AM623: CPU frequency change not persistent after handover from u-boot to RTOS
Part Number: AM623
we are trying to increase the CPU frequency from 1.25GHz to 1.4GHz. u-boot has been updated to configure the voltage and frequency and within a Linux system this change can also be verified using the k3conf tool.
However, when loading our RTOS instead, the CPU frequency resets to 1.25GHz (read back by TISCI_MSG_GET_FREQ).
I tried to capture some SYSFW traces to see when it is changed, can you please have a look at them?
They seem to be incomplete, there is no difference between a 1.25GHz and a 1.4GHz boot. And I would also expect to see the 0x010e for TISCI_MSG_GET_FREQ shortly after host id 12 takes over (A53 non secure channel, which is used by our SCI driver).
Is it normal that the trace parser classifies non-secure hosts as "Message from secure host received"?
Later the Resource and Interrupt configuration messages correspond to what I am expecting from the system configuration. At the end I see some TISCI_MSG_PROC_SET_CONFIG (0xc100) requests, presumably from the psci calls to start the secondary cores.
Is it possible that they reset some previous configuration?
Is a specific handover from u-boot to OS required to retain the setup? Linux was launched using "bootm"/"booti", the RTOS is extracted and directly launched with "go".
Are there other options available to detect the operating frequency? Then we could maybe check earlier during RTOS boot at which state the frequency changes back.
Thanks and regards.
Configuring trace data version to: 0x03007
TI SCI: CPUFREQ: 1250000000
0x04003007:   BasePort: TRACE_DATA_VERSION(OSAL/Baseport trace data version): Trace version major: 0x03 Trace version minor: 0x007
0x04400B06:   BasePort:   SYSFW_VERSION(System Firmware version): version: 11 subversion: 0 patch: 6
0x00400002:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: 2
0x00800023:   BasePort: TISCI_MSG_SENDER_HOST_ID(Message from secure host received): Queue ID: 0 Host ID: 35
0x0040C120:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: c120
0x0040C000:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: c000
0x0040C100:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: c100
0x0040C005:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: c005
0x0042C000:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: c000
0x008200FA:   BasePort: TISCI_MSG_SENDER_HOST_ID(Message from secure host received): Queue ID: 2 Host ID: 250
0x0042C400:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: c400
0x0042C100:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: c100
0x0042C401:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: c401
0x0042C101:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: c101
0x0042C001:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: c001
0x00420021:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: 21
0x00820024:   BasePort: TISCI_MSG_SENDER_HOST_ID(Message from secure host received): Queue ID: 2 Host ID: 36
0x0042000C:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: c
0x00420002:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: 2
0x0080000A:   BasePort: TISCI_MSG_SENDER_HOST_ID(Message from secure host received): Queue ID: 0 Host ID: 10
0x00400200:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: 200
0x004F0200:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 15 Message ID: 200
0x008F00FE:   BasePort: TISCI_MSG_SENDER_HOST_ID(Message from secure host received): Queue ID: 15 Host ID: 254
0x00400022:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: 22
0x004F0022:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 15 Message ID: 22
0x0080000B:   BasePort: TISCI_MSG_SENDER_HOST_ID(Message from secure host received): Queue ID: 0 Host ID: 11
0x00409002:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: 9002
0x00409001:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: 9001
0x00409000:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: 9000
0x00409033:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: 9033
0x00409034:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: 9034
0x00409029:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: 9029
0x0082000C:   BasePort: TISCI_MSG_SENDER_HOST_ID(Message from secure host received): Queue ID: 2 Host ID: 12
0x0042C120:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: c120
0x00421110:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: 1110
0x00421205:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: 1205
0x00421280:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: 1280
0x00421215:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: 1215
0x00421281:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: 1281
0x00000004:   BasePort: INIT_COMPLETE(OSAL/Baseport init complete): MSG:0x000004
1110
0x00042111:   BasePort: INIT_COMPLETE(OSAL/Baseport init complete): MSG:0x042111
0x00421000:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: 1000
x82000C
0x00429000:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 2 Message ID: 9000
0x00000082:   BasePort: INIT_COMPLETE(OSAL/Baseport init complete): MSG:0x000082
00C
0x0040C101:   BasePort: TISCI_MSG_RECEIVED(TISCI Message interrupt handled): Queue ID: 0 Message ID: c101
    I am looking into your query, I will provide an update by mid of next week.
    Meet.
    it turned out that the frequency was not actually changed. After rebuilding the R5 Firmware, u-boot successfully set the core frequency and it also holds after the RTOS starts up, and can be properly read back and verified with some benchmarks. So this issue is resolved.
    However, in the trace there are still no indications of this change happening, so if you have any feedback why they are not logged, it might be helpful for the future.
    Thanks and regards.
