PROCESSOR-SDK-J784S4: CPSW9G Linux Switch Mode systemd
Part Number: PROCESSOR-SDK-J784S4
Hi
We have (again) problems facilitating the switch mode of the CPSW9G on Linux with systemd.
The fix added to systemd (https://github.com/systemd/systemd/pull/34438) previously doesn't work anymore with SDK 11.0.
Here is the debug log of system-networkd:
Jul 23 09:58:48 priceless-goldwasser systemd[1]: Starting systemd-networkd.service - Network Configuration...
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: SELinux enabled state cached to: disabled
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Bus bus-api-network: changing state UNSET → OPENING
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: sd-bus: starting bus bus-api-network by connecting to /run/dbus/system_bus_socket...
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Bus bus-api-network: changing state OPENING → AUTHENTICATING
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Registering bus object implementation for path=/org/freedesktop/network1 iface=org.freedesktop.network1.Manager
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Registering bus object implementation for path=/org/freedesktop/network1/link iface=org.freedesktop.network1.DHCPServer
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Registering bus object implementation for path=/org/freedesktop/network1/link iface=org.freedesktop.network1.Link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Registering bus object implementation for path=/org/freedesktop/network1/network iface=org.freedesktop.network1.Network
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Registering bus object implementation for path=/org/freedesktop/LogControl1 iface=org.freedesktop.LogControl1
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: sd-device-monitor(n/a): Failed to stat PID1's netns, ignoring: No such file or directory
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/ksi.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/xf1.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/koi_ecat.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/kli.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/xf2.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/krc_net.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/diob.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/xg19.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/switch.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/cn9300.netdev'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: No virtualization found in DMI vendor table.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Unable to read /sys/firmware/dmi/entries/0-0/raw, using the virtualization information found in DMI vendor table, ignoring: No such file or directory
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: UML virtualization not found in /proc/cpuinfo.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Virtualization XEN not found, /proc/xen does not exist
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: No virtualization found in CPUID
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: No virtualization found in /proc/device-tree/*
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: This platform does not support /proc/sysinfo
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Found VM virtualization none
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/cn9300.netdev: Conditions in the file do not match the system environment, skipping.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: diob: loaded "vlan"
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli: loaded "vlan"
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: koi_ecat: loaded "vlan"
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: krc_net: loaded "vlan"
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: ksi: loaded "vlan"
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: loaded "bridge"
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Using MAC address: 8e:dc:ce:8f:98:04
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Creating
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/xf1.netdev: Conditions in the file do not match the system environment, skipping.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/xf2.netdev: Conditions in the file do not match the system environment, skipping.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/xg19.netdev: Conditions in the file do not match the system environment, skipping.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/80-6rd-tunnel.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/80-container-host0.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/80-container-vb.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/80-container-ve.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/80-container-vz.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/80-vm-vt.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/80-wifi-adhoc.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/cn9300.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/eexb_ai.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/xf1.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/xg19.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/switch.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/xf4.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/eexb_tp.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/koi_ecat.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/kli_it.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/eexb_win.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/diob.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/eexb_kosi.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/eexb_kosi_2.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/xf9.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/krc_net.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/kli.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/xf8.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/xf2.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/ksi.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/80-container-host0.network: Conditions in the file do not match the system environment, skipping.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/eexb_kosi.network: Setting RequiredForOnline=no because ActivationPolicy=always-down.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/eexb_kosi_2.network: Setting RequiredForOnline=no because ActivationPolicy=always-down.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/kli_it.network: Setting RequiredForOnline=no because ActivationPolicy=always-down.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Skipping overridden file '/usr/lib/systemd/network/krc_net.network.d/10_proxy_auto_discovery.conf'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/xf2.network: Setting RequiredForOnline=no because ActivationPolicy=always-down.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/xf8.network: Setting RequiredForOnline=no because ActivationPolicy=always-down.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: /var/lib/systemd/network/xf9.network: Setting RequiredForOnline=no because ActivationPolicy=always-down.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: netdev has index 14
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: netdev ready
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Saved new link: ifindex=14, iftype=ETHER(1), kind=bridge
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Saved original MTU 1500 (min: 68, max: 65535)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Saved hardware address: 8e:dc:ce:8f:98:04
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Saved new link: ifindex=13, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Saved original MTU 1500 (min: 68, max: 9194)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Saved hardware address: d6:ad:85:1b:d8:59
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: sd-device: Failed to chase symlinks in "/sys/devices/platform/bus@100000/2930000.pcie/pci0003:00/0003:00:00.0/0003:01:00.0/physfn".
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Saved new link: ifindex=12, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Saved original MTU 1500 (min: 68, max: 9194)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Saved hardware address: 7a:17:95:10:2f:6d
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: sd-device: Failed to chase symlinks in "/sys/devices/platform/bus@100000/2920000.pcie/pci0002:00/0002:00:00.0/0002:01:00.0/physfn".
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Saved new link: ifindex=11, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Saved original MTU 1500 (min: 68, max: 9194)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Saved hardware address: 1e:48:ef:31:10:9d
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: sd-device: Failed to chase symlinks in "/sys/devices/platform/bus@100000/2900000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/physfn".
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Saved new link: ifindex=10, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Saved original MTU 1500 (min: 64, max: 2002)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Saved hardware address: 02:60:c8:00:00:07
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Saved new link: ifindex=9, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Saved original MTU 1500 (min: 64, max: 2002)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Saved hardware address: 02:60:c8:00:00:06
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Saved new link: ifindex=8, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Saved original MTU 1500 (min: 64, max: 2002)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Saved hardware address: 02:60:c8:00:00:05
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Saved new link: ifindex=7, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Saved original MTU 1500 (min: 64, max: 2002)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Saved hardware address: 02:60:c8:00:00:04
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: cn9300: Saved new link: ifindex=6, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: cn9300: Saved original MTU 1500 (min: 64, max: 2002)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: cn9300: Saved hardware address: 02:60:c8:00:00:03
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: cn9300: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: cn9300: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: cn9300: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: cn9300: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xg19: Saved new link: ifindex=5, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xg19: Saved original MTU 1500 (min: 64, max: 2002)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xg19: Saved hardware address: 02:60:c8:00:00:02
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xg19: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xg19: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xg19: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xg19: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf1: Saved new link: ifindex=4, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf1: Saved original MTU 1500 (min: 64, max: 2002)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf1: Saved hardware address: 02:60:c8:00:00:01
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf1: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf1: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf1: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf1: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eth0: Saved new link: ifindex=3, iftype=ETHER(1), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eth0: Saved original MTU 1500 (min: 64, max: 2002)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eth0: Saved hardware address: 02:60:c8:00:00:00
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eth0: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eth0: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eth0: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eth0: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: dummy0: Saved new link: ifindex=2, iftype=ETHER(1), kind=dummy
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: dummy0: Saved original MTU 1500 (min: 0, max: 4294967295)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: dummy0: Saved hardware address: ca:46:7f:92:b5:35
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: dummy0: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: dummy0: Flags change: +BROADCAST +NOARP
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: dummy0: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: dummy0: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Saved new link: ifindex=1, iftype=LOOPBACK(772), kind=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Saved original MTU 65536 (min: 0, max: 4294967295)
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Saved hardware address: 00:00:00:00:00:00
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Flags change: +LOOPBACK +UP +LOWER_UP +RUNNING
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Link UP
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Gained carrier
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: udev initialized link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: State changed: pending -> initialized
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Received new foreign QDisc (configured): handle=0:0, parent=ffff:ffff, kind=noqueue
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Received new foreign address (configured): ::1/128 (valid forever, preferred forever), flags: permanent,no-prefixroute, scope: host
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: link_check_ready(): link is in initialized state.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Received new foreign address (configured): 127.0.0.1/8 (valid forever, preferred forever), flags: permanent, scope: host
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: rtnl: received non-static neighbor, ignoring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Received new foreign route (configured): dst: ::1/128, src: n/a, gw: n/a, prefsrc: n/a, scope: global, table: main(254), proto: kernel, type: local, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Received new foreign route (configured): dst: 127.255.255.255/32, src: n/a, gw: n/a, prefsrc: 127.0.0.1, scope: link, table: local(255), proto: kernel, type: broadcast, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Received new foreign route (configured): dst: 127.0.0.1/32, src: n/a, gw: n/a, prefsrc: 127.0.0.1, scope: host, table: local(255), proto: kernel, type: local, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: lo: Received new foreign route (configured): dst: 127.0.0.0/8, src: n/a, gw: n/a, prefsrc: 127.0.0.1, scope: host, table: local(255), proto: kernel, type: local, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Could not enumerate routing policy rules, ignoring: Operation not supported
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Could not enumerate wireless LAN phy, ignoring: Operation not supported
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Could not enumerate wireless LAN interfaces, ignoring: Operation not supported
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Enumeration completed
Jul 23 09:58:48 priceless-goldwasser systemd[1]: Started systemd-networkd.service - Network Configuration.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Bus bus-api-network: changing state AUTHENTICATING → HELLO
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_call sender=n/a destination=org.freedesktop.DBus path=/org/freedesktop/DBus interface=org.freedesktop.DBus member=Hello cookie=1 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_call sender=n/a destination=org.freedesktop.DBus path=/org/freedesktop/DBus interface=org.freedesktop.DBus member=RequestName cookie=2 reply_cookie=0 signature=su error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_call sender=n/a destination=org.freedesktop.DBus path=/org/freedesktop/DBus interface=org.freedesktop.DBus member=AddMatch cookie=3 reply_cookie=0 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: dummy0: Found driver: dummy
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: dummy0: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Found driver: am65-cpsw-nuss
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Saved permanent hardware address: 02:60:c8:00:00:06
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Got message type=method_return sender=org.freedesktop.DBus destination=:1.6 path=n/a interface=n/a member=n/a cookie=1 reply_cookie=1 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Bus bus-api-network: changing state HELLO → RUNNING
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Got message type=signal sender=org.freedesktop.DBus.Local destination=n/a path=/org/freedesktop/DBus/Local interface=org.freedesktop.DBus.Local member=Connected cookie=4294967295 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Got message type=signal sender=org.freedesktop.DBus destination=:1.6 path=/org/freedesktop/DBus interface=org.freedesktop.DBus member=NameAcquired cookie=2 reply_cookie=0 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Got message type=signal sender=org.freedesktop.DBus destination=:1.6 path=/org/freedesktop/DBus interface=org.freedesktop.DBus member=NameAcquired cookie=3 reply_cookie=0 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Got message type=method_return sender=org.freedesktop.DBus destination=:1.6 path=n/a interface=n/a member=n/a cookie=4 reply_cookie=2 signature=u error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Successfully acquired requested service name.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Got message type=method_return sender=org.freedesktop.DBus destination=:1.6 path=n/a interface=n/a member=n/a cookie=5 reply_cookie=3 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Match type='signal',sender='org.freedesktop.login1',path='/org/freedesktop/login1',interface='org.freedesktop.login1.Manager',member='PrepareForSleep' successfully installed.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: cn9300: Found driver: am65-cpsw-nuss
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: cn9300: Saved permanent hardware address: 02:60:c8:00:00:03
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xg19: Found driver: am65-cpsw-nuss
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xg19: Saved permanent hardware address: 02:60:c8:00:00:02
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Found driver: am65-cpsw-nuss
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Saved permanent hardware address: 02:60:c8:00:00:04
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Found driver: am65-cpsw-nuss
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Saved permanent hardware address: 02:60:c8:00:00:07
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Found driver: am65-cpsw-nuss
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Saved permanent hardware address: 02:60:c8:00:00:05
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: New interface name 'eth2' received from the kernel does not correspond with the name currently configured on the actual interface 'eexb_kosi_2'. Ignoring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Found driver: r8169
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Hardware address is changed: 1e:48:ef:31:10:9d → 92:4a:07:60:77:1a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf1: Found driver: am65-cpsw-nuss
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf1: Saved permanent hardware address: 02:60:c8:00:00:01
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: New interface name 'eth1' received from the kernel does not correspond with the name currently configured on the actual interface 'eexb_kosi'. Ignoring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Found driver: r8169
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Hardware address is changed: 7a:17:95:10:2f:6d → fe:96:57:f5:8e:96
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: New interface name 'eth3' received from the kernel does not correspond with the name currently configured on the actual interface 'kli_it'. Ignoring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Found driver: r8169
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Hardware address is changed: d6:ad:85:1b:d8:59 → fe:87:e3:9a:44:7f
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Hardware address is changed: 92:4a:07:60:77:1a → 1e:48:ef:31:10:9d
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Hardware address is changed: fe:96:57:f5:8e:96 → 7a:17:95:10:2f:6d
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Hardware address is changed: fe:87:e3:9a:44:7f → d6:ad:85:1b:d8:59
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: rtnl: received neighbor message with invalid family '7', ignoring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Found driver: bridge
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Created
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Bridge parameters set success
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Link state is up-to-date
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: found matching network '/var/lib/systemd/network/switch.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Configuring with /var/lib/systemd/network/switch.network.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_314 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=4 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: State changed: initialized -> configuring
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_314 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=5 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: link_check_ready(): link is not activated.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/switch/use_tempaddr' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: No change in value '0', suppressing write
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/switch/accept_ra' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/switch/proxy_ndp' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/switch/promote_secondaries' to '1'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Requested to set IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Requested stacked netdev 'koi_ecat'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Requested stacked netdev 'diob'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Requested stacked netdev 'kli'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Requested stacked netdev 'ksi'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Requested stacked netdev 'krc_net'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Requested to set bridge VLAN configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Requested to activate link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: link_check_ready(): link layer is configuring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=6 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Setting IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: switch: Setting bridge VLAN configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Link state is up-to-date
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: found matching network '/var/lib/systemd/network/kli_it.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Configuring with /var/lib/systemd/network/kli_it.network.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: State changed: initialized -> configuring
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_313 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=7 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: link_check_ready(): link is not activated.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/kli_it/use_tempaddr' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/kli_it/accept_ra' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/kli_it/proxy_ndp' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/kli_it/promote_secondaries' to '1'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Requested to set MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Requested to set IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: link_check_ready(): link layer is configuring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Requested to activate link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Requested configuring of the DHCPv4 client.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Setting MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: kli_it: Setting IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Link state is up-to-date
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: found matching network '/var/lib/systemd/network/eexb_kosi.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Configuring with /var/lib/systemd/network/eexb_kosi.network.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: State changed: initialized -> configuring
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_312 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=8 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: link_check_ready(): link is not activated.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/eexb_kosi/use_tempaddr' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/eexb_kosi/accept_ra' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/eexb_kosi/proxy_ndp' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/eexb_kosi/promote_secondaries' to '1'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Requested to set MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Requested to set IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: link_check_ready(): link layer is configuring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Requested to activate link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Requested configuring of the DHCPv4 client.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Setting MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Setting IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Link state is up-to-date
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: found matching network '/var/lib/systemd/network/eexb_kosi_2.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Configuring with /var/lib/systemd/network/eexb_kosi_2.network.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: State changed: initialized -> configuring
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_311 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=9 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: link_check_ready(): link is not activated.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/eexb_kosi_2/use_tempaddr' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/eexb_kosi_2/accept_ra' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/eexb_kosi_2/proxy_ndp' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/eexb_kosi_2/promote_secondaries' to '1'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Requested to set MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Requested to set IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: link_check_ready(): link layer is configuring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Requested to activate link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Requested configuring of the DHCPv4 client.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Setting MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Setting IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Link state is up-to-date
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: found matching network '/var/lib/systemd/network/xf8.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Configuring with /var/lib/systemd/network/xf8.network.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: State changed: initialized -> configuring
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_310 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=10 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: link_check_ready(): link is not activated.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf8/use_tempaddr' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf8/accept_ra' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf8/proxy_ndp' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/xf8/promote_secondaries' to '1'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Requested to set MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Requested to set IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Requested to set master interface
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: link_check_ready(): link layer is configuring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Requested to set bridge configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Requested to set bridge VLAN configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Requested to activate link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Setting MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Setting IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Bringing link up
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf8: Setting master interface
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Link state is up-to-date
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: found matching network '/var/lib/systemd/network/xf9.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Configuring with /var/lib/systemd/network/xf9.network.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: State changed: initialized -> configuring
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_39 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=11 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: link_check_ready(): link is not activated.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf9/use_tempaddr' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf9/accept_ra' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf9/proxy_ndp' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/xf9/promote_secondaries' to '1'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Requested to set MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Requested to set IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Requested to set master interface
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: link_check_ready(): link layer is configuring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Requested to set bridge configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Requested to set bridge VLAN configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Requested to activate link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Setting MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Setting IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Bringing link up
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf9: Setting master interface
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.7 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.7 path=n/a interface=n/a member=n/a cookie=12 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Link state is up-to-date
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: found matching network '/var/lib/systemd/network/xf4.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Configuring with /var/lib/systemd/network/xf4.network.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_38 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=13 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: State changed: initialized -> configuring
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_38 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=14 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: link_check_ready(): link is not activated.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf4/use_tempaddr' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf4/accept_ra' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf4/proxy_ndp' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/xf4/promote_secondaries' to '1'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Requested to set MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Requested to set IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Requested to set master interface
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: link_check_ready(): link layer is configuring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Requested to set bridge configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Requested to set bridge VLAN configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Requested to activate link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Setting MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Setting IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Bringing link up
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf4: Setting master interface
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.7 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.7 path=n/a interface=n/a member=n/a cookie=15 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.10 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=SetLinkDNSEx cookie=3 reply_cookie=0 signature=ia(iayqs) error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.10 path=n/a interface=n/a member=n/a cookie=16 reply_cookie=3 signature=s error-name=org.freedesktop.resolve1.LinkBusy error-message=Link lo is loopback device.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Failed to process message type=method_call sender=:1.10 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=SetLinkDNSEx cookie=3 reply_cookie=0 signature=ia(iayqs) error-name=n/a error-message=n/a: Link lo is loopback device.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Link state is up-to-date
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: found matching network '/var/lib/systemd/network/xf2.network'.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Configuring with /var/lib/systemd/network/xf2.network.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: State changed: initialized -> configuring
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_37 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=17 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: link_check_ready(): link is not activated.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf2/use_tempaddr' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf2/accept_ra' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf2/proxy_ndp' to '0'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/xf2/promote_secondaries' to '1'
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Requested to set MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Requested to set IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Requested to set master interface
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: link_check_ready(): link layer is configuring.
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Requested to set bridge configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Requested to set bridge VLAN configurations
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Requested to activate link
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Setting MAC address
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Setting IPv6LL address generation mode
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Bringing link up
Jul 23 09:58:48 priceless-goldwasser systemd-networkd[1077]: xf2: Setting master interface
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.12 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.12 path=n/a interface=n/a member=n/a cookie=18 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: found matching network '/var/lib/systemd/network/cn9300.network'.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Configuring with /var/lib/systemd/network/cn9300.network.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_36 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=19 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: State changed: initialized -> configuring
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_36 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=20 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/cn9300/use_tempaddr' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: No change in value '0', suppressing write
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/cn9300/accept_ra' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/cn9300/proxy_ndp' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/cn9300/promote_secondaries' to '1'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Requested to set IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Requested to set master interface
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: link_check_ready(): link layer is configuring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Requested to set bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Requested to set bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Requested to activate link
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Setting IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Bringing link up
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Setting master interface
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.12 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.12 path=n/a interface=n/a member=n/a cookie=21 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: found matching network '/var/lib/systemd/network/xg19.network'.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Configuring with /var/lib/systemd/network/xg19.network.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_35 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=22 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: State changed: initialized -> configuring
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_35 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=23 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xg19/use_tempaddr' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xg19/accept_ra' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xg19/proxy_ndp' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/xg19/promote_secondaries' to '1'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Requested to set IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Requested to set master interface
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: link_check_ready(): link layer is configuring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Requested to set bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Requested to set bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Requested to activate link
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Setting IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Bringing link up
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Setting master interface
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: found matching network '/var/lib/systemd/network/xf1.network'.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Configuring with /var/lib/systemd/network/xf1.network.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_34 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=24 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: State changed: initialized -> configuring
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_34 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=25 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf1/use_tempaddr' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf1/accept_ra' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/xf1/proxy_ndp' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/xf1/promote_secondaries' to '1'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Requested to set MAC address
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Requested to set IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Requested to set master interface
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: link_check_ready(): link layer is configuring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Requested to set bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Requested to set bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Requested to activate link
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Setting MAC address
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Setting IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Bringing link up
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Setting master interface
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eth0: Found driver: am65-cpsw-nuss
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eth0: Saved permanent hardware address: 02:60:c8:00:00:00
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eth0: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eth0: Unmanaging interface.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eth0: State changed: initialized -> unmanaged
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_33 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=26 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: dummy0: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: dummy0: Unmanaging interface.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: dummy0: State changed: initialized -> unmanaged
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_32 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=27 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: lo: Failed to get driver, continuing without: Operation not supported
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: lo: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: lo: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: lo: Unmanaging interface.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: lo: State changed: initialized -> unmanaged
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_31 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=28 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: rtnl: received neighbor message with invalid family '7', ignoring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: bridge VLAN configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: Bringing link up
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli_it: Hardware address is changed: d6:ad:85:1b:d8:59 → 00:60:c8:05:fc:e3
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli_it: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli_it: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli_it: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli_it: Bringing link down
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Hardware address is changed: 7a:17:95:10:2f:6d → 00:60:c8:05:fb:db
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: Bringing link down
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Hardware address is changed: 1e:48:ef:31:10:9d → 00:60:c8:05:fb:de
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: Bringing link down
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: Hardware address is changed: 02:60:c8:00:00:07 → 00:60:c8:05:fb:dc
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: Flags change: +UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_310 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=29 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: Link UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=30 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: Attached to master interface: 14
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: rtnl: received neighbor message with invalid family '7', ignoring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: master interface set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: Hardware address is changed: 02:60:c8:00:00:06 → 00:60:c8:05:fb:dd
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: Flags change: +UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_39 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=31 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: Link UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: Attached to master interface: 14
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: rtnl: received neighbor message with invalid family '7', ignoring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: master interface set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Hardware address is changed: 02:60:c8:00:00:05 → 00:60:c8:05:fc:e2
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Flags change: +UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_38 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=32 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Link UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Attached to master interface: 14
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: rtnl: received neighbor message with invalid family '7', ignoring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: master interface set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Hardware address is changed: 02:60:c8:00:00:04 → 00:60:c8:05:fc:e1
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Flags change: +UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_37 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=33 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Link UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Attached to master interface: 14
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: rtnl: received neighbor message with invalid family '7', ignoring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: master interface set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Flags change: +UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_36 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=34 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Link UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Attached to master interface: 14
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: rtnl: received neighbor message with invalid family '7', ignoring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: master interface set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Flags change: +UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_35 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=35 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Link UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Attached to master interface: 14
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: rtnl: received neighbor message with invalid family '7', ignoring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: master interface set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Hardware address is changed: 02:60:c8:00:00:01 → 00:60:c8:05:fc:e0
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Flags change: +UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_34 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=36 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Link UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Attached to master interface: 14
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: rtnl: received neighbor message with invalid family '7', ignoring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: master interface set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=1:0, parent=ffff:ffff, kind=mqprio
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: Flags change: +UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_314 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=37 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: Link UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: link_check_ready(): stacked netdevs are not created.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Creating
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Using MAC address: 02:60:c8:00:00:03
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Creating
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Creating
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Using MAC address: 02:60:c8:00:00:01
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Creating
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Using MAC address: 02:60:c8:00:00:02
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Creating
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli_it: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli_it: link_check_ready(): DHCPv4, DHCPv6, DHCP-PD or IPv4LL is enabled but no dynamic address is assigned yet.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi: link_check_ready(): DHCPv4, DHCPv6, DHCP-PD or IPv4LL is enabled but no dynamic address is assigned yet.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: eexb_kosi_2: link_check_ready(): DHCPv4, DHCPv6, DHCP-PD or IPv4LL is enabled but no dynamic address is assigned yet.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=ffff:0, parent=ffff:fff1, kind=clsact
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: Setting bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: Setting bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: Setting bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: Setting bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Failed to get link from ifindex 18, ignoring: No such device
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Failed to get link from ifindex 16, ignoring: No such device
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Failed to get link from ifindex 17, ignoring: No such device
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Failed to get link from ifindex 15, ignoring: No such device
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Setting bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Setting bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=10:0, parent=1:1, kind=tbf
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Setting bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Setting bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Failed to get link from ifindex 19, ignoring: No such device
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Setting bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: Setting bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Setting bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: Setting bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.15 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.15 path=n/a interface=n/a member=n/a cookie=38 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=20:0, parent=1:2, kind=pfifo
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Setting bridge configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: Setting bridge VLAN configurations
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.15 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.15 path=n/a interface=n/a member=n/a cookie=39 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: netdev has index 15
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: netdev ready
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Saved new link: ifindex=15, iftype=ETHER(1), kind=vlan
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Saved original MTU 1500 (min: 0, max: 65535)
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Saved hardware address: 8e:dc:ce:8f:98:04
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Failed to manage link by its new hardware address, ignoring: File exists
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=40 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: udev initialized link
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: State changed: pending -> initialized
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=41 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: netdev has index 16
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: netdev ready
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Saved new link: ifindex=16, iftype=ETHER(1), kind=vlan
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Saved original MTU 1500 (min: 0, max: 65535)
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Saved hardware address: 02:60:c8:00:00:03
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Failed to manage link by its new hardware address, ignoring: File exists
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_316 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=42 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: udev initialized link
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: State changed: pending -> initialized
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_316 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=43 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: netdev has index 17
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: netdev ready
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Saved new link: ifindex=17, iftype=ETHER(1), kind=vlan
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Saved original MTU 1500 (min: 0, max: 65535)
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Saved hardware address: 8e:dc:ce:8f:98:04
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Failed to manage link by its new hardware address, ignoring: File exists
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=44 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: udev initialized link
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: State changed: pending -> initialized
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=45 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=30:0, parent=1:3, kind=pfifo
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: netdev has index 18
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: netdev ready
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Saved new link: ifindex=18, iftype=ETHER(1), kind=vlan
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Saved original MTU 1500 (min: 0, max: 65535)
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Saved hardware address: 02:60:c8:00:00:01
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=46 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: udev initialized link
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: State changed: pending -> initialized
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=47 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: netdev has index 19
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: netdev ready
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Saved new link: ifindex=19, iftype=ETHER(1), kind=vlan
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Saved original MTU 1500 (min: 0, max: 65535)
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Saved hardware address: 02:60:c8:00:00:02
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Failed to manage link by its new hardware address, ignoring: File exists
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Saved IPv6 link-local address generation mode: eui64
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Flags change: +MULTICAST +BROADCAST
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=48 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: udev initialized link
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: State changed: pending -> initialized
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=49 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: Stacked netdevs created.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: switch: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_314 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=50 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: bridge configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: bridge VLAN configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: Bringing link down
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=40:0, parent=1:4, kind=pfifo
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: bridge configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: bridge VLAN configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: Bringing link down
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: bridge configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: bridge VLAN configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Bringing link up
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=50:0, parent=1:5, kind=pfifo
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: bridge configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: bridge VLAN configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Bringing link down
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: bridge configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: bridge VLAN configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=60:0, parent=1:6, kind=pfifo
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: bridge configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: bridge VLAN configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: bridge configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: bridge VLAN configurations set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=70:0, parent=1:7, kind=pfifo
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Found driver: 802.1Q VLAN Support
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: found matching network '/var/lib/systemd/network/koi_ecat.network'.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Configuring with /var/lib/systemd/network/koi_ecat.network.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=51 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: State changed: initialized -> configuring
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=52 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/koi_ecat/use_tempaddr' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/koi_ecat/accept_ra' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/koi_ecat/proxy_ndp' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/koi_ecat/promote_secondaries' to '1'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Requested to set IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: link_check_ready(): link layer is configuring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Setting IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Found driver: 802.1Q VLAN Support
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: found matching network '/var/lib/systemd/network/diob.network'.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Configuring with /var/lib/systemd/network/diob.network.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_316 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=53 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: State changed: initialized -> configuring
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_316 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=54 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/diob/use_tempaddr' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/diob/accept_ra' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/diob/proxy_ndp' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/diob/promote_secondaries' to '1'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Requested to set IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: link_check_ready(): link layer is configuring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: Setting IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Found driver: 802.1Q VLAN Support
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: found matching network '/var/lib/systemd/network/kli.network'.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Configuring with /var/lib/systemd/network/kli.network.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=55 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: State changed: initialized -> configuring
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=56 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/kli/use_tempaddr' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/kli/accept_ra' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/kli/proxy_ndp' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/kli/promote_secondaries' to '1'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Requested to set MAC address
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Requested to set IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: link_check_ready(): link layer is configuring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Requested configuring of the DHCPv4 client.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Setting MAC address
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Setting IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Found driver: 802.1Q VLAN Support
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: found matching network '/var/lib/systemd/network/ksi.network'.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Configuring with /var/lib/systemd/network/ksi.network.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=57 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: State changed: initialized -> configuring
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=58 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/ksi/use_tempaddr' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/ksi/accept_ra' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/ksi/proxy_ndp' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/ksi/promote_secondaries' to '1'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Requested to set MAC address
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Requested to set IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: link_check_ready(): link layer is configuring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Requesting DHCP server.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Requesting static address (n/a): 172.16.0.1/29 (valid forever, preferred forever), flags: tentative, scope: global
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Setting addresses
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Setting MAC address
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Setting IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Received new foreign QDisc (configured): handle=80:0, parent=1:8, kind=pfifo
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Found driver: 802.1Q VLAN Support
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Saved permanent hardware address: 00:00:00:00:00:00
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Link state is up-to-date
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: found matching network '/var/lib/systemd/network/krc_net.network'.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Configuring with /var/lib/systemd/network/krc_net.network.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=59 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: State changed: initialized -> configuring
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=60 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: link_check_ready(): link is not activated.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/krc_net/use_tempaddr' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/krc_net/accept_ra' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv6/conf/krc_net/proxy_ndp' to '0'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Setting '/proc/sys/net/ipv4/conf/krc_net/promote_secondaries' to '1'
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Requested to set IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: link_check_ready(): link layer is configuring.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Requested to activate link
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Requesting DHCP server.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Requesting static address (n/a): 172.16.0.129/25 (valid forever, preferred forever), flags: tentative, scope: global
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Setting addresses
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Setting IPv6LL address generation mode
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: Flags change: -UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_310 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=61 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: Link DOWN
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf8: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_310 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=62 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: Flags change: -UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_39 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=63 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: Link DOWN
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf9: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_39 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=64 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_38 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=65 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Flags change: -UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_37 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=66 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: Link DOWN
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf2: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_37 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=67 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: cn9300: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_36 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=68 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xg19: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_35 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=69 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf1: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_34 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=70 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: koi_ecat: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=71 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: diob: State changed: configuring -> configured
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_316 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=72 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=1:0, parent=ffff:ffff, kind=mqprio
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: Hardware address is changed: 8e:dc:ce:8f:98:04 → 00:60:c8:05:fc:e4
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: link_check_ready(): DHCPv4, DHCPv6, DHCP-PD or IPv4LL is enabled but no dynamic address is assigned yet.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Hardware address is changed: 02:60:c8:00:00:01 → 00:60:c8:05:fc:e0
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: Failed to manage link by its new hardware address, ignoring: File exists
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: MAC address set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: link_check_ready(): static addresses are not configured.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: IPv6LL address generation mode set.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Bringing link up
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=ffff:0, parent=ffff:fff1, kind=clsact
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=10:0, parent=1:1, kind=tbf
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: kli: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: ksi: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Flags change: +UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=73 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: Link UP
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: krc_net: link_check_ready(): static addresses are not configured.
Jul 23 09:58:49 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=20:0, parent=1:2, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=30:0, parent=1:3, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=40:0, parent=1:4, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=50:0, parent=1:5, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=60:0, parent=1:6, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.16 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.16 path=n/a interface=n/a member=n/a cookie=74 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.16 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.16 path=n/a interface=n/a member=n/a cookie=75 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=70:0, parent=1:7, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign QDisc (configured): handle=80:0, parent=1:8, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=1:0, parent=ffff:ffff, kind=mqprio
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=ffff:0, parent=ffff:fff1, kind=clsact
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=10:0, parent=1:1, kind=tbf
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=20:0, parent=1:2, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=30:0, parent=1:3, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=40:0, parent=1:4, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=50:0, parent=1:5, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=60:0, parent=1:6, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=70:0, parent=1:7, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf8: Received new foreign QDisc (configured): handle=80:0, parent=1:8, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=1:0, parent=ffff:ffff, kind=mqprio
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=ffff:0, parent=ffff:fff1, kind=clsact
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=10:0, parent=1:1, kind=tbf
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=20:0, parent=1:2, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=30:0, parent=1:3, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=40:0, parent=1:4, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=50:0, parent=1:5, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=60:0, parent=1:6, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=70:0, parent=1:7, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xf9: Received new foreign QDisc (configured): handle=80:0, parent=1:8, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=1:0, parent=ffff:ffff, kind=mqprio
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=ffff:0, parent=ffff:fff1, kind=clsact
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=10:0, parent=1:1, kind=tbf
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=20:0, parent=1:2, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=30:0, parent=1:3, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=40:0, parent=1:4, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=50:0, parent=1:5, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=60:0, parent=1:6, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=70:0, parent=1:7, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.17 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.17 path=n/a interface=n/a member=n/a cookie=76 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.17 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.17 path=n/a interface=n/a member=n/a cookie=77 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign QDisc (configured): handle=80:0, parent=1:8, kind=pfifo
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.18 destination=:1.6 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Introspectable member=Introspect cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.18 path=n/a interface=n/a member=n/a cookie=78 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.18 destination=:1.6 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=GetLinkByName cookie=4 reply_cookie=0 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.18 path=n/a interface=n/a member=n/a cookie=79 reply_cookie=4 signature=io error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.18 destination=:1.6 path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Introspectable member=Introspect cookie=7 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.18 path=n/a interface=n/a member=n/a cookie=80 reply_cookie=7 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.18 destination=:1.6 path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=Get cookie=8 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:50 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.18 path=n/a interface=n/a member=n/a cookie=81 reply_cookie=8 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.19 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.19 path=n/a interface=n/a member=n/a cookie=82 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.21 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.21 path=n/a interface=n/a member=n/a cookie=83 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.21 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_31 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.21 path=n/a interface=n/a member=n/a cookie=84 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.21 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_31 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.21 path=n/a interface=n/a member=n/a cookie=85 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.22 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.22 path=n/a interface=n/a member=n/a cookie=86 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.22 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_32 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.22 path=n/a interface=n/a member=n/a cookie=87 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.22 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_32 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.22 path=n/a interface=n/a member=n/a cookie=88 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.23 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.23 path=n/a interface=n/a member=n/a cookie=89 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.23 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_33 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.23 path=n/a interface=n/a member=n/a cookie=90 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.23 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_33 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.23 path=n/a interface=n/a member=n/a cookie=91 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.24 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.24 path=n/a interface=n/a member=n/a cookie=92 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.24 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_37 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.24 path=n/a interface=n/a member=n/a cookie=93 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.24 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_37 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.24 path=n/a interface=n/a member=n/a cookie=94 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.25 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.25 path=n/a interface=n/a member=n/a cookie=95 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.25 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_39 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.25 path=n/a interface=n/a member=n/a cookie=96 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.25 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_39 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.25 path=n/a interface=n/a member=n/a cookie=97 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.26 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.26 path=n/a interface=n/a member=n/a cookie=98 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.26 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_310 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.26 path=n/a interface=n/a member=n/a cookie=99 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.26 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_310 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.26 path=n/a interface=n/a member=n/a cookie=100 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.27 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.27 path=n/a interface=n/a member=n/a cookie=101 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.27 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_311 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.27 path=n/a interface=n/a member=n/a cookie=102 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.27 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_311 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.27 path=n/a interface=n/a member=n/a cookie=103 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.28 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.28 path=n/a interface=n/a member=n/a cookie=104 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.29 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.29 path=n/a interface=n/a member=n/a cookie=105 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.29 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.29 path=n/a interface=n/a member=n/a cookie=106 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.28 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_312 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.28 path=n/a interface=n/a member=n/a cookie=107 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.28 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_312 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.28 path=n/a interface=n/a member=n/a cookie=108 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.30 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.30 path=n/a interface=n/a member=n/a cookie=109 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.30 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_313 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.30 path=n/a interface=n/a member=n/a cookie=110 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.30 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_313 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.30 path=n/a interface=n/a member=n/a cookie=111 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.31 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.31 path=n/a interface=n/a member=n/a cookie=112 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.31 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.31 path=n/a interface=n/a member=n/a cookie=113 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.31 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.31 path=n/a interface=n/a member=n/a cookie=114 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.32 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.32 path=n/a interface=n/a member=n/a cookie=115 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.32 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_316 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.32 path=n/a interface=n/a member=n/a cookie=116 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.32 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_316 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.32 path=n/a interface=n/a member=n/a cookie=117 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.33 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.33 path=n/a interface=n/a member=n/a cookie=118 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.33 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.33 path=n/a interface=n/a member=n/a cookie=119 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.33 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.33 path=n/a interface=n/a member=n/a cookie=120 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.34 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.34 path=n/a interface=n/a member=n/a cookie=121 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.34 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.34 path=n/a interface=n/a member=n/a cookie=122 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.34 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.34 path=n/a interface=n/a member=n/a cookie=123 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.35 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.35 path=n/a interface=n/a member=n/a cookie=124 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.35 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:51 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.35 path=n/a interface=n/a member=n/a cookie=125 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.36 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.36 path=n/a interface=n/a member=n/a cookie=126 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.36 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.36 path=n/a interface=n/a member=n/a cookie=127 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: xf1: Received new foreign route (configured): dst: ff00::/8, src: n/a, gw: n/a, prefsrc: n/a, scope: global, table: main(254), proto: kernel, type: multicast, nexthop: 0, priority: 256, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: xf1: Flags change: +LOWER_UP +RUNNING
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_34 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=128 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: xf1: Gained carrier
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: xf1: found matching network '/var/lib/systemd/network/xf1.network'.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Requested to bring link up
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: xf1: LLDP Rx: Started LLDP client
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=129 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Bringing link up
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: switch: Received new foreign route (configured): dst: ff00::/8, src: n/a, gw: n/a, prefsrc: n/a, scope: global, table: main(254), proto: kernel, type: multicast, nexthop: 0, priority: 256, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: switch: Flags change: +LOWER_UP +RUNNING
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_314 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=130 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: switch: Gained carrier
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: switch: found matching network '/var/lib/systemd/network/switch.network'.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Received new foreign route (configured): dst: ff00::/8, src: n/a, gw: n/a, prefsrc: n/a, scope: global, table: main(254), proto: kernel, type: multicast, nexthop: 0, priority: 256, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Flags change: +LOWER_UP +RUNNING
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=131 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Gained carrier
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: found matching network '/var/lib/systemd/network/krc_net.network'.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: LLDP Rx: Started LLDP client
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Requesting static address (requesting): 172.16.0.129/25 (valid forever, preferred forever), flags: tentative, scope: global
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Setting addresses
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: link_check_ready(): static addresses are not configured.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Configuring static address (requesting): 172.16.0.129/25 (valid forever, preferred forever), flags: tentative, scope: global
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Flags change: +UP +LOWER_UP
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=132 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Link UP
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.37 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.37 path=n/a interface=n/a member=n/a cookie=133 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Received updated static address (configured): 172.16.0.129/25 (valid forever, preferred forever), flags: permanent, scope: global
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=134 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=135 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Received new foreign route (configured): dst: 172.16.0.129/32, src: n/a, gw: n/a, prefsrc: 172.16.0.129, scope: host, table: local(255), proto: kernel, type: local, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Received new foreign route (configured): dst: 172.16.0.255/32, src: n/a, gw: n/a, prefsrc: 172.16.0.129, scope: link, table: local(255), proto: kernel, type: broadcast, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Received new foreign route (configured): dst: 172.16.0.128/25, src: n/a, gw: n/a, prefsrc: 172.16.0.129, scope: link, table: main(254), proto: kernel, type: unicast, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Addresses set
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: State changed: configuring -> configured
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=136 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Configuring DHCP Server.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=137 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Not emitting SIP servers on link, couldn't find suitable uplink.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: DHCPv4 server: STARTED
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: krc_net: Offering DHCPv4 leases
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Received new foreign route (configured): dst: ff00::/8, src: n/a, gw: n/a, prefsrc: n/a, scope: global, table: main(254), proto: kernel, type: multicast, nexthop: 0, priority: 256, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Flags change: +RUNNING
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=138 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Gained carrier
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: found matching network '/var/lib/systemd/network/ksi.network'.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: LLDP Rx: Started LLDP client
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Requesting static address (requesting): 172.16.0.1/29 (valid forever, preferred forever), flags: tentative, scope: global
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Setting addresses
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: link_check_ready(): static addresses are not configured.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.37 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.37 path=n/a interface=n/a member=n/a cookie=139 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Configuring static address (requesting): 172.16.0.1/29 (valid forever, preferred forever), flags: tentative, scope: global
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Received updated static address (configured): 172.16.0.1/29 (valid forever, preferred forever), flags: permanent, scope: global
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=140 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Received new foreign route (configured): dst: 172.16.0.1/32, src: n/a, gw: n/a, prefsrc: 172.16.0.1, scope: host, table: local(255), proto: kernel, type: local, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Received new foreign route (configured): dst: 172.16.0.7/32, src: n/a, gw: n/a, prefsrc: 172.16.0.1, scope: link, table: local(255), proto: kernel, type: broadcast, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Received new foreign route (configured): dst: 172.16.0.0/29, src: n/a, gw: n/a, prefsrc: 172.16.0.1, scope: link, table: main(254), proto: kernel, type: unicast, nexthop: 0, priority: 0, flags: n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Addresses set
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: State changed: configuring -> configured
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=141 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Configuring DHCP Server.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=142 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Not emitting SIP servers on link, couldn't find suitable uplink.
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: DHCPv4 server: STARTED
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: ksi: Offering DHCPv4 leases
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.37 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.37 path=n/a interface=n/a member=n/a cookie=143 reply_cookie=4 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.38 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.38 path=n/a interface=n/a member=n/a cookie=144 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.38 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.38 path=n/a interface=n/a member=n/a cookie=145 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.38 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.38 path=n/a interface=n/a member=n/a cookie=146 reply_cookie=4 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.39 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.39 path=n/a interface=n/a member=n/a cookie=147 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.39 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.39 path=n/a interface=n/a member=n/a cookie=148 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.39 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_319 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.39 path=n/a interface=n/a member=n/a cookie=149 reply_cookie=4 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.40 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.40 path=n/a interface=n/a member=n/a cookie=150 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.40 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.40 path=n/a interface=n/a member=n/a cookie=151 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.40 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.40 path=n/a interface=n/a member=n/a cookie=152 reply_cookie=4 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.41 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.41 path=n/a interface=n/a member=n/a cookie=153 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.41 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.41 path=n/a interface=n/a member=n/a cookie=154 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.41 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.41 path=n/a interface=n/a member=n/a cookie=155 reply_cookie=4 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.42 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.42 path=n/a interface=n/a member=n/a cookie=156 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.42 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.42 path=n/a interface=n/a member=n/a cookie=157 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.42 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_318 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.42 path=n/a interface=n/a member=n/a cookie=158 reply_cookie=4 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.43 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.43 path=n/a interface=n/a member=n/a cookie=159 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.43 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:52 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.43 path=n/a interface=n/a member=n/a cookie=160 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: xf4: Received new foreign route (configured): dst: ff00::/8, src: n/a, gw: n/a, prefsrc: n/a, scope: global, table: main(254), proto: kernel, type: multicast, nexthop: 0, priority: 256, flags: n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: xf4: Flags change: +LOWER_UP +RUNNING
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_38 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=161 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: xf4: Gained carrier
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: xf4: found matching network '/var/lib/systemd/network/xf4.network'.
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: Requested to bring link up
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: xf4: LLDP Rx: Started LLDP client
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: Bringing link up
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: Flags change: +UP +LOWER_UP
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=162 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: Link UP
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: Received new foreign route (configured): dst: ff00::/8, src: n/a, gw: n/a, prefsrc: n/a, scope: global, table: main(254), proto: kernel, type: multicast, nexthop: 0, priority: 256, flags: n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: Flags change: +RUNNING
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=163 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: Gained carrier
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: found matching network '/var/lib/systemd/network/kli.network'.
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: LLDP Rx: Started LLDP client
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: link_check_ready(): DHCPv4, DHCPv6, DHCP-PD or IPv4LL is enabled but no dynamic address is assigned yet.
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.44 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.44 path=n/a interface=n/a member=n/a cookie=164 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: DHCPv4 client: STARTED on ifindex 17
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: DHCPv4 client is configured, acquiring DHCPv4 lease.
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: kli: DHCPv4 client: DISCOVER
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.44 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.44 path=n/a interface=n/a member=n/a cookie=165 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.44 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_317 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.44 path=n/a interface=n/a member=n/a cookie=166 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.45 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.45 path=n/a interface=n/a member=n/a cookie=167 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.45 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.45 path=n/a interface=n/a member=n/a cookie=168 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.46 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.46 path=n/a interface=n/a member=n/a cookie=169 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.46 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.network1.Manager member=Describe cookie=3 reply_cookie=0 signature=n/a error-name=n/a error-message=n/a
Jul 23 09:58:53 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.46 path=n/a interface=n/a member=n/a cookie=170 reply_cookie=3 signature=s error-name=n/a error-message=n/a
Jul 23 09:58:56 priceless-goldwasser systemd-networkd[1077]: kli: DHCPv4 client: DISCOVER
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: xg19: Received new foreign route (configured): dst: ff00::/8, src: n/a, gw: n/a, prefsrc: n/a, scope: global, table: main(254), proto: kernel, type: multicast, nexthop: 0, priority: 256, flags: n/a
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: xg19: Flags change: +LOWER_UP +RUNNING
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_35 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=171 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: xg19: Gained carrier
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: xg19: found matching network '/var/lib/systemd/network/xg19.network'.
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Requested to bring link up
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: xg19: LLDP Rx: Started LLDP client
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Bringing link up
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: koi_ecat: IPv6 link-local address generation mode is changed: eui64 -> none
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Flags change: +UP +LOWER_UP +RUNNING
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: Sent message type=signal sender=n/a destination=n/a path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=172 reply_cookie=0 signature=sa{sv}as error-name=n/a error-message=n/a
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Link UP
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Gained carrier
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: koi_ecat: found matching network '/var/lib/systemd/network/koi_ecat.network'.
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: koi_ecat: LLDP Rx: Started LLDP client
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: koi_ecat: Received new foreign route (configured): dst: ff00::/8, src: n/a, gw: n/a, prefsrc: n/a, scope: global, table: main(254), proto: kernel, type: multicast, nexthop: 0, priority: 256, flags: n/a
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.50 destination=org.freedesktop.network1 path=/org/freedesktop/network1 interface=org.freedesktop.DBus.Properties member=Get cookie=2 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.50 path=n/a interface=n/a member=n/a cookie=173 reply_cookie=2 signature=v error-name=n/a error-message=n/a
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.50 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=Get cookie=3 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: Sent message type=method_return sender=n/a destination=:1.50 path=n/a interface=n/a member=n/a cookie=174 reply_cookie=3 signature=v error-name=n/a error-message=n/a
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: Got message type=method_call sender=:1.50 destination=org.freedesktop.network1 path=/org/freedesktop/network1/link/_315 interface=org.freedesktop.DBus.Properties member=Get cookie=4 reply_cookie=0 signature=ss error-name=n/a error-message=n/a
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: Sent message type=error sender=n/a destination=:1.50 path=n/a interface=n/a member=n/a cookie=175 reply_cookie=4 signature=s error-name=org.freedesktop.DBus.Error.UnknownProperty error-message=Unknown interface org.freedesktop.network1.DHCPServer or property Leases.
Jul 23 09:59:00 priceless-goldwasser systemd-networkd[1077]: kli: DHCPv4 client: DISCOVER
Jul 23 09:59:08 priceless-goldwasser systemd-networkd[1077]: kli: DHCPv4 client: DISCOVER
Jul 23 09:59:25 priceless-goldwasser systemd-networkd[1077]: kli: DHCPv4 client: DISCOVE
It seems the systemd patch is doing what it should do - bringing up the interfaces before joining the bridge. But the switch is, as before, not really functional.
Deleting the bridge after startup of the system and restart systemd-network seems to fix the issue.
Can you help us to fix this issue finally, please?
Related older issues:
 DRA829J: Configuring CPSW9G with systemd-networkd/ debug CPSW9G
 TDA4VH-Q1: Tooling for CPSW debug
Daniel
  • Hello Daniel,
    Can you please share the list of bridge configuration commands that are being executed?
    Siddharth.
  • Hi Siddarth
    This is the systemd configuration we are using:
    network.zip
    Daniel
  • Hello Daniel,
    I am not familiar with the .network files. Can you please share the equivalent user-space commands that are being executed?
    I am referring to commands of the form:
    texasinstruments.github.io/.../CPSWng-Native-Ethernet.html
    Siddharth.
  • As far as we interpret it, this configuration is executing the same commands as in your documentation.
    I can enable some kernel debug logs and post the result if this helps somehow.
  • Hello Daniel,
    Yes, please share the kernel debug logs. Please refer to the following documentation update:
    https://github.com/TexasInstruments/processor-sdk-doc/commit/8d5998a0ef0257882790cc904d7491871235aa11
    There is an extra command that is required for bridge configuration. I am suspecting that it is affecting the configuration in your setup.
    Specifically, the following command is *newly* required due to a change in Mainline Linux as indicated above:
    bridge vlan add dev br0 vid 1 self
    I am not sure what it translates to in the systemd-networkd files.
    Siddharth.
  • There is an extra command that is required for bridge configuration. I am suspecting that it is affecting the configuration in your setup.
    I think we already have this one.
    This is what the bridge looks like:
    # bridge vlan show
    port              vlan-id
    xf1               43 PVID Egress Untagged
    xg19              1 PVID Egress Untagged
                      6 Egress Untagged
    cn9300            7 PVID Egress Untagged
    xf2               3 PVID Egress Untagged
    xf4               2 PVID Egress Untagged
    xf9               1 PVID Egress Untagged
    xf8               1 PVID Egress Untagged
    switch            1
                      2
                      6
                      7
                      43
    It works, after enabling all kernel debug logs Smiley
    I would assume this is a timing issue.
    Do you have any clue what could be the root cause here?
  • Hello Daniel,
    The systemd-analyze tool can be used to view the sequence for the non-working and working (kernel debug logs enabled) cases to identify the cause for the issue. It does seem to be a timing issue as you have mentioned.
    Siddharth.
  • To be honest - we had the same issue before and were discussing it many times.
    We cannot see ANY difference in userspace between cases it works and cases it don't works. The switch mode seems to be a very fragile construct in kernel / hardware.
    We need a way to see what's wrong in the kernel or in the hardware.
    Firstly, running commands from the user-space to configure the Switch (CPSW) is known to work in all cases - No driver / kernel changes that affect functionality.
    Secondly, the issue is seen with the systemd-networkd model - You have already identified it as a timing issue - User-space commands are strictly ordered and execute in a known sequence. Their systemd-networkd counterpart could vary and I am not an expert on it. I have recommended using the systemd-analyze utility to identify possible changes in the sequence of scripts. We can be certain that the issue is purely due to the order of commands being run - and potential errors being ignored - for example, interface doesn't yet exist when the command has been run via systemd-networkd.
    My suggestion is the following:
    switch-config utility can be used to check the ALE Entries in the working and non-working cases - identifying missing entries will help narrow down the portions of the systemd-networkd script that is affecting the outcome due to incorrect timing.
    Siddharth.
  • Hi Siddharth
    We fixed the issue by manually configuring the physical interfaces before hand over to systemd.
    This works for now. Lets see what happens in the future.
    Thanks for your help!
    Daniel
