Other Parts Discussed in Thread: SK-AM62A-LP,
Hi experts,
Based on the original thread, I set both the AM62A-LP and AM62D-EVM to 500MHz and 1000MHz and ran the same measurement app.
As a result, we found that the measured number of execution clock cycles differed even when running the same process on the same EVM.
Also, despite assuming that the c7x performance of the AM62A and AM62D is the same, the results differ between SK-AM62A-LP and AM62D-EVM.
Q1: Could you please explain why the number of execution clock cycles differs even when performing the same process on the same evaluation board?
Our assumption was that the number of measurable clock cycles would be the same for the same process, even if the startup frequency was different.
Q2: Can you please explain why there is a difference between SK-AM62A-LP and AM62D-EVM even when using the same SDK binary?
We perform a simple data copy process as shown below and measure the count value using the CCS Profile clock.
#include "copy_buffer.h"
double4 gd_src_lch_d4[SAMPLE_NUM_QUATER];
double4 gd_src_rch_d4[SAMPLE_NUM_QUATER];
double4 gd_dst_lch_d4[SAMPLE_NUM_QUATER];
double4 gd_dst_rch_d4[SAMPLE_NUM_QUATER];
#pragma DATA_SECTION(".sdram");
float sdram_buffer01[768 * 1024];
float sdram_buffer02[768 * 1024];
float sdram_buffer03[768 * 1024];
float sdram_buffer04[3 * 1024 * 1024];
float sdram_buffer05[4][4000 * 96];
float sdram_buffer06[3 * 1024 * 1024];
float sdram_buffer07[2][12][4096];
float sdram_buffer08[9600];
float sdram_buffer09[9600];
float sdram_buffer10[2][8][32768];
float sdram_buffer11[4096];
float sdram_buffer12[4096];
float sdram_buffer13[768 * 1024];
float sdram_buffer14[768 * 1024];
void copy_float( float *restrict src_lch, float *restrict src_rch, float *restrict dst_lch, float *restrict dst_rch )
int num;
ALIGNED_ARRAY(src_lch);
ALIGNED_ARRAY(src_rch);
ALIGNED_ARRAY(dst_lch);
ALIGNED_ARRAY(dst_rch);
for(num=0; num<SAMPLE_NUM; num++) {
dst_lch[num] = src_lch[num];
dst_rch[num] = src_rch[num];
void copy_float_size( float *restrict src_lch, float *restrict src_rch, float *restrict dst_lch, float *restrict dst_rch, int size )
int num;
for(num=0; num < size; num++) {
void copy_double( double *restrict src_lch, double *restrict src_rch, double *restrict dst_lch, double *restrict dst_rch )
int num;
void copy_double4( double4 *restrict src_lch, double4 *restrict src_rch, double4 *restrict dst_lch, double4 *restrict dst_rch )
int num;
for(num=0; num<SAMPLE_NUM_QUATER; num++) {
void test_func01( void )
int i;
for(i=0; i < 100; i++)
copy_double(gd_src_lch, gd_src_rch, gd_dst_lch, gd_dst_rch);
void test_func02( void )
int i;
copy_double4(gd_src_lch_d4, gd_src_rch_d4, gd_dst_lch_d4, gd_dst_rch_d4);
void test_func03( void )
int i;
int size = sizeof(sdram_buffer04)/sizeof(float);
for(i=0; i < 10; i++)
copy_float_size(sdram_buffer04, sdram_buffer04, sdram_buffer06, sdram_buffer06, size);
void test_func04( void )
int i;
int size = sizeof(sdram_buffer01)/sizeof(float);
copy_float_size(sdram_buffer01, sdram_buffer02, sdram_buffer04, sdram_buffer04 + size, size);
copy_float_size(sdram_buffer03, sdram_buffer13, sdram_buffer06, sdram_buffer06 + size, size);
Based on am62ax_mcu_plus_sdk_10_00_00_14. The results were the same with v11.1. The difference between the EVMs was 1.15x for test_func03 and 1.06x for test_func04 when C7x=1000MHz.
func03 | SK-AM62A-LP | AUDIO-AM62D-EVM |
1000MHz | 368680012 | 425624480 |
500MHz | 206590725 | 225976894 |
func04 | SK-AM62A-LP | AUDIO-AM62D-EVM |
1000MHz | 461088870 | 488769638 |
500MHz | 250512996 | 261783175 |
O.H
