I have tried compiling YOLOPv2 for TIDL-Tools version 11_00_06_00.
The code used for compiling is attached as sample.py
import os import copy import time import argparse import cv2 import numpy as np import onnxruntime from utils import utils_onnx from pathlib import Path from utils.utils_onnx import increment_path, LoadImages import shutil import platform def get_args(): parser = argparse.ArgumentParser() parser.add_argument( '--video', type=str, default='sample.mp4', ) parser.add_argument( "-c", "--compile", action="store_true", help="Run in Model compilation mode" ) parser.add_argument( "-d", "--disable_offload", action="store_true", help="Disable offload to TIDL" ) parser.add_argument( '--model', type=str, default='weight/YOLOPv2.onnx', ) parser.add_argument( '--score_th', type=float, default=0.3, ) parser.add_argument( '--nms_th', type=float, default=0.45, ) parser.add_argument( '--save', action='store_true', help='save images/videos' ) parser.add_argument( '--source', type=str, default='sample.mp4', help='input source' ) parser.add_argument( '--project', default='runs/detect', help='save results to project/name' ) parser.add_argument( '--name', default='exp', help='save results to project/name' ) parser.add_argument( '--exist-ok', action='store_true', help='existing project/name ok, do not increment' ) parser.add_argument( '--screen', type=int, default=1, help='Screen number you want to use for capturing' ) parser.add_argument( '--log', type=int, default=2, help='Log severity level.0:Verbose, 1:Info, 2:Warning. 3:Error, 4:Fatal.' ) args = parser.parse_args() return args def run_inference( onnx_session, image, score_th, nms_th, ): # 前処理 # パディング処理を実行 input_image = copy.deepcopy(image) input_image, _, (pad_w, pad_h) = utils_onnx.letterbox(input_image) # BGR→RGB変換 input_image = input_image[:, :, ::-1].transpose(2, 0, 1) # PyTorch Tensorに変換 input_image = np.ascontiguousarray(input_image) # 正規化 input_image = input_image.astype('float32') input_image /= 255.0 # NCHWに変換 input_image = np.expand_dims(input_image, axis=0) # 推論 input_details = onnx_session.get_inputs() input_name = input_details[0].name input_shape = input_details[0].shape results = onnx_session.run(None, {input_name: input_image}) result_dets = [] result_dets.append(results[0][0]) result_dets.append(results[0][1]) result_dets.append(results[0][2]) anchor_grid = [] anchor_grid.append(results[1]) anchor_grid.append(results[2]) anchor_grid.append(results[3]) # 後処理 # 車検出 result_dets = utils_onnx.split_for_trace_model( result_dets, anchor_grid, ) result_dets = utils_onnx.non_max_suppression( result_dets, conf_thres=score_th, iou_thres=nms_th, ) bboxes = [] scores = [] class_ids = [] for result_det in result_dets: if len(result_det) > 0: # バウンディングボックスのスケールを調整 result_det[:, :4] = utils_onnx.scale_coords( input_image.shape[2:], result_det[:, :4], image.shape, ).round() # バウンディングボックス、スコア、クラスIDを取得 for *xyxy, score, class_id in reversed(result_det): x1, y1 = xyxy[0], xyxy[1] x2, y2 = xyxy[2], xyxy[3] bboxes.append([int(x1), int(y1), int(x2), int(y2)]) scores.append(float(score)) class_ids.append(int(class_id)) # 路面セグメンテーション result_road_seg = utils_onnx.driving_area_mask( results[4], (pad_w, pad_h), ) # レーンセグメンテーション result_lane_seg = utils_onnx.lane_line_mask( results[5], (pad_w, pad_h), ) return (bboxes, scores, class_ids), result_road_seg, result_lane_seg def main(): # 引数 args = get_args() # Enforce compilation on x86 only if platform.machine() == "aarch64" and args.compile == True: print( "Compilation of models is only supported on x86 machine \n\ Please do the compilation on PC and copy artifacts for running on TIDL devices " ) exit(-1) source = args.source screen = args.screen save_img = args.save # save inference images if save_img: save_dir = Path(increment_path(Path(args.project) / args.name, exist_ok=args.exist_ok)) # increment run save_dir.mkdir(parents=True, exist_ok=True) # make save_dir video_path = args.video model_path = args.model score_th = args.score_th nms_th = args.nms_th # ONNXファイル有無確認 if not os.path.isfile(model_path): import urllib.request url = 'https://github.com/Kazuhito00/YOLOPv2-ONNX-Sample/releases/download/v0.0.0/YOLOPv2.onnx' weights_save_path = 'weight/YOLOPv2.onnx' print('Start Download:YOLOPv2.onnx') urllib.request.urlretrieve(url, weights_save_path) print('Finish Download') # モデルロード c7x_firmware_version = "11_00_00_00" #set variable for firmware version. compile_options = {} so = onnxruntime.SessionOptions() so.log_severity_level = args.log compile_options['artifacts_folder'] = 'custom-artifacts/yolopv2' compile_options['tidl_tools_path'] = os.environ.get("TIDL_TOOLS_PATH") compile_options['advanced_options:c7x_firmware_version'] = c7x_firmware_version # compile_options['calibration_frames'] = 1 print(f"compile_options: {compile_options}") calib_images = os.listdir('calib-imgs') if args.compile: import onnx os.makedirs(compile_options["artifacts_folder"], exist_ok=True) for root, dirs, files in os.walk( compile_options["artifacts_folder"], topdown=False ): [os.remove(os.path.join(root, f)) for f in files] [os.rmdir(os.path.join(root, d)) for d in dirs] EP_list = ['TIDLCompilationProvider', 'CPUExecutionProvider'] # Shape inference needed for offload to C7x onnx.shape_inference.infer_shapes_path( model_path, model_path ) onnx_session = onnxruntime.InferenceSession( model_path, providers=EP_list, provider_options=[compile_options, {}], sess_options=so ) print(f"EP: {onnx_session.get_providers()}") elif args.disable_offload: EP_list = ['CPUExecutionProvider'] onnx_session = onnxruntime.InferenceSession( model_path, providers=EP_list, sess_options=so ) print(f"EP: {onnx_session.get_providers()}") else: EP_list = ['TIDLExecutionProvider', 'CPUExecutionProvider'] onnx_session = onnxruntime.InferenceSession( model_path, providers=EP_list, provider_options=[compile_options, {}], sess_options=so ) print(f"EP: {onnx_session.get_providers()}") vid_path, vid_writer = None, None dataset = LoadImages(source, screen=screen) # ビデオ読み込み #video_capture = cv2.VideoCapture(video_path) for path, frame, vid_cap in dataset: start_time = time.time() # 画像読み込み # ret, frame = video_capture.read() # if not ret: # break # 推論 (bboxes, scores, class_ids), road_seg, lane_seg = run_inference( onnx_session, frame, score_th, nms_th, ) fps = 1 / (time.time() - start_time) # 推論結果可視化 debug_image = draw_debug_image( frame, (bboxes, scores, class_ids), road_seg, lane_seg, fps, ) if not args.compile: # Image height and width are needed for drawing mid points on the image prepared from all the results of seg, lanes, boxes img_height, img_width, _ = debug_image.shape # cv2.imshow("YOLOPv2", debug_image) # key = cv2.waitKey(1) # if key == 27: # ESC # break out_pipeline = "appsrc ! videoconvert ! kmssink driver-name=tidss sync=false" # Save image/video with segments, lanes and mid points shown. Not relevant for inference though. if save_img: p = Path(path) save_path = str(save_dir / p.name) # img.jpg if dataset.mode == 'image': cv2.imwrite(save_path, debug_image) print(f" The image with the result is saved in: {save_path}") else: # 'video' or 'stream' if vid_path != save_path: # new video vid_path = save_path if isinstance(vid_writer, cv2.VideoWriter): vid_writer.release() # release previous video writer if vid_cap: # video fps = vid_cap.get(cv2.CAP_PROP_FPS) #w = int(video_capture.get(cv2.CAP_PROP_FRAME_WIDTH)) #h = int(video_capture.get(cv2.CAP_PROP_FRAME_HEIGHT)) w,h = debug_image.shape[1], debug_image.shape[0] else: # stream fps, w, h = 30, debug_image.shape[1], debug_image.shape[0] save_path += '.mp4' vid_writer = cv2.VideoWriter(out_pipeline, cv2.CAP_GSTREAMER, 0, fps, (w, h)) vid_writer.write(debug_image) # video_capture.release() # cv2.destroyAllWindows() def draw_debug_image( image, car_dets, road_seg, lane_seg, fps, ): debug_image = copy.deepcopy(image) # 路面セグメンテーション image_width, image_height = debug_image.shape[1], debug_image.shape[0] # マスク画像を生成 road_mask = np.stack((road_seg, ) * 3, axis=-1).astype('float32') road_mask = cv2.resize( road_mask, dsize=(image_width, image_height), interpolation=cv2.INTER_LINEAR, ) road_mask = np.where(road_mask > 0.5, 0, 1) # マスク画像と画像を合成 bg_image = np.zeros(debug_image.shape, dtype=np.uint8) bg_image[:] = [0, 255, 0] road_mask_image = np.where(road_mask, debug_image, bg_image) # 半透明画像として合成 debug_image = cv2.addWeighted(debug_image, 0.5, road_mask_image, 0.5, 1.0) # レーンセグメンテーション # マスク画像を生成 road_mask = np.stack((lane_seg, ) * 3, axis=-1).astype('float32') road_mask = cv2.resize( road_mask, dsize=(image_width, image_height), interpolation=cv2.INTER_LINEAR, ) road_mask = np.where(road_mask > 0.5, 0, 1) # マスク画像と画像を合成 bg_image = np.zeros(debug_image.shape, dtype=np.uint8) bg_image[:] = [0, 0, 255] road_mask_image = np.where(road_mask, debug_image, bg_image) # 半透明画像として合成 debug_image = cv2.addWeighted(debug_image, 0.5, road_mask_image, 0.5, 1.0) # 車検出結果 for bbox, score, class_id in zip(*car_dets): # バウンディングボックス cv2.rectangle( debug_image, pt1=(bbox[0], bbox[1]), pt2=(bbox[2], bbox[3]), color=(0, 255, 255), thickness=2, ) # クラスID、スコア # text = '%s:%s' % (str(class_id), '%.2f' % score) # cv2.putText( # debug_image, # text, # (bbox[0], bbox[1] - 10), # cv2.FONT_HERSHEY_SIMPLEX, # 0.7, # color=(0, 255, 255), # thickness=2, # ) # 処理時間 cv2.putText( debug_image, "FPS:" + '{:.1f}'.format(fps), (10, 30), cv2.FONT_HERSHEY_SIMPLEX, 0.8, (255, 0, 0), 2, cv2.LINE_AA, ) return debug_image if __name__ == "__main__": main()
The compilation starts fine but after compiling the first subgraph, it just gets stuck without anything happening. I have waited for up to half an hour for anything to change, without any success.
Running the compilation code with logging level 0 (verbose) I got the following output.
root@c1921b6aa976:/home/root/yolopv2# python3 .ipynb_checkpoints/ README.md calib-imgs/ exp/ runs/ screen_grab.py steering.py video2.jpg Convert2ONNX.ipynb YOLOPv2.onnx custom-artifacts/ pid.py sample.mp4 scripts/ trial.ipynb weight/ LICENSE __pycache__/ da_seg_mid.py pipeline.txt sample.py some-imgs/ utils/ yolopv2_compile_log.txt root@c1921b6aa976:/home/root/yolopv2# python3 sample.py -c --source calib-imgs/ --log 0 compile_options: {'artifacts_folder': 'custom-artifacts/yolopv2', 'tidl_tools_path': '/home/root/tools/AM68PA/tidl_tools', 'advanced_options:c7x_firmware_version': '11_00_00_00'} 2025-06-02 13:15:02.696482614 [I:onnxruntime:, inference_session.cc:284 operator()] Flush-to-zero and denormal-as-zero are off 2025-06-02 13:15:02.696510496 [I:onnxruntime:, inference_session.cc:292 ConstructorCommon] Creating and using per session threadpools since use_per_session_threads_ is true 2025-06-02 13:15:02.696521637 [I:onnxruntime:, inference_session.cc:310 ConstructorCommon] Dynamic block base set to 0 2025-06-02 13:15:02.798449102 [I:onnxruntime:, inference_session.cc:1344 Initialize] Initializing session. 2025-06-02 13:15:02.798503866 [I:onnxruntime:, session_state.cc:98 SetupAllocators] Allocator already registered for OrtMemoryInfo:[name:Cpu id:0 OrtMemType:0 OrtAllocatorType:1 Device:[DeviceType:0 MemoryType:0 DeviceId:0]]. Ignoring allocator from CPUExecutionProvider 2025-06-02 13:15:02.800720522 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 5 2025-06-02 13:15:02.807740881 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 2025-06-02 13:15:02.808963876 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 0 2025-06-02 13:15:02.812330249 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 2025-06-02 13:15:02.813189185 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 0 2025-06-02 13:15:02.816438586 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 2025-06-02 13:15:02.817257235 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 0 2025-06-02 13:15:02.820504522 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 2025-06-02 13:15:02.821372575 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 0 2025-06-02 13:15:02.824646312 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 2025-06-02 13:15:02.825452639 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 0 2025-06-02 13:15:02.828733299 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 2025-06-02 13:15:02.829554554 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 0 2025-06-02 13:15:02.832909735 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 2025-06-02 13:15:02.833777538 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 0 2025-06-02 13:15:02.837073777 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 2025-06-02 13:15:02.837885394 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 0 2025-06-02 13:15:02.841124886 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 2025-06-02 13:15:02.841943405 [I:onnxruntime:, constant_sharing.cc:257 ApplyImpl] Total shared scalar initializer count: 0 2025-06-02 13:15:02.845196804 [I:onnxruntime:, reshape_fusion.cc:53 ApplyImpl] Total fused reshape node count: 0 ========================= [Model Compilation Started] ========================= Model compilation will perform the following stages: 1. Parsing 2. Graph Optimization 3. Quantization & Calibration 4. Memory Planning ============================== [Version Summary] ============================== ------------------------------------------------------------------------------- | TIDL Tools Version | 11_00_06_00 | ------------------------------------------------------------------------------- | C7x Firmware Version | 11_00_00_00 | ------------------------------------------------------------------------------- | Runtime Version | 1.15.0 | ------------------------------------------------------------------------------- | Model Opset Version | 17 | ------------------------------------------------------------------------------- ============================== [Parsing Started] ============================== [TIDL Import] [PARSER] WARNING: Network not identified as Object Detection network : (1) Ignore if network is not Object Detection network (2) If network is Object Detection network, please specify "model_type":"OD" as part of OSRT compilation options [TIDL Import] WARNING: Change to Upsample/Resize if possible instead of Deconvolution. It will be more efficient [TIDL Import] WARNING: Change to Upsample/Resize if possible instead of Deconvolution. It will be more efficient [TIDL Import] WARNING: Change to Upsample/Resize if possible instead of Deconvolution. It will be more efficient ------------------------- Subgraph Information Summary ------------------------- ------------------------------------------------------------------------------- | Core | No. of Nodes | Number of Subgraphs | ------------------------------------------------------------------------------- | C7x | 419 | 3 | | CPU | 5 | x | ------------------------------------------------------------------------------- ---------------------------------------------------------------------------------------------------------------------------------- | Node | Node Name | Reason | ---------------------------------------------------------------------------------------------------------------------------------- | MaxPool | /MaxPool_5 | Kernel size (13x13) with stride (1x1) not supported | | MaxPool | /MaxPool_4 | Kernel size (9x9) with stride (1x1) not supported | | MaxPool | /MaxPool_3 | Kernel size (5x5) with stride (1x1) not supported | | Expand | /Expand | Layer type not supported by TIDL | | SequenceConstruct | /SequenceConstruct | Layer 303 - op type SequenceConstruct, Unknown input dimension, not supported by TIDL | ---------------------------------------------------------------------------------------------------------------------------------- ============================= [Parsing Completed] ============================= 2025-06-02 13:15:03.933148924 [W:onnxruntime:, graph.cc:3533 CleanUnusedInitializersAndNodeArgs] Removing initializer '777'. It is not used by any node and should be removed from the model. 2025-06-02 13:15:03.933186165 [W:onnxruntime:, graph.cc:3533 CleanUnusedInitializersAndNodeArgs] Removing initializer '776'. It is not used by any node and should be removed from the model. 2025-06-02 13:15:03.933203958 [W:onnxruntime:, graph.cc:3533 CleanUnusedInitializersAndNodeArgs] Removing initializer '775'. It is not used by any node and should be removed from the model. 2025-06-02 13:15:04.035994196 [V:onnxruntime:, session_state.cc:1149 VerifyEachNodeIsAssignedToAnEp] Node placements 2025-06-02 13:15:04.036025415 [V:onnxruntime:, session_state.cc:1155 VerifyEachNodeIsAssignedToAnEp] Node(s) placed on [TIDLExecutionProvider]. Number of nodes: 3 2025-06-02 13:15:04.036031547 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] TIDL_0 (TIDLExecutionProvider_TIDL_0_0) 2025-06-02 13:15:04.036036436 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] TIDL_1 (TIDLExecutionProvider_TIDL_1_1) 2025-06-02 13:15:04.036041155 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] TIDL_2 (TIDLExecutionProvider_TIDL_2_2) 2025-06-02 13:15:04.036046134 [V:onnxruntime:, session_state.cc:1155 VerifyEachNodeIsAssignedToAnEp] Node(s) placed on [CPUExecutionProvider]. Number of nodes: 9 2025-06-02 13:15:04.036052947 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] Expand (/Expand) 2025-06-02 13:15:04.036059059 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] SequenceConstruct (/SequenceConstruct) 2025-06-02 13:15:04.036067104 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] MaxPool (/MaxPool_5_output_0_nchwc) 2025-06-02 13:15:04.036073767 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] ReorderInput (ReorderInput) 2025-06-02 13:15:04.036080169 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] MaxPool (/MaxPool_4_output_0_nchwc) 2025-06-02 13:15:04.036086140 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] MaxPool (/MaxPool_3_output_0_nchwc) 2025-06-02 13:15:04.036092182 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] ReorderOutput (ReorderOutput) 2025-06-02 13:15:04.036098624 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] ReorderOutput (ReorderOutput_token_245) 2025-06-02 13:15:04.036105326 [V:onnxruntime:, session_state.cc:1157 VerifyEachNodeIsAssignedToAnEp] ReorderOutput (ReorderOutput_token_246) 2025-06-02 13:15:04.036205466 [V:onnxruntime:, session_state.cc:133 CreateGraphInfo] SaveMLValueNameIndexMapping 2025-06-02 13:15:04.036279115 [V:onnxruntime:, session_state.cc:179 CreateGraphInfo] Done saving OrtValue mappings. 2025-06-02 13:15:04.036289856 [I:onnxruntime:, allocation_planner.cc:2376 CreateGraphPartitioner] Use DeviceBasedPartition as default 2025-06-02 13:15:04.036560849 [I:onnxruntime:, session_state_utils.cc:201 SaveInitializedTensors] Saving initialized tensors. 2025-06-02 13:15:04.058569250 [I:onnxruntime:, session_state_utils.cc:344 SaveInitializedTensors] Done saving initialized tensors 2025-06-02 13:15:11.108170419 [I:onnxruntime:, inference_session.cc:1645 Initialize] Session successfully initialized. EP: ['TIDLExecutionProvider', 'CPUExecutionProvider'] /home/root/yolopv2/calib-imgs 2025-06-02 13:15:11.122816784 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:11.123040657 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution ==================== [Optimization for subgraph_0 Started] ==================== ----------------------------- Optimization Summary ----------------------------- -------------------------------------------------------------------------------- | Layer | Nodes before optimization | Nodes after optimization | -------------------------------------------------------------------------------- | TIDL_BatchNormLayer | 0 | 47 | | TIDL_ConcatLayer | 7 | 7 | | TIDL_EltWiseLayer | 47 | 47 | | TIDL_SigmoidLayer | 47 | 0 | | TIDL_ConvolutionLayer | 47 | 47 | | TIDL_PoolingLayer | 3 | 3 | -------------------------------------------------------------------------------- Total nodes in subgraph: 156 =================== [Optimization for subgraph_0 Completed] =================== The soft limit is 10240 The hard limit is 10240 MEM: Init ... !!! MEM: Init ... Done !!! 0.0s: VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO 0.11s: VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR 0.14s: VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING 0.153s: VX_ZONE_INFO: [ownAddTargetKernelInternal:189] registered kernel vx_tutorial_graph.phase_rgb on target DSP-1 0.178s: VX_ZONE_INFO: [ownAddTargetKernelInternal:189] registered kernel vx_tutorial_graph.phase_rgb on target DSP-2 0.1848s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-0 0.1900s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-1 0.1962s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-2 0.2018s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-3 0.2081s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP_C7-1 0.2139s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP_C7-1_PRI_2 0.2199s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP_C7-1_PRI_3 0.2261s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP_C7-1_PRI_4 0.2335s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP_C7-1_PRI_5 0.2542s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP_C7-1_PRI_6 0.2604s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP_C7-1_PRI_7 0.2668s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP_C7-1_PRI_8 0.2735s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MCU2-0 0.2795s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target VPAC_NF 0.2864s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target VPAC_LDC1 0.2929s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target VPAC_MSC1 0.2990s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target VPAC_MSC2 0.3039s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target VPAC_VISS1 0.3093s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target CAPTURE1 0.3153s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target CAPTURE2 0.3215s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target CAPTURE3 0.3283s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target CAPTURE4 0.3351s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target CAPTURE5 0.3411s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target CAPTURE6 0.3476s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target CAPTURE7 0.3532s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target CAPTURE8 0.3580s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DISPLAY1 0.3635s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DISPLAY2 0.3691s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target CSITX 0.3753s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSS_M2M1 0.3823s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSS_M2M2 0.3878s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSS_M2M3 0.3939s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSS_M2M4 0.3995s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target VPAC_FC 0.4058s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MCU2-1 0.4120s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DMPAC_SDE 0.4183s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DMPAC_DOF 0.4253s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MCU3-0 0.4333s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MCU3-1 0.4390s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP-1 0.4459s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target DSP-2 0.4467s: VX_ZONE_INFO: [tivxInit:152] Initialization Done !!! 0.4470s: VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO ============= [Quantization & Calibration for subgraph_0 Started] ============= 2025-06-02 13:15:14.848349008 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:14.848430682 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:14.848514401 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:14.848541011 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:14.848659786 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:14.848716243 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:14.848826792 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:14.848875324 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 ==================== [Optimization for subgraph_1 Started] ==================== ----------------------------- Optimization Summary ----------------------------- --------------------------------------------------------------------------------- | Layer | Nodes before optimization | Nodes after optimization | --------------------------------------------------------------------------------- | TIDL_InnerProductLayer | 2 | 2 | | TIDL_BatchNormLayer | 1 | 27 | | TIDL_EltWiseLayer | 25 | 25 | | TIDL_SigmoidLayer | 26 | 0 | | TIDL_ConstDataLayer | 0 | 2 | | TIDL_ResizeLayer | 5 | 5 | | TIDL_ConvolutionLayer | 28 | 28 | | TIDL_ConcatLayer | 6 | 6 | | TIDL_PoolingLayer | 1 | 1 | | TIDL_LeakyReluLayer | 1 | 0 | --------------------------------------------------------------------------------- Total nodes in subgraph: 115 =================== [Optimization for subgraph_1 Completed] =================== ============= [Quantization & Calibration for subgraph_1 Started] ============= 2025-06-02 13:15:17.277308184 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:17.277335836 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:17.277341797 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:17.277347658 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:17.277353169 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:17.277359521 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:17.277368157 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:17.277374279 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:17.277510537 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:17.277517650 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 ==================== [Optimization for subgraph_2 Started] ==================== ----------------------------- Optimization Summary ----------------------------- -------------------------------------------------------------------------------- | Layer | Nodes before optimization | Nodes after optimization | -------------------------------------------------------------------------------- | TIDL_BatchNormLayer | 6 | 50 | | TIDL_Deconv2DLayer | 3 | 3 | | TIDL_ConcatLayer | 8 | 8 | | TIDL_EltWiseLayer | 52 | 46 | | TIDL_SigmoidLayer | 46 | 0 | | TIDL_ResizeLayer | 1 | 1 | | TIDL_ConvolutionLayer | 50 | 50 | | TIDL_LeakyReluLayer | 3 | 0 | | TIDL_PoolingLayer | 2 | 2 | -------------------------------------------------------------------------------- Total nodes in subgraph: 175 =================== [Optimization for subgraph_2 Completed] =================== [TIDL Import] WARNING: Change to Upsample/Resize if possible instead of Deconvolution. It will be more efficient [TIDL Import] WARNING: Change to Upsample/Resize if possible instead of Deconvolution. It will be more efficient [TIDL Import] WARNING: Change to Upsample/Resize if possible instead of Deconvolution. It will be more efficient ============= [Quantization & Calibration for subgraph_2 Started] ============= 2025-06-02 13:15:20.245013095 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:20.245042210 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:20.245051819 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:20.245061246 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:20.245071155 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:20.245080743 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:20.245089099 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:20.245098978 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:20.245106813 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:20.245115940 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:20.245124136 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:20.245395830 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:20.245406049 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:20.245414806 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:20.245422731 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:20.286478427 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:20.286569049 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:20.478881306 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:20.478946620 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:20.479053112 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:20.479107174 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:20.479168310 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:20.479212704 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:20.479286513 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:20.479332280 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:20.537889276 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:20.537915926 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:20.537921907 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:20.537926797 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:20.537931606 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:20.537936515 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:20.537943588 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:20.537949449 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:20.538091088 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:20.538098772 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:20.821868013 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:20.821893552 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:20.821902338 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:20.821910033 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:20.821917647 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:20.821925873 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:20.821933377 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:20.821938807 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:20.821945460 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:20.821954186 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:20.821962873 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:20.822179353 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:20.822186456 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:20.822192668 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:20.822199601 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:20.872306892 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:20.872393215 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:21.066153814 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:21.066226712 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:21.066354554 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:21.066400521 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:21.066472938 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:21.066513475 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:21.066585641 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:21.066627631 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:21.130442469 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:21.130478498 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:21.130488126 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:21.130495339 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:21.130502613 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:21.130512121 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:21.130519746 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:21.130527691 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:21.130699676 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:21.130707922 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:21.426586205 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:21.426613997 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:21.426619628 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:21.426626451 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:21.426633254 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:21.426640878 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:21.426649494 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:21.426658521 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:21.426666477 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:21.426674261 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:21.426682347 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:21.426926869 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:21.426935726 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:21.426942589 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:21.426950224 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:21.473976011 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:21.474062705 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:21.664769934 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:21.664841530 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:21.664967899 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:21.665022342 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:21.665086504 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:21.665131549 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:21.665206711 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:21.665255604 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:21.727714856 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:21.727742999 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:21.727749502 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:21.727755613 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:21.727764871 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:21.727771674 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:21.727784738 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:21.727796010 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:21.727974968 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:21.727987352 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:22.023556950 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:22.023585625 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:22.023591365 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:22.023596325 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:22.023601074 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:22.023606143 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:22.023614219 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:22.023621002 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:22.023627965 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:22.023635319 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:22.023646480 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:22.023885753 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:22.023894349 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:22.023899679 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:22.023905210 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:22.066271547 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:22.066357540 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:22.257371570 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:22.257526843 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:22.257595273 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:22.257632483 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:22.257684963 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:22.257723536 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:22.257801193 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:22.257843022 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:22.314622282 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:22.314651037 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:22.314659032 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:22.314667037 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:22.314676976 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:22.314683769 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:22.314688798 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:22.314695311 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:22.314853951 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:22.314863319 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:22.610782619 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:22.610815872 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:22.610824739 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:22.610837252 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:22.610850638 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:22.610862821 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:22.610877168 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:22.610890583 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:22.610904189 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:22.610917444 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:22.610928896 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:22.611177116 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:22.611191062 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:22.611200340 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:22.611209607 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:22.664921181 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:22.665008095 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:22.856112596 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:22.856179854 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:22.856269363 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:22.856304700 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:22.856538733 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:22.856597474 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:22.856671975 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:22.856719585 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:22.925074217 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:22.925098904 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:22.925104074 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:22.925109033 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:22.925113672 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:22.925117980 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:22.925122929 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:22.925127859 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:22.925383202 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:22.925390556 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:23.217027249 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:23.217056875 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:23.217062145 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:23.217066974 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:23.217072345 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:23.217077314 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:23.217084538 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:23.217089317 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:23.217096801 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:23.217102592 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:23.217108453 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:23.217345632 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:23.217355811 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:23.217362975 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:23.217369858 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:23.259896058 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:23.259986599 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:23.453046151 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:23.453229247 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:23.453295403 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:23.453351699 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:23.453431530 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:23.453500210 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:23.453583718 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:23.453637621 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:23.521007418 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:23.521033127 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:23.521042074 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:23.521050760 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:23.521056551 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:23.521062112 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:23.521069045 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:23.521075487 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:23.521205633 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:23.521211865 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:23.804086362 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:23.804114896 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:23.804120377 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:23.804127250 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:23.804132520 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:23.804138300 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:23.804143871 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:23.804149772 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:23.804155042 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:23.804160523 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:23.804166183 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:23.804390979 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:23.804399936 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:23.804406268 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:23.804413291 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:23.844797727 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:23.844891494 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:24.040743522 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:24.040925957 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:24.040991411 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:24.041044161 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:24.041110507 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:24.041160291 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:24.041244290 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:24.041293924 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:24.103383646 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:24.103411199 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:24.103418482 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:24.103426848 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:24.103434382 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:24.103439953 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:24.103446425 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:24.103452717 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:24.103602621 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:24.103611287 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:24.384281542 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:24.384309976 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:24.384317169 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:24.384325054 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:24.384332248 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:24.384339652 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:24.384348028 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:24.384356303 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:24.384363697 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:24.384370651 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:24.384379417 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:24.384629310 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:24.384641774 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:24.384649689 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:24.384655850 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:24.430254636 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:24.430341000 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:24.619391513 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:24.619562517 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:24.619623823 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:24.619745503 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:24.619802601 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:24.619848077 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:24.619917699 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:24.619965008 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:24.680948707 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:24.680976380 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:24.680981489 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:24.680986339 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:24.680991118 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:24.680996398 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:24.681001307 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:24.681011426 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:24.681135982 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:24.681143386 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:24.971137880 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:24.971165653 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:24.971170773 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:24.971176233 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:24.971181122 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:24.971185811 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:24.971190941 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:24.971197503 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:24.971202693 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:24.971212161 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:24.971219625 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:24.971430755 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:24.971439672 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:24.971444291 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:24.971451574 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:25.021513098 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:25.021607367 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:25.211102912 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:25.211170179 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:25.211243057 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:25.211276160 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:25.211576608 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:25.211631833 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:25.211704450 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:25.211752842 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:25.276464448 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:25.276498111 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:25.276505315 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:25.276511787 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:25.276518320 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:25.276524692 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:25.276535502 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:25.276546052 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:25.276715493 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:25.276724680 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:25.578046477 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:25.578075702 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:25.578081834 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:25.578090440 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:25.578098195 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:25.578106030 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:25.578112362 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:25.578117862 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:25.578123252 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:25.578129173 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:25.578138491 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:25.578340383 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:25.578349270 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:25.578356143 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:25.578363196 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:25.618964242 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:25.619049413 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:25.809279779 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:25.809344592 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:25.809462145 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:25.809521146 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:25.809582813 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:25.809629692 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:25.809701768 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:25.809747986 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:25.873467864 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:25.873499554 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:25.873506407 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:25.873513190 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:25.873519321 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:25.873528168 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:25.873535071 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:25.873542996 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:25.873714872 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:25.873723388 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:26.179855810 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:26.179885206 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:26.179890887 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:26.179895846 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:26.179900515 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:26.179905935 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:26.179913159 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:26.179920753 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:26.179926194 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:26.179931704 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:26.179937906 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:26.180152863 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:26.180159235 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:26.180166629 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:26.180174033 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:26.228065268 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:26.228150991 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:26.417417572 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:26.417571343 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:26.417624073 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:26.417659731 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:26.417719273 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:26.417760331 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:26.417835183 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:26.417873786 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:26.491396551 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:26.491422099 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:26.491427219 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:26.491432058 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:26.491437268 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:26.491442027 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:26.491448158 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:26.491463096 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:26.491592892 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:26.491600346 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:26.782635541 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:26.782661550 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:26.782667341 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:26.782672180 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:26.782677109 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:26.782684774 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:26.782690595 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:26.782696215 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:26.782701916 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:26.782707837 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:26.782714220 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:26.782910721 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:26.782918336 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:26.782923826 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:26.782929407 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:26.825639735 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:26.825731479 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:27.018741126 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:27.018806740 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:27.018872304 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:27.018900498 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:27.019110525 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:27.019136454 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:27.019469855 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:27.019580435 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:27.081776739 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:27.081805503 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:27.081810513 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:27.081815132 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:27.081819740 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:27.081824479 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:27.081829118 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:27.081834378 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:27.081955517 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:27.081961198 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:27.361627041 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:27.361653511 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:27.361658490 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:27.361664021 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:27.361668840 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:27.361673699 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:27.361680552 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:27.361685762 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:27.361692765 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:27.361698947 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:27.361704668 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:27.361916088 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:27.361923833 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:27.361932259 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:27.361937519 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:27.419856636 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:27.419944763 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:27.609319039 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:27.609384522 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:27.609539376 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:27.609596203 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:27.609715108 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:27.609755515 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:27.609832931 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:27.609878277 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:27.673215651 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:27.673240789 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:27.673246239 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:27.673254475 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:27.673261468 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:27.673268211 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:27.673275465 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:27.673283400 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:27.673414678 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:27.673422904 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:27.965791121 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:27.965819535 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:27.965824885 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:27.965832640 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:27.965839593 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:27.965849271 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:27.965856365 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:27.965864260 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:27.965871473 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:27.965880160 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:27.965889087 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:27.966095688 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:27.966105556 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:27.966112780 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:27.966119533 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:28.009193750 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:28.009285273 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:28.200983117 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:28.201052679 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:28.201143220 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:28.201173738 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:28.201421286 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:28.201445833 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:28.201584275 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:28.201640061 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:28.264055419 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:28.264083543 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:28.264090406 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:28.264099102 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:28.264108289 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:28.264116044 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:28.264123548 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:28.264131774 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:28.264288861 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:28.264297417 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:28.564795715 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:28.564825521 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:28.564834608 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:28.564843816 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:28.564851370 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:28.564858604 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:28.564865777 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:28.564872931 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:28.564880074 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:28.564887749 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:28.564895904 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:28.565129637 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:28.565139245 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:28.565146889 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:28.565154133 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:28.605612328 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:28.605696658 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:28.802247949 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:28.802317350 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:28.802396710 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:28.802423782 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:28.802638618 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:28.802663155 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:28.802988671 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:28.803001826 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:28.856038441 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:28.856068288 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:28.856076924 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:28.856087194 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:28.856096481 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:28.856106540 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:28.856115858 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:28.856125997 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:28.856271803 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:28.856282403 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:29.157264576 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:29.157295625 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:29.157305343 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:29.157318348 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:29.157331232 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:29.157343015 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:29.157355228 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:29.157367261 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:29.157380375 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:29.157393761 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:29.157408549 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:29.157638093 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:29.157652350 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:29.157661698 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:29.157673079 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:29.209163929 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:29.209248028 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:29.399964875 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:29.400123445 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:29.400170283 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:29.400207063 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:29.400274350 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:29.400312573 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:29.400385641 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:29.400423413 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:29.463448796 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:29.463483943 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:29.463489503 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:29.463494643 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:29.463499612 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:29.463504662 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:29.463509451 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:29.463518298 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:29.463653283 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:29.463660597 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:29.751780222 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:29.751805971 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:29.751810980 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:29.751818053 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:29.751823434 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:29.751829215 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:29.751834955 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:29.751840676 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:29.751846487 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:29.751854593 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:29.751864602 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:29.752088045 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:29.752098595 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:29.752103784 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:29.752109074 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:29.794499317 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:29.794582564 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:29.983508711 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:29.983576990 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:29.983697929 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:29.983751821 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:29.983820381 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:29.983863252 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:29.983939126 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:29.983984913 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:30.053142204 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:30.053172621 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:30.053179174 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:30.053184183 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:30.053189002 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:30.053194302 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:30.053199312 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:30.053209301 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:30.053351219 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:30.053361028 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:30.350529682 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:30.350558486 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:30.350565730 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:30.350576280 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:30.350583344 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:30.350591078 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:30.350599314 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:30.350610455 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:30.350617338 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:30.350625904 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:30.350634550 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:30.350872841 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:30.350881408 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:30.350886988 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:30.350893110 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:30.391694675 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:30.391789915 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution 2025-06-02 13:15:30.581876388 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:15:30.582047011 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:15:30.582104701 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:15:30.582153603 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:15:30.582220530 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:15:30.582265766 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:15:30.582343192 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:15:30.582390602 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432 2025-06-02 13:15:30.643162420 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 102 released 2025-06-02 13:15:30.643194651 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 103 released 2025-06-02 13:15:30.643201564 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 104 released 2025-06-02 13:15:30.643208637 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 105 released 2025-06-02 13:15:30.643214909 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 106 released 2025-06-02 13:15:30.643224818 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 107 released 2025-06-02 13:15:30.643232182 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 313 released 2025-06-02 13:15:30.643240187 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 426 2025-06-02 13:15:30.643411641 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 1 released 2025-06-02 13:15:30.643422091 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 364 2025-06-02 13:15:30.944111480 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 3 released 2025-06-02 13:15:30.944141737 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 172 released 2025-06-02 13:15:30.944148430 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 173 released 2025-06-02 13:15:30.944158408 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 174 released 2025-06-02 13:15:30.944165442 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 175 released 2025-06-02 13:15:30.944173146 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 176 released 2025-06-02 13:15:30.944178977 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 177 released 2025-06-02 13:15:30.944185339 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 178 released 2025-06-02 13:15:30.944191331 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 179 released 2025-06-02 13:15:30.944199115 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 316 released 2025-06-02 13:15:30.944207421 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 427 2025-06-02 13:15:30.944428440 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 4 released 2025-06-02 13:15:30.944437908 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 5 released 2025-06-02 13:15:30.944443759 [V:onnxruntime:, stream_execution_context.cc:171 RecycleNodeInputs] ort value 6 released 2025-06-02 13:15:30.944450802 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 424 2025-06-02 13:15:30.987430440 [V:onnxruntime:, sequential_executor.cc:534 ExecuteThePlan] Number of streams: 1 2025-06-02 13:15:30.987526251 [V:onnxruntime:, sequential_executor.cc:184 SessionScope] Begin execution -------- Running Calibration in Float Mode to Collect Tensor Statistics -------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [1 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [2 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [3 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [4 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [5 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [6 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [7 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [8 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [9 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [10 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [11 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [12 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [13 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [14 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [15 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [16 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [17 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [18 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [19 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [20 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [21 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [22 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [23 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [24 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [25 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [26 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [27 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [28 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [29 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [30 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [31 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [32 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [33 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [34 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [35 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [36 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [37 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [38 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [39 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [40 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [41 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [42 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [43 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [44 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [45 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [46 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [47 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [48 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [49 / 50]: ----------------- [=============================================================================] 100 % ----------------- Fixed-point Calibration Iteration [50 / 50]: ----------------- [=============================================================================] 100 % ==================== [Quantization & Calibration Completed] ==================== ========================== [Memory Planning Started] ========================== ------------------------- Network Compiler Traces ------------------------------ Successful Memory Allocation Successful Workload Creation ========================= [Memory Planning Completed] ========================= Rerunning network compiler... ========================== [Memory Planning Started] ========================== ------------------------- Network Compiler Traces ------------------------------ Successful Memory Allocation Successful Workload Creation ========================= [Memory Planning Completed] ========================= ======================== Subgraph Compiled Successfully ======================== 2025-06-02 13:23:09.236513072 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 425 2025-06-02 13:23:09.236732547 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 429 2025-06-02 13:23:09.236798893 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 431 2025-06-02 13:23:09.236847625 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 434 2025-06-02 13:23:09.236911957 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 430 2025-06-02 13:23:09.236958555 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 433 2025-06-02 13:23:09.237036883 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 428 2025-06-02 13:23:09.237081898 [V:onnxruntime:, sequential_executor.cc:518 ExecuteKernel] stream 0 launch kernel with idx 432
The problem with custom models not compiling beyond a certain point also occurred when trying to compile YOLOP.
Both these models' compilation went through with version 10_01_04_00 of TIDL Tools and the PSDK Linux Edgeai 10, although with their own set of problems when run on the TDA4VM-SK
The issue with YOLOPv2 has been documented here, whereas for YOLOP I'll have to create a new post.
Let me know if any clarification is required.
utils_onnx.py
import copy import time import cv2 import numpy as np from pathlib import Path import glob import re import os #from screen_grab import grab class LoadImages: # for inference def __init__(self, path, screen=1): self.dev = False self.grab_screen = False p = str(Path(path).absolute()) # os-agnostic absolute path print(p) if '*' in p: files = sorted(glob.glob(p, recursive=True)) # glob elif os.path.isdir(p): files = sorted(glob.glob(os.path.join(p, '*.*'))) # dir elif os.path.isfile(p): files = [p] # files elif p.startswith("/dev/video"): files = [p] self.dev = True # elif "screengrab" in p: # files = [p] # self.grab_screen = True else: raise Exception(f'ERROR: {p} does not exist') img_formats = ['bmp', 'jpg', 'jpeg', 'png', 'tif', 'tiff', 'dng', 'webp', 'mpo'] # acceptable image suffixes vid_formats = ['mov', 'avi', 'mp4', 'mpg', 'mpeg', 'm4v', 'wmv', 'mkv'] # acceptable video suffixes images = [x for x in files if x.split('.')[-1].lower() in img_formats] videos = [x for x in files if x.split('.')[-1].lower() in vid_formats] if self.dev: videos = [p] ni, nv = len(images), len(videos) self.files = images + videos self.screen = screen self.nf = ni + nv # number of files self.video_flag = [False] * ni + [True] * nv self.mode = 'image' # if self.grab_screen: # self.nf = 1 # self.video_flag = [False] # self.files = [p] if any(videos): self.new_video(videos[0]) # new video else: self.cap = None assert self.nf > 0, f'No images or videos found in {p}. ' \ f'Supported formats are:\nimages: {img_formats}\nvideos: {vid_formats}' def __iter__(self): self.count = 0 return self def __next__(self): if self.count == self.nf: raise StopIteration path = self.files[self.count] if self.video_flag[self.count]: # Read video self.mode = 'video' ret_val, img0 = self.cap.read() if not ret_val: self.count += 1 self.cap.release() if self.count == self.nf: # last video raise StopIteration else: path = self.files[self.count] self.new_video(path) ret_val, img0 = self.cap.read() # if self.dev: # if (cv2.waitKey(1) & 0xFF) == ord('q'): # raise StopIteration self.frame += 1 print(f'video {self.count + 1}/{self.nf} ({self.frame}/{self.nframes}) {path}: ', end='') # elif self.grab_screen: # self.mode = 'video' # img0 = grab(self.screen) # assert img0 is not None, 'Frame Error' # if (cv2.waitKey(1) & 0xFF) == ord('q'): # raise StopIteration else: # Read image self.count += 1 img0 = cv2.imread(path) # BGR assert img0 is not None, 'Image Not Found ' + path #print(f'image {self.count}/{self.nf} {path}: ', end='') # Padded resize img0 = cv2.resize(img0, (1280,720), interpolation=cv2.INTER_LINEAR) return path, img0, self.cap def new_video(self, path): self.frame = 0 self.cap = cv2.VideoCapture(path) self.nframes = int(self.cap.get(cv2.CAP_PROP_FRAME_COUNT)) if self.dev: self.nframes = 250 def __len__(self): return self.nf # number of files def increment_path(path, exist_ok=True, sep=''): # Increment path, i.e. runs/exp --> runs/exp{sep}0, runs/exp{sep}1 etc. path = Path(path) # os-agnostic if (path.exists() and exist_ok) or (not path.exists()): return str(path) else: dirs = glob.glob(f"{path}{sep}*") # similar paths matches = [re.search(rf"%s{sep}(\d+)" % path.stem, d) for d in dirs] i = [int(m.groups()[0]) for m in matches if m] # indices n = max(i) + 1 if i else 2 # increment number return f"{path}{sep}{n}" # update path def letterbox( img, new_shape=(320, 320), color=(114, 114, 114), auto=True, scaleFill=False, scaleup=True, stride=32, ): # Resize and pad image while meeting stride-multiple constraints shape = img.shape[:2] # current shape [height, width] if isinstance(new_shape, int): new_shape = (new_shape, new_shape) # Scale ratio (new / old) r = min(new_shape[0] / shape[0], new_shape[1] / shape[1]) if not scaleup: # only scale down, do not scale up (for better test mAP) r = min(r, 1.0) # Compute padding ratio = r, r # width, height ratios new_unpad = int(round(shape[1] * r)), int(round(shape[0] * r)) dw, dh = new_shape[1] - new_unpad[0], new_shape[0] - new_unpad[ 1] # wh padding if auto: # minimum rectangle dw, dh = np.mod(dw, stride), np.mod(dh, stride) # wh padding elif scaleFill: # stretch dw, dh = 0.0, 0.0 new_unpad = (new_shape[1], new_shape[0]) ratio = new_shape[1] / shape[1], new_shape[0] / shape[ 0] # width, height ratios # divide padding into 2 sides dw /= 2 dh /= 2 if shape[::-1] != new_unpad: # resize img = cv2.resize(img, new_unpad, interpolation=cv2.INTER_LINEAR) top, bottom = int(round(dh - 0.1)), int(round(dh + 0.1)) left, right = int(round(dw - 0.1)), int(round(dw + 0.1)) img = cv2.copyMakeBorder( img, top, bottom, left, right, cv2.BORDER_CONSTANT, value=color, ) # add border return img, ratio, (dw, dh) def _make_grid(nx=20, ny=20): xv, yv = np.meshgrid(np.arange(0, nx), np.arange(0, ny)) return np.stack((xv, yv), 2).reshape((1, 1, ny, nx, 2)).astype('float32') def _sigmoid(arr): arr = np.array(arr, dtype=np.float32) return 1.0 / (1.0 + np.exp(-1.0 * arr)) def split_for_trace_model(pred=None, anchor_grid=None): z = [] st = [8, 16, 32] for i in range(3): bs, _, ny, nx = pred[i].shape pred[i] = pred[i].reshape(bs, 3, 85, ny, nx).transpose(0, 1, 3, 4, 2) y = _sigmoid(pred[i]) gr = _make_grid(nx, ny) y[..., 0:2] = (y[..., 0:2] * 2. - 0.5 + gr) * st[i] # xy y[..., 2:4] = (y[..., 2:4] * 2)**2 * anchor_grid[i] # wh z.append(y.reshape(bs, -1, 85)) pred = np.concatenate(z, 1) return pred def _xywh2xyxy(x): # Convert nx4 boxes from [x, y, w, h] to [x1, y1, x2, y2] # where xy1=top-left, xy2=bottom-right y = np.copy(x) y[:, 0] = x[:, 0] - x[:, 2] / 2 # top left x y[:, 1] = x[:, 1] - x[:, 3] / 2 # top left y y[:, 2] = x[:, 0] + x[:, 2] / 2 # bottom right x y[:, 3] = x[:, 1] + x[:, 3] / 2 # bottom right y return y def _box_iou(box1, box2): # https://github.com/pytorch/vision/blob/master/torchvision/ops/boxes.py """ Return intersection-over-union (Jaccard index) of boxes. Both sets of boxes are expected to be in (x1, y1, x2, y2) format. Arguments: box1 (Tensor[N, 4]) box2 (Tensor[M, 4]) Returns: iou (Tensor[N, M]): the NxM matrix containing the pairwise IoU values for every element in boxes1 and boxes2 """ def box_area(box): # box = 4xn return (box[2] - box[0]) * (box[3] - box[1]) area1 = box_area(box1.T) area2 = box_area(box2.T) # inter(N,M) = (rb(N,M,2) - lt(N,M,2)).clamp(0).prod(2) inter = (np.minimum(box1[:, None, 2:], box2[:, 2:]) - np.maximum(box1[:, None, :2], box2[:, :2])).clamp(0).prod(2) return inter / (area1[:, None] + area2 - inter ) # iou = inter / (area1 + area2 - inter) def _nms(boxes, scores, iou_threshold): x1, y1 = boxes[:, 0], boxes[:, 1] x2, y2 = boxes[:, 2], boxes[:, 3] areas = (x2 - x1 + 1) * (y2 - y1 + 1) order = scores.argsort()[::-1] keep = [] while order.size > 0: i = order[0] keep.append(i) xx1 = np.maximum(x1[i], x1[order[1:]]) yy1 = np.maximum(y1[i], y1[order[1:]]) xx2 = np.minimum(x2[i], x2[order[1:]]) yy2 = np.minimum(y2[i], y2[order[1:]]) w = np.maximum(0.0, xx2 - xx1 + 1) h = np.maximum(0.0, yy2 - yy1 + 1) inter = w * h ovr = inter / (areas[i] + areas[order[1:]] - inter) inds = np.where(ovr <= iou_threshold)[0] order = order[inds + 1] result = np.stack(keep) return result def non_max_suppression( prediction, conf_thres=0.25, iou_thres=0.45, multi_label=False, labels=(), ): """Runs Non-Maximum Suppression (NMS) on inference results Returns: list of detections, on (n,6) tensor per image [xyxy, conf, cls] """ nc = prediction.shape[2] - 5 # number of classes xc = prediction[..., 4] > conf_thres # candidates # Settings max_det = 300 # maximum number of detections per image max_nms = 30000 # maximum number of boxes into torchvision.ops.nms() time_limit = 10.0 # seconds to quit after multi_label &= nc > 1 # multiple labels per box (adds 0.5ms/img) t = time.time() output = [np.zeros((0, 6))] * prediction.shape[0] for xi, x in enumerate(prediction): # image index, image inference # Apply constraints x = x[xc[xi]] # confidence # Cat apriori labels if autolabelling if labels and len(labels[xi]): l = labels[xi] v = np.zeros((len(l), nc + 5), device=x.device) v[:, :4] = l[:, 1:5] # box v[:, 4] = 1.0 # conf v[range(len(l)), l[:, 0].long() + 5] = 1.0 # cls x = np.concatenate((x, v), 0) # If none remain process next image if not x.shape[0]: continue # Compute conf x[:, 5:] *= x[:, 4:5] # conf = obj_conf * cls_conf # Box (center x, center y, width, height) to (x1, y1, x2, y2) box = _xywh2xyxy(x[:, :4]) # Detections matrix nx6 (xyxy, conf, cls) if multi_label: i, j = (x[:, 5:] > conf_thres).nonzero(as_tuple=False).T x = np.concatenate((box[i], x[i, j + 5, None], j[:, None].float()), 1) else: # best class only conf = np.max(x[:, 5:], axis=1, keepdims=True) j = np.argmax(x[:, 5:], axis=1) j = j.reshape((j.shape[0], 1)) x = np.concatenate((box, conf, j.astype('float32')), 1)[conf.reshape(-1) > conf_thres] # Check shape n = x.shape[0] # number of boxes if not n: # no boxes continue elif n > max_nms: # excess boxes x = x[x[:, 4].argsort( descending=True)[:max_nms]] # sort by confidence # NMS boxes, scores = x[:, :4], x[:, 4] # boxes (offset by class), scores i = _nms( boxes, scores, iou_thres, ) if i.shape[0] > max_det: # limit detections i = i[:max_det] output[xi] = x[i] if (time.time() - t) > time_limit: print(f'WARNING: NMS time limit {time_limit}s exceeded') break # time limit exceeded return output def scale_coords(img1_shape, coords, img0_shape, ratio_pad=None): # Rescale coords (xyxy) from img1_shape to img0_shape if ratio_pad is None: # calculate from img0_shape gain = min(img1_shape[0] / img0_shape[0], img1_shape[1] / img0_shape[1]) # gain = old / new pad = (img1_shape[1] - img0_shape[1] * gain) / 2, ( img1_shape[0] - img0_shape[0] * gain) / 2 # wh padding else: gain = ratio_pad[0][0] pad = ratio_pad[1] coords[:, [0, 2]] -= pad[0] # x padding coords[:, [1, 3]] -= pad[1] # y padding coords[:, :4] /= gain _clip_coords(coords, img0_shape) return coords def _clip_coords(boxes, img_shape): # Clip bounding xyxy bounding boxes to image shape (height, width) boxes[:, 0] = np.clip(boxes[:, 0], 0, img_shape[1]) # x1 boxes[:, 1] = np.clip(boxes[:, 1], 0, img_shape[0]) # y1 boxes[:, 2] = np.clip(boxes[:, 2], 0, img_shape[1]) # x2 boxes[:, 3] = np.clip(boxes[:, 3], 0, img_shape[0]) # y1 def driving_area_mask(seg, pad_wh=None): if pad_wh is None: return 1.0 - seg[0][0] else: temp_seg = copy.deepcopy(seg[0][0]) pad_w = int(pad_wh[0]) pad_h = int(pad_wh[1]) seg_width = int(temp_seg.shape[1]) seg_height = int(temp_seg.shape[0]) temp_seg = temp_seg[pad_h:seg_height - pad_h, pad_w:seg_width - pad_w] return 1.0 - temp_seg def lane_line_mask(ll, pad_wh=None): if pad_wh is None: return ll[0][0] else: temp_ll = copy.deepcopy(ll[0][0]) pad_w = int(pad_wh[0]) pad_h = int(pad_wh[1]) seg_width = int(temp_ll.shape[1]) seg_height = int(temp_ll.shape[0]) temp_ll = temp_ll[pad_h:seg_height - pad_h, pad_w:seg_width - pad_w] return temp_ll
Charanjit Singh
