Other Parts Discussed in Thread: TDA4VH
Hello I'm using custom board using tda4vh and the sdk version is 9.2 version.
Currently, I want to store every frame camera image as yuv using multicam application,
but if it exceeds a certain frame unit, about 2,000 frames kernel panic error occurs.
The same error occurs even when saving using the en_out_img_write option in multicam application.
Is it a hardware problem if the storage capacity is sufficient?
Thank you
