Part Number: TMS320C6657
Hello I have issue with ECC, but I can't edit IBL.
So can ECC be enabled by modifying only the GEL file, without changing the IBL?
My GEL file is shown below.
#define TRUE 1
#define FALSE 0
#define ibl_MAGIC_VALUE 0xCEC11EBC
#define ibl_HIGHEST_PRIORITY 1
#define ibl_LOWEST_PRIORITY 10
#define ibl_DEVICE_NOBOOT 20
#define ibl_PORT_SWITCH_ALL -2
#define SETIP(array,i0,i1,i2,i3) array[0]=(i0); \
array[1]=(i1); \
array[2]=(i2); \
array[3]=(i3)
#define ibl_BOOT_MODE_TFTP 10
#define ibl_BOOT_MODE_NAND 11
#define ibl_BOOT_MODE_NOR 12
#define ibl_BOOT_MODE_NONE 13
#define ibl_BOOT_FORMAT_AUTO 0
#define ibl_BOOT_FORMAT_NAME 1
#define ibl_BOOT_FORMAT_BIS 2
#define ibl_BOOT_FORMAT_COFF 3
#define ibl_BOOT_FORMAT_ELF 4
#define ibl_BOOT_FORMAT_BBLOB 5
#define ibl_BOOT_FORMAT_BTBL 6
#define ibl_PMEM_IF_GPIO 0
#define ibl_PMEM_IF_CHIPSEL_2 2 /* EMIF interface using chip select 2, no wait enabled */
#define ibl_PMEM_IF_CHIPSEL_3 3 /* EMIF interface using chip select 3, no wait enabled */
#define ibl_PMEM_IF_CHIPSEL_4 4 /* EMIF interface using chip select 4 */
#define ibl_PMEM_IF_CHIPSEL_5 5 /* EMIF interface using chip select 5 */
#define ibl_PMEM_IF_SPI 100 /* Interface through SPI */
#define ibl_MAIN_PLL 0
#define ibl_DDR_PLL 1
#define ibl_NET_PLL 2
#define ibl_EMIF4_ENABLE_sdRamConfig (1 << 0)
#define ibl_EMIF4_ENABLE_sdRamConfig2 (1 << 1)
#define ibl_EMIF4_ENABLE_sdRamRefreshCtl (1 << 2)
#define ibl_EMIF4_ENABLE_sdRamTiming1 (1 << 3)
#define ibl_EMIF4_ENABLE_sdRamTiming2 (1 << 4)
#define ibl_EMIF4_ENABLE_sdRamTiming3 (1 << 5)
#define ibl_EMIF4_ENABLE_lpDdrNvmTiming (1 << 6)
#define ibl_EMIF4_ENABLE_powerManageCtl (1 << 7)
#define ibl_EMIF4_ENABLE_iODFTTestLogic (1 << 8)
#define ibl_EMIF4_ENABLE_performCountCfg (1 << 9)
#define ibl_EMIF4_ENABLE_performCountMstRegSel (1 << 10)
#define ibl_EMIF4_ENABLE_readIdleCtl (1 << 11)
#define ibl_EMIF4_ENABLE_sysVbusmIntEnSet (1 << 12)
#define ibl_EMIF4_ENABLE_sdRamOutImpdedCalCfg (1 << 13)
#define ibl_EMIF4_ENABLE_tempAlterCfg (1 << 14)
#define ibl_EMIF4_ENABLE_ddrPhyCtl1 (1 << 15)
#define ibl_EMIF4_ENABLE_ddrPhyCtl2 (1 << 16)
#define ibl_EMIF4_ENABLE_priClassSvceMap (1 << 17)
#define ibl_EMIF4_ENABLE_mstId2ClsSvce1Map (1 << 18)
#define ibl_EMIF4_ENABLE_mstId2ClsSvce2Map (1 << 11)
#define ibl_EMIF4_ENABLE_eccCtl (1 << 19)
#define ibl_EMIF4_ENABLE_eccRange1 (1 << 20)
#define ibl_EMIF4_ENABLE_eccRange2 (1 << 21)
#define ibl_EMIF4_ENABLE_rdWrtExcThresh (1 << 22)
#define ibl_BOOT_EMIF4_ENABLE_ALL 0x007fffff
#define ibl_EVM_C6455L 0x10 /**< C6455 Low Cost EVM */
#define ibl_EVM_C6457L 0x20 /**< C6457 Low Cost EVM */
#define ibl_EVM_C6472L 0x30 /**< C6472 Low Cost EVM */
#define ibl_EVM_C6474L 0x40 /**< C6474 Low Cost EVM */
#define ibl_EVM_C6474M 0x41 /**< C6474 Mez EVM */
#define ibl_EVM_C6670L 0x50 /**< C6670 Low Cost EVM */
#define ibl_EVM_C6678L 0x60 /**< C6678 Low Cost EVM */
#define ibl_EVM_C6657L 0x70 /**< C6657 Low Cost EVM */
// C6657 EMIF4 Register Addresses
#define EMIF4_ECC_CTL 0x210100F0
#define EMIF4_ECC_RANGE1 0x210100F4
hotmenu Enable_DDR_ECC()
GEL_MapOff(); // Memory Map protection disable
*(int*)EMIF4_ECC_CTL = 0x80000000;
*(int*)EMIF4_ECC_RANGE1 = 0x0000FFFF;
GEL_MapOn(); // Memory Map protection Enable
GEL_TextOut("DDR ECC Enabled via GEL.\n");
menuitem "EVM c6657 IBL";
hotmenu setConfig_c6657_main()
Enable_DDR_ECC();
ibl.iblMagic = ibl_MAGIC_VALUE;
ibl.iblEvmType = ibl_EVM_C6657L;
/* Main PLL: 100 MHz reference, 1GHz output */
ibl.pllConfig[ibl_MAIN_PLL].doEnable = 1;
ibl.pllConfig[ibl_MAIN_PLL].prediv = 1;
ibl.pllConfig[ibl_MAIN_PLL].mult = 20;
ibl.pllConfig[ibl_MAIN_PLL].postdiv = 2;
ibl.pllConfig[ibl_MAIN_PLL].pllOutFreqMhz = 1000;
/* DDR PLL: */
// ibl.pllConfig[ibl_DDR_PLL].doEnable = 1;
// ibl.pllConfig[ibl_DDR_PLL].prediv = 2;
// ibl.pllConfig[ibl_DDR_PLL].mult = 20;
// ibl.pllConfig[ibl_DDR_PLL].postdiv = 2;
// ibl.pllConfig[ibl_DDR_PLL].pllOutFreqMhz = 500;
/* 2015. 2. 5 sero21 */
ibl.pllConfig[ibl_DDR_PLL].mult = 8; //10
/* Net PLL: 100 MHz reference, 1050 MHz output (followed by a built in divide by 3 to give 350 MHz to PA) */
ibl.pllConfig[ibl_NET_PLL].doEnable = 0;
ibl.ddrConfig.configDdr = TRUE;
ibl.ddrConfig.uEmif.emif4p0.registerMask = ibl_EMIF4_ENABLE_sdRamConfig | ibl_EMIF4_ENABLE_sdRamRefreshCtl | ibl_EMIF4_ENABLE_sdRamTiming1 | ibl_EMIF4_ENABLE_sdRamTiming2 | ibl_EMIF4_ENABLE_sdRamTiming3 | ibl_EMIF4_ENABLE_ddrPhyCtl1;
ibl.ddrConfig.uEmif.emif4p0.registerMask |= ibl_EMIF4_ENABLE_eccCtl | ibl_EMIF4_ENABLE_eccRange1; // to ECC by. LSH 260304
//ibl.ddrConfig.uEmif.emif4p0.sdRamConfig = 0x62476AB2;
ibl.ddrConfig.uEmif.emif4p0.sdRamConfig = 0x62477AB2;
ibl.ddrConfig.uEmif.emif4p0.sdRamConfig2 = 0;
// ibl.ddrConfig.uEmif.emif4p0.sdRamRefreshCtl = 0x000030D4;
ibl.ddrConfig.uEmif.emif4p0.sdRamRefreshCtl = 0x0000079E;
ibl.ddrConfig.uEmif.emif4p0.sdRamTiming1 = 0x1333780C;
ibl.ddrConfig.uEmif.emif4p0.sdRamTiming2 = 0x304F7FE3;
ibl.ddrConfig.uEmif.emif4p0.sdRamTiming3 = 0x559F86AF;
// chg by sky : 2014.11.25 (e)
// ibl.ddrConfig.uEmif.emif4p0.sdRamConfig = 0x63C13AB3;
// ibl.ddrConfig.uEmif.emif4p0.sdRamConfig2 = 0;
// ibl.ddrConfig.uEmif.emif4p0.sdRamRefreshCtl = 0x0000079E;
// ibl.ddrConfig.uEmif.emif4p0.sdRamTiming1 = 0x1335782D;
// ibl.ddrConfig.uEmif.emif4p0.sdRamTiming2 = 0x405B7FEB;
// ibl.ddrConfig.uEmif.emif4p0.sdRamTiming3 = 0x057F82B8;
// default
// ibl.ddrConfig.uEmif.emif4p0.sdRamTiming1 = 0x1557B9AC; // default
// ibl.ddrConfig.uEmif.emif4p0.sdRamTiming2 = 0x6E5F7FED; // default
// ibl.ddrConfig.uEmif.emif4p0.sdRamTiming3 = 0x007FE576; // default
ibl.ddrConfig.uEmif.emif4p0.lpDdrNvmTiming = 0;
ibl.ddrConfig.uEmif.emif4p0.powerManageCtl = 0;
ibl.ddrConfig.uEmif.emif4p0.iODFTTestLogic = 0;
ibl.ddrConfig.uEmif.emif4p0.performCountCfg = 0;
ibl.ddrConfig.uEmif.emif4p0.performCountMstRegSel = 0;
ibl.ddrConfig.uEmif.emif4p0.readIdleCtl = 0;
ibl.ddrConfig.uEmif.emif4p0.sysVbusmIntEnSet = 0;
ibl.ddrConfig.uEmif.emif4p0.sdRamOutImpdedCalCfg = 0;
ibl.ddrConfig.uEmif.emif4p0.tempAlterCfg = 0;
ibl.ddrConfig.uEmif.emif4p0.ddrPhyCtl1 = 0x0010010F;
ibl.ddrConfig.uEmif.emif4p0.ddrPhyCtl2 = 0;
ibl.ddrConfig.uEmif.emif4p0.priClassSvceMap = 0;
ibl.ddrConfig.uEmif.emif4p0.mstId2ClsSvce1Map = 0;
ibl.ddrConfig.uEmif.emif4p0.mstId2ClsSvce2Map = 0;
//ibl.ddrConfig.uEmif.emif4p0.eccCtl = 0;
ibl.ddrConfig.uEmif.emif4p0.eccCtl = 0x80000000; // ECC Enable bit confirm
ibl.ddrConfig.uEmif.emif4p0.eccRange1 = 0x800080AB;
ibl.ddrConfig.uEmif.emif4p0.eccRange2 = 0;
ibl.ddrConfig.uEmif.emif4p0.rdWrtExcThresh = 0;
/* SGMII 0 is present */
ibl.sgmiiConfig[0].configure = TRUE;
ibl.sgmiiConfig[0].adviseAbility = 0x1;
ibl.sgmiiConfig[0].control = 0x1;
ibl.sgmiiConfig[0].txConfig = 0x00000e21;
ibl.sgmiiConfig[0].rxConfig = 0x00081021;
ibl.sgmiiConfig[0].auxConfig = 0x0000000b;
/* There is no port 1 on the 6657 */
ibl.sgmiiConfig[1].configure = FALSE;
/* MDIO configuration */
ibl.mdioConfig.nMdioOps = 0;
ibl.mdioConfig.mdioClkDiv = 0xa5;
ibl.mdioConfig.interDelay = 3000; /* ~2ms at 1000 MHz */
ibl.spiConfig.addrWidth = 24;
ibl.spiConfig.nPins = 5;
ibl.spiConfig.mode = 1; /* TODO: Confirm SPI Mode */
ibl.spiConfig.csel = 2;
ibl.spiConfig.c2tdelay = 1;
ibl.spiConfig.busFreqMHz = 20;
ibl.emifConfig[0].csSpace = 2;
ibl.emifConfig[0].busWidth = 8;
ibl.emifConfig[0].waitEnable = 0;
ibl.emifConfig[1].csSpace = 0;
ibl.emifConfig[1].busWidth = 0;
ibl.emifConfig[1].waitEnable = 0;
ibl.bootModes[0].bootMode = ibl_BOOT_MODE_NOR;
ibl.bootModes[0].priority = ibl_HIGHEST_PRIORITY;
ibl.bootModes[0].port = 0;
ibl.bootModes[0].u.norBoot.bootFormat = ibl_BOOT_FORMAT_ELF;
ibl.bootModes[0].u.norBoot.bootAddress[0][0] = 0; /* Image 0 NOR offset byte address in LE mode */
ibl.bootModes[0].u.norBoot.bootAddress[0][1] = 0xA00000; /* Image 1 NOR offset byte address in LE mode */
ibl.bootModes[0].u.norBoot.bootAddress[1][0] = 0; /* Image 0 NOR offset byte address in BE mode */
ibl.bootModes[0].u.norBoot.bootAddress[1][1] = 0xA00000; /* Image 1 NOR offset byte address in BE mode */
ibl.bootModes[0].u.norBoot.interface = ibl_PMEM_IF_SPI;
ibl.bootModes[0].u.norBoot.blob[0][0].startAddress = 0x80000000; /* Image 0 load start address in LE mode */
ibl.bootModes[0].u.norBoot.blob[0][0].sizeBytes = 0xA00000; /* Image 0 size (10 MB) in LE mode */
ibl.bootModes[0].u.norBoot.blob[0][0].branchAddress = 0x80000000; /* Image 0 branch address after loading in LE mode */
ibl.bootModes[0].u.norBoot.blob[0][1].startAddress = 0x80000000; /* Image 1 load start address in LE mode */
ibl.bootModes[0].u.norBoot.blob[0][1].sizeBytes = 0xA00000; /* Image 1 size (10 MB) in LE mode */
ibl.bootModes[0].u.norBoot.blob[0][1].branchAddress = 0x80000000; /* Image 1 branch address after loading in LE mode */
ibl.bootModes[0].u.norBoot.blob[1][0].startAddress = 0x80000000; /* Image 0 load start address in BE mode */
ibl.bootModes[0].u.norBoot.blob[1][0].sizeBytes = 0xA00000; /* Image 0 size (10 MB) in BE mode */
ibl.bootModes[0].u.norBoot.blob[1][0].branchAddress = 0x80000000; /* Image 0 branch address after loading in BE mode */
ibl.bootModes[0].u.norBoot.blob[1][1].startAddress = 0x80000000; /* Image 1 load start address in BE mode */
ibl.bootModes[0].u.norBoot.blob[1][1].sizeBytes = 0xA00000; /* Image 1 size (10 MB) in BE mode */
ibl.bootModes[0].u.norBoot.blob[1][1].branchAddress = 0x80000000; /* Image 1 branch address after loading in BE mode */
ibl.bootModes[1].bootMode = ibl_BOOT_MODE_NAND;
ibl.bootModes[1].priority = ibl_HIGHEST_PRIORITY;
ibl.bootModes[1].port = 0;
ibl.bootModes[1].u.nandBoot.bootFormat = ibl_BOOT_FORMAT_BBLOB; //ibl_BOOT_FORMAT_BBLOB; ibl_BOOT_FORMAT_ELF;
ibl.bootModes[1].u.nandBoot.bootAddress[0][0] = 0x20000; /* Image 0 NAND offset address (block 1) in LE mode */
ibl.bootModes[1].u.nandBoot.bootAddress[0][1] = 0x200000; /* Image 1 NAND offset address (block 512) in LE mode */
ibl.bootModes[1].u.nandBoot.bootAddress[1][0] = 0x20000; /* Image 0 NAND offset address (block 1) in BE mode */
ibl.bootModes[1].u.nandBoot.bootAddress[1][1] = 0x4000000; /* Image 1 NAND offset address (block 512) in BE mode */
ibl.bootModes[1].u.nandBoot.interface = ibl_PMEM_IF_CHIPSEL_2;
ibl.bootModes[1].u.nandBoot.blob[0][0].startAddress = 0x9E000000; /* Image 0 load start address in LE mode */
ibl.bootModes[1].u.nandBoot.blob[0][0].sizeBytes = 0x400000; /*0xFFC000;*/ /* Image 0 size in LE mode */
ibl.bootModes[1].u.nandBoot.blob[0][0].branchAddress = 0x9E001040; /* Image 0 branch address after loading in LE mode */
ibl.bootModes[1].u.nandBoot.blob[0][1].startAddress = 0x80000000; /* Image 1 load start address in LE mode */
ibl.bootModes[1].u.nandBoot.blob[0][1].sizeBytes = 0xFFC000; /* Image 1 size in LE mode */
ibl.bootModes[1].u.nandBoot.blob[0][1].branchAddress = 0x80000000; /* Image 1 branch address after loading in LE mode */
ibl.bootModes[1].u.nandBoot.blob[1][0].startAddress = 0x80000000; /* Image 0 load start address in BE mode */
ibl.bootModes[1].u.nandBoot.blob[1][0].sizeBytes = 0xFFC000; /* Image 0 size in BE mode */
ibl.bootModes[1].u.nandBoot.blob[1][0].branchAddress = 0x80000000; /* Image 0 branch address after loading in BE mode */
ibl.bootModes[1].u.nandBoot.blob[1][1].startAddress = 0x80000000; /* Image 1 load start address in BE mode */
ibl.bootModes[1].u.nandBoot.blob[1][1].sizeBytes = 0xFFC000; /* Image 1 size in BE mode */
ibl.bootModes[1].u.nandBoot.blob[1][1].branchAddress = 0x80000000; /* Image 1 branch address after loading in BE mode */
ibl.bootModes[1].u.nandBoot.nandInfo.busWidthBits = 8;
ibl.bootModes[1].u.nandBoot.nandInfo.pageSizeBytes = 2048;
ibl.bootModes[1].u.nandBoot.nandInfo.pageEccBytes = 64;
ibl.bootModes[1].u.nandBoot.nandInfo.pagesPerBlock = 64;
ibl.bootModes[1].u.nandBoot.nandInfo.totalBlocks = 4096; // evm - 1024 4g - 4096 8G-4096
//ibl.bootModes[1].u.nandBoot.nandInfo.addressBytes = 4;
ibl.bootModes[1].u.nandBoot.nandInfo.addressBytes = 5; // suspicious
ibl.bootModes[1].u.nandBoot.nandInfo.lsbFirst = TRUE;
ibl.bootModes[1].u.nandBoot.nandInfo.blockOffset = 18; // evm - 22 4g - 18 8g - 18
ibl.bootModes[1].u.nandBoot.nandInfo.pageOffset = 12; // evm - 16 4g - 12 8g - 12
ibl.bootModes[1].u.nandBoot.nandInfo.columnOffset = 0;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[0] = 0;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[1] = 1;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[2] = 2;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[3] = 3;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[4] = 4;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[5] = 6;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[6] = 7;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[7] = 13;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[8] = 14;
ibl.bootModes[1].u.nandBoot.nandInfo.eccBytesIdx[9] = 15;
ibl.bootModes[1].u.nandBoot.nandInfo.badBlkMarkIdx[0]= 0;
ibl.bootModes[1].u.nandBoot.nandInfo.badBlkMarkIdx[1]= 0xff;
ibl.bootModes[1].u.nandBoot.nandInfo.resetCommand = 0xff;
ibl.bootModes[1].u.nandBoot.nandInfo.readCommandPre = 0x00;
ibl.bootModes[1].u.nandBoot.nandInfo.readCommandPost = 0x30;
ibl.bootModes[1].u.nandBoot.nandInfo.postCommand = TRUE;
ibl.bootModes[2].bootMode = ibl_BOOT_MODE_TFTP;
ibl.bootModes[2].priority = ibl_HIGHEST_PRIORITY+1;
ibl.bootModes[2].port = ibl_PORT_SWITCH_ALL;
ibl.bootModes[2].u.ethBoot.doBootp = TRUE;
ibl.bootModes[2].u.ethBoot.useBootpServerIp = TRUE;
ibl.bootModes[2].u.ethBoot.useBootpFileName = TRUE;
ibl.bootModes[2].u.ethBoot.bootFormat = ibl_BOOT_FORMAT_BBLOB;
SETIP(ibl.bootModes[2].u.ethBoot.ethInfo.ipAddr, 192,168,1,3);
SETIP(ibl.bootModes[2].u.ethBoot.ethInfo.serverIp, 192,168,1,2);
SETIP(ibl.bootModes[2].u.ethBoot.ethInfo.gatewayIp, 192,168,1,1);
SETIP(ibl.bootModes[2].u.ethBoot.ethInfo.netmask, 255,255,255,0);
/* Use the e-fuse value */
ibl.bootModes[2].u.ethBoot.ethInfo.hwAddress[0] = 0;
ibl.bootModes[2].u.ethBoot.ethInfo.hwAddress[1] = 0;
ibl.bootModes[2].u.ethBoot.ethInfo.hwAddress[2] = 0;
ibl.bootModes[2].u.ethBoot.ethInfo.hwAddress[3] = 0;
ibl.bootModes[2].u.ethBoot.ethInfo.hwAddress[4] = 0;
ibl.bootModes[2].u.ethBoot.ethInfo.hwAddress[5] = 0;
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[0] = 'c';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[1] = '6';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[2] = '6';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[3] = '5';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[4] = '7';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[5] = '-';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[6] = 'l';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[7] = 'e';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[8] = '.';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[9] = 'b';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[10] = 'i';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[11] = 'n';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[12] = '\0';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[13] = '\0';
ibl.bootModes[2].u.ethBoot.ethInfo.fileName[14] = '\0';
ibl.bootModes[2].u.ethBoot.blob.startAddress = 0x80000000; /* Load start address */
ibl.bootModes[2].u.ethBoot.blob.sizeBytes = 0x20000000;
ibl.bootModes[2].u.ethBoot.blob.branchAddress = 0x80000000; /* Branch address after loading */
ibl.chkSum = 0;
I have already modified the GEL file once for ECC.
But it seems not working...
Lee
