AM62P: Getting the MCAN external read write example running on MCU R5F using FreeRTOS
Part Number: AM62P
Hello Ti experts,
Currently I've successfully executed the mcan_loopback_polling example on MCU R5F core using FreeRTOS.
Now I want to demonstrate the actual working CAN  example by connecting an external transceiver on MCU_MCAN0 on Rx and Tx pins. As the provided sample code under mcan_external_read_write directory is not working when I did the below connections
So, can you provide guidance on what steps should I follow to make the external read write example work?
Aditya T
