Hello.
My EVM is TMDSEVM6657LS
I tested been the boot option for ROM SPI Boot (No EEPROM, No IBL, Just direct to ROM SPI Boot).
But, now I have problem.
Below step is my test procedure.
Please check, and where do I fix it.
1. I use the executable file for my test
- mcsdk_2_01_01_04\tools\boot_loader\examples\i2c\nor\evmc6657l\bin\i2cnorboot_evm6657l.out
- This example software just print out to UART:
"NOR Boot Over I2C Example Version 01.00.00.00"
"Booting Hello World image from NOR flash via IBL over I2C 0x51 ..."
2. I make the batch file
- spiboot.bat
hex6x spiboot.rmd
bconvert64x -le spiboot.btbl spiboot.le.btbl
b2i2c spiboot.le.btbl spiboot.le.btbl.i2c b2ccs
spiboot.le.btbl.i2c spiboot.le.btbl.i2c.ccs
romparse spiRom.map.pp
ccs2bin i2crom.ccs spirom_le.bin
ccs2bin -swap i2crom.ccs spirom_le.swap.bin
rm i2crom.ccs spiboot.btbl spiboot.le.btbl spiboot.le.btbl.i2c spiboot.le.btbl.i2c.ccs
3. spiboot.rmd: I copy the C:\ti\mcsdk_2_01_01_04\tools\boot_loader\ibl\src\make\ibl_c665x\ibl.rmd and modified.
- spiboot.rmd
spiboot.out
-a
-boot
-e _c_int00
-order L
ROMS
ROM1: org = 0x0400, length = 0x20000, memwidth = 32, romwidth = 32
files = { spiboot.btbl }
4. spiRom.map.pp: I copy the C:\ti\mcsdk_2_01_01_04\tools\boot_loader\ibl\src\make\ibl_c665x\spiRom.map.pp and modified.
- spiRom.map.pp
section
param_index = 0
boot_mode = 50
sw_pll_prediv = 0
sw_pll_mult = 0
sw_pll_postdiv = 0
sw_pll_flags = 0
options = 1
core_freq_mhz = 800
bus_freq_mhz = 1
bus_freq_khz = 0
addr_width = 24
n_pins = 5
mode = 1
csel = 2
exe_file = "spiboot.le.btbl.i2c.ccs"
layout
dev_addr = 0x400
dev_addr_ext = 0
file_align = 0x80
pad_file_id = 1
exe_file = ""
pad_file_id = 1
pad
pad_file_id = 1
dev_addr = 0x500
dev_addr_ext = 0
len = 0x300
5. I excuted the spiboot.bat and have not error message.
6. In CCS, I load the NOR Writer at CCS Debug, and load the image "spirom_le.swap.bin" to memory index 0x80000000
7. I run the NOR Writer and successfuly loaded the image "spirom_le.swap.bin" to EVM
8. I change the DIP Switch for booting from ROM SPI and re-boot.
ROM SPI Boot: DIP SW3 (off, on, off, off, on, on, on, on) SW5 (on, on, off, on, on, on, on, on)
9. Terminal do not show message.
Above procedure, Where do I change?
Please help me.
