Part Number: AM62L
I am unable to boot the device, AM62L using SD card. I am getting the log uptil the PHY training completed, but only numbers and CCCC are coming after that.
NOTICE: bl1_plat_arch_setup arch setup
NOTICE: Booting Trusted Firmware
NOTICE: BL1: v2.12.0(debug):11.00.15-1-g2523204b0-dirty
NOTICE: BL1: Built : 10:50:54, Oct 13 2025
INFO: BL1: RAM 0x7080b000 - 0x7080f000
INFO: BL1: cortex_a53: CPU workaround for erratum 855873 was applied
INFO: BL1: cortex_a53: CPU workaround for erratum 1530924 was applied
INFO: lpddr4_init <--
INFO: lpddr4 dtb: ctl-data ptr=0x7080718c, pi-data=0x70807834, phy-data=0x70807da4
NOTICE: BL1: dram_class: 11
INFO: memory node =0x28
INFO: lpddr4: probe done
INFO: lpddr4/ddr4: init done
INFO: start-status: offset =0x0
INFO: start-status reg: before =0x10460b00
INFO: Doing normal DDR initINFO: lpddr4: Start DDR controller
INFO: k3_lpddr4_freq_update DDR Freq change complete
INFO: lpddr4: start completed successfully status=0x0
INFO: start-status reg: after =0x10460b01
INFO: LPDDR4 start completed !!
NOTICE: lpddr4: post start - PI training status=0x27c0a000
INFO: lpddr4: post start - CTL Interrupt status=0x4
NOTICE: bl1_platform_setup DDR init done
NOTICE: k3_bl1_handoff ENTERING WFI - end of bl1
This is the log I am getting while booting with USB and some garbage values come up if I boot with sd card
02000000011a0000616d36326c0000000000000048534653000001000000010002a6000000000000ad0bc40b000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000ad0bc40b00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000045818321883fc1e46a7aa92789c0bb27043b4a16dc68fa2b88f7fdc4bd5503adCCCCCCCCCCCCCCCCCCCCC
This is what I am getting when booting with sd card. Is the LPDDR4 looking for some file ?
The both logs shows BL1(tiboot3.bin) boots, but bootibg stops afterwards...
1/. Is test on TI EVM or customer board?
2/. which Linux SDK was used for testing?
-Hong
1/. what're main HW difference between the customer board vs the TI EVM?
2/. Is DDR on the customer board different comparing to the one on the TI EVM?
-Hong
1. It is similar to the TI EVM, same PMIC, same ram, similar peripherals.
2. it is the same LPDDR4 as the TI EVM. The only difference is some but swapping within the 8-bit lanes. We have used the configuration tool to compensate for these changes.
Is there a way to get more feedback about what is failing in the DDR training? Are there other tools to interface with the DDR? I saw some timing analysis tools but it for the AM62L, yet.
thanks
Let me loop in my colleague to follow-up lpddr4 configuration questions.
-Hong
Hi Nathan, to get more info from the DDR please add the patch found here:
and post the reg dump here. This will help determine if the DDR init and training is completing successfully.
James
We tried doing this, but didn't get any result.
NOTICE: BL1: v2.12.0(debug):11.00.15-30-gc2ce2c1da-dirty
NOTICE: BL1: Built : 07:23:27, Oct 21 2025
This is the output log.
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Found DFU: [0451:6165] ver=0200, devnum=46, cfg=1, intf=0, path="1-2", alt=1, name="SocId", serial="01.00.00.00"
Found DFU: [0451:6165] ver=0200, devnum=46, cfg=1, intf=0, path="1-2", alt=0, name="bootloader", serial="01.00.00.00"
Found DFU: [0bda:5800] ver=0001, devnum=4, cfg=1, intf=0, path="3-4", alt=0, name="Camera DFU Device", serial="200901010001"
++ sudo dfu-util -R -a bootloader -D tiboot3.bin
dfu-util 0.9
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Opening DFU capable USB device...
ID 0451:6165
Run-time device DFU version 0110
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 0110
Device returned transfer size 512
Copying data from PC to DFU device
Download [=========================] 100% 225967 bytes
Download done.
state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is present
state(2) = dfuIDLE, status(0) = No error condition is present
Done!
dfu-util: can't detach
Resetting USB to switch back to runtime mode
++ sleep 5
++ sudo dfu-util -l
dfu-util 0.9
Found DFU: [0451:6165] ver=0200, devnum=48, cfg=1, intf=0, path="1-2", alt=1, name="SocId", serial="01.00.00.00"
Found DFU: [0451:6165] ver=0200, devnum=48, cfg=1, intf=0, path="1-2", alt=0, name="bootloader", serial="01.00.00.00"
++ sudo dfu-util -R -a bootloader -D tispl.bin
dfu-util 0.9
ID 0451:6165
dfuIDLE, continuing
Download [=========================] 100% 1472848 bytes
Download done.
Done!
++ sleep 5
++ sudo dfu-util -R -a u-boot.img -D u-boot.img
dfu-util 0.9
dfu-util: No DFU capable USB device available
++ sleep 5
Hi, JJD,
Thanks for your response. We were able to modify and apply the patch successfully. But the problem is it output is always getting stuck at NOTICE: k3_bl1_handoff ENTERING WFI - end of bl1
It is not loading the tispl.bin file. We have attached logs of our boot and programming steps for your reference. We are able to program tiboot3.bin and tispl.bin but tispl is not booting and due to which we are not able to get any DDR logs.
That's strange, it should output the regdump immediately after DDR init in tiboot3.bin, it shouldn't need to get to tispl.bin.
In the link i sent, there is a section called "Adding statements to uboot". Can you ensure the #define DEBUG statement is in the appropriate place?
BTW, i don't see anything attached to the last post
James
Hi JJD,
You can see the logs attached by Megha for your reference. We dont see any logs beyond that. Attached a screenshot for your reference.
Sharing the git commit of patch for your reference: https://github.com/Narashiman/ti-u-boot/commit/b062312e5592064ae89765e04b45c9722f4e0b9d
I think the issue is similar to RE: AM62L-PROCESSOR-SDK: tispl.bin doesn't work on the custom board.
Attached our config as zip for your reference.Trial_1.zip
James
I am also working on this with Narashiman and Megha. I am adding a log with a register dump; we were able to get that output.
Hi Nathan,
sorry, i was reminded by our software team that the structure of the AM62L bootloader is different than previous devices, so the patch needed to be applied differently.
At any rate, it looks like you got it working. From the regdump, i can see that VREFca training is not completing correctly. Can you provide the DDR datasheet and and part number you are using. Also would like to see the schematic portion of the DDR interface, both the AM62L side and the memory side.
James
Hi James
We are using the same Micron part used on the development kit, we believe, MT53E1G16D1ZW-046 WT:C. Please find attached the schematics from our design. I believe it is the same as the development kit, except we swapped the data bits within the byte lanes for easier routing. We have used the SysConfig tool to change the .dtsi file to match our design.
Hi James,
We have been able to bootup the device, there was some issue with the dtsi file that we were able to figure out.
Thanks for the support!
Megha
In case someone else runs into the issue, the problem we had was with the bit swapping within byte lanes in the SysConfig tool; we missed that the left column is Processor DQ labels and the right column is Memory DQ labels; that made the ordering wrong in the original dtsi file we tried, it was backwards.
