Hi Biser,
For the GPMC interface, we used set 46 to connect NAND flash and set 16 (only use 8 bits data bus with 20 bits address bus) to connect our CPLD.
In the GPMC IO set 16, we didn't use pin H19,H18,H17,G18,G19,G17 as GPMC_A2x_MUX1 but as MMC0 port. Is that OK?
Pls see our pin mux configuration file as attached. 0181.PinMuxDesignState_AM3352_Zorilla.dat
By the way, MMC0 port can support booting from 8G Byte Micro SD, right?
Thanks a lot!
Cosmo
