AM625: SDK11 kernel boot failed (SD Card)
Part Number: AM625
Hello TI,
We try to use SDK 11 for our custom board. Boot it from SD Card (Micro SD HC I Ultra)) but failed, please help.
Build option cmd: MACHINE=am62xx-evm bitbake -k  tisdk-base-image
kernel boot error:
[ 2.509987] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 12.510875] platform fa00000.mmc: deferred probe pending: platform: supplier regulator-3 not ready
[ 12.519887] platform regulator-3: deferred probe pending: platform: supplier 1-0022 not ready
[ 12.528416] platform 2b300050.target-module: deferred probe pending: (reason unknown)
Based on our expereinced when using SDK 9.0 (https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1381861/sk-am62b-p1-custom-board-bring-up-using-microsd-fa00000-mmc-deferred-probe-pending)
We added the patch but it does not work.
paul@VM41UBT2204:~/tisdk/build/arago-tmp-default-glibc/work-shared/am62xx-evm/kernel-source$ git diff
diff --git a/arch/arm64/boot/dts/ti/k3-am62-main.dtsi b/arch/arm64/boot/dts/ti/k3-am62-main.dtsi
index fd1a9eef9070..afe4925466a8 100644
--- a/arch/arm64/boot/dts/ti/k3-am62-main.dtsi
+++ b/arch/arm64/boot/dts/ti/k3-am62-main.dtsi
@@ -591,7 +591,7 @@ sdhci1: mmc@fa00000 {
power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 58 5>, <&k3_clks 58 6>;
clock-names = "clk_ahb", "clk_xin";
- bus-width = <4>;
+ bus-width = <1>;
ti,clkbuf-sel = <0x7>;
ti,otap-del-sel-legacy = <0x0>;
ti,otap-del-sel-sd-hs = <0x0>;
diff --git a/arch/arm64/boot/dts/ti/k3-am625-sk.dts b/arch/arm64/boot/dts/ti/k3-am625-sk.dts
index 5c8da5a871a2..8459d980e6d7 100644
--- a/arch/arm64/boot/dts/ti/k3-am625-sk.dts
+++ b/arch/arm64/boot/dts/ti/k3-am625-sk.dts
@@ -181,6 +181,7 @@ exp1: gpio@22 {
&sdhci1 {
vmmc-supply = <&vdd_mmc1>;
vqmmc-supply = <&vdd_sd_dv>;
+ no-1-8-v; /* disabling all the UHS modes */
&cpsw3g {
Console log:
U-Boot SPL 2025.01-00253-g9a3137c5c11a-dirty (Feb 26 2025 - 17:07:57 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.2-v11.00.02 (Fancy Rat)')
Changed A53 CPU frequency to 1250000000Hz (T grade) in DT
SPL initial stack usage: 13424 bytes
Trying to boot from MMC2
Skipping authentication on GP device
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.12.0(release):11.00.05-dirty
NOTICE:  BL31: Built : 05:00:39, Feb 26 2025
SPL initial stack usage: 1952 bytes
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
U-Boot 2025.01-00253-g9a3137c5c11a-dirty (Feb 26 2025 - 17:07:57 +0000)
SoC:   AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
DRAM:  2 GiB
Core:  81 devices, 31 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@8000000port@1
Hit any key to stop autoboot:  0
Scanning for bootflows in all bootdevs
Seq  Method       State   Uclass    Part  Name                      Filename
Scanning bootdev 'mmc@fa00000.bootdev':
  0  efi          ready   mmc          1  mmc@fa00000.bootdev.part_ /EFI/BOOT/BO        OTAA64.EFI
** Booting bootflow 'mmc@fa00000.bootdev.part_1' with efi
Cannot persist EFI variables without system partition
Booting /\EFI\BOOT\BOOTAA64.EFI
error: no such device: ((hd0,msdos1)/EFI/BOOT)/EFI/BOOT/grub.cfg.
error: serial port `com0' isn't found.
                             GNU GRUB  version 2.12
 lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
 x*boot        x
 x        x
 x        x
 x        x
 x        x
 x        x
 x        x
 x        x
 x        x
 x        x
 x        x
 x        x
 mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
      Use the ▲ and ▼ keys to select which entry is highlighted.
      Press enter to boot the selected OS, `e' to edit the commands
      before booting or `c' for a command-line.
   The highlighted entry will be executed automatically in 0s.
  Booting `boot'
EFI stub: Booting Linux Kernel...
EFI stub: EFI_RNG_PROTOCOL unavailable
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.12.13-ti-00555-g1a2d611ee02d-dirty (oe-user@oe-ho        st) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #        1 SMP PREEMPT Wed Feb 26 17:29:25 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments AM625 SK
[    0.000000] efi: EFI v2.10 by Das U-Boot
[    0.000000] efi: ESRT=0xfce53040 RTPROP=0xfce55040 SMBIOS 3.0=0xfdeb1000 MEMR        ESERVE=0xfcd7a040
[    0.000000] esrt: Reserving ESRT space from 0x00000000fce53040 to 0x00000000f        ce530c8.
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000eec00000, s        ize 128 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id share        d-dma-pool
[    0.000000] OF: reserved mem: 0x00000000eec00000..0x00000000f6bfffff (131072        KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 K        iB) nomap non-reusable optee@9e800000
[    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB        ) nomap non-reusable tfa@80000000
[    0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 Ki        B) map non-reusable ramoops@9c700000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, s        ize 3 MiB
[    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compati        ble id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 Ki        B) nomap non-reusable ipc-memories@9c800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, s        ize 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compa        tible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 Ki        B) nomap non-reusable m4f-dma-memory@9cb00000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, s        ize 14 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatibl        e id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 K        iB) nomap non-reusable m4f-memory@9cc00000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, s        ize 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compa        tible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 Ki        B) nomap non-reusable r5f-dma-memory@9da00000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, s        ize 12 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatibl        e id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 K        iB) nomap non-reusable r5f-memory@9db00000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
[    0.000000]   node   0: [mem 0x0000000080080000-0x000000009c7fffff]
[    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000fce54fff]
[    0.000000]   node   0: [mem 0x00000000fce55000-0x00000000fce55fff]
[    0.000000]   node   0: [mem 0x00000000fce56000-0x00000000fce58fff]
[    0.000000]   node   0: [mem 0x00000000fce59000-0x00000000fce7afff]
[    0.000000]   node   0: [mem 0x00000000fce7b000-0x00000000fdeb0fff]
[    0.000000]   node   0: [mem 0x00000000fdeb1000-0x00000000fdeb1fff]
[    0.000000]   node   0: [mem 0x00000000fdeb2000-0x00000000ffeaffff]
[    0.000000]   node   0: [mem 0x00000000ffeb0000-0x00000000ffebffff]
[    0.000000]   node   0: [mem 0x00000000ffec0000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 22 pages/cpu s51288 r8192 d30632 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: BOOT_IMAGE=/Image root=PARTUUID=076c4a2a-02        rootwait rootfstype=ext4
[    0.000000] Unknown kernel command line parameters "BOOT_IMAGE=/Image", will        be passed to user space.
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes,        linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes,        linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 524288
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000ff559000-0x00000000ff75900        0] (2MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif        fies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 r        cu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adju        st=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->1        9
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat,        esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080450000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x000000008046000        0
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles        : 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 43980        46511102ns
[    0.000585] Console: colour dummy device 80x25
[    0.000601] printk: legacy console [tty0] enabled
[    0.001381] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 400.00 BogoMIPS (lpj=800000)
[    0.001408] pid_max: default: 32768 minimum: 301
[    0.001517] LSM: initializing lsm=capability
[    0.001682] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, line        ar)
[    0.001717] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes,        linear)
[    0.016008] rcu: Hierarchical SRCU implementation.
[    0.016050] rcu:     Max phase no-delay instances is 1000.
[    0.016283] Timer migration: 1 hierarchy levels; 8 children per group; 1 cros        snode level
[    0.020566] Remapping and enabling EFI services.
[    0.024043] smp: Bringing up secondary CPUs ...
[    0.032424] Detected VIPT I-cache on CPU1
[    0.032522] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.032541] GICv3: CPU1: using allocated LPI pending table @0x000000008047000        0
[    0.032598] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.040417] Detected VIPT I-cache on CPU2
[    0.040495] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.040510] GICv3: CPU2: using allocated LPI pending table @0x000000008048000        0
[    0.040549] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.044545] Detected VIPT I-cache on CPU3
[    0.044618] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.044633] GICv3: CPU3: using allocated LPI pending table @0x000000008049000        0
[    0.044669] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.044831] smp: Brought up 1 node, 4 CPUs
[    0.045041] SMP: Total of 4 processors activated.
[    0.045054] CPU: All CPU(s) started at EL2
[    0.045066] CPU features: detected: 32-bit EL0 Support
[    0.045078] CPU features: detected: CRC32 instructions
[    0.045136] alternatives: applying system-wide alternatives
[    0.045787] Memory: 1833968K/2097152K available (12352K kernel code, 1232K rw        data, 4440K rodata, 2624K init, 604K bss, 123248K reserved, 131072K cma-reserved        )
[    0.047028] devtmpfs: initialized
[    0.057012] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 7645041785100000 ns
[    0.057081] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.061466] 27408 pages in range for non-PLT usage
[    0.061497] 518928 pages in range for PLT usage
[    0.061892] pinctrl core: initialized pinctrl subsystem
[    0.062501] SMBIOS 3.7.0 present.
[    0.062555] DMI: ti Texas Instruments AM625 SK/Texas Instruments AM625 SK, BI        OS 2025.01-00253-g9a3137c5c11a-dirty 01/01/2025
[    0.062582] DMI: Memory slots populated: 0/0
[    0.065411] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.066711] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.067372] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allo        cations
[    0.068160] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic al        locations
[    0.068790] audit: initializing netlink subsys (disabled)
[    0.069152] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=        0 res=1
[    0.069637] thermal_sys: Registered thermal governor 'step_wise'
[    0.069644] thermal_sys: Registered thermal governor 'power_allocator'
[    0.069709] cpuidle: using governor menu
[    0.069917] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.070042] ASID allocator initialised with 65536 entries
[    0.076150] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s        ) with /bus@f0000/interrupt-controller@1800000
[    0.076286] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency c        ycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[    0.076326] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s)        with /bus@f0000/dss@30200000
[    0.076396] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(        s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[    0.076467] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f000        0/i2c@20010000/bridge-hdmi@3b
[    0.081241] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency c        ycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[    0.081402] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s)        with /bus@f0000/dss@30200000
[    0.082279] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(        s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[    0.083131] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s)        with /bus@f0000/dss@30200000
[    0.083209] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f000        0/i2c@20010000/bridge-hdmi@3b
[    0.084935] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s)        with /connector-hdmi
[    0.085031] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20        010000/bridge-hdmi@3b
[    0.087112] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.087151] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.087165] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.087176] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.087189] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.087201] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.087213] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.087225] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.089105] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7        e02f] Detected
[    0.089858] iommu: Default domain type: Translated
[    0.089892] iommu: DMA domain TLB invalidation policy: strict mode
[    0.091242] SCSI subsystem initialized
[    0.091680] usbcore: registered new interface driver usbfs
[    0.091723] usbcore: registered new interface driver hub
[    0.091764] usbcore: registered new device driver usb
[    0.092300] pps_core: LinuxPPS API ver. 1 registered
[    0.092314] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome        tti <giometti@linux.it>
[    0.092340] PTP clock support registered
[    0.092382] EDAC MC: Ver: 3.0.0
[    0.092771] scmi_core: SCMI protocol bus registered
[    0.092863] efivars: Registered efivars operations
[    0.093306] FPGA manager framework
[    0.093415] Advanced Linux Sound Architecture Driver Initialized.
[    0.094445] vgaarb: loaded
[    0.094884] clocksource: Switched to clocksource arch_sys_counter
[    0.095200] VFS: Disk quotas dquot_6.6.0
[    0.095233] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.101928] NET: Registered PF_INET protocol family
[    0.102224] IP idents hash table entries: 32768 (order: 6, 262144 bytes, line        ar)
[    0.103855] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 1638        4 bytes, linear)
[    0.103922] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes,        linear)
[    0.103947] TCP established hash table entries: 16384 (order: 5, 131072 bytes        , linear)
[    0.104113] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linea        r)
[    0.104645] TCP: Hash tables configured (established 16384 bind 16384)
[    0.104868] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.104942] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.105172] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.105783] RPC: Registered named UNIX socket transport module.
[    0.105813] RPC: Registered udp transport module.
[    0.105824] RPC: Registered tcp transport module.
[    0.105834] RPC: Registered tcp-with-tls transport module.
[    0.105844] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.105871] PCI: CLS 0 bytes, default 64
[    0.107320] Initialise system trusted keyrings
[    0.107623] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.107978] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.108286] NFS: Registering the id_resolver key type
[    0.108326] Key type id_resolver registered
[    0.108337] Key type id_legacy registered
[    0.108365] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.108379] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering        ...
[    0.161071] Key type asymmetric registered
[    0.161105] Asymmetric key parser 'x509' registered
[    0.161190] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        44)
[    0.161208] io scheduler mq-deadline registered
[    0.161221] io scheduler kyber registered
[    0.161270] io scheduler bfq registered
[    0.164518] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.165136] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.166839] ledtrig-cpu: registered to indicate activity on CPUs
[    0.172708] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.181640] loop: module loaded
[    0.182833] megasas: 07.727.03.00-rc1
[    0.186785] tun: Universal TUN/TAP device driver, 1.6
[    0.187978] VFIO - User Level meta-driver version: 0.3
[    0.189111] usbcore: registered new interface driver usb-storage
[    0.189784] i2c_dev: i2c /dev entries driver
[    0.191574] sdhci: Secure Digital Host Controller Interface driver
[    0.191610] sdhci: Copyright(c) Pierre Ossman
[    0.191830] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.192844] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.193566] usbcore: registered new interface driver usbhid
[    0.193582] usbhid: USB HID core driver
[    0.194956] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,800        0003f) counters available
[    0.195676] optee: probing for conduit method.
[    0.195721] optee: revision 4.5 (ef1ebdc23034a804)
[    0.196050] optee: dynamic shared memory is enabled
[    0.196839] optee: initialized driver
[    0.196957] random: crng init done
[    0.198839] NET: Registered PF_PACKET protocol family
[    0.199000] Key type dns_resolver registered
[    0.207093] registered taskstats version 1
[    0.207390] Loading compiled-in X.509 certificates
[    0.219543] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b        '11.0.2-v11.00.02 (Fancy Rat)')
[    0.285029] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency c        ycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[    0.285170] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    0.287020] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20        010000/bridge-hdmi@3b
[    0.287124] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f000        0/i2c@20010000/bridge-hdmi@3b
[    0.287192] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s)        with /connector-hdmi
[    0.287258] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s)        with /bus@f0000/dss@30200000
[    0.287690] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    0.289062] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    0.289372] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Rout        er 3 domain created
[    0.289659] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator d        omain 28 created
[    0.291723] ti-udma 485c0100.dma-controller: Number of rings: 82
[    0.294381] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan:        12, rchan: 18)
[    0.297044] ti-udma 485c0000.dma-controller: Number of rings: 150
[    0.301888] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan:        15)
[    0.305111] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 238, base_baud = 3        000000) is a 8250
[    0.305243] printk: legacy console [ttyS2] enabled
[    2.003341] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[    2.010362] Creating 7 MTD partitions on "fc40000.spi.0":
[    2.015783] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    2.022679] 0x000000080000-0x000000280000 : "ospi.tispl"
[    2.029186] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    2.035806] 0x000000680000-0x0000006c0000 : "ospi.env"
[    2.042121] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[    2.048991] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    2.055603] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    2.062647] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration        .
[    2.071369] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    2.110890] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 10        00000
[    2.120780] mdio_bus 8000f00.mdio: MDIO device at address 1 is missing.
[    2.127422] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver        TI DP83867
[    2.135558] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss vers        ion 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000002
[    2.148508] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    2.155650] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
[    2.163611] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000        000, add_val:1 pps:0
[    2.183007] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    2.193582] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency c        ycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[    2.205507] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(        s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[    2.222215] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.227862] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu        mber 1
[    2.235717] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    2.241758] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110        quirks 0x0000808020000010
[    2.251263] xhci-hcd xhci-hcd.0.auto: irq 244, io mem 0x31100000
[    2.258156] hub 1-0:1.0: USB hub found
[    2.261970] hub 1-0:1.0: 1 port detected
[    2.269835] mmc0: CQHCI version 5.10
[    2.279204] pca953x 1-0022: supply vcc not found, using dummy regulator
[    2.286023] pca953x 1-0022: using AI
[    2.303020] pca953x 1-0022: failed writing register: -121
[    2.308651] pca953x 1-0022: probe with driver pca953x failed with error -121
[    2.313536] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64        -bit
[    2.325264] clk: Disabling unused clocks
[    2.338166] PM: genpd: Disabling unused power domains
[    2.343343] ALSA device list:
[    2.346309]   No soundcards found.
[    2.350433] Waiting for root device PARTUUID=076c4a2a-02...
[    2.379132] mmc0: Command Queue Engine enabled
[    2.383616] mmc0: new HS200 MMC card at address 0001
[    2.389555] mmcblk0: mmc0:0001 0IM20E 29.6 GiB
[    2.396162]  mmcblk0: p1
[    2.399275] mmcblk0boot0: mmc0:0001 0IM20E 31.5 MiB
[    2.405263] mmcblk0boot1: mmc0:0001 0IM20E 31.5 MiB
[    2.411737] mmcblk0rpmb: mmc0:0001 0IM20E 4.00 MiB, chardev (239:0)
[    2.510928] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[   12.511771] platform fa00000.mmc: deferred probe pending: platform: supplier        regulator-3 not ready
[   12.520804] platform regulator-3: deferred probe pending: platform: supplier        1-0022 not ready
[   12.529328] platform 2b300050.target-module: deferred probe pending: (reason        unknown)
  • Hi Paul,
    Here is the problem:
    On the EVM, sdcard vdd_mmc1 is controlled by gpio "exp1 3", which likely doesn't exist on your custom board, and this causes the sdcard init failed. You need update the vdd_mmc1 node in kernel k3-am625-sk.dts file according to your board design.
