APPLE is not set
    # CONFIG_HID_APPLEIR is not set
    # CONFIG_HID_ASUS is not set
    # CONFIG_HID_AUREAL is not set
    # CONFIG_HID_BELKIN is not set
    # CONFIG_HID_BETOP_FF is not set
    # CONFIG_HID_BIGBEN_FF is not set
    # CONFIG_HID_CHERRY is not set
    # CONFIG_HID_CHICONY is not set
    # CONFIG_HID_CORSAIR is not set
    # CONFIG_HID_COUGAR is not set
    # CONFIG_HID_MACALLY is not set
    # CONFIG_HID_PRODIKEYS is not set
    # CONFIG_HID_CMEDIA is not set
    # CONFIG_HID_CREATIVE_SB0540 is not set
    # CONFIG_HID_CYPRESS is not set
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EMS_FF is not set
    # CONFIG_HID_ELAN is not set
    # CONFIG_HID_ELECOM is not set
    # CONFIG_HID_ELO is not set
    # CONFIG_HID_EZKEY is not set
    # CONFIG_HID_GEMBIRD is not set
    # CONFIG_HID_GFRM is not set
    # CONFIG_HID_GLORIOUS is not set
    # CONFIG_HID_HOLTEK is not set
    # CONFIG_HID_VIVALDI is not set
    # CONFIG_HID_GT683R is not set
    # CONFIG_HID_KEYTOUCH is not set
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_UCLOGIC is not set
    # CONFIG_HID_WALTOP is not set
    # CONFIG_HID_VIEWSONIC is not set
    # CONFIG_HID_VRC2 is not set
    # CONFIG_HID_XIAOMI is not set
    # CONFIG_HID_GYRATION is not set
    # CONFIG_HID_ICADE is not set
    # CONFIG_HID_ITE is not set
    # CONFIG_HID_JABRA is not set
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    # CONFIG_HID_LCPOWER is not set
    # CONFIG_HID_LED is not set
    # CONFIG_HID_LENOVO is not set
    # CONFIG_HID_LETSKETCH is not set
    # CONFIG_HID_LOGITECH is not set
    # CONFIG_HID_MAGICMOUSE is not set
    # CONFIG_HID_MALTRON is not set
    # CONFIG_HID_MAYFLASH is not set
    # CONFIG_HID_MEGAWORLD_FF is not set
    # CONFIG_HID_REDRAGON is not set
    # CONFIG_HID_MICROSOFT is not set
    # CONFIG_HID_MONTEREY is not set
    # CONFIG_HID_MULTITOUCH is not set
    # CONFIG_HID_NINTENDO is not set
    # CONFIG_HID_NTI is not set
    # CONFIG_HID_NTRIG is not set
    # CONFIG_HID_ORTEK is not set
    # CONFIG_HID_PANTHERLORD is not set
    # CONFIG_HID_PENMOUNT is not set
    # CONFIG_HID_PETALYNX is not set
    # CONFIG_HID_PICOLCD is not set
    # CONFIG_HID_PLANTRONICS is not set
    # CONFIG_HID_PXRC is not set
    # CONFIG_HID_RAZER is not set
    # CONFIG_HID_PRIMAX is not set
    # CONFIG_HID_RETRODE is not set
    # CONFIG_HID_ROCCAT is not set
    # CONFIG_HID_SAITEK is not set
    # CONFIG_HID_SAMSUNG is not set
    # CONFIG_HID_SEMITEK is not set
    # CONFIG_HID_SIGMAMICRO is not set
    # CONFIG_HID_SONY is not set
    # CONFIG_HID_SPEEDLINK is not set
    # CONFIG_HID_STEAM is not set
    # CONFIG_HID_STEELSERIES is not set
    # CONFIG_HID_SUNPLUS is not set
    # CONFIG_HID_RMI is not set
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    # CONFIG_HID_TIVO is not set
    # CONFIG_HID_TOPSEED is not set
    # CONFIG_HID_TOPRE is not set
    # CONFIG_HID_THINGM is not set
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_UDRAW_PS3 is not set
    # CONFIG_HID_U2FZERO is not set
    # CONFIG_HID_WACOM is not set
    # CONFIG_HID_WIIMOTE is not set
    # CONFIG_HID_XINMO is not set
    # CONFIG_HID_ZEROPLUS is not set
    # CONFIG_HID_ZYDACRON is not set
    # CONFIG_HID_SENSOR_HUB is not set
    # CONFIG_HID_ALPS is not set
    # CONFIG_HID_MCP2221 is not set
    # end of Special HID drivers
    # USB HID support
    CONFIG_USB_HID=y
    # CONFIG_HID_PID is not set
    # CONFIG_USB_HIDDEV is not set
    # end of USB HID support
    # I2C HID support
    # CONFIG_I2C_HID_OF is not set
    # CONFIG_I2C_HID_OF_ELAN is not set
    # CONFIG_I2C_HID_OF_GOODIX is not set
    # end of I2C HID support
    # Intel ISH HID support
    # end of Intel ISH HID support
    # AMD SFH HID Support
    # CONFIG_AMD_SFH_HID is not set
    # end of AMD SFH HID Support
    # end of HID support
    CONFIG_USB_OHCI_LITTLE_ENDIAN=y
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_COMMON=y
    # CONFIG_USB_LED_TRIG is not set
    CONFIG_USB_ULPI_BUS=y
    CONFIG_USB_CONN_GPIO=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB=y
    CONFIG_USB_PCI=y
    # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
    # Miscellaneous USB options
    CONFIG_USB_DEFAULT_PERSIST=y
    # CONFIG_USB_FEW_INIT_RETRIES is not set
    # CONFIG_USB_DYNAMIC_MINORS is not set
    CONFIG_USB_OTG=y
    # CONFIG_USB_OTG_PRODUCTLIST is not set
    # CONFIG_USB_OTG_DISABLE_EXTERNAL_HUB is not set
    # CONFIG_USB_OTG_FSM is not set
    # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
    CONFIG_USB_AUTOSUSPEND_DELAY=2
    # CONFIG_USB_MON is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    CONFIG_USB_XHCI_HCD=y
    # CONFIG_USB_XHCI_DBGCAP is not set
    CONFIG_USB_XHCI_PCI=y
    # CONFIG_USB_XHCI_PCI_RENESAS is not set
    CONFIG_USB_XHCI_PLATFORM=y
    # CONFIG_USB_XHCI_HISTB is not set
    # CONFIG_USB_XHCI_MTK is not set
    # CONFIG_USB_XHCI_MVEBU is not set
    # CONFIG_USB_XHCI_RCAR is not set
    # CONFIG_USB_BRCMSTB is not set
    CONFIG_USB_EHCI_HCD=y
    CONFIG_USB_EHCI_ROOT_HUB_TT=y
    CONFIG_USB_EHCI_TT_NEWSCHED=y
    CONFIG_USB_EHCI_PCI=y
    # CONFIG_USB_EHCI_FSL is not set
    # CONFIG_USB_EHCI_HCD_NPCM7XX is not set
    CONFIG_USB_EHCI_HCD_OMAP=y
    # CONFIG_USB_EHCI_HCD_ORION is not set
    # CONFIG_USB_EHCI_HCD_SPEAR is not set
    # CONFIG_USB_EHCI_HCD_STI is not set
    # CONFIG_USB_EHCI_HCD_AT91 is not set
    # CONFIG_USB_EHCI_SH is not set
    # CONFIG_USB_EHCI_EXYNOS is not set
    # CONFIG_USB_EHCI_MV is not set
    # CONFIG_USB_CNS3XXX_EHCI is not set
    CONFIG_USB_EHCI_HCD_PLATFORM=y
    # CONFIG_USB_OXU210HP_HCD is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_ISP1362_HCD is not set
    # CONFIG_USB_FOTG210_HCD is not set
    # CONFIG_USB_MAX3421_HCD is not set
    CONFIG_USB_OHCI_HCD=y
    # CONFIG_USB_OHCI_HCD_SPEAR is not set
    # CONFIG_USB_OHCI_HCD_STI is not set
    # CONFIG_USB_OHCI_HCD_S3C2410 is not set
    CONFIG_USB_OHCI_HCD_LPC32XX=y
    # CONFIG_USB_OHCI_HCD_AT91 is not set
    # CONFIG_USB_OHCI_HCD_OMAP3 is not set
    # CONFIG_USB_OHCI_HCD_DAVINCI is not set
    CONFIG_USB_OHCI_HCD_PCI=y
    # CONFIG_USB_OHCI_SH is not set
    # CONFIG_USB_OHCI_EXYNOS is not set
    # CONFIG_USB_CNS3XXX_OHCI is not set
    CONFIG_USB_OHCI_HCD_PLATFORM=y
    # CONFIG_USB_UHCI_HCD is not set
    # CONFIG_USB_SL811_HCD is not set
    CONFIG_USB_R8A66597_HCD=y
    # CONFIG_USB_HCD_BCMA is not set
    # CONFIG_USB_HCD_TEST_MODE is not set
    # CONFIG_USB_RENESAS_USBHS is not set
    # USB Device Class drivers
    CONFIG_USB_ACM=y
    # CONFIG_USB_PRINTER is not set
    # CONFIG_USB_WDM is not set
    # CONFIG_USB_TMC is not set
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_REALTEK is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_STORAGE_ENE_UB6250 is not set
    CONFIG_USB_UAS=y
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    # CONFIG_USBIP_CORE is not set
    CONFIG_USB_CDNS_SUPPORT=y
    CONFIG_USB_CDNS3=y
    # CONFIG_USB_CDNS3_GADGET is not set
    # CONFIG_USB_CDNS3_HOST is not set
    CONFIG_USB_CDNS3_TI=y
    CONFIG_USB_CDNS3_IMX=y
    # CONFIG_USB_MTU3 is not set
    CONFIG_USB_MUSB_HDRC=y
    # CONFIG_USB_MUSB_HOST is not set
    # CONFIG_USB_MUSB_GADGET is not set
    CONFIG_USB_MUSB_DUAL_ROLE=y
    # Platform Glue Layer
    CONFIG_USB_MUSB_TUSB6010=m
    CONFIG_USB_MUSB_OMAP2PLUS=y
    CONFIG_USB_MUSB_AM35X=y
    CONFIG_USB_MUSB_DSPS=y
    # CONFIG_USB_MUSB_UX500 is not set
    # CONFIG_USB_MUSB_MEDIATEK is not set
    # CONFIG_USB_MUSB_POLARFIRE_SOC is not set
    # MUSB DMA mode
    # CONFIG_MUSB_PIO_ONLY is not set
    CONFIG_USB_INVENTRA_DMA=y
    CONFIG_USB_TI_CPPI41_DMA=y
    CONFIG_USB_DWC3=y
    # CONFIG_USB_DWC3_ULPI is not set
    # CONFIG_USB_DWC3_HOST is not set
    # CONFIG_USB_DWC3_GADGET is not set
    CONFIG_USB_DWC3_DUAL_ROLE=y
    # Platform Glue Driver Support
    CONFIG_USB_DWC3_OMAP=y
    CONFIG_USB_DWC3_EXYNOS=y
    CONFIG_USB_DWC3_HAPS=m
    CONFIG_USB_DWC3_KEYSTONE=y
    CONFIG_USB_DWC3_MESON_G12A=y
    CONFIG_USB_DWC3_OF_SIMPLE=m
    CONFIG_USB_DWC3_ST=y
    CONFIG_USB_DWC3_QCOM=y
    CONFIG_USB_DWC3_IMX8MP=y
    CONFIG_USB_DWC3_AM62=y
    # CONFIG_USB_DWC2 is not set
    # CONFIG_USB_CHIPIDEA is not set
    CONFIG_USB_ISP1760=y
    CONFIG_USB_ISP1760_HCD=y
    CONFIG_USB_ISP1761_UDC=y
    # CONFIG_USB_ISP1760_HOST_ROLE is not set
    # CONFIG_USB_ISP1760_GADGET_ROLE is not set
    CONFIG_USB_ISP1760_DUAL_ROLE=y
    # USB port drivers
    # CONFIG_USB_SERIAL is not set
    # USB Miscellaneous drivers
    # CONFIG_USB_EMI62 is not set
    # CONFIG_USB_EMI26 is not set
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_LEGOTOWER is not set
    # CONFIG_USB_LCD is not set
    # CONFIG_USB_CYPRESS_CY7C63 is not set
    # CONFIG_USB_CYTHERM is not set
    # CONFIG_USB_IDMOUSE is not set
    # CONFIG_USB_FTDI_ELAN is not set
    # CONFIG_USB_APPLEDISPLAY is not set
    # CONFIG_USB_QCOM_EUD is not set
    # CONFIG_APPLE_MFI_FASTCHARGE is not set
    # CONFIG_USB_SISUSBVGA is not set
    # CONFIG_USB_LD is not set
    # CONFIG_USB_TRANCEVIBRATOR is not set
    # CONFIG_USB_IOWARRIOR is not set
    # CONFIG_USB_TEST is not set
    # CONFIG_USB_EHSET_TEST_FIXTURE is not set
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_YUREX is not set
    # CONFIG_USB_EZUSB_FX2 is not set
    # CONFIG_USB_HUB_USB251XB is not set
    CONFIG_USB_HSIC_USB3503=y
    # CONFIG_USB_HSIC_USB4604 is not set
    # CONFIG_USB_LINK_LAYER_TEST is not set
    # CONFIG_USB_CHAOSKEY is not set
    # CONFIG_BRCM_USB_PINMAP is not set
    CONFIG_USB_ONBOARD_HUB=m
    # USB Physical Layer drivers
    CONFIG_USB_PHY=y
    # CONFIG_ISP1301_OMAP is not set
    # CONFIG_KEYSTONE_USB_PHY is not set
    CONFIG_NOP_USB_XCEIV=y
    CONFIG_AM335X_CONTROL_USB=y
    CONFIG_AM335X_PHY_USB=y
    CONFIG_TWL6030_USB=m
    CONFIG_USB_GPIO_VBUS=y
    CONFIG_USB_ISP1301=y
    # CONFIG_USB_TEGRA_PHY is not set
    CONFIG_USB_ULPI=y
    CONFIG_USB_ULPI_VIEWPORT=y
    # CONFIG_JZ4770_PHY is not set
    # end of USB Physical Layer drivers
    CONFIG_USB_GADGET=y
    # CONFIG_USB_GADGET_DEBUG is not set
    # CONFIG_USB_GADGET_DEBUG_FILES is not set
    # CONFIG_USB_GADGET_DEBUG_FS is not set
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32
    # CONFIG_U_SERIAL_CONSOLE is not set
    # USB Peripheral Controller
    # CONFIG_USB_LPC32XX is not set
    # CONFIG_USB_FUSB300 is not set
    # CONFIG_USB_FOTG210_UDC is not set
    # CONFIG_USB_GR_UDC is not set
    # CONFIG_USB_R8A66597 is not set
    # CONFIG_USB_RENESAS_USB3 is not set
    # CONFIG_USB_PXA27X is not set
    # CONFIG_USB_MV_UDC is not set
    # CONFIG_USB_MV_U3D is not set
    CONFIG_USB_SNP_CORE=y
    CONFIG_USB_SNP_UDC_PLAT=y
    # CONFIG_USB_M66592 is not set
    CONFIG_USB_BDC_UDC=y
    # CONFIG_USB_AMD5536UDC is not set
    # CONFIG_USB_NET2272 is not set
    # CONFIG_USB_NET2280 is not set
    # CONFIG_USB_GOKU is not set
    # CONFIG_USB_EG20T is not set
    # CONFIG_USB_GADGET_XILINX is not set
    # CONFIG_USB_MAX3420_UDC is not set
    # CONFIG_USB_ASPEED_UDC is not set
    # CONFIG_USB_ASPEED_VHUB is not set
    # CONFIG_USB_DUMMY_HCD is not set
    # end of USB Peripheral Controller
    CONFIG_USB_LIBCOMPOSITE=y
    CONFIG_USB_F_ACM=y
    CONFIG_USB_F_SS_LB=y
    CONFIG_USB_U_SERIAL=y
    CONFIG_USB_U_ETHER=y
    CONFIG_USB_U_AUDIO=m
    CONFIG_USB_F_SERIAL=y
    CONFIG_USB_F_OBEX=y
    CONFIG_USB_F_NCM=y
    CONFIG_USB_F_ECM=y
    CONFIG_USB_F_EEM=y
    CONFIG_USB_F_SUBSET=y
    CONFIG_USB_F_RNDIS=y
    CONFIG_USB_F_MASS_STORAGE=y
    CONFIG_USB_F_FS=y
    CONFIG_USB_F_UAC1=m
    CONFIG_USB_F_UAC1_LEGACY=m
    CONFIG_USB_F_UAC2=m
    CONFIG_USB_F_UVC=m
    CONFIG_USB_F_MIDI=m
    CONFIG_USB_F_HID=y
    CONFIG_USB_F_PRINTER=y
    CONFIG_USB_CONFIGFS=y
    CONFIG_USB_CONFIGFS_SERIAL=y
    CONFIG_USB_CONFIGFS_ACM=y
    CONFIG_USB_CONFIGFS_OBEX=y
    CONFIG_USB_CONFIGFS_NCM=y
    CONFIG_USB_CONFIGFS_ECM=y
    CONFIG_USB_CONFIGFS_ECM_SUBSET=y
    CONFIG_USB_CONFIGFS_RNDIS=y
    CONFIG_USB_CONFIGFS_EEM=y
    CONFIG_USB_CONFIGFS_MASS_STORAGE=y
    CONFIG_USB_CONFIGFS_F_LB_SS=y
    CONFIG_USB_CONFIGFS_F_FS=y
    CONFIG_USB_CONFIGFS_F_UAC1=y
    CONFIG_USB_CONFIGFS_F_UAC1_LEGACY=y
    CONFIG_USB_CONFIGFS_F_UAC2=y
    CONFIG_USB_CONFIGFS_F_MIDI=y
    CONFIG_USB_CONFIGFS_F_HID=y
    CONFIG_USB_CONFIGFS_F_UVC=y
    CONFIG_USB_CONFIGFS_F_PRINTER=y
    # USB Gadget precomposed configurations
    CONFIG_USB_ZERO=m
    # CONFIG_USB_ZERO_HNPTEST is not set
    # CONFIG_USB_AUDIO is not set
    CONFIG_USB_ETH=m
    CONFIG_USB_ETH_RNDIS=y
    # CONFIG_USB_ETH_EEM is not set
    CONFIG_USB_G_NCM=m
    # CONFIG_USB_GADGETFS is not set
    # CONFIG_USB_FUNCTIONFS is not set
    CONFIG_USB_MASS_STORAGE=m
    CONFIG_USB_G_SERIAL=m
    # CONFIG_USB_MIDI_GADGET is not set
    # CONFIG_USB_G_PRINTER is not set
    # CONFIG_USB_CDC_COMPOSITE is not set
    # CONFIG_USB_G_ACM_MS is not set
    CONFIG_USB_G_MULTI=m
    CONFIG_USB_G_MULTI_RNDIS=y
    CONFIG_USB_G_MULTI_CDC=y
    # CONFIG_USB_G_HID is not set
    # CONFIG_USB_G_DBGP is not set
    # CONFIG_USB_G_WEBCAM is not set
    # CONFIG_USB_RAW_GADGET is not set
    # end of USB Gadget precomposed configurations
    CONFIG_TYPEC=m
    # CONFIG_TYPEC_TCPM is not set
    # CONFIG_TYPEC_UCSI is not set
    # CONFIG_TYPEC_TPS6598X is not set
    # CONFIG_TYPEC_ANX7411 is not set
    # CONFIG_TYPEC_RT1719 is not set
    # CONFIG_TYPEC_HD3SS3220 is not set
    CONFIG_TYPEC_STUSB160X=m
    # CONFIG_TYPEC_QCOM_PMIC is not set
    # CONFIG_TYPEC_WUSB3801 is not set
    # USB Type-C Multiplexer/DeMultiplexer Switch support
    # CONFIG_TYPEC_MUX_FSA4480 is not set
    # CONFIG_TYPEC_MUX_PI3USB30532 is not set
    # end of USB Type-C Multiplexer/DeMultiplexer Switch support
    # USB Type-C Alternate Mode drivers
    # CONFIG_TYPEC_DP_ALTMODE is not set
    # end of USB Type-C Alternate Mode drivers
    CONFIG_USB_ROLE_SWITCH=y
    CONFIG_MMC=y
    CONFIG_PWRSEQ_EMMC=y
    # CONFIG_PWRSEQ_SD8787 is not set
    CONFIG_PWRSEQ_SIMPLE=y
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_MINORS=16
    # CONFIG_SDIO_UART is not set
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_DEBUG is not set
    # CONFIG_MMC_ARMMMCI is not set
    CONFIG_MMC_SDHCI=y
    CONFIG_MMC_SDHCI_IO_ACCESSORS=y
    # CONFIG_MMC_SDHCI_PCI is not set
    CONFIG_MMC_SDHCI_PLTFM=y
    CONFIG_MMC_SDHCI_OF_ARASAN=y
    # CONFIG_MMC_SDHCI_OF_ASPEED is not set
    CONFIG_MMC_SDHCI_OF_AT91=y
    # CONFIG_MMC_SDHCI_OF_ESDHC is not set
    # CONFIG_MMC_SDHCI_OF_DWCMSHC is not set
    # CONFIG_MMC_SDHCI_OF_SPARX5 is not set
    # CONFIG_MMC_SDHCI_CADENCE is not set
    # CONFIG_MMC_SDHCI_CNS3XXX is not set
    # CONFIG_MMC_SDHCI_ESDHC_IMX is not set
    # CONFIG_MMC_SDHCI_DOVE is not set
    # CONFIG_MMC_SDHCI_TEGRA is not set
    # CONFIG_MMC_SDHCI_S3C is not set
    # CONFIG_MMC_SDHCI_PXAV3 is not set
    # CONFIG_MMC_SDHCI_PXAV2 is not set
    # CONFIG_MMC_SDHCI_SPEAR is not set
    # CONFIG_MMC_SDHCI_BCM_KONA is not set
    # CONFIG_MMC_SDHCI_F_SDH30 is not set
    # CONFIG_MMC_SDHCI_MILBEAUT is not set
    # CONFIG_MMC_SDHCI_IPROC is not set
    # CONFIG_MMC_MESON_GX is not set
    # CONFIG_MMC_MESON_MX_SDHC is not set
    # CONFIG_MMC_MESON_MX_SDIO is not set
    # CONFIG_MMC_MOXART is not set
    # CONFIG_MMC_SDHCI_ST is not set
    CONFIG_MMC_OMAP=y
    CONFIG_MMC_OMAP_HS=y
    # CONFIG_MMC_SDHCI_MSM is not set
    # CONFIG_MMC_TIFM_SD is not set
    # CONFIG_MMC_MVSDIO is not set
    # CONFIG_MMC_DAVINCI is not set
    # CONFIG_MMC_SPI is not set
    # CONFIG_MMC_S3C is not set
    # CONFIG_MMC_SDHCI_SPRD is not set
    # CONFIG_MMC_TMIO is not set
    # CONFIG_MMC_SDHI is not set
    # CONFIG_MMC_UNIPHIER is not set
    # CONFIG_MMC_CB710 is not set
    # CONFIG_MMC_VIA_SDMMC is not set
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_SH_MMCIF is not set
    # CONFIG_MMC_VUB300 is not set
    # CONFIG_MMC_USHC is not set
    # CONFIG_MMC_USDHI6ROL0 is not set
    CONFIG_MMC_CQHCI=y
    # CONFIG_MMC_HSQ is not set
    # CONFIG_MMC_TOSHIBA_PCI is not set
    # CONFIG_MMC_BCM2835 is not set
    # CONFIG_MMC_MTK is not set
    # CONFIG_MMC_SDHCI_XENON is not set
    CONFIG_MMC_SDHCI_OMAP=y
    CONFIG_MMC_SDHCI_AM654=y
    # CONFIG_MMC_OWL is not set
    CONFIG_MMC_SDHCI_EXTERNAL_DMA=y
    # CONFIG_MMC_LITEX is not set
    # CONFIG_SCSI_UFSHCD is not set
    # CONFIG_MEMSTICK is not set
    CONFIG_NEW_LEDS=y
    CONFIG_LEDS_CLASS=y
    CONFIG_LEDS_CLASS_FLASH=m
    # CONFIG_LEDS_CLASS_MULTICOLOR is not set
    # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
    # LED drivers
    # CONFIG_LEDS_AN30259A is not set
    # CONFIG_LEDS_ARIEL is not set
    # CONFIG_LEDS_AW2013 is not set
    # CONFIG_LEDS_BCM6328 is not set
    # CONFIG_LEDS_BCM6358 is not set
    CONFIG_LEDS_CPCAP=m
    # CONFIG_LEDS_CR0014114 is not set
    # CONFIG_LEDS_EL15203000 is not set
    # CONFIG_LEDS_LM3530 is not set
    # CONFIG_LEDS_LM3532 is not set
    # CONFIG_LEDS_LM3642 is not set
    # CONFIG_LEDS_LM3692X is not set
    # CONFIG_LEDS_S3C24XX is not set
    # CONFIG_LEDS_COBALT_QUBE is not set
    # CONFIG_LEDS_COBALT_RAQ is not set
    # CONFIG_LEDS_PCA9532 is not set
    CONFIG_LEDS_GPIO=y
    # CONFIG_LEDS_LP3944 is not set
    # CONFIG_LEDS_LP3952 is not set
    # CONFIG_LEDS_LP50XX is not set
    # CONFIG_LEDS_LP55XX_COMMON is not set
    # CONFIG_LEDS_LP8860 is not set
    # CONFIG_LEDS_PCA955X is not set
    # CONFIG_LEDS_PCA963X is not set
    # CONFIG_LEDS_DAC124S085 is not set
    # CONFIG_LEDS_PWM is not set
    # CONFIG_LEDS_REGULATOR is not set
    # CONFIG_LEDS_BD2802 is not set
    # CONFIG_LEDS_LT3593 is not set
    CONFIG_LEDS_NS2=y
    CONFIG_LEDS_NETXBIG=y
    # CONFIG_LEDS_TCA6507 is not set
    # CONFIG_LEDS_TLC591XX is not set
    # CONFIG_LEDS_LM355x is not set
    # CONFIG_LEDS_OT200 is not set
    # CONFIG_LEDS_IS31FL319X is not set
    # CONFIG_LEDS_IS31FL32XX is not set
    # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
    # CONFIG_LEDS_BLINKM is not set
    # CONFIG_LEDS_SYSCON is not set
    # CONFIG_LEDS_MLXREG is not set
    # CONFIG_LEDS_USER is not set
    # CONFIG_LEDS_SPI_BYTE is not set
    # CONFIG_LEDS_TI_LMU_COMMON is not set
    # CONFIG_LEDS_IP30 is not set
    # CONFIG_LEDS_BCM63138 is not set
    # CONFIG_LEDS_LGM is not set
    # Flash and Torch LED drivers
    # CONFIG_LEDS_AAT1290 is not set
    # CONFIG_LEDS_AS3645A is not set
    # CONFIG_LEDS_KTD2692 is not set
    # CONFIG_LEDS_LM3601X is not set
    # CONFIG_LEDS_RT4505 is not set
    # CONFIG_LEDS_RT8515 is not set
    # CONFIG_LEDS_SGM3140 is not set
    # RGB LED drivers
    # LED Triggers
    CONFIG_LEDS_TRIGGERS=y
    CONFIG_LEDS_TRIGGER_TIMER=y
    CONFIG_LEDS_TRIGGER_ONESHOT=y
    # CONFIG_LEDS_TRIGGER_DISK is not set
    # CONFIG_LEDS_TRIGGER_MTD is not set
    CONFIG_LEDS_TRIGGER_HEARTBEAT=y
    CONFIG_LEDS_TRIGGER_BACKLIGHT=y
    CONFIG_LEDS_TRIGGER_CPU=y
    # CONFIG_LEDS_TRIGGER_ACTIVITY is not set
    CONFIG_LEDS_TRIGGER_GPIO=y
    CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
    # iptables trigger is under Netfilter config (LED target)
    CONFIG_LEDS_TRIGGER_TRANSIENT=y
    CONFIG_LEDS_TRIGGER_CAMERA=y
    # CONFIG_LEDS_TRIGGER_PANIC is not set
    # CONFIG_LEDS_TRIGGER_NETDEV is not set
    # CONFIG_LEDS_TRIGGER_PATTERN is not set
    CONFIG_LEDS_TRIGGER_AUDIO=m
    # CONFIG_LEDS_TRIGGER_TTY is not set
    # Simple LED drivers
    # CONFIG_ACCESSIBILITY is not set
    # CONFIG_INFINIBAND is not set
    CONFIG_EDAC_ATOMIC_SCRUB=y
    CONFIG_EDAC_SUPPORT=y
    CONFIG_EDAC=y
    CONFIG_EDAC_LEGACY_SYSFS=y
    # CONFIG_EDAC_DEBUG is not set
    # CONFIG_EDAC_AL_MC is not set
    # CONFIG_EDAC_ALTERA is not set
    # CONFIG_EDAC_SYNOPSYS is not set
    # CONFIG_EDAC_XGENE is not set
    # CONFIG_EDAC_TI is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    CONFIG_RTC_SYSTOHC=y
    CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
    # CONFIG_RTC_DEBUG is not set
    CONFIG_RTC_NVMEM=y
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    # CONFIG_RTC_DRV_ABB5ZES3 is not set
    # CONFIG_RTC_DRV_ABEOZ9 is not set
    # CONFIG_RTC_DRV_ABX80X is not set
    # CONFIG_RTC_DRV_BRCMSTB is not set
    CONFIG_RTC_DRV_DS1307=y
    # CONFIG_RTC_DRV_DS1307_CENTURY is not set
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_HYM8563 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_MAX8907 is not set
    # CONFIG_RTC_DRV_MAX77686 is not set
    # CONFIG_RTC_DRV_NCT3018Y is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_ISL12022 is not set
    # CONFIG_RTC_DRV_ISL12026 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    # CONFIG_RTC_DRV_PCF8523 is not set
    # CONFIG_RTC_DRV_PCF85063 is not set
    CONFIG_RTC_DRV_PCF85263=y
    CONFIG_RTC_DRV_PCF85363=m
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    # CONFIG_RTC_DRV_BQ32K is not set
    CONFIG_RTC_DRV_TWL4030=y
    CONFIG_RTC_DRV_PALMAS=y
    CONFIG_RTC_DRV_TPS6586X=y
    CONFIG_RTC_DRV_TPS65910=y
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8010 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # CONFIG_RTC_DRV_RX8025 is not set
    # CONFIG_RTC_DRV_EM3027 is not set
    # CONFIG_RTC_DRV_RV3028 is not set
    # CONFIG_RTC_DRV_RV3032 is not set
    # CONFIG_RTC_DRV_RV8803 is not set
    # CONFIG_RTC_DRV_S5M is not set
    # CONFIG_RTC_DRV_SD3078 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T93 is not set
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1302 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1343 is not set
    # CONFIG_RTC_DRV_DS1347 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6916 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RX4581 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # CONFIG_RTC_DRV_MCP795 is not set
    CONFIG_RTC_I2C_AND_SPI=y
    # SPI and I2C RTC drivers
    # CONFIG_RTC_DRV_DS3232 is not set
    # CONFIG_RTC_DRV_PCF2127 is not set
    # CONFIG_RTC_DRV_RV3029C2 is not set
    # CONFIG_RTC_DRV_RX6110 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1685_FAMILY is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_DS2404 is not set
    CONFIG_RTC_DRV_EFI=m
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_MSM6242 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_RP5C01 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # CONFIG_RTC_DRV_GAMECUBE is not set
    # CONFIG_RTC_DRV_SC27XX is not set
    CONFIG_RTC_DRV_SPEAR=y
    # CONFIG_RTC_DRV_ZYNQMP is not set
    # on-CPU RTC drivers
    # CONFIG_RTC_DRV_ASM9260 is not set
    # CONFIG_RTC_DRV_DAVINCI is not set
    # CONFIG_RTC_DRV_DIGICOLOR is not set
    # CONFIG_RTC_DRV_FSL_FTM_ALARM is not set
    # CONFIG_RTC_DRV_MESON is not set
    # CONFIG_RTC_DRV_MESON_VRTC is not set
    # CONFIG_RTC_DRV_OMAP is not set
    # CONFIG_RTC_DRV_S3C is not set
    # CONFIG_RTC_DRV_EP93XX is not set
    # CONFIG_RTC_DRV_SUNPLUS is not set
    # CONFIG_RTC_DRV_PL030 is not set
    CONFIG_RTC_DRV_PL031=y
    # CONFIG_RTC_DRV_AT91RM9200 is not set
    # CONFIG_RTC_DRV_AT91SAM9 is not set
    # CONFIG_RTC_DRV_RZN1 is not set
    # CONFIG_RTC_DRV_GENERIC is not set
    # CONFIG_RTC_DRV_VT8500 is not set
    # CONFIG_RTC_DRV_SUN6I is not set
    # CONFIG_RTC_DRV_SUNXI is not set
    # CONFIG_RTC_DRV_MV is not set
    # CONFIG_RTC_DRV_ARMADA38X is not set
    # CONFIG_RTC_DRV_CADENCE is not set
    # CONFIG_RTC_DRV_FTRTC010 is not set
    # CONFIG_RTC_DRV_STMP is not set
    # CONFIG_RTC_DRV_JZ4740 is not set
    # CONFIG_RTC_DRV_LPC24XX is not set
    # CONFIG_RTC_DRV_LPC32XX is not set
    # CONFIG_RTC_DRV_PM8XXX is not set
    # CONFIG_RTC_DRV_TEGRA is not set
    # CONFIG_RTC_DRV_MXC is not set
    # CONFIG_RTC_DRV_MXC_V2 is not set
    # CONFIG_RTC_DRV_SNVS is not set
    # CONFIG_RTC_DRV_MOXART is not set
    # CONFIG_RTC_DRV_MT2712 is not set
    # CONFIG_RTC_DRV_MT6397 is not set
    # CONFIG_RTC_DRV_MT7622 is not set
    # CONFIG_RTC_DRV_XGENE is not set
    # CONFIG_RTC_DRV_R7301 is not set
    # CONFIG_RTC_DRV_STM32 is not set
    CONFIG_RTC_DRV_CPCAP=m
    # CONFIG_RTC_DRV_RTD119X is not set
    # CONFIG_RTC_DRV_ASPEED is not set
    # CONFIG_RTC_DRV_TI_K3 is not set
    # HID Sensor RTC drivers
    # CONFIG_RTC_DRV_GOLDFISH is not set
    # CONFIG_RTC_DRV_MSC313 is not set
    CONFIG_DMADEVICES=y
    # CONFIG_DMADEVICES_DEBUG is not set
    # DMA Devices
    CONFIG_DMA_ENGINE=y
    CONFIG_DMA_VIRTUAL_CHANNELS=y
    CONFIG_DMA_OF=y
    # CONFIG_ALTERA_MSGDMA is not set
    # CONFIG_AMBA_PL08X is not set
    # CONFIG_APPLE_ADMAC is not set
    # CONFIG_AXI_DMAC is not set
    # CONFIG_BCM_SBA_RAID is not set
    # CONFIG_DMA_JZ4780 is not set
    # CONFIG_DMA_SA11X0 is not set
    # CONFIG_DMA_SUN6I is not set
    # CONFIG_DW_AXI_DMAC is not set
    # CONFIG_EP93XX_DMA is not set
    CONFIG_FSL_EDMA=y
    # CONFIG_FSL_QDMA is not set
    # CONFIG_HISI_DMA is not set
    # CONFIG_IMG_MDC_DMA is not set
    # CONFIG_INTEL_IDMA64 is not set
    # CONFIG_INTEL_IOP_ADMA is not set
    # CONFIG_K3_DMA is not set
    # CONFIG_MCF_EDMA is not set
    # CONFIG_MILBEAUT_HDMAC is not set
    # CONFIG_MILBEAUT_XDMAC is not set
    # CONFIG_MMP_PDMA is not set
    # CONFIG_MMP_TDMA is not set
    # CONFIG_MV_XOR is not set
    # CONFIG_MXS_DMA is not set
    # CONFIG_NBPFAXI_DMA is not set
    # CONFIG_PCH_DMA is not set
    CONFIG_PL330_DMA=y
    # CONFIG_PLX_DMA is not set
    # CONFIG_STM32_DMA is not set
    # CONFIG_STM32_DMAMUX is not set
    # CONFIG_STM32_MDMA is not set
    # CONFIG_SPRD_DMA is not set
    # CONFIG_S3C24XX_DMAC is not set
    # CONFIG_TEGRA20_APB_DMA is not set
    # CONFIG_TEGRA210_ADMA is not set
    # CONFIG_TIMB_DMA is not set
    # CONFIG_UNIPHIER_MDMAC is not set
    # CONFIG_UNIPHIER_XDMAC is not set
    # CONFIG_XGENE_DMA is not set
    # CONFIG_XILINX_ZYNQMP_DMA is not set
    # CONFIG_XILINX_ZYNQMP_DPDMA is not set
    # CONFIG_MTK_HSDMA is not set
    # CONFIG_MTK_CQDMA is not set
    # CONFIG_QCOM_ADM is not set
    # CONFIG_QCOM_BAM_DMA is not set
    # CONFIG_QCOM_HIDMA_MGMT is not set
    # CONFIG_QCOM_HIDMA is not set
    CONFIG_DW_DMAC_CORE=y
    CONFIG_DW_DMAC=y
    # CONFIG_RZN1_DMAMUX is not set
    # CONFIG_DW_DMAC_PCI is not set
    # CONFIG_DW_EDMA is not set
    # CONFIG_DW_EDMA_PCIE is not set
    CONFIG_HSU_DMA=y
    # CONFIG_SF_PDMA is not set
    CONFIG_RENESAS_DMA=y
    CONFIG_SH_DMAE_BASE=y
    # CONFIG_SH_DMAE is not set
    # CONFIG_RCAR_DMAC is not set
    # CONFIG_RENESAS_USB_DMAC is not set
    # CONFIG_RZ_DMAC is not set
    CONFIG_TI_CPPI41=y
    CONFIG_TI_EDMA=y
    CONFIG_DMA_OMAP=y
    CONFIG_TI_DMA_CROSSBAR=y
    # CONFIG_INTEL_LDMA is not set
    # DMA Clients
    # CONFIG_ASYNC_TX_DMA is not set
    # CONFIG_DMATEST is not set
    # DMABUF options
    CONFIG_SYNC_FILE=y
    # CONFIG_SW_SYNC is not set
    # CONFIG_UDMABUF is not set
    # CONFIG_DMABUF_MOVE_NOTIFY is not set
    # CONFIG_DMABUF_DEBUG is not set
    # CONFIG_DMABUF_SELFTESTS is not set
    CONFIG_DMABUF_HEAPS=y
    # CONFIG_DMABUF_SYSFS_STATS is not set
    CONFIG_DMABUF_HEAPS_SYSTEM=y
    CONFIG_DMABUF_HEAPS_CMA=y
    CONFIG_DMABUF_HEAPS_CARVEOUT=y
    # end of DMABUF options
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_UIO is not set
    # CONFIG_VFIO is not set
    # CONFIG_VIRT_DRIVERS is not set
    CONFIG_VIRTIO_ANCHOR=y
    CONFIG_VIRTIO=y
    CONFIG_VIRTIO_PCI_LIB=y
    CONFIG_VIRTIO_PCI_LIB_LEGACY=y
    CONFIG_VIRTIO_MENU=y
    CONFIG_VIRTIO_PCI=y
    CONFIG_VIRTIO_PCI_LEGACY=y
    # CONFIG_VIRTIO_BALLOON is not set
    # CONFIG_VIRTIO_INPUT is not set
    CONFIG_VIRTIO_MMIO=y
    # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set
    # CONFIG_VDPA is not set
    CONFIG_VHOST_MENU=y
    # CONFIG_VHOST_NET is not set
    # CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set
    # Microsoft Hyper-V guest support
    # end of Microsoft Hyper-V guest support
    # CONFIG_GREYBUS is not set
    # CONFIG_COMEDI is not set
    CONFIG_STAGING=y
    # CONFIG_PRISM2_USB is not set
    # CONFIG_RTL8192U is not set
    # CONFIG_RTLLIB is not set
    # CONFIG_RTL8723BS is not set
    # CONFIG_R8712U is not set
    # CONFIG_R8188EU is not set
    # CONFIG_RTS5208 is not set
    # CONFIG_OCTEON_ETHERNET is not set
    # CONFIG_VT6655 is not set
    # CONFIG_VT6656 is not set
    # IIO staging drivers
    # Accelerometers
    # CONFIG_ADIS16203 is not set
    # CONFIG_ADIS16240 is not set
    # end of Accelerometers
    # Analog to digital converters
    # CONFIG_AD7816 is not set
    # end of Analog to digital converters
    # Analog digital bi-direction converters
    # CONFIG_ADT7316 is not set
    # end of Analog digital bi-direction converters
    # Direct Digital Synthesis
    # CONFIG_AD9832 is not set
    # CONFIG_AD9834 is not set
    # end of Direct Digital Synthesis
    # Network Analyzer, Impedance Converters
    # CONFIG_AD5933 is not set
    # end of Network Analyzer, Impedance Converters
    # Active energy metering IC
    # CONFIG_ADE7854 is not set
    # end of Active energy metering IC
    # Resolver to digital converters
    # CONFIG_AD2S1210 is not set
    # end of Resolver to digital converters
    # end of IIO staging drivers
    # CONFIG_FB_SM750 is not set
    # CONFIG_USB_EMXX is not set
    # CONFIG_STAGING_MEDIA is not set
    CONFIG_STAGING_BOARD=y
    # CONFIG_LTE_GDM724X is not set
    # CONFIG_FB_TFT is not set
    # CONFIG_KS7010 is not set
    CONFIG_BCM_VIDEOCORE=y
    # CONFIG_BCM2835_VCHIQ is not set
    # CONFIG_SND_BCM2835 is not set
    # CONFIG_VIDEO_BCM2835 is not set
    # CONFIG_PI433 is not set
    # CONFIG_XIL_AXIS_FIFO is not set
    # CONFIG_FIELDBUS_DEV is not set
    # CONFIG_QLGE is not set
    # CONFIG_VME_BUS is not set
    # CONFIG_GOLDFISH is not set
    # CONFIG_CHROME_PLATFORMS is not set
    # CONFIG_MELLANOX_PLATFORM is not set
    # CONFIG_OLPC_XO175 is not set
    CONFIG_SURFACE_PLATFORMS=y
    CONFIG_HAVE_CLK=y
    CONFIG_HAVE_CLK_PREPARE=y
    CONFIG_COMMON_CLK=y
    # Clock driver for ARM Reference designs
    CONFIG_CLK_ICST=y
    CONFIG_CLK_SP810=y
    CONFIG_CLK_VEXPRESS_OSC=y
    # end of Clock driver for ARM Reference designs
    # CONFIG_CLK_HSDK is not set
    # CONFIG_LMK04832 is not set
    # CONFIG_COMMON_CLK_APPLE_NCO is not set
    # CONFIG_COMMON_CLK_MAX77686 is not set
    # CONFIG_COMMON_CLK_MAX9485 is not set
    # CONFIG_COMMON_CLK_HI655X is not set
    # CONFIG_COMMON_CLK_SCMI is not set
    # CONFIG_COMMON_CLK_SCPI is not set
    # CONFIG_COMMON_CLK_SI5341 is not set
    # CONFIG_COMMON_CLK_SI5351 is not set
    # CONFIG_COMMON_CLK_SI514 is not set
    # CONFIG_COMMON_CLK_SI544 is not set
    # CONFIG_COMMON_CLK_SI570 is not set
    # CONFIG_COMMON_CLK_BM1880 is not set
    # CONFIG_COMMON_CLK_CDCE706 is not set
    # CONFIG_COMMON_CLK_TPS68470 is not set
    # CONFIG_COMMON_CLK_CDCE925 is not set
    # CONFIG_COMMON_CLK_CS2000_CP is not set
    # CONFIG_COMMON_CLK_EN7523 is not set
    # CONFIG_COMMON_CLK_FSL_FLEXSPI is not set
    # CONFIG_COMMON_CLK_FSL_SAI is not set
    # CONFIG_COMMON_CLK_GEMINI is not set
    # CONFIG_COMMON_CLK_LAN966X is not set
    # CONFIG_COMMON_CLK_ASPEED is not set
    # CONFIG_COMMON_CLK_S2MPS11 is not set
    # CONFIG_COMMON_CLK_AXI_CLKGEN is not set
    # CONFIG_CLK_QORIQ is not set
    # CONFIG_CLK_LS1028A_PLLDIG is not set
    # CONFIG_COMMON_CLK_XGENE is not set
    # CONFIG_COMMON_CLK_PALMAS is not set
    # CONFIG_COMMON_CLK_PWM is not set
    # CONFIG_COMMON_CLK_OXNAS is not set
    # CONFIG_COMMON_CLK_RS9_PCIE is not set
    # CONFIG_COMMON_CLK_VC5 is not set
    # CONFIG_COMMON_CLK_VC7 is not set
    # CONFIG_COMMON_CLK_MMP2_AUDIO is not set
    # CONFIG_COMMON_CLK_FIXED_MMIO is not set
    # CONFIG_CLK_ACTIONS is not set
    # CONFIG_CLK_BAIKAL_T1 is not set
    # CONFIG_CLK_BCM2711_DVP is not set
    # CONFIG_CLK_BCM2835 is not set
    # CONFIG_CLK_BCM_63XX is not set
    # CONFIG_CLK_BCM_63XX_GATE is not set
    # CONFIG_CLK_BCM_KONA is not set
    # CONFIG_CLK_BCM_CYGNUS is not set
    # CONFIG_CLK_BCM_HR2 is not set
    # CONFIG_CLK_BCM_NSP is not set
    # CONFIG_CLK_BCM_NS2 is not set
    # CONFIG_CLK_BCM_SR is not set
    # CONFIG_CLK_RASPBERRYPI is not set
    # CONFIG_COMMON_CLK_HI3516CV300 is not set
    # CONFIG_COMMON_CLK_HI3519 is not set
    # CONFIG_COMMON_CLK_HI3559A is not set
    # CONFIG_COMMON_CLK_HI3660 is not set
    # CONFIG_COMMON_CLK_HI3670 is not set
    # CONFIG_COMMON_CLK_HI3798CV200 is not set
    # CONFIG_COMMON_CLK_HI6220 is not set
    # CONFIG_RESET_HISI is not set
    CONFIG_STUB_CLK_HI6220=y
    CONFIG_STUB_CLK_HI3660=y
    # CONFIG_COMMON_CLK_BOSTON is not set
    # CONFIG_MXC_CLK is not set
    # CONFIG_CLK_IMX8MM is not set
    # CONFIG_CLK_IMX8MN is not set
    # CONFIG_CLK_IMX8MP is not set
    # CONFIG_CLK_IMX8MQ is not set
    # CONFIG_CLK_IMX8ULP is not set
    # CONFIG_CLK_IMX93 is not set
    # Ingenic SoCs drivers
    # CONFIG_INGENIC_CGU_JZ4740 is not set
    # CONFIG_INGENIC_CGU_JZ4725B is not set
    # CONFIG_INGENIC_CGU_JZ4760 is not set
    # CONFIG_INGENIC_CGU_JZ4770 is not set
    # CONFIG_INGENIC_CGU_JZ4780 is not set
    # CONFIG_INGENIC_CGU_X1000 is not set
    # CONFIG_INGENIC_CGU_X1830 is not set
    # CONFIG_INGENIC_TCU_CLK is not set
    # end of Ingenic SoCs drivers
    CONFIG_COMMON_CLK_KEYSTONE=y
    # CONFIG_TI_SYSCON_CLK is not set
    # Clock driver for MediaTek SoC
    # CONFIG_COMMON_CLK_MT2701 is not set
    # CONFIG_COMMON_CLK_MT2712 is not set
    # CONFIG_COMMON_CLK_MT6765 is not set
    # CONFIG_COMMON_CLK_MT6779 is not set
    # CONFIG_COMMON_CLK_MT6795 is not set
    # CONFIG_COMMON_CLK_MT6797 is not set
    # CONFIG_COMMON_CLK_MT7622 is not set
    # CONFIG_COMMON_CLK_MT7629 is not set
    # CONFIG_COMMON_CLK_MT7986 is not set
    # CONFIG_COMMON_CLK_MT8135 is not set
    # CONFIG_COMMON_CLK_MT8167 is not set
    # CONFIG_COMMON_CLK_MT8173 is not set
    # CONFIG_COMMON_CLK_MT8183 is not set
    # CONFIG_COMMON_CLK_MT8186 is not set
    # CONFIG_COMMON_CLK_MT8192 is not set
    # CONFIG_COMMON_CLK_MT8195 is not set
    # CONFIG_COMMON_CLK_MT8365 is not set
    # CONFIG_COMMON_CLK_MT8516 is not set
    # end of Clock driver for MediaTek SoC
    # Clock support for Amlogic platforms
    CONFIG_COMMON_CLK_MESON_REGMAP=y
    CONFIG_COMMON_CLK_MESON_MPLL=y
    CONFIG_COMMON_CLK_MESON_PLL=y
    CONFIG_COMMON_CLK_MESON8B=y
    # end of Clock support for Amlogic platforms
    # CONFIG_MSTAR_MSC313_MPLL is not set
    # CONFIG_MCHP_CLK_MPFS is not set
    # CONFIG_COMMON_CLK_PISTACHIO is not set
    # CONFIG_COMMON_CLK_QCOM is not set
    # CONFIG_CLK_MT7621 is not set
    # CONFIG_CLK_RENESAS is not set
    # CONFIG_COMMON_CLK_SAMSUNG is not set
    # CONFIG_S3C2410_COMMON_CLK is not set
    # CONFIG_S3C2412_COMMON_CLK is not set
    # CONFIG_S3C2443_COMMON_CLK is not set
    # CONFIG_CLK_SIFIVE is not set
    CONFIG_CLK_INTEL_SOCFPGA=y
    CONFIG_CLK_INTEL_SOCFPGA32=y
    # CONFIG_CLK_INTEL_SOCFPGA64 is not set
    # CONFIG_SPRD_COMMON_CLK is not set
    # CONFIG_CLK_STARFIVE_JH7100 is not set
    CONFIG_CLK_SUNXI=y
    CONFIG_CLK_SUNXI_CLOCKS=y
    CONFIG_CLK_SUNXI_PRCM_SUN6I=y
    CONFIG_CLK_SUNXI_PRCM_SUN8I=y
    CONFIG_CLK_SUNXI_PRCM_SUN9I=y
    # CONFIG_SUNXI_CCU is not set
    CONFIG_COMMON_CLK_TI_ADPLL=y
    # CONFIG_CLK_UNIPHIER is not set
    # CONFIG_COMMON_CLK_VISCONTI is not set
    # CONFIG_CLK_LGM_CGU is not set
    # CONFIG_XILINX_VCU is not set
    # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
    # CONFIG_COMMON_CLK_ZYNQMP is not set
    CONFIG_HWSPINLOCK=y
    # CONFIG_HWSPINLOCK_OMAP is not set
    # CONFIG_HWSPINLOCK_QCOM is not set
    # CONFIG_HWSPINLOCK_SPRD is not set
    # CONFIG_HWSPINLOCK_STM32 is not set
    # CONFIG_HWSPINLOCK_SUN6I is not set
    # CONFIG_HSEM_U8500 is not set
    # Clock Source drivers
    CONFIG_TIMER_OF=y
    CONFIG_TIMER_PROBE=y
    CONFIG_OMAP_DM_SYSTIMER=y
    CONFIG_CLKSRC_MMIO=y
    # CONFIG_BCM2835_TIMER is not set
    # CONFIG_BCM_KONA_TIMER is not set
    # CONFIG_DAVINCI_TIMER is not set
    # CONFIG_DIGICOLOR_TIMER is not set
    CONFIG_OMAP_DM_TIMER=y
    CONFIG_DW_APB_TIMER=y
    CONFIG_DW_APB_TIMER_OF=y
    # CONFIG_FTTMR010_TIMER is not set
    # CONFIG_IXP4XX_TIMER is not set
    # CONFIG_ROCKCHIP_TIMER is not set
    # CONFIG_ARMADA_370_XP_TIMER is not set
    # CONFIG_MESON6_TIMER is not set
    # CONFIG_ORION_TIMER is not set
    # CONFIG_OWL_TIMER is not set
    # CONFIG_RDA_TIMER is not set
    # CONFIG_SUN4I_TIMER is not set
    # CONFIG_SUN5I_HSTIMER is not set
    # CONFIG_TEGRA_TIMER is not set
    # CONFIG_TEGRA186_TIMER is not set
    # CONFIG_VT8500_TIMER is not set
    # CONFIG_NPCM7XX_TIMER is not set
    # CONFIG_CADENCE_TTC_TIMER is not set
    # CONFIG_ASM9260_TIMER is not set
    # CONFIG_CLKSRC_NOMADIK_MTU is not set
    # CONFIG_CLKSRC_DBX500_PRCMU is not set
    # CONFIG_CLPS711X_TIMER is not set
    # CONFIG_MXS_TIMER is not set
    # CONFIG_NSPIRE_TIMER is not set
    CONFIG_KEYSTONE_TIMER=y
    # CONFIG_INTEGRATOR_AP_TIMER is not set
    # CONFIG_CLKSRC_LPC32XX is not set
    # CONFIG_CLKSRC_PISTACHIO is not set
    CONFIG_CLKSRC_TI_32K=y
    # CONFIG_CLKSRC_STM32 is not set
    # CONFIG_CLKSRC_STM32_LP is not set
    # CONFIG_CLKSRC_MPS2 is not set
    # CONFIG_ARC_TIMERS is not set
    CONFIG_ARM_ARCH_TIMER=y
    CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
    # CONFIG_ARM_GLOBAL_TIMER is not set
    # CONFIG_ARM_TIMER_SP804 is not set
    # CONFIG_ARMV7M_SYSTICK is not set
    # CONFIG_ATMEL_PIT is not set
    # CONFIG_ATMEL_ST is not set
    # CONFIG_ATMEL_TCB_CLKSRC is not set
    # CONFIG_CLKSRC_EXYNOS_MCT is not set
    # CONFIG_CLKSRC_SAMSUNG_PWM is not set
    # CONFIG_FSL_FTM_TIMER is not set
    # CONFIG_OXNAS_RPS_TIMER is not set
    # CONFIG_MTK_TIMER is not set
    # CONFIG_SPRD_TIMER is not set
    # CONFIG_CLKSRC_JCORE_PIT is not set
    # CONFIG_SH_TIMER_CMT is not set
    # CONFIG_SH_TIMER_MTU2 is not set
    # CONFIG_RENESAS_OSTM is not set
    # CONFIG_SH_TIMER_TMU is not set
    # CONFIG_EM_TIMER_STI is not set
    # CONFIG_CLKSRC_QCOM is not set
    # CONFIG_CLKSRC_VERSATILE is not set
    # CONFIG_CLKSRC_PXA is not set
    # CONFIG_CLKSRC_IMX_GPT is not set
    # CONFIG_CLKSRC_IMX_TPM is not set
    # CONFIG_TIMER_IMX_SYS_CTR is not set
    # CONFIG_CLKSRC_ST_LPC is not set
    # CONFIG_GXP_TIMER is not set
    # CONFIG_MILBEAUT_TIMER is not set
    # CONFIG_MSC313E_TIMER is not set
    # CONFIG_INGENIC_TIMER is not set
    # CONFIG_INGENIC_SYSOST is not set
    # CONFIG_INGENIC_OST is not set
    CONFIG_MICROCHIP_PIT64B=y
    # end of Clock Source drivers
    CONFIG_MAILBOX=y
    # CONFIG_ARM_MHU is not set
    # CONFIG_ARM_MHU_V2 is not set
    # CONFIG_IMX_MBOX is not set
    # CONFIG_PLATFORM_MHU is not set
    CONFIG_PL320_MBOX=y
    # CONFIG_ARMADA_37XX_RWTM_MBOX is not set
    # CONFIG_OMAP2PLUS_MBOX is not set
    # CONFIG_ROCKCHIP_MBOX is not set
    # CONFIG_ALTERA_MBOX is not set
    # CONFIG_TI_MESSAGE_MANAGER is not set
    CONFIG_HI3660_MBOX=y
    CONFIG_HI6220_MBOX=y
    # CONFIG_MAILBOX_TEST is not set
    # CONFIG_POLARFIRE_SOC_MAILBOX is not set
    CONFIG_QCOM_APCS_IPC=y
    # CONFIG_BCM_PDC_MBOX is not set
    # CONFIG_STM32_IPCC is not set
    # CONFIG_MTK_ADSP_MBOX is not set
    # CONFIG_MTK_CMDQ_MBOX is not set
    CONFIG_SUN6I_MSGBOX=y
    # CONFIG_SPRD_MBOX is not set
    CONFIG_QCOM_IPCC=y
    CONFIG_IOMMU_SUPPORT=y
    # Generic IOMMU Pagetable Support
    CONFIG_IOMMU_IO_PGTABLE=y
    CONFIG_IOMMU_IO_PGTABLE_LPAE=y
    # CONFIG_IOMMU_IO_PGTABLE_LPAE_SELFTEST is not set
    # CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set
    # CONFIG_IOMMU_IO_PGTABLE_DART is not set
    # end of Generic IOMMU Pagetable Support
    # CONFIG_IOMMU_DEBUGFS is not set
    # CONFIG_MSM_IOMMU is not set
    # CONFIG_OMAP_IOMMU is not set
    # CONFIG_ROCKCHIP_IOMMU is not set
    # CONFIG_SUN50I_IOMMU is not set
    # CONFIG_EXYNOS_IOMMU is not set
    # CONFIG_IPMMU_VMSA is not set
    # CONFIG_APPLE_DART is not set
    # CONFIG_ARM_SMMU is not set
    # CONFIG_S390_CCW_IOMMU is not set
    # CONFIG_S390_AP_IOMMU is not set
    # CONFIG_MTK_IOMMU is not set
    # CONFIG_MTK_IOMMU_V1 is not set
    # CONFIG_QCOM_IOMMU is not set
    # CONFIG_SPRD_IOMMU is not set
    # Remoteproc drivers
    # CONFIG_REMOTEPROC is not set
    # end of Remoteproc drivers
    # Rpmsg drivers
    CONFIG_RPMSG=m
    # CONFIG_RPMSG_CHAR is not set
    # CONFIG_RPMSG_CTRL is not set
    CONFIG_RPMSG_NS=m
    # CONFIG_RPMSG_QCOM_GLINK_RPM is not set
    CONFIG_RPMSG_VIRTIO=m
    # end of Rpmsg drivers
    # Rpmsg virtual device drivers
    CONFIG_RPMSG_KDRV=m
    # CONFIG_RPMSG_KDRV_DEMO is not set
    # CONFIG_RPMSG_KDRV_DISPLAY is not set
    CONFIG_RPMSG_KDRV_ETH_SWITCH=m
    # end of Rpmsg virtual device drivers
    # CONFIG_SOUNDWIRE is not set
    # SOC (System On Chip) specific Drivers
    # CONFIG_OWL_PM_DOMAINS is not set
    # Amlogic SoC drivers
    # CONFIG_MESON_CANVAS is not set
    # CONFIG_MESON_CLK_MEASURE is not set
    # CONFIG_MESON_GX_SOCINFO is not set
    # CONFIG_MESON_GX_PM_DOMAINS is not set
    # CONFIG_MESON_EE_PM_DOMAINS is not set
    # CONFIG_MESON_MX_SOCINFO is not set
    # end of Amlogic SoC drivers
    # Apple SoC drivers
    # CONFIG_APPLE_PMGR_PWRSTATE is not set
    # CONFIG_APPLE_RTKIT is not set
    # CONFIG_APPLE_SART is not set
    # end of Apple SoC drivers
    # ASPEED SoC drivers
    # CONFIG_ASPEED_LPC_CTRL is not set
    # CONFIG_ASPEED_LPC_SNOOP is not set
    # CONFIG_ASPEED_UART_ROUTING is not set
    # CONFIG_ASPEED_P2A_CTRL is not set
    # CONFIG_ASPEED_SOCINFO is not set
    # end of ASPEED SoC drivers
    # CONFIG_AT91_SOC_ID is not set
    # CONFIG_AT91_SOC_SFR is not set
    # Broadcom SoC drivers
    # CONFIG_BCM2835_POWER is not set
    # CONFIG_SOC_BCM63XX is not set
    CONFIG_SOC_BRCMSTB=y
    # CONFIG_BCM_PMB is not set
    # end of Broadcom SoC drivers
    # NXP/Freescale QorIQ SoC drivers
    # CONFIG_QUICC_ENGINE is not set
    CONFIG_DPAA2_CONSOLE=y
    # CONFIG_FSL_RCPM is not set
    # end of NXP/Freescale QorIQ SoC drivers
    # fujitsu SoC drivers
    # end of fujitsu SoC drivers
    # i.MX SoC drivers
    # CONFIG_IMX_GPCV2_PM_DOMAINS is not set
    # CONFIG_SOC_IMX8M is not set
    # CONFIG_SOC_IMX9 is not set
    # end of i.MX SoC drivers
    # IXP4xx SoC drivers
    # CONFIG_IXP4XX_QMGR is not set
    # CONFIG_IXP4XX_NPE is not set
    # end of IXP4xx SoC drivers
    # Enable LiteX SoC Builder specific drivers
    # CONFIG_LITEX_SOC_CONTROLLER is not set
    # end of Enable LiteX SoC Builder specific drivers
    # MediaTek SoC drivers
    # CONFIG_MTK_CMDQ is not set
    # CONFIG_MTK_DEVAPC is not set
    # CONFIG_MTK_INFRACFG is not set
    # CONFIG_MTK_PMIC_WRAP is not set
    # CONFIG_MTK_SCPSYS is not set
    # CONFIG_MTK_SCPSYS_PM_DOMAINS is not set
    # CONFIG_MTK_MMSYS is not set
    # end of MediaTek SoC drivers
    # Qualcomm SoC drivers
    # CONFIG_QCOM_AOSS_QMP is not set
    # CONFIG_QCOM_COMMAND_DB is not set
    # CONFIG_QCOM_GENI_SE is not set
    # CONFIG_QCOM_GSBI is not set
    # CONFIG_QCOM_LLCC is not set
    # CONFIG_QCOM_RPMH is not set
    # CONFIG_QCOM_SMEM is not set
    # CONFIG_QCOM_SMD_RPM is not set
    # CONFIG_QCOM_SPM is not set
    # CONFIG_QCOM_WCNSS_CTRL is not set
    # CONFIG_QCOM_APR is not set
    # CONFIG_QCOM_ICC_BWMON is not set
    # end of Qualcomm SoC drivers
    # CONFIG_SOC_RENESAS is not set
    # CONFIG_ROCKCHIP_GRF is not set
    # CONFIG_ROCKCHIP_IODOMAIN is not set
    # CONFIG_ROCKCHIP_PM_DOMAINS is not set
    # CONFIG_SOC_SAMSUNG is not set
    # CONFIG_SOC_TEGRA20_VOLTAGE_COUPLER is not set
    # CONFIG_SOC_TEGRA30_VOLTAGE_COUPLER is not set
    # CONFIG_SOC_TI is not set
    # CONFIG_UX500_SOC_ID is not set
    # Xilinx SoC drivers
    # end of Xilinx SoC drivers
    # end of SOC (System On Chip) specific Drivers
    CONFIG_PM_DEVFREQ=y
    # DEVFREQ Governors
    CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y
    # CONFIG_DEVFREQ_GOV_PERFORMANCE is not set
    # CONFIG_DEVFREQ_GOV_POWERSAVE is not set
    # CONFIG_DEVFREQ_GOV_USERSPACE is not set
    # CONFIG_DEVFREQ_GOV_PASSIVE is not set
    # DEVFREQ Drivers
    # CONFIG_ARM_EXYNOS_BUS_DEVFREQ is not set
    # CONFIG_ARM_IMX_BUS_DEVFREQ is not set
    # CONFIG_ARM_IMX8M_DDRC_DEVFREQ is not set
    # CONFIG_ARM_TEGRA_DEVFREQ is not set
    # CONFIG_ARM_MEDIATEK_CCI_DEVFREQ is not set
    # CONFIG_ARM_RK3399_DMC_DEVFREQ is not set
    # CONFIG_ARM_SUN8I_A33_MBUS_DEVFREQ is not set
    # CONFIG_PM_DEVFREQ_EVENT is not set
    CONFIG_EXTCON=y
    # Extcon Device Drivers
    # CONFIG_EXTCON_ADC_JACK is not set
    # CONFIG_EXTCON_FSA9480 is not set
    # CONFIG_EXTCON_GPIO is not set
    # CONFIG_EXTCON_MAX3355 is not set
    # CONFIG_EXTCON_PALMAS is not set
    # CONFIG_EXTCON_PTN5150 is not set
    # CONFIG_EXTCON_QCOM_SPMI_MISC is not set
    # CONFIG_EXTCON_RT8973A is not set
    # CONFIG_EXTCON_SM5502 is not set
    CONFIG_EXTCON_USB_GPIO=y
    # CONFIG_EXTCON_USBC_TUSB320 is not set
    CONFIG_MEMORY=y
    CONFIG_DDR=y
    # CONFIG_ARM_PL172_MPMC is not set
    # CONFIG_ATMEL_SDRAMC is not set
    # CONFIG_ATMEL_EBI is not set
    # CONFIG_BRCMSTB_DPFE is not set
    # CONFIG_BRCMSTB_MEMC is not set
    # CONFIG_BT1_L2_CTL is not set
    # CONFIG_TI_AEMIF is not set
    # CONFIG_TI_EMIF is not set
    CONFIG_OMAP_GPMC=y
    # CONFIG_OMAP_GPMC_DEBUG is not set
    # CONFIG_TI_EMIF_SRAM is not set
    # CONFIG_MVEBU_DEVBUS is not set
    # CONFIG_FSL_CORENET_CF is not set
    # CONFIG_FSL_IFC is not set
    # CONFIG_JZ4780_NEMC is not set
    # CONFIG_MTK_SMI is not set
    # CONFIG_DA8XX_DDRCTL is not set
    CONFIG_PL353_SMC=y
    # CONFIG_RENESAS_RPCIF is not set
    # CONFIG_STM32_FMC2_EBI is not set
    # CONFIG_SAMSUNG_MC is not set
    CONFIG_TEGRA_MC=y
    CONFIG_TEGRA20_EMC=y
    CONFIG_TEGRA30_EMC=y
    CONFIG_TEGRA124_EMC=y
    # CONFIG_TEGRA210_EMC is not set
    CONFIG_IIO=y
    CONFIG_IIO_BUFFER=y
    CONFIG_IIO_BUFFER_CB=m
    # CONFIG_IIO_BUFFER_DMA is not set
    # CONFIG_IIO_BUFFER_DMAENGINE is not set
    CONFIG_IIO_BUFFER_HW_CONSUMER=m
    CONFIG_IIO_KFIFO_BUF=y
    CONFIG_IIO_TRIGGERED_BUFFER=y
    CONFIG_IIO_CONFIGFS=y
    CONFIG_IIO_TRIGGER=y
    CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
    # CONFIG_IIO_SW_DEVICE is not set
    CONFIG_IIO_SW_TRIGGER=y
    # CONFIG_IIO_TRIGGERED_EVENT is not set
    # Accelerometers
    # CONFIG_ADIS16201 is not set
    # CONFIG_ADIS16209 is not set
    # CONFIG_ADXL313_I2C is not set
    # CONFIG_ADXL313_SPI is not set
    # CONFIG_ADXL355_I2C is not set
    # CONFIG_ADXL355_SPI is not set
    # CONFIG_ADXL367_SPI is not set
    # CONFIG_ADXL367_I2C is not set
    # CONFIG_ADXL372_SPI is not set
    # CONFIG_ADXL372_I2C is not set
    # CONFIG_BMA180 is not set
    # CONFIG_BMA220 is not set
    # CONFIG_BMA400 is not set
    # CONFIG_BMC150_ACCEL is not set
    # CONFIG_BMI088_ACCEL is not set
    # CONFIG_DA280 is not set
    # CONFIG_DA311 is not set
    # CONFIG_DMARD06 is not set
    # CONFIG_DMARD09 is not set
    # CONFIG_DMARD10 is not set
    # CONFIG_FXLS8962AF_I2C is not set
    # CONFIG_FXLS8962AF_SPI is not set
    # CONFIG_IIO_ST_ACCEL_3AXIS is not set
    # CONFIG_KXSD9 is not set
    # CONFIG_KXCJK1013 is not set
    # CONFIG_MC3230 is not set
    # CONFIG_MMA7455_I2C is not set
    # CONFIG_MMA7455_SPI is not set
    # CONFIG_MMA7660 is not set
    # CONFIG_MMA8452 is not set
    # CONFIG_MMA9551 is not set
    # CONFIG_MMA9553 is not set
    # CONFIG_MSA311 is not set
    # CONFIG_MXC4005 is not set
    # CONFIG_MXC6255 is not set
    # CONFIG_SCA3000 is not set
    # CONFIG_SCA3300 is not set
    # CONFIG_STK8312 is not set
    # CONFIG_STK8BA50 is not set
    # CONFIG_AD7091R5 is not set
    # CONFIG_AD7124 is not set
    # CONFIG_AD7192 is not set
    # CONFIG_AD7266 is not set
    # CONFIG_AD7280 is not set
    # CONFIG_AD7291 is not set
    # CONFIG_AD7292 is not set
    # CONFIG_AD7298 is not set
    # CONFIG_AD7476 is not set
    # CONFIG_AD7606_IFACE_PARALLEL is not set
    # CONFIG_AD7606_IFACE_SPI is not set
    # CONFIG_AD7766 is not set
    # CONFIG_AD7768_1 is not set
    # CONFIG_AD7780 is not set
    # CONFIG_AD7791 is not set
    # CONFIG_AD7793 is not set
    # CONFIG_AD7887 is not set
    # CONFIG_AD7923 is not set
    # CONFIG_AD7949 is not set
    # CONFIG_AD799X is not set
    # CONFIG_ADI_AXI_ADC is not set
    # CONFIG_ASPEED_ADC is not set
    # CONFIG_AT91_ADC is not set
    # CONFIG_AT91_SAMA5D2_ADC is not set
    # CONFIG_BCM_IPROC_ADC is not set
    # CONFIG_BERLIN2_ADC is not set
    # CONFIG_CC10001_ADC is not set
    CONFIG_CPCAP_ADC=m
    # CONFIG_ENVELOPE_DETECTOR is not set
    # CONFIG_EXYNOS_ADC is not set
    # CONFIG_HI8435 is not set
    # CONFIG_HX711 is not set
    # CONFIG_INA2XX_ADC is not set
    # CONFIG_INGENIC_ADC is not set
    # CONFIG_IMX7D_ADC is not set
    # CONFIG_IMX8QXP_ADC is not set
    # CONFIG_LPC18XX_ADC is not set
    # CONFIG_LPC32XX_ADC is not set
    # CONFIG_LTC2471 is not set
    # CONFIG_LTC2485 is not set
    # CONFIG_LTC2496 is not set
    # CONFIG_LTC2497 is not set
    # CONFIG_MAX1027 is not set
    # CONFIG_MAX11100 is not set
    # CONFIG_MAX1118 is not set
    # CONFIG_MAX11205 is not set
    # CONFIG_MAX1241 is not set
    # CONFIG_MAX1363 is not set
    # CONFIG_MAX9611 is not set
    # CONFIG_MCP320X is not set
    # CONFIG_MCP3422 is not set
    # CONFIG_MCP3911 is not set
    # CONFIG_MEDIATEK_MT6577_AUXADC is not set
    # CONFIG_MESON_SARADC is not set
    # CONFIG_NAU7802 is not set
    # CONFIG_NPCM_ADC is not set
    # CONFIG_PALMAS_GPADC is not set
    CONFIG_QCOM_VADC_COMMON=m
    # CONFIG_QCOM_SPMI_IADC is not set
    CONFIG_QCOM_SPMI_VADC=m
    # CONFIG_QCOM_SPMI_ADC5 is not set
    # CONFIG_RCAR_GYRO_ADC is not set
    # CONFIG_ROCKCHIP_SARADC is not set
    # CONFIG_RICHTEK_RTQ6056 is not set
    # CONFIG_RZG2L_ADC is not set
    # CONFIG_SC27XX_ADC is not set
    # CONFIG_SPEAR_ADC is not set
    # CONFIG_SD_ADC_MODULATOR is not set
    # CONFIG_STM32_ADC_CORE is not set
    # CONFIG_STM32_DFSDM_CORE is not set
    # CONFIG_STM32_DFSDM_ADC is not set
    # CONFIG_TI_ADC081C is not set
    # CONFIG_TI_ADC0832 is not set
    # CONFIG_TI_ADC084S021 is not set
    # CONFIG_TI_ADC12138 is not set
    # CONFIG_TI_ADC108S102 is not set
    # CONFIG_TI_ADC128S052 is not set
    # CONFIG_TI_ADC161S626 is not set
    # CONFIG_TI_ADS1015 is not set
    # CONFIG_TI_ADS7950 is not set
    # CONFIG_TI_ADS8344 is not set
    # CONFIG_TI_ADS8688 is not set
    # CONFIG_TI_ADS124S08 is not set
    # CONFIG_TI_ADS131E08 is not set
    CONFIG_TI_AM335X_ADC=y
    # CONFIG_TI_TLC4541 is not set
    # CONFIG_TI_TSC2046 is not set
    # CONFIG_TWL4030_MADC is not set
    # CONFIG_TWL6030_GPADC is not set
    CONFIG_VF610_ADC=m
    CONFIG_XILINX_XADC=y
    # CONFIG_XILINX_AMS is not set
    # Analog to digital and digital to analog converters
    # CONFIG_AD74413R is not set
    # end of Analog to digital and digital to analog converters
    # Analog Front Ends
    # CONFIG_IIO_RESCALE is not set
    # end of Analog Front Ends
    # Amplifiers
    # CONFIG_AD8366 is not set
    # CONFIG_ADA4250 is not set
    # CONFIG_HMC425 is not set
    # end of Amplifiers
    # Capacitance to digital converters
    # CONFIG_AD7150 is not set
    # CONFIG_AD7746 is not set
    # end of Capacitance to digital converters
    # Chemical Sensors
    # CONFIG_ATLAS_PH_SENSOR is not set
    # CONFIG_ATLAS_EZO_SENSOR is not set
    # CONFIG_BME680 is not set
    # CONFIG_CCS811 is not set
    # CONFIG_IAQCORE is not set
    # CONFIG_PMS7003 is not set
    # CONFIG_SCD30_CORE is not set
    # CONFIG_SCD4X is not set
    # CONFIG_SENSIRION_SGP30 is not set
    # CONFIG_SENSIRION_SGP40 is not set
    # CONFIG_SPS30_I2C is not set
    # CONFIG_SPS30_SERIAL is not set
    # CONFIG_SENSEAIR_SUNRISE_CO2 is not set
    # CONFIG_VZ89X is not set
    # end of Chemical Sensors
    # Hid Sensor IIO Common
    # end of Hid Sensor IIO Common
    # IIO SCMI Sensors
    # CONFIG_IIO_SCMI is not set
    # end of IIO SCMI Sensors
    # SSP Sensor Common
    # CONFIG_IIO_SSP_SENSORHUB is not set
    # end of SSP Sensor Common
    # Digital to analog converters
    # CONFIG_AD3552R is not set
    # CONFIG_AD5064 is not set
    # CONFIG_AD5360 is not set
    # CONFIG_AD5380 is not set
    # CONFIG_AD5421 is not set
    # CONFIG_AD5446 is not set
    # CONFIG_AD5449 is not set
    # CONFIG_AD5592R is not set
    # CONFIG_AD5593R is not set
    # CONFIG_AD5504 is not set
    # CONFIG_AD5624R_SPI is not set
    # CONFIG_LTC2688 is not set
    # CONFIG_AD5686_SPI is not set
    # CONFIG_AD5696_I2C is not set
    # CONFIG_AD5755 is not set
    # CONFIG_AD5758 is not set
    # CONFIG_AD5761 is not set
    # CONFIG_AD5764 is not set
    # CONFIG_AD5766 is not set
    # CONFIG_AD5770R is not set
    # CONFIG_AD5791 is not set
    # CONFIG_AD7293 is not set
    # CONFIG_AD7303 is not set
    # CONFIG_AD8801 is not set
    # CONFIG_DPOT_DAC is not set
    # CONFIG_DS4424 is not set
    # CONFIG_LPC18XX_DAC is not set
    # CONFIG_LTC1660 is not set
    # CONFIG_LTC2632 is not set
    # CONFIG_M62332 is not set
    # CONFIG_MAX517 is not set
    # CONFIG_MAX5821 is not set
    # CONFIG_MCP4725 is not set
    # CONFIG_MCP4922 is not set
    # CONFIG_STM32_DAC is not set
    # CONFIG_TI_DAC082S085 is not set
    # CONFIG_TI_DAC5571 is not set
    # CONFIG_TI_DAC7311 is not set
    # CONFIG_TI_DAC7612 is not set
    # CONFIG_VF610_DAC is not set
    # end of Digital to analog converters
    # IIO dummy driver
    # end of IIO dummy driver
    # Filters
    # end of Filters
    # Frequency Synthesizers DDS/PLL
    # Clock Generator/Distribution
    # CONFIG_AD9523 is not set
    # end of Clock Generator/Distribution
    # Phase-Locked Loop (PLL) frequency synthesizers
    # CONFIG_ADF4350 is not set
    # CONFIG_ADF4371 is not set
    # CONFIG_ADMV1013 is not set
    # CONFIG_ADMV4420 is not set
    # CONFIG_ADRF6780 is not set
    # end of Phase-Locked Loop (PLL) frequency synthesizers
    # end of Frequency Synthesizers DDS/PLL
    # Digital gyroscope sensors
    # CONFIG_ADIS16080 is not set
    # CONFIG_ADIS16130 is not set
    # CONFIG_ADIS16136 is not set
    # CONFIG_ADIS16260 is not set
    # CONFIG_ADXRS290 is not set
    # CONFIG_ADXRS450 is not set
    # CONFIG_BMG160 is not set
    # CONFIG_FXAS21002C is not set
    CONFIG_MPU3050=y
    CONFIG_MPU3050_I2C=y
    # CONFIG_IIO_ST_GYRO_3AXIS is not set
    # CONFIG_ITG3200 is not set
    # end of Digital gyroscope sensors
    # Health Sensors
    # Heart Rate Monitors
    # CONFIG_AFE4403 is not set
    # CONFIG_AFE4404 is not set
    # CONFIG_MAX30100 is not set
    # CONFIG_MAX30102 is not set
    # end of Heart Rate Monitors
    # end of Health Sensors
    # Humidity sensors
    # CONFIG_AM2315 is not set
    # CONFIG_DHT11 is not set
    # CONFIG_HDC100X is not set
    # CONFIG_HDC2010 is not set
    # CONFIG_HTS221 is not set
    # CONFIG_HTU21 is not set
    # CONFIG_SI7005 is not set
    # CONFIG_SI7020 is not set
    # end of Humidity sensors
    # Inertial measurement units
    # CONFIG_ADIS16400 is not set
    # CONFIG_ADIS16460 is not set
    # CONFIG_ADIS16475 is not set
    # CONFIG_ADIS16480 is not set
    # CONFIG_BMI160_I2C is not set
    # CONFIG_BMI160_SPI is not set
    # CONFIG_BOSCH_BNO055_SERIAL is not set
    # CONFIG_BOSCH_BNO055_I2C is not set
    # CONFIG_FXOS8700_I2C is not set
    # CONFIG_FXOS8700_SPI is not set
    # CONFIG_KMX61 is not set
    # CONFIG_INV_ICM42600_I2C is not set
    # CONFIG_INV_ICM42600_SPI is not set
    # CONFIG_INV_MPU6050_I2C is not set
    # CONFIG_INV_MPU6050_SPI is not set
    # CONFIG_IIO_ST_LSM6DSX is not set
    # CONFIG_IIO_ST_LSM9DS0 is not set
    # end of Inertial measurement units
    # Light sensors
    # CONFIG_ADJD_S311 is not set
    # CONFIG_ADUX1020 is not set
    # CONFIG_AL3010 is not set
    # CONFIG_AL3320A is not set
    # CONFIG_APDS9300 is not set
    # CONFIG_APDS9960 is not set
    # CONFIG_AS73211 is not set
    # CONFIG_BH1750 is not set
    # CONFIG_BH1780 is not set
    # CONFIG_CM32181 is not set
    # CONFIG_CM3232 is not set
    # CONFIG_CM3323 is not set
    # CONFIG_CM3605 is not set
    CONFIG_CM36651=m
    # CONFIG_GP2AP002 is not set
    # CONFIG_GP2AP020A00F is not set
    # CONFIG_IQS621_ALS is not set
    CONFIG_SENSORS_ISL29018=y
    CONFIG_SENSORS_ISL29028=y
    # CONFIG_ISL29125 is not set
    # CONFIG_JSA1212 is not set
    # CONFIG_RPR0521 is not set
    # CONFIG_LTR501 is not set
    # CONFIG_LTRF216A is not set
    # CONFIG_LV0104CS is not set
    # CONFIG_MAX44000 is not set
    # CONFIG_MAX44009 is not set
    # CONFIG_NOA1305 is not set
    # CONFIG_OPT3001 is not set
    # CONFIG_PA12203001 is not set
    # CONFIG_SI1133 is not set
    # CONFIG_SI1145 is not set
    # CONFIG_STK3310 is not set
    # CONFIG_ST_UVIS25 is not set
    # CONFIG_TCS3414 is not set
    # CONFIG_TCS3472 is not set
    # CONFIG_SENSORS_TSL2563 is not set
    # CONFIG_TSL2583 is not set
    # CONFIG_TSL2591 is not set
    # CONFIG_TSL2772 is not set
    # CONFIG_TSL4531 is not set
    # CONFIG_US5182D is not set
    # CONFIG_VCNL4000 is not set
    # CONFIG_VCNL4035 is not set
    # CONFIG_VEML6030 is not set
    # CONFIG_VEML6070 is not set
    # CONFIG_VL6180 is not set
    # CONFIG_ZOPT2201 is not set
    # end of Light sensors
    # Magnetometer sensors
    # CONFIG_AK8974 is not set
    CONFIG_AK8975=y
    # CONFIG_AK09911 is not set
    # CONFIG_BMC150_MAGN_I2C is not set
    # CONFIG_BMC150_MAGN_SPI is not set
    # CONFIG_MAG3110 is not set
    # CONFIG_MMC35240 is not set
    # CONFIG_IIO_ST_MAGN_3AXIS is not set
    # CONFIG_SENSORS_HMC5843_I2C is not set
    # CONFIG_SENSORS_HMC5843_SPI is not set
    # CONFIG_SENSORS_RM3100_I2C is not set
    # CONFIG_SENSORS_RM3100_SPI is not set
    # CONFIG_YAMAHA_YAS530 is not set
    # end of Magnetometer sensors
    # Multiplexers
    # CONFIG_IIO_MUX is not set
    # end of Multiplexers
    # Inclinometer sensors
    # end of Inclinometer sensors
    # Triggers - standalone
    CONFIG_IIO_HRTIMER_TRIGGER=y
    # CONFIG_IIO_INTERRUPT_TRIGGER is not set
    # CONFIG_IIO_STM32_LPTIMER_TRIGGER is not set
    # CONFIG_IIO_STM32_TIMER_TRIGGER is not set
    # CONFIG_IIO_TIGHTLOOP_TRIGGER is not set
    # CONFIG_IIO_SYSFS_TRIGGER is not set
    # end of Triggers - standalone
    # Linear and angular position sensors
    # CONFIG_IQS624_POS is not set
    # end of Linear and angular position sensors
    # Digital potentiometers
    # CONFIG_AD5110 is not set
    # CONFIG_AD5272 is not set
    # CONFIG_DS1803 is not set
    # CONFIG_MAX5432 is not set
    # CONFIG_MAX5481 is not set
    # CONFIG_MAX5487 is not set
    # CONFIG_MCP4018 is not set
    # CONFIG_MCP4131 is not set
    # CONFIG_MCP4531 is not set
    # CONFIG_MCP41010 is not set
    # CONFIG_TPL0102 is not set
    # end of Digital potentiometers
    # Digital potentiostats
    # CONFIG_LMP91000 is not set
    # end of Digital potentiostats
    # Pressure sensors
    # CONFIG_ABP060MG is not set
    # CONFIG_BMP280 is not set
    # CONFIG_DLHL60D is not set
    # CONFIG_DPS310 is not set
    # CONFIG_HP03 is not set
    # CONFIG_ICP10100 is not set
    # CONFIG_MPL115_I2C is not set
    # CONFIG_MPL115_SPI is not set
    # CONFIG_MPL3115 is not set
    # CONFIG_MS5611 is not set
    # CONFIG_MS5637 is not set
    # CONFIG_IIO_ST_PRESS is not set
    # CONFIG_T5403 is not set
    # CONFIG_HP206C is not set
    # CONFIG_ZPA2326 is not set
    # end of Pressure sensors
    # Lightning sensors
    # CONFIG_AS3935 is not set
    # end of Lightning sensors
    # Proximity and distance sensors
    # CONFIG_ISL29501 is not set
    # CONFIG_LIDAR_LITE_V2 is not set
    # CONFIG_MB1232 is not set
    # CONFIG_PING is not set
    # CONFIG_RFD77402 is not set
    # CONFIG_SRF04 is not set
    # CONFIG_SX9310 is not set
    # CONFIG_SX9324 is not set
    # CONFIG_SX9360 is not set
    # CONFIG_SX9500 is not set
    # CONFIG_SRF08 is not set
    # CONFIG_VCNL3020 is not set
    # CONFIG_VL53L0X_I2C is not set
    # end of Proximity and distance sensors
    # CONFIG_AD2S90 is not set
    # CONFIG_AD2S1200 is not set
    # Temperature sensors
    # CONFIG_IQS620AT_TEMP is not set
    # CONFIG_LTC2983 is not set
    # CONFIG_MAXIM_THERMOCOUPLE is not set
    # CONFIG_MLX90614 is not set
    # CONFIG_MLX90632 is not set
    # CONFIG_TMP006 is not set
    # CONFIG_TMP007 is not set
    # CONFIG_TMP117 is not set
    # CONFIG_TSYS01 is not set
    # CONFIG_TSYS02D is not set
    # CONFIG_MAX31856 is not set
    # CONFIG_MAX31865 is not set
    # end of Temperature sensors
    # CONFIG_NTB is not set
    CONFIG_PWM=y
    CONFIG_PWM_SYSFS=y
    # CONFIG_PWM_DEBUG is not set
    CONFIG_PWM_ATMEL=m
    # CONFIG_PWM_ATMEL_TCB is not set
    CONFIG_PWM_BCM_IPROC=y
    CONFIG_PWM_BCM_KONA=y
    CONFIG_PWM_BCM2835=y
    # CONFIG_PWM_BERLIN is not set
    CONFIG_PWM_BRCMSTB=m
    # CONFIG_PWM_CLK is not set
    # CONFIG_PWM_CLPS711X is not set
    # CONFIG_PWM_DWC is not set
    # CONFIG_PWM_EP93XX is not set
    # CONFIG_PWM_FSL_FTM is not set
    # CONFIG_PWM_HIBVT is not set
    # CONFIG_PWM_IMG is not set
    # CONFIG_PWM_IMX1 is not set
    # CONFIG_PWM_IMX27 is not set
    # CONFIG_PWM_IMX_TPM is not set
    # CONFIG_PWM_INTEL_LGM is not set
    # CONFIG_PWM_IQS620A is not set
    # CONFIG_PWM_JZ4740 is not set
    # CONFIG_PWM_KEEMBAY is not set
    # CONFIG_PWM_LPC18XX_SCT is not set
    # CONFIG_PWM_LPC32XX is not set
    # CONFIG_PWM_LPSS_PCI is not set
    # CONFIG_PWM_LPSS_PLATFORM is not set
    CONFIG_PWM_MESON=m
    # CONFIG_PWM_MTK_DISP is not set
    # CONFIG_PWM_MEDIATEK is not set
    # CONFIG_PWM_MXS is not set
    CONFIG_PWM_OMAP_DMTIMER=y
    # CONFIG_PWM_PCA9685 is not set
    # CONFIG_PWM_PXA is not set
    # CONFIG_PWM_RASPBERRYPI_POE is not set
    CONFIG_PWM_RCAR=m
    CONFIG_PWM_RENESAS_TPU=y
    CONFIG_PWM_ROCKCHIP=m
    CONFIG_PWM_SAMSUNG=m
    # CONFIG_PWM_SIFIVE is not set
    # CONFIG_PWM_SL28CPLD is not set
    # CONFIG_PWM_SPEAR is not set
    # CONFIG_PWM_SPRD is not set
    CONFIG_PWM_STI=y
    CONFIG_PWM_STM32=m
    CONFIG_PWM_STM32_LP=m
    CONFIG_PWM_SUN4I=y
    # CONFIG_PWM_SUNPLUS is not set
    CONFIG_PWM_TEGRA=y
    # CONFIG_PWM_TIECAP is not set
    # CONFIG_PWM_TIEHRPWM is not set
    # CONFIG_PWM_TWL is not set
    # CONFIG_PWM_TWL_LED is not set
    # CONFIG_PWM_VISCONTI is not set
    CONFIG_PWM_VT8500=y
    # CONFIG_PWM_XILINX is not set
    # IRQ chip support
    CONFIG_IRQCHIP=y
    CONFIG_ARM_GIC=y
    CONFIG_ARM_GIC_MAX_NR=1
    # CONFIG_AL_FIC is not set
    CONFIG_OMAP_IRQCHIP=y
    # CONFIG_JCORE_AIC is not set
    # CONFIG_RENESAS_INTC_IRQPIN is not set
    # CONFIG_RENESAS_IRQC is not set
    # CONFIG_RENESAS_RZA1_IRQC is not set
    # CONFIG_RENESAS_RZG2L_IRQC is not set
    # CONFIG_SL28CPLD_INTC is not set
    # CONFIG_TS4800_IRQ is not set
    # CONFIG_XILINX_INTC is not set
    CONFIG_IRQ_CROSSBAR=y
    CONFIG_KEYSTONE_IRQ=y
    # CONFIG_INGENIC_TCU_IRQ is not set
    # CONFIG_IRQ_UNIPHIER_AIDET is not set
    # CONFIG_MESON_IRQ_GPIO is not set
    # CONFIG_IMX_IRQSTEER is not set
    # CONFIG_IMX_INTMUX is not set
    # CONFIG_IMX_MU_MSI is not set
    # CONFIG_EXYNOS_IRQ_COMBINER is not set
    # CONFIG_MST_IRQ is not set
    # CONFIG_MCHP_EIC is not set
    # CONFIG_SUNPLUS_SP7021_INTC is not set
    # end of IRQ chip support
    # CONFIG_IPACK_BUS is not set
    CONFIG_ARCH_HAS_RESET_CONTROLLER=y
    CONFIG_RESET_CONTROLLER=y
    # CONFIG_RESET_A10SR is not set
    # CONFIG_RESET_ATH79 is not set
    # CONFIG_RESET_AXS10X is not set
    # CONFIG_RESET_BCM6345 is not set
    # CONFIG_RESET_BERLIN is not set
    # CONFIG_RESET_BRCMSTB is not set
    # CONFIG_RESET_BRCMSTB_RESCAL is not set
    # CONFIG_RESET_HSDK is not set
    # CONFIG_RESET_IMX7 is not set
    # CONFIG_RESET_INTEL_GW is not set
    # CONFIG_RESET_K210 is not set
    # CONFIG_RESET_LANTIQ is not set
    # CONFIG_RESET_LPC18XX is not set
    # CONFIG_RESET_MCHP_SPARX5 is not set
    # CONFIG_RESET_MESON is not set
    # CONFIG_RESET_MESON_AUDIO_ARB is not set
    # CONFIG_RESET_NPCM is not set
    # CONFIG_RESET_PISTACHIO is not set
    # CONFIG_RESET_QCOM_AOSS is not set
    # CONFIG_RESET_QCOM_PDC is not set
    CONFIG_RESET_RASPBERRYPI=y
    # CONFIG_RESET_RZG2L_USBPHY_CTRL is not set
    # CONFIG_RESET_SCMI is not set
    CONFIG_RESET_SIMPLE=y
    CONFIG_RESET_SOCFPGA=y
    # CONFIG_RESET_STARFIVE_JH7100 is not set
    # CONFIG_RESET_SUNPLUS is not set
    # CONFIG_RESET_SUNXI is not set
    # CONFIG_RESET_TI_SCI is not set
    # CONFIG_RESET_TI_SYSCON is not set
    # CONFIG_RESET_TI_TPS380X is not set
    # CONFIG_RESET_TN48M_CPLD is not set
    # CONFIG_RESET_UNIPHIER is not set
    # CONFIG_RESET_UNIPHIER_GLUE is not set
    # CONFIG_RESET_ZYNQ is not set
    # CONFIG_COMMON_RESET_HI3660 is not set
    # CONFIG_COMMON_RESET_HI6220 is not set
    # PHY Subsystem
    CONFIG_GENERIC_PHY=y
    # CONFIG_PHY_LPC18XX_USB_OTG is not set
    # CONFIG_PHY_PISTACHIO_USB is not set
    # CONFIG_PHY_XGENE is not set
    # CONFIG_USB_LGM_PHY is not set
    # CONFIG_PHY_CAN_TRANSCEIVER is not set
    # CONFIG_PHY_SUN4I_USB is not set
    # CONFIG_PHY_SUN6I_MIPI_DPHY is not set
    # CONFIG_PHY_SUN9I_USB is not set
    # CONFIG_PHY_SUN50I_USB3 is not set
    # CONFIG_PHY_MESON8_HDMI_TX is not set
    # CONFIG_PHY_MESON8B_USB2 is not set
    # CONFIG_PHY_MESON_GXL_USB2 is not set
    # CONFIG_PHY_MESON_G12A_MIPI_DPHY_ANALOG is not set
    # CONFIG_PHY_MESON_G12A_USB2 is not set
    # CONFIG_PHY_MESON_G12A_USB3_PCIE is not set
    # CONFIG_PHY_MESON_AXG_PCIE is not set
    # CONFIG_PHY_MESON_AXG_MIPI_PCIE_ANALOG is not set
    # CONFIG_PHY_MESON_AXG_MIPI_DPHY is not set
    # PHY drivers for Broadcom platforms
    # CONFIG_PHY_BCM63XX_USBH is not set
    # CONFIG_PHY_CYGNUS_PCIE is not set
    # CONFIG_PHY_BCM_SR_USB is not set
    # CONFIG_BCM_KONA_USB2_PHY is not set
    # CONFIG_PHY_BCM_NS_USB2 is not set
    # CONFIG_PHY_BCM_NS_USB3 is not set
    # CONFIG_PHY_NS2_PCIE is not set
    # CONFIG_PHY_NS2_USB_DRD is not set
    # CONFIG_PHY_BRCM_SATA is not set
    # CONFIG_PHY_BRCM_USB is not set
    # CONFIG_PHY_BCM_SR_PCIE is not set
    # end of PHY drivers for Broadcom platforms
    # CONFIG_PHY_CADENCE_TORRENT is not set
    # CONFIG_PHY_CADENCE_DPHY is not set
    # CONFIG_PHY_CADENCE_DPHY_RX is not set
    # CONFIG_PHY_CADENCE_SIERRA is not set
    # CONFIG_PHY_CADENCE_SALVO is not set
    # CONFIG_PHY_FSL_IMX8MQ_USB is not set
    # CONFIG_PHY_MIXEL_LVDS_PHY is not set
    # CONFIG_PHY_MIXEL_MIPI_DPHY is not set
    # CONFIG_PHY_FSL_IMX8M_PCIE is not set
    # CONFIG_PHY_FSL_LYNX_28G is not set
    # CONFIG_PHY_HI6220_USB is not set
    # CONFIG_PHY_HI3660_USB is not set
    # CONFIG_PHY_HI3670_USB is not set
    # CONFIG_PHY_HI3670_PCIE is not set
    # CONFIG_PHY_HISTB_COMBPHY is not set
    # CONFIG_PHY_HISI_INNO_USB2 is not set
    # CONFIG_PHY_INGENIC_USB is not set
    # CONFIG_PHY_LANTIQ_VRX200_PCIE is not set
    # CONFIG_PHY_LANTIQ_RCU_USB2 is not set
    # CONFIG_ARMADA375_USBCLUSTER_PHY is not set
    # CONFIG_PHY_BERLIN_SATA is not set
    # CONFIG_PHY_BERLIN_USB is not set
    CONFIG_PHY_MVEBU_A3700_COMPHY=y
    CONFIG_PHY_MVEBU_A3700_UTMI=y
    # CONFIG_PHY_MVEBU_A38X_COMPHY is not set
    # CONFIG_PHY_MVEBU_CP110_COMPHY is not set
    # CONFIG_PHY_MVEBU_CP110_UTMI is not set
    # CONFIG_PHY_PXA_28NM_HSIC is not set
    # CONFIG_PHY_PXA_28NM_USB2 is not set
    # CONFIG_PHY_PXA_USB is not set
    # CONFIG_PHY_MMP3_USB is not set
    # CONFIG_PHY_MMP3_HSIC is not set
    # CONFIG_PHY_MTK_PCIE is not set
    # CONFIG_PHY_MTK_TPHY is not set
    # CONFIG_PHY_MTK_UFS is not set
    # CONFIG_PHY_MTK_XSPHY is not set
    # CONFIG_PHY_MTK_HDMI is not set
    # CONFIG_PHY_MTK_MIPI_DSI is not set
    # CONFIG_PHY_MTK_DP is not set
    # CONFIG_PHY_SPARX5_SERDES is not set
    CONFIG_PHY_LAN966X_SERDES=m
    CONFIG_PHY_CPCAP_USB=m
    # CONFIG_PHY_MAPPHONE_MDM6600 is not set
    # CONFIG_PHY_OCELOT_SERDES is not set
    CONFIG_PHY_ATH79_USB=y
    # CONFIG_PHY_QCOM_EDP is not set
    # CONFIG_PHY_QCOM_IPQ4019_USB is not set
    # CONFIG_PHY_QCOM_PCIE2 is not set
    # CONFIG_PHY_QCOM_QMP is not set
    # CONFIG_PHY_QCOM_QUSB2 is not set
    CONFIG_PHY_QCOM_USB_HS=y
    # CONFIG_PHY_QCOM_USB_SNPS_FEMTO_V2 is not set
    # CONFIG_PHY_QCOM_USB_HSIC is not set
    # CONFIG_PHY_QCOM_USB_HS_28NM is not set
    # CONFIG_PHY_QCOM_USB_SS is not set
    # CONFIG_PHY_QCOM_IPQ806X_USB is not set
    # CONFIG_PHY_MT7621_PCI is not set
    # CONFIG_PHY_RALINK_USB is not set
    # CONFIG_PHY_RCAR_GEN3_USB3 is not set
    # CONFIG_PHY_ROCKCHIP_DPHY_RX0 is not set
    # CONFIG_PHY_ROCKCHIP_INNO_HDMI is not set
    # CONFIG_PHY_ROCKCHIP_INNO_USB2 is not set
    # CONFIG_PHY_ROCKCHIP_INNO_CSIDPHY is not set
    # CONFIG_PHY_ROCKCHIP_INNO_DSIDPHY is not set
    # CONFIG_PHY_ROCKCHIP_PCIE is not set
    # CONFIG_PHY_ROCKCHIP_SNPS_PCIE3 is not set
    # CONFIG_PHY_ROCKCHIP_TYPEC is not set
    # CONFIG_PHY_EXYNOS_DP_VIDEO is not set
    # CONFIG_PHY_EXYNOS_MIPI_VIDEO is not set
    # CONFIG_PHY_EXYNOS_PCIE is not set
    # CONFIG_PHY_SAMSUNG_UFS is not set
    # CONFIG_PHY_SAMSUNG_USB2 is not set
    CONFIG_PHY_EXYNOS5_USBDRD=y
    # CONFIG_PHY_UNIPHIER_USB2 is not set
    # CONFIG_PHY_UNIPHIER_USB3 is not set
    # CONFIG_PHY_UNIPHIER_PCIE is not set
    CONFIG_PHY_UNIPHIER_AHCI=m
    # CONFIG_PHY_ST_SPEAR1310_MIPHY is not set
    # CONFIG_PHY_ST_SPEAR1340_MIPHY is not set
    # CONFIG_PHY_STIH407_USB is not set
    # CONFIG_PHY_STM32_USBPHYC is not set
    # CONFIG_PHY_SUNPLUS_USB is not set
    # CONFIG_PHY_TEGRA194_P2U is not set
    # CONFIG_PHY_DA8XX_USB is not set
    CONFIG_PHY_DM816X_USB=m
    # CONFIG_PHY_AM654_SERDES is not set
    # CONFIG_PHY_J721E_WIZ is not set
    CONFIG_OMAP_CONTROL_PHY=y
    CONFIG_OMAP_USB2=y
    CONFIG_TI_PIPE3=y
    # CONFIG_PHY_TUSB1210 is not set
    CONFIG_PHY_TI_GMII_SEL=y
    # CONFIG_PHY_INTEL_KEEMBAY_EMMC is not set
    # CONFIG_PHY_INTEL_KEEMBAY_USB is not set
    # CONFIG_PHY_INTEL_LGM_COMBO is not set
    # CONFIG_PHY_INTEL_LGM_EMMC is not set
    # CONFIG_PHY_INTEL_THUNDERBAY_EMMC is not set
    # CONFIG_PHY_XILINX_ZYNQMP is not set
    # end of PHY Subsystem
    # CONFIG_POWERCAP is not set
    # CONFIG_MCB is not set
    # Performance monitor support
    # CONFIG_ARM_CCI_PMU is not set
    # CONFIG_ARM_CCN is not set
    # CONFIG_ARM_CMN is not set
    CONFIG_ARM_PMU=y
    # CONFIG_FSL_IMX8_DDR_PMU is not set
    # CONFIG_ARM_DMC620_PMU is not set
    # CONFIG_ALIBABA_UNCORE_DRW_PMU is not set
    # CONFIG_HNS3_PMU is not set
    # end of Performance monitor support
    CONFIG_RAS=y
    # CONFIG_USB4 is not set
    # Android
    # CONFIG_ANDROID_BINDER_IPC is not set
    # end of Android
    # CONFIG_DAX is not set
    CONFIG_NVMEM=y
    CONFIG_NVMEM_SYSFS=y
    # CONFIG_NVMEM_APPLE_EFUSES is not set
    # CONFIG_NVMEM_BCM_OCOTP is not set
    # CONFIG_NVMEM_BRCM_NVRAM is not set
    # CONFIG_NVMEM_IMX_IIM is not set
    # CONFIG_NVMEM_IMX_OCOTP is not set
    # CONFIG_NVMEM_JZ4780_EFUSE is not set
    # CONFIG_NVMEM_LAN9662_OTPC is not set
    # CONFIG_NVMEM_LAYERSCAPE_SFP is not set
    # CONFIG_NVMEM_LPC18XX_EEPROM is not set
    # CONFIG_NVMEM_LPC18XX_OTP is not set
    # CONFIG_NVMEM_MESON_MX_EFUSE is not set
    # CONFIG_NVMEM_MICROCHIP_OTPC is not set
    # CONFIG_NVMEM_MTK_EFUSE is not set
    # CONFIG_NVMEM_MXS_OCOTP is not set
    # CONFIG_NVMEM_NINTENDO_OTP is not set
    # CONFIG_NVMEM_QCOM_QFPROM is not set
    CONFIG_NVMEM_RMEM=m
    # CONFIG_NVMEM_ROCKCHIP_EFUSE is not set
    # CONFIG_NVMEM_ROCKCHIP_OTP is not set
    # CONFIG_NVMEM_SC27XX_EFUSE is not set
    # CONFIG_NVMEM_SNVS_LPGPR is not set
    # CONFIG_NVMEM_SPMI_SDAM is not set
    # CONFIG_NVMEM_SPRD_EFUSE is not set
    # CONFIG_NVMEM_STM32_ROMEM is not set
    # CONFIG_NVMEM_SUNPLUS_OCOTP is not set
    # CONFIG_NVMEM_U_BOOT_ENV is not set
    # CONFIG_NVMEM_UNIPHIER_EFUSE is not set
    # CONFIG_NVMEM_VF610_OCOTP is not set
    # HW tracing support
    # CONFIG_STM is not set
    # CONFIG_INTEL_TH is not set
    # end of HW tracing support
    # CONFIG_FPGA is not set
    CONFIG_FSI=m
    # CONFIG_FSI_NEW_DEV_NODE is not set
    CONFIG_FSI_MASTER_GPIO=m
    CONFIG_FSI_MASTER_HUB=m
    CONFIG_FSI_MASTER_ASPEED=m
    CONFIG_FSI_SCOM=m
    CONFIG_FSI_SBEFIFO=m
    CONFIG_FSI_OCC=m
    # CONFIG_TEE is not set
    CONFIG_PM_OPP=y
    # CONFIG_SIOX is not set
    # CONFIG_SLIMBUS is not set
    CONFIG_INTERCONNECT=y
    # CONFIG_INTERCONNECT_IMX is not set
    # CONFIG_INTERCONNECT_QCOM_OSM_L3 is not set
    # CONFIG_INTERCONNECT_SAMSUNG is not set
    CONFIG_COUNTER=m
    # CONFIG_104_QUAD_8 is not set
    # CONFIG_INTERRUPT_CNT is not set
    CONFIG_STM32_TIMER_CNT=m
    CONFIG_STM32_LPTIMER_CNT=m
    # CONFIG_TI_EQEP is not set
    # CONFIG_FTM_QUADDEC is not set
    # CONFIG_MICROCHIP_TCB_CAPTURE is not set
    # CONFIG_INTEL_QEP is not set
    # CONFIG_TI_ECAP_CAPTURE is not set
    # CONFIG_MOST is not set
    # CONFIG_PECI is not set
    # CONFIG_HTE is not set
    # end of Device Drivers
    # File systems
    CONFIG_DCACHE_WORD_ACCESS=y
    # CONFIG_VALIDATE_FS_PARSER is not set
    CONFIG_FS_IOMAP=y
    CONFIG_EXT2_FS=y
    CONFIG_EXT2_FS_XATTR=y
    # CONFIG_EXT2_FS_POSIX_ACL is not set
    CONFIG_EXT2_FS_SECURITY=y
    CONFIG_EXT3_FS=y
    CONFIG_EXT3_FS_POSIX_ACL=y
    CONFIG_EXT3_FS_SECURITY=y
    CONFIG_EXT4_FS=y
    CONFIG_EXT4_FS_POSIX_ACL=y
    CONFIG_EXT4_FS_SECURITY=y
    # CONFIG_EXT4_DEBUG is not set
    CONFIG_JBD2=y
    # CONFIG_JBD2_DEBUG is not set
    CONFIG_FS_MBCACHE=y
    CONFIG_REISERFS_FS=y
    # CONFIG_REISERFS_CHECK is not set
    # CONFIG_REISERFS_PROC_INFO is not set
    CONFIG_REISERFS_FS_XATTR=y
    # CONFIG_REISERFS_FS_POSIX_ACL is not set
    CONFIG_REISERFS_FS_SECURITY=y
    CONFIG_JFS_FS=y
    # CONFIG_JFS_POSIX_ACL is not set
    CONFIG_JFS_SECURITY=y
    # CONFIG_JFS_DEBUG is not set
    # CONFIG_JFS_STATISTICS is not set
    # CONFIG_XFS_FS is not set
    # CONFIG_GFS2_FS is not set
    # CONFIG_OCFS2_FS is not set
    CONFIG_BTRFS_FS=y
    CONFIG_BTRFS_FS_POSIX_ACL=y
    # CONFIG_BTRFS_FS_CHECK_INTEGRITY is not set
    # CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set
    # CONFIG_BTRFS_DEBUG is not set
    # CONFIG_BTRFS_ASSERT is not set
    # CONFIG_BTRFS_FS_REF_VERIFY is not set
    # CONFIG_NILFS2_FS is not set
    # CONFIG_F2FS_FS is not set
    CONFIG_FS_POSIX_ACL=y
    CONFIG_EXPORTFS=y
    # CONFIG_EXPORTFS_BLOCK_OPS is not set
    CONFIG_FILE_LOCKING=y
    # CONFIG_FS_ENCRYPTION is not set
    # CONFIG_FS_VERITY is not set
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY_USER=y
    CONFIG_FANOTIFY=y
    # CONFIG_FANOTIFY_ACCESS_PERMISSIONS is not set
    CONFIG_QUOTA=y
    # CONFIG_QUOTA_NETLINK_INTERFACE is not set
    CONFIG_PRINT_QUOTA_WARNING=y
    # CONFIG_QUOTA_DEBUG is not set
    # CONFIG_QFMT_V1 is not set
    # CONFIG_QFMT_V2 is not set
    CONFIG_QUOTACTL=y
    CONFIG_AUTOFS4_FS=y
    CONFIG_AUTOFS_FS=y
    # CONFIG_FUSE_FS is not set
    # CONFIG_OVERLAY_FS is not set
    # Caches
    # CONFIG_FSCACHE is not set
    # end of Caches
    # CD-ROM/DVD Filesystems
    # CONFIG_ISO9660_FS is not set
    # CONFIG_UDF_FS is not set
    # end of CD-ROM/DVD Filesystems
    # DOS/FAT/EXFAT/NT Filesystems
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    # CONFIG_FAT_DEFAULT_UTF8 is not set
    CONFIG_EXFAT_FS=y
    CONFIG_EXFAT_DEFAULT_IOCHARSET="utf8"
    CONFIG_NTFS_FS=y
    # CONFIG_NTFS_DEBUG is not set
    # CONFIG_NTFS_RW is not set
    CONFIG_NTFS3_FS=y
    # CONFIG_NTFS3_LZX_XPRESS is not set
    # CONFIG_NTFS3_FS_POSIX_ACL is not set
    # end of DOS/FAT/EXFAT/NT Filesystems
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    # CONFIG_PROC_CHILDREN is not set
    CONFIG_KERNFS=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    CONFIG_TMPFS_POSIX_ACL=y
    CONFIG_TMPFS_XATTR=y
    CONFIG_MEMFD_CREATE=y
    CONFIG_CONFIGFS_FS=y
    CONFIG_EFIVAR_FS=m
    # end of Pseudo filesystems
    CONFIG_MISC_FILESYSTEMS=y
    # CONFIG_ORANGEFS_FS is not set
    # CONFIG_ADFS_FS is not set
    # CONFIG_AFFS_FS is not set
    # CONFIG_ECRYPT_FS is not set
    # CONFIG_HFS_FS is not set
    # CONFIG_HFSPLUS_FS is not set
    # CONFIG_BEFS_FS is not set
    # CONFIG_BFS_FS is not set
    # CONFIG_EFS_FS is not set
    CONFIG_JFFS2_FS=y
    CONFIG_JFFS2_FS_DEBUG=0
    CONFIG_JFFS2_FS_WRITEBUFFER=y
    # CONFIG_JFFS2_FS_WBUF_VERIFY is not set
    CONFIG_JFFS2_SUMMARY=y
    CONFIG_JFFS2_FS_XATTR=y
    CONFIG_JFFS2_FS_POSIX_ACL=y
    CONFIG_JFFS2_FS_SECURITY=y
    # CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
    CONFIG_JFFS2_ZLIB=y
    CONFIG_JFFS2_RTIME=y
    CONFIG_UBIFS_FS=y
    # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
    CONFIG_UBIFS_FS_LZO=y
    CONFIG_UBIFS_FS_ZLIB=y
    CONFIG_UBIFS_FS_ZSTD=y
    # CONFIG_UBIFS_ATIME_SUPPORT is not set
    CONFIG_UBIFS_FS_XATTR=y
    CONFIG_UBIFS_FS_SECURITY=y
    # CONFIG_UBIFS_FS_AUTHENTICATION is not set
    # CONFIG_CRAMFS is not set
    CONFIG_SQUASHFS=y
    CONFIG_SQUASHFS_FILE_CACHE=y
    # CONFIG_SQUASHFS_FILE_DIRECT is not set
    CONFIG_SQUASHFS_DECOMP_SINGLE=y
    # CONFIG_SQUASHFS_DECOMP_MULTI is not set
    # CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set
    # CONFIG_SQUASHFS_XATTR is not set
    CONFIG_SQUASHFS_ZLIB=y
    # CONFIG_SQUASHFS_LZ4 is not set
    CONFIG_SQUASHFS_LZO=y
    CONFIG_SQUASHFS_XZ=y
    # CONFIG_SQUASHFS_ZSTD is not set
    # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set
    # CONFIG_SQUASHFS_EMBEDDED is not set
    CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
    # CONFIG_VXFS_FS is not set
    # CONFIG_MINIX_FS is not set
    # CONFIG_OMFS_FS is not set
    # CONFIG_HPFS_FS is not set
    # CONFIG_QNX4FS_FS is not set
    # CONFIG_QNX6FS_FS is not set
    # CONFIG_ROMFS_FS is not set
    CONFIG_PSTORE=y
    CONFIG_PSTORE_DEFAULT_KMSG_BYTES=10240
    CONFIG_PSTORE_DEFLATE_COMPRESS=y
    # CONFIG_PSTORE_LZO_COMPRESS is not set
    # CONFIG_PSTORE_LZ4_COMPRESS is not set
    # CONFIG_PSTORE_LZ4HC_COMPRESS is not set
    # CONFIG_PSTORE_842_COMPRESS is not set
    # CONFIG_PSTORE_ZSTD_COMPRESS is not set
    CONFIG_PSTORE_COMPRESS=y
    CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT=y
    CONFIG_PSTORE_COMPRESS_DEFAULT="deflate"
    CONFIG_PSTORE_CONSOLE=y
    CONFIG_PSTORE_PMSG=y
    CONFIG_PSTORE_RAM=y
    # CONFIG_PSTORE_BLK is not set
    # CONFIG_SYSV_FS is not set
    # CONFIG_UFS_FS is not set
    # CONFIG_EROFS_FS is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V2=y
    CONFIG_NFS_V3=y
    CONFIG_NFS_V3_ACL=y
    CONFIG_NFS_V4=y
    # CONFIG_NFS_SWAP is not set
    CONFIG_NFS_V4_1=y
    CONFIG_NFS_V4_2=y
    CONFIG_PNFS_FILE_LAYOUT=y
    CONFIG_PNFS_FLEXFILE_LAYOUT=y
    CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
    # CONFIG_NFS_V4_1_MIGRATION is not set
    CONFIG_NFS_V4_SECURITY_LABEL=y
    CONFIG_ROOT_NFS=y
    # CONFIG_NFS_USE_LEGACY_DNS is not set
    CONFIG_NFS_USE_KERNEL_DNS=y
    CONFIG_NFS_DISABLE_UDP_SUPPORT=y
    # CONFIG_NFS_V4_2_READ_PLUS is not set
    # CONFIG_NFSD is not set
    CONFIG_GRACE_PERIOD=y
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_ACL_SUPPORT=y
    CONFIG_NFS_COMMON=y
    CONFIG_NFS_V4_2_SSC_HELPER=y
    CONFIG_SUNRPC=y
    CONFIG_SUNRPC_GSS=y
    CONFIG_SUNRPC_BACKCHANNEL=y
    # CONFIG_SUNRPC_DEBUG is not set
    # CONFIG_CEPH_FS is not set
    # CONFIG_CIFS is not set
    # CONFIG_SMB_SERVER is not set
    # CONFIG_CODA_FS is not set
    # CONFIG_AFS_FS is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    # CONFIG_NLS_CODEPAGE_737 is not set
    # CONFIG_NLS_CODEPAGE_775 is not set
    # CONFIG_NLS_CODEPAGE_850 is not set
    # CONFIG_NLS_CODEPAGE_852 is not set
    # CONFIG_NLS_CODEPAGE_855 is not set
    # CONFIG_NLS_CODEPAGE_857 is not set
    # CONFIG_NLS_CODEPAGE_860 is not set
    # CONFIG_NLS_CODEPAGE_861 is not set
    # CONFIG_NLS_CODEPAGE_862 is not set
    # CONFIG_NLS_CODEPAGE_863 is not set
    # CONFIG_NLS_CODEPAGE_864 is not set
    # CONFIG_NLS_CODEPAGE_865 is not set
    # CONFIG_NLS_CODEPAGE_866 is not set
    # CONFIG_NLS_CODEPAGE_869 is not set
    # CONFIG_NLS_CODEPAGE_936 is not set
    # CONFIG_NLS_CODEPAGE_950 is not set
    # CONFIG_NLS_CODEPAGE_932 is not set
    # CONFIG_NLS_CODEPAGE_949 is not set
    # CONFIG_NLS_CODEPAGE_874 is not set
    # CONFIG_NLS_ISO8859_8 is not set
    # CONFIG_NLS_CODEPAGE_1250 is not set
    # CONFIG_NLS_CODEPAGE_1251 is not set
    # CONFIG_NLS_ASCII is not set
    CONFIG_NLS_ISO8859_1=y
    # CONFIG_NLS_ISO8859_2 is not set
    # CONFIG_NLS_ISO8859_3 is not set
    # CONFIG_NLS_ISO8859_4 is not set
    # CONFIG_NLS_ISO8859_5 is not set
    # CONFIG_NLS_ISO8859_6 is not set
    # CONFIG_NLS_ISO8859_7 is not set
    # CONFIG_NLS_ISO8859_9 is not set
    # CONFIG_NLS_ISO8859_13 is not set
    # CONFIG_NLS_ISO8859_14 is not set
    # CONFIG_NLS_ISO8859_15 is not set
    # CONFIG_NLS_KOI8_R is not set
    # CONFIG_NLS_KOI8_U is not set
    # CONFIG_NLS_MAC_ROMAN is not set
    # CONFIG_NLS_MAC_CELTIC is not set
    # CONFIG_NLS_MAC_CENTEURO is not set
    # CONFIG_NLS_MAC_CROATIAN is not set
    # CONFIG_NLS_MAC_CYRILLIC is not set
    # CONFIG_NLS_MAC_GAELIC is not set
    # CONFIG_NLS_MAC_GREEK is not set
    # CONFIG_NLS_MAC_ICELAND is not set
    # CONFIG_NLS_MAC_INUIT is not set
    # CONFIG_NLS_MAC_ROMANIAN is not set
    # CONFIG_NLS_MAC_TURKISH is not set
    CONFIG_NLS_UTF8=y
    # CONFIG_DLM is not set
    # CONFIG_UNICODE is not set
    CONFIG_IO_WQ=y
    # end of File systems
    # Security options
    CONFIG_KEYS=y
    # CONFIG_KEYS_REQUEST_CACHE is not set
    # CONFIG_PERSISTENT_KEYRINGS is not set
    # CONFIG_TRUSTED_KEYS is not set
    # CONFIG_ENCRYPTED_KEYS is not set
    # CONFIG_KEY_DH_OPERATIONS is not set
    # CONFIG_SECURITY_DMESG_RESTRICT is not set
    CONFIG_SECURITY=y
    CONFIG_SECURITY_WRITABLE_HOOKS=y
    CONFIG_SECURITYFS=y
    CONFIG_SECURITY_NETWORK=y
    # CONFIG_SECURITY_NETWORK_XFRM is not set
    # CONFIG_SECURITY_PATH is not set
    CONFIG_LSM_MMAP_MIN_ADDR=32768
    CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
    # CONFIG_HARDENED_USERCOPY is not set
    # CONFIG_FORTIFY_SOURCE is not set
    # CONFIG_STATIC_USERMODEHELPER is not set
    CONFIG_SECURITY_SELINUX=y
    CONFIG_SECURITY_SELINUX_BOOTPARAM=y
    CONFIG_SECURITY_SELINUX_DISABLE=y
    CONFIG_SECURITY_SELINUX_DEVELOP=y
    CONFIG_SECURITY_SELINUX_AVC_STATS=y
    CONFIG_SECURITY_SELINUX_CHECKREQPROT_VALUE=0
    CONFIG_SECURITY_SELINUX_SIDTAB_HASH_BITS=9
    CONFIG_SECURITY_SELINUX_SID2STR_CACHE_SIZE=256
    # CONFIG_SECURITY_SMACK is not set
    # CONFIG_SECURITY_TOMOYO is not set
    # CONFIG_SECURITY_APPARMOR is not set
    # CONFIG_SECURITY_LOADPIN is not set
    # CONFIG_SECURITY_YAMA is not set
    # CONFIG_SECURITY_SAFESETID is not set
    # CONFIG_SECURITY_LOCKDOWN_LSM is not set
    # CONFIG_SECURITY_LANDLOCK is not set
    CONFIG_INTEGRITY=y
    # CONFIG_INTEGRITY_SIGNATURE is not set
    CONFIG_INTEGRITY_AUDIT=y
    # CONFIG_IMA is not set
    # CONFIG_EVM is not set
    # CONFIG_DEFAULT_SECURITY_SELINUX is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,bpf"
    # Kernel hardening options
    # Memory initialization
    CONFIG_INIT_STACK_NONE=y
    # CONFIG_GCC_PLUGIN_STRUCTLEAK_USER is not set
    # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF is not set
    # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF_ALL is not set
    # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
    # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
    CONFIG_CC_HAS_ZERO_CALL_USED_REGS=y
    # CONFIG_ZERO_CALL_USED_REGS is not set
    # end of Memory initialization
    CONFIG_RANDSTRUCT_NONE=y
    # CONFIG_RANDSTRUCT_FULL is not set
    # CONFIG_RANDSTRUCT_PERFORMANCE is not set
    # end of Kernel hardening options
    # end of Security options
    CONFIG_XOR_BLOCKS=y
    CONFIG_CRYPTO=y
    # Crypto core or helper
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_AEAD=m
    CONFIG_CRYPTO_AEAD2=y
    CONFIG_CRYPTO_SKCIPHER=m
    CONFIG_CRYPTO_SKCIPHER2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG=m
    CONFIG_CRYPTO_RNG2=y
    CONFIG_CRYPTO_RNG_DEFAULT=m
    CONFIG_CRYPTO_AKCIPHER2=y
    CONFIG_CRYPTO_AKCIPHER=y
    CONFIG_CRYPTO_KPP2=y
    CONFIG_CRYPTO_KPP=m
    CONFIG_CRYPTO_ACOMP2=y
    CONFIG_CRYPTO_MANAGER=y
    CONFIG_CRYPTO_MANAGER2=y
    CONFIG_CRYPTO_USER=m
    CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
    CONFIG_CRYPTO_GF128MUL=m
    CONFIG_CRYPTO_NULL=m
    CONFIG_CRYPTO_NULL2=y
    # CONFIG_CRYPTO_PCRYPT is not set
    CONFIG_CRYPTO_CRYPTD=m
    CONFIG_CRYPTO_AUTHENC=m
    # CONFIG_CRYPTO_TEST is not set
    CONFIG_CRYPTO_SIMD=m
    CONFIG_CRYPTO_ENGINE=m
    # end of Crypto core or helper
    # Public-key cryptography
    CONFIG_CRYPTO_RSA=y
    # CONFIG_CRYPTO_DH is not set
    CONFIG_CRYPTO_ECC=m
    CONFIG_CRYPTO_ECDH=m
    # CONFIG_CRYPTO_ECDSA is not set
    # CONFIG_CRYPTO_ECRDSA is not set
    # CONFIG_CRYPTO_SM2 is not set
    # CONFIG_CRYPTO_CURVE25519 is not set
    # end of Public-key cryptography
    # Block ciphers
    CONFIG_CRYPTO_AES=m
    # CONFIG_CRYPTO_AES_TI is not set
    # CONFIG_CRYPTO_ANUBIS is not set
    # CONFIG_CRYPTO_ARIA is not set
    # CONFIG_CRYPTO_BLOWFISH is not set
    # CONFIG_CRYPTO_CAMELLIA is not set
    # CONFIG_CRYPTO_CAST5 is not set
    # CONFIG_CRYPTO_CAST6 is not set
    # CONFIG_CRYPTO_DES is not set
    # CONFIG_CRYPTO_FCRYPT is not set
    # CONFIG_CRYPTO_KHAZAD is not set
    # CONFIG_CRYPTO_SEED is not set
    # CONFIG_CRYPTO_SERPENT is not set
    # CONFIG_CRYPTO_SM4_GENERIC is not set
    # CONFIG_CRYPTO_TEA is not set
    # CONFIG_CRYPTO_TWOFISH is not set
    # end of Block ciphers
    # Length-preserving ciphers and modes
    # CONFIG_CRYPTO_ADIANTUM is not set
    # CONFIG_CRYPTO_ARC4 is not set
    # CONFIG_CRYPTO_CHACHA20 is not set
    CONFIG_CRYPTO_CBC=m
    # CONFIG_CRYPTO_CFB is not set
    CONFIG_CRYPTO_CTR=m
    # CONFIG_CRYPTO_CTS is not set
    CONFIG_CRYPTO_ECB=m
    # CONFIG_CRYPTO_HCTR2 is not set
    # CONFIG_CRYPTO_KEYWRAP is not set
    # CONFIG_CRYPTO_LRW is not set
    # CONFIG_CRYPTO_OFB is not set
    # CONFIG_CRYPTO_PCBC is not set
    CONFIG_CRYPTO_XTS=m
    # end of Length-preserving ciphers and modes
    # AEAD (authenticated encryption with associated data) ciphers
    # CONFIG_CRYPTO_AEGIS128 is not set
    # CONFIG_CRYPTO_CHACHA20POLY1305 is not set
    CONFIG_CRYPTO_CCM=m
    CONFIG_CRYPTO_GCM=m
    CONFIG_CRYPTO_SEQIV=m
    CONFIG_CRYPTO_ECHAINIV=m
    # CONFIG_CRYPTO_ESSIV is not set
    # end of AEAD (authenticated encryption with associated data) ciphers
    # Hashes, digests, and MACs
    CONFIG_CRYPTO_BLAKE2B=y
    CONFIG_CRYPTO_CMAC=m
    CONFIG_CRYPTO_GHASH=m
    CONFIG_CRYPTO_HMAC=m
    # CONFIG_CRYPTO_MD4 is not set
    # CONFIG_CRYPTO_MD5 is not set
    # CONFIG_CRYPTO_MICHAEL_MIC is not set
    # CONFIG_CRYPTO_POLY1305 is not set
    # CONFIG_CRYPTO_RMD160 is not set
    CONFIG_CRYPTO_SHA1=m
    CONFIG_CRYPTO_SHA256=y
    CONFIG_CRYPTO_SHA512=m
    # CONFIG_CRYPTO_SHA3 is not set
    # CONFIG_CRYPTO_SM3_GENERIC is not set
    # CONFIG_CRYPTO_STREEBOG is not set
    # CONFIG_CRYPTO_VMAC is not set
    # CONFIG_CRYPTO_WP512 is not set
    # CONFIG_CRYPTO_XCBC is not set
    CONFIG_CRYPTO_XXHASH=y
    # end of Hashes, digests, and MACs
    # CRCs (cyclic redundancy checks)
    CONFIG_CRYPTO_CRC32C=y
    # CONFIG_CRYPTO_CRC32 is not set
    # CONFIG_CRYPTO_CRCT10DIF is not set
    # end of CRCs (cyclic redundancy checks)
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    CONFIG_CRYPTO_LZO=y
    # CONFIG_CRYPTO_842 is not set
    # CONFIG_CRYPTO_LZ4 is not set
    # CONFIG_CRYPTO_LZ4HC is not set
    CONFIG_CRYPTO_ZSTD=y
    # end of Compression
    # Random number generation
    # CONFIG_CRYPTO_ANSI_CPRNG is not set
    CONFIG_CRYPTO_DRBG_MENU=m
    CONFIG_CRYPTO_DRBG_HMAC=y
    # CONFIG_CRYPTO_DRBG_HASH is not set
    # CONFIG_CRYPTO_DRBG_CTR is not set
    CONFIG_CRYPTO_DRBG=m
    CONFIG_CRYPTO_JITTERENTROPY=m
    # end of Random number generation
    # Userspace interface
    CONFIG_CRYPTO_USER_API=m
    CONFIG_CRYPTO_USER_API_HASH=m
    CONFIG_CRYPTO_USER_API_SKCIPHER=m
    CONFIG_CRYPTO_USER_API_RNG=m
    # CONFIG_CRYPTO_USER_API_RNG_CAVP is not set
    CONFIG_CRYPTO_USER_API_AEAD=m
    CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE=y
    # CONFIG_CRYPTO_STATS is not set
    # end of Userspace interface
    CONFIG_CRYPTO_HASH_INFO=y
    # Accelerated Cryptographic Algorithms for CPU (arm)
    # CONFIG_CRYPTO_CURVE25519_NEON is not set
    CONFIG_CRYPTO_GHASH_ARM_CE=m
    # CONFIG_CRYPTO_NHPOLY1305_NEON is not set
    # CONFIG_CRYPTO_POLY1305_ARM is not set
    # CONFIG_CRYPTO_BLAKE2S_ARM is not set
    # CONFIG_CRYPTO_BLAKE2B_NEON is not set
    CONFIG_CRYPTO_SHA1_ARM=m
    CONFIG_CRYPTO_SHA1_ARM_NEON=m
    CONFIG_CRYPTO_SHA1_ARM_CE=m
    CONFIG_CRYPTO_SHA2_ARM_CE=m
    CONFIG_CRYPTO_SHA256_ARM=m
    # CONFIG_CRYPTO_SHA512_ARM is not set
    CONFIG_CRYPTO_AES_ARM=m
    CONFIG_CRYPTO_AES_ARM_BS=m
    CONFIG_CRYPTO_AES_ARM_CE=m
    CONFIG_CRYPTO_CHACHA20_NEON=m
    CONFIG_CRYPTO_CRC32_ARM_CE=m
    # end of Accelerated Cryptographic Algorithms for CPU (arm)
    CONFIG_CRYPTO_HW=y
    # CONFIG_CRYPTO_DEV_ALLWINNER is not set
    # CONFIG_CRYPTO_DEV_SL3516 is not set
    # CONFIG_CRYPTO_DEV_HIFN_795X is not set
    # CONFIG_CRYPTO_DEV_OMAP is not set
    # CONFIG_CRYPTO_DEV_EXYNOS_RNG is not set
    # CONFIG_CRYPTO_DEV_S5P is not set
    # CONFIG_CRYPTO_DEV_ATMEL_AES is not set
    # CONFIG_CRYPTO_DEV_ATMEL_TDES is not set
    # CONFIG_CRYPTO_DEV_ATMEL_SHA is not set
    # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
    # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
    # CONFIG_CRYPTO_DEV_QAT_DH895xCC is not set
    # CONFIG_CRYPTO_DEV_QAT_C3XXX is not set
    # CONFIG_CRYPTO_DEV_QAT_C62X is not set
    # CONFIG_CRYPTO_DEV_QAT_4XXX is not set
    # CONFIG_CRYPTO_DEV_QAT_DH895xCCVF is not set
    # CONFIG_CRYPTO_DEV_QAT_C3XXXVF is not set
    # CONFIG_CRYPTO_DEV_QAT_C62XVF is not set
    # CONFIG_CRYPTO_DEV_QCE is not set
    # CONFIG_CRYPTO_DEV_QCOM_RNG is not set
    # CONFIG_CRYPTO_DEV_IMGTEC_HASH is not set
    # CONFIG_CRYPTO_DEV_ZYNQMP_AES is not set
    # CONFIG_CRYPTO_DEV_ZYNQMP_SHA3 is not set
    # CONFIG_CRYPTO_DEV_VIRTIO is not set
    # CONFIG_CRYPTO_DEV_SAFEXCEL is not set
    # CONFIG_CRYPTO_DEV_ARTPEC6 is not set
    # CONFIG_CRYPTO_DEV_CCREE is not set
    # CONFIG_CRYPTO_DEV_HISI_SEC is not set
    CONFIG_CRYPTO_DEV_AMLOGIC_GXL=m
    # CONFIG_CRYPTO_DEV_AMLOGIC_GXL_DEBUG is not set
    # CONFIG_CRYPTO_DEV_SA2UL is not set
    # CONFIG_CRYPTO_DEV_KEEMBAY_OCS_AES_SM4 is not set
    # CONFIG_CRYPTO_DEV_KEEMBAY_OCS_ECC is not set
    # CONFIG_CRYPTO_DEV_KEEMBAY_OCS_HCU is not set
    # CONFIG_CRYPTO_DEV_ASPEED is not set
    CONFIG_ASYMMETRIC_KEY_TYPE=y
    CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
    CONFIG_X509_CERTIFICATE_PARSER=y
    # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set
    CONFIG_PKCS7_MESSAGE_PARSER=y
    # CONFIG_PKCS7_TEST_KEY is not set
    # CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
    # CONFIG_FIPS_SIGNATURE_SELFTEST is not set
    # Certificates for signature checking
    CONFIG_SYSTEM_TRUSTED_KEYRING=y
    CONFIG_SYSTEM_TRUSTED_KEYS=""
    # CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
    # CONFIG_SECONDARY_TRUSTED_KEYRING is not set
    # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
    # end of Certificates for signature checking
    # Library routines
    CONFIG_RAID6_PQ=y
    CONFIG_RAID6_PQ_BENCHMARK=y
    CONFIG_LINEAR_RANGES=y
    CONFIG_PACKING=y
    CONFIG_BITREVERSE=y
    CONFIG_HAVE_ARCH_BITREVERSE=y
    CONFIG_GENERIC_STRNCPY_FROM_USER=y
    CONFIG_GENERIC_STRNLEN_USER=y
    CONFIG_GENERIC_NET_UTILS=y
    # CONFIG_CORDIC is not set
    # CONFIG_PRIME_NUMBERS is not set
    CONFIG_RATIONAL=y
    CONFIG_GENERIC_PCI_IOMAP=y
    CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
    # Crypto library routines
    CONFIG_CRYPTO_LIB_UTILS=y
    CONFIG_CRYPTO_LIB_AES=m
    CONFIG_CRYPTO_LIB_ARC4=m
    CONFIG_CRYPTO_LIB_BLAKE2S_GENERIC=y
    CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m
    # CONFIG_CRYPTO_LIB_CHACHA is not set
    # CONFIG_CRYPTO_LIB_CURVE25519 is not set
    CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9
    # CONFIG_CRYPTO_LIB_POLY1305 is not set
    # CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set
    CONFIG_CRYPTO_LIB_SHA1=y
    CONFIG_CRYPTO_LIB_SHA256=y
    # end of Crypto library routines
    CONFIG_CRC_CCITT=y
    CONFIG_CRC16=y
    # CONFIG_CRC_T10DIF is not set
    # CONFIG_CRC64_ROCKSOFT is not set
    CONFIG_CRC_ITU_T=m
    CONFIG_CRC32=y
    # CONFIG_CRC32_SELFTEST is not set
    CONFIG_CRC32_SLICEBY8=y
    # CONFIG_CRC32_SLICEBY4 is not set
    # CONFIG_CRC32_SARWATE is not set
    # CONFIG_CRC32_BIT is not set
    # CONFIG_CRC64 is not set
    CONFIG_CRC4=m
    # CONFIG_CRC7 is not set
    CONFIG_LIBCRC32C=y
    # CONFIG_CRC8 is not set
    CONFIG_XXHASH=y
    CONFIG_AUDIT_GENERIC=y
    # CONFIG_RANDOM32_SELFTEST is not set
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    CONFIG_LZ4_DECOMPRESS=y
    CONFIG_ZSTD_COMMON=y
    CONFIG_ZSTD_COMPRESS=y
    CONFIG_ZSTD_DECOMPRESS=y
    CONFIG_XZ_DEC=y
    CONFIG_XZ_DEC_X86=y
    CONFIG_XZ_DEC_POWERPC=y
    CONFIG_XZ_DEC_IA64=y
    CONFIG_XZ_DEC_ARM=y
    CONFIG_XZ_DEC_ARMTHUMB=y
    CONFIG_XZ_DEC_SPARC=y
    # CONFIG_XZ_DEC_MICROLZMA is not set
    CONFIG_XZ_DEC_BCJ=y
    # CONFIG_XZ_DEC_TEST is not set
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_DECOMPRESS_BZIP2=y
    CONFIG_DECOMPRESS_LZMA=y
    CONFIG_DECOMPRESS_XZ=y
    CONFIG_DECOMPRESS_LZO=y
    CONFIG_DECOMPRESS_LZ4=y
    CONFIG_DECOMPRESS_ZSTD=y
    CONFIG_GENERIC_ALLOCATOR=y
    CONFIG_REED_SOLOMON=y
    CONFIG_REED_SOLOMON_ENC8=y
    CONFIG_REED_SOLOMON_DEC8=y
    CONFIG_BCH=y
    CONFIG_XARRAY_MULTI=y
    CONFIG_ASSOCIATIVE_ARRAY=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT_MAP=y
    CONFIG_HAS_DMA=y
    CONFIG_DMA_OPS=y
    CONFIG_NEED_DMA_MAP_STATE=y
    CONFIG_DMA_DECLARE_COHERENT=y
    CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
    CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
    CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y
    CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y
    CONFIG_DMA_NONCOHERENT_MMAP=y
    CONFIG_DMA_CMA=y
    # CONFIG_DMA_PERNUMA_CMA is not set
    # Default contiguous memory area size:
    CONFIG_CMA_SIZE_MBYTES=64
    CONFIG_CMA_SIZE_SEL_MBYTES=y
    # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
    # CONFIG_CMA_SIZE_SEL_MIN is not set
    # CONFIG_CMA_SIZE_SEL_MAX is not set
    CONFIG_CMA_ALIGNMENT=8
    # CONFIG_DMA_API_DEBUG is not set
    # CONFIG_DMA_MAP_BENCHMARK is not set
    CONFIG_SGL_ALLOC=y
    # CONFIG_FORCE_NR_CPUS is not set
    CONFIG_CPU_RMAP=y
    CONFIG_DQL=y
    CONFIG_GLOB=y
    # CONFIG_GLOB_SELFTEST is not set
    CONFIG_NLATTR=y
    CONFIG_CLZ_TAB=y
    # CONFIG_IRQ_POLL is not set
    CONFIG_MPILIB=y
    CONFIG_DIMLIB=y
    CONFIG_LIBFDT=y
    CONFIG_OID_REGISTRY=y
    CONFIG_UCS2_STRING=y
    CONFIG_HAVE_GENERIC_VDSO=y
    CONFIG_GENERIC_GETTIMEOFDAY=y
    CONFIG_GENERIC_VDSO_32=y
    CONFIG_FONT_SUPPORT=y
    # CONFIG_FONTS is not set
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    CONFIG_SG_SPLIT=y
    CONFIG_SG_POOL=y
    CONFIG_STACKDEPOT=y
    CONFIG_SBITMAP=y
    # CONFIG_PARMAN is not set
    # CONFIG_OBJAGG is not set
    # end of Library routines
    CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y
    # Kernel hacking
    # printk and dmesg options
    CONFIG_PRINTK_TIME=y
    # CONFIG_PRINTK_CALLER is not set
    # CONFIG_STACKTRACE_BUILD_ID is not set
    CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
    CONFIG_CONSOLE_LOGLEVEL_QUIET=4
    CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
    # CONFIG_BOOT_PRINTK_DELAY is not set
    # CONFIG_DYNAMIC_DEBUG is not set
    # CONFIG_DYNAMIC_DEBUG_CORE is not set
    CONFIG_SYMBOLIC_ERRNAME=y
    CONFIG_DEBUG_BUGVERBOSE=y
    # end of printk and dmesg options
    CONFIG_DEBUG_KERNEL=y
    CONFIG_DEBUG_MISC=y
    # Compile-time checks and compiler options
    CONFIG_AS_HAS_NON_CONST_LEB128=y
    CONFIG_DEBUG_INFO_NONE=y
    # CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT is not set
    # CONFIG_DEBUG_INFO_DWARF4 is not set
    # CONFIG_DEBUG_INFO_DWARF5 is not set
    CONFIG_FRAME_WARN=1024
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_READABLE_ASM is not set
    # CONFIG_HEADERS_INSTALL is not set
    # CONFIG_DEBUG_SECTION_MISMATCH is not set
    CONFIG_SECTION_MISMATCH_WARN_ONLY=y
    # CONFIG_VMLINUX_MAP is not set
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    # end of Compile-time checks and compiler options
    # Generic Kernel Debugging Instruments
    CONFIG_MAGIC_SYSRQ=y
    CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
    CONFIG_MAGIC_SYSRQ_SERIAL=y
    CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE=""
    CONFIG_DEBUG_FS=y
    CONFIG_DEBUG_FS_ALLOW_ALL=y
    # CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set
    # CONFIG_DEBUG_FS_ALLOW_NONE is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    # CONFIG_UBSAN is not set
    CONFIG_HAVE_KCSAN_COMPILER=y
    # end of Generic Kernel Debugging Instruments
    # Networking Debugging
    # CONFIG_NET_DEV_REFCNT_TRACKER is not set
    # CONFIG_NET_NS_REFCNT_TRACKER is not set
    # CONFIG_DEBUG_NET is not set
    # end of Networking Debugging
    # Memory Debugging
    # CONFIG_PAGE_EXTENSION is not set
    # CONFIG_DEBUG_PAGEALLOC is not set
    CONFIG_SLUB_DEBUG=y
    # CONFIG_SLUB_DEBUG_ON is not set
    # CONFIG_PAGE_OWNER is not set
    # CONFIG_PAGE_POISONING is not set
    # CONFIG_DEBUG_RODATA_TEST is not set
    # CONFIG_DEBUG_WX is not set
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_SHRINKER_DEBUG is not set
    CONFIG_HAVE_DEBUG_KMEMLEAK=y
    # CONFIG_DEBUG_KMEMLEAK is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_SCHED_STACK_END_CHECK is not set
    # CONFIG_DEBUG_VM is not set
    CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
    # CONFIG_DEBUG_VIRTUAL is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_PER_CPU_MAPS is not set
    # CONFIG_DEBUG_KMAP_LOCAL is not set
    # CONFIG_DEBUG_HIGHMEM is not set
    CONFIG_HAVE_ARCH_KASAN=y
    CONFIG_HAVE_ARCH_KASAN_VMALLOC=y
    CONFIG_CC_HAS_KASAN_GENERIC=y
    CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
    # CONFIG_KASAN is not set
    CONFIG_HAVE_ARCH_KFENCE=y
    # CONFIG_KFENCE is not set
    # end of Memory Debugging
    # CONFIG_DEBUG_SHIRQ is not set
    # Debug Oops, Lockups and Hangs
    # CONFIG_PANIC_ON_OOPS is not set
    CONFIG_PANIC_ON_OOPS_VALUE=0
    CONFIG_PANIC_TIMEOUT=0
    # CONFIG_SOFTLOCKUP_DETECTOR is not set
    # CONFIG_DETECT_HUNG_TASK is not set
    # CONFIG_WQ_WATCHDOG is not set
    # CONFIG_TEST_LOCKUP is not set
    # end of Debug Oops, Lockups and Hangs
    # Scheduler Debugging
    CONFIG_SCHED_DEBUG=y
    # CONFIG_SCHEDSTATS is not set
    # end of Scheduler Debugging
    # CONFIG_DEBUG_TIMEKEEPING is not set
    # Lock Debugging (spinlocks, mutexes, etc...)
    CONFIG_LOCK_DEBUGGING_SUPPORT=y
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    # CONFIG_DEBUG_MUTEXES is not set
    # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
    # CONFIG_DEBUG_RWSEMS is not set
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_DEBUG_ATOMIC_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    # CONFIG_LOCK_TORTURE_TEST is not set
    # CONFIG_WW_MUTEX_SELFTEST is not set
    # CONFIG_SCF_TORTURE_TEST is not set
    # end of Lock Debugging (spinlocks, mutexes, etc...)
    # CONFIG_DEBUG_IRQFLAGS is not set
    CONFIG_STACKTRACE=y
    # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
    # CONFIG_DEBUG_KOBJECT is not set
    # Debug kernel data structures
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_DEBUG_PLIST is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_BUG_ON_DATA_CORRUPTION is not set
    # CONFIG_DEBUG_MAPLE_TREE is not set
    # end of Debug kernel data structures
    # CONFIG_DEBUG_CREDENTIALS is not set
    # RCU Debugging
    # CONFIG_RCU_SCALE_TEST is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    # CONFIG_RCU_REF_SCALE_TEST is not set
    CONFIG_RCU_CPU_STALL_TIMEOUT=21
    CONFIG_RCU_EXP_CPU_STALL_TIMEOUT=0
    CONFIG_RCU_TRACE=y
    # CONFIG_RCU_EQS_DEBUG is not set
    # end of RCU Debugging
    # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
    # CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set
    # CONFIG_LATENCYTOP is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
    CONFIG_HAVE_DYNAMIC_FTRACE=y
    CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
    CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
    CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
    CONFIG_HAVE_C_RECORDMCOUNT=y
    CONFIG_HAVE_BUILDTIME_MCOUNT_SORT=y
    CONFIG_TRACE_CLOCK=y
    # CONFIG_SAMPLES is not set
    # CONFIG_STRICT_DEVMEM is not set
    # arm Debugging
    # CONFIG_ARM_PTDUMP_DEBUGFS is not set
    # CONFIG_UNWINDER_FRAME_POINTER is not set
    CONFIG_UNWINDER_ARM=y
    CONFIG_ARM_UNWIND=y
    # CONFIG_BACKTRACE_VERBOSE is not set
    # CONFIG_DEBUG_USER is not set
    CONFIG_DEBUG_LL=y
    CONFIG_DEBUG_KEYSTONE_UART0=y
    # CONFIG_DEBUG_KEYSTONE_UART1 is not set
    # CONFIG_DEBUG_OMAP2UART1 is not set
    # CONFIG_DEBUG_OMAP2UART2 is not set
    # CONFIG_DEBUG_OMAP2UART3 is not set
    # CONFIG_DEBUG_OMAP3UART3 is not set
    # CONFIG_DEBUG_OMAP4UART3 is not set
    # CONFIG_DEBUG_OMAP3UART4 is not set
    # CONFIG_DEBUG_OMAP4UART4 is not set
    # CONFIG_DEBUG_TI81XXUART1 is not set
    # CONFIG_DEBUG_TI81XXUART2 is not set
    # CONFIG_DEBUG_TI81XXUART3 is not set
    # CONFIG_DEBUG_AM33XXUART1 is not set
    # CONFIG_DEBUG_ZOOM_UART is not set
    # CONFIG_DEBUG_SOCFPGA_UART0 is not set
    # CONFIG_DEBUG_SOCFPGA_ARRIA10_UART1 is not set
    # CONFIG_DEBUG_SOCFPGA_CYCLONE5_UART1 is not set
    # CONFIG_DEBUG_ICEDCC is not set
    # CONFIG_DEBUG_SEMIHOSTING is not set
    # CONFIG_DEBUG_LL_UART_8250 is not set
    # CONFIG_DEBUG_LL_UART_PL01X is not set
    # CONFIG_DEBUG_UART_FLOW_CONTROL is not set
    CONFIG_DEBUG_LL_INCLUDE="debug/8250.S"
    CONFIG_DEBUG_UART_8250=y
    CONFIG_DEBUG_UART_PHYS=0x481a8000
    CONFIG_DEBUG_UART_VIRT=0xfeb30c00
    CONFIG_DEBUG_UART_8250_SHIFT=2
    CONFIG_DEBUG_UART_8250_WORD=y
    # CONFIG_DEBUG_UART_8250_PALMCHIP is not set
    CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
    # CONFIG_EARLY_PRINTK is not set
    # CONFIG_PID_IN_CONTEXTIDR is not set
    # CONFIG_CORESIGHT is not set
    # end of arm Debugging
    # Kernel Testing and Coverage
    # CONFIG_KUNIT is not set
    # CONFIG_NOTIFIER_ERROR_INJECTION is not set
    # CONFIG_FAULT_INJECTION is not set
    CONFIG_ARCH_HAS_KCOV=y
    CONFIG_CC_HAS_SANCOV_TRACE_PC=y
    # CONFIG_KCOV is not set
    CONFIG_RUNTIME_TESTING_MENU=y
    # CONFIG_LKDTM is not set
    # CONFIG_TEST_MIN_HEAP is not set
    # CONFIG_TEST_DIV64 is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_TEST_REF_TRACKER is not set
    # CONFIG_RBTREE_TEST is not set
    # CONFIG_REED_SOLOMON_TEST is not set
    # CONFIG_INTERVAL_TREE_TEST is not set
    # CONFIG_PERCPU_TEST is not set
    # CONFIG_ATOMIC64_SELFTEST is not set
    # CONFIG_TEST_HEXDUMP is not set
    # CONFIG_STRING_SELFTEST is not set
    # CONFIG_TEST_STRING_HELPERS is not set
    # CONFIG_TEST_STRSCPY is not set
    # CONFIG_TEST_KSTRTOX is not set
    # CONFIG_TEST_PRINTF is not set
    # CONFIG_TEST_SCANF is not set
    # CONFIG_TEST_BITMAP is not set
    # CONFIG_TEST_UUID is not set
    # CONFIG_TEST_XARRAY is not set
    # CONFIG_TEST_MAPLE_TREE is not set
    # CONFIG_TEST_RHASHTABLE is not set
    # CONFIG_TEST_SIPHASH is not set
    # CONFIG_TEST_IDA is not set
    # CONFIG_TEST_LKM is not set
    # CONFIG_TEST_BITOPS is not set
    # CONFIG_TEST_VMALLOC is not set
    # CONFIG_TEST_USER_COPY is not set
    # CONFIG_TEST_BPF is not set
    # CONFIG_TEST_BLACKHOLE_DEV is not set
    # CONFIG_FIND_BIT_BENCHMARK is not set
    # CONFIG_TEST_FIRMWARE is not set
    # CONFIG_TEST_SYSCTL is not set
    # CONFIG_TEST_UDELAY is not set
    # CONFIG_TEST_STATIC_KEYS is not set
    # CONFIG_TEST_KMOD is not set
    # CONFIG_TEST_MEMCAT_P is not set
    # CONFIG_TEST_MEMINIT is not set
    # CONFIG_TEST_FREE_PAGES is not set
    CONFIG_ARCH_USE_MEMTEST=y
    # CONFIG_MEMTEST is not set
    # end of Kernel Testing and Coverage
    # Rust hacking
    # end of Rust hacking
    # CONFIG_WARN_MISSING_DOCUMENTS is not set
    # CONFIG_WARN_ABI_ERRORS is not set
    # end of Kernel hacking
    -  these message is something that probably needs investigating. They appear to indicate the gpios used to reset the PHY are accessible.
    reset-gpio are not used as per schematic.
    As per 4.19 kernel dts. these nodes are not moved to in 6.1 kernel, as i take am437x-sk dts as reference.
    &mac {
    //slaves = <1>;
    //pinctrl-names = "default", "sleep";
    pinctrl-names = "default";
    pinctrl-0 = <&cpsw1_default>, <&cpsw2_default>;
    //pinctrl-1 = <&cpsw_sleep>;
    dual_emac = <1>;
    status = "okay";
    &phy_sel {
    rmii-clock-ext = <1>;
    &elm {
    status = "okay";
    Siva.
  • when i run udhcpc -i eth1, i can see link going up nd down.
    udhcpc: broadcasting discover
    [ 471.924955] cpsw-switch 4a100000.switch eth1: Link is Up - 10Mbps/Full - flow control off
    13:33:06.846753 IP6 fe80::ba94:d9ff:fec7:4b19 > ff02::16: HBH ICMP6, multicast listener report v2, 1 group record(s), length 28
    13:33:07.776749 IP6 fe80::ba94:d9ff:fec7:4b19 > ff02::16: HBH ICMP6, multicast listener report v2, 1 group record(s), length 28
    [ 472.965454] cpsw-switch 4a100000.switch eth1: Link is Down
    [ 501.045003] cpsw-switch 4a100000.switch eth1: Link is Up - 10Mbps/Full - flow control off
    13:33:35.966709 IP6 fe80::ba94:d9ff:fec7:4b19 > ff02::16: HBH ICMP6, multicast listener report v2, 1 group record(s), length 28
    13:33:36.356729 IP6 fe80::ba94:d9ff:fec7:4b19 > ff02::16: HBH ICMP6, multicast listener report v2, 1 group record(s), length 28
    13:33:58.206756 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from b8:94:d9:c7:4b:19 (oui Unknown), length 300
    [ 523.925456] cpsw-switch 4a100000.switch eth1: Link is Down
    [ 533.284965] cpsw-switch 4a100000.switch eth1: Link is Up - 10Mbps/Full - flow control off
    13:34:08.206758 IP6 fe80::ba94:d9ff:fec7:4b19 > ff02::16: HBH ICMP6, multicast listener report v2, 1 group record(s), length 28
    13:34:08.896733 IP6 fe80::ba94:d9ff:fec7:4b19 > ff02::16: HBH ICMP6, multicast listener report v2, 1 group record(s), length 28
    [ 534.325445] cpsw-switch 4a100000.switch eth1: Link is Down
