VPIF DMA configuration
I am working on a video driver that is based on an existing video driver, Due to HW design I need to change the DAM parameters.
I found that the VPIF port is set in vpif_capture.c but couldn't find where the DMA is configured.
In which file and how can I change the DMA configuration?
  • Hi Erez,
    Which hardware are you working on dm6467/da850 ?
    general the configuration for EDMA is done in board files , you can find it in <linux_kernel_dir>/arch/arm/mach-davinci/board-  file.
    Thx,
    --Prabhakar Lad
  • Thanks for your reply/
    I am using the da850.
    I looked in the board files and couldn't find how the VPIF DMA is configured.
    Can you point me to the file or function that configures the DMA?
    Is there a document that describes the power up and configuration procedure?
