Other Parts Discussed in Thread: TMS320C6713B
Hi.
I am using c6713B+MX98728, CCS2.1, NDK1.4, winXP
I want to use in win7 64bit-CCSv4.
What is NDK to use?
Hi.
What is NDK to use?
I am currently in TMS320C6713B-CCS2.1-winXP used.
And, PC to communicate with the network mx98728 are used.
In order to use mx98728 uses NDK Library.
I HOST PC specs win7 64bit, CCSv4 to try to change.
Which version should I use NDK?
Now in the open, NDK v1.9 does not support the TMS320C6713B, v1.91 is
does not support the mx98728.
So, NDK v1.8 should you use?
Where Can I download the NDK v1.8?
NDK v1.8 is win7 64bit, CCSv4 in use?
And thank you, I need a quick answer.
Hi Kim,
Thanks for your post.
To download the latest versions of NDK v2.0 & after, please check the below link:
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/ndk/index.html
For versions of NDK prior to v2.0, you should look at the legacy embedded software product NDK & version downloads for NDK v1.8 which needs TI approval to use this software:
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/legacy.html
For NDK FAQ, please see the below wiki links:
http://processors.wiki.ti.com/index.php/Network_Developers_Kit_FAQ
http://processors.wiki.ti.com/index.php/BIOS_MCSDK_2.0_User_Guide
FYI, Windows7 is not officially supported on CCS3.3. We recommend Windows 7 users to move to CCSv4
http://processors.wiki.ti.com/index.php/Download_CCS#Code_Composer_Studio_Version_4_Downloads
Please also walkthough the E2E post which i think, it would help you to understand the constraints of c6713 DSK connectivity with Win 7 users:
http://e2e.ti.com/support/dsp/tms320c6000_high_performance_dsps/f/115/t/228227.aspx
http://e2e.ti.com/support/dsp/tms320c6000_high_performance_dsps/f/115/t/150629.aspx
http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/59932.aspx
Please also check with the board vendors to make sure on the driver availability for Win 7.
Thanks & regards,
Sivaraj K
Thank you for your reply !!
But I need more detailed answer.
On Win7, NDK v1.8 is compatible with CCS v4.
If NDK v1.8 is not, How can I do?
I just forgive up using TMS320C6713 & MX98728?
Hi Eok seob,
Thanks for your update.
Check the release notes , read me user guide, NDK doucmentation for the compatibility info.with the older versions of NDK downlaods:
http://software-dl.ti.com/targetcontent/legacy_files/targetcontent/NDK/index.html
Thanks & regards,
Sivaraj K
