SK-AM62P-LP: EMMC BOOT fail ,stop at Waiting for root device PARTUUID
Part Number: SK-AM62P-LP
Other Parts Discussed in Thread: AM62P
Hi  Ti
Now I use emmc boot AM62P SKEVM board , I have use dfu   flash boot  and rootfs files  in EMMC successfully
But boot is failed ,  stop at  Waiting for root device PARTUUID=76d18add-2a18-b64b-9c38-80a2b9b9f614...
There is the boot log
you can check
U-Boot SPL 2025.01-00535-g827c35b4d141 (Jul 03 2025 - 17:34:00 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
SPL initial stack usage: 17088 bytes
Trying to boot from MMC1
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.13.0(release):v2.13.0-259-ge0c4d3903b-dirty
NOTICE:  BL31: Built : 07:01:36, Jul  1 2025
DM ABI: 3.0 (firmware ver 0x000b 'MSDK.11.01.00.05-dirty--v11.01.02' patch_ver: 2)
SPL initial stack usage: 1984 bytes
MMC: no card present
** Bad device specification mmc 1 **
Couldn't find partition mmc 1:1
Error: could not access storage.
U-Boot 2025.01-00535-g827c35b4d141 (Jul 03 2025 - 17:34:00 +0000)
SoC:   AM62PX SR1.0 HS-FS
Model: Texas Instruments AM62P5 SK
DRAM:  2 GiB (total 8 GiB)
Core:  97 devices, 32 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@8000000port@1
Warning: ethernet@8000000port@2 (eth1) using random MAC address - 5a:c2:f0:7f:ff:9f
, eth1: ethernet@8000000port@2
Hit any key to stop autoboot:  0
=> mmc list
mmc@fa10000: 0
mmc@fa00000: 1
=> mmc dev 0
switch to partitions #0, OK
mmc0(part 0) is current device
=> mmc list
mmc@fa10000: 0 (eMMC)
mmc@fa00000: 1
=> mmc part
Partition Map for mmc device 0  --   Partition Type: EFI
Part    Start LBA       End LBA         Name
        Attributes
        Type GUID
        Partition GUID
  1     0x00000022      0x03b47fde      "rootfs"
        attrs:  0x0000000000000000
        type:   ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
        guid:   76d18add-2a18-b64b-9c38-80a2b9b9f614
=> ls mmc 0:1
            lost+found/
    <SYM>   bin
            boot/
            dev/
            etc/
            home/
    <SYM>   lib
            media/
            mnt/
            proc/
            root/
            run/
    <SYM>   sbin
            srv/
            sys/
            tmp/
            usr/
            var/
3 file(s), 17 dir(s)
=> setenv mmcdev 0
=> setenv bootpart 0
=> boot
SD/MMC found on device 0
Can't set block device
15743488 bytes read in 118 ms (127.2 MiB/s)
65105 bytes read in 2 ms (31 MiB/s)
Working FDT set to 88000000
   Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
Working FDT set to 8feed000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.12.35-ti-00920-g78e6abff3220-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Thu Jul  3 17:10:29 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments AM62P5 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: legacy bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
[    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b4fffff]
[    0.000000]   node   0: [mem 0x000000009b500000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 22 pages/cpu s50520 r8192 d31400 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=76d18add-2a18-b64b-9c38-80a2b9b9f614 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880050000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008657] Console: colour dummy device 80x25
[    0.013249] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023918] pid_max: default: 32768 minimum: 301
[    0.028713] LSM: initializing lsm=capability
[    0.033202] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.040956] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.051212] rcu: Hierarchical SRCU implementation.
[    0.056142] rcu:     Max phase no-delay instances is 1000.
[    0.061664] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.070376] EFI services will not be available.
[    0.075232] smp: Bringing up secondary CPUs ...
[    0.080429] Detected VIPT I-cache on CPU1
[    0.080508] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.080526] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
[    0.080571] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.081273] Detected VIPT I-cache on CPU2
[    0.081333] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.081348] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
[    0.081381] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.082010] Detected VIPT I-cache on CPU3
[    0.082066] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.082080] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
[    0.082108] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.082224] smp: Brought up 1 node, 4 CPUs
[    0.161849] SMP: Total of 4 processors activated.
[    0.166654] CPU: All CPU(s) started at EL2
[    0.170854] CPU features: detected: 32-bit EL0 Support
[    0.176106] CPU features: detected: CRC32 instructions
[    0.181400] alternatives: applying system-wide alternatives
[    0.187468] Memory: 7487076K/8388608K available (9472K kernel code, 974K rwdata, 3084K rodata, 1728K init, 571K bss, 302780K reserved, 589824K cma-reserved)
[    0.202801] devtmpfs: initialized
[    0.213553] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.223550] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.245075] 28752 pages in range for non-PLT usage
[    0.245099] 520272 pages in range for PLT usage
[    0.250271] pinctrl core: initialized pinctrl subsystem
[    0.260601] DMI not present or invalid.
[    0.266545] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.273744] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.281171] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.289281] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.297471] audit: initializing netlink subsys (disabled)
[    0.303205] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.311143] cpuidle: using governor menu
[    0.315240] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.322255] ASID allocator initialised with 65536 entries
[    0.333486] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
[    0.344979] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    0.357620] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.367534] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[    0.380259] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.394720] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    0.407472] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.418016] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[    0.432463] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.442400] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.453745] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[    0.462973] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.472819] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.479779] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.486188] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.493119] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.499521] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.506454] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.512856] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.519788] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.527610] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
[    0.536708] iommu: Default domain type: Translated
[    0.541621] iommu: DMA domain TLB invalidation policy: strict mode
[    0.548492] EDAC MC: Ver: 3.0.0
[    0.551934] scmi_core: SCMI protocol bus registered
[    0.558102] clocksource: Switched to clocksource arch_sys_counter
[    0.571128] NET: Registered PF_INET protocol family
[    0.576402] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.589416] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.598251] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.606180] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.614678] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.623900] TCP: Hash tables configured (established 65536 bind 65536)
[    0.630742] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.637856] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.645528] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.651764] RPC: Registered named UNIX socket transport module.
[    0.657832] RPC: Registered udp transport module.
[    0.662638] RPC: Registered tcp transport module.
[    0.667442] RPC: Registered tcp-with-tls transport module.
[    0.673045] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.680821] Initialise system trusted keyrings
[    0.685558] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.693100] NFS: Registering the id_resolver key type
[    0.698304] Key type id_resolver registered
[    0.702576] Key type id_legacy registered
[    0.706688] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.713536] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.776010] Key type asymmetric registered
[    0.780198] Asymmetric key parser 'x509' registered
[    0.785235] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.792802] io scheduler mq-deadline registered
[    0.797435] io scheduler kyber registered
[    0.801561] io scheduler bfq registered
[    0.807663] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.814142] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.824848] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.840414] loop: module loaded
[    0.845362] i2c_dev: i2c /dev entries driver
[    0.850646] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.858612] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[    0.868783] optee: probing for conduit method.
[    0.873357] optee: revision 4.6 (71785645fa6ce42d)
[    0.873646] optee: dynamic shared memory is enabled
[    0.884194] optee: initialized driver
[    0.884306] random: crng init done
[    0.888452] NET: Registered PF_PACKET protocol family
[    0.896638] Key type dns_resolver registered
[    0.906055] Loading compiled-in X.509 certificates
[    0.919289] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
[    0.961041] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    0.973808] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    0.980988] pca953x 1-0023: supply vcc not found, using dummy regulator
[    0.987848] pca953x 1-0023: using AI
[    1.008298] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    1.018285] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    1.028302] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.035075] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    1.041004] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.050258] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.059251] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
[    1.068598] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.077125] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.087980] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.098790] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.108105] ti-udma 4e230000.dma-controller: Number of rings: 6
[    1.114747] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
[    1.124054] printk: legacy console [ttyS2] disabled
[    1.129408] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 250, base_baud = 3000000) is a 8250
[    1.138292] printk: legacy console [ttyS2] enabled
[    1.147977] printk: legacy bootconsole [ns16550a0] disabled
[    1.170965] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.177683] pca953x 1-0022: using AI
[    1.184403] sii902x 1-003b: supply iovcc not found, using dummy regulator
[    1.191460] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[    1.200805] i2c i2c-1: Added multiplexed i2c bus 3
[    1.207882] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
[    1.214870] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    1.221901] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    1.222193] clk: Disabling unused clocks
[    1.237125] PM: genpd: Disabling unused power domains
[    1.242707] Waiting for root device PARTUUID=76d18add-2a18-b64b-9c38-80a2b9b9f614...
[   31.950150] vdd_mmc1: disabling
    I believe you have modified the Linux Kernel and the DTS files. Could you please share those modifications?
  • Hi
    There are my modify in linux kernel  patch  0001-test-dts.patch
    From 639b00abb37e0e78f6abdafce90fea4a0189db1e Mon Sep 17 00:00:00 2001
    Date: Thu, 24 Jul 2025 14:02:59 +0800
    Subject: [PATCH] test-dts
     arch/arm64/boot/dts/ti/k3-am62p5-sk.dts | 4 ++--
     kernel/configs/ti_early_display.config  | 5 ++++-
     2 files changed, 6 insertions(+), 3 deletions(-)
    diff --git a/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts b/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts
    index ddcbdee853e6..85635c91d6ec 100644
    --- a/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts
    +++ b/arch/arm64/boot/dts/ti/k3-am62p5-sk.dts
    @@ -36,7 +36,7 @@ chosen {
     		#address-cells = <2>;
     		#size-cells = <2>;
     		ranges;
    +        bootargs = "console=ttyS2,115200n8 root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait";
     		stdout-path = &main_uart0;
     		framebuffer0: framebuffer@0 {
    @@ -605,7 +605,7 @@ &main_i2c2 {
     &sdhci0 {
    -	status = "okay";
    +	status = "disabled";
     	ti,driver-strength-ohm = <50>;
     	disable-wp;
     	bootph-all;
    diff --git a/kernel/configs/ti_early_display.config b/kernel/configs/ti_early_display.config
    index 06aee44546f2..d45e8093a4ce 100644
    --- a/kernel/configs/ti_early_display.config
    +++ b/kernel/configs/ti_early_display.config
    @@ -42,7 +42,7 @@ CONFIG_PTP_1588_CLOCK=m
     # Remove MMC support
     # This reduces kernel image size by 137.2KB and reduces boot time by 32ms
    -CONFIG_MMC=m
    +# CONFIG_MMC is not set
     ### Additional reduction ###
    @@ -216,6 +216,9 @@ CONFIG_FB_SIMPLE=y
     CONFIG_BACKLIGHT_CLASS_DEVICE=y
     CONFIG_DRM_PANEL_LVDS=y
     CONFIG_DRM_PANEL_SIMPLE=y
    +CONFIG_DRM_SII902X=y
    +CONFIG_DRM_SIMPLE_BRIDGE=y
    +CONFIG_DRM_DISPLAY_CONNECTOR=y
     CONFIG_FRAMEBUFFER_CONSOLE=n
     CONFIG_LOGO=n
    2.34.1
    I add
    SRC_URI +="file://k3/defconfig"
    SRC_URI +="file://0001-test-dts.patch"
    at  linux-ti-staging_6.12.bb
    The eMMC is disable in both the Linux Kernel and the DTS. Please enable the eMMC with CONFIG_MMC=y in the Kernel and status = "okay" in the DTS.
  • Hi
    NOW I  enable the eMMC with CONFIG_MMC=y in the Kernel and status = "okay"  in the DTS
    resolved my issue
    Thank you very much
