Other Parts Discussed in Thread: TVP7002
I am using EZSDK 5.02.02.60 on board DM8168.
I am using C6RUN(00.98.00.00) with OpenMax(05.02.00.15) .
My program will down after worked 1min~4 hours, with the error like below.
Assertion at Line no: 1737 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_00_02_80-r4i/syslink_2_00_02_80/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/MessageQ.c: (MessageQ_module->heaps [heapId] != NULL) : failed
Assertion at Line no: 2880 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_00_02_80-r4i/syslink_2_00_02_80/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/family/hlos/knl/ti81xx/Platform.c: (entry.isValid == TRUE) : failed
Assertion at Line no: 301 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_00_02_80-r4i/syslink_2_00_02_80/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/Linux/IpcDrv.c: (status >= 0) : failed
Unable to handle kernel paging request at virtual address db792004
pgd = d1aa8000
[db792004] *pgd=92b73011, *pte=00000000, *ppte=00000000
Internal error: Oops: 7 [#1]
last sysfs file: /sys/devices/platform/musb-ti81xx.0/musb-hdrc.0/usb1/1-1/devnum
Modules linked in: cmemk bufferclass_ti omaplfb pvrsrvkm ti81xxhdmi ti81xxfb vpss syslink ipv6
CPU: 0 Not tainted (2.6.37 #1)
PC is at DM8168DSP_halResetCtrl+0x8c/0x128 [syslink]
LR is at DM8168DSP_halResetCtrl+0x38/0x128 [syslink]
pc : [<bf065a3c>] lr : [<bf0659e8>] psr: 80000013
sp : d199f210 ip : 00000000 fp : d199f22c
r10: 00000000 r9 : d199e000 r8 : bf142c6c
r7 : 400a27b0 r6 : 00000000 r5 : db792000 r4 : 00000000
r3 : db792000 r2 : db792000 r1 : 00050000 r0 : bf0e0482
Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 91aa8019 DAC: 00000015
Process PSeriesEBMain (pid: 1106, stack limit = 0xd199e2e8)
Stack: (0xd199f210 to 0xd19a0000)
f200: 00000000 00000000 bf142c6c d7fc3000
f220: d199f24c d199f230 bf0668fc bf0659bc bf142c6c 00000009 d7fc0000 d7fd8000
f240: d199f26c d199f250 bf04bc04 bf066858 6e657265 00646563 d72a9000 d7fd8000
f260: d199f294 d199f270 bf04f204 bf04bb9c 00746174 d1a0a000 00000009 00000000
f280: d1a0a000 00000009 d199fef4 d199f298 bf051da4 bf04f110 c008e0a6 400a27b0
f2a0: 7a737000 614e5342 7300656d 61657241 6d657449 52565000 5f565253 4f525245
f2c0: 61680052 656c646e 69750072 52493233 69740051 735f656d 6563696c 5f616900
f2e0: 6d697463 75720065 6e696e6e 5f640067 5f627472 64726168 696d696c 69750074
f300: 54503233 6c615645 4d006469 4c55444f 54535f45 5f455441 494d4f43 7400474e
f320: 5f636576 65736162 73617400 69735f6b 7300657a 7269645f 626f0074 7463656a
f340: 696b0073 6e61635f 006c6563 74655262 5f737100 6f757175 63006174 5f726f74
f360: 745f6e66 7a737000 656d614e 5f475000 6f747075 65746164 52565000 5f565253
f380: 544d454d 5f455059 4e4b4e55 004e574f 53525650 455f5652 524f5252 414e555f
f3a0: 5f454c42 415f4f54 485f4444 4c444e41 69730045 745f657a 74757000 6572705f
f3c0: 61745f76 62006b73 646e6550 46676e69 00656572 6665726b 52565000 5f565253
f3e0: 4f525245 41465f52 44454c49 5f4f545f 59504f43 4741505f 70005345 5f656761
f400: 65657274 5f6c6600 65707974 474d4900 5552545f 73700045 72616853 79536465
f420: 6e49636e 694c6f66 65007473 726f7078 706f5f74 74617265 736e6f69 474d4900
f440: 4c41465f 73004553 66746174 736d0073 655f7869 6c62616e 69006465 5f74696e
f460: 5f646970 6100736e 49435062 6f736552 65637275 73556e49 6c660065 6572625f
f480: 745f6b61 00656d69 5f474d49 43524f46 4c415f45 004e4749 706f7473 645f7300
f4a0: 70007665 78654e73 004d4b74 74616462 6d6d0061 756f635f 6800746e 74617769
f4c0: 765f7265 6572006d 74003273 626d7568 6c6f7000 4473006c 654d7665 79726f6d
f4e0: 6f666e49 474d4900 5245565f 5f594649 54534554 5f6c6600 6970736e 52570064
f500: 545f5041 5f455059 5f544547 52455355 4741505f 6d005345 655f6973 6c62616e
f520: 65006465 746e6576 6d697400 00745f65 53525650 4d5f5652 4c424d45 7670004b
f540: 61746144 69786500 6c750074 6f796542 6e45646e 64644164 69724f72 696c0067
f560: 50006576 52535256 52455f56 5f524f52 53594850 4444415f 53534552 4358455f
f580: 53444545 4232335f 64005449 62735f71 616d6d00 65735f70 7370006d 756e694c
f5a0: 6d654d78 61657241 73667100 6c626e5f 7500736b 00444969 65726874 665f6461
f5c0: 6975006e 79533233 6548636e 44497061 5f646200 00766564 75736572 6e5f656d
f5e0: 7172696f 63727300 73726576 006e6f69 5256505f 5f565253 4e52454b 4d5f4c45
f600: 495f4d45 5f4f464e 73706100 69766544 6f436563 6e616d6d 74614464 43500061
f620: 54535f49 45525f44 52554f53 00534543 69726570 7100646f 61746f75 006e656c
f640: 6d654d73 006b6c42 5f696370 6e616863 5f6c656e 665f6f69 657a6f72 6c75006e
f660: 65747942 505f0073 52535256 55515f56 5f455545 4f464e49 7063005f 6f635f75
f680: 755f7970 5f726573 68676968 65676170 52565000 5f565253 4f525245 454d5f52
f6a0: 59524f4d 5345545f 41465f54 44454c49 4d427000 746e6f43 00747865 76657270
f6c0: 736f705f 52565000 5f565253 4f525245 4e555f52 454c4241 5f4f545f 5f544547
f6e0: 54535953 435f4d45 4b434f4c 49767000 61445253 50006174 52535256 52455f56
f700: 5f524f52 42414e55 545f454c 45445f4f 4f525453 56455f59 00544e45 665f6173
f720: 7367616c 50534f00 48636f72 72507361 72537669 696e4976 56500074 56525352
f740: 5252455f 535f524f 454e4543 564e495f 44494c41 57655f00 4d706172 79546d65
f760: 005f6570 5f757063 61656c63 73755f72 685f7265 70686769 00656761 72657375
f780: 6d616e5f 61707365 70006563 484d4273 00706165 5f697261 62616e65 0064656c
f7a0: 63616e69 65766974 7461725f 50006f69 52535256 52455f56 5f524f52 444e4148
f7c0: 545f454c 5f455059 4d53494d 48435441 75716400 6f5f746f 61726570 6e6f6974
f7e0: 5f730073 74627573 00657079 735f7066 65746174 5f564b00 5346464f 535f5445
f800: 43555254 41545f54 616c0047 735f7473 6e696769 50006f66 52535256 52455f56
f820: 5f524f52 49564544 505f4543 5245574f 4148435f 5f45474e 4c494146 00455255
f840: 76697270 5f657461 61746164 6e667000 c04aa450 d2810040 90851ceb 000004aa
f860: d2810038 00000001 d199f89c d199f878 c00644e4 c018e974 d23d8044 d23d9080
f880: c04aa408 00000001 d23d90b0 00000000 d199f8c4 d199f8a0 c0064628 c006444c
f8a0: c04aa408 d23d9080 00000001 00000000 c04aa970 00000001 44042500 d7fd8000
f8c0: d3694b00 00000000 c04aa970 00000001 d199f8fc d199f8e0 c0062a54 c0063fbc
f8e0: 00000001 d23d9080 c04aa408 00000000 d199f924 d199f900 c006578c c0062a30
f900: c004ff54 80000193 d185bf5c c04aa964 00000000 00000001 d199f934 d199f928
f920: c00657d8 d23d8038 d199f95c d199f938 c018ea70 c018e87c c04aa450 d23d803c
f940: a692dd6b 000004aa d23d8038 00000001 d199f984 d199f960 c00644e4 c018e974
f960: d23d8044 d23d9080 c04aa408 00000001 d23d90b0 00000000 d3694b00 d23d90b0
f980: d3694b30 c04aa408 d3694b00 d23d90b0 d199f9c4 d199f9a0 c006403c c0061fa0
f9a0: c04aa408 c036d380 d3694b00 00000000 c04aa970 00000001 d199f9e4 d199f9c8
f9c0: c0062a54 c0063fbc 00000001 d23d9080 c04aa408 00000000 d199fa0c d23d9378
f9e0: d199fa14 d199f9f0 c018ea70 c018e87c c04aa450 d23d9380 a692dd6b 000004aa
fa00: d23d9378 25cbcdfc d199fa3c d199fa18 c00644e4 c018e974 d23d9384 d3694840
fa20: c04aa408 00000001 d3694870 25cc40dc d199fa64 d199fa40 c006574c c0061f7c
fa40: d199fa6c a0000193 c04abdc4 bf1d9a6c c04abdc4 c04abdc4 d199fa74 d199fa68
fa60: c006580c c0065734 d199fa84 d199fa78 c0079714 c0065800 d199faa4 d199fa88
fa80: c0079774 c0079700 00000088 c04abdc4 d189dc00 c04abdc4 d199fad4 d199faa8
faa0: c0079a4c c0079724 00000001 00000000 80000113 bf1cae30 d199e000 c04faa8c
fac0: c04fa68c c04fa88c d199faec d199fad8 c0079ab8 c00798b8 c04f9c80 00000100
fae0: d199fafc d199faf0 c0079b00 c0079a90 d199fb0c d199fb00 bf1cae4c c0079af0
fb00: d199fb54 d199fb10 c00725d0 bf1cae3c 25cbcdfc 00004150 25cbcdfc c04fa48c
fb20: d199fb20 d199fb20 c0191014 d199e000 00000100 00000004 d199fb54 d199fb48
fb40: d199e000 00000100 d199fb8c d199fb58 c006cee0 c006cd50 d199fb74 d199fb68
fb60: c005069c 00000043 00000000 00000000 00000000 c04d960b 00000105 00000108
fb80: d199fb9c d199fb90 c006cf4c c006359c d199fbb4 d199fba0 c0038080 c006cf04
fba0: ffffffff fa200000 d199fc74 d199fbb8 c0366bb4 c003800c c04aa998 09b83251
fbc0: 00000001 60000013 c04aa954 c014f497 00000000 00000000 c04d960b 00000105
fbe0: 00000108 d199fc74 d199fbd8 d199fc00 c006861c c0068c48 20000013 ffffffff
fc00: d199fc1c 00000001 60000013 0000010b c0191014 c018f888 d199fed0 d199fd95
fc20: 00000002 bf10ed8b ffffffff bf10ed97 d199fed0 d199fda2 d199fc8c d199fda2
fc40: d199fed0 c0191da0 ffffffff d199fca4 c014f497 ffffffff 00000006 400a279c
fc60: d199e000 00000000 d199fc8c d199fc78 c0364cec c0068924 d199e000 d199fc94
fc80: d199febc d199fca0 bf07c7d4 c0364cd8 d199fca4 bf10ed97 2e660358 00000000
fca0: d199fcbc 413e313c 72657373 6e6f6974 20746120 656e694c 3a6f6e20 31303320
fcc0: 206e6920 6377732f 732f656f 632f6b64 656e2f6d 2f617274 67617261 6d742d6f
fce0: 6f772f70 642f6b72 3631386d 76652d78 6f6e2d6d 6c2d656e 78756e69 756e672d
fd00: 69626165 2d69742f 6c737973 2d6b6e69 30305f32 5f32305f 722d3038 732f6934
fd20: 696c7379 325f6b6e 5f30305f 385f3230 61702f30 67616b63 742f7365 79732f69
fd40: 6e696c73 74752f6b 2f736c69 736f6c68 6c6e6b2f 6e694c2f 2e2f7875 2e2e2f2e
fd60: 2f2e2e2f 2e2f2e2e 2e2e2f2e 2f69742f 6c737973 2f6b6e69 2f637069 736f6c68
fd80: 6c6e6b2f 6e694c2f 492f7875 72446370 3a632e76 74732820 73757461 203d3e20
fda0: 3a202930 69616620 0a64656c 00000000 d199fde4 d199fdc0 bf073dc4 bf07272c
fdc0: dc277000 00000008 bf07d4f8 000003e8 00000000 ffffffff d199fea4 d199fde8
fde0: bf062314 bf072678 ffffffff bf0de751 d199fe24 d199fe00 bf074200 bf07272c
fe00: bf0742a0 bf072678 c0038080 d72c4000 00000000 db35a000 d199fe3c d199fe28
fe20: bf09e2cc bf07418c db354000 00000000 d199fe5c d199fe40 bf093248 bf07272c
fe40: 00000000 dc007500 dc007500 dc007500 d199fe94 d199fe60 00000000 00000000
fe60: 00000000 00000001 00000080 00000001 00000000 c01cf35a 400a2774 00000011
fe80: babe0002 00000000 00000000 bf142c6c 400a279c ffffffff d199fecc d199fea8
fea0: bf095ea8 d199fec4 ffffffff 400a279c d199fef4 d199fed0 bf0cf1f0 bf07c794
fec0: d199fef4 d199fed0 bf0cf3cc bf072678 c014f497 00000000 d1a0a000 00000009
fee0: 00000009 400a27b0 d199ff04 d199fef8 c00cbe68 bf050d30 d199ff74 d199ff08
ff00: c00cc578 c00cbe4c d199ff34 d199ff18 00000000 00000000 fffffffd 00000000
ff20: d199ff54 d199ff30 c0368c8c c003e170 d357a01c d3694b00 00000017 d3487b80
ff40: d199e000 00000000 d199ff6c 00000000 400a27b0 c008e0a6 00000009 d1a0a000
ff60: d199e000 00000000 d199ffa4 d199ff78 c00cc610 c00cc084 d199ffac 00000001
ff80: c0365404 400a27b0 00000000 00000000 00000036 c0042f48 00000000 d199ffa8
ffa0: c0042da0 c00cc5c4 400a27b0 00000000 00000009 c008e0a6 400a27b0 00000001
ffc0: 400a27b0 00000000 00000000 00000036 40201e88 401fd8e0 40201ed8 400a27e4
ffe0: c008e0a6 400a2780 400d5464 40937aec 60000010 00000009 6c635f72 5f6b636f
Backtrace:
[<bf0659b0>] (DM8168DSP_halResetCtrl+0x0/0x128 [syslink]) from [<bf0668fc>] (DM8168DSPPROC_stop+0xb0/0x140 [syslink])
r5:d7fc3000 r4:bf142c6c
[<bf06684c>] (DM8168DSPPROC_stop+0x0/0x140 [syslink]) from [<bf04bc04>] (Processor_stop+0x74/0xf8 [syslink])
r5:d7fd8000 r4:d7fc0000
[<bf04bb90>] (Processor_stop+0x0/0xf8 [syslink]) from [<bf04f204>] (ProcMgr_stop+0x100/0x1c0 [syslink])
r5:d7fd8000 r4:d72a9000
[<bf04f104>] (ProcMgr_stop+0x0/0x1c0 [syslink]) from [<bf051da4>] (ProcMgrDrv_ioctl+0x1080/0x1dd8 [syslink])
r6:00000009 r5:d1a0a000 r4:00000000
[<bf050d24>] (ProcMgrDrv_ioctl+0x0/0x1dd8 [syslink]) from [<c00cbe68>] (vfs_ioctl+0x28/0x44)
r8:400a27b0 r7:00000009 r6:00000009 r5:d1a0a000 r4:00000000
[<c00cbe40>] (vfs_ioctl+0x0/0x44) from [<c00cc578>] (do_vfs_ioctl+0x500/0x540)
[<c00cc078>] (do_vfs_ioctl+0x0/0x540) from [<c00cc610>] (sys_ioctl+0x58/0x7c)
[<c00cc5b8>] (sys_ioctl+0x0/0x7c) from [<c0042da0>] (ret_fast_syscall+0x0/0x30)
r8:c0042f48 r7:00000036 r6:00000000 r5:00000000 r4:400a27b0
Code: e3540002 059f408c 1a000009 ea000012 (e5952004)
---[ end trace a8c410fcc6fdea88 ]---
omap_i2c omap_i2c.1: rpm_resume flags 0x4
omap_i2c omap_i2c.1: omap_pm_runtime_resume
omap_i2c omap_i2c.1: rpm_resume returns 0
omap_i2c omap_i2c.1: rpm_suspend flags 0x0
omap_i2c omap_i2c.1: omap_pm_runtime_suspend
omap_i2c omap_i2c.1: rpm_suspend returns 0
Q1,Is there any advises about this problem?
Q2, what means about the error on omap_i2c1?
Is it the error message about VPSS? BTW, we didn't use any Encode/decode chip such as TVP7002 on our board.
lei
