Part Number: AM62A7
Hi TI Experts,
This command works fine on an unmodified system, but an error message appears after starting it with the modified init script. What could be the reason?
Am I missing something that is not loaded or initialized?
Command:
gst-launch-1.0 v4l2src device=/dev/video3 io-mode=dmabuf-import ! \
video/x-bayer, width=1920, height=1080, framerate=30/1, format=rggb ! \
tiovxisp sink_0::device=/dev/v4l-imx219-subdev0 \
sensor-name="SENSOR_SONY_IMX219_RPI" \
dcc-isp-file=/opt/imaging/imx219/linear/dcc_viss.bin \
sink_0::dcc-2a-file=/opt/imaging/imx219/linear/dcc_2a.bin format-msb=7 ! \
video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1 ! \
kmssink driver-name=tidss sync=false
ErrorLog:
sh-5.2# gst-launch-1.0 v4l2src device=/dev/video3 io-mode=dmabuf-import ! \
APP: Init ... !!!
20.394192 s: MEM: Init ... !!!
20.394253 s: MEM: Initialized DMA HEAP (fd=8) !!!
20.394395 s: MEM: Init ... Done !!!
20.394407 s: IPC: Init ... !!!
20.411470 s: IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
20.416190 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
20.416322 s: VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR
20.416344 s: VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING
20.416355 s: VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO
20.416562 s: VX_ZONE_ERROR: [ownPlatformInit:131] POSIX semaphore create fd
20.417379 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target M
20.417664 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target M
20.417946 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target M
20.418161 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target M
20.418193 s: VX_ZONE_INFO: [tivxInitLocal:126] Initialization Done !!!
20.418206 s: VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO
Setting pipeline to PAUSED ...
Caught SIGSEGV
ScriptFile:myinit.sh
#!/bin/sh
export PATH=/usr/bin:/sbin:/bin
export LD_LIBRARY_PATH=/lib:/usr/lib:$LD_LIBRARY_PATH
mount -t proc proc /proc
mount -n -t sysfs none /sys
mount -n -t tmpfs none /run
export SOC=am62a
export DEVICE_NAME=AM62A
insmod /lib/modules/6.6.44-ti-01478-g541c20281af7-dirty/kernel/drivers/remoteproc/ti_k3_r5_remoteproc.ko
insmod /lib/modules/6.6.44-ti-01478-g541c20281af7-dirty/kernel/drivers/remoteproc/ti_k3_dsp_remoteproc.ko
insmod /lib/modules/6.6.44-ti-01478-g541c20281af7-dirty/kernel/drivers/rpmsg/rpmsg_char.ko
/usr/lib/systemd/systemd-udevd --daemon
/usr/lib/systemd/systemd-journald &
/sbin/udevd --daemon
/sbin/udevadm trigger --action=add
/sbin/udevadm settle
bash /opt/edgeai-gst-apps/scripts/setup_cameras_v3link.sh
media-ctl -V '"imx219 4-0010":0 [fmt:SRGGB8_1X8/1920x1080 field:none]'
media-ctl -V '"cdns_csi2rx.30101000.csi-bridge":0 [fmt:SRGGB8_1X8/1920x1080 field:none]'
media-ctl -V '"30102000.ticsi2rx":0 [fmt:SRGGB8_1X8/1920x1080 field:none]'
./opt/edgeai-gst-apps/apps_cpp/bin/Release/app_edgeai ./opt/edgeai-gst-apps/configs/imx219_cam_example.yaml
echo "Hello world!!!!!!"
exec /bin/sh
/bin/sh
Meng
