Hello TI,
SetUp based on this link :
PROCESSOR-SDK-AM64X: Duplicate Packets are not removed with HSR PRU Firmware
We have observed that on 100Mbps link speed, when down/up eth1 and eth2, the HSR firmware doesn't remove duplicated packet anymore.
- Ensure eth interfaces are up if they are not brought up yet
- Set up hsr offload + cut-through
- Set 100M on eth1 & eth2 with ethtool
- Ping EVM1 (sender) to EVM3 (destination) and check no packet loss
- Bring down and back up eth1 and eth2 on EVM1 with ip link set dev <interface name> down/up
- Ping EVM1 (sender) to EVM3 (destination) again
- Check cat /proc/interrupts on EVM3 (destination) and check if IRQ count seems to only increase on one port at a time during the ping
After doing this, I now indeed can ping from EVM1 to EVM3 but when I check EVM3, I still see that IRQ counter is increasing on both port eth1 and eth2.
Here are the logs :
EVM1 :
am64xx-evm login: root root@am64xx-evm:~# ip link set dev eth1 up link set dev eth2 uproot@am64xx-evm:~# ip link set dev eth2 up root@am64xx-evm:~# /usr/bin/hsr_offload_script.sh hsr_hw eth1 eth2 192.168.1.1 hsr_hw eth1 eth2 192.168.1.1 ip=192.168.1.1 if=hsr0 mac=70:ff:76:1f:40:90 slave-a=eth1 slave-b=eth2 device=platform/icssg1-eth hsr-tag-ins-offload: off hsr-tag-rm-offload: off hsr-fwd-offload: off hsr-dup-offload: off Actual changes: hsr-tag-ins-offload: on [not requested] hsr-dup-offload: on hsr-tag-ins-offload: on hsr-tag-rm-offload: on hsr-fwd-offload: on hsr-dup-offload: on hsr-tag-ins-offload: off hsr-tag-rm-offload: off hsr-fwd-offload: off hsr-dup-offload: off Actual changes: hsr-tag-ins-offload: on [not requested] hsr-dup-offload: on hsr-tag-ins-offload: on hsr-tag-rm-offload: on hsr-fwd-offload: on hsr-dup-offload: on root@am64xx-evm:~# ping 192.168.1.2 -c 10 -i 0.1 PING 192.168.1.2 (192.168.1.2): 56 data bytes 64 bytes from 192.168.1.2: seq=0 ttl=64 time=0.855 ms 64 bytes from 192.168.1.2: seq=1 ttl=64 time=0.388 ms 64 bytes from 192.168.1.2: seq=2 ttl=64 time=0.301 ms 64 bytes from 192.168.1.2: seq=3 ttl=64 time=0.358 ms 64 bytes from 192.168.1.2: seq=4 ttl=64 time=0.267 ms 64 bytes from 192.168.1.2: seq=5 ttl=64 time=0.395 ms 64 bytes from 192.168.1.2: seq=6 ttl=64 time=0.321 ms 64 bytes from 192.168.1.2: seq=7 ttl=64 time=0.525 ms 64 bytes from 192.168.1.2: seq=8 ttl=64 time=0.348 ms 64 bytes from 192.168.1.2: seq=9 ttl=64 time=0.360 ms --- 192.168.1.2 ping statistics --- 10 packets transmitted, 10 packets received, 0% packet loss round-trip min/avg/max = 0.267/0.411/0.855 ms root@am64xx-evm:~# ethtool -s eth1 speed 100 duplex full ool -s eth2 speedroot@am64xx-evm:~# ethtool -s eth2 speed 100 duplex full root@am64xx-evm:~# ping 192.168.1.2 -c 10 -i 0.1 PING 192.168.1.2 (192.168.1.2): 56 data bytes 64 bytes from 192.168.1.2: seq=0 ttl=64 time=0.720 ms 64 bytes from 192.168.1.2: seq=1 ttl=64 time=0.387 ms 64 bytes from 192.168.1.2: seq=2 ttl=64 time=0.417 ms 64 bytes from 192.168.1.2: seq=3 ttl=64 time=0.299 ms 64 bytes from 192.168.1.2: seq=4 ttl=64 time=0.291 ms 64 bytes from 192.168.1.2: seq=5 ttl=64 time=0.289 ms 64 bytes from 192.168.1.2: seq=6 ttl=64 time=0.389 ms 64 bytes from 192.168.1.2: seq=7 ttl=64 time=0.362 ms 64 bytes from 192.168.1.2: seq=8 ttl=64 time=0.274 ms 64 bytes from 192.168.1.2: seq=9 ttl=64 time=0.343 ms --- 192.168.1.2 ping statistics --- 10 packets transmitted, 10 packets received, 0% packet loss round-trip min/avg/max = 0.274/0.377/0.720 ms root@am64xx-evm:~# ping 192.168.1.2 -c 10 -i 0.1 PING 192.168.1.2 (192.168.1.2): 56 data bytes 64 bytes from 192.168.1.2: seq=0 ttl=64 time=0.753 ms 64 bytes from 192.168.1.2: seq=1 ttl=64 time=0.461 ms 64 bytes from 192.168.1.2: seq=2 ttl=64 time=0.364 ms 64 bytes from 192.168.1.2: seq=3 ttl=64 time=0.362 ms 64 bytes from 192.168.1.2: seq=4 ttl=64 time=0.274 ms 64 bytes from 192.168.1.2: seq=5 ttl=64 time=0.376 ms 64 bytes from 192.168.1.2: seq=6 ttl=64 time=0.341 ms 64 bytes from 192.168.1.2: seq=7 ttl=64 time=0.286 ms 64 bytes from 192.168.1.2: seq=8 ttl=64 time=0.424 ms 64 bytes from 192.168.1.2: seq=9 ttl=64 time=0.288 ms --- 192.168.1.2 ping statistics --- 10 packets transmitted, 10 packets received, 0% packet loss round-trip min/avg/max = 0.274/0.392/0.753 ms root@am64xx-evm:~# ping 192.168.1.2 -c 10 -i 0.1 PING 192.168.1.2 (192.168.1.2): 56 data bytes 64 bytes from 192.168.1.2: seq=0 ttl=64 time=0.526 ms 64 bytes from 192.168.1.2: seq=1 ttl=64 time=0.370 ms 64 bytes from 192.168.1.2: seq=2 ttl=64 time=0.352 ms 64 bytes from 192.168.1.2: seq=3 ttl=64 time=0.306 ms 64 bytes from 192.168.1.2: seq=4 ttl=64 time=0.314 ms 64 bytes from 192.168.1.2: seq=5 ttl=64 time=0.322 ms 64 bytes from 192.168.1.2: seq=6 ttl=64 time=0.260 ms 64 bytes from 192.168.1.2: seq=7 ttl=64 time=0.388 ms 64 bytes from 192.168.1.2: seq=8 ttl=64 time=0.343 ms 64 bytes from 192.168.1.2: seq=9 ttl=64 time=0.282 ms --- 192.168.1.2 ping statistics --- 10 packets transmitted, 10 packets received, 0% packet loss round-trip min/avg/max = 0.260/0.346/0.526 ms root@am64xx-evm:~#
EVM2 :
am64xx-evm login: root root@am64xx-evm:~# ip link set dev eth1 up link set dev eth2 uproot@am64xx-evm:~# ip link set dev eth2 up root@am64xx-evm:~# /usr/bin/hsr_offload_script.sh hsr_hw eth1 eth2 192.168.1.10 hsr_hw eth1 eth2 192.168.1.10 ip=192.168.1.10 if=hsr0 mac=70:ff:76:1e:2d:e9 slave-a=eth1 slave-b=eth2 device=platform/icssg1-eth hsr-tag-ins-offload: off hsr-tag-rm-offload: off hsr-fwd-offload: off hsr-dup-offload: off Actual changes: hsr-tag-ins-offload: on [not requested] hsr-dup-offload: on hsr-tag-ins-offload: on hsr-tag-rm-offload: on hsr-fwd-offload: on hsr-dup-offload: on hsr-tag-ins-offload: off hsr-tag-rm-offload: off hsr-fwd-offload: off hsr-dup-offload: off Actual changes: hsr-tag-ins-offload: on [not requested] hsr-dup-offload: on hsr-tag-ins-offload: on hsr-tag-rm-offload: on hsr-fwd-offload: on hsr-dup-offload: on
EVM3:
am64xx-evm login: root root@am64xx-evm:~# ip link set dev eth1 up link set dev eth2 uproot@am64xx-evm:~# ip link set dev eth2 up root@am64xx-evm:~# /usr/bin/hsr_offload_script.sh hsr_hw eth1 eth2 192.168.1.2 hsr_hw eth1 eth2 192.168.1.2 ip=192.168.1.2 if=hsr0 mac=70:ff:76:1e:e6:f4 slave-a=eth1 slave-b=eth2 device=platform/icssg1-eth hsr-tag-ins-offload: off hsr-tag-rm-offload: off hsr-fwd-offload: off hsr-dup-offload: off Actual changes: hsr-tag-ins-offload: on [not requested] hsr-dup-offload: on hsr-tag-ins-offload: on hsr-tag-rm-offload: on hsr-fwd-offload: on hsr-dup-offload: on hsr-tag-ins-offload: off hsr-tag-rm-offload: off hsr-fwd-offload: off hsr-dup-offload: off Actual changes: hsr-tag-ins-offload: on [not requested] hsr-dup-offload: on hsr-tag-ins-offload: on hsr-tag-rm-offload: on hsr-fwd-offload: on hsr-dup-offload: on root@am64xx-evm:~# ethtool -s eth1 speed 100 duplex full tool -s eth2 speed 10root@am64xx-evm:~# ethtool -s eth2 speed 100 duplex full root@am64xx-evm:~# cat /proc/interrupts | grep icssg 146: 66 0 MSI-INTA 1970792 Level icssg1-eth-tx0 150: 23 0 MSI-INTA 1970796 Level icssg1-eth-tx0 246: 13 0 MSI-INTA 1971824 Level icssg1-eth 262: 1 0 MSI-INTA 1971840 Level icssg1-eth 541: 0 0 pruss-intc 24 Level icssg1-eth 542: 0 0 pruss-intc 25 Level icssg1-eth root@am64xx-evm:~# cat /proc/interrupts | grep icssg 146: 81 0 MSI-INTA 1970792 Level icssg1-eth-tx0 150: 23 0 MSI-INTA 1970796 Level icssg1-eth-tx0 246: 24 0 MSI-INTA 1971824 Level icssg1-eth 262: 1 0 MSI-INTA 1971840 Level icssg1-eth 541: 0 0 pruss-intc 24 Level icssg1-eth 542: 0 0 pruss-intc 25 Level icssg1-eth root@am64xx-evm:~# echo "EVM3" EVM3 (failed reverse-i-search)`down': ethtool -s eth2 speed 100 ^Cplex full root@am64xx-evm:~# ip link set dev eth1 down root@am64xx-evm:~# ip link set dev eth2 down root@am64xx-evm:~# ip link set dev eth1 up root@am64xx-evm:~# ip link set dev eth2 up root@am64xx-evm:~# cat /proc/interrupts | grep icssg 146: 117 0 MSI-INTA 1970792 Level icssg1-eth-tx0 150: 26 0 MSI-INTA 1970796 Level icssg1-eth-tx0 246: 26 0 MSI-INTA 1971824 Level icssg1-eth 262: 2 0 MSI-INTA 1971840 Level icssg1-eth 541: 0 0 pruss-intc 24 Level icssg1-eth 542: 0 0 pruss-intc 25 Level icssg1-eth root@am64xx-evm:~# cat /proc/interrupts | grep icssg 146: 132 0 MSI-INTA 1970792 Level icssg1-eth-tx0 150: 32 0 MSI-INTA 1970796 Level icssg1-eth-tx0 246: 37 0 MSI-INTA 1971824 Level icssg1-eth 262: 13 0 MSI-INTA 1971840 Level icssg1-eth 541: 0 0 pruss-intc 24 Level icssg1-eth 542: 0 0 pruss-intc 25 Level icssg1-eth root@am64xx-evm:~# ethtool eth1 Settings for eth1: Supported ports: [ TP MII ] Supported link modes: 10baseT/Full 100baseT/Full 1000baseT/Full 1000baseX/Full Supported pause frame use: No Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 100baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 100baseT/Full Link partner advertised pause frame use: No Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 100Mb/s Duplex: Full Auto-negotiation: on master-slave cfg: preferred slave master-slave status: slave Port: Twisted Pair PHYAD: 15 Transceiver: external MDI-X: Unknown Current message level: 0x00000000 (0) Link detected: yes root@am64xx-evm:~# ethtool eth2 Settings for eth2: Supported ports: [ TP MII ] Supported link modes: 10baseT/Full 100baseT/Full 1000baseT/Full 1000baseX/Full Supported pause frame use: No Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 100baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Full 100baseT/Full 1000baseT/Full Link partner advertised pause frame use: No Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 100Mb/s Duplex: Full Auto-negotiation: on master-slave cfg: preferred slave master-slave status: slave Port: Twisted Pair PHYAD: 3 Transceiver: external MDI-X: Unknown Current message level: 0x00000000 (0) Link detected: yes root@am64xx-evm:~# cat /proc/interrupts | grep icssg 146: 145 0 MSI-INTA 1970792 Level icssg1-eth-tx0 150: 34 0 MSI-INTA 1970796 Level icssg1-eth-tx0 246: 38 0 MSI-INTA 1971824 Level icssg1-eth 262: 14 0 MSI-INTA 1971840 Level icssg1-eth 541: 0 0 pruss-intc 24 Level icssg1-eth 542: 0 0 pruss-intc 25 Level icssg1-eth root@am64xx-evm:~# cat /proc/interrupts | grep icssg 146: 158 0 MSI-INTA 1970792 Level icssg1-eth-tx0 150: 34 0 MSI-INTA 1970796 Level icssg1-eth-tx0 246: 48 0 MSI-INTA 1971824 Level icssg1-eth 262: 24 0 MSI-INTA 1971840 Level icssg1-eth 541: 0 0 pruss-intc 24 Level icssg1-eth 542: 0 0 pruss-intc 25 Level icssg1-eth root@am64xx-evm:~#
- Tianyi
