Rather similar to this old post, the ONVIF code in our IPNC SDK crashes with memory corruption errors whenever we get the network configuration with Onvif Device manager.
I have applied the gSoap fix suggested in that link, but with no result.
The console output / log is here, you can see the ONVIF request come in, get processed & returned, but something goes a bit wrong in the process. As you can see, I've added various debug prints to try and track what's happening:
[onvif] received from IP
[s:Envelope]:192.168.2.108
[onvif] --> (POST /onvif/services HTTP/1.1 Content-Type: application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver10/device/wsdl/GetNetworkDefaultGateway" Host: 192.168.2.168 Content-Length: 265 Accept-Encoding: gzip, deflate <s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><GetNetworkDefaultGateway xmlns="http://www.onvif.org/ver10/device/wsdl"/></s:Body></s:Envelope>)
[Bob] soap_malloc - Setting canary for 0x4ed480 of 112 bytes at 0x4ed4ee
[Bob] soap_malloc - Setting canary for 0x4ed518 of 68 bytes at 0x4ed55a
[SOAP] soap_element_begin_in tag SOAP-ENV:Envelope
[SOAP] soap_peek_element - tag-> s:Envelope Begin element found (level=1) 's:Envelope'='SOAP-ENV:Envelope', type='(null)'
[SOAP] soap_element_begin_in tag SOAP-ENV:Header
[SOAP] soap_element_begin_in tag SOAP-ENV:Body
[SOAP] soap_peek_element Soap is peeked! Begin element found (level=2) 's:Body'='SOAP-ENV:Body', type='(null)'
[SOAP] soap_peek_element - tag-> s:Body
[Bob] - ONVIF: soap_serve_request - Got GetNetworkDefaultGateway, lookupindex = 4
[Bob] - ONVIF: soap_serve_request - Looking up SERVICE_DEVICE soap_id_enter Loc=0xbec64b4c looks wrong, resetting to NULL
[SOAP] soap_element_begin_in tag tds:GetNetworkDefaultGateway
[SOAP] soap_peek_element Soap is peeked! Begin element found (level=2) 'GetNetworkDefaultGateway'='tds:GetNetworkDefaultGateway', type='(null)'
[SOAP] soap_peek_element Soap is peeked! Begin element found (level=2) 'GetNetworkDefaultGateway'='tds:GetNetworkDefaultGateway', type=''
[Bob] onvif_src/onvif.c __tds__GetNetworkDefaultGateway(2968) - _GatewayAddress = 192.168.2.254
[Bob] soap_malloc - Setting canary for 0x4edb98 of 8 bytes at 0x4edb9e
[Bob] soap_malloc - Setting canary for 0x4edbe0 of 8 bytes at 0x4edbe6
[Bob] soap_malloc - Setting canary for 0x4edc10 of 104 bytes at 0x4edc76
[Bob] - onvif_src/onvifC.c:soap_serializeheader() - 28
[Bob] - onvif_src/onvifC.c:soap_serializeheader() - 31
[Bob] - onvif_src/stdsoap2.c:soap_reference() - 6998
[Bob] - onvif_src/stdsoap2.c:soap_pointer_lookup() - 6676 Lookup location=0x4edb98 type=5358
[Bob] - onvif_src/stdsoap2.c:soap_pointer_lookup() - 6676 Lookup location=0x4edc10 type=4 Element begin tag='SOAP-ENV:Envelope' @0x467db0 Element begin tag='SOAP-ENV:Body' @0x467db0
[Bob] - onvif_src/stdsoap2.c:soap_embed() - 6649
[Bob] - onvif_src/stdsoap2.c:soap_pointer_lookup() - 6676 Lookup location=0xbec64b48 type=5242
[Bob] Lookup location=0xbec64b48 is out of bounds
[Bob] - onvif_src/stdsoap2.c:soap_embedded_id() - 7057 Element begin tag='tds:GetNetworkDefaultGatewayResponse' @0x467db0
[Bob] - onvif_src/stdsoap2.c:soap_element_id() - 9727
[Bob] - onvif_src/stdsoap2.c:soap_embedded_id() - 7057 Element begin tag='tds:NetworkGateway' @0x467db0
[Bob] - onvif_src/stdsoap2.c:soap_element_id() - 9727 Element begin tag='tt:IPv4Address' @0x467db0 Element begin tag='SOAP-ENV:Envelope' @0x467db0 Element begin tag='SOAP-ENV:Body' @0x467db0
[onvif] fsend 2884 @ 0x467db0 - bufsize = 10240
[onvif] fsend 2884 @ 0x467db0 - Content START>>> HTTP/1.1 200 OK Server: gSOAP/2.8 Content-Type: application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver10/device/wsdl/GetNetworkDefaultGateway" Content-Length: 2680 Connection: close <?xml version="1.0" encoding="UTF-8"?> <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://tempuri.org/xmime.xsd" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:ns2="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:ns3="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:ns1="http://www.onvif.org/ver10/network/wsdl" xmlns:ns4="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns5="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:ns6="http://docs.oasis-open.org/wsn/b-2" xmlns:ns7="http://docs.oasis-open.org/wsn/t-1" xmlns:ns9="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tet="http://www.onvif.org/ver10/events/wsdl" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:tad="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tls="http://www.onvif.org/ver10/display/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:dis="http://docs.oasis-open.org/ws-dd/ns/discovery/2009/01"><SOAP-ENV:Body><tds:GetNetworkDefaultGatewayResponse><tds:NetworkGateway><tt:IPv4Address>192.168.2.254</tt:IPv4Address></tds:NetworkGateway></tds:GetNetworkDefaultGatewayResponse></SOAP-ENV:Body></SOAP-ENV:Envelope> <<< END
[SOAP_MEM_DEBUG] soap_dealloc 7509 Data corruption in dynamic allocation (see logs) -->
[SOAP] tag = s:Envelope, q=0x4edba0, f=0x4edc78
[Bob] boa soap_dealloc 7528
[SOAP] tag = s:Envelope, q=0x4edba0, f=0x4edba0
[Bob] buffer.c 257 - Buffer start (nil) == buffer end (nil)
I also have a question about the code in stdsoap2.c - it seems to use the register keyword a lot (as well as static) but I can't see a good reason to do so for a lot of the cases. Does anyone know if this is done with good reason or is it some artefact of the auto-generated code than can be removed?
