AM62A7: Power-on probability does not display the camera image
Part Number: AM62A7
Hi, TI experts,
The specific project details are as follows:
Processor: AM62A7
SDK: 10.00.00.08
Boot method: EMMC boot
The hardware platform was designed by ourselves.
My device has a probabilistic issue where it fails to display the camera image. The probability of this occurring is approximately 1 in 30. Here is the comparison of dmesg information.
normal.txt       no image.txt
Furthermore, I attempted to directly display the camera image using commands. Here is the comparison of debug logs.
command_normal.txt       command_no image.txt
It seems that the key mistake is IPC: ERROR: Unable to create TX channels for CPU [c7x_1] !!!
Please assist with the analysis. Thank you.
Gaogao
  • Hello Gaogao,
    It looks like you are initializing the non-Linux cores during u-boot, and then attaching to the non-Linux cores with the Linux remoteproc driver later in boot. The other option is to let the Linux remoteproc driver initialize the non-Linux cores during Linux boot time.
    Let's check to see if something is going wrong with that "attach" code (for example, to see if there is a race condition going on somewhere). Please change your u-boot settings so that the C7 core and the MCU R5F are NOT initialized during uboot. Note that you will still see Linux attaching to the DM R5F core, since the DM R5F needs to start running during the SPL or SBL phases.
    For more information about how to change the out-of-the-box behavior so that the remote cores are initialized by Linux:
    Refer to AM62Ax academy > Linux > Booting Remote Cores
    https://dev.ti.com/tirex/explore/node?isTheia=false&node=A__AX2DLf3J3o-JHYMSq7Eg0w__AM62A-ACADEMY__WeZ9SsL__LATEST
    For more information about booting non-Linux cores in general:
    Refer to AM62Ax academy > Multicore > Booting and Disabling Processor Cores
    https://dev.ti.com/tirex/explore/node?isTheia=false&node=A__Ada-WjvmUg3JmB109NavGA__AM62A-ACADEMY__WeZ9SsL__LATEST
    Nick
  • I would also be curious to see if there are any differences in the print logs for the non-Linux cores in a working and a not-working case.
    Please take a look at AM62Ax academy > Multicore > Application Development on Remote Cores > Debug the remote core through the Linux terminal
    https://dev.ti.com/tirex/explore/node?isTheia=false&node=A__AfxfZqDGh-M3Xu5tsO1uFQ__AM62A-ACADEMY__WeZ9SsL__LATEST
    Nick
  •         hi, Nick
    1. According to the reference documents, it should already be linux to initialize the non-linux cores. we did not use env.txt and parts of the U-Boot and Linux boot logs show below:
      -------- u-boot
      Working FDT set to 88000000
      Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
      Working FDT set to 8feed000
      Starting kernel ...
      -------- kernel
      [ 4.598077] remoteproc remoteproc1: remote processor 79000000.r5f is now up
      [ 4.600137] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
      [ 4.602122] platform 78000000.r5f: R5F core initialized in IPC-only mode
      [ 4.602158] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node r5f-dma-memory@9c800000
      [ 4.602721] virtio_rpmsg_bus virtio1: rpmsg host is online
      [ 4.602761] rproc-virtio rproc-virtio.9.auto: registered virtio1 (type 7)
      [ 4.602770] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
      [ 4.603414] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
      [ 4.609195] remoteproc remoteproc0: powering up 7e000000.dsp
      [ 4.609225] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11604048
      [ 4.669727] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000
      [ 4.678247] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node c7x-dma-memory@99800000
      [ 4.683266] virtio_rpmsg_bus virtio2: rpmsg host is online
      [ 4.683320] rproc-virtio rproc-virtio.10.auto: registered virtio2 (type 7)
      [ 4.683330] remoteproc remoteproc0: remote processor 7e000000.dsp is now up
      U-Boot SPL 2024.04-dirty (Jan 15 2026 - 18:28:16 +0800)
      SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
      SPL initial stack usage: 13568 bytes
      Trying to boot from MMC1
      Authentication passed
      Starting ATF on ARM64 core...
      NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
      NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
      U-Boot SPL 2024.04-dirty (Jan 15 2026 - 18:28:10 +0800)
      U-Boot 2024.04-dirty (Jan 15 2026 - 18:28:10 +0800)
      SoC:   AM62AX SR1.0 HS-FS
      Model: Texas Instruments AM62A7 SK
      DRAM:  2 GiB (effective 4 GiB)
      Core:  81 devices, 29 uclasses, devicetree: separate
      MMC:   mmc@fa10000: 0, mmc@fa00000: 1
      Loading Environment from nowhere... OK
      In:    serial@2800000
      Out:   serial@2800000
      Err:   serial@2800000
      Net:   eth0: ethernet@8000000port@1
      Hit any key to stop autoboot:  0
      switch to partitions #0, OK
      mmc0(part 0) is current device
      SD/MMC found on device 0
      Can't set block device
      21252608 bytes read in 149 ms (136 MiB/s)
      64428 bytes read in 33 ms (1.9 MiB/s)
      Starting kernel ...
      [    0.138772] omap-mailbox 29030000.mailbox: no available mbox devices found
      [    0.232359] pca953x 1-0023: failed writing register
      [    0.926572] pinctrl-single f4000.pinctrl: Invalid number of rows: 0
      [    0.932853] pinctrl-single f4000.pinctrl: no pins entries for main-gpio1-ioexp-intr-default-pins
      [    0.941799] max96714 2-002a: twl max96714_get_hw_resources success[0]
      [    1.015597] max96714 2-002a: Error invalid reg-width 0 for reg 0x0010
      [    1.237199] panel-lvds panel-lvds: /panel-lvds: problems parsing panel-timing (-2)
      [    1.461374] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
      [    1.468719] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
      Welcome to Arago 2023.10!
      [  OK  ] Created slice Slice /system/getty.
      [  OK  ] Created slice Slice /system/modprobe.
      [  OK  ] Created slice Slice /system/serial-getty.
      [  OK  ] Created slice User and Session Slice.
      [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
      [  OK  ] Started Forward Password Requests to Wall Directory Watch.
      [  OK  ] Reached target Path Units.
      [  OK  ] Reached target Remote File Systems.
      [  OK  ] Reached target Slice Units.
      [  OK  ] Reached target Swaps.
      [  OK  ] Listening on Process Core Dump Socket.
      [  OK  ] Listening on initctl Compatibility Named Pipe.
      [  OK  ] Listening on Journal Audit Socket.
      [  OK  ] Listening on Journal Socket (/dev/log).
      [  OK  ] Listening on Journal Socket.
      [  OK  ] Listening on Network Service Netlink Socket.
      [  OK  ] Listening on udev Control Socket.
      [  OK  ] Listening on udev Kernel Socket.
      [  OK  ] Listening on User Database Manager Socket.
               Mounting Huge Pages File System...
               Mounting POSIX Message Queue File System...
               Mounting Kernel Debug File System...
               Mounting Temporary Directory /tmp...
               Starting Create List of Static Device Nodes...
               Starting Load Kernel Module configfs...
               Starting Load Kernel Module drm...
               Starting Load Kernel Module fuse...
               Starting Journal Service...
               Starting Generate network units from Kernel command line...
               Starting Remount Root and Kernel File Systems...
               Starting Apply Kernel Variables...
               Starting Coldplug All udev Devices...
      [  OK  ] Mounted Huge Pages File System.
      [  OK  ] Mounted POSIX Message Queue File System.
      [  OK  ] Mounted Kernel Debug File System.
      [  OK  ] Mounted Temporary Directory /tmp.
      [  OK  ] Finished Create List of Static Device Nodes.
      [  OK  ] Finished Load Kernel Module configfs.
      [  OK  ] Started Journal Service.
      [  OK  ] Finished Load Kernel Module drm.
      [  OK  ] Finished Load Kernel Module fuse.
      [  OK  ] Finished Generate network units from Kernel command line.
      [  OK  ] Finished Remount Root and Kernel File Systems.
      [  OK  ] Finished Apply Kernel Variables.
      [  OK  ] Reached target Preparation for Network.
               Mounting FUSE Control File System...
               Mounting Kernel Configuration File System...
               Starting Flush Journal to Persistent Storage...
               Starting Create Static Device Nodes in /dev gracefully...
      [  OK  ] Mounted FUSE Control File System.
      [  OK  ] Mounted Kernel Configuration File System.
      [  OK  ] Finished Flush Journal to Persistent Storage.
      [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
               Starting Create Static Device Nodes in /dev...
      [  OK  ] Finished Create Static Device Nodes in /dev.
      [  OK  ] Reached target Preparation for Local File Systems.
               Mounting /var/volatile...
               Starting Rule-based Manager for Device Events and Files...
      [  OK  ] Finished Coldplug All udev Devices.
      [  OK  ] Mounted /var/volatile.
               Starting Load/Save OS Random Seed...
      [  OK  ] Reached target Local File Systems.
               Starting Create Volatile Files and Directories...
      [  OK  ] Finished Load/Save OS Random Seed.
      [  OK  ] Started Rule-based Manager for Device Events and Files.
               Starting Network Configuration...
      [  OK  ] Finished Create Volatile Files and Directories.
               Starting Network Name Resolution...
               Starting Network Time Synchronization...
      [    4.485027] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
      [    4.492863] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
               Starting Record System Boot/Shutdown in UTMP...
               Starting User Database Manager...
      [  OK  ] Finished Record System Boot/Shutdown in UTMP.
               Starting Virtual Console Setup...
      [  OK  ] Started User Database Manager.
      [  OK  ] Reached target Sound Card.
      [  OK  ] Finished Virtual Console Setup.
      [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
      [  OK  ] Started Network Name Resolution.
      [  OK  ] Started Network Time Synchronization.
      [  OK  ] Started Network Configuration.
      [  OK  ] Reached target Network.
      [  OK  ] Reached target Host and Network Name Lookups.
      [  OK  ] Reached target System Initialization.
      [  OK  ] Started Daily Cleanup of Temporary Directories.
      [  OK  ] Reached target System Time Set.
      [  OK  ] Reached target Timer Units.
      [  OK  ] Listening on D-Bus System Message Bus Socket.
      [  OK  ] Reached target Socket Units.
      [  OK  ] Reached target Basic System.
               Starting D-Bus System Message Bus...
               Starting BootStart Script Service...
               Starting User Login Management...
       Boot time: 5.49s
               Starting Permit User Sessions...
      [  OK  ] Started D-Bus System Message Bus.
      [  OK  ] Started BootStart Script Service.
      [  OK  ] Finished Permit User Sessions.
      [  OK  ] Started Getty on tty1.
      [  OK  ] Reached target Login Prompts.
               Starting Synchronize System and HW clocks...
      root@am62axx-evm:~# dmesg
      [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
      [    0.000000] Linux version 6.6.32 (flork@ti) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #67 SMP PREEMPT Fri Nov 28 11:49:43 HKT 2025
      [    0.000000] KASLR disabled due to lack of seed
      [    0.000000] Machine model: Texas Instruments AM62A7 SK
      [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
      [    0.000000] printk: bootconsole [ns16550a0] enabled
      [    0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 576 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x00000000c0000000..0x00000000e3ffffff (589824 KiB) map reusable linux,cma
      [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
      [    0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB
      [    0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x0000000099800000..0x00000000998fffff (1024 KiB) nomap non-reusable c7x-dma-memory@99800000
      [    0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 31 MiB
      [    0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x0000000099900000..0x000000009b7fffff (31744 KiB) nomap non-reusable c7x-memory@99900000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
      [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9b800000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
      [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable r5f-dma-memory@9b900000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
      [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
      [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-dma-memory@9c900000
      [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
      [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a0ffffff (16384 KiB) nomap non-reusable edgeai-rtos-ipc-memory-region
      [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB
      [    0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a2ffffff (32768 KiB) nomap non-reusable edgeai-dma-memory@a1000000
      [    0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout
      [    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000adffffff (180224 KiB) map non-reusable edgeai_shared-memories
      [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 288 MiB
      [    0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@ae000000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x00000000ae000000..0x00000000bfffffff (294912 KiB) nomap non-reusable edgeai-core-heap-memory@ae000000
      [    0.000000] Zone ranges:
      [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
      [    0.000000]   DMA32    empty
      [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
      [    0.000000] Movable zone start for each node
      [    0.000000] Early memory node ranges
      [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
      [    0.000000]   node   0: [mem 0x0000000080080000-0x00000000997fffff]
      [    0.000000]   node   0: [mem 0x0000000099800000-0x000000009e6fffff]
      [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
      [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a2ffffff]
      [    0.000000]   node   0: [mem 0x00000000a3000000-0x00000000adffffff]
      [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000bfffffff]
      [    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
      [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
      [    0.000000] psci: probing for conduit method from DT.
      [    0.000000] psci: PSCIv1.1 detected in firmware.
      [    0.000000] psci: Using standard PSCI v0.2 function IDs
      [    0.000000] psci: Trusted OS migration not required
      [    0.000000] psci: SMC Calling Convention v1.4
      [    0.000000] percpu: Embedded 20 pages/cpu s43496 r8192 d30232 u81920
      [    0.000000] pcpu-alloc: s43496 r8192 d30232 u81920 alloc=20*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Detected VIPT I-cache on CPU0
      [    0.000000] CPU features: detected: GIC system register CPU interface
      [    0.000000] CPU features: detected: ARM erratum 845719
      [    0.000000] alternatives: applying boot alternatives
      [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=71306855-01 rw rootfstype=ext4 rootwait
      [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
      [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
      [    0.000000] software IO TLB: area num 4.
      [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
      [    0.000000] Memory: 2806888K/4194304K available (12672K kernel code, 1234K rwdata, 4304K rodata, 2432K init, 503K bss, 797592K reserved, 589824K cma-reserved)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] rcu: Preemptible hierarchical RCU implementation.
      [    0.000000] rcu:     RCU event tracing is enabled.
      [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
      [    0.000000]  Trampoline variant of Tasks RCU enabled.
      [    0.000000]  Tracing variant of Tasks RCU enabled.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
      [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
      [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
      [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
      [    0.000000] GICv3: 256 SPIs implemented
      [    0.000000] GICv3: 0 Extended SPIs implemented
      [    0.000000] Root IRQ handler: gic_handle_irq
      [    0.000000] GICv3: GICv3 features: 16 PPIs
      [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
      [    0.000000] ITS [mem 0x01820000-0x0182ffff]
      [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
      [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
      [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
      [    0.000000] ITS: using cache flushing for cmd queue
      [    0.000000] GICv3: using LPI property table @0x0000000880040000
      [    0.000000] GIC: using cache flushing for LPI property table
      [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
      [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
      [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
      [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
      [    0.000335] Console: colour dummy device 80x25
      [    0.000386] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
      [    0.000397] pid_max: default: 32768 minimum: 301
      [    0.000476] LSM: initializing lsm=capability,integrity
      [    0.000578] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.000597] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.002207] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
      [    0.002276] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
      [    0.002446] rcu: Hierarchical SRCU implementation.
      [    0.002451] rcu:     Max phase no-delay instances is 1000.
      [    0.002688] Platform MSI: msi-controller@1820000 domain created
      [    0.002885] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
      [    0.003137] EFI services will not be available.
      [    0.003362] smp: Bringing up secondary CPUs ...
      [    0.003945] Detected VIPT I-cache on CPU1
      [    0.004015] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
      [    0.004032] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
      [    0.004076] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
      [    0.004739] Detected VIPT I-cache on CPU2
      [    0.004789] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
      [    0.004802] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
      [    0.004833] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
      [    0.005410] Detected VIPT I-cache on CPU3
      [    0.005457] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
      [    0.005470] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
      [    0.005498] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
      [    0.005570] smp: Brought up 1 node, 4 CPUs
      [    0.005586] SMP: Total of 4 processors activated.
      [    0.005591] CPU features: detected: 32-bit EL0 Support
      [    0.005596] CPU features: detected: CRC32 instructions
      [    0.005652] CPU: All CPU(s) started at EL2
      [    0.005655] alternatives: applying system-wide alternatives
      [    0.007174] devtmpfs: initialized
      [    0.016326] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.016351] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.030434] pinctrl core: initialized pinctrl subsystem
      [    0.030874] DMI not present or invalid.
      [    0.031479] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [    0.032267] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
      [    0.032391] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
      [    0.032543] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
      [    0.032608] audit: initializing netlink subsys (disabled)
      [    0.032772] audit: type=2000 audit(0.032:1): state=initialized audit_enabled=0 res=1
      [    0.033203] thermal_sys: Registered thermal governor 'step_wise'
      [    0.033208] thermal_sys: Registered thermal governor 'power_allocator'
      [    0.033250] cpuidle: using governor menu
      [    0.033420] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
      [    0.033502] ASID allocator initialised with 65536 entries
      [    0.045696] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
      [    0.047619] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/bridge-lvds@29
      [    0.049447] platform panel-lvds: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/bridge-lvds@29
      [    0.050144] Modules: 27440 pages in range for non-PLT usage
      [    0.050153] Modules: 518960 pages in range for PLT usage
      [    0.050845] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
      [    0.050856] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
      [    0.050862] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
      [    0.050866] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
      [    0.050871] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
      [    0.050875] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
      [    0.050880] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
      [    0.050884] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
      [    0.052188] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
      [    0.052899] iommu: Default domain type: Translated
      [    0.052912] iommu: DMA domain TLB invalidation policy: strict mode
      [    0.053178] SCSI subsystem initialized
      [    0.053296] libata version 3.00 loaded.
      [    0.053456] usbcore: registered new interface driver usbfs
      [    0.053482] usbcore: registered new interface driver hub
      [    0.053515] usbcore: registered new device driver usb
      [    0.053952] mc: Linux media interface: v0.10
      [    0.053994] videodev: Linux video capture interface: v2.00
      [    0.054038] pps_core: LinuxPPS API ver. 1 registered
      [    0.054043] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.054058] PTP clock support registered
      [    0.054222] EDAC MC: Ver: 3.0.0
      [    0.054686] scmi_core: SCMI protocol bus registered
      [    0.054923] FPGA manager framework
      [    0.055030] Advanced Linux Sound Architecture Driver Initialized.
      [    0.055889] vgaarb: loaded
      [    0.056220] clocksource: Switched to clocksource arch_sys_counter
      [    0.056438] VFS: Disk quotas dquot_6.6.0
      [    0.056467] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
      [    0.062458] Carveout Heap: Exported 176 MiB at 0x00000000a3000000
      [    0.062561] NET: Registered PF_INET protocol family
      [    0.062748] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
      [    0.065650] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
      [    0.065696] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.065746] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
      [    0.065961] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
      [    0.066774] TCP: Hash tables configured (established 32768 bind 32768)
      [    0.066904] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
      [    0.066994] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
      [    0.067223] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [    0.067664] RPC: Registered named UNIX socket transport module.
      [    0.067675] RPC: Registered udp transport module.
      [    0.067679] RPC: Registered tcp transport module.
      [    0.067682] RPC: Registered tcp-with-tls transport module.
      [    0.067686] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.067694] NET: Registered PF_XDP protocol family
      [    0.067714] PCI: CLS 0 bytes, default 64
      [    0.069020] Initialise system trusted keyrings
      [    0.069214] workingset: timestamp_bits=46 max_order=20 bucket_order=0
      [    0.069500] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.069731] NFS: Registering the id_resolver key type
      [    0.069754] Key type id_resolver registered
      [    0.069759] Key type id_legacy registered
      [    0.069778] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.069784] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [    0.103456] Key type asymmetric registered
      [    0.103465] Asymmetric key parser 'x509' registered
      [    0.103514] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
      [    0.103648] io scheduler mq-deadline registered
      [    0.103654] io scheduler kyber registered
      [    0.103681] io scheduler bfq registered
      [    0.106676] pinctrl-single 4084000.pinctrl: 34 pins, size 136
      [    0.107380] pinctrl-single f4000.pinctrl: 151 pins, size 604
      [    0.109360] pinctrl-single a40000.pinctrl: 512 pins, size 2048
      [    0.115072] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
      [    0.128619] loop: module loaded
      [    0.129601] megasas: 07.725.01.00-rc1
      [    0.132007] tun: Universal TUN/TAP device driver, 1.6
      [    0.132980] VFIO - User Level meta-driver version: 0.3
      [    0.134124] usbcore: registered new interface driver usb-storage
      [    0.134506] i2c_dev: i2c /dev entries driver
      [    0.134666] IR NEC protocol handler initialized
      [    0.136142] sdhci: Secure Digital Host Controller Interface driver
      [    0.136153] sdhci: Copyright(c) Pierre Ossman
      [    0.136422] sdhci-pltfm: SDHCI platform and OF driver helper
      [    0.137194] ledtrig-cpu: registered to indicate activity on CPUs
      [    0.137489] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
      [    0.138155] usbcore: registered new interface driver usbhid
      [    0.138162] usbhid: USB HID core driver
      [    0.138456] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
      [    0.138602] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
      [    0.138715] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
      [    0.147143] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
      [    0.147800] optee: probing for conduit method.
      [    0.147828] optee: revision 4.2 (12d7c4ee)
      [    0.148102] optee: dynamic shared memory is enabled
      [    0.148791] random: crng init done
      [    0.148876] optee: initialized driver
      [    0.150448] Initializing XFRM netlink socket
      [    0.150484] NET: Registered PF_PACKET protocol family
      [    0.150546] Key type dns_resolver registered
      [    0.158472] registered taskstats version 1
      [    0.158617] Loading compiled-in X.509 certificates
      [    0.171840] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
      [    0.209211] i2c 0-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@48/regulators/buck5
      [    0.209404] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
      [    0.210618] pca953x 1-0023: supply vcc not found, using dummy regulator
      [    0.210745] pca953x 1-0023: using AI
      [    0.237468] pca953x: probe of 1-0023 failed with error -121
      [    0.237560] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
      [    0.238502] i2c 2-002a: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
      [    0.238720] platform panel-lvds: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/bridge-lvds@29
      [    0.238781] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/bridge-lvds@29
      [    0.238840] i2c 2-0029: Fixed dependency cycle(s) with /panel-lvds
      [    0.238892] i2c 2-0029: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
      [    0.239133] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
      [    0.239445] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
      [    0.239595] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
      [    0.239821] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
      [    0.240069] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created
      [    0.240839] ti-udma 485c0100.dma-controller: Number of rings: 82
      [    0.243337] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
      [    0.245844] ti-udma 485c0000.dma-controller: Number of rings: 150
      [    0.250452] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
      [    0.252371] ti-udma 4e230000.dma-controller: Number of rings: 6
      [    0.252906] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
      [    0.254033] printk: console [ttyS2] disabled
      [    0.254347] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 252, base_baud = 3000000) is a 8250
      [    0.254398] printk: console [ttyS2] enabled
      [    0.254404] printk: bootconsole [ns16550a0] disabled
      [    0.255613] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 254, base_baud = 3000000) is a 8250
      [    0.659111] spi-nand: probe of spi0.0 failed with error -110
      [    0.700230] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
      [    0.701641] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
      [    0.701771] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
      [    0.701779] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
      [    0.702239] pps pps0: new PPS source ptp0
      [    0.702483] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
      [    0.707472] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
      [    0.711457] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
      [    0.711487] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
      [    0.711656] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
      [    0.711664] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
      [    0.711714] xhci-hcd xhci-hcd.0.auto: irq 267, io mem 0x31000000
      [    0.712509] hub 1-0:1.0: USB hub found
      [    0.712548] hub 1-0:1.0: 1 port detected
      [    0.714621] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
      [    0.714648] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
      [    0.714770] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports
      [    0.714778] xhci-hcd xhci-hcd.1.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
      [    0.714826] xhci-hcd xhci-hcd.1.auto: irq 268, io mem 0x31100000
      [    0.715543] hub 2-0:1.0: USB hub found
      [    0.715579] hub 2-0:1.0: 1 port detected
      [    0.717558] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
      [    0.717588] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4)
      [    0.718798] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
      [    0.720530] mmc0: CQHCI version 5.10
      [    0.720682] mmc1: CQHCI version 5.10
      [    0.756796] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
      [    0.820673] mmc0: Command Queue Engine enabled
      [    0.820694] mmc0: new HS200 MMC card at address 0001
      [    0.821195] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
      [    0.822276]  mmcblk0: p1
      [    0.822640] mmcblk0boot0: mmc0:0001 8GUF4R 31.9 MiB
      [    0.823336] mmcblk0boot1: mmc0:0001 8GUF4R 31.9 MiB
      [    0.823997] mmcblk0rpmb: mmc0:0001 8GUF4R 4.00 MiB, chardev (238:0)
      [    0.926425] tps6594-rtc tps6594-rtc.7.auto: registered as rtc1
      [    0.941753] max96714_probe start
      [    0.988224]  -------------------------------------
      [    0.988224]
      [    1.012414] twl max96714 read device id [c9]
      [    1.012636] link freq[500000000]
      [    1.012641] twl max96714_parse_dt_txport num_data_lanes[4]
      [    1.014205] max96714 2-002a: Deserializer: max96714
      [    1.014210] twl max96714_log_status
      [    1.014407] max96714 2-002a: Link locked:1
      [    1.014606] twl max96714_link_status lock: 1
      [    1.014804] max96714 2-002a: Pipe vidlock:1
      [    1.015002] twl max96714_pipe_status Pipe vidlock: 1
      [    1.015393] max96714 2-002a: CSI controller DPLL freq:1000MHz CSIPHY enabled:0
      [    1.015592] twl max96714_csi_status CSI controller DPLL freq:1000MHz CSIPHY enabled:0
      [    1.236352] max96714_probe success
      [    1.236358] flork max96714_kthread start
      [    1.236539] lt9211 2-0029: #####111 find panel error: -517
      [    1.236563] [Flork]:96714 GMSL2 link state change! [0] -> [1]
      [    1.236762] [Flork]:96714 Video pipe link state change! [0] -> [1]
      [    1.236961] [Flork]:96717 0X000D = 0xbf!
      [    1.236966] [Flork] SUCCESS :96717 DEV ID correct!
      [    1.244818] panel-lvds: probe of panel-lvds failed with error -2
      [    1.244916] twl 2025-03-04 panel_simple_probe
      [    1.244921] twl test panel
      [    1.284231] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
      [    1.285309] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver unknown
      [    1.285788] Registered IR keymap rc-nec-terratec-cinergy-xs
      [    1.285874] rc rc0: gpio_ir_recv as /devices/platform/gpio-ir-receiver/rc/rc0
      [    1.285979] input: gpio_ir_recv as /devices/platform/gpio-ir-receiver/rc/rc0/input0
      [    1.286963] lt9211 2-0029: panel found
      [    1.286978] lt9211 2-0029: bridge found
      [    1.432222] twl reset chip
      [    1.453760] lt9211 2-0029: Chip ID: 0x21 0x03 0xe1
      [    1.455100] LT9211C chip id:0x21 0x03 0xe1
      [    1.455105] lt9211 2-0029: ########################### 2
      [    1.455111] lt9211 2-0029: DRM bridge lt9211 probed
      [    1.455218] twl LT9211C_Main start
      [    1.457371] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
      [    1.458640] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
      [    1.476823] clk: Disabling unused clocks
      [    1.480845] ALSA device list:
      [    1.480852]   No soundcards found.
      [    1.560230] RxState = 0x02
      [    1.560240] TxState = 0x02
      [    1.565168] RxState = 0x03
      [    1.570804] TTLRx Input Mode:    RGB888
      [    1.570808] RxState = 0x04
      [    1.956672] Rx Pll Cal done and Lock
      [    1.957561] vmax, vmin = 0x0a 0x00
      [    1.958009] vcoset = 0x05
      [    1.960065] uci fit = 0x04
      [    1.960068] ucihact, ucivact = 1280 720
      [    1.967298] self timing set:
      [    1.967301] hfp, hs, hbp, hact, htotal = 80 20 88 1280 1468
      [    1.967307] vfp, vs, vbp, vact, vtotal = 13 8 23 720 764
      [    2.072666] TTL input sync_polarity = 0x0f
      [    2.074357] sync mode enable, generate de
      [    2.075207] RxState = 0x05
      [    2.092664] FM CLOCK DET Stable
      [    2.095242] TTL input dclock: 66999
      [    2.095247] ==============
      [    2.095250] ==============
      [    2.095252] ==============
      [    2.208608] ************video check phase: 0x09
      [    2.208613] sync_polarity = 0x0f
      [    2.208616] hfp, hs, hbp, hact, htotal = 80 20 88 1280 1468
      [    2.208621] vfp, vs, vbp, vact, vtotal = 13 8 23 720 764
      [    2.208626] RxState = 0x06
      [    2.210314] TxState = 0x03
      [    2.224663] FM CLOCK DET Stable
      [    2.229639] temp is: 0x01
      [    2.240280] sdhci-am654 fa00000.mmc: Power on failed
      [    2.269104] Tx Pll Lock
      [    2.269107] TxState = 0x04
      [    2.270870] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
      [    2.282189] EXT4-fs (mmcblk0p1): 1 orphan inode deleted
      [    2.282212] EXT4-fs (mmcblk0p1): recovery complete
      [    2.285920] EXT4-fs (mmcblk0p1): mounted filesystem 6178f84d-13e8-45bf-890c-a219a0607b8a r/w with ordered data mode. Quota mode: none.
      [    2.286000] VFS: Mounted root (ext4 filesystem) on device 179:1.
      [    2.286333] devtmpfs: mounted
      [    2.286961] Freeing unused kernel memory: 2432K
      [    2.287045] Run /sbin/init as init process
      [    2.287049]   with arguments:
      [    2.287051]     /sbin/init
      [    2.287054]   with environment:
      [    2.287057]     HOME=/
      [    2.287059]     TERM=linux
      [    2.379505] systemd[1]: System time before build time, advancing clock.
      [    2.403629] NET: Registered PF_INET6 protocol family
      [    2.404512] Segment Routing with IPv6
      [    2.404537] In-situ OAM (IOAM) with IPv6
      [    2.420527] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.421276] systemd[1]: Configuration file /usr/lib/systemd/system.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.422504] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
      [    2.422533] systemd[1]: Detected architecture arm64.
      [    2.433467] systemd[1]: Hostname set to <am62axx-evm>.
      [    2.542119] systemd[1]: Configuration file /usr/lib/systemd/system/blockdev@.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.543352] systemd[1]: Configuration file /usr/lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.544043] systemd[1]: Configuration file /usr/lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.548575] systemd[1]: Configuration file /usr/lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.549428] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.551362] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journald.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.555206] systemd[1]: Configuration file /usr/lib/systemd/system/soft-reboot.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.556524] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-soft-reboot.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.558216] systemd[1]: Configuration file /usr/lib/systemd/system/final.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.558961] systemd[1]: Configuration file /usr/lib/systemd/system/sysinit.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.563517] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-update-utmp.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.565802] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-update-done.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.567611] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.570252] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udevd-kernel.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.572029] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udevd-control.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.573994] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udev-trigger.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.575751] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.577868] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-switch-root.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.579801] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-cleanup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.581117] systemd[1]: Configuration file /usr/lib/systemd/system/initrd.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.582885] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-battery-check.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.584925] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-hibernate-resume.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.586730] systemd[1]: Configuration file /usr/lib/systemd/system/rescue.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.588771] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-update-utmp-runlevel.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.591420] systemd[1]: Configuration file /usr/lib/systemd/system/graphical.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.593629] systemd[1]: Configuration file /usr/lib/systemd/system/multi-user.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.598282] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-user-sessions.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.600350] systemd[1]: Configuration file /usr/lib/systemd/system/network.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.601176] systemd[1]: Configuration file /usr/lib/systemd/system/network-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.602285] systemd[1]: Configuration file /usr/lib/systemd/system/nss-user-lookup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.603738] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-networkd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.607377] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-networkd.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.608940] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-logind.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.613397] systemd[1]: Configuration file /usr/lib/systemd/system/dbus.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.614476] systemd[1]: Configuration file /usr/lib/systemd/system/modprobe@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.616566] systemd[1]: Configuration file /usr/lib/systemd/system/user.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.617386] systemd[1]: Configuration file /usr/lib/systemd/system/slices.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.618122] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-ask-password-wall.path is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.620918] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-ask-password-wall.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.623475] systemd[1]: Configuration file /usr/lib/systemd/system/paths.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.624263] systemd[1]: Configuration file /usr/lib/systemd/system/remote-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.625401] systemd[1]: Configuration file /usr/lib/systemd/system/remote-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.626869] systemd[1]: Configuration file /etc/systemd/system/hd260_init.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.628015] systemd[1]: Configuration file /usr/lib/systemd/system/serial-getty@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.631794] systemd[1]: Configuration file /usr/lib/systemd/system/rc-local.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.633216] systemd[1]: Configuration file /usr/lib/systemd/system/getty-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.635099] systemd[1]: Configuration file /usr/lib/systemd/system/getty.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.636770] systemd[1]: Configuration file /usr/lib/systemd/system/getty@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.639844] systemd[1]: Configuration file /usr/lib/systemd/system/dbus.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.640822] systemd[1]: Configuration file /usr/lib/systemd/system/rescue.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.641841] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-parse-etc.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.643581] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-usr-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.645139] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-root-device.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.646719] systemd[1]: Configuration file /usr/lib/systemd/system/basic.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.647815] systemd[1]: Configuration file /usr/lib/systemd/system/timers.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.649218] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-clean.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.651050] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-clean.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.653003] systemd[1]: Configuration file /usr/lib/systemd/system/time-set.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.654103] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.655259] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-root-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.656857] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-udevadm-cleanup-db.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.659224] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udev-settle.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.661024] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-switch-root.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.662693] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.665276] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-setup-dev-early.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.668326] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-timesyncd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.671998] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-sysusers.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.673842] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.675282] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-resolved.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.678958] systemd[1]: Configuration file /usr/lib/systemd/system/nss-lookup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.680107] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-random-seed.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.682862] systemd[1]: Configuration file /usr/lib/systemd/system/first-boot-complete.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.684490] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-network-generator.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.686400] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-modules-load.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.688265] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-machine-id-commit.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.690480] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journal-flush.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.692405] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journal-catalog-update.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.694756] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-hwdb-update.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.696550] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-ask-password-console.path is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.699130] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-ask-password-console.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.701528] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-vconsole-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.703561] systemd[1]: Configuration file /usr/lib/systemd/system/sys-kernel-tracing.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.705433] systemd[1]: Configuration file /usr/lib/systemd/system/sys-kernel-debug.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.707132] systemd[1]: Configuration file /usr/lib/systemd/system/sys-kernel-config.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.709340] systemd[1]: Configuration file /usr/lib/systemd/system/modprobe@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.710509] systemd[1]: Configuration file /usr/lib/systemd/system/sys-fs-fuse-connections.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.712978] systemd[1]: Configuration file /usr/lib/systemd/system/modprobe@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.713926] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.714290] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
      [    2.715203] systemd[1]: Configuration file /usr/lib/systemd/system/ldconfig.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.716203] systemd[1]: Configuration file /usr/lib/systemd/system/kmod-static-nodes.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.717868] systemd[1]: Configuration file /usr/lib/systemd/system/dev-mqueue.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.719163] systemd[1]: Configuration file /usr/lib/systemd/system/dev-hugepages.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.720491] systemd[1]: Configuration file /usr/lib/systemd/system/emergency.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.721484] systemd[1]: Configuration file /usr/lib/systemd/system/syslog.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.722825] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journald-audit.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.724662] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journald-dev-log.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.727124] systemd[1]: Configuration file /usr/lib/systemd/system/sockets.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.729446] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-userdbd.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.731048] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-userdbd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.733480] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-initctl.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.734908] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-initctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.736097] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-coredump.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.737525] systemd[1]: Configuration file /usr/lib/systemd/system/var-volatile-srv.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.739195] systemd[1]: Configuration file /usr/lib/systemd/system/var-volatile-spool.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.740919] systemd[1]: Configuration file /usr/lib/systemd/system/var-volatile-lib.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.742631] systemd[1]: Configuration file /usr/lib/systemd/system/var-volatile-cache.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.744401] systemd[1]: Configuration file /usr/lib/systemd/system/tmp.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.745402] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-remount-fs.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.747145] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-fsck-root.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.748836] systemd[1]: Configuration file /usr/lib/systemd/system/emergency.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.749629] systemd[1]: Configuration file /usr/lib/systemd/system/shutdown.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.750303] systemd[1]: Configuration file /usr/lib/systemd/system/local-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.756941] systemd[1]: Queued start job for default target Multi-User System.
      [    2.777582] systemd[1]: Unnecessary job was removed for /dev/ttyS2.
      [    2.779977] systemd[1]: Created slice Slice /system/getty.
      [    2.798373] systemd[1]: Created slice Slice /system/modprobe.
      [    2.813800] systemd[1]: Created slice Slice /system/serial-getty.
      [    2.829421] systemd[1]: Created slice User and Session Slice.
      [    2.844619] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
      [    2.860541] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [    2.876421] systemd[1]: Reached target Path Units.
      [    2.892348] systemd[1]: Reached target Remote File Systems.
      [    2.908306] systemd[1]: Reached target Slice Units.
      [    2.924306] systemd[1]: Reached target Swaps.
      [    2.940686] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-coredump@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.946459] systemd[1]: Listening on Process Core Dump Socket.
      [    2.964679] systemd[1]: Listening on initctl Compatibility Named Pipe.
      [    2.981286] systemd[1]: Listening on Journal Audit Socket.
      [    2.996858] systemd[1]: Listening on Journal Socket (/dev/log).
      [    3.012881] systemd[1]: Listening on Journal Socket.
      [    3.029028] systemd[1]: Listening on Network Service Netlink Socket.
      [    3.045274] systemd[1]: Listening on udev Control Socket.
      [    3.060916] systemd[1]: Listening on udev Kernel Socket.
      [    3.076899] systemd[1]: Listening on User Database Manager Socket.
      [    3.120555] systemd[1]: Mounting Huge Pages File System...
      [    3.135491] systemd[1]: Mounting POSIX Message Queue File System...
      [    3.155550] systemd[1]: Mounting Kernel Debug File System...
      [    3.164879] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
      [    3.168995] systemd[1]: Mounting Temporary Directory /tmp...
      [    3.184592] systemd[1]: Starting Create List of Static Device Nodes...
      [    3.204359] systemd[1]: Starting Load Kernel Module configfs...
      [    3.220288] systemd[1]: Starting Load Kernel Module drm...
      [    3.236279] systemd[1]: Starting Load Kernel Module fuse...
      [    3.248658] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
      [    3.255539] systemd[1]: Starting Journal Service...
      [    3.263350] fuse: init (API version 7.39)
      [    3.266021] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
      [    3.269956] systemd[1]: Starting Generate network units from Kernel command line...
      [    3.288206] systemd[1]: Starting Remount Root and Kernel File Systems...
      [    3.308459] systemd[1]: Starting Apply Kernel Variables...
      [    3.325205] systemd[1]: Starting Coldplug All udev Devices...
      [    3.328862] LVDS Output PortA
      [    3.339032] LVDS MODE : SYNC
      [    3.340954] Data Format: VESA
      [    3.340972] ColorSpace: RGB
      [    3.340975] ColorDepth: 8Bit
      [    3.353216] systemd[1]: Mounted Huge Pages File System.
      [    3.354366] systemd-journald[124]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    3.354860] systemd-journald[124]: Configuration file /usr/lib/systemd/journald.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    3.355760] systemd-journald[124]: Collecting audit messages is enabled.
      [    3.361242] systemd[1]: Mounted POSIX Message Queue File System.
      [    3.362024] LVDS Tx Video Out
      [    3.362040] TxState = 0x05
      [    3.362049] LT9211C_Main tx rx all ready.
      [    3.362052] LT9211C_Main exit.
      [    3.365554] EXT4-fs (mmcblk0p1): re-mounted 6178f84d-13e8-45bf-890c-a219a0607b8a r/w. Quota mode: none.
      [    3.378651] systemd[1]: Mounted Kernel Debug File System.
      [    3.397190] systemd[1]: Mounted Temporary Directory /tmp.
      [    3.413514] systemd[1]: Finished Create List of Static Device Nodes.
      [    3.429860] systemd[1]: modprobe@configfs.service: Deactivated successfully.
      [    3.436385] systemd[1]: Finished Load Kernel Module configfs.
      [    3.453176] systemd[1]: Started Journal Service.
      [    3.710407] systemd-journald[124]: Received client request to flush runtime journal.
      [    3.918805] audit: type=1334 audit(1709054765.536:2): prog-id=6 op=LOAD
      [    3.918980] audit: type=1334 audit(1709054765.536:3): prog-id=7 op=LOAD
      [    4.090145] audit: type=1334 audit(1709054765.708:4): prog-id=8 op=LOAD
      [    4.364199] audit: type=1334 audit(1709054765.980:5): prog-id=9 op=LOAD
      [    4.382648] CAN device driver interface
      [    4.395190] m_can_platform 20701000.can: m_can device registered (irq=541, version=32)
      [    4.408182] audit: type=1334 audit(1709054766.024:6): prog-id=10 op=LOAD
      [    4.414146] tas2505-codec 2-0018: tas2505_i2c_probe: clock-source = BCLK
      [    4.519945] audit: type=1334 audit(1709054766.136:7): prog-id=11 op=LOAD
      [    4.527466] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
      [    4.527595] audit: type=1334 audit(1709054766.144:8): prog-id=12 op=LOAD
      [    4.528350] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
      [    4.528942] k3-dsp-rproc 7e000000.dsp: local reset is deasserted for device
      [    4.529358] audit: type=1334 audit(1709054766.148:9): prog-id=13 op=LOAD
      [    4.530055] platform 79000000.r5f: configured R5F for remoteproc mode
      [    4.530422] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
      [    4.533092] remoteproc remoteproc0: 7e000000.dsp is available
      [    4.548348] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
      [    4.548371] vdec 30210000.video-codec: Product Code:      0x521c
      [    4.548378] vdec 30210000.video-codec: Firmware Revision: 320127
      [    4.557920] remoteproc remoteproc1: 79000000.r5f is available
      [    4.569888] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
      [    4.571604] platform 78000000.r5f: configured R5F for IPC-only mode
      [    4.571760] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
      [    4.573823] remoteproc remoteproc1: powering up 79000000.r5f
      [    4.573852] remoteproc remoteproc1: Booting fw image am62a-mcu-r5f0_0-fw, size 53172
      [    4.586593] remoteproc remoteproc2: 78000000.r5f is available
      [    4.586706] remoteproc remoteproc2: attaching to 78000000.r5f
      [    4.587422] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node r5f-dma-memory@9b800000
      [    4.595500] virtio_rpmsg_bus virtio0: rpmsg host is online
      [    4.596381] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
      [    4.598053] rproc-virtio rproc-virtio.8.auto: registered virtio0 (type 7)
      [    4.598077] remoteproc remoteproc1: remote processor 79000000.r5f is now up
      [    4.600137] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
      [    4.602122] platform 78000000.r5f: R5F core initialized in IPC-only mode
      [    4.602158] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node r5f-dma-memory@9c800000
      [    4.602721] virtio_rpmsg_bus virtio1: rpmsg host is online
      [    4.602761] rproc-virtio rproc-virtio.9.auto: registered virtio1 (type 7)
      [    4.602770] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
      [    4.603414] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
      [    4.609195] remoteproc remoteproc0: powering up 7e000000.dsp
      [    4.609225] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11604048
      [    4.669727] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000
      [    4.678247] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node c7x-dma-memory@99800000
      [    4.683266] virtio_rpmsg_bus virtio2: rpmsg host is online
      [    4.683320] rproc-virtio rproc-virtio.10.auto: registered virtio2 (type 7)
      [    4.683330] remoteproc remoteproc0: remote processor 7e000000.dsp is now up
      [    4.689986] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
      [    4.690103] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
      [    4.692755] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
      [    4.692894] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
      [    4.698390] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
      [    4.698577] virtio_rpmsg_bus virtio1: msg received with no recipient
      [    4.698729] virtio_rpmsg_bus virtio2: msg received with no recipient
      [    4.764755] e5010 fd20000.jpeg-encoder: Device registered as /dev/video2
      [    4.769485] tas2505-codec 2-0018: tas2505_codec_probe:tas2505_codec_probe
      [    4.936530] m_can_platform 20701000.can main_mcan0: renamed from can0
      [    5.033325] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY
      [    5.192711] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    5.215955] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    5.216756] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
      [    5.216961] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    5.216985] cfg80211: failed to load regulatory.db
      [    5.272608] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [Generic PHY] (irq=POLL)
      [    5.272636] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
      [    5.495328] audit: type=1334 audit(1769478194.459:10): prog-id=14 op=LOAD
      [    5.496258] audit: type=1334 audit(1769478194.459:11): prog-id=15 op=LOAD
      [    5.496957] audit: type=1334 audit(1769478194.463:12): prog-id=16 op=LOAD
      [    6.070060] systemd-journald[124]: Time jumped backwards, rotating.
      [    6.102802] can: controller area network core
      [    6.102886] NET: Registered PF_CAN protocol family
      [    6.110061] can: raw protocol
      [    6.361564] tas2505-codec 2-0018: tas2505_hw_params: bit width = 16
      [    6.361595] tas2505-codec 2-0018: tas2505_setup_pll: tas2505_setup_pll
      [    6.361601] tas2505-codec 2-0018: [0] mclksrc.rate (48000) vs rate (44100)
      [    6.361608] tas2505-codec 2-0018: [1] mclksrc.rate (44100) vs rate (44100)
      [    6.379575] davinci-mcasp 2b10000.audio-controller: Sample-rate is off by 400 PPM
      [    6.381169] tas2505-codec 2-0018: tas2505_set_bias_level:power on
      [    6.599249] max 96714 get format
      [    6.599862] max96712 stream on
      [    6.599871] max96714 2-002a: stream on!!!!
      [    7.301200] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
      [   39.300671] systemd-journald[124]: Time jumped backwards, rotating.
      [   45.422064] audit: type=1006 audit(1769478292.203:13): pid=2629 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
      [   45.422113] audit: type=1300 audit(1769478292.203:13): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffd0198de8 a2=1 a3=1 items=0 ppid=1 pid=2629 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
      [   45.422128] audit: type=1327 audit(1769478292.203:13): proctitle="(systemd)"
      [   45.482443] audit: type=1334 audit(1769478292.263:14): prog-id=17 op=LOAD
      [   45.482493] audit: type=1300 audit(1769478292.263:14): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe21e5e88 a2=90 a3=0 items=0 ppid=1 pid=2629 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
      [   45.482506] audit: type=1327 audit(1769478292.263:14): proctitle="(systemd)"
      [   45.482519] audit: type=1334 audit(1769478292.263:15): prog-id=17 op=UNLOAD
      [   45.482550] audit: type=1300 audit(1769478292.263:15): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff91494c60 items=0 ppid=1 pid=2629 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
      [   45.482563] audit: type=1327 audit(1769478292.263:15): proctitle="(systemd)"
      [   45.482842] audit: type=1334 audit(1769478292.263:16): prog-id=18 op=LOAD
      root@am62axx-evm:~#
    2. When we use the SBL mode, a similar issue also occurs. Please refer to the issue link below. Additionally, the DM-R5 core also has a certain probability (about 2%) of failure to communicate with the Linux kernel.
      AM62A7: mcu1_0 c7x_1 start too slow - Processors forum - Processors - TI E2E support forums
  • hi,Nick,
    any update?
    gaogao
    The thread owner is out of office till until week of Feb 17. Please ping the thread if you do not get an update during that week.
    Thank you for your patience.
    Harshith
  • hi,Nick,
    any update?
    gaogao
  • Hello Gaogao,
    Apologies for the continued delays. I have set aside some time to look into your threads on Thursday. I will provide more information then.
    Nick
  • Dear Nick.
    may I ask your help to provide the update?
    thanks a lot!
    yong
  • Hi, Nick,
    More Info,
    I attempted to directly display the camera image using commands on the EVM platform.
    gst-launch-1.0 videotestsrc is-live=true num-buffers=1 ! \
    video/x-raw,width=640,height=480,format=NV12,framerate=60/1 ! \
    queue ! \
    tiovxmultiscaler name=multi \
    multi.src_0 ! video/x-raw, width=1280,height=720,format=NV12 ! queue ! \
    filesink location=/tmp/out0.nv12 sync=true
    here are the output logs of the commands.
    APP: Init ... !!!
        18.683240 s: MEM: Init ... !!!
        18.683281 s: MEM: Initialized DMA HEAP (fd=5) !!!
        18.683410 s: MEM: Init ... Done !!!
        18.683423 s: IPC: Init ... !!!
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio0.rpmsg_chrdev.-1.13
        18.698946 s: IPC: ERROR: Unable to create TX channels for CPU [c7x_1] !!!
        18.698962 s: IPC: Init ... Done !!!
    APP: ERROR: IPC init failed !!!
    REMOTE_SERVICE: Init ... !!!
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio1.rpmsg_chrdev.-1.21
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio0.rpmsg_chrdev.-1.21
    REMOTE_SERVICE: Init ... Done !!!
        18.700952 s: GTC Frequency = 200 MHz
    APP: Init ... Done !!!
        18.701085 s:  VX_ZONE_INIT:Enabled
        18.701097 s:  VX_ZONE_ERROR:Enabled
        18.701106 s:  VX_ZONE_WARNING:Enabled
        18.701922 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
        18.702156 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
        18.702289 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
        18.702416 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
        18.702439 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
        18.702522 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
    WARNING: erroneous pipeline: could not link multi to queue1, multi can't handle caps video/x-raw, width=(int)1280, height=(int)720, format=(string)NV12
    the key mistake is IPC: ERROR: Unable to create TX channels for CPU [c7x_1] !!!
    here are the summary of the test results:
    On the EVM platform, when booting from eMMC, the same issue occurs, with a probability of approximately 1 in 30.
    On the EVM platform, when booting from SD card, no problem occurs.
    gaogao
  • any information?
  • SDK 10.00.00.08
    The verification steps on the EVM are as follows:
    1. Burn the program onto the eMMC using the SD card.
    2. Change the startup mode to eMMC.
    3. Power on
    4. Run commands on the serial port
    queue ! \
    5. Check if there is " IPC: ERROR: Unable to create TX channels for CPU [c7x_1] !!! " in the output.
    6. Power off
    7. Repeat steps 3 to 6
  • when using vx_app_arm_remote_log.out to check the startup logs of the DM MCU and DSP C7x, Here's the comparison between normal and abnormal scenarios. When it fails, the MCU gets stuck waiting for client sync, and the DSP hangs during IPC initialization.
  • [MCU1_0]      0.033965 s: CIO: Init ... Done !!!
    [MCU1_0]      0.034004 s: APP: Init ... !!!
    [MCU1_0]      0.034038 s: MEM: Init ... !!!
    [MCU1_0]      0.034056 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ af000000 of size 16777216 bytes !!!
    [MCU1_0]      0.034095 s: MEM: Init ... Done !!!
    [MCU1_0]      0.034123 s: IPC: Init ... !!!
    [MCU1_0]      0.034139 s: IPC: 3 CPUs participating in IPC !!!
    [MCU1_0]      0.034432 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU1_0]      0.038784 s: #Sciserver Version: v2023.11.0.0REL.MCUSDK.MM.NN.PP.bb
    [MCU1_0]      0.041557 s: ##RM_PM_HAL Version: vMM.NN.PP
    [MCU1_0]      0.044504 s: ##Starting Sciserver..... PASSED
    [MCU1_0]      9.000653 s: IPC: HLOS is ready !!!
    [MCU1_0]      9.000744 s: IPC: Init ... Done !!!
    [MCU1_0]      9.000767 s: APP: Syncing with 2 CPUs ... !!!
    [MCU1_0]      9.116933 s: APP: Syncing with 2 CPUs ... Done !!!
    [MCU1_0]      9.116971 s: REMOTE_SERVICE: Init ... !!!
    [MCU1_0]      9.117053 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU1_0]      9.117080 s: FVID2: Init ... !!!
    [MCU1_0]      9.117106 s: FVID2: Init ... Done !!!
    [MCU1_0]      9.117125 s: VHWA: VPAC Init ... !!!
    [MCU1_0]      9.117140 s: SCICLIENT: Sciclient_pmSetModuleState module=219 state=2
    [MCU1_0]      9.117226 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU1_0]      9.117351 s: VHWA: LDC Init ... !!!
    [MCU1_0]      9.117448 s: VHWA: LDC Init ... Done !!!
    [MCU1_0]      9.117480 s: VHWA: MSC Init ... !!!
    [MCU1_0]      9.118067 s: VHWA: MSC Init ... Done !!!
    [MCU1_0]      9.118124 s: VHWA: VISS Init ... !!!
    [MCU1_0]      9.118816 s: VHWA: VISS Init ... Done !!!
    [MCU1_0]      9.118888 s: VHWA: VPAC Init ... Done !!!
    [MCU1_0]      9.118918 s:  VX_ZONE_INIT:Enabled
    [MCU1_0]      9.118977 s:  VX_ZONE_ERROR:Enabled
    [MCU1_0]      9.118994 s:  VX_ZONE_WARNING:Enabled
    [MCU1_0]      9.120048 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU1-0
    [MCU1_0]      9.120140 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_LDC1
    [MCU1_0]      9.120212 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC1
    [MCU1_0]      9.120291 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC2
    [MCU1_0]      9.120361 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_VISS1
    [MCU1_0]      9.120393 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU1_0]      9.120415 s: APP: OpenVX Target kernel init ... !!!
    [MCU1_0]      9.124955 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU1_0]      9.124985 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU1_0]      9.125032 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU1_0]      9.125052 s: APP: Init ... Done !!!
    [MCU1_0]      9.125069 s: APP: Run ... !!!
    [MCU1_0]      9.125083 s: IPC: Starting echo test ...
    [MCU1_0]      9.125200 s: APP: Run ... Done !!!
    [MCU1_0]      9.125895 s: IPC: Echo status: a530-0[.] r5f0-0[s] c75ss0[P]
    [C7x_1 ]      9.059449 s: CIO: Init ... Done !!!
    [C7x_1 ]      9.059469 s: APP: Init ... !!!
    [C7x_1 ]      9.059482 s: SCICLIENT: Init ... !!!
    [C7x_1 ]      9.059547 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_1 ]      9.059569 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_1 ]      9.059584 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_1 ]      9.059601 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]      9.059617 s: UDMA: Init ... !!!
    [C7x_1 ]      9.059629 s: UDMA: Init ... Done !!!
    [C7x_1 ]      9.059642 s: MEM: Init ... !!!
    [C7x_1 ]      9.059656 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ b2000000 of size 117440512 bytes !!!
    [C7x_1 ]      9.059687 s: MEM: Init ... Done !!!
    [C7x_1 ]      9.059699 s: IPC: Init ... !!!
    [C7x_1 ]      9.059713 s: IPC: 3 CPUs participating in IPC !!!
    [C7x_1 ]      9.059984 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]      9.116821 s: IPC: HLOS is ready !!!
    [C7x_1 ]      9.116899 s: IPC: Init ... Done !!!
    [C7x_1 ]      9.116915 s: APP: Syncing with 2 CPUs ... !!!
    [C7x_1 ]      9.116933 s: APP: Syncing with 2 CPUs ... Done !!!
    [C7x_1 ]      9.116948 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ]      9.117834 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ]      9.117873 s:  VX_ZONE_INIT:Enabled
    [C7x_1 ]      9.117892 s:  VX_ZONE_ERROR:Enabled
    [C7x_1 ]      9.117912 s:  VX_ZONE_WARNING:Enabled
    [C7x_1 ]      9.118781 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1
    [C7x_1 ]      9.118885 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_2
    [C7x_1 ]      9.118988 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_3
    [C7x_1 ]      9.119091 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_4
    [C7x_1 ]      9.119190 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_5
    [C7x_1 ]      9.119291 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_6
    [C7x_1 ]      9.119393 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_7
    [C7x_1 ]      9.119497 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_8
    [C7x_1 ]      9.119526 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_1 ]      9.119553 s:  VX_ZONE_INIT:[tivxInitLocal:137] Flork fix ROI version!!!
    [C7x_1 ]      9.119571 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ]      9.119842 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ]      9.119860 s: APP: Init ... Done !!!
    [C7x_1 ]      9.119873 s: APP: Run ... !!!
    [C7x_1 ]      9.119886 s: IPC: Starting echo test ...
    [C7x_1 ]      9.119988 s: APP: Run ... Done !!!
    [C7x_1 ]      9.125984 s: IPC: Echo status: a530-0[.] r5f0-0[P] c75ss0[s]
    [MCU1_0]    218.258307 s: CIO: Init ... Done !!!
    [MCU1_0]    218.258360 s: APP: Init ... !!!
    [MCU1_0]    218.258378 s: MEM: Init ... !!!
    [MCU1_0]    218.258395 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ af000000 of size 16777216 bytes !!!
    [MCU1_0]    218.258446 s: MEM: Init ... Done !!!
    [MCU1_0]    218.258462 s: IPC: Init ... !!!
    [MCU1_0]    218.258478 s: IPC: 3 CPUs participating in IPC !!!
    [MCU1_0]    218.258773 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU1_0]    218.263118 s: #Sciserver Version: v2023.11.0.0REL.MCUSDK.MM.NN.PP.bb
    [MCU1_0]    218.265891 s: ##RM_PM_HAL Version: vMM.NN.PP
    [MCU1_0]    218.268838 s: ##Starting Sciserver..... PASSED
    [MCU1_0]    227.202028 s: IPC: HLOS is ready !!!
    [MCU1_0]    227.202119 s: IPC: Init ... Done !!!
    [MCU1_0]    227.202148 s: APP: Syncing with 2 CPUs ... !!!
    [C7x_1 ]    227.290528 s: CIO: Init ... Done !!!
    [C7x_1 ]    227.290549 s: APP: Init ... !!!
    [C7x_1 ]    227.290563 s: SCICLIENT: Init ... !!!
    [C7x_1 ]    227.290629 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_1 ]    227.290650 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_1 ]    227.290665 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_1 ]    227.290684 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]    227.290698 s: UDMA: Init ... !!!
    [C7x_1 ]    227.290712 s: UDMA: Init ... Done !!!
    [C7x_1 ]    227.290727 s: MEM: Init ... !!!
    [C7x_1 ]    227.290741 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ b2000000 of size 117440512 bytes !!!
    [C7x_1 ]    227.290771 s: MEM: Init ... Done !!!
    [C7x_1 ]    227.290795 s: IPC: Init ... !!!
    [C7x_1 ]    227.290808 s: IPC: 3 CPUs participating in IPC !!!
  • Dear canjian.
    Please help check DSP C7x and DM R5F state w/ JTAG tool. you can load right symbol file then attach to these two cores.
    thanks a lot!
    yong
  • When the DSP C7x fails to boot, CCS reports an error when trying to connect. After a forced connection, the DSP is shown to be stuck while registering the IPC interrupt.
    The no-strip version of the MCU cannot run because it exceeds the eMMC partition size allocated for TISPL. With the strip version, adding debug prints shows it’s stuck waiting in appLogCpuSyncWithSlave. The register dumps for the DSP and MCU are in the attachment.  boot_dsp_failed-dsp_register.txt
    521177 13
    R PC 0x0000000B 0x9D006CB0
    R SP 0x0000000B 0x9CFABD48
    R LR 0x0000000B 0x9CFFC3D8
    R CPSR 0x0000000B 0xA008001F
    R R0 0x0000000B 0x00000002
    R R1 0x0000000B 0x9CFABD4C
    R R2 0x0000000B 0xA1000000
    R R3 0x0000000B 0x00000002
    R R4 0x0000000B 0x00000002
    R R5 0x0000000B 0x9CFABD4C
    R R6 0x0000000B 0x9CF96EF8
    R R7 0x0000000B 0x00000002
    R R8 0x0000000B 0x00000001
    R R9 0x0000000B 0x09090909
    R R10 0x0000000B 0x10101010
    R R11 0x0000000B 0x11111111
    R R12 0x0000000B 0x00000000
    R R13 0x0000000B 0x9CFABD48
    R R14 0x0000000B 0x9CFFC3D8
    R USER_Registers_R8_USER 0x0000000B 0x00000001
    R USER_Registers_R9_USER 0x0000000B 0x09090909
    R USER_Registers_R10_USER 0x0000000B 0x10101010
    R USER_Registers_R11_USER 0x0000000B 0x11111111
    R USER_Registers_R12_USER 0x0000000B 0x00000000
    R USER_Registers_R13_USER 0x0000000B 0x9CFABD48
    R USER_Registers_R14_USER 0x0000000B 0x9CFFC3D8
    R FIQ_Registers_SPSR_FIQ 0x0000000B 0xA008001F
    R FIQ_Registers_R8_FIQ 0x0000000B 0x00000001
    R FIQ_Registers_R9_FIQ 0x0000000B 0x09090909
    R FIQ_Registers_R10_FIQ 0x0000000B 0x10101010
    R FIQ_Registers_R11_FIQ 0x0000000B 0x11111111
    R FIQ_Registers_R12_FIQ 0x0000000B 0x00000000
    R FIQ_Registers_R13_FIQ 0x0000000B 0x9CFABD48
    R FIQ_Registers_R14_FIQ 0x0000000B 0x9CFFC3D8
    R Supervisor_Registers_SPSR_SVC 0x0000000B 0x6000003F
    R Supervisor_Registers_R13_SVC 0x0000000B 0x9E6F6E00
    R Supervisor_Registers_R14_SVC 0x0000000B 0x9CFE4D3A
    R Abort_Registers_SPSR_ABT 0x0000000B 0x8E0923CF
    R Abort_Registers_R13_ABT 0x0000000B 0x9E6F8000
    R Abort_Registers_R14_ABT 0x0000000B 0xDBA8BBBE
    R IRQ_Registers_SPSR_IRQ 0x0000000B 0xA008001F
    R IRQ_Registers_R13_IRQ 0x0000000B 0x9E6F7E00
    R IRQ_Registers_R14_IRQ 0x0000000B 0x9CFFC3D8
    R Undefined_Registers_SPSR_UND 0x0000000B 0x7201CB75
    R Undefined_Registers_R13_UND 0x0000000B 0x9E6F6D00
    R Undefined_Registers_R14_UND 0x0000000B 0xC9C71D9F
    R All_Banked_Registers_SPSR_FIQ 0x0000000B 0xA008001F
    R All_Banked_Registers_R8_FIQ 0x0000000B 0x00000001
    R All_Banked_Registers_R9_FIQ 0x0000000B 0x09090909
    R All_Banked_Registers_R10_FIQ 0x0000000B 0x10101010
    R All_Banked_Registers_R11_FIQ 0x0000000B 0x11111111
    R All_Banked_Registers_R12_FIQ 0x0000000B 0x00000000
    R All_Banked_Registers_R13_FIQ 0x0000000B 0x9CFABD48
    R All_Banked_Registers_R14_FIQ 0x0000000B 0x9CFFC3D8
    R All_Banked_Registers_SPSR_SVC 0x0000000B 0x6000003F
    R All_Banked_Registers_R13_SVC 0x0000000B 0x9E6F6E00
    R All_Banked_Registers_R14_SVC 0x0000000B 0x9CFE4D3A
    R All_Banked_Registers_SPSR_ABT 0x0000000B 0x8E0923CF
    R All_Banked_Registers_R13_ABT 0x0000000B 0x9E6F8000
    R All_Banked_Registers_R14_ABT 0x0000000B 0xDBA8BBBE
    R All_Banked_Registers_SPSR_IRQ 0x0000000B 0xA008001F
    R All_Banked_Registers_R13_IRQ 0x0000000B 0x9E6F7E00
    R All_Banked_Registers_R14_IRQ 0x0000000B 0x9CFFC3D8
    R All_Banked_Registers_SPSR_UND 0x0000000B 0x7201CB75
    R All_Banked_Registers_R13_UND 0x0000000B 0x9E6F6D00
    R All_Banked_Registers_R14_UND 0x0000000B 0xC9C71D9F
    R Debug_Registers_REG_DIDR 0x0000000B 0x77040013
    R Debug_Registers_BPWP_VERSION 0x0000000B 0x00040013
    R Debug_Registers_BPWP_NUM_BP_AVAILABLE 0x0000000B 0x00000008
    R Debug_Registers_BPWP_NUM_BP_WITH_CONTEXT 0x0000000B 0x00000001
    R Debug_Registers_BPWP_FIRST_CONTEXT_BP 0x0000000B 0x00000007
    R Debug_Registers_BPWP_NUM_WP_AVAILABLE 0x0000000B 0x00000008
    R Debug_Registers_BPWP_BP_ADDR0 0x0000000B 0xE6BAB5C4
    R Debug_Registers_BPWP_BP_ADDR1 0x0000000B 0x3B6BCFDC
    R Debug_Registers_BPWP_BP_ADDR2 0x0000000B 0xADAB86D0
    R Debug_Registers_BPWP_BP_ADDR3 0x0000000B 0x773F08FC
    R Debug_Registers_BPWP_BP_ADDR4 0x0000000B 0xEB1CF164
    R Debug_Registers_BPWP_BP_ADDR5 0x0000000B 0xDF71DF70
    R Debug_Registers_BPWP_BP_ADDR6 0x0000000B 0x70FCEBB0
    R Debug_Registers_BPWP_BP_ADDR7 0x0000000B 0xBCC77CDA
    R Debug_Registers_BPWP_BP_ADDR8 0x0000000B 0xE6BAB5C4
    R Debug_Registers_BPWP_BP_ADDR9 0x0000000B 0x3B6BCFDC
    R Debug_Registers_BPWP_BP_ADDR10 0x0000000B 0xADAB86D0
    R Debug_Registers_BPWP_BP_ADDR11 0x0000000B 0x773F08FC
    R Debug_Registers_BPWP_BP_ADDR12 0x0000000B 0xEB1CF164
    R Debug_Registers_BPWP_BP_ADDR13 0x0000000B 0xDF71DF70
    R Debug_Registers_BPWP_BP_ADDR14 0x0000000B 0x70FCEBB0
    R Debug_Registers_BPWP_BP_ADDR15 0x0000000B 0xBCC77CDA
    R Debug_Registers_BPWP_BP_CNTL0 0x0000000B 0x1F5801E6
    R Debug_Registers_BPWP_BP_CNTL1 0x0000000B 0x1F3301E2
    R Debug_Registers_BPWP_BP_CNTL2 0x0000000B 0x113601E2
    R Debug_Registers_BPWP_BP_CNTL3 0x0000000B 0x1F480186
    R Debug_Registers_BPWP_BP_CNTL4 0x0000000B 0x156701E0
    R Debug_Registers_BPWP_BP_CNTL5 0x0000000B 0x011D0006
    R Debug_Registers_BPWP_BP_CNTL6 0x0000000B 0x1A5F0182
    R Debug_Registers_BPWP_BP_CNTL7 0x0000000B 0x0D6F01E2
    R Debug_Registers_BPWP_BP_CNTL8 0x0000000B 0x1F5801E6
    R Debug_Registers_BPWP_BP_CNTL9 0x0000000B 0x1F3301E2
    R Debug_Registers_BPWP_BP_CNTL10 0x0000000B 0x113601E2
    R Debug_Registers_BPWP_BP_CNTL11 0x0000000B 0x1F480186
    R Debug_Registers_BPWP_BP_CNTL12 0x0000000B 0x156701E0
    R Debug_Registers_BPWP_BP_CNTL13 0x0000000B 0x011D0006
    R Debug_Registers_BPWP_BP_CNTL14 0x0000000B 0x1A5F0182
    R Debug_Registers_BPWP_BP_CNTL15 0x0000000B 0x0D6F01E2
    R Debug_Registers_BPWP_WP_ADDR0 0x0000000B 0x75BBAE2C
    R Debug_Registers_BPWP_WP_ADDR1 0x0000000B 0xD774DFB4
    R Debug_Registers_BPWP_WP_ADDR2 0x0000000B 0xCDE67778
    R Debug_Registers_BPWP_WP_ADDR3 0x0000000B 0xD342B7EC
    R Debug_Registers_BPWP_WP_ADDR4 0x0000000B 0xC5D969F8
    R Debug_Registers_BPWP_WP_ADDR5 0x0000000B 0x774436EC
    R Debug_Registers_BPWP_WP_ADDR6 0x0000000B 0xF474736C
    R Debug_Registers_BPWP_WP_ADDR7 0x0000000B 0xFF27E7B4
    R Debug_Registers_BPWP_WP_ADDR8 0x0000000B 0x75BBAE2C
    R Debug_Registers_BPWP_WP_ADDR9 0x0000000B 0xD774DFB4
    R Debug_Registers_BPWP_WP_ADDR10 0x0000000B 0xCDE67778
    R Debug_Registers_BPWP_WP_ADDR11 0x0000000B 0xD342B7EC
    R Debug_Registers_BPWP_WP_ADDR12 0x0000000B 0xC5D969F8
    R Debug_Registers_BPWP_WP_ADDR13 0x0000000B 0x774436EC
    R Debug_Registers_BPWP_WP_ADDR14 0x0000000B 0xF474736C
    R Debug_Registers_BPWP_WP_ADDR15 0x0000000B 0xFF27E7B4
    R Debug_Registers_BPWP_WP_CNTL0 0x0000000B 0x111113FE
    R Debug_Registers_BPWP_WP_CNTL1 0x0000000B 0x1D0C014E
    R Debug_Registers_BPWP_WP_CNTL2 0x0000000B 0x060709CE
    R Debug_Registers_BPWP_WP_CNTL3 0x0000000B 0x1E1E0E66
    R Debug_Registers_BPWP_WP_CNTL4 0x0000000B 0x010F1EB6
    R Debug_Registers_BPWP_WP_CNTL5 0x0000000B 0x0C0F0F3C
    R Debug_Registers_BPWP_WP_CNTL6 0x0000000B 0x051617C0
    R Debug_Registers_BPWP_WP_CNTL7 0x0000000B 0x0A130CB2
    R Debug_Registers_BPWP_WP_CNTL8 0x0000000B 0x111113FE
    R Debug_Registers_BPWP_WP_CNTL9 0x0000000B 0x1D0C014E
    R Debug_Registers_BPWP_WP_CNTL10 0x0000000B 0x060709CE
    R Debug_Registers_BPWP_WP_CNTL11 0x0000000B 0x1E1E0E66
    R Debug_Registers_BPWP_WP_CNTL12 0x0000000B 0x010F1EB6
    R Debug_Registers_BPWP_WP_CNTL13 0x0000000B 0x0C0F0F3C
    R Debug_Registers_BPWP_WP_CNTL14 0x0000000B 0x051617C0
    R Debug_Registers_BPWP_WP_CNTL15 0x0000000B 0x0A130CB2
    R System_Registers_CP15_ID_CODE 0x0000000B 0x411FC153
    R System_Registers_CP15_MAIN_ID 0x0000000B 0x411FC153
    R System_Registers_CP15_CACHE_TYPE 0x0000000B 0x8003C003
    R System_Registers_CP15_TCM_TYPE 0x0000000B 0x00010001
    R System_Registers_CP15_MPU_TYPE 0x0000000B 0x00001000
    R System_Registers_CP15_MULTIPROCESSOR_ID 0x0000000B 0xC0000000
    R System_Registers_CP15_PROCESSOR_FEATURE_0 0x0000000B 0x00000131
    R System_Registers_CP15_PROCESSOR_FEATURE_1 0x0000000B 0x00000001
    R System_Registers_CP15_DEBUG_FEATURE_0 0x0000000B 0x00010400
    R System_Registers_CP15_AUXILIARY_FEATURE_0 0x0000000B 0x00000000
    R System_Registers_CP15_MEMORY_MODEL_FEATURE_0 0x0000000B 0x00210030
    R System_Registers_CP15_MEMORY_MODEL_FEATURE_1 0x0000000B 0x00000000
    R System_Registers_CP15_MEMORY_MODEL_FEATURE_2 0x0000000B 0x01200000
    R System_Registers_CP15_MEMORY_MODEL_FEATURE_3 0x0000000B 0x00000211
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_0 0x0000000B 0x02101111
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_1 0x0000000B 0x13112111
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_2 0x0000000B 0x21232141
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_3 0x0000000B 0x01112131
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_4 0x0000000B 0x00010142
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_5 0x0000000B 0x00000000
    R System_Registers_CP15_CURRENT_CACHE_SIZE_ID 0x0000000B 0xF01FE019
    R System_Registers_CP15_CURRENT_CACHE_LEVEL_ID 0x0000000B 0x09200003
    R System_Registers_CP15_CACHE_SIZE_SELECTION 0x0000000B 0x00000001
    R System_Registers_CP15_SYSTEM_CONTROL 0x0000000B 0x01E5187D
    R System_Registers_CP15_AUXILIARY_CONTROL 0x0000000B 0x0E000020
    R System_Registers_CP15_COPROCESSOR_ACCESS 0x0000000B 0xC0F00000
    R System_Registers_CP15_DATA_FAULT_STATUS 0x0000000B 0x00000000
    R System_Registers_CP15_INSTRUCTION_FAULT_STATUS 0x0000000B 0x00000000
    R System_Registers_CP15_AUX_DATA_FAULT_STATUS 0x0000000B 0x00000000
    R System_Registers_CP15_AUX_INSTRUCTION_FAULT_STATUS 0x0000000B 0x00000000
    R System_Registers_CP15_DATA_FAULT_ADDRESS 0x0000000B 0x00000000
    R System_Registers_CP15_INSTRUCTION_FAULT_ADDRESS 0x0000000B 0x00000000
    R System_Registers_CP15_MPU_REGION_BASE_ADDRESS 0x0000000B 0xA2000000
    R System_Registers_CP15_MPU_REGION_SIZE_ENABLE 0x0000000B 0x0000002F
    R System_Registers_CP15_MPU_REGION_ACCESS 0x0000000B 0x00001300
    R System_Registers_CP15_MPU_REGION_NUMBER 0x0000000B 0x00000008
    R System_Registers_CP15_TCM_BTCM_REGION 0x0000000B 0x00000019
    R System_Registers_CP15_TCM_ATCM_REGION 0x0000000B 0x41010019
    R System_Registers_CP15_TCM_TCM_SELECTION 0x0000000B 0x00000000
    R System_Registers_CP15_PERFORMANCE_MONITOR_CONTROL 0x0000000B 0x41151801
    R System_Registers_CP15_COUNT_ENABLE_SET 0x0000000B 0x80000000
    R System_Registers_CP15_COUNT_ENABLE_CLEAR 0x0000000B 0x80000000
    R System_Registers_CP15_OVERFLOW_FLAG_STATUS 0x0000000B 0x80000000
    R System_Registers_CP15_COUNTER_SELECTION 0x0000000B 0x00000000
    R System_Registers_CP15_CYCLE_COUNT 0x0000000B 0xB52CA6A0
    R System_Registers_CP15_EVENT_SELECTION 0x0000000B 0x00000000
    R System_Registers_CP15_PERFORMANCE_MONITOR_COUNT 0x0000000B 0x00000000
    R System_Registers_CP15_USER_ENABLE 0x0000000B 0x00000000
    R System_Registers_CP15_INTERRUPT_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_INTERRUPT_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_SLAVE_PORT_CONTROL 0x0000000B 0x00000000
    R System_Registers_CP15_FCSE_PID 0x0000000B 0x00000000
    R System_Registers_CP15_CONTEXT_ID 0x0000000B 0x00000000
    R System_Registers_CP15_USER_READ_WRITE_THREAD_PROCESS_ID 0x0000000B 0x00000000
    R System_Registers_CP15_USER_READ_ONLY_THREAD_PROCESS_ID 0x0000000B 0x00000000
    R System_Registers_CP15_PRIVILEDGED_ONLY_THREAD_PROCESS_ID 0x0000000B 0x00000000
    R System_Registers_CP15_SECONDARY_AUXILIARY_CONTROL 0x0000000B 0x00400000
    R System_Registers_CP15_NVAL_IRQ_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_FIQ_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_RESET_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_DEBUG_REQUEST_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_IRQ_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_FIQ_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_RESET_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_DEBUG_REQUEST_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_BUILD_OPTIONS_1 0x0000000B 0x41010000
    R System_Registers_CP15_BUILD_OPTIONS_2 0x0000000B 0x0ABFC1C2
    R System_Registers_CP15_CORRECTABLE_FAULT_LOCATION 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_ID 0x0000000B 0x66FCA100
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_SYSCONFIG 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_MESSAGE 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_FIFOSTATUS 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_MSGSTATUS 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_IRQ_EOI 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_IRQ_STATUS_RAW 0x0000000B 0xAAAAAAEA
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_IRQ_STATUS_CLR 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_IRQ_ENABLE_SET 0x0000000B 0x00000001
    R MAILBOX0_MAILBOX_CLUSTER_0_REGS0_REGS0_MAILBOX_IRQ_ENABLE_CLR 0x0000000B 0x00000001
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_ID 0x0000000B 0x66FCA100
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_SYSCONFIG 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_MESSAGE 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_FIFOSTATUS 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_MSGSTATUS 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_IRQ_EOI 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_IRQ_STATUS_RAW 0x0000000B 0xAAAAAABE
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_IRQ_STATUS_CLR 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_IRQ_ENABLE_SET 0x0000000B 0x00000001
    R MAILBOX0_MAILBOX_CLUSTER_1_REGS1_REGS1_MAILBOX_IRQ_ENABLE_CLR 0x0000000B 0x00000001
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_ID 0x0000000B 0x66FCA100
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_SYSCONFIG 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_MESSAGE 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_FIFOSTATUS 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_MSGSTATUS 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_IRQ_EOI 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_IRQ_STATUS_RAW 0x0000000B 0xAAAAAAAA
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_IRQ_STATUS_CLR 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_IRQ_ENABLE_SET 0x0000000B 0x00000001
    R MAILBOX0_MAILBOX_CLUSTER_2_REGS2_REGS2_MAILBOX_IRQ_ENABLE_CLR 0x0000000B 0x00000001
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_ID 0x0000000B 0x66FCA100
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_SYSCONFIG 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_MESSAGE 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_FIFOSTATUS 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_MSGSTATUS 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_IRQ_EOI 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_IRQ_STATUS_RAW 0x0000000B 0xAAAAAAAA
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_IRQ_STATUS_CLR 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_IRQ_ENABLE_SET 0x0000000B 0x00000000
    R MAILBOX0_MAILBOX_CLUSTER_3_REGS3_REGS3_MAILBOX_IRQ_ENABLE_CLR 0x0000000B 0x00000000
  • Hi, all
    We have some progress. When the DSP is registering the IPC interrupt, there are nested disable/enable interrupt operations. We tried to remove this nesting, as shown in the code below. Verification showed that the issue was resolved — after over 500 repeated reboots, the problem did not reappear, whereas previously it would occur roughly every 50 reboots.
    Our questions are:
    1. Is there any issue with this modification of removing the nesting? Is the nesting necessary?
    2. Could this problem be caused by the nesting?
