we are trying to output RGB888 24 bit signal through the vout2 port.
We are able to generate the signal, but we are unable to change the DE signal's polarity.
No matter if select DRM_BUS_FLAG_DE_HIGH or DRM_BUS_FLAG_DE_LOW in the panel_desc.bus_flags, the signal is active low always.
Is there any other location apart from the panel config struct, that we need to change to get DE as active High?
Thanks and Regards,
Anand Mistry
