Part Number: TDA3LA
Hi Team,
I am currently working on implementing a Driver Monitoring System (DMS) application on the TDA3x platform, and I need some guidance regarding the initial setup and development flow.
I would appreciate your support on the following points:
Compiler Setup
What are the required compilers for the TDA4x platform (ARM, DSP, and other cores)?
Could you please share the official documentation or user guide for setting up the development environment?
Booting Sequence
I would like to understand the complete boot flow of the TDA3x SoC.
Kindly provide references or documentation explaining:
Boot modes (SD, eMMC, OSPI, etc.)
Bootloader (SBL/U-Boot) flow
Steps to boot the EVM board
Flashing Procedure
What is the recommended method to flash images onto the TDA4x EVM?
Are there any official tools or guides available for this process?
SDK Selection (RTOS vs Linux)
For a real-time DMS application, which SDK would you recommend:
Processor SDK RTOS
Processor SDK Linux
It would be helpful if you could share documentation comparing both approaches for vision-based applications.
Reference Documentation
Please share links to:
Processor SDK (RTOS/Linux)
Vision Apps / Edge AI documentation
Relevant user guides or application notes
Your guidance will help me proceed in the right direction for development.
Thanks in advance for your support.
Chaithra B V
