StarterWare "enet_echo" example
Other Parts Discussed in Thread: OMAPL138
I use "enet_echo" example to test Ethernet but I don't have PHY into my board. Instead of my emac communicates directly with FPGA.
Can I use this example by doing some modifications? If yes, what are these modifications? It's just to test functionnality of this one.
Is there another example to use without PHY?
My board : cpu4 (custom board based to omapl138_lcdk)
  • Hi Sebastien,
    You can't work ETHERNET without PHY.
    /opt/ti/C6748_StarterWare_1_20_04_01/drivers/phy.c
    /opt/ti/C6748_StarterWare_1_20_04_01/drivers/emac.c
  • Do you have any solutions?
  • Hi Sebastien,
    Sorry, I don't have idea on this.
    I'm not sure MAC-MAC in OMAPL138.
    You can search our TI E2E forums for this question and check.
    http://e2e.ti.com/support/embedded/linux/f/354/t/234215.aspx
    http://e2e.ti.com/support/arm/sitara_arm/f/791/t/264745.aspx
  • In fact communication has to be done by MII interface with FPGA and without PHY controler.
    You say it's impossible to use an EMAC without PHY. And so I've to develop a PHY controler into FPGA.
    Is it that?
  • Hi Sebastien,
    I'm trying to say is that without external PHY, you can't communicate with ethernet but  In your case FPGA is going to act as PHY.
    Some how PHY is important for ethernet interface.
  • Titus,
    Could you please send me the below files you're refering to, maybe they can help putting MAC is such a state that it doesnt require response from the PHY:
    thanks
  • Hi O'Mellin,
    Please refer to the following links.
    http://software-dl.ti.com/dsps/dsps_public_sw/c6000/starterware/01_20_04_01/index_FDS.html
    http://processors.wiki.ti.com/index.php/StarterWare
     *  \file   phy.c
     *  \brief  APIs for configuring ethernet PHYs
     *   This file contains the device abstraction APIs for ethernet PHYs.
    * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/
    *  Redistribution and use in source and binary forms, with or without
    *  modification, are permitted provided that the following conditions
    *  are met:
    *    Redistributions of source code must retain the above copyright
    *    Redistributions in binary form must reproduce the above copyright
    *    documentation and/or other materials provided with the
    *    distribution.
    *    Neither the name of Texas Instruments Incorporated nor the names of
    *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include "hw_types.h"
    #include "mdio.h"
    #include "phy.h"
    #define PHY_ADV_VAL_MASK                 (0x01e0)
    #define PHY_GIG_ADV_VAL_MASK             (0x0300)
    *                        API FUNCTION DEFINITIONS
     * \brief   Reads the PHY ID.
     * \param   mdioBaseAddr  Base Address of the MDIO Module Registers.
     * \param   phyAddr       PHY Adress.
     * \return  32 bit PHY ID (ID1:ID2)
    unsigned int PhyIDGet(unsigned int mdioBaseAddr, unsigned int phyAddr)
        unsigned int id = 0;
        unsigned short data;
        /* read the ID1 register */
        MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_ID1, &data);
        /* update the ID1 value */
        id = data << PHY_ID_SHIFT;
        /* read the ID2 register */
        MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_ID2, &data);
        /* update the ID2 value */
        id |= data;
        /* return the ID in ID1:ID2 format */
        return id;
     * \brief   Reads a register from the the PHY
     * \param   regIdx        Index of the register to be read
     * \param   regValAdr     address where value of the register will be written
     * \return  status of the read
    unsigned int PhyRegRead(unsigned int mdioBaseAddr, unsigned int phyAddr,
                            unsigned int regIdx, unsigned short *regValAdr)
        return (MDIOPhyRegRead(mdioBaseAddr, phyAddr, regIdx, regValAdr));
     * \brief   Writes a register with the input
     * \param   regValAdr     value to be written
     * \return  None
    void PhyRegWrite(unsigned int mdioBaseAddr, unsigned int phyAddr,
                     unsigned int regIdx, unsigned short regVal)
        MDIOPhyRegWrite(mdioBaseAddr, phyAddr, regIdx, regVal);
     * \brief   Enables Loop Back mode
     * \return  status after enabling.  \n
     *          TRUE if loop back is enabled \n
     *          FALSE if not able to enable
    unsigned int PhyLoopBackEnable(unsigned int mdioBaseAddr, unsigned int phyAddr)
        if(MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BCR, &data) != TRUE )
            return FALSE;
        data |= PHY_LPBK_ENABLE;
        /* Enable loop back */
        MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_BCR, data);
        return TRUE;
     * \brief   Disables Loop Back mode
     *          TRUE if loop back is disabled \n
     *          FALSE if not able to disable
    unsigned int PhyLoopBackDisable(unsigned int mdioBaseAddr, unsigned int phyAddr)
            return FALSE;
        data &= ~(PHY_LPBK_ENABLE);
        /* Disable loop back */
        return TRUE;
     * \brief   Resets the PHY
     * \param   speed         Speed to be enabled
     * \param   duplexMode    Duplex Mode
     * \return  status after configuring \n
     *          TRUE if configuration successful
     *          FALSE if configuration failed
    unsigned int PhyReset(unsigned int mdioBaseAddr, unsigned int phyAddr)
        data = PHY_SOFTRESET;
        /* Reset the phy */
        /* wait till the reset bit is auto cleared */
        while(data & PHY_SOFTRESET)
            /* Read the reset */
            if(MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BCR, &data) != TRUE)
                return FALSE;
        return TRUE;
     * \brief   Configures the PHY for a given speed and duplex mode.
    unsigned int PhyConfigure(unsigned int mdioBaseAddr, unsigned int phyAddr,
                              unsigned short speed, unsigned short duplexMode)
        /* Set the configurations */
        MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_BCR, (speed | duplexMode));
        return TRUE;
     * \brief   This function ask the phy device to start auto negotiation.
     * \param   advVal        Autonegotiation advertisement value
     * \param   gigAdvVal     Gigabit capability advertisement value
     *          advVal can take the following any OR combination of the values \n
     *               PHY_100BTX - 100BaseTX \n
     *               PHY_100BTX_FD - Full duplex capabilty for 100BaseTX \n
     *               PHY_10BT - 10BaseT \n
     *               PHY_10BT_FD - Full duplex capability for 10BaseT \n
     *          gigAdvVal can take one of the following values \n
     *               PHY_NO_1000BT - No 1000Base-T capability\n
     *               PHY_1000BT_FD - Full duplex capabilty for 1000 Base-T \n
     *               PHY_1000BT_HD - Half duplex capabilty for 1000 Base-T \n
     *               FALSE - It is passed as an argument if phy dosen't support
     *                       Giga bit capability
     * \return  status after autonegotiation \n
     *          TRUE if autonegotiation started
     *          FALSE if autonegotiation not started
    unsigned int PhyAutoNegotiate(unsigned int mdioBaseAddr, unsigned int phyAddr,
                                  unsigned short *advPtr, unsigned short *gigAdvPtr)
        volatile unsigned short data;
        volatile unsigned short anar;
            return FALSE;
        data |= PHY_AUTONEG_ENABLE;
        if (*gigAdvPtr != 0)
            /* Set phy for gigabit speed */
            data &= PHY_SPEED_MASK;
            data |= PHY_SPEED_1000MBPS;
        /* Enable Auto Negotiation */
            return FALSE;
        /* Write Auto Negotiation capabilities */
        MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_AUTONEG_ADV, &anar);
        anar &= ~PHY_ADV_VAL_MASK;
        MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_AUTONEG_ADV, (anar |(*advPtr)));
        /* Write Auto Negotiation Gigabyte capabilities */
        anar = 0;
        MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_1000BT_CONTROL, &anar);
        anar &= ~PHY_GIG_ADV_VAL_MASK;
        MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_1000BT_CONTROL,
                        (anar |(*gigAdvPtr)));
        data |= PHY_AUTONEG_RESTART;
        /* Start Auto Negotiation */
        return TRUE;
     * \brief   Returns the status of Auto Negotiation completion.
     * \return  Auto negotiation completion status \n
     *          TRUE if auto negotiation is completed
     *          FALSE if auto negotiation is not completed
    unsigned int PhyAutoNegStatusGet(unsigned int mdioBaseAddr, unsigned int phyAddr)
        MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BSR, &data);
        /* Auto negotiation completion status */
        if(PHY_AUTONEG_COMPLETE == (data & (PHY_AUTONEG_STATUS)))
            return TRUE;
        return FALSE;
     * \brief   Reads the Link Partner Ability register of the PHY.
     * \param   ptnerAblty      Pointer to which partner ability will be written.
     * \param   gbpsPtnerAblty  Pointer to which Giga bit capability will be written.
     *          gbpsPtnerAblty can take following Macros.\n
     *          TRUE  - It is passed as argument if phy supports Giga bit capability.\n
     *          FALSE - It is passed as argument if phy dosen't supports Giga bit
     *                  capability.\n
     * \return  status after reading \n
     *          TRUE if reading successful
     *          FALSE if reading failed
    unsigned int PhyPartnerAbilityGet(unsigned int mdioBaseAddr,
                                      unsigned short *ptnerAblty,
                                      unsigned short *gbpsPtnerAblty)
        unsigned int status;
        status = MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_LINK_PARTNER_ABLTY,
                               ptnerAblty);
        if (*gbpsPtnerAblty != 0)
            status = status | MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_1000BT_STATUS,
                                             gbpsPtnerAblty);
        return status;
     * \brief   Reads the link status of the PHY.
     * \param   retries       The number of retries before indicating down status
     * \return  link status after reading \n
     *          TRUE if link is up
     *          FALSE if link is down \n
     * \note    This reads both the basic status register of the PHY and the
     *          link register of MDIO for double check
    unsigned int PhyLinkStatusGet(unsigned int mdioBaseAddr,
                                  volatile unsigned int retries)
        volatile unsigned short linkStatus;
        retries++;
        while (retries)
            /* First read the BSR of the PHY */
            MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BSR, &linkStatus);
            if(linkStatus & PHY_LINK_STATUS)
                return TRUE;
            retries--;
        return FALSE;
    /**************************** End Of File ***********************************/
     *  \file   emac.c
     *  \brief  EMAC APIs.
     *   This file contains the device abstraction layer APIs for EMAC.
    *  are met:
    *    distribution.
    /* HW Macros and Peripheral Defines */
    #include "hw_emac.h"
    #include "hw_emac_ctrl.h"
    /* Driver APIs */
    #include "emac.h"
    *                       INTERNAL MACRO DEFINITIONS
    #define EMAC_CONTROL_RESET             (0x01u)
    #define EMAC_SOFT_RESET                (0x01u)
    #define EMAC_MAX_HEADER_DESC           (8u)
    #define EMAC_UNICAST_DISABLE           (0xFFu)
     * \brief   Enables the TXPULSE Interrupt Generation.
     * \param   emacBase      Base address of the EMAC Module registers.
     * \param   emacCtrlBase  Base address of the EMAC CONTROL module registers
     * \param   ctrlCore      Control core for which the interrupt to be enabled.
     * \param   channel       Channel number for which interrupt to be enabled
     * \return  None
    void EMACTxIntPulseEnable(unsigned int emacBase, unsigned int emacCtrlBase,
                              unsigned int ctrlCore, unsigned int channel)
        HWREG(emacBase + EMAC_TXINTMASKSET) |= (1 << channel);
        HWREG(emacCtrlBase + EMAC_CTRL_CnTXEN(ctrlCore)) |= (1 << channel);
     * \brief   Disables the TXPULSE Interrupt Generation.
     * \param   ctrlCore      Control core for which the interrupt to be disabled.
     * \param   channel       Channel number for which interrupt to be disabled
     * \return  None
    void EMACTxIntPulseDisable(unsigned int emacBase, unsigned int emacCtrlBase,
        HWREG(emacBase + EMAC_TXINTMASKCLEAR) |= (1 << channel);
        HWREG(emacCtrlBase + EMAC_CTRL_CnTXEN(ctrlCore)) &= ~(1 << channel);
     * \brief   Enables the RXPULSE Interrupt Generation.
     * \return  None
    void EMACRxIntPulseEnable(unsigned int emacBase, unsigned int emacCtrlBase,
        HWREG(emacBase + EMAC_RXINTMASKSET) |= (1 << channel);
        HWREG(emacCtrlBase + EMAC_CTRL_CnRXEN(ctrlCore)) |= (1 << channel);
     * \brief   Disables the RXPULSE Interrupt Generation.
     * \return  None
    void EMACRxIntPulseDisable(unsigned int emacBase, unsigned int emacCtrlBase,
        HWREG(emacBase + EMAC_RXINTMASKCLEAR) |= (1 << channel);
        HWREG(emacCtrlBase + EMAC_CTRL_CnRXEN(ctrlCore)) &= ~(1 << channel);
     * \brief   This API sets the RMII speed. The RMII Speed can be 10 Mbps or
     *          100 Mbps
     * \param   speed        speed for setting.
     *          speed can take the following values. \n
     *                EMAC_RMIISPEED_10MBPS - 10 Mbps \n
     *                EMAC_RMIISPEED_100MBPS - 100 Mbps.
     * \return  None
    void EMACRMIISpeedSet(unsigned int emacBase, unsigned int speed)
        HWREG(emacBase + EMAC_MACCONTROL) &= ~EMAC_MACCONTROL_RMIISPEED;
        HWREG(emacBase + EMAC_MACCONTROL) |= speed;
     * \brief   This API enables the MII control block
     * \return  None
    void EMACMIIEnable(unsigned int emacBase)
        HWREG(emacBase + EMAC_MACCONTROL) |= EMAC_MACCONTROL_GMIIEN;
     * \brief   This API sets the duplex mode of operation(full/half) for MAC.
     * \param   duplexMode   duplex mode of operation.
     *          duplexMode can take the following values. \n
     *                EMAC_DUPLEX_FULL - Full Duplex  \n
     *                EMAC_DUPLEX_HALF - Half Duplex.
     * \return  None
    void EMACDuplexSet(unsigned int emacBase, unsigned int duplexMode)
        HWREG(emacBase + EMAC_MACCONTROL) &= ~EMAC_MACCONTROL_FULLDUPLEX;
        HWREG(emacBase + EMAC_MACCONTROL) |= duplexMode;
     * \brief   API to enable the transmit in the TX Control Register
     *          After the transmit is enabled, any write to TXHDP of
     *          a channel will start transmission
     * \param   emacBase      Base Address of the EMAC Module Registers.
     * \return  None
    void EMACTxEnable(unsigned int emacBase)
        HWREG(emacBase + EMAC_TXCONTROL) = EMAC_TXCONTROL_TXEN;
     * \brief   API to enable the receive in the RX Control Register
     *          After the transmit is enabled, and write to RXHDP of
     *          a channel, the data can be received in the destination
     *          specified by the corresponding RX buffer descriptor.
     * \return  None
    void EMACRxEnable(unsigned int emacBase)
        HWREG(emacBase + EMAC_RXCONTROL) = EMAC_RXCONTROL_RXEN;
     * \brief   API to write the TX HDP register. If transmit is enabled,
     *          write to the TX HDP will immediately start transmission.
     *          The data will be taken from the buffer pointer of the TX buffer
     *          descriptor written to the TX HDP
     * \param   emacBase      Base Address of the EMAC Module Registers.\n
     * \param   descHdr       Address of the TX buffer descriptor
     * \param   channel       Channel Number
     * \return  None
    void EMACTxHdrDescPtrWrite(unsigned int emacBase, unsigned int descHdr,
        HWREG(emacBase + EMAC_TXHDP(channel)) = descHdr;
     * \brief   API to write the RX HDP register. If receive is enabled,
     *          write to the RX HDP will enable data reception to point to
     *          the corresponding RX buffer descriptor's buffer pointer.
     * \param   descHdr       Address of the RX buffer descriptor
     * \return  None
    void EMACRxHdrDescPtrWrite(unsigned int emacBase, unsigned int descHdr,
        HWREG(emacBase + EMAC_RXHDP(channel)) = descHdr;
     * \brief   This API Initializes the EMAC and EMAC Control modules. The
     *          EMAC Control module is reset, the CPPI RAM is cleared. also,
     *          all the interrupts are disabled. This API doesnot enable any
     *          interrupt or operation of the EMAC.
     * \param   emacCtrlBase      Base Address of the EMAC Control module
     *                            registers.\n
     * \param   emacBase          Base address of the EMAC module registers
     * \return  None
    void EMACInit(unsigned int emacCtrlBase, unsigned int emacBase)
        unsigned int cnt;
        /* Reset the EMAC Control Module. This clears the CPPI RAM also */
        HWREG(emacCtrlBase + EMAC_CTRL_SOFTRESET) = EMAC_CONTROL_RESET;
        while(HWREG(emacCtrlBase + EMAC_CTRL_SOFTRESET) & EMAC_CONTROL_RESET);
        HWREG(emacBase + EMAC_SOFTRESET) = EMAC_SOFT_RESET;
        while(HWREG(emacBase + EMAC_SOFTRESET) & EMAC_SOFT_RESET);
        HWREG(emacBase + EMAC_MACCONTROL)= 0;
        HWREG(emacBase + EMAC_RXCONTROL)= 0;
        HWREG(emacBase + EMAC_TXCONTROL)= 0;
        /* Initialize all the header descriptor pointer registers */
        for(cnt =  0; cnt< EMAC_MAX_HEADER_DESC; cnt++)
            HWREG(emacBase + EMAC_RXHDP(cnt)) = 0;
            HWREG(emacBase + EMAC_TXHDP(cnt)) = 0;
            HWREG(emacBase + EMAC_RXCP(cnt)) = 0;
            HWREG(emacBase + EMAC_TXCP(cnt)) = 0;
            HWREG(emacBase + EMAC_RXFREEBUFFER(cnt)) = 0xFF;
        /* Clear the interrupt enable for all the channels */
        HWREG(emacBase + EMAC_TXINTMASKCLEAR) = 0xFF;
        HWREG(emacBase + EMAC_RXINTMASKCLEAR) = 0xFF;
        HWREG(emacBase + EMAC_MACHASH1) = 0;
        HWREG(emacBase + EMAC_MACHASH2) = 0;
        HWREG(emacBase + EMAC_RXBUFFEROFFSET) = 0;
     * \brief   Sets the MAC Address in MACSRCADDR registers.
     * \param   emacBase      Base Address of the EMAC module registers.
     * \param   macAddr       Start address of a MAC address array.
     *                        The array[0] shall be the LSB of the MAC address
     * \return  None
    void  EMACMACSrcAddrSet(unsigned int emacBase, unsigned char *macAddr)
        HWREG(emacBase + EMAC_MACSRCADDRHI) = macAddr[5] |(macAddr[4] << 8)
                                         |(macAddr[3] << 16) |(macAddr[2] << 24);
        HWREG(emacBase + EMAC_MACSRCADDRLO) = macAddr[1] | (macAddr[0] << 8);
     * \brief   Sets the MAC Address in MACADDR registers.
     * \param   matchFilt     Match or Filter
     *          matchFilt can take the following values \n
     *          EMAC_MACADDR_NO_MATCH_NO_FILTER - Address is not used to match
     *                                             or filter incoming packet. \n
     *          EMAC_MACADDR_FILTER - Address is used to filter incoming packets \n
     *          EMAC_MACADDR_MATCH - Address is used to match incoming packets \n
     * \return  None
    void EMACMACAddrSet(unsigned int emacBase, unsigned int channel,
                        unsigned char *macAddr, unsigned int matchFilt)
        HWREG(emacBase + EMAC_MACINDEX) = channel;
        HWREG(emacBase + EMAC_MACADDRHI) = macAddr[5] |(macAddr[4] << 8)
        HWREG(emacBase + EMAC_MACADDRLO) = macAddr[1] | (macAddr[0] << 8)
                                         | matchFilt | (channel << 16);
     * \brief   Acknowledges an interrupt processed to the EMAC Control Core.
     * \param   eoiFlag       Type of interrupt to acknowledge to the EMAC Control
     *                         module.
     *          eoiFlag can take the following values \n
     *             EMAC_INT_CORE0_TX - Core 0 TX Interrupt
     *             EMAC_INT_CORE1_TX - Core 1 TX Interrupt
     *             EMAC_INT_CORE2_TX - Core 2 TX Interrupt
     *             EMAC_INT_CORE0_RX - Core 0 RX Interrupt
     *             EMAC_INT_CORE1_RX - Core 1 RX Interrupt
     *             EMAC_INT_CORE2_RX - Core 2 RX Interrupt
     * \return  None
    void EMACCoreIntAck(unsigned int emacBase, unsigned int eoiFlag)
        /* Acknowledge the EMAC Control Core */
        HWREG(emacBase + EMAC_MACEOIVECTOR) = eoiFlag;
     * \brief   Writes the the TX Completion Pointer for a specific channel
     * \param   channel       Channel Number.
     * \param   comPtr        Completion Pointer Value to be written
     * \return  None
    void EMACTxCPWrite(unsigned int emacBase, unsigned int channel, unsigned int comPtr)
        HWREG(emacBase + EMAC_TXCP(channel)) = comPtr;
     * \brief   Writes the the RX Completion Pointer for a specific channel
     * \return  None
    void EMACRxCPWrite(unsigned int emacBase, unsigned int channel, unsigned int comPtr)
        HWREG(emacBase + EMAC_RXCP(channel)) = comPtr;
     * \brief   Acknowledges an interrupt processed to the EMAC module. After
     *          processing an interrupt, the last processed buffer descriptor is
     *          written to the completion pointer. Also this API acknowledges
     *          the EMAC Control Module that the RX interrupt is processed for
     *          a specified core
     * \param   comPtr        Completion Pointer value. This shall be the buffer
     *                        descriptor address last processed.
                              module.
     * \return  None
    void EMACRxIntAckToClear(unsigned int emacBase, unsigned int channel,
                             unsigned int comPtr, unsigned eoiFlag)
     * \brief   Enables a specific channel to receive broadcast frames
     * \return  None
    void EMACRxBroadCastEnable(unsigned int emacBase, unsigned int channel)
        HWREG(emacBase + EMAC_RXMBPENABLE) &= ~EMAC_RXMBPENABLE_RXBROADCH;
        HWREG(emacBase + EMAC_RXMBPENABLE) |=
                                  EMAC_RXMBPENABLE_RXBROADEN |
                                  (channel << EMAC_RXMBPENABLE_RXBROADCH_SHIFT);
     * \brief   Enables unicast for a specific channel
     * \return  None
    void EMACRxUnicastSet(unsigned int emacBase, unsigned int channel)
        HWREG(emacBase + EMAC_RXUNICASTSET) |= (1 << channel);
     * \brief   Set the free buffers for a specific channel
     * \param   nBuf          Number of free buffers
     * \return  None
    void EMACNumFreeBufSet(unsigned int emacBase, unsigned int channel,
                           unsigned int nBuf)
        HWREG(emacBase + EMAC_RXFREEBUFFER(channel)) = nBuf;
     * \brief   Gets the interrupt vectors of EMAC, which are pending
     * \return  Vectors
    unsigned int EMACIntVectorGet(unsigned int emacBase)
        return (HWREG(emacBase + EMAC_MACINVECTOR));
    /***************************** End Of File ***********************************/
