Other Parts Discussed in Thread: SK-AM62-LP
Dear TI expert.
local customer wants to use GigaDevice QSPI FLASH, PN: GD5F1GQ5REY2GR, for their ADAS Application w/ AM620-Q1.
they choose Serial NAND boot mode, connect D0~D3 only as QSPI NAND has only 4 data lines.
and Using SK-AM62-LP EVM, hand work to solder GD5F1GQ5REY2GR on board instead of W35N01JWTBAG.
they found that, at boot stage, the first command sent by AM6254 to read NAND parameter from address 01. But GigaDevice QSPI NAND need read from address 04. Then AM6254 can not read NAND parameters successfully, so subsequent data read error, Eventually it will not start.
would you please help check if if TI can support this GigaDevice QSPI NAND on AM620-Q1?
as they close to finish schematic design in this week, they wants us to help give quick response on the request ASAP
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/serial_2D00_nand_2D00_1.8V.sal
DS-00845-GD5F1GQ5RExxG-Rev1.0_Automotive.pdf
Thanks a lot!
yong
